[Mapbender-commits] r2829 - branches/2.5/resources/db/postgresql/utf8
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 15 10:44:47 EDT 2008
Author: christoph
Date: 2008-08-15 10:44:45 -0400 (Fri, 15 Aug 2008)
New Revision: 2829
   branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql
created from template database
Modified: branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql
--- branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql	2008-08-15 14:43:44 UTC (rev 2828)
+++ branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql	2008-08-15 14:44:45 UTC (rev 2829)
@@ -1,203 +1,310 @@
--- postgresql data utf8
--- Mapbender (Version: 2.5)
--- 2008-02-20
-UPDATE pg_catalog.pg_class SET reltriggers = 0;
--- TOC entry 1856 (class 0 OID 5377115)
--- Dependencies: 1253
--- Data for Name: gui; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin2_en', 'admin2_en', 'admin GUI in english', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin2_de', 'admin2_de', 'admin GUI in deutscher Sprache', 1);
+-- PostgreSQL database dump
+SET client_encoding = 'UTF8';
+SET check_function_bodies = false;
+SET client_min_messages = warning;
+SET search_path = public, pg_catalog;
+-- Name: gui_kml_kml_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_kml', 'kml_id'), 1, false);
+-- Name: gui_treegde_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_treegde', 'id'), 99, true);
+-- Name: keyword_keyword_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('keyword', 'keyword_id'), 231, true);
+-- Name: layer_layer_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('layer', 'layer_id'), 20125, true);
+-- Name: mb_group_mb_group_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_group', 'mb_group_id'), 20, true);
+-- Name: mb_log_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_log', 'id'), 1, false);
+-- Name: mb_user_mb_user_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_user', 'mb_user_id'), 1, true);
+-- Name: md_topic_category_md_topic_category_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('md_topic_category', 'md_topic_category_id'), 19, true);
+-- Name: sld_user_layer_sld_user_layer_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('sld_user_layer', 'sld_user_layer_id'), 1, false);
+-- Name: translations_trs_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('translations', 'trs_id'), 287, true);
+-- Name: wfs_conf_element_wfs_conf_element_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_conf_element', 'wfs_conf_element_id'), 29, true);
+-- Name: wfs_conf_wfs_conf_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_conf', 'wfs_conf_id'), 4, true);
+-- Name: wfs_element_element_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_element', 'element_id'), 175, true);
+-- Name: wfs_featuretype_featuretype_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_featuretype', 'featuretype_id'), 23, true);
+-- Name: wfs_wfs_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs', 'wfs_id'), 2, true);
+-- Name: wms_wms_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wms', 'wms_id'), 910, true);
+-- Data for Name: gui; Type: TABLE DATA; Schema: public; Owner: admin
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin2_en', 'admin2_en', 'admin GUI in english', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin2_de', 'admin2_de', 'admin GUI in deutscher Sprache', 1);
 INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_de_services', 'admin_de_services', 'erweiterte admin GUI - WMS, WFS, Metadaten (deutsch)
-', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_en_services', 'admin_en_services', 'extended admin GUI - WMS, WFS, metadata-handling (english)', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_germany', 'wms_germany', 'Container for german WMS', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_gdi_de', 'wms_gdi_de', 'Container for german WMS from GDI-DE', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui1', 'gui1', 'GUI combining most of the Mapbender functionality', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin1', 'admin1', 'admin GUI containing all adminstrative modules (use only as a template)', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui_digitize', 'gui_digitize', 'GUI with WFS search and digitizing using WFS-T', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui', 'gui', 'GUI with tab, search modules', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_europe', 'wms_europe', 'Container for european WMS', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_worldwide', 'wms_worldwide', 'Container for world wide WMS', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_north_america', 'wms_north_america', 'Container for north America WMS', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_australia', 'wms_australia', 'Container for Australia WMS', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_africa', 'wms_africa', 'Container for Africa WMS', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui2', 'gui2', 'GUI with focus on layout', 1);
--- TOC entry 1857 (class 0 OID 5377121)
--- Dependencies: 1254
--- Data for Name: gui_element; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_north_america', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_worldwide', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', E'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Beh&auml;lter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfl&auml;che. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuw&auml;hlen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, NULL, NULL, NULL, '', '', 'body', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, NULL, NULL, NULL, '', '', 'body', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_north_america', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_north_america', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_worldwide', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_worldwide', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', E'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''onmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''onmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'FeatureInfoRedirect', 2, 1, 'redirect featureInfoRequests in an iframe for each wms', 'Info', 'iframe', '../html/mod_blank.html', 'frameborder="0"', 83, -17, 1, 1, 0, '', '', 'iframe', 'mod_featureInfoRedirect.php', '', '', '', 'http://www.mapbender.org/index.php/FeatureInfoRedirect');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'WMS_preferences', 2, 1, 'configures the preferences of each loaded wms', 'WMS preferences', 'img', '../img/button_gray/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 540, 10, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', 'http://www.mapbender.org/index.php/WMS_preferences');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'addWMS', 2, 1, 'add a WMS to the running application', 'Adding WMS', 'img', '../img/button_gray/add_off.png', 'onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 515, 10, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'addWMSfromfilteredList_ajax', 2, 1, 'add a WMS to the running application from a filtered list', 'Adding WMS from filtered list', 'img', '../img/button_blink_red/add_filtered_list_off.png', 'onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 490, 10, 24, 24, 1, '', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'back', 2, 1, 'History.back()', 'Back', 'img', '../img/button_gray/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"', 360, 10, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Back');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'body', 1, 1, 'body (obligatory)', '', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, '', '', '', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'copyright', 2, 1, 'a Copyright in the map', 'Copyright', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', '', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/DependentDiv');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'Drag Mapsize', 'div', '', '', 81, -19, NULL, NULL, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'Query', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfo');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'Query', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')"', 425, 10, 24, 24, 1, '', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfoTunnel');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'forward', 2, 1, 'History.forward()', 'Forward', 'img', '../img/button_gray/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ', 385, 10, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Forward');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'gazetteerMetadata', 2, 1, 'gazetteer for metadata', 'Metadatasearch', 'iframe', '../php/mod_gazetteerMetadata.php?sessionID&target=mapframe1,overview', 'frameborder = "0"', 1, 1, 1, 1, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'gazetteerWFS', 2, 1, 'a gazetteer for user in the mapbender user map', 'Search', 'iframe', '../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', 'geometry.js', 'mapframe1,overview', 'wz-graphics', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" ', 620, 10, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'highlightPOI', 2, 1, 'highlight 1 to n pois in your gui with a Symbol and a special text', '', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_highlightPOI.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'imprint', 2, 1, 'Information about the owner of the gui', 'Imprint', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_back', 3, 1, 'layout, background for buttons', '', 'div', '', '', 360, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_featureInfo', 3, 1, 'layout, background for FeatureInfo', '', 'div', '', '', 425, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_help', 3, 1, 'layout, background for Help-button', '', 'div', '', '', 620, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_logout', 3, 1, 'layout, background for Logout-button', '', 'div', '', '', 660, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_metadata', 3, 1, 'layout, background for Metadata', '', 'div', '', '', 580, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_wms', 3, 1, 'layout, background for wms', '', 'div', '', '', 490, 10, 76, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_zoom', 3, 1, 'layout, background for Zoom-button', '', 'div', '', '', 220, 10, 126, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'legend', 2, 1, 'legend', 'Legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'loadData', 2, 1, 'IFRAME, um Daten zu laden', '', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'logo', 2, 1, 'Logo', 'Logo', 'img', '../img/mapbender_logo.png', '', 20, 20, 180, 26, 5, '', '', '', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ', 660, 10, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'mapbender', 2, 1, 'Mapbender-Logo', '', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', 81, -19, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'mapframe1', 2, 1, 'frame for a map', 'Mapframe', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 230, 55, 500, 450, 2, '', '', 'iframe', '', '', '', '', 'http://www.mapbender.org/index.php/Mapframe');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'meetingPoint', 2, 1, 'create a meeting point', 'Meetingpoint', 'iframe', '../php/mod_meetingPoint.php?sessionID', 'frameborder = "0" ', 0, 0, NULL, NULL, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'Show WMS infos', 'img', '../img/button_gray/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' ', 580, 10, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'navFrame', 2, 1, 'navigation mapborder', 'Navigation Frame', 'div', '', '', 0, 0, 0, 0, 0, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ', 'div', 'mod_navFrame.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/NavFrame');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'overview', 2, 1, 'OverviewFrame', 'Overview', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 30, 65, 150, 130, 100, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/Overview');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'pan1', 2, 1, 'pan', 'Pan', 'img', '../img/button_gray/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')" ', 270, 10, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Pan');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'printPDF', 2, 1, 'pdf print', 'Print', 'iframe', '../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf', 'frameborder = "0" ', 1, 1, 2, 2, 5, 'visibility:hidden', '', 'iframe', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Print');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'sandclock', 2, 1, 'displays a sand clock while waiting for requests', '', 'div', '', '', 80, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'selArea1', 2, 1, 'zoombox', 'Zoom by rectangle', 'img', '../img/button_gray/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')" ', 295, 10, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/SelArea1');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', '', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'setBackground', 2, 1, 'switch background-wms', 'Set Background', 'form', '', '', 30, 210, NULL, NULL, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'Coordinates', 'img', '../img/button_gray/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ', 450, 10, 24, 24, 1, '', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', 'http://www.mapbender.org/index.php/ShowCoords_div');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'tabs', 2, 1, 'vertical tabs to handle iframes', '', 'div', '', '', 10, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', '');
+', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_en_services', 'admin_en_services', 'extended admin GUI - WMS, WFS, metadata-handling (english)', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_germany', 'wms_germany', 'Container for german WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_gdi_de', 'wms_gdi_de', 'Container for german WMS from GDI-DE', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui1', 'gui1', 'GUI combining most of the Mapbender functionality', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin1', 'admin1', 'admin GUI containing all adminstrative modules (use only as a template)', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui_digitize', 'gui_digitize', 'GUI with WFS search and digitizing using WFS-T', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui', 'gui', 'GUI with tab, search modules', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_europe', 'wms_europe', 'Container for european WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_worldwide', 'wms_worldwide', 'Container for world wide WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_north_america', 'wms_north_america', 'Container for north America WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_australia', 'wms_australia', 'Container for Australia WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_africa', 'wms_africa', 'Container for Africa WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui2', 'gui2', 'GUI with focus on layout', 1);
+-- Data for Name: gui_element; Type: TABLE DATA; Schema: public; Owner: admin
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_north_america', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_worldwide', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', E'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Beh&auml;lter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfl&auml;che. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuw&auml;hlen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, NULL, NULL, NULL, '', '', 'body', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'body', 1, 1, 'obligatory body', NULL, 'body', '', '', 0, 0, NULL, NULL, NULL, '', '', 'body', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_north_america', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_north_america', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_worldwide', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_worldwide', 'content', 2, 1, 'text', NULL, 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'logout', 2, 1, 'Logout', NULL, 'img', '../img/button_gray/logout_off.png', E'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''onmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''onmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'FeatureInfoRedirect', 2, 1, 'redirect featureInfoRequests in an iframe for each wms', 'Info', 'iframe', '../html/mod_blank.html', 'frameborder="0"', 83, -17, 1, 1, 0, '', '', 'iframe', 'mod_featureInfoRedirect.php', '', '', '', 'http://www.mapbender.org/index.php/FeatureInfoRedirect');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'WMS_preferences', 2, 1, 'configures the preferences of each loaded wms', 'WMS preferences', 'img', '../img/button_gray/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 540, 10, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', 'http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'addWMS', 2, 1, 'add a WMS to the running application', 'Adding WMS', 'img', '../img/button_gray/add_off.png', 'onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 515, 10, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'addWMSfromfilteredList_ajax', 2, 1, 'add a WMS to the running application from a filtered list', 'Adding WMS from filtered list', 'img', '../img/button_blink_red/add_filtered_list_off.png', 'onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 490, 10, 24, 24, 1, '', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'back', 2, 1, 'History.back()', 'Back', 'img', '../img/button_gray/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"', 360, 10, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'body', 1, 1, 'body (obligatory)', '', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, '', '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'copyright', 2, 1, 'a Copyright in the map', 'Copyright', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', '', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'Drag Mapsize', 'div', '', '', 81, -19, NULL, NULL, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'Query', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'Query', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')"', 425, 10, 24, 24, 1, '', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'forward', 2, 1, 'History.forward()', 'Forward', 'img', '../img/button_gray/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ', 385, 10, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'gazetteerMetadata', 2, 1, 'gazetteer for metadata', 'Metadatasearch', 'iframe', '../php/mod_gazetteerMetadata.php?sessionID&target=mapframe1,overview', 'frameborder = "0"', 1, 1, 1, 1, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'gazetteerWFS', 2, 1, 'a gazetteer for user in the mapbender user map', 'Search', 'iframe', '../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', 'geometry.js', 'mapframe1,overview', 'wz-graphics', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" ', 620, 10, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'highlightPOI', 2, 1, 'highlight 1 to n pois in your gui with a Symbol and a special text', '', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_highlightPOI.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'imprint', 2, 1, 'Information about the owner of the gui', 'Imprint', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_back', 3, 1, 'layout, background for buttons', '', 'div', '', '', 360, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_featureInfo', 3, 1, 'layout, background for FeatureInfo', '', 'div', '', '', 425, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_help', 3, 1, 'layout, background for Help-button', '', 'div', '', '', 620, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_logout', 3, 1, 'layout, background for Logout-button', '', 'div', '', '', 660, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_metadata', 3, 1, 'layout, background for Metadata', '', 'div', '', '', 580, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_wms', 3, 1, 'layout, background for wms', '', 'div', '', '', 490, 10, 76, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_zoom', 3, 1, 'layout, background for Zoom-button', '', 'div', '', '', 220, 10, 126, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'legend', 2, 1, 'legend', 'Legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'loadData', 2, 1, 'IFRAME, um Daten zu laden', '', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'logo', 2, 1, 'Logo', 'Logo', 'img', '../img/mapbender_logo.png', '', 20, 20, 180, 26, 5, '', '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ', 660, 10, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'mapbender', 2, 1, 'Mapbender-Logo', '', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', 81, -19, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'mapframe1', 2, 1, 'frame for a map', 'Mapframe', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 230, 55, 500, 450, 2, '', '', 'iframe', '', '', '', '', 'http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'meetingPoint', 2, 1, 'create a meeting point', 'Meetingpoint', 'iframe', '../php/mod_meetingPoint.php?sessionID', 'frameborder = "0" ', 0, 0, NULL, NULL, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'Show WMS infos', 'img', '../img/button_gray/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' ', 580, 10, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'navFrame', 2, 1, 'navigation mapborder', 'Navigation Frame', 'div', '', '', 0, 0, 0, 0, 0, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ', 'div', 'mod_navFrame.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'overview', 2, 1, 'OverviewFrame', 'Overview', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 30, 65, 150, 130, 100, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'pan1', 2, 1, 'pan', 'Pan', 'img', '../img/button_gray/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')" ', 270, 10, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'printPDF', 2, 1, 'pdf print', 'Print', 'iframe', '../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf', 'frameborder = "0" ', 1, 1, 2, 2, 5, 'visibility:hidden', '', 'iframe', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'sandclock', 2, 1, 'displays a sand clock while waiting for requests', '', 'div', '', '', 80, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'selArea1', 2, 1, 'zoombox', 'Zoom by rectangle', 'img', '../img/button_gray/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')" ', 295, 10, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', '', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'setBackground', 2, 1, 'switch background-wms', 'Set Background', 'form', '', '', 30, 210, NULL, NULL, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'Coordinates', 'img', '../img/button_gray/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ', 450, 10, 24, 24, 1, '', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', 'http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'tabs', 2, 1, 'vertical tabs to handle iframes', '', 'div', '', '', 10, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'treeGDE', 2, 1, 'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
-for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2', 'Maps', 'iframe', '../html/mod_treefolder2.php?sessionID', 'frameborder = "0" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomFull', 2, 1, 'zoom to full extent button', 'Display complete map', 'img', '../img/button_gray/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ', 320, 10, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomFull');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomIn1', 2, 1, 'zoomIn button', 'Zoom in', 'img', '../img/button_gray/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ', 220, 10, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomOut1', 2, 1, 'zoomOut button', 'Zoom out', 'img', '../img/button_gray/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''', 245, 10, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomOut');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'WMS_preferences', 2, 1, 'configure the preferences of each loaded wms', 'WMS preferences', 'img', '../img/button_blink_red/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 670, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', 'http://www.mapbender.org/index.php/WMS_preferences');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'addWMS', 2, 1, 'add a WMS to the running application', 'Adding WMS', 'img', '../img/button_blink_red/add_off.png', 'onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 645, 60, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'addWMSfromList', 2, 1, 'add a WMS to the running application from a list', 'Adding WMS from List', 'img', '../img/button_blink_red/addlist_off.png', 'onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 595, 60, 24, 24, 1, '', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_list');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 2, 1, 'add a WMS to the running application from a filtered list', 'Adding WMS from filtered list', 'img', '../img/button_blink_red/add_filtered_list_off.png', 'onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 620, 60, 24, 24, 1, '', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'back', 2, 1, 'History.back()', 'Back', 'img', '../img/button_blink_red/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" ', 400, 60, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview', '', 'http://www.mapbender.org/index.php/Back');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'body', 1, 1, 'body (obligatory)', '', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, '', '', '', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'center1', 2, 1, 'Center button', 'Set map center', 'img', '../img/button_blink_red/center_off.png', 'onmouseover = "mb_regButton(''init_gui1_center'')" ', 310, 60, 24, 24, 1, '', '', '', 'mod_center1.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'changeEPSG', 2, 1, 'change EPSG, Postgres required, overview is targed for full extent', 'Change Projection', 'iframe', '../php/mod_changeEPSG.php?sessionID', 'scrolling="no" frameborder=''0'' ', 432, 25, 107, 24, 1, '', '', 'iframe', '', '', 'overview', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'changePassword_button', 2, 1, 'button: change password of logged user', 'Change Password', 'img', '../img/button_blink_red/change_password_off.png', 'onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' ', 750, 60, 24, 24, 1, 'cursor:hand', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/ChangePassword');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'closePolygon', 3, 1, 'close Polygon ', 'Close Polygon', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_closePolygon.js', '', 'mapframe1', 'measure', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'copyright', 2, 1, 'a Copyright in the map', 'Copyright', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', '', 'div', '', '', -59, 1, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/DependentDiv');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'Drag Mapsize', 'div', '', '', -59, 1, 0, 0, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'featureInfo1', 2, 1, 'FeatureInfoRequest', 'Query', 'img', '../img/button_blink_red/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')" ', 465, 60, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfo');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'forward', 2, 1, 'History.forward()', 'Forward', 'img', '../img/button_blink_red/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ', 425, 60, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview', '', 'http://www.mapbender.org/index.php/Forward');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'getArea', 3, 1, 'Calculation of area, Postgis required', 'Get Area', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_getArea.php', '', 'mapframe1', 'measure', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_blink_red/help_off.png', 'onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''', 790, 60, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'help1', 2, 1, 'button help', 'Help', 'img', '../img/button_blink_red/help_off.png', 'onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''', 790, 60, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/help');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'highlightPOI', 2, 1, 'highlight 1 to n pois in your gui with a Symbol and a special text', '', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_highlightPOI.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'layout_1', 3, 1, 'layout, background for buttons', '', 'div', '', '', 208, 58, 670, 28, 0, 'background-color:#FFFFFF;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'legend', 2, 1, 'legend', 'Legend', 'iframe', '../javascripts/mod_legend.php?sessionID&wms_legend = yes', 'frameborder=''0''', -59, 200, 180, 600, 3, '', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'loadData', 2, 1, 'IFRAME to load data', '', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'loadwmc', 2, 1, 'load workspace from WMC', 'Load a web map context document', 'img', '../img/button_blink_red/wmc_load_off.png', 'onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 895, 60, 24, 24, 1, '', '', '', 'mod_loadwmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/LoadWMC');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_blink_red/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' ', 830, 60, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'mapbender', 2, 1, 'Mapbender-Logo', '', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', -59, 1, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'mapframe1', 2, 1, 'Frame for a map', 'Mapframe', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 220, 105, 625, 400, 2, '', '', 'iframe', '', '', '', '', 'http://www.mapbender.org/index.php/Mapframe');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'measure', 2, 1, 'Measure', 'Measure distance', 'img', '../img/button_blink_red/measure_off.png', 'onmouseover = "mb_regButton(''init_mod_measure'')"', 515, 60, 24, 24, 1, '', '', '', 'mod_measure.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Measure');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'Show WMS infos', 'img', '../img/button_blink_red/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' ', 710, 60, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'navFrame', 2, 1, 'navigation mapborder', 'Navigation Frame', 'div', '', '', 0, 0, 0, 0, 10, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ', 'div', 'mod_navFrame.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/NavFrame');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'overview', 2, 1, 'OverviewFrame', 'Overview', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 15, 25, 150, 150, 2, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/Overview');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'pan1', 2, 1, 'pan', 'Pan', 'img', '../img/button_blink_red/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')"', 260, 60, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Pan');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'print1', 2, 0, 'start print GUI', 'Print', 'img', '../img/button_blink_red/print_off.png', 'onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 555, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'printPDF', 2, 1, 'start print GUI', 'Print', 'img', '../img/button_blink_red/print_off.png', 'onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 555, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Print');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'repaint', 2, 1, 'refresh a mapobject', 'Redraw', 'img', '../img/button_blink_red/repaint_off.png', 'onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' ', 360, 60, 24, 24, 1, '', '', '', 'mod_repaint.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'rubber', 3, 1, 'deletes temporary (digitized) objects', 'Rubber', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_rubber.js', '', 'mapframe1', 'measure', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'sandclock', 2, 1, 'displays a sand clock while waiting for requests', '', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'savewmc', 2, 1, 'save workspace as WMC', 'Save workspace as web map context document', 'img', '../img/button_blink_red/wmc_save_off.png', 'onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 870, 60, 24, 24, 1, '', '', '', 'mod_savewmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/SaveWMC');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'scaleSelect', 2, 1, 'Scale-Selectbox', 'Scale Select', 'select', '', 'onchange=''mod_scaleSelect(this)''', 555, 25, 100, 20, 1, '', '<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>', 'select', 'mod_scaleSel.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'scaleText', 2, 1, 'Scale-description field', 'Scale Text', 'form', '', 'onsubmit=''return mod_scaleText()''', 672, 25, 100, 30, 0, '', '<input type="text">', 'form', 'mod_scaleText.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'scalebar', 2, 1, 'scalebar', 'Scalebar', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_scalebar.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'selArea1', 2, 1, 'zoombox', 'Zoom by rectangle', 'img', '../img/button_blink_red/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')"', 285, 60, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/SelArea1');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setBBOX', 2, 1, 'set Extent for mapframe and overviewframe', '', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setBackground', 2, 0, 'switch background-wms', 'Set Background', 'form', '', '', 15, 190, 0, 0, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setBackground_all', 2, 0, 'switch all background-wms', 'Set Background', 'form', '', '', 157, 190, 40, 20, 1, '', '<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>', 'form', 'mod_setBackground_all.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setPOI2Scale', 2, 1, 'zoom to a poi (get-parameter)', '', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'mod_setPOI2Scale.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Mod_setPoi2Scale');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setScaleHint', 1, 0, 'set scaleHint for mapframes', '', 'div', '', '', 1, 1, 1, 1, 0, 'visibility:hidden;', '', 'div', 'mod_scaleHint.php', '', 'mapframe1,100,10000000', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'showCoords_div', 2, 1, 'displays coordinates by onmouseover', 'Coordinates', 'img', '../img/button_blink_red/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ', 490, 60, 24, 24, 1, '', '', '', 'mod_coords_div.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ShowCoords_div');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeConfGDE', 2, 0, 'configurable directory tree', 'Maps', 'iframe', '../php/mod_treefolderClient.php?sessionID', 'frameborder = "0" ', 0, 180, 250, 500, 0, 'visibility:visible', '', 'iframe', 'mod_treeConf.js', '', 'mapframe1', '', '');
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2', 'Maps', 'iframe', '../html/mod_treefolder2.php?sessionID', 'frameborder = "0" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomFull', 2, 1, 'zoom to full extent button', 'Display complete map', 'img', '../img/button_gray/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ', 320, 10, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomIn1', 2, 1, 'zoomIn button', 'Zoom in', 'img', '../img/button_gray/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ', 220, 10, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomOut1', 2, 1, 'zoomOut button', 'Zoom out', 'img', '../img/button_gray/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''', 245, 10, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'WMS_preferences', 2, 1, 'configure the preferences of each loaded wms', 'WMS preferences', 'img', '../img/button_blink_red/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 670, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', 'http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'addWMS', 2, 1, 'add a WMS to the running application', 'Adding WMS', 'img', '../img/button_blink_red/add_off.png', 'onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 645, 60, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'addWMSfromList', 2, 1, 'add a WMS to the running application from a list', 'Adding WMS from List', 'img', '../img/button_blink_red/addlist_off.png', 'onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 595, 60, 24, 24, 1, '', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 2, 1, 'add a WMS to the running application from a filtered list', 'Adding WMS from filtered list', 'img', '../img/button_blink_red/add_filtered_list_off.png', 'onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 620, 60, 24, 24, 1, '', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'back', 2, 1, 'History.back()', 'Back', 'img', '../img/button_blink_red/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" ', 400, 60, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview', '', 'http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'body', 1, 1, 'body (obligatory)', '', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, '', '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'center1', 2, 1, 'Center button', 'Set map center', 'img', '../img/button_blink_red/center_off.png', 'onmouseover = "mb_regButton(''init_gui1_center'')" ', 310, 60, 24, 24, 1, '', '', '', 'mod_center1.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'changeEPSG', 2, 1, 'change EPSG, Postgres required, overview is targed for full extent', 'Change Projection', 'iframe', '../php/mod_changeEPSG.php?sessionID', 'scrolling="no" frameborder=''0'' ', 432, 25, 107, 24, 1, '', '', 'iframe', '', '', 'overview', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'changePassword_button', 2, 1, 'button: change password of logged user', 'Change Password', 'img', '../img/button_blink_red/change_password_off.png', 'onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' ', 750, 60, 24, 24, 1, 'cursor:hand', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'closePolygon', 3, 1, 'close Polygon ', 'Close Polygon', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_closePolygon.js', '', 'mapframe1', 'measure', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'copyright', 2, 1, 'a Copyright in the map', 'Copyright', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', '', 'div', '', '', -59, 1, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'Drag Mapsize', 'div', '', '', -59, 1, 0, 0, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'featureInfo1', 2, 1, 'FeatureInfoRequest', 'Query', 'img', '../img/button_blink_red/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')" ', 465, 60, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'forward', 2, 1, 'History.forward()', 'Forward', 'img', '../img/button_blink_red/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ', 425, 60, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview', '', 'http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'getArea', 3, 1, 'Calculation of area, Postgis required', 'Get Area', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_getArea.php', '', 'mapframe1', 'measure', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_blink_red/help_off.png', 'onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''', 790, 60, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'help1', 2, 1, 'button help', 'Help', 'img', '../img/button_blink_red/help_off.png', 'onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''', 790, 60, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/help');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'highlightPOI', 2, 1, 'highlight 1 to n pois in your gui with a Symbol and a special text', '', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_highlightPOI.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'layout_1', 3, 1, 'layout, background for buttons', '', 'div', '', '', 208, 58, 670, 28, 0, 'background-color:#FFFFFF;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'legend', 2, 1, 'legend', 'Legend', 'iframe', '../javascripts/mod_legend.php?sessionID&wms_legend = yes', 'frameborder=''0''', -59, 200, 180, 600, 3, '', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'loadData', 2, 1, 'IFRAME to load data', '', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'loadwmc', 2, 1, 'load workspace from WMC', 'Load a web map context document', 'img', '../img/button_blink_red/wmc_load_off.png', 'onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 895, 60, 24, 24, 1, '', '', '', 'mod_loadwmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_blink_red/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' ', 830, 60, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'mapbender', 2, 1, 'Mapbender-Logo', '', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', -59, 1, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'mapframe1', 2, 1, 'Frame for a map', 'Mapframe', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 220, 105, 625, 400, 2, '', '', 'iframe', '', '', '', '', 'http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'measure', 2, 1, 'Measure', 'Measure distance', 'img', '../img/button_blink_red/measure_off.png', 'onmouseover = "mb_regButton(''init_mod_measure'')"', 515, 60, 24, 24, 1, '', '', '', 'mod_measure.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'Show WMS infos', 'img', '../img/button_blink_red/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' ', 710, 60, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'navFrame', 2, 1, 'navigation mapborder', 'Navigation Frame', 'div', '', '', 0, 0, 0, 0, 10, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ', 'div', 'mod_navFrame.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'overview', 2, 1, 'OverviewFrame', 'Overview', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 15, 25, 150, 150, 2, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'pan1', 2, 1, 'pan', 'Pan', 'img', '../img/button_blink_red/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')"', 260, 60, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'print1', 2, 0, 'start print GUI', 'Print', 'img', '../img/button_blink_red/print_off.png', 'onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 555, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'repaint', 2, 1, 'refresh a mapobject', 'Redraw', 'img', '../img/button_blink_red/repaint_off.png', 'onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' ', 360, 60, 24, 24, 1, '', '', '', 'mod_repaint.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'rubber', 3, 1, 'deletes temporary (digitized) objects', 'Rubber', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_rubber.js', '', 'mapframe1', 'measure', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'sandclock', 2, 1, 'displays a sand clock while waiting for requests', '', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'savewmc', 2, 1, 'save workspace as WMC', 'Save workspace as web map context document', 'img', '../img/button_blink_red/wmc_save_off.png', 'onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 870, 60, 24, 24, 1, '', '', '', 'mod_savewmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'scaleSelect', 2, 1, 'Scale-Selectbox', 'Scale Select', 'select', '', 'onchange=''mod_scaleSelect(this)''', 555, 25, 100, 20, 1, '', '<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>', 'select', 'mod_scaleSel.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'scaleText', 2, 1, 'Scale-description field', 'Scale Text', 'form', '', 'onsubmit=''return mod_scaleText()''', 672, 25, 100, 30, 0, '', '<input type="text">', 'form', 'mod_scaleText.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'scalebar', 2, 1, 'scalebar', 'Scalebar', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_scalebar.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'selArea1', 2, 1, 'zoombox', 'Zoom by rectangle', 'img', '../img/button_blink_red/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')"', 285, 60, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setBBOX', 2, 1, 'set Extent for mapframe and overviewframe', '', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setBackground', 2, 0, 'switch background-wms', 'Set Background', 'form', '', '', 15, 190, 0, 0, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setBackground_all', 2, 0, 'switch all background-wms', 'Set Background', 'form', '', '', 157, 190, 40, 20, 1, '', '<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>', 'form', 'mod_setBackground_all.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setPOI2Scale', 2, 1, 'zoom to a poi (get-parameter)', '', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'mod_setPOI2Scale.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Mod_setPoi2Scale');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setScaleHint', 1, 0, 'set scaleHint for mapframes', '', 'div', '', '', 1, 1, 1, 1, 0, 'visibility:hidden;', '', 'div', 'mod_scaleHint.php', '', 'mapframe1,100,10000000', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'showCoords_div', 2, 1, 'displays coordinates by onmouseover', 'Coordinates', 'img', '../img/button_blink_red/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ', 490, 60, 24, 24, 1, '', '', '', 'mod_coords_div.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeConfGDE', 2, 0, 'configurable directory tree', 'Maps', 'iframe', '../php/mod_treefolderClient.php?sessionID', 'frameborder = "0" ', 0, 180, 250, 500, 0, 'visibility:visible', '', 'iframe', 'mod_treeConf.js', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeGDE', 2, 1, 'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
-for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2', 'Maps', 'iframe', '../html/mod_treefolder2.php?sessionID', 'frameborder = "0" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeGDE_1', 2, 0, 'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers', 'Maps', 'iframe', '../html/mod_sync_treefolder_1.html', 'frameborder = "0" ', 0, 180, 250, 500, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'wfs_gazetteer', 2, 0, 'gazetteer using wfs', 'Search', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255', 'frameborder = "0" ', -50, 490, 250, 300, 0, 'visibility:visible', '', 'iframe', '', '', 'mapframe1,overview', 'wfs', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomCoords', 2, 1, 'zoom to coordinate', 'Zoom to Coordinates', 'iframe', '../php/mod_zoomCoords_en.php?sessionID', 'frameborder = "0" ', 205, 7, 220, 45, 0, '', '', 'iframe', '', '', 'mapframe1,overview', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomFull', 2, 1, 'zoom to full extent button', 'Display complete map', 'img', '../img/button_blink_red/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ', 335, 60, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomFull');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomIn1', 2, 1, 'zoomIn button', 'Zoom in', 'img', '../img/button_blink_red/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ', 210, 60, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomOut1', 2, 1, 'zoomOut button', 'Zoom out', 'img', '../img/button_blink_red/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' ', 235, 60, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomOut');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'WMS_preferences', 2, 1, 'configures the preferences of each loaded wms', 'WMS preferences', 'img', '../img/button_blue/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 604, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', 'mapframe1,treeGDE', '', 'http://www.mapbender.org/index.php/WMS_preferences');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'addWMS', 2, 1, 'add a WMS to the running application', 'Adding WMS', 'img', '../img/button_blue/add_off.png', 'onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 580, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 2, 1, 'add a WMS to the running application from a filtered list', 'Adding WMS from filtered list', 'img', '../img/button_blue/add_filtered_list_off.png', 'onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 553, 40, 28, 28, 1, 'filter:Chroma(color=#C2CBCF);', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'back', 2, 1, 'History.back()', 'Back', 'img', '../img/button_blue/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"', 398, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_back.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeGDE_1', 2, 0, 'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers', 'Maps', 'iframe', '../html/mod_sync_treefolder_1.html', 'frameborder = "0" ', 0, 180, 250, 500, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'wfs_gazetteer', 2, 0, 'gazetteer using wfs', 'Search', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255', 'frameborder = "0" ', -50, 490, 250, 300, 0, 'visibility:visible', '', 'iframe', '', '', 'mapframe1,overview', 'wfs', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomCoords', 2, 1, 'zoom to coordinate', 'Zoom to Coordinates', 'iframe', '../php/mod_zoomCoords_en.php?sessionID', 'frameborder = "0" ', 205, 7, 220, 45, 0, '', '', 'iframe', '', '', 'mapframe1,overview', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomFull', 2, 1, 'zoom to full extent button', 'Display complete map', 'img', '../img/button_blink_red/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ', 335, 60, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomIn1', 2, 1, 'zoomIn button', 'Zoom in', 'img', '../img/button_blink_red/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ', 210, 60, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomOut1', 2, 1, 'zoomOut button', 'Zoom out', 'img', '../img/button_blink_red/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' ', 235, 60, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'WMS_preferences', 2, 1, 'configures the preferences of each loaded wms', 'WMS preferences', 'img', '../img/button_blue/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 604, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', 'mapframe1,treeGDE', '', 'http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'addWMS', 2, 1, 'add a WMS to the running application', 'Adding WMS', 'img', '../img/button_blue/add_off.png', 'onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 580, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 2, 1, 'add a WMS to the running application from a filtered list', 'Adding WMS from filtered list', 'img', '../img/button_blue/add_filtered_list_off.png', 'onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 553, 40, 28, 28, 1, 'filter:Chroma(color=#C2CBCF);', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'back', 2, 1, 'History.back()', 'Back', 'img', '../img/button_blue/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"', 398, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_back.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Back');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'body', 1, 1, 'body
-(obligatory)', '', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, 'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;', '', '', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'center1', 2, 1, 'Center button', 'Set map center', 'img', '../img/button_blue/center_off.png', 'onmouseover = "mb_regButton(''init_gui1_center'')"', 308, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_center1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ReCenter');
+(obligatory)', '', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, 'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;', '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'center1', 2, 1, 'Center button', 'Set map center', 'img', '../img/button_blue/center_off.png', 'onmouseover = "mb_regButton(''init_gui1_center'')"', 308, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_center1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ReCenter');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'changePassword_button', 2, 1, 'button: change password of logged user', 'Change Password', 'img', '../img/button_blue/change_password_off.png', 'onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0''
-onmouseover=''this.src="../img/button_blue/change_password_over.png"'' onmouseout=''this.src="../img/button_blue/change_password_off.png"''', 668, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/ChangePassword');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'closePolygon', 3, 1, 'close Polygon ', '', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_closePolygon.js', '', 'mapframe1', 'measure', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'copyright', 2, 1, 'a Copyright in the map', 'Copyright', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', '', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/DependentDiv');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'Drag Mapsize', 'div', '', '', 81, -19, NULL, NULL, 2, 'background-color:#799FEB; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'dynamicOverview', 2, 1, 'oveview acts in accordance with main mapframe', '', 'div', '', '', NULL, NULL, NULL, NULL, NULL, '', '', 'div', 'mod_dynamicOverview.php', '', 'mapframe1,overview', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'Query', 'img', '../img/button_blue/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfo');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'Query', 'img', '../img/button_blue/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')"', 461, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfoTunnel');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'forward', 2, 1, 'History.forward()', 'Forward', 'img', '../img/button_blue/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"', 423, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Forward');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'gazetteerWFS', 2, 1, 'a gazetteer for user in the mapbender user map', 'Search', 'iframe', '../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', 'geometry.js', 'mapframe1,overview', 'wz-graphics', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'getArea', 3, 1, 'Calculation of area, Postgis required', '', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_getArea.php', '', 'mapframe1', 'measure', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'header_yellow', 2, 0, 'header', '', 'img', '../img/header_yellow.jpg', '', -1, -1, 833, 75, NULL, '', '', '', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_blue/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 693, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'imprint', 2, 1, 'Information about the owner of the gui', 'Imprint', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'layout_linie', 3, 0, 'layout', '', 'div', '', '', 1, 70, 830, 1, 1, 'background-color:#799FEB;font-size:1px;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'layout_linie2', 3, 0, 'layout', '', 'div', '', '', 1, 35, 830, 1, 1, 'background-color:#799FEB;font-size:1px;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'legend', 2, 1, 'legend', 'Legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'loadData', 2, 1, 'IFRAME, um Daten zu laden', '', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
+onmouseover=''this.src="../img/button_blue/change_password_over.png"'' onmouseout=''this.src="../img/button_blue/change_password_off.png"''', 668, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'closePolygon', 3, 1, 'close Polygon ', '', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_closePolygon.js', '', 'mapframe1', 'measure', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'copyright', 2, 1, 'a Copyright in the map', 'Copyright', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', '', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'Drag Mapsize', 'div', '', '', 81, -19, NULL, NULL, 2, 'background-color:#799FEB; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'dynamicOverview', 2, 1, 'oveview acts in accordance with main mapframe', '', 'div', '', '', NULL, NULL, NULL, NULL, NULL, '', '', 'div', 'mod_dynamicOverview.php', '', 'mapframe1,overview', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'Query', 'img', '../img/button_blue/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'Query', 'img', '../img/button_blue/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')"', 461, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'forward', 2, 1, 'History.forward()', 'Forward', 'img', '../img/button_blue/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"', 423, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'gazetteerWFS', 2, 1, 'a gazetteer for user in the mapbender user map', 'Search', 'iframe', '../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', 'geometry.js', 'mapframe1,overview', 'wz-graphics', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'getArea', 3, 1, 'Calculation of area, Postgis required', '', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_getArea.php', '', 'mapframe1', 'measure', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'header_yellow', 2, 0, 'header', '', 'img', '../img/header_yellow.jpg', '', -1, -1, 833, 75, NULL, '', '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_blue/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 693, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'imprint', 2, 1, 'Information about the owner of the gui', 'Imprint', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'layout_linie', 3, 0, 'layout', '', 'div', '', '', 1, 70, 830, 1, 1, 'background-color:#799FEB;font-size:1px;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'layout_linie2', 3, 0, 'layout', '', 'div', '', '', 1, 35, 830, 1, 1, 'background-color:#799FEB;font-size:1px;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'legend', 2, 1, 'legend', 'Legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'loadData', 2, 1, 'IFRAME, um Daten zu laden', '', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'loadwmc', 2, 1, 'load workspace from WMC', 'Load a web map context document', 'img', '../img/button_blue/wmc_load_off.png', 'onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
-onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 758, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_loadwmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/LoadWMC');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'logo', 2, 1, 'Logo', 'Logo', 'img', '../img/mapbender_oo.png', '', 10, 35, 129, 32, 5, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_blue/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''', 798, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'mapbender', 2, 1, 'Mapbender-Logo', '', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', 81, -19, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'mapframe1', 2, 1, 'frame for a map', 'Mapframe', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 213, 90, 608, 467, 2, '', '', 'iframe', '', '', '', '', 'http://www.mapbender.org/index.php/Mapframe');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'measure', 2, 1, 'Measure', 'Measure distance', 'img', '../img/button_blue/measure_off.png', 'onmouseover = "mb_regButton(''init_mod_measure'')"', 513, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_measure.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Measure');
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 758, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_loadwmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'logo', 2, 1, 'Logo', 'Logo', 'img', '../img/mapbender_oo.png', '', 10, 35, 129, 32, 5, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_blue/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''', 798, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'mapbender', 2, 1, 'Mapbender-Logo', '', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', 81, -19, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'mapframe1', 2, 1, 'frame for a map', 'Mapframe', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 213, 90, 608, 467, 2, '', '', 'iframe', '', '', '', '', 'http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'measure', 2, 1, 'Measure', 'Measure distance', 'img', '../img/button_blue/measure_off.png', 'onmouseover = "mb_regButton(''init_mod_measure'')"', 513, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_measure.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Measure');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'Show WMS infos', 'img', '../img/button_blue/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''" border=''0''
-onmouseover=''this.src="../img/button_blue/metadata_over.png"'' onmouseout=''this.src="../img/button_blue/metadata_off.png"''', 643, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
+onmouseover=''this.src="../img/button_blue/metadata_over.png"'' onmouseout=''this.src="../img/button_blue/metadata_off.png"''', 643, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'navFrame', 2, 1, 'navigation mapborder', 'Navigation Frame', 'div', '', '', 0, 0, 0, 0, 0, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
 <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
 <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
@@ -205,63 +312,63 @@
 <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
 <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
 <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
-<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>', 'div', 'mod_navFrame.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/NavFrame');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'overview', 2, 1, 'OverviewFrame', 'Overview', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 9, 80, 185, 130, 100, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/Overview');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'pan1', 2, 1, 'pan', 'Pan', 'img', '../img/button_blue/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')"', 258, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_pan.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Pan');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'printPDF', 2, 1, 'pdf print', 'Print', 'iframe', '../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf', 'frameborder = "0" ', 1, 1, 2, 2, 5, 'visibility:hidden', '', 'iframe', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Print');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'repaint', 2, 1, 'refresh a mapobject', 'Redraw', 'img', '../img/button_blue/repaint_off.png', 'onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)''', 358, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_repaint.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Repaint');
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>', 'div', 'mod_navFrame.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'overview', 2, 1, 'OverviewFrame', 'Overview', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 9, 80, 185, 130, 100, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'pan1', 2, 1, 'pan', 'Pan', 'img', '../img/button_blue/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')"', 258, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_pan.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'printPDF', 2, 1, 'pdf print', 'Print', 'iframe', '../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf', 'frameborder = "0" ', 1, 1, 2, 2, 5, 'visibility:hidden', '', 'iframe', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'repaint', 2, 1, 'refresh a mapobject', 'Redraw', 'img', '../img/button_blue/repaint_off.png', 'onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)''', 358, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_repaint.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Repaint');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'resizeMapsize', 2, 1, 'resize mapsize to browser window size', 'Resize Mapsize', 'img', '../img/button_blink_red/resizemapsize_off.png', 'onclick = "adjustDimension()"
-onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 838, 40, 24, 24, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_resize_mapsize.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ResizeMapsize');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'rubber', 3, 1, 'deletes temporary (digitized) objects', '', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_rubber.js', '', 'mapframe1', 'measure', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'sandclock', 2, 1, 'displays a sand clock while waiting for requests', '', 'div', '', '', 80, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'savewmc', 2, 1, 'save workspace as WMC', 'Save workspace as web map context document', 'img', '../img/button_blue/wmc_save_off.png', 'onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 733, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_savewmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/SaveWMC');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'selArea1', 2, 1, 'zoombox', 'Zoom by rectangle', 'img', '../img/button_blue/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')"', 283, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/SelArea1');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', '', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'setBackground', 2, 1, 'switch background-wms', 'Set Background', 'form', '', '', 10, 218, NULL, NULL, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'Coordinates', 'img', '../img/button_blue/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')"', 488, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', 'http://www.mapbender.org/index.php/ShowCoords_div');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'tabs', 2, 1, 'vertical tabs to handle iframes', '', 'div', '', '', 2, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', '');
+onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 838, 40, 24, 24, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_resize_mapsize.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ResizeMapsize');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'rubber', 3, 1, 'deletes temporary (digitized) objects', '', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_rubber.js', '', 'mapframe1', 'measure', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'sandclock', 2, 1, 'displays a sand clock while waiting for requests', '', 'div', '', '', 80, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'savewmc', 2, 1, 'save workspace as WMC', 'Save workspace as web map context document', 'img', '../img/button_blue/wmc_save_off.png', 'onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 733, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_savewmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'selArea1', 2, 1, 'zoombox', 'Zoom by rectangle', 'img', '../img/button_blue/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')"', 283, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', '', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'setBackground', 2, 1, 'switch background-wms', 'Set Background', 'form', '', '', 10, 218, NULL, NULL, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'Coordinates', 'img', '../img/button_blue/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')"', 488, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', 'http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'tabs', 2, 1, 'vertical tabs to handle iframes', '', 'div', '', '', 2, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'treeGDE', 2, 1, 'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'zoomFull', 2, 1, 'zoom to full extent button', 'Display complete map', 'img', '../img/button_blue/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"', 333, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomFull');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'zoomIn1', 2, 1, 'zoomIn button', 'Zoom in', 'img', '../img/button_blue/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''', 203, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'zoomOut1', 2, 1, 'zoomOut button', 'Zoom out', 'img', '../img/button_blue/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''', 231, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomOut');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'FeatureInfoRedirect', 2, 0, 'redirect featureInfoRequests in an iframe for each wms', 'Info', 'iframe', '../html/mod_blank.html', 'frameborder="0"', 83, -17, 1, 1, NULL, '', '', 'iframe', 'mod_featureInfoRedirect.php', '', '', '', '');
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2', 'Maps', 'iframe', '../html/mod_treefolder2.php?sessionID', 'frameborder = "0" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'zoomFull', 2, 1, 'zoom to full extent button', 'Display complete map', 'img', '../img/button_blue/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"', 333, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'zoomIn1', 2, 1, 'zoomIn button', 'Zoom in', 'img', '../img/button_blue/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''', 203, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'zoomOut1', 2, 1, 'zoomOut button', 'Zoom out', 'img', '../img/button_blue/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''', 231, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'FeatureInfoRedirect', 2, 0, 'redirect featureInfoRequests in an iframe for each wms', 'Info', 'iframe', '../html/mod_blank.html', 'frameborder="0"', 83, -17, 1, 1, NULL, '', '', 'iframe', 'mod_featureInfoRedirect.php', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'WMS_preferences', 2, 1, 'configures the preferences of each loaded wms', 'WMS preferences', 'img', '../img/button_gray/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''
-onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 540, 10, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', '');
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 540, 10, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'addWMS', 2, 1, 'add a WMS to the running application', 'Adding WMS', 'img', '../img/button_gray/add_off.png', 'onclick=''mod_addWMS()''
-onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 515, 10, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 2, 1, 'add a WMS to the running application from a filtered list', 'Adding WMS from filtered list', 'img', '../img/button_blink_red/add_filtered_list_off.png', 'onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 490, 10, 24, 24, 1, '', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'back', 2, 1, 'History.back()', 'Back', 'img', '../img/button_gray/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"', 360, 10, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview0', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'body', 1, 1, 'body (obligatory)', '', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, '', '', '', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'closePolygonExt', 3, 0, 'close Polygon ', 'Close Polygon', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_closePolygonExt.js', '', 'mapframe1', 'setExtRequest', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'copyright', 2, 1, 'a Copyright in the map', 'Copyright', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', '', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'digitize', 2, 1, 'Digitize tool.', 'Digitize', 'iframe', '../javascripts/mod_digitize_tab.php?sessionID', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', 'geometry.js', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'Drag Mapsize', 'div', '', '', 81, -19, NULL, NULL, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'Query', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'Query', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')"', 425, 10, 24, 24, 1, '', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'forward', 2, 1, 'History.forward()', 'Forward', 'img', '../img/button_gray/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"', 385, 10, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'gazetteerWFS', 2, 1, 'a gazetteer for user in the mapbender user map', 'Search', 'iframe', '../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', 'geometry.js', 'mapframe1,overview', 'wz-graphics', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 620, 10, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'imprint', 2, 1, 'Information about the owner of the gui', 'Imprint', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'initWmc', 2, 0, 'initialise client with wmc', '', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'mod_initWmc.php', '', 'mapframe1,overview', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_1', 3, 0, 'Warning notice', '', 'div', '', '', 150, 250, 300, 16, 100, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;', 'Development Version - Work in Progress!', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_back', 3, 1, 'layout, background for buttons', '', 'div', '', '', 360, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_featureInfo', 3, 1, 'layout, background for FeatureInfo', '', 'div', '', '', 425, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_help', 3, 1, 'layout, background for Help-button', '', 'div', '', '', 620, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_logout', 3, 1, 'layout, background for Logout-button', '', 'div', '', '', 660, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_metadata', 3, 1, 'layout, background for Metadata', '', 'div', '', '', 580, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_wms', 3, 1, 'layout, background for wms', '', 'div', '', '', 490, 10, 76, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_zoom', 3, 1, 'layout, background for Zoom-button', '', 'div', '', '', 220, 10, 126, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'legend', 2, 1, 'legend', 'Legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'loadData', 2, 1, 'IFRAME, um Daten zu laden', '', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'loadwmc', 2, 0, 'load workspace from WMC', 'Load a web map context document', 'img', '../img/button_wmc/wmc_load.png', 'onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''', 760, 10, 24, 24, 1, '', '', '', 'mod_loadwmc.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'logo', 2, 1, 'Logo', '', 'img', '../img/mapbender_logo.png', '', 20, 20, 180, 26, 5, '', '', '', '', '', '', '', '');
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 515, 10, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 2, 1, 'add a WMS to the running application from a filtered list', 'Adding WMS from filtered list', 'img', '../img/button_blink_red/add_filtered_list_off.png', 'onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', 490, 10, 24, 24, 1, '', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'back', 2, 1, 'History.back()', 'Back', 'img', '../img/button_gray/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"', 360, 10, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview0', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'body', 1, 1, 'body (obligatory)', '', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, '', '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'closePolygonExt', 3, 0, 'close Polygon ', 'Close Polygon', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_closePolygonExt.js', '', 'mapframe1', 'setExtRequest', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'copyright', 2, 1, 'a Copyright in the map', 'Copyright', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', '', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'digitize', 2, 1, 'Digitize tool.', 'Digitize', 'iframe', '../javascripts/mod_digitize_tab.php?sessionID', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', 'geometry.js', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'Drag Mapsize', 'div', '', '', 81, -19, NULL, NULL, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'Query', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'Query', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')"', 425, 10, 24, 24, 1, '', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'forward', 2, 1, 'History.forward()', 'Forward', 'img', '../img/button_gray/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"', 385, 10, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'gazetteerWFS', 2, 1, 'a gazetteer for user in the mapbender user map', 'Search', 'iframe', '../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', 'geometry.js', 'mapframe1,overview', 'wz-graphics', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 620, 10, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'imprint', 2, 1, 'Information about the owner of the gui', 'Imprint', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'initWmc', 2, 0, 'initialise client with wmc', '', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'mod_initWmc.php', '', 'mapframe1,overview', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_1', 3, 0, 'Warning notice', '', 'div', '', '', 150, 250, 300, 16, 100, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;', 'Development Version - Work in Progress!', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_back', 3, 1, 'layout, background for buttons', '', 'div', '', '', 360, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_featureInfo', 3, 1, 'layout, background for FeatureInfo', '', 'div', '', '', 425, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_help', 3, 1, 'layout, background for Help-button', '', 'div', '', '', 620, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_logout', 3, 1, 'layout, background for Logout-button', '', 'div', '', '', 660, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_metadata', 3, 1, 'layout, background for Metadata', '', 'div', '', '', 580, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_wms', 3, 1, 'layout, background for wms', '', 'div', '', '', 490, 10, 76, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_zoom', 3, 1, 'layout, background for Zoom-button', '', 'div', '', '', 220, 10, 126, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'legend', 2, 1, 'legend', 'Legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'loadData', 2, 1, 'IFRAME, um Daten zu laden', '', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'loadwmc', 2, 0, 'load workspace from WMC', 'Load a web map context document', 'img', '../img/button_wmc/wmc_load.png', 'onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''', 760, 10, 24, 24, 1, '', '', '', 'mod_loadwmc.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'logo', 2, 1, 'Logo', '', 'img', '../img/mapbender_logo.png', '', 20, 20, 180, 26, 5, '', '', '', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''
 onmouseover=''this.src="../img/button_gray/logout_over.png"''
-onmouseout=''this.src="../img/button_gray/logout_off.png"''', 660, 10, 24, 24, 1, '', '', '', '', '', '', '', '');
+onmouseout=''this.src="../img/button_gray/logout_off.png"''', 660, 10, 24, 24, 1, '', '', '', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'mapbender', 2, 1, 'Mapbender-Logo', '', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', 81, -19, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>
@@ -269,12 +376,12 @@
-</script>', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'mapframe1', 2, 1, 'frame for a map', 'Mapframe', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 230, 55, 500, 450, 2, '', '', 'iframe', '', '', '', '', '');
+</script>', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'mapframe1', 2, 1, 'frame for a map', 'Mapframe', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 230, 55, 500, 450, 2, '', '', 'iframe', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'Show WMS infos', 'img', '../img/button_gray/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''"
 border=''0''
 onmouseover=''this.src="../img/button_gray/metadata_over.png"''
-onmouseout=''this.src="../img/button_gray/metadata_off.png"''', 580, 10, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', '');
+onmouseout=''this.src="../img/button_gray/metadata_off.png"''', 580, 10, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'navFrame', 2, 1, 'navigation mapborder', 'Navigation Frame', 'div', '', '', 0, 0, NULL, NULL, NULL, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
 <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
 <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
@@ -283,13 +390,13 @@
 <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
 <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
 <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>
-', 'div', 'mod_navFrame.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'overview', 2, 1, 'OverviewFrame', 'Overview', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 30, 65, 150, 130, 100, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'pan1', 2, 1, 'pan', 'Pan', 'img', '../img/button_gray/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')"', 270, 10, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'printPDF', 2, 1, 'pdf print', 'Print', 'iframe', '../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf', 'frameborder = "0" ', 1, 1, 2, 2, 5, 'visibility:hidden', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'rubberExt', 3, 1, 'deletes temporary (digitized) objects', 'Rubber', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_rubberExt.js', '', 'mapframe1', 'setExtRequest', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'sandclock', 2, 1, 'displays a sand clock while waiting for requests', '', 'div', '', '', 80, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'savewmc', 2, 0, 'save workspace as WMC', 'Save workspace as web map context document', 'img', '../img/button_wmc/wmc_save.png', 'onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''', 730, 10, 24, 24, 1, '', '', '', 'mod_savewmc.php', '', 'mapframe1', '', '');
+', 'div', 'mod_navFrame.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'overview', 2, 1, 'OverviewFrame', 'Overview', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 30, 65, 150, 130, 100, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'pan1', 2, 1, 'pan', 'Pan', 'img', '../img/button_gray/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')"', 270, 10, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'printPDF', 2, 1, 'pdf print', 'Print', 'iframe', '../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf', 'frameborder = "0" ', 1, 1, 2, 2, 5, 'visibility:hidden', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'rubberExt', 3, 1, 'deletes temporary (digitized) objects', 'Rubber', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_rubberExt.js', '', 'mapframe1', 'setExtRequest', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'sandclock', 2, 1, 'displays a sand clock while waiting for requests', '', 'div', '', '', 80, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'savewmc', 2, 0, 'save workspace as WMC', 'Save workspace as web map context document', 'img', '../img/button_wmc/wmc_save.png', 'onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''', 730, 10, 24, 24, 1, '', '', '', 'mod_savewmc.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'scaleSelect', 2, 0, 'Scale-Selectbox', 'Scale Select', 'select', '', 'onchange=''mod_scaleSelect(this)''', 555, 25, 100, 20, 1, '', '<option value = ''''>Scale</option>
 <option value=''100''>1 : 100</option>
 <option value=''250''>1 : 250</option>
@@ -311,403 +418,406 @@
 <option value=''700000''>1 : 700000</option>
 <option value=''800000''>1 : 800000</option>
 <option value=''900000''>1 : 900000</option>
-<option value=''1000000''>1 : 1000000</option>', 'select', 'mod_scaleSel.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'selArea1', 2, 1, 'zoombox', 'Zoom by rectangle', 'img', '../img/button_gray/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')"', 295, 10, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', '', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', '');
+<option value=''1000000''>1 : 1000000</option>', 'select', 'mod_scaleSel.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'selArea1', 2, 1, 'zoombox', 'Zoom by rectangle', 'img', '../img/button_gray/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')"', 295, 10, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', '', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setBackground', 2, 1, 'switch background-wms', 'Set Background', 'form', '', '', 30, 210, NULL, NULL, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12''
-value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setSpatialRequest', 2, 1, 'Spatial Request', '', 'div', '', '', 1, 1, 1, 1, 1, 'visibility:hidden;', '', 'div', '../javascripts/mod_wfs_SpatialRequest.php', 'geometry.js', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'Coordinates', 'img', '../img/button_gray/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ', 450, 10, 24, 24, 1, '', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'showLoggedUser', 2, 0, 'Displays current user', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'tabs', 1, 1, 'vertical tabs to handle iframes', '', 'div', '', '', 10, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', '');
+value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setSpatialRequest', 2, 1, 'Spatial Request', '', 'div', '', '', 1, 1, 1, 1, 1, 'visibility:hidden;', '', 'div', '../javascripts/mod_wfs_SpatialRequest.php', 'geometry.js', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'Coordinates', 'img', '../img/button_gray/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ', 450, 10, 24, 24, 1, '', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'showLoggedUser', 2, 0, 'Displays current user', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'tabs', 1, 1, 'vertical tabs to handle iframes', '', 'div', '', '', 10, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'treeGDE', 2, 1, 'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
-for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2', 'Maps', 'iframe', '../html/mod_treefolder2.php?sessionID', 'frameborder = "0" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfs', 2, 1, 'wfs request and result handling', '', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'wfs.js', '../extensions/wz_jsgraphics.js', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfs_conf', 2, 1, 'get all wfs_conf-params', '', 'iframe', '../php/mod_wfs.php', 'frameborder = "0"', 1, 1, 1, 1, 0, 'visibility:hidden', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfsresult', 2, 1, 'display the list of wfs results', '', 'iframe', '../html/mod_blank.html', 'frameborder = "0"', 10, 730, 200, 150, 4, '', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomFull', 2, 1, 'zoom to full extent button', 'Display complete map', 'img', '../img/button_gray/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"', 320, 10, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomIn1', 2, 1, 'zoomIn button', 'Zoom in', 'img', '../img/button_gray/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''', 220, 10, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomOut1', 2, 1, 'zoomOut button', 'Zoom out', 'img', '../img/button_gray/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''', 245, 10, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'AdminFrame', 2, 1, 'the frame for administration modules', '', 'iframe', '', 'frameborder = "0"', 220, 20, 800, 800, NULL, '', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'CreateTreeGDE', 2, 1, 'create a foldertree for a individual geodataexplorer', 'Create treeGDE', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 810, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'CREATE TREE_GDE', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 950, 250, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT WMS-METADATA', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Group_Gui', 2, 1, 'allocate groups to guis', '', 'a', '', 'href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ', 10, 610, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Group_User', 2, 1, 'allocate groups to user', '', 'a', '', 'href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ', 10, 550, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'GROUP -> USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Group_filteredGui', 2, 1, 'allocate Groups to the guis of this admin', '', 'a', '', 'href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ', 10, 710, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Gui_Group', 2, 1, 'allocate guis to groups', '', 'a', '', 'href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ', 10, 250, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Gui_User', 2, 1, 'allocate a gui to user', '', 'a', '', 'href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ', 10, 190, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'User_Group', 2, 1, 'allocat user to groups', '', 'a', '', 'href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ', 10, 430, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'body', 1, 1, 'navigation', '', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 0, 0, 0, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteGui', 2, 1, 'delete gui', '', 'a', '', 'href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ', 10, 150, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteWFS', 2, 1, 'delete WFS', 'Delete WFS', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 890, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWFS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteWMS', 2, 1, 'delete wms', 'Delete WMS completely', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 110, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'delete_filteredGui', 2, 1, 'delete guis of this admin', 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 790, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editElements', 2, 1, 'edit gui elements', 'Edit GUI elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 170, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'EDIT GUI-ELEMENTS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editFilteredGroup', 2, 1, 'edit group of this admin', 'Create and edit group', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 10, 530, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editFilteredUser', 2, 1, 'save, edit, delete user where this admin is owner', 'Create and edit user', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 10, 350, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editGUI_WMS', 2, 1, 'edit the elements of the gui', 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 90, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT GUI-WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editGroup', 2, 1, 'edit group', '', 'a', '', 'href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ', 10, 510, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editUser', 2, 1, 'save, edit, delete user', '', 'a', '', 'href = "../php/mod_editUser.php?sessionID" target="AdminFrame"', 10, 330, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'exportGUI', 2, 1, 'export gui, create SQLL', 'export GUI, create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 310, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EXPORT GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGoup_filteredUser', 2, 1, 'allocate the groups of this admin to user where the admin is owner', 'Add several users to one group', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 10, 590, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> myUSER ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGroup_Gui', 2, 1, 'allocate groups of this admin to guis', '', 'a', '', 'href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ', 10, 750, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGroup_User', 2, 1, 'allocate groups of this admin to user', '', 'a', '', 'href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ', 10, 690, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGroup_filteredGui', 2, 1, 'allocate groups of this admin to guis of this admin', 'Allow one group access to several GUIs', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 10, 730, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_Group', 2, 1, 'allocate guis to groups', '', 'a', '', 'href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ', 10, 270, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> GROUP ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_filteredGroup', 2, 1, 'allocate guis of this admin to groups where this admin is owner', 'Allow several groups access to one GUI', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 10, 290, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_filteredUser', 2, 1, 'allocate the user where the admin is owner to his guis ', 'Allow several users access to one GUI ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 10, 230, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_user', 2, 1, 'allocate the guis of this admin to a user', '', 'a', '', 'href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ', 10, 210, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> USER ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_Group', 2, 1, 'allocate user of this admin to groups', '', 'a', '', 'href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ', 10, 670, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_Gui', 2, 1, 'allocate user of this admin to guis', '', 'a', '', 'href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ', 10, 770, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_filteredGroup', 2, 1, 'allocate user where this admin is owner to groups where this admin is owner', 'Add one user to serveral groups', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 10, 490, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_filteredGui', 2, 1, 'allocate admins user to guis of this admin', 'Allow one user to access several GUIs', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 10, 410, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'getStyles', 2, 0, 'load styles from wms', '', 'a', '', 'href = "../php/mod_getStyles.php?sessionID" target = "AdminFrame" ', 10, 890, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GET_STYLES', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'group_filteredUser', 2, 1, 'allocate groups to user where this admin is owner', '', 'a', '', 'href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ', 10, 570, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'gui_filteredGroup', 2, 1, 'allocate guis to groups of this admin', '', 'a', '', 'href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ', 10, 650, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'gui_filteredUser', 2, 1, 'allocate guis to user of this admin', '', 'a', '', 'href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ', 10, 630, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'gui_owner', 2, 1, 'set owner', 'Edit GUI assign to user', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ', 10, 830, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> OWNER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'loadWFS', 2, 1, 'load capabilities in a gui', 'Load WFS Capabilities into a GUI', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 850, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/WFS_Konfiguration');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'loadWMS', 2, 1, 'load capabilities in a gui', 'Load WMS', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 30, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'loadWMSList', 2, 1, 'load wms from a list', 'Link WMS into GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 50, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD myWMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''', 180, 2, 24, 24, 1, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'myGUIlist', 2, 1, 'go back to your GUI list', 'Move back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ', 150, 2, 24, 24, 1, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'newGui', 2, 1, 'create a new gui', 'Create new GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 130, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'NEW GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'orphanWMS', 2, 1, 'display orphaned WMS', 'Delete orphaned WMS', 'a', '', 'href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"', 10, 930, 200, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'ORPHAN WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'owsproxy', 2, 1, 'secure services', 'OWSPROXY', 'a', '', 'href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"', 10, 910, 200, 20, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'rename_copy_Gui', 2, 1, 'rename and copy gui', 'Rename / copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 470, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'RENAME COPY GUI', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'showLoggedUser', 2, 1, 'displays the logged admin', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, NULL, '', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'updateWMSs', 2, 1, 'edit the elements of the gui', 'Update WMS', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 70, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'UPDATE WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'user_filteredGroup', 2, 1, 'allocate user to groups where this admin is owner', '', 'a', '', 'href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ', 10, 450, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> myGROUP', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'user_filteredGui', 2, 1, 'allocate guis of this admin to user', '', 'a', '', 'href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ', 10, 390, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER-> myGUI', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'user_gui', 2, 1, 'allocate guis to user', '', 'a', '', 'href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ', 10, 370, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> GUI ', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'wfs_conf', 2, 1, 'create and edit a gazetteer module', 'Configure WFS', 'a', '', 'href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"', 10, 870, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'WFS CONF', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'wfs_gui', 2, 1, 'edit wfs settings', 'Assign WFS conf to gui', 'a', '', 'href = "../javascripts/mod_wfs_client.html" target="AdminFrame"', 10, 1000, 250, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'asign WFS conf to gui', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'AdminFrame', 2, 1, 'Bereich für Administrationsmodule', '', 'iframe', '', 'frameborder = "0"', 200, 20, 980, 800, NULL, '', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'CreateTreeGDE', 2, 1, 'Ordnerbaum konfigurieren', 'Create treeGDE', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 8, 280, 190, 20, 5, '', 'Ordnerbaum konfigurieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'body', 1, 1, 'Navigation', '', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 180, 20, 0, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'deleteWMS', 2, 1, '!Vollständig löschen!', 'Delete WMS completely', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 8, 100, 190, 20, 5, '', '!Vollständig löschen!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'delete_filteredGui', 2, 1, 'GUI löschen', 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 110, 240, 80, 20, 5, '', 'GUI löschen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editElements', 2, 1, 'Oberflächenelemente editieren', 'Edit GUI elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 8, 260, 190, 20, 5, '', 'GUI-Elemente editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editFilteredGroup', 2, 1, 'Gruppe anlegen und editieren', 'Create and edit group', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 8, 400, 190, 20, 10, '', 'Gruppe anlegen und editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editFilteredUser', 2, 1, 'Benutzer anlegen und editieren', 'Create and edit user', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 8, 380, 190, 20, 10, '', 'Benutzer anlegen und editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editGUI_WMS', 2, 1, 'WMS GUI Einstellungen', 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 8, 180, 190, 20, 5, '', 'WMS GUI Einstellungen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'exportGUI', 2, 1, 'Oberfläche (GUI) exportieren, SQL erzeugen', 'export GUI, create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 8, 300, 190, 20, 10, '', 'GUI exportieren (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGoup_filteredUser', 2, 1, 'Gruppe mit Benutzern bestücken', 'Add several users to one group', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 8, 440, 190, 20, 10, '', 'Gruppe mit Benutzern bestücken ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGroup_filteredGui', 2, 1, 'Einzelner Gruppe mehrere Oberflaechen zuordnen', 'Allow one group access to several GUIs', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 8, 570, 190, 25, 10, '', 'Einzelner Gruppe mehrere <br>GUIs zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredGroup', 2, 1, 'Einzelner Oberfläche mehrere Gruppen zuordnen', 'Allow several groups access to one GUI', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 8, 605, 190, 25, 10, '', 'Einzelner GUI mehrere<br> Gruppen zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredUser', 2, 1, 'Oberfläche mehreren Benutzer zuordnen ', 'Allow several users access to one GUI ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 8, 535, 190, 25, 10, '', 'GUI mehreren Benutzern <br> zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredUser_filteredGroup', 2, 1, 'Benutzer in Gruppen eintragen', 'Add one user to serveral groups', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 8, 420, 190, 20, 10, '', 'Benutzer in Gruppen eintragen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredUser_filteredGui', 2, 1, 'Einem Nutzer Zugriff auf mehrere Oberflächen erteilen', 'Allow one user to access several GUIs', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 8, 500, 190, 25, 10, '', 'Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'gui_owner', 2, 1, 'GUI editieren Benutzer zuordnen', 'Edit GUI assign to user', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ', 8, 640, 190, 20, 10, '', 'GUI editieren Benutzer zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_Configure_WMS_Access', 3, 1, 'Hintergrund WMS Zuordnung', 'Configure WMS Access', 'div', '', '', 5, 137, 193, 66, 2, '', ' WMS Zuordnung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_GUI_Management', 3, 1, 'Hintergrund Oberflächenverwaltung', 'GUI Management', 'div', '', '', 5, 217, 193, 126, 2, '', ' GUI-Verwaltung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_User_Authorization', 3, 1, 'Hintergrund Benutzerzugriff erteilen', 'Authorization ', 'div', '', '', 5, 477, 193, 196, 2, '', ' Benutzerzugriff erteilen', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_User_Management', 3, 1, 'Hintergrund Benutzerverwaltung', 'User Management', 'div', '', '', 5, 357, 193, 106, 2, '', ' Benutzerverwaltung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_WMS_Management', 3, 1, 'Hintergrund WMS Management', 'WMS Management', 'div', '', '', 5, 37, 193, 86, 2, '', ' WMS Verwaltung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadWMS', 2, 1, 'Capabilities hochladen', 'Load WMS', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 8, 60, 190, 20, 5, '', 'Capabilities hochladen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadWMSList', 2, 1, 'WMS in GUI einbinden', 'Link WMS into GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 8, 160, 190, 20, 5, '', 'WMS in GUI einbinden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'myGUIlist', 2, 1, 'Zurück zur eigenen GUI Liste', 'Move back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'newGui', 2, 1, 'GUI erzeugen', 'Create new GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 8, 240, 85, 20, 5, '', 'GUI erzeugen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'rename_copy_Gui', 2, 1, 'GUI umbenennen/ kopieren', 'Rename / copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 8, 320, 190, 20, 10, '', 'GUI umbenennen/kopieren', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'showLoggedUser', 2, 1, 'Anzeige des eingeloggten Benutzers', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'updateWMSs', 2, 1, 'Hochgeladene aktualisieren', 'Update WMS', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 8, 80, 190, 20, 5, '', 'Hochgeladene aktualisieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'AdminFrame', 2, 1, 'the frame for administration modules', '', 'iframe', '', 'frameborder = "0"', 200, 20, 800, 800, 0, '', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'CreateTreeGDE', 2, 1, 'TreeGDE set up', 'Create treeGDE', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 8, 280, 190, 20, 5, '', 'Create treeGDE', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'body', 1, 1, 'navigation', '', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 0, 0, 0, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'deleteWMS', 2, 1, '!Delete WMS completely!', 'Delete WMS completely', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 8, 100, 190, 20, 5, '', '!Delete WMS completely!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'delete_filteredGui', 2, 1, 'Delete GUI', 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 120, 240, 80, 20, 5, '', 'Delete GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editElements', 2, 1, 'Edit GUI elements', 'Edit GUI elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 8, 260, 190, 20, 5, '', 'Edit GUI elements', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editFilteredGroup', 2, 1, 'Create and edit group', 'Create and edit group', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 8, 400, 190, 20, 10, '', 'Create and edit group', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editFilteredUser', 2, 1, 'Create and edit user', 'Create and edit user', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 8, 380, 190, 20, 10, '', 'Create and edit user', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editGUI_WMS', 2, 1, 'WMS GUI settings', 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 8, 180, 190, 20, 5, '', 'WMS GUI settings', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'exportGUI', 2, 1, 'export GUI, create SQL', 'export GUI, create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 8, 300, 190, 20, 10, '', 'Export GUI (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGoup_filteredUser', 2, 1, 'Add several users to one group', 'Add several users to one group', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 8, 440, 190, 20, 10, '', 'Add several users to one group ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGroup_filteredGui', 2, 1, 'Allow one group access to several GUIs', 'Allow one group access to several GUIs', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 8, 570, 190, 25, 10, '', 'Allow one group access to <br> several GUIs', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGui_filteredGroup', 2, 1, 'Allow several groups access to one GUI', 'Allow several groups access to one GUI', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 8, 605, 190, 25, 10, '', 'Allow several groups access <br> to one GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGui_filteredUser', 2, 1, 'Allow several users access to one GUI ', 'Allow several users access to one GUI ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 8, 535, 190, 25, 10, '', 'Allow several users access to <br> one GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredUser_filteredGroup', 2, 1, 'Add one user to serveral groups', 'Add one user to serveral groups', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 8, 420, 190, 20, 10, '', 'Add one user to serveral groups', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredUser_filteredGui', 2, 1, 'Allow one user to access several GUIs', 'Allow one user to access several GUIs', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 8, 500, 190, 25, 10, '', 'Allow one user to access <br> several GUIs', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'gui_owner', 2, 1, 'Edit GUI assign to user', 'Edit GUI assign to user', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame"  ', 8, 640, 190, 20, 10, '', 'Edit GUI assign to user', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_Configure_WMS_Access', 3, 1, 'Configure WMS Access', 'Configure WMS Access', 'div', '', '', 5, 137, 193, 66, 2, '', ' Configure WMS Access', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_GUI_Management', 3, 1, 'GUI Management caption', 'GUI Management', 'div', '', '', 5, 217, 193, 126, 2, '', ' GUI Management ', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_User_Authorization', 3, 1, 'Authorization caption', 'Authorization ', 'div', '', '', 5, 477, 193, 186, 2, '', ' Authorization', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_User_Management', 3, 1, 'User Management caption', 'User Management', 'div', '', '', 5, 357, 193, 106, 2, '', ' User Management ', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_WMS_Management', 3, 1, 'WMS Management caption', 'WMS Management', 'div', '', '', 5, 37, 193, 86, 2, '', ' WMS Management', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" ', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadWMS', 2, 1, 'Load Capabilities', 'Load WMS', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 8, 60, 190, 20, 5, '', 'Load WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadWMSList', 2, 1, 'Link WMS into GUI', 'Link WMS into GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 8, 160, 190, 20, 5, '', 'Link WMS into GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'myGUIlist', 2, 1, 'go back to your GUI list', 'Move back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'newGui', 2, 1, 'Create new GUI', 'Create new GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 8, 240, 110, 20, 5, '', 'Create new GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'rename_copy_Gui', 2, 1, 'Rename/ copy GUI', 'Rename / copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 8, 320, 190, 20, 10, '', 'Rename / copy GUI', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'showLoggedUser', 2, 1, 'Logged User:', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'updateWMSs', 2, 1, 'Update with Capabilities', 'Update WMS', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 8, 80, 190, 20, 5, '', 'Update WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'AdminFrame', 2, 1, 'Bereich für Administrationsmodule', '', 'iframe', '', 'frameborder = "0"', 210, 25, 800, 800, 12, '', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'CreateTreeGDE', 2, 1, 'Ordnerbaum konfigurieren', 'Create treeGDE', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 533, 200, 20, 5, '', 'Ordnerbaum konfigurieren', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 275, 200, 20, 5, '', 'WMS Metadaten', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_WMS_Metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'body', 1, 1, 'Navigation', '', 'body', '', 'onload=''mod_adminNavigation_init()''', NULL, NULL, NULL, NULL, NULL, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'deleteWFS', 2, 1, 'WFS löschen', 'Delete WFS', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 393, 200, 20, 5, '', 'WFS löschen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWFS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'deleteWMS', 2, 1, '!Vollständig löschen!', '!Delete WMS completely!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 200, 20, 5, '', 'WMS löschen!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'delete_filteredGui', 2, 1, 'GUI löschen', 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 491, 200, 20, 5, '', 'GUI löschen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'editElements', 2, 1, 'Oberflächenelemente editieren', 'Edit GUI Elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 511, 200, 25, 5, '', 'GUI editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'editGUI_WMS', 2, 1, 'WMS GUI Einstellungen', 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 218, 200, 20, 5, '', 'WMS Einstellungen ändern', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'exportGUI', 2, 1, 'GUI exportieren, SQL erzeugen', 'Export GUI (SQL), create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 554, 200, 25, 10, 'x', 'GUI exportieren (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'filteredWms_layer_topic', 2, 1, 'allocate topics to layers of wms of this user', 'allocate topics to layers of wms of this user', 'a', '', 'href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ', 10, 295, 200, 20, 5, '', 'Kategoriezuordnung', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Topic_/_Category');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_Configure_WMS_Access', 3, 1, 'Hintergrund WMS Zuordnung', 'WMS Assignment', 'div', '', '', 1, 175, 210, 63, 2, '', 'WMS Zuordnung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_GUI_Management', 3, 1, 'Oberflächenverwaltung', 'GUI Management', 'div', '', '', 1, 448, 210, 153, 2, '', 'GUI Verwaltung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_Metadata', 3, 1, 'Metadateneditor Caption', 'Metadata', 'div', '', '', 1, 252, 210, 63, 2, '', 'Metadaten', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_WFS_Management', 3, 1, 'WFS Verwaltung', 'WFS Management', 'div', '', '', 1, 330, 210, 103, 2, '', 'WFS Verwaltung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_WMS_Management', 3, 1, 'Dienstverwaltung Beschriftung', 'WMS Management', 'div', '', '', 0, 37, 210, 123, 2, '', 'WMS Verwaltung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWFS', 2, 1, 'WFS Capabilities in eine GUI laden', 'Load WFS Capabilities into a GUI', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 353, 200, 20, 5, '', 'WFS laden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/LoadWFS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWMS', 2, 1, 'Capabilities hochladen', 'Load WMS', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 200, 20, 5, '', 'WMS laden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWMSList', 2, 1, 'WMS in GUI einbinden', 'Assign WMS to a GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 198, 200, 20, 5, '', 'WMS einbinden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'myGUIlist', 2, 1, 'Zurück zur eigenen GUI Liste', 'Move back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'newGui', 2, 1, 'GUI erzeugen', 'New GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 471, 200, 20, 5, '', 'GUI erzeugen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2', 'Maps', 'iframe', '../html/mod_treefolder2.php?sessionID', 'frameborder = "0" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfs', 2, 1, 'wfs request and result handling', '', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'wfs.js', '../extensions/wz_jsgraphics.js', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfs_conf', 2, 1, 'get all wfs_conf-params', '', 'iframe', '../php/mod_wfs.php', 'frameborder = "0"', 1, 1, 1, 1, 0, 'visibility:hidden', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomFull', 2, 1, 'zoom to full extent button', 'Display complete map', 'img', '../img/button_gray/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"', 320, 10, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomIn1', 2, 1, 'zoomIn button', 'Zoom in', 'img', '../img/button_gray/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''', 220, 10, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomOut1', 2, 1, 'zoomOut button', 'Zoom out', 'img', '../img/button_gray/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''', 245, 10, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'AdminFrame', 2, 1, 'the frame for administration modules', '', 'iframe', '', 'frameborder = "0"', 220, 20, 800, 800, NULL, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'CreateTreeGDE', 2, 1, 'create a foldertree for a individual geodataexplorer', 'Create treeGDE', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 810, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'CREATE TREE_GDE', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 950, 250, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT WMS-METADATA', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Group_Gui', 2, 1, 'allocate groups to guis', '', 'a', '', 'href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ', 10, 610, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Group_User', 2, 1, 'allocate groups to user', '', 'a', '', 'href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ', 10, 550, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'GROUP -> USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Group_filteredGui', 2, 1, 'allocate Groups to the guis of this admin', '', 'a', '', 'href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ', 10, 710, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Gui_Group', 2, 1, 'allocate guis to groups', '', 'a', '', 'href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ', 10, 250, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Gui_User', 2, 1, 'allocate a gui to user', '', 'a', '', 'href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ', 10, 190, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'User_Group', 2, 1, 'allocat user to groups', '', 'a', '', 'href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ', 10, 430, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'body', 1, 1, 'navigation', '', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 0, 0, 0, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteGui', 2, 1, 'delete gui', '', 'a', '', 'href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ', 10, 150, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteWFS', 2, 1, 'delete WFS', 'Delete WFS', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 890, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteWMS', 2, 1, 'delete wms', 'Delete WMS completely', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 110, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'delete_filteredGui', 2, 1, 'delete guis of this admin', 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 790, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editElements', 2, 1, 'edit gui elements', 'Edit GUI elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 170, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'EDIT GUI-ELEMENTS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editFilteredGroup', 2, 1, 'edit group of this admin', 'Create and edit group', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 10, 530, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editFilteredUser', 2, 1, 'save, edit, delete user where this admin is owner', 'Create and edit user', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 10, 350, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editGUI_WMS', 2, 1, 'edit the elements of the gui', 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 90, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT GUI-WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editGroup', 2, 1, 'edit group', '', 'a', '', 'href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ', 10, 510, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editUser', 2, 1, 'save, edit, delete user', '', 'a', '', 'href = "../php/mod_editUser.php?sessionID" target="AdminFrame"', 10, 330, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'exportGUI', 2, 1, 'export gui, create SQLL', 'export GUI, create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 310, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EXPORT GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGoup_filteredUser', 2, 1, 'allocate the groups of this admin to user where the admin is owner', 'Add several users to one group', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 10, 590, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> myUSER ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGroup_Gui', 2, 1, 'allocate groups of this admin to guis', '', 'a', '', 'href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ', 10, 750, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGroup_User', 2, 1, 'allocate groups of this admin to user', '', 'a', '', 'href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ', 10, 690, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGroup_filteredGui', 2, 1, 'allocate groups of this admin to guis of this admin', 'Allow one group access to several GUIs', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 10, 730, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_Group', 2, 1, 'allocate guis to groups', '', 'a', '', 'href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ', 10, 270, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> GROUP ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_filteredGroup', 2, 1, 'allocate guis of this admin to groups where this admin is owner', 'Allow several groups access to one GUI', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 10, 290, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_filteredUser', 2, 1, 'allocate the user where the admin is owner to his guis ', 'Allow several users access to one GUI ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 10, 230, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_user', 2, 1, 'allocate the guis of this admin to a user', '', 'a', '', 'href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ', 10, 210, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> USER ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_Group', 2, 1, 'allocate user of this admin to groups', '', 'a', '', 'href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ', 10, 670, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_Gui', 2, 1, 'allocate user of this admin to guis', '', 'a', '', 'href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ', 10, 770, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_filteredGroup', 2, 1, 'allocate user where this admin is owner to groups where this admin is owner', 'Add one user to serveral groups', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 10, 490, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_filteredGui', 2, 1, 'allocate admins user to guis of this admin', 'Allow one user to access several GUIs', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 10, 410, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'getStyles', 2, 0, 'load styles from wms', '', 'a', '', 'href = "../php/mod_getStyles.php?sessionID" target = "AdminFrame" ', 10, 890, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GET_STYLES', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'group_filteredUser', 2, 1, 'allocate groups to user where this admin is owner', '', 'a', '', 'href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ', 10, 570, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'gui_filteredGroup', 2, 1, 'allocate guis to groups of this admin', '', 'a', '', 'href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ', 10, 650, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'gui_filteredUser', 2, 1, 'allocate guis to user of this admin', '', 'a', '', 'href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ', 10, 630, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'gui_owner', 2, 1, 'set owner', 'Edit GUI assign to user', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ', 10, 830, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> OWNER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'loadWFS', 2, 1, 'load capabilities in a gui', 'Load WFS Capabilities into a GUI', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 850, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/WFS_Konfiguration');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'loadWMS', 2, 1, 'load capabilities in a gui', 'Load WMS', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 30, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'loadWMSList', 2, 1, 'load wms from a list', 'Link WMS into GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 50, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD myWMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''', 180, 2, 24, 24, 1, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'myGUIlist', 2, 1, 'go back to your GUI list', 'Move back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ', 150, 2, 24, 24, 1, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'newGui', 2, 1, 'create a new gui', 'Create new GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 130, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'NEW GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'orphanWMS', 2, 1, 'display orphaned WMS', 'Delete orphaned WMS', 'a', '', 'href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"', 10, 930, 200, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'ORPHAN WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'owsproxy', 2, 1, 'secure services', 'OWSPROXY', 'a', '', 'href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"', 10, 910, 200, 20, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'rename_copy_Gui', 2, 1, 'rename and copy gui', 'Rename / copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 470, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'RENAME COPY GUI', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'showLoggedUser', 2, 1, 'displays the logged admin', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, NULL, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'updateWMSs', 2, 1, 'edit the elements of the gui', 'Update WMS', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 70, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'UPDATE WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'user_filteredGroup', 2, 1, 'allocate user to groups where this admin is owner', '', 'a', '', 'href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ', 10, 450, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> myGROUP', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'user_filteredGui', 2, 1, 'allocate guis of this admin to user', '', 'a', '', 'href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ', 10, 390, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER-> myGUI', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'user_gui', 2, 1, 'allocate guis to user', '', 'a', '', 'href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ', 10, 370, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> GUI ', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'wfs_conf', 2, 1, 'create and edit a gazetteer module', 'Configure WFS', 'a', '', 'href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"', 10, 870, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'WFS CONF', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'wfs_gui', 2, 1, 'edit wfs settings', 'Assign WFS conf to gui', 'a', '', 'href = "../javascripts/mod_wfs_client.html" target="AdminFrame"', 10, 1000, 250, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'asign WFS conf to gui', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'AdminFrame', 2, 1, 'Bereich für Administrationsmodule', '', 'iframe', '', 'frameborder = "0"', 200, 20, 980, 800, NULL, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'CreateTreeGDE', 2, 1, 'Ordnerbaum konfigurieren', 'Create treeGDE', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 8, 280, 190, 20, 5, '', 'Ordnerbaum konfigurieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'body', 1, 1, 'Navigation', '', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 180, 20, 0, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'deleteWMS', 2, 1, '!Vollständig löschen!', 'Delete WMS completely', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 8, 100, 190, 20, 5, '', '!Vollständig löschen!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'delete_filteredGui', 2, 1, 'GUI löschen', 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 110, 240, 80, 20, 5, '', 'GUI löschen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editElements', 2, 1, 'Oberflächenelemente editieren', 'Edit GUI elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 8, 260, 190, 20, 5, '', 'GUI-Elemente editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editFilteredGroup', 2, 1, 'Gruppe anlegen und editieren', 'Create and edit group', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 8, 400, 190, 20, 10, '', 'Gruppe anlegen und editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editFilteredUser', 2, 1, 'Benutzer anlegen und editieren', 'Create and edit user', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 8, 380, 190, 20, 10, '', 'Benutzer anlegen und editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editGUI_WMS', 2, 1, 'WMS GUI Einstellungen', 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 8, 180, 190, 20, 5, '', 'WMS GUI Einstellungen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'exportGUI', 2, 1, 'Oberfläche (GUI) exportieren, SQL erzeugen', 'export GUI, create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 8, 300, 190, 20, 10, '', 'GUI exportieren (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGoup_filteredUser', 2, 1, 'Gruppe mit Benutzern bestücken', 'Add several users to one group', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 8, 440, 190, 20, 10, '', 'Gruppe mit Benutzern bestücken ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGroup_filteredGui', 2, 1, 'Einzelner Gruppe mehrere Oberflaechen zuordnen', 'Allow one group access to several GUIs', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 8, 570, 190, 25, 10, '', 'Einzelner Gruppe mehrere <br>GUIs zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredGroup', 2, 1, 'Einzelner Oberfläche mehrere Gruppen zuordnen', 'Allow several groups access to one GUI', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 8, 605, 190, 25, 10, '', 'Einzelner GUI mehrere<br> Gruppen zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredUser', 2, 1, 'Oberfläche mehreren Benutzer zuordnen ', 'Allow several users access to one GUI ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 8, 535, 190, 25, 10, '', 'GUI mehreren Benutzern <br> zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredUser_filteredGroup', 2, 1, 'Benutzer in Gruppen eintragen', 'Add one user to serveral groups', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 8, 420, 190, 20, 10, '', 'Benutzer in Gruppen eintragen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredUser_filteredGui', 2, 1, 'Einem Nutzer Zugriff auf mehrere Oberflächen erteilen', 'Allow one user to access several GUIs', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 8, 500, 190, 25, 10, '', 'Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'gui_owner', 2, 1, 'GUI editieren Benutzer zuordnen', 'Edit GUI assign to user', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ', 8, 640, 190, 20, 10, '', 'GUI editieren Benutzer zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_Configure_WMS_Access', 3, 1, 'Hintergrund WMS Zuordnung', 'Configure WMS Access', 'div', '', '', 5, 137, 193, 66, 2, '', ' WMS Zuordnung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_GUI_Management', 3, 1, 'Hintergrund Oberflächenverwaltung', 'GUI Management', 'div', '', '', 5, 217, 193, 126, 2, '', ' GUI-Verwaltung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_User_Authorization', 3, 1, 'Hintergrund Benutzerzugriff erteilen', 'Authorization ', 'div', '', '', 5, 477, 193, 196, 2, '', ' Benutzerzugriff erteilen', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_User_Management', 3, 1, 'Hintergrund Benutzerverwaltung', 'User Management', 'div', '', '', 5, 357, 193, 106, 2, '', ' Benutzerverwaltung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_WMS_Management', 3, 1, 'Hintergrund WMS Management', 'WMS Management', 'div', '', '', 5, 37, 193, 86, 2, '', ' WMS Verwaltung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadWMS', 2, 1, 'Capabilities hochladen', 'Load WMS', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 8, 60, 190, 20, 5, '', 'Capabilities hochladen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadWMSList', 2, 1, 'WMS in GUI einbinden', 'Link WMS into GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 8, 160, 190, 20, 5, '', 'WMS in GUI einbinden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'myGUIlist', 2, 1, 'Zurück zur eigenen GUI Liste', 'Move back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'newGui', 2, 1, 'GUI erzeugen', 'Create new GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 8, 240, 85, 20, 5, '', 'GUI erzeugen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'rename_copy_Gui', 2, 1, 'GUI umbenennen/ kopieren', 'Rename / copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 8, 320, 190, 20, 10, '', 'GUI umbenennen/kopieren', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'showLoggedUser', 2, 1, 'Anzeige des eingeloggten Benutzers', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'updateWMSs', 2, 1, 'Hochgeladene aktualisieren', 'Update WMS', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 8, 80, 190, 20, 5, '', 'Hochgeladene aktualisieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'AdminFrame', 2, 1, 'the frame for administration modules', '', 'iframe', '', 'frameborder = "0"', 200, 20, 800, 800, 0, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'CreateTreeGDE', 2, 1, 'TreeGDE set up', 'Create treeGDE', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 8, 280, 190, 20, 5, '', 'Create treeGDE', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'body', 1, 1, 'navigation', '', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 0, 0, 0, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'deleteWMS', 2, 1, '!Delete WMS completely!', 'Delete WMS completely', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 8, 100, 190, 20, 5, '', '!Delete WMS completely!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'delete_filteredGui', 2, 1, 'Delete GUI', 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 120, 240, 80, 20, 5, '', 'Delete GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editElements', 2, 1, 'Edit GUI elements', 'Edit GUI elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 8, 260, 190, 20, 5, '', 'Edit GUI elements', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editFilteredGroup', 2, 1, 'Create and edit group', 'Create and edit group', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 8, 400, 190, 20, 10, '', 'Create and edit group', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editFilteredUser', 2, 1, 'Create and edit user', 'Create and edit user', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 8, 380, 190, 20, 10, '', 'Create and edit user', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editGUI_WMS', 2, 1, 'WMS GUI settings', 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 8, 180, 190, 20, 5, '', 'WMS GUI settings', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'exportGUI', 2, 1, 'export GUI, create SQL', 'export GUI, create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 8, 300, 190, 20, 10, '', 'Export GUI (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGoup_filteredUser', 2, 1, 'Add several users to one group', 'Add several users to one group', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 8, 440, 190, 20, 10, '', 'Add several users to one group ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGroup_filteredGui', 2, 1, 'Allow one group access to several GUIs', 'Allow one group access to several GUIs', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 8, 570, 190, 25, 10, '', 'Allow one group access to <br> several GUIs', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGui_filteredGroup', 2, 1, 'Allow several groups access to one GUI', 'Allow several groups access to one GUI', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 8, 605, 190, 25, 10, '', 'Allow several groups access <br> to one GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGui_filteredUser', 2, 1, 'Allow several users access to one GUI ', 'Allow several users access to one GUI ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 8, 535, 190, 25, 10, '', 'Allow several users access to <br> one GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredUser_filteredGroup', 2, 1, 'Add one user to serveral groups', 'Add one user to serveral groups', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 8, 420, 190, 20, 10, '', 'Add one user to serveral groups', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredUser_filteredGui', 2, 1, 'Allow one user to access several GUIs', 'Allow one user to access several GUIs', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 8, 500, 190, 25, 10, '', 'Allow one user to access <br> several GUIs', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'gui_owner', 2, 1, 'Edit GUI assign to user', 'Edit GUI assign to user', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame"  ', 8, 640, 190, 20, 10, '', 'Edit GUI assign to user', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_Configure_WMS_Access', 3, 1, 'Configure WMS Access', 'Configure WMS Access', 'div', '', '', 5, 137, 193, 66, 2, '', ' Configure WMS Access', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_GUI_Management', 3, 1, 'GUI Management caption', 'GUI Management', 'div', '', '', 5, 217, 193, 126, 2, '', ' GUI Management ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_User_Authorization', 3, 1, 'Authorization caption', 'Authorization ', 'div', '', '', 5, 477, 193, 186, 2, '', ' Authorization', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_User_Management', 3, 1, 'User Management caption', 'User Management', 'div', '', '', 5, 357, 193, 106, 2, '', ' User Management ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_WMS_Management', 3, 1, 'WMS Management caption', 'WMS Management', 'div', '', '', 5, 37, 193, 86, 2, '', ' WMS Management', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" ', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadWMS', 2, 1, 'Load Capabilities', 'Load WMS', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 8, 60, 190, 20, 5, '', 'Load WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadWMSList', 2, 1, 'Link WMS into GUI', 'Link WMS into GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 8, 160, 190, 20, 5, '', 'Link WMS into GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'myGUIlist', 2, 1, 'go back to your GUI list', 'Move back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'newGui', 2, 1, 'Create new GUI', 'Create new GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 8, 240, 110, 20, 5, '', 'Create new GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'rename_copy_Gui', 2, 1, 'Rename/ copy GUI', 'Rename / copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 8, 320, 190, 20, 10, '', 'Rename / copy GUI', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'showLoggedUser', 2, 1, 'Logged User:', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'updateWMSs', 2, 1, 'Update with Capabilities', 'Update WMS', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 8, 80, 190, 20, 5, '', 'Update WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'AdminFrame', 2, 1, 'Bereich für Administrationsmodule', '', 'iframe', '', 'frameborder = "0"', 210, 25, 800, 800, 12, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'CreateTreeGDE', 2, 1, 'Ordnerbaum konfigurieren', 'Create treeGDE', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 533, 200, 20, 5, '', 'Ordnerbaum konfigurieren', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 275, 200, 20, 5, '', 'WMS Metadaten', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'body', 1, 1, 'Navigation', '', 'body', '', 'onload=''mod_adminNavigation_init()''', NULL, NULL, NULL, NULL, NULL, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'deleteWFS', 2, 1, 'WFS löschen', 'Delete WFS', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 393, 200, 20, 5, '', 'WFS löschen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'deleteWMS', 2, 1, '!Vollständig löschen!', '!Delete WMS completely!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 200, 20, 5, '', 'WMS löschen!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'delete_filteredGui', 2, 1, 'GUI löschen', 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 491, 200, 20, 5, '', 'GUI löschen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'editElements', 2, 1, 'Oberflächenelemente editieren', 'Edit GUI Elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 511, 200, 25, 5, '', 'GUI editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'editGUI_WMS', 2, 1, 'WMS GUI Einstellungen', 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 218, 200, 20, 5, '', 'WMS Einstellungen ändern', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'exportGUI', 2, 1, 'GUI exportieren, SQL erzeugen', 'Export GUI (SQL), create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 554, 200, 25, 10, 'x', 'GUI exportieren (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'filteredWms_layer_topic', 2, 1, 'allocate topics to layers of wms of this user', 'allocate topics to layers of wms of this user', 'a', '', 'href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ', 10, 295, 200, 20, 5, '', 'Kategoriezuordnung', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_Configure_WMS_Access', 3, 1, 'Hintergrund WMS Zuordnung', 'WMS Assignment', 'div', '', '', 1, 175, 210, 63, 2, '', 'WMS Zuordnung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_GUI_Management', 3, 1, 'Oberflächenverwaltung', 'GUI Management', 'div', '', '', 1, 448, 210, 153, 2, '', 'GUI Verwaltung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_Metadata', 3, 1, 'Metadateneditor Caption', 'Metadata', 'div', '', '', 1, 252, 210, 63, 2, '', 'Metadaten', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_WFS_Management', 3, 1, 'WFS Verwaltung', 'WFS Management', 'div', '', '', 1, 330, 210, 103, 2, '', 'WFS Verwaltung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_WMS_Management', 3, 1, 'Dienstverwaltung Beschriftung', 'WMS Management', 'div', '', '', 0, 37, 210, 123, 2, '', 'WMS Verwaltung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWFS', 2, 1, 'WFS Capabilities in eine GUI laden', 'Load WFS Capabilities into a GUI', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 353, 200, 20, 5, '', 'WFS laden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWMS', 2, 1, 'Capabilities hochladen', 'Load WMS', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 200, 20, 5, '', 'WMS laden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWMSList', 2, 1, 'WMS in GUI einbinden', 'Assign WMS to a GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 198, 200, 20, 5, '', 'WMS einbinden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'myGUIlist', 2, 1, 'Zurück zur eigenen GUI Liste', 'Move back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'newGui', 2, 1, 'GUI erzeugen', 'New GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 471, 200, 20, 5, '', 'GUI erzeugen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'orphanWMS', 2, 1, 'display orphaned WMS', 'Delete orphaned WMS', 'a', '', 'href = "../php/mod_orphanWMS.php?sessionID"
-target = "AdminFrame"', 10, 120, 200, 20, 5, '', 'WMS ohne Zuordung löschen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'owsproxy', 2, 1, 'secure services', 'OWSPROXY', 'a', '', 'href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"', 10, 140, 200, 20, 10, '', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Owsproxy');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'rename_copy_Gui', 2, 1, 'GUI umbenennen/ kopieren', 'Rename / copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 576, 200, 20, 10, '', 'GUI umbenennen/kopieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/RenameGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'showLoggedUser', 2, 1, 'Anzeige des eingeloggten Benutzers', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'updateWMSs', 2, 1, 'Hochgeladene aktualisieren', 'Update WMS', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 80, 200, 20, 5, '', 'WMS aktualisieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'wfs_conf', 2, 1, 'WFS konfigurieren', 'Configure WFS', 'a', '', 'href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"', 10, 373, 200, 20, 5, '', 'WFS konfigurieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Wfs_conf');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'wfs_gui', 2, 1, 'edit wfs settings', 'Assign WFS conf to gui', 'a', '', 'href = "../javascripts/mod_wfs_client.html" target="AdminFrame"', 10, 413, 200, 20, 10, '', 'WFS Konfiguration GUI zuweisen', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'AdminFrame', 2, 1, 'administration frame', '', 'iframe', '', 'frameborder = "0"', 210, 25, 1000, 800, 12, '', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'CreateTreeGDE', 2, 1, 'Configure TreeGDE', 'Create treeGDE', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 533, 200, 20, 5, '', 'Configure TreeGDE', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 275, 200, 20, 5, '', 'WMS Metadata', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_WMS_Metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'body', 1, 1, 'Navigation', '', 'body', '', 'onload=''mod_adminNavigation_init()''', NULL, NULL, NULL, NULL, NULL, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'deleteWFS', 2, 1, 'Delete WFS', 'Delete WFS', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 393, 200, 20, 5, '', 'Delete WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWFS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'deleteWMS', 2, 1, '!Delete completely!', '!Delete WMS completely!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 200, 20, 5, '', '!Delete WMS completely!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'delete_filteredGui', 2, 1, 'Delete GUI', 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 491, 200, 20, 5, '', 'Delete GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'editElements', 2, 1, 'Edit GUI Elements', 'Edit GUI Elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 511, 200, 20, 5, '', 'Edit GUI Elements', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'editGUI_WMS', 2, 1, 'WMS GUI settings', 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 218, 200, 20, 5, '', 'WMS GUI settings', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'exportGUI', 2, 1, 'Export GUI (SQL), create SQL', 'Export GUI (SQL), create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 553, 200, 20, 10, 'x', 'Export GUI (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'filteredWms_layer_topic', 2, 1, 'allocate topics to layers of wms of this user', 'allocate topics to layers of wms of this user', 'a', '', 'href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ', 10, 295, 200, 20, 5, '', 'Allocate topics', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Topic_/_Category');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_Configure_WMS_Access', 3, 1, 'WMS Assignment', 'WMS Assignment', 'div', '', '', 1, 175, 210, 63, 2, '', 'WMS Assignment', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_GUI_Management', 3, 1, 'GUI Management', 'GUI Management', 'div', '', '', 1, 448, 210, 148, 2, '', 'GUI Management', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_Metadata', 3, 1, 'Metadata', 'Metadata', 'div', '', '', 1, 252, 210, 63, 2, '', 'Metadata', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_WFS_Management', 3, 1, 'WFS Management', 'WFS Management', 'div', '', '', 1, 330, 210, 103, 2, '', 'WFS Management', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_WMS_Management', 3, 1, 'WMS Management', 'WMS Management', 'div', '', '', 0, 37, 210, 123, 2, '', 'WMS Management', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'loadWFS', 2, 1, 'Load WFS Capabilities into a GUI', 'Load WFS Capabilities into a GUI', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 353, 200, 20, 5, '', 'Load WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/LoadWFS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'loadWMS', 2, 1, 'load Capabilities', 'Load WMS', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 200, 20, 5, '', 'Load WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'loadWMSList', 2, 1, 'assign WMS to a GUI', 'Assign WMS to a GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 198, 200, 20, 5, '', 'Assign WMS to a GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'myGUIlist', 2, 1, 'back to GUI list', 'Move back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'newGui', 2, 1, 'New GUI', 'New GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 471, 200, 20, 5, '', 'New GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+target = "AdminFrame"', 10, 120, 200, 20, 5, '', 'WMS ohne Zuordung löschen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'owsproxy', 2, 1, 'secure services', 'OWSPROXY', 'a', '', 'href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"', 10, 140, 200, 20, 10, '', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'rename_copy_Gui', 2, 1, 'GUI umbenennen/ kopieren', 'Rename / copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 576, 200, 20, 10, '', 'GUI umbenennen/kopieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'showLoggedUser', 2, 1, 'Anzeige des eingeloggten Benutzers', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'updateWMSs', 2, 1, 'Hochgeladene aktualisieren', 'Update WMS', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 80, 200, 20, 5, '', 'WMS aktualisieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'wfs_conf', 2, 1, 'WFS konfigurieren', 'Configure WFS', 'a', '', 'href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"', 10, 373, 200, 20, 5, '', 'WFS konfigurieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'wfs_gui', 2, 1, 'edit wfs settings', 'Assign WFS conf to gui', 'a', '', 'href = "../javascripts/mod_wfs_client.html" target="AdminFrame"', 10, 413, 200, 20, 10, '', 'WFS Konfiguration GUI zuweisen', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'AdminFrame', 2, 1, 'administration frame', '', 'iframe', '', 'frameborder = "0"', 210, 25, 1000, 800, 12, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'CreateTreeGDE', 2, 1, 'Configure TreeGDE', 'Create treeGDE', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 533, 200, 20, 5, '', 'Configure TreeGDE', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 275, 200, 20, 5, '', 'WMS Metadata', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'body', 1, 1, 'Navigation', '', 'body', '', 'onload=''mod_adminNavigation_init()''', NULL, NULL, NULL, NULL, NULL, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'deleteWFS', 2, 1, 'Delete WFS', 'Delete WFS', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 393, 200, 20, 5, '', 'Delete WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'deleteWMS', 2, 1, '!Delete completely!', '!Delete WMS completely!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 200, 20, 5, '', '!Delete WMS completely!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'delete_filteredGui', 2, 1, 'Delete GUI', 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 491, 200, 20, 5, '', 'Delete GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'editElements', 2, 1, 'Edit GUI Elements', 'Edit GUI Elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 511, 200, 20, 5, '', 'Edit GUI Elements', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'editGUI_WMS', 2, 1, 'WMS GUI settings', 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 218, 200, 20, 5, '', 'WMS GUI settings', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'exportGUI', 2, 1, 'Export GUI (SQL), create SQL', 'Export GUI (SQL), create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 553, 200, 20, 10, 'x', 'Export GUI (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'filteredWms_layer_topic', 2, 1, 'allocate topics to layers of wms of this user', 'allocate topics to layers of wms of this user', 'a', '', 'href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ', 10, 295, 200, 20, 5, '', 'Allocate topics', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_Configure_WMS_Access', 3, 1, 'WMS Assignment', 'WMS Assignment', 'div', '', '', 1, 175, 210, 63, 2, '', 'WMS Assignment', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_GUI_Management', 3, 1, 'GUI Management', 'GUI Management', 'div', '', '', 1, 448, 210, 148, 2, '', 'GUI Management', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_Metadata', 3, 1, 'Metadata', 'Metadata', 'div', '', '', 1, 252, 210, 63, 2, '', 'Metadata', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_WFS_Management', 3, 1, 'WFS Management', 'WFS Management', 'div', '', '', 1, 330, 210, 103, 2, '', 'WFS Management', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_WMS_Management', 3, 1, 'WMS Management', 'WMS Management', 'div', '', '', 0, 37, 210, 123, 2, '', 'WMS Management', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'help', 2, 1, 'button help', 'Help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'loadWFS', 2, 1, 'Load WFS Capabilities into a GUI', 'Load WFS Capabilities into a GUI', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 353, 200, 20, 5, '', 'Load WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'loadWMS', 2, 1, 'load Capabilities', 'Load WMS', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 200, 20, 5, '', 'Load WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'loadWMSList', 2, 1, 'assign WMS to a GUI', 'Assign WMS to a GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 198, 200, 20, 5, '', 'Assign WMS to a GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'logout', 2, 1, 'Logout', 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'myGUIlist', 2, 1, 'back to GUI list', 'Move back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'newGui', 2, 1, 'New GUI', 'New GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 471, 200, 20, 5, '', 'New GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'orphanWMS', 2, 1, 'Delete orphaned WMS', 'Delete orphaned WMS', 'a', '', 'href = "../php/mod_orphanWMS.php?sessionID"
-target = "AdminFrame"', 10, 120, 200, 20, 5, '', 'Delete orphaned WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'owsproxy', 2, 1, 'secure services', 'OWSPROXY', 'a', '', 'href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"', 10, 140, 200, 20, 10, '', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Owsproxy');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'rename_copy_Gui', 2, 1, 'Rename / copy GUI', 'Rename / copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 576, 200, 20, 10, '', 'Rename / copy GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/RenameGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'showLoggedUser', 2, 1, 'show logged in user', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'updateWMSs', 2, 1, 'Update Capabilities', 'Update WMS', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 80, 200, 20, 5, '', 'Update WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'wfs_conf', 2, 1, 'Configure WFS', 'Configure WFS', 'a', '', 'href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"', 10, 373, 200, 20, 5, '', 'Configure WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Wfs_conf');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'wfs_gui', 2, 1, 'edit wfs settings (Assign WFS conf to GUI)', 'Assign WFS conf to gui', 'a', '', 'href = "../javascripts/mod_wfs_client.html" target="AdminFrame"', 10, 413, 200, 20, 10, '', 'Assign WFS conf to GUI', 'a', '', '', '', 'AdminFrame', '');
--- TOC entry 1858 (class 0 OID 5377129)
--- Dependencies: 1255
--- Data for Name: gui_element_vars; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('wms_gdi_de', 'body', 'file css', '../css/mapbender.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_all', '0', '1 enables option "load all wms"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_group', '0', '1 enables option "load wms from group"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load wms from gui"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_height', '14', 'height of the poi_image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_width', '14', 'width of the poi_image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_subject', 'Ein Treffpunkt wurde erzeugt. Folgen Sie dem Link!', 'if you choose format email, define the text for the subject', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_height', '14', 'height of the meetingPoint_icon', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_icon', '../img/redball.gif', 'path to meetingPoint image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_max_characters', '70', 'define the maximum length of the text', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_please_click', 'Please click in  the map to define the meeting point position!', 'text to show if no clickposition is set', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_style', 'background-color:white;font-weight: bold;color:red;font-family:Arial;', 'style to display the meetingPoint text', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_width', '14', 'width of the meetingPoint_icon', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[5]', '160', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[6]', '280', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[5]', 'meetingPoint', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[6]', 'gazetteerMetadata', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', '  ', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'false', 'link for layer-metadata', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_db', '0', '1 enables option "load configured wms from gui"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_minScale', 'false', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_startExtent', '-24.5,32,34.5,71', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_useMaxExtent', 'false', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_wmsIndex', '0', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_zoomFactor', '5', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'sandclock', 'mod_sandclock_image', '../img/sandclock_oo.gif', 'define a sandclock image ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', '  ', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-3px; padding-top:3px;padding-left:4px;', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
+target = "AdminFrame"', 10, 120, 200, 20, 5, '', 'Delete orphaned WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'owsproxy', 2, 1, 'secure services', 'OWSPROXY', 'a', '', 'href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"', 10, 140, 200, 20, 10, '', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'rename_copy_Gui', 2, 1, 'Rename / copy GUI', 'Rename / copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 576, 200, 20, 10, '', 'Rename / copy GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'showLoggedUser', 2, 1, 'show logged in user', '', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'updateWMSs', 2, 1, 'Update Capabilities', 'Update WMS', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 80, 200, 20, 5, '', 'Update WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'wfs_conf', 2, 1, 'Configure WFS', 'Configure WFS', 'a', '', 'href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"', 10, 373, 200, 20, 5, '', 'Configure WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'wfs_gui', 2, 1, 'edit wfs settings (Assign WFS conf to GUI)', 'Assign WFS conf to gui', 'a', '', 'href = "../javascripts/mod_wfs_client.html" target="AdminFrame"', 10, 413, 200, 20, 10, '', 'Assign WFS conf to GUI', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'switchLocale_noreload', 8, 1, 'changes the locale without reloading the client', 'Set language', 'div', '', 'frameborder=''0''', 696, 14, 50, 30, 5, '', '<form id=''form_switch_locale'' name=''form_switch_locale'' target=''parent''>
+<select id=''language'' name=''language'' onchange=''validate_locale()''>
+</select>
+</form>
+', 'div', 'mod_switchLocale_noreload.php', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'popup', 6, 1, 'popup replacement', NULL, 'div', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 'div', 'popup.js', NULL, NULL, NULL, NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'printPDF', 2, 1, 'start print GUI', 'Print', 'img', '../img/button_blink_red/print_off.png', 'onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=260, height=380, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ', 555, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfsresult', 2, 1, 'display the list of wfs results', '', 'iframe', '../html/mod_blank.html', 'frameborder = "0"', 10, 800, 200, 150, 1, '', '', 'iframe', '', '', '', '', '');
+-- Data for Name: gui_element_vars; Type: TABLE DATA; Schema: public; Owner: admin
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('wms_gdi_de', 'body', 'file css', '../css/mapbender.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_all', '0', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_group', '0', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_height', '14', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_width', '14', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_subject', 'Ein Treffpunkt wurde erzeugt. Folgen Sie dem Link!', 'if you choose format email, define the text for the subject', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_height', '14', 'height of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_icon', '../img/redball.gif', 'path to meetingPoint image', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_max_characters', '70', 'define the maximum length of the text', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_please_click', 'Please click in  the map to define the meeting point position!', 'text to show if no clickposition is set', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_style', 'background-color:white;font-weight: bold;color:red;font-family:Arial;', 'style to display the meetingPoint text', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_width', '14', 'width of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[5]', '160', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[6]', '280', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[5]', 'meetingPoint', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[6]', 'gazetteerMetadata', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'false', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_db', '0', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_minScale', 'false', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_startExtent', '-24.5,32,34.5,71', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_useMaxExtent', 'false', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_wmsIndex', '0', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_zoomFactor', '5', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'sandclock', 'mod_sandclock_image', '../img/sandclock_oo.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-3px; padding-top:3px;padding-left:4px;', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'text css', ' body{
  font-family: Arial, Helvetica, sans-serif;
  font-size : 12px;
@@ -720,7508 +830,7661 @@
  height: 18px;
  width: 32px;
-', 'text css', 'text/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'wfsCssUrl', '../css/mapbender.css', 'var', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'wfsConfIdString', '1,2,3,4', 'comma seperated list of WFS conf ids', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'wfs_conf_filename', 'wfs_default.conf', 'location and name of the WFS configuration file', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '5', 'define which tab should be opened when a gui is opened', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[5]', '250', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[5]', 'digitize', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_prefix', '  ', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;padding-left:8px;', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'menu', '', 'context menu elements', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'wfs', 'displayWfsResultList', '1', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'editGUI_WMS', 'file_css', '../css/edit_gui.css', '', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_user', 'file css', '../css/administration_alloc.css', 'a file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'group_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGoup_filteredUser', 'css_file_filteredGroup_filterdUser', '../css/administration_alloc.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGroup', 'css_filteredUser_filteredGroup', '../css/administration_alloc.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
--- TOC entry 1859 (class 0 OID 5377139)
--- Dependencies: 1257
--- Data for Name: gui_kml; Type: TABLE DATA; Schema: public; Owner: postgres
--- TOC entry 1860 (class 0 OID 5377145)
--- Dependencies: 1258
--- Data for Name: gui_layer; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14111, 767, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18218, 882, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19178, 615, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10173, 640, 1, 1, 1, 0, 0, 1002199, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13775, 101, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13776, 101, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13777, 101, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9891, 615, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9892, 615, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9893, 615, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9894, 615, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9895, 615, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9896, 615, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9897, 615, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9898, 615, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9899, 615, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9900, 615, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10106, 634, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10107, 634, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10108, 634, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10109, 634, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10110, 634, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19209, 785, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14252, 785, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14253, 785, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14254, 785, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19251, 832, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19272, 867, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18155, 869, 1, 1, 1, 1, 1, 0, 150214, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18142, 867, 1, 1, 1, 1, 1, 22497, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14928, 842, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14929, 842, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14930, 842, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14931, 842, 1, 1, 1, 0, 0, 0, 0, 37, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14932, 842, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14933, 842, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19306, 841, 1, 1, 1, 0, 0, 0, 0, 66, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19307, 841, 1, 1, 1, 0, 0, 0, 0, 67, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19355, 824, 1, 1, 1, 0, 0, 0, 0, 47, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19176, 250, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19176, 250, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19176, 250, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19176, 250, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2713, 250, 1, 1, 1, 1, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2713, 250, 1, 1, 1, 1, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2715, 250, 1, 1, 1, 1, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2715, 250, 1, 1, 1, 1, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19208, 717, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19208, 717, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 11630, 717, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19253, 836, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19274, 837, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14870, 841, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14871, 841, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14872, 841, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14873, 841, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14874, 841, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14875, 841, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14876, 841, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19294, 841, 1, 1, 1, 0, 0, 0, 0, 39, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14877, 841, 1, 1, 1, 0, 0, 0, 0, 26, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14878, 841, 1, 1, 1, 0, 0, 0, 0, 27, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19298, 841, 1, 1, 1, 0, 0, 0, 0, 45, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19299, 841, 1, 1, 1, 0, 0, 0, 0, 46, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7491, 583, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7492, 583, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7493, 583, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7494, 583, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7495, 583, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7496, 583, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7497, 583, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7498, 583, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7499, 583, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7500, 583, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7501, 583, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7502, 583, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7503, 583, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7504, 583, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7505, 583, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7506, 583, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7507, 583, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7508, 583, 1, 1, 1, 0, 0, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7509, 583, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7510, 583, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7511, 583, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7512, 583, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7513, 583, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7514, 583, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7515, 583, 1, 1, 1, 1, 1, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7516, 583, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9877, 614, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9878, 614, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9879, 614, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9880, 614, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9881, 614, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9882, 614, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9883, 614, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9884, 614, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9885, 614, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9886, 614, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9887, 614, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9888, 614, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9889, 614, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13751, 86, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13752, 86, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13753, 86, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13754, 86, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13755, 86, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10047, 625, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10048, 625, 1, 1, 1, 1, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10049, 625, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10050, 625, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10051, 625, 1, 1, 1, 1, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10052, 625, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14104, 767, 1, 1, 1, 0, 0, 500, 62500, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19213, 767, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10053, 625, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10054, 625, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14105, 767, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10055, 625, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10056, 625, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14106, 767, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10057, 625, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14107, 767, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10058, 625, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14108, 767, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14109, 767, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14110, 767, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14112, 767, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14113, 767, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14114, 767, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14115, 767, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10194, 645, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10195, 645, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10196, 645, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10197, 645, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10198, 645, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10199, 645, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10200, 645, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5575, 486, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7255, 525, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5576, 486, 1, 1, 1, 0, 0, 750000, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7256, 525, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5577, 486, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7257, 525, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5578, 486, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7258, 525, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7259, 525, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7260, 525, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7261, 525, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7262, 525, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7263, 525, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7264, 525, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7265, 525, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7266, 525, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7267, 525, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19212, 800, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14365, 800, 1, 1, 1, 0, 0, 802, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14364, 800, 1, 1, 1, 0, 0, 802, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14366, 800, 1, 1, 1, 0, 0, 241, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19222, 800, 1, 1, 1, 0, 0, 481, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19224, 800, 1, 1, 1, 0, 0, 481, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10415, 655, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19258, 655, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19259, 655, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10416, 655, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10417, 655, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10418, 655, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10419, 655, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10420, 655, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10421, 655, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10422, 655, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10423, 655, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10424, 655, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10425, 655, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10426, 655, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10427, 655, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10428, 655, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10429, 655, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10430, 655, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10431, 655, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10432, 655, 1, 1, 1, 0, 0, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10433, 655, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10434, 655, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10435, 655, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10436, 655, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10437, 655, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10438, 655, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14255, 786, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19214, 786, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14256, 786, 1, 1, 1, 0, 0, 1, 20000, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19215, 786, 1, 1, 1, 0, 0, 1, 9999, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19216, 786, 1, 1, 1, 0, 0, 1, 20000, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19217, 786, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19220, 786, 1, 1, 1, 0, 0, 1, 9999, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19221, 786, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19223, 786, 1, 1, 1, 0, 0, 1, 20000, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19225, 786, 1, 1, 1, 0, 0, 9999, 1000000, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19227, 786, 1, 1, 1, 0, 0, 1, 9999, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19260, 840, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19276, 844, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15004, 844, 1, 1, 1, 1, 1, 0, 0, 53, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14965, 844, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14967, 844, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14971, 844, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15005, 844, 1, 1, 1, 1, 1, 0, 0, 54, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14998, 844, 1, 1, 1, 1, 1, 0, 0, 47, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19285, 844, 1, 1, 1, 1, 1, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14968, 844, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14993, 844, 1, 1, 1, 1, 1, 0, 0, 42, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15002, 844, 1, 1, 1, 1, 1, 0, 0, 51, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19288, 844, 1, 1, 1, 1, 1, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19290, 844, 1, 1, 1, 1, 1, 0, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19292, 844, 1, 1, 1, 1, 1, 0, 0, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14981, 844, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14903, 842, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14964, 844, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14904, 842, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14995, 844, 1, 1, 1, 1, 1, 0, 0, 44, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14905, 842, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14988, 844, 1, 1, 1, 1, 1, 0, 0, 37, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14906, 842, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14984, 844, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14907, 842, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19293, 844, 1, 1, 1, 1, 1, 0, 0, 19, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14908, 842, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14973, 844, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14972, 844, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14909, 842, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14994, 844, 1, 1, 1, 1, 1, 0, 0, 43, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14910, 842, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14969, 844, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14911, 842, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14997, 844, 1, 1, 1, 1, 1, 0, 0, 46, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14980, 844, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14912, 842, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15010, 844, 1, 1, 1, 1, 1, 0, 0, 59, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14913, 842, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14976, 844, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14914, 842, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14983, 844, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14915, 842, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14916, 842, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14977, 844, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14917, 842, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19295, 844, 1, 1, 1, 1, 1, 0, 0, 30, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19296, 844, 1, 1, 1, 1, 1, 0, 0, 31, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14918, 842, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19297, 844, 1, 1, 1, 1, 1, 0, 0, 32, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14919, 842, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14920, 842, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14974, 844, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14921, 842, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14922, 842, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15006, 844, 1, 1, 1, 1, 1, 0, 0, 55, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15001, 844, 1, 1, 1, 1, 1, 0, 0, 50, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14923, 842, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14966, 844, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14924, 842, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14970, 844, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14925, 842, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14978, 844, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14926, 842, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14927, 842, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14990, 844, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19177, 613, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19218, 792, 1, 1, 1, 0, 0, 200, 200440, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14288, 792, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14289, 792, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14290, 792, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14291, 792, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14292, 792, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14293, 792, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14294, 792, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14295, 792, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14296, 792, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19261, 883, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18236, 883, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18237, 883, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18238, 883, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18239, 883, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18240, 883, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10439, 655, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18219, 882, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18220, 882, 1, 1, 1, 0, 0, 135001, 300000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18221, 882, 1, 1, 1, 0, 0, 20001, 135000, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18222, 882, 1, 1, 1, 0, 0, 12001, 20000, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18223, 882, 1, 1, 1, 0, 0, 2751, 12000, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18224, 882, 1, 1, 1, 0, 0, 0, 2750, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18225, 882, 1, 1, 1, 0, 0, 300000, 1000000, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18226, 882, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18227, 882, 1, 1, 1, 0, 0, 0, 300000, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18228, 882, 1, 1, 1, 0, 0, 0, 300000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18229, 882, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18230, 882, 1, 1, 1, 0, 0, 0, 300000, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18231, 882, 1, 1, 1, 0, 0, 0, 300000, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18232, 882, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18233, 882, 1, 1, 1, 0, 0, 0, 300000, 15, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18234, 882, 1, 1, 1, 0, 0, 0, 300000, 16, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14982, 844, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19308, 824, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19309, 824, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19310, 824, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19311, 824, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19312, 824, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19313, 824, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19314, 824, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19315, 824, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19316, 824, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19317, 824, 1, 1, 1, 0, 0, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19318, 824, 1, 1, 1, 0, 0, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19319, 824, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19320, 824, 1, 1, 1, 0, 0, 0, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19321, 824, 1, 1, 1, 0, 0, 0, 0, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19322, 824, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19323, 824, 1, 1, 1, 0, 0, 0, 0, 15, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19324, 824, 1, 1, 1, 0, 0, 0, 0, 16, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19325, 824, 1, 1, 1, 0, 0, 0, 0, 17, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19326, 824, 1, 1, 1, 0, 0, 0, 0, 18, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19327, 824, 1, 1, 1, 0, 0, 0, 0, 19, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19328, 824, 1, 1, 1, 0, 0, 0, 0, 20, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19329, 824, 1, 1, 1, 0, 0, 0, 0, 21, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19330, 824, 1, 1, 1, 0, 0, 0, 0, 22, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19331, 824, 1, 1, 1, 0, 0, 0, 0, 23, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19332, 824, 1, 1, 1, 0, 0, 0, 0, 24, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19333, 824, 1, 1, 1, 0, 0, 0, 0, 25, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19334, 824, 1, 1, 1, 0, 0, 0, 0, 26, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19335, 824, 1, 1, 1, 0, 0, 0, 0, 27, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19336, 824, 1, 1, 1, 0, 0, 0, 0, 28, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19337, 824, 1, 1, 1, 0, 0, 0, 0, 29, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19338, 824, 1, 1, 1, 0, 0, 0, 0, 30, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19339, 824, 1, 1, 1, 0, 0, 0, 0, 31, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19340, 824, 1, 1, 1, 0, 0, 0, 0, 32, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19341, 824, 1, 1, 1, 0, 0, 0, 0, 33, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19342, 824, 1, 1, 1, 0, 0, 0, 0, 34, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19343, 824, 1, 1, 1, 0, 0, 0, 0, 35, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19344, 824, 1, 1, 1, 0, 0, 0, 0, 36, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19345, 824, 1, 1, 1, 0, 0, 0, 0, 37, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19346, 824, 1, 1, 1, 0, 0, 0, 0, 38, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19347, 824, 1, 1, 1, 0, 0, 0, 0, 39, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19348, 824, 1, 1, 1, 0, 0, 0, 0, 40, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19349, 824, 1, 1, 1, 0, 0, 0, 0, 41, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19350, 824, 1, 1, 1, 0, 0, 0, 0, 42, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19351, 824, 1, 1, 1, 0, 0, 0, 0, 43, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19352, 824, 1, 1, 1, 0, 0, 0, 0, 44, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19353, 824, 1, 1, 1, 0, 0, 0, 0, 45, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19354, 824, 1, 1, 1, 0, 0, 0, 0, 46, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2713, 250, 1, 1, 1, 1, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2715, 250, 1, 1, 1, 1, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19179, 624, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19179, 624, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19180, 624, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19180, 624, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19181, 624, 1, 1, 1, 1, 1, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19181, 624, 1, 1, 1, 1, 1, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19182, 624, 1, 1, 1, 1, 1, 524922, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19182, 624, 1, 1, 1, 1, 1, 524922, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19183, 624, 1, 1, 1, 1, 1, 200, 524922, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19183, 624, 1, 1, 1, 1, 1, 200, 524922, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19184, 624, 1, 1, 1, 1, 1, 200, 89987, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19184, 624, 1, 1, 1, 1, 1, 200, 89987, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19185, 624, 1, 1, 1, 1, 1, 200, 74989, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19185, 624, 1, 1, 1, 1, 1, 200, 74989, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19186, 624, 1, 1, 1, 1, 1, 200, 74989, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19186, 624, 1, 1, 1, 1, 1, 200, 74989, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19187, 624, 1, 1, 1, 1, 1, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19187, 624, 1, 1, 1, 1, 1, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19188, 624, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19188, 624, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19189, 624, 1, 1, 1, 1, 1, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19189, 624, 1, 1, 1, 1, 1, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19226, 789, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14265, 789, 1, 1, 1, 0, 0, 117283, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14266, 789, 1, 1, 1, 0, 0, 23457, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14268, 789, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14270, 789, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14271, 789, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14269, 789, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14267, 789, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14272, 789, 1, 1, 1, 0, 0, 9382, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14273, 789, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14275, 789, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14276, 789, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14274, 789, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19235, 789, 1, 1, 1, 0, 0, 4691, 9382, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19236, 789, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19237, 789, 1, 1, 1, 0, 0, 0, 0, 15, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19238, 789, 1, 1, 1, 0, 0, 0, 0, 16, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19239, 789, 1, 1, 1, 0, 0, 0, 0, 17, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19241, 789, 1, 1, 1, 0, 0, 94, 4691, 18, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19242, 789, 1, 1, 1, 0, 0, 0, 0, 19, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19243, 789, 1, 1, 1, 0, 0, 0, 0, 20, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19244, 789, 1, 1, 1, 0, 0, 0, 0, 21, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19245, 789, 1, 1, 1, 0, 0, 0, 0, 22, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14558, 832, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14559, 832, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14560, 832, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19262, 841, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19264, 841, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19265, 841, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19266, 841, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19267, 841, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19268, 841, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19269, 841, 1, 1, 1, 0, 0, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14860, 841, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14861, 841, 1, 1, 1, 0, 0, 20000000, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14862, 841, 1, 1, 1, 0, 0, 1700000, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14863, 841, 1, 1, 1, 0, 0, 0, 1699999, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14864, 841, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14865, 841, 1, 1, 1, 0, 0, 20000000, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14866, 841, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19275, 841, 1, 1, 1, 0, 0, 0, 0, 17, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19277, 841, 1, 1, 1, 0, 0, 0, 0, 18, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19278, 841, 1, 1, 1, 0, 0, 0, 0, 19, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19279, 841, 1, 1, 1, 0, 0, 1999999, 0, 20, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19280, 841, 1, 1, 1, 0, 0, 0, 1999999, 21, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19281, 841, 1, 1, 1, 0, 0, 0, 0, 22, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19282, 841, 1, 1, 1, 0, 0, 0, 0, 23, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14894, 842, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19284, 841, 1, 1, 1, 0, 0, 0, 0, 24, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14895, 842, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19286, 841, 1, 1, 1, 0, 0, 1999999, 0, 25, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19287, 841, 1, 1, 1, 0, 0, 0, 1999999, 26, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14896, 842, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14897, 842, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14867, 841, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14898, 842, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14868, 841, 1, 1, 1, 0, 0, 11999988, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14899, 842, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14869, 841, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14900, 842, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19289, 841, 1, 1, 1, 0, 0, 0, 0, 30, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14901, 842, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19291, 841, 1, 1, 1, 0, 0, 0, 0, 31, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14902, 842, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19190, 328, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3385, 328, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3386, 328, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3387, 328, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3388, 328, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3393, 328, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19191, 328, 1, 1, 1, 1, 1, 0, 68150, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19192, 328, 1, 1, 1, 1, 1, 0, 50110, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19193, 328, 1, 1, 1, 1, 1, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19194, 328, 1, 1, 1, 1, 1, 0, 68150, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19195, 328, 1, 1, 1, 1, 1, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19196, 328, 1, 1, 1, 1, 1, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3391, 328, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19197, 328, 1, 1, 1, 1, 1, 0, 50110, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19198, 328, 1, 1, 1, 1, 1, 0, 50110, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19199, 328, 1, 1, 1, 1, 1, 0, 0, 15, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19200, 328, 1, 1, 1, 1, 1, 0, 0, 16, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19201, 328, 1, 1, 1, 1, 1, 0, 0, 17, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19202, 328, 1, 1, 1, 1, 1, 0, 0, 18, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19203, 328, 1, 1, 1, 1, 1, 0, 0, 19, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19204, 328, 1, 1, 1, 0, 0, 0, 0, 20, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19205, 328, 1, 1, 1, 0, 0, 0, 0, 21, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19219, 640, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19219, 640, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19219, 640, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19219, 640, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10166, 640, 1, 1, 1, 0, 0, 20044, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10166, 640, 1, 1, 1, 0, 0, 20044, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10166, 640, 1, 1, 1, 0, 0, 20044, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10166, 640, 1, 1, 1, 0, 0, 20044, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10167, 640, 1, 1, 1, 0, 0, 20044, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10167, 640, 1, 1, 1, 0, 0, 20044, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10167, 640, 1, 1, 1, 0, 0, 20044, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10167, 640, 1, 1, 1, 0, 0, 20044, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10168, 640, 1, 1, 1, 0, 0, 40088, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10168, 640, 1, 1, 1, 0, 0, 40088, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10168, 640, 1, 1, 1, 0, 0, 40088, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19229, 640, 1, 1, 1, 0, 0, 20044, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19229, 640, 1, 1, 1, 0, 0, 20044, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19229, 640, 1, 1, 1, 0, 0, 20044, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19229, 640, 1, 1, 1, 0, 0, 20044, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19230, 640, 1, 1, 1, 0, 0, 250550, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19230, 640, 1, 1, 1, 0, 0, 250550, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19230, 640, 1, 1, 1, 0, 0, 250550, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19230, 640, 1, 1, 1, 0, 0, 250550, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19231, 640, 1, 1, 1, 0, 0, 250550, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19231, 640, 1, 1, 1, 0, 0, 250550, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19231, 640, 1, 1, 1, 0, 0, 250550, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19231, 640, 1, 1, 1, 0, 0, 250550, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19232, 640, 1, 1, 1, 0, 0, 250550, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19232, 640, 1, 1, 1, 0, 0, 250550, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19232, 640, 1, 1, 1, 0, 0, 250550, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19232, 640, 1, 1, 1, 0, 0, 250550, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19234, 640, 1, 1, 1, 0, 0, 250550, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19234, 640, 1, 1, 1, 0, 0, 250550, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19234, 640, 1, 1, 1, 0, 0, 250550, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19234, 640, 1, 1, 1, 0, 0, 250550, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10171, 640, 1, 1, 1, 0, 0, 250550, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10171, 640, 1, 1, 1, 0, 0, 250550, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10171, 640, 1, 1, 1, 0, 0, 250550, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10172, 640, 1, 1, 1, 0, 0, 250550, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10172, 640, 1, 1, 1, 0, 0, 250550, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10172, 640, 1, 1, 1, 0, 0, 250550, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10172, 640, 1, 1, 1, 0, 0, 250550, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19240, 640, 1, 1, 1, 0, 0, 501099, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19240, 640, 1, 1, 1, 0, 0, 501099, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10370, 648, 1, 1, 1, 1, 1, 200, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10371, 648, 1, 1, 1, 1, 1, 200, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19228, 834, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14759, 834, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14843, 840, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14844, 840, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14851, 841, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14845, 840, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14852, 841, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14846, 840, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14856, 841, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14847, 840, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14848, 840, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14849, 840, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14850, 840, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19263, 887, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18275, 887, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14804, 837, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14944, 843, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14945, 843, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14946, 843, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14947, 843, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14948, 843, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14805, 837, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14949, 843, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14950, 843, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14806, 837, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14853, 841, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14854, 841, 1, 1, 1, 0, 0, 44999930, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14855, 841, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14879, 841, 1, 1, 1, 0, 0, 0, 0, 28, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14880, 841, 1, 1, 1, 0, 0, 0, 0, 29, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14881, 841, 1, 1, 1, 0, 0, 0, 0, 30, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14882, 841, 1, 1, 1, 0, 0, 0, 0, 31, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14883, 841, 1, 1, 1, 0, 0, 0, 0, 32, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14884, 841, 1, 1, 1, 0, 0, 0, 0, 33, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14885, 841, 1, 1, 1, 0, 0, 0, 0, 34, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14886, 841, 1, 1, 1, 0, 0, 0, 0, 35, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14887, 841, 1, 1, 1, 0, 0, 0, 0, 36, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14888, 841, 1, 1, 1, 0, 0, 0, 0, 37, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14889, 841, 1, 1, 1, 0, 0, 0, 0, 38, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14890, 841, 1, 1, 1, 0, 0, 0, 0, 39, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14891, 841, 1, 1, 1, 0, 0, 0, 0, 40, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14892, 841, 1, 1, 1, 0, 0, 0, 0, 41, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14893, 841, 1, 1, 1, 0, 0, 0, 0, 42, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19302, 841, 1, 1, 1, 0, 0, 0, 0, 62, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19303, 841, 1, 1, 1, 0, 0, 0, 0, 63, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19304, 841, 1, 1, 1, 0, 0, 0, 0, 64, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19305, 841, 1, 1, 1, 0, 0, 0, 0, 65, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7517, 584, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7518, 584, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10153, 637, 1, 1, 1, 0, 0, 50000, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10154, 637, 1, 1, 1, 0, 0, 50000, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10155, 637, 1, 1, 1, 0, 0, 50000, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10156, 637, 1, 1, 1, 0, 0, 50000, 2000000, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10157, 637, 1, 1, 1, 0, 0, 50000, 1000000, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10158, 637, 1, 1, 1, 0, 0, 50000, 749999, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10159, 637, 1, 1, 1, 0, 0, 4999990, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10160, 637, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19211, 637, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19270, 869, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18146, 869, 1, 1, 1, 1, 1, 0, 150214, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18147, 869, 1, 1, 1, 1, 1, 0, 150214, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18133, 867, 1, 1, 1, 1, 1, 22497, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18148, 869, 1, 1, 1, 1, 1, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18134, 867, 1, 1, 1, 1, 1, 22497, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18135, 867, 1, 1, 1, 1, 1, 22497, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18121, 866, 1, 1, 1, 1, 1, 200, 749888, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18122, 866, 1, 1, 1, 1, 1, 200, 749888, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18149, 869, 1, 1, 1, 1, 1, 0, 150214, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18136, 867, 1, 1, 1, 1, 1, 22497, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18150, 869, 1, 1, 1, 1, 1, 0, 150214, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18137, 867, 1, 1, 1, 1, 1, 22497, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18123, 866, 1, 1, 1, 1, 1, 200, 749888, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18151, 869, 1, 1, 1, 1, 1, 0, 150214, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18138, 867, 1, 1, 1, 1, 1, 22497, 74989, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18124, 866, 1, 1, 1, 1, 1, 200, 749888, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18152, 869, 1, 1, 1, 1, 1, 0, 150214, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18139, 867, 1, 1, 1, 1, 1, 22497, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18153, 869, 1, 1, 1, 1, 1, 0, 150214, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18125, 866, 1, 1, 1, 1, 1, 200, 749888, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18140, 867, 1, 1, 1, 1, 1, 22497, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18126, 866, 1, 1, 1, 1, 1, 200, 374944, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18154, 869, 1, 1, 1, 1, 1, 0, 150214, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19117, 902, 1, 1, 1, 0, 0, 25001, 250001, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18127, 866, 1, 1, 1, 1, 1, 200, 374944, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18141, 867, 1, 1, 1, 1, 1, 22497, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19206, 670, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19206, 670, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10989, 670, 1, 1, 1, 0, 0, 37494, 187472, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10990, 670, 1, 1, 1, 0, 0, 37494, 187472, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19240, 640, 1, 1, 1, 0, 0, 501099, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19240, 640, 1, 1, 1, 0, 0, 501099, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10173, 640, 1, 1, 1, 0, 0, 1002199, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10173, 640, 1, 1, 1, 0, 0, 1002199, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10173, 640, 1, 1, 1, 0, 0, 1002199, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10174, 640, 1, 1, 1, 0, 0, 90198, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10174, 640, 1, 1, 1, 0, 0, 90198, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10174, 640, 1, 1, 1, 0, 0, 90198, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10174, 640, 1, 1, 1, 0, 0, 90198, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10175, 640, 1, 1, 1, 0, 0, 1002199, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10175, 640, 1, 1, 1, 0, 0, 1002199, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10175, 640, 1, 1, 1, 0, 0, 1002199, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10175, 640, 1, 1, 1, 0, 0, 1002199, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10176, 640, 1, 1, 1, 0, 0, 90198, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10370, 648, 1, 1, 1, 1, 1, 200, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10989, 670, 1, 1, 1, 0, 0, 37494, 187472, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19207, 671, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19207, 671, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10990, 670, 1, 1, 1, 0, 0, 37494, 187472, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10371, 648, 1, 1, 1, 1, 1, 200, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10992, 671, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10992, 671, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10993, 671, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10993, 671, 1, 1, 1, 1, 1, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10994, 671, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10994, 671, 1, 1, 1, 1, 1, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 11630, 717, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10995, 671, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10995, 671, 1, 1, 1, 1, 1, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10168, 640, 1, 1, 1, 0, 0, 40088, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10171, 640, 1, 1, 1, 0, 0, 250550, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7519, 584, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7520, 584, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7521, 584, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7522, 584, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7523, 584, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7524, 584, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7525, 584, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7526, 584, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7527, 584, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19246, 828, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19247, 828, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19248, 828, 1, 1, 1, 1, 1, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19249, 828, 1, 1, 1, 1, 1, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19250, 828, 1, 1, 1, 1, 1, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19252, 828, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19254, 828, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19255, 828, 1, 1, 1, 1, 1, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19256, 828, 1, 1, 1, 1, 1, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19257, 828, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19273, 843, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14935, 843, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14936, 843, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14937, 843, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19110, 902, 1, 1, 1, 0, 0, 25001, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14938, 843, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14939, 843, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19111, 902, 1, 1, 1, 1, 1, 25001, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14940, 843, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19112, 902, 1, 1, 1, 0, 0, 25001, 150000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14941, 843, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19113, 902, 1, 1, 1, 0, 0, 25001, 2000000, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19114, 902, 1, 1, 1, 0, 0, 25001, 600000, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14942, 843, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14943, 843, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19115, 902, 1, 1, 1, 0, 0, 25001, 200000, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19283, 843, 1, 1, 1, 0, 0, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19116, 902, 1, 1, 1, 0, 0, 25001, 150000, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19170, 908, 1, 1, 1, 0, 0, 0, 140316, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19171, 908, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2713, 250, 1, 1, 1, 1, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2715, 250, 1, 1, 1, 1, 0, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19172, 909, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19173, 909, 1, 1, 1, 1, 1, 0, 0, 1, NULL, '2');
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19174, 909, 1, 1, 1, 1, 1, 0, 0, 2, NULL, '3');
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19175, 909, 1, 1, 1, 1, 1, 0, 0, 3, NULL, '4');
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19210, 787, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14258, 787, 1, 1, 1, 0, 0, 20, 400880, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14259, 787, 1, 1, 1, 0, 0, 20, 80176, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14260, 787, 1, 1, 1, 0, 0, 20, 801759, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10176, 640, 1, 1, 1, 0, 0, 90198, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10176, 640, 1, 1, 1, 0, 0, 90198, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10176, 640, 1, 1, 1, 0, 0, 90198, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10177, 640, 1, 1, 1, 0, 0, 40088, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10177, 640, 1, 1, 1, 0, 0, 40088, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10177, 640, 1, 1, 1, 0, 0, 40088, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10177, 640, 1, 1, 1, 0, 0, 40088, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10178, 640, 1, 1, 1, 0, 0, 90198, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10178, 640, 1, 1, 1, 0, 0, 90198, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10178, 640, 1, 1, 1, 0, 0, 90198, 0, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10178, 640, 1, 1, 1, 0, 0, 90198, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10179, 640, 1, 1, 1, 0, 0, 90198, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10179, 640, 1, 1, 1, 0, 0, 90198, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10179, 640, 1, 1, 1, 0, 0, 90198, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10179, 640, 1, 1, 1, 0, 0, 90198, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19271, 866, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18120, 866, 1, 1, 1, 1, 1, 200, 749888, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19118, 902, 1, 1, 1, 0, 0, 25001, 250001, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18128, 866, 1, 1, 1, 1, 1, 200, 374944, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19119, 902, 1, 1, 1, 0, 0, 25001, 100000, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18129, 866, 1, 1, 1, 1, 1, 200, 374944, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19120, 902, 1, 1, 1, 0, 0, 25001, 250001, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18130, 866, 1, 1, 1, 1, 1, 200, 374944, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19121, 902, 1, 1, 1, 0, 0, 25001, 749999, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19122, 902, 1, 1, 1, 0, 0, 25001, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18131, 866, 1, 1, 1, 1, 1, 200, 374944, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19123, 902, 1, 1, 1, 0, 0, 25001, 100000, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19124, 902, 1, 1, 1, 0, 0, 2000000, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14999, 844, 1, 1, 1, 1, 1, 0, 0, 48, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14986, 844, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15000, 844, 1, 1, 1, 1, 1, 0, 0, 49, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14985, 844, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14987, 844, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14975, 844, 1, 1, 1, 1, 1, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14989, 844, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15003, 844, 1, 1, 1, 1, 1, 0, 0, 52, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14992, 844, 1, 1, 1, 1, 1, 0, 0, 41, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14979, 844, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19300, 844, 1, 1, 1, 1, 1, 0, 0, 50, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19301, 844, 1, 1, 1, 1, 1, 0, 0, 51, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14996, 844, 1, 1, 1, 1, 1, 0, 0, 45, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15007, 844, 1, 1, 1, 1, 1, 0, 0, 56, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15009, 844, 1, 1, 1, 1, 1, 0, 0, 58, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19356, 824, 1, 1, 1, 0, 0, 0, 0, 48, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19357, 824, 1, 1, 1, 0, 0, 0, 0, 49, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19358, 824, 1, 1, 1, 0, 0, 0, 0, 50, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19359, 824, 1, 1, 1, 0, 0, 0, 0, 51, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19360, 824, 1, 1, 1, 0, 0, 0, 0, 52, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19361, 824, 1, 1, 1, 0, 0, 0, 0, 53, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19362, 824, 1, 1, 1, 0, 0, 0, 0, 54, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19363, 824, 1, 1, 1, 0, 0, 0, 0, 55, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19364, 824, 1, 1, 1, 0, 0, 0, 0, 56, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19365, 824, 1, 1, 1, 0, 0, 0, 0, 57, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19366, 824, 1, 1, 1, 0, 0, 0, 0, 58, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19367, 824, 1, 1, 1, 0, 0, 0, 0, 59, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19368, 824, 1, 1, 1, 0, 0, 0, 0, 60, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19369, 824, 1, 1, 1, 0, 0, 0, 0, 61, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19370, 824, 1, 1, 1, 0, 0, 0, 0, 62, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19371, 824, 1, 1, 1, 0, 0, 0, 0, 63, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19372, 824, 1, 1, 1, 0, 0, 0, 0, 64, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19373, 824, 1, 1, 1, 0, 0, 0, 0, 65, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19374, 824, 1, 1, 1, 0, 0, 0, 0, 66, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19375, 824, 1, 1, 1, 0, 0, 0, 0, 67, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19376, 824, 1, 1, 1, 0, 0, 0, 0, 68, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19377, 824, 1, 1, 1, 0, 0, 0, 0, 69, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19378, 824, 1, 1, 1, 0, 0, 0, 0, 70, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19379, 824, 1, 1, 1, 0, 0, 0, 0, 71, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19380, 824, 1, 1, 1, 0, 0, 0, 0, 72, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19381, 824, 1, 1, 1, 0, 0, 0, 0, 73, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19382, 824, 1, 1, 1, 0, 0, 0, 0, 74, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19383, 824, 1, 1, 1, 0, 0, 0, 0, 75, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19384, 824, 1, 1, 1, 0, 0, 0, 0, 76, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19385, 824, 1, 1, 1, 0, 0, 0, 0, 77, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19386, 824, 1, 1, 1, 0, 0, 0, 0, 78, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19387, 824, 1, 1, 1, 0, 0, 0, 0, 79, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19388, 824, 1, 1, 1, 0, 0, 0, 0, 80, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19389, 824, 1, 1, 1, 0, 0, 0, 0, 81, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19390, 824, 1, 1, 1, 0, 0, 0, 0, 82, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19391, 824, 1, 1, 1, 0, 0, 0, 0, 83, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19392, 824, 1, 1, 1, 0, 0, 0, 0, 84, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19393, 824, 1, 1, 1, 0, 0, 0, 0, 85, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19394, 824, 1, 1, 1, 0, 0, 0, 0, 86, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19395, 824, 1, 1, 1, 0, 0, 0, 0, 87, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19396, 824, 1, 1, 1, 0, 0, 0, 0, 88, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19397, 824, 1, 1, 1, 0, 0, 0, 0, 89, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19398, 824, 1, 1, 1, 0, 0, 0, 0, 90, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19399, 824, 1, 1, 1, 0, 0, 0, 0, 91, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19400, 824, 1, 1, 1, 0, 0, 0, 0, 92, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19401, 824, 1, 1, 1, 0, 0, 0, 0, 93, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19402, 824, 1, 1, 1, 0, 0, 0, 0, 94, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19403, 824, 1, 1, 1, 0, 0, 0, 0, 95, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19404, 824, 1, 1, 1, 0, 0, 0, 0, 96, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19405, 824, 1, 1, 1, 0, 0, 0, 0, 97, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19406, 824, 1, 1, 1, 0, 0, 0, 0, 98, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19407, 824, 1, 1, 1, 0, 0, 0, 0, 99, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19408, 824, 1, 1, 1, 0, 0, 0, 0, 100, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19409, 824, 1, 1, 1, 0, 0, 0, 0, 101, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19410, 824, 1, 1, 1, 0, 0, 0, 0, 102, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19411, 824, 1, 1, 1, 0, 0, 0, 0, 103, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19412, 824, 1, 1, 1, 0, 0, 0, 0, 104, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19413, 824, 1, 1, 1, 0, 0, 0, 0, 105, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19414, 824, 1, 1, 1, 0, 0, 0, 0, 106, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19415, 824, 1, 1, 1, 0, 0, 0, 0, 107, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19416, 824, 1, 1, 1, 0, 0, 0, 0, 108, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19417, 824, 1, 1, 1, 0, 0, 0, 0, 109, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19418, 824, 1, 1, 1, 0, 0, 0, 0, 110, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19419, 824, 1, 1, 1, 0, 0, 0, 0, 111, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19420, 824, 1, 1, 1, 0, 0, 0, 0, 112, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19421, 824, 1, 1, 1, 0, 0, 0, 0, 113, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19422, 824, 1, 1, 1, 0, 0, 0, 0, 114, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19423, 824, 1, 1, 1, 0, 0, 0, 0, 115, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19424, 824, 1, 1, 1, 0, 0, 0, 0, 116, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19425, 824, 1, 1, 1, 0, 0, 0, 0, 117, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19426, 824, 1, 1, 1, 0, 0, 0, 0, 118, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19427, 824, 1, 1, 1, 0, 0, 0, 0, 119, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19428, 824, 1, 1, 1, 0, 0, 0, 0, 120, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19429, 824, 1, 1, 1, 0, 0, 0, 0, 121, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19430, 824, 1, 1, 1, 0, 0, 0, 0, 122, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19431, 824, 1, 1, 1, 0, 0, 0, 0, 123, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19432, 824, 1, 1, 1, 0, 0, 0, 0, 124, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19433, 824, 1, 1, 1, 0, 0, 0, 0, 125, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19434, 824, 1, 1, 1, 0, 0, 0, 0, 126, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19435, 824, 1, 1, 1, 0, 0, 0, 0, 127, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19436, 824, 1, 1, 1, 0, 0, 0, 0, 128, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19437, 824, 1, 1, 1, 0, 0, 0, 0, 129, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19438, 824, 1, 1, 1, 0, 0, 0, 0, 130, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19439, 824, 1, 1, 1, 0, 0, 0, 0, 131, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19440, 824, 1, 1, 1, 0, 0, 0, 0, 132, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19441, 824, 1, 1, 1, 0, 0, 0, 0, 133, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19442, 824, 1, 1, 1, 0, 0, 0, 0, 134, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19443, 824, 1, 1, 1, 0, 0, 0, 0, 135, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19444, 824, 1, 1, 1, 0, 0, 0, 0, 136, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19445, 824, 1, 1, 1, 0, 0, 0, 0, 137, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19446, 824, 1, 1, 1, 0, 0, 0, 0, 138, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19447, 824, 1, 1, 1, 0, 0, 0, 0, 139, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19448, 824, 1, 1, 1, 0, 0, 0, 0, 140, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19449, 824, 1, 1, 1, 0, 0, 0, 0, 141, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19450, 824, 1, 1, 1, 0, 0, 0, 0, 142, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19451, 824, 1, 1, 1, 0, 0, 0, 0, 143, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19452, 824, 1, 1, 1, 0, 0, 0, 0, 144, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19453, 824, 1, 1, 1, 0, 0, 0, 0, 145, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19454, 824, 1, 1, 1, 0, 0, 0, 0, 146, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19455, 824, 1, 1, 1, 0, 0, 0, 0, 147, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19456, 824, 1, 1, 1, 0, 0, 0, 0, 148, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19457, 824, 1, 1, 1, 0, 0, 0, 0, 149, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19458, 824, 1, 1, 1, 0, 0, 0, 0, 150, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19459, 824, 1, 1, 1, 0, 0, 0, 0, 151, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19460, 824, 1, 1, 1, 0, 0, 0, 0, 152, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19461, 824, 1, 1, 1, 0, 0, 0, 0, 153, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19462, 824, 1, 1, 1, 0, 0, 0, 0, 154, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19463, 824, 1, 1, 1, 0, 0, 0, 0, 155, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19464, 824, 1, 1, 1, 0, 0, 0, 0, 156, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19465, 824, 1, 1, 1, 0, 0, 0, 0, 157, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19466, 824, 1, 1, 1, 0, 0, 0, 0, 158, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19467, 824, 1, 1, 1, 0, 0, 0, 0, 159, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19468, 824, 1, 1, 1, 0, 0, 0, 0, 160, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19469, 824, 1, 1, 1, 0, 0, 0, 0, 161, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19470, 824, 1, 1, 1, 0, 0, 0, 0, 162, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19471, 824, 1, 1, 1, 0, 0, 0, 0, 163, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19472, 824, 1, 1, 1, 0, 0, 0, 0, 164, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19473, 824, 1, 1, 1, 0, 0, 0, 0, 165, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19474, 824, 1, 1, 1, 0, 0, 0, 0, 166, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19475, 824, 1, 1, 1, 0, 0, 0, 0, 167, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19476, 824, 1, 1, 1, 0, 0, 0, 0, 168, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19477, 824, 1, 1, 1, 0, 0, 0, 0, 169, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19478, 824, 1, 1, 1, 0, 0, 0, 0, 170, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19479, 824, 1, 1, 1, 0, 0, 0, 0, 171, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19480, 824, 1, 1, 1, 0, 0, 0, 0, 172, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19481, 824, 1, 1, 1, 0, 0, 0, 0, 173, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19482, 824, 1, 1, 1, 0, 0, 0, 0, 174, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19483, 824, 1, 1, 1, 0, 0, 0, 0, 175, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19484, 824, 1, 1, 1, 0, 0, 0, 0, 176, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19485, 824, 1, 1, 1, 0, 0, 0, 0, 177, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19486, 824, 1, 1, 1, 0, 0, 0, 0, 178, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19487, 824, 1, 1, 1, 0, 0, 0, 0, 179, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19488, 824, 1, 1, 1, 0, 0, 0, 0, 180, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19489, 824, 1, 1, 1, 0, 0, 0, 0, 181, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19490, 824, 1, 1, 1, 0, 0, 0, 0, 182, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19491, 824, 1, 1, 1, 0, 0, 0, 0, 183, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19492, 824, 1, 1, 1, 0, 0, 0, 0, 184, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19493, 824, 1, 1, 1, 0, 0, 0, 0, 185, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19494, 824, 1, 1, 1, 0, 0, 0, 0, 186, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19495, 824, 1, 1, 1, 0, 0, 0, 0, 187, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19496, 824, 1, 1, 1, 0, 0, 0, 0, 188, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19497, 824, 1, 1, 1, 0, 0, 0, 0, 189, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19498, 824, 1, 1, 1, 0, 0, 0, 0, 190, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19499, 824, 1, 1, 1, 0, 0, 0, 0, 191, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19500, 824, 1, 1, 1, 0, 0, 0, 0, 192, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19501, 824, 1, 1, 1, 0, 0, 0, 0, 193, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19502, 824, 1, 1, 1, 0, 0, 0, 0, 194, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19503, 824, 1, 1, 1, 0, 0, 0, 0, 195, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19504, 824, 1, 1, 1, 0, 0, 0, 0, 196, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19505, 824, 1, 1, 1, 0, 0, 0, 0, 197, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19506, 824, 1, 1, 1, 0, 0, 0, 0, 198, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19507, 824, 1, 1, 1, 0, 0, 0, 0, 199, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19508, 824, 1, 1, 1, 0, 0, 0, 0, 200, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19509, 824, 1, 1, 1, 0, 0, 0, 0, 201, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19510, 824, 1, 1, 1, 0, 0, 0, 0, 202, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19511, 824, 1, 1, 1, 0, 0, 0, 0, 203, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19512, 824, 1, 1, 1, 0, 0, 0, 0, 204, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19513, 824, 1, 1, 1, 0, 0, 0, 0, 205, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19514, 824, 1, 1, 1, 0, 0, 0, 0, 206, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19515, 824, 1, 1, 1, 0, 0, 0, 0, 207, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19516, 824, 1, 1, 1, 0, 0, 0, 0, 208, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19517, 824, 1, 1, 1, 0, 0, 0, 0, 209, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19518, 824, 1, 1, 1, 0, 0, 0, 0, 210, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19519, 824, 1, 1, 1, 0, 0, 0, 0, 211, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19520, 824, 1, 1, 1, 0, 0, 0, 0, 212, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19521, 824, 1, 1, 1, 0, 0, 0, 0, 213, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19522, 824, 1, 1, 1, 0, 0, 0, 0, 214, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19523, 824, 1, 1, 1, 0, 0, 0, 0, 215, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19524, 824, 1, 1, 1, 0, 0, 0, 0, 216, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19525, 824, 1, 1, 1, 0, 0, 0, 0, 217, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19526, 824, 1, 1, 1, 0, 0, 0, 0, 218, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19527, 824, 1, 1, 1, 0, 0, 0, 0, 219, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19528, 824, 1, 1, 1, 0, 0, 0, 0, 220, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19529, 824, 1, 1, 1, 0, 0, 0, 0, 221, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19530, 824, 1, 1, 1, 0, 0, 0, 0, 222, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19531, 824, 1, 1, 1, 0, 0, 0, 0, 223, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19532, 824, 1, 1, 1, 0, 0, 0, 0, 224, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19533, 824, 1, 1, 1, 0, 0, 0, 0, 225, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19534, 824, 1, 1, 1, 0, 0, 0, 0, 226, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19535, 824, 1, 1, 1, 0, 0, 0, 0, 227, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19536, 824, 1, 1, 1, 0, 0, 0, 0, 228, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19537, 824, 1, 1, 1, 0, 0, 0, 0, 229, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19538, 824, 1, 1, 1, 0, 0, 0, 0, 230, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19539, 824, 1, 1, 1, 0, 0, 0, 0, 231, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19540, 824, 1, 1, 1, 0, 0, 0, 0, 232, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19541, 824, 1, 1, 1, 0, 0, 0, 0, 233, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19542, 824, 1, 1, 1, 0, 0, 0, 0, 234, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19543, 824, 1, 1, 1, 0, 0, 0, 0, 235, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19544, 824, 1, 1, 1, 0, 0, 0, 0, 236, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19545, 824, 1, 1, 1, 0, 0, 0, 0, 237, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19546, 824, 1, 1, 1, 0, 0, 0, 0, 238, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19547, 824, 1, 1, 1, 0, 0, 0, 0, 239, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19548, 824, 1, 1, 1, 0, 0, 0, 0, 240, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19549, 824, 1, 1, 1, 0, 0, 0, 0, 241, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19550, 824, 1, 1, 1, 0, 0, 0, 0, 242, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19551, 824, 1, 1, 1, 0, 0, 0, 0, 243, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19552, 824, 1, 1, 1, 0, 0, 0, 0, 244, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19553, 824, 1, 1, 1, 0, 0, 0, 0, 245, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19554, 824, 1, 1, 1, 0, 0, 0, 0, 246, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19555, 824, 1, 1, 1, 0, 0, 0, 0, 247, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19556, 824, 1, 1, 1, 0, 0, 0, 0, 248, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19557, 824, 1, 1, 1, 0, 0, 0, 0, 249, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19558, 824, 1, 1, 1, 0, 0, 0, 0, 250, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19559, 824, 1, 1, 1, 0, 0, 0, 0, 251, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19560, 824, 1, 1, 1, 0, 0, 0, 0, 252, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19561, 824, 1, 1, 1, 0, 0, 0, 0, 253, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19562, 824, 1, 1, 1, 0, 0, 0, 0, 254, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19563, 824, 1, 1, 1, 0, 0, 0, 0, 255, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19564, 824, 1, 1, 1, 0, 0, 0, 0, 256, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19565, 824, 1, 1, 1, 0, 0, 0, 0, 257, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19566, 824, 1, 1, 1, 0, 0, 0, 0, 258, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19567, 824, 1, 1, 1, 0, 0, 0, 0, 259, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19568, 824, 1, 1, 1, 0, 0, 0, 0, 260, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19569, 824, 1, 1, 1, 0, 0, 0, 0, 261, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19570, 824, 1, 1, 1, 0, 0, 0, 0, 262, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19571, 824, 1, 1, 1, 0, 0, 0, 0, 263, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19572, 824, 1, 1, 1, 0, 0, 0, 0, 264, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19573, 824, 1, 1, 1, 0, 0, 0, 0, 265, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19574, 824, 1, 1, 1, 0, 0, 0, 0, 266, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19575, 824, 1, 1, 1, 0, 0, 0, 0, 267, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19576, 824, 1, 1, 1, 0, 0, 0, 0, 268, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19577, 824, 1, 1, 1, 0, 0, 0, 0, 269, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19578, 824, 1, 1, 1, 0, 0, 0, 0, 270, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19579, 824, 1, 1, 1, 0, 0, 0, 0, 271, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19580, 824, 1, 1, 1, 0, 0, 0, 0, 272, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19581, 824, 1, 1, 1, 0, 0, 0, 0, 273, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19582, 824, 1, 1, 1, 0, 0, 0, 0, 274, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19583, 824, 1, 1, 1, 0, 0, 0, 0, 275, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19584, 824, 1, 1, 1, 0, 0, 0, 0, 276, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19585, 824, 1, 1, 1, 0, 0, 0, 0, 277, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19586, 824, 1, 1, 1, 0, 0, 0, 0, 278, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19587, 824, 1, 1, 1, 0, 0, 0, 0, 279, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19588, 824, 1, 1, 1, 0, 0, 0, 0, 280, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19589, 824, 1, 1, 1, 0, 0, 0, 0, 281, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19590, 824, 1, 1, 1, 0, 0, 0, 0, 282, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19591, 824, 1, 1, 1, 0, 0, 0, 0, 283, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19592, 824, 1, 1, 1, 0, 0, 0, 0, 284, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19593, 824, 1, 1, 1, 0, 0, 0, 0, 285, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19594, 824, 1, 1, 1, 0, 0, 0, 0, 286, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19595, 824, 1, 1, 1, 0, 0, 0, 0, 287, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19596, 824, 1, 1, 1, 0, 0, 0, 0, 288, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19597, 824, 1, 1, 1, 0, 0, 0, 0, 289, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19598, 824, 1, 1, 1, 0, 0, 0, 0, 290, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19599, 824, 1, 1, 1, 0, 0, 0, 0, 291, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19600, 824, 1, 1, 1, 0, 0, 0, 0, 292, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19601, 824, 1, 1, 1, 0, 0, 0, 0, 293, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19602, 824, 1, 1, 1, 0, 0, 0, 0, 294, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19603, 824, 1, 1, 1, 0, 0, 0, 0, 295, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19604, 824, 1, 1, 1, 0, 0, 0, 0, 296, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19605, 824, 1, 1, 1, 0, 0, 0, 0, 297, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19606, 824, 1, 1, 1, 0, 0, 0, 0, 298, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19607, 824, 1, 1, 1, 0, 0, 0, 0, 299, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19608, 824, 1, 1, 1, 0, 0, 0, 0, 300, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19609, 824, 1, 1, 1, 0, 0, 0, 0, 301, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19610, 824, 1, 1, 1, 0, 0, 0, 0, 302, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19611, 824, 1, 1, 1, 0, 0, 0, 0, 303, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19612, 824, 1, 1, 1, 0, 0, 0, 0, 304, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19613, 824, 1, 1, 1, 0, 0, 0, 0, 305, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19614, 824, 1, 1, 1, 0, 0, 0, 0, 306, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19615, 824, 1, 1, 1, 0, 0, 0, 0, 307, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19616, 824, 1, 1, 1, 0, 0, 0, 0, 308, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19617, 824, 1, 1, 1, 0, 0, 0, 0, 309, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19618, 824, 1, 1, 1, 0, 0, 0, 0, 310, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19619, 824, 1, 1, 1, 0, 0, 0, 0, 311, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19620, 824, 1, 1, 1, 0, 0, 0, 0, 312, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19621, 824, 1, 1, 1, 0, 0, 0, 0, 313, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19622, 824, 1, 1, 1, 0, 0, 0, 0, 314, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19623, 824, 1, 1, 1, 0, 0, 0, 0, 315, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19624, 824, 1, 1, 1, 0, 0, 0, 0, 316, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19625, 824, 1, 1, 1, 0, 0, 0, 0, 317, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19626, 824, 1, 1, 1, 0, 0, 0, 0, 318, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19627, 824, 1, 1, 1, 0, 0, 0, 0, 319, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19628, 824, 1, 1, 1, 0, 0, 0, 0, 320, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19629, 824, 1, 1, 1, 0, 0, 0, 0, 321, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19630, 824, 1, 1, 1, 0, 0, 0, 0, 322, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19631, 824, 1, 1, 1, 0, 0, 0, 0, 323, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19632, 824, 1, 1, 1, 0, 0, 0, 0, 324, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19633, 824, 1, 1, 1, 0, 0, 0, 0, 325, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19634, 824, 1, 1, 1, 0, 0, 0, 0, 326, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19635, 824, 1, 1, 1, 0, 0, 0, 0, 327, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19636, 824, 1, 1, 1, 0, 0, 0, 0, 328, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19637, 824, 1, 1, 1, 0, 0, 0, 0, 329, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19638, 824, 1, 1, 1, 0, 0, 0, 0, 330, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19639, 824, 1, 1, 1, 0, 0, 0, 0, 331, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19640, 824, 1, 1, 1, 0, 0, 0, 0, 332, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19641, 824, 1, 1, 1, 0, 0, 0, 0, 333, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19642, 824, 1, 1, 1, 0, 0, 0, 0, 334, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19643, 824, 1, 1, 1, 0, 0, 0, 0, 335, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19644, 824, 1, 1, 1, 0, 0, 0, 0, 336, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19645, 824, 1, 1, 1, 0, 0, 0, 0, 337, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19646, 824, 1, 1, 1, 0, 0, 0, 0, 338, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19647, 824, 1, 1, 1, 0, 0, 0, 0, 339, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19648, 824, 1, 1, 1, 0, 0, 0, 0, 340, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19649, 824, 1, 1, 1, 0, 0, 0, 0, 341, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19650, 824, 1, 1, 1, 0, 0, 0, 0, 342, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19651, 824, 1, 1, 1, 0, 0, 0, 0, 343, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19652, 824, 1, 1, 1, 0, 0, 0, 0, 344, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19653, 824, 1, 1, 1, 0, 0, 0, 0, 345, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19654, 824, 1, 1, 1, 0, 0, 0, 0, 346, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19655, 824, 1, 1, 1, 0, 0, 0, 0, 347, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19656, 824, 1, 1, 1, 0, 0, 0, 0, 348, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19657, 824, 1, 1, 1, 0, 0, 0, 0, 349, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19658, 824, 1, 1, 1, 0, 0, 0, 0, 350, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19659, 824, 1, 1, 1, 0, 0, 0, 0, 351, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19660, 824, 1, 1, 1, 0, 0, 0, 0, 352, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19661, 824, 1, 1, 1, 0, 0, 0, 0, 353, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19662, 824, 1, 1, 1, 0, 0, 0, 0, 354, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19663, 824, 1, 1, 1, 0, 0, 0, 0, 355, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19664, 824, 1, 1, 1, 0, 0, 0, 0, 356, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19665, 824, 1, 1, 1, 0, 0, 0, 0, 357, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19666, 824, 1, 1, 1, 0, 0, 0, 0, 358, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19667, 824, 1, 1, 1, 0, 0, 0, 0, 359, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19668, 824, 1, 1, 1, 0, 0, 0, 0, 360, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19669, 824, 1, 1, 1, 0, 0, 0, 0, 361, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19670, 824, 1, 1, 1, 0, 0, 0, 0, 362, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19671, 824, 1, 1, 1, 0, 0, 0, 0, 363, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19672, 824, 1, 1, 1, 0, 0, 0, 0, 364, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19673, 824, 1, 1, 1, 0, 0, 0, 0, 365, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19674, 824, 1, 1, 1, 0, 0, 0, 0, 366, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19675, 824, 1, 1, 1, 0, 0, 0, 0, 367, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19676, 824, 1, 1, 1, 0, 0, 0, 0, 368, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19677, 824, 1, 1, 1, 0, 0, 0, 0, 369, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19678, 824, 1, 1, 1, 0, 0, 0, 0, 370, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19679, 824, 1, 1, 1, 0, 0, 0, 0, 371, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19680, 824, 1, 1, 1, 0, 0, 0, 0, 372, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19681, 824, 1, 1, 1, 0, 0, 0, 0, 373, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19682, 824, 1, 1, 1, 0, 0, 0, 0, 374, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19683, 824, 1, 1, 1, 0, 0, 0, 0, 375, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19684, 824, 1, 1, 1, 0, 0, 0, 0, 376, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19685, 824, 1, 1, 1, 0, 0, 0, 0, 377, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19686, 824, 1, 1, 1, 0, 0, 0, 0, 378, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19687, 824, 1, 1, 1, 0, 0, 0, 0, 379, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19688, 824, 1, 1, 1, 0, 0, 0, 0, 380, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19689, 824, 1, 1, 1, 0, 0, 0, 0, 381, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19690, 824, 1, 1, 1, 0, 0, 0, 0, 382, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19691, 824, 1, 1, 1, 0, 0, 0, 0, 383, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19692, 824, 1, 1, 1, 0, 0, 0, 0, 384, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19693, 824, 1, 1, 1, 0, 0, 0, 0, 385, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19694, 824, 1, 1, 1, 0, 0, 0, 0, 386, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19695, 824, 1, 1, 1, 0, 0, 0, 0, 387, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19696, 824, 1, 1, 1, 0, 0, 0, 0, 388, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19697, 824, 1, 1, 1, 0, 0, 0, 0, 389, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19698, 824, 1, 1, 1, 0, 0, 0, 0, 390, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19699, 824, 1, 1, 1, 0, 0, 0, 0, 391, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19700, 824, 1, 1, 1, 0, 0, 0, 0, 392, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19701, 824, 1, 1, 1, 0, 0, 0, 0, 393, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19702, 824, 1, 1, 1, 0, 0, 0, 0, 394, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19703, 824, 1, 1, 1, 0, 0, 0, 0, 395, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19704, 824, 1, 1, 1, 0, 0, 0, 0, 396, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19705, 824, 1, 1, 1, 0, 0, 0, 0, 397, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19706, 824, 1, 1, 1, 0, 0, 0, 0, 398, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19707, 824, 1, 1, 1, 0, 0, 0, 0, 399, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19708, 824, 1, 1, 1, 0, 0, 0, 0, 400, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19709, 824, 1, 1, 1, 0, 0, 0, 0, 401, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19710, 824, 1, 1, 1, 0, 0, 0, 0, 402, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19711, 824, 1, 1, 1, 0, 0, 0, 0, 403, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19712, 824, 1, 1, 1, 0, 0, 0, 0, 404, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19713, 824, 1, 1, 1, 0, 0, 0, 0, 405, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19714, 824, 1, 1, 1, 0, 0, 0, 0, 406, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19715, 824, 1, 1, 1, 0, 0, 0, 0, 407, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19716, 824, 1, 1, 1, 0, 0, 0, 0, 408, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19717, 824, 1, 1, 1, 0, 0, 0, 0, 409, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19718, 824, 1, 1, 1, 0, 0, 0, 0, 410, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19719, 824, 1, 1, 1, 0, 0, 0, 0, 411, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19720, 824, 1, 1, 1, 0, 0, 0, 0, 412, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19721, 824, 1, 1, 1, 0, 0, 0, 0, 413, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19722, 824, 1, 1, 1, 0, 0, 0, 0, 414, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19723, 824, 1, 1, 1, 0, 0, 0, 0, 415, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19724, 824, 1, 1, 1, 0, 0, 0, 0, 416, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19725, 824, 1, 1, 1, 0, 0, 0, 0, 417, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19726, 824, 1, 1, 1, 0, 0, 0, 0, 418, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19727, 824, 1, 1, 1, 0, 0, 0, 0, 419, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19728, 824, 1, 1, 1, 0, 0, 0, 0, 420, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19729, 824, 1, 1, 1, 0, 0, 0, 0, 421, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19730, 824, 1, 1, 1, 0, 0, 0, 0, 422, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19731, 824, 1, 1, 1, 0, 0, 0, 0, 423, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19732, 824, 1, 1, 1, 0, 0, 0, 0, 424, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19733, 824, 1, 1, 1, 0, 0, 0, 0, 425, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19734, 824, 1, 1, 1, 0, 0, 0, 0, 426, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19735, 824, 1, 1, 1, 0, 0, 0, 0, 427, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19736, 824, 1, 1, 1, 0, 0, 0, 0, 428, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19737, 824, 1, 1, 1, 0, 0, 0, 0, 429, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19738, 824, 1, 1, 1, 0, 0, 0, 0, 430, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19739, 824, 1, 1, 1, 0, 0, 0, 0, 431, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19740, 824, 1, 1, 1, 0, 0, 0, 0, 432, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19741, 824, 1, 1, 1, 0, 0, 0, 0, 433, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19742, 824, 1, 1, 1, 0, 0, 0, 0, 434, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19743, 824, 1, 1, 1, 0, 0, 0, 0, 435, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19744, 824, 1, 1, 1, 0, 0, 0, 0, 436, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19745, 824, 1, 1, 1, 0, 0, 0, 0, 437, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19746, 824, 1, 1, 1, 0, 0, 0, 0, 438, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19747, 824, 1, 1, 1, 0, 0, 0, 0, 439, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19748, 824, 1, 1, 1, 0, 0, 0, 0, 440, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19749, 824, 1, 1, 1, 0, 0, 0, 0, 441, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19750, 824, 1, 1, 1, 0, 0, 0, 0, 442, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19751, 824, 1, 1, 1, 0, 0, 0, 0, 443, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19752, 824, 1, 1, 1, 0, 0, 0, 0, 444, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19753, 824, 1, 1, 1, 0, 0, 0, 0, 445, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19754, 824, 1, 1, 1, 0, 0, 0, 0, 446, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19755, 824, 1, 1, 1, 0, 0, 0, 0, 447, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19756, 824, 1, 1, 1, 0, 0, 0, 0, 448, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19757, 824, 1, 1, 1, 0, 0, 0, 0, 449, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19758, 824, 1, 1, 1, 0, 0, 0, 0, 450, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19759, 824, 1, 1, 1, 0, 0, 0, 0, 451, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19760, 824, 1, 1, 1, 0, 0, 0, 0, 452, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19761, 824, 1, 1, 1, 0, 0, 0, 0, 453, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19762, 824, 1, 1, 1, 0, 0, 0, 0, 454, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19763, 824, 1, 1, 1, 0, 0, 0, 0, 455, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19764, 824, 1, 1, 1, 0, 0, 0, 0, 456, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19765, 824, 1, 1, 1, 0, 0, 0, 0, 457, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19766, 824, 1, 1, 1, 0, 0, 0, 0, 458, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19767, 824, 1, 1, 1, 0, 0, 0, 0, 459, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19768, 824, 1, 1, 1, 0, 0, 0, 0, 460, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19769, 824, 1, 1, 1, 0, 0, 0, 0, 461, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19770, 824, 1, 1, 1, 0, 0, 0, 0, 462, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19771, 824, 1, 1, 1, 0, 0, 0, 0, 463, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19772, 824, 1, 1, 1, 0, 0, 0, 0, 464, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19773, 824, 1, 1, 1, 0, 0, 0, 0, 465, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19774, 824, 1, 1, 1, 0, 0, 0, 0, 466, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19775, 824, 1, 1, 1, 0, 0, 0, 0, 467, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19776, 824, 1, 1, 1, 0, 0, 0, 0, 468, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19777, 824, 1, 1, 1, 0, 0, 0, 0, 469, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19778, 824, 1, 1, 1, 0, 0, 0, 0, 470, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19779, 824, 1, 1, 1, 0, 0, 0, 0, 471, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19780, 824, 1, 1, 1, 0, 0, 0, 0, 472, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19781, 824, 1, 1, 1, 0, 0, 0, 0, 473, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19782, 824, 1, 1, 1, 0, 0, 0, 0, 474, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19783, 824, 1, 1, 1, 0, 0, 0, 0, 475, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19784, 824, 1, 1, 1, 0, 0, 0, 0, 476, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19785, 824, 1, 1, 1, 0, 0, 0, 0, 477, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19786, 824, 1, 1, 1, 0, 0, 0, 0, 478, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19787, 824, 1, 1, 1, 0, 0, 0, 0, 479, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19788, 824, 1, 1, 1, 0, 0, 0, 0, 480, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19789, 824, 1, 1, 1, 0, 0, 0, 0, 481, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19790, 824, 1, 1, 1, 0, 0, 0, 0, 482, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19791, 824, 1, 1, 1, 0, 0, 0, 0, 483, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19792, 824, 1, 1, 1, 0, 0, 0, 0, 484, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19793, 824, 1, 1, 1, 0, 0, 0, 0, 485, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19794, 824, 1, 1, 1, 0, 0, 0, 0, 486, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19795, 824, 1, 1, 1, 0, 0, 0, 0, 487, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19796, 824, 1, 1, 1, 0, 0, 0, 0, 488, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19797, 824, 1, 1, 1, 0, 0, 0, 0, 489, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19798, 824, 1, 1, 1, 0, 0, 0, 0, 490, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19799, 824, 1, 1, 1, 0, 0, 0, 0, 491, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19800, 824, 1, 1, 1, 0, 0, 0, 0, 492, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19801, 824, 1, 1, 1, 0, 0, 0, 0, 493, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19802, 824, 1, 1, 1, 0, 0, 0, 0, 494, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19803, 824, 1, 1, 1, 0, 0, 0, 0, 495, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19804, 824, 1, 1, 1, 0, 0, 0, 0, 496, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19805, 824, 1, 1, 1, 0, 0, 0, 0, 497, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19806, 824, 1, 1, 1, 0, 0, 0, 0, 498, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19807, 824, 1, 1, 1, 0, 0, 0, 0, 499, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19808, 824, 1, 1, 1, 0, 0, 0, 0, 500, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19809, 824, 1, 1, 1, 0, 0, 0, 0, 501, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19810, 824, 1, 1, 1, 0, 0, 0, 0, 502, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19811, 824, 1, 1, 1, 0, 0, 0, 0, 503, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19812, 824, 1, 1, 1, 0, 0, 0, 0, 504, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19813, 824, 1, 1, 1, 0, 0, 0, 0, 505, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19814, 824, 1, 1, 1, 0, 0, 0, 0, 506, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19815, 824, 1, 1, 1, 0, 0, 0, 0, 507, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19816, 824, 1, 1, 1, 0, 0, 0, 0, 508, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19817, 824, 1, 1, 1, 0, 0, 0, 0, 509, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19818, 824, 1, 1, 1, 0, 0, 0, 0, 510, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19819, 824, 1, 1, 1, 0, 0, 0, 0, 511, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19820, 824, 1, 1, 1, 0, 0, 0, 0, 512, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19821, 824, 1, 1, 1, 0, 0, 0, 0, 513, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19822, 824, 1, 1, 1, 0, 0, 0, 0, 514, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19823, 824, 1, 1, 1, 0, 0, 0, 0, 515, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19824, 824, 1, 1, 1, 0, 0, 0, 0, 516, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19825, 824, 1, 1, 1, 0, 0, 0, 0, 517, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19826, 824, 1, 1, 1, 0, 0, 0, 0, 518, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19827, 824, 1, 1, 1, 0, 0, 0, 0, 519, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19828, 824, 1, 1, 1, 0, 0, 0, 0, 520, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19829, 824, 1, 1, 1, 0, 0, 0, 0, 521, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19830, 824, 1, 1, 1, 0, 0, 0, 0, 522, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19831, 824, 1, 1, 1, 0, 0, 0, 0, 523, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19832, 824, 1, 1, 1, 0, 0, 0, 0, 524, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19833, 824, 1, 1, 1, 0, 0, 0, 0, 525, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19834, 824, 1, 1, 1, 0, 0, 0, 0, 526, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19835, 824, 1, 1, 1, 0, 0, 0, 0, 527, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19836, 824, 1, 1, 1, 0, 0, 0, 0, 528, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19837, 824, 1, 1, 1, 0, 0, 0, 0, 529, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19838, 824, 1, 1, 1, 0, 0, 0, 0, 530, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19839, 824, 1, 1, 1, 0, 0, 0, 0, 531, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19840, 824, 1, 1, 1, 0, 0, 0, 0, 532, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19841, 824, 1, 1, 1, 0, 0, 0, 0, 533, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19842, 824, 1, 1, 1, 0, 0, 0, 0, 534, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19843, 824, 1, 1, 1, 0, 0, 0, 0, 535, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19844, 824, 1, 1, 1, 0, 0, 0, 0, 536, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19845, 824, 1, 1, 1, 0, 0, 0, 0, 537, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19846, 824, 1, 1, 1, 0, 0, 0, 0, 538, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19847, 824, 1, 1, 1, 0, 0, 0, 0, 539, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19848, 824, 1, 1, 1, 0, 0, 0, 0, 540, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19849, 824, 1, 1, 1, 0, 0, 0, 0, 541, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19850, 824, 1, 1, 1, 0, 0, 0, 0, 542, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19851, 824, 1, 1, 1, 0, 0, 0, 0, 543, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19852, 824, 1, 1, 1, 0, 0, 0, 0, 544, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19853, 824, 1, 1, 1, 0, 0, 0, 0, 545, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19854, 824, 1, 1, 1, 0, 0, 0, 0, 546, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19855, 824, 1, 1, 1, 0, 0, 0, 0, 547, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19856, 824, 1, 1, 1, 0, 0, 0, 0, 548, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19857, 824, 1, 1, 1, 0, 0, 0, 0, 549, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19858, 824, 1, 1, 1, 0, 0, 0, 0, 550, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19859, 824, 1, 1, 1, 0, 0, 0, 0, 551, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19860, 824, 1, 1, 1, 0, 0, 0, 0, 552, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19861, 824, 1, 1, 1, 0, 0, 0, 0, 553, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19862, 824, 1, 1, 1, 0, 0, 0, 0, 554, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19863, 824, 1, 1, 1, 0, 0, 0, 0, 555, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19864, 824, 1, 1, 1, 0, 0, 0, 0, 556, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19865, 824, 1, 1, 1, 0, 0, 0, 0, 557, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19866, 824, 1, 1, 1, 0, 0, 0, 0, 558, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19867, 824, 1, 1, 1, 0, 0, 0, 0, 559, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19868, 824, 1, 1, 1, 0, 0, 0, 0, 560, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19869, 824, 1, 1, 1, 0, 0, 0, 0, 561, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19870, 824, 1, 1, 1, 0, 0, 0, 0, 562, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19871, 824, 1, 1, 1, 0, 0, 0, 0, 563, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19872, 824, 1, 1, 1, 0, 0, 0, 0, 564, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19873, 824, 1, 1, 1, 0, 0, 0, 0, 565, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19874, 824, 1, 1, 1, 0, 0, 0, 0, 566, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19875, 824, 1, 1, 1, 0, 0, 0, 0, 567, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19876, 824, 1, 1, 1, 0, 0, 0, 0, 568, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19877, 824, 1, 1, 1, 0, 0, 0, 0, 569, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19878, 824, 1, 1, 1, 0, 0, 0, 0, 570, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19879, 824, 1, 1, 1, 0, 0, 0, 0, 571, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19880, 824, 1, 1, 1, 0, 0, 0, 0, 572, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19881, 824, 1, 1, 1, 0, 0, 0, 0, 573, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19882, 824, 1, 1, 1, 0, 0, 0, 0, 574, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19883, 824, 1, 1, 1, 0, 0, 0, 0, 575, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19884, 824, 1, 1, 1, 0, 0, 0, 0, 576, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19885, 824, 1, 1, 1, 0, 0, 0, 0, 577, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19886, 824, 1, 1, 1, 0, 0, 0, 0, 578, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19887, 824, 1, 1, 1, 0, 0, 0, 0, 579, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19888, 824, 1, 1, 1, 0, 0, 0, 0, 580, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19889, 824, 1, 1, 1, 0, 0, 0, 0, 581, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19890, 824, 1, 1, 1, 0, 0, 0, 0, 582, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19891, 824, 1, 1, 1, 0, 0, 0, 0, 583, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19892, 824, 1, 1, 1, 0, 0, 0, 0, 584, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19893, 824, 1, 1, 1, 0, 0, 0, 0, 585, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19894, 824, 1, 1, 1, 0, 0, 0, 0, 586, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19895, 824, 1, 1, 1, 0, 0, 0, 0, 587, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19896, 824, 1, 1, 1, 0, 0, 0, 0, 588, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19897, 824, 1, 1, 1, 0, 0, 0, 0, 589, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19898, 824, 1, 1, 1, 0, 0, 0, 0, 590, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19899, 824, 1, 1, 1, 0, 0, 0, 0, 591, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19900, 824, 1, 1, 1, 0, 0, 0, 0, 592, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19901, 824, 1, 1, 1, 0, 0, 0, 0, 593, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19902, 824, 1, 1, 1, 0, 0, 0, 0, 594, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19903, 824, 1, 1, 1, 0, 0, 0, 0, 595, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19904, 824, 1, 1, 1, 0, 0, 0, 0, 596, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19905, 824, 1, 1, 1, 0, 0, 0, 0, 597, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19906, 824, 1, 1, 1, 0, 0, 0, 0, 598, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19907, 824, 1, 1, 1, 0, 0, 0, 0, 599, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19908, 824, 1, 1, 1, 0, 0, 0, 0, 600, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19909, 824, 1, 1, 1, 0, 0, 0, 0, 601, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19910, 824, 1, 1, 1, 0, 0, 0, 0, 602, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19911, 824, 1, 1, 1, 0, 0, 0, 0, 603, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19912, 824, 1, 1, 1, 0, 0, 0, 0, 604, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19913, 824, 1, 1, 1, 0, 0, 0, 0, 605, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19914, 824, 1, 1, 1, 0, 0, 0, 0, 606, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19915, 824, 1, 1, 1, 0, 0, 0, 0, 607, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19916, 824, 1, 1, 1, 0, 0, 0, 0, 608, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19917, 824, 1, 1, 1, 0, 0, 0, 0, 609, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19918, 824, 1, 1, 1, 0, 0, 0, 0, 610, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19919, 824, 1, 1, 1, 0, 0, 0, 0, 611, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19920, 824, 1, 1, 1, 0, 0, 0, 0, 612, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19921, 824, 1, 1, 1, 0, 0, 0, 0, 613, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19922, 824, 1, 1, 1, 0, 0, 0, 0, 614, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19923, 824, 1, 1, 1, 0, 0, 0, 0, 615, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19924, 824, 1, 1, 1, 0, 0, 0, 0, 616, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19925, 824, 1, 1, 1, 0, 0, 0, 0, 617, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19926, 824, 1, 1, 1, 0, 0, 0, 0, 618, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19927, 824, 1, 1, 1, 0, 0, 0, 0, 619, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19928, 824, 1, 1, 1, 0, 0, 0, 0, 620, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19929, 824, 1, 1, 1, 0, 0, 0, 0, 621, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19930, 824, 1, 1, 1, 0, 0, 0, 0, 622, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19931, 824, 1, 1, 1, 0, 0, 0, 0, 623, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19932, 824, 1, 1, 1, 0, 0, 0, 0, 624, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19933, 824, 1, 1, 1, 0, 0, 0, 0, 625, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19934, 824, 1, 1, 1, 0, 0, 0, 0, 626, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19935, 824, 1, 1, 1, 0, 0, 0, 0, 627, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19936, 824, 1, 1, 1, 0, 0, 0, 0, 628, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19937, 824, 1, 1, 1, 0, 0, 0, 0, 629, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19938, 824, 1, 1, 1, 0, 0, 0, 0, 630, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19939, 824, 1, 1, 1, 0, 0, 0, 0, 631, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19940, 824, 1, 1, 1, 0, 0, 0, 0, 632, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19941, 824, 1, 1, 1, 0, 0, 0, 0, 633, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19942, 824, 1, 1, 1, 0, 0, 0, 0, 634, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19943, 824, 1, 1, 1, 0, 0, 0, 0, 635, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19944, 824, 1, 1, 1, 0, 0, 0, 0, 636, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19945, 824, 1, 1, 1, 0, 0, 0, 0, 637, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19946, 824, 1, 1, 1, 0, 0, 0, 0, 638, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19947, 824, 1, 1, 1, 0, 0, 0, 0, 639, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19948, 824, 1, 1, 1, 0, 0, 0, 0, 640, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19949, 824, 1, 1, 1, 0, 0, 0, 0, 641, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19950, 824, 1, 1, 1, 0, 0, 0, 0, 642, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19951, 824, 1, 1, 1, 0, 0, 0, 0, 643, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19952, 824, 1, 1, 1, 0, 0, 0, 0, 644, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19953, 824, 1, 1, 1, 0, 0, 0, 0, 645, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19954, 824, 1, 1, 1, 0, 0, 0, 0, 646, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19955, 824, 1, 1, 1, 0, 0, 0, 0, 647, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19956, 824, 1, 1, 1, 0, 0, 0, 0, 648, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19957, 824, 1, 1, 1, 0, 0, 0, 0, 649, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19958, 824, 1, 1, 1, 0, 0, 0, 0, 650, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19959, 824, 1, 1, 1, 0, 0, 0, 0, 651, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19960, 824, 1, 1, 1, 0, 0, 0, 0, 652, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19961, 824, 1, 1, 1, 0, 0, 0, 0, 653, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19962, 824, 1, 1, 1, 0, 0, 0, 0, 654, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19963, 824, 1, 1, 1, 0, 0, 0, 0, 655, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19964, 824, 1, 1, 1, 0, 0, 0, 0, 656, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19965, 824, 1, 1, 1, 0, 0, 0, 0, 657, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19966, 824, 1, 1, 1, 0, 0, 0, 0, 658, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19967, 824, 1, 1, 1, 0, 0, 0, 0, 659, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19968, 824, 1, 1, 1, 0, 0, 0, 0, 660, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19969, 824, 1, 1, 1, 0, 0, 0, 0, 661, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19970, 824, 1, 1, 1, 0, 0, 0, 0, 662, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19971, 824, 1, 1, 1, 0, 0, 0, 0, 663, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19972, 824, 1, 1, 1, 0, 0, 0, 0, 664, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19973, 824, 1, 1, 1, 0, 0, 0, 0, 665, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19974, 824, 1, 1, 1, 0, 0, 0, 0, 666, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19975, 824, 1, 1, 1, 0, 0, 0, 0, 667, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19976, 824, 1, 1, 1, 0, 0, 0, 0, 668, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19977, 824, 1, 1, 1, 0, 0, 0, 0, 669, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19978, 824, 1, 1, 1, 0, 0, 0, 0, 670, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19979, 824, 1, 1, 1, 0, 0, 0, 0, 671, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19980, 824, 1, 1, 1, 0, 0, 0, 0, 672, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19981, 824, 1, 1, 1, 0, 0, 0, 0, 673, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19982, 824, 1, 1, 1, 0, 0, 0, 0, 674, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19983, 824, 1, 1, 1, 0, 0, 0, 0, 675, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19984, 824, 1, 1, 1, 0, 0, 0, 0, 676, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19985, 824, 1, 1, 1, 0, 0, 0, 0, 677, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19986, 824, 1, 1, 1, 0, 0, 0, 0, 678, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19987, 824, 1, 1, 1, 0, 0, 0, 0, 679, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19988, 824, 1, 1, 1, 0, 0, 0, 0, 680, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19989, 824, 1, 1, 1, 0, 0, 0, 0, 681, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19990, 824, 1, 1, 1, 0, 0, 0, 0, 682, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19991, 824, 1, 1, 1, 0, 0, 0, 0, 683, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19992, 824, 1, 1, 1, 0, 0, 0, 0, 684, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19993, 824, 1, 1, 1, 0, 0, 0, 0, 685, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19994, 824, 1, 1, 1, 0, 0, 0, 0, 686, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19995, 824, 1, 1, 1, 0, 0, 0, 0, 687, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19996, 824, 1, 1, 1, 0, 0, 0, 0, 688, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19997, 824, 1, 1, 1, 0, 0, 0, 0, 689, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19998, 824, 1, 1, 1, 0, 0, 0, 0, 690, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19999, 824, 1, 1, 1, 0, 0, 0, 0, 691, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20000, 824, 1, 1, 1, 0, 0, 0, 0, 692, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20001, 824, 1, 1, 1, 0, 0, 0, 0, 693, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20002, 824, 1, 1, 1, 0, 0, 0, 0, 694, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20003, 824, 1, 1, 1, 0, 0, 0, 0, 695, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20004, 824, 1, 1, 1, 0, 0, 0, 0, 696, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20005, 824, 1, 1, 1, 0, 0, 0, 0, 697, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20006, 824, 1, 1, 1, 0, 0, 0, 0, 698, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20007, 824, 1, 1, 1, 0, 0, 0, 0, 699, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20008, 824, 1, 1, 1, 0, 0, 0, 0, 700, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20009, 824, 1, 1, 1, 0, 0, 0, 0, 701, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20010, 824, 1, 1, 1, 0, 0, 0, 0, 702, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20011, 824, 1, 1, 1, 0, 0, 0, 0, 703, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20012, 824, 1, 1, 1, 0, 0, 0, 0, 704, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20013, 824, 1, 1, 1, 0, 0, 0, 0, 705, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20014, 824, 1, 1, 1, 0, 0, 0, 0, 706, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20015, 824, 1, 1, 1, 0, 0, 0, 0, 707, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20016, 824, 1, 1, 1, 0, 0, 0, 0, 708, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20017, 824, 1, 1, 1, 0, 0, 0, 0, 709, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20018, 824, 1, 1, 1, 0, 0, 0, 0, 710, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20019, 824, 1, 1, 1, 0, 0, 0, 0, 711, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20020, 824, 1, 1, 1, 0, 0, 0, 0, 712, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20021, 824, 1, 1, 1, 0, 0, 0, 0, 713, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20022, 824, 1, 1, 1, 0, 0, 0, 0, 714, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20023, 824, 1, 1, 1, 0, 0, 0, 0, 715, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20024, 824, 1, 1, 1, 0, 0, 0, 0, 716, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20025, 824, 1, 1, 1, 0, 0, 0, 0, 717, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20026, 824, 1, 1, 1, 0, 0, 0, 0, 718, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20027, 824, 1, 1, 1, 0, 0, 0, 0, 719, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20028, 824, 1, 1, 1, 0, 0, 0, 0, 720, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20029, 824, 1, 1, 1, 0, 0, 0, 0, 721, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20030, 824, 1, 1, 1, 0, 0, 0, 0, 722, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20031, 824, 1, 1, 1, 0, 0, 0, 0, 723, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20032, 824, 1, 1, 1, 0, 0, 0, 0, 724, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20033, 824, 1, 1, 1, 0, 0, 0, 0, 725, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20034, 824, 1, 1, 1, 0, 0, 0, 0, 726, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20035, 824, 1, 1, 1, 0, 0, 0, 0, 727, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20036, 824, 1, 1, 1, 0, 0, 0, 0, 728, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20037, 824, 1, 1, 1, 0, 0, 0, 0, 729, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20038, 824, 1, 1, 1, 0, 0, 0, 0, 730, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20039, 824, 1, 1, 1, 0, 0, 0, 0, 731, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20040, 824, 1, 1, 1, 0, 0, 0, 0, 732, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20041, 824, 1, 1, 1, 0, 0, 0, 0, 733, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20042, 824, 1, 1, 1, 0, 0, 0, 0, 734, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20043, 824, 1, 1, 1, 0, 0, 0, 0, 735, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20044, 824, 1, 1, 1, 0, 0, 0, 0, 736, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20045, 824, 1, 1, 1, 0, 0, 0, 0, 737, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20046, 824, 1, 1, 1, 0, 0, 0, 0, 738, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20047, 824, 1, 1, 1, 0, 0, 0, 0, 739, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20048, 824, 1, 1, 1, 0, 0, 0, 0, 740, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20049, 824, 1, 1, 1, 0, 0, 0, 0, 741, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20050, 824, 1, 1, 1, 0, 0, 0, 0, 742, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20051, 824, 1, 1, 1, 0, 0, 0, 0, 743, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20052, 824, 1, 1, 1, 0, 0, 0, 0, 744, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20053, 824, 1, 1, 1, 0, 0, 0, 0, 745, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20054, 824, 1, 1, 1, 0, 0, 0, 0, 746, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20055, 824, 1, 1, 1, 0, 0, 0, 0, 747, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20056, 824, 1, 1, 1, 0, 0, 0, 0, 748, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20057, 824, 1, 1, 1, 0, 0, 0, 0, 749, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20058, 824, 1, 1, 1, 0, 0, 0, 0, 750, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20059, 824, 1, 1, 1, 0, 0, 0, 0, 751, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20060, 824, 1, 1, 1, 0, 0, 0, 0, 752, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20061, 824, 1, 1, 1, 0, 0, 0, 0, 753, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20062, 824, 1, 1, 1, 0, 0, 0, 0, 754, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20063, 824, 1, 1, 1, 0, 0, 0, 0, 755, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20064, 824, 1, 1, 1, 0, 0, 0, 0, 756, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20065, 824, 1, 1, 1, 0, 0, 0, 0, 757, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20066, 824, 1, 1, 1, 0, 0, 0, 0, 758, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20067, 824, 1, 1, 1, 0, 0, 0, 0, 759, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20068, 824, 1, 1, 1, 0, 0, 0, 0, 760, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20069, 824, 1, 1, 1, 0, 0, 0, 0, 761, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20070, 824, 1, 1, 1, 0, 0, 0, 0, 762, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20071, 824, 1, 1, 1, 0, 0, 0, 0, 763, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20072, 824, 1, 1, 1, 0, 0, 0, 0, 764, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20073, 824, 1, 1, 1, 0, 0, 0, 0, 765, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20074, 824, 1, 1, 1, 0, 0, 0, 0, 766, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20075, 824, 1, 1, 1, 0, 0, 0, 0, 767, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20076, 824, 1, 1, 1, 0, 0, 0, 0, 768, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20077, 824, 1, 1, 1, 0, 0, 0, 0, 769, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20078, 824, 1, 1, 1, 0, 0, 0, 0, 770, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20079, 824, 1, 1, 1, 0, 0, 0, 0, 771, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20080, 824, 1, 1, 1, 0, 0, 0, 0, 772, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20081, 824, 1, 1, 1, 0, 0, 0, 0, 773, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20082, 824, 1, 1, 1, 0, 0, 0, 0, 774, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20083, 824, 1, 1, 1, 0, 0, 0, 0, 775, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20084, 824, 1, 1, 1, 0, 0, 0, 0, 776, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20085, 824, 1, 1, 1, 0, 0, 0, 0, 777, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20086, 824, 1, 1, 1, 0, 0, 0, 0, 778, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20087, 824, 1, 1, 1, 0, 0, 0, 0, 779, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20088, 824, 1, 1, 1, 0, 0, 0, 0, 780, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20089, 824, 1, 1, 1, 0, 0, 0, 0, 781, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20090, 824, 1, 1, 1, 0, 0, 0, 0, 782, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20091, 824, 1, 1, 1, 0, 0, 0, 0, 783, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20092, 824, 1, 1, 1, 0, 0, 0, 0, 784, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20093, 824, 1, 1, 1, 0, 0, 0, 0, 785, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20094, 824, 1, 1, 1, 0, 0, 0, 0, 786, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20095, 824, 1, 1, 1, 0, 0, 0, 0, 787, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20096, 824, 1, 1, 1, 0, 0, 0, 0, 788, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20097, 824, 1, 1, 1, 0, 0, 0, 0, 789, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20098, 824, 1, 1, 1, 0, 0, 0, 0, 790, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20099, 824, 1, 1, 1, 0, 0, 0, 0, 791, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20100, 824, 1, 1, 1, 0, 0, 0, 0, 792, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20101, 824, 1, 1, 1, 0, 0, 0, 0, 793, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19149, 905, 1, 1, 1, 0, 0, 50000, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19150, 905, 1, 1, 1, 1, 1, 50000, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19151, 905, 1, 1, 1, 1, 1, 50000, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19152, 905, 1, 1, 1, 1, 1, 50000, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19153, 905, 1, 1, 1, 1, 1, 50000, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19154, 905, 1, 1, 1, 1, 1, 50000, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3401, 329, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19138, 904, 1, 1, 1, 0, 0, 25001, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3402, 329, 1, 1, 1, 0, 0, 2400, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19139, 904, 1, 1, 1, 1, 1, 200000, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19140, 904, 1, 1, 1, 0, 0, 200000, 1000000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3403, 329, 1, 1, 1, 0, 0, 375, 3900, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19141, 904, 1, 1, 1, 0, 0, 200000, 749999, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3404, 329, 1, 1, 1, 0, 0, 1, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19142, 904, 1, 1, 1, 0, 0, 200000, 749999, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3405, 329, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19143, 904, 1, 1, 1, 0, 0, 200000, 749999, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3406, 329, 1, 1, 1, 0, 0, 1, 2500, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19144, 904, 1, 1, 1, 0, 0, 200000, 749999, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19155, 906, 1, 1, 1, 0, 0, 50000, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3407, 329, 1, 1, 1, 0, 0, 1, 2500, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19145, 904, 1, 1, 1, 0, 0, 200000, 400000, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3408, 329, 1, 1, 1, 0, 0, 1, 2500, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19156, 906, 1, 1, 1, 0, 0, 50000, 1000000, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19146, 904, 1, 1, 1, 0, 0, 200000, 1000000, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19157, 906, 1, 1, 1, 1, 1, 50000, 1000000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3409, 329, 1, 1, 1, 0, 0, 1, 2500, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19147, 904, 1, 1, 1, 0, 0, 200000, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19158, 906, 1, 1, 1, 1, 1, 50000, 1000000, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19148, 904, 1, 1, 1, 0, 0, 1000000, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19159, 906, 1, 1, 1, 1, 1, 50000, 1000000, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19160, 906, 1, 1, 1, 1, 1, 50000, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19161, 906, 1, 1, 1, 1, 1, 50000, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19162, 906, 1, 1, 1, 0, 0, 50000, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19163, 906, 1, 1, 1, 0, 0, 50000, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19164, 906, 1, 1, 1, 0, 0, 50000, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19165, 906, 1, 1, 1, 0, 0, 50000, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19166, 906, 1, 1, 1, 0, 0, 50000, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19167, 906, 1, 1, 1, 0, 0, 50000, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 19233, 706, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11542, 706, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11543, 706, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11544, 706, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11545, 706, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11546, 706, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11547, 706, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19125, 903, 1, 1, 1, 0, 0, 100, 50000, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19126, 903, 1, 1, 1, 0, 0, 100, 50000, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19127, 903, 1, 1, 1, 1, 1, 1000, 50000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19128, 903, 1, 1, 1, 0, 0, 1000, 50000, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19129, 903, 1, 1, 1, 0, 0, 1000, 50000, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19130, 903, 1, 1, 1, 0, 0, 1000, 50000, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19131, 903, 1, 1, 1, 0, 0, 1000, 50000, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19132, 903, 1, 1, 1, 0, 0, 1000, 50000, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19133, 903, 1, 1, 1, 0, 0, 1000, 29999, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19134, 903, 1, 1, 1, 0, 0, 1000, 50000, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19135, 903, 1, 1, 1, 0, 0, 1000, 50000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19136, 903, 1, 1, 1, 0, 0, 1000, 50000, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19137, 903, 1, 1, 1, 0, 0, 1000, 50000, 12, NULL, NULL);
--- TOC entry 1861 (class 0 OID 5377157)
--- Dependencies: 1259
--- Data for Name: gui_mb_group; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin2_de', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin2_en', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('gui', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('gui1', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_africa', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_australia', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_europe', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_germany', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_north_america', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_worldwide', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('gui2', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_de_services', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_en_services', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('gui_digitize', 20, '');
--- TOC entry 1862 (class 0 OID 5377162)
--- Dependencies: 1260
--- Data for Name: gui_mb_user; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin1', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin2_de', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin2_en', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('gui', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('gui1', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_africa', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_australia', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_europe', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_gdi_de', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_germany', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_north_america', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_worldwide', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('gui2', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_en_services', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('gui_digitize', 1, 'owner');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_de_services', 1, 'owner');
--- TOC entry 1863 (class 0 OID 5377168)
--- Dependencies: 1262
--- Data for Name: gui_treegde; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('admin1', '', 4, 1, 4, 'new', '', '');
-INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('admin1', '', 5, 2, 3, 'new', '', '');
-INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('gui', '', 11, 1, 4, 'Verkehr', '', '');
-INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('gui', '15348', 12, 2, 3, 'Strassen', 'Strassen', '118');
-INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('gui1', '', 11, 1, 4, 'new', '', '');
-INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('gui1', '', 12, 2, 3, 'new', '', '');
-INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('wms_africa', NULL, 98, 1, 4, 'new', '', NULL);
-INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('wms_africa', NULL, 99, 2, 3, 'new', '', NULL);
-INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('gui2', '', 11, 1, 4, 'Verkehr', '', '');
-INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) VALUES ('gui2', '15348', 12, 2, 3, 'Strassen', 'Strassen', '118');
--- TOC entry 1864 (class 0 OID 5377177)
--- Dependencies: 1263
--- Data for Name: gui_wfs; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) VALUES ('gui', 1);
-INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) VALUES ('gui2', 1);
--- TOC entry 1865 (class 0 OID 5377181)
--- Dependencies: 1264
--- Data for Name: gui_wfs_conf; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 1);
-INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 3);
-INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 4);
-INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 2);
--- TOC entry 1866 (class 0 OID 5377185)
--- Dependencies: 1265
--- Data for Name: gui_wms; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui', 250, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui1', 407, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_africa', 615, 0, 'PNG', 'mime', 'INIMAGE', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui', 407, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_australia', 706, 0, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_australia', 634, 1, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:26915', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui', 640, 1, 'image/png', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui2', 640, 1, 'image/png', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 329, 2, 'IMAGE/PNG', 'text/plain', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31467', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 583, 0, 'image/gif', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 584, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 655, 2, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 614, 3, 'PNG', 'mime', 'INIMAGE', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui1', 893, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 717, 1, 'image/jpeg', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31492', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 624, 3, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 648, 4, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 328, 5, 'IMAGE/PNG', 'application/vnd.ogc.gml', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 486, 6, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31467', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 767, 7, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:25833', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 670, 8, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 671, 9, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui2', 250, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui2', 893, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 893, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui', 893, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui2', 407, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_gdi_de', 866, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_gdi_de', 867, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_gdi_de', 869, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 787, 11, 'IMAGE/PNG', '', 'application/vnd.ogc.se_xml', 'EPSG:31464', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui_digitize', 640, 1, 'image/png', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_worldwide', 640, 1, 'IMAGE/PNG', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 792, 13, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31468', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 786, 10, 'IMAGE/PNG', 'text/plain', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31468', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 789, 12, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui_digitize', 250, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui_digitize', 893, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('gui_digitize', 909, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_worldwide', 613, 0, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_worldwide', 637, 2, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_worldwide', 101, 3, 'image/gif', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_worldwide', 250, 4, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_worldwide', 86, 5, 'image/gif', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_worldwide', 840, 6, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:27700', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_worldwide', 841, 7, 'image/png', 'text/plain', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_worldwide', 842, 8, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_worldwide', 843, 9, 'png', 'mime', 'inimage', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_worldwide', 844, 10, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 800, 7, 'image/jpeg', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 836, 10, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', '', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 837, 11, 'image/jpeg', '', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_europe', 824, 0, 'image/png', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 625, 4, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:42304', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 645, 5, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 525, 6, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_europe', 828, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:23030', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 785, 14, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 902, 15, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 904, 17, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 903, 16, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 905, 18, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 906, 19, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_germany', 908, 20, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 832, 8, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_north_america', 834, 9, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:102257', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_gdi_de', 882, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_gdi_de', 883, 4, 'png', 'mime', 'WMS_XML', 'EPSG:31467', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_gdi_de', 887, 5, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31492', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_gdi_de', 717, 6, 'image/jpeg', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31492', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_gdi_de', 624, 7, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_gdi_de', 648, 8, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_gdi_de', 670, 9, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible, gui_wms_sldurl) VALUES ('wms_gdi_de', 671, 10, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1, '');
--- TOC entry 1867 (class 0 OID 5377201)
--- Dependencies: 1267
--- Data for Name: keyword; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO keyword (keyword_id, keyword) VALUES (1, 'Germany');
-INSERT INTO keyword (keyword_id, keyword) VALUES (2, 'Deutschland');
-INSERT INTO keyword (keyword_id, keyword) VALUES (3, 'WebGIS');
-INSERT INTO keyword (keyword_id, keyword) VALUES (5, 'WFS');
-INSERT INTO keyword (keyword_id, keyword) VALUES (6, 'WhereGroup');
-INSERT INTO keyword (keyword_id, keyword) VALUES (7, 'Mapbender');
-INSERT INTO keyword (keyword_id, keyword) VALUES (8, 'Laender');
-INSERT INTO keyword (keyword_id, keyword) VALUES (10, 'city');
-INSERT INTO keyword (keyword_id, keyword) VALUES (11, 'Ort');
-INSERT INTO keyword (keyword_id, keyword) VALUES (12, 'Staedte');
-INSERT INTO keyword (keyword_id, keyword) VALUES (13, 'Stadt');
-INSERT INTO keyword (keyword_id, keyword) VALUES (14, 'Postleitzahl');
-INSERT INTO keyword (keyword_id, keyword) VALUES (15, 'PLZ');
-INSERT INTO keyword (keyword_id, keyword) VALUES (16, 'postcode');
-INSERT INTO keyword (keyword_id, keyword) VALUES (17, 'railroad');
-INSERT INTO keyword (keyword_id, keyword) VALUES (18, 'Bahn');
-INSERT INTO keyword (keyword_id, keyword) VALUES (19, 'DB');
-INSERT INTO keyword (keyword_id, keyword) VALUES (20, 'river');
-INSERT INTO keyword (keyword_id, keyword) VALUES (21, 'Fluss');
-INSERT INTO keyword (keyword_id, keyword) VALUES (22, 'water');
-INSERT INTO keyword (keyword_id, keyword) VALUES (23, 'Wasser');
-INSERT INTO keyword (keyword_id, keyword) VALUES (24, 'road');
-INSERT INTO keyword (keyword_id, keyword) VALUES (25, 'Strasse');
-INSERT INTO keyword (keyword_id, keyword) VALUES (26, 'Infrastruktur');
-INSERT INTO keyword (keyword_id, keyword) VALUES (28, 'Bundesland');
-INSERT INTO keyword (keyword_id, keyword) VALUES (29, 'Land');
-INSERT INTO keyword (keyword_id, keyword) VALUES (30, 'digitize');
-INSERT INTO keyword (keyword_id, keyword) VALUES (31, 'polygon');
-INSERT INTO keyword (keyword_id, keyword) VALUES (32, 'Linie');
-INSERT INTO keyword (keyword_id, keyword) VALUES (33, 'line');
-INSERT INTO keyword (keyword_id, keyword) VALUES (34, 'point');
-INSERT INTO keyword (keyword_id, keyword) VALUES (35, 'Punkt');
-INSERT INTO keyword (keyword_id, keyword) VALUES (36, 'poi');
-INSERT INTO keyword (keyword_id, keyword) VALUES (37, 'ArcIMS');
-INSERT INTO keyword (keyword_id, keyword) VALUES (38, 'ESRI');
-INSERT INTO keyword (keyword_id, keyword) VALUES (39, 'OGC Map Service');
-INSERT INTO keyword (keyword_id, keyword) VALUES (40, 'Web Mapping');
-INSERT INTO keyword (keyword_id, keyword) VALUES (41, 'GIS');
-INSERT INTO keyword (keyword_id, keyword) VALUES (42, 'GDI NRW');
-INSERT INTO keyword (keyword_id, keyword) VALUES (43, 'NWSIB');
-INSERT INTO keyword (keyword_id, keyword) VALUES (44, 'klassifiziertes Straßennetz');
-INSERT INTO keyword (keyword_id, keyword) VALUES (45, 'Anweisung Straßeninformationsbank ASB');
-INSERT INTO keyword (keyword_id, keyword) VALUES (46, 'Netzknoten-Stationierungssystem');
-INSERT INTO keyword (keyword_id, keyword) VALUES (47, 'birds');
-INSERT INTO keyword (keyword_id, keyword) VALUES (48, 'distribution');
-INSERT INTO keyword (keyword_id, keyword) VALUES (49, 'abundance');
-INSERT INTO keyword (keyword_id, keyword) VALUES (50, 'conservation');
-INSERT INTO keyword (keyword_id, keyword) VALUES (51, 'sites');
-INSERT INTO keyword (keyword_id, keyword) VALUES (52, 'monitoring');
-INSERT INTO keyword (keyword_id, keyword) VALUES (53, 'populations');
-INSERT INTO keyword (keyword_id, keyword) VALUES (54, 'canada');
-INSERT INTO keyword (keyword_id, keyword) VALUES (55, 'iba');
-INSERT INTO keyword (keyword_id, keyword) VALUES (56, 'birdlife');
-INSERT INTO keyword (keyword_id, keyword) VALUES (57, 'winter');
-INSERT INTO keyword (keyword_id, keyword) VALUES (58, 'survey');
-INSERT INTO keyword (keyword_id, keyword) VALUES (59, 'population');
-INSERT INTO keyword (keyword_id, keyword) VALUES (60, 'volunteers');
-INSERT INTO keyword (keyword_id, keyword) VALUES (61, 'cbc');
-INSERT INTO keyword (keyword_id, keyword) VALUES (62, 'christmas');
-INSERT INTO keyword (keyword_id, keyword) VALUES (63, 'SÅ‚ubfurt');
-INSERT INTO keyword (keyword_id, keyword) VALUES (64, 'SÅ‚ubice');
-INSERT INTO keyword (keyword_id, keyword) VALUES (65, 'Frankfurt (Oder)');
-INSERT INTO keyword (keyword_id, keyword) VALUES (66, 'topophilia');
-INSERT INTO keyword (keyword_id, keyword) VALUES (67, 'mental maps');
-INSERT INTO keyword (keyword_id, keyword) VALUES (68, 'geopgraphy');
-INSERT INTO keyword (keyword_id, keyword) VALUES (69, 'spatial perception');
-INSERT INTO keyword (keyword_id, keyword) VALUES (71, 'sense of place and identity');
-INSERT INTO keyword (keyword_id, keyword) VALUES (70, 'waterbirds');
-INSERT INTO keyword (keyword_id, keyword) VALUES (72, 'amphibians');
-INSERT INTO keyword (keyword_id, keyword) VALUES (73, 'cognitive map');
-INSERT INTO keyword (keyword_id, keyword) VALUES (74, 'marsh');
-INSERT INTO keyword (keyword_id, keyword) VALUES (75, 'spatial cognition');
-INSERT INTO keyword (keyword_id, keyword) VALUES (76, 'wetland');
-INSERT INTO keyword (keyword_id, keyword) VALUES (77, 'cognitive psychology');
-INSERT INTO keyword (keyword_id, keyword) VALUES (78, 'cognitive science');
-INSERT INTO keyword (keyword_id, keyword) VALUES (79, 'urban design');
-INSERT INTO keyword (keyword_id, keyword) VALUES (80, 'united states');
-INSERT INTO keyword (keyword_id, keyword) VALUES (81, 'great lakes');
-INSERT INTO keyword (keyword_id, keyword) VALUES (82, 'spatial orientation');
-INSERT INTO keyword (keyword_id, keyword) VALUES (83, 'AOC');
-INSERT INTO keyword (keyword_id, keyword) VALUES (84, 'identity of place');
-INSERT INTO keyword (keyword_id, keyword) VALUES (85, 'borders');
-INSERT INTO keyword (keyword_id, keyword) VALUES (86, 'national landscapes');
-INSERT INTO keyword (keyword_id, keyword) VALUES (87, 'Gavia immer');
-INSERT INTO keyword (keyword_id, keyword) VALUES (88, 'loons');
-INSERT INTO keyword (keyword_id, keyword) VALUES (89, 'lakes');
-INSERT INTO keyword (keyword_id, keyword) VALUES (90, 'acid rain');
-INSERT INTO keyword (keyword_id, keyword) VALUES (91, 'disturbance');
-INSERT INTO keyword (keyword_id, keyword) VALUES (92, 'ecosystem health');
-INSERT INTO keyword (keyword_id, keyword) VALUES (93, 'breeding range');
-INSERT INTO keyword (keyword_id, keyword) VALUES (94, 'Ontario');
-INSERT INTO keyword (keyword_id, keyword) VALUES (95, 'deegree');
-INSERT INTO keyword (keyword_id, keyword) VALUES (96, 'wms');
-INSERT INTO keyword (keyword_id, keyword) VALUES (97, 'ImageryBaseMapsEarthCover');
-INSERT INTO keyword (keyword_id, keyword) VALUES (99, 'BaseMaps');
-INSERT INTO keyword (keyword_id, keyword) VALUES (100, 'EarthCover');
-INSERT INTO keyword (keyword_id, keyword) VALUES (101, 'JPL');
-INSERT INTO keyword (keyword_id, keyword) VALUES (102, 'Jet Propulsion Laboratory');
-INSERT INTO keyword (keyword_id, keyword) VALUES (104, 'none');
-INSERT INTO keyword (keyword_id, keyword) VALUES (105, 'SLD');
-INSERT INTO keyword (keyword_id, keyword) VALUES (106, 'owls');
-INSERT INTO keyword (keyword_id, keyword) VALUES (107, 'Global');
-INSERT INTO keyword (keyword_id, keyword) VALUES (108, 'broadcast');
-INSERT INTO keyword (keyword_id, keyword) VALUES (109, 'breeding');
-INSERT INTO keyword (keyword_id, keyword) VALUES (110, 'roadside');
-INSERT INTO keyword (keyword_id, keyword) VALUES (111, 'Delaware');
-INSERT INTO keyword (keyword_id, keyword) VALUES (112, 'DataMIL');
-INSERT INTO keyword (keyword_id, keyword) VALUES (113, 'The National Map');
-INSERT INTO keyword (keyword_id, keyword) VALUES (114, 'framework');
-INSERT INTO keyword (keyword_id, keyword) VALUES (115, 'orthoimagery');
-INSERT INTO keyword (keyword_id, keyword) VALUES (116, 'orthophotography');
-INSERT INTO keyword (keyword_id, keyword) VALUES (117, 'aerial imagery');
-INSERT INTO keyword (keyword_id, keyword) VALUES (118, 'imagery');
-INSERT INTO keyword (keyword_id, keyword) VALUES (119, 'OGC');
-INSERT INTO keyword (keyword_id, keyword) VALUES (120, 'La Rioja');
-INSERT INTO keyword (keyword_id, keyword) VALUES (121, 'Cartografia');
-INSERT INTO keyword (keyword_id, keyword) VALUES (122, 'Mapas');
-INSERT INTO keyword (keyword_id, keyword) VALUES (123, 'TAT');
-INSERT INTO keyword (keyword_id, keyword) VALUES (124, 'Critical Habitat');
-INSERT INTO keyword (keyword_id, keyword) VALUES (125, 'NWI');
-INSERT INTO keyword (keyword_id, keyword) VALUES (126, 'seacoos');
-INSERT INTO keyword (keyword_id, keyword) VALUES (127, 'near real-time ocean data');
-INSERT INTO keyword (keyword_id, keyword) VALUES (128, 'merged observational data');
-INSERT INTO keyword (keyword_id, keyword) VALUES (129, 'merged models');
-INSERT INTO keyword (keyword_id, keyword) VALUES (130, 'southeastern united states');
-INSERT INTO keyword (keyword_id, keyword) VALUES (131, 'in-situ moored sensing');
-INSERT INTO keyword (keyword_id, keyword) VALUES (132, 'in-situ drifting sensing');
-INSERT INTO keyword (keyword_id, keyword) VALUES (133, 'coastal');
-INSERT INTO keyword (keyword_id, keyword) VALUES (134, 'offshore');
-INSERT INTO keyword (keyword_id, keyword) VALUES (135, 'remote sensing');
-INSERT INTO keyword (keyword_id, keyword) VALUES (136, 'satellites');
-INSERT INTO keyword (keyword_id, keyword) VALUES (137, 'aircraft');
-INSERT INTO keyword (keyword_id, keyword) VALUES (138, 'current');
-INSERT INTO keyword (keyword_id, keyword) VALUES (139, 'sea surface temperature');
-INSERT INTO keyword (keyword_id, keyword) VALUES (140, 'SST');
-INSERT INTO keyword (keyword_id, keyword) VALUES (141, 'wind speed and direction');
-INSERT INTO keyword (keyword_id, keyword) VALUES (142, 'RGB');
-INSERT INTO keyword (keyword_id, keyword) VALUES (143, 'true color');
-INSERT INTO keyword (keyword_id, keyword) VALUES (144, 'TBA');
-INSERT INTO keyword (keyword_id, keyword) VALUES (145, 'enhanced true color image');
-INSERT INTO keyword (keyword_id, keyword) VALUES (146, 'upper ocean waters');
-INSERT INTO keyword (keyword_id, keyword) VALUES (171, 'Testing');
-INSERT INTO keyword (keyword_id, keyword) VALUES (147, 'coastal zones');
-INSERT INTO keyword (keyword_id, keyword) VALUES (148, 'ocean color');
-INSERT INTO keyword (keyword_id, keyword) VALUES (149, 'MODerate Resolution Imaging Spectroradiometers');
-INSERT INTO keyword (keyword_id, keyword) VALUES (150, 'MODIS');
-INSERT INTO keyword (keyword_id, keyword) VALUES (151, 'NASA polar orbiting Terra and Aqua satellites');
-INSERT INTO keyword (keyword_id, keyword) VALUES (152, 'USF Institute for Marine Remote Sensing');
-INSERT INTO keyword (keyword_id, keyword) VALUES (153, 'imars');
-INSERT INTO keyword (keyword_id, keyword) VALUES (154, 'approximate true color');
-INSERT INTO keyword (keyword_id, keyword) VALUES (155, 'land areas');
-INSERT INTO keyword (keyword_id, keyword) VALUES (156, 'chesapeake bay');
-INSERT INTO keyword (keyword_id, keyword) VALUES (157, 'florida bay');
-INSERT INTO keyword (keyword_id, keyword) VALUES (158, 'miss plume');
-INSERT INTO keyword (keyword_id, keyword) VALUES (159, 'suwannee river');
-INSERT INTO keyword (keyword_id, keyword) VALUES (160, 'tampa bay');
-INSERT INTO keyword (keyword_id, keyword) VALUES (161, 'operational');
-INSERT INTO keyword (keyword_id, keyword) VALUES (162, 'cloud free');
-INSERT INTO keyword (keyword_id, keyword) VALUES (163, 'satellite SST');
-INSERT INTO keyword (keyword_id, keyword) VALUES (164, 'Optimal Interpolation');
-INSERT INTO keyword (keyword_id, keyword) VALUES (165, 'NOAA and NASA satellites');
-INSERT INTO keyword (keyword_id, keyword) VALUES (166, 'USF Ocean Circulation Group');
-INSERT INTO keyword (keyword_id, keyword) VALUES (168, 'AVHRR');
-INSERT INTO keyword (keyword_id, keyword) VALUES (169, 'Advanced Very High Resolution Radiometer');
-INSERT INTO keyword (keyword_id, keyword) VALUES (170, 'NOAA satellites');
-INSERT INTO keyword (keyword_id, keyword) VALUES (172, 'ICEDS');
-INSERT INTO keyword (keyword_id, keyword) VALUES (173, 'Texas');
-INSERT INTO keyword (keyword_id, keyword) VALUES (174, 'LANDSAT');
-INSERT INTO keyword (keyword_id, keyword) VALUES (175, 'Mesonet');
-INSERT INTO keyword (keyword_id, keyword) VALUES (176, 'SRTM');
-INSERT INTO keyword (keyword_id, keyword) VALUES (177, 'radar');
-INSERT INTO keyword (keyword_id, keyword) VALUES (178, 'GRID');
-INSERT INTO keyword (keyword_id, keyword) VALUES (179, 'LANDSAT 5');
-INSERT INTO keyword (keyword_id, keyword) VALUES (180, 'SRTM3');
-INSERT INTO keyword (keyword_id, keyword) VALUES (181, 'GSHHS');
-INSERT INTO keyword (keyword_id, keyword) VALUES (182, 'SRTM30');
-INSERT INTO keyword (keyword_id, keyword) VALUES (183, 'GTOPO30');
-INSERT INTO keyword (keyword_id, keyword) VALUES (184, 'USGS');
-INSERT INTO keyword (keyword_id, keyword) VALUES (185, 'DOQ');
-INSERT INTO keyword (keyword_id, keyword) VALUES (186, 'DRG');
-INSERT INTO keyword (keyword_id, keyword) VALUES (187, 'DNM');
-INSERT INTO keyword (keyword_id, keyword) VALUES (188, 'Topographic');
-INSERT INTO keyword (keyword_id, keyword) VALUES (189, 'GDI');
-INSERT INTO keyword (keyword_id, keyword) VALUES (190, 'UrbanArea');
-INSERT INTO keyword (keyword_id, keyword) VALUES (191, 'Urban Areas');
-INSERT INTO keyword (keyword_id, keyword) VALUES (192, 'Navigation');
-INSERT INTO keyword (keyword_id, keyword) VALUES (193, 'Brandenburg');
-INSERT INTO keyword (keyword_id, keyword) VALUES (194, 'Weather Maps');
-INSERT INTO keyword (keyword_id, keyword) VALUES (210, 'ALK');
-INSERT INTO keyword (keyword_id, keyword) VALUES (211, 'ZV-Aut');
-INSERT INTO keyword (keyword_id, keyword) VALUES (212, 'obak');
-INSERT INTO keyword (keyword_id, keyword) VALUES (213, 'Liegenschaftskarte');
-INSERT INTO keyword (keyword_id, keyword) VALUES (200, 'BLUE MARBLE');
-INSERT INTO keyword (keyword_id, keyword) VALUES (201, 'DMSP');
-INSERT INTO keyword (keyword_id, keyword) VALUES (202, 'NOAA');
-INSERT INTO keyword (keyword_id, keyword) VALUES (203, 'night lights');
-INSERT INTO keyword (keyword_id, keyword) VALUES (204, 'ASTER DEM footprints');
-INSERT INTO keyword (keyword_id, keyword) VALUES (205, 'water bodies');
-INSERT INTO keyword (keyword_id, keyword) VALUES (206, 'ASTER');
-INSERT INTO keyword (keyword_id, keyword) VALUES (207, 'Three Gorges');
-INSERT INTO keyword (keyword_id, keyword) VALUES (208, 'ECW');
-INSERT INTO keyword (keyword_id, keyword) VALUES (209, 'JPEG 2000');
-INSERT INTO keyword (keyword_id, keyword) VALUES (214, 'Kataster');
-INSERT INTO keyword (keyword_id, keyword) VALUES (215, 'Flurstueckssuche');
-INSERT INTO keyword (keyword_id, keyword) VALUES (216, 'Flurstueck');
-INSERT INTO keyword (keyword_id, keyword) VALUES (217, 'Flurstueckskennzeichen');
-INSERT INTO keyword (keyword_id, keyword) VALUES (218, 'Nations Europe');
-INSERT INTO keyword (keyword_id, keyword) VALUES (219, 'Onshore Geology Europe Geochronologic Age Lithology Metamorphism');
-INSERT INTO keyword (keyword_id, keyword) VALUES (220, 'Offshore Geology Europe Geochronologic Age Lithology Metamorphism');
-INSERT INTO keyword (keyword_id, keyword) VALUES (221, 'Geology Europe Ophiolite Complex');
-INSERT INTO keyword (keyword_id, keyword) VALUES (222, 'Onshore Geology Europe Magmatic');
-INSERT INTO keyword (keyword_id, keyword) VALUES (223, 'Offshore Geology Europe Magmatic');
-INSERT INTO keyword (keyword_id, keyword) VALUES (224, 'Geology Europe Onshore Metamorphism');
-INSERT INTO keyword (keyword_id, keyword) VALUES (225, 'Rivers Europe Topography');
-INSERT INTO keyword (keyword_id, keyword) VALUES (226, 'Canals Europe Topography');
-INSERT INTO keyword (keyword_id, keyword) VALUES (227, 'Geology Europe Lakes Topography');
-INSERT INTO keyword (keyword_id, keyword) VALUES (228, 'Geology Europe Boundaries Topography');
-INSERT INTO keyword (keyword_id, keyword) VALUES (229, 'Geology Europe Towns Topography');
-INSERT INTO keyword (keyword_id, keyword) VALUES (230, 'Geology Europe Capitals Topography');
-INSERT INTO keyword (keyword_id, keyword) VALUES (231, 'Geology Europe Coastline Topography');
--- TOC entry 1868 (class 0 OID 5377206)
--- Dependencies: 1269
--- Data for Name: layer; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7517, 584, 0, '', 'BSC_WMS', 'Data provided by Bird Studies Canada', 0, 0, 0, '', '', 'Bird Studies Canada WMS/WFS Server for bird distribution and abundance data, and related information.  Bird Studies Canada gratefully acknowledges the support of Environment Canada - Canadian Information System for the Environment in developing this service.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7518, 584, 1, '0', 'IBA', 'Canadian Important Bird Areas', 1, 0, 0, '', 'http://www.bsc-eoc.org/website/metadata/caniba_poly.xml', 'This layer represents *generalized* boundaries of Important Bird Areas (IBA) in Canada.  IBAs, in Canada and elsewhere, are evaluated and designated on the basis of internationally criteria.  The polygons contained in the dataset meet these criteria and are therefore deemed significant at the national, continental, or global level.  In Canada, IBAs are not legally recognized entities and therefore do not have any regulatory status.  Nevertheless, they are extremely useful for conservation planning for birds.  Polygon boundaries were digitized on-screen in ArcView GIS 3.2 by using NTDB 1:50K or 1:250K digital layers for reference.  If NTDB coverage was not available (e.g., far north), the Digital Chart of the World (1:1M) was used.  The boundaries of IBAs in this dataset are intentionally generalized to reflect the importance of the surrounding ecosystem on the values present within IBAs.  For example, small islands supporting colonies of seabirds might be buffered by 1 or 2 km to form an IBA.  Boundaries for a very small minority of IBAs were available in paper form as part of IBA conservation plans that had been developed previously.  In such cases, we visually estimated their boundaries against the NTDB or other base layers.  Many IBAs are already recognized as other types of protected areas, e.g., National Wildlife Areas, National and Provincial Parks, Migratory Bird Sanctuaries, conservation reserves, and so on.  In these cases, we used digital boundaries from other sources (e.g., WWF Canada''s Designated Areas Database, Environment Canada''s Canadian Conservation Areas Database) as reference points when digitizing IBA boundaries.  Please cite as follows:  Bird Studies Canada and Nature Canada.  2004.  Important Bird Areas of Canada Database.  Port Rowan, Ontario:  Bird Studies Canada.  To access the Canadian IBA directory: http://www.bsc-eoc.org/iba/ibasites.html.  Full metadata for this layer:  http://www.bsc-eoc.org/website/metadata/caniba_poly.xml');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19208, 717, 0, '', 'forstamtsgr', 'forstamtsgr', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19253, 836, 0, '', 'NDOP', 'NDOP', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19209, 785, 0, '', 'dtk200_500_1000_a10_gk3_wms', 'dtk200_500_1000_a10_gk3_wms', 0, 0, 0, '', '', 'WMS Map Server');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14114, 767, 11, '0', 'HotSpots-2', 'HotSpots-2', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Nearest Neighbor Hierarchical Clustering - Second Order; For each identified cluster a Standard Deviational Ellipse is calculated. Typically, one standard deviation will cover more than 50% of the cases, one and a half standard deviations will cover more than 90% of the cases, and two standard deviations will cover more than 99% of the cases, although the exact percentage will depend on the distribution (Levine, 2002).');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14115, 767, 12, '0', 'SDE-W', 'SDE-W', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002; Standard Deviational Ellipse - Weighted: A standard deviational ellipse is centered around the mean center of the data set. The ellipse is an indicator of spatial concentration and dispertion with a directional bias. The deviation along the major axis will be the direction of maximum spread of the points and the minor axis will be the direction of minimum spread of the points.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10172, 640, 10, '0', 'daily_aqua', 'Daily composite of MODIS-AQUA images', 0, 250550, 0, '', '', ' 	Daily generated mosaic of the AQUA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19240, 640, 11, '0', 'BMNG', 'Blue Marble Next Generation, Global MODIS derived image', 0, 501099, 0, '', '', '         A set of twelve images built from MODIS data, one for each month of 2004. The native resolution is 15 arcseconds. This is the version with land and ocean bottom hillshading.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10173, 640, 12, '0', 'modis', 'Blue Marble, Global MODIS derived image', 0, 1002199, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10174, 640, 13, '0', 'huemapped_srtm', 'SRTM derived global elevation, 3 arc-second, hue mapped', 0, 90198, 0, '', '', ' An SRTM derived elevation dataset, where elevation is mapped to hue, resulting a color image');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10175, 640, 14, '0', 'srtmplus', 'Global 1km elevation, seamless SRTM land elevation and ocean depth', 0, 1002199, 0, '', '', ' 	The SRTM30 Plus dataset, a 30 arc-second seamless combination of GTOPO30, SRTM derived land elevation and UCSD Sandwell bathymetry data.  The default style is scaled to 8 bit, non-linear.  It is possible to request the elevation data in meters by the short_int tyle and requesting PNG format.  The resulting PNG file will be a unsigned 16 bit per pixel image. The values are then the elevation in meters.  Values are signed 16 bit integers, but PNG will present them as unsigned, any values larger than 32767 should be interpreted as negative numbers.  For elevation values in feet, request PNG format with the style feet_short_int.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10176, 640, 15, '0', 'worldwind_dem', 'SRTM derived global elevation, 3 arc-second', 0, 90198, 0, '', '', ' 	A global elevation model, prepared from the 3 arc-second SRTM dataset by filling some of the problem areas. Prepared by the NASA Learning Technologies. 	The default style is scaled to 8 bit, non-linear. 	It is possible to request the elevation data in meters by the short_int tyle and requesting PNG format. The resulting PNG file will be a unsigned 16 bit per pixel image. The values are then the elevation in meters. 	Values are signed 16 bit integers, but PNG will present them as unsigned, leading to a few areas with very large values (65000+) 	For elevation values in feet, request PNG format with the style feet_short_int.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19255, 828, 7, '0', 'Puntos_geodésicos', 'Puntos_geodésicos', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19176, 250, 0, '', 'Demis World Map', 'Demis World Map', 0, 0, 0, '', '', 'None');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2713, 250, 1, '0', 'Bathymetry', 'Bathymetry', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2714, 250, 2, '0', 'Countries', 'Countries', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2715, 250, 3, '0', 'Topography', 'Topography', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2716, 250, 4, '0', 'Hillshading', 'Hillshading', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2717, 250, 5, '0', 'Builtup areas', 'Builtup areas', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2718, 250, 6, '0', 'Coastlines', 'Coastlines', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2719, 250, 7, '0', 'Waterbodies', 'Waterbodies', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2720, 250, 8, '0', 'Inundated', 'Inundated', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2721, 250, 9, '0', 'Rivers', 'Rivers', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2722, 250, 10, '0', 'Streams', 'Streams', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2723, 250, 11, '0', 'Railroads', 'Railroads', 1, 0, 1683694, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2724, 250, 12, '0', 'Highways', 'Highways', 1, 0, 1403078, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2725, 250, 13, '0', 'Roads', 'Roads', 1, 0, 841847, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2726, 250, 14, '0', 'Trails', 'Trails', 1, 0, 561231, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2727, 250, 15, '0', 'Borders', 'Borders', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2728, 250, 16, '0', 'Cities', 'Cities', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2729, 250, 17, '0', 'Settlements', 'Settlements', 1, 0, 1122463, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2730, 250, 18, '0', 'Spot elevations', 'Spot elevations', 0, 0, 561231, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2731, 250, 19, '0', 'Airports', 'Airports', 1, 0, 1122463, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2732, 250, 20, '0', 'Ocean features', 'Ocean features', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7520, 584, 3, '0', 'CBC_PY', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', '', 'A winter survey of bird populations conducted during the Christmas period - December 14 to January 5th inclusive.  More than 1800 counts are conducted each year across Canada, the United States and Latin America.  On a selected day within the count period, local birders count as many birds as possible within a 24 km (15 mile) diameter circle.  The Christmas Bird Count had long been organized on the continental scale by the New York-based National Audubon Society. In 2000, Audubon finalized an agreement with Bird Studies Canada that would see BSC partner with Audubon to coordinate CBCs in Canada.  This layer represents the 24 km circles surveyed as part of each Christmas Bird Count conducted in Canada.  An accompanying layer (CBC_PT) contains the centre point of the circles.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7521, 584, 4, '0', 'MMP', 'Marsh Monitoring Program Route Locations', 1, 0, 0, '', '', 'A Spring survey of birds and amphibians carried out primarily within the Great Lakes region of North America.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7522, 584, 5, '0', 'CLLS', 'Canadian Lakes Loon Survey Locations', 1, 0, 0, '', '', 'A volunteer-based program that monitors the effects of acid rain and other human disturbance on loon breeding and presence on Canada''s cottage lakes and other waterbodies.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19244, 789, 21, '18', 'tk10v', 'TK 10 - Vegetation', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK10VEG');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5575, 486, 0, '', 'PLZ_441', 'PLZ_441', 0, 1, 0, '', '', 'PLZ (post code areas Germany) served with UMN MapServer 4.4.1');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5576, 486, 1, '0', 'Nationalborder', 'National Border', 0, 750000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5577, 486, 2, '0', 'Postcodeareas', 'Post Code Areas', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5578, 486, 3, '0', 'Postcodelabels', 'Post Code Labels', 0, 0, 350000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9891, 615, 1, '0', 'Population', 'Population', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9892, 615, 2, '0', 'Landuse', 'Landuse', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9893, 615, 3, '0', 'Countries', 'Countries', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9894, 615, 4, '0', 'Landsat images', 'Landsat images', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9895, 615, 5, '0', 'Watersheds', 'Watersheds', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9896, 615, 6, '0', 'Rivers', 'Rivers', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9897, 615, 7, '0', 'Ramsar sites (Polygons)', 'Ramsar sites (Polygons)', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9898, 615, 8, '0', 'Ramsar sites', 'Ramsar sites', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19210, 787, 0, '', 'OGC-Dienst der Bayerischen Vermessungsverwaltung', 'OGC-Dienst der Bayerischen Vermessungsverwaltung', 0, 0, 0, '', '', 'Saemtliche Rechte an den ueber diesen Dienst verfuegbaren Geobasisdaten liegen beim Landesamt fuer Vermessung und Geoinformation (LVG Bayern). Fuer ihre Nutzung durch Vervielfaeltigung, Verbreitung und Veroeffentlichung beachten Sie bitte die Nutzungsbedingungen unter http://www.geodaten.bayern.de/ogc/Nutzungsbedingungen.htm. Kostenfrei gestattet ist die Vervielfaeltigung zum privaten Gebrauch sowie die Veroeffentlichung von Geobasisdaten auf der eigenen Website im Umfang eines Bildes von maximal 1024 x 768 Pixel. Die Quellenangabe ist in der Form "(c) LVG Bayern" anzubringen und als Link auf http://www.lvg.bayern.de auszufuehren. Fuer jede andere Nutzung ist eine Nutzungsvereinbarung mit dem LVG Bayern erforderlich.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10166, 640, 1, '0', 'global_mosaic', 'WMS Global Mosaic, pan sharpened', 0, 20044, 0, '', 'http://onearth.jpl.nasa.gov/WAF/WMS_GM.xml', ' 	Release 2 of the WMS Global Mosaic, a seamless mosaic of Landsat7 scenes. 	Spatial resolution is 0.5 second for the pan band, 1 second for the visual and near-IR bands and 2 second for the thermal bands 	Use this layer to request individual grayscale bands. The default styles may have gamma, sharpening and saturation filters applied. 	The grayscale styles have no extra processing applied, and will return the image data as stored on the server. 	The source dataset is part of the NASA Scientific Data Purchase, and contains scenes acquired in 1999-2003.         This layer provides pan-sharpened images, where the pan band is used for the image brightness regardless of the color combination requested.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19245, 789, 22, '18', 'tk10g', 'TK 10 - Grundriss', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK10GRU');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9877, 614, 0, '', '', 'ArcIMS Map Server', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9878, 614, 1, '0', '250K Topo Map', '250K Topo Map', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9879, 614, 2, '0', '100K Topo Map', '100K Topo Map', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9880, 614, 3, '0', '24K Topo Map', '24K Topo Map', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9881, 614, 4, '0', 'General Topo Map', 'General Topo Map', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9882, 614, 5, '0', 'Road', 'Road', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9883, 614, 6, '0', '24K Quad', '24K Quad', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9884, 614, 7, '0', '100K Quad', '100K Quad', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9885, 614, 8, '0', '250K Quad', '250K Quad', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9886, 614, 9, '0', 'County', 'County', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9887, 614, 10, '0', 'State', 'State', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9888, 614, 11, '0', 'City', 'City', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9889, 614, 12, '0', 'Geographic Name', 'Geographic Name', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7255, 525, 0, '', 'Middle_America', 'Middle America', 0, 0, 0, '', '', 'Middle_America');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7256, 525, 1, '0', 'North_and_South_American_States', 'America', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7257, 525, 2, '0', 'Middle_American_States_AREA', 'State Area', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7258, 525, 3, '0', 'Middle_America_DEM_surface', 'Elevation Model', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7259, 525, 4, '0', 'National_borders', 'Borders', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7260, 525, 5, '0', 'Lakes_and_temporary_inundated_areas', 'Lakes', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7261, 525, 6, '0', 'Temporary_and_permanent_rivers_and_streams', 'Rivers', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7262, 525, 7, '0', 'Larger_cities_polygon', 'Cities', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7263, 525, 8, '0', 'Roads', 'Roads', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7264, 525, 9, '0', 'Railway_systems', 'Rails', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7265, 525, 10, '0', 'Smaller_cities_and_villages_point', 'Places', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7266, 525, 11, '0', 'Archaeological_maya_sites', 'Maya Sites', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7510, 583, 19, '0', 'places_labels_2m', 'Populated Places (labels 1:2M)', 1, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7511, 583, 20, '0', 'places_symb_7.5m', 'Populated Places (symbols 1:7.5M)', 1, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7512, 583, 21, '0', 'places_labels_7.5m', 'Populated Places (labels 1:7.5M)', 1, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7513, 583, 22, '0', 'places_symb_15m', 'Populated Places (symbols 1:15M)', 1, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7514, 583, 23, '0', 'places_labels_15m', 'Populated Places (labels 1:15M)', 1, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7515, 583, 24, '0', 'cap_symb_e', 'Capitals (symbols)', 1, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7516, 583, 25, '0', 'cap_labels', 'Capitals (Canada)', 1, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10194, 645, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10195, 645, 1, '0', 'HDM:LANDMASS', 'Land Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10196, 645, 2, '0', 'HDM:DFIRM_BFE', 'DFIRM Base Flood Elevations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10197, 645, 3, '0', 'HDM:DFIRM_XSECTION', 'DFIRM Cross Sections', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10198, 645, 4, '0', 'HDM:DFIRM_FLD_AR', 'DFIRM Flood Hazard Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10199, 645, 5, '0', 'HDM:Q3_COUNTYMAP', 'Flood Data Availability', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10200, 645, 6, '0', 'HDM:Q3_FLOOD', 'Q3 Flood Hazards', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7491, 583, 0, '', 'canada_base', 'Atlas of Canada WMS', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7492, 583, 1, '0', 'roc_2m', 'Regions outside Canada (1:2 000 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7493, 583, 2, '0', 'roc_7.5m', 'Regions outside Canada (1:7 500 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7494, 583, 3, '0', 'roc_15m', 'Regions outside Canada (1:15 000 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7495, 583, 4, '0', 'wa_2m', 'Water areas (1:2 000 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7496, 583, 5, '0', 'wa_7.5m', 'Water areas (1:7 500 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7497, 583, 6, '0', 'wa_15m', 'Water areas (1:15 000 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7506, 583, 15, '0', 'nat_bounds', 'Provincial and Territorial Boundaries', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7507, 583, 16, '0', 'int_bounds', 'Boundaries', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7508, 583, 17, '0', 'can_7.5m', 'Landmass outline (1:7 500 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7509, 583, 18, '0', 'places_symb_2m', 'Populated Places (symbols 1:2M)', 1, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7267, 525, 12, '0', 'Archaeological_maya_records', 'Maya Records', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10994, 671, 3, '0', 'Heilquellen Zone 1 punktfoermig', 'Heilquellen Zone 1 punktfoermig', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10995, 671, 4, '0', 'Heilquellenschutzgebiete', 'Heilquellenschutzgebiete', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11630, 717, 1, '0', '0', 'Forstamtsgrenzen', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10047, 625, 0, '', 'DEMO', 'DM Solutions'' WMS Demo Server', 0, 0, 0, '', '', 'This demonstration server was setup by DM Solutions Group (http://www.dmsolutions.ca/) and is powered by MapServer (http://mapserver.gis.umn.edu/).  This server uses Canadian source data (c)2000, Government of Canada with permission from Natural Resources Canada from NRCan');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10048, 625, 1, '0', 'bathymetry', 'Elevation/Bathymetry', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10049, 625, 2, '0', 'land_fn', 'US Land', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10050, 625, 3, '0', 'park', 'Parks', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10051, 625, 4, '0', 'drain_fn', 'US Lakes', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10052, 625, 5, '0', 'drainage', 'Lakes', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10053, 625, 6, '0', 'prov_bound', 'Provincial Borders', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10054, 625, 7, '0', 'fedlimit', 'Federal Limit', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10055, 625, 8, '0', 'rail', 'Railroads', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10167, 640, 2, '0', 'global_mosaic_base', 'WMS Global Mosaic, not pan sharpened', 0, 20044, 0, '', '', ' 	Release 2 of the WMS Global Mosaic, a seamless mosaic of Landsat7 scenes. 	Spatial resolution is 0.5 second for the pan band, 1 second for the visual and near-IR bands and 2 second for the thermal bands 	Use this layer to request individual grayscale bands. The default styles may have gamma, sharpening and saturation filters applied. 	The source dataset is part of the NASA Scientific Data Purchase, and contains scenes acquired in 1999-2003. 	Release 2.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10056, 625, 9, '0', 'road', 'Roads', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10168, 640, 3, '0', 'us_landsat_wgs84', 'CONUS mosaic of 1990 MRLC dataset', 0, 40088, 0, '', '', ' 	CONUS seamless mosaic of Landsat5 scenes. Maximum resolution is 1 arc-second. 	The default styles may have gamma, sharpening and saturation filters applied. 	The source dataset is part of the MRLC 1990 dataset. 	This layer is not precisely geo-referenced!       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10057, 625, 10, '0', 'popplace', 'Cities', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10058, 625, 11, '0', 'grid', 'Grid', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7500, 583, 9, '0', 'drain_7.5m', 'Drainage (1:7 500 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7501, 583, 10, '0', 'drain_15m', 'Drainage (1:15 000 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7502, 583, 11, '0', 'drain_60m', 'Drainage (1:60 000 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7503, 583, 12, '0', 'roads_2m', 'Road network (1:2 000 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7504, 583, 13, '0', 'roads_7.5m', 'Road network (1:7 500 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7505, 583, 14, '0', 'roads_15m', 'Road network (1:15 000 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7498, 583, 7, '0', 'wa_60m', 'Water areas (1:60 000 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13775, 101, 0, '', 'UMN_Mapserver', 'UMN Mapserver', 0, 1, 0, '', '', 'UMN User Overview (UMN MapServer/Postgis)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7499, 583, 8, '0', 'drain_2m', 'Drainage (1:2 000 000)', 0, 0, 0, '', NULL, '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13776, 101, 1, '0', 'UMN_USER', 'UMN MapServer User', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13777, 101, 2, '0', 'UMN_USER_NAMES', 'UMN Info', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13751, 86, 0, '', 'World_map', 'World Map', 0, 1, 0, '', '', 'World Map in WGS84 Reference System');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13752, 86, 1, '0', 'Countries', 'Countries', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13753, 86, 2, '0', 'Countrynames', 'Countrynames', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13754, 86, 3, '0', 'Citypoints', 'Citypoints', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13755, 86, 4, '0', 'City', 'Citynames', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19177, 613, 0, '', 'ArcIMS MapService', 'ArcIMS MapService', 0, 0, 0, '', '', 'OGC - Web Map Server.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14104, 767, 0, '', 'SLUBFURT', 'SÅ‚ubfurt', 0, 125, 62500, '', '', 'SÅ‚ubfurter Mental Map Survey 2000 - 2002.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19212, 800, 0, '', 'LMIC WMS server (aerial photography)', 'LMIC WMS server (aerial photography)', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14105, 767, 2, '0', 'Mentalscape', 'Mentalscape', 0, 0, 0, '', '', 'SÅ‚ubfurter Mental Map Survey 2000 - 2002: mentalscape');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14365, 800, 1, '0', 'fsa', '2003 color FSA', 0, 802, 0, '', 'http://www.lmic.state.mn.us/chouse/metadata/naip03.html', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14106, 767, 3, '0', 'Districts', 'Districts', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Districts are the medium to large sections of the city, conceived of as having two dimensional extent, which the observer enters  - inside of -, and which are recognizable as having some common identifying cha  racter (eg. city center, central business district, shopping zone, neighborhoods, villages, large city parks or wooded areas ...).(Lynch 1960: The Image of the City)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19178, 615, 0, '', 'ArcIMS Map Server', 'ArcIMS Map Server', 0, 0, 0, '', '', 'WMT Map Server maintained by ESRI Inc.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9899, 615, 9, '0', 'Ramsar sites (Points)', 'Ramsar sites (Points)', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9900, 615, 10, '0', 'Cities', 'Cities', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14258, 787, 1, '0', 'DOP', 'DOP', 0, 20, 400880, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14252, 785, 1, '0', 'DTK200-V', 'Digitale Topographische Karte 1:200.000', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14259, 787, 2, '0', 'TK50', 'TK50', 0, 20, 80176, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14253, 785, 2, '0', 'DTK500-V', 'Digitale Topographische Karte 1:500.000', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14260, 787, 3, '0', 'UK500', 'UK500', 0, 20, 801759, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14254, 785, 3, '0', 'DTK1000', 'Digitale Topographische Karte 1:1.000.000', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19213, 767, 1, '0', 'slubfurtmap', 'SÅ‚ubfurt City Map', 0, 0, 0, '', '', 'SÅ‚ubfurter City Map');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14255, 786, 0, '', 'MS', 'Luftbilder', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14256, 786, 2, '1', 'ortho', 'Sachsen 1999-2004', 0, 1, 20000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14107, 767, 4, '0', 'Odra', 'Odra', 1, 0, 0, '', '', 'Odralandia - Odra');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14108, 767, 5, '0', 'Paths', 'Paths', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Paths are the channels along which the observer customarily, occasionally, or potentially moves (e.g. walkways, streets, roads, alleys, rivers, railway lines). (Lynch 1960: The Image of the City)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14265, 789, 1, '0', 'UEB', 'Uebersicht', 0, 117283, 0, '', '', 'FREETK:MS:FREETK:RASTER UEB');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19179, 624, 0, '', 'gewstat', 'gewstat', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19180, 624, 1, '0', '2', 'Einzugsgebiete', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19181, 624, 2, '0', '12', 'Kanal', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19182, 624, 3, '0', '14', 'groessere Fliessgewaesser (generalisiert)', 1, 524922, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19183, 624, 4, '0', '9', 'Fliessgewaesser', 1, 200, 524922, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19184, 624, 5, '0', '16', 'Gewaesserflaeche', 1, 200, 89987, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19185, 624, 6, '0', '15', 'Stationierungslinie', 1, 200, 74989, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19186, 624, 7, '0', '6', 'Stationierung', 1, 200, 74989, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19187, 624, 8, '0', '17', 'Beschriftung Kanal', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19188, 624, 9, '0', '13', 'Beschriftung Fliessgewaesser', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19189, 624, 10, '0', '18', 'Beschriftung Einzugsgebiete', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19214, 786, 1, '0', 'bw', 'Graustufen', 0, 0, 0, '', '', 'bw');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19215, 786, 3, '1', 'ortho_pan06', 'Sachsen 2005/06', 0, 1, 9999, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19216, 786, 4, '1', 'ortho_flut', 'Flut 2002', 0, 1, 20000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19217, 786, 5, '0', 'ir', 'Farbe (infrarot)', 0, 0, 0, '', '', 'ir');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19220, 786, 6, '5', 'ortho_cir06', 'Sachsen 2005/06', 0, 1, 9999, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19221, 786, 7, '0', 'c', 'Farbe (RGB)', 0, 0, 0, '', '', 'c');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19223, 786, 8, '7', 'ortho_color', 'Mittelsachsen 2002', 0, 1, 20000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19225, 786, 9, '7', 'ortho_rgb06_lowres', 'Sachsen 2005/06 LowRes', 0, 9999, 1000000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19227, 786, 10, '7', 'ortho_rgb06', 'Sachsen 2005/06', 0, 1, 9999, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14270, 789, 4, '2', 'tk100i', 'TK 100 - Hoehenlinien', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK100ISO');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14271, 789, 5, '2', 'tk100v', 'TK 100 - Vegetation', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK100VEG');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14269, 789, 6, '2', 'tk100g', 'TK 100 - Grundriss', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK100GRU');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14267, 789, 7, '2', 'tk100s', 'TK 100 - Schriften', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK100SCHR');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14272, 789, 8, '0', 'tk50', 'TK 50', 0, 9382, 23456, '', '', 'FREETK:MS:FREETK:');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14273, 789, 9, '8', 'tk50w', 'TK 50 - Gewaesser', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK50GEW');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14275, 789, 10, '8', 'tk50i', 'TK 50 - Hoehenlinien', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK50ISO');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14276, 789, 11, '8', 'tk50v', 'TK 50 - Vegetation', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK50VEG');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14274, 789, 12, '8', 'tk50g', 'TK 50 - Grundriss', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK50GRU');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19235, 789, 13, '0', 'tk25', 'TK 25', 0, 4691, 9382, '', '', 'FREETK:MS:FREETK:');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19236, 789, 14, '13', 'tk25w', 'TK 25 - Gewaesser', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK25GEW');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19237, 789, 15, '13', 'tk25i', 'TK 25 - Hoehenlinien', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK25ISO');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19238, 789, 16, '13', 'tk25v', 'TK 25 - Vegetation', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK25VEG');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19239, 789, 17, '13', 'tk25g', 'TK 25 - Grundriss', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK25GRU');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19241, 789, 18, '0', 'tk10', 'TK 10', 0, 94, 4691, '', '', 'FREETK:MS:FREETK:');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19242, 789, 19, '18', 'tk10w', 'TK 10 - Gewaesser', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK10GEW');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19243, 789, 20, '18', 'tk10i', 'TK 10 - Hoehenlinien', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK10ISO');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19190, 328, 0, '', 'verfügbare Layer', 'verfügbare Layer', 0, 0, 0, '', '', 'Web Map Service auf Basis des Smallworld GIS');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3385, 328, 1, '0', 'Autobahn', 'Autobahn', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3386, 328, 2, '0', 'Bundesstr.', 'Bundesstr.', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3387, 328, 3, '0', 'Landesstr.', 'Landesstr.', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3388, 328, 4, '0', 'Kreisstr.', 'Kreisstr.', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3393, 328, 5, '0', 'Aeste', 'Äste', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19191, 328, 6, '0', 'Netzknoten', 'Netzknoten', 1, 0, 68150, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19192, 328, 7, '0', 'Nullpunkte', 'Nullpunkte', 1, 0, 50110, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19193, 328, 8, '0', 'AS-Nummern', 'AS-Nummern', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19194, 328, 9, '0', 'AS-Namen', 'AS-Namen', 1, 0, 68150, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19195, 328, 10, '0', 'Strassenbez.', 'Straßenbez.', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19196, 328, 11, '0', 'Abschnittsnr.', 'Abschnittsnr.', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3391, 328, 12, '0', 'Bauwerke', 'Bauwerke', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19197, 328, 13, '12', 'Bauwerkslage', 'Bauwerkslage', 1, 0, 50110, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19198, 328, 14, '12', 'Bauwerksnr.', 'Bauwerksnr.', 1, 0, 50110, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19199, 328, 15, '0', 'Verwaltungsbezirke', 'Verwaltungsbezirke', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19200, 328, 16, '15', 'Bundesland', 'Bundesland', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19201, 328, 17, '15', 'Regierungsbezirke', 'Regierungsbezirke', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19202, 328, 18, '15', 'Kreise_/_kreisfreie_Staedte', 'Kreise / kreisfreie Städte', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19203, 328, 19, '15', 'Gemeinden', 'Gemeinden', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19204, 328, 20, '0', 'Rasterkarten', 'Rasterkarten', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19205, 328, 21, '20', 'Strassenkarte', 'Straßenkarte', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7523, 584, 6, '0', 'OBBA_SQUARE', 'Ontario Breeding Bird Atlas 10 km Squares', 1, 0, 0, '', '', 'A sampling unit used by the Ontario Breeding Bird Atlas to collect breeding evidence data for all bird species within the Province of Ontario.  Squares are based upon the Universal Transverse Mercator (UTM) grid system, NAD83, and measure 10Km by 10Km except near UTM zone boundaries, where they are smaller.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7524, 584, 7, '0', 'OBBA_REGION', 'Ontario Breeding Bird Atlas Administrative Regions', 1, 0, 0, '', '', 'An administrative unit that is used for local bird atlas co-ordination, which is based on bioregions and access.  Each region is assigned a Regional Coordinator who administers bird surveys within their region.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7525, 584, 8, '0', 'OBBA_BLOCK', 'Ontario Breeding Bird Atlas 100 km Blocks', 1, 0, 0, '', '', 'A sampling unit used by the Ontario Breeding Bird Atlas to collect breeding evidence data for all bird species within the Province of Ontario.  Blocks are based upon the Universal Transverse Mercator (UTM) grid system, NAD83, and measure 100Km by 100Km except near UTM zone boundaries, where they are smaller.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7526, 584, 9, '0', 'OWLS', 'Nocturnal Owl Survey Locations', 1, 0, 0, '', '', 'A volunteer-based program that monitors the abundance of owl species across Canada by means of broadcast surveys.  Ontario survey locations are currently available through this service.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7527, 584, 10, '0', 'BBS_PT', 'Breeding Bird Survey Route Start Points', 1, 0, 0, '', '', 'The Breeding Bird Survey, initiated in 1966, is one of the oldest surveys of breeding birds in North America. It is conducted primarily by volunteers, who follow a predetermined, roadside route each year at the height of the breeding season.  This layer portrays the start point for each BBS route in Canada.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19228, 834, 0, '', 'DE_aerial02', 'DE_aerial02', 0, 0, 0, '', '', 'The Delaware 2002 Aerial Imagery Map Service serves statewide orthophotography as captured in 2002. The State of Delaware contracted with EarthData International to develop 0.25-meter resolution color infrared digital ortho-photos for the entire state. Map scale of the photography is approximately 1:2,400. Airphotos were taken in March and April, 2002, digitized and georeferenced to Delaware State Plane NAD83 meters. This data is available as an ArcIMS map service, a WMS map service, original 1-meter raw data files. ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19246, 828, 0, '', 'CAPAS', 'CAPAS', 0, 0, 0, '', '', 'IDERIOJA Gobierno de La Rioja OGC WMS');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19247, 828, 1, '0', 'Elementos_hidrográficos', 'Elementos_hidrográficos', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19248, 828, 2, '0', 'Hojas_cartográficas_1-5000', 'Hojas_cartográficas_1-5000', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19249, 828, 3, '0', 'Manzanas_de_los_núcleos_urbanos', 'Manzanas_de_los_núcleos_urbanos', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10106, 634, 0, '', 'Location', 'Point locations', 0, 0, 0, '', '', 'This service provides approximate point locations for various     themes.   ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10107, 634, 1, '0', 'city_austral', 'Australasian Cities', 0, 0, 0, '', '', '           Location of cities in the Australasian region.         ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10108, 634, 2, '0', 'capital_aus', 'Australian Capital Cities', 0, 0, 0, '', '', '           Location of capital cities in Australia.         ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10109, 634, 3, '0', 'town_aus', '           Some Australian towns         ', 0, 0, 0, '', '', '           Location of some towns in Australia.         ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10110, 634, 4, '0', 'wastewet', '           Wastewater artificial wetlands listed as important wetlands           in Australia         ', 0, 0, 0, '', '', '           Location of artificial wetlands that are comprised primarily of           waste water as listed in "A Directory of Important Wetlands in           Australia Database".         ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14364, 800, 2, '0', 'doq', '1991 doqs', 0, 802, 0, '', 'http://www.lmic.state.mn.us/chouse/metadata/doq.html', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14366, 800, 3, '0', 'metro', '2004 metro area NGA', 0, 241, 0, '', 'http://mcmcweb.er.usgs.gov/catalog/metadata/Minneapolis-StPaul_2004.html', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19222, 800, 4, '0', 'bw1997', '1997 Met Council BW', 0, 481, 0, '', 'http://www.datafinder.org/metadata/orthos1997.htm', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19224, 800, 5, '0', 'bw2000', '2000 Met Council BW', 0, 481, 0, '', 'http://www.datafinder.org/metadata/orthos2000.htm', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19229, 640, 4, '0', 'srtm_mag', 'SRTM reflectance magnitude, 30m', 0, 20044, 0, '', '', '   This is the radar reflectance image produced by the SRTM mission. It is the best available snapshot of the surface of the earth, being the highest resolution image collected in the shortest ammount of time, with near-global 30m coverage collected during an 11-day Endeavour mission, in February of 2000. Five basic bands are available as WMS styles, ss1, ss2, ss3 and ss4 being SRTM image subswath averages, the "all" style being an average of the four subswath composites. The "default" style is derived from the "all" band, using an arbitrary color map to make more detail visible. The subswath composites also available as WMS bands, band 0 correspoinding to ss1, 1 to "ss2", 2 to "ss3", 3 to "ss4" and 5 to "all". A radar image has little in common with a visual image, depending mostly on the material and orientation of the object. Areas with low detail such as lakes and sand tend to have no reflection, and very steep terrain can obscure certain areas from the side look ing SRTM instrument, both fenomena generating voids in the SRTM reflectance image. Urban areas tend to have stronger reflectance. The banding artifacts still visible in the images are the result of the combination of data from multiple orbits or are intrinsic to the SRTM instrument.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19230, 640, 5, '0', 'daily_terra_721', 'Daily composite of MODIS-TERRA 721 pseudocolor', 0, 250550, 0, '', '', ' 	Daily generated mosaic of TERRA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.         The 721 band mapping is used to identify burnt and flooded areas.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19231, 640, 6, '0', 'daily_aqua_721', 'Daily composite of MODIS-AQUA 721 pseudocolor', 0, 250550, 0, '', '', ' 	Daily generated mosaic of the AQUA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.         The 721 band mapping is used to identify burnt and flooded areas.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19232, 640, 7, '0', 'daily_terra_ndvi', 'Daily composite of MODIS-TERRA images, NDVI processing', 0, 250550, 0, '', '', ' 	Daily generated mosaic of TERRA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.         The Normalized Difference Vegetation Index (NDVI) is strongly correlated with the plant density and state.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19234, 640, 8, '0', 'daily_aqua_ndvi', 'Daily composite of MODIS-AQUA images, NDVI processing', 0, 250550, 0, '', '', ' 	Daily generated mosaic of the AQUA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.         The Normalized Difference Vegetation Index (NDVI) is strongly correlated with the plant density and state.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10171, 640, 9, '0', 'daily_terra', 'Daily composite of MODIS-TERRA images', 0, 250550, 0, '', '', ' 	Daily generated mosaic of TERRA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10177, 640, 16, '0', 'us_ned', 'United States elevation, 30m', 0, 40088, 0, '', '', '         Continental United States elevation, produced from the USGS National Elevation.         The default style is scaled to 8 bit from the orginal floating point data.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10370, 648, 1, '0', 'hangneigung', 'Hangneigung', 1, 200, 374944, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10371, 648, 2, '0', 'Fliessgewaesser', 'Fliessgewaesser', 1, 200, 374944, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19218, 792, 0, '', 'TKVV', 'TKVV', 0, 200, 200440, '', '', 'wms reference implementation');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14288, 792, 1, '0', 'Thueringer_Orthofotos', 'Thueringer_Orthofotos', 0, 0, 0, '', '', 'cascaded WMS layers remote WFS and remote WCS examples');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14289, 792, 2, '1', 'Orthophotos_TH-2m', 'Orthophotos_TH-2m', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14290, 792, 3, '0', 'TK50', 'TK50', 0, 0, 0, '', '', 'cascaded WMS layers remote WFS and remote WCS examples');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14291, 792, 4, '3', 'Top.Karte_50_gesamt', 'Top.Karte_50_gesamt', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14292, 792, 5, '3', 'Grundriss', 'Grundriss', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14293, 792, 6, '3', 'Gewaesser', 'Gewaesser', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14294, 792, 7, '3', 'Hoehenschichten', 'Hoehenschichten', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14295, 792, 8, '3', 'Strassen', 'Strassen', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14296, 792, 9, '3', 'Wald', 'Wald', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14759, 834, 1, '0', 'ortho2002', '2002 Aerial Imagery', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10178, 640, 17, '0', 'us_elevation', 'Digital Elevation Map of the United States, DTED dataset, 3 second resolution, grayscale', 0, 90198, 0, '', '', ' 	DTED Level 3 US elevation.  The default style is scaled to 8 bit. 	It is possible to request the elevation data in meters by the short_int tyle and requesting PNG format. The resulting PNG file will be a unsigned 16 bit per pixel image. The values are elevation in meters, zero clipped (no negative values).       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19206, 670, 0, '', 'waldtyp', 'waldtyp', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10989, 670, 1, '0', 'Waldtyp_50', 'Waldtyp_50', 0, 37494, 187472, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10990, 670, 2, '0', 'Waldtyp_Real', 'Waldtyp_Real', 0, 37494, 187472, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19219, 640, 0, '', 'OnEarth Web Map Server', 'OnEarth Web Map Server', 0, 0, 0, '', '', 'WMS Server maintained by JPL, worldwide satellite imagery.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19250, 828, 4, '0', 'Masas_de_agua', 'Masas_de_agua', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19252, 828, 5, '0', 'Municipios', 'Municipios', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15337, 407, 0, '', 'Mapbender', 'Mapbender User', 0, 1, 0, '', '', 'Mapbender User Overview (Mapbender User/Postgis)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19254, 828, 6, '0', 'Ortofoto_2004', 'Ortofoto_2004', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15338, 407, 1, '0', 'Mapbender_User', 'Mapbender User', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Mapbender');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15339, 407, 2, '0', 'Mapbender_Names', 'Mapbender Info', 1, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Mapbender');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19172, 909, 0, '', 'germany_wfs_myedit', 'MyEdit Elements', 0, 1, 0, '', '', 'This is the demo WMS for the Mapbender digitize test-gui.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10153, 637, 0, '', 'Bathymetry', 'MapServer WMS Demo', 0, 50000, 0, '', '', 'This is a UMN WMS MapServer demonstration application for global elevation data.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10154, 637, 1, '0', 'etopo2', 'etopo2', 0, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10155, 637, 2, '0', 'ecbathy', 'ecbathy', 0, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10156, 637, 3, '0', 'gom', 'gom', 0, 50000, 2000000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10157, 637, 4, '0', 'bbay', 'bbay', 0, 50000, 1000000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10158, 637, 5, '0', 'gomctr', 'gomctr', 0, 50000, 749999, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10159, 637, 6, '0', 'world_line_simp', 'world_line_simp', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10160, 637, 7, '0', 'world_line', 'world_line', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19211, 637, 8, '0', 'alvin', 'alvin', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14109, 767, 6, '0', 'Edges', 'Edges', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Edges are the linear elements not used or considered as paths by the observer. They are boundaries between two phases, linear breaks in continuity (eg. highways, shores, railroad lines, edges of built up areas, walls).(Lynch 1960: The Image of the City) ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14110, 767, 7, '0', 'Nodes', 'Nodes', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Nodes are points, the strategic spots in a city into which an observer can enter, and which are the intensive foci to and from which he is traveling (e.g. intersections, street corner, play grounds, railway stations, core areas or polarizing center of districts, etc.). (Lynch 1960: The Image of the City)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19207, 671, 0, '', 'wsg', 'wsg', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10992, 671, 1, '0', 'Trinkwasser Zone 1 punktfoermig', 'Trinkwasser Zone 1 punktfoermig', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10993, 671, 2, '0', 'Trinkwasserschutzgebiete', 'Trinkwasserschutzgebiete', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14111, 767, 8, '0', 'Landmarks', 'Landmarks', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Landmarks are another type of point reference, but in this case the observer does not enter within them, they are external (eg. distinctive reference points such as a building or a tower, a sign, a store, a statue, a natural feature in the landscape such as a mountain or even a tree). (Lynch 1960: The Image of the City)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19173, 909, 1, '0', 'my_polygons', 'my polygons', 1, 0, 0, '', '', 'polygon');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14112, 767, 9, '0', 'CityWall', 'CityWall', 1, 0, 0, '', '', 'Slubfurter Stadtmauer:http://www.art.artpp.net/slubfurt/d/city/p1de_vita.html');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19174, 909, 2, '0', 'my_lines', 'my lines', 1, 0, 0, '', '', 'line, Linie');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19175, 909, 3, '0', 'my_points', 'my points', 1, 0, 0, '', '', 'point,Punkt,poi');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14113, 767, 10, '0', 'HotSpots', 'HotSpots', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Nearest Neighbor Hierarchical Clustering - First Order; For each identified cluster a Standard Deviational Ellipse is calculated. Typically, one standard deviation will cover more than 50% of the cases, one and a half standard deviations will cover more than 90% of the cases, and two standard deviations will cover more than 99% of the cases, although the exact percentage will depend on the distribution (Levine, 2002).');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19006, 893, 0, '', 'Germany', 'Germany', 0, 1, 0, '', '', 'Germany');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19007, 893, 1, '0', 'Topographie', 'topography', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Topographie,Landschaft');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7519, 584, 2, '0', 'CBC_PT', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', '', 'A winter survey of bird populations conducted during the Christmas period - December 14 to January 5th inclusive.  More than 1800 counts are conducted each year across Canada, the United States and Latin America.  On a selected day within the count period, local birders count as many birds as possible within a 24 km (15 mile) diameter circle.  The Christmas Bird Count had long been organized on the continental scale by the New York-based National Audubon Society. In 2000, Audubon finalized an agreement with Bird Studies Canada that would see BSC partner with Audubon to coordinate CBCs in Canada.  This layer represents the centre point of all the Christmas Bird Counts conducted in Canada.  An accompanying layer (CBC_PY) contains the 24 km circles.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19170, 908, 0, '', 'NRW', 'NRW', 0, 0, 140316, '', '', 'Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktmöglichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschließlich für Testzwecke und im Rahmen von GDI-Projekten zulässig; die Nutzung für kommerzielle Anwendungen ist ausdrücklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdrückliche Genehmigung durch das Landesvermessungsamt NRW nicht zulässig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigentümer bei Visualisierungen jeder Art anzubringen.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19171, 908, 1, '0', 'Raster:TK100_KMF:Farbkombination', 'Farbkombination', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19226, 789, 0, '', 'Topographische Karten', 'Topographische Karten', 0, 0, 0, '', '', 'SICAD Internet Suite V6.0A05 at http://www.landesvermessung.sachsen.de/sims/sicad-');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19008, 893, 2, '0', 'Grenze', 'border', 0, 750000, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Grenzen, border');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14266, 789, 2, '0', 'tk100', 'TK 100', 0, 23457, 117283, '', '', 'FREETK:MS:FREETK:');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19009, 893, 3, '0', 'Bundeslaender', 'federal states', 0, 750000, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Laender');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19010, 893, 4, '0', 'Staedte', 'places', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Staedte in der BRD');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14268, 789, 3, '2', 'tk100w', 'TK 100 - Gewaesser', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK100GEW');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19011, 893, 5, '0', 'Postleitzahlbereiche', 'postcode areas', 1, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Postleitzahl,PLZ,postcode');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19012, 893, 6, '0', 'Bahnlinien', 'railroad lines', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'railroad,Bahn,DB');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19013, 893, 7, '0', 'Fluesse', 'rivers', 0, 0, 1250000, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'river');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19014, 893, 8, '0', 'Strassen', 'roads', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'road');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19015, 893, 9, '0', 'Staedtepunkte', 'places as point', 1, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Stadt');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19016, 893, 10, '0', 'Postleitzahlbereichname', 'postcode areas (names)', 0, 0, 350000, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'PLZ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19017, 893, 11, '0', 'Staedtenamen', 'places (names)', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'city');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19018, 893, 12, '0', 'Bundeslaendernamen', 'federal states (names)', 0, 1000000, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Bundesland');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10179, 640, 18, '0', 'us_colordem', 'Digital Elevation Map of the United States, DTED dataset, 3 second resolution, hue mapped', 0, 90198, 0, '', '', ' 	The DTED Level 3 US elevation, mapped to a color image using the full spectrum. 	This result is not achievable by using SLD, so it is presented as a different layer.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19251, 832, 0, '', 'ArcIMS MapService', 'ArcIMS MapService', 0, 0, 0, '', '', 'This is an OGC compliant MapService served by the USGS Technology Applications Team (TAT) from the USGS''s Fort Collins Science Center');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14558, 832, 1, '0', 'overview', 'Wetland Overview', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10415, 655, 0, '', 'SEACOOS Remotely-Sensed Imagery', 'SEACOOS Remotely-Sensed Imagery', 0, 0, 0, '', '', 'The SouthEast Atlantic Coastal Ocean Observing System (SEACOOS) is a regional partnership that has initiated an integrated coastal ocean observing system for a four-state region of the southeast U.S.  SEACOOS brings together many organizations witha vested interest in improved oceanographic information and in building an Integrated Ocean Observing System (IOOS). The IOOS seeks to address the needs and concerns of the larger coastal community.  SEACOOS endeavors to significantly increase the quantity and quality of environmental information that is needed to address critical scientific problems and societal issues including:  commercial, military, and recreational maritime operations; K-16 and public education; safety; weather prediction; public health related to waste disposal and harmful algal blooms; shore erosion; and fisheries management.    To accomplish this, SEACOOS uses observing systems that operate at the sub-regional level, collecting real-time information using buoys and other automated coastal sensors every few minutes.  It combines these data with real-time downlinks of satellite images that cover the region in a synoptic manner several times a day.  The founding institutions are research universities within the region, while members include state and federal agencies. The Institute for Marine Remote Sensing (IMaRS) of the College of Marine Science at the University of South Florida, and the Rosenstiel School of Marine and Atmospheric Sciences (RSMAS) of the University of Miami operate the satellite ground stations and generate the various satellite data products consumed by SEACOOS users.  The University of North Carolina at Chapel Hill, the University of South Florida, and the University of Miami produce the model output with hindcasting and forecasting capabilities..  A current list of partners and affiliates can be found at http://www.seacoos.org.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14559, 832, 2, '0', 'wetlands_low', 'Wetlands Low Res', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14560, 832, 3, '0', 'wetlands', 'Wetlands High Res', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19258, 655, 1, '0', 'etopo2_bathy_relief', 'TBA', 0, 0, 0, '', '', 'TBA');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19259, 655, 2, '0', 'etopo2_bathy_contour', 'TBA', 0, 0, 0, '', '', 'TBA');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10416, 655, 3, '0', 'modis_ergb_low', 'MODIS Enhanced RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'An enhanced true color image of the upper ocean waters and coastal zones, estimated from the ocean color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. The red, green, and blue channels are provided by the water-leaving radiance data at 1km resolution, namely 555nm (R), 490nm (G), 443nm (B). This layer is provided by the USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10417, 655, 4, '0', 'modis_rgb_composite_low', 'MODIS Low Resolution RGB Composite, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, estimated from the ocean color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 1km resolution, uses radiance data at 678nm, 551nm, and 443nm as the red, green, blue channels, respectively.  The composite image is created by superimposing the most recent four passes with the latest pass drawn on top.  These data are made available by the USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19256, 828, 8, '0', 'Tramos_de_carreteras', 'Tramos_de_carreteras', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19257, 828, 9, '0', 'Tramos_de_ferrocarril', 'Tramos_de_ferrocarril', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10418, 655, 5, '0', 'modis_rgb_low', 'MODIS Low Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, estimated from the ocean color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 1km resolution, uses radiance data at 678nm, 551nm, and 443nm as the red, green, blue channels, respectively. These data are made available by the USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10419, 655, 6, '0', 'modis_rgb_hi_chesapeake_bay', 'MODIS High Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, coastal zones, and land areas estimated from color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 250m resolution, uses radiance data at 645nm, 555nm, 469nm as the red, green, and blue channels, respectively. This layer is available for select coastal locations and is provided by USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10420, 655, 7, '0', 'modis_rgb_hi_florida_bay', 'MODIS High Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, coastal zones, and land areas estimated from color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 250m resolution, uses radiance data at 645nm, 555nm, 469nm as the red, green, and blue channels, respectively. This layer is available for select coastal locations and is provided by USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10421, 655, 8, '0', 'modis_rgb_hi_miss_plume', 'MODIS High Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, coastal zones, and land areas estimated from color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 250m resolution, uses radiance data at 645nm, 555nm, 469nm as the red, green, and blue channels, respectively. This layer is available for select coastal locations and is provided by USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10422, 655, 9, '0', 'modis_rgb_hi_suwannee_river', 'MODIS High Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, coastal zones, and land areas estimated from color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 250m resolution, uses radiance data at 645nm, 555nm, 469nm as the red, green, and blue channels, respectively. This layer is available for select coastal locations and is provided by USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10423, 655, 10, '0', 'modis_rgb_hi_tampa_bay', 'MODIS High Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, coastal zones, and land areas estimated from color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 250m resolution, uses radiance data at 645nm, 555nm, 469nm as the red, green, and blue channels, respectively. This layer is available for select coastal locations and is provided by USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10424, 655, 11, '0', 'oi_sst', 'Optimally Interpolated SST, courtesy USF Ocean Circulation Group (http://ocg6.marine.usf.edu/)', 0, 0, 0, '', '', 'This layer is an operational, cloud-free, satellite SST product for the SEACOOS domain. Using Optimal Interpolation (OI) three types of satellite sea surface temperature (SST) data are merged to produce a cloud-free satellite SST field. Input data come from NOAA and NASA satellites and are compiled and processed daily by the USF Ocean Circulation Group, http://ocg6.marine.usf.edu. DISPLAY NOTE : A land mask cover should be placed over this layer.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10425, 655, 12, '0', 'modis_sst', 'MODIS SST, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'This SST layer is estimated from infrared measurements collected by the Advanced Very High Resolution Radiometer aboard NOAA''s series of polar orbiting satellites. Energy levels at the top of the atmosphere in the 10 - 11 micron range are fit statistically to in-water SST measurements to allow 1km resolution SST estimates to be made. These data are made available by the USF Institute for Marine Remote Sensing, http://imars.usf.edu. DISPLAY NOTE : A land mask cover should be placed over this layer.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19260, 840, 0, '', 'World', 'World', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10426, 655, 13, '0', 'avhrr_sst', 'AVHRR SST, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'This SST layer is derived from infrared measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Energy levels at the top of the atmosphere in the 10-11 micron range (daytime) and 3-4 micron range (nighttime) are fit statistically to in-water SST measurements to allow 1km resolution SST estimates to be made. The resolution and accuracy of MODIS data are among the best available to Earth scientists today. These data are made available by the USF Institute for Marine Remote Sensing, http://imars.usf.edu.  DISPLAY NOTE : A land mask cover should be placed over this layer.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10427, 655, 14, '0', 'modis_chl', 'MODIS Chl-A, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'TBA DISPLAY NOTE : A land mask cover should be placed over this layer.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19261, 883, 0, '', 'Luftbilder', 'Luftbilder', 0, 0, 0, '', '', 'SICAD/SD Internet Map Services V5.1 at http://192.168.252.12:80-Luftbilder');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14843, 840, 1, '0', 'GLOBEImage', 'GlobeImage', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10428, 655, 15, '0', 'jpl_sea_surface_height_composite', 'TBA', 0, 0, 0, '', '', 'TBA');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10429, 655, 16, '0', 'tamu_level_III', 'Texas Mesonet Radar, courtesy Texas A and M University (http://mesonet.tamu.edu/)', 0, 0, 0, '', '', 'The Texas Mesonet is a network of meteorological monitoring instruments, broadly dispersed across the State, and reporting to a common point for display of the data in near-real-time.  The data are archived and available to the public and the academic community for research and analysis.  The goal of this site is to provide a demonstration of the potential and capabilities of a Mesoscale (medium scale) monitoring network to the potential users:  The Citizens of Texas, the academic community, Emergency Planners and Managers, the Public Utilities, and anyone else who will find this data useful.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14851, 841, 0, '', 'ICEDSWMS', 'ICEDS (Integrated CEOS European Data Server) WMS', 0, 0, 0, '', '', 'Integrated CEOS European Data Server (ICEDS) Web Map Service, maintained by the Geomatic Engineering Dept at UCL');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14852, 841, 1, '0', 'GRID', 'MAPDRESSING GRID', 0, 0, 0, '', '', 'MAPDRESSING GRID');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14856, 841, 2, '0', 'landsat5', 'LANDSAT 5 mosaic for Africa and Europe', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Africa and Europe produced and kindly provided by Dr. Nevin Bryant (JPL)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10430, 655, 17, '0', 'tamu_usrad', 'Texas Mesonet Radar, courtesy Texas A and M University (http://mesonet.tamu.edu/)', 0, 0, 0, '', '', 'The Texas Mesonet is a network of meteorological monitoring instruments, broadly dispersed across the State, and reporting to a common point for display of the data in near-real-time.  The data are archived and available to the public and the academic community for research and analysis.  The goal of this site is to provide a demonstration of the potential and capabilities of a Mesoscale (medium scale) monitoring network to the potential users:  The Citizens of Texas, the academic community, Emergency Planners and Managers, the Public Utilities, and anyone else who will find this data useful.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19262, 841, 3, '2', 'landsat_1_01', 'LANDSAT 5 mosaic for Africa and Europe (100 arscsec. level)', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Africa and Europe produced and kindly provided by Dr. Nevin Bryant (JPL). Data resolution is a resampled version of the original dataset (100 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19264, 841, 4, '2', 'landsat_2_01', 'LANDSAT 5 mosaic for Africa and Europe (10 arscsec. level)', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Africa and Europe produced and kindly provided by Dr. Nevin Bryant (JPL). Data resolution is a resampled version of the original dataset (10 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19265, 841, 5, '2', 'landsat_3_01', 'LANDSAT 5 mosaic for Africa and Europe (1 arscsec. level)', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Africa and Europe produced and kindly provided by Dr. Nevin Bryant (JPL). Data resolution of 1 arcsec. per pixel');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10431, 655, 18, '0', 'surface_currents_radar', 'Surface currents (Radar) (EXPERIMENTAL), courtesy SEACOOS', 0, 0, 0, '', '', 'TBA');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19266, 841, 6, '0', 'landsat', 'Landsat 5 for Northamerica, Europe and Africa', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Northamerica, Europe and Africa');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19267, 841, 7, '6', 'landsat_1_02', 'LANDSAT 5 for Northamerica, Europe and Africa', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Northamerica, Europe and Africa');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10432, 655, 19, '0', 'depth_averaged_currents', 'Depth-averaged currents (EXPERIMENTAL), courtesy University of North Carolina, Chapel Hill', 0, 0, 0, '', '', 'TBA');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19268, 841, 8, '6', 'landsat_2_02', 'LANDSAT 5 for Northamerica, Europe and Africa', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Northamerica, Europe and Africa');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19269, 841, 9, '6', 'landsat_3_02', 'LANDSAT 5 for Northamerica, Europe and Africa', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Northamerica, Europe and Africa');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14860, 841, 10, '0', 'srtm', 'Hillshaded SRTM3 mosaic', 0, 0, 0, '', '', 'Hillshaded SRTM3 mosaic with the sea masked by the NOAA GSHHS global shorelines dataset');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10433, 655, 20, '0', 'sea_surface_elevation', 'Sea surface elevation (EXPERIMENTAL), courtesy University of North Carolina, Chapel Hill', 0, 0, 0, '', '', 'TBA');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14844, 840, 2, '0', 'ADMIN', 'Admin', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14845, 840, 3, '0', 'COUNTRY', ' Country', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14846, 840, 4, '0', 'Lakes', ' Lakes', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14847, 840, 5, '0', 'RAILWAY', ' Railway', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19263, 887, 0, '', 'BK50', 'BK50', 1, 0, 0, '', '', 'WMS Map Server');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14848, 840, 6, '0', 'WorldGridLines', ' World Grid Lines', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14849, 840, 7, '0', 'OCEAN_TEXT', ' Ocean Label', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14850, 840, 8, '0', 'CAPITALS', ' Capitals', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18275, 887, 1, '0', 'bk50', 'bk50', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18236, 883, 1, '0', '1', '$_nav_uebersicht', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18237, 883, 2, '0', '2', 'Stadtplan ', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18238, 883, 3, '0', '5', 'Luftbilder 1999', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18239, 883, 4, '0', '8', 'Flurstuecksstruktur', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18240, 883, 5, '0', '9', 'Texte', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14861, 841, 11, '10', 'srtm3_1', 'Hillshaded SRTM3 mosaic (180 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM3 mosaic with the sea masked by the NOAA GSHHS global shorelines dataset. Data resolution is a resampled version of the original dataset (180 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14862, 841, 12, '10', 'srtm3_2', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 1700000, 0, '', '', 'Hillshaded SRTM3 mosaic with the sea masked by the NOAA GSHHS global shorelines dataset. Data resolution is a resampled version of the original dataset (30 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14863, 841, 13, '10', 'srtm3_3', 'Hillshaded SRTM3 mosaic (3 arscsec. level)', 0, 0, 1699999, '', '', 'Hillshaded SRTM3 mosaic with the sea masked by the NOAA GSHHS global shorelines dataset. Data resolution of 3 arcsec. per pixel');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14864, 841, 14, '0', 'srtm30', 'Hillshaded SRTM30 mosaic', 0, 0, 0, '', '', 'Hillshaded SRTM30 mosaic combined with GTOPO30 data');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14865, 841, 15, '14', 'srtm30_1', 'Hillshaded SRTM30 mosaic (300 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM30 mosaic combined with GTOPO30 data. Data resolution is a resampled version of the original dataset (300 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14866, 841, 16, '14', 'srtm30_2', 'Hillshaded SRTM30 mosaic (30 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM30 mosaic combined with GTOPO30 data. Data resolution of 30 arcsec. per pixel');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19275, 841, 17, '0', 'srtm3_v2', 'Hillshaded SRTM3 mosaic (Version 2)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies masked by SRTM Water Bodies Mask');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19277, 841, 18, '17', 'srtm3_v2_0', 'Hillshaded SRTM3 mosaic (180 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies makes by SRTM Water Bodies Mask dataset. Data resolution is a resampled version of the original dataset (180 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19278, 841, 19, '17', 'srtm3_v2_1', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution is a resampled version of the original dataset (30 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19279, 841, 20, '17', 'srtm3_v2_2', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 1999999, 0, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution is a resampled version of the original dataset (30 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19280, 841, 21, '17', 'srtm3_v2_3', 'Hillshaded SRTM3 Version 2 mosaic (3 arscsec. level)', 0, 0, 1999999, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution of 3 arcsec. per pixel');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19281, 841, 22, '0', 'srtm3_v1', 'Hillshaded SRTM3 mosaic (Version 1)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 1 mosaic with waterbodies masked by SRTM Water Bodies Mask');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19282, 841, 23, '22', 'srtm3_v1_0', 'Hillshaded SRTM3 mosaic (180 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 1 mosaic with waterbodies makes by SRTM Water Bodies Mask dataset. Data resolution is a resampled version of the original dataset (180 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19284, 841, 24, '22', 'srtm3_v1_1', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 1 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution is a resampled version of the original dataset (30 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19286, 841, 25, '22', 'srtm3_v1_2', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 1999999, 0, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution is a resampled version of the original dataset (30 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19287, 841, 26, '22', 'srtm3_v1_3', 'Hillshaded SRTM3 Version 1 mosaic (3 arscsec. level)', 0, 0, 1999999, '', '', 'Hillshaded SRTM3 Version 1 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution of 3 arcsec. per pixel');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14867, 841, 27, '0', 'bluemarble', 'Global MODIS Blue Marble', 0, 0, 0, '', '', 'Global MODIS Blue Marble');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14868, 841, 28, '27', 'bluemarble_1', 'Global MODIS Blue Marble (300 arcsec. level)', 0, 0, 0, '', '', 'Global MODIS Blue Marble. Data resolution of 300 arcsec. per pixel');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14869, 841, 29, '27', 'bluemarble_2', 'Global MODIS Blue Marble (30 arcsec. level)', 0, 0, 0, '', '', 'Global MODIS Blue Marble. Data resolution of 30 arcsec. per pixel');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19289, 841, 30, '0', 'ciesin_pop', 'Cascaded population data from CIESIN', 0, 0, 0, '', '', 'ciesin_pop');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19291, 841, 31, '30', 'gpw1990', 'Gridded Population of the World , v3 beta: Pop Density 1990', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14870, 841, 32, '0', 'globe', 'Cascaded data from GLOBE', 0, 0, 0, '', '', 'globe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14871, 841, 33, '32', 'rivers', 'Cascaded Rivers from GLOBE', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14872, 841, 34, '32', 'coastlines', 'Cascaded Coastlines from GLOBE', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14873, 841, 35, '0', 'demis', 'Cascaded data from Demis', 0, 0, 0, '', '', 'demis');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10434, 655, 21, '0', 'opaque_legend_background', 'Opaque legend background', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10435, 655, 22, '0', 'modis_chl_legend_full_range', 'MODIS Chl-A Legend, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10436, 655, 23, '0', 'sst_legend_full_range', 'SST Legend, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10437, 655, 24, '0', 'tamu_level_III_legend_full_range', 'Texas Mesonet Radar Legend, courtesy Texas A and M University (http://mesonet.tamu.edu/)', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19270, 869, 0, '', 'linfos', 'linfos', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19271, 866, 0, '', 'hochwasser', 'hochwasser', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10438, 655, 25, '0', 'current_velocity_legend', 'Current velocity legend', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19272, 867, 0, '', 'stobo', 'stobo', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19110, 902, 0, '', 'Brandenburg', 'DNM 100/2', 0, 25001, 0, '', '', '2. Generation des Digitalen Navigationsmodells 1:100.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19273, 843, 0, '', 'hazards', 'hazards', 0, 0, 0, '', '', 'WMS Map Server');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19274, 837, 0, '', 'U.S. Geological Survey', 'U.S. Geological Survey', 0, 0, 0, '', '', 'WMT Map Server maintained by Microsoft Corporation.  Data returned provided by US Geological Survey.  Contact: tbarclay at microsoft.com or gylee at usgs.gov.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18146, 869, 1, '0', '51', 'Vegetationstypen', 1, 0, 150214, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14935, 843, 1, '0', 'Ambient Population 2002 (per 30 arc seconds)', 'Ambient Population 2002 (per 30 arc seconds)', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14936, 843, 2, '0', 'Elevation/Bathymetry', 'Elevation/Bathymetry', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10439, 655, 26, '0', 'water_level_legend', 'Elevation legend', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18147, 869, 2, '0', '49', 'Vegetationsaufnahmen', 1, 0, 150214, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18133, 867, 1, '0', 'Bleibelastung der Ackerboeden in mg pro kg', 'Bleibelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18120, 866, 1, '0', '8', 'rhein-hq100-odeich', 1, 200, 749888, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19276, 844, 0, '', 'CustomWeather Map Server', 'CustomWeather Map Server', 0, 0, 0, '', '', 'CustomWeather WMS Map Server.  Contact: info at customweather.com.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14937, 843, 3, '0', 'Continents', 'Continents', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18148, 869, 3, '0', '45', 'Naturraeumliche Haupteinheiten', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18134, 867, 2, '0', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14804, 837, 1, '0', 'DOQ', 'USGS Digital Ortho-Quadrangles', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18121, 866, 2, '0', '9', 'rhein-hq100-mdeich', 1, 200, 749888, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14938, 843, 4, '0', 'Lakes', 'Lakes', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18135, 867, 3, '0', 'Zinkbelastung der Ackerboeden in mg pro kg', 'Zinkbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18149, 869, 4, '0', '43', 'Landschaftsschutzgebiete', 1, 0, 150214, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18150, 869, 5, '0', '42', 'Stand der Landschaftsplanung', 1, 0, 150214, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18151, 869, 6, '0', '32', 'FFH-Gebiete', 1, 0, 150214, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18152, 869, 7, '0', '31', 'Vogelschutzgebiete', 1, 0, 150214, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18153, 869, 8, '0', '28', 'Biotoptypen', 1, 0, 150214, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18154, 869, 9, '0', '3', 'Biotopkataster', 1, 0, 150214, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18155, 869, 10, '0', '1', 'Naturschutzgebiete', 1, 0, 150214, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15004, 844, 1, '0', 'severe_warnings', 'severe_warnings', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14965, 844, 2, '0', 'anim', 'anim', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14967, 844, 3, '0', 'au_radar_stations', 'au_radar_stations', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14971, 844, 4, '0', 'conditions', 'conditions', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15005, 844, 5, '0', 'severe_watches', 'severe_watches', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14998, 844, 6, '0', 'marine_zones', 'marine_zones', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19285, 844, 7, '0', 'synoptic_weather', 'synoptic_weather', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14968, 844, 8, '0', 'base', 'base', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14993, 844, 9, '0', 'land_sea_mask', 'land_sea_mask', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15002, 844, 10, '0', 'radar_mask', 'radar_mask', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19288, 844, 11, '0', 'world_borders', 'world_borders', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19290, 844, 12, '0', 'fire_zones', 'fire_zones', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19292, 844, 13, '0', 'coasts_lakes', 'coasts_lakes', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14981, 844, 14, '0', 'earthquakes', 'earthquakes', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14964, 844, 15, '0', 'airport_delay', 'airport_delay', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14995, 844, 16, '0', 'lightning', 'lightning', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14988, 844, 17, '0', 'global_ir_satellite_10km', 'global_ir_satellite_10km', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14984, 844, 18, '0', 'frontlines', 'frontlines', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19293, 844, 19, '0', 'openwms', 'openwms', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14973, 844, 20, '0', 'contour_high', 'contour_high', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14972, 844, 21, '0', 'contour_fire_danger', 'contour_fire_danger', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14994, 844, 22, '0', 'legend', 'legend', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14969, 844, 23, '0', 'borders', 'borders', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14997, 844, 24, '0', 'maple_raster', 'maple_raster', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14980, 844, 25, '0', 'counties', 'counties', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15010, 844, 26, '0', 'zones', 'zones', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14976, 844, 27, '0', 'contour_precip', 'contour_precip', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14983, 844, 28, '0', 'forecasts', 'forecasts', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14977, 844, 29, '0', 'contour_pressure', 'contour_pressure', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19295, 844, 30, '0', 'hurricane', 'hurricane', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19296, 844, 31, '0', 'nhe_exp', 'nhe_exp', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19297, 844, 32, '0', 'high_seas', 'high_seas', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14974, 844, 33, '0', 'contour_jet_stream', 'contour_jet_stream', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15006, 844, 34, '0', 'state_borders', 'state_borders', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15001, 844, 35, '0', 'radar', 'radar', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14966, 844, 36, '0', 'au_radar', 'au_radar', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14970, 844, 37, '0', 'coasts', 'coasts', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14978, 844, 38, '0', 'contour_syn_precip', 'contour_syn_precip', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14990, 844, 39, '0', 'interstates', 'interstates', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19111, 902, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 25001, 0, '', '', 'Landkreise und kreisfreie Städte');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19112, 902, 2, '0', 'wald', 'Wald', 0, 25001, 150000, '', '', 'Wald');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19113, 902, 3, '0', 'ozen', 'Oberzentren', 0, 25001, 2000000, '', '', 'Oberzentren, TYP = 0');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19114, 902, 4, '0', 'mzen', 'Mittelzentren', 0, 25001, 600000, '', '', 'Mittelzentren, TYP = 1');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19115, 902, 5, '0', 'uzen', 'Unterzentren', 0, 25001, 200000, '', '', 'Unterzentren, TYP = 2');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19116, 902, 6, '0', 'lwas', 'Flüsse und Kanäle', 0, 25001, 150000, '', '', 'Flüsse und Kanäle');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19117, 902, 7, '0', 'fwas', 'Seen', 0, 25001, 250001, '', '', 'Seen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19118, 902, 8, '0', 'ebahn', 'Eisenbahnen', 0, 25001, 250001, '', '', 'Eisenbahnen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19119, 902, 9, '0', 'kstr', 'Kreisstraßen', 0, 25001, 100000, '', '', 'Kreisstraßen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19120, 902, 10, '0', 'lstr', 'Landesstraßen', 0, 25001, 250001, '', '', 'Landesstraßen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19121, 902, 11, '0', 'bstr', 'Bundesstraßen', 0, 25001, 749999, '', '', 'Bundesstraßen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19122, 902, 12, '0', 'astr', 'Autobahnen', 0, 25001, 0, '', '', 'Autobahnen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19123, 902, 13, '0', 'nfwas', 'Namen der Seen', 0, 25001, 100000, '', '', 'Namen der Seen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19124, 902, 14, '0', 'kfz', 'Kfz-Zeichen', 0, 2000000, 0, '', '', 'Kfz-Zeichen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14939, 843, 5, '0', 'Rivers', 'Rivers', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14940, 843, 6, '0', 'Countries', 'Countries', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14941, 843, 7, '0', 'States', 'States', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14942, 843, 8, '0', 'Cities', 'Cities', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14943, 843, 9, '0', 'Plate Boundaries', 'Plate Boundaries', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19283, 843, 10, '0', 'DART Buoys', 'DART Buoys', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14944, 843, 11, '0', 'Volcanoes', 'Volcanoes', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14945, 843, 12, '0', 'Tsunami Events with runups', 'Tsunami Events with runups', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14946, 843, 13, '0', 'Tsunami Events with slides', 'Tsunami Events with slides', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14947, 843, 14, '0', 'Tsunami Events', 'Tsunami Events', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14948, 843, 15, '0', 'Tsunami Runups', 'Tsunami Runups', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14949, 843, 16, '0', 'Significant Earthquakes with slides', 'Significant Earthquakes with slides', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14950, 843, 17, '0', 'Significant Earthquakes', 'Significant Earthquakes', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18136, 867, 4, '0', 'Bleibelastung der Gartenboeden in mg pro kg', 'Bleibelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18137, 867, 5, '0', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18138, 867, 6, '0', 'Zinkbelastung der Gartenboeden in mg pro kg', 'Zinkbelastung der Gartenboeden in mg pro kg', 1, 22497, 74989, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18139, 867, 7, '0', 'Bleibelastung der Gruenlandboeden in mg pro kg', 'Bleibelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18140, 867, 8, '0', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18141, 867, 9, '0', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18142, 867, 10, '0', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 1, 22497, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18122, 866, 3, '0', '6', 'rhein-hq200-odeich', 1, 200, 749888, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18123, 866, 4, '0', '7', 'rhein-hq200-mdeich', 1, 200, 749888, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18124, 866, 5, '0', '4', 'rhein-hq500-odeich', 1, 200, 749888, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18125, 866, 6, '0', '5', 'rhein-hq500-mdeich', 1, 200, 749888, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18126, 866, 7, '0', '0', 'vereinf_Verfahren', 1, 200, 374944, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18127, 866, 8, '0', '1', 'Sonstige_UESG', 1, 200, 374944, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18128, 866, 9, '0', '2', 'Historische_UESG', 1, 200, 374944, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18129, 866, 10, '0', '3', 'neuere_Berechnungsverfahren', 1, 200, 374944, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18130, 866, 11, '0', '18', 'Seen', 1, 200, 374944, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18131, 866, 12, '0', '19', 'Talsperre', 1, 200, 374944, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14805, 837, 2, '0', 'DRG', 'USGS Raster Graphics (Topo Maps)', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14894, 842, 0, '', 'Tsunami_Disaster_Map', 'Tsunami_Diasaster_Data', 0, 0, 0, '', '', 'This WMS server contains data used in http://www.mapsherpa.com/tsunami/. Much of the reference data is cascaded from other WMS servers.  Before using this data in your live application, please consult the metadata url for each layer to check to see if you can legally use the data in your application.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14895, 842, 1, '0', 'Satellite_Imagery', 'Satellite_Imagery', 0, 0, 0, '', '', 'Satellite_Imagery');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14896, 842, 2, '1', 'GAEL_WORLD_MARCH', 'ENVISAT MERIS mosaic', 0, 0, 0, '', 'http://mapserv2.esrin.esa.it/ionicweb/map/GAEL_WORLD_MARCH?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14897, 842, 3, '1', 'srtm_tiles', 'SRTM 90m DEM - unclassified', 0, 0, 0, '', 'http://gisweb.ciat.cgiar.org/sig/90m_data_tropics.htm', 'Hole-filled seamless SRTM data V1, 2004, International Centre for Tropical Agriculture (CIAT). Processed by the Laboratory for Applied Geomatics and GIS Science (LAGGISS), University of Ottawa.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14898, 842, 4, '1', 'thai-LandsatTrue', 'Landsat Mosaic of Thailand', 1, 0, 0, '', 'http://203.159.10.13/cgi-bin/mapserv?map=/var/www/html/gms/thaiwms.map', 'Landsat Mosaic of Thailand. Provided by the Asian Institute of Technology (AIT), Pathumthani, Thailand.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14806, 837, 3, '0', 'UrbanArea', 'USGS Urban Areas Ortho-Imagery', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14899, 842, 5, '1', 'sri_landsat', 'Landsat Mosaic of Sri Lanka', 0, 0, 0, '', 'https://zulu.ssc.nasa.gov/mrsid/docs/GeoCover_circa_2000_Product_Description.pdf', 'Landsat ETM+ image of Sri Lanka, obtained from https://zulu.ssc.nasa.gov/mrsid/mrsid.pl.  Processed by the Laboratory for Applied Geomatics and GIS Science (LAGGISS), University of Ottawa.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14900, 842, 6, '0', 'Physical_Geography', 'Physical_Geography', 0, 0, 0, '', '', 'Physical_Geography');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14901, 842, 7, '6', 'GTOPO30:Foundation', 'Global 30 Second Elevations', 1, 0, 0, '', 'http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14902, 842, 8, '6', 'RELIEF:Foundation', 'Two Minute Shaded Relief', 1, 0, 0, '', 'http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14903, 842, 9, '6', 'Bathymetry', 'Bathymetry', 0, 0, 0, '', 'http://www.ngdc.noaa.gov/mgg/fliers/01mgg04.html', '2-Minute Gridded Global Relief Data (ETOPO2), obtained from NOAA');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14904, 842, 10, '6', 'Topography', 'Topography', 0, 0, 0, '', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14905, 842, 11, '6', 'Hillshading', 'Hillshading', 0, 0, 0, '', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14906, 842, 12, '6', 'CONTOURL_ELEV_1M:Foundation', 'Elevation Contours', 1, 0, 0, '', 'http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14907, 842, 13, '0', 'Disaster_Info', 'Disaster_Info', 0, 0, 0, '', '', 'Disaster_Info');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14908, 842, 14, '13', 'locations', 'Disaster Point Locations', 1, 0, 0, '', 'N/A', 'Click points of interest for Disaster_Information about that location.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14874, 841, 36, '35', 'bathymetry', 'Cascaded Bathymetry from Demis', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14875, 841, 37, '0', 'onearth', 'Cascaded data from OnEarth', 0, 0, 0, '', '', 'onearth');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14876, 841, 38, '37', 'landsat7', 'Cascaded Landsat7 from OnEarth', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19294, 841, 39, '37', 'srtm_amp', 'Cascaded colourised SRTM amplitude mosaic from OnEarth', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14877, 841, 40, '37', 'terra', 'Cascaded daily MODIS Terra from OnEarth', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14878, 841, 41, '37', 'aqua', 'Cascaded daily MODIS Aqua from OnEarth', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14853, 841, 42, '0', 'lights', 'DMSP/NOAA human settlements night lights of the world', 0, 0, 0, '', '', 'Defense Metereological Satellite Program (DMSP)/NOAA - human settlements nightime lights. The brigthness is related to the average DN values for the year. The human settlements are the stable lights minus the identified gas flares');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14854, 841, 43, '42', 'lights_1', 'DMSP/NOAA human settlements night lights (300 arcsec. level)', 0, 0, 0, '', '', 'Defense Metereological Satellite Program (DMSP)/NOAA - human settlements nightime lights. The brigthness is related to the average DN values for the year. The human settlements are the stable lights minus the identified gas flares. Data resolution is a resampled version of the original dowloaded dataset (300 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14855, 841, 44, '42', 'lights_2', 'DMSP/NOAA human settlements night lights (30 arcsec. level)', 0, 0, 0, '', '', 'Defense Metereological Satellite Program (DMSP)/NOAA - human settlements nightime lights. The brigthness is related to the average DN values for the year. The human settlements are the stable lights minus the identified gas flares. Data resolution corresponds to the original dowloaded dataset resolution (30 arcsec.)');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19298, 841, 45, '0', 'usgs_aster', 'Footprints of pre-processed USGS ASTER DEMs', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19299, 841, 46, '0', 'swbd', 'Water bodies detected from SRTM amplitudes', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14879, 841, 47, '0', 'metarweather', 'Cascaded World Hourly METAR Weather Reports from Compusult', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14880, 841, 48, '0', 'noaa', 'Cascaded NOAA World Natural Hazards data', 0, 0, 0, '', '', 'noaa');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14881, 841, 49, '48', 'earthquakes', 'Cascaded NOAA Significant Earthquakes', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14882, 841, 50, '48', 'tsunamievents', 'Cascaded NOAA Tsunami Events', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14883, 841, 51, '48', 'volcanoes', 'Cascaded NOAA Volcanoes', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14884, 841, 52, '48', 'plateboundaries', 'Cascaded NOAA Plate Boundaries', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14885, 841, 53, '48', 'countries', 'Cascaded NOAA Countries', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14886, 841, 54, '48', 'cities', 'Cascaded NOAA Cities', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14887, 841, 55, '0', 'sigafrique', 'Cascaded SIGAFRIQUE data', 0, 0, 0, '', '', 'sigafrique');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14888, 841, 56, '55', 'geofault10', 'Cascaded geologic faults 10 m', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14889, 841, 57, '55', 'geoform10', 'Cascaded geologic formations 10 m', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14890, 841, 58, '55', 'towns', 'Cascaded towns', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14891, 841, 59, '55', 'mainrivers', 'Cascaded main water courses and inland water bodies', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14892, 841, 60, '55', 'water', 'Cascaded water courses', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14909, 842, 15, '13', 'faults', 'Fault Lines', 0, 0, 0, '', 'http://www.colorado.edu/geography/foote/maps/assign/hotspots/hotspots.html', 'Boundary lines between major world tectonic plates.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14910, 842, 16, '13', 'Wave_Heights', 'Wave Heights', 1, 0, 0, '', 'http://www.drs.dpri.kyoto-u.ac.jp/sumatra/index-e.html', 'Surveyed Wave Heights collected by Asian Research Group.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14911, 842, 17, '13', 'earthquakes', 'Recent Earthquakes', 1, 0, 0, '', 'http://earthquake.usgs.gov/recenteqsww/Maps/10/95_5.html', 'List of earthquakes of various magnitudes in the Indian Ocean region.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14912, 842, 18, '13', 'epicenter', 'Epicenter of the Earthquake', 1, 0, 0, '', 'http://earthquake.usgs.gov/recenteqsww/Maps/10/95_5.html', 'Epicenter of the earthquake - 9.0M, 2004/12/26 00:58:53 UTC');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18218, 882, 0, '', 'Wahlen', 'Wahlen', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18219, 882, 1, '0', 'HINTERGRUNDKARTE', 'HINTERGRUNDKARTE', 0, 0, 0, '', '', 'HINTERGRUNDKARTE');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14913, 842, 19, '0', 'Political', 'Political', 0, 0, 0, '', '', 'Political');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14914, 842, 20, '19', 'World_WMS-WorldGen', 'World Countries', 1, 0, 0, '', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_world?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18220, 882, 2, '1', 'stadtplan_grau_zoomst_1', 'stadtplan_grau_zoomst_1', 0, 135001, 300000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18221, 882, 3, '1', 'stadtplan_zoom3_01', '02_stadtplan', 0, 20001, 135000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14915, 842, 21, '19', 'Coastlines', 'Coastlines', 0, 0, 0, '', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14916, 842, 22, '19', 'Borders', 'Borders', 0, 0, 0, '', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18222, 882, 4, '1', 'stadtplan_zoom3_02', '03_stadtplan', 0, 12001, 20000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14917, 842, 23, '19', 'oceans', 'World Oceans Labels', 0, 0, 0, '', 'N/A', 'Ocean labels for visual purpose only.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18223, 882, 5, '1', 'stadtplan_zoom3_03', '04_stadtplan', 0, 2751, 12000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14918, 842, 24, '19', 'Cities', 'World Cities', 0, 0, 0, '', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14919, 842, 25, '0', 'Affected_Country_Statistics', 'Affected_Country_Statistics', 0, 0, 0, '', '', 'Affected_Country_Statistics');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18224, 882, 6, '1', 'dgk5_liste', 'Deutsche Grundkarte', 0, 0, 2750, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14920, 842, 26, '25', 'gdp', 'Gross Domestic Product (GDP)', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/', 'Classified layer of countries affected by the tsunami.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18225, 882, 7, '0', 'stadtplan_72dpi', 'stadtplan_uebersicht', 0, 300000, 1000000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14921, 842, 27, '25', 'gdpper', 'Gross Domestic Product (GDP) per capita', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/', 'Classified layer of countries affected by the tsunami.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18226, 882, 8, '0', 'Stadtbezirke', 'Stadtbezirke', 0, 0, 0, '', '', 'Stadtbezirke');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14922, 842, 28, '25', 'extdebt', 'External Debt', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/', 'Classified layer of countries affected by the tsunami.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18227, 882, 9, '8', 'stadtbezirke_pl', 'stadtbezirke_pl', 0, 0, 300000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14923, 842, 29, '25', 'density', 'Population Density (per sq. km)', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/', 'Classified layer of countries affected by the tsunami.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14924, 842, 30, '25', 'population', '2004 Population', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/', 'Classified layer of countries affected by the tsunami.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14925, 842, 31, '25', 'deaths', 'Total Deaths Per Country', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/geos/in.html. Death Toll: http://www.cnn.com/2004/WORLD/asiapcf/12/28/tsunami.deaths/index.html', 'Classified layer of countries affected by the tsunami.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14926, 842, 32, '25', 'SriLanka_deaths', 'Sri Lanka Total Deaths by Region', 1, 0, 0, '', 'http://www.cnosrilanka.org/', 'Total reported deaths as a result of the tsunami in each region.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14927, 842, 33, '25', 'SriLanka_injured', 'Sri Lanka Total injuries by Region', 1, 0, 0, '', 'http://www.cnosrilanka.org/', 'Number of population that were physically injured as a result of the tsunami.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14928, 842, 34, '25', 'SriLanka_missing', 'Sri Lanka Total missing persons by Region', 1, 0, 0, '', 'http://www.cnosrilanka.org/', 'Population curently missing in each region.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14929, 842, 35, '25', 'SriLanka_displaced', 'Sri Lanka Total Displaced Population by Region', 1, 0, 0, '', 'http://www.cnosrilanka.org/', 'Population displaced from their homes by the effects of the tsunami.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14930, 842, 36, '25', 'SriLanka_camps', 'Sri Lanka Total camps by Region', 1, 0, 0, '', 'http://www.cnosrilanka.org/', 'Number of temporary relief camps to shelter those displaced by the tsunami');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14931, 842, 37, '0', 'Infrastructure', 'Infrastructure', 0, 0, 0, '', '', 'Infrastructure');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14932, 842, 38, '37', 'BUILTUPA_POP_1M:Foundation', 'Built-Up Areas', 1, 0, 0, '', 'http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14933, 842, 39, '37', 'ROADL_TRANS_1M:Foundation', 'Roads', 1, 0, 0, '', 'http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18228, 882, 10, '8', 'stadtbezirke_t', 'stadtbezirke_t', 0, 0, 300000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18229, 882, 11, '0', 'Wahlbezirke', 'Wahlbezirke', 0, 0, 0, '', '', 'Wahlbezirke');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18230, 882, 12, '11', 'wahlbezirke_pl', 'wahlbezirke_pl', 0, 0, 300000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18231, 882, 13, '11', 'wahlbezirke_t', 'wahlbezirke_t', 0, 0, 300000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18232, 882, 14, '0', 'Stimmbezirke', 'Stimmbezirke', 0, 0, 0, '', '', 'Stimmbezirke');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18233, 882, 15, '14', 'stimmbezirke_pl', 'stimmbezirke_pl', 0, 0, 300000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18234, 882, 16, '14', 'stimmbezirke_t', 'stimmbezirke_t', 0, 0, 300000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14999, 844, 40, '0', 'pacus_ir_satellite_4km', 'pacus_ir_satellite_4km', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14986, 844, 41, '0', 'gazetteer', 'gazetteer', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15000, 844, 42, '0', 'post_borders', 'post_borders', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14985, 844, 43, '0', 'future_lightning', 'future_lightning', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14987, 844, 44, '0', 'geom', 'geom', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14975, 844, 45, '0', 'contour_low', 'contour_low', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14989, 844, 46, '0', 'hurricanes', 'hurricanes', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15003, 844, 47, '0', 'rivers', 'rivers', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14992, 844, 48, '0', 'label', 'label', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14979, 844, 49, '0', 'conus_ir_satellite_4km', 'conus_ir_satellite_4km', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19300, 844, 50, '0', 'country_borders', 'country_borders', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19301, 844, 51, '0', 'radar_edited', 'radar_edited', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14996, 844, 52, '0', 'maple', 'maple', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15007, 844, 53, '0', 'storm_track', 'storm_track', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15009, 844, 54, '0', 'wide_conus_ir_satellite_4km', 'wide_conus_ir_satellite_4km', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14982, 844, 55, '0', 'eqc', 'eqc', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14893, 841, 61, '55', 'railway', 'Cascaded railway network', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19302, 841, 62, '0', 'aster1', 'Hillshaded ASTER 1 arc sec DEM for the Three Gorges Area, China', 0, 0, 0, '', '', 'Hillshaded ASTER 1 arc sec DEM for the Three Gorges Area, China');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19303, 841, 63, '62', 'threegorges_1', 'Hillshaded ASTER 1 mosaic (10 arscsec. level)', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19304, 841, 64, '62', 'threegorges_2', 'Hillshaded ASTER 1 mosaic (1 arscsec. level)', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19305, 841, 65, '0', 'srtm_v3', 'Hillshaded ASTER 1 arc sec DEM for the Three Gorges Area, China', 0, 0, 0, '', '', 'Hillshaded ASTER 1 arc sec DEM for the Three Gorges Area, China');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19306, 841, 66, '65', 'srtm_v3_1', 'Hillshaded SRTM Version 3 ', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19307, 841, 67, '65', 'srtm_v3_2', 'Hillshaded ASTER 1 mosaic (1 arscsec. level)', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19308, 824, 0, '', 'Images', 'Images', 0, 0, 0, '', '', 'Image Web Server');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19309, 824, 1, '0', 'AUSTRALIA_PARRAMATTA', 'parramatta', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/australia/parramatta.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19310, 824, 2, '0', 'GEODETIC_USADEMO', 'USADemo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/geodetic/USADemo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19311, 824, 3, '0', 'GEODETIC_WORLDGEODEMO', 'WorldGeoDemo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/geodetic/WorldGeoDemo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19312, 824, 4, '0', 'USA_1METERCALIF', '1metercalif', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/1metercalif.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19313, 824, 5, '0', 'USA_SANDIEGO1M_BW', 'Sandiego1m_bw', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/Sandiego1m_bw.jp2', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19314, 824, 6, '0', 'USA_SANDIEGO1M_NULL', 'Sandiego1m_null', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/Sandiego1m_null.jp2', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19315, 824, 7, '0', 'USA_SANDIEGO3I', 'sandiego3i', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/sandiego3i.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19316, 824, 8, '0', 'USA_SANDIEGOAIRPHOTO', 'sandiegoairphoto', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/sandiegoairphoto.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19317, 824, 9, '0', 'USA_SANDIEGOAIRPHOTO_01', 'sandiegoairphoto', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/sandiegoairphoto.jp2', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19318, 824, 10, '0', 'USA_SANDIEGOAIRPHOTO_LOSSLESS', 'sandiegoairphoto_lossless', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/sandiegoairphoto_lossless.jp2', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19319, 824, 11, '0', 'AUSTRALIA_PARRAMATTA_01', 'parramatta', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/australia/parramatta.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19320, 824, 12, '0', 'elevation', 'elevation', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19321, 824, 13, '12', 'HILLSHADE_HS', 'hs', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/elevation/hillshade/hs.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19322, 824, 14, '12', 'HILLSHADE_HS2', 'hs2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/elevation/hillshade/hs2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19323, 824, 15, '12', 'HILLSHADE_HS3', 'hs3', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/elevation/hillshade/hs3.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19324, 824, 16, '12', 'GEODETIC_HS', 'hs', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/elevation/hillshade/geodetic/hs.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19325, 824, 17, '12', 'HILLSHADE_HS_01', 'hs', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/hillshade/hs.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19326, 824, 18, '12', 'HILLSHADE_HS2_01', 'hs2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/hillshade/hs2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19327, 824, 19, '12', 'HILLSHADE_HS3_01', 'hs3', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/hillshade/hs3.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19328, 824, 20, '12', 'GEODETIC_HS_01', 'hs', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/hillshade/geodetic/hs.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19329, 824, 21, '0', 'geodetic', 'geodetic', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19330, 824, 22, '21', 'GEODETIC_USADEMO_01', 'USADemo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/geodetic/USADemo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19331, 824, 23, '21', 'GEODETIC_WORLDGEODEMO_01', 'WorldGeoDemo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/geodetic/WorldGeoDemo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19332, 824, 24, '0', 'optical', 'optical', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19333, 824, 25, '24', 'ECW_ORTHOLANDSAT5_201_23', 'ortholandsat5_201_23', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_201_23.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19334, 824, 26, '24', 'ECW_ORTHOLANDSAT5_201_24', 'ortholandsat5_201_24', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_201_24.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19335, 824, 27, '24', 'ECW_ORTHOLANDSAT5_202_22', 'ortholandsat5_202_22', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_202_22.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19336, 824, 28, '24', 'ECW_ORTHOLANDSAT5_202_23', 'ortholandsat5_202_23', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_202_23.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19337, 824, 29, '24', 'ECW_ORTHOLANDSAT5_202_24', 'ortholandsat5_202_24', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_202_24.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19338, 824, 30, '24', 'ECW_ORTHOLANDSAT5_202_25', 'ortholandsat5_202_25', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_202_25.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19339, 824, 31, '24', 'ECW_ORTHOLANDSAT5_203_22', 'ortholandsat5_203_22', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_203_22.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19340, 824, 32, '24', 'ECW_ORTHOLANDSAT5_203_23', 'ortholandsat5_203_23', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_203_23.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19341, 824, 33, '24', 'ECW_ORTHOLANDSAT5_203_24', 'ortholandsat5_203_24', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_203_24.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19342, 824, 34, '24', 'ECW_ORTHOLANDSAT5_203_25', 'ortholandsat5_203_25', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_203_25.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19343, 824, 35, '24', 'ECW_ORTHOLANDSAT5_204_20Q1', 'ortholandsat5_204_20q1', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_20q1.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19344, 824, 36, '24', 'ECW_ORTHOLANDSAT5_204_20Q3', 'ortholandsat5_204_20q3', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_20q3.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19345, 824, 37, '24', 'ECW_ORTHOLANDSAT5_204_21', 'ortholandsat5_204_21', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_21.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19346, 824, 38, '24', 'ECW_ORTHOLANDSAT5_204_22', 'ortholandsat5_204_22', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_22.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19347, 824, 39, '24', 'ECW_ORTHOLANDSAT5_204_23', 'ortholandsat5_204_23', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_23.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19348, 824, 40, '24', 'ECW_ORTHOLANDSAT5_204_24', 'ortholandsat5_204_24', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_24.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19349, 824, 41, '24', 'ECW_ORTHOLANDSAT5_204_25', 'ortholandsat5_204_25', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_25.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19350, 824, 42, '24', 'ECW_ORTHOLANDSAT5_205_18Q1', 'ortholandsat5_205_18q1', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_205_18q1.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19351, 824, 43, '24', 'ECW_ORTHOLANDSAT5_205_18Q2', 'ortholandsat5_205_18q2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_205_18q2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19352, 824, 44, '24', 'ECW_ORTHOLANDSAT5_205_20', 'ortholandsat5_205_20', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_205_20.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19353, 824, 45, '24', 'ECW_ORTHOLANDSAT5_205_21', 'ortholandsat5_205_21', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_205_21.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19354, 824, 46, '24', 'ECW_ORTHOLANDSAT5_205_22', 'ortholandsat5_205_22', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_205_22.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19355, 824, 47, '24', 'ECW_ORTHOLANDSAT5_206_18', 'ortholandsat5_206_18', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_206_18.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19356, 824, 48, '24', 'ECW_ORTHOLANDSAT5_206_19', 'ortholandsat5_206_19', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_206_19.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19357, 824, 49, '24', 'ECW_ORTHOLANDSAT5_206_20', 'ortholandsat5_206_20', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_206_20.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19358, 824, 50, '24', 'ECW_ORTHOLANDSAT5_206_21', 'ortholandsat5_206_21', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_206_21.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19359, 824, 51, '24', 'ECW_ORTHOLANDSAT5_206_22', 'ortholandsat5_206_22', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_206_22.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19360, 824, 52, '24', 'ECW_ORTHOLANDSAT5_207_20', 'ortholandsat5_207_20', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_207_20.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19361, 824, 53, '24', 'ECW_ORTHOLANDSAT5_207_21', 'ortholandsat5_207_21', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_207_21.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19362, 824, 54, '24', 'ECW_ORTHOLANDSAT5_207_22', 'ortholandsat5_207_22', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_207_22.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19363, 824, 55, '24', 'ECW_ORTHOLANDSAT5_208_19', 'ortholandsat5_208_19', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_208_19.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19364, 824, 56, '24', 'ECW_ORTHOLANDSAT5_208_20', 'ortholandsat5_208_20', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_208_20.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19365, 824, 57, '24', 'ECW_2_ORTHOLANDSAT5_201_23_2', 'ortholandsat5_201_23_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_201_23_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19366, 824, 58, '24', 'ECW_2_ORTHOLANDSAT5_201_24_2', 'ortholandsat5_201_24_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_201_24_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19367, 824, 59, '24', 'ECW_2_ORTHOLANDSAT5_202_22_2', 'ortholandsat5_202_22_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_202_22_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19368, 824, 60, '24', 'ECW_2_ORTHOLANDSAT5_202_23_2', 'ortholandsat5_202_23_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_202_23_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19369, 824, 61, '24', 'ECW_2_ORTHOLANDSAT5_202_24_2', 'ortholandsat5_202_24_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_202_24_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19370, 824, 62, '24', 'ECW_2_ORTHOLANDSAT5_202_25_2', 'ortholandsat5_202_25_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_202_25_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19371, 824, 63, '24', 'ECW_2_ORTHOLANDSAT5_203_22_2', 'ortholandsat5_203_22_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_203_22_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19372, 824, 64, '24', 'ECW_2_ORTHOLANDSAT5_203_23_2', 'ortholandsat5_203_23_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_203_23_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19373, 824, 65, '24', 'ECW_2_ORTHOLANDSAT5_203_24_2', 'ortholandsat5_203_24_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_203_24_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19374, 824, 66, '24', 'ECW_2_ORTHOLANDSAT5_203_25_2', 'ortholandsat5_203_25_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_203_25_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19375, 824, 67, '24', 'ECW_2_ORTHOLANDSAT5_204_20Q1_2', 'ortholandsat5_204_20q1_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_204_20q1_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19376, 824, 68, '24', 'ECW_2_ORTHOLANDSAT5_204_20Q3_2', 'ortholandsat5_204_20q3_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_204_20q3_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19377, 824, 69, '24', 'ECW_2_ORTHOLANDSAT5_204_21_2', 'ortholandsat5_204_21_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_204_21_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19378, 824, 70, '24', 'ECW_2_ORTHOLANDSAT5_204_22_2', 'ortholandsat5_204_22_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_204_22_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19379, 824, 71, '24', 'ECW_2_ORTHOLANDSAT5_204_23_2', 'ortholandsat5_204_23_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_204_23_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19380, 824, 72, '24', 'ECW_2_ORTHOLANDSAT5_204_24_2', 'ortholandsat5_204_24_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_204_24_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19381, 824, 73, '24', 'ECW_2_ORTHOLANDSAT5_204_25_2', 'ortholandsat5_204_25_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_204_25_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19382, 824, 74, '24', 'ECW_2_ORTHOLANDSAT5_205_18Q1_2', 'ortholandsat5_205_18q1_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_205_18q1_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19383, 824, 75, '24', 'ECW_2_ORTHOLANDSAT5_205_18Q2_2', 'ortholandsat5_205_18q2_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_205_18q2_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19384, 824, 76, '24', 'ECW_2_ORTHOLANDSAT5_205_20_2', 'ortholandsat5_205_20_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_205_20_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19385, 824, 77, '24', 'ECW_2_ORTHOLANDSAT5_205_21_2', 'ortholandsat5_205_21_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_205_21_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19386, 824, 78, '24', 'ECW_2_ORTHOLANDSAT5_205_22_2', 'ortholandsat5_205_22_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_205_22_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19387, 824, 79, '24', 'ECW_2_ORTHOLANDSAT5_206_18_2', 'ortholandsat5_206_18_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_206_18_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19388, 824, 80, '24', 'ECW_2_ORTHOLANDSAT5_206_19_2', 'ortholandsat5_206_19_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_206_19_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19389, 824, 81, '24', 'ECW_2_ORTHOLANDSAT5_206_20_2', 'ortholandsat5_206_20_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_206_20_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19390, 824, 82, '24', 'ECW_2_ORTHOLANDSAT5_206_21_2', 'ortholandsat5_206_21_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_206_21_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19391, 824, 83, '24', 'ECW_2_ORTHOLANDSAT5_206_22_2', 'ortholandsat5_206_22_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_206_22_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19392, 824, 84, '24', 'ECW_2_ORTHOLANDSAT5_207_20_2', 'ortholandsat5_207_20_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_207_20_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19393, 824, 85, '24', 'ECW_2_ORTHOLANDSAT5_207_21_2', 'ortholandsat5_207_21_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_207_21_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19394, 824, 86, '24', 'ECW_2_ORTHOLANDSAT5_207_22_2', 'ortholandsat5_207_22_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_207_22_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19395, 824, 87, '24', 'ECW_2_ORTHOLANDSAT5_208_19_2', 'ortholandsat5_208_19_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_208_19_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19396, 824, 88, '24', 'ECW_2_ORTHOLANDSAT5_208_20_2', 'ortholandsat5_208_20_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_2/ortholandsat5_208_20_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19397, 824, 89, '24', 'ECW_4_ORTHOLANDSAT5_201_23_4', 'ortholandsat5_201_23_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_201_23_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19398, 824, 90, '24', 'ECW_4_ORTHOLANDSAT5_201_24_4', 'ortholandsat5_201_24_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_201_24_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19399, 824, 91, '24', 'ECW_4_ORTHOLANDSAT5_202_22_4', 'ortholandsat5_202_22_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_202_22_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19400, 824, 92, '24', 'ECW_4_ORTHOLANDSAT5_202_23_4', 'ortholandsat5_202_23_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_202_23_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19401, 824, 93, '24', 'ECW_4_ORTHOLANDSAT5_202_24_4', 'ortholandsat5_202_24_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_202_24_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19402, 824, 94, '24', 'ECW_4_ORTHOLANDSAT5_202_25_4', 'ortholandsat5_202_25_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_202_25_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19403, 824, 95, '24', 'ECW_4_ORTHOLANDSAT5_203_22_4', 'ortholandsat5_203_22_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_203_22_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19404, 824, 96, '24', 'ECW_4_ORTHOLANDSAT5_203_23_4', 'ortholandsat5_203_23_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_203_23_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19405, 824, 97, '24', 'ECW_4_ORTHOLANDSAT5_203_24_4', 'ortholandsat5_203_24_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_203_24_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19406, 824, 98, '24', 'ECW_4_ORTHOLANDSAT5_203_25_4', 'ortholandsat5_203_25_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_203_25_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19407, 824, 99, '24', 'ECW_4_ORTHOLANDSAT5_204_20Q1_4', 'ortholandsat5_204_20q1_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_204_20q1_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19408, 824, 100, '24', 'ECW_4_ORTHOLANDSAT5_204_20Q3_4', 'ortholandsat5_204_20q3_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_204_20q3_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19409, 824, 101, '24', 'ECW_4_ORTHOLANDSAT5_204_21_4', 'ortholandsat5_204_21_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_204_21_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19410, 824, 102, '24', 'ECW_4_ORTHOLANDSAT5_204_22_4', 'ortholandsat5_204_22_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_204_22_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19411, 824, 103, '24', 'ECW_4_ORTHOLANDSAT5_204_23_4', 'ortholandsat5_204_23_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_204_23_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19412, 824, 104, '24', 'ECW_4_ORTHOLANDSAT5_204_24_4', 'ortholandsat5_204_24_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_204_24_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19413, 824, 105, '24', 'ECW_4_ORTHOLANDSAT5_204_25_4', 'ortholandsat5_204_25_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_204_25_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19414, 824, 106, '24', 'ECW_4_ORTHOLANDSAT5_205_18Q1_4', 'ortholandsat5_205_18q1_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_205_18q1_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19415, 824, 107, '24', 'ECW_4_ORTHOLANDSAT5_205_18Q2_4', 'ortholandsat5_205_18q2_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_205_18q2_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19416, 824, 108, '24', 'ECW_4_ORTHOLANDSAT5_205_20_4', 'ortholandsat5_205_20_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_205_20_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19417, 824, 109, '24', 'ECW_4_ORTHOLANDSAT5_205_21_4', 'ortholandsat5_205_21_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_205_21_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19418, 824, 110, '24', 'ECW_4_ORTHOLANDSAT5_205_22_4', 'ortholandsat5_205_22_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_205_22_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19419, 824, 111, '24', 'ECW_4_ORTHOLANDSAT5_206_18_4', 'ortholandsat5_206_18_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_206_18_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19420, 824, 112, '24', 'ECW_4_ORTHOLANDSAT5_206_19_4', 'ortholandsat5_206_19_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_206_19_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19421, 824, 113, '24', 'ECW_4_ORTHOLANDSAT5_206_20_4', 'ortholandsat5_206_20_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_206_20_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19422, 824, 114, '24', 'ECW_4_ORTHOLANDSAT5_206_21_4', 'ortholandsat5_206_21_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_206_21_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19423, 824, 115, '24', 'ECW_4_ORTHOLANDSAT5_206_22_4', 'ortholandsat5_206_22_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_206_22_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19424, 824, 116, '24', 'ECW_4_ORTHOLANDSAT5_207_20_4', 'ortholandsat5_207_20_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_207_20_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19425, 824, 117, '24', 'ECW_4_ORTHOLANDSAT5_207_21_4', 'ortholandsat5_207_21_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_207_21_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19426, 824, 118, '24', 'ECW_4_ORTHOLANDSAT5_207_22_4', 'ortholandsat5_207_22_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_207_22_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19427, 824, 119, '24', 'ECW_4_ORTHOLANDSAT5_208_19_4', 'ortholandsat5_208_19_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_208_19_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19428, 824, 120, '24', 'ECW_4_ORTHOLANDSAT5_208_20_4', 'ortholandsat5_208_20_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw_4/ortholandsat5_208_20_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19429, 824, 121, '24', 'MOSAICS_L5MOSAIC', 'l5mosaic', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/mosaics/l5mosaic.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19430, 824, 122, '24', 'MOSAICS_L5MOSAICB742', 'l5mosaicb742', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/mosaics/l5mosaicb742.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19431, 824, 123, '24', 'MOSAICS_L5MOSAIC_B247', 'l5mosaic_b247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/mosaics/l5mosaic_b247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19432, 824, 124, '24', 'MOSAICS_L5MOSAIC_UTM', 'l5mosaic_UTM', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/mosaics/l5mosaic_UTM.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19433, 824, 125, '24', 'GEODETIC_L5MOSAIC_GEODETIC1', 'l5mosaic_geodetic1', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/mosaics/geodetic/l5mosaic_geodetic1.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19434, 824, 126, '24', 'ECW_ORTHOL7_20123XS190600', 'orthol7_20123xs190600', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20123xs190600.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19435, 824, 127, '24', 'ECW_ORTHOL7_20124XS190600', 'orthol7_20124xs190600', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20124xs190600.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19436, 824, 128, '24', 'ECW_ORTHOL7_20125XS190600', 'orthol7_20125xs190600', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20125xs190600.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19437, 824, 129, '24', 'ECW_ORTHOL7_20222XS120501', 'orthol7_20222xs120501', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20222xs120501.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19438, 824, 130, '24', 'ECW_ORTHOL7_20223XS120501', 'orthol7_20223xs120501', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20223xs120501.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19439, 824, 131, '24', 'ECW_ORTHOL7_20224XS120501', 'orthol7_20224xs120501', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20224xs120501.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19440, 824, 132, '24', 'ECW_ORTHOL7_20225XS120501', 'orthol7_20225xs120501', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20225xs120501.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19441, 824, 133, '24', 'ECW_ORTHOL7_20323XS170600', 'orthol7_20323xs170600', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20323xs170600.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19442, 824, 134, '24', 'ECW_ORTHOL7_20324XS170600', 'orthol7_20324xs170600', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20324xs170600.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19443, 824, 135, '24', 'ECW_ORTHOL7_20325XS300400', 'orthol7_20325xs300400', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20325xs300400.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19444, 824, 136, '24', 'ECW_ORTHOL7_20421XS070500', 'orthol7_20421xs070500', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20421xs070500.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19445, 824, 137, '24', 'ECW_ORTHOL7_20422XS070500', 'orthol7_20422xs070500', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20422xs070500.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19446, 824, 138, '24', 'ECW_ORTHOL7_20423XS100999', 'orthol7_20423xs100999', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20423xs100999.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19447, 824, 139, '24', 'ECW_ORTHOL7_20424XS240799', 'orthol7_20424xs240799', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20424xs240799.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19448, 824, 140, '24', 'ECW_ORTHOL7_20425XS240799', 'orthol7_20425xs240799', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20425xs240799.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19449, 824, 141, '24', 'ECW_ORTHOL7_20520XS170700', 'orthol7_20520xs170700', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20520xs170700.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19450, 824, 142, '24', 'ECW_ORTHOL7_20521XS170700', 'orthol7_20521xs170700', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20521xs170700.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19451, 824, 143, '24', 'ECW_ORTHOL7_20522XS170700', 'orthol7_20522xs170700', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20522xs170700.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19452, 824, 144, '24', 'ECW_ORTHOL7_20619XS180300', 'orthol7_20619xs180300', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20619xs180300.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19453, 824, 145, '24', 'ECW_ORTHOL7_20620XS050500', 'orthol7_20620xs050500', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20620xs050500.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19454, 824, 146, '24', 'ECW_ORTHOL7_20621XS250800', 'orthol7_20621xs250800', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20621xs250800.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19455, 824, 147, '24', 'ECW_ORTHOL7_20622XS240501', 'orthol7_20622xs240501', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20622xs240501.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19456, 824, 148, '24', 'ECW_ORTHOL7_20719XS290799', 'orthol7_20719xs290799', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20719xs290799.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19457, 824, 149, '24', 'ECW_ORTHOL7_20720XS120500', 'orthol7_20720xs120500', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw/orthol7_20720xs120500.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19458, 824, 150, '24', 'ECW_2_ORTHOL7_20123XS190600_2', 'orthol7_20123xs190600_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20123xs190600_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19459, 824, 151, '24', 'ECW_2_ORTHOL7_20124XS190600_2', 'orthol7_20124xs190600_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20124xs190600_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19460, 824, 152, '24', 'ECW_2_ORTHOL7_20125XS190600_2', 'orthol7_20125xs190600_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20125xs190600_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19461, 824, 153, '24', 'ECW_2_ORTHOL7_20222XS120501_2', 'orthol7_20222xs120501_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20222xs120501_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19462, 824, 154, '24', 'ECW_2_ORTHOL7_20223XS120501_2', 'orthol7_20223xs120501_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20223xs120501_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19463, 824, 155, '24', 'ECW_2_ORTHOL7_20224XS120501_2', 'orthol7_20224xs120501_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20224xs120501_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19464, 824, 156, '24', 'ECW_2_ORTHOL7_20225XS120501_2', 'orthol7_20225xs120501_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20225xs120501_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19465, 824, 157, '24', 'ECW_2_ORTHOL7_20323XS170600_2', 'orthol7_20323xs170600_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20323xs170600_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19466, 824, 158, '24', 'ECW_2_ORTHOL7_20324XS170600_2', 'orthol7_20324xs170600_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20324xs170600_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19467, 824, 159, '24', 'ECW_2_ORTHOL7_20325XS300400_2', 'orthol7_20325xs300400_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20325xs300400_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19468, 824, 160, '24', 'ECW_2_ORTHOL7_20421XS070500_2', 'orthol7_20421xs070500_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20421xs070500_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19469, 824, 161, '24', 'ECW_2_ORTHOL7_20422XS070500_2', 'orthol7_20422xs070500_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20422xs070500_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19470, 824, 162, '24', 'ECW_2_ORTHOL7_20423XS100999_2', 'orthol7_20423xs100999_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20423xs100999_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19471, 824, 163, '24', 'ECW_2_ORTHOL7_20424XS240799_2', 'orthol7_20424xs240799_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20424xs240799_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19472, 824, 164, '24', 'ECW_2_ORTHOL7_20425XS240799_2', 'orthol7_20425xs240799_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20425xs240799_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19473, 824, 165, '24', 'ECW_2_ORTHOL7_20520XS170700_2', 'orthol7_20520xs170700_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20520xs170700_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19474, 824, 166, '24', 'ECW_2_ORTHOL7_20521XS170700_2', 'orthol7_20521xs170700_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20521xs170700_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19475, 824, 167, '24', 'ECW_2_ORTHOL7_20522XS170700_2', 'orthol7_20522xs170700_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20522xs170700_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19476, 824, 168, '24', 'ECW_2_ORTHOL7_20619XS180300_2', 'orthol7_20619xs180300_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20619xs180300_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19477, 824, 169, '24', 'ECW_2_ORTHOL7_20620XS050500_2', 'orthol7_20620xs050500_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20620xs050500_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19478, 824, 170, '24', 'ECW_2_ORTHOL7_20621XS250800_2', 'orthol7_20621xs250800_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20621xs250800_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19479, 824, 171, '24', 'ECW_2_ORTHOL7_20622XS240501_2', 'orthol7_20622xs240501_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20622xs240501_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19480, 824, 172, '24', 'ECW_2_ORTHOL7_20719XS290799_2', 'orthol7_20719xs290799_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20719xs290799_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19481, 824, 173, '24', 'ECW_2_ORTHOL7_20720XS120500_2', 'orthol7_20720xs120500_2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_2/orthol7_20720xs120500_2.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19482, 824, 174, '24', 'ECW_4_ORTHOL7_20123XS190600_4', 'orthol7_20123xs190600_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20123xs190600_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19483, 824, 175, '24', 'ECW_4_ORTHOL7_20124XS190600_4', 'orthol7_20124xs190600_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20124xs190600_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19484, 824, 176, '24', 'ECW_4_ORTHOL7_20125XS190600_4', 'orthol7_20125xs190600_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20125xs190600_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19485, 824, 177, '24', 'ECW_4_ORTHOL7_20222XS120501_4', 'orthol7_20222xs120501_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20222xs120501_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19486, 824, 178, '24', 'ECW_4_ORTHOL7_20223XS120501_4', 'orthol7_20223xs120501_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20223xs120501_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19487, 824, 179, '24', 'ECW_4_ORTHOL7_20224XS120501_4', 'orthol7_20224xs120501_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20224xs120501_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19488, 824, 180, '24', 'ECW_4_ORTHOL7_20225XS120501_4', 'orthol7_20225xs120501_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20225xs120501_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19489, 824, 181, '24', 'ECW_4_ORTHOL7_20323XS170600_4', 'orthol7_20323xs170600_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20323xs170600_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19490, 824, 182, '24', 'ECW_4_ORTHOL7_20324XS170600_4', 'orthol7_20324xs170600_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20324xs170600_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19491, 824, 183, '24', 'ECW_4_ORTHOL7_20325XS300400_4', 'orthol7_20325xs300400_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20325xs300400_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19492, 824, 184, '24', 'ECW_4_ORTHOL7_20421XS070500_4', 'orthol7_20421xs070500_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20421xs070500_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19493, 824, 185, '24', 'ECW_4_ORTHOL7_20422XS070500_4', 'orthol7_20422xs070500_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20422xs070500_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19494, 824, 186, '24', 'ECW_4_ORTHOL7_20423XS100999_4', 'orthol7_20423xs100999_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20423xs100999_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19495, 824, 187, '24', 'ECW_4_ORTHOL7_20424XS240799_4', 'orthol7_20424xs240799_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20424xs240799_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19496, 824, 188, '24', 'ECW_4_ORTHOL7_20425XS240799_4', 'orthol7_20425xs240799_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20425xs240799_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19497, 824, 189, '24', 'ECW_4_ORTHOL7_20520XS170700_4', 'orthol7_20520xs170700_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20520xs170700_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19498, 824, 190, '24', 'ECW_4_ORTHOL7_20521XS170700_4', 'orthol7_20521xs170700_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20521xs170700_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19499, 824, 191, '24', 'ECW_4_ORTHOL7_20522XS170700_4', 'orthol7_20522xs170700_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20522xs170700_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19500, 824, 192, '24', 'ECW_4_ORTHOL7_20619XS180300_4', 'orthol7_20619xs180300_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20619xs180300_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19501, 824, 193, '24', 'ECW_4_ORTHOL7_20620XS050500_4', 'orthol7_20620xs050500_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20620xs050500_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19502, 824, 194, '24', 'ECW_4_ORTHOL7_20621XS250800_4', 'orthol7_20621xs250800_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20621xs250800_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19503, 824, 195, '24', 'ECW_4_ORTHOL7_20622XS240501_4', 'orthol7_20622xs240501_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20622xs240501_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19504, 824, 196, '24', 'ECW_4_ORTHOL7_20719XS290799_4', 'orthol7_20719xs290799_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20719xs290799_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19505, 824, 197, '24', 'ECW_4_ORTHOL7_20720XS120500_4', 'orthol7_20720xs120500_4', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/ecw_4/orthol7_20720xs120500_4.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19506, 824, 198, '24', 'MOSAICS_L7B123', 'l7b123', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/l7b123.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19507, 824, 199, '24', 'MOSAICS_L7BOV', 'l7bov', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/l7bov.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19508, 824, 200, '24', 'MOSAICS_L7BOVSTR', 'l7bovstr', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/l7bovstr.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19509, 824, 201, '24', 'MOSAICS_L7BPAN', 'l7bpan', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/l7bpan.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19510, 824, 202, '24', 'MOSAICS_L7BPAN_S', 'l7bpan_s', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/l7bpan_s.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19511, 824, 203, '24', 'MOSAICS_L7BPAN_S_GEO.BECW', 'l7bpan_s_geo.becw', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/l7bpan_s_geo.becw.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19512, 824, 204, '24', 'MOSAICS_L7BPAN_S_GEO', 'l7bpan_s_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/l7bpan_s_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19513, 824, 205, '24', 'MOSAICS_LANDSAT7M25', 'landsat7m25', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/landsat7m25.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19514, 824, 206, '24', 'MOSAICS_LANDSAT7M25R', 'landsat7m25r', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/landsat7m25r.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19515, 824, 207, '24', 'MOSAICS_LANDSAT7M25_123', 'landsat7m25_123', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/landsat7m25_123.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19516, 824, 208, '24', 'MOSAICS_LANDSAT_MOSAIC_15M', 'landsat_mosaic_15m', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/landsat_mosaic_15m.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19517, 824, 209, '24', 'MOSAICS_NEWL7PANMOSAIC', 'newl7panmosaic', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/newl7panmosaic.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19518, 824, 210, '24', 'NEW_LANDSAT7FUSED', 'landsat7fused', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/new/landsat7fused.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19519, 824, 211, '24', 'NEW_LANDSAT7FUSED_753', 'landsat7fused_753', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/new/landsat7fused_753.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19520, 824, 212, '24', 'NEW_LANDSAT7FUSED_S1', 'landsat7fused_s1', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/new/landsat7fused_s1.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19521, 824, 213, '24', 'NEW_LANDSAT7FUSED_URBAN', 'landsat7fused_urban', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat7/mosaics/new/landsat7fused_urban.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19522, 824, 214, '24', 'ECW_ORTHOSPOT10_240IE', 'orthospot10_240ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot10_240ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19523, 824, 215, '24', 'ECW_ORTHOSPOT10_243IE', 'orthospot10_243ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot10_243ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19524, 824, 216, '24', 'ECW_ORTHOSPOT13_231', 'orthospot13_231', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_231.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19525, 824, 217, '24', 'ECW_ORTHOSPOT13_231A', 'orthospot13_231a', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_231a.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19526, 824, 218, '24', 'ECW_ORTHOSPOT13_232', 'orthospot13_232', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_232.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19527, 824, 219, '24', 'ECW_ORTHOSPOT13_232A', 'orthospot13_232a', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_232a.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19528, 824, 220, '24', 'ECW_ORTHOSPOT13_233', 'orthospot13_233', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_233.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19529, 824, 221, '24', 'ECW_ORTHOSPOT13_234', 'orthospot13_234', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_234.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19530, 824, 222, '24', 'ECW_ORTHOSPOT13_235', 'orthospot13_235', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_235.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19531, 824, 223, '24', 'ECW_ORTHOSPOT13_238IE', 'orthospot13_238ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_238ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19532, 824, 224, '24', 'ECW_ORTHOSPOT13_239IE', 'orthospot13_239ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_239ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19533, 824, 225, '24', 'ECW_ORTHOSPOT13_240IE', 'orthospot13_240ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_240ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19534, 824, 226, '24', 'ECW_ORTHOSPOT13_241IE', 'orthospot13_241ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_241ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19535, 824, 227, '24', 'ECW_ORTHOSPOT13_242IE', 'orthospot13_242ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_242ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19536, 824, 228, '24', 'ECW_ORTHOSPOT13_243IE', 'orthospot13_243ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_243ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19537, 824, 229, '24', 'ECW_ORTHOSPOT13_244IE', 'orthospot13_244ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_244ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19538, 824, 230, '24', 'ECW_ORTHOSPOT13_245IE', 'orthospot13_245ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot13_245ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19539, 824, 231, '24', 'ECW_ORTHOSPOT14_230', 'orthospot14_230', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_230.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19540, 824, 232, '24', 'ECW_ORTHOSPOT14_231', 'orthospot14_231', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_231.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19541, 824, 233, '24', 'ECW_ORTHOSPOT14_232', 'orthospot14_232', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_232.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19542, 824, 234, '24', 'ECW_ORTHOSPOT14_233', 'orthospot14_233', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_233.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19543, 824, 235, '24', 'ECW_ORTHOSPOT14_234', 'orthospot14_234', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_234.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19544, 824, 236, '24', 'ECW_ORTHOSPOT14_235', 'orthospot14_235', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_235.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19545, 824, 237, '24', 'ECW_ORTHOSPOT14_236', 'orthospot14_236', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_236.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19546, 824, 238, '24', 'ECW_ORTHOSPOT14_238IE', 'orthospot14_238ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_238ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19547, 824, 239, '24', 'ECW_ORTHOSPOT14_239IE', 'orthospot14_239ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_239ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19548, 824, 240, '24', 'ECW_ORTHOSPOT14_240IE', 'orthospot14_240ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_240ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19549, 824, 241, '24', 'ECW_ORTHOSPOT14_241IE', 'orthospot14_241ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_241ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19550, 824, 242, '24', 'ECW_ORTHOSPOT14_242IE', 'orthospot14_242ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_242ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19551, 824, 243, '24', 'ECW_ORTHOSPOT14_243IE', 'orthospot14_243ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_243ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19552, 824, 244, '24', 'ECW_ORTHOSPOT14_244IE', 'orthospot14_244ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_244ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19553, 824, 245, '24', 'ECW_ORTHOSPOT14_245IE', 'orthospot14_245ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot14_245ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19554, 824, 246, '24', 'ECW_ORTHOSPOT17_230', 'orthospot17_230', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_230.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19555, 824, 247, '24', 'ECW_ORTHOSPOT17_231', 'orthospot17_231', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_231.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19556, 824, 248, '24', 'ECW_ORTHOSPOT17_232', 'orthospot17_232', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_232.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19557, 824, 249, '24', 'ECW_ORTHOSPOT17_233', 'orthospot17_233', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_233.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19558, 824, 250, '24', 'ECW_ORTHOSPOT17_234', 'orthospot17_234', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_234.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19559, 824, 251, '24', 'ECW_ORTHOSPOT17_235', 'orthospot17_235', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_235.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19560, 824, 252, '24', 'ECW_ORTHOSPOT17_236', 'orthospot17_236', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_236.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19561, 824, 253, '24', 'ECW_ORTHOSPOT17_237', 'orthospot17_237', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_237.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19562, 824, 254, '24', 'ECW_ORTHOSPOT17_238', 'orthospot17_238', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_238.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19563, 824, 255, '24', 'ECW_ORTHOSPOT17_239', 'orthospot17_239', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_239.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19564, 824, 256, '24', 'ECW_ORTHOSPOT17_239IE', 'orthospot17_239ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_239ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19565, 824, 257, '24', 'ECW_ORTHOSPOT17_240', 'orthospot17_240', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_240.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19566, 824, 258, '24', 'ECW_ORTHOSPOT17_240IE', 'orthospot17_240ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_240ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19567, 824, 259, '24', 'ECW_ORTHOSPOT17_241IE', 'orthospot17_241ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_241ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19568, 824, 260, '24', 'ECW_ORTHOSPOT17_242IE', 'orthospot17_242ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_242ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19569, 824, 261, '24', 'ECW_ORTHOSPOT17_243IE', 'orthospot17_243ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_243ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19570, 824, 262, '24', 'ECW_ORTHOSPOT17_244IE', 'orthospot17_244ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_244ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19571, 824, 263, '24', 'ECW_ORTHOSPOT17_245', 'orthospot17_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19572, 824, 264, '24', 'ECW_ORTHOSPOT17_245IE', 'orthospot17_245ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot17_245ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19573, 824, 265, '24', 'ECW_ORTHOSPOT18_229', 'orthospot18_229', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_229.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19574, 824, 266, '24', 'ECW_ORTHOSPOT18_231', 'orthospot18_231', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_231.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19575, 824, 267, '24', 'ECW_ORTHOSPOT18_232', 'orthospot18_232', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_232.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19576, 824, 268, '24', 'ECW_ORTHOSPOT18_233', 'orthospot18_233', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_233.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19577, 824, 269, '24', 'ECW_ORTHOSPOT18_234', 'orthospot18_234', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_234.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19578, 824, 270, '24', 'ECW_ORTHOSPOT18_235', 'orthospot18_235', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_235.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19579, 824, 271, '24', 'ECW_ORTHOSPOT18_236', 'orthospot18_236', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_236.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19580, 824, 272, '24', 'ECW_ORTHOSPOT18_237', 'orthospot18_237', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_237.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19581, 824, 273, '24', 'ECW_ORTHOSPOT18_238', 'orthospot18_238', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_238.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19582, 824, 274, '24', 'ECW_ORTHOSPOT18_239IE', 'orthospot18_239ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_239ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19583, 824, 275, '24', 'ECW_ORTHOSPOT18_240IE', 'orthospot18_240ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_240ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19584, 824, 276, '24', 'ECW_ORTHOSPOT18_241IE', 'orthospot18_241ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_241ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19585, 824, 277, '24', 'ECW_ORTHOSPOT18_242IE', 'orthospot18_242ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_242ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19586, 824, 278, '24', 'ECW_ORTHOSPOT18_243IE', 'orthospot18_243ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_243ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19587, 824, 279, '24', 'ECW_ORTHOSPOT18_244IE', 'orthospot18_244ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot18_244ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19588, 824, 280, '24', 'ECW_ORTHOSPOT21_232', 'orthospot21_232', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot21_232.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19589, 824, 281, '24', 'ECW_ORTHOSPOT21_233', 'orthospot21_233', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot21_233.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19590, 824, 282, '24', 'ECW_ORTHOSPOT21_234', 'orthospot21_234', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot21_234.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19591, 824, 283, '24', 'ECW_ORTHOSPOT21_235', 'orthospot21_235', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot21_235.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19592, 824, 284, '24', 'ECW_ORTHOSPOT21_236', 'orthospot21_236', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot21_236.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19593, 824, 285, '24', 'ECW_ORTHOSPOT21_237', 'orthospot21_237', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot21_237.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19594, 824, 286, '24', 'ECW_ORTHOSPOT21_238', 'orthospot21_238', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot21_238.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19595, 824, 287, '24', 'ECW_ORTHOSPOT21_239', 'orthospot21_239', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot21_239.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19596, 824, 288, '24', 'ECW_ORTHOSPOT21_240', 'orthospot21_240', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot21_240.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19597, 824, 289, '24', 'ECW_ORTHOSPOT21_242', 'orthospot21_242', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot21_242.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19598, 824, 290, '24', 'ECW_ORTHOSPOT22_236', 'orthospot22_236', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot22_236.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19599, 824, 291, '24', 'ECW_ORTHOSPOT22_238', 'orthospot22_238', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot22_238.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19600, 824, 292, '24', 'ECW_ORTHOSPOT22_239', 'orthospot22_239', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot22_239.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19601, 824, 293, '24', 'ECW_ORTHOSPOT22_240', 'orthospot22_240', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot22_240.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19602, 824, 294, '24', 'ECW_ORTHOSPOT22_243', 'orthospot22_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot22_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19603, 824, 295, '24', 'ECW_ORTHOSPOT22_244', 'orthospot22_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot22_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19604, 824, 296, '24', 'ECW_ORTHOSPOT22_245', 'orthospot22_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot22_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19605, 824, 297, '24', 'ECW_ORTHOSPOT22_248', 'orthospot22_248', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot22_248.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19606, 824, 298, '24', 'ECW_ORTHOSPOT24_246', 'orthospot24_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot24_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19607, 824, 299, '24', 'ECW_ORTHOSPOT25_237', 'orthospot25_237', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot25_237.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19608, 824, 300, '24', 'ECW_ORTHOSPOT25_238', 'orthospot25_238', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot25_238.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19609, 824, 301, '24', 'ECW_ORTHOSPOT25_241', 'orthospot25_241', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot25_241.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19610, 824, 302, '24', 'ECW_ORTHOSPOT25_242', 'orthospot25_242', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot25_242.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19611, 824, 303, '24', 'ECW_ORTHOSPOT25_243', 'orthospot25_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot25_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19612, 824, 304, '24', 'ECW_ORTHOSPOT25_244', 'orthospot25_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot25_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19613, 824, 305, '24', 'ECW_ORTHOSPOT25_245', 'orthospot25_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot25_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19614, 824, 306, '24', 'ECW_ORTHOSPOT25_247', 'orthospot25_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot25_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19615, 824, 307, '24', 'ECW_ORTHOSPOT25_248', 'orthospot25_248', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot25_248.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19616, 824, 308, '24', 'ECW_ORTHOSPOT26_239', 'orthospot26_239', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot26_239.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19617, 824, 309, '24', 'ECW_ORTHOSPOT26_240', 'orthospot26_240', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot26_240.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19618, 824, 310, '24', 'ECW_ORTHOSPOT26_241', 'orthospot26_241', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot26_241.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19619, 824, 311, '24', 'ECW_ORTHOSPOT26_242', 'orthospot26_242', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot26_242.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19620, 824, 312, '24', 'ECW_ORTHOSPOT26_243', 'orthospot26_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot26_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19621, 824, 313, '24', 'ECW_ORTHOSPOT26_244', 'orthospot26_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot26_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19622, 824, 314, '24', 'ECW_ORTHOSPOT26_245', 'orthospot26_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot26_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19623, 824, 315, '24', 'ECW_ORTHOSPOT26_246', 'orthospot26_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot26_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19624, 824, 316, '24', 'ECW_ORTHOSPOT26_247', 'orthospot26_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot26_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19625, 824, 317, '24', 'ECW_ORTHOSPOT26_248', 'orthospot26_248', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot26_248.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19626, 824, 318, '24', 'ECW_ORTHOSPOT28_246', 'orthospot28_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot28_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19627, 824, 319, '24', 'ECW_ORTHOSPOT28_247', 'orthospot28_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot28_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19628, 824, 320, '24', 'ECW_ORTHOSPOT29_239', 'orthospot29_239', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot29_239.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19629, 824, 321, '24', 'ECW_ORTHOSPOT29_240', 'orthospot29_240', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot29_240.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19630, 824, 322, '24', 'ECW_ORTHOSPOT29_241', 'orthospot29_241', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot29_241.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19631, 824, 323, '24', 'ECW_ORTHOSPOT29_242', 'orthospot29_242', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot29_242.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19632, 824, 324, '24', 'ECW_ORTHOSPOT29_243', 'orthospot29_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot29_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19633, 824, 325, '24', 'ECW_ORTHOSPOT29_244', 'orthospot29_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot29_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19634, 824, 326, '24', 'ECW_ORTHOSPOT29_245', 'orthospot29_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot29_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19635, 824, 327, '24', 'ECW_ORTHOSPOT30_242', 'orthospot30_242', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot30_242.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19636, 824, 328, '24', 'ECW_ORTHOSPOT30_243', 'orthospot30_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot30_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19637, 824, 329, '24', 'ECW_ORTHOSPOT30_245', 'orthospot30_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot30_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19638, 824, 330, '24', 'ECW_ORTHOSPOT30_246', 'orthospot30_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot30_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19639, 824, 331, '24', 'ECW_ORTHOSPOT30_247', 'orthospot30_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot30_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19640, 824, 332, '24', 'ECW_ORTHOSPOT32_246', 'orthospot32_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot32_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19641, 824, 333, '24', 'ECW_ORTHOSPOT32_247', 'orthospot32_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot32_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19642, 824, 334, '24', 'ECW_ORTHOSPOT33_243', 'orthospot33_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot33_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19643, 824, 335, '24', 'ECW_ORTHOSPOT33_244', 'orthospot33_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot33_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19644, 824, 336, '24', 'ECW_ORTHOSPOT33_245', 'orthospot33_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot33_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19645, 824, 337, '24', 'ECW_ORTHOSPOT34_243', 'orthospot34_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot34_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19646, 824, 338, '24', 'ECW_ORTHOSPOT34_244', 'orthospot34_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot34_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19647, 824, 339, '24', 'ECW_ORTHOSPOT34_245', 'orthospot34_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot34_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19648, 824, 340, '24', 'ECW_ORTHOSPOT34_246', 'orthospot34_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot34_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19649, 824, 341, '24', 'ECW_ORTHOSPOT34_247', 'orthospot34_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw/orthospot34_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19650, 824, 342, '24', 'ECW_STRETCHED_ORTHOSPOT13_231', 'orthospot13_231', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot13_231.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19651, 824, 343, '24', 'ECW_STRETCHED_ORTHOSPOT13_232', 'orthospot13_232', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot13_232.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19652, 824, 344, '24', 'ECW_STRETCHED_ORTHOSPOT13_233', 'orthospot13_233', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot13_233.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19653, 824, 345, '24', 'ECW_STRETCHED_ORTHOSPOT13_234', 'orthospot13_234', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot13_234.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19654, 824, 346, '24', 'ECW_STRETCHED_ORTHOSPOT13_235', 'orthospot13_235', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot13_235.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19655, 824, 347, '24', 'ECW_STRETCHED_ORTHOSPOT14_230', 'orthospot14_230', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot14_230.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19656, 824, 348, '24', 'ECW_STRETCHED_ORTHOSPOT14_231', 'orthospot14_231', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot14_231.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19657, 824, 349, '24', 'ECW_STRETCHED_ORTHOSPOT14_232', 'orthospot14_232', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot14_232.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19658, 824, 350, '24', 'ECW_STRETCHED_ORTHOSPOT14_233', 'orthospot14_233', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot14_233.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19659, 824, 351, '24', 'ECW_STRETCHED_ORTHOSPOT14_234', 'orthospot14_234', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot14_234.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19660, 824, 352, '24', 'ECW_STRETCHED_ORTHOSPOT14_235', 'orthospot14_235', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot14_235.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19661, 824, 353, '24', 'ECW_STRETCHED_ORTHOSPOT14_236', 'orthospot14_236', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot14_236.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19662, 824, 354, '24', 'ECW_STRETCHED_ORTHOSPOT17_230', 'orthospot17_230', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot17_230.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19663, 824, 355, '24', 'ECW_STRETCHED_ORTHOSPOT17_231', 'orthospot17_231', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot17_231.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19664, 824, 356, '24', 'ECW_STRETCHED_ORTHOSPOT17_232', 'orthospot17_232', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot17_232.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19665, 824, 357, '24', 'ECW_STRETCHED_ORTHOSPOT17_233', 'orthospot17_233', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot17_233.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19666, 824, 358, '24', 'ECW_STRETCHED_ORTHOSPOT17_234', 'orthospot17_234', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot17_234.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19667, 824, 359, '24', 'ECW_STRETCHED_ORTHOSPOT17_235', 'orthospot17_235', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot17_235.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19668, 824, 360, '24', 'ECW_STRETCHED_ORTHOSPOT17_236', 'orthospot17_236', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot17_236.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19669, 824, 361, '24', 'ECW_STRETCHED_ORTHOSPOT17_237', 'orthospot17_237', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot17_237.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19670, 824, 362, '24', 'ECW_STRETCHED_ORTHOSPOT17_238', 'orthospot17_238', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot17_238.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19671, 824, 363, '24', 'ECW_STRETCHED_ORTHOSPOT17_239', 'orthospot17_239', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot17_239.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19672, 824, 364, '24', 'ECW_STRETCHED_ORTHOSPOT17_240', 'orthospot17_240', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot17_240.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19673, 824, 365, '24', 'ECW_STRETCHED_ORTHOSPOT18_229', 'orthospot18_229', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot18_229.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19674, 824, 366, '24', 'ECW_STRETCHED_ORTHOSPOT18_231', 'orthospot18_231', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot18_231.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19675, 824, 367, '24', 'ECW_STRETCHED_ORTHOSPOT18_232', 'orthospot18_232', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot18_232.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19676, 824, 368, '24', 'ECW_STRETCHED_ORTHOSPOT18_233', 'orthospot18_233', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot18_233.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19677, 824, 369, '24', 'ECW_STRETCHED_ORTHOSPOT18_234', 'orthospot18_234', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot18_234.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19678, 824, 370, '24', 'ECW_STRETCHED_ORTHOSPOT18_235', 'orthospot18_235', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot18_235.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19679, 824, 371, '24', 'ECW_STRETCHED_ORTHOSPOT18_236', 'orthospot18_236', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot18_236.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19680, 824, 372, '24', 'ECW_STRETCHED_ORTHOSPOT18_237', 'orthospot18_237', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot18_237.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19681, 824, 373, '24', 'ECW_STRETCHED_ORTHOSPOT18_238', 'orthospot18_238', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot18_238.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19682, 824, 374, '24', 'ECW_STRETCHED_ORTHOSPOT21_232', 'orthospot21_232', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot21_232.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19683, 824, 375, '24', 'ECW_STRETCHED_ORTHOSPOT21_233', 'orthospot21_233', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot21_233.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19684, 824, 376, '24', 'ECW_STRETCHED_ORTHOSPOT21_234', 'orthospot21_234', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot21_234.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19685, 824, 377, '24', 'ECW_STRETCHED_ORTHOSPOT21_235', 'orthospot21_235', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot21_235.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19686, 824, 378, '24', 'ECW_STRETCHED_ORTHOSPOT21_236', 'orthospot21_236', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot21_236.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19687, 824, 379, '24', 'ECW_STRETCHED_ORTHOSPOT21_238', 'orthospot21_238', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot21_238.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19688, 824, 380, '24', 'ECW_STRETCHED_ORTHOSPOT21_239', 'orthospot21_239', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot21_239.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19689, 824, 381, '24', 'ECW_STRETCHED_ORTHOSPOT21_240', 'orthospot21_240', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot21_240.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19690, 824, 382, '24', 'ECW_STRETCHED_ORTHOSPOT21_242', 'orthospot21_242', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot21_242.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19691, 824, 383, '24', 'ECW_STRETCHED_ORTHOSPOT22_236', 'orthospot22_236', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot22_236.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19692, 824, 384, '24', 'ECW_STRETCHED_ORTHOSPOT22_238', 'orthospot22_238', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot22_238.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19693, 824, 385, '24', 'ECW_STRETCHED_ORTHOSPOT22_239', 'orthospot22_239', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot22_239.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19694, 824, 386, '24', 'ECW_STRETCHED_ORTHOSPOT22_240', 'orthospot22_240', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot22_240.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19695, 824, 387, '24', 'ECW_STRETCHED_ORTHOSPOT22_243', 'orthospot22_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot22_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19696, 824, 388, '24', 'ECW_STRETCHED_ORTHOSPOT22_244', 'orthospot22_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot22_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19697, 824, 389, '24', 'ECW_STRETCHED_ORTHOSPOT22_245', 'orthospot22_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot22_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19698, 824, 390, '24', 'ECW_STRETCHED_ORTHOSPOT22_248', 'orthospot22_248', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot22_248.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19699, 824, 391, '24', 'ECW_STRETCHED_ORTHOSPOT24_246', 'orthospot24_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot24_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19700, 824, 392, '24', 'ECW_STRETCHED_ORTHOSPOT25_237', 'orthospot25_237', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot25_237.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19701, 824, 393, '24', 'ECW_STRETCHED_ORTHOSPOT25_238', 'orthospot25_238', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot25_238.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19702, 824, 394, '24', 'ECW_STRETCHED_ORTHOSPOT25_241', 'orthospot25_241', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot25_241.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19703, 824, 395, '24', 'ECW_STRETCHED_ORTHOSPOT25_242', 'orthospot25_242', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot25_242.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19704, 824, 396, '24', 'ECW_STRETCHED_ORTHOSPOT25_243', 'orthospot25_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot25_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19705, 824, 397, '24', 'ECW_STRETCHED_ORTHOSPOT25_244', 'orthospot25_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot25_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19706, 824, 398, '24', 'ECW_STRETCHED_ORTHOSPOT25_245', 'orthospot25_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot25_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19707, 824, 399, '24', 'ECW_STRETCHED_ORTHOSPOT25_247', 'orthospot25_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot25_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19708, 824, 400, '24', 'ECW_STRETCHED_ORTHOSPOT25_248', 'orthospot25_248', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot25_248.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19709, 824, 401, '24', 'ECW_STRETCHED_ORTHOSPOT26_239', 'orthospot26_239', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot26_239.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19710, 824, 402, '24', 'ECW_STRETCHED_ORTHOSPOT26_240', 'orthospot26_240', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot26_240.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19711, 824, 403, '24', 'ECW_STRETCHED_ORTHOSPOT26_241', 'orthospot26_241', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot26_241.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19712, 824, 404, '24', 'ECW_STRETCHED_ORTHOSPOT26_242', 'orthospot26_242', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot26_242.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19713, 824, 405, '24', 'ECW_STRETCHED_ORTHOSPOT26_243', 'orthospot26_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot26_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19714, 824, 406, '24', 'ECW_STRETCHED_ORTHOSPOT26_244', 'orthospot26_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot26_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19715, 824, 407, '24', 'ECW_STRETCHED_ORTHOSPOT26_245', 'orthospot26_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot26_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19716, 824, 408, '24', 'ECW_STRETCHED_ORTHOSPOT26_246', 'orthospot26_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot26_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19717, 824, 409, '24', 'ECW_STRETCHED_ORTHOSPOT26_247', 'orthospot26_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot26_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19718, 824, 410, '24', 'ECW_STRETCHED_ORTHOSPOT26_248', 'orthospot26_248', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot26_248.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19719, 824, 411, '24', 'ECW_STRETCHED_ORTHOSPOT28_246', 'orthospot28_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot28_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19720, 824, 412, '24', 'ECW_STRETCHED_ORTHOSPOT28_247', 'orthospot28_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot28_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19721, 824, 413, '24', 'ECW_STRETCHED_ORTHOSPOT29_239', 'orthospot29_239', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot29_239.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19722, 824, 414, '24', 'ECW_STRETCHED_ORTHOSPOT29_240', 'orthospot29_240', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot29_240.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19723, 824, 415, '24', 'ECW_STRETCHED_ORTHOSPOT29_241', 'orthospot29_241', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot29_241.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19724, 824, 416, '24', 'ECW_STRETCHED_ORTHOSPOT29_242', 'orthospot29_242', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot29_242.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19725, 824, 417, '24', 'ECW_STRETCHED_ORTHOSPOT29_243', 'orthospot29_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot29_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19726, 824, 418, '24', 'ECW_STRETCHED_ORTHOSPOT29_244', 'orthospot29_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot29_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19727, 824, 419, '24', 'ECW_STRETCHED_ORTHOSPOT29_245', 'orthospot29_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot29_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19728, 824, 420, '24', 'ECW_STRETCHED_ORTHOSPOT30_242', 'orthospot30_242', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot30_242.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19729, 824, 421, '24', 'ECW_STRETCHED_ORTHOSPOT30_243', 'orthospot30_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot30_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19730, 824, 422, '24', 'ECW_STRETCHED_ORTHOSPOT30_245', 'orthospot30_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot30_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19731, 824, 423, '24', 'ECW_STRETCHED_ORTHOSPOT30_246', 'orthospot30_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot30_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19732, 824, 424, '24', 'ECW_STRETCHED_ORTHOSPOT30_247', 'orthospot30_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot30_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19733, 824, 425, '24', 'ECW_STRETCHED_ORTHOSPOT32_246', 'orthospot32_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot32_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19734, 824, 426, '24', 'ECW_STRETCHED_ORTHOSPOT32_247', 'orthospot32_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot32_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19735, 824, 427, '24', 'ECW_STRETCHED_ORTHOSPOT33_243', 'orthospot33_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot33_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19736, 824, 428, '24', 'ECW_STRETCHED_ORTHOSPOT33_244', 'orthospot33_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot33_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19737, 824, 429, '24', 'ECW_STRETCHED_ORTHOSPOT33_245', 'orthospot33_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot33_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19738, 824, 430, '24', 'ECW_STRETCHED_ORTHOSPOT34_243', 'orthospot34_243', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot34_243.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19739, 824, 431, '24', 'ECW_STRETCHED_ORTHOSPOT34_244', 'orthospot34_244', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot34_244.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19740, 824, 432, '24', 'ECW_STRETCHED_ORTHOSPOT34_245', 'orthospot34_245', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot34_245.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19741, 824, 433, '24', 'ECW_STRETCHED_ORTHOSPOT34_246', 'orthospot34_246', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot34_246.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19742, 824, 434, '24', 'ECW_STRETCHED_ORTHOSPOT34_247', 'orthospot34_247', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/orthospot34_247.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19743, 824, 435, '24', 'IE_ORTHOSPOT10_240IE', 'orthospot10_240ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot10_240ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19744, 824, 436, '24', 'IE_ORTHOSPOT10_243IE', 'orthospot10_243ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot10_243ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19745, 824, 437, '24', 'IE_ORTHOSPOT12_242IE', 'orthospot12_242ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot12_242ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19746, 824, 438, '24', 'IE_ORTHOSPOT13_238IE', 'orthospot13_238ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot13_238ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19747, 824, 439, '24', 'IE_ORTHOSPOT13_239IE', 'orthospot13_239ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot13_239ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19748, 824, 440, '24', 'IE_ORTHOSPOT13_240IE', 'orthospot13_240ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot13_240ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19749, 824, 441, '24', 'IE_ORTHOSPOT13_241IE', 'orthospot13_241ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot13_241ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19750, 824, 442, '24', 'IE_ORTHOSPOT13_243IE', 'orthospot13_243ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot13_243ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19751, 824, 443, '24', 'IE_ORTHOSPOT13_244IE', 'orthospot13_244ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot13_244ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19752, 824, 444, '24', 'IE_ORTHOSPOT13_245IE', 'orthospot13_245ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot13_245ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19753, 824, 445, '24', 'IE_ORTHOSPOT14_238IE', 'orthospot14_238ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot14_238ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19754, 824, 446, '24', 'IE_ORTHOSPOT14_239IE', 'orthospot14_239ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot14_239ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19755, 824, 447, '24', 'IE_ORTHOSPOT14_240IE', 'orthospot14_240ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot14_240ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19756, 824, 448, '24', 'IE_ORTHOSPOT14_241IE', 'orthospot14_241ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot14_241ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19757, 824, 449, '24', 'IE_ORTHOSPOT14_242IE', 'orthospot14_242ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot14_242ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19758, 824, 450, '24', 'IE_ORTHOSPOT14_243IE', 'orthospot14_243ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot14_243ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19759, 824, 451, '24', 'IE_ORTHOSPOT14_244IE', 'orthospot14_244ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot14_244ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19760, 824, 452, '24', 'IE_ORTHOSPOT14_245IE', 'orthospot14_245ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot14_245ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19761, 824, 453, '24', 'IE_ORTHOSPOT17_239IE', 'orthospot17_239ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot17_239ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19762, 824, 454, '24', 'IE_ORTHOSPOT17_240IE', 'orthospot17_240ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot17_240ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19763, 824, 455, '24', 'IE_ORTHOSPOT17_241IE', 'orthospot17_241ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot17_241ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19764, 824, 456, '24', 'IE_ORTHOSPOT17_242IE', 'orthospot17_242ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot17_242ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19765, 824, 457, '24', 'IE_ORTHOSPOT17_243IE', 'orthospot17_243ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot17_243ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19766, 824, 458, '24', 'IE_ORTHOSPOT17_244IE', 'orthospot17_244ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot17_244ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19767, 824, 459, '24', 'IE_ORTHOSPOT17_245IE', 'orthospot17_245ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot17_245ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19768, 824, 460, '24', 'IE_ORTHOSPOT18_239IE', 'orthospot18_239ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot18_239ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19769, 824, 461, '24', 'IE_ORTHOSPOT18_240IE', 'orthospot18_240ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot18_240ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19770, 824, 462, '24', 'IE_ORTHOSPOT18_241IE', 'orthospot18_241ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot18_241ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19771, 824, 463, '24', 'IE_ORTHOSPOT18_242IE', 'orthospot18_242ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot18_242ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19772, 824, 464, '24', 'IE_ORTHOSPOT18_243IE', 'orthospot18_243ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot18_243ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19773, 824, 465, '24', 'IE_ORTHOSPOT18_244IE', 'orthospot18_244ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot18_244ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19774, 824, 466, '24', 'IE_ORTHOSPOT21_237IE', 'orthospot21_237ie', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/ecw_stretched/ie/orthospot21_237ie.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19775, 824, 467, '24', 'MOSAIC_MOSAICS', 'mosaics', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/spot/mosaic/mosaics.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19776, 824, 468, '0', 'radar', 'radar', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19777, 824, 469, '468', 'AP_AP040808_104124_VH_PWR_FIL_GEO', 'ap040808_104124_vh_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/ap/ap040808_104124_vh_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19778, 824, 470, '468', 'AP_AP040808_104124_VV_PWR_FIL_GEO', 'ap040808_104124_vv_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/ap/ap040808_104124_vv_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19779, 824, 471, '468', 'IM_IM050715_102519_PWR_FIL_GEO', 'im050715_102519_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050715_102519_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19780, 824, 472, '468', 'IM_IM050715_214855_PWR_FIL_GEO', 'im050715_214855_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050715_214855_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19781, 824, 473, '468', 'IM_IM050717_110152_PWR_FIL_GEO', 'im050717_110152_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050717_110152_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19782, 824, 474, '468', 'IM_IM050721_103522_PWR_FIL_GEO', 'im050721_103522_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050721_103522_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19783, 824, 475, '468', 'IM_IM050721_215921_PWR_FIL_GEO', 'im050721_215921_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050721_215921_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19784, 824, 476, '468', 'IM_IM050721_215946_PWR_FIL_GEO', 'im050721_215946_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050721_215946_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19785, 824, 477, '468', 'IM_IM050724_104047_PWR_FIL_GEO', 'im050724_104047_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050724_104047_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19786, 824, 478, '468', 'IM_IM050724_104249_PWR_FIL_GEO', 'im050724_104249_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050724_104249_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19787, 824, 479, '468', 'IM_IM050725_101107_PWR_FIL_GEO', 'im050725_101107_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050725_101107_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19788, 824, 480, '468', 'IM_IM050725_213323_PWR_FIL_GEO', 'im050725_213323_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050725_213323_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19789, 824, 481, '468', 'IM_IM050727_104614_PWR_FIL_GEO', 'im050727_104614_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050727_104614_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19790, 824, 482, '468', 'IM_IM050728_213939_PWR_FIL_GEO', 'im050728_213939_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050728_213939_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19791, 824, 483, '468', 'IM_IM050816_214210_PWR_FIL_GEO', 'im050816_214210_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050816_214210_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19792, 824, 484, '468', 'IM_IM050825_103638_PWR_FIL_GEO', 'im050825_103638_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/im050825_103638_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19793, 824, 485, '468', 'INTER_IM040727_041214_PWR_FIL_GEO', 'im040727_041214_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im040727_041214_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19794, 824, 486, '468', 'INTER_IM040727_101948_PWR_FIL_GEO', 'im040727_101948_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im040727_101948_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19795, 824, 487, '468', 'INTER_IM041214_101941_PWR_FIL_GEO', 'im041214_101941_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im041214_101941_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19796, 824, 488, '468', 'INTER_IM050118_050816_PWR_FIL_GEO', 'im050118_050816_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050118_050816_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19797, 824, 489, '468', 'INTER_IM050118_214159_PWR_FIL_GEO', 'im050118_214159_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050118_214159_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19798, 824, 490, '468', 'INTER_IM050121_102508_PWR_FIL_GEO', 'im050121_102508_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050121_102508_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19799, 824, 491, '468', 'INTER_IM050121_214159_PWR_FIL_GEO', 'im050121_214159_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050121_214159_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19800, 824, 492, '468', 'INTER_IM050121_214741_PWR_FIL_GEO', 'im050121_214741_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050121_214741_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19801, 824, 493, '468', 'INTER_IM050124_215329_PWR_MT_FIL_GEO', 'im050124_215329_pwr_mt_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050124_215329_pwr_mt_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19802, 824, 494, '468', 'INTER_IM050401_102457_PWR_GEO', 'im050401_102457_pwr_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050401_102457_pwr_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19803, 824, 495, '468', 'INTER_IM050522_214503_PWR_FIL_GEO', 'im050522_214503_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050522_214503_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19804, 824, 496, '468', 'INTER_IM050610_102514_PWR_GEO', 'im050610_102514_pwr_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050610_102514_pwr_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19805, 824, 497, '468', 'INTER_IM050718_215335_PWR_MT_FIL_GEO', 'im050718_215335_pwr_mt_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050718_215335_pwr_mt_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19806, 824, 498, '468', 'INTER_IM050725_213443_PWR_FIL_RSP_GEO', 'im050725_213443_pwr_fil_rsp_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050725_213443_pwr_fil_rsp_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19807, 824, 499, '468', 'INTER_IM050731_214505_PWR_RSP_FIL_GEO', 'im050731_214505_pwr_rsp_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050731_214505_pwr_rsp_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19808, 824, 500, '468', 'INTER_IM050731_214544_PWR_FIL_GEO', 'im050731_214544_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050731_214544_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19809, 824, 501, '468', 'INTER_IM050816_PWR_RSP_FIL_GEO', 'im050816_pwr_rsp_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050816_pwr_rsp_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19810, 824, 502, '468', 'INTER_IM050819_214745_PWR_FIL_GEO', 'im050819_214745_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050819_214745_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19811, 824, 503, '468', 'INTER_IM050825_215907_PWR_FIL_GEO', 'im050825_215907_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050825_215907_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19812, 824, 504, '468', 'INTER_IM050829_213438_PWR_RSP_FIL_GEO', 'im050829_213438_pwr_rsp_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050829_213438_pwr_rsp_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19813, 824, 505, '468', 'INTER_IM050904_214539_PWR_RSP_FIL_GEO', 'im050904_214539_pwr_rsp_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im050904_214539_pwr_rsp_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19814, 824, 506, '468', 'INTER_IM051103_PWR_RSP_FIL_GEO', 'im051103_pwr_rsp_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/im051103_pwr_rsp_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19815, 824, 507, '468', 'COH_IM050121_050610_SLC_CC_GEO', 'im050121_050610_slc_cc_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/coh/im050121_050610_slc_cc_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19816, 824, 508, '468', 'COH_IM050121_050819_SLC_CC_GEO', 'im050121_050819_slc_cc_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/coh/im050121_050819_slc_cc_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19817, 824, 509, '468', 'COH_IM050124_050718_SLC_CC_FIL_GEO', 'im050124_050718_slc_cc_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/coh/im050124_050718_slc_cc_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19818, 824, 510, '468', 'COH_IM050522_050731_SLC_CC_GEO', 'im050522_050731_slc_cc_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/coh/im050522_050731_slc_cc_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19819, 824, 511, '468', 'COH_IM050725_050829_SLC_CC_FIL_GEO', 'im050725_050829_slc_cc_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/coh/im050725_050829_slc_cc_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19820, 824, 512, '468', 'COH_IM050731_050904_SLC_CC_GEO', 'im050731_050904_slc_cc_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/coh/im050731_050904_slc_cc_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19821, 824, 513, '468', 'RSP_IM050725_213443_PWR_FIL_RSP_GEO', 'im050725_213443_pwr_fil_rsp_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/rsp/im050725_213443_pwr_fil_rsp_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19822, 824, 514, '468', 'RSP_IM050731_214505_PWR_RSP_FIL_GEO', 'im050731_214505_pwr_rsp_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/rsp/im050731_214505_pwr_rsp_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19823, 824, 515, '468', 'RSP_IM050816_PWR_RSP_FIL_GEO', 'im050816_pwr_rsp_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/rsp/im050816_pwr_rsp_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19824, 824, 516, '468', 'RSP_IM050829_213438_PWR_RSP_FIL_GEO', 'im050829_213438_pwr_rsp_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/rsp/im050829_213438_pwr_rsp_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19825, 824, 517, '468', 'RSP_IM050904_214539_PWR_RSP_FIL_GEO', 'im050904_214539_pwr_rsp_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/rsp/im050904_214539_pwr_rsp_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19826, 824, 518, '468', 'RSP_IM051103_PWR_RSP_FIL_GEO', 'im051103_pwr_rsp_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/inter/rsp/im051103_pwr_rsp_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19827, 824, 519, '468', 'MD_IM040727_041214_MD', 'im040727_041214_md', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/md/im040727_041214_md.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19828, 824, 520, '468', 'MD_IM041214_040727_MD', 'im041214_040727_md', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/md/im041214_040727_md.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19829, 824, 521, '468', 'MD_IM050118_050816_MD', 'im050118_050816_md', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/md/im050118_050816_md.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19830, 824, 522, '468', 'MD_IM050121_050610_MD', 'im050121_050610_md', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/md/im050121_050610_md.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19831, 824, 523, '468', 'MD_IM050121_050819_MD', 'im050121_050819_md', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/md/im050121_050819_md.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19832, 824, 524, '468', 'MD_IM050124_050718_MD', 'im050124_050718_md', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/md/im050124_050718_md.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19833, 824, 525, '468', 'MD_IM050522_050731_MD', 'im050522_050731_md', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/md/im050522_050731_md.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19834, 824, 526, '468', 'MD_IM050725_050829_MD', 'im050725_050829_md', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/md/im050725_050829_md.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19835, 824, 527, '468', 'MD_IM050731_050904_MD', 'im050731_050904_md', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/md/im050731_050904_md.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19836, 824, 528, '468', 'MD_IM050825_051103_MD', 'im050825_051103_md', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/im/md/im050825_051103_md.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19837, 824, 529, '468', 'WS_WS050712_101922_PWR_FIL_GEO', 'ws050712_101922_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/ws/ws050712_101922_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19838, 824, 530, '468', 'WS_WS050718_103010_PWR_FIL_GEO', 'ws050718_103010_pwr_fil_geo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/8_bit_ecw/ws/ws050718_103010_pwr_fil_geo.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19839, 824, 531, '468', 'ECW_ENVISAT', 'envisat', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/envisat/im_mosaic/ecw/envisat.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19840, 824, 532, '468', 'COH_20394.2511.721.COH', '20394.2511.721.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/20394.2511.721.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19841, 824, 533, '468', 'COH_20394.2511.721', '20394.2511.721', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/20394.2511.721.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19842, 824, 534, '468', 'COH_20423.2511.750.COH', '20423.2511.750.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/20423.2511.750.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19843, 824, 535, '468', 'COH_20544.1017.871.COH', '20544.1017.871.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/20544.1017.871.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19844, 824, 536, '468', 'COH_20566.2421.893.COH', '20566.2421.893.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/20566.2421.893.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19845, 824, 537, '468', 'COH_20566.2493.893.COH', '20566.2493.893.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/20566.2493.893.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19846, 824, 538, '468', 'COH_20773.1017.1100.COH', '20773.1017.1100.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/20773.1017.1100.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19847, 824, 539, '468', 'COH_20773.1071.1100.COH', '20773.1071.1100.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/20773.1071.1100.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19848, 824, 540, '468', 'COH_21897.2511.2224.COH', '21897.2511.2224.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/21897.2511.2224.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19849, 824, 541, '468', 'COH_21940.2475.2267.COH', '21940.2475.2267.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/21940.2475.2267.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19850, 824, 542, '468', 'COH_22026.2403.2353.COH', '22026.2403.2353.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/22026.2403.2353.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19851, 824, 543, '468', 'COH_22112.2421.2439.COH', '22112.2421.2439.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/22112.2421.2439.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19852, 824, 544, '468', 'COH_22112.2493.2439.COH', '22112.2493.2439.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/22112.2493.2439.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19853, 824, 545, '468', 'COH_22112.2547.2439.COH', '22112.2547.2439.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/22112.2547.2439.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19854, 824, 546, '468', 'COH_22126.2511.2453.COH', '22126.2511.2453.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/22126.2511.2453.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19855, 824, 547, '468', 'COH_22169.2493.2496.COH', '22169.2493.2496.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/22169.2493.2496.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19856, 824, 548, '468', 'COH_22312.2547.2639.COH', '22312.2547.2639.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/22312.2547.2639.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19857, 824, 549, '468', 'COH_22484.2439.2811.COH', '22484.2439.2811.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/22484.2439.2811.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19858, 824, 550, '468', 'COH_22484.2529.2811.COH', '22484.2529.2811.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/22484.2529.2811.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19859, 824, 551, '468', 'COH_23114.2421.3441.COH', '23114.2421.3441.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/23114.2421.3441.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19860, 824, 552, '468', 'COH_23114.2511.3441.COH', '23114.2511.3441.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/23114.2511.3441.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19861, 824, 553, '468', 'COH_23300.2421.3627.COH', '23300.2421.3627.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/23300.2421.3627.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19862, 824, 554, '468', 'COH_23300.2493.3627.COH', '23300.2493.3627.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/23300.2493.3627.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19863, 824, 555, '468', 'COH_23343.2421.3670.COH', '23343.2421.3670.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/23343.2421.3670.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19864, 824, 556, '468', 'COH_23343.2511.3670.COH', '23343.2511.3670.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/23343.2511.3670.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19865, 824, 557, '468', 'COH_24030.2385.4357.COH', '24030.2385.4357.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/24030.2385.4357.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19866, 824, 558, '468', 'COH_24137.999.4464.COH', '24137.999.4464.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/24137.999.4464.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19867, 824, 559, '468', 'COH_25053.1017.5380.COH', '25053.1017.5380.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/25053.1017.5380.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19868, 824, 560, '468', 'COH_25161.2493.5488.COH', '25161.2493.5488.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/25161.2493.5488.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19869, 824, 561, '468', 'COH_26492.2367.6819.COH', '26492.2367.6819.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/26492.2367.6819.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19870, 824, 562, '468', 'COH_26492.2439.6819.COH', '26492.2439.6819.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/26492.2439.6819.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19871, 824, 563, '468', 'COH_26492.2529.6819.COH', '26492.2529.6819.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/26492.2529.6819.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19872, 824, 564, '468', 'COH_2_22126.2511.2453.COH', '2_22126.2511.2453.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/2_22126.2511.2453.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19873, 824, 565, '468', 'COH_30607.1035.10934.COH', '30607.1035.10934.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/30607.1035.10934.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19874, 824, 566, '468', 'COH_30607.1125.10934.COH', '30607.1125.10934.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/30607.1125.10934.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19875, 824, 567, '468', 'COH_31609.1017.11936.COH', '31609.1017.11936.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/31609.1017.11936.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19876, 824, 568, '468', 'COH_42631.1017.22958.COH', '42631.1017.22958.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/42631.1017.22958.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19877, 824, 569, '468', 'COH_42696.2511.23023.COH', '42696.2511.23023.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/42696.2511.23023.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19878, 824, 570, '468', 'COH_42982.2475.23309.COH', '42982.2475.23309.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/42982.2475.23309.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19879, 824, 571, '468', 'COH_43275.1017.23602.COH', '43275.1017.23602.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/43275.1017.23602.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19880, 824, 572, '468', 'COH_43526.2367.23853.COH', '43526.2367.23853.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/43526.2367.23853.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19881, 824, 573, '468', 'COH_43526.2439.23853.COH', '43526.2439.23853.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/43526.2439.23853.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19882, 824, 574, '468', 'COH_43526.2529.23853.COH', '43526.2529.23853.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/coh/43526.2529.23853.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19883, 824, 575, '468', 'ERS1_20394.2511.AMP', '20394.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/20394.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19884, 824, 576, '468', 'ERS1_20423.2511.AMP', '20423.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/20423.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19885, 824, 577, '468', 'ERS1_20544.1017.AMP', '20544.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/20544.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19886, 824, 578, '468', 'ERS1_20566.2421.AMP', '20566.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/20566.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19887, 824, 579, '468', 'ERS1_20566.2493.AMP', '20566.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/20566.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19888, 824, 580, '468', 'ERS1_20773.1017.AMP', '20773.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/20773.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19889, 824, 581, '468', 'ERS1_20773.1071.AMP', '20773.1071.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/20773.1071.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19890, 824, 582, '468', 'ERS1_21897.2511.AMP', '21897.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/21897.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19891, 824, 583, '468', 'ERS1_21940.2475.AMP', '21940.2475.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/21940.2475.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19892, 824, 584, '468', 'ERS1_22026.2403.AMP', '22026.2403.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/22026.2403.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19893, 824, 585, '468', 'ERS1_22112.2421.AMP', '22112.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/22112.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19894, 824, 586, '468', 'ERS1_22112.2493.AMP', '22112.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/22112.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19895, 824, 587, '468', 'ERS1_22112.2547.AMP', '22112.2547.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/22112.2547.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19896, 824, 588, '468', 'ERS1_22126.2511.AMP', '22126.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/22126.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19897, 824, 589, '468', 'ERS1_22169.2493.AMP', '22169.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/22169.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19898, 824, 590, '468', 'ERS1_22312.2547.AMP', '22312.2547.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/22312.2547.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19899, 824, 591, '468', 'ERS1_22484.2439.AMP', '22484.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/22484.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19900, 824, 592, '468', 'ERS1_22484.2529.AMP', '22484.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/22484.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19901, 824, 593, '468', 'ERS1_23114.2421.AMP', '23114.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/23114.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19902, 824, 594, '468', 'ERS1_23114.2511.AMP', '23114.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/23114.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19903, 824, 595, '468', 'ERS1_23300.2421.AMP', '23300.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/23300.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19904, 824, 596, '468', 'ERS1_23300.2493.AMP', '23300.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/23300.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19905, 824, 597, '468', 'ERS1_23343.2421.AMP', '23343.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/23343.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19906, 824, 598, '468', 'ERS1_23343.2421A.AMP', '23343.2421a.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/23343.2421a.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19907, 824, 599, '468', 'ERS1_23343.2511.AMP', '23343.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/23343.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19908, 824, 600, '468', 'ERS1_24030.2385.AMP', '24030.2385.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/24030.2385.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19909, 824, 601, '468', 'ERS1_24137.999.AMP', '24137.999.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/24137.999.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19910, 824, 602, '468', 'ERS1_25053.1017.AMP', '25053.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/25053.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19911, 824, 603, '468', 'ERS1_25161.2493.AMP', '25161.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/25161.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19912, 824, 604, '468', 'ERS1_26492.2367.AMP', '26492.2367.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/26492.2367.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19913, 824, 605, '468', 'ERS1_26492.2439.AMP', '26492.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/26492.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19914, 824, 606, '468', 'ERS1_26492.2529.AMP', '26492.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/26492.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19915, 824, 607, '468', 'ERS1_30607.1035.AMP', '30607.1035.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/30607.1035.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19916, 824, 608, '468', 'ERS1_30607.1125.AMP', '30607.1125.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/30607.1125.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19917, 824, 609, '468', 'ERS1_31609.1017.AMP', '31609.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/31609.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19918, 824, 610, '468', 'ERS1_42631.1017.AMP', '42631.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/42631.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19919, 824, 611, '468', 'ERS1_42696.2511.AMP', '42696.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/42696.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19920, 824, 612, '468', 'ERS1_42982.2475.AMP', '42982.2475.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/42982.2475.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19921, 824, 613, '468', 'ERS1_43275.1017.AMP', '43275.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/43275.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19922, 824, 614, '468', 'ERS1_43526.2367.AMP', '43526.2367.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/43526.2367.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19923, 824, 615, '468', 'ERS1_43526.2439.AMP', '43526.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/43526.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19924, 824, 616, '468', 'ERS1_43526.2529.AMP', '43526.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers1/43526.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19925, 824, 617, '468', 'ERS2_10934.1035.AMP', '10934.1035.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/10934.1035.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19926, 824, 618, '468', 'ERS2_10934.1125.AMP', '10934.1125.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/10934.1125.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19927, 824, 619, '468', 'ERS2_1100.1017.AMP', '1100.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/1100.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19928, 824, 620, '468', 'ERS2_1100.1071.AMP', '1100.1071.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/1100.1071.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19929, 824, 621, '468', 'ERS2_11936.1017.AMP', '11936.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/11936.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19930, 824, 622, '468', 'ERS2_2224.2511.AMP', '2224.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2224.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19931, 824, 623, '468', 'ERS2_2267.2475.AMP', '2267.2475.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2267.2475.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19932, 824, 624, '468', 'ERS2_22958.1017.AMP', '22958.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/22958.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19933, 824, 625, '468', 'ERS2_23023.2511.AMP', '23023.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/23023.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19934, 824, 626, '468', 'ERS2_23309.2475.AMP', '23309.2475.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/23309.2475.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19935, 824, 627, '468', 'ERS2_2353.2403.AMP', '2353.2403.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2353.2403.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19936, 824, 628, '468', 'ERS2_23602.1017.AMP', '23602.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/23602.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19937, 824, 629, '468', 'ERS2_23853.2367.AMP', '23853.2367.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/23853.2367.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19938, 824, 630, '468', 'ERS2_23853.2439.AMP', '23853.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/23853.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19939, 824, 631, '468', 'ERS2_23853.2529.AMP', '23853.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/23853.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19940, 824, 632, '468', 'ERS2_2439.2421.AMP', '2439.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2439.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19941, 824, 633, '468', 'ERS2_2439.2493.AMP', '2439.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2439.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19942, 824, 634, '468', 'ERS2_2439.2547.AMP', '2439.2547.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2439.2547.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19943, 824, 635, '468', 'ERS2_2453.2511.AMP', '2453.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2453.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19944, 824, 636, '468', 'ERS2_2496.2493.AMP', '2496.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2496.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19945, 824, 637, '468', 'ERS2_2639.2547.AMP', '2639.2547.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2639.2547.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19946, 824, 638, '468', 'ERS2_2811.2439.AMP', '2811.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2811.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19947, 824, 639, '468', 'ERS2_2811.2529.AMP', '2811.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2811.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19948, 824, 640, '468', 'ERS2_2_2453.2511.AMP', '2_2453.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/2_2453.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19949, 824, 641, '468', 'ERS2_3441.2421.AMP', '3441.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/3441.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19950, 824, 642, '468', 'ERS2_3441.2511.AMP', '3441.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/3441.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19951, 824, 643, '468', 'ERS2_3627.2421.AMP', '3627.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/3627.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19952, 824, 644, '468', 'ERS2_3627.2493.AMP', '3627.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/3627.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19953, 824, 645, '468', 'ERS2_3670.2421.AMP', '3670.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/3670.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19954, 824, 646, '468', 'ERS2_3670.2511.AMP', '3670.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/3670.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19955, 824, 647, '468', 'ERS2_4357.2385.AMP', '4357.2385.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/4357.2385.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19956, 824, 648, '468', 'ERS2_4464.999.AMP', '4464.999.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/4464.999.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19957, 824, 649, '468', 'ERS2_5380.1017.AMP', '5380.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/5380.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19958, 824, 650, '468', 'ERS2_5488.2493.AMP', '5488.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/5488.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19959, 824, 651, '468', 'ERS2_6819.2367.AMP', '6819.2367.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/6819.2367.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19960, 824, 652, '468', 'ERS2_6819.2439.AMP', '6819.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/6819.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19961, 824, 653, '468', 'ERS2_6819.2529.AMP', '6819.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/6819.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19962, 824, 654, '468', 'ERS2_721.2511.AMP', '721.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/721.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19963, 824, 655, '468', 'ERS2_750.2511.AMP', '750.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/750.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19964, 824, 656, '468', 'ERS2_871.1017.AMP', '871.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/871.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19965, 824, 657, '468', 'ERS2_893.2421.AMP', '893.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/893.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19966, 824, 658, '468', 'ERS2_893.2493.AMP', '893.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/bng_ecw/ers2/893.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19967, 824, 659, '468', 'COH_20394.2511.721.COH_01', '20394.2511.721.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/20394.2511.721.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19968, 824, 660, '468', 'COH_20394.2511.721_01', '20394.2511.721', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/20394.2511.721.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19969, 824, 661, '468', 'COH_20423.2511.750.COH_01', '20423.2511.750.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/20423.2511.750.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19970, 824, 662, '468', 'COH_20544.1017.871.COH_01', '20544.1017.871.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/20544.1017.871.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19971, 824, 663, '468', 'COH_20566.2421.893.COH_01', '20566.2421.893.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/20566.2421.893.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19972, 824, 664, '468', 'COH_20566.2493.893.COH_01', '20566.2493.893.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/20566.2493.893.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19973, 824, 665, '468', 'COH_20773.1017.1100.COH_01', '20773.1017.1100.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/20773.1017.1100.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19974, 824, 666, '468', 'COH_20773.1071.1100.COH_01', '20773.1071.1100.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/20773.1071.1100.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19975, 824, 667, '468', 'COH_21897.2511.2224.COH_01', '21897.2511.2224.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/21897.2511.2224.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19976, 824, 668, '468', 'COH_21940.2475.2267.COH_01', '21940.2475.2267.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/21940.2475.2267.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19977, 824, 669, '468', 'COH_22026.2403.2353.COH_01', '22026.2403.2353.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/22026.2403.2353.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19978, 824, 670, '468', 'COH_22112.2421.2439.COH_01', '22112.2421.2439.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/22112.2421.2439.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19979, 824, 671, '468', 'COH_22112.2493.2439.COH_01', '22112.2493.2439.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/22112.2493.2439.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19980, 824, 672, '468', 'COH_22112.2547.2439.COH_01', '22112.2547.2439.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/22112.2547.2439.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19981, 824, 673, '468', 'COH_22126.2511.2453.COH_01', '22126.2511.2453.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/22126.2511.2453.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19982, 824, 674, '468', 'COH_22169.2493.2496.COH_01', '22169.2493.2496.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/22169.2493.2496.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19983, 824, 675, '468', 'COH_22312.2547.2639.COH_01', '22312.2547.2639.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/22312.2547.2639.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19984, 824, 676, '468', 'COH_22484.2439.2811.COH_01', '22484.2439.2811.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/22484.2439.2811.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19985, 824, 677, '468', 'COH_22484.2529.2811.COH_01', '22484.2529.2811.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/22484.2529.2811.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19986, 824, 678, '468', 'COH_23114.2421.3441.COH_01', '23114.2421.3441.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/23114.2421.3441.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19987, 824, 679, '468', 'COH_23114.2511.3441.COH_01', '23114.2511.3441.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/23114.2511.3441.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19988, 824, 680, '468', 'COH_23300.2421.3627.COH_01', '23300.2421.3627.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/23300.2421.3627.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19989, 824, 681, '468', 'COH_23300.2493.3627.COH_01', '23300.2493.3627.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/23300.2493.3627.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19990, 824, 682, '468', 'COH_23343.2421.3670.COH_01', '23343.2421.3670.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/23343.2421.3670.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19991, 824, 683, '468', 'COH_23343.2511.3670.COH_01', '23343.2511.3670.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/23343.2511.3670.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19992, 824, 684, '468', 'COH_24030.2385.4357.COH_01', '24030.2385.4357.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/24030.2385.4357.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19993, 824, 685, '468', 'COH_24137.999.4464.COH_01', '24137.999.4464.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/24137.999.4464.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19994, 824, 686, '468', 'COH_25053.1017.5380.COH_01', '25053.1017.5380.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/25053.1017.5380.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19995, 824, 687, '468', 'COH_25161.2493.5488.COH_01', '25161.2493.5488.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/25161.2493.5488.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19996, 824, 688, '468', 'COH_26492.2367.6819.COH_01', '26492.2367.6819.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/26492.2367.6819.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19997, 824, 689, '468', 'COH_26492.2439.6819.COH_01', '26492.2439.6819.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/26492.2439.6819.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19998, 824, 690, '468', 'COH_26492.2529.6819.COH_01', '26492.2529.6819.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/26492.2529.6819.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19999, 824, 691, '468', 'COH_2_22126.2511.2453.COH_01', '2_22126.2511.2453.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/2_22126.2511.2453.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20000, 824, 692, '468', 'COH_30607.1035.10934.COH_01', '30607.1035.10934.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/30607.1035.10934.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20001, 824, 693, '468', 'COH_30607.1125.10934.COH_01', '30607.1125.10934.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/30607.1125.10934.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20002, 824, 694, '468', 'COH_31609.1017.11936.COH_01', '31609.1017.11936.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/31609.1017.11936.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20003, 824, 695, '468', 'COH_42631.1017.22958.COH_01', '42631.1017.22958.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/42631.1017.22958.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20004, 824, 696, '468', 'COH_42696.2511.23023.COH_01', '42696.2511.23023.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/42696.2511.23023.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20005, 824, 697, '468', 'COH_42982.2475.23309.COH_01', '42982.2475.23309.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/42982.2475.23309.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20006, 824, 698, '468', 'COH_43275.1017.23602.COH_01', '43275.1017.23602.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/43275.1017.23602.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20007, 824, 699, '468', 'COH_43526.2367.23853.COH_01', '43526.2367.23853.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/43526.2367.23853.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20008, 824, 700, '468', 'COH_43526.2439.23853.COH_01', '43526.2439.23853.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/43526.2439.23853.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20009, 824, 701, '468', 'COH_43526.2529.23853.COH_01', '43526.2529.23853.coh', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/coh/43526.2529.23853.coh.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20010, 824, 702, '468', 'ERS1_20394.2511.AMP_01', '20394.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/20394.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20011, 824, 703, '468', 'ERS1_20423.2511.AMP_01', '20423.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/20423.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20012, 824, 704, '468', 'ERS1_20544.1017.AMP_01', '20544.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/20544.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20013, 824, 705, '468', 'ERS1_20566.2421.AMP_01', '20566.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/20566.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20014, 824, 706, '468', 'ERS1_20566.2493.AMP_01', '20566.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/20566.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20015, 824, 707, '468', 'ERS1_20773.1017.AMP_01', '20773.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/20773.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20016, 824, 708, '468', 'ERS1_20773.1071.AMP_01', '20773.1071.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/20773.1071.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20017, 824, 709, '468', 'ERS1_21897.2511.AMP_01', '21897.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/21897.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20018, 824, 710, '468', 'ERS1_21940.2475.AMP_01', '21940.2475.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/21940.2475.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20019, 824, 711, '468', 'ERS1_22026.2403.AMP_01', '22026.2403.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/22026.2403.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20020, 824, 712, '468', 'ERS1_22112.2421.AMP_01', '22112.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/22112.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20021, 824, 713, '468', 'ERS1_22112.2493.AMP_01', '22112.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/22112.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20022, 824, 714, '468', 'ERS1_22112.2547.AMP_01', '22112.2547.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/22112.2547.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20023, 824, 715, '468', 'ERS1_22126.2511.AMP_01', '22126.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/22126.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20024, 824, 716, '468', 'ERS1_22169.2493.AMP_01', '22169.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/22169.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20025, 824, 717, '468', 'ERS1_22312.2547.AMP_01', '22312.2547.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/22312.2547.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20026, 824, 718, '468', 'ERS1_22484.2439.AMP_01', '22484.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/22484.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20027, 824, 719, '468', 'ERS1_22484.2529.AMP_01', '22484.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/22484.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20028, 824, 720, '468', 'ERS1_23114.2421.AMP_01', '23114.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/23114.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20029, 824, 721, '468', 'ERS1_23114.2511.AMP_01', '23114.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/23114.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20030, 824, 722, '468', 'ERS1_23300.2421.AMP_01', '23300.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/23300.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20031, 824, 723, '468', 'ERS1_23300.2493.AMP_01', '23300.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/23300.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20032, 824, 724, '468', 'ERS1_23343.2421.AMP_01', '23343.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/23343.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20033, 824, 725, '468', 'ERS1_23343.2511.AMP_01', '23343.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/23343.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20034, 824, 726, '468', 'ERS1_24030.2385.AMP_01', '24030.2385.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/24030.2385.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20035, 824, 727, '468', 'ERS1_24137.999.AMP_01', '24137.999.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/24137.999.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20036, 824, 728, '468', 'ERS1_25053.1017.AMP_01', '25053.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/25053.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20037, 824, 729, '468', 'ERS1_25161.2493.AMP_01', '25161.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/25161.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20038, 824, 730, '468', 'ERS1_26492.2367.AMP_01', '26492.2367.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/26492.2367.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20039, 824, 731, '468', 'ERS1_26492.2439.AMP_01', '26492.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/26492.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20040, 824, 732, '468', 'ERS1_26492.2529.AMP_01', '26492.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/26492.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20041, 824, 733, '468', 'ERS1_30607.1035.AMP_01', '30607.1035.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/30607.1035.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20042, 824, 734, '468', 'ERS1_30607.1125.AMP_01', '30607.1125.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/30607.1125.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20043, 824, 735, '468', 'ERS1_31609.1017.AMP_01', '31609.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/31609.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20044, 824, 736, '468', 'ERS1_42631.1017.AMP_01', '42631.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/42631.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20045, 824, 737, '468', 'ERS1_42696.2511.AMP_01', '42696.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/42696.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20046, 824, 738, '468', 'ERS1_42982.2475.AMP_01', '42982.2475.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/42982.2475.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20047, 824, 739, '468', 'ERS1_43275.1017.AMP_01', '43275.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/43275.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20048, 824, 740, '468', 'ERS1_43526.2367.AMP_01', '43526.2367.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/43526.2367.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20049, 824, 741, '468', 'ERS1_43526.2439.AMP_01', '43526.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/43526.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20050, 824, 742, '468', 'ERS1_43526.2529.AMP_01', '43526.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers1/43526.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20051, 824, 743, '468', 'ERS2_10934.1035.AMP_01', '10934.1035.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/10934.1035.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20052, 824, 744, '468', 'ERS2_10934.1125.AMP_01', '10934.1125.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/10934.1125.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20053, 824, 745, '468', 'ERS2_1100.1017.AMP_01', '1100.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/1100.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20054, 824, 746, '468', 'ERS2_1100.1071.AMP_01', '1100.1071.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/1100.1071.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20055, 824, 747, '468', 'ERS2_11936.1017.AMP_01', '11936.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/11936.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20056, 824, 748, '468', 'ERS2_2224.2511.AMP_01', '2224.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2224.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20057, 824, 749, '468', 'ERS2_2267.2475.AMP_01', '2267.2475.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2267.2475.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20058, 824, 750, '468', 'ERS2_22958.1017.AMP_01', '22958.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/22958.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20059, 824, 751, '468', 'ERS2_23023.2511.AMP_01', '23023.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/23023.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20060, 824, 752, '468', 'ERS2_23309.2475.AMP_01', '23309.2475.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/23309.2475.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20061, 824, 753, '468', 'ERS2_2353.2403.AMP_01', '2353.2403.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2353.2403.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20062, 824, 754, '468', 'ERS2_23602.1017.AMP_01', '23602.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/23602.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20063, 824, 755, '468', 'ERS2_23853.2367.AMP_01', '23853.2367.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/23853.2367.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20064, 824, 756, '468', 'ERS2_23853.2439.AMP_01', '23853.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/23853.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20065, 824, 757, '468', 'ERS2_23853.2529.AMP_01', '23853.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/23853.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20066, 824, 758, '468', 'ERS2_2439.2421.AMP_01', '2439.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2439.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20067, 824, 759, '468', 'ERS2_2439.2493.AMP_01', '2439.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2439.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20068, 824, 760, '468', 'ERS2_2439.2547.AMP_01', '2439.2547.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2439.2547.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20069, 824, 761, '468', 'ERS2_2453.2511.AMP_01', '2453.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2453.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20070, 824, 762, '468', 'ERS2_2496.2493.AMP_01', '2496.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2496.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20071, 824, 763, '468', 'ERS2_2639.2547.AMP_01', '2639.2547.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2639.2547.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20072, 824, 764, '468', 'ERS2_2639.2547A.AMP', '2639.2547a.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2639.2547a.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20073, 824, 765, '468', 'ERS2_2811.2439.AMP_01', '2811.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2811.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20074, 824, 766, '468', 'ERS2_2811.2529.AMP_01', '2811.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2811.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20075, 824, 767, '468', 'ERS2_2_2453.2511.AMP_01', '2_2453.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/2_2453.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20076, 824, 768, '468', 'ERS2_3441.2421.AMP_01', '3441.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/3441.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20077, 824, 769, '468', 'ERS2_3441.2511.AMP_01', '3441.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/3441.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20078, 824, 770, '468', 'ERS2_3627.2421.AMP_01', '3627.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/3627.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20079, 824, 771, '468', 'ERS2_3627.2493.AMP_01', '3627.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/3627.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20080, 824, 772, '468', 'ERS2_3670.2421.AMP_01', '3670.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/3670.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20081, 824, 773, '468', 'ERS2_3670.2511.AMP_01', '3670.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/3670.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20082, 824, 774, '468', 'ERS2_4357.2385.AMP_01', '4357.2385.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/4357.2385.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20083, 824, 775, '468', 'ERS2_4464.999.AMP_01', '4464.999.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/4464.999.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20084, 824, 776, '468', 'ERS2_5380.1017.AMP_01', '5380.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/5380.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20085, 824, 777, '468', 'ERS2_5488.2493.AMP_01', '5488.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/5488.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20086, 824, 778, '468', 'ERS2_6819.2367.AMP_01', '6819.2367.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/6819.2367.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20087, 824, 779, '468', 'ERS2_6819.2439.AMP_01', '6819.2439.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/6819.2439.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20088, 824, 780, '468', 'ERS2_6819.2529.AMP_01', '6819.2529.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/6819.2529.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20089, 824, 781, '468', 'ERS2_721.2511.AMP_01', '721.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/721.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20090, 824, 782, '468', 'ERS2_750.2511.AMP_01', '750.2511.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/750.2511.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20091, 824, 783, '468', 'ERS2_871.1017.AMP_01', '871.1017.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/871.1017.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20092, 824, 784, '468', 'ERS2_893.2421.AMP_01', '893.2421.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/893.2421.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20093, 824, 785, '468', 'ERS2_893.2493.AMP_01', '893.2493.amp', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/radar/ers/geodetic_ecw/ers2/893.2493.amp.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20094, 824, 786, '0', 'usa', 'usa', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20095, 824, 787, '786', 'USA_1METERCALIF_01', '1metercalif', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/usa/1metercalif.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20096, 824, 788, '786', 'USA_SANDIEGO1M_BW_01', 'Sandiego1m_bw', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/usa/Sandiego1m_bw.jp2', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20097, 824, 789, '786', 'USA_SANDIEGO1M_NULL_01', 'Sandiego1m_null', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/usa/Sandiego1m_null.jp2', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20098, 824, 790, '786', 'USA_SANDIEGO3I_01', 'sandiego3i', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/usa/sandiego3i.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20099, 824, 791, '786', 'USA_SANDIEGOAIRPHOTO_02', 'sandiegoairphoto', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/usa/sandiegoairphoto.ecw', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20100, 824, 792, '786', 'USA_SANDIEGOAIRPHOTO_03', 'sandiegoairphoto', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/usa/sandiegoairphoto.jp2', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20101, 824, 793, '786', 'USA_SANDIEGOAIRPHOTO_LOSSLESS_01', 'sandiegoairphoto_lossless', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/usa/sandiegoairphoto_lossless.jp2', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19149, 905, 0, '', 'Brandenburg', 'DNM FÜK', 0, 50000, 0, '', '', 'Digitales Navigationsmodell Flurübersichtskarte der Brandenburger Landesvermessung');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19150, 905, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19151, 905, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19152, 905, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19153, 905, 4, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19138, 904, 0, '', 'Brandenburg', 'DNM 250/2', 0, 25001, 0, '', '', '2. Generation des Digitalen Navigationsmodells 1:250.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19154, 905, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3401, 329, 0, '', 'MUENSTER', 'Geobasisdaten Muenster', 0, 0, 0, '', '', 'Geobasisdaten Muenster');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3402, 329, 1, '0', 'splan', 'Stadtplan', 0, 2400, 2000000, '', '', 'Stadtplan');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19139, 904, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 200000, 0, '', '', 'Landkreise und kreisfreie Städte');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3403, 329, 2, '0', 'luftb', 'Luftbilder', 0, 375, 3900, '', '', 'Luftbilder');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19140, 904, 2, '0', 'orte', 'Zentren', 0, 200000, 1000000, '', '', 'Zentren, TYP = 0');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19141, 904, 3, '0', 'korte', 'Orte', 0, 200000, 749999, '', '', 'Orte, TYP = 0');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3404, 329, 3, '0', 'dgk5dbr', 'DGK5', 0, 1, 3900, '', '', 'DGK5');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19142, 904, 4, '0', 'lwas', 'Flüsse und Kanäle', 0, 200000, 749999, '', '', 'Flüsse und Kanäle');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3405, 329, 4, '0', 'Stadtgrundkarte', 'Stadtgrundkarte', 0, 0, 0, '', '', 'Stadtgrundkarte');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19143, 904, 5, '0', 'fwas', 'Seen', 0, 200000, 749999, '', '', 'Seen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3406, 329, 5, '4', 'flst', 'Flurstuecke', 0, 1, 2500, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19155, 906, 0, '', 'Brandenburg', 'DNM VG', 0, 50000, 0, '', '', 'Digitales Navigationsmodell Verwaltungsgrenzen als Basisnavigationsdaten der Brandenburger Landesvermessung');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19144, 904, 6, '0', 'ebahn', 'Eisenbahnen', 0, 200000, 749999, '', '', 'Eisenbahnen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3407, 329, 6, '4', 'gebaeude', 'Gebaeude', 0, 1, 2500, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3408, 329, 7, '4', 'linien', 'Topographie', 0, 1, 2500, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3409, 329, 8, '4', 'texte', 'Beschriftung', 0, 1, 2500, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19145, 904, 7, '0', 'lstr', 'Landesstraßen', 0, 200000, 400000, '', '', 'Landesstraßen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19146, 904, 8, '0', 'bstr', 'Bundesstraßen', 0, 200000, 1000000, '', '', 'Bundesstraßen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19147, 904, 9, '0', 'astr', 'Autobahnen', 0, 200000, 0, '', '', 'Autobahnen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19148, 904, 10, '0', 'kfz', 'Kfz-Zeichen', 0, 1000000, 0, '', '', 'Kfz-Zeichen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19156, 906, 1, '0', 'berlin', 'Berliner Bezirke', 0, 50000, 1000000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19157, 906, 2, '0', 'geme', 'Gemeinde', 1, 50000, 1000000, '', '', 'digitaliert aus DTK 1:100.000');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19158, 906, 3, '0', 'kamt', 'Amtsfreie Gemeinde', 1, 50000, 1000000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19159, 906, 4, '0', 'amt', 'Ämter', 1, 50000, 1000000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19160, 906, 5, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19161, 906, 6, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19162, 906, 7, '0', 'land', 'Land', 0, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19163, 906, 8, '0', 'staat', 'Deutschland', 0, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19164, 906, 9, '0', 'ngeme', 'Namen der Gemeinden', 0, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19165, 906, 10, '0', 'nkamt', 'Namen der amtfreien Gemeinden', 0, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19166, 906, 11, '0', 'namt', 'Namen der Ämter', 0, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19167, 906, 12, '0', 'nkreis', 'KFZ Kennzeichen der Kreise', 0, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19233, 706, 0, '', 'WA_Atlas_GN_WMS', 'WA_Atlas_GN_WMS', 0, 0, 0, '', '', 'WMS Map Server');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11542, 706, 1, '0', 'Australia Base Map', 'Australia Base Map', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11543, 706, 2, '0', 'WA Base Map', 'WA Base Map', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11544, 706, 3, '0', 'WA Base Map - Detailed', 'WA Base Map - Detailed', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11545, 706, 4, '0', 'Bathymetry - Above Chart Datum', 'Bathymetry - Above Chart Datum', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11546, 706, 5, '0', 'State Geological Polygons', 'State Geological Polygons', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11547, 706, 6, '0', 'Beards Vegetation', 'Beards Vegetation', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19125, 903, 0, '', 'Brandenburg', 'DNM 25', 0, 100, 50000, '', '', 'Digitales Navigationsmodell 1:25.000 als Basisnavigationsdaten der Brandenburger Landesvermessung');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19126, 903, 1, '0', 'land', 'Landkreise und kreisfreie Städte', 0, 100, 50000, '', '', 'digitalisiert und generalisiert aus DTK 1:100.000');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19127, 903, 2, '0', 'ort', 'Ortschaften', 1, 1000, 50000, '', '', 'digitaliert aus DTK 1:100.000');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19128, 903, 3, '0', 'wald', 'Waldflächen', 0, 1000, 50000, '', '', 'aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19129, 903, 4, '0', 'gruen', 'Grünflächen', 0, 1000, 50000, '', '', 'Grünflächen aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19130, 903, 5, '0', 'lwas', 'Flüsse und Kanäle', 0, 1000, 50000, '', '', 'aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19131, 903, 6, '0', 'fwas', 'Seen, Teiche', 0, 1000, 50000, '', '', 'aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19132, 903, 7, '0', 'kgrnz', 'Kreisgrenze', 0, 1000, 50000, '', '', 'generalisiert aus 1:100.000');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19133, 903, 8, '0', 'flug', 'Internationale Flughäfen', 0, 1000, 29999, '', '', 'aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19134, 903, 9, '0', 'ebahn', 'Eisenbahnverbindungen', 0, 1000, 50000, '', '', 'aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19135, 903, 10, '0', 'str', 'Straßen', 0, 1000, 50000, '', '', 'aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19136, 903, 11, '0', 'haus', 'Gebäude', 0, 1000, 50000, '', '', 'aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19137, 903, 12, '0', 'nfwas', 'Namen der Seen, Teiche', 0, 1000, 50000, '', '', 'aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20102, 910, 0, '', 'IGME5000', 'IGME5000 preliminary release', 0, 0, 0, NULL, NULL, 'The 1 : 5 Million International Geological Map of Europe and Adjacent Areas (IGME 5000).');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20103, 910, 1, '0', 'la_igme_nations', 'Nations', 0, 0, 0, NULL, NULL, 'Nation Shapes of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20104, 910, 2, '0', 'gp_GeoByAge', 'Geology by Age (Geochronologic)', 0, 0, 0, NULL, NULL, 'Geology of Europe by Geochronology');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20105, 910, 3, '2', 'la_GeoKonti', 'Onshore Geology', 1, 0, 0, NULL, NULL, 'Onshore Geology of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20106, 910, 4, '2', 'la_GeoMarin', 'Offshore Geology', 1, 100000, 0, NULL, NULL, 'Offshore Geology of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20107, 910, 5, '0', 'gp_GeoOph', 'Ophiolite Complex', 0, 0, 0, NULL, NULL, 'Ophiolite Complex of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20108, 910, 6, '5', 'la_GeoOph_konti', 'Onshore Ophiolite Complex', 1, 100000, 0, NULL, NULL, 'Onshore Ophiolite Complex of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20109, 910, 7, '5', 'la_GeoOph_marin', 'Offshore Ophiolite Complex', 1, 100000, 0, NULL, NULL, 'Offshore Ophiolite Complex of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20110, 910, 8, '0', 'gp_GeoMagma', 'Magmatic Rocks', 0, 0, 0, NULL, NULL, 'Magmatic Rocks of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20111, 910, 9, '8', 'la_magma_konti', 'Onshore Magmatic Rocks', 1, 100000, 0, NULL, NULL, 'Onshore Magmatic Rocks of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20112, 910, 10, '8', 'la_magma_marin', 'Offshore Magmatic Rocks', 1, 100000, 0, NULL, NULL, 'Offshore Magmatic Rocks of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20113, 910, 11, '0', 'gp_GeoMetamorph', 'Metamorphism', 0, 0, 0, NULL, NULL, 'Metamorphism of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20114, 910, 12, '11', 'la_meta_konti', 'Onshore Metamorphism', 1, 50000, 0, NULL, NULL, 'Onshore Metamorphism of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20115, 910, 13, '11', 'la_meta_marin', 'Offshore Metamorphism', 1, 50000, 0, NULL, NULL, 'Offshore Metamorphism of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20116, 910, 14, '0', 'gp_Topo', 'Topography', 0, 0, 0, NULL, NULL, 'Topography of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20117, 910, 15, '14', 'la_Rivers', 'Rivers', 0, 0, 0, NULL, NULL, 'Rivers of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20118, 910, 16, '14', 'la_kan', 'Canals', 0, 50000, 0, NULL, NULL, 'Canals of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20119, 910, 17, '14', 'la_BroadRivers', 'Broad Rivers', 0, 0, 0, NULL, NULL, 'Broad Rivers of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20120, 910, 18, '14', 'la_Lakes', 'Lakes', 0, 0, 0, NULL, NULL, 'Lakes of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20121, 910, 19, '14', 'la_Grenzen', 'Boundaries', 0, 0, 0, NULL, NULL, 'Boundaries of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20122, 910, 20, '14', 'la_Towns', 'Towns', 0, 0, 0, NULL, NULL, 'Towns of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20123, 910, 21, '14', 'la_Capitals', 'Capitals', 0, 0, 0, NULL, NULL, 'Capitals of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20124, 910, 22, '0', 'la_Kueste', 'Coastline', 0, 0, 0, NULL, NULL, 'Coastline of Europe');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20125, 910, 23, '0', 'copyright', 'Copyright', 0, 0, 0, NULL, NULL, 'Copyright');
--- TOC entry 1869 (class 0 OID 5377220)
--- Dependencies: 1270
--- Data for Name: layer_epsg; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7491, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7491, 'EPSG:42304', -2750560, -936638, 3583870, 4673120);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7492, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7493, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7494, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7495, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7496, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7497, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7498, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7499, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7500, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7501, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7502, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7503, 'EPSG:4326', -154.14400000000001, 34.323099999999997, -31.789100000000001, 73.791300000000007);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7504, 'EPSG:4326', -154.14400000000001, 34.323099999999997, -31.789100000000001, 73.791300000000007);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7505, 'EPSG:4326', -153.90199999999999, 34.459499999999998, -32.129100000000001, 73.791799999999995);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7506, 'EPSG:4326', -179.80500000000001, 42.081899999999997, 178.86600000000001, 89.948800000000006);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7507, 'EPSG:4326', -179.96000000000001, 34.240900000000003, 178.833, 89.905100000000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7508, 'EPSG:4326', -173.53700000000001, 35.845199999999998, -11.9603, 83.800899999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7509, 'EPSG:4326', -172.30099999999999, 36.499099999999999, -13.175800000000001, 83.483999999999995);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7510, 'EPSG:4326', -172.30099999999999, 36.499099999999999, -13.175800000000001, 83.483999999999995);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7511, 'EPSG:4326', -171.90600000000001, 36.698399999999999, -13.537599999999999, 83.482500000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7512, 'EPSG:4326', -171.90600000000001, 36.698399999999999, -13.537599999999999, 83.482500000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7513, 'EPSG:4326', -171.12, 37.323399999999999, -14.197699999999999, 83.483900000000006);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7514, 'EPSG:4326', -171.12, 37.323399999999999, -14.197699999999999, 83.483900000000006);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7515, 'EPSG:4326', -135.917, 38.119700000000002, -42.582099999999997, 66.775800000000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7516, 'EPSG:4326', -135.917, 38.119700000000002, -42.582099999999997, 66.775800000000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14104, 'EPSG:4326', 14.530200000000001, 52.330599999999997, 14.5791, 52.360500000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14104, 'EPSG:25833', 468004, 5797910, 471315, 5801220);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19213, 'EPSG:4326', 14.362399999999999, 52.242899999999999, 14.625, 52.411200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14105, 'EPSG:4326', 14.362399999999999, 52.242899999999999, 14.625, 52.411200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14106, 'EPSG:4326', 14.362399999999999, 52.242899999999999, 14.625, 52.411200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14107, 'EPSG:4326', 14.362399999999999, 52.242899999999999, 14.625, 52.411200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14108, 'EPSG:4326', 14.362399999999999, 52.242899999999999, 14.625, 52.411200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14109, 'EPSG:4326', 14.362399999999999, 52.242899999999999, 14.625, 52.411200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14110, 'EPSG:4326', 14.362399999999999, 52.242899999999999, 14.625, 52.411200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14111, 'EPSG:4326', 14.362399999999999, 52.4101, 15, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14112, 'EPSG:4326', 14.362399999999999, 52.242899999999999, 14.625, 52.411200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14113, 'EPSG:4326', 14.362399999999999, 52.242899999999999, 14.625, 52.411200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14114, 'EPSG:4326', 14.362399999999999, 52.242899999999999, 14.625, 52.411200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14115, 'EPSG:4326', 14.362399999999999, 52.242899999999999, 14.625, 52.411200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19260, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19260, 'EPSG:27700', -345532424.51410002, -513987011.16250002, 349465159.60829997, 458560849.56580001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19260, 'EPSG:32616', -345353751.10619998, -463997395.12129998, 334988226.61290002, 493120011.7148);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19260, 'EPSG:4267', -179.99850000000001, -89.998599999999996, 180.0001, 89.998599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14843, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14843, 'EPSG:27700', -345532424.51410002, -513987011.16250002, 349465159.60829997, 458560849.56580001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14843, 'EPSG:32616', -345353751.10619998, -463997395.12129998, 334988226.61290002, 493120011.7148);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14843, 'EPSG:4267', -179.99850000000001, -89.998599999999996, 180.0001, 89.998599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14844, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14844, 'EPSG:27700', -345532424.51410002, -513987011.16250002, 349465159.60829997, 458560849.56580001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14844, 'EPSG:32616', -345353751.10619998, -463997395.12129998, 334988226.61290002, 493120011.7148);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14844, 'EPSG:4267', -179.99850000000001, -89.998599999999996, 180.0001, 89.998599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14845, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14845, 'EPSG:27700', -345532424.51410002, -513987011.16250002, 349465159.60829997, 458560849.56580001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14845, 'EPSG:32616', -345353751.10619998, -463997395.12129998, 334988226.61290002, 493120011.7148);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14845, 'EPSG:4267', -179.99850000000001, -89.998599999999996, 180.0001, 89.998599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14846, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14846, 'EPSG:27700', -345532424.51410002, -513987011.16250002, 349465159.60829997, 458560849.56580001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14846, 'EPSG:32616', -345353751.10619998, -463997395.12129998, 334988226.61290002, 493120011.7148);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14846, 'EPSG:4267', -179.99850000000001, -89.998599999999996, 180.0001, 89.998599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14847, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14847, 'EPSG:27700', -345532424.51410002, -513987011.16250002, 349465159.60829997, 458560849.56580001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14847, 'EPSG:32616', -345353751.10619998, -463997395.12129998, 334988226.61290002, 493120011.7148);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14847, 'EPSG:4267', -179.99850000000001, -89.998599999999996, 180.0001, 89.998599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14848, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14848, 'EPSG:27700', -345532424.51410002, -513987011.16250002, 349465159.60829997, 458560849.56580001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14848, 'EPSG:32616', -345353751.10619998, -463997395.12129998, 334988226.61290002, 493120011.7148);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14848, 'EPSG:4267', -179.99850000000001, -89.998599999999996, 180.0001, 89.998599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14849, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14849, 'EPSG:27700', -345532424.51410002, -513987011.16250002, 349465159.60829997, 458560849.56580001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14849, 'EPSG:32616', -345353751.10619998, -463997395.12129998, 334988226.61290002, 493120011.7148);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14849, 'EPSG:4267', -179.99850000000001, -89.998599999999996, 180.0001, 89.998599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14850, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14850, 'EPSG:27700', -345532424.51410002, -513987011.16250002, 349465159.60829997, 458560849.56580001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14850, 'EPSG:32616', -345353751.10619998, -463997395.12129998, 334988226.61290002, 493120011.7148);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14850, 'EPSG:4267', -179.99850000000001, -89.998599999999996, 180.0001, 89.998599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18154, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18154, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18154, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18155, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18155, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18155, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18155, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18155, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18130, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18130, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18130, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18130, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18130, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18131, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19209, 'EPSG:4326', 6.0018496199999998, 46.950000000000003, 16.123398860000002, 55.096068099999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19209, 'EPSG:31463', 3271885.7914000005, 5206662.5389424879, 3956235.7914000005, 6130259.0976999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19209, 'EPSG:31467', 3271885.7914000005, 5206662.5389424879, 3956235.7914000005, 6130259.0976999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14252, 'EPSG:4326', 6.0735873399999996, 47.161701000000001, 16.055210580000001, 55.096068099999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14252, 'EPSG:31463', 3278185.6428000005, 5228939.0976999998, 3950085.6428000005, 6130259.0976999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14252, 'EPSG:31467', 3278185.6428000005, 5228939.0976999998, 3950085.6428000005, 6130259.0976999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14253, 'EPSG:4326', 6.0018496199999998, 46.959702, 16.123398860000002, 54.936997300000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14253, 'EPSG:31463', 3271885.7914000005, 5206690.9778000023, 3956235.7914000005, 6113040.9778000023);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14253, 'EPSG:31467', 3271885.7914000005, 5206690.9778000023, 3956235.7914000005, 6113040.9778000023);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14254, 'EPSG:4326', 6.0024283699999996, 46.950000000000003, 16.12332498, 54.936999999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14254, 'EPSG:31463', 3271928.8134942902, 5206662.5389424879, 3956228.8134942902, 6113062.5389424879);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14254, 'EPSG:31467', 3271928.8134942902, 5206662.5389424879, 3956228.8134942902, 6113062.5389424879);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19261, 'EPSG:4326', 8.3545118943380707, 51.908979944405303, 8.6909819574333795, 52.119335104626302);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19261, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18236, 'EPSG:4326', 8.3545118943380707, 51.908979944405303, 8.6909819574333795, 52.119335104626302);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18236, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18237, 'EPSG:4326', 8.3545118943380707, 51.908979944405303, 8.6909819574333795, 52.119335104626302);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18237, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18238, 'EPSG:4326', 8.3545118943380707, 51.908979944405303, 8.6909819574333795, 52.119335104626302);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18238, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18239, 'EPSG:4326', 8.3545118943380707, 51.908979944405303, 8.6909819574333795, 52.119335104626302);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18239, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18240, 'EPSG:4326', 8.3545118943380707, 51.908979944405303, 8.6909819574333795, 52.119335104626302);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18240, 'EPSG:31467', 3455652, 5752972, 3478906, 5776226);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14968, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14993, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15002, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14869, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14950, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19288, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19289, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19290, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19291, 'EPSG:4326', -180, -58, 180, 85);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19292, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14981, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14870, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14964, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14871, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14995, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14872, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14988, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14873, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14984, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14874, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19293, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14973, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14875, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14972, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14994, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14969, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14997, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18218, 'EPSG:4326', 8.3767600000000009, 51.915599999999998, 8.6878100000000007, 52.116799999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14980, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18218, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14876, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15010, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18219, 'EPSG:4326', 8.3767600000000009, 51.915599999999998, 8.6878100000000007, 52.116799999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18219, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19294, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14976, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14877, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18220, 'EPSG:4326', 8.3767600000000009, 51.915599999999998, 8.6878100000000007, 52.116799999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18220, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14983, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18221, 'EPSG:4326', 8.3767600000000009, 51.915599999999998, 8.6878100000000007, 52.116799999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18221, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14878, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14977, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14853, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18222, 'EPSG:4326', 8.3767600000000009, 51.915599999999998, 8.6878100000000007, 52.116799999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18222, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19295, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14854, 'EPSG:4326', -180, -60, 180, 75);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19296, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18223, 'EPSG:4326', 8.3767600000000009, 51.915599999999998, 8.6878100000000007, 52.116799999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18223, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19297, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18224, 'EPSG:4326', 8.3767600000000009, 51.915599999999998, 8.6878100000000007, 52.116799999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18224, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14974, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14855, 'EPSG:4326', -180, -60, 180, 75);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18225, 'EPSG:4326', 8.3767600000000009, 51.915599999999998, 8.6878100000000007, 52.116799999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18225, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15006, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18226, 'EPSG:4326', 8.3767600000000009, 51.915599999999998, 8.6878100000000007, 52.116799999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18226, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18227, 'EPSG:4326', -180, -4.5267700000000001e+032, 176.99100000000001, 4.5267700000000001e+032);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18227, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19298, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15001, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13775, 'EPSG:4326', -11, 35, 32, 72);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13776, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13777, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19210, 'EPSG:4326', 9.1024741000000002, 47.0828299, 13.978153499999999, 50.610060599999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19210, 'EPSG:31464', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19210, 'EPSG:31468', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19210, 'EPSG:31494', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14258, 'EPSG:4326', 9.1024741000000002, 47.0828299, 13.978153499999999, 50.610060599999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14258, 'EPSG:31464', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14258, 'EPSG:31468', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14258, 'EPSG:31494', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14259, 'EPSG:4326', 9.1024741000000002, 47.0828299, 13.978153499999999, 50.610060599999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14259, 'EPSG:31464', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14259, 'EPSG:31468', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14259, 'EPSG:31494', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14260, 'EPSG:4326', 9.1024741000000002, 47.0828299, 13.978153499999999, 50.610060599999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14260, 'EPSG:31464', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14260, 'EPSG:31468', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14260, 'EPSG:31494', 4280000, 5220000, 4640000, 5610000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14851, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14852, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14856, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19262, 'EPSG:4326', -30, -35, 65, 80);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19264, 'EPSG:4326', -30, -35, 65, 80);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19265, 'EPSG:4326', -30, -35, 65, 80);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19266, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19267, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19268, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19269, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14860, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14861, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14862, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14863, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14864, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14865, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14866, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19275, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19277, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19278, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19279, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18150, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18150, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18150, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19280, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18150, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18150, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18151, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18151, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18151, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19281, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18151, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18151, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19282, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18152, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18152, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18152, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9877, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9878, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9879, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9880, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9881, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9882, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9883, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9884, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9885, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9886, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9887, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9888, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9889, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18152, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18152, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18153, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18153, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18153, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18153, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19284, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18153, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18154, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18154, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2713, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2714, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2715, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2716, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2717, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2718, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2719, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2720, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2721, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2722, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2723, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2724, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2725, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2726, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2727, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2728, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2729, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2730, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2731, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (2732, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10047, 'EPSG:4326', -172.36699999999999, 35.667299999999997, -11.5624, 83.829300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10047, 'EPSG:42304', -2200000, -712631, 3072800, 3840000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10048, 'EPSG:4326', -172.36699999999999, 35.667299999999997, -11.5624, 83.829300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10048, 'EPSG:42304', -2200000, -712631, 3072800, 3840000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10049, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10049, 'EPSG:42304', -2750560, -936638, 3583870, 4673120);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10050, 'EPSG:4326', -173.43299999999999, 41.427100000000003, -13.3643, 83.746600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10050, 'EPSG:42304', -2346800, -67422.399999999994, 2840370, 3830120);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10051, 'EPSG:4326', -179.97300000000001, 35.246400000000001, 179.91999999999999, 88.060000000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10051, 'EPSG:42304', -2750560, -936638, 2758820, 4367270);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10052, 'EPSG:4326', -169.62899999999999, 39.223199999999999, -15.108499999999999, 83.012900000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10052, 'EPSG:42304', -2169400, -386968, 2797470, 3743360);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10053, 'EPSG:4326', -173.53700000000001, 35.877499999999998, -11.9603, 83.800899999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10053, 'EPSG:42304', -2340600, -719746, 3009430, 3836610);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10054, 'EPSG:4326', -179.96000000000001, 34.240900000000003, 178.833, 89.905100000000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10054, 'EPSG:42304', -2693580, -724162, 3385190, 4654500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10055, 'EPSG:4326', -137.447, 37.714599999999997, -46.6233, 66.720100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10055, 'EPSG:42304', -2145720, -680853, 2616060, 1930970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10056, 'EPSG:4326', -148.059, 35.881999999999998, -33.774500000000003, 72.550299999999993);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10056, 'EPSG:42304', -2303690, -724118, 3000530, 2564970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10057, 'EPSG:4326', -172.30099999999999, 36.354100000000003, -12.969799999999999, 83.483199999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10057, 'EPSG:42304', -2303860, -681503, 2961770, 3798860);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10058, 'EPSG:4326', -178.83799999999999, 31.884399999999999, 179.94, 89.825400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10058, 'EPSG:42304', -2750560, -936639, 3583870, 4673120);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19263, 'EPSG:4326', 5.8681999999999999, 50.318899999999999, 8.6518999999999995, 52.505400000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19263, 'EPSG:31492', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18275, 'EPSG:4326', 2738496, 77673, 5821724, 625065);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10194, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10195, 'EPSG:4326', -180, -90, 180, 83.623599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10196, 'EPSG:4326', -122.21081, 31.143339999999998, -71.017359999999996, 43.658859999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10197, 'EPSG:4326', -122.21037, 31.145099999999999, -71.009450000000001, 43.657020000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10198, 'EPSG:4326', -122.78509, 29.082560000000001, -67.454070000000002, 47.529919999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10199, 'EPSG:4326', -179.14474496567601, 17.681049999999999, 179.776672368596, 71.379199999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10200, 'EPSG:4326', -159.78818999999999, 17.674320000000002, -64.561369999999997, 65.453180000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13751, 'EPSG:4326', -140, -80, 170, 80);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13752, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13753, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13754, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (13755, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10159, 'EPSG:4326', -180, 90, 180, -90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10160, 'EPSG:4326', -180, 90, 180, -90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19211, 'EPSG:4326', -177.767, -31.8659, 146.983, 58.921999999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10434, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10434, 'EPSG:4269', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10435, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10435, 'EPSG:4269', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10436, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10436, 'EPSG:4269', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10437, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10437, 'EPSG:4269', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10438, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10438, 'EPSG:4269', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10439, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10439, 'EPSG:4269', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18123, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18123, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18123, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18123, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18124, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18124, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18124, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18124, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18124, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18125, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18125, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18125, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18125, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18125, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18126, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18126, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18126, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18126, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18126, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19286, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18127, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18127, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18127, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18127, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18127, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18128, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19287, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18128, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18128, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18128, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18128, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18129, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18129, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14867, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18129, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18129, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18129, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14868, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (5575, 'EPSG:4326', 5.6007499999999997, 47.244100000000003, 15.425000000000001, 55.031700000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (5575, 'EPSG:31467', 3282450, 5248260, 3912240, 6100130);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (5576, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (5577, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (5578, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19212, 'EPSG:4326', -97.540000000000006, 43.369999999999997, -89.329999999999998, 49.399999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19212, 'EPSG:26915', 170240, 4808960, 766464, 5478912);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14365, 'EPSG:4326', -97.299999999999997, 43.369999999999997, -89.459999999999994, 49.350000000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14365, 'EPSG:26915', 187392, 4808960, 756992, 5472000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14364, 'EPSG:4326', -97.540000000000006, 43.420000000000002, -89.329999999999998, 49.399999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14364, 'EPSG:26915', 170240, 4815872, 766464, 5478912);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14366, 'EPSG:4326', -93.519999999999996, 44.740000000000002, -92.739999999999995, 45.259999999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14366, 'EPSG:26915', 458964, 4954473.5999999996, 520521.59999999998, 5011500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19222, 'EPSG:4326', -94.079999999999998, 44.43, -92.680000000000007, 45.439999999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19222, 'EPSG:26915', 415490.09999999998, 4920146.7000000002, 525138.30000000005, 5032061.7000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19224, 'EPSG:4326', -94.079999999999998, 44.43, -92.680000000000007, 45.439999999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19224, 'EPSG:26915', 415485.29999999999, 4920156.2999999998, 525129.90000000002, 5032059.9000000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19270, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19270, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19270, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19270, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19270, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18146, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18146, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18146, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18146, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18146, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18147, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18147, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18147, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18147, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18147, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18148, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18148, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18148, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18148, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18148, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18149, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18149, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18149, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18149, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18149, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7255, 'EPSG:4326', -117, 8, -82, 36);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7256, 'EPSG:4326', -179.227, -56.510899999999999, 158.80699999999999, 83.674700000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7257, 'EPSG:4326', -117.114, 12.9824, -83.1554, 32.720599999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7258, 'EPSG:4326', -117, 8, -82, 36);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7259, 'EPSG:4326', -117.114, 12.9824, -83.1554, 32.720599999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7260, 'EPSG:4326', -116.911, 13.156499999999999, -83.209199999999996, 32.716999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7261, 'EPSG:4326', -117.05200000000001, 12.988, -83.200000000000003, 32.716999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7262, 'EPSG:4326', -117.069, 13.111499999999999, -85.881200000000007, 32.6601);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7263, 'EPSG:4326', -117.119, 13.003, -83.230900000000005, 32.710999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7264, 'EPSG:4326', -117.02500000000001, 13.2639, -86.137600000000006, 32.658200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7265, 'EPSG:4326', -117.048, 13.0238, -83.225399999999993, 32.6768);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7266, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7267, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14255, 'EPSG:4326', 11.7651, 50.029400000000003, 15.1358, 51.859200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14255, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19214, 'EPSG:4326', 11.7651, 50.029400000000003, 15.1358, 51.859200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19214, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14256, 'EPSG:4326', 11.7651, 50.029400000000003, 15.1358, 51.859200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14256, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19177, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19215, 'EPSG:4326', 11.7651, 50.029400000000003, 15.1358, 51.859200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19215, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19216, 'EPSG:4326', 11.7651, 50.029400000000003, 15.1358, 51.859200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19216, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19217, 'EPSG:4326', 11.7651, 50.029400000000003, 15.1358, 51.859200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19217, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19220, 'EPSG:4326', 11.7651, 50.029400000000003, 15.1358, 51.859200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19220, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19221, 'EPSG:4326', 11.7651, 50.029400000000003, 15.1358, 51.859200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19221, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19223, 'EPSG:4326', 11.7651, 50.029400000000003, 15.1358, 51.859200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19223, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19225, 'EPSG:4326', 11.7651, 50.029400000000003, 15.1358, 51.859200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19225, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19227, 'EPSG:4326', 11.7651, 50.029400000000003, 15.1358, 51.859200000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19227, 'EPSG:31468', 4483820, 5547910, 4716180, 5747080);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19271, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19271, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19271, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19271, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19271, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18120, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18120, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18120, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18120, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18120, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18121, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18121, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18121, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18121, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18121, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18122, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18122, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18122, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18122, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18122, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18123, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19178, 'EPSG:4326', -4810601.5, -5769556, 5262368.5, 4734162.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9891, 'EPSG:4326', -4708082, -4345438, 4051932, 3830884);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9892, 'EPSG:4326', -4078050, -4399070, 3433950, 3816930);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9893, 'EPSG:4326', -4708264.5, -4339414.5, 4114750.2000000002, 3834475.2000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9894, 'EPSG:4326', -4810601.5, -5769556, 5262368.5, 4734162.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9895, 'EPSG:4326', -3975499.7999999998, -4345500, 3968500.2000000002, 3597500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9896, 'EPSG:4326', -3929000, -4332000, 3363000, 3556000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9897, 'EPSG:4326', -3918171.7999999998, -4332588, 3959946.2000000002, 3834456.2000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9898, 'EPSG:4326', -3887826.5, -4329412.5, 3945989.2000000002, 3835184);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9899, 'EPSG:4326', -3801453.2000000002, -3784234.5, 3316692.7999999998, 3681196.7999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (9900, 'EPSG:4326', -3903968.5, -4243231, 3930238.7999999998, 3771816);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19218, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19218, 'EPSG:31468', 4500038.056252609, -10000959.949100513, 4500018.6561646834, 10000963.64770234);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14288, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14289, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14290, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14291, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14292, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14293, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14294, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14295, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14296, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19272, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19272, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19272, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19272, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19272, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18133, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18133, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18133, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18133, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18133, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18134, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18134, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18134, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19179, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19179, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19179, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19179, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19179, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19180, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19180, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19180, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19180, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19180, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19181, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19181, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19181, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19181, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19181, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19182, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19182, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19182, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19182, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19182, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19183, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19183, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19183, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19183, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19183, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19184, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19184, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19184, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19184, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19184, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19185, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19185, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19185, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19185, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19185, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19186, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19186, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19186, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19186, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19186, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19187, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19187, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19187, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19187, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19187, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19188, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19188, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19188, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19188, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19188, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19189, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19189, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19189, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19189, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19189, 'EPSG:25833', 832015.48999999999, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19219, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10166, 'EPSG:4326', -180, -60, 180, 84);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10167, 'EPSG:4326', -180, -60, 180, 84);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10168, 'EPSG:4326', -127, 23, -66, 50);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19229, 'EPSG:4326', -180, -55, 180, 60);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19230, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19231, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19232, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19234, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10171, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10172, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19240, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10173, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10174, 'EPSG:4326', -180, -80, 180, 80);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10175, 'EPSG:4326', -180, -80, 180, 80);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10176, 'EPSG:4326', -180, -80, 180, 80);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10177, 'EPSG:4326', -125, 24, -66, 50);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10178, 'EPSG:4326', -127, 23, -66, 50);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10179, 'EPSG:4326', -127, 23, -66, 50);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19274, 'EPSG:4326', -168.66999999999999, 17.84, -65.150000000000006, 71.549999999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26905', 552600, 6540200, 670200, 6794800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26906', 332200, 6653000, 440600, 6822600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26910', 364600, 3751400, 777800, 5433600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26911', 189600, 3564600, 783400, 5432200);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26912', 216600, 3463800, 784600, 5436200);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26913', 215400, 3201800, 790600, 5437600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26914', 204400, 2855400, 794000, 5436400);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26915', 206000, 3162400, 792400, 5478800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26916', 207800, 3196000, 789600, 5345400);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26917', 210200, 2709400, 778200, 5112800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26918', 222000, 3744800, 753000, 4992000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26919', 247200, 1976600, 818200, 5247600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14804, 'EPSG:26920', 181800, 1985200, 269400, 2048600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18137, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18137, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18137, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18138, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18138, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18138, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18138, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18138, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18139, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18139, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18139, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18139, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18139, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26904', 366800, 2170400, 816000, 2460400);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26905', 178000, 2086800, 317600, 2307600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26910', 359600, 3745600, 776800, 5432800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26911', 218000, 3569200, 783600, 5432800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26912', 216000, 3455600, 785200, 5432800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26913', 214800, 3204800, 791200, 5432800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26914', 208800, 2847200, 795200, 5432800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26915', 205200, 3154000, 792800, 5473200);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18140, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18140, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26916', 207200, 3194400, 790800, 5350800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18140, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26917', 209600, 2708000, 778800, 5113600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19190, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19190, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19190, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19190, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19190, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3385, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3385, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3385, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3385, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3385, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3386, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3386, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3386, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3386, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3386, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3387, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3387, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3387, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3387, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3387, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3388, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3388, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3388, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3388, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3388, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3393, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3393, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3393, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3393, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3393, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19191, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19191, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19191, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19191, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19191, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19192, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19192, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19192, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19192, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19192, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19193, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19193, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19193, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19193, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19193, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19194, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19194, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19194, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19194, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19194, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19195, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19195, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19195, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19195, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19195, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19196, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19196, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19196, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19196, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19196, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3391, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3391, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3391, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3391, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (3391, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19197, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19197, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19197, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19197, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19197, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19198, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19198, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19198, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19198, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19198, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19199, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19199, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19199, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19199, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19199, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19200, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19200, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19200, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19200, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19200, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19201, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19201, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19201, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19201, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19201, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19202, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19202, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19202, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19202, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19202, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19203, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19203, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19203, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19203, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19203, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19204, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19204, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19204, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19204, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19204, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19205, 'EPSG:4326', 5.6529638599999998, 50.312478050000003, 9.6160663399999997, 52.542589460000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19205, 'EPSG:31466', 2475321.1099999999, 5575227.3090000004, 2745328.6069999998, 5829431.9620000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19205, 'EPSG:31467', 3261687.6120000002, 5580528.4699999997, 3541868.6290000002, 5823459.9869999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19205, 'EPSG:31468', 4048175.5550000002, 5594462.9409999996, 4338378.7879999997, 5825949.4239999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19205, 'EPSG:31469', 4834899.6880000001, 5617086.0539999995, 5135004.608, 5836908.6359999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19226, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19226, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14265, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14265, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14266, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14266, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14268, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14268, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14270, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14270, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14271, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14271, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14269, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14269, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14267, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14267, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14272, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14272, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14273, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14273, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14275, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14275, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14276, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14276, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14274, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14274, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19235, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19235, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19236, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19236, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19237, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19237, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19238, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19238, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19239, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19239, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19241, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19241, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19242, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19242, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19243, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19243, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19244, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19244, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19245, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19245, 'EPSG:31468', 4491000, 5559498, 4712373, 5728178);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19273, 'EPSG:4326', -180, -90.008330000000001, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14935, 'EPSG:4326', -180, -90.008330000000001, 180, 84);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14936, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14937, 'EPSG:4326', -180, -90, 180, 83.623599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14938, 'EPSG:4326', -125.12332000000001, -16.606266000000002, 109.965, 67.046936000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14939, 'EPSG:4326', -164.88744, -36.969444000000003, 160.7636, 71.392489999999995);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14940, 'EPSG:4326', -180, -90, 180, 83.623599999999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14941, 'EPSG:4326', -178.2176, 18.921785, -66.969269999999995, 71.406234999999995);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14942, 'EPSG:4326', -176.15156999999999, -54.792000000000002, 179.22190000000001, 78.200000000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14943, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19283, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14894, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14944, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14895, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14945, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14946, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14896, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14947, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14897, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14948, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14898, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14949, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14899, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14900, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18131, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18131, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7517, 'EPSG:4326', -141, 41, -52, 78);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7518, 'EPSG:4326', -141.238, 41.671799999999998, -52.667000000000002, 78.105900000000005);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7519, 'EPSG:4326', -137.517, 42.031700000000001, -52.700000000000003, 65.278400000000005);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7520, 'EPSG:4326', -137.745, 41.926499999999997, -52.540700000000001, 65.390000000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7521, 'EPSG:4326', -99.961600000000004, 40.414299999999997, -66.443100000000001, 50.5366);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7522, 'EPSG:4326', -137.09999999999999, 42.466700000000003, -52.700000000000003, 62.909999999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7523, 'EPSG:4326', -95.292599999999993, 41.629600000000003, -74.235500000000002, 56.922499999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7524, 'EPSG:4326', -95.292599999999993, 41.629600000000003, -74.235500000000002, 56.922499999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7525, 'EPSG:4326', -96, 41.528599999999997, -73.707499999999996, 57.732900000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7526, 'EPSG:4326', -94.989699999999999, 43.285800000000002, -74.754999999999995, 51.709499999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (7527, 'EPSG:4326', -140.952, 42.098599999999998, -52.818399999999997, 68.085599999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19228, 'EPSG:4326', -75.884841873300005, 38.374105834600002, -74.991050618100004, 39.875112621299998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19228, 'EPSG:102257', 166499.875, 50000.125, 232799.875, 204700.125);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14759, 'EPSG:4326', -75.808075973399994, 38.449822322999999, -75.033438778100006, 39.843288729400001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14759, 'EPSG:102257', 166499.874927962, 50000.124927962199, 321199.87492796202, 204700.124927962);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19110, 'EPSG:4326', 10.859400000000001, 51.196599999999997, 15.0908, 53.662700000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19110, 'EPSG:25833', 3226000, 5679000, 3506000, 5946000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19111, 'EPSG:4326', 11.2317, 51.309899999999999, 14.765599999999999, 53.563899999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19111, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19112, 'EPSG:4326', 11.252000000000001, 51.315899999999999, 14.7666, 53.533700000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19112, 'EPSG:25833', 3251290, 5691010, 3483750, 5931680);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19113, 'EPSG:4326', 11.2461, 51.320599999999999, 14.762499999999999, 53.5473);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19113, 'EPSG:25833', 3250980, 5691540, 3483470, 5933190);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19114, 'EPSG:4326', 11.2461, 51.320599999999999, 14.762499999999999, 53.5473);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19114, 'EPSG:25833', 3250980, 5691540, 3483470, 5933190);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19115, 'EPSG:4326', 11.2461, 51.320599999999999, 14.762499999999999, 53.5473);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19115, 'EPSG:25833', 3250980, 5691540, 3483470, 5933190);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19116, 'EPSG:4326', 11.2394, 51.321199999999997, 14.7654, 53.525399999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19116, 'EPSG:25833', 3250400, 5691640, 3483670, 5930750);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26918', 217200, 3736400, 754000, 4997600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14805, 'EPSG:26919', 246800, 4540800, 669200, 5261600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19117, 'EPSG:4326', 11.231999999999999, 51.330199999999998, 14.759, 53.560699999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19117, 'EPSG:25833', 3250120, 5692660, 3483230, 5934670);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19118, 'EPSG:4326', 11.6416, 51.333599999999997, 14.736000000000001, 53.488199999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19118, 'EPSG:25833', 3276960, 5691790, 3481630, 5926610);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18142, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18142, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19119, 'EPSG:4326', 11.2393, 51.3127, 14.764099999999999, 53.5593);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19119, 'EPSG:25833', 3250600, 5690680, 3483580, 5934520);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19120, 'EPSG:4326', 11.3238, 51.3172, 14.754799999999999, 53.563200000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19120, 'EPSG:25833', 3256240, 5690920, 3482930, 5934960);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26906', 332200, 6653000, 440600, 6822600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26910', 364600, 3751400, 777800, 5433600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26911', 189600, 3564600, 783400, 5432200);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26912', 216600, 3463800, 784600, 5436200);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26913', 215400, 3201800, 790600, 5437600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26914', 204400, 2855400, 794000, 5436400);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26915', 206000, 3162400, 792400, 5478800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26916', 207800, 3196000, 789600, 5345400);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19121, 'EPSG:4326', 11.245900000000001, 51.358499999999999, 14.7403, 53.496499999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19121, 'EPSG:25833', 3250670, 5695780, 3481940, 5927540);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26917', 210200, 2709400, 778200, 5112800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26918', 222000, 3744800, 753000, 4992000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14806, 'EPSG:26919', 247200, 1976600, 818200, 5247600);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19122, 'EPSG:4326', 11.9598, 51.332599999999999, 14.7545, 53.5259);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18131, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19122, 'EPSG:25833', 3298310, 5690790, 3482910, 5930810);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18131, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19123, 'EPSG:4326', 11.231999999999999, 51.330199999999998, 14.759, 53.560699999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19123, 'EPSG:25833', 3250120, 5692660, 3483230, 5934670);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14901, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19124, 'EPSG:4326', 11.2317, 51.309899999999999, 14.765599999999999, 53.563899999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19124, 'EPSG:25833', 3250120, 5690400, 3483680, 5935030);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14902, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14903, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14904, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14905, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14906, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14907, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14908, 'EPSG:4326', 79.748800000000003, 5.5360699999999996, 95.377200000000002, 13.342599999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14909, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14910, 'EPSG:4326', 72.893900000000002, -0.68999999999999995, 98.777000000000001, 13.021100000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14911, 'EPSG:4326', -173.83000000000001, -19.100000000000001, 167.75999999999999, 53.280000000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14912, 'EPSG:4326', 95.849999999999994, 3.3199999999999998, 95.849999999999994, 3.3199999999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14913, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14914, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14915, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14916, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14917, 'EPSG:4326', 63.107999999999997, -13.8714, 95.438800000000001, 15.632);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14918, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14919, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14920, 'EPSG:4326', 29.5869, -11.740399999999999, 141.00700000000001, 35.505600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14921, 'EPSG:4326', 29.5869, -11.740399999999999, 141.00700000000001, 35.505600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14922, 'EPSG:4326', 29.5869, -11.740399999999999, 141.00700000000001, 35.505600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18228, 'EPSG:4326', -180, -4.5267700000000001e+032, 176.99100000000001, 4.5267700000000001e+032);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14923, 'EPSG:4326', 29.5869, -11.740399999999999, 141.00700000000001, 35.505600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18228, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18229, 'EPSG:4326', 8.3767600000000009, 51.915599999999998, 8.6878100000000007, 52.116799999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18229, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19299, 'EPSG:4326', -180, -56, 180, 60.417999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14966, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18230, 'EPSG:4326', -180, -4.5267700000000001e+032, 176.99100000000001, 4.5267700000000001e+032);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10106, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10106, 'EPSG:26915', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10107, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10107, 'EPSG:26915', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10108, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10108, 'EPSG:26915', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10109, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10109, 'EPSG:26915', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10110, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10110, 'EPSG:26915', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19276, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15004, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14965, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14967, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14971, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15005, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14998, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19285, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10370, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19206, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19206, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19206, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19206, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19172, 'EPSG:4326', 5.8799999999999999, 46.621299999999998, 15, 55.718699999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19173, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19174, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19175, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19206, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10989, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10989, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10989, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10989, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10989, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10990, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10990, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10990, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10990, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10990, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19246, 'EPSG:4326', -3.2623000000000002, 41.850900000000003, -1.5416000000000001, 42.747300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19246, 'EPSG:23030', 478621.4999, 4634401.5, 619671.50009999995, 4733511.3584000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19246, 'EPSG:25830', 478517.3309, 4634188.7847999996, 619566.80810000002, 4733298.3071999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10153, 'EPSG:4326', -180, 90, 180, -90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10154, 'EPSG:4326', -180, 90, 180, -90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10155, 'EPSG:4326', -82, 48, -65, 20);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10156, 'EPSG:4326', -71, 46, -63, 39);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10157, 'EPSG:4326', -71.333299999999994, 42.167499999999997, -70.332499999999996, 41.166699999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10158, 'EPSG:4326', -71, 46, -63, 39);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10370, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10370, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10370, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10370, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10371, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10371, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10371, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10371, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10371, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19247, 'EPSG:4326', -3.2623000000000002, 41.850900000000003, -1.5416000000000001, 42.747300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19247, 'EPSG:23030', 478621.4999, 4634401.5, 619671.50009999995, 4733511.3584000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19247, 'EPSG:25830', 478517.3309, 4634188.7847999996, 619566.80810000002, 4733298.3071999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19248, 'EPSG:4326', -3.2623000000000002, 41.850900000000003, -1.5416000000000001, 42.747300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19248, 'EPSG:23030', 478621.4999, 4634401.5, 619671.50009999995, 4733511.3584000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19248, 'EPSG:25830', 478517.3309, 4634188.7847999996, 619566.80810000002, 4733298.3071999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19249, 'EPSG:4326', -3.2623000000000002, 41.850900000000003, -1.5416000000000001, 42.747300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19249, 'EPSG:23030', 478621.4999, 4634401.5, 619671.50009999995, 4733511.3584000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19249, 'EPSG:25830', 478517.3309, 4634188.7847999996, 619566.80810000002, 4733298.3071999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19250, 'EPSG:4326', -3.2623000000000002, 41.850900000000003, -1.5416000000000001, 42.747300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19250, 'EPSG:23030', 478621.4999, 4634401.5, 619671.50009999995, 4733511.3584000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19250, 'EPSG:25830', 478517.3309, 4634188.7847999996, 619566.80810000002, 4733298.3071999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19252, 'EPSG:4326', -3.2623000000000002, 41.850900000000003, -1.5416000000000001, 42.747300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19252, 'EPSG:23030', 478621.4999, 4634401.5, 619671.50009999995, 4733511.3584000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19252, 'EPSG:25830', 478517.3309, 4634188.7847999996, 619566.80810000002, 4733298.3071999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19254, 'EPSG:4326', -3.2623000000000002, 41.850900000000003, -1.5416000000000001, 42.747300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19254, 'EPSG:23030', 478621.4999, 4634401.5, 619671.50009999995, 4733511.3584000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19254, 'EPSG:25830', 478517.3309, 4634188.7847999996, 619566.80810000002, 4733298.3071999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19255, 'EPSG:4326', -3.2623000000000002, 41.850900000000003, -1.5416000000000001, 42.747300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19255, 'EPSG:23030', 478621.4999, 4634401.5, 619671.50009999995, 4733511.3584000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19255, 'EPSG:25830', 478517.3309, 4634188.7847999996, 619566.80810000002, 4733298.3071999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19256, 'EPSG:4326', -3.2623000000000002, 41.850900000000003, -1.5416000000000001, 42.747300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19256, 'EPSG:23030', 478621.4999, 4634401.5, 619671.50009999995, 4733511.3584000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19256, 'EPSG:25830', 478517.3309, 4634188.7847999996, 619566.80810000002, 4733298.3071999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19257, 'EPSG:4326', -3.2623000000000002, 41.850900000000003, -1.5416000000000001, 42.747300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19257, 'EPSG:23030', 478621.4999, 4634401.5, 619671.50009999995, 4733511.3584000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19257, 'EPSG:25830', 478517.3309, 4634188.7847999996, 619566.80810000002, 4733298.3071999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18140, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18140, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18141, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18141, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18141, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18141, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18141, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18142, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18142, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18142, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19207, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19207, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19207, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19207, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19207, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10992, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10992, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10992, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10992, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10992, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10993, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10993, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10993, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10993, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10993, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10994, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10994, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10994, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10994, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19006, 'EPSG:4326', 5.6007499999999997, 47.244100000000003, 15.425000000000001, 55.031700000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19006, 'EPSG:31467', 3282450, 5248260, 3912240, 6100130);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19007, 'EPSG:4326', 5.8656300000000003, 47.275799999999997, 15, 55.055599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19008, 'EPSG:4326', 5.8656300000000003, 47.275799999999997, 15, 55.055599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19009, 'EPSG:4326', 5.8641699999999997, 47.274700000000003, 15.0389, 55.056699999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19010, 'EPSG:4326', 6.0522299999999998, 47.482500000000002, 14.998100000000001, 54.9405);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19011, 'EPSG:4326', 5.8662900000000002, 47.273600000000002, 15.0486, 55.058300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19012, 'EPSG:4326', 5.9825900000000001, 47.406399999999998, 15, 54.904499999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10994, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10995, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10995, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10995, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10995, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10995, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19251, 'EPSG:4326', -180, 15, -60, 70);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14558, 'EPSG:4326', -168.00280000000001, 13.16666, 145.84165999999999, 70.749740000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14559, 'EPSG:4326', -168.002790909091, 13.1666636363636, 145.84166363636399, 70.749745454545504);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14560, 'EPSG:4326', -168.00279, 13.166667, 145.841667, 70.749747999999997);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18134, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18134, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18135, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18135, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18135, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18135, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18135, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18136, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18136, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18136, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18136, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18136, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19013, 'EPSG:4326', 5.9519200000000003, 47.2864, 14.975899999999999, 54.910699999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19014, 'EPSG:4326', 5.9050799999999999, 47.313600000000001, 14.998100000000001, 55.015700000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19015, 'EPSG:4326', 6.0166700000000004, 47.399999999999999, 15, 54.899999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19016, 'EPSG:4326', 5.8662900000000002, 47.273600000000002, 15.0486, 55.058300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19017, 'EPSG:4326', 6.0166700000000004, 47.399999999999999, 15, 54.899999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19018, 'EPSG:4326', 5.8641699999999997, 47.274700000000003, 15.0389, 55.056699999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18137, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18137, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15337, 'EPSG:4326', 7, 42, 12, 59);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15338, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15339, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19208, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19208, 'EPSG:31492', 2490669.8999999999, 5576388.9000000004, 2738505.3522109799, 5825350.1160288397);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19208, 'EPSG:31466', 2490669.8999999999, 5576388.9000000004, 2738505.3522109799, 5825350.1160288397);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19208, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19208, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:31462', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:31492', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:25831', 691515.46999999997, 5541873.3499999996, 981462.09999999998, 5870966.6200000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:25833', -167984.51000000001, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:31462', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:31492', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:25831', 691515.46999999997, 5541873.3499999996, 981462.09999999998, 5870966.6200000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:25833', -167984.51000000001, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19208, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11630, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11630, 'EPSG:31492', 2490669.8999999999, 5576388.9000000004, 2738505.3522109799, 5825350.1160288397);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11630, 'EPSG:31466', 2490669.8999999999, 5576388.9000000004, 2738505.3522109799, 5825350.1160288397);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11630, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11630, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (11630, 'EPSG:25833', -149462, 5580271.6100000003, 127822, 5858091.8799999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10415, 'EPSG:4326', -91.5, 22, -71.5, 36.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10415, 'EPSG:4269', -91.5, 22, -71.5, 36.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19258, 'EPSG:4326', -100, 0, -60, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19258, 'EPSG:4269', -100, 0, -60, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19259, 'EPSG:4326', -100, 0, -60, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19259, 'EPSG:4269', -100, 0, -60, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10416, 'EPSG:4326', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10416, 'EPSG:4269', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10417, 'EPSG:4326', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10417, 'EPSG:4269', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10418, 'EPSG:4326', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10418, 'EPSG:4269', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10419, 'EPSG:4326', -78, 34, -74, 40);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10419, 'EPSG:4269', -78, 34, -74, 40);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10420, 'EPSG:4326', -83, 24.399999999999999, -80.400000000000006, 26.199999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10420, 'EPSG:4269', -83, 24.399999999999999, -80.400000000000006, 26.199999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10421, 'EPSG:4326', -94.5, 28, -87, 31);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10421, 'EPSG:4269', -94.5, 28, -87, 31);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10422, 'EPSG:4326', -84.5, 27.5, -82.5, 30.199999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10422, 'EPSG:4269', -84.5, 27.5, -82.5, 30.199999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10423, 'EPSG:4326', -83.5, 26.199999999999999, -81.700000000000003, 28.399999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10423, 'EPSG:4269', -83.5, 26.199999999999999, -81.700000000000003, 28.399999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10424, 'EPSG:4326', -98, 8, -59, 40);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10424, 'EPSG:4269', -98, 8, -59, 40);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10425, 'EPSG:4326', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10425, 'EPSG:4269', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10426, 'EPSG:4326', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10426, 'EPSG:4269', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10427, 'EPSG:4326', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10427, 'EPSG:4269', -125, -5, -45, 55);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10428, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10428, 'EPSG:4269', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10429, 'EPSG:4326', -96.829999999999998, 24.699999999999999, -79.900000000000006, 37.420000000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10429, 'EPSG:4269', -96.829999999999998, 24.699999999999999, -79.900000000000006, 37.420000000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10430, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10430, 'EPSG:4269', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10431, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10431, 'EPSG:4269', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10432, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10432, 'EPSG:4269', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10433, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (10433, 'EPSG:4269', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18230, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18231, 'EPSG:4326', -180, -4.5267700000000001e+032, 176.99100000000001, 4.5267700000000001e+032);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18231, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18232, 'EPSG:4326', 8.3767600000000009, 51.915599999999998, 8.6878100000000007, 52.116799999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18232, 'EPSG:31467', 3457310, 5753550, 3478520, 5775790);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18233, 'EPSG:4326', -180, -4.5267700000000001e+032, 176.99100000000001, 4.5267700000000001e+032);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18233, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18234, 'EPSG:4326', -180, -4.5267700000000001e+032, 176.99100000000001, 4.5267700000000001e+032);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18234, 'EPSG:31467', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14924, 'EPSG:4326', 29.5869, -11.740399999999999, 141.00700000000001, 35.505600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14925, 'EPSG:4326', 29.5869, -11.740399999999999, 141.00700000000001, 35.505600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14926, 'EPSG:4326', 79.652900000000002, 5.91683, 81.881299999999996, 9.8313600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14927, 'EPSG:4326', 79.652900000000002, 5.91683, 81.881299999999996, 9.8313600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14928, 'EPSG:4326', 79.652900000000002, 5.91683, 81.881299999999996, 9.8313600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14929, 'EPSG:4326', 79.652900000000002, 5.91683, 81.881299999999996, 9.8313600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14930, 'EPSG:4326', 79.652900000000002, 5.91683, 81.881299999999996, 9.8313600000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14931, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14932, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14933, 'EPSG:4326', 21.0123, -34.409199999999998, 133.25299999999999, 49.659599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14970, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14978, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14990, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14999, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14986, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15000, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14985, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14987, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14975, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14989, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15003, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14992, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14979, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19300, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19301, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14996, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15007, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15009, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14982, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14879, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14880, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14881, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14882, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14883, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14884, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14885, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14886, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14887, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14888, 'EPSG:4326', -25, -40, 60, 40);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14889, 'EPSG:4326', -25, -40, 60, 40);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14890, 'EPSG:4326', -25.616, -37.420400000000001, 60.4559, 37.349600000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14891, 'EPSG:4326', -25.616, -37.420400000000001, 60.4559, 37.349600000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14892, 'EPSG:4326', -25.616, -37.420400000000001, 60.4559, 37.349600000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (14893, 'EPSG:4326', -25.616, -37.420400000000001, 60.4559, 37.349600000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19302, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19303, 'EPSG:4326', 107.669, 30.080300000000001, 111.788, 31.800000000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19304, 'EPSG:4326', 107.669, 30.080300000000001, 111.788, 31.800000000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19305, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19306, 'EPSG:4326', 107.669, 30.080300000000001, 111.788, 31.800000000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19307, 'EPSG:4326', 107.669, 30.080300000000001, 111.788, 31.800000000000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19308, 'EPSG:4326', -180, -89.999999999992468, 179.99999999998494, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19309, 'none', 313999.99999999994, 6256000, 314999.99999999994, 6257000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19310, 'EPSG:4326', -155.35833333333434, 7.1755712121246376, -44.633333333338967, 66.141666666667632);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19311, 'EPSG:4326', -180, -89.999999999992468, 179.99999999998494, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19312, 'EPSG:4326', -117.15745945683787, 32.694867249290432, -117.14180304768071, 32.708001820082657);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19312, 'EPSG:26911', 485242.52235471504, 3617471.676763834, 486707.93851865374, 3618925.6443639919);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19313, 'EPSG:4326', -117.16234591954237, 32.700326041666926, -117.13433511844829, 32.720791167681533);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19313, 'EPSG:26911', 484786.71950667776, 3618077.499133341, 487408.72193219373, 3620342.499133341);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19314, 'EPSG:4326', -117.16049999090751, 32.700814178128681, -117.13851029053757, 32.71927880118303);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19314, 'EPSG:26911', 484959.44720383431, 3618131.3487617401, 487017.45093544538, 3620175.3487617401);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19315, 'EPSG:4326', -117.15131695999575, 32.704722665049502, -117.14940643447164, 32.70634639769159);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19315, 'EPSG:26911', 485817.95316164225, 3618563.3629860291, 485996.76273262367, 3618743.1087327749);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19316, 'EPSG:4326', -117.15111930337908, 32.715645195645031, -117.13596562589053, 32.727958130030281);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19316, 'EPSG:26911', 485839.89132843388, 3619774.1525449031, 487258.06913956191, 3621137.1885699364);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19317, 'EPSG:4326', -117.15111930337908, 32.715645195645031, -117.13596562589053, 32.727958130030281);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19317, 'EPSG:26911', 485839.89132843388, 3619774.1525449022, 487258.06913956191, 3621137.1885699355);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19318, 'EPSG:4326', -117.15111930337908, 32.715645195645031, -117.13596562589053, 32.727958130030281);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19318, 'EPSG:26911', 485839.89132843388, 3619774.1525449022, 487258.06913956191, 3621137.1885699355);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19319, 'none', 313999.99999999994, 6256000, 314999.99999999994, 6257000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19320, 'EPSG:4326', -15.516222892279139, 48.547566767877612, 5.1966717340961956, 62.309262015392946);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19321, 'EPSG:4326', -9.4307216236642208, 49.766492520216985, 3.5824420393407923, 61.302099976479312);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19321, 'EPSG:27700', 31.57408349035541, -37.5, 700006.57408349041, 1268962.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19322, 'EPSG:4326', -15.516222892279139, 48.547566767877612, 5.1966717340961956, 62.309262015392946);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19322, 'EPSG:27700', -312469.46946416295, -105151.70653074142, 774980.53053583705, 1381198.2934692586);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19323, 'none', 0, -16920, 9333, 0);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19324, 'EPSG:4326', -9.4307216236642208, 49.766490256102166, 3.5821545967096924, 61.302335092824933);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19324, 'EPSG:27700', -134781.89673206198, -14838.41120336618, 801993.1372231741, 1291619.3334667052);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19325, 'EPSG:4326', -9.4307216236642208, 49.766492520216985, 3.5824420393407923, 61.302099976479312);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19325, 'EPSG:27700', 31.57408349035541, -37.5, 700006.57408349041, 1268962.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19326, 'EPSG:4326', -15.516222892279139, 48.547566767877612, 5.1966717340961956, 62.309262015392946);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19326, 'EPSG:27700', -312469.46946416295, -105151.70653074142, 774980.53053583705, 1381198.2934692586);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19327, 'none', 0, -16920, 9333, 0);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19328, 'EPSG:4326', -9.4307216236642208, 49.766490256102166, 3.5821545967096924, 61.302335092824933);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19328, 'EPSG:27700', -134781.89673206198, -14838.41120336618, 801993.1372231741, 1291619.3334667052);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19329, 'EPSG:4326', -180, -89.999999999992468, 179.99999999998494, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19330, 'EPSG:4326', -155.35833333333434, 7.1755712121246376, -44.633333333338967, 66.141666666667632);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19331, 'EPSG:4326', -180, -89.999999999992468, 179.99999999998494, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19332, 'EPSG:4326', -12.208553864986046, 49.224585375217444, 5.6857963568288348, 69.655165068223994);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19333, 'EPSG:4326', -1.0766050274525021, 51.29488400215515, 2.4888540683086222, 53.2662972653102);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19333, 'EPSG:27700', 464375, 163875, 699975, 374800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19334, 'EPSG:4326', -1.4970028950809673, 50.264044408751047, 2.0343309498738851, 52.226913553359296);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19334, 'EPSG:27700', 435900, 47625, 676025, 258875);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19335, 'EPSG:4326', -1.6310374587394187, 53.514452058790113, 2.2345885036219277, 55.50196905319163);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19335, 'EPSG:27700', 424525, 409575, 668000, 623200);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19336, 'EPSG:4326', -2.267446250413462, 52.107483956119658, 1.4425499338053795, 54.080674754374996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19336, 'EPSG:27700', 382600, 250575, 625550, 464975);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19337, 'EPSG:4326', -2.8761450740407817, 50.713605576777908, 0.71695291815851092, 52.67306643539991);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19337, 'EPSG:27700', 340850, 93675, 583925, 308375);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19338, 'EPSG:4326', -3.4484527622252688, 49.883995009410683, -0.0026577383759644807, 51.256357579248871);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19338, 'EPSG:27700', 299000, 0, 539525, 150800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19339, 'EPSG:4326', -3.1236528826412147, 53.511174626470392, 0.75709233519501407, 55.4962715260978);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19339, 'EPSG:27700', 329100, 404825, 574400, 622500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19340, 'EPSG:4326', -3.8017109441751096, 52.11131426377333, -0.050073759271810424, 54.084492042258674);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19340, 'EPSG:27700', 282200, 247525, 527700, 465400);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19341, 'EPSG:4326', -4.407621169976756, 50.70390929369298, -0.77665068283297389, 52.687895051093335);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19341, 'EPSG:27700', 237275, 91900, 482800, 310025);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19342, 'EPSG:4326', -4.9855484790087363, 49.863954309666369, -1.469145051467871, 51.278383010052188);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19342, 'EPSG:27700', 191700, 0, 437125, 153250);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19343, 'EPSG:4326', -2.88358327382082, 57.297704383170547, -0.7406081517592481, 58.314370405041785);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19343, 'EPSG:27700', 348325, 823675, 473900, 936200);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19344, 'EPSG:4326', -3.2781805334075829, 56.559236567474308, -1.1685474747820073, 57.579425541058846);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19344, 'EPSG:27700', 323650, 741500, 449825, 854375);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19345, 'EPSG:4326', -4.0317532878178151, 54.916640633088861, 0.029330008158417003, 56.916494181083429);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19345, 'EPSG:27700', 276350, 559700, 523700, 780575);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19346, 'EPSG:4326', -4.7179330316334189, 53.50325719423558, -0.79410551654531858, 55.519193965738182);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19346, 'EPSG:27700', 228375, 403850, 476250, 625050);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19347, 'EPSG:4326', -5.3635536363325187, 52.079779499604655, -1.571282495318445, 54.113021155283946);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19347, 'EPSG:27700', 180000, 247250, 428125, 468575);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19348, 'EPSG:4326', -5.9697014502388157, 50.671951882285136, -2.2893656513142906, 52.726183422079977);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19348, 'EPSG:27700', 131650, 92700, 379675, 314325);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19349, 'EPSG:4326', -6.5522401974058431, 49.815972255951486, -2.970388031426813, 51.316158833501142);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19349, 'EPSG:27700', 82325, 0, 330400, 157925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19350, 'EPSG:4326', -2.9145727952570244, 60.074261962635227, -0.53419806289013183, 61.109200513830693);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19350, 'EPSG:27700', 350800, 1133025, 479125, 1247450);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19351, 'EPSG:4326', -1.3572200463839352, 59.83301653542938, 1.0486192655651267, 60.893234831139587);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19351, 'EPSG:27700', 436100, 1109000, 565675, 1223575);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19352, 'EPSG:4326', -4.9358927427533983, 56.287868000728601, -0.67500917980739594, 58.335023765173737);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19352, 'EPSG:27700', 228050, 714075, 477700, 938500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19353, 'EPSG:4326', -5.7446417241606547, 54.871609491953222, -1.640061657641751, 56.940748396219945);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19353, 'EPSG:27700', 171975, 558775, 422000, 783275);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19354, 'EPSG:4326', -6.4206772293509662, 53.465242963940661, -2.4367843864652015, 55.556753989211302);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19354, 'EPSG:27700', 120775, 404750, 371150, 629325);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19355, 'EPSG:4326', -3.0478198560520551, 59.683148893217684, -0.69146350641992294, 60.735284281982665);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19355, 'EPSG:27700', 342950, 1089300, 471475, 1205800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19356, 'EPSG:4326', -5.762257924992622, 57.64281744375274, -1.2791886559084573, 59.738618691391693);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19356, 'EPSG:27700', 188325, 866975, 440625, 1094800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19357, 'EPSG:4326', -6.5242895927856548, 56.249291207634371, -2.207340268882434, 58.369417566801964);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19357, 'EPSG:27700', 134950, 714550, 387275, 942350);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19358, 'EPSG:4326', -7.2478752073138608, 54.837005422443134, -3.0483803112320285, 56.982803833488717);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19358, 'EPSG:27700', 80425, 560500, 332925, 788500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19359, 'EPSG:4326', -8.1136494503563465, 53.381239402646351, -3.6021987961225896, 55.636303933331284);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19359, 'EPSG:27700', 14100, 402875, 293850, 639375);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19360, 'EPSG:4326', -8.2253578293737775, 56.208129279744746, -3.7844626340140932, 58.409355666117449);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19360, 'EPSG:27700', 35225, 717325, 289775, 948325);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19361, 'EPSG:4326', -8.9396772883118842, 54.802994376437994, -4.669461741668318, 57.021141216035097);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19361, 'EPSG:27700', -22650, 565225, 229150, 795750);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19362, 'EPSG:4326', -9.614743913251818, 53.396582079457907, -5.4559308215434745, 55.634905481926658);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19362, 'EPSG:27700', -81025, 413325, 171250, 643925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19363, 'EPSG:4326', -7.6848897444680491, 57.701528443648229, -5.3059289502666589, 58.85518887077059);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19363, 'EPSG:27700', 71600, 881350, 203525, 1001425);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19364, 'EPSG:4326', -9.735121900725078, 56.178687976407723, -5.2186897693953593, 58.448475035446741);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19364, 'EPSG:27700', -53200, 722525, 201225, 956175);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19365, 'EPSG:4326', -1.0766095474041213, 51.294659841507155, 2.4888540683086222, 53.2662972653102);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19365, 'EPSG:27700', 464375, 163850, 699975, 374800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19366, 'EPSG:4326', -1.4970028950809673, 50.264032734298141, 2.0346954925524301, 52.226913553359296);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19366, 'EPSG:27700', 435900, 47625, 676050, 258875);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19367, 'EPSG:4326', -1.6310394140846312, 53.51421517686282, 2.2349824587562748, 55.50196905319163);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19367, 'EPSG:27700', 424525, 409550, 668025, 623200);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19368, 'EPSG:4326', -2.267446250413462, 52.107483956119658, 1.4425499338053795, 54.080674754374996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19368, 'EPSG:27700', 382600, 250575, 625550, 464975);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19369, 'EPSG:4326', -2.8761450740407817, 50.713597671894597, 0.71732196282469796, 52.673066477520976);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19369, 'EPSG:27700', 340850, 93675, 583950, 308375);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19370, 'EPSG:4326', -3.4484527622252688, 49.883989186136326, -0.0022998415310099443, 51.256357627923187);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19370, 'EPSG:27700', 299000, 0, 539550, 150800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19371, 'EPSG:4326', -3.1236528826412147, 53.510950153356958, 0.75709233519501407, 55.4962715260978);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19371, 'EPSG:27700', 329100, 404800, 574400, 622500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19372, 'EPSG:4326', -3.8017109441751096, 52.111089619641625, -0.050073759271810424, 54.084492042258674);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19372, 'EPSG:27700', 282200, 247500, 527700, 465400);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19373, 'EPSG:4326', -4.407621169976756, 50.703684658552781, -0.7762809721621764, 52.687894907223509);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19373, 'EPSG:27700', 237275, 91875, 482825, 310025);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19374, 'none', 191700, 0, 437150, 153250);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19375, 'EPSG:4326', -2.88358327382082, 57.297475825964533, -0.74018165013411286, 58.314370414654981);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19375, 'EPSG:27700', 348325, 823650, 473925, 936200);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19376, 'EPSG:4326', -3.2781805334075829, 56.559012023935985, -1.1681295068322404, 57.579425603147854);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19376, 'EPSG:27700', 323650, 741475, 449850, 854375);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19377, 'none', 276350, 559675, 523700, 780575);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19378, 'EPSG:4326', -4.7179330316334189, 53.50325719423558, -0.7937097292714248, 55.519194060854097);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19378, 'EPSG:27700', 228375, 403850, 476275, 625050);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19379, 'EPSG:4326', -5.3635536363325187, 52.079555088832336, -1.5709000965790096, 54.113020913847691);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19379, 'EPSG:27700', 180000, 247225, 428150, 468575);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19380, 'EPSG:4326', -5.9697014502388157, 50.671727558360601, -2.289010026952599, 52.726184366157185);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19380, 'EPSG:27700', 131650, 92675, 379700, 314325);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19381, 'EPSG:4326', -6.5522401974058431, 49.815748072887743, -2.9700354969237761, 51.316161896369557);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19381, 'EPSG:27700', 82325, -25, 330425, 157925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19382, 'EPSG:4326', -2.9145727952570244, 60.074032738291692, -0.53373452313681957, 61.109200575058672);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19382, 'EPSG:27700', 350800, 1133000, 479150, 1247450);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19383, 'EPSG:4326', -1.3572243753970072, 59.832782351104449, 1.0490788092463459, 60.893234831139587);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19383, 'EPSG:27700', 436100, 1108975, 565700, 1223575);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19384, 'EPSG:4326', -4.9358927427533983, 56.28764365881451, -0.67500917980739594, 58.335023765173737);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19384, 'EPSG:27700', 228050, 714050, 477700, 938500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19385, 'EPSG:4326', -5.7446417241606547, 54.871609491953222, -1.6396507994109089, 56.940748437098264);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19385, 'EPSG:27700', 171975, 558775, 422025, 783275);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19386, 'EPSG:4326', -6.4206772293509662, 53.465018858991613, -2.4364048646719549, 55.556755473152585);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19386, 'EPSG:27700', 120775, 404725, 371175, 629325);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19387, 'EPSG:4326', -3.0478198560520551, 59.683144606554464, -0.69100531205682214, 60.735284246046248);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19387, 'EPSG:27700', 342950, 1089300, 471500, 1205800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19388, 'EPSG:4326', -5.762257924992622, 57.642593317120642, -1.2791886559084573, 59.738618691391693);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19388, 'EPSG:27700', 188325, 866950, 440625, 1094800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19389, 'EPSG:4326', -6.5242895927856548, 56.249291207634371, -2.2069360561920912, 58.369418298409535);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19389, 'EPSG:27700', 134950, 714550, 387300, 942350);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19390, 'EPSG:4326', -7.2478752073138608, 54.837005422443134, -3.0483803112320285, 56.982803833488717);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19390, 'EPSG:27700', 80425, 560500, 332925, 788500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19391, 'EPSG:4326', -8.1136494503563465, 53.381239402646351, -3.6021987961225896, 55.636303933331284);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19391, 'EPSG:27700', 14100, 402875, 293850, 639375);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19392, 'EPSG:4326', -8.2253578293737775, 56.208129279744746, -3.7844626340140932, 58.409355666117449);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19392, 'EPSG:27700', 35225, 717325, 289775, 948325);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19393, 'EPSG:4326', -8.9396772883118842, 54.802771196908409, -4.6694468569597873, 57.021141216035097);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19393, 'EPSG:27700', -22650, 565200, 229150, 795750);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19394, 'EPSG:4326', -9.614743913251818, 53.396582079457907, -5.4555540394445448, 55.634917240935444);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19394, 'EPSG:27700', -81025, 413325, 171275, 643925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19395, 'EPSG:4326', -7.6848897444680491, 57.701304928524621, -5.3054888021201769, 58.855200293900218);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19395, 'EPSG:27700', 71600, 881325, 203550, 1001425);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19396, 'EPSG:4326', -9.735121900725078, 56.178687976407723, -5.2182858750971679, 58.448486409927717);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19396, 'EPSG:27700', -53200, 722525, 201250, 956175);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19397, 'EPSG:4326', -1.0766005074424514, 51.295108162788303, 2.4888540683086222, 53.2662972653102);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19397, 'EPSG:27700', 464375, 163900, 699975, 374800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19398, 'EPSG:4326', -1.497007638886261, 50.263607440311183, 2.0339664069296024, 52.226913553359296);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19398, 'EPSG:27700', 435900, 47575, 676000, 258875);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19399, 'EPSG:4326', -1.6310355033678072, 53.514663477657443, 2.2349824587562748, 55.50196905319163);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19399, 'EPSG:27700', 424525, 409600, 668025, 623200);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19400, 'EPSG:4326', -2.267446250413462, 52.107463582314097, 1.4433118888794669, 54.080674714007742);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19400, 'EPSG:27700', 382600, 250575, 625600, 464975);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19401, 'EPSG:4326', -2.8761450740407817, 50.713597671894597, 0.71732196282469796, 52.673066477520976);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19401, 'EPSG:27700', 340850, 93675, 583950, 308375);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19402, 'EPSG:4326', -3.4484527622252688, 49.884000831642375, -0.003015635346357467, 51.256357530391092);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19402, 'EPSG:27700', 299000, 0, 539500, 150800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19403, 'EPSG:4326', -3.1236528826412147, 53.510950153356958, 0.75709233519501407, 55.4962715260978);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19403, 'EPSG:27700', 329100, 404800, 574400, 622500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19404, 'EPSG:4326', -3.8017109441751096, 52.111089619641625, -0.050073759271810424, 54.084492042258674);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19404, 'EPSG:27700', 282200, 247500, 527700, 465400);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19405, 'EPSG:4326', -4.407621169976756, 50.704133928822735, -0.77702039358696717, 52.687895194426808);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19405, 'EPSG:27700', 237275, 91925, 482775, 310025);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19406, 'none', 191700, -50, 437100, 153250);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19407, 'EPSG:4326', -2.88358327382082, 57.297924862884798, -0.74018165013411286, 58.314370414654981);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19407, 'EPSG:27700', 348325, 823700, 473925, 936200);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19408, 'EPSG:4326', -3.2781805334075829, 56.559012023935985, -1.1681295068322404, 57.579425603147854);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19408, 'EPSG:27700', 323650, 741475, 449850, 854375);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19409, 'EPSG:4326', -4.0317532878178151, 54.916416103777159, 0.030150342435612904, 56.916494185245931);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19409, 'EPSG:27700', 276350, 559675, 523750, 780575);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19410, 'EPSG:4326', -4.7179330316334189, 53.50325719423558, -0.7937097292714248, 55.519194060854097);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19410, 'EPSG:27700', 228375, 403850, 476275, 625050);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19411, 'EPSG:4326', -5.3635536363325187, 52.080003910364816, -1.5716648940895102, 54.113021395716082);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19411, 'EPSG:27700', 180000, 247275, 428100, 468575);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19412, 'EPSG:4326', -5.9697014502388157, 50.672176206196269, -2.2897212790671242, 52.726182476847413);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19412, 'EPSG:27700', 131650, 92725, 379650, 314325);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19413, 'EPSG:4326', -6.5522401974058431, 49.816196439000315, -2.970044513833372, 51.316161896369557);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19413, 'EPSG:27700', 82325, 25, 330425, 157925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19414, 'EPSG:4326', -2.9145727952570244, 60.074491185532963, -0.53466160281296726, 61.109200452392358);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19414, 'EPSG:27700', 350800, 1133050, 479100, 1247450);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19415, 'EPSG:4326', -1.3572243753970072, 59.832782351104449, 1.0490788092463459, 60.893234831139587);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19415, 'EPSG:27700', 436100, 1108975, 565700, 1223575);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19416, 'EPSG:4326', -4.9358927427533983, 56.288092342631437, -0.67415571712240285, 58.335023907441624);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19416, 'EPSG:27700', 228050, 714100, 477750, 938500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19417, 'EPSG:4326', -5.7446417241606547, 54.871609491953222, -1.6404725159040934, 56.940748354226123);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19417, 'EPSG:27700', 171975, 558775, 421975, 783275);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19418, 'EPSG:4326', -6.4206772293509662, 53.465018858991613, -2.4364048646719549, 55.556755473152585);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19418, 'EPSG:27700', 120775, 404725, 371175, 629325);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19419, 'EPSG:4326', -3.0478198560520551, 59.683153178380238, -0.69192170093041927, 60.735284317595401);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19419, 'EPSG:27700', 342950, 1089300, 471450, 1205800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19420, 'EPSG:4326', -5.762257924992622, 57.643041570371544, -1.2791886559084573, 59.738618691391693);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19420, 'EPSG:27700', 188325, 867000, 440625, 1094800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19421, 'EPSG:4326', -6.5242895927856548, 56.249291207634371, -2.207744481555284, 58.369416833768483);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19421, 'EPSG:27700', 134950, 714550, 387250, 942350);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19422, 'EPSG:4326', -7.2478752073138608, 54.837005422443134, -3.0483803112320285, 56.982803833488717);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19422, 'EPSG:27700', 80425, 560500, 332925, 788500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19423, 'EPSG:4326', -8.1136494503563465, 53.381239402646351, -3.6014451257052071, 55.636314855287708);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19423, 'EPSG:27700', 14100, 402875, 293900, 639375);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19424, 'EPSG:4326', -8.2253578293737775, 56.208129279744746, -3.7836543365572051, 58.409368268289313);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19424, 'EPSG:27700', 35225, 717325, 289825, 948325);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19425, 'EPSG:4326', -8.9396772883118842, 54.80321755594295, -4.6694766265836041, 57.021141216035097);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19425, 'EPSG:27700', -22650, 565250, 229150, 795750);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19426, 'EPSG:4326', -9.614743913251818, 53.396582079457907, -5.4555540394445448, 55.634917240935444);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19426, 'EPSG:27700', -81025, 413325, 171275, 643925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19427, 'EPSG:4326', -7.6848897444680491, 57.701304928524621, -5.3063280812666891, 58.855177446194254);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19427, 'EPSG:27700', 71600, 881325, 203500, 1001425);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19428, 'EPSG:4326', -9.735121900725078, 56.178242408685236, -5.2190558397754403, 58.448463659541886);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19428, 'EPSG:27700', -53200, 722475, 201200, 956175);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19429, 'EPSG:4326', -9.002056140020688, 49.766807219548681, 3.2584511025793259, 59.336149091669959);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19429, 'EPSG:27700', 0, 0, 700000, 1050000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19430, 'EPSG:4326', -9.0018164020107836, 49.766703633461212, 3.258651960984889, 59.33603644303161);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19430, 'EPSG:27700', 12.5, -12.5, 700012.5, 1049987.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19431, 'EPSG:4326', -9.002056140020688, 49.766807219548681, 3.2584511025793259, 59.336149091669959);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19431, 'EPSG:27700', 0, 0, 700000, 1050000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19432, 'EPSG:4326', -9.0186118540566458, 49.74133100821058, 3.5191034551972562, 59.38042958479204);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19432, 'EPSG:32630', 156942.39322212461, 5522666.6024576621, 871792.39322212455, 6582441.6024576621);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19432, 'EPSG:27700', -14948.579785844486, -9354.2189786969393, 714962.61797239631, 1060520.4960116555);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19433, 'EPSG:4326', -9.002056140020688, 49.766770411448064, 3.2585637991695808, 59.336365722842373);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19433, 'EPSG:27700', -103949.6448303613, -14811.072549509248, 778704.7302293753, 1070954.5913852823);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19434, 'EPSG:4326', -0.73539318474528437, 52.087422755112534, 2.5789544335490113, 54.10510722819901);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19434, 'EPSG:27700', 486600, 252275, 699975, 468500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19435, 'EPSG:4326', -1.3184925602431667, 50.68086710858617, 2.2531791568732142, 52.697018512947096);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19435, 'EPSG:27700', 448175, 94725, 687950, 311275);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19436, 'EPSG:4326', -2.0793712603620871, 49.841791722979622, 1.7991079265986751, 51.399979878061345);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19436, 'EPSG:27700', 394575, 0, 664700, 166775);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19437, 'EPSG:4326', -1.7500447238591899, 53.437470427917916, 2.3199652104629145, 55.562724021686698);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19437, 'EPSG:27700', 416675, 401275, 673000, 629925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19438, 'EPSG:4326', -2.3887895208982033, 52.026960679435916, 1.5298568140897331, 54.144501779600439);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19438, 'EPSG:27700', 374700, 241850, 630925, 472075);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19439, 'EPSG:4326', -2.9879819978001776, 50.639498329825933, 0.79298919494702558, 52.731281200319287);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19439, 'EPSG:27700', 333375, 85600, 588825, 314850);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19440, 'EPSG:4326', -3.5652792895062486, 49.882170577156522, 0.10904397263551871, 51.312096641238682);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19440, 'EPSG:27700', 290975, 0, 547150, 157000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19441, 'EPSG:4326', -3.9350575485850761, 52.059795140926646, -0.058375716135255787, 54.119341256045217);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19441, 'EPSG:27700', 273575, 241775, 527050, 469275);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19442, 'EPSG:4326', -4.5475659692148858, 50.640787199928532, -0.79074408943160901, 52.713084466081085);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19442, 'EPSG:27700', 227900, 85175, 481800, 312825);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19443, 'EPSG:4326', -5.1073989966530604, 49.224585375217444, -1.4627588092806589, 51.303564315804024);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19443, 'EPSG:27700', 183300, -70850, 437550, 156050);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19444, 'EPSG:4326', -4.1967131154924244, 54.848961970674402, -0.0092626599226349835, 56.938922211977726);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19444, 'EPSG:27700', 266375, 552450, 521275, 783075);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19445, 'EPSG:4326', -4.8518711644801717, 53.46790168195939, -0.92546732405763876, 55.535375253045551);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19445, 'EPSG:27700', 219975, 400225, 467925, 626850);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19446, 'EPSG:4326', -5.4420779341776369, 52.008920672924518, -1.5849736208476124, 54.158869130315473);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19446, 'EPSG:27700', 175100, 239575, 427200, 473675);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19447, 'EPSG:4326', -6.0528190993062712, 50.586645236955491, -2.3019390448489347, 52.755812771150175);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19447, 'EPSG:27700', 126200, 83475, 378750, 317625);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19448, 'EPSG:4326', -6.6288140452219704, 49.813264737547179, -2.9714321093157636, 51.357280443893011);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19448, 'EPSG:27700', 77250, 0, 330325, 162500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19449, 'EPSG:4326', -5.0919711752018948, 56.22169351130816, -0.65796824829832856, 58.356788322183817);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19449, 'EPSG:27700', 219000, 707075, 478650, 940925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19450, 'EPSG:4326', -5.8178163424770704, 54.807961384522933, -1.574061227100586, 56.963874918173254);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19450, 'EPSG:27700', 167650, 551900, 426000, 785850);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19451, 'EPSG:4326', -6.4906536168906301, 53.394585940653918, -2.3739403277939348, 55.572480810257268);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19451, 'EPSG:27700', 116450, 397125, 375275, 631050);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19452, 'EPSG:4326', -5.9932190759074784, 57.550890954141927, -1.2306504349541103, 59.799900757949608);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19452, 'EPSG:27700', 175700, 857400, 443275, 1101625);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19453, 'EPSG:4326', -6.6806420315119093, 56.167658176421689, -2.2738891054232728, 58.407670654559503);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19453, 'EPSG:27700', 126050, 706000, 383125, 946625);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19454, 'EPSG:4326', -7.4952831953064569, 54.739556521366893, -3.0437541248427253, 57.043900037088328);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19454, 'EPSG:27700', 65825, 550675, 333075, 795300);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19455, 'EPSG:4326', -8.1708842915516371, 53.321706995226627, -3.8273217561625619, 55.65162883895534);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19455, 'EPSG:27700', 10650, 396500, 278750, 641475);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19456, 'EPSG:4326', -7.4868903591205038, 57.532983081889533, -2.8223022852684116, 59.824185173566839);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19456, 'EPSG:27700', 91625, 860925, 351000, 1104650);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19457, 'EPSG:4326', -8.2841420572640629, 56.129378560604046, -3.7433756110553249, 58.450105457572469);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19457, 'EPSG:27700', 32175, 708775, 292100, 952800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19458, 'EPSG:4326', -0.73539955335930329, 52.087185112492428, 2.5793348242244702, 54.10510722819901);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19458, 'EPSG:27700', 486600, 252250, 700000, 468500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19459, 'EPSG:4326', -1.3184925602431667, 50.68085474960052, 2.2535474379627574, 52.697018512947096);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19459, 'EPSG:27700', 448175, 94725, 687975, 311275);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19460, 'EPSG:4326', -2.0793712603620871, 49.841556305769245, 1.7994660230553143, 51.399979878061345);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19460, 'EPSG:27700', 394575, -25, 664725, 166775);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19461, 'EPSG:4326', -1.7500447238591899, 53.437457495220919, 2.3203596951212813, 55.562724021686698);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19461, 'EPSG:27700', 416675, 401275, 673025, 629925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19462, 'EPSG:4326', -2.3887895208982033, 52.026725902016544, 1.5302383178572456, 54.144501788979952);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19462, 'EPSG:27700', 374700, 241825, 630950, 472075);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19463, 'EPSG:4326', -2.9879819978001776, 50.639498329825933, 0.79298919494702558, 52.731281200319287);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19463, 'EPSG:27700', 333375, 85600, 588825, 314850);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19464, 'EPSG:4326', -3.5652792895062486, 49.882164435911193, 0.10940226249670876, 51.312096719176935);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19464, 'EPSG:27700', 290975, 0, 547175, 157000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19465, 'EPSG:4326', -3.9350575485850761, 52.059789413246705, -0.057993605563374351, 54.119341251089295);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19465, 'EPSG:27700', 273575, 241775, 527075, 469275);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19466, 'EPSG:4326', -4.5475659692148858, 50.640787199928532, -0.79074408943160901, 52.713084466081085);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19466, 'EPSG:27700', 227900, 85175, 481800, 312825);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19467, 'EPSG:4326', -5.1073989966530604, 49.224585375217444, -1.4627588092806589, 51.303564315804024);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19467, 'EPSG:27700', 183300, -70850, 437550, 156050);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19468, 'EPSG:4326', -4.1967131154924244, 54.848737459752925, -0.0092626599226349835, 56.938922211977726);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19468, 'EPSG:27700', 266375, 552425, 521275, 783075);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19469, 'EPSG:4326', -4.8518711644801717, 53.46767722284936, -0.92546732405763876, 55.535375253045551);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19469, 'EPSG:27700', 219975, 400200, 467925, 626850);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19470, 'EPSG:4326', -5.4420779341776369, 52.008920672924518, -1.5849736208476124, 54.158869130315473);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19470, 'EPSG:27700', 175100, 239575, 427200, 473675);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19471, 'EPSG:4326', -6.0528190993062712, 50.586645236955491, -2.3019390448489347, 52.755812771150175);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19471, 'EPSG:27700', 126200, 83475, 378750, 317625);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19472, 'EPSG:4326', -6.6288140452219704, 49.813264737547179, -2.9710840834096262, 51.357283514542438);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19472, 'EPSG:27700', 77250, 0, 330350, 162500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19473, 'EPSG:4326', -5.0919711752018948, 56.22169351130816, -0.65796824829832856, 58.356788322183817);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19473, 'EPSG:27700', 219000, 707075, 478650, 940925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19474, 'EPSG:4326', -5.8178163424770704, 54.807961384522933, -1.574061227100586, 56.963874918173254);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19474, 'EPSG:27700', 167650, 551900, 426000, 785850);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19475, 'EPSG:4326', -6.4906536168906301, 53.394361849893791, -2.373561746795195, 55.572482083519603);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19475, 'EPSG:27700', 116450, 397100, 375300, 631050);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19476, 'EPSG:4326', -5.9932190759074784, 57.550666874700205, -1.2302049975040106, 59.79990102846979);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19476, 'EPSG:27700', 175700, 857375, 443300, 1101625);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19477, 'EPSG:4326', -6.6806420315119093, 56.167434232569164, -2.2734841032151927, 58.407671624307689);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19477, 'EPSG:27700', 126050, 705975, 383150, 946625);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19478, 'EPSG:4326', -7.4952831953064569, 54.739332781186334, -3.0437483250865864, 57.043900037088328);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19478, 'EPSG:27700', 65825, 550650, 333075, 795300);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19479, 'none', 10650, 396475, 278750, 641475);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19480, 'EPSG:4326', -7.4868903591205038, 57.532759429291119, -2.8218785655974994, 59.824188139344429);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19480, 'EPSG:27700', 91625, 860900, 351025, 1104650);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19481, 'EPSG:4326', -8.2841420572640629, 56.129155148364482, -3.7429620492873239, 58.450111636386232);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19481, 'EPSG:27700', 32175, 708750, 292125, 952800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19482, 'EPSG:4326', -0.73538681604771239, 52.087633327642578, 2.5793348242244702, 54.10510722819901);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19482, 'EPSG:27700', 486600, 252300, 700000, 468500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19483, 'EPSG:4326', -1.3184990856390919, 50.680406251007717, 2.2535474379627574, 52.697018512947096);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19483, 'EPSG:27700', 448175, 94675, 687975, 311275);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19484, 'EPSG:4326', -2.0793712603620871, 49.841578365629779, 1.7987498299026672, 51.399979878061345);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19484, 'EPSG:27700', 394575, -25, 664675, 166775);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19485, 'EPSG:4326', -1.7500473650998782, 53.437035090325715, 2.3195707254599642, 55.562724021686698);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19485, 'EPSG:27700', 416675, 401225, 672975, 629925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19486, 'EPSG:4326', -2.3887895208982033, 52.027195455888211, 1.5294753100626195, 54.144501770210894);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19486, 'EPSG:27700', 374700, 241875, 630900, 472075);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19487, 'EPSG:4326', -2.9879819978001776, 50.639032988978919, 0.79372818877835893, 52.731281126316276);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19487, 'EPSG:27700', 333375, 85550, 588875, 314850);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19488, 'EPSG:4326', -3.5652792895062486, 49.882164435911193, 0.10940226249670876, 51.312096719176935);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19488, 'EPSG:27700', 290975, 0, 547175, 157000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19489, 'EPSG:4326', -3.9350575485850761, 52.059789413246705, -0.057993605563374351, 54.119341251089295);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19489, 'EPSG:27700', 273575, 241775, 527075, 469275);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19490, 'EPSG:4326', -4.5475659692148858, 50.640337966831567, -0.79074408943160901, 52.713084466081085);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19490, 'EPSG:27700', 227900, 85125, 481800, 312825);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19491, 'EPSG:4326', -5.1073989966530604, 49.224585375217444, -1.4620416312738611, 51.303564104427196);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19491, 'EPSG:27700', 183300, -70850, 437600, 156050);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19492, 'EPSG:4326', -4.1967131154924244, 54.849186481585889, -0.0092626599226349835, 56.938922211977726);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19492, 'EPSG:27700', 266375, 552475, 521275, 783075);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19493, 'EPSG:4326', -4.8518711644801717, 53.468126141058271, -0.92467536410272577, 55.535375237722072);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19493, 'EPSG:27700', 219975, 400250, 467975, 626850);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19494, 'EPSG:4326', -5.4420779341776369, 52.008920672924518, -1.5849736208476124, 54.158869130315473);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19494, 'EPSG:27700', 175100, 239575, 427200, 473675);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19495, 'EPSG:4326', -6.0528190993062712, 50.586196619341408, -2.301228937358355, 52.755814745753106);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19495, 'EPSG:27700', 126200, 83425, 378800, 317625);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19496, 'EPSG:4326', -6.6288140452219704, 49.813264737547179, -2.9710840834096262, 51.357283514542438);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19496, 'EPSG:27700', 77250, 0, 330350, 162500);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19497, 'EPSG:4326', -5.0919711752018948, 56.221244877736666, -0.65711427047449167, 58.356788638070164);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19497, 'EPSG:27700', 219000, 707025, 478700, 940925);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19498, 'EPSG:4326', -5.8178163424770704, 54.807512958443297, -1.5732390126858586, 56.963874680237979);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19498, 'EPSG:27700', 167650, 551850, 426050, 785850);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19499, 'EPSG:4326', -6.4906536168906301, 53.394810031399011, -2.3743189127707649, 55.57247953571288);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19499, 'EPSG:27700', 116450, 397150, 375250, 631050);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19500, 'EPSG:4326', -5.9932190759074784, 57.551115033569737, -1.2302049975040106, 59.79990102846979);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19500, 'EPSG:27700', 175700, 857425, 443300, 1101625);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19501, 'EPSG:4326', -6.6806420315119093, 56.167882120258277, -2.2734873081646612, 58.407671624307689);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19501, 'EPSG:27700', 126050, 706025, 383150, 946625);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19502, 'EPSG:4326', -7.4952831953064569, 54.739780261528956, -3.0429814103427781, 57.043907301592995);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19502, 'EPSG:27700', 65825, 550700, 333125, 795300);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19503, 'EPSG:4326', -8.1708842915516371, 53.321483449514119, -3.8273121115466382, 55.65162883895534);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19503, 'EPSG:27700', 10650, 396475, 278750, 641475);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19504, 'EPSG:4326', -7.4868903591205038, 57.533206734468806, -2.821888714373153, 59.824188139344429);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19504, 'EPSG:27700', 91625, 860950, 351025, 1104650);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19505, 'EPSG:4326', -8.2841420572640629, 56.129601972821526, -3.7437891775414576, 58.450099277330168);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19505, 'EPSG:27700', 32175, 708800, 292075, 952800);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19506, 'EPSG:4326', -9.0018164020107836, 49.766703633461212, 3.258651960984889, 59.33603644303161);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19506, 'EPSG:27700', 12.5, -12.5, 700012.5, 1049987.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19507, 'EPSG:4326', -12.208490638063356, 59.59301508001672, 5.6849881473223078, 69.655031467828607);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19507, 'EPSG:27700', 12.5, 1099987.5, 699987.5, 2199967.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19508, 'EPSG:4326', -12.208490638063356, 59.59301508001672, 5.6849881473223078, 69.655031467828607);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19508, 'EPSG:27700', 12.5, 1099987.5, 699987.5, 2199967.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19509, 'EPSG:4326', -9.0019122970481522, 49.766745067935389, 3.2586588600594317, 59.336081407800378);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19509, 'EPSG:27700', 7.5, -7.5, 700012.5, 1049992.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19510, 'EPSG:4326', -9.001912297048154, 49.766745067935389, 3.2586588600594317, 59.336081407800378);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19510, 'EPSG:27700', 7.4999999999507541, -7.5, 700012.5, 1049992.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19511, 'EPSG:4326', -9.0019122970481522, 49.76677775938937, 3.258566260300455, 59.33629837362303);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19511, 'EPSG:27700', -103939.22245768917, -14810.241544534176, 778704.84998406377, 1070946.2569299436);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19512, 'EPSG:4326', -9.0019122970481522, 49.76678906294503, 3.2586038848598484, 59.33629837362303);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19512, 'EPSG:27700', -103939.10476324864, -14808.979603018481, 778707.46938601858, 1070946.2569299436);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19513, 'EPSG:4326', -9.002056140020688, 49.319179049898246, 3.2584511025793259, 59.336149091669959);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19513, 'EPSG:27700', 0, -50000, 700000, 1050000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19514, 'EPSG:4326', -9.002056140020688, 49.319179049898246, 3.2584511025793259, 59.336149091669959);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19514, 'EPSG:27700', 0, -50000, 700000, 1050000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19515, 'EPSG:4326', -9.002056140020688, 49.319179049898246, 3.2584511025793259, 59.336149091669959);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19515, 'EPSG:27700', 0, -50000, 700000, 1050000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19516, 'EPSG:4326', -9.002056140020688, 49.766807219548681, 3.2585383450479766, 59.336148996991398);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19516, 'EPSG:27700', 0, 0, 700005, 1050000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19517, 'EPSG:4326', -12.208553864986046, 59.59301508001672, 5.6857963568288348, 69.655165068223994);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19517, 'EPSG:27700', 12.5, 1099987.5, 700017.5, 2199982.5);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19518, 'EPSG:4326', -9.0948068945813727, 49.766745173124995, 3.3286404839843966, 59.785057758532183);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19518, 'EPSG:27700', 7.3488910000000001, -7.4770250001456589, 700007.54219000007, 1099992.5096189999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19519, 'EPSG:4326', -9.0948068945813727, 49.766745173124995, 3.3286404839843966, 59.785057758532183);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19519, 'EPSG:27700', 7.3488910000000001, -7.4770250001456589, 700007.54219000007, 1099992.5096189999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19520, 'EPSG:4326', -9.0948068945813727, 49.766745173124995, 3.3286404839843966, 59.785057758532183);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19520, 'EPSG:27700', 7.3488910000000001, -7.4770250001456589, 700007.54219000007, 1099992.5096189999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19521, 'EPSG:4326', -9.0948068945813727, 49.766745173124995, 3.3286404839843966, 59.785057758532183);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19521, 'EPSG:27700', 7.3488910000000001, -7.4770250001456589, 700007.54219000007, 1099992.5096189999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19522, 'EPSG:4326', -6.8303465136991894, 52.338001830307924, -5.636083533922517, 53.051866636512919);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19522, 'EPSG:27700', 76110, 281760, 152620, 356890);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19523, 'none', 28900, 127280, 105350, 201860);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19524, 'none', 123735, 897715, 203685, 975725);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19525, 'EPSG:4326', -6.75503038598114, 57.883048005530618, -5.3166344114197566, 58.624819385328678);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19525, 'EPSG:27700', 123739.99999999997, 897709.99999999977, 203689.99999999997, 975719.99999999977);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19526, 'EPSG:4326', -7.0307007861247541, 57.42741483988852, -5.6174764451337458, 58.171513599187108);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19526, 'EPSG:27700', 103939.99999999997, 848209.99999999977, 183189.99999999997, 926229.99999999977);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19527, 'none', 103935, 848215, 183185, 926235);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19528, 'none', 78800, 797470, 165470, 878540);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19529, 'EPSG:4326', -7.5106447052034913, 56.504788291115545, -6.1326770242887845, 57.253801187964967);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19529, 'EPSG:27700', 67370, 747860, 146130, 825980);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19530, 'none', 47560, 698410, 126340, 776050);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19531, 'none', 174830, 385490, 251370, 460280);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19532, 'none', 158340, 333860, 234820, 408680);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19533, 'none', 142710, 281740, 239090, 355360);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19534, 'none', 131200, 229570, 227630, 303760);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19535, 'none', 108080, 178840, 184900, 253580);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19536, 'none', 91040, 126970, 168140, 201730);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19537, 'none', 74400, 75120, 151120, 149930);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19538, 'none', 58530, 18790, 152490, 100170);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19539, 'none', 200130, 940360, 301000, 1029170);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19540, 'none', 175690, 890780, 277160, 979040);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19541, 'none', 152030, 841230, 253240, 929480);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19542, 'none', 127820, 791580, 229280, 879250);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19543, 'none', 104490, 741880, 205250, 830490);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19544, 'none', 78300, 692100, 181280, 781390);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19545, 'none', 55820, 642360, 157140, 730960);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19546, 'none', 198650, 381370, 292070, 463780);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19547, 'none', 178650, 329750, 272340, 411620);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19548, 'none', 220780, 281890, 297280, 356020);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19549, 'none', 204590, 229870, 281350, 304050);
