[Mapbender-commits] r2847 - branches/nimix_dev/http/frames
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 18 10:17:35 EDT 2008
Author: nimix
Date: 2008-08-18 10:17:34 -0400 (Mon, 18 Aug 2008)
New Revision: 2847
Removed:
   branches/nimix_dev/http/frames/jquery.html
   branches/nimix_dev/http/frames/index.php
   branches/nimix_dev/http/frames/login.php
merge
Modified: branches/nimix_dev/http/frames/index.php
--- branches/nimix_dev/http/frames/index.php	2008-08-18 14:16:40 UTC (rev 2846)
+++ branches/nimix_dev/http/frames/index.php	2008-08-18 14:17:34 UTC (rev 2847)
@@ -18,10 +18,12 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-mb_internal_encoding("UTF-8");
 require("../php/mb_validateSession.php");
 require_once(dirname(__FILE__)."/../classes/class_locale.php");
+require_once(dirname(__FILE__)."/../classes/class_gui.php");
+$_SESSION["mb_user_gui"] = $gui_id;
 // check if user is allowed to access current GUI;
 // if not, return to login screen
@@ -31,21 +33,6 @@
 	header("Location: ".LOGIN);
 	die();
-#$e = new mb_notice("index.php: arguments: GML: " . $_SESSION["GML"]);
-#$e = new mb_notice("index.php: arguments: Zoom to layer: " . $_REQUEST["zoomToLayer"]);
-#$e = new mb_notice("index.php: arguments: portal_services: " . $_REQUEST["portal_services"]);
-#$e = new mb_notice("index.php: arguments: portal_services_wfs: " . $_REQUEST["portal_services_wfs"]);
-#$e = new mb_notice("index.php: arguments: layer_preview: " . $_REQUEST["layer_preview"]);
-$pattern = "/sessionID/";
-$_SESSION["mb_user_gui"] = $gui_id;
-$localeObj = new Mb_locale($_SESSION["mb_lang"]);
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 <html>
@@ -59,11 +46,9 @@
 <meta http-equiv="cache-control" content="no-cache">
 <meta http-equiv="pragma" content="no-cache">
 <meta http-equiv="expires" content="0">
+<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
+<title><?php echo  $gui_id;?> - presented by Mapbender</title>
 <?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title><?php  echo  $gui_id;?> - presented by Mapbender</title>
-<?php
 $sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = 'body' AND fkey_gui_id = $1 and var_type='file/css'";
 $v = array($gui_id);
 $t = array('s');
@@ -87,84 +72,11 @@
 </style>
-<?php
-$frame = "";
-echo "<script type='text/javascript' src='../javascripts/core.php'></script>";
+<script type='text/javascript' src='../javascripts/core.php'></script>
 </head>
 <?php
-$sql = "SELECT fkey_gui_id,e_id,e_pos,e_public,e_comment,gettext($1, e_title) as e_title, e_element,";
-$sql .= "e_src,e_attributes,e_left,e_top,e_width,e_height,e_z_index,e_more_styles,";
-$sql .= "e_content,e_closetag,e_js_file,e_mb_mod,e_target,e_requires,e_url FROM gui_element WHERE e_public = 1 AND fkey_gui_id = $2 ORDER BY e_pos";
-$v = array($_SESSION["mb_lang"], $gui_id);
-$t = array('s', 's');
-$res = db_prep_query($sql,$v,$t);
-$i = 0;
-while(db_fetch_row($res)){
-	$replacement = $urlParameters."&elementID=".db_result($res,$i,"e_id");
-	echo "<".db_result($res,$i,"e_element")." ";
-	if(db_result($res,$i,"e_id") != ""){
-		echo " id='".db_result($res,$i,"e_id")."'";
-		echo " name='".db_result($res,$i,"e_id")."'";
-	if(db_result($res,$i,"e_attributes") != ""){
-		echo " ".stripslashes(preg_replace($pattern,$replacement,db_result($res,$i,"e_attributes")));
-	if(db_result($res,$i,"e_title") != ""){
-		echo " title='".db_result($res,$i,"e_title")."' ";
-	if(db_result($res,$i,"e_src") != ""){
-		if(db_result($res,$i,"e_closetag") == "iframe" && db_result($res,$i,"e_id") != 'loadData'){
-      		echo " src = '".preg_replace($pattern,$replacement,db_result($res,$i,"e_src"));
-				if(mb_strpos(db_result($res,$i,"e_src"), "?")) {
-					echo "&";
-				else {
-	      			echo "?";
-      			echo "e_id_css=".db_result($res,$i,"e_id")."&e_id=".db_result($res,$i,"e_id") .
-					"&e_target=".db_result($res,$i,"e_target").
-					"&" . $urlParameters . "'";
-		else{
-			echo " src = '".preg_replace($pattern,$replacement,db_result($res,$i,"e_src"))."'";
-	echo " style = '";
-	if(db_result($res,$i,"e_left") != "" && db_result($res,$i,"e_top") != ""){
-		echo "position:absolute;";
-		echo "left:".db_result($res,$i,"e_left").";";
-		echo "top:".db_result($res,$i,"e_top").";";
-	if(db_result($res,$i,"e_width") != "" && db_result($res,$i,"e_height") != ""){
-		echo "width:".db_result($res,$i,"e_width").";";
-		echo "height:".db_result($res,$i,"e_height").";";
-	if(db_result($res,$i,"e_z_index") != ""){
-    	echo "z-index:".db_result($res,$i,"e_z_index").";";
-	if(db_result($res,$i,"e_more_styles") != ""){
-    	echo db_result($res,$i,"e_more_styles");
-	echo "' >";
-	if(db_result($res,$i,"e_content") != ""){
-		echo " ".stripslashes(db_result($res,$i,"e_content"));
-	if(db_result($res,$i,"e_closetag") != "" && db_result($res,$i,"e_closetag") != "body"){
-		echo " </".db_result($res,$i,"e_closetag").">";
-	$i++;
-<form id='sendData' name='sendData' action='' method='POST' target='loadData' style='position:absolute;left:800px'>
-<input type='hidden' name='data'>
-</form>
-<?php
-#echo "<script type='text/javascript' src='../javascripts/map.php?gui_id=".$_REQUEST["gui_id"]."&zoomToLayer=".$_REQUEST["zoomToLayer"]."&portal_services=".$_REQUEST['portal_services']."&portal_services_wfs=".$_REQUEST['portal_services_wfs']."&layer_preview=".$_REQUEST['layer_preview']."&".strip_tags(SID)."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
+$currentApplication = new gui($gui_id);
+echo $currentApplication->toHtml();
 echo "<script type='text/javascript' src='../javascripts/map.php?".$urlParameters."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
-</body>
 </html>
\ No newline at end of file
Deleted: branches/nimix_dev/http/frames/jquery.html
--- branches/nimix_dev/http/frames/jquery.html	2008-08-18 14:16:40 UTC (rev 2846)
+++ branches/nimix_dev/http/frames/jquery.html	2008-08-18 14:17:34 UTC (rev 2847)
@@ -1,10 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>Untitled</title>
-<script type='text/javascript' src="../extensions/jquery.js"></script>
-</head>
-<body>
-</body>
-</html>
Modified: branches/nimix_dev/http/frames/login.php
--- branches/nimix_dev/http/frames/login.php	2008-08-18 14:16:40 UTC (rev 2846)
+++ branches/nimix_dev/http/frames/login.php	2008-08-18 14:17:34 UTC (rev 2847)
@@ -17,10 +17,8 @@
 ob_start();
-include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 require_once(dirname(__FILE__) . "/../classes/class_administration.php");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 function setSession(){
More information about the Mapbender_commits mailing list
