[Mapbender-commits] r2799 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 14 11:13:09 EDT 2008
Author: christoph
Date: 2008-08-14 11:13:08 -0400 (Thu, 14 Aug 2008)
New Revision: 2799
   trunk/mapbender/resources/db/schema_2.5.dia
removed gui_gml typo
fkey_layer_id set to integer in gui_treegde
Modified: trunk/mapbender/resources/db/schema_2.5.dia
--- trunk/mapbender/resources/db/schema_2.5.dia	2008-08-14 15:01:50 UTC (rev 2798)
+++ trunk/mapbender/resources/db/schema_2.5.dia	2008-08-14 15:13:08 UTC (rev 2799)
@@ -10156,7 +10156,7 @@
             <dia:string>#fkey_layer_id#</dia:string>
           </dia:attribute>
           <dia:attribute name="type">
-            <dia:string>#text#</dia:string>
+            <dia:string>#integer#</dia:string>
           </dia:attribute>
           <dia:attribute name="value">
             <dia:string>##</dia:string>
@@ -15702,7 +15702,7 @@
       <dia:attribute name="text">
         <dia:composite type="text">
           <dia:attribute name="string">
-            <dia:string>#ALTER TABLE gui_gml CHANGE COLUMN kml_id kml_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+            <dia:string>#ALTER TABLE gui_kml CHANGE COLUMN kml_id kml_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
           </dia:attribute>
           <dia:attribute name="font">
             <dia:font family="monospace" style="0" name="Courier"/>
More information about the Mapbender_commits mailing list
