[Mapbender-commits] r2774 - branches/2.5/http/tools
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Aug 13 07:05:07 EDT 2008
Author: christoph
Date: 2008-08-13 07:05:07 -0400 (Wed, 13 Aug 2008)
New Revision: 2774
Added:
   branches/2.5/http/tools/1_createMySqlDump.php
   branches/2.5/http/tools/2_convertDataDumps.php
   branches/2.5/http/tools/3_addHeaderToDataDumps.php
for the build script...just a backup
Added: branches/2.5/http/tools/1_createMySqlDump.php
--- branches/2.5/http/tools/1_createMySqlDump.php	                        (rev 0)
+++ branches/2.5/http/tools/1_createMySqlDump.php	2008-08-13 11:05:07 UTC (rev 2774)
@@ -0,0 +1,61 @@
+<?php
+	$fileArray = array(
+		"mysql" =>
+			array(	"from" => "../../resources/db/postgresql/utf8/pgsql_data.sql",
+					"to" => "../../resources/db/mysql/utf8/mysql_data.sql")
+	function saveAsFile($filename, $data) {
+		if ($h = fopen($filename, "w")) {
+			if (!fwrite($h, $data)) {
+				return false;
+			fclose($h);
+		return true;
+	// load file
+	$from = $fileArray["mysql"]["from"];
+	$to = $fileArray["mysql"]["to"];
+	if (file_exists($from)) {
+		$data = file_get_contents($from);
+	else {
+		echo "Fatal error: File not found ('" . $from . "').\n";
+		exit(1);
+	// replace postgresql's string escape syntax
+	$pattern = "/, E'/";
+	$data = preg_replace($pattern, ", '", $data);
+	// disable foreign keys
+	$pattern = "/UPDATE pg_catalog\.pg_class SET reltriggers = 0;/";
+	if (preg_match($pattern, $data)) {
+		$data = preg_replace($pattern, "SET FOREIGN_KEY_CHECKS=0;", $data);
+	else {
+		echo "Fatal error: Didn't find expression (pattern: " . $pattern . ").\n";
+		exit(1);
+	// enable foreign keys
+	$pattern = 	"/UPDATE pg_catalog\.pg_class SET reltriggers = \(SELECT pg_catalog\.count\(\*\) FROM pg_catalog\.pg_trigger where pg_class\.oid = tgrelid\);/";
+		$data = preg_replace($pattern, "SET FOREIGN_KEY_CHECKS=1;", $data);
+	else {
+		exit(1);
+	// save mysql file
+	if (!saveAsFile($to, $data)) {
+		echo "Fatal error: File could not be saved ('" . $to . "').\n";
+		exit(1);
+	echo "Finished.\n\n";
+	exit(0);
\ No newline at end of file
Added: branches/2.5/http/tools/2_convertDataDumps.php
--- branches/2.5/http/tools/2_convertDataDumps.php	                        (rev 0)
+++ branches/2.5/http/tools/2_convertDataDumps.php	2008-08-13 11:05:07 UTC (rev 2774)
@@ -0,0 +1,44 @@
+<?php
+	// needs to be set, otherwise the iconv option //TRANSLIT
+	// won't work
+	setlocale(LC_CTYPE, "de_DE.utf8");
+		"mysql" =>
+			array(	"from" => "../../resources/db/mysql/utf8/mysql_data.sql",
+					"to" => "../../resources/db/mysql/iso/mysql_data.sql"),
+		"pgsql" =>
+					"to" => "../../resources/db/postgresql/iso/pgsql_data.sql")
+				return false;
+			fclose($h);
+		return true;
+	foreach ($fileArray as $file) {
+		$from = $file["from"];
+		$to = $file["to"];
+		else {
+		$dataConverted = iconv("UTF-8", "ASCII//TRANSLIT", $data);
+		if (!saveAsFile($to, $dataConverted)) {
Added: branches/2.5/http/tools/3_addHeaderToDataDumps.php
--- branches/2.5/http/tools/3_addHeaderToDataDumps.php	                        (rev 0)
+++ branches/2.5/http/tools/3_addHeaderToDataDumps.php	2008-08-13 11:05:07 UTC (rev 2774)
@@ -0,0 +1,53 @@
+<?php
+	require_once(dirname(__FILE__) . "/../../core/system.php");
+	setlocale(LC_TIME, "de_DE.utf8");
+		"mysql" =>
+			array(	"iso" => "../../resources/db/mysql/iso/mysql_data.sql",
+					"utf8" => "../../resources/db/mysql/utf8/mysql_data.sql"),
+		"postgresql" =>
+			array(	"iso" => "../../resources/db/postgresql/iso/pgsql_data.sql",
+					"utf8" => "../../resources/db/postgresql/utf8/pgsql_data.sql")
+				return false;
+			fclose($h);
+		return true;
+	foreach ($fileArray as $dbType => $files) {
+		foreach ($files as $characterSet => $file) {
+			if (file_exists($file)) {
+				$data = file_get_contents($file);
+			else {
+				echo "Fatal error: File not found ('" . $file . "').\n";
+				exit(1);
+			// add header to file
+			$header = 	"--\n" .
+						"-- " . $dbType . " " . $characterSet . " data dump\n" .
+						"-- \n" .
+						"-- Mapbender " . MB_VERSION_NUMBER . " " . MB_VERSION_APPENDIX . "\n" .
+						"-- \n" .
+						"-- " . date("Y/m/d", MB_RELEASE_DATE) . "\n" .
+						"--\n\n";
+			$data = $header . $data;
+			if (!saveAsFile($file, $data)) {
+				echo "Fatal error: File could not be saved ('" . $file . "').\n";
+				exit(1);
+	exit(0);
More information about the Mapbender_commits mailing list
