[Mapbender-commits] r3282 - branches/beck_dev/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Dec 9 06:33:01 EST 2008
Author: beck
Date: 2008-12-09 06:33:01 -0500 (Tue, 09 Dec 2008)
New Revision: 3282
Removed:
   branches/beck_dev/http/javascripts/mod_wmsByCookie.php
Deleted: branches/beck_dev/http/javascripts/mod_wmsByCookie.php
--- branches/beck_dev/http/javascripts/mod_wmsByCookie.php	2008-12-09 11:32:38 UTC (rev 3281)
+++ branches/beck_dev/http/javascripts/mod_wmsByCookie.php	2008-12-09 11:33:01 UTC (rev 3282)
@@ -1,56 +0,0 @@
-<?php
-# $Id: mod_mapCookie.php 264 2008-12-09 12:10:19Z beck
-# http://www.mapbender.org/index.php/mod_savewmc.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-echo "var mod_mapCookie_target = '".$e_target[0]."';";
-eventInit.register(restoreMapState);
-eventInit.register(triggerUnload);
-function restoreMapState() {
-	if(!document.cookie) {
-		return;
-function storeMapState() {
-	var mapIndex      = getMapObjIndexByName(mod_wmsByCookie_target);
-	var cookieData    = {}
-	var cookieExpires = new Date();
-	cookieExpires.setTime(cookieExpires.getTime() + (24 * 60 * 60 * 1000));
-	cookieData.extent = $.toJSON(mb_mapObj[getMapObjIndexByName(mod_wmsByCookie_target)].extent);
-	document.cookie = 'stored_map_state=' + $.toJSON(cookieData) + ';expires=' + cookieExpires.toGMTString();
-function triggerUnload() {
-	if(ie) {
-		document.getElementById('body').onunload = function() {
-			var trigger = new Function ('','storeMapState()');
-			trigger();
-	else {
-		document.getElementById('body').setAttribute('onunload','storeMapState();');
\ No newline at end of file
More information about the Mapbender_commits mailing list
