[Mapbender-commits] r2877 - branches/nimix_dev/http/php
svn_mapbender at osgeo.org
Mon Aug 18 13:41:10 EDT 2008
Author: nimix
Date: 2008-08-18 13:41:05 -0400 (Mon, 18 Aug 2008)
New Revision: 2877
Added:
branches/nimix_dev/http/php/mod_wfs_gazetteer_server.php
merge
Added: branches/nimix_dev/http/php/mod_wfs_gazetteer_server.php
--- branches/nimix_dev/http/php/mod_wfs_gazetteer_server.php (rev 0)
+++ branches/nimix_dev/http/php/mod_wfs_gazetteer_server.php 2008-08-18 17:41:05 UTC (rev 2877)
@@ -0,0 +1,154 @@
+<?php
+# $Id: mod_wfs_gazetteer_server.php 1190 2007-10-18 10:38:38Z baudson $
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_gml2.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs_conf.php");
+$command = $_REQUEST["command"];
+ * checks if a variable name is valid.
+ * Currently a valid name would be sth. like $_SESSION["mb_user_id"]
+ * TODO: this function is also in mod_wfs_result!! Maybe merge someday.
+function isValidVarName ($varname) {
+ if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
+ return true;
+ return false;
+ * If access to the WFS conf is restricted, modify the filter.
+ function checkAccessConstraint($filter, $wfs_conf_id) {
+ /* wfs_conf_element */
+ $sql = "SELECT * FROM wfs_conf_element ";
+ $sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+ $sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+ $sql .= "ORDER BY wfs_conf_element.f_respos";
+ $v = array($wfs_conf_id);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ while($row = db_fetch_array($res)){
+ if (!empty($row["f_auth_varname"])) {
+ $auth_varname = $row["f_auth_varname"];
+ $element_name = $row["element_name"];
+ if (!empty($auth_varname)) {
+ if (isValidVarName($auth_varname)) {
+ $user = eval("return " . $auth_varname . ";");
+ if ($user) {
+ $pattern = "(<ogc:Filter[^>]*>)(.*)(</ogc:Filter>)";
+ $replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
+ $filter = mb_eregi_replace($pattern, $replacement, $filter);
+ else {
+ $e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: invalid value of variable containing user information!");
+ else {
+ $e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: var name is not valid! (" . $auth_varname . ")");
+ return $filter;
+if ($command == "getWfsConf") {
+ $wfsConfIdString = $_GET["wfsConfIdString"];
+ if ($wfsConfIdString != "") {
+ //array_keys(array_flip()) produces an array with unique entries
+ $wfsConfIdArray = array_keys(array_flip(mb_split(",", $wfsConfIdString)));
+ else {
+ echo "please specify wfs conf id.";
+ die();
+ $obj = new WfsConf();
+ $obj->load($wfsConfIdArray);
+ $json = new Mapbender_JSON();
+ $output = $json->encode($obj->confArray);
+ echo $output;
+else if ($command == "getSearchResults") {
+ $wfs_conf_id = $_REQUEST["wfs_conf_id"];
+ $backlink = $_REQUEST["backlink"];
+ $frame = $_REQUEST["frame"];
+ $filter = $_REQUEST["filter"];
+ $url = $_REQUEST["url"];
+ /* wfs_conf */
+ $sql = "SELECT * FROM wfs_conf JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+ $sql .= "WHERE wfs_conf.wfs_conf_id = $1";
+ $t = array('i');
+ if ($row = db_fetch_array($res)) {
+ $g_res_style = $row["g_res_style"];
+ else {
+ die("wfs_conf " . $wfs_conf_id . "data not available");
+ $sql .= "AND wfs_conf_element.f_show = 1 ORDER BY wfs_conf_element.f_respos;";
+ $t = array('i');
+ $col = array();
+ while ($row = db_fetch_array($res)) {
+ array_push($col, $row["element_name"]);
+ if (count($col) == 0) {
+ die("wfs_conf_element data not available");
+ // append authorisation condition to filter
+ $filter = checkAccessConstraint($filter, $wfs_conf_id);
+ $admin = new administration();
+ $req = urldecode($url).urlencode($admin->char_decode(stripslashes($filter)));
+ $mygml = new gml2();
+ $mygml->parseFile($req);
+ header("Content-type:application/x-json; charset=utf-8");
+ echo $mygml->toGeoJSON();
+else {
+ echo "please enter a valid command.";
More information about the Mapbender_commits
