[Mapbender-commits] r2842 - branches/nimix_dev/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 18 09:59:57 EDT 2008
Author: nimix
Date: 2008-08-18 09:59:57 -0400 (Mon, 18 Aug 2008)
New Revision: 2842
Added:
   branches/nimix_dev/http/php/mod_editApplication.php
   branches/nimix_dev/http/php/mod_editApplication_server.php
   branches/nimix_dev/http/php/mod_loadwmc_server.php
   branches/nimix_dev/http/php/mod_savewmc_server.php
Removed:
   branches/nimix_dev/http/php/database-mysql.php
   branches/nimix_dev/http/php/database-pgsql.php
   branches/nimix_dev/http/php/mb_listWMCs.php
   branches/nimix_dev/http/php/mod_createJSObjFromDB.php
   branches/nimix_dev/http/php/mod_insertWmcIntoDb.php
   branches/nimix_dev/http/php/mb_listGUIs.php
   branches/nimix_dev/http/php/mb_validateSession.php
   branches/nimix_dev/http/php/mod_WMSpreferences.php
   branches/nimix_dev/http/php/mod_addWmsFromFeatureInfo.php
   branches/nimix_dev/http/php/mod_createJSObjFromDBByWMS.php
   branches/nimix_dev/http/php/mod_editElements.php
   branches/nimix_dev/http/php/mod_gazetteerMetadata.php
   branches/nimix_dev/http/php/mod_map1.php
   branches/nimix_dev/http/php/mod_mapOV.php
   branches/nimix_dev/http/php/mod_treefolderClient.php
   branches/nimix_dev/http/php/mod_wfs.php
   branches/nimix_dev/http/php/mod_wfs_conf.php
   branches/nimix_dev/http/php/mod_wfs_edit.php
   branches/nimix_dev/http/php/mod_wfs_gazetteer_server.php
   branches/nimix_dev/http/php/mod_zoomCoords_en.php
   branches/nimix_dev/http/php/system.php
merge
Deleted: branches/nimix_dev/http/php/database-mysql.php
--- branches/nimix_dev/http/php/database-mysql.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/database-mysql.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -1,409 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/database-mysql.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
- * \file
- * \brief MySQL database connection/querying layer
- * MySQL database connection/querying layer
- * example:
- * \code
- * include_once(dirname(__FILE__)."/afwphp/database-mysql.php");
- * $sys_dbhost=...
- * $sys_dbuser=...
- * $sys_dbpasswd=...
- * $sys_dbname=...
- * db_connect();
- * $rs = db_query("select * from table");
- * while($row = db_fetch_array($rs));
- * \endcode
- * System-wide database type
- * @var	constant		$sys_database_type
-$sys_database_type='mysql';
- *  Connect to the database
- *  Notice the global vars that must be set up
- *  Notice the global vars $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname that must be set up
- *  in other functions in this library
-include_once(dirname(__FILE__)."/../../http/classes/class_mb_exception.php");
-include_once(dirname(__FILE__)."/../../http/classes/class_checkInput.php");
-function db_escapestring($unescaped_string){
-	return @mysql_escape_string($unescaped_string);
-function db_escape_string($unescaped_string){
-function db_connect($DBSERVER="",$OWNER="",$PW="") {
-	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,
-		$conn,$conn_update,$sys_db_use_replication,$sys_dbreadhost;
-	if ($DBSERVER)
-		$sys_dbhost = $DBSERVER;
-	if ($OWNER)
-		$sys_dbuser = $OWNER;
-	if ($PW)
-		$sys_dbpasswd = $PW;
-	if (PORT!=''){
-		$sys_dbport = ':'.PORT;
-	else{
-		$sys_dbport = '';
-	if ($sys_db_use_replication) {
-		//  if configured for replication, $conn is the read-only host
-		//  we do not connect to update server until needed
-		$conn = @mysql_pconnect($sys_dbreadhost,$sys_dbuser,$sys_dbpasswd);
-		$conn_update=@mysql_pconnect($sys_dbhost,$sys_dbuser,$sys_dbpasswd);
-	} else {
-		$conn = @mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd);
-		#echo "@mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd)";
-	if ($sys_dbname)
-		@mysql_select_db($sys_dbname);
-	return $conn;
-function db_select_db($DB,$con="") {
-	global $conn,$sys_dbname;
-	$sys_dbname = $DB;
-	$_con = $con ? $con : $conn;
-	$ret = @mysql_select_db($sys_dbname,$_con);
-	if ($ret){
-		return true;
-	else {
-		return false;
-//	echo "$ret=@mysql_select_db($sys_dbname,$_con);";
- *  Query the database
- *  @param		$qstring (string)	SQL statement
- *  @param		$limit (int)		How many rows do you want returned
- *  @param		$offset (int)		Of matching rows, return only rows starting here
-function db_query($qstring,$limit='-1',$offset=0) {
-	global $QUERY_COUNT,$sys_db_use_replication,$sys_db_is_dirty,$DB,
-		$sys_dbname,$conn,$conn_update,$sys_dbhost,$sys_dbuser,$sys_dbpasswd;
-	$QUERY_COUNT++;
-	if(!$sys_dbname && $DB)
-	db_select_db($sys_dbname,$conn);
-	if ($limit > 0) {
-		if (!$offset || $offset < 0) {
-			$offset=0;
-		$qstring=$qstring." LIMIT $offset,$limit";
-//	if ($GLOBALS['IS_DEBUG'])
-		$GLOBALS['G_DEBUGQUERY'] .= $qstring . "<P><BR>\n";
-	//are we configured to try to use replication?
-		//if we haven't yet done an insert/update,
-		//read from the read-only db
-		if (!$sys_db_is_dirty && mb_eregi("^( )*(select)",$qstring)) {
-			if ($QUERY_COUNT%3==0) {
-				// 1/3rd of read queries go to master for now
-				return @mysql_db_query($sys_dbname,$qstring,$conn_update);
-			} else {
-				return @mysql_db_query($sys_dbname,$qstring,$conn);
-		} else {
-			//must be an update/insert/delete query - go to master server
-			$sys_db_is_dirty=true;
-	} else {
-		$ret = @mysql_db_query($sys_dbname,$qstring,$conn);
-//		echo "@mysql_db_query($sys_dbname,$qstring,$conn); ret=$ret<br>";
-		if(!$ret){
-			$e = new mb_exception("db_query($qstring)=$ret db_error=".db_error());
-		return $ret;
-	//echo "SQL__".$qstring;
- *  prepare and query the database
- *  @param		$params (array string params)
- *  @param		$types (array string types)
-function db_prep_query($qstring, $params, $types){
-	$ci = new checkInput($qstring,$params,$types);
-	$params = $ci->v;
-	for ($i=0; $i<count($params); $i++){
-		$needle = "$".strval($i+1);
-		$tmp = '';
-		if($params[$i] !== NULL){
-			if($types[$i] == 's'){ $tmp .= "'"; }
-			$tmp .= $params[$i];
-		else{
-			$tmp .= "NULL";
-		$posa = mb_strpos($qstring, $needle);
-		$posb = mb_strlen($needle);
-		$qstring = mb_substr($qstring,0,$posa).$tmp.mb_substr($qstring,($posa + $posb));
-	$r = db_query($qstring);
-	return $r;
- *	Begin a transaction
- *	Begin a transaction for databases that support them
- *	may cause unexpected behavior in databases that don't
-function db_begin() {
-	return db_query("BEGIN WORK");
- * Commit a transaction
- * Commit a transaction for databases that support them
-function db_commit() {
-	return db_query("COMMIT");
- * Roll back a transaction
- * Rollback a transaction for databases that support them
-function db_rollback() {
-	$str = db_error();
-	db_query("ROLLBACK");
-	die('sql error: ' . $str . " ROLLBACK performed....");
- * Returns the number of rows in this result set
- *  @param		$qhandle (string)	Query result set handle
-function db_numrows($qhandle) {
-	// return only if qhandle exists, otherwise 0
-	if ($qhandle) {
-		return @mysql_numrows($qhandle);
-	} else {
-		return 0;
- * php 3,4,5
-function db_num_rows($qhandle) {
-	if ($qhandle) {
-		return @mysql_num_rows($qhandle);
-	} else {
-		return 0;
- *  Frees a database result properly
-function db_free_result($qhandle) {
-	return @mysql_free_result($qhandle);
- *  Reset a result set.
- *  Reset is useful for db_fetch_array sometimes you need to start over
- *  @param		$row (int)		Row number
-function db_reset_result($qhandle,$row=0) {
-	return mysql_data_seek($qhandle,$row);
- *  Returns a field from a result set
- *  @param		$field (string)	Field name
-function db_result($qhandle,$row,$field) {
-	return @mysql_result($qhandle,$row,$field);
- *  Returns the number of fields in this result set
- *  @param		$lhandle (string)	Query result set handle
-function db_numfields($lhandle) {
-	return @mysql_numfields($lhandle);
- * php 3,4,5
-function db_num_fields($lhandle) {
-	return @mysql_num_fields($lhandle);
- *  Returns the number of rows changed in the last query
- *  @param		$fnumber (int)	Column number
-function db_fieldname($lhandle,$fnumber) {
-	   return @mysql_fieldname($lhandle,$fnumber);
-function db_affected_rows($qhandle) {
-	return @mysql_affected_rows();
- *  Fetch an array
- *  Returns an associative array from
- *  the current row of this database result
- *  Use db_reset_result to seek a particular row
-function db_fetch_array($qhandle) {
-	return @mysql_fetch_array($qhandle);
- * fetch a row into an array
-function db_fetch_row($qhandle,$fnumber=0) {
-	  return @mysql_fetch_row($qhandle);
- *  Returns the last primary key from an insert
- *  @param		$table_name (string)	Is the name of the table you inserted into
- *  @param		$pkey_field_name (string)	Is the field name of the primary key
-function db_insertid($qhandle="",$table_name="",$pkey_field_name="") {
-	return @mysql_insert_id();
-function db_insert_id($qhandle="",$table_name="",$pkey_field_name="") {
- * Returns the last error from the database
-function db_error() {
-	return @mysql_error();
- * Get the flags associated with the specified field in a result
- * 					Examples: "not_null", "primary_key", "unique_key", "multiple_key",
- *                    "blob", "unsigned", "zerofill","binary", "enum",
- *                    "auto_increment", "timestamp"
-function db_field_flags($lhandle,$fnumber) {
-	   return @mysql_field_flags($lhandle,$fnumber);
- * Get the type of the specified field
-function db_field_type($lhandle,$fnumber) {
-	   return @mysql_field_type($lhandle,$fnumber);
- * Get the length of the specified field
-function db_field_len($lhandle,$fnumber) {
-	   return @mysql_field_len($lhandle,$fnumber);
\ No newline at end of file
Deleted: branches/nimix_dev/http/php/database-pgsql.php
--- branches/nimix_dev/http/php/database-pgsql.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/database-pgsql.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -1,436 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/database-pgsql.php
- * \file
- * example:
- * \code
- * $sys_dbhost=...
- * $sys_dbuser=...
- * $sys_dbname=...
- * db_connect();
- * \endcode
-$sys_database_type='pgsql';
-	return @pg_escape_string(stripslashes($unescaped_string));
-$DB = DB;
-	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,$db_debug;
-	global $conn,$conn_update,$DB;
-	$db_debug=0;
-	if ($DBSERVER)
-	if ($OWNER)
-	if ($PW && $PW != null)
-	$sys_dbport = PORT;
-	if($GLOBALS['DB'])
-	$connstring = "";
-	if ($sys_dbuser)
-		$connstring.=" user=$sys_dbuser";
-	if ($sys_dbname)
-		$connstring.=" dbname=$sys_dbname";
-	if ($sys_dbhost)
-		$connstring.=" host=$sys_dbhost";
-	if ($sys_dbport)
-		$connstring.=" port=$sys_dbport";
-	if ($sys_dbpasswd)
-		$connstring.=" password=$sys_dbpasswd";
-	if ($db_debug)
-		echo $connstring." ";
-	$conn = pg_connect($connstring);
-		#if(isset($sys_db_clientencoding) && $sys_db_clientencoding > "")
-		#pg_set_client_encoding ( $conn, $sys_db_clientencoding);
-	#return $conn;
-	if ($db_debug)
-		echo "conn=".$conn;
-#echo $connstring;
-#if(!$conn)
-#{echo "FEHLER in Connection";
-#pg_error($conn);}
-	return $conn;
-#	$sys_dbname = DB;
-#	$_con = $con ? $con : $conn;
-#	$ret = @mysql_select_db($sys_dbname,$_con);
-function db_query($qstring) {
-	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,$db_debug,
-		$conn,$conn_update,$QUERY_COUNT,$DBSERVER,$OWNER,$PW,$DB;
-	$QUERY_COUNT++;
-	$ret = pg_exec($qstring);
-//	$e = new mb_exception("not ps:  ".$_SERVER['SCRIPT_FILENAME']." : ".$qstring);
-	if(!$ret){
-	return $ret;
- *  @param		$params (array params as strings)
- *  @param		$types (array types as strings)
-	$params = $ci->v;
-	if(PREPAREDSTATEMENTS == false){
-			$tmp = '';
-			else{
-				$tmp .= "NULL";
-		if(!$r){
-			$e = new mb_exception("Error while executing sql statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-	else{
-		$result = pg_prepare("", $qstring);
-		if(!$result){
-			$e = new mb_exception("Error while preparing statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-		$r = pg_execute("", $params);
-		if(!$r){
-			$e = new mb_exception("Error while executing prepared statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-	return $r;
-	if ($qhandle) {
-		return @pg_numrows($qhandle);
-	} else {
-		return 0;
- *	php > 4.2
-	if ($qhandle) {
-		return @pg_num_rows($qhandle);
-	} else {
-		return 0;
-	return @pg_freeresult($qhandle);
-#dummy
-	return 0;#mysql_data_seek($qhandle,$row);
-	return @pg_result($qhandle,$row,$field);
-	return @pg_numfields($lhandle);
- *	php >4.2
-	return @pg_num_fields($lhandle);
-	   return @pg_fieldname($lhandle,$fnumber);
-	return @pg_cmdtuples($qhandle);
- *  Fetch an array
-	return @pg_fetch_array($qhandle);
-function db_fetch_all($qhandle){
-		return @pg_fetch_all($qhandle);
-	  return pg_fetch_row($qhandle);
-	$res=db_query("SELECT max($pkey_field_name) AS id FROM $table_name");
-    if ($res && db_numrows($res) > 0) {
-        return @db_result($res,0,'id');
-    } else {
-        return 0;
-	$oid =pg_last_oid($qhandle);
-	echo $oid;
-	$res=db_query("SELECT ".$pkey_field_name." FROM ".$table_name." WHERE oid =".$oid );
-        return @db_result($res,0,0);
-    } else {
-        return 0;
-        return db_result($res,0,'id');
-    } else {
-        return 0;
-function db_last_oid()
-		$conn,$conn_update,$QUERY_COUNT;
-        global $DBSERVER,$OWNER,$PW,$DB	;
-             return pg_getlastoid($conn);
-	return @pg_last_error();
-	   print "db_field_flags()	isn't implemented";
-	   return @pg_fieldtype($lhandle,$fnumber);
-	   return @pg_fieldlen($lhandle,$fnumber);
Modified: branches/nimix_dev/http/php/mb_listGUIs.php
--- branches/nimix_dev/http/php/mb_listGUIs.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mb_listGUIs.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -36,7 +36,7 @@
 		$sql_list_guis .= ") ORDER BY gui_name";
 		$res_list_guis = db_prep_query($sql_list_guis,$v,$t);
-		if ($_SESSION["mb_user_name"] != "test" && $_SESSION["mb_user_name"] != "demo") {
+		if ($_SESSION["mb_user_name"] != "test" && $_SESSION["mb_user_name"] != "demo" && $_SESSION["mb_user_name"] != "guest") {
 			echo "<a href=\"../php/mod_editSelf.php?".SID."\" class='list_guis' target=_blank>Change personal settings</a>";
 		echo "</td><td align = 'right'>";
Deleted: branches/nimix_dev/http/php/mb_listWMCs.php
--- branches/nimix_dev/http/php/mb_listWMCs.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mb_listWMCs.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -1,201 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mb_listWMCs.php
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__) . "/../classes/class_administration.php");
-require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
-$gui_id = $_SESSION["mb_user_gui"];
-$user_id = $_SESSION["mb_user_id"];
-$action = $_GET["action"];
-$wmcId = $_GET["wmc_id"];
-$delWmcId = $_POST["del_wmc_id"];
-$clientFilename = $_FILES['local_wmc_filename']['tmp_name'];
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-	<head>
-		<meta http-equiv="cache-control" content="no-cache">
-		<meta http-equiv="pragma" content="no-cache">
-		<meta http-equiv="expires" content="0">
-		<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
-		<title>Select web map contect document from list</title>
-	</head>
-	<body>
-		<form name='delete_wmc' action='<?php echo $self; ?>' method='POST'>
-			<input type='hidden' id='delete_wmc' name='del_wmc_id' value ='' >
-		</form>
-<?php
-function mb_listWMCs($wmcIdArray, $form_target){
-	$display = "<h2 style='font-family: Arial, Helvetica, sans-serif; color: #808080;background-color: White;'><font align='left' color='#000000'>load WMC from list</font></h2>";
-	$display .= "<table width='90%' style='font-family: Arial, Helvetica, sans-serif;font-size : 12px;color: #808080;' border='1' cellpadding='3' rules='rows'><tr style='background-color:#F0F0F0;' width='80px'><td ><b>WMC name</b></td><td><b>last update</b></td><td colspan=5></td></tr>";
-	if (count($wmcIdArray) > 0) {
-		$v = array();
-		$t = array();
-		$wmcIdList = "";
-		for ($i = 0; $i < count($wmcIdArray); $i++){
-			if ($i > 0){
-				$wmcIdList .= ",";
-			$wmcIdList .= "$".($i+1);
-			array_push($v, $wmcIdArray[$i]);
-			array_push($t, 's');
-		$sql_list_wmcs = "SELECT DISTINCT wmc_id, wmc_title, wmc_timestamp FROM mb_user_wmc ";
-		$sql_list_wmcs .= "WHERE wmc_id IN (" . $wmcIdList . ") ";
-		$sql_list_wmcs .= "ORDER BY wmc_timestamp DESC";
-		$res_list_wmcs = db_prep_query($sql_list_wmcs, $v, $t);
-		while($row = db_fetch_array($res_list_wmcs)){
-			$this_id = $row["wmc_id"];
-			$this_title = $row["wmc_title"];
-			$this_timestamp = date("M d Y H:i:s", $row["wmc_timestamp"]);
-			$display .= "<tr onmouseover='this.style.backgroundColor = \"#F08080\"' onmouseout='this.style.backgroundColor = \"#ffffff\"'>";
-			$display .= "<td>".$this_title."</td>";
-			$display .= "<td>".$this_timestamp. "</td>";
-			$display .= "<td><a href=\"" . $form_target . "&action=load&wmc_id=".$this_id."\"><img src=\"../img/button_gray/wmc_load.png\" title=\"load this WMC\"  border=0></a></td>";
-			$display .= "<td><a href=\"" . $form_target . "&action=merge&wmc_id=".$this_id."\"><img src=\"../img/button_gray/wmc_merge.png\" title=\"merge WMC\"  border=0></a></td>";
-			$display .= "<td><a href=\"" . $form_target . "&action=append&wmc_id=".$this_id."\"><img src=\"../img/button_gray/wmc_append.png\" title=\"append WMC\"  border=0></a></td>";
-			$display .= "<td><a href='../javascripts/mod_displayWmc.php?wmc_id=".$this_id."' target = '_blank'><img src=\"../img/button_gray/wmc_xml.png\" title=\"display WMC XML\"  border=0></a></td>";
-			$display .= "<td><a href=\"" . $form_target . "&action=delete&wmc_id=".$this_id."\"><img src=\"../img/button_gray/del.png\" title=\"delete this WMC\"  border=0></a></td>";
-			$display .= "</tr>";
-	else{
-		$display .= "<tr><td>There are no WMCs availiable</td></tr>";
-	$display .= "</table>";
-	return $display;
-function getTarget($gui_id) {
-	$sql = "SELECT e_requires, e_target FROM gui_element WHERE e_id = 'loadwmc' AND fkey_gui_id = $1";
-	$v = array($gui_id);
-	$t = array("s");
-	$res = db_prep_query($sql, $v, $t);
-	$cnt = 0;
-	while($row = db_fetch_array($res)){
-		$e_target = $row["e_target"];
-		$e_require = $row["e_requires"];
-		$cnt++;
-	if ($cnt > 1) {
-		$e = new mb_exception("listWMCs: e_id 'loadwmc' not unique in GUI '" . $gui_id . "'!");
-	$targetArray = explode(",", $e_target);
-	if (in_array('mapframe1', $targetArray)) {
-		return 'mapframe1';
-	else {
-		return trim($targetArray[0]);
-function loadFile($filename) {
-	$handle = fopen($filename, "r");
-	$cnt = 0;
-	while (!feof($handle)) {
-    	$buffer .= fgets($handle, 4096);
-	fclose ($handle);
-	return $buffer;
-$admin = new administration();
-$wmcIdArray = $admin->getWmcByOwner($user_id);
-// wmc is being deleted
-if (!empty($delWmcId)) {
-	$result = $admin->deleteWmc($delWmcId, $user_id);
-	if (!$result) {
-		echo "<script language='javascript'>";
-		echo "alert('WMC could not be deleted!');";
-		echo "</script>";
-// wmc is being loaded from file
-elseif ($clientFilename) {
-	$serverFilename = "../tmp/wmc" . time() . ".xml";
-	copy($clientFilename, $serverFilename);
-	$wmc = new wmc();
-	$wmc->createObjFromWMC_xml(loadFile($serverFilename));
-	$mytarget = getTarget($gui_id);
-	$js = $wmc->createJsObjFromWMC("window.opener.", $mytarget, "load");
-	echo $js;
-	if ($wmc->getTitle()) {
-		$title = "'" . $wmc->getTitle() . "' ";
-	echo "alert(\"WMC " . $title . ": load successful.\");\n";
-	echo "window.close();";
-	echo "</script>";
-// load a WMC from file
-<h2 style='font-family: Arial, Helvetica, sans-serif; color: #808080;background-color: White;'><font align='left' color='#000000'>load WMC from file</font></h2>
-<form enctype="multipart/form-data" action="<?php echo $self;?>" method=POST target="_self">
-<input type='file' name='local_wmc_filename'>
-<input type='submit' value='load'>
-</form>
-<?php
-// load a WMC from list
-echo mb_listWMCs($wmcIdArray, $self);
-if ($wmcId && in_array($wmcId, $wmcIdArray)){
-	if ($action == "delete") {
-		echo "value = confirm('Do you really want to delete this document?');";
-		echo "if (value == true) {";
-		echo "document.delete_wmc.del_wmc_id.value = '" . $wmcId . "';";
-		echo "document.delete_wmc.submit();";
-		echo "}";
-		echo "</script>";
-	else if ($action == "append" || $action == "merge" || $action == "load") {
-		$wmc = new wmc();
-		$wmc->createObjFromWMC_id($wmcId);
-		$js = $wmc->createJsObjFromWMC("window.opener.", $mytarget, $action);
-		echo $js;
-		echo "alert(\"WMC " . $title . ": " . $action . " successful.\");\n";
-		echo "</script>";
-</body>
-</html>
Modified: branches/nimix_dev/http/php/mb_validateSession.php
--- branches/nimix_dev/http/php/mb_validateSession.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mb_validateSession.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -17,18 +17,9 @@
-session_start();
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__)."/../php/system.php");
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
-// establish database connection
-$con = db_connect($DBSERVER, $OWNER, $PW);
-db_select_db(DB, $con);
 $e = new mb_notice("mb_validateSession.php: checking file " . $_SERVER["PHP_SELF"]);
@@ -49,12 +40,12 @@
 if (!$gui_id) {
 	$e = new mb_notice("gui id not set");
 	if ($_REQUEST["guiID"]) {
-		$e = new mb_notice("gui id set to guiID");
 		$gui_id = $_REQUEST["guiID"];
+		$e = new mb_notice("gui id set to guiID: " . $gui_id);
 	elseif ($_REQUEST["gui_id"]) {
-		$e = new mb_notice("gui id set to gui_id");
 		$gui_id = $_REQUEST["gui_id"];
+		$e = new mb_notice("gui id set to gui_id: " . $gui_id);
 	else {
 		$e = new mb_notice("mb_validateSession.php: gui_id not set in script: " . $_SERVER["PHP_SELF"]);
Modified: branches/nimix_dev/http/php/mod_WMSpreferences.php
--- branches/nimix_dev/http/php/mod_WMSpreferences.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_WMSpreferences.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -106,6 +106,27 @@
 var ind = window.opener.getMapObjIndexByName(mod_WMSpreferences_target1);
 var my = window.opener.mb_mapObj[ind];
+ function mb_swapWmsByIndex(mapObj_ind, indexA, indexB) {
+	if (indexA != indexB && indexA >= 0 && indexA < mb_mapObj[mapObj_ind].wms.length && indexB >= 0 && indexB < mb_mapObj[mapObj_ind].wms.length) {
+		upper = mb_mapObj[mapObj_ind].wms[indexA];
+		mb_mapObj[mapObj_ind].wms[indexA] = mb_mapObj[mapObj_ind].wms[indexB];
+		mb_mapObj[mapObj_ind].wms[indexB] = upper;
+		var upperLayers = mb_mapObj[mapObj_ind].layers[indexA];
+		var upperStyles = mb_mapObj[mapObj_ind].styles[indexA];
+		var upperQuerylayers = mb_mapObj[mapObj_ind].querylayers[indexA];
+		mb_mapObj[mapObj_ind].layers[indexA] = mb_mapObj[mapObj_ind].layers[indexB];
+		mb_mapObj[mapObj_ind].styles[indexA] = mb_mapObj[mapObj_ind].styles[indexB];
+		mb_mapObj[mapObj_ind].querylayers[indexA] = mb_mapObj[mapObj_ind].querylayers[indexB];
+		mb_mapObj[mapObj_ind].layers[indexB] = upperLayers;
+		mb_mapObj[mapObj_ind].styles[indexB] = upperStyles;
+		mb_mapObj[mapObj_ind].querylayers[indexB] = upperQuerylayers;
+		return true;
+	else {
+		return false;
 // Opacity version
Modified: branches/nimix_dev/http/php/mod_addWmsFromFeatureInfo.php
--- branches/nimix_dev/http/php/mod_addWmsFromFeatureInfo.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_addWmsFromFeatureInfo.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -23,6 +23,56 @@
 echo "var mod_target = '".$e_target[0]."';";
+function mb_swapWmsByIndex(mapObj_ind, indexA, indexB) {
+		return true;
+	else {
+		return false;
+function mb_wmsMoveByIndex(mapObj_ind, fromIndex, toIndex) {
+	if (fromIndex != toIndex && fromIndex >= 0 && fromIndex < mb_mapObj[mapObj_ind].wms.length && toIndex >= 0 && toIndex < mb_mapObj[mapObj_ind].wms.length) {
+		var changed = false;
+		var i;
+		var result;
+		if (fromIndex > toIndex) {
+			for (i = fromIndex; i > toIndex ; i--) {
+				result = mb_swapWmsByIndex(mapObj_ind, i-1, i);
+				if (result === true) {
+					changed = true;
+		else {
+			for (i = fromIndex; i < toIndex ; i++) {
+				result = mb_swapWmsByIndex(mapObj_ind, i, i+1);
+					changed = true;
+		return changed;
+	else {
+		return false;
 function addWmsFromFeatureInfo(pointer_name, version) {
 	mb_registerloadWmsSubFunctions("addWmsFromInfo_pos()");
 	var mywms = pointer_name;
@@ -55,5 +105,4 @@
 		mb_wmsMoveByIndex(getMapObjIndexByName(mod_target), mb_mapObj[getMapObjIndexByName(mod_target)].wms.length-1, mod_addWmsFromFeatureInfo_position-1);
 	eventAfterLoadWMS.unregister("addWmsFromInfo_pos()");
-//	mb_removeFunctionFromArray("mb_loadWmsSubFunctions", "addWmsFromInfo_pos()");
Deleted: branches/nimix_dev/http/php/mod_createJSObjFromDB.php
--- branches/nimix_dev/http/php/mod_createJSObjFromDB.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_createJSObjFromDB.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -1,33 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_createJSObjectFromDB.php
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
-$sql = "SELECT fkey_wms_id FROM gui_wms WHERE fkey_gui_id = $1 ORDER BY gui_wms_position";
-$v = array($_SESSION["mb_user_gui"]);
-$t = array('s');
-$res = db_prep_query($sql,$v,$t);
-while($row = db_fetch_array($res)){
-	$mywms = new wms();
-	$mywms->createObjFromDB($_SESSION["mb_user_gui"],$row["fkey_wms_id"]);
-	$mywms->createJsObjFromWMS();
Modified: branches/nimix_dev/http/php/mod_createJSObjFromDBByWMS.php
--- branches/nimix_dev/http/php/mod_createJSObjFromDBByWMS.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_createJSObjFromDBByWMS.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -39,7 +39,12 @@
 if ($admin->getWmsPermission($wms_id, $user_id)) {
 	$mywms = new wms();
-	$mywms->createObjFromDB($gui_id, $wms_id);
+	if(isset($gui_id) && $gui_id!='undefined'){
+		$mywms->createObjFromDB($gui_id, $wms_id);
+	else{
+		$mywms->createObjFromDBNoGui($wms_id);
 	$mywms->createJsObjFromWMS(true);
 	echo "parent.mod_addWMS_refresh();";
Copied: branches/nimix_dev/http/php/mod_editApplication.php (from rev 2653, trunk/mapbender/http/php/mod_editApplication.php)
--- branches/nimix_dev/http/php/mod_editApplication.php	                        (rev 0)
+++ branches/nimix_dev/http/php/mod_editApplication.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -0,0 +1,252 @@
+<?php
+# $Id: mod_editElements.php 2413 2008-04-23 16:21:04Z christoph $
+# http://www.mapbender.org/index.php/mod_editElements.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_user.php");
+$editApplicationId = $_REQUEST["editApplicationId"];
+$user = new User($_SESSION["mb_user_id"]);
+$myApplicationArray = $user->getApplicationsByPermission(false);
+if (!in_array($editApplicationId, $myApplicationArray)) {
+	die("You are not allowed to edit the application '" . $editApplicationId . "'");
+<html>
+<head>
+<style type="text/css">
+.ui-selecting {
+  border-width:thin;
+  border-style:solid;
+  border-color:red;
+  background-color:transparent;
+  font-size:9px;
+.ui-selected {
+  border-color:red;
+  font-size:9px;
+.ui-draggable {
+.div-border {
+  border-color:black;
+  font-size:9px;
+</style>
+<link rel='stylesheet' type='text/css' href='../css/popup.css'>
+<script type='text/javascript' src='../extensions/jquery-1.2.6.min.js'></script>
+<script type='text/javascript' src='../extensions/jquery-ui-personalized-1.5.min.js'></script>
+<script type='text/javascript' src='../extensions/jqjson.js'></script>
+<script type='text/javascript' src='../javascripts/popup.js'></script>
+<script language="JavaScript" type="text/javascript">
+<?php
+	include("../../lib/event.js");
+	include("../../lib/buttonNew.js");
+	include("../../lib/draggableButton.js");
+	include("../../lib/selectableButton.js");
+	include("../../lib/resizableButton.js");
+	include("../../lib/alignButton.js");
+	include("../../lib/saveButton.js");
+	echo "var editApplicationId = '" . $editApplicationId . "';";
+$(function() {
+	// create the toolbox
+	var controlPopup;
+	controlPopup = new mb_popup({
+		left:300,
+		top:300,
+		width:180,
+		height:80,
+		html:"<div id='controls'></div>",
+		title:"Toolbox"
+	var toolbox = new ButtonGroup("controls");
+	// add tools to the toolbox
+	// select tool
+	var selectButton = new Button(Selectable.buttonParameters);
+	toolbox.add(selectButton);
+	// drag tool
+	var dragButton = new Button(Draggable.buttonParameters);
+	toolbox.add(dragButton);
+	// resize tool
+	var resizeButton = new Button(Resizable.buttonParameters);
+	toolbox.add(resizeButton);
+	// save tool
+	var saveButton = new Button(Save.buttonParameters);
+	toolbox.add(saveButton);
+	//align top
+	alignTopButton = new Button(Align.top.buttonParameters);
+	toolbox.add(alignTopButton);
+	//align left
+	alignLeftButton = new Button(Align.left.buttonParameters);
+	toolbox.add(alignLeftButton);
+	//align bottom
+	alignBottomButton = new Button(Align.bottom.buttonParameters);
+	toolbox.add(alignBottomButton);
+	//align right
+	alignRightButton = new Button(Align.right.buttonParameters);
+	toolbox.add(alignRightButton);
+	// add functionality to the buttons
+	selectButton.registerPush(Selectable.makeSelectable);
+	selectButton.registerRelease(Selectable.removeSelection);
+	dragButton.registerPush(Draggable.makeDraggable);
+	dragButton.registerStop(Draggable.removeDraggable);
+	resizeButton.registerPush(Selectable.removeSelection);
+	resizeButton.registerPush(Resizable.makeResizable);
+	resizeButton.registerStop(Resizable.removeResizable);
+	saveButton.registerPush(function () {
+		Save.updateDatabase(saveButton.triggerStop);
+	alignTopButton.registerPush(Align.top.align);
+	alignLeftButton.registerPush(Align.left.align);
+	alignBottomButton.registerPush(Align.bottom.align);
+	alignRightButton.registerPush(Align.right.align);
+	// display the toolbox
+	controlPopup.show();
+</script>
+</head>
+<?php
+$pattern = "/sessionID/";
+$sql = "SELECT fkey_gui_id,e_id,e_pos,e_public,e_comment,gettext($1, e_title) as e_title, e_element,";
+$sql .= "e_src,e_attributes,e_left,e_top,e_width,e_height,e_z_index,e_more_styles,";
+$sql .= "e_content,e_closetag,e_js_file,e_mb_mod,e_target,e_requires,e_url FROM gui_element WHERE ";
+$sql .= "e_public = 1 AND fkey_gui_id = $2 ORDER BY e_pos";
+$v = array($_SESSION["mb_lang"], $editApplicationId);
+$t = array('s', 's');
+$res = db_prep_query($sql,$v,$t);
+$i = 0;
+while(db_fetch_row($res)){
+	$replacement = $urlParameters."&elementID=".db_result($res,$i,"e_id");
+	if (db_result($res,$i,"e_element") == "body" ) {
+		echo "<".db_result($res,$i,"e_element")." ";
+		echo "' ><div class='collection'>";
+	else {
+		if (db_result($res,$i,"e_left") && db_result($res,$i,"e_top")) {
+			// open tag
+			if (db_result($res,$i,"e_closetag") != "iframe" && db_result($res,$i,"e_closetag") != "form" ) {
+			else {
+				echo "<div ";
+			echo " class='div-border' ";
+			// style
+			echo " style = '";
+			if(db_result($res,$i,"e_left") != "" && db_result($res,$i,"e_top") != ""){
+				echo "position:absolute;";
+				echo "left:".db_result($res,$i,"e_left").";";
+				echo "top:".db_result($res,$i,"e_top").";";
+			if(db_result($res,$i,"e_width") != "" && db_result($res,$i,"e_height") != ""){
+				echo "width:".db_result($res,$i,"e_width").";";
+				echo "height:".db_result($res,$i,"e_height").";";
+			echo "' ";
+			// attributes
+			if(db_result($res,$i,"e_id") != ""){
+				echo " id='".db_result($res,$i,"e_id")."' ";
+				echo " name='".db_result($res,$i,"e_id")."' ";
+			if (db_result($res,$i,"e_closetag") == "select" ) {
+				echo " disabled ";
+			if(db_result($res,$i,"e_title") != ""){
+				echo " title='".db_result($res,$i,"e_title")."' ";
+			if(db_result($res,$i,"e_src") != "" && db_result($res,$i,"e_closetag") != "iframe" ){
+				if(db_result($res,$i,"e_closetag") == "iframe" && db_result($res,$i,"e_id") != 'loadData'){
+		      		echo " src = '".preg_replace($pattern,$replacement,db_result($res,$i,"e_src"));
+						if(mb_strpos(db_result($res,$i,"e_src"), "?")) {
+							echo "&";
+						else {
+			      			echo "?";
+		      			echo "e_id_css=".db_result($res,$i,"e_id")."&e_id=".db_result($res,$i,"e_id") .
+							"&e_target=".db_result($res,$i,"e_target").
+							"&" . $urlParameters . "'";
+				else{
+					echo " src = '".preg_replace($pattern,$replacement,db_result($res,$i,"e_src"))."'";
+			echo "' >";
+			if (db_result($res,$i,"e_closetag") == "iframe" || db_result($res,$i,"e_closetag") == "div") {
+				echo db_result($res,$i,"e_id");
+				echo "</".db_result($res,$i,"e_element").">";
+			else {
+				echo "</div>";
+	$i++;
+</div></body>
+</html>
Copied: branches/nimix_dev/http/php/mod_editApplication_server.php (from rev 2653, trunk/mapbender/http/php/mod_editApplication_server.php)
--- branches/nimix_dev/http/php/mod_editApplication_server.php	                        (rev 0)
+++ branches/nimix_dev/http/php/mod_editApplication_server.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -0,0 +1,58 @@
+<?php
+require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
+require_once(dirname(__FILE__) . "/../classes/class_user.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
+ * encodes and delivers the data
+ * @param object the un-encoded object
+function sendOutput($out){
+	global $json;
+	$output = $json->encode($out);
+	header("Content-Type: text/x-json");
+	echo $output;
+$json = new Mapbender_JSON();
+$queryObj = $json->decode(stripslashes($_REQUEST['queryObj']));
+$resultObj = array();
+$e = new mb_exception("command: " . $queryObj->command);
+$userId = $_SESSION[mb_user_id];
+switch($queryObj->command){
+	// gets available WMCs
+	case 'update':
+		$elementArray = $queryObj->parameters->data;
+		for ($i = 0; $i < count($elementArray); $i++) {
+			$currentElement = $elementArray[$i];
+			$id = $currentElement->id;
+			$top = $currentElement->top;
+			$left = $currentElement->left;
+			$width = $currentElement->width;
+			$height = $currentElement->height;
+			$app = $queryObj->parameters->applicationId;
+			$sql = "UPDATE gui_element SET e_left = $1, e_top = $2, " .
+					"e_width = $3, e_height = $4 " .
+					"WHERE e_id = $5 AND fkey_gui_id = $6";
+			$v = array($left, $top, $width, $height, $id, $app);
+			$t = array("i", "i", "i", "i", "s", "s");
+			$res = db_prep_query($sql, $v, $t);
+			$e = new mb_notice("updating element '" . $id . "'");
+		$resultObj["success"] = "Elements have been updated in the database.";
+	break;
+	// Invalid command
+	default:
+		$resultObj["error"] = "no action specified...";
+sendOutput($resultObj);
Modified: branches/nimix_dev/http/php/mod_editElements.php
--- branches/nimix_dev/http/php/mod_editElements.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_editElements.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -466,6 +466,12 @@
 	   echo "<input type='button' class='' name='' value='delete' onclick='thisDelete()'> \n";
 	   echo "<input type='button' class='' name='' value='show' onclick='thisShow()'> \n";
 	   echo "<input type='button' class='' name='' value='sql' onclick='thisExport()'> \n";
+	   echo	"<input type='button' class='' name='' value='arrange' " .
+	   		"onclick='window.open(\"mod_editApplication.php?" . SID . "&" .
+	   		"guiID=" . $_SESSION["mb_user_gui"] . "&" .
+	   		"editApplicationId=" . $guiList1 . "\", " .
+	   		"\"edit application\", " .
+	   		"\"width=500,height=500,dependent\");'> \n";
 	   echo "</div>\n";
 	   echo "<input type='hidden'  name='guiList1' value='".$guiList1."' >\n";
 	   echo "<input type='hidden'  name='guiId' value='".$guiId."' >\n";
Modified: branches/nimix_dev/http/php/mod_gazetteerMetadata.php
--- branches/nimix_dev/http/php/mod_gazetteerMetadata.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_gazetteerMetadata.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -99,7 +99,7 @@
    else{
 		document.getElementById("resultDivTag").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Searching...</td></tr></table>";
-		parent.mb_ajax_json("mod_gazetteerMetadata_search.php", {"search":document.form1.search.value}, function(jsonObj, status){
+		parent.mb_ajax_json("../php/mod_gazetteerMetadata_search.php", {"search":document.form1.search.value}, function(jsonObj, status){
 			document.getElementById("resultDivTag").innerHTML = displayTable(jsonObj);
 		return false;
@@ -236,4 +236,4 @@
 </form>
 <div id='resultDivTag' class='result'></div>
 </body>
-</html>
+</html>
Deleted: branches/nimix_dev/http/php/mod_insertWmcIntoDb.php
--- branches/nimix_dev/http/php/mod_insertWmcIntoDb.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_insertWmcIntoDb.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -1,63 +0,0 @@
-<?php
-#$Id: mod_insertWmcIntoDb.php 1198 2007-10-18 14:37:52Z baudson $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-require_once(dirname(__FILE__)."/../classes/class_wmc.php");
-require_once(dirname(__FILE__)."/../extensions/JSON.php");
-$json = new Services_JSON();
-$mapObject = $json->decode(stripslashes($_POST["mapObject"]));
-$save_in_session = $_POST["saveInSession"];
-$generalTitle = $_POST["generalTitle"];
-$extensionData = $json->decode(stripslashes($_POST["extensionData"]));
-$wmc = new wmc();
-$wmc->createWMCFromObj($mapObject, $user_id, $generalTitle, $extensionData);
-if ($save_in_session) {
-	$_SESSION["mb_wmc"] = $wmc->xml;
-	$_SESSION["epsg"] = $mapObject->epsg;
-	$_SESSION["previous_gui"] = $_SESSION["mb_user_gui"];
-	$e = new mb_notice("mod_insertWMCIntoDB: save WMC in session succeeded.");
-else {
-	if ($user_id && $wmc->wmc_id) {
-		$sql = "INSERT INTO mb_user_wmc VALUES ($1, $2, $3, $4, $5)";
-		$v = array($wmc->wmc_id, $user_id, $wmc->xml, $generalTitle, time());
-		$t = array("s", "i", "s", "s", "s");
-		if (db_error()) {
-			$errMsg = "Error while saving WMC document '" . $generalTitle . "': " . db_error();
-			echo $errMsg;
-			$e = new mb_exception("mod_insertWMCIntoDB: " . $errMsg);
-		else {
-			echo "WMC document '" . $generalTitle . "' has been saved.";
-			$e = new mb_notice("mod_insertWMCIntoDB: WMC  '" . $generalTitle . "' saved successfully.");
-	else {
-		$e = new mb_exception("mod_insertWMCIntoDB: missing parameters (user_id: ".$user_id.", wmc_id: ".$wmc->wmc_id."))");
Copied: branches/nimix_dev/http/php/mod_loadwmc_server.php (from rev 2653, trunk/mapbender/http/php/mod_loadwmc_server.php)
--- branches/nimix_dev/http/php/mod_loadwmc_server.php	                        (rev 0)
+++ branches/nimix_dev/http/php/mod_loadwmc_server.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -0,0 +1,174 @@
+<?php
+require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
+	global $json;
+	echo $output;
+ * Get all available WMC documents from the database
+ * @return mixed[] an array of wmcs
+ * 					(wmc = assoc. array of "id", "title", "timestamp")
+function getWmc(){
+	global $con;
+	global $userId;
+	$wmcArray = array();
+	// get WMC ids
+	$currentUser = new User($userId);
+	$wmcIdArray = $currentUser->getWmcByOwner();
+	// get WMC data
+	$v = array();
+	$t = array();
+	$wmcIdList = "";
+	for ($i = 0; $i < count($wmcIdArray); $i++) {
+		if ($i > 0) {
+			$wmcIdList .= ",";
+		$wmcIdList .= "$".($i+1);
+		array_push($v, $wmcIdArray[$i]);
+		array_push($t, 's');
+	$sql = "SELECT DISTINCT wmc_id, wmc_title, wmc_timestamp " .
+		"FROM mb_user_wmc WHERE wmc_id IN (" . $wmcIdList . ") " .
+		"ORDER BY wmc_timestamp DESC";
+	while($row = db_fetch_array($res)){
+		$currentResult = array();
+		$currentResult["id"] = $row["wmc_id"];
+		$currentResult["title"] = $row["wmc_title"];
+		$currentResult["timestamp"] = date("M d Y H:i:s", $row["wmc_timestamp"]);
+		array_push($wmcArray, $currentResult);
+	return $wmcArray;
+$wmc = new wmc();
+	case 'getWmc':
+		$resultObj["wmc"] = getWmc();
+	break;
+	// gets XML document of a WMC
+	case 'getWmcDocument':
+		$wmcId = $queryObj->parameters->id;
+		$doc = $wmc->getDocument($wmcId);
+		if (!$doc) {
+			$resultObj["error"] = "The WMC document could not be found.";
+		else {
+			$resultObj["wmc"] = array("document" => $doc);
+	break;
+	// deletes a WMC
+	case 'deleteWmc':
+		if ($wmc->delete($wmcId)) {
+			$resultObj["success"] = "WMC has been deleted from the database.";
+		else {
+			$resultObj["error"] = "WMC could not be deleted.";
+	break;
+	// loads a WMC (returns array of JS code)
+	case 'loadWmc':
+		$wmc->createFromDb($wmcId);
+		$jsArray = $wmc->toJavaScript();
+		if ($jsArray) {
+			$resultObj["javascript"] = $jsArray;
+		else {
+			$resultObj["error"] = "WMC could not be loaded.";
+	break;
+	// merges data with WMC and loads it (returns array of JS code)
+	case 'mergeWmc':
+		$params = $queryObj->parameters;
+		// generate a WMC for the current client state
+		$currentWmc = new wmc();
+		$currentWmc->createFromJs($params->mapObject, $params->generalTitle, $params->extensionData);
+		// get the desired WMC from the database
+		$wmcXml = wmc::getDocument($wmcId);
+		// merge the two WMCs
+		$currentWmc->merge($wmcXml);
+		// load the merged WMC
+		$jsArray = $currentWmc->toJavaScript();
+		if (is_array($jsArray) && count($jsArray) > 0) {
+		else {
+	break;
+	// appends a WMC (returns JS code)
+	case 'appendWmc':
+		$currentWmc->append($wmcXml);
+		else {
+			$resultObj["error"] = "WMC could not be appended.";
+	break;
+	default:
Modified: branches/nimix_dev/http/php/mod_map1.php
--- branches/nimix_dev/http/php/mod_map1.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_map1.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -48,17 +48,74 @@
 echo "var mod_map1_height = '".$e_height."';\n";
 echo "</script>\n";
+<script type='text/javascript' src='../extensions/jquery.mousewheel.min.js'></script>
 <script type="text/javascript">
+var mapTimeout;
+var	sum_delta = 0;
+var lastTimestamp;
+var lastScrollPositionX;
+var lastScrollPositionY;
 function init () {
 	parent.eventInitMap.register(function init_mod_map1(){
 		parent.mb_registerMapObj('mapframe1', 'maps', null,mod_map1_width, mod_map1_height);
-		document.getElementById("maps").style.width = mod_map1_width;
-		document.getElementById("maps").style.height = mod_map1_height;
+		parent.$(document, window.frames['mapframe1']).mousewheel(function (event, delta) {
+			if (sum_delta == 0) {
+				mapTimeout = setTimeout(function () {
+						lastScrollPositionX=event.pageX;
+						lastScrollPositionY=event.pageY;
+						mousewheelZoom();
+					100);
+			sum_delta = sum_delta + (delta);
+			var currentTime = new Date();
+			lastTimestamp = currentTime.getTime();
+			return false;
+function mousewheelZoom () {
+	if (currentTime.getTime() - lastTimestamp > 200) {
+		var ind = parent.getMapObjIndexByName('mapframe1');
+		var pos = parent.makeClickPos2RealWorldPos("mapframe1", lastScrollPositionX, lastScrollPositionY);
+		if (sum_delta > 0) {
+			parent.zoom("mapframe1", true, Math.pow(parent.mapbender.zoomMousewheel, sum_delta), pos[0],pos[1]);
+		else {
+			parent.zoom("mapframe1", false, Math.pow(parent.mapbender.zoomMousewheel, -sum_delta), pos[0], pos[1]);
+		var newPosX =  parent.parent.mb_mapObj[ind].width - lastScrollPositionX;
+		var newPosY =  parent.parent.mb_mapObj[ind].height - lastScrollPositionY;
+		var posAfterZoom = parent.makeClickPos2RealWorldPos("mapframe1", newPosX, newPosY);
+		parent.zoom('mapframe1', false, 1.0, posAfterZoom[0], posAfterZoom[1]);
+		sum_delta = 0;
+		clearTimeout(mapTimeout);
+	else {
+				mousewheelZoom(sum_delta);
+			100);
 </script>
 </head>
Modified: branches/nimix_dev/http/php/mod_mapOV.php
--- branches/nimix_dev/http/php/mod_mapOV.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_mapOV.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -68,12 +68,12 @@
 		document.onmousedown = parent.mod_box_start;
 		document.onmouseup = mod_ov_getExtent;
 		document.onmousemove = parent.mod_box_run;
-		document.getElementById("maps").style.width = mod_overview_width;
-		document.getElementById("maps").style.height = mod_overview_height;
 		var ind = parent.getMapObjIndexByName('overview');
 		var ov_extent = parent.mb_mapObj[ind].getExtentInfos();
-		parent.mb_setWmcExtensionData({"ov_minx":ov_extent.minx,"ov_miny":ov_extent.miny,"ov_maxx":ov_extent.maxx,"ov_maxy":ov_extent.maxy});
+//		parent.mb_setWmcExtensionData({"ov_minx":ov_extent.minx,"ov_miny":ov_extent.miny,"ov_maxx":ov_extent.maxx,"ov_maxy":ov_extent.maxy});
+		parent.mb_mapObj[ind].isOverview = true;
 function mod_ov_setHandler(e){
Copied: branches/nimix_dev/http/php/mod_savewmc_server.php (from rev 2653, trunk/mapbender/http/php/mod_savewmc_server.php)
--- branches/nimix_dev/http/php/mod_savewmc_server.php	                        (rev 0)
+++ branches/nimix_dev/http/php/mod_savewmc_server.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -0,0 +1,50 @@
+<?php
+#$Id: mod_insertWmcIntoDb.php 1198 2007-10-18 14:37:52Z baudson $
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+require_once(dirname(__FILE__)."/../classes/class_wmc.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+// get data from POST and SESSION
+$mapObject = $json->decode(stripslashes($_POST["mapObject"]));
+$userId = $_SESSION["mb_user_id"];
+$saveInSession = $_POST["saveInSession"];
+$generalTitle = $_POST["generalTitle"];
+$extensionData = $json->decode(stripslashes($_POST["extensionData"]));
+// create WMC object
+$wmc = new wmc();
+$wmc->createFromJs($mapObject, $generalTitle, $extensionData);
+if ($saveInSession) {
+	// store XML in session
+	$_SESSION["mb_wmc"] = $wmc->xml;
+	$_SESSION["epsg"] = $mapObject->epsg;
+	$_SESSION["previous_gui"] = $_SESSION["mb_user_gui"];
+	$e = new mb_notice("mod_insertWMCIntoDB: save WMC in session succeeded.");
+else {
+	// insert WMC into database
+	$result = $wmc->insert();
+	echo $result["message"];
Modified: branches/nimix_dev/http/php/mod_treefolderClient.php
--- branches/nimix_dev/http/php/mod_treefolderClient.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_treefolderClient.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -204,12 +204,22 @@
 		cBox[ind]['layer'] = array_layer;
+function mb_getLayerObjByName(fname,wms_id,layer_name){
+	var ind = parent.getMapObjIndexByName(fname);
+	var wmsInd = parent.getWMSIndexById(fname,wms_id);
+	var t = parent.mb_mapObj[ind].wms[wmsInd];
+	for(var i=0; i < t.objLayer.length; i++){
+		if(t.objLayer[i].layer_name == layer_name){
+			return t.objLayer[i];
 function checkLayer(){
 	var checkit;
 	for(var i=0; i<cBox.length; i++){
 		checkit = true;
 		for(var j=0; j<cBox[i]['wms'].length;j++){
-			var obj = parent.mb_getLayerObjByName(treetarget,cBox[i]['wms'][j],cBox[i]['layer'][j]);
+			var obj = mb_getLayerObjByName(treetarget,cBox[i]['wms'][j],cBox[i]['layer'][j]);
 			if(obj){
 				if(obj.gui_layer_visible == '0' || obj.gui_layer_visible == 0){
 					checkit = false;
Modified: branches/nimix_dev/http/php/mod_wfs.php
--- branches/nimix_dev/http/php/mod_wfs.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_wfs.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -67,7 +67,7 @@
 </script>
 <?php
 echo "<script language='JavaScript' type='text/javascript'>";
-if(isset($_REQUEST['id'])){
+if(isset($_REQUEST['id']) && $_REQUEST['id']!=""){
 	$wfs = mb_split(",",$_REQUEST['id']);
 	$con = db_connect($DBSERVER,$OWNER,$PW);
Modified: branches/nimix_dev/http/php/mod_wfs_conf.php
--- branches/nimix_dev/http/php/mod_wfs_conf.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_wfs_conf.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -65,6 +65,32 @@
+function controlOperators(checkVal,operatorField,valType){
+	var opSelect = document.getElementById(operatorField);
+	removeChildNodes(opSelect);
+	option1 = new Option("-----","0");
+	opSelect.options[opSelect.length] = option1;
+	if(checkVal==true){
+		opSelect.disabled = '';
+		option2 = new Option("%...%","bothside");
+		opSelect.options[opSelect.length] = option2;
+		option3 = new Option("...%","rightside");
+		opSelect.options[opSelect.length] = option3;
+		option4 = new Option("equal","equal");
+		opSelect.options[opSelect.length] = option4;
+		option5 = new Option(">","greater_than");
+		opSelect.options[opSelect.length] = option5;
+		option6 = new Option("<","less_than");
+		opSelect.options[opSelect.length] = option6;
+		option7 = new Option(">=","greater_equal_than");
+		opSelect.options[opSelect.length] = option7;
+		option8 = new Option("<=","less_equal_than");
+		opSelect.options[opSelect.length] = option8;
+	else{
+		opSelect.disabled = 'disabled';
 </script>
 </head>
@@ -72,9 +98,9 @@
 <br>
 <b>WFS Configuration</b>
 <br>
-<form method='POST' onsubmit='return validate()'>
+<form method='POST' action='<?php echo $self;?>'onsubmit='return validate()'>
 <br>
-<a href="mod_wfs_edit.php">edit WFS Configuration</a><br><br>
+<a href="mod_wfs_edit.php?<?php echo $urlParameters;?>">edit WFS Configuration</a><br><br>
 Select WFS:&nbsp;
 <?php
 $aWFS = new wfs_conf();
@@ -95,67 +121,81 @@
         db_select_db($DB,$con);
-        $sql = "INSERT INTO wfs_conf (wfs_conf_abstract,wfs_conf_description,fkey_wfs_id,fkey_featuretype_id,g_label,g_label_id,g_button,g_button_id,g_style,g_buffer,g_res_style,g_use_wzgraphics) VALUES(";
-        $sql .= "'".$_REQUEST["wfs_conf_abstract"]."',";
-        $sql .= "'".$_REQUEST["wfs_conf_description"]."',";
-        $sql .= "'".$_REQUEST["wfs"]."',";
-        $sql .= "'".$_REQUEST["featuretype"]."',";
-        $sql .= "'".$_REQUEST["g_label"]."',";
-        $sql .= "'".$_REQUEST["g_label_id"]."',";
-        $sql .= "'".$_REQUEST["g_button"]."',";
-        $sql .= "'".$_REQUEST["g_button_id"]."',";
-        $sql .= "'".$_REQUEST["g_style"]."',";
-        $sql .= "'".$_REQUEST["g_buffer"]."',";
-        $sql .= "'".$_REQUEST["g_res_style"]."',";
+        $sql = "INSERT INTO wfs_conf (";
+        $sql .= "wfs_conf_abstract, fkey_wfs_id, ";
+        $sql .= "fkey_featuretype_id, g_label, g_label_id, g_button, ";
+        $sql .= "g_button_id, g_style, g_buffer, g_res_style, g_use_wzgraphics";
+		$sql .= ") VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, ";
         if(!empty($_REQUEST["g_use_wzgraphics"])){
 			$sql .= "'1'";
-		}else{$sql .= "'0'";}
+		else {
+			$sql .= "'0'";
         $sql .= "); ";
-        $res = db_query($sql);
+		$v = array($_REQUEST["wfs_conf_abstract"], $_REQUEST["wfs"], $_REQUEST["featuretype"], $_REQUEST["g_label"], $_REQUEST["g_label_id"], $_REQUEST["g_button"], $_REQUEST["g_button_id"], $_REQUEST["g_style"], $_REQUEST["g_buffer"], $_REQUEST["g_res_style"]);
+		$t = array("s", "s", "s", "s", "s", "s", "s", "s", "s", "s");
         $wfsID = db_insert_id($con,'wfs_conf','wfs_conf_id');
         for($i=0; $i<$_REQUEST["num"]; $i++){
-                $sql = "INSERT INTO wfs_conf_element (fkey_wfs_conf_id,f_id,f_search,f_pos,f_style_id,f_toupper,f_label,f_label_id,f_show,f_respos,f_edit,f_form_element_html,f_mandatory,f_auth_varname,f_show_detail) VALUES(";
-                $sql .= "'".$wfsID."',";
-                $sql .= "'".$_REQUEST["f_id".$i]."',";
-                if(!empty($_REQUEST["f_search".$i])){
-                	$sql .= "'1',";
-                }else{$sql .= "'0',";}
-                $sql .= "'".$_REQUEST["f_pos".$i]."',";
-                $sql .= "'".$_REQUEST["f_style_id".$i]."',";
-				if(!empty($_REQUEST["f_toupper".$i])){
-                	$sql .= "'1',";
-                $sql .= "'".$_REQUEST["f_label".$i]."',";
-                $sql .= "'".$_REQUEST["f_label_id".$i]."',";
-                if(!empty($_REQUEST["f_show".$i])){
-                	$sql .= "'1',";
-                $sql .= "'".$_REQUEST["f_respos".$i]."'";
-				$sql .= ",";
-                if(!empty($_REQUEST["f_edit".$i])){
-                	$sql .= "'1',";
-                $sql .= "'".$_REQUEST["f_form_element_html".$i]."',";
-                if(!empty($_REQUEST["f_mandatory".$i])){
+                $sql = "INSERT INTO wfs_conf_element (fkey_wfs_conf_id,f_id,f_search,f_pos,f_min_input,f_style_id,f_toupper,f_label,f_label_id,f_show,f_respos,f_edit,f_form_element_html,f_mandatory,f_auth_varname,f_show_detail,f_detailpos,f_operator) VALUES(";
+                $sql .= "$1, $2, ";
+                if (!empty($_REQUEST["f_search".$i])) {
                 	$sql .= "'1'";
-                $sql .= ", ";
-                $sql .= "'".$_REQUEST["f_auth_varname".$i];
-				$sql .= "'";
-				$sql .= ", ";
-				if(!empty($_REQUEST["f_show_detail".$i])){
-            		$sql .= "'1'";
-               $sql .= "); ";
+                else {
+                	$sql .= "'0'";
+                $sql .= ", $3, $4, $5, ";
+				if (!empty($_REQUEST["f_toupper".$i])) {
+                	$sql .= "'1'";
+                else {
+                	$sql .= "'0'";
+                $sql .= ",$6, $7, ";
+                if (!empty($_REQUEST["f_show".$i])) {
+                	$sql .= "'1'";
+                else {
+                	$sql .= "'0'";
+                $sql .= ", $8, ";
+                if (!empty($_REQUEST["f_edit".$i])) {
+                	$sql .= "'1'";
+                else {
+                	$sql .= "'0'";
+                $sql .= ",$9, ";
+                if (!empty($_REQUEST["f_mandatory".$i])) {
+                	$sql .= "'1'";
+                else {
+                	$sql .= "'0'";
+                $sql .= ",$10,";
+                if(!empty($_REQUEST["f_show_detail".$i])){
+                	$sql .= "'1'";
+                else {
+                	$sql .= "'0'";
+                $sql .= ",$11,$12";
+ 				$sql .= "); ";
+				$v = array($wfsID, $_REQUEST["f_id".$i], $_REQUEST["f_pos".$i], $_REQUEST["f_min_input".$i], $_REQUEST["f_style_id".$i], $_REQUEST["f_label".$i], $_REQUEST["f_label_id".$i], $_REQUEST["f_respos".$i], stripslashes($_REQUEST["f_form_element_html".$i]), $_REQUEST["f_auth_varname".$i], $_REQUEST["f_detailpos".$i], $_REQUEST["f_operator".$i]);
+				$t = array("i", "s", "s", "i", "s", "s", "s", "i", "s", "s", "i", "s");
         if (isset($_REQUEST["f_geom"])) {
-	        $sql = "UPDATE wfs_conf_element SET ";
-	        $sql .= "f_geom = 1";
-	        $sql .= " WHERE fkey_wfs_conf_id = ".$wfsID." AND f_id = ".$_REQUEST["f_geom"].";";
+	        $sql = "UPDATE wfs_conf_element SET f_geom = 1 ";
+	        $sql .= "WHERE fkey_wfs_conf_id = $1 AND f_id = $2;";
+	        $v = array($wfsID, $_REQUEST["f_geom"]);
+	        $t = array("i", "i");
 		echo "document.location.href = 'mod_wfs_edit.php?gaz=".$wfsID."';";
@@ -233,8 +273,7 @@
         /* set featuretype options */
         echo "<table>";
-        echo "<tr><td>Title:</td><td><input type='text' name='wfs_conf_abstract'></td></tr>" ;
-        echo "<tr><td>Description:</td><td><input type='text' name='wfs_conf_description'></td></tr>" ;
+        echo "<tr><td>Abstract:</td><td><input type='text' name='wfs_conf_abstract'></td></tr>" ;
         echo "<tr><td>Label:</td><td><input type='text' name='g_label'></td></tr>" ;
         echo "<tr><td>Label_id:</td><td><input type='text' name='g_label_id'></td></tr>" ;
         echo "<tr><td>Button:</td><td><input type='text' name='g_button'></td></tr>" ;
@@ -255,17 +294,20 @@
                 echo "<td>" . toImage('geom') . "</td>";
                 echo "<td>" . toImage('search') . "</td>";
                 echo "<td>" . toImage('pos') . "</td>";
+                echo "<td>" . toImage('minimum_input') . "</td>";
                 echo "<td>" . toImage('style_id') . "</td>";
                 echo "<td>" . toImage('upper') . "</td>";
                 echo "<td>" . toImage('label') . "</td>";
                 echo "<td>" . toImage('label_id') . "</td>";
                 echo "<td>" . toImage('show') . "</td>";
+                echo "<td>" . toImage('position') . "</td>";
                 echo "<td>" . toImage('show_detail') . "</td>";
-                echo "<td>" . toImage('position') . "</td>";
+                echo "<td>" . toImage('detail_position') . "</td>";
                 echo "<td>" . toImage('mandatory') . "</td>";
                 echo "<td>" . toImage('edit') . "</td>";
                 echo "<td>" . toImage('html') . "</td>";
                 echo "<td>" . toImage('auth') . "</td>";
+                echo "<td>" . toImage('operator') . "</td>";
         echo "</tr>";
@@ -274,19 +316,31 @@
                 echo "<td>".$aWFS->elements->element_id[$i]."<input type='hidden' name='f_id".$i."' value='".$aWFS->elements->element_id[$i]."'></td>";
                 echo "<td>".$aWFS->elements->element_name[$i]."<br><div style='font-size:10'>".$aWFS->elements->element_type[$i]."</div></td>";
                 echo "<td><input name='f_geom' type='radio' value='".$aWFS->elements->element_id[$i]."'></td>";
-                echo "<td><input name='f_search".$i."' type='checkbox'></td>";
+                echo "<td><input name='f_search".$i."' type='checkbox' onclick='controlOperators(document.forms[0].f_search".$i.".checked,\"f_operator".$i."\",\"".$aWFS->elements->element_type[$i]."\");'></td>";
                 echo "<td><input name='f_pos".$i."' type='text' size='1' value='0'></td>";
+                echo "<td><select name='f_min_input".$i."' id='f_min_input".$i."'>";
+                echo "<option value='0'>-----</option>";
+                echo "<option value='1'>1</option>";
+                echo "<option value='2'>2</option>";
+                echo "<option value='3'>3</option>";
+                echo "<option value='4'>4</option>";
+                echo "<option value='5'>5</option>";
+                echo "</select></td>";
                 echo "<td><input name='f_style_id".$i."' type='text' size='2' value='0'></td>";
                 echo "<td><input name='f_toupper".$i."' type='checkbox'></td>";
                 echo "<td><input name='f_label".$i."' type='text' size='4'></td>";
                 echo "<td><input name='f_label_id".$i."' type='text' size='2'  value='0'></td>";
                 echo "<td><input name='f_show".$i."' type='checkbox'></td>";
+                echo "<td><input name='f_respos".$i."' type='text' size='1' value='0'></td>";
                 echo "<td><input name='f_show_detail".$i."' type='checkbox'></td>";
-                echo "<td><input name='f_respos".$i."' type='text' size='1' value='0'></td>";
+                echo "<td><input name='f_detailpos".$i."' type='text' size='1' value='0'></td>";
                 echo "<td><input name='f_mandatory".$i."' type='checkbox'></td>";
                 echo "<td><input name='f_edit".$i."' type='checkbox'></td>";
                 echo "<td><textarea name='f_form_element_html".$i."' cols='15' rows='1'></textarea></td>";
                 echo "<td><input name='f_auth_varname".$i."' type='text' size='8' value=''></td>";
+                echo "<td><select name='f_operator".$i."' id='f_operator".$i."' disabled>";
                 echo "</tr>";
         echo "</table>";
Modified: branches/nimix_dev/http/php/mod_wfs_edit.php
--- branches/nimix_dev/http/php/mod_wfs_edit.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_wfs_edit.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -40,18 +40,6 @@
 function validate(){
 	return true;
-function openwindow(Adresse) {
-	Fenster1 = window.open(Adresse, "GeoPortal Rheinland-Pfalz - Metadaten", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
-	Fenster1.focus();
-function removeChildNodes(node) {
-	while (node.childNodes.length > 0) {
-		var childNode = node.firstChild;
-		node.removeChild(childNode);
 </script>
 </head>
@@ -59,100 +47,98 @@
 <br>
 <br><br>
-<form name='form1' method='POST' onsubmit='return validate()'>
-<a href="mod_wfs_conf.php">new Configuration</a><br><br>
+<form name='form1' action='<?php echo $self;?>' method='POST' onsubmit='return validate()'>
+<a href="mod_wfs_conf.php?<?php echo $urlParameters;?>">new Configuration</a><br><br>
 Select WFS Configuration:<br><br>
 <?php
 /* save wfs_conf properties */
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db($DB,$con);
 if(isset($_REQUEST["save"])){
         $sql = "UPDATE wfs_conf SET ";
-        $sql .= "wfs_conf_abstract = '".$_REQUEST["wfs_conf_abstract"]."',";
-        $sql .= "wfs_conf_description = '".$_REQUEST["wfs_conf_description"]."',";
-        $sql .= "g_label = '".$_REQUEST["g_label"]."',";
-        $sql .= "g_label_id = '".$_REQUEST["g_label_id"]."',";
-        $sql .= "g_button = '".$_REQUEST["g_button"]."',";
-        $sql .= "g_button_id = '".$_REQUEST["g_button_id"]."',";
-        $sql .= "g_style = '".$_REQUEST["g_style"]."',";
-        $sql .= "g_buffer = '".$_REQUEST["g_buffer"]."',";
-        $sql .= "g_res_style = '".$_REQUEST["g_res_style"]."',";
-        $sql .= "g_use_wzgraphics = ";
-        if(!empty($_REQUEST["g_use_wzgraphics"])){
-        	$sql .= '1';
-        }else{$sql .= '0';}
-        $sql .= " WHERE wfs_conf_id = ".$_REQUEST["gaz"].";";
+        $sql .= "wfs_conf_abstract = $1, g_label = $2, ";
+        $sql .= "g_label_id = $3, g_button = $4, g_button_id = $5, g_style = $6, ";
+        $sql .= "g_buffer = $7, g_res_style = $8, g_use_wzgraphics = ";
+        if (!empty($_REQUEST["g_use_wzgraphics"])) {
+        	$sql .= "1";
+        else {
+        	$sql .= "0";
+        $sql .= " WHERE wfs_conf_id = $9;";
+        $v = array($_REQUEST["wfs_conf_abstract"], $_REQUEST["g_label"], $_REQUEST["g_label_id"], $_REQUEST["g_button"], $_REQUEST["g_button_id"], $_REQUEST["g_style"], $_REQUEST["g_buffer"], $_REQUEST["g_res_style"], $_REQUEST["gaz"]);
+        $t = array("s", "s", "s", "s", "s", "s", "s", "i", "s");
-	        $sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id = ".$_REQUEST["f_geom"].";";
+	        $v = array($_REQUEST["gaz"], $_REQUEST["f_geom"]);
+	        $t = array("i", "s");
-	        $sql .= "f_geom = 0";
-	        $sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id <>  ".$_REQUEST["f_geom"].";";
+			$sql = "UPDATE wfs_conf_element SET f_geom = 0 ";
+	        $sql .= "WHERE fkey_wfs_conf_id = $1 AND f_id <> $2;";
 		else {
-	        $sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"].";";
+	        $sql .= "WHERE fkey_wfs_conf_id = $1;";
+	        $v = array($_REQUEST["gaz"]);
+	        $t = array("i");
-                $sql .= "f_search = '";
-                	$sql .= '1';
-                $sql .= "',";
-                $sql .= "f_pos = '".$_REQUEST["f_pos".$i]."',";
-                $sql .= "f_style_id = '".$_REQUEST["f_style_id".$i]."',";
+                $sql = "UPDATE wfs_conf_element SET f_search = '";
+                	$sql .= "1";
+                else {
+                	$sql .= "0";
+                $sql .= "', f_pos = $1, f_style_id = $2,";
                 $sql .= "f_toupper = '" ;
-                	$sql .= '1';
-                $sql .= "',";
-                $sql .= "f_label = '".$_REQUEST["f_label".$i]."',";
-                $sql .= "f_label_id = '".$_REQUEST["f_label_id".$i]."',";
+                	$sql .= "1";
+                else {
+                	$sql .= "0";
+                $sql .= "',f_label = $3, f_label_id = $4,";
                 $sql .= "f_show = '";
-                	$sql .= '1';
-				$sql .= "',";
-                $sql .= "f_respos = '".$_REQUEST["f_respos".$i]."' ";
-				$sql .= ",";
+                	$sql .= "1";
+                else {
+                	$sql .= "0";
+				$sql .= "',f_respos = $5,";
                 $sql .= "f_edit = '";
-                	$sql .= '1';
-				$sql .= "',";
-                $sql .= "f_form_element_html = '".$_REQUEST["f_form_element_html".$i];
-				$sql .= "',";
+                	$sql .= "1";
+                else {
+                	$sql .= "0";
+				$sql .= "', f_form_element_html = $6,";
                 $sql .= "f_mandatory = '";
                 	$sql .= "1";
-                }else{$sql .= "0";}
-				$sql .= "'";
-                $sql .= ", ";
-                $sql .= "f_auth_varname = '".$_REQUEST["f_auth_varname".$i];
-				$sql .= "'";
-				$sql .= ", ";
-				$sql .= "f_show_detail = '";
-                	$sql .= '1';
-                $sql .= "'";
-				$sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id = ".$_REQUEST["f_id".$i].";";
+                else {
+                	$sql .= "0";
+				$sql .= "', f_auth_varname = $7";
+				$sql .= " WHERE fkey_wfs_conf_id = $8 AND f_id = $9;";
+				$v = array($_REQUEST["f_pos".$i], $_REQUEST["f_style_id".$i], $_REQUEST["f_label".$i], $_REQUEST["f_label_id".$i], $_REQUEST["f_respos".$i], stripslashes($_REQUEST["f_form_element_html".$i]), $_REQUEST["f_auth_varname".$i], $_REQUEST["gaz"], $_REQUEST["f_id".$i]);
@@ -160,10 +146,8 @@
 /* select wfs */
-$sql = "SELECT * FROM wfs_conf, wfs WHERE wfs.wfs_owner = $1 AND wfs_conf.fkey_wfs_id = wfs.wfs_id";
-$v = array($_SESSION['mb_user_id']);
-$t = array('i');
+$sql = "SELECT * FROM wfs_conf";
+$res = db_query($sql);
 echo "<select size='10' name='gaz' onchange='submit()'>";
 $cnt = 0;
@@ -189,15 +173,15 @@
 /* configure elements */
-if(isset($_REQUEST["gaz"])){
-        $sql = "SELECT * FROM wfs_conf WHERE wfs_conf_id = ".$_REQUEST["gaz"];
+if (isset($_REQUEST["gaz"])) {
+        $sql = "SELECT * FROM wfs_conf WHERE wfs_conf_id = $1";
+        $t = array("i");
         if($row = db_fetch_array($res)){
                 echo "<table>";
-                #echo "<tr><td><a onclick='openwindow(this.href); return false' target='_blank' href='../x_geoportal/mod_featuretypeMetadata.php?wfs_conf_id=".$row["wfs_conf_id"]."'>Link zum WFS</a></td></tr>";
                 echo "<tr><td>GazetterID:</td><td>".$row["wfs_conf_id"]."</td></tr>" ;
-                echo "<tr><td>Title:</td><td><input type='text' name='wfs_conf_abstract' value='".$row["wfs_conf_abstract"]."'></td></tr>" ;
-                echo "<tr><td>Description:</td><td><input type='text' name='wfs_conf_description' value='".$row["wfs_conf_description"]."'></td></tr>" ;
+                echo "<tr><td>Abstract:</td><td><input type='text' name='wfs_conf_abstract' value='".$row["wfs_conf_abstract"]."'></td></tr>" ;
                 echo "<tr><td>Label:</td><td><input type='text' name='g_label' value='".$row["g_label"]."'></td></tr>" ;
                 echo "<tr><td>Label_id:</td><td><input type='text' name='g_label_id' value='".$row["g_label_id"]."'></td></tr>" ;
                 echo "<tr><td>Button:</td><td><input type='text' name='g_button' value='".$row["g_button"]."'></td></tr>" ;
@@ -205,18 +189,19 @@
                 echo "<tr><td>Style:</td><td><textarea cols=50 rows=5 name='g_style'>".$row["g_style"]."</textarea></td></tr>" ;
                 echo "<tr><td>Buffer:</td><td><input type='text' size='4' name='g_buffer' value='".$row["g_buffer"]."'></td></tr>" ;
                 echo "<tr><td>ResultStyle:</td><td><textarea cols=50 rows=5 name='g_res_style'>".$row["g_res_style"]."</textarea></td></tr>" ;
-//                echo "<tr><td>WZ-Graphics:</td><td><input name='g_use_wzgraphics' type='checkbox'";
-//                if($row["g_use_wzgraphics"] == 1){ echo " checked"; }
-//                echo "></td></tr>";
+                echo "<tr><td>WZ-Graphics:</td><td><input name='g_use_wzgraphics' type='checkbox'";
+                if($row["g_use_wzgraphics"] == 1){ echo " checked"; }
+                echo "></td></tr>";
                 echo "</table>";
         /* set element options */
         $sql = "SELECT * FROM wfs_conf_element ";
         $sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-        $sql .= "WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." ORDER BY f_id";
+        $sql .= "WHERE fkey_wfs_conf_id = $1 ORDER BY f_id";
+		$t = array("i");
         echo "<table border='1'>";
         echo "<tr valign = bottom>";
@@ -230,13 +215,10 @@
-                echo "<td>" . toImage('show_detail') . "</td>";
-                echo "<td>" . toImage('auth') . "</td>";
         echo "</tr>";
         $cnt = 0;
@@ -263,9 +245,6 @@
                 echo "<td><input name='f_show".$cnt."' type='checkbox'";
                 if($row["f_show"] == 1){ echo " checked"; }
                 echo "></td>";
-                echo "<td><input name='f_show_detail".$cnt."' type='checkbox'";
-                if($row["f_show_detail"] == 1){ echo " checked"; }
-                echo "></td>";
                 echo "<td><input name='f_respos".$cnt."' type='text' size='1' value='".$row["f_respos"]."'></td>";
                 echo "<td><input name='f_mandatory".$cnt."' type='checkbox'";
                 if($row["f_mandatory"] == 1){ echo " checked"; }
@@ -274,7 +253,6 @@
                 if($row["f_edit"] == 1){ echo " checked"; }
                 echo "></td>";
                 echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".$row["f_form_element_html"]."</textarea></td>";
-                echo "<td><input name='f_auth_varname".$cnt."' type='text' size='8' value='".$row["f_auth_varname"]."'></td>";
                 echo "</tr>";
                 $cnt++;
Modified: branches/nimix_dev/http/php/mod_wfs_gazetteer_server.php
--- branches/nimix_dev/http/php/mod_wfs_gazetteer_server.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_wfs_gazetteer_server.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -144,22 +144,10 @@
 	$req = urldecode($url).urlencode($admin->char_decode(stripslashes($filter)));
 	$mygml = new gml2();
-	$mygml->parsegml($req);
+	$mygml->parseFile($req);
-	// generates JavaScript code that will add a geometry array containing
-	// all the result geometries and their attributes (wfs_conf_elements)
-	$js = "";
-	if ($mygml->getMemberCount() > 0) {
-		$js .= $mygml->exportGeometriesToJS(true);
-		for ($i = 0; $i < $mygml->getMemberCount(); $i++) {
-			for ($j = 0; $j < count($col); $j++){
-				$js .= "geom.get(".$i.").e.setElement('".$j."', '".$mygml->getValueBySeparatedKey($i, $col[$j]) . "');\n";
-	echo $js;
+	header("Content-type:application/x-json; charset=utf-8");
+	echo $mygml->toGeoJSON();
 else {
 	echo "please enter a valid command.";
Modified: branches/nimix_dev/http/php/mod_zoomCoords_en.php
--- branches/nimix_dev/http/php/mod_zoomCoords_en.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/mod_zoomCoords_en.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -81,7 +81,7 @@
 <?php
 echo '<script type="text/javascript">';
-echo "var mod_zoomCoords_target = '".$e_target[0]."';";
+echo "var mod_zoomCoords_target = '".$e_target."';";
 echo "var target = mod_zoomCoords_target.split(',');";
@@ -104,14 +104,14 @@
    var valid = true;
  /*  if(parseFloat(coordx) < 5.88 ||  parseFloat(coordx) > 15){
-      alert("Eingabe unzul�ssig!");
+      alert("Eingabe unzulässig!");
       document.form1.X.select();
       document.form1.X.focus();
       valid = false;
       return false;
    if(parseFloat(coordy) < 46.62 ||  parseFloat(coordy) > 55.71){
       document.form1.Y.select();
       document.form1.Y.focus();
       valid = false;
@@ -128,20 +128,21 @@
 function highlight(x, y){
-   x=x.replace(",",".");
-   y=y.replace(",",".");
-   document.form1.X.value=x;
-   document.form1.Y.value=y;
-   if (isNaN(x)==true || isNaN(y)==true){
-   else{
-      parent.mb_showHighlight(target[0],x,y);
-      parent.mb_showHighlight(target[1],x,y);
+	if(x!='' && y!=''){
+       x=x.replace(",",".");
+	   y=y.replace(",",".");
+	   document.form1.X.value=x;
+	   document.form1.Y.value=y;
+	   if (isNaN(x)==true || isNaN(y)==true){
+	   else{
+	      parent.mb_showHighlight(target[0],x,y);
+	      parent.mb_showHighlight(target[1],x,y);
 function hideHighlight(){
@@ -171,7 +172,7 @@
       echo "<span class='labely'>Y-Coordinate:</span>";
       echo "<input class='textx' type='text' name='X'>";
       echo "<input class='texty' type='text' name='Y'>";
-      echo "<input class='send' type='button' value='ok' onclick='zoomCoordinate();' onmouseover='highlight(document.form1.X.value, document.form1.Y.value)' onmouseout='hideHighlight(document.form1.X.value, document.form1.Y.value)' >";
+      echo "<input class='send' type='button' value='ok' onclick='zoomCoordinate();' onmouseover='highlight(document.form1.X.value, document.form1.Y.value)' onmouseout='if(document.form1.X.value !=\"\" && document.form1.Y.value !=\"\"){hideHighlight(document.form1.X.value, document.form1.Y.value);}' >";
 </form>
Modified: branches/nimix_dev/http/php/system.php
--- branches/nimix_dev/http/php/system.php	2008-08-18 13:57:32 UTC (rev 2841)
+++ branches/nimix_dev/http/php/system.php	2008-08-18 13:59:57 UTC (rev 2842)
@@ -28,8 +28,10 @@
 define("MB_RESOLUTION", "28.35");
 define("MB_FEATURE_COUNT", "100");
+define("MB_SECURITY_PROXY", "http://wms1.ccgis.de/mapbender/tools/security_proxy.php?mb_ows_security_proxy=");
 # available log levels
-define("LOG_LEVEL_LIST", "off,error,warning,notice,all");
+define("LOG_LEVEL_LIST", "off,error,warning,notice,all");
+define("ZOOM_MOUSEWHEEL", "1.1");
More information about the Mapbender_commits mailing list
