[Mapbender-commits] r3336 - branches/beck_dev/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Dec 16 03:53:16 EST 2008
Author: beck
Date: 2008-12-16 03:53:15 -0500 (Tue, 16 Dec 2008)
New Revision: 3336
   branches/beck_dev/http/javascripts/map_obj.js
Modified: branches/beck_dev/http/javascripts/map_obj.js
--- branches/beck_dev/http/javascripts/map_obj.js	2008-12-16 08:42:54 UTC (rev 3335)
+++ branches/beck_dev/http/javascripts/map_obj.js	2008-12-16 08:53:15 UTC (rev 3336)
@@ -6,6 +6,73 @@
 var mb_mapObj = [];
 function mb_mapObj_const(frameName, elementName, width, height, wms_index){
+	 * set the extent of the wms
+	this.setExtent = function(minx, miny, maxx, maxy){
+		this.extent = String(minx) + "," + String(miny) + "," + String(maxx) + "," + String(maxy);
+	 * get the width of the mapObj
+	 * @member mb_mapObj_const
+	 * @return width of the mapObj
+	 * @type integer
+	this.getWidth = function(){
+		return parseInt(this.width, 10);
+	 * set the width of the mapObj
+	 * @param {integer} widht the width of the mapObj
+	this.setWidth = function(width){
+		this.width = parseInt(width, 10);
+	 * get the height of the mapObj
+	 * @type integer
+	this.getHeight = function(){
+		return parseInt(this.height, 10);
+	 * set the height of the mapObj
+	 * @param {integer} height the height of the mapObj
+	this.setHeight = function(height){
+		this.height = parseInt(height, 10);
+	 * converts the extent of the mapobject so that the maximum	extent will be displayed
+	this.calculateExtent = function(ext){
+		var relation_px_x = this.getWidth() / this.getHeight();
+		var relation_px_y = this.getHeight() / this.getWidth();
+		var relation_bbox_x = ext.extentx / ext.extenty;
+		if (relation_bbox_x <= relation_px_x) {
+			ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
+			ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
+		if (relation_bbox_x > relation_px_x) {
+			ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
+			ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
+		this.setExtent(ext.minx, ext.miny, ext.maxx, ext.maxy);
+		return ext;
 	this.width = width;
 	this.height = height;
 	this.frameName = frameName;
@@ -14,16 +81,16 @@
 	this.styles = [];
 	this.querylayers = [];
 	this.geom = "";
-	this.gml = "";
+	this.gml = "";
 	this.wms = [];
 	// Add pointers to WMS objects which are in this map.
 	// If wms_index is set (=map is overview), only this
 	// WMS is being pointed to.
 	var index = 0;
-	for(var i=0; i < wms.length; i++){
+	for (var i = 0; i < wms.length; i++) {
 		var isValidWms = (wms_index === null) || (wms_index == i);
 		if (isValidWms) {
 			this.wms[index] = wms[i];
@@ -31,7 +98,7 @@
 			index++;
 	// set list of visible layers, active querylayers
 	// and styles for each WMS in this map
@@ -41,89 +108,69 @@
 	var styles;
 	var layers;
 	var querylayers = "";
-	for(i=0; i< this.wms.length; i++){
+	for (i = 0; i < this.wms.length; i++) {
 		cnt_layers = 0;
 		cnt_querylayers = 0;
 		styles = "";
 		layers = "";
 		querylayers = "";
-		for(var ii=0; ii<this.wms[i].objLayer.length; ii++){
+		for (var ii = 0; ii < this.wms[i].objLayer.length; ii++) {
 			// layer is visible and not root layer
-			if(this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii>0){
-				if(cnt_layers > 0){
-					layers += ","; styles += ",";
+			if (this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii > 0) {
+				if (cnt_layers > 0) {
+					layers += ",";
+					styles += ",";
-				layers += wms[i].objLayer[ii].layer_name;
-				styles += "";
+				layers += wms[i].objLayer[ii].layer_name;
+				styles += "";
 				cnt_layers++;
 			// layer is queryable and not root layer
-			if(this.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii>0){
-				if(cnt_querylayers > 0){
+			if (this.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii > 0) {
+				if (cnt_querylayers > 0) {
 					querylayers += ",";
-				querylayers += wms[i].objLayer[ii].layer_name;
+				querylayers += wms[i].objLayer[ii].layer_name;
 				cnt_querylayers++;
 		this.layers[i] = layers;
 		this.styles[i] = styles;
 		this.querylayers[i] = querylayers;
 	this.epsg = wms[0].gui_wms_epsg;
-	this.extent = setExtent(this.width,this.height,this.epsg);
+	var bbox_minx, bbox_miny, bbox_maxx, bbox_maxy;
+	for (var i = 0; i < wms[0].gui_epsg.length; i++) {
+		if (this.epsg == wms[0].gui_epsg[i]) {
+			bbox_minx = parseFloat(wms[0].gui_minx[i]);
+			bbox_miny = parseFloat(wms[0].gui_miny[i]);
+			bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
+			bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
+	var wmsExtent = new Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy);
+	this.calculateExtent(wmsExtent);
 	this.mapURL = [];
-	var styleTag = window.frames[this.frameName].document.getElementById(this.elementName).style;
-	styleTag.width = this.width;
-	styleTag.height = this.height;
+	if(this.frameName){
+		this.domElement = window.frames[this.frameName].document.getElementById(this.elementName);
+	else{
+		this.domElement = document.getElementById(this.elementName);
+	this.domElement.style.width = this.width;
+	this.domElement.style.height = this.height;
-	 * get the width of the mapObj
-	 * @member mb_mapObj_const
-	 * @return width of the mapObj
-	 * @type integer
-	this.getWidth = function(){
-		return parseInt(this.width, 10);
-	 * set the width of the mapObj
-	 * @param {integer} widht the width of the mapObj
-	this.setWidth = function(width){
-		this.width = parseInt(width, 10);
-	 * get the height of the mapObj
-	 * @type integer
-	this.getHeight = function(){
-		return parseInt(this.height, 10);
-	 * set the height of the mapObj
-	 * @param {integer} height the height of the mapObj
-	this.setHeight = function(height){
-		this.height = parseInt(height, 10);
 	 * get the extent of the mapObj
-	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
+	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
 	 * @type string
 	this.getExtent = function(){
@@ -133,44 +180,139 @@
 	 * get the extent as minx, maxx, miny, maxy
-	 * @return extent and additional informations of the mapObj
+	 * @return extent and additional informations of the mapObj
 	 * @type Object
 	this.getExtentInfos = function(){
 		var c = this.getExtent().split(",");
-		var ext = new Extent(c[0],c[1],c[2],c[3]);
+		var ext = new Extent(c[0], c[1], c[2], c[3]);
 		return ext;
-	 * converts the extent of the mapobject so that the maximum	extent will be displayed
+	 * Sets the list of layers, styles and querylayers for a specified WMS
-	this.calculateExtent = function(ext){
-		var relation_px_x = this.getWidth() / this.getHeight();
-		var relation_px_y = this.getHeight() / this.getWidth();
-		var relation_bbox_x = ext.extentx / ext.extenty;
-		if(relation_bbox_x <= relation_px_x){
-			ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
-			ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
+	this.restateLayers = function(wms_id){
+		for (var i = 0; i < this.wms.length; i++) {
+			if (this.wms[i].wms_id == wms_id) {
+				var currentWms = this.wms[i];
+				var cnt_layers = 0;
+				var cnt_querylayers = 0;
+				var layers = "";
+				var styles = "";
+				var querylayers = "";
+				for (var ii = 0; ii < currentWms.objLayer.length; ii++) {
+					var currentLayer = currentWms.objLayer[ii];
+					if (currentLayer.gui_layer_visible == 1 && !currentLayer.has_childs) {
+							layers += ",";
+							styles += ",";
+						layers += currentLayer.layer_name;
+						styles += "";
+						cnt_layers++;
+					if (currentLayer.gui_layer_querylayer == 1 && !currentLayer.has_childs) {
+							querylayers += ",";
+						querylayers += currentLayer.layer_name;
+						cnt_querylayers++;
+				this.layers[i] = layers;
+				this.querylayers[i] = querylayers;
+				this.styles[i] = styles;
-		if(relation_bbox_x > relation_px_x){
-			ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
-			ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
+//		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
+	 * @param {Object} direction
+	this.pan = function (direction) {
+		var arrayBBox = this.extent.split(",");
+		var minx = parseFloat(arrayBBox[0]);
+		var miny = parseFloat(arrayBBox[1]);
+		var maxx = parseFloat(arrayBBox[2]);
+		var maxy = parseFloat(arrayBBox[3]);
+		var xtentx = maxx - minx;
+		var xtenty =  maxy - miny;
+		var factor = 0.5;
+		switch (direction) {
+			case "NW" :
+				minx -= (xtentx * factor);
+				maxx -= (xtentx * factor);
+				miny += (xtenty * factor);
+				maxy += (xtenty * factor);
+				break;
+			case "N" :
+				break;
+			case "NE" :
+				minx += (xtentx * factor);
+				maxx += (xtentx * factor);
+				break;
+			case "E" :
+				break;
+			case "SE" :
+				miny -= (xtenty * factor);
+				maxy -= (xtenty * factor);
+				break;
+			case "S" :
+				break;
+			case "SW" :
+				break;
+			case "W" :
+				break;
-		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
+		this.extent = minx + "," + miny + "," + maxx + "," + maxy;
+		this.setMapRequest();
+	this.zoomFull = function () {
+		for (var i = 0; i < this.wms[0].gui_epsg.length; i++) {
+			if (this.epsg == this.wms[0].gui_epsg[i]) {
+				var bbox_minx = parseFloat(this.wms[0].gui_minx[i]);
+				var bbox_miny = parseFloat(this.wms[0].gui_miny[i]);
+				var bbox_maxx = parseFloat(this.wms[0].gui_maxx[i]);
+				var bbox_maxy = parseFloat(this.wms[0].gui_maxy[i]);
+				var newExtent = this.calculateExtent(wmsExtent);
+				this.repaint(new Point(newExtent.minx, newExtent.miny), new Point(newExtent.maxx, newExtent.maxy));
 	 * zoom the map with a zoomfactor and optional to x,y coords
 	 * @param {boolean} in_ in = true, out = false
 	 * @param {float} factor the zoomfactor 1 equals 100%
 	 * @param {float} x center to x-position
 	 * @param {float} y center to y-position
-	 this.zoom = function(in_, factor, x, y){
+	this.zoom = function(in_, factor, x, y){
 		factor = parseFloat(factor);
 		if (!in_) {
 			factor = 1 / factor;
@@ -178,41 +320,88 @@
 		var extent = this.getExtentInfos();
 		var distx = extent.maxx - extent.minx;
-		var disty =  extent.maxy - extent.miny;
+		var disty = extent.maxy - extent.miny;
-		if(x && y){
+		if (x && y) {
 			var centerx = parseFloat(x);
 			var centery = parseFloat(y);
-		else{
-			var centerx = extent.minx + distx/2;
-			var centery = extent.miny + disty/2;
+		else {
+			var centerx = extent.minx + distx / 2;
+			var centery = extent.miny + disty / 2;
 		var new_distx = distx / factor;
 		var new_disty = disty / factor;
 		var minx = centerx - new_distx / 2;
 		var miny = centery - new_disty / 2;
 		var maxx = centerx + new_distx / 2;
 		var maxy = centery + new_disty / 2;
-		this.setExtent(minx,miny,maxx,maxy);
-		//Todo:
-		//setMapRequest!
+		this.setExtent(minx, miny, maxx, maxy);
+	var performUnknownCalculation = function (value) {
+		return Math.pow(10,(
+			Math.round(
+				Math.log(value)/
+				Math.log(10)
+	this.convertPixelToReal = function (aPoint) {
+		var minX = parseFloat(arrayBBox[0]);
+		var minY = parseFloat(arrayBBox[1]);
+		var maxX = parseFloat(arrayBBox[2]);
+		var maxY = parseFloat(arrayBBox[3]);
+		var xtentx = maxX - minX;
+		var xtenty = maxY - minY;
+		var deltaX = xtentx/this.width;
+		var deltaY = xtenty/this.height;
+		var roundx, roundy;
+		if(deltaX > 0){
+			roundx = 1/performUnknownCalculation(deltaX);
+		else{
+			roundx = performUnknownCalculation(deltaX);
+		if(deltaY > 0){
+			roundy = 1/performUnknownCalculation(deltaY);
+		else{
+			roundy =  performUnknownCalculation(deltaY);
+		var posX = parseFloat(minX + (aPoint.x / this.width) * xtentx);
+		var posY = parseFloat(maxY - (aPoint.y / this.height) * xtenty);
+		posX = Math.round(posX * roundx) / roundx;
+		posY = Math.round(posY * roundy) / roundy;
+		return new Point(posX, posY);
-	 * set the extent of the wms
+	 * Convert real world coordinates to pixel coordinates
-	 this.setExtent = function(minx,miny,maxx,maxy){
-	 	this.extent = String(minx)+","+String(miny)+","+String(maxx)+","+String(maxy);
+	this.convertRealToPixel = function (aPoint) {
+		return new Point(
+			Math.round((aPoint.x - minX) * this.width /(maxX - minX)),
+			Math.round((maxY - aPoint.y) * this.height/(maxY - minY))
 	 * get the srs of the mapObj
-	 * @return srs as epsg:number
+	 * @return srs as epsg:number
 	 * @type string
 	this.getSRS = function(){
@@ -220,51 +409,54 @@
-	 * get all mapRequests
+	 * get all mapRequests
-	 * @return array of mapRequests of this map object
-	 * @type string[]
+	 * @return array of mapRequests of this map object
+	 * @type string[]
 	this.getMapRequests = function(){
 		var allRequests = [];
 		//loop through all wms to get the mapRequests
-		for(var i=0; i<this.wms.length; i++){
 			var currentRequest = this.wms[i].getMapRequest(this);
-			if(currentRequest){
+			if (currentRequest) {
 				allRequests.push(currentRequest);
-		if(allRequests.length > 0){
+		if (allRequests.length > 0) {
 			return allRequests;
 		return false;
 	 * Return the map URL of the WMS at index i
 	 * @param {Object} currentWmsIndex
-	this.getMapUrl = function (i, ii) {
+	this.getMapUrl = function(ii){
 		var currentWms = this.wms[ii];
 		var validLayers = currentWms.getLayers(this);
+		if(validLayers.length === 0) {
+			return false;
 		var layerNames = validLayers.join(",");
-		url = currentWms.wms_getmap;
+		url = currentWms.wms_getmap;
 		url += mb_getConjunctionCharacter(currentWms.wms_getmap);
 		if (currentWms.wms_version == "1.0.0") {
 			url += "WMTVER=" + currentWms.wms_version + "&REQUEST=map&";
 		else {
 			url += "VERSION=" + currentWms.wms_version + "&REQUEST=GetMap&SERVICE=WMS&";
 		url += "LAYERS=" + layerNames + "&";
 		url += "STYLES=";
 		var layer = layerNames.split(",");
-		for (var j = 0; j < layer.length; j++){
+		for (var j = 0; j < layer.length; j++) {
 			if (j > 0) {
-				url  += ",";
+				url += ",";
 			if (currentWms.getCurrentStyleByLayerName(layer[j]) !== false) {
 				url += currentWms.getCurrentStyleByLayerName(layer[j]);
@@ -277,87 +469,314 @@
 		url += "HEIGHT=" + this.height + "&";
 		url += "FORMAT=" + currentWms.gui_wms_mapformat + "&";
 		url += "BGCOLOR=0xffffff&";
-		if (currentWms.gui_wms_mapformat.search(/gif/i)>-1 ||
-			currentWms.gui_wms_mapformat.search(/png/i)>-1) {
-				url += "TRANSPARENT=TRUE&";
+		if (currentWms.gui_wms_mapformat.search(/gif/i) > -1 ||
+		currentWms.gui_wms_mapformat.search(/png/i) > -1) {
+			url += "TRANSPARENT=TRUE&";
 		url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
 		// add vendor-specific
 		for (var v = 0; v < mb_vendorSpecific.length; v++) {
-			var vendorSpecificString = eval(mb_vendorSpecific[v]);
+			var vendorSpecificString = eval(mb_vendorSpecific[v]);
 			// if eval doesn't evaluate a function, the result is undefined.
 			// Sometimes it is necessary not to evaluate a function, for
 			// example if you want to change a variable from the current
 			// scope (see mod_addSLD.php)
 			if (typeof(vendorSpecificString) != "undefined") {
 				url += vendorSpecificString + "&";
 		// add Filter
-		if (currentWms.wms_filter !== ""){
-			url += "&SLD=" + currentWms.wms_filter +"?id="+ mb_styleID + "&";
+		if (currentWms.wms_filter !== "") {
+			url += "&SLD=" + currentWms.wms_filter + "?id=" + mb_styleID + "&";
 		// add sld
-		if(currentWms.gui_wms_sldurl !== ""){
+		if (currentWms.gui_wms_sldurl !== "") {
 			url += "&SLD=" + escape(currentWms.gui_wms_sldurl) + "&";
 		return url;
-	 * get all featureInfoRequests
+	 * get all featureInfoRequests
 	 * @param float x the x-value of the click position in pixel
 	 * @param float y the y-value of the click position in pixel
-	 * @return array of all featureInfoRequests of this map object
-	 * @type string[]
+	 * @return array of all featureInfoRequests of this map object
+	 * @type string[]
 	this.getFeatureInfoRequests = function(clickPoint){
 		//loop through all wms to get the FeatureInfoRequests
 			var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
 			return allRequests;
 		return false;
-	 * calculation of the mapscale
+	 * calculation of the mapscale
-	 * @return scale
-	 * @type integer
+	 * @return scale
+	 * @type integer
 	this.getScale = function(){
 		var scale;
 		var bbox = this.extent.split(",");
 		var xtenty;
-		if(this.epsg=="EPSG:4326"){
-			var pxLenx = (parseFloat(bbox[2])-parseFloat(bbox[0]))/this.width;
-			var pxLeny = (parseFloat(bbox[3])-parseFloat(bbox[1]))/this.height;
-			var lat_from = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2)*Math.PI)/180;
-			var lat_to = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2+pxLeny)*Math.PI)/180;
-			var lon_from = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2)*Math.PI)/180;
-			var lon_to = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2+pxLeny)*Math.PI)/180;
-			var dist=6371229*Math.acos(Math.sin(lat_from)*Math.sin(lat_to)+Math.cos(lat_from)*Math.cos(lat_to)*Math.cos(lon_from-lon_to));
-			scale = (dist/Math.SQRT2) * (mb_resolution * 100);
-		}else{
-			xtenty =  parseFloat(bbox[3]) - parseFloat(bbox[1]);
+		if (this.epsg == "EPSG:4326") {
+			var pxLenx = (parseFloat(bbox[2]) - parseFloat(bbox[0])) / this.width;
+			var pxLeny = (parseFloat(bbox[3]) - parseFloat(bbox[1])) / this.height;
+			var lat_from = ((parseFloat(bbox[3]) - parseFloat(bbox[1]) / 2) * Math.PI) / 180;
+			var lat_to = ((parseFloat(bbox[3]) - parseFloat(bbox[1]) / 2 + pxLeny) * Math.PI) / 180;
+			var lon_from = ((parseFloat(bbox[2]) - parseFloat(bbox[0]) / 2) * Math.PI) / 180;
+			var lon_to = ((parseFloat(bbox[2]) - parseFloat(bbox[0]) / 2 + pxLeny) * Math.PI) / 180;
+			var dist = 6371229 * Math.acos(Math.sin(lat_from) * Math.sin(lat_to) + Math.cos(lat_from) * Math.cos(lat_to) * Math.cos(lon_from - lon_to));
+			scale = (dist / Math.SQRT2) * (mb_resolution * 100);
+		else {
+			xtenty = parseFloat(bbox[3]) - parseFloat(bbox[1]);
 			scale = (xtenty / this.height) * (mb_resolution * 100);
-		return Math.round(scale);
+		return parseInt(Math.round(scale));
+	this.checkScale = function(wmsIndex){
+		var thisLayer = this.layers[wmsIndex].split(",");
+		var thisScale = this.getScale();
+		var str_layer = "";
+		var cnt_layer = 0;
+		for (var i = 0; i < this.wms[wmsIndex].objLayer.length; i++) {
+			var currentLayer = this.wms[wmsIndex].objLayer[i];
+			var myLayername = currentLayer.layer_name;
+			var myMinscale = currentLayer.gui_layer_minscale;
+			var myMaxscale = currentLayer.gui_layer_maxscale;
+			for (var ii = 0; ii < thisLayer.length; ii++) {
+				if (thisLayer[ii] == myLayername && !currentLayer.has_childs) {
+					if (myMinscale !== 0 && thisScale < myMinscale) {
+						continue;
+					if (myMaxscale !== 0 && thisScale > myMaxscale) {
+						continue;
+					if (cnt_layer > 0) {
+						str_layer += ",";
+					str_layer += thisLayer[ii];
+					cnt_layer++;
+		var str_layerstyles = [];
+		str_layerstyles[0] = str_layer;
+		return str_layerstyles;
+	this.repaintScale = function(x, y, scale){
+		if (x === null && y === null) {
+			x = parseFloat(arrayBBox[0]) +
+			((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0])) /
+			2);
+			y = parseFloat(arrayBBox[1]) +
+			((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1])) /
+			2);
+		var minx = parseFloat(x) - (this.width / (mb_resolution * 100 * 2) * scale);
+		var miny = parseFloat(y) - (this.height / (mb_resolution * 100 * 2) * scale);
+		var maxx = parseFloat(x) + (this.width / (mb_resolution * 100 * 2) * scale);
+		var maxy = parseFloat(y) + (this.height / (mb_resolution * 100 * 2) * scale);
+		this.repaint(new Point(minx, miny), new Point(maxx, maxy));
+	this.repaint = function(min, max){
+		this.extent = min.x + "," + min.y + "," + max.x + "," + max.y;
+	this.setSingleMapRequest = function (wms_id) {
+		eventBeforeMapRequest.trigger({frameName:this.frameName});
+		var ts = mb_timestamp();
+		for (var ii = 0; ii < this.wms.length; ii++){
+			var currentWms = this.wms[ii];
+			if (currentWms.wms_id != wms_id) {
+				continue;
+			var newMapRequest = getLayerHtmlCode(ii);
+			if (mb_log) {
+				var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
+			var myDivId = this.elementName + "_div_" + ii;
+			writeTag(this.frameName, myDivId, newMapRequest);
+			var myMapId = this.elementName + "_map_" + ii;
+			eventAfterMapRequest.trigger({"frameName":this.elementName, "myMapId":myMapId});
+			return true;
+		return false;
+	this.setMapRequest = function(){
+		var functionName = 'setMapRequest';
+		var ret = eventBeforeMapRequest.trigger({
+				frameName: this.frameName
+			}, "AND");
+		if (ret === false) {
+			return true;
+		var myMapId = [];
+		var newMapRequest = "";
+		for (var ii = 0; ii < this.wms.length; ii++) {
+			if (!(currentWms.gui_wms_visible > 0)) {
+				continue;
+			myMapId.push(this.elementName + "_map_" + ii);
+			newMapRequest += getLayerHtmlCode(ii);
+		writeTag(this.frameName, this.elementName+"_maps", newMapRequest);
+			"frameName": this.elementName,
+			"myMapId": myMapId.join(",")
+	var that = this;
+	var getLayerHtmlCode = function (ii) {
+		var currentWms = that.wms[ii];
+		var myDivId = that.elementName + "_div_" + ii;
+		var myMapId = that.elementName + "_map_" + ii;
+		//disable Layer which are out of scale
+		var validLayers = that.checkScale(ii);
+		var layerNames = validLayers.toString();
+		var newMapURL = false;
+		var opacityString = "";
+		if (that.layers[ii] !== "" && layerNames !== ''){
+			// get map URL
+			newMapURL = that.getMapUrl(ii);
+			var currentOpacity = currentWms.gui_wms_mapopacity;
+			if (currentOpacity != 1) {
+				opacityString += "opacity:" + currentOpacity + "; ";
+				opacityString += "Filter: Alpha(Opacity=" + currentOpacity*100 + "); ";
+				opacityString += "-moz-opacity:" + currentOpacity + " ; ";
+				opacityString += "-khtml-opacity:" + currentOpacity;
+		var imageString = "";
+		if (newMapURL) {
+			imageString = "<img id='"+myMapId+"' name='mapimage' ";
+			imageString += "src='" + newMapURL + "' ";
+			imageString += "width='"+that.width+"' ";
+			imageString += "height='"+that.height+"' ";
+			imageString += "border='0'>";
+		var newMapRequest = "<div id='"+myDivId+"' ";
+		newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
+		newMapRequest += "z-index:" + ii + ";" + opacityString + "\">";
+		newMapRequest += imageString;
+		newMapRequest += "</div>";
+		that.mapURL[ii]= newMapURL;
+		currentWms.mapURL = newMapURL;
+		if (mb_log && currentWms.mapURL) {
+			var tmp = eval(mb_log + "('" +newMapURL + "','" + ts + "')");
+		return newMapRequest;
+	this.getWmsIdByTitle = function (title) {
+		for (var i=0; i < this.wms.length; i++) {
+			if (this.wms[i].wms_title == title) {
+				return this.wms[i].wms_id;
+		return null;
+	this.getWmsIndexById = function (wms_id) {
+		for (var i=0; i< this.wms.length; i++){
+			if(this.wms[i].wms_id == wms_id){
+				return i;
+		return null;
+	this.removeWms = function (wmsIndex) {
+		var wms_ID = null;
+		var i;
+		var new_wmsarray = [];
+		var new_layerarray = [];
+		var new_querylayerarray = [];
+		var new_stylesarray = [];
+		var new_mapURLarray = [];
+			if (i != wmsIndex) {
+				new_wmsarray.push(this.wms[i]);
+				new_layerarray.push(this.layers[i]);
+				new_querylayerarray.push(this.querylayers[i]);
+				new_stylesarray.push(this.styles[i]);
+				new_mapURLarray.push(this.mapURL[i]);
+			else {
+				wms_ID = this.wms[i].wms_id;
+		this.wms = new_wmsarray;
+		this.layers = new_layerarray;
+		this.querylayers = new_querylayerarray;
+		this.styles = new_stylesarray;
+		this.mapURL = new_mapURLarray;
+		var another_new_wmsarray = [];
+		for	(i = 0; i < window.wms.length; i++) {
+			if (window.wms[i].wms_id != wms_ID) {
+				another_new_wmsarray.push(window.wms[i]);
+		window.wms = another_new_wmsarray;
 	 * move a wms or layer
 	 * @param int wms_id id of wms to move
@@ -400,5 +819,32 @@
 		return true;
+	this.getDomElement = function(){
+		return this.domElement;
+	this.getMousePos = function(e){
+		if(ie){
+				clickX = window.frames[fName].event.clientX;
+				clickY = window.frames[fName].event.clientY;
+			else{
+				clickX = event.clientX;
+				clickY = event.clientY;
+		else{
+			clickX = e.pageX;
+			clickY = e.pageY;
+		//remove divtag offset
+		clickX -= parseInt(this.getDomElement().style.left);
+		clickY -= parseInt(this.getDomElement().style.top);
+		return new Point(clickX, clickY);
 	eventAfterMapObjectConstruction.trigger();
\ No newline at end of file
More information about the Mapbender_commits mailing list
