[Mapbender-commits] r2879 - branches/nimix_dev/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Aug 19 04:14:26 EDT 2008
Author: nimix
Date: 2008-08-19 04:14:26 -0400 (Tue, 19 Aug 2008)
New Revision: 2879
   branches/nimix_dev/http/javascripts/tooltip_wms.php
   branches/nimix_dev/http/javascripts/wms.js
wms tooltip
Modified: branches/nimix_dev/http/javascripts/tooltip_wms.php
--- branches/nimix_dev/http/javascripts/tooltip_wms.php	2008-08-18 18:20:44 UTC (rev 2878)
+++ branches/nimix_dev/http/javascripts/tooltip_wms.php	2008-08-19 08:14:26 UTC (rev 2879)
@@ -24,90 +24,72 @@
 include '../include/dyn_js.php';
-var tooltipTime = 500;
+//destination frame for the request (creates Popup if empty)
+var destFrameName = "tooltip";
+var tooltipTime = 1000;
+var no_result_text = ["Kein Ergebnis."];
 var mouseMoves=0;
 var tooltipWin=null;
 var point;
-var numberOfFinishedAjaxCalls = 0;
-buttonWfs_toDigitize_on ="0";
+//buttonWfs_toDigitize_on ="0";
 function mod_tooltipInit(){
-	$(window.frames["mapframe1"].document).mousemove(function(event){
+	$(window.frames[tooltipTarget].document).mousemove(function(event){
 		mod_tooltip_run();
-		mb_getMousePos(event,"mapframe1");
+		mb_getMousePos(event,tooltipTarget);
 	}).mouseout(function(){mouseMoves=0;});
-mb_registerInitFunctions("mod_tooltipInit();");
+eventInit.register(mod_tooltipInit);
 function mod_tooltip_run(){
 	mouseMoves++;
-	setTimeout("if(mouseMoves=="+mouseMoves+")showWMSBalloon();",tooltipTime);
-function showWMSBalloon(){
-	x=clickX+parseInt(document.getElementById("mapframe1").style.left);
-	y=clickY+parseInt(document.getElementById("mapframe1").style.top);
-	if(tooltipWin&&tooltipWin.isVisible())
-		tooltipWin.destroy();
-	url = getfirstFeatureInfoRequest(tooltipTarget,clickX,clickY,"../extensions/ext_featureInfoTunnel.php");
-//	var ind = getMapObjIndexByName("mapframe1");
-//	req = mb_mapObj[ind].getFeatureInfoRequests({x:clickX,y:clickY});
-	mb_ajax_post(url, null, function(js_code,status){
-		if(js_code.indexOf("Kein Ergebnis.")!==-1)
-			return;
-		tooltipWin = new mb_popup({html:"<iframe>"+js_code+"</iframe>",title:"Feature Info",width:270,height:200,balloon:true,left:x,top:y});
-		tooltipWin.show();
-	//if(req)
+	setTimeout("if(mouseMoves=="+mouseMoves+")fireFeatureInfo();",tooltipTime);
-function getfirstFeatureInfoRequest(fName,x,y,path) {
-	for(i=0; i<mb_mapObj.length; i++){
-		if(mb_mapObj[i].frameName == fName){
-			for(var ii=0; ii<mb_mapObj[i].wms.length; ii++){
-				var newfeatureInfoRequest = "";
-				var requestParams = "";
-				var validation = false;
-				newfeatureInfoRequest += mb_mapObj[i].wms[ii].wms_getfeatureinfo;
-            	newfeatureInfoRequest += mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getfeatureinfo);
+function fireFeatureInfo(){
+	var ind = getMapObjIndexByName(tooltipTarget);
+	point = new Point(clickX,clickY);
+	urls = mb_mapObj[ind].getFeatureInfoRequests(point);
+	for(var j=0;j < urls.length;j++){
+		mb_ajax_post("../x_tour_rlp/ext_featureInfoTunnel.php?url="+escape(urls[j]), null, function(js_code,status){
+			for(var k=0;k < no_result_text.length;k++){
+				if(js_code.indexOf(no_result_text[k])!==-1)
+					return;
+			//test if we have a fixed destination and create popup otherwise
+			if(destFrameName=="")
+				showWmsBalloon(js_code);
-				if(mb_mapObj[i].wms[ii].wms_version == "1.0.0"){requestParams += "WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=feature_info&";}
-				if(mb_mapObj[i].wms[ii].wms_version != "1.0.0"){requestParams += "VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetFeatureInfo&SERVICE=WMS&";}
-				requestParams += "SRS="+mb_mapObj[i].epsg+"&";
-				requestParams += "BBOX="+mb_mapObj[i].extent+"&";
-				requestParams += "WIDTH="+mb_mapObj[i].width+"&";
-				requestParams += "HEIGHT="+mb_mapObj[i].height+"&";
-				requestParams += "LAYERS="+mb_mapObj[i].layers[ii]+"&";
-				requestParams += "STYLES="+mb_mapObj[i].styles[ii]+"&";
-				requestParams += "FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";
-				requestParams += "INFO_FORMAT="+mb_mapObj[i].wms[ii].gui_wms_featureinfoformat+"&";
-				requestParams += "EXCEPTIONS=application/vnd.ogc.se_xml&";
-				if(mb_feature_count > 0){
-					requestParams += "FEATURE_COUNT="+mb_feature_count+"&";
+			//if so put the frame there
+			$("#"+destFrameName).each(function(){
+			    var oDoc = this.contentWindow || this.contentDocument;
+			    if (oDoc.document) {
+			        oDoc = oDoc.document;
-				requestParams += "QUERY_LAYERS="+mb_mapObj[i].querylayers[ii]+"&";
-				requestParams += "X=" + x  + "&";
-				requestParams += "Y=" + y;
-				if(mb_mapObj[i].querylayers[ii] !== "" && mb_mapObj[i].layers[ii] !== ""){
-					validation = true;
-				//add vendor-specific
-				for(var v=0; v < mb_vendorSpecific.length; v++){
-					var vendorSpecificString = eval(mb_vendorSpecific[v]);
-					requestParams += "&" + vendorSpecificString;
-				if(mb_log && validation){
-					var tmp = eval(mb_log + "('" + newfeatureInfoRequest + requestParams + "','" + ts + "')");
-				if(validation){
-					newfeatureInfoRequest += requestParams;
-					return newfeatureInfoRequest;
+    			oDoc.open();
+				oDoc.write(js_code);
+				oDoc.close();
-	return false;
+function showWMSBalloon(html){
+	x=clickX+parseInt(document.getElementById(tooltipTarget).style.left);
+	y=clickY+parseInt(document.getElementById(tooltipTarget).style.top);
+	if(tooltipWin&&tooltipWin.isVisible())
+		tooltipWin.destroy();
+	tooltipWin = new mb_popup({html:'<iframe id="tooltipWin" name="tooltipWin" src="about:blank"/>',title:"Feature Info",width:270,height:200,balloon:true,left:x,top:y});
+	$("#"+tooltipWin.id+" iframe").each(function(){
+		oDoc.write(html);
+	tooltipWin.show();
Modified: branches/nimix_dev/http/javascripts/wms.js
--- branches/nimix_dev/http/javascripts/wms.js	2008-08-18 18:20:44 UTC (rev 2878)
+++ branches/nimix_dev/http/javascripts/wms.js	2008-08-19 08:14:26 UTC (rev 2879)
@@ -207,6 +207,9 @@
 	rq += "&LAYERS=" + layers.join(",");
+	if(mb_feature_count > 0){
+		rq += "&FEATURE_COUNT="+mb_feature_count;
 	rq += "&QUERY_LAYERS=" + querylayers.join(",");
 	rq += "&WIDTH=" + mapObj.getWidth();
 	rq += "&HEIGHT=" + mapObj.getHeight();
@@ -405,11 +408,13 @@
  * @return array of layernames
  * @type string[]
-wms_const.prototype.getQuerylayers = function(){
+wms_const.prototype.getQuerylayers = function(mapObj){
 	queryLayers = [];
 	for(var i=0; i< this.objLayer.length; i++){
 		if(this.objLayer[i].gui_layer_querylayer === 1 && ! this.objLayer[i].has_childs ){
-			queryLayers.push(this.objLayer[i].layer_name);
+			if(this.objLayer[i].checkScale(mapObj)){
+				queryLayers.push(this.objLayer[i].layer_name);
 	if(queryLayers.length === 0){
More information about the Mapbender_commits mailing list
