[Mapbender-commits] r2827 - trunk/build
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 15 10:43:20 EDT 2008
Author: christoph
Date: 2008-08-15 10:43:20 -0400 (Fri, 15 Aug 2008)
New Revision: 2827
Removed:
   trunk/build/jsmin-1.1.0.php
Deleted: trunk/build/jsmin-1.1.0.php
--- trunk/build/jsmin-1.1.0.php	2008-08-15 14:43:01 UTC (rev 2826)
+++ trunk/build/jsmin-1.1.0.php	2008-08-15 14:43:20 UTC (rev 2827)
@@ -1,296 +0,0 @@
-<?php
- * jsmin.php - PHP implementation of Douglas Crockford's JSMin.
- * This is pretty much a direct port of jsmin.c to PHP with just a few
- * PHP-specific performance tweaks. Also, whereas jsmin.c reads from stdin and
- * outputs to stdout, this library accepts a string as input and returns another
- * string as output.
- * PHP 5 or higher is required.
- * Permission is hereby granted to use this version of the library under the
- * same terms as jsmin.c, which has the following license:
- * Copyright (c) 2002 Douglas Crockford  (www.crockford.com)
- * Permission is hereby granted, free of charge, to any person obtaining a copy of
- * this software and associated documentation files (the "Software"), to deal in
- * the Software without restriction, including without limitation the rights to
- * use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
- * of the Software, and to permit persons to whom the Software is furnished to do
- * so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in all
- * copies or substantial portions of the Software.
- * The Software shall be used for Good, not Evil.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
- * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
- * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
- * SOFTWARE.
- * @package JSMin
- * @author Ryan Grove <ryan at wonko.com>
- * @copyright 2002 Douglas Crockford <douglas at crockford.com> (jsmin.c)
- * @copyright 2007 Ryan Grove <ryan at wonko.com> (PHP port)
- * @license http://opensource.org/licenses/mit-license.php MIT License
- * @version 1.1.0 (2007-06-01)
- * @link http://code.google.com/p/jsmin-php/
-class JSMin {
-  const ORD_LF    = 10;
-  const ORD_SPACE = 32;
-  protected $a           = '';
-  protected $b           = '';
-  protected $input       = '';
-  protected $inputIndex  = 0;
-  protected $inputLength = 0;
-  protected $lookAhead   = null;
-  protected $output      = array();
-  // -- Public Static Methods --------------------------------------------------
-  public static function minify($js) {
-    $jsmin = new JSMin($js);
-    return $jsmin->min();
-  // -- Public Instance Methods ------------------------------------------------
-  public function __construct($input) {
-    $this->input       = str_replace("\r\n", "\n", $input);
-    $this->inputLength = strlen($this->input);
-  // -- Protected Instance Methods ---------------------------------------------
-  protected function action($d) {
-    switch($d) {
-      case 1:
-        $this->output[] = $this->a;
-      case 2:
-        $this->a = $this->b;
-        if ($this->a === "'" || $this->a === '"') {
-          for (;;) {
-            $this->a        = $this->get();
-            if ($this->a === $this->b) {
-              break;
-            if (ord($this->a) <= self::ORD_LF) {
-              throw new JSMinException('Unterminated string literal.');
-            if ($this->a === '\\') {
-      case 3:
-        $this->b = $this->next();
-        if ($this->b === '/' && (
-            $this->a === '(' || $this->a === ',' || $this->a === '=' ||
-            $this->a === ':' || $this->a === '[' || $this->a === '!' ||
-            $this->a === '&' || $this->a === '|' || $this->a === '?')) {
-          $this->output[] = $this->b;
-          for (;;) {
-            if ($this->a === '/') {
-              break;
-            elseif ($this->a === '\\') {
-            elseif (ord($this->a) <= self::ORD_LF) {
-              throw new JSMinException('Unterminated regular expression '.
-                  'literal.');
-  protected function get() {
-    $c = $this->lookAhead;
-    $this->lookAhead = null;
-    if ($c === null) {
-      if ($this->inputIndex < $this->inputLength) {
-        $c = $this->input[$this->inputIndex];
-        $this->inputIndex += 1;
-      else {
-        $c = null;
-    if ($c === "\r") {
-      return "\n";
-    if ($c === null || $c === "\n" || ord($c) >= self::ORD_SPACE) {
-      return $c;
-    return ' ';
-  protected function isAlphaNum($c) {
-    return ord($c) > 126 || $c === '\\' || preg_match('/^[\w\$]$/', $c) === 1;
-  protected function min() {
-    $this->a = "\n";
-    $this->action(3);
-    while ($this->a !== null) {
-      switch ($this->a) {
-        case ' ':
-          if ($this->isAlphaNum($this->b)) {
-            $this->action(1);
-          else {
-            $this->action(2);
-          break;
-        case "\n":
-          switch ($this->b) {
-            case '{':
-            case '[':
-            case '(':
-            case '+':
-            case '-':
-              $this->action(1);
-              break;
-            case ' ':
-              $this->action(3);
-              break;
-            default:
-                $this->action(1);
-              else {
-                $this->action(2);
-          break;
-        default:
-            case ' ':
-              if ($this->isAlphaNum($this->a)) {
-                $this->action(1);
-                break;
-              $this->action(3);
-              break;
-            case "\n":
-                case '}':
-                case ']':
-                case ')':
-                case '+':
-                case '-':
-                case '"':
-                case "'":
-                  $this->action(1);
-                  break;
-                default:
-                    $this->action(1);
-                  else {
-                    $this->action(3);
-              break;
-            default:
-              $this->action(1);
-              break;
-    return implode('', $this->output);
-  protected function next() {
-    $c = $this->get();
-    if ($c === '/') {
-      switch($this->peek()) {
-        case '/':
-          for (;;) {
-            if (ord($c) <= self::ORD_LF) {
-              return $c;
-        case '*':
-          $this->get();
-          for (;;) {
-            switch($this->get()) {
-              case '*':
-                if ($this->peek() === '/') {
-                  $this->get();
-                  return ' ';
-                break;
-              case null:
-                throw new JSMinException('Unterminated comment.');
-        default:
-          return $c;
-    return $c;
-  protected function peek() {
-    $this->lookAhead = $this->get();
-    return $this->lookAhead;
-// -- Exceptions ---------------------------------------------------------------
-class JSMinException extends Exception {}
\ No newline at end of file
More information about the Mapbender_commits mailing list
