[Mapbender-commits] r2769 - trunk/build
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 11 11:37:31 EDT 2008
Author: christoph
Date: 2008-08-11 11:37:31 -0400 (Mon, 11 Aug 2008)
New Revision: 2769
Added:
   trunk/build/mpbn25_.dia
db structure
Added: trunk/build/mpbn25_.dia
--- trunk/build/mpbn25_.dia	                        (rev 0)
+++ trunk/build/mpbn25_.dia	2008-08-11 15:37:31 UTC (rev 2769)
@@ -0,0 +1,9680 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<dia:diagram xmlns:dia="http://www.lysator.liu.se/~alla/dia/">
+  <dia:diagramdata>
+    <dia:attribute name="background">
+      <dia:color val="#ffffff"/>
+    </dia:attribute>
+    <dia:attribute name="pagebreak">
+      <dia:color val="#000099"/>
+    </dia:attribute>
+    <dia:attribute name="paper">
+      <dia:composite type="paper">
+        <dia:attribute name="name">
+          <dia:string>#A4#</dia:string>
+        </dia:attribute>
+        <dia:attribute name="tmargin">
+          <dia:real val="2.8222000598907471"/>
+        </dia:attribute>
+        <dia:attribute name="bmargin">
+        </dia:attribute>
+        <dia:attribute name="lmargin">
+        </dia:attribute>
+        <dia:attribute name="rmargin">
+        </dia:attribute>
+        <dia:attribute name="is_portrait">
+          <dia:boolean val="true"/>
+        </dia:attribute>
+        <dia:attribute name="scaling">
+          <dia:real val="1"/>
+        </dia:attribute>
+        <dia:attribute name="fitto">
+          <dia:boolean val="false"/>
+        </dia:attribute>
+      </dia:composite>
+    </dia:attribute>
+    <dia:attribute name="grid">
+      <dia:composite type="grid">
+        <dia:attribute name="width_x">
+        </dia:attribute>
+        <dia:attribute name="width_y">
+        </dia:attribute>
+        <dia:attribute name="visible_x">
+          <dia:int val="1"/>
+        </dia:attribute>
+        <dia:attribute name="visible_y">
+        </dia:attribute>
+        <dia:composite type="color"/>
+      </dia:composite>
+    </dia:attribute>
+    <dia:attribute name="color">
+      <dia:color val="#d8e5e5"/>
+    </dia:attribute>
+    <dia:attribute name="guides">
+      <dia:composite type="guides">
+        <dia:attribute name="hguides"/>
+        <dia:attribute name="vguides"/>
+      </dia:composite>
+    </dia:attribute>
+  </dia:diagramdata>
+  <dia:layer name="Background" visible="true">
+    <dia:object type="UML - Class" version="0" id="O0">
+      <dia:attribute name="obj_pos">
+        <dia:point val="-0.55,-24.15"/>
+      </dia:attribute>
+      <dia:attribute name="obj_bb">
+        <dia:rectangle val="-0.6,-24.2;12.25,-19.3"/>
+      </dia:attribute>
+      <dia:attribute name="elem_corner">
+      </dia:attribute>
+      <dia:attribute name="elem_width">
+        <dia:real val="12.75"/>
+      </dia:attribute>
+      <dia:attribute name="elem_height">
+        <dia:real val="4.8000000000000007"/>
+      </dia:attribute>
+        <dia:string>#mb_group#</dia:string>
+      </dia:attribute>
+      <dia:attribute name="stereotype">
+        <dia:string>##</dia:string>
+      </dia:attribute>
+      <dia:attribute name="comment">
+      </dia:attribute>
+      <dia:attribute name="abstract">
+      </dia:attribute>
+      <dia:attribute name="suppress_attributes">
+      </dia:attribute>
+      <dia:attribute name="suppress_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_attributes">
+      </dia:attribute>
+      <dia:attribute name="visible_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_comments">
+      </dia:attribute>
+      <dia:attribute name="wrap_operations">
+      </dia:attribute>
+      <dia:attribute name="wrap_after_char">
+        <dia:int val="40"/>
+      </dia:attribute>
+      <dia:attribute name="comment_line_length">
+      </dia:attribute>
+      <dia:attribute name="comment_tagging">
+      </dia:attribute>
+      <dia:attribute name="line_color">
+        <dia:color val="#000000"/>
+      </dia:attribute>
+      <dia:attribute name="fill_color">
+        <dia:color val="#add8e6"/>
+      </dia:attribute>
+      <dia:attribute name="text_color">
+      </dia:attribute>
+      <dia:attribute name="normal_font">
+        <dia:font family="monospace" style="0" name="Courier"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_font">
+        <dia:font family="monospace" style="88" name="Courier-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font">
+        <dia:font family="monospace" style="8" name="Courier-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="classname_font">
+        <dia:font family="sans" style="80" name="Helvetica-Bold"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font">
+        <dia:font family="sans" style="88" name="Helvetica-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="comment_font">
+        <dia:font family="sans" style="8" name="Helvetica-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="normal_font_height">
+        <dia:real val="0.80000000000000004"/>
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font_height">
+      </dia:attribute>
+      <dia:attribute name="abstract_font_height">
+      </dia:attribute>
+      <dia:attribute name="classname_font_height">
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font_height">
+      </dia:attribute>
+      <dia:attribute name="comment_font_height">
+      </dia:attribute>
+      <dia:attribute name="attributes">
+        <dia:composite type="umlattribute">
+            <dia:string>#mb_group_id#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="type">
+            <dia:string>#integer#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="value">
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="visibility">
+            <dia:enum val="2"/>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="class_scope">
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_group_name#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(50)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:enum val="0"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_group_owner#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_group_description#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(255)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="operations"/>
+      <dia:attribute name="template">
+      </dia:attribute>
+      <dia:attribute name="templates"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O1">
+        <dia:point val="24.05,-56.25"/>
+      </dia:attribute>
+        <dia:rectangle val="24,-56.3;39.3,-39.4"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="15.199999999999999"/>
+      </dia:attribute>
+        <dia:real val="16.800000000000004"/>
+      </dia:attribute>
+        <dia:string>#mb_user#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#mb_user_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_password#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_owner#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_description#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_login_count#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_email#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_phone#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_department#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_resolution#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#72 NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_organisation_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_position_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_phone1#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_facsimile#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_delivery_point#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_city#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_postal_code#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_country#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_online_resource#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O2">
+        <dia:point val="1.05,-41.7"/>
+      </dia:attribute>
+        <dia:rectangle val="1,-41.75;10.7,-38.45"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="9.5999999999999996"/>
+      </dia:attribute>
+        <dia:real val="3.2000000000000002"/>
+      </dia:attribute>
+        <dia:string>#mb_user_mb_group#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#fkey_mb_user_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_mb_group_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O3">
+        <dia:point val="23.9995,-47.85"/>
+      </dia:attribute>
+        <dia:rectangle val="5.1,-48.935;24.0495,-40.95"/>
+      </dia:attribute>
+      <dia:attribute name="orth_points">
+        <dia:point val="5.85,-47.85"/>
+        <dia:point val="5.85,-41.7"/>
+      </dia:attribute>
+      <dia:attribute name="orth_orient">
+        <dia:enum val="1"/>
+      </dia:attribute>
+      <dia:attribute name="autorouting">
+      </dia:attribute>
+      </dia:attribute>
+      <dia:attribute name="direction">
+      </dia:attribute>
+      <dia:attribute name="ends">
+        <dia:composite>
+          <dia:attribute name="role">
+          </dia:attribute>
+          <dia:attribute name="multiplicity">
+          </dia:attribute>
+          <dia:attribute name="arrow">
+          </dia:attribute>
+          <dia:attribute name="aggregate">
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+            <dia:string>#on delete cascade on update cascade#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O1" connection="46"/>
+        <dia:connection handle="1" to="O2" connection="1"/>
+      </dia:connections>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O4">
+        <dia:point val="5.825,-24.2003"/>
+      </dia:attribute>
+        <dia:rectangle val="5.1,-39.25;18.65,-23.4003"/>
+      </dia:attribute>
+        <dia:point val="5.825,-31.3501"/>
+        <dia:point val="5.85,-31.3501"/>
+        <dia:point val="5.85,-38.5"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O0" connection="16"/>
+        <dia:connection handle="1" to="O2" connection="6"/>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O5">
+        <dia:point val="-0.5157,-11.6675"/>
+      </dia:attribute>
+        <dia:rectangle val="-0.5657,-12.6175;45.2843,-9.4175"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="45.75"/>
+      </dia:attribute>
+        <dia:real val="2.2000000000000002"/>
+      </dia:attribute>
+      <dia:attribute name="line_colour">
+      </dia:attribute>
+      <dia:attribute name="fill_colour">
+      </dia:attribute>
+        <dia:string>#postgres:post#</dia:string>
+      </dia:attribute>
+      <dia:attribute name="text">
+        <dia:composite type="text">
+          <dia:attribute name="string">
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_user','mb_user_id'), (SELECT max(mb_user_id) FROM mb_user), true);#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="font">
+          </dia:attribute>
+          <dia:attribute name="height">
+          </dia:attribute>
+          <dia:attribute name="pos">
+            <dia:point val="-0.2157,-10.025"/>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="alignment">
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O6">
+        <dia:point val="-0.5307,-8.0525"/>
+      </dia:attribute>
+        <dia:rectangle val="-0.5807,-9.0025;30.9193,-5.8025"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="31.400000000000002"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#innodb:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE mb_user CHANGE COLUMN mb_user_id mb_user_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-0.2307,-6.41"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O7">
+        <dia:point val="-0.5,-17.05"/>
+      </dia:attribute>
+        <dia:rectangle val="-0.55,-18;32.35,-14"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="32.800000000000004"/>
+      </dia:attribute>
+        <dia:real val="3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#postgres:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE mb_user_id_seq;
+ALTER TABLE mb_user ALTER COLUMN mb_user_id SET DEFAULT nextval('mb_user_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-0.2,-15.4075"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O8">
+        <dia:point val="-0.4074,3.7"/>
+      </dia:attribute>
+        <dia:rectangle val="-0.4574,2.75;32.0926,5.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="32.450000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE mb_group CHANGE COLUMN mb_group_id mb_group_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-0.1074,5.3425"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O9">
+        <dia:point val="-0.4574,-0.025"/>
+      </dia:attribute>
+        <dia:rectangle val="-0.5074,-0.975;46.7426,2.225"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="47.149999999999999"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_group','mb_group_id'), (SELECT max(mb_group_id) FROM mb_group), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-0.1574,1.6175"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O10">
+        <dia:point val="-0.5074,-4.325"/>
+      </dia:attribute>
+        <dia:rectangle val="-0.5574,-5.275;33.3926,-1.275"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="33.850000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE mb_group_id_seq;
+ALTER TABLE mb_group ALTER COLUMN mb_group_id SET DEFAULT nextval('mb_group_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-0.2074,-2.6825"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O11">
+        <dia:point val="56,-35"/>
+      </dia:attribute>
+        <dia:rectangle val="55.95,-35.05;71.95,-30.15"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="15.9"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#gui#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#90ee90"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#gui_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#'' not null#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_description#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_public#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#1 not null#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O12">
+        <dia:point val="56,-25"/>
+      </dia:attribute>
+        <dia:rectangle val="55.95,-25.05;69.85,-6.55"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="13.800000000000001"/>
+      </dia:attribute>
+        <dia:real val="18.400000000000006"/>
+      </dia:attribute>
+        <dia:string>#gui_element#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#fkey_gui_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#''#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_pos#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_public#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_comment#</dia:string>
+          </dia:attribute>
+            <dia:string>#text#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_element#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#'' NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_attributes#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_left#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_tio#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_width#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_height#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_z_index#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_more_styles#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_content#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_closetag#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_js_file#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_mb_mod#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_target#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_requires#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_url#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="operations">
+        <dia:composite type="umloperation">
+            <dia:string>#gui_element_idx#</dia:string>
+          </dia:attribute>
+            <dia:string>#btree#</dia:string>
+          </dia:attribute>
+            <dia:string>#unique index#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="inheritance_type">
+          </dia:attribute>
+          <dia:attribute name="query">
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="parameters">
+            <dia:composite type="umlparameter">
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              <dia:attribute name="kind">
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O13">
+        <dia:point val="56,-2"/>
+      </dia:attribute>
+        <dia:rectangle val="55.95,-2.05;69.15,4.45"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="13.1"/>
+      </dia:attribute>
+        <dia:real val="6.4000000000000004"/>
+      </dia:attribute>
+        <dia:string>#gui_element_vars#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_e_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#var_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#var_value#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#context#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#var_type#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+            <dia:string>#gui_element_vars_idx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#index#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O14">
+        <dia:point val="62.9,-6.54972"/>
+      </dia:attribute>
+        <dia:rectangle val="61.8,-6.59972;75.35,-1.3004"/>
+      </dia:attribute>
+        <dia:point val="62.9,-4.30006"/>
+        <dia:point val="62.55,-4.30006"/>
+        <dia:point val="62.55,-2.0504"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#fkey_gui_id,e_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+            <dia:string>#fkey_gui_id,fkey_e_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O12" connection="50"/>
+        <dia:connection handle="1" to="O13" connection="20"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O15">
+        <dia:point val="63.95,-30.1497"/>
+      </dia:attribute>
+        <dia:rectangle val="62.15,-30.1997;75.7,-24.25"/>
+      </dia:attribute>
+        <dia:point val="63.95,-27.5749"/>
+        <dia:point val="62.9,-27.5749"/>
+        <dia:point val="62.9,-25"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="16"/>
+        <dia:connection handle="1" to="O12" connection="1"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O16">
+        <dia:point val="14.1,-30.9"/>
+      </dia:attribute>
+        <dia:rectangle val="14.05,-30.95;27.95,-26.85"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="4"/>
+      </dia:attribute>
+        <dia:string>#gui_mb_user#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#0 NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_type#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O17">
+        <dia:point val="31.65,-39.3997"/>
+      </dia:attribute>
+        <dia:rectangle val="20.25,-39.4497;35.35,-30.2003"/>
+      </dia:attribute>
+        <dia:point val="31.65,-35.175"/>
+        <dia:point val="21,-35.175"/>
+        <dia:point val="21,-30.9503"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O16" connection="14"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O18">
+        <dia:point val="55.9495,-32.6"/>
+      </dia:attribute>
+        <dia:rectangle val="27.2004,-33.685;55.9995,-27.9825"/>
+      </dia:attribute>
+        <dia:point val="41.95,-32.6"/>
+        <dia:point val="41.95,-28.9"/>
+        <dia:point val="27.9504,-28.9"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O19">
+        <dia:point val="135.3,-61.55"/>
+      </dia:attribute>
+        <dia:rectangle val="135.25,-61.6;152.65,-34.3"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="17.300000000000001"/>
+      </dia:attribute>
+        <dia:real val="27.200000000000014"/>
+      </dia:attribute>
+        <dia:string>#wms#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffc0cb"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#wms_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_version#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getcapabilities#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getmap#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getfeatureinfo#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getlegendurl#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_filter#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_owsproxy#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_upload_url#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fees#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#accessconstraints#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactperson#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactposition#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactorganization#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#address#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#city#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#stateorprovince#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#postcode#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#country#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactvoicetelephone#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactfacsimiletelephone#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactelectronicmailaddress#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_mb_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_owner#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_timestamp#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_supportsld#</dia:string>
+          </dia:attribute>
+            <dia:string>#boolean#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_userlayer#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_userstyle#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_remotewfs#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O20">
+        <dia:point val="135.284,-28.2175"/>
+      </dia:attribute>
+        <dia:rectangle val="135.234,-29.1675;175.484,-25.9675"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="40.149999999999999"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wms','wms_id'), (SELECT max(wms_id) FROM wms), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="135.584,-26.575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O21">
+        <dia:point val="135.269,-24.3025"/>
+      </dia:attribute>
+        <dia:rectangle val="135.219,-25.2525;162.519,-22.0525"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="27.200000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE wms CHANGE COLUMN wms_id wms_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="135.569,-22.66"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O22">
+        <dia:point val="135.3,-32.7"/>
+      </dia:attribute>
+        <dia:rectangle val="135.25,-33.65;163.95,-29.65"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="28.600000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE wms_id_seq;
+ALTER TABLE wms ALTER COLUMN wms_id SET DEFAULT nextval('wms_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="135.6,-31.0575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O23">
+        <dia:point val="86.8,-68.65"/>
+      </dia:attribute>
+        <dia:rectangle val="86.75,-68.7;101.35,-57.4"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="14.5"/>
+      </dia:attribute>
+        <dia:real val="11.200000000000001"/>
+      </dia:attribute>
+        <dia:string>#layer#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#layer_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_wms_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_pos#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_parent#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_queryable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_minscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#0#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_maxscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_dataurl#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_metadataurl#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O24">
+        <dia:point val="43.8,-69.6"/>
+      </dia:attribute>
+        <dia:rectangle val="43.75,-69.65;58,-58.35"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="14.15"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#gui_layer#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_layer_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_wms_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_status#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#1#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_selectable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_visible#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_queryable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_minscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_maxscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_priotity#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_style#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_wfs_featuretype#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+            <dia:string>#gui_layer_idx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O25">
+        <dia:point val="98.95,-18.2"/>
+      </dia:attribute>
+        <dia:rectangle val="98.9,-18.25;116.3,4.25"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="22.400000000000009"/>
+      </dia:attribute>
+        <dia:string>#wfs#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffa500"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#wfs_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_version#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_getcapabilities#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_getfeature#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_transaction#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_owsproxy#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_upload_url#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#individualname#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#positionname#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#providername#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#deliverypoint#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#postalcode#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#voice#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#facsimile#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#electronicmailaddress#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_mb_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_owner#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_timestamp#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O26">
+        <dia:point val="63.95,-35.0503"/>
+      </dia:attribute>
+        <dia:rectangle val="50.125,-59.0997;66.25,-34.2503"/>
+      </dia:attribute>
+        <dia:point val="63.95,-46.7"/>
+        <dia:point val="50.875,-46.7"/>
+        <dia:point val="50.875,-58.3497"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O24" connection="32"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O27">
+        <dia:point val="86.7496,-63.05"/>
+      </dia:attribute>
+        <dia:rectangle val="57.2504,-64.75;86.7996,-62.535"/>
+      </dia:attribute>
+        <dia:point val="72.375,-63.05"/>
+        <dia:point val="72.375,-64"/>
+        <dia:point val="58.0004,-64"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O23" connection="32"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O28">
+        <dia:point val="135.25,-47.95"/>
+      </dia:attribute>
+        <dia:rectangle val="100.6,-63.8;135.3,-47.435"/>
+      </dia:attribute>
+        <dia:point val="118.3,-47.95"/>
+        <dia:point val="118.3,-63.05"/>
+        <dia:point val="101.35,-63.05"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O19" connection="72"/>
+        <dia:connection handle="1" to="O23" connection="32"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O29">
+        <dia:point val="79.3299,-29.085"/>
+      </dia:attribute>
+        <dia:rectangle val="79.2799,-29.135;88.6299,-25.835"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="9.25"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#gui_wfs#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_wfs_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+            <dia:string>#gui_wfs_idx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O30">
+        <dia:point val="71.9505,-32.6"/>
+      </dia:attribute>
+        <dia:rectangle val="65.4296,-33.685;80.0296,-26.5675"/>
+      </dia:attribute>
+        <dia:point val="75.6151,-32.6"/>
+        <dia:point val="75.6151,-27.485"/>
+        <dia:point val="79.2796,-27.485"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O29" connection="12"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O31">
+        <dia:point val="107.6,-18.2503"/>
+      </dia:attribute>
+        <dia:rectangle val="83.2049,-26.5846;109.9,-17.4503"/>
+      </dia:attribute>
+        <dia:point val="107.6,-22.0425"/>
+        <dia:point val="83.9549,-22.0425"/>
+        <dia:point val="83.9549,-25.8346"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      <dia:attribute name="name">
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O25" connection="60"/>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O32">
+        <dia:point val="99.0449,11.21"/>
+      </dia:attribute>
+        <dia:rectangle val="98.9949,10.26;139.245,13.46"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs','wfs_id'), (SELECT max(wfs_id) FROM wfs), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="99.3449,12.8525"/>
+          </dia:attribute>
+          <dia:attribute name="color">
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O33">
+      <dia:attribute name="obj_pos">
+        <dia:point val="99.0299,14.975"/>
+      </dia:attribute>
+      <dia:attribute name="obj_bb">
+        <dia:rectangle val="98.9799,14.025;126.28,17.225"/>
+      </dia:attribute>
+      <dia:attribute name="elem_corner">
+      </dia:attribute>
+      <dia:attribute name="elem_width">
+      </dia:attribute>
+      <dia:attribute name="elem_height">
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE wfs CHANGE COLUMN wfs_id wfs_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="99.3299,16.6175"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O34">
+        <dia:point val="99.1106,6.7275"/>
+      </dia:attribute>
+        <dia:rectangle val="99.0606,5.7775;127.761,9.7775"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      <dia:attribute name="stereotype">
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE wfs_id_seq;
+ALTER TABLE wfs ALTER COLUMN wfs_id SET DEFAULT nextval('wfs_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="99.4106,8.37"/>
+          </dia:attribute>
+            <dia:color val="#000000"/>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O35">
+        <dia:point val="29.745,-23.6225"/>
+      </dia:attribute>
+        <dia:rectangle val="29.695,-23.6725;44.645,-19.5725"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="14.85"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#gui_mb_group#</dia:string>
+      </dia:attribute>
+        <dia:string>##</dia:string>
+      </dia:attribute>
+      <dia:attribute name="comment">
+      </dia:attribute>
+      <dia:attribute name="abstract">
+        <dia:boolean val="false"/>
+      </dia:attribute>
+      <dia:attribute name="suppress_attributes">
+      </dia:attribute>
+      <dia:attribute name="suppress_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_attributes">
+        <dia:boolean val="true"/>
+      </dia:attribute>
+      <dia:attribute name="visible_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_comments">
+      </dia:attribute>
+      <dia:attribute name="wrap_operations">
+      </dia:attribute>
+      <dia:attribute name="wrap_after_char">
+        <dia:int val="40"/>
+      </dia:attribute>
+      <dia:attribute name="comment_line_length">
+      </dia:attribute>
+      <dia:attribute name="comment_tagging">
+      </dia:attribute>
+      <dia:attribute name="line_color">
+      </dia:attribute>
+      <dia:attribute name="fill_color">
+        <dia:color val="#add8e6"/>
+      </dia:attribute>
+      <dia:attribute name="text_color">
+      </dia:attribute>
+      <dia:attribute name="normal_font">
+        <dia:font family="monospace" style="0" name="Courier"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_font">
+        <dia:font family="monospace" style="88" name="Courier-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font">
+        <dia:font family="monospace" style="8" name="Courier-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="classname_font">
+        <dia:font family="sans" style="80" name="Helvetica-Bold"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font">
+        <dia:font family="sans" style="88" name="Helvetica-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="comment_font">
+        <dia:font family="sans" style="8" name="Helvetica-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="normal_font_height">
+        <dia:real val="0.80000000000000004"/>
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font_height">
+      </dia:attribute>
+      <dia:attribute name="abstract_font_height">
+      </dia:attribute>
+      <dia:attribute name="classname_font_height">
+        <dia:real val="1"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font_height">
+      </dia:attribute>
+      <dia:attribute name="comment_font_height">
+      </dia:attribute>
+      <dia:attribute name="attributes">
+        <dia:composite type="umlattribute">
+          </dia:attribute>
+          <dia:attribute name="type">
+            <dia:string>#varchar(50)#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="value">
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="visibility">
+            <dia:enum val="2"/>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="class_scope">
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+            <dia:string>#integer#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_group_type#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:enum val="0"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="operations"/>
+      <dia:attribute name="template">
+      </dia:attribute>
+      <dia:attribute name="templates"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O36">
+        <dia:point val="12.2504,-21.75"/>
+      </dia:attribute>
+        <dia:rectangle val="12.2004,-22.835;30.495,-20.805"/>
+      </dia:attribute>
+        <dia:point val="20.9977,-21.75"/>
+        <dia:point val="20.9977,-21.7225"/>
+        <dia:point val="29.745,-21.7225"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#mb_group_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O35" connection="8"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O37">
+      </dia:attribute>
+        <dia:rectangle val="36.42,-30.1997;66.25,-22.9228"/>
+      </dia:attribute>
+        <dia:point val="63.95,-26.9112"/>
+        <dia:point val="37.17,-26.9112"/>
+        <dia:point val="37.17,-23.6728"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O35" connection="14"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O38">
+        <dia:point val="79.345,-40.1975"/>
+      </dia:attribute>
+        <dia:rectangle val="79.295,-40.2475;98.445,-30.5475"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="19.050000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#gui_wms#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_position#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_mapformat#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_featureinfoformat#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_exceptionformat#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_epsg#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_visible#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#1 NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_sldurl#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(255)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_opacity#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#100#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+            <dia:string>#gui_wms_idx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O39">
+        <dia:point val="71.95,-32.6"/>
+      </dia:attribute>
+        <dia:rectangle val="65.4447,-36.1475;80.0447,-32.085"/>
+      </dia:attribute>
+        <dia:point val="75.6226,-32.6"/>
+        <dia:point val="75.6226,-35.3975"/>
+        <dia:point val="79.2947,-35.3975"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:enum val="1"/>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O38" connection="28"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O40">
+      </dia:attribute>
+        <dia:rectangle val="97.695,-49.035;135.3,-34.48"/>
+      </dia:attribute>
+      <dia:attribute name="orth_points">
+        <dia:point val="105.884,-47.95"/>
+        <dia:point val="105.884,-35.3975"/>
+        <dia:point val="98.445,-35.3975"/>
+      </dia:attribute>
+      <dia:attribute name="orth_orient">
+      </dia:attribute>
+      <dia:attribute name="autorouting">
+      </dia:attribute>
+      </dia:attribute>
+      <dia:attribute name="direction">
+      </dia:attribute>
+      <dia:attribute name="ends">
+        <dia:composite>
+          <dia:attribute name="role">
+          </dia:attribute>
+          <dia:attribute name="multiplicity">
+          </dia:attribute>
+          <dia:attribute name="arrow">
+          </dia:attribute>
+          <dia:attribute name="aggregate">
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+            <dia:string>#on delete cascade on update cascade#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+      </dia:connections>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O41">
+        <dia:point val="77.8219,-18.185"/>
+      </dia:attribute>
+        <dia:rectangle val="77.7719,-18.235;93.0719,-6.135"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="15.199999999999999"/>
+      </dia:attribute>
+        <dia:real val="12.000000000000002"/>
+      </dia:attribute>
+        <dia:string>#wfs_conf#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#wfs_conf_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_conf_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_featuretype_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_label#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_label_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_button#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_button_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_style#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_buffer#</dia:string>
+          </dia:attribute>
+            <dia:string>#double#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_res_style#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_use_wzgraphics#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_conf_description#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O42">
+        <dia:point val="76.7719,29.815"/>
+      </dia:attribute>
+        <dia:rectangle val="76.7219,29.765;92.7219,37.065"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="7.1999999999999993"/>
+      </dia:attribute>
+        <dia:string>#wfs_featuretype#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_srs#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_searchable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O43">
+        <dia:point val="98.8997,-7"/>
+      </dia:attribute>
+        <dia:rectangle val="91.9724,-8.085;106.572,34.3325"/>
+      </dia:attribute>
+        <dia:point val="95.8111,-7"/>
+        <dia:point val="95.8111,33.415"/>
+        <dia:point val="92.7224,33.415"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O42" connection="22"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O44">
+      </dia:attribute>
+        <dia:rectangle val="63.9214,-33.685;78.5214,-11.2675"/>
+      </dia:attribute>
+        <dia:point val="74.861,-32.6"/>
+        <dia:point val="74.861,-12.185"/>
+        <dia:point val="77.7714,-12.185"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#gui_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O41" connection="34"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O45">
+        <dia:point val="84.7219,29.7646"/>
+      </dia:attribute>
+        <dia:rectangle val="84.6719,-6.88463;98.2219,30.5646"/>
+      </dia:attribute>
+        <dia:point val="84.7219,11.815"/>
+        <dia:point val="85.4219,11.815"/>
+        <dia:point val="85.4219,-6.13463"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O42" connection="22"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O46">
+      </dia:attribute>
+        <dia:rectangle val="92.3224,-12.935;106.922,-6.485"/>
+      </dia:attribute>
+        <dia:point val="95.9861,-7"/>
+        <dia:point val="95.9861,-12.185"/>
+        <dia:point val="93.0724,-12.185"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O47">
+        <dia:point val="99.5578,19.49"/>
+      </dia:attribute>
+        <dia:rectangle val="99.5078,19.44;114.808,24.34"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="4.8000000000000007"/>
+      </dia:attribute>
+        <dia:string>#wfs_element#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#element_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#element_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#element_type#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O48">
+      </dia:attribute>
+        <dia:rectangle val="84.6719,23.5903;119.958,30.5646"/>
+      </dia:attribute>
+        <dia:point val="84.7219,27.0524"/>
+        <dia:point val="107.158,27.0524"/>
+        <dia:point val="107.158,24.3403"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O47" connection="16"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O49">
+        <dia:point val="179.859,-48.46"/>
+      </dia:attribute>
+        <dia:rectangle val="179.809,-48.51;194.409,-44.41"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#wms_format#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#data_type#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#'' NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#data_format#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(100)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O50">
+        <dia:point val="152.65,-47.95"/>
+      </dia:attribute>
+        <dia:rectangle val="152.6,-49.035;180.559,-45.5425"/>
+      </dia:attribute>
+        <dia:point val="166.229,-47.95"/>
+        <dia:point val="166.229,-46.46"/>
+        <dia:point val="179.809,-46.46"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O49" connection="14"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O51">
+        <dia:point val="180.014,-40.21"/>
+      </dia:attribute>
+        <dia:rectangle val="179.964,-40.26;192.814,-36.96"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="12.75"/>
+      </dia:attribute>
+        <dia:real val="3.2000000000000002"/>
+      </dia:attribute>
+        <dia:string>#wms_srs#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O52">
+      </dia:attribute>
+        <dia:rectangle val="152.6,-49.035;180.714,-37.6925"/>
+      </dia:attribute>
+        <dia:point val="166.307,-47.95"/>
+        <dia:point val="166.307,-38.61"/>
+        <dia:point val="179.964,-38.61"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O51" connection="12"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O53">
+        <dia:point val="177.864,-56.06"/>
+      </dia:attribute>
+        <dia:rectangle val="177.814,-56.11;194.514,-52.81"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="16.600000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#wms_md_topic_category#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_md_topic_category_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O54">
+      </dia:attribute>
+        <dia:rectangle val="130.632,-55.21;178.567,-47.435"/>
+      </dia:attribute>
+        <dia:point val="165.232,-47.95"/>
+        <dia:point val="165.232,-54.46"/>
+        <dia:point val="177.814,-54.46"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="1" to="O53" connection="12"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O55">
+        <dia:point val="167.564,-71.1475"/>
+      </dia:attribute>
+        <dia:rectangle val="167.514,-71.1975;182.114,-67.0975"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="4"/>
+      </dia:attribute>
+        <dia:string>#md_topic_category#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffffff"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#md_topic_category_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#md_topic_category_code_en#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#md_topic_category_code_de#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O56">
+        <dia:point val="174.814,-67.0972"/>
+      </dia:attribute>
+        <dia:rectangle val="174.764,-67.1472;198.964,-55.3604"/>
+      </dia:attribute>
+        <dia:point val="174.814,-61.6038"/>
+        <dia:point val="186.164,-61.6038"/>
+        <dia:point val="186.164,-56.1104"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O55" connection="14"/>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O57">
+        <dia:point val="99.3592,31.485"/>
+      </dia:attribute>
+        <dia:rectangle val="99.3092,30.535;150.759,33.735"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="51.350000000000001"/>
+      </dia:attribute>
+        <dia:real val="2.2000000000000002"/>
+      </dia:attribute>
+      <dia:attribute name="line_colour">
+      </dia:attribute>
+      <dia:attribute name="fill_colour">
+      </dia:attribute>
+        <dia:string>#postgres:post#</dia:string>
+      </dia:attribute>
+      <dia:attribute name="text">
+        <dia:composite type="text">
+          <dia:attribute name="string">
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_element','wfs_element_id'), (SELECT max(wfs_element_id) FROM wfs_element), true);#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="font">
+          </dia:attribute>
+          <dia:attribute name="height">
+          </dia:attribute>
+          <dia:attribute name="pos">
+            <dia:point val="99.6592,33.1275"/>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="alignment">
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O58">
+        <dia:point val="99.3442,35.25"/>
+      </dia:attribute>
+        <dia:rectangle val="99.2942,34.3;132.194,37.5"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="32.800000000000004"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#innodb:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE wfs_element CHANGE COLUMN element_id element_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="99.6442,36.8925"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O59">
+        <dia:point val="99.4249,27.0025"/>
+      </dia:attribute>
+        <dia:rectangle val="99.3749,26.0525;135.075,30.0525"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="35.600000000000001"/>
+      </dia:attribute>
+        <dia:real val="3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#postgres:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE wfs_element_id_seq;
+ALTER TABLE wfs_element ALTER COLUMN element_id SET DEFAULT nextval('wfs_element_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="99.7249,28.645"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O60">
+        <dia:point val="76.6092,43.91"/>
+      </dia:attribute>
+        <dia:rectangle val="76.5592,42.96;133.609,46.16"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="56.950000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_featuretype','wfs_featuretype_id'), (SELECT max(wfs_featuretype_id) FROM wfs_featuretype), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="76.9092,45.5525"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O61">
+        <dia:point val="76.5942,47.675"/>
+      </dia:attribute>
+        <dia:rectangle val="76.5442,46.725;113.644,49.925"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="37"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE wfs_featuretype CHANGE COLUMN featuretype_id featuretype_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="76.8942,49.3175"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O62">
+        <dia:point val="76.6749,39.4275"/>
+      </dia:attribute>
+        <dia:rectangle val="76.6249,38.4775;116.525,42.4775"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="39.800000000000004"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE wfs_featuretype_id_seq;
+ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_id SET DEFAULT nextval('wfs_featuretype_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="76.9749,41.07"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O63">
+        <dia:point val="64.7954,-50.29"/>
+      </dia:attribute>
+        <dia:rectangle val="64.7454,-51.24;107.795,-48.04"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="42.950000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffc0cb"/>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('layer','layer_id'), (SELECT max(layer_id) FROM layer), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="65.0954,-48.6475"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O64">
+        <dia:point val="64.7804,-46.375"/>
+      </dia:attribute>
+        <dia:rectangle val="64.7304,-47.325;94.1304,-44.125"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="29.300000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE layer CHANGE COLUMN layer_id layer_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="65.0804,-44.7325"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O65">
+        <dia:point val="64.8114,-54.7725"/>
+      </dia:attribute>
+        <dia:rectangle val="64.7614,-55.7225;95.5614,-51.7225"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="30.700000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE layer_id_seq;
+ALTER TABLE layer ALTER COLUMN layer_id SET DEFAULT nextval('layer_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="65.1114,-53.13"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+  </dia:layer>
+</dia:diagram>
More information about the Mapbender_commits mailing list
