[Mapbender-commits] r2796 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Thu Aug 14 10:58:28 EDT 2008
Author: christoph
Date: 2008-08-14 10:58:28 -0400 (Thu, 14 Aug 2008)
New Revision: 2796
trunk/mapbender/resources/db/schema_2.5.dia
changed column name in gui_treegde from left to lft
Modified: trunk/mapbender/resources/db/schema_2.5.dia
--- trunk/mapbender/resources/db/schema_2.5.dia 2008-08-14 14:39:37 UTC (rev 2795)
+++ trunk/mapbender/resources/db/schema_2.5.dia 2008-08-14 14:58:28 UTC (rev 2796)
@@ -10032,13 +10032,13 @@
<dia:point val="34,-63"/>
</dia:attribute>
<dia:attribute name="obj_bb">
- <dia:rectangle val="33.95,-63.05;44.35,-54.95"/>
+ <dia:rectangle val="33.95,-63.05;45.05,-54.95"/>
</dia:attribute>
<dia:attribute name="elem_corner">
</dia:attribute>
<dia:attribute name="elem_width">
- <dia:real val="10.300000000000001"/>
+ <dia:real val="11"/>
</dia:attribute>
<dia:attribute name="elem_height">
<dia:real val="8"/>
@@ -10136,7 +10136,7 @@
<dia:string>#varchar(50)#</dia:string>
</dia:attribute>
<dia:attribute name="value">
- <dia:string>##</dia:string>
+ <dia:string>#''#</dia:string>
</dia:attribute>
<dia:attribute name="comment">
@@ -10199,7 +10199,7 @@
</dia:composite>
<dia:composite type="umlattribute">
<dia:attribute name="name">
- <dia:string>#left#</dia:string>
+ <dia:string>#lft#</dia:string>
</dia:attribute>
<dia:attribute name="type">
<dia:string>#integer#</dia:string>
@@ -13922,7 +13922,7 @@
<dia:point val="152,-8.3"/>
</dia:attribute>
- <dia:rectangle val="91.4,-9.45;152.05,-7.7"/>
+ <dia:rectangle val="91.4,-9.45;152.05,-7.7825"/>
</dia:attribute>
<dia:attribute name="orth_points">
@@ -14970,12 +14970,12 @@
<dia:point val="53,-71.5"/>
</dia:attribute>
- <dia:rectangle val="38.4,-72.585;53.05,-62.25"/>
+ <dia:rectangle val="38.75,-72.585;53.05,-62.25"/>
</dia:attribute>
- <dia:point val="39.15,-71.5"/>
- <dia:point val="39.15,-63"/>
+ <dia:point val="39.5,-71.5"/>
+ <dia:point val="39.5,-63"/>
</dia:attribute>
<dia:attribute name="orth_orient">
<dia:enum val="0"/>
More information about the Mapbender_commits
