[Mapbender-commits] r2119 - in trunk/build: . JSDoc JSDoc/JSDoc JSDoc/JavaScript JSDoc/JavaScript/Syntax
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Feb 20 06:31:03 EST 2008
Author: christoph
Date: 2008-02-20 06:31:02 -0500 (Wed, 20 Feb 2008)
New Revision: 2119
Added:
   trunk/build/JSDoc/
   trunk/build/JSDoc/.jsdoc_config
   trunk/build/JSDoc/CHANGES
   trunk/build/JSDoc/JSDoc.pm
   trunk/build/JSDoc/JSDoc/
   trunk/build/JSDoc/JSDoc/XMI.pm
   trunk/build/JSDoc/JSDoc/XML.pm
   trunk/build/JSDoc/JSDoc/xmi.tmpl
   trunk/build/JSDoc/JSDoc/xml.tmpl
   trunk/build/JSDoc/JavaScript/
   trunk/build/JSDoc/JavaScript/Syntax/
   trunk/build/JSDoc/JavaScript/Syntax/HTML.pm
   trunk/build/JSDoc/README
   trunk/build/JSDoc/TODO
   trunk/build/JSDoc/TestJSDoc.pl
   trunk/build/JSDoc/allclasses-frame.tmpl
   trunk/build/JSDoc/allclasses-noframe.tmpl
   trunk/build/JSDoc/constant-values.tmpl
   trunk/build/JSDoc/help-doc.tmpl
   trunk/build/JSDoc/index-all.tmpl
   trunk/build/JSDoc/index.tmpl
   trunk/build/JSDoc/jsdoc.pl
   trunk/build/JSDoc/main.tmpl
   trunk/build/JSDoc/overview-frame.tmpl
   trunk/build/JSDoc/overview-summary.tmpl
   trunk/build/JSDoc/overview-tree.tmpl
   trunk/build/JSDoc/stylesheet.css
   trunk/build/JSDoc/test.js
JSDoc
Added: trunk/build/JSDoc/.jsdoc_config
--- trunk/build/JSDoc/.jsdoc_config	                        (rev 0)
+++ trunk/build/JSDoc/.jsdoc_config	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,47 @@
+# Configuration file for JSDoc
+# The following hashes are used for supplying user-defined @attribute tags
+# that will be parsed. Non-standard attributes (such as @subclass) can be
+# added into these hashes, along with a code reference. The return value
+# from the code reference will be included in the documentation. All
+# non-standard tags that are not in the below hashes will be ignored.
+# The code reference will receive a reference to an array of
+# values that were supplied with the @... tag
+# Class attributes
+#eval {
+#   $CLASS_ATTRS_MAP{subclass} =
+#         # subclass is the name of the @... tag
+#         sub {
+#            # Body from which a string is returned
+#            '<DT><B>Subclasses:</B><DD>-' .
+#            join('<DD>-',
+#              map ({"<A HREF=\"$_.html\">$_</A>"}
+#                  map ( { s/\s*(\w+)\s*/$1/; $_} @{@_->[0]})
+#            ) . '<P>'
+#   $CLASS_ATTRS_MAP{with} =
+#         sub {
+#            'This class has a \'@with\' attribute'
+# Method attributes
+# eval {
+#  Uncomment this to allow the filename to be displayed for
+#  each function
+#  $METHOD_ATTRS_MAP{filename} =
+#     sub {
+#          '<DT><B>Filename:</B> ' .  $_[0] . '<P>'
+#  $CLASS_ATTRS_MAP{filename} = $METHOD_ATTRS_MAP{filename};
Added: trunk/build/JSDoc/CHANGES
--- trunk/build/JSDoc/CHANGES	                        (rev 0)
+++ trunk/build/JSDoc/CHANGES	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,622 @@
+JSDoc 1.10.2
+- Fixed broken links to non-existant classes
+JSDoc 1.10.1
+- Added support for @singleton tag, as supplied by Jeffrey To
+- Fixes to constants templates as supplied by Jeffrey To
+JSDoc 1.10
+- Added nested directory structure, as requested by Nitobi
+- Added @implements tag, as requested by Nitobi
+JSDoc 1.9.9.2
+- Fixed disappearing argument list for package-style class constructors
+JSDoc 1.9.9.1
+- Fixed bug in template dir designation that caused JSDoc to crash if
+  run from an absolute path
+JSDoc 1.9.9
+- Added a commandline parameter for supplying a template directory
+- Adding sorting of class names on overview-summary-$filename.js
+  (sf.net bug #1416564)
+- Fix for broken anchors from the overview-summary-$filename page to static
+  methods (SF.net bug #1416543)
+JSDoc 1.9.8.1
+- Don't touch the file source (src) when processing the file overview data
+- Pick up functions as constructors of the @class tag is used
+JSDoc 1.9.8
+- Allow the @base tag to accept the form: @base ClassName URL (RFE 1114510)
+- Be more lenient with @param and @return types (RFE 1104728)
+- Corrected CSS error, changed "pts" to "pt"
+JSDoc 1.9.7
+- Added "--no-lexical-privates" option to ignore locally-defined values
+  from within constructors
+- Fixed linking to static fields/methods
+JSDoc 1.9.6.2
+- Set correct permissions on files in packaging script
+- Fixed compile error on some versions of perl
+- Create distinct anchors for static methods and fields in HTML so that
+  if there is a static and instance method of the same name, the links work
+  correctly
+JSDoc 1.9.6.1
+- Updated unit tests for clearing of function contents
+- Removed collapsing of string literals; this was originally added for version
+  1.9.5.1 to avoid segfaults, but the decision has been made that it is up
+  to the user to use a version of perl that doesn't segfault instead of
+  trying to work around it in perl code.
+- Added (experimental) @exec tag for initialization blocks that should be 'run'
+JSDoc 1.9.6
+- Fix for incorrect return type and parameter types for static method
+  listing in file overview
+- Clear out unused nested functions with the preprocessor to avoid problems
+JSDoc 1.9.5.8
+- Yet another fix for __defineGetter__ and __defineSetter__
+JSDoc 1.9.5.7
+- Fixed bug in syntax highlighting for single-line inline comments
+- Fixed bug in preprocessing of __defineGetter__ and __defineSetter__
+JSDoc 1.9.5.6
+- Fixed incorrect listing of private classes when --private not enabled
+JSDoc 1.9.5.4
+- Corrected bug with function assignment inside constructor
+JSDoc 1.9.5.3
+- Added ability to specify different file extensions on commandline
+JSDoc 1.9.5.2
+- Fixed formatted text munging for @class description
+- Added support for @package tag to be used with XMI export
+JSDoc 1.9.5.1
+- Added collapsing of string literals during preprocessing
+JSDoc 1.9.5
+- Added listing of global (static) methods to file overview summary, code
+  submitted by Jeremy Gillick
+- Allow a global variable to be defined as a class from an anonymous
+  function declaration
+JSDoc 1.9.4.2.1
+- Further fix for typed parameter names starting with a dollar sign
+JSDoc 1.9.4.2
+- Added ability to handle parameter names starting with a dollar sign
+JSDoc 1.9.4.1
+- Only use the first sentence for file and class summary on the
+  overview pages
+- Add a non-breaking space in the overview summary tables when there is no
+  appropriate value to display
+JSDoc 1.9.4
+- If there are multiple source files documented, the index page defaults
+  to the overview summary for the main frame
+- Made JSDoc site link open in parent frame
+- Added overview and file summary tables (similar to package overview table
+  in JavaDoc)
+JSDoc 1.9.3.1
+- Fixed duplicate class-tree output
+JSDoc 1.9.3
+- Added alpha release of XML and XMI output formats
+- Upgrade a function to a class if the @base tag is used
+- Fixed issue with sub-package nested classes requiring the @addon tag
+- Added the implicit "Object" class to the inheritance tree, as well as
+  other classes that are referenced but not defined
+JSDoc 1.9.2.1
+- Added @addon tag, which is used when adding static methods to core classes
+  or classes not defined within the files being documented
+- Fix for the base class of nested classes not being properly set
+- Fix for infinite recursion when all classes are private
+JSDoc 1.9.2
+- Removed unecessary table from overview-summary.tmpl
+- Added the @ignore tag to allow total hiding of functions
+- Fix for incorrect marking of methods as void when the return value is
+  enclosed in parentheses
+- Fix so that methods with a @return tag but without a return statement
+  are not marked as void
+- Fixed issue with not all files being listed in the file listing
+JSDoc 1.9.1.3
+- Fixed issue with backslashes in path
+- Fixed issue with <pre> tags and JavaScript code within fileoverview sections
+- Made documented versions of a method take precedence over a
+  non-documented version
+- Added support for prototype assignment without parentheses
+- Added new @return label {type typeLink} Description... syntax
+JSDoc 1.9.1.2
+- Further improvements to mark_void_method
+- Improved handling of dynamically-bound methods within functions
+- Improved handling of erroneous documenting of 'this'
+- Fixed quoting on error message
+- Added a few new unit tests for testing general behaviour
+JSDoc 1.9.1.1
+- Fix for embarrassing bug in mark_void_method
+JSDoc 1.9.1
+- Fix for the incorrect void marking of methods that return a string literal
+- Fix to stop dynamic prototyping from adding non-dynamic classes
+- Added ability to add a link to parameter-type data, as follows:
+    @param {TypeName http://my.link.com/} myParam Description of parameter
+JSDoc 1.9
+- Added support for a Constant Values page like in Javadoc
+- Added support for private classes (by marking the constructor with
+  the @private attribute)
+- Added a "File" page with links to it in the navbar. The "File" page includes
+  the file overview if one has been supplied, as well as the source view
+  (unless jsdoc has been invoked with the --no-sources flag)
+- Added a --no-sources commandline option to not show the sourcecode for
+  the JavaScript files
+- Added --package-naming commandline option, which specifies that the path
+  leading to each source file will be preserved. This allows for the same
+  filename to be used in different directories. Using the same class name
+  in different packages is _not_ supported (yet)
+- Added JSDoc link and creation time in the footer of each page
+- Added support for @member tag to explicitly mark a method as a member of
+  a class
+JSDoc 1.8.4
+- Added step in prepocessing to attempt to add missing @constructor tags where
+  the 'new' operator is used in combination with a function name elsewhere
+  in the source.
+- Only the first @extends marking (or assignment of an instance to a sub-
+  class's prototype) will be used in determining the base class of a class.
+- Updated test.js to show off more features of JSDoc, as well as a general
+  clean-up.
+- Changed the parser to consider a method to be a class declaration if its
+  documentation contains a @class tag (in addition to the @constructor tag)
+JSDoc 1.8.3.1
+- Some general code cleanup and refactoring.
+- Properly fixed marking of void/non-void methods, and at the same time
+  re-introduced recursive regexes (this time non-dynamic, as dynamic seem
+  to be much too unstable)
+JSDoc 1.8.3
+- Changed the handling for __defineGetter__ and __defineSetter__
+  to define a property instead of a method in the documentation
+- Fixed bug in parse_jsdoc_comment that didn't allow for email addresses
+  to be entered verbatim (instead, the domain of the address was parsed
+  as a tag)
+- Re-did the @fileoverview parsing, now other tags and inner {@link...}
+  tags are included. Additionally, if only one file is processed and there
+  is no project overview file included, the file's overview (if it exists)
+  is used as the project overview. Thanks to Robert Flaherty for input
+  and bug reports on this issue.
+JSDoc 1.8.2.1
+- Got rid of extra '*' with @fileoverview
+JSDoc 1.8.2
+- Fixed bug where other @tags were included as part of the @fileoverview
+- Added support for @version in method documentation
+- Partial fix for incorrect marking of void methods
+- Made field and return @type handling more robust and flexible
+JSDoc 1.8.1
+- Added @extends as a synonym for @base
+- Fixed doubled-up <UL> tags in hierarchy tree code (thanks to Robert Flaherty)
+- Fixed bug where a class's base class would not get recorded if
+  there was a forward assignment of a static value to the class
+  (thanks to Robert Flaherty)
+JSDoc 1.8
+- Remove the GLOBALS class if it is empty
+- Fixed case-sensitive sort in index
+- Added support for comments with long blocks of '*'s in the opening and
+  closing of the doc string
+- Added sourcecode view
+- Fixed bug where named anonymous functions were not recognized as methods
+  when assigned to prototypes
+- Allow for singletons to be declared with var
+- Allow for binding static properties to classes before they are defined
+- Added @overviewfile attribute for class documentation, inlines html or
+  textfiles into the documentation
+- Added beginnings of unit testing
+- Don't add 'constructor' as an instance or class property
+- Added an @overviewfile tag which can be put in an independent
+  jsdoc-comment block at the top of each file. This results in a project
+  overview page for each file with an overview, similar to JavaDoc's
+  package pages.
+- Added support for Mozilla's __defineGetter__ and __defineSetter__
+- Return type for methods is now Object, and is displayed instead of the
+  'function' declaration. The 'void' type is shown if no return can be
+  found in the function and no other type is defined. The defaulting to
+  Object also goes for fields, and is shown instead of the 'var' declaration
+- Allow usage of the {@link url label} construct for the @type tag
+JSDoc 1.7.2.1
+- Fixed segfault problem in huge constructors with deconstruct_constructor
+  selection regex
+JSDoc 1.7.2
+- Added a @class tag to constructors, for providing class-specific information
+- Added handling for Singleton classes
+- Added handler for @base tag to denote inheritance
+JSDoc 1.7.1.4
+- Fixed bug introduced by refactoring of &format_link
+JSDoc 1.7.1.3
+- Added workaround in &format_link for apparent bug in some builds of
+  perl 5.8.0
+- Fixed bug in handling of --recursive (was always recursive)
+JSDoc 1.7.1.2
+- Fixed problems with new preprocessor when confronted with nested classes
+JSDoc 1.7.1.1
+- Fixed bug where {@link}s inside of @params weren't processed
+JSDoc 1.7.1
+- Added --quiet switch and message to signify ending of successful execution
+- Fixed problem with perl segfaulting on big class prototype block definitions
+- Fixed incorrectly formatted {@link}s nested in other @attributes
+- Added preprocessor for handling private methods to replace bulky
+  and buggy evaluate_constructor method
+JSDoc 1.7
+- Added usage of strict and warnings in JSDoc.pm
+- Added ability to set type information for method parameters
+  (e.g. /** @param {String} userName The name of the current user */ )
+- Added support for class prototype initialization blocks (finally!)
+JSDoc 1.6.3.1
+- Fixed bug where static fields initialized to 0 are not picked up
+JSDoc 1.6.3
+- Removed the constraint that a nested class constructor must be marked
+  with the @constructor attribute
+- Allow @constructor attribute to mark nested class constructors which would
+  otherwise be considered static methods
+- Allow newlines as well as semi-colon for line-endings
+- Allow a leading '$' for field names
+JSDoc 1.6.2.1
+- Fixed splicing error for nested classes, thanks again to jdber
+JSDoc 1.6.2
+- Carry over overridden method description attributes even if there is
+  no text description to carry over
+- Improved HTML in main.tmpl
+- Fixed infinite loop and recognition for when static inner class construct is
+  used (thanks to jdber for the patch)
+- Added a Nested Class Summary section to the output documentation to display
+  inner classes
+JSDoc 1.6.1.1
+- Fixed bug in carrying over description of overridden methods
+JSDoc 1.6.1
+- Improved the format_link function in jsdoc.pl so that {@links} will
+  not be made to non-existent resources, and parentheses are not placed
+  after a field name (as opposed to a method name)
+- Carry over method documentation for overridden methods if no new
+  documentation has been supplied for the method. This is in following with
+  javadoc functionality
+- Fixed /* functionality(whatever) bug
+- Fixed remaining problems with comments inside of parameter lists
+JSDoc 1.6
+- Big cleanup in jsdoc.pl in terms of writing templates to file
+- Fixed bug where multi-line @params don't work
+- Added filename-scoped frame, as well as the name of the filename for
+  each class
+- Improved the linking implementation for @link and @see to do a better job
+  in terms of not building broken links
+JSDoc 1.5.2
+- Changed the name '[default context]' for non-class functions to be
+  GLOBALS, also made this name configurable with command-line parameters
+- Made jsdoc easily runnable from anywhere on the filesystem, without
+  requiring installing JSDoc.pm in the @INC
+JSDoc 1.5.1
+- Added support for @requires in methods
+- Generic '@' attributes now work for constructors, such as @see and @throws.
+  Also added support for @return and @returns for constructors
+- Fixed the @link construct to allow custom labels
+- Added standard support for @author in methods as well as classes
+  (Thanks for Rainer Eschen for bringing me to my senses)
+- Fixed spacing for @author attributes
+JSDoc 1.5
+- Fixed bug that would break HTML links within documentation
+- Fixed bug in path to logo in IMG tags
+- Added support for type information for both methods and fields
+- Added suppport for @private in instance fields
+- Fixed bug where private methods would show up in the inherited methods list
+  in subclasses
+- Private class methods are now also supported
+- Method parameters details are displayed in the same order as the parameter
+  list for a method
+- Moved more info into the 'vars' member of methods, and away from the parser
+- Added @final (with synonym @const) for class and instance properties
+- Fix in parser where string literals bound to classes in a constructor were
+  not caught by the parser
+JSDoc 1.4
+- Added @attributes: @author, @deprecated, @see, @version, @requires, @throws
+- Updated pod (removed documentation for non-existant parse_jsdoc_source,
+added a small example)
+- Added function to reset the parser (reset_parser)
+- Fixed bug where the same property could be bound to a class's prototype
+more than once
+- Fixed bug where embedded // comments would break the parser
+- Added ability to set project name, page footer, logo and project summary
+(thanks to Jeff Conrad for code and suggestions)
+- Added overview summary (thanks to Jeff Conrad for code)
+- Split up loading/parsing of sources file to prevent crashes that were caused
+by overloading the regex engine
+- Added overview-tree (thanks to Jeff Conrad for the code contribution)
+- Fixed bug where some assignments of methods to instances in a constructor
+would get lost
+- Fix in doc-parsing where a line with only a star and a newline would get
+passed over
+- Added ability to 'hide' methods with @private
+JSDoc 1.3
+- When a function is marked with @constructor, it will always be dealt
+with as a class
+- Improved doc regex
+- Added recursive directory handling
Added: trunk/build/JSDoc/JSDoc/XMI.pm
--- trunk/build/JSDoc/JSDoc/XMI.pm	                        (rev 0)
+++ trunk/build/JSDoc/JSDoc/XMI.pm	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,291 @@
+package JSDoc::XMI;
+use strict;
+use warnings;
+use HTML::Template;
+use Data::Dumper;
+=head1 DESCRIPTION
+    @packages
+        @classes
+            $classname
+            $classid
+            $classuuid
+            $classvisibility (public|protected|private)
+            @specializationids
+                $specializationid
+            $generalizationid
+            @attributes
+                $attributeid
+                $attributeuuid
+                $attributename
+                $attributevisibility (public|protected|private)
+                $ownerscope (instance|classifier)
+                $classid
+                $typeid
+            @methods
+                $methodid
+                $methoduuid
+                $methodname
+                $methodvisibility (public|protected|private)
+                $returnid
+                $returnuuid
+                $returntypeid
+    @datatypes
+        $datatypeid
+        $datatypeuuid
+        $datatypename
+    @generalizations
+        $generalizationid
+        $generalizationuuid
+        $generalizationchild
+        $generalizationparent
+=cut
+sub new {
+    my ($package, $location) = @_;
+    bless {
+        location        => "${location}JSDoc/",
+        idcounter       => 2,
+        types           => {},
+        classes         => {},
+        generalizations => {}
+    }, $package;
+sub output {
+    my ($self, $classes) = @_;
+    my $template = HTML::Template->new(
+        filename    => $self->{location} . 'xmi.tmpl',
+        die_on_bad_params => 1);
+    my @packages = $self->get_packages($classes);
+    my @datatypes = $self->get_datatypes;
+    my @generalizations = $self->get_generalizations;
+    $template->param(
+        packages        => \@packages,
+        datatypes       => \@datatypes,
+        generalizations => \@generalizations );
+    return $template->output;
+sub get_id {
+    'xmi.' . shift->{idcounter}++;
+sub get_uuid {
+    my @chars = ('A'..'Z', 'a'..'z', 0..9);
+    my @uuid;
+    for (1..32){
+        push @uuid, $chars[rand(@chars)];
+    join("", @uuid);
+sub get_packages {
+    my %packages;
+    push(@{$packages{$_->{package}}}, $_)
+        for $self->get_classes($classes);
+    map {
+        name        => $_,
+        classes     => $packages{$_},
+        packageid   => $self->get_id,
+        packageuuid => $self->get_uuid
+    }, keys %packages;
+sub get_classes {
+    my @classes;
+    # Store all the class-ids before we start on anything else
+    $self->add_class($_) for keys %$classes;
+    for my $cname (keys %$classes){
+        my $class = {
+            classname       => $cname,
+            classid         => $self->add_class($cname),
+            classuuid       => $self->get_uuid,
+            classvisibility =>
+                defined($classes->{$cname}->{constructor_vars}->{private})
+                ? 'private' : 'public'
+        $class->{attributes} = $self->get_attributes(
+            $class->{classid},
+            $classes->{$cname});
+        $class->{methods} = $self->get_methods(
+        $class->{generalizationid} =
+            $self->get_generalizationid($classes->{$cname});
+        $class->{package} =
+            defined($classes->{$cname}->{constructor_vars}->{package})
+            ? $classes->{$cname}->{constructor_vars}->{package}->[0] : '';
+        push @classes, $class;
+    for my $class (@classes){
+        $class->{specializationids} = $self->get_specializationids($class);
+    @classes;
+sub get_methods {
+    my ($self, $classid, $class) = @_;
+    my @methods;
+    for my $k (qw(instance class)){
+        for my $method (@{$class->{"${k}_methods"}}){
+            my $type = defined($method->{vars}->{type})
+                ? $method->{vars}->{type}->[0] : 'Object';
+            my $meth = {
+                methodid            => $self->get_id,
+                methoduuid          => $self->get_uuid,
+                methodname          => $method->{mapped_name},
+                methodvisibility    =>
+                    defined($method->{vars}->{private})
+                    ? 'private' : 'public',
+                ownerscope          =>
+                    $k eq 'class' ? 'classifier' : 'instance',
+                returnid            => $self->get_id,
+                returnuuid          => $self->get_uuid,
+                returntypeid        => $self->add_type($type)
+            push @methods, $meth;
+    return \@methods;
+sub get_attributes {
+    my @attributes;
+        for my $field (@{$class->{"${k}_fields"}}){
+            my $type = defined($field->{field_vars}->{type})
+                ? $field->{field_vars}->{type}->[0] : 'Object';
+            my $attr = {
+                attributeid         => $self->get_id,
+                attributeuuid       => $self->get_uuid,
+                attributename       => $field->{field_name},
+                attributevisibility =>
+                    defined($field->{field_vars}->{private})
+                ownerscope          =>
+                classid             => $classid,
+                typeid              => $self->add_type($type)
+            push @attributes, $attr;
+    \@attributes;
+sub get_generalizationid {
+    my ($self, $class) = @_;
+    if ($class->{extends}){
+        return $self->add_generalization(
+            $class->{classname},
+            $class->{extends});
+sub get_specializationids {
+    my $cname = $class->{classname};
+    my $cid = $self->add_class($cname);
+    my @specializationids;
+    for my $id (keys %{$self->{generalizations}}){
+        my $generalization = $self->{generalizations}->{$id};
+        if ($generalization->{parent} eq $cid){
+            push @specializationids, { specializationid => $id };
+    \@specializationids;
+sub get_datatypes {
+    my ($self) = @_;
+    my @datatypes;
+    while (my ($type, $id) = each(%{$self->{types}})){
+        push @datatypes, {
+            datatypeid      => $id,
+            datatypeuuid    => $self->get_uuid,
+            datatypename    => $type };
+    @datatypes;
+sub get_generalizations {
+    my ($self) = @_;
+    my @generalizations;
+    while (my ($id, $generalization) = each(%{$self->{generalizations}})){
+        push @generalizations, {
+            generalizationid        => $id,
+            generalizationuuid      => $self->get_uuid,
+            generalizationchild     => $generalization->{parent},
+            generalizationparent    => $generalization->{child}};
+    @generalizations;
+sub add_type {
+    my ($self, $type) = @_;
+    $type =~ s/^\s*(\S+)\s*$/$1/;
+    if (defined($self->{classes}->{$type})){
+        return $self->add_class($type);
+    } elsif (defined($self->{types}->{$type})){
+        return $self->{types}->{$type};
+    $self->{types}->{$type} = $self->get_id;
+sub add_class {
+    $class =~ s/^\s*(\S+)\s*$/$1/;
+    if (defined($self->{classes}->{$class})){
+        return $self->{classes}->{$class};
+    $self->{classes}->{$class} = $self->get_id;
+sub add_generalization {
+    my ($self, $subclassname, $superclassname) = @_;
+    my $subclassid = $self->add_class($subclassname);
+    my $superclassid = $self->add_class($superclassname);
+    my $generalization = {
+        child       => $subclassid,
+        parent      => $superclassid };
+    my $generalizationid = $self->get_id;
+    $self->{generalizations}->{$generalizationid} = $generalization;
+    $generalizationid;
+1;
Added: trunk/build/JSDoc/JSDoc/XML.pm
--- trunk/build/JSDoc/JSDoc/XML.pm	                        (rev 0)
+++ trunk/build/JSDoc/JSDoc/XML.pm	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,72 @@
+package JSDoc::XML;
+use strict;
+use warnings;
+sub new {
+    bless { location => "${location}JSDoc/" }, $package;
+sub output {
+    my @classes = _preprocess(
+        grep {defined($_->{classname})} values %$classes);
+        filename    => $self->{location} . 'xml.tmpl',
+    $template->param(classes => \@classes);
+sub _preprocess {
+    my @classes = @_;
+    for (@classes){
+        $_->{inherits} = _preprocess_inherits($_->{inherits});
+        $_->{constructor_vars} = _preprocess_vars($_->{constructor_vars});
+        for my $method (@{$_->{instance_methods}}, @{$_->{class_methods}}){
+            $method->{vars} = _preprocess_vars($method->{vars});
+        for my $field (@{$_->{instance_fields}}, @{$_->{class_fields}}){
+            $field->{field_vars} = _preprocess_vars($field->{field_vars});
+    @classes;
+sub _preprocess_inherits {
+    my ($inherits) = @_;
+    my @inherits;
+    for my $class (keys %$inherits){
+        my $inherit = {
+            class   => $class,
+            methods => [map { name => $_ },
+                            @{$inherits->{$class}->{instance_methods}}]};
+        push @inherits, $inherit;
+    \@inherits;
+sub _preprocess_vars {
+    my ($vars) = @_;
+    return $vars if ref($vars) eq 'ARRAY';
+    my @vars;
+    for my $key (keys %$vars){
+        my $var;
+        if (ref($vars->{$key}) eq 'ARRAY'){
+            $var = {
+                '@name' => $key,
+                values  => [map { val => $_ }, @{$vars->{$key}}] };
+        } else {
+            $var = {
+                '@name' => $key,
+                values  => [ { val => $vars->{$key} } ] };
+        push @vars, $var;
+    \@vars;
+1;
Added: trunk/build/JSDoc/JSDoc/xmi.tmpl
--- trunk/build/JSDoc/JSDoc/xmi.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/JSDoc/xmi.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,250 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<XMI xmi.version="1.0">
+  <XMI.header>
+    <XMI.documentation>
+      <XMI.exporter>JSDoc XMI Export</XMI.exporter>
+      <XMI.exporterVersion>0.1</XMI.exporterVersion>
+    </XMI.documentation>
+    <XMI.metamodel xmi.name="UML" xmi.version="1.3"/>
+  </XMI.header>
+  <XMI.content>
+    <Model_Management.Model xmi.id="xmi.1" xmi.uuid="10-0-0-5-3605f878:101c2e18bff:-8000">
+      <Foundation.Core.ModelElement.name>JSDoc</Foundation.Core.ModelElement.name>
+      <Foundation.Core.ModelElement.isSpecification xmi.value="false"/>
+      <Foundation.Core.GeneralizableElement.isRoot xmi.value="false"/>
+      <Foundation.Core.GeneralizableElement.isLeaf xmi.value="false"/>
+      <Foundation.Core.GeneralizableElement.isAbstract xmi.value="false"/>
+      <Foundation.Core.Namespace.ownedElement>
+        <!-- BEGIN PACKAGES -->
+        <TMPL_LOOP NAME="packages">
+          <TMPL_IF NAME="name">
+            <Model_Management.Package
+              xmi.id="<TMPL_VAR NAME="packageid">"
+              xmi.uuid="<TMPL_VAR NAME="packageuuid">">
+            <Foundation.Core.ModelElement.name><TMPL_VAR NAME="name"></Foundation.Core.ModelElement.name>
+            <Foundation.Core.ModelElement.namespace>
+              <Foundation.Core.Namespace xmi.idref="xmi.1"/>
+            </Foundation.Core.ModelElement.namespace>
+          </TMPL_IF>
+            <!-- BEGIN CLASS DESCRIPTIONS -->
+            <TMPL_LOOP NAME="classes">
+              <TMPL_IF NAME="package">
+              </TMPL_IF>
+              <!-- BEGIN CLASS -->
+              <Foundation.Core.Class
+                  xmi.id="<TMPL_VAR NAME=classid>"
+                  xmi.uuid="<TMPL_VAR NAME=classuuid>">
+                <!-- CLASS NAME -->
+                <Foundation.Core.ModelElement.name><!-- TMPL_VAR NAME="classname" --></Foundation.Core.ModelElement.name>
+                <Foundation.Core.ModelElement.visibility
+                    xmi.value="<TMPL_VAR NAME=classvisibility>"/>
+                <Foundation.Core.Class.isActive xmi.value="false"/>
+                <!-- BEGIN REFERENCE TO INHERITANCE -->
+                <TMPL_IF NAME="generalizationid">
+                <Foundation.Core.GeneralizableElement.generalization>
+                  <Foundation.Core.Generalization
+                      xmi.idref="<TMPL_VAR NAME=generalizationid >"/>
+                </Foundation.Core.GeneralizableElement.generalization>
+                </TMPL_IF>
+                <TMPL_LOOP NAME="specializationids">
+                <Foundation.Core.GeneralizableElement.specialization>
+                      xmi.idref="<TMPL_VAR NAME=specializationid >"/>
+                </Foundation.Core.GeneralizableElement.specialization>
+                </TMPL_LOOP>
+                <!-- END REFERENCE TO INHERITANCE -->
+                <Foundation.Core.Classifier.feature>
+                <!-- BEGIN ATTRIBUTES -->
+                <TMPL_LOOP NAME="attributes">
+                  <!-- BEGIN ATTRIBUTE -->
+                  <Foundation.Core.Attribute
+                      xmi.id="<TMPL_VAR NAME=attributeid>"
+                      xmi.uuid="<TMPL_VAR NAME=attributeuuid>">
+                    <Foundation.Core.ModelElement.name><!-- TMPL_VAR NAME="attributename" --></Foundation.Core.ModelElement.name>
+                    <Foundation.Core.ModelElement.visibility xmi.value="<TMPL_VAR NAME=attributevisibility>"/>
+                    <Foundation.Core.Feature.ownerScope
+                        xmi.value="<TMPL_VAR NAME=ownerscope>"/>
+                    <!--Foundation.Core.StructuralFeature.multiplicity>
+                      <Foundation.Data_Types.Multiplicity xmi.id="xmi.5">
+                        <Foundation.Data_Types.Multiplicity.range>
+                          <Foundation.Data_Types.MultiplicityRange xmi.id="xmi.6">
+                            <Foundation.Data_Types.MultiplicityRange.lower>1</Foundation.Data_Types.MultiplicityRange.lower>
+                            <Foundation.Data_Types.MultiplicityRange.upper>1</Foundation.Data_Types.MultiplicityRange.upper>
+                          </Foundation.Data_Types.MultiplicityRange>
+                        </Foundation.Data_Types.Multiplicity.range>
+                      </Foundation.Data_Types.Multiplicity>
+                    </Foundation.Core.StructuralFeature.multiplicity-->
+                    <Foundation.Core.StructuralFeature.changeability xmi.value="changeable"/>
+                    <Foundation.Core.StructuralFeature.targetScope xmi.value="instance"/>
+                    <Foundation.Core.Feature.owner>
+                        xmi.idref="<TMPL_VAR NAME=classid>"/>
+                    </Foundation.Core.Feature.owner>
+                    <Foundation.Core.StructuralFeature.type>
+                          xmi.idref="<TMPL_VAR NAME=typeid>"/>
+                    </Foundation.Core.StructuralFeature.type>
+                    <!--Foundation.Core.ModelElement.taggedValue>
+                      <Foundation.Extension_Mechanisms.TaggedValue xmi.id="xmi.8">
+                        <Foundation.Extension_Mechanisms.TaggedValue.tag>transient</Foundation.Extension_Mechanisms.TaggedValue.tag>
+                        <Foundation.Extension_Mechanisms.TaggedValue.value>false</Foundation.Extension_Mechanisms.TaggedValue.value>
+                        <Foundation.Extension_Mechanisms.TaggedValue.modelElement>
+                          <Foundation.Core.ModelElement xmi.idref="xmi.4"/>
+                        </Foundation.Extension_Mechanisms.TaggedValue.modelElement>
+                      </Foundation.Extension_Mechanisms.TaggedValue>
+                      <Foundation.Extension_Mechanisms.TaggedValue xmi.id="xmi.9">
+                        <Foundation.Extension_Mechanisms.TaggedValue.tag>volatile</Foundation.Extension_Mechanisms.TaggedValue.tag>
+                    </Foundation.Core.ModelElement.taggedValue-->
+                  </Foundation.Core.Attribute>
+                  <!-- END ATTRIBUTE -->
+                </TMPL_LOOP>
+                <!-- END ATTRIBUTES -->
+                <!-- BEGIN METHODS -->
+                <TMPL_LOOP NAME="methods">
+                  <!-- BEGIN METHOD -->
+                  <Foundation.Core.Operation
+                      xmi.id="<TMPL_VAR NAME=methodid>"
+                      xmi.uuid="<TMPL_VAR NAME=methoduuid>">
+                      <Foundation.Core.ModelElement.name><!-- TMPL_VAR NAME="methodname" --></Foundation.Core.ModelElement.name>
+                        xmi.value="<TMPL_VAR NAME=methodvisibility>"/>
+                    <Foundation.Core.BehavioralFeature.isQuery xmi.value="false"/>
+                    <Foundation.Core.Operation.concurrency xmi.value="sequential"/>
+                    <Foundation.Core.Operation.isRoot xmi.value="false"/>
+                    <Foundation.Core.Operation.isLeaf xmi.value="false"/>
+                    <Foundation.Core.Operation.isAbstract xmi.value="false"/>
+                    <Foundation.Core.BehavioralFeature.parameter>
+                      <!-- BEGIN RETURN TYPE -->
+                      <Foundation.Core.Parameter
+                          xmi.id="<TMPL_VAR NAME=returnid>"
+                          xmi.uuid="<TMPL_VAR NAME=returnuuid>">
+                        <Foundation.Core.ModelElement.name>return</Foundation.Core.ModelElement.name>
+                        <Foundation.Core.Parameter.kind xmi.value="return"/>
+                        <!--Foundation.Core.Parameter.behavioralFeature>
+                          <Foundation.Core.BehavioralFeature xmi.idref="xmi.10"/>
+                        </Foundation.Core.Parameter.behavioralFeature-->
+                        <Foundation.Core.Parameter.type>
+                              xmi.idref="<TMPL_VAR NAME=returntypeid>"/>
+                        </Foundation.Core.Parameter.type>
+                      </Foundation.Core.Parameter>
+                      <!-- END RETURN TYPE -->
+                    </Foundation.Core.BehavioralFeature.parameter>
+                  </Foundation.Core.Operation>
+                  <!-- END METHOD -->
+                </TMPL_LOOP>
+                <!-- END METHODS -->
+                </Foundation.Core.Classifier.feature>
+              </Foundation.Core.Class>
+              <!-- END CLASS -->
+                </Foundation.Core.Namespace.ownedElement>
+              </TMPL_IF>
+            </TMPL_LOOP>
+            <!-- END CLASS DESCRIPTIONS -->
+            <TMPL_IF name="name">
+            </Model_Management.Package>
+            </TMPL_IF>
+      </TMPL_LOOP>
+      <!-- END PACKAGES -->
+      <!-- BEGIN DATATYPE DESCRIPTIONS -->
+      <TMPL_LOOP name="datatypes">
+        <!-- BEGIN DATATYPE -->
+        <Foundation.Core.DataType
+            xmi.id="<TMPL_VAR NAME=datatypeid>"
+            xmi.uuid="<TMPL_VAR NAME=datatypeuuid>">
+          <Foundation.Core.ModelElement.name><!-- TMPL_VAR NAME="datatypename" --></Foundation.Core.ModelElement.name>
+        </Foundation.Core.DataType>
+        <!-- END DATATYPE -->
+      </TMPL_LOOP>
+      <!-- END DATATYPE DESCRIPTIONS -->
+      <!-- BEGIN GENERALIZATIONS -->
+      <TMPL_LOOP NAME="generalizations">
+        <!-- BEGIN GENERALIZATION -->
+            xmi.id="<TMPL_VAR NAME=generalizationid >"
+            xmi.uuid="<TMPL_VAR NAME=generalizationuuid >" >
+          <Foundation.Core.Generalization.child>
+                xmi.idref="<TMPL_VAR NAME=generalizationchild >"/>
+          </Foundation.Core.Generalization.child>
+          <Foundation.Core.Generalization.parent>
+                xmi.idref="<TMPL_VAR NAME=generalizationparent >"/>
+          </Foundation.Core.Generalization.parent>
+        </Foundation.Core.Generalization>
+        <!-- END GENERALIZATION -->
+      </TMPL_LOOP>
+      <!-- END GENERALIZATIONS -->
+    </Model_Management.Model>
+  </XMI.content>
+</XMI>
Added: trunk/build/JSDoc/JSDoc/xml.tmpl
--- trunk/build/JSDoc/JSDoc/xml.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/JSDoc/xml.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,128 @@
+<?xml version="1.0"?>
+<javascript>
+    <classes>
+        <class
+            name="<TMPL_VAR NAME="classname">"
+                <TMPL_IF NAME="extends">extends="<TMPL_VAR NAME='extends'>"</TMPL_IF> >
+            <constructor_args><!-- TMPL_VAR NAME="constructor_args" --></constructor_args>
+            <constructor_vars>
+            <TMPL_LOOP NAME="constructor_vars">
+                <var name="<TMPL_VAR NAME='@name'>">
+                <TMPL_LOOP NAME="values">
+                    <value><![CDATA[<TMPL_VAR NAME="val">]]></value>
+                </TMPL_LOOP>
+                </var>
+            </TMPL_LOOP>
+            </constructor_vars>
+            <constructor_detail><![CDATA[<TMPL_VAR NAME="constructor_detail">]]></constructor_detail>
+            <instance-methods>
+                <TMPL_LOOP NAME="instance_methods">
+                    <method mapped_name="<TMPL_VAR NAME='mapped_name'>">
+                        <description><![CDATA[<TMPL_VAR NAME="description">]]></description>
+                        <argument_list><!--
+                            TMPL_VAR NAME="argument_list"
+                            --></argument_list>
+                        <vars>
+                            <TMPL_LOOP NAME="vars">
+                            </TMPL_LOOP>
+                            </var>
+                            </TMPL_LOOP>
+                        </vars>
+                </method>
+               </TMPL_LOOP>
+            </instance-methods>
+            <instance-fields>
+                <TMPL_LOOP NAME="instance_fields">
+                    <field name="<TMPL_VAR NAME='field_name'>">
+                    <field-value><![CDATA[<TMPL_VAR NAME="field_value">]]></field-value>
+                        <field-description><![CDATA[<TMPL_VAR NAME="field_description">]]></field-description>
+                            <vars>
+                                <TMPL_LOOP NAME="field_vars">
+                            </TMPL_LOOP>
+                                    </var>
+                                </TMPL_LOOP>
+                        </vars>
+                    </field>
+                </TMPL_LOOP>
+            </instance-fields>
+            <class-methods>
+                <TMPL_LOOP NAME="class_methods">
+                        <vars>
+                            </TMPL_LOOP>
+                            </var>
+                            </TMPL_LOOP>
+                        </vars>
+                </method>
+                </TMPL_LOOP>
+            </class-methods>
+            <class-fields>
+                <TMPL_LOOP NAME="class_fields">
+                            <vars>
+                            </TMPL_LOOP>
+                                    </var>
+                                </TMPL_LOOP>
+                        </vars>
+                    </field>
+                </TMPL_LOOP>
+            </class-fields>
+            <inner-classes>
+            <TMPL_LOOP NAME="inner_classes">
+                <class name="<TMPL_VAR NAME='class_name'>"/>
+            </TMPL_LOOP>
+        </inner-classes>
+            <TMPL_LOOP NAME="inherits">
+                <inherits from="<TMPL_VAR NAME='class'>">
+                <TMPL_IF NAME="methods">
+                <methods>
+                        <method><!-- TMPL_VAR NAME="name" --></method>
+                    </TMPL_LOOP>
+                </methods>
+                </TMPL_IF>
+                <TMPL_IF NAME="fields">
+                <fields>
+                </fields>
+            </TMPL_IF>
+        </inherits>
+            </TMPL_LOOP>
+        </class>
+    </TMPL_LOOP>
+    </classes>
+</javascript>
Added: trunk/build/JSDoc/JSDoc.pm
--- trunk/build/JSDoc/JSDoc.pm	                        (rev 0)
+++ trunk/build/JSDoc/JSDoc.pm	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,1090 @@
+package JSDoc;
+=head1 NAME
+JSDoc - parse JavaScript source file for JSDoc comments
+=head1 SYNOPSIS
+Create JavaScript sourcefiles commented in a manner similar to javadoc
+(ie. with documentation starting with '/**' and then pass a list of references
+to JavaScript source to parse_code_tree:
+    * This is a class for example purposes
+    * @param name Name for the new object
+    * @constructor
+    function MyClass(name){
+      this.name = name;
+   $code_tree = parse_code_tree(@src_refs);
+A tree structure describing the code layout, inheritance and documentation
+is returned
+To clear the cache of classes and functions in the parser:
+   reset_parser();
+=head1 DESCRIPTION
+The C<parse_code_tree> function requires a ref to a string holding the
+souce code of a javascript object file or files. It returns a data structure
+that describes the object hierarchy contained in the source file, as well
+as included documentation for all fields and methods. The resulting
+data structure has the following form (for each class):
+   Class
+      +- classname
+      +- constructor_args
+      +- extends
+      +- constructor_detail
+      +- constructor_vars
+      +- class_methods
+      |  +- description
+      |  +- mapped_name
+      |  +- argument_list
+      |  +- vars
+      +- instance_methods
+      |  +- description
+      |  +- mapped_name
+      |  +- vars
+      +- class_fields
+      |  +- field_description
+      |  +- field_name
+      |  +- field_value
+      |  +- field_vars
+      +- instance_fields
+      |  +- field_name
+      |  +- field_value
+      |  +- field_vars
+      +- inner_classes
+      |  +- class_name
+      +- inherits
+         +- Class
+There is also an additional entry under the key __FILES__ that contains
+keyed entries for each @tag that was defined in the first JSDoc comment
+block with a @fileoverview tag. Each entry under __FILES__ is keyed by
+filename, and is a hash reference.
+=head1 AUTHORS
+Gabriel Reid gab_reid at users.sourceforge.net,
+Michael Mathews michael at mathews.net
+=cut
+require 5.000;
+use strict;
+use warnings;
+use Exporter;
+# Recursion limit for recursive regexes
+use constant RECURSION  => 10;
+use vars qw/ @ISA @EXPORT /;
+ at ISA = qw(Exporter);
+ at EXPORT = qw(parse_code_tree configure_parser reset_parser);
+# State
+use vars qw/ %CLASSES %FUNCTIONS %CONFIG $CTX_FILE /;
+# Regexes
+use vars qw/ $BAL_PAREN $BAL_BRACE $BAL_SQUAR $SQUOTE $DQUOTE $NONQUOTE
+               $FUNC_DEF $RET_FUNC_DEF $ANON_FUNCTION $LITERAL $FUNC_CALL
+               $JSDOC_COMMENT $MLINE_COMMENT $SLINE_COMMENT /;
+# This limits nested braces to 30 levels, but is much more
+# stable than using a dynamic regex
+$BAL_BRACE      = qr/\{(?:[^\{\}])*\}/;
+$BAL_PAREN      = qr/\((?:[^()])*\)/;
+$BAL_SQUAR      = qr/\[(?:[^[\]])*\]/;
+for (1..RECURSION){
+    $BAL_BRACE  = qr/\{(?:[^\{\}]|$BAL_BRACE)*\}/;
+    $BAL_PAREN  = qr/\((?:[^()]|$BAL_PAREN)*\)/;
+    $BAL_SQUAR  = qr/\[(?:[^[\]]|$BAL_SQUAR)*\]/;
+$SQUOTE         = qr{'[^'\\]*(?:\\.[^'\\]*)*'};
+$DQUOTE         = qr{"[^"\\]*(?:\\.[^"\\]*)*"};
+$NONQUOTE       = qr{[^"'/]};
+$FUNC_DEF       = qr/function\s+\w+(?:\.\w+)*\s*$BAL_PAREN\s*$BAL_BRACE/;
+$RET_FUNC_DEF   = qr/function\s+(\w+(?:\.\w+)*)\s*($BAL_PAREN)\s*($BAL_BRACE)/;
+$ANON_FUNCTION  = qr/function\s*$BAL_PAREN\s*$BAL_BRACE/;
+$LITERAL        = qr/$DQUOTE|$SQUOTE|\d+/;
+$FUNC_CALL      = qr/(?:new\s+)?\w+(?:\.\w+)*\s*$BAL_PAREN/;
+$JSDOC_COMMENT  = qr{/\*\*[^*]*\*+(?:[^/*][^*]*\*+)*/};
+$MLINE_COMMENT  = qr{/\*[^*]*\*+(?:[^/*][^*]*\*+)*/};
+$SLINE_COMMENT  = qr{//[^\n]*};
+# Public function that returns a datastructure representing the JS classes
+# and their documentation
+sub parse_code_tree {
+    &initialize_parser;
+    # This (I mean the "<<$_>>") is pretty hacky, but I've made it this
+    # way to maintain backwards compatibility with anyone who's automatically
+    # expecting this to work when they throw an array of refs to it. If you're
+    # using this for your own work, please don't expect to be able to
+    # put the context file in like this in the future
+    for my $js_src (map { ref and ${$_} or "<<$_>>" } @_){
+        if ($js_src =~ /^<<(.+)>>$/){
+            $CTX_FILE = $1;
+            next;
+        # perlify os line-endings
+        $js_src =~ s/(\r\n|\r)/\n/g;
+        &parse_file_info($js_src);
+        $js_src = &preprocess_source($js_src);
+        &fetch_funcs_and_classes($js_src);
+    &map_all_properties();
+    &build_class_hierarchy();
+    &set_class_constructors();
+    &filter_globals;
+    while (my ($classname, $class) = each %CLASSES){
+        delete $class->{_class_properties};
+        delete $class->{_instance_properties};
+        $class->{classname} = $classname unless $classname eq '__FILES__';
+    return \%CLASSES;
+# Parses up a a jsdoc comment into its component parts
+# PARAM: The document string to be parsed
+sub parse_jsdoc_comment {
+    my ($doc, $raw) = @_;
+    # Remove excess '*' characters
+    $doc =~ s/^[*\s]*([^*].*?)[*\s]*$/$1/s;
+    $doc =~ s/^\s*\*//gm;
+    my %parsed = (); # remember each part that is parsed
+    # the first paragraph could be a summary statement
+    # a paragraph may follow of variable defs (variable names start with "@")
+    my ($summary, $variable_str) = $doc =~
+        /^\s*
+        \s*
+        $/xs;
+    $summary =~ s/^\s*(\S.*?)\s*$/$1/s;
+    $parsed{summary} = $summary;
+    # two types of variable def can be dealt with here:
+    # a @argument has a two-part value -- the arg name and a description
+    # all other @<variables> only have a single value each (although there may
+    # be many variables with the same name)
+    if($variable_str) {
+        my %vars = ();
+        while ($variable_str =~ /
+            (?<![\{\w])\@(\w+)      # The @attribute, but not a {@link}
+            \s*
+            ((?:\{\@|\w\@|[^\@])*)   # Everything up to the next @attribute
+            /gsx) {
+            my ($name, $val) = ($1, $2);
+            $vars{$name} = [] unless defined $vars{$name};
+            $val =~ s/\n/ /g unless $raw or $name eq 'class';
+            push(@{$vars{$name}}, ($val =~ /^\s*(.*)\s*$/s)[0]);
+        $parsed{vars} = \%vars;
+    return \%parsed;
+# Builds up the global FUNCTION and CLASSES hashes
+# with the names of functions and classes
+sub fetch_funcs_and_classes {
+    my $js_src = shift;
+    while ($js_src =~ m!
+        # Documentation
+            /\*\*                         # Opening of docs
+            \*/\s*\n\s*                   # Closing of docs
+        # Function
+        (?:(?:function\s+(\w+)\s*(\(.*?\))\s*\{)|
+        # Anonymous function
+        (?:(\w+(?:\.\w+)*?)(\.prototype)?\.(\w+)\s*=\s*function\s*
+                                                        (?:\w+\s*)?(\(.*?\)))|
+        # Instance property
+        (?:(\w+(?:\.\w+)*?)\.prototype\.(\$?\w+)\s*=\s*(.*?)\s*[;\n])|
+        #Inheritance
+        (?:(\w+(?:\.\w+)*?)\.prototype\s*=
+                           \s*new\s*(\w+(?:\.\w+)*?)(?:\(.*?\))?\s*[;\n])|
+        # Class property
+        (?:(\w+(?:\.\w+)*?)\.(\$?\w+)\s*=\s*(.*?)\s*[;\n]))
+    !gsx){
+        my ($doc, $fname1,  $arglist1, $cname1, $prototype, $fname2, $arglist2)
+            = ($1 || '', $2, $3, $4, $5, $6, $7);
+        my ($cname2, $propname1, $propval1) = ($8, $9, $10);
+        my ($cname3, $baseclass) = ($11, $12);
+        my ($cname4, $propname2, $propval2) = ($13, $14, $15);
+        next if $doc =~ /\@ignore\b/;
+        if ($fname1){
+            &add_function($doc, $fname1, $arglist1);
+            if ($doc =~ /\@(?:constructor|class|base)\b/){
+                # Add all @constructor and @class methods as classes
+                &add_class($fname1, $doc);
+        } elsif ($cname1 && $fname2 && $FUNCTIONS{$cname1}){
+            # Anonymous functions added onto a class or class prototype
+            &add_anonymous_function($doc, $cname1, $fname2,
+                $arglist2, not defined($prototype));
+        } elsif ($cname1 && $fname2 && not defined($FUNCTIONS{$cname1})){
+            if ($doc =~ /\@(addon|base|constructor)\b/
+                    || $prototype || $CLASSES{$cname1}){
+                # Called for methods added to the prototype of core classes
+        } elsif ($cname2 && $propname1 && defined($propval1)) {
+            &add_property($doc, $cname2, $propname1, $propval1, 0);
+        } elsif ($cname3 && $baseclass){
+            &set_base_class($cname3, $baseclass);
+        } elsif ($cname4 && $propname2 && defined($propval2)
+                    && $propname2 ne 'prototype'
+                    && $cname4 ne 'this'){
+            if ($FUNCTIONS{$cname4}
+                || $CLASSES{$cname4}
+                || $js_src =~ /function\s*\Q$cname4\E\b/){
+                    &add_property($doc, $cname4, $propname2, $propval2, 1);
+# Add a function that is given as Class.prototype.blah = function(){...}
+sub add_anonymous_function {
+    my ($doc, $class, $function_name, $arg_list, $is_class_prop) = @_;
+    # Just get out if the class is called 'this'. Reason for this is that
+    # binding methods to 'this' should already be converted to binding methods
+    # to the prototype, therefore binding to 'this' is only possible in
+    # member functions, and is therefore not considered static or consistent
+    # enough to be documented.
+    return unless $class ne 'this';
+    &add_class($class);
+    my $fake_name = "__$class.$function_name";
+    # This is dirty
+    my $is_private = $doc =~ /\@private\b/;
+    &add_function($doc, $fake_name, $arg_list, $is_private) and
+        &add_property($doc, $class, $function_name, $fake_name, $is_class_prop);
+    &add_class("$class.$function_name", $doc)
+        if $doc =~ /\@(?:constructor|class)\b/;
+# Add a class to the global CLASSES hash
+sub add_class {
+    my $class = shift;
+    warn "Can't add 'this' as a class, please file a bug report!"
+        if $class eq 'this';
+    my $class_doc = shift || '';
+    if (!$CLASSES{$class}){
+        $CLASSES{$class} = {};
+        $CLASSES{$class}->{$_} = [] for qw(instance_fields class_fields
+                                            instance_methods class_methods
+                                            inner_classes);
+    unless ($CLASSES{$class}->{extends}){
+        &set_base_class($class, $1)
+            if $class_doc =~ /\@base\s+(\w+(?:\.\w+)*)/;
+# Set the base class for a given class
+sub set_base_class {
+    my ($class, $base_class) = @_;
+    $CLASSES{$class}->{extends} = $base_class
+        unless $CLASSES{$class}->{extends};
+# Add a property, either a class or instance method or field
+sub add_property {
+    my ($doc, $class, $property, $value, $is_class_property) = @_;
+    return if $property eq 'constructor';
+    my $parsed_doc = &parse_jsdoc_comment($doc);
+    $doc = $parsed_doc->{summary};
+    my $key = $is_class_property ? '_class_properties' : '_instance_properties';
+    for my $classref (@{$CLASSES{$class}->{$key}}){
+        if ($classref->{property_name} eq $property){
+            # Whine about rebinding functions to classes
+            if ($FUNCTIONS{$value}){
+                warn "Already bound property '$property' to '$class'\n";
+                return;
+            # Only take on new attributes
+            $classref->{property_doc} ||= $doc;
+            $classref->{property_vars} ||= $parsed_doc->{vars};
+            return;
+    push @{$CLASSES{$class}->{$key}}, {
+        property_doc => $doc,
+        property_name => $property,
+        property_value => $value,
+        property_vars => $parsed_doc->{vars}
+# Add a function and its documentation to the global FUNCTION hash
+sub add_function {
+    my ($doc, $function, $arg_list, $is_private) = @_;
+    # clean remaining comments out of arg list
+    # (all others are already gone)
+    # Again, taken from Jeffrey Friedl's "Mastering Regular Expressions"
+        no warnings;
+        $arg_list =~ s/
+            ($NONQUOTE+|
+            $DQUOTE$NONQUOTE*|
+            $SQUOTE$NONQUOTE*)
+            |$MLINE_COMMENT|$SLINE_COMMENT/$1/gx;
+    if ($FUNCTIONS{$function}){
+        warn "Function '$function' already declared\n";
+        unless ($doc && !$FUNCTIONS{$function}->{documentation}->{summary}){
+            return 0;
+    $FUNCTIONS{$function} = {};
+    my $func = $FUNCTIONS{$function};
+    $arg_list and $func->{argument_list} = join(" ", split("\\s+", $arg_list))
+        or $func->{argument_list} = "()";
+    my $documentation = parse_jsdoc_comment($doc);
+    if ($documentation->{vars}->{member}){
+        my ($classname) = map { s/^\s*(\S*)\s*$/$1/; $_ }
+            @{$documentation->{vars}->{member}};
+        &add_property($doc, $classname, $function, $function, 0)
+            if $classname =~ /\w+/;
+    my $function_ref = $FUNCTIONS{$function};
+    $function_ref->{documentation} = $documentation;
+    $function_ref->{description} = $documentation->{summary};
+    $function_ref->{vars} = $function_ref->{documentation}->{vars};
+    $function_ref->{vars}->{filename} = $CTX_FILE;
+    $function_ref->{vars}->{private} = 1 if $is_private;
+    1;
+# Map all the class and instance properties to their implementation
+sub map_all_properties {
+    for my $type (qw(_class_properties _instance_properties)){
+        for my $class (keys %CLASSES){
+            &map_single_property(
+                $class,
+                $_->{property_name},
+                $_->{property_value},
+                $_->{property_doc},
+                $_->{property_vars}, $type eq '_class_properties')
+                    for @{$CLASSES{$class}->{$type}}
+    # Map all the unattached functions
+    my $classname = $CONFIG{GLOBALS_NAME} || 'GLOBALS';
+    &add_class($classname);
+    for my $function
+        (grep !($FUNCTIONS{$_}->{is_mapped} || $CLASSES{$_}), keys %FUNCTIONS){
+                $classname, $function, $function, '', undef, 1);
+    # Map static inner classes
+    for $classname (keys %CLASSES){
+        my $i = 0;
+        my @to_remove;
+        for my $cprop (@{$CLASSES{$classname}->{class_methods}}){
+            my $propname = $cprop->{mapped_name};
+            if ($CLASSES{"$classname.$propname"}){
+                push @to_remove, $i;
+                push @{$CLASSES{$classname}->{inner_classes}},
+                    {class_name => "$classname." . $cprop->{mapped_name}};
+                $FUNCTIONS{"$classname.$propname"} =
+                delete $FUNCTIONS{"__$classname.$propname"};
+            $i++;
+        splice(@{$CLASSES{$classname}->{class_methods}}, $_, 1)
+            for reverse @to_remove;
+# Map a single instance or class field or method
+sub map_single_property {
+    my ($class, $prop_name, $prop_val,
+    $description, $vars, $is_class_prop) = @_;
+    if (!$FUNCTIONS{$prop_val}){
+        push @{$CLASSES{$class}->{$is_class_prop
+                                    ? 'class_fields' : 'instance_fields'}}, {
+            field_name          => $prop_name,
+            field_description   => $description,
+            field_value         => $prop_val,
+            field_vars          => $vars };
+            return;
+    my %method;
+    my $function = $FUNCTIONS{$prop_val};
+    $function->{is_mapped} = 1;
+    $method{mapped_name} = $prop_name;
+    $method{$_} = $function->{$_} for
+        qw/ argument_list description vars /;
+                            ? 'class_methods'
+                            : 'instance_methods'}}, \%method;
+# Build up the full hierarchy of classes, including figuring out
+# what methods are overridden by subclasses, etc
+# PARAM: The JS source code
+sub build_class_hierarchy {
+    # Find out what is inherited
+    for my $class (map($CLASSES{$_}, sort keys %CLASSES)){
+        my $superclassname = $class->{extends};
+        !$superclassname and next;
+        my $superclass = $CLASSES{$superclassname};
+        $class->{inherits} = {};
+        while ($superclass){
+            $class->{inherits}->{$superclassname} = {};
+            my @instance_fields;
+            my @instance_methods;
+            &handle_instance_methods($superclass, $superclassname,
+                                        $class, \@instance_methods);
+            &handle_instance_fields($superclass, $superclassname,
+                                    $class, \@instance_fields);
+            $superclassname = $superclass->{extends};
+            $superclass = $superclassname ? $CLASSES{$superclassname} : undef;
+# This is just a helper function for build_class_hierarchy
+# because that function was getting way oversized
+sub handle_instance_methods {
+    my ($superclass, $superclassname, $class, $instance_methods) = @_;
+    if ($superclass->{instance_methods}){
+        INSTANCE_METHODS:
+        for my $base_method (@{$superclass->{instance_methods}}){
+            for my $method (@{$class->{instance_methods}}){
+                if ($$base_method{mapped_name} eq $$method{mapped_name}){
+                    # Carry over the description for overridden methods with
+                    # no description (to be javadoc compliant)
+                    if (($base_method->{description} or $base_method->{vars})
+                            and not $method->{description}){
+                        $method->{description} = $base_method->{description};
+                        for my $varkey (keys(%{$base_method->{vars}})){
+                            $method->{vars}->{$varkey}
+                                = $base_method->{vars}->{$varkey}
+                                    unless $method->{vars}->{$varkey};
+                    next INSTANCE_METHODS;
+            for (keys %{$class->{inherits}}){
+                my $inherited = $class->{inherits}->{$_};
+                for my $method (@{$inherited->{instance_methods}}){
+                        if $$base_method{mapped_name} eq $method;
+            push @$instance_methods, $$base_method{mapped_name};
+        $class->{inherits}->{$superclassname}->{instance_methods}
+            = $instance_methods;
+sub handle_instance_fields {
+    my ($superclass, $superclassname, $class, $instance_fields) = @_;
+    if ($superclass->{instance_fields}){
+        INSTANCE_FIELDS:
+        for my $base_field  (@{$superclass->{instance_fields}}){
+            for my $field (@{$class->{instance_fields}}){
+                next INSTANCE_FIELDS if $field eq $base_field;
+            push @$instance_fields, $base_field->{field_name};
+        $class->{inherits}->{$superclassname}->{instance_fields}
+            = $instance_fields;
+# Set all the class constructors
+sub set_class_constructors {
+    for my $classname (keys %CLASSES){
+        my $constructor = $FUNCTIONS{$classname};
+        $CLASSES{$classname}->{constructor_args} =
+        $constructor->{argument_list};
+        $CLASSES{$classname}->{constructor_detail}
+            = $constructor->{description};
+        $CLASSES{$classname}->{constructor_vars} = $constructor->{vars} || {};
+# Clear out everything from the parsed classes and functions
+sub reset_parser {
+    %CLASSES = ();
+    %FUNCTIONS = ();
+# Set global parameters for the parser
+sub configure_parser {
+    %CONFIG = @_;
+# Set the initial defaults for the parser
+sub initialize_parser {
+    $CONFIG{GLOBALS_NAME} ||= 'GLOBALS';
+# Run through the source and convert 'confusing' JavaScript constructs
+# into ones that are understood by the parser, as well as stripping
+# out unwanted comment blocks.
+# For example:
+#  Foo.prototype = {
+#     bar: function(){ return "Eep!"; },
+#     baz: "Ha!"
+#  becomes
+#  Foo.prototype.bar = function(){ return "Eep!"; };
+#  Foo.prototype.baz = "Ha!";
+sub preprocess_source {
+    my ($src) = @_;
+    # Make all the @extends tags into @base tags
+    $src =~ s/\@extends\b/\@base/g;
+    # This had better not break anything!
+    $src = &deconstruct_getset($src);
+    # Convert:
+    #     /** @singleton */
+    #     Foo = {...};
+    # to:
+    #     Foo = function(){}
+    #     Foo.prototype = {...};
+    $src =~ s!
+        ($JSDOC_COMMENT\s*)
+        (?:var\s*)?(\w+(?:\.\w+)*?)
+        \s*=\s*{
+        !index($1, '@singleton') == -1 ? "$1$2 = {" : "$1$2 = function(){}\n$2.prototype = {"!egx;
+    # Convert:
+    #     /** @constructor */
+    #     Foo.Bar = function(){...}
+    # to:
+    #     /** @constroctor */
+    #     Foo.Bar = function(){}
+    #     function Foo.Bar(){...}
+    # Note that we have to keep the original declaration so that Foo.Bar
+    # can be recognized as a nested class. Yes, I know it's bad...
+    $src =~ s!
+        \s*=
+        (\s*function)(?=\s*($BAL_PAREN)\s*\{)
+        !index($1, '@constructor') == -1 ? "$1$2 = $3" : "$1$2 = function$4 {};\n$1$3 $2"!egx;
+    # remove all uninteresting comments, but only if they're not inside
+    # of other comments
+    # (adapted from Jeffrey Friedl's "Mastering Regular Expressions"
+       no warnings;
+       $src =~ s/
+          ($NONQUOTE+|
+             $JSDOC_COMMENT$NONQUOTE*|
+        1 while $src =~ s/$JSDOC_COMMENT\s*($JSDOC_COMMENT)/$1/g;
+    # Alter the prototype-initialization blocks
+    $src =~ s/
+       (\w+(?:\.\w+)*)\.prototype
+       \s*=\s*($BAL_BRACE)/deconstruct_prototype($1, $2)/egx;
+    # Mark all constructors based on 'new' statements
+    my %seen;
+    my @classnames =  grep { not $seen{$_}++ }
+        $src =~ /\bnew\s+(\w+(?:\.\w+)*)\s*\(/g;
+    for my $cname (@classnames){
+        $src =~ s/($JSDOC_COMMENT?)
+                    (?=\s*function\s+\Q$cname\E\s*$BAL_PAREN
+                    \s*$BAL_BRACE)
+                /&annotate_comment($1, '@constructor')/ex;
+    $src =~ s/
+       ($JSDOC_COMMENT?)\s*
+       (function\s+\w+(?:\.\w+)*\s*$BAL_PAREN\s*)
+       ($BAL_BRACE)
+       /&deconstruct_constructor($1, "$2$3")/egx;
+    $src =~ s!
+       (?:var\s+)?(\w+(?:\.\w+)*)
+       \s*=\s*
+       new\s+
+       ($ANON_FUNCTION)!&deconstruct_singleton($1, $2)!egx;
+    $src = &remove_dynamic_bindings($src);
+    # Mark all void methods with "@type void"
+    $src =~ s/($JSDOC_COMMENT?)\s*
+          (?:function\s+\w+(?:\.\w+)*\s*$BAL_PAREN\s*)
+          (?:\w+(?:\.\w+)*\s*=\s*function\s*(?:\w+\s*)?$BAL_PAREN\s*)
+       )$BAL_BRACE)
+       /&mark_void_method($1, $2)/egx;
+    # Clear nested functions (will save trouble later on)
+       (\w+(?:\.\w+)*\s*=\s*)?
+       (function(?:\s+\w+(?:\.\w+)*)?\s*$BAL_PAREN\s*)
+       ($BAL_BRACE)
+       /&clear_nested($1, $2, $3, $4)/egx;
+    return $src;
+sub clear_nested {
+    my ($doc, $assign_to, $declaration, $funcbody) = @_;
+    $assign_to ||= '';
+    if ($doc =~ /^(?=.*\@constructor|\@class)(?=.*\@exec)/){
+        warn "\@constructor or \@class can't be used together with \@exec\n";
+    if ($doc !~ /\@(constructor|class|exec)/
+            or $assign_to =~ /^\w+\.prototype\./) {
+        return "$doc\n$assign_to$declaration" . "{}\n";
+    } elsif ($doc =~ /\@(constructor|class)/) {
+        return "$doc\n$assign_to$declaration$funcbody";
+    } else {
+        my @visible_funcs = $funcbody =~ /
+                    ((?:$JSDOC_COMMENT)?
+                    (?:\w+\.\w+(?:\.\w+)*)\s*=\s*
+                        $FUNC_DEF
+                        $ANON_FUNCTION
+                        $FUNC_CALL
+                        \w+
+                    )\s*;)/gx;
+        return join("\n", @visible_funcs);
+# Remove dynamic binding.
+# Change this:
+#   function MyFunc(class){
+#       var x = 2;
+#       class.prototype.func = function(){};
+#       return x;
+# to:
+#       var x = 2;
+#       return x;
+# and change this:
+#   function BindMethod(obj){
+#       obj.someFunc = function(){ return null; };
+#       return obj;
+# to:
+#       return obj;
+sub remove_dynamic_bindings {
+    my ($src) = @_;
+    while ($src =~ /$RET_FUNC_DEF/g){
+        my ($fname, $params, $definition) = ($1, $2, $3);
+        next unless $definition =~ /\bfunction\b|\w+\.prototype\./;
+        my @params = split(/\s*,\s*/, substr($params, 1, length($params) - 2));
+        for my $param (@params){
+            $src =~ s/\b$param\.prototype\.[^;\n]*[;\n]//g;
+            $src =~ s/\b$param\.\w+ = $ANON_FUNCTION//g;
+    $src;
+# Annotate a method as being void if no @type can be found, and there is no
+# statement to return a value in the method itself.
+sub mark_void_method {
+    my ($doc, $funcdef) = @_;
+    return "$doc\n$funcdef" if $doc =~ /\@(constructor|type|returns?)\b/;
+    my ($fbody) = $funcdef =~ /^[^{]*($BAL_BRACE)/;
+    $fbody =~ s/$FUNC_DEF/function x(){}/g;
+    $fbody =~ s/$ANON_FUNCTION/function (){}/g;
+    $doc = &annotate_comment($doc, '@type void')
+        if $fbody !~ /\breturn\s+(?:(?:\w+)|(?:(["']).*?\1)|$BAL_PAREN)/;
+    "$doc\n$funcdef";
+# A helper to change singleton declarations like
+#     MySingleton = new function(){this.x=function(){}}
+# into:
+#     function MySingleton(){}
+#     MySingleton.prototype.x = function(){};
+sub deconstruct_singleton {
+    my ($classname, $definition) = @_;
+    $definition =~ s/function\s*$BAL_PAREN\s*\{(.*)\}\s*$/$1/s;
+    $definition =~ s/\bthis\./$classname.prototype\./g;
+    qq#
+        function $classname(){}
+        $definition;
+# A helper to preprocess_source, change prototype-initialization
+# blocks into multiple prototype-property assignments
+sub deconstruct_prototype {
+    my ($class, $src) = @_;
+    $src =~ s/^\{(.*)\}$/$1/s;
+    $src =~ s!
+        (\w+)
+        \s*:\s*
+        $ANON_FUNCTION
+        $FUNC_DEF
+        $FUNC_CALL
+        $LITERAL
+        $BAL_SQUAR
+        $BAL_BRACE
+        [-\w.+]+
+        \s*,?
+    !$class.prototype.$1 = $2;!gsx;
+    $src;
+# Unpacks a constructor into separate calls
+sub deconstruct_constructor {
+    my ($doc, $func_def) = @_;
+    return "$doc$func_def" unless $doc =~ /\@(constructor|class)/;
+    my ($classname) = $func_def =~ /function\s+(\w+(?:\.\w+)*)/;
+    $func_def =~ s/
+        /&deconstruct_inner_constructor($classname, $1)/esx;
+    "$doc$func_def";
+sub deconstruct_inner_constructor {
+    my ($classname, $inner_src) = @_;
+    $inner_src = substr($inner_src, 1, -1);
+    my @doc_n_fnames = $inner_src =~ /($JSDOC_COMMENT?)\s*function\s+(\w+)/g;
+    unless ($CONFIG{NO_LEXICAL_PRIVATES}){
+        $inner_src =~ s/
+            ($JSDOC_COMMENT)?
+            \s*
+            var
+            \s+
+            (\w+)/&annotate_comment($1) . "\n$classname\.prototype\.$2"/egx;
+        $inner_src =~ s/
+            ($JSDOC_COMMENT)?\s*
+            ^\s*
+            function
+            \s+
+            (\w+)
+            /&annotate_comment($1) .
+                "\n$classname\.prototype\.$2 = function"/egmx;
+        no warnings;
+        $inner_src =~ s/
+            ($JSDOC_COMMENT\s*)?
+            ^\s*this(?=\.)
+            /$1$classname.prototype/gmx;
+    # Replace all bindings of private methods to public names
+    for (my $i = 0; $i < @doc_n_fnames; $i += 2)
+        my ($doc, $fname) = @doc_n_fnames[$i, $i + 1];
+        $inner_src =~ s/
+            $classname\.prototype\.\w+)
+            \s*=\s*
+            $fname\s*[\n;]
+            /$1 = function(){}/gx;
+        $inner_src =~ s/
+            ($classname\.prototype\.\w+)
+            \s*=\s*
+            $fname\s*[\n;]
+            /$doc\n$1 = function(){}/gx;
+    "{}\n$inner_src";
+# Deconstruct mozilla's __defineGetter__ and __defineSetter__
+# (Yes, I know this goes against my principles...)
+sub deconstruct_getset {
+    my ($src) = @_;
+    # Crack open the assignments for define(Getter|Setter)
+    my $crack = sub {
+        my $code = shift; $code =~ s/^.(.*).$/$1/s;
+        my ($name) = split ",", $code;
+        $name = ($name =~ /.*?(['"])([^'"]+)\1/)[1];
+        $name;
+    for my $prefix ('get', 'set'){
+        my $fname = "define\u${prefix}ter";
+        $src =~ s/
+            (\w+(?:\.\w+)*
+            \.prototype)
+            \.__${fname}__\s*($BAL_PAREN)/
+            my $name = $crack->($2);
+            "$1.$name = null"/gex;
+    $src;
+# Add an annotation (@tag) to a documentation block. The block is assumed to
+# be a valid JSDoc documentation block ==> /^\/\*\*.*\*\/$/
+# and no checking is done to verify this
+sub annotate_comment {
+    my $annotation = $_[1] || '@private';
+    return "\n/** $annotation */" unless $_[0];
+    substr($_[0], 0, -2) . " \n$annotation \n*/";
+# This is here to stop perl from segfaulting from deep recursion in regexes
+# The first character in the text _should_ be open_token, as everything
+# before open_token will be discarded, unless there is no matching text
+# at all.
+sub find_balanced_block {
+    my ($open_token, $close_token, $text) = @_;
+    my ($count, $open, $close) = (0, 0, 0);
+    return ('', $text) unless $text =~ /\Q$open_token\E/;
+    $text =~ s/^.*?(?=\Q$open_token\E)//s;
+    for (split //, $text){
+       $count++;
+       $open++ if $_ eq $open_token;
+       $close++ if $_ eq $close_token;
+       last unless ($open != $close);
+    warn "Unbalanced block\n" if ($open != $close);
+    (substr($text, 0, $count), substr($text, $count));
+# Remove the $CONFIG{GLOBALS_NAME} class if it doesn't contain anything
+sub filter_globals {
+    my $global = $CLASSES{$CONFIG{GLOBALS_NAME}};
+    delete $CLASSES{$CONFIG{GLOBALS_NAME}} if
+        not (defined $global->{constructor_args} ||
+                defined $global->{constructor_detail})
+            && not (@{$global->{instance_methods}} ||
+            @{$global->{instance_fields}} ||
+            @{$global->{class_methods}} ||
+            @{$global->{class_fields}});
+    # Also get rid of extra info under the '__files__' key
+    delete $CLASSES{__FILES__}->{$_} for qw(constructor_params constructor_args
+                                          constructor_detail class_methods
+                                          constructor_vars);
+# Try to grab the first block comment from the file that has a @fileoverview
+# tag in it, and get the file info from there
+sub parse_file_info {
+    my ($src) = @_;
+    my %fileinfo = ( src => $src );
+    while ($src =~ /($JSDOC_COMMENT)/g){
+       local $_ = substr($1, 3, length($1) - 5); # Get the actual content
+       if (/\@fileoverview\b/){
+          my $doc = parse_jsdoc_comment($_, 1);
+          %fileinfo = (%{$doc->{vars}}, %fileinfo);
+          last;
+    $CLASSES{__FILES__}->{$CTX_FILE} = \%fileinfo if $CTX_FILE;
+1;
Added: trunk/build/JSDoc/JavaScript/Syntax/HTML.pm
--- trunk/build/JSDoc/JavaScript/Syntax/HTML.pm	                        (rev 0)
+++ trunk/build/JSDoc/JavaScript/Syntax/HTML.pm	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,95 @@
+package JavaScript::Syntax::HTML;
+=head1 NAME
+JavaScript::Syntax::HTML - Convert JavaScript sourcecode to HTML
+=head1 SYNOPSIS
+    use JavaScript::Syntax::HTML qw(to_html to_html_document);
+    my $html_fragment = to_html($js_src);
+    my $html_doc = output_html_document($js_src);
+=head1 DESCRIPTION
+JavaScript::Syntax::HTML processes JavaScript code and outputs HTML with
+all reserved words marked up.
+The to_html method only outputs an HTML fragment (no <body> or <html> tags),
+and only marks up the reserved words with CSS styles.
+The to_html_document method outputs a full HTML document, and does include
+style information for the reserved words markup.
+The style classes that can be defined for use with to_html are C<comment>,
+C<literal>, and C<reserved>.
+=head1 AUTHOR
+=cut
+use warnings;
+use strict;
+use Exporter;
+our @ISA = qw(Exporter);
+our @EXPORT_OK = qw(to_html to_html_document);
+sub to_html {
+    local $_ = shift;
+    s/\&/&amp;/g;
+    s/</&lt;/g;
+    s/>/&gt;/g;
+    s/
+        (?:\/\/[^\n]*$))
+        \b(function|for|if|while|return|else|prototype|this)\b
+        / get_substitution($1, $2, $3) /egsxm;
+    $_;
+sub get_substitution {
+    my ($comment, $stringliteral, $resword) = @_;
+    my $content;
+    if ($comment){
+        $comment =~ s/(\@\w+)\b/get_span('attrib', $1)/eg;
+        return get_span('comment', $comment);
+    } elsif ($stringliteral){
+        return get_span('literal', $stringliteral);
+    } elsif ($resword){
+        return get_span('reserved', $resword);
+sub get_span {
+    my ($class, $inner) = @_;
+    qq(<span class="$class">$inner</span>);
+sub to_html_document {
+    my ($src) = @_;
+    $src = &to_html($src);
+    qq(
+<html>
+    <head>
+	<style>
+            body { background: #FFFFFF }
+	    .reserved { color: #DD3333 }
+            .comment { color: #339933 }
+            .attrib { color: #FF0000 }
+            .literal { color: #5555FF }
+	</style>
+    </head>
+    <body>
+	<pre>
+$src
+	</pre>
+    </body>
+</html>);
Added: trunk/build/JSDoc/README
--- trunk/build/JSDoc/README	                        (rev 0)
+++ trunk/build/JSDoc/README	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,30 @@
+README for jsdoc.pl
+jsdoc.pl is a script that produces javadoc-style documentation from well-formed
+JavaScript sourcefiles. At the moment, this means it supports sourcefiles where
+all functions are mapped to a class using prototype-based inheritance.
+Anonymous function definitions
+(e.g. Circle.prototype.getRadius = function(){ ...} ) are supported.
+This application requires Perl5, as well as one non-standard addon module:
+    - HTML::Template, which is available from CPAN (cpan.org)
+Invocation is simple: Just run the application, giving one or more well-formed
+OO JavaScript sourcefilename(s) as arguments. A sample JS sourcefile, test.js,
+is given along with this application. An example of running the application is
+shown below:
+    $ ./jsdoc.pl test.js
+OR
+    perl jsdoc.pl test.js
+Further information about using JsDoc can be found at
+http://jsdoc.sourceforge.net
+If there are any questions, comments, problems or anything else, please mail
+the jsdoc-user mailing list; more information can be found at
+http://sourceforge.net/mail/?group_id=30801. This application has been
+successfully tested on Linux (Debian and Redhat), and Windows 2000 with
+ActivePerl.
Added: trunk/build/JSDoc/TODO
--- trunk/build/JSDoc/TODO	                        (rev 0)
+++ trunk/build/JSDoc/TODO	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,46 @@
+TODO for JSDoc
+- XML / XMI export
+- Improve the --package-naming option so that there are separate namespaces
+  for each package (so that you can have the same class name defined in
+  different packages)
+- Fix some spacing/table issues in the navbar in the templates (use a td
+  border in the stylesheet to debug)
+- Introduce a more generalized system for generating the navbar
+- Handle additional information (such as @see) for fields
+- Uncallable methods/functions should be marked as private, or show the scope
+  from which they can be called
+- Dynamic handling of assignment of prototype to a temp variable (preprocessor)
+- Add support for interfaces, but first this has to be better defined
+- Top-level var documenting (maybe add a '@global' tag to force toplevel vars
+  to be documented
+- Add an FAQ, more and better documentation
+- Java port (someday...)
+- Make a more polished API for using other doclets, like javadoc
+- Add a deprecated page, make deprecated support more like javadoc
+- Add support for js files without .js extension
+- Support for a time stamp
+- Some of the ->{vars} are set to undef, should always be an empty map
+- Add command line params --dump-tree, --dump-xml
+- Add command line param --stylesheet
+- Make navbar links selective so they are never broken
+- Update the help doc
Added: trunk/build/JSDoc/TestJSDoc.pl
--- trunk/build/JSDoc/TestJSDoc.pl	                        (rev 0)
+++ trunk/build/JSDoc/TestJSDoc.pl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,696 @@
+#!/usr/bin/perl
+package JSDoc;
+# Unit testing of JSDoc
+# Run with 'perl TestJSDoc.pl' or './TestJSDoc.pl'
+use strict;
+use warnings;
+use JSDoc;
+use Data::Dumper;
+use Test::More qw(no_plan);
+# parse_jsdoc_comment
+diag("Testing parse_jsdoc_comment");
+is_deeply(parse_jsdoc_comment(''), {summary => ''},
+    "Ensure only summary is filled in");
+is(parse_jsdoc_comment('')->{summary}, '', 'Empty comment value');
+        '************************* test *************')->{summary},
+    'test', 'long leading and trailing stars');
+# annotate_comment
+diag("Testing annotate_comment");
+is(annotate_comment, "\n/** \@private */", 'annotate_comment w/o arg');
+like(annotate_comment("/** This is a test */"),
+        qr#^/\s*\*\*\s*This is a test\s+\@private\s*\*/\s*$#,
+        'annotate_comment w/ arg');
+like(annotate_comment("/** This is a test */", '@testtag value'),
+        qr#^/\s*\*\*\s*This is a test\s+\@testtag\svalue\s*\*/\s*$#,
+        'annotate_comment w/ tag argument');
+# find_balanced_block
+diag("Testing find_balanced_block");
+my @blocks = (
+        # basic simple input
+        ['{', '}', '{ this is in the braces } {this is after}{{',
+            ['{ this is in the braces }', ' {this is after}{{'] ,
+            'basic input'],
+        # discard leading chars before opening char
+        ['{', '}', 'discard {inner} after',
+            ['{inner}', ' after'], 'discard leading chars'],
+        # empty input string
+            ['', ''], 'empty input string'],
+        # nothing to match at all
+        ['{', '}', 'there is nothing to match',
+            ['', 'there is nothing to match'], 'nothing to match'],
+for my $test (@blocks){
+    my @args = @{$test}[0..2];
+    my ($expect, $explain) = @{$test}[3,4];
+    is_deeply([find_balanced_block(@args)], $expect, $explain);
+# Test the @member tag
+diag('Testing the @member tag');
+reset_parser();
+my $src = q#
+/** @constructor */
+function Foo(){
+    this.x = function(){return null;};
+/** Unrelated */
+function myfunc(){return null;}
+my $classes = parse_code_tree(\$src);
+my %method_names = map { $_->{mapped_name} => 1 }
+            @{$classes->{Foo}->{instance_methods}};
+ok(not(defined($method_names{myfunc})),
+    'Unrelated method is not added to class without @member tag');
+reset_parser();
+$src = q#
+function Foo(){
+ * @member Foo
+$classes = parse_code_tree(\$src);
+%method_names = map { $_->{mapped_name} => 1 }
+ok(defined($method_names{myfunc}),
+    'Add method marked with @member to class');
+reset_parser();
+# preprocess_source
+diag("Testing preprocess_source");
+# Make sure that:
+#     baz: "Ha!"
+#  becomes:
+my $before = q/
+  Foo.prototype = {
+     bar: function(){ return "Eep!"; },
+     baz: "Ha!"
+my $after_re = qr/^\s*(?:$JSDOC_COMMENT)?\s*Foo.prototype.bar
+                            \s*=\s*
+                            function\(\s*\)\s*\{[^\}]*}\s*;\s*
+                            Foo\.prototype\.baz\s*=\s*"[^"]+"\s*;\s*$/x;
+like(preprocess_source($before), $after_re,
+    'Unpack prototype block assignment');
+# Make sure that:
+#     /** @constructor */
+#     Foo.Bar = function(){this.x = 2;var y = 3;}
+# becomes:
+#     Foo.Bar = function(){};
+#     function Foo.Bar(){}
+#     Foo.Bar.prototype.x = 2;
+#     /** @private */
+#     Foo.Bar.prototype.y = 3;
+$before = q#
+     /** @constructor */
+     Foo.Bar = function(){this.x = 2; var y = 3; }#;
+$after_re = qr{
+     ^\s*/\*\*\s*\@constructor\s*\*/\s*
+     Foo\.Bar\s*=\s*function\s*\(\s*\)\s*\{\s*\}\s*;\s*
+     /\*\*\s*\@constructor\s*\*/\s*
+     function\s+Foo\.Bar\s*\(\s*\)\s*\{\s*\}
+     \s*
+     Foo\.Bar\.prototype\.x\s*=\s*2\s*;\s*
+     /\*\*\s*\@private\s*\*/\s*
+     Foo\.Bar\.prototype\.y\s*=\s*3\s*;\s*$
+    }x;
+        'Unpack nested class');
+# Make sure that:
+#   and
+#       var MySingleton = new function(){this.x=function(){}}
+# become:
+$before = q# MySingleton = new function(){this.x=function(){}} #;
+$after_re =  qr{
+        ^\s*(?:$JSDOC_COMMENT)?
+        \s*function\s*MySingleton\s*\(\)\s*\{\s*\}\s*
+        (?:$JSDOC_COMMENT)?\s*
+        MySingleton\.prototype\.x\s*=\s*function\s*\(\s*\)\s*\{\s*\}\s*;\s*$}x;
+        'Unpack singleton');
+# Same thing, but with var before the declaration
+$before = q#var MySingleton = new function(){this.x=function(){}} #;
+        "Unpack var'd singleton");
+# Test unpacking a constructor into a bunch of
+# prototype-based declarations
+$before = q#
+     * @constructor
+    function MyClass(){
+        /** Private variable 'x' */
+        var x = 3;
+         * This is my function
+        this.myFunction = function(){ return null; };
+         * This is a private function
+        function myPrivateFunction(x){
+            return null;
+$after_re = qr{
+    /\*\*\s*
+     \*\s*\@constructor\s*
+     \*/\s*
+    function\s+MyClass\s*\(\s*\)\s*\{\s*\}\s*
+    /\*\*\s*Private\svariable\s'x'\s*
+    \@private\s*\*/\s*
+    MyClass\.prototype\.x\s*=\s*3\s*;\s*
+    /\*\*\s*
+    \*\s*This\sis\smy\sfunction\s*\*/\s*
+    MyClass\.prototype\.myFunction\s*=\s*function\s*\(\s*\)\s*\{
+        [^\}]*\}\s*;\s*
+    /\*\*\s*
+     \*\s*This\sis\sa\sprivate\sfunction\s*
+    MyClass\.prototype\.myPrivateFunction\s*=\s*function\(\s*x\s*\)\s*
+    \{[^\}]*\}\s*$
+}x;
+    'Testing unpacking a constructor into prototype-based assignments');
+# Test the marking of void methods
+$before = q'function MyFunc(){}';
+$after_re = qr{/\*\*\s*\@type\s+void\s*\*/\s*function\s+MyFunc\s*\(\)\{\}};
+   "Testing basic marking of void method without a docstring");
+$before = q'
+/** Method */
+function MyFunc(){}
+$after_re = qr{/\*\*\s*Method\s+\@type\s+void\s*\*/\s*
+                function\s+MyFunc\(\)\{\}}x;
+    "Testing basic marking of void methods");
+$before = '/** Method */
+            Shape.prototype.MyFunc = function(){}';
+$after_re = qr{
+    /\*\*\s*
+        Method\s+
+        \@type\s+void\s*
+    \*/\s*Shape\.prototype\.MyFunc\s*=\s*function\(\)\{\}}x;
+    "Testing marking of void anonymous method");
+$before = 'Shape.prototype.MyFunc = function(){return null;}';
+$after_re = qr{^\s*Shape\.prototype\.MyFunc\s*=
+                \s*function\(\)\{[^\}]*\}}x;
+$before = "function x(){return null;}";
+$after_re = qr{\s*function\sx\(\)\s*\{[^\}]*\}\s*$};
+    "Leave non-void methods without docstrings alone");
+$before = "/** My test function */\nfunction x(){return null;}";
+$after_re = qr{\s*/\*\*\s*My\stest\sfunction\s*\*/\s*
+                function\sx\(\)\s*\{[^\}]*\}\s*$}x;
+    "Leave non-void methods with docstrings alone");
+reset_parser();
+$src = q#
+ * @constructor
+function MyClass(){
+    this.af = afunc;
+    this.bf = bfunc;
+    this.cf = cfunc;
+    function afunc(){}
+    function bfunc(){}
+    function cfunc(){}
+ok(eq_set(
+        [ map { $_->{mapped_name} }
+            @{$classes->{MyClass}->{instance_methods}}],
+        ['af', 'bf', 'cf', 'afunc', 'bfunc', 'cfunc']),
+    "Ensure instance methods in constructor are correctly assigned");
+reset_parser();
+$src = 'function MyFunction(){ return ""; }';
+ok(!defined($classes->{GLOBALS}->{class_methods}->[0]->{vars}->{type}),
+    "Ensure a function returning an empty string is not marked as void");
+reset_parser();
+$src = 'function A(){ var x = "x"; }';
+ok($classes->{GLOBALS}->{class_methods}->[0]->{vars}->{type}->[0] eq 'void',
+    "Ensure a global void is void");
+reset_parser();
+$src = 'function A(c){ c.someFunc = function(){ return 2; }; }';
+    "Ensure inner function definitions don't affect the return type");
+reset_parser();
+$src = 'function A(c){ c.someFunc = function(){ return 2; }; return ""; }';
+ok(!defined($classes->{GLOBALS}->{class_methods}->[0]->{vars}->{type}->[0]),
+    "Ensure inner-function measures don't affect non-void functions");
+reset_parser();
+$src = '/** @return {int} Description */function f(){}';
+    'Methods with a @return tag but no return statement are not marked void');
+reset_parser();
+$src = 'function f(){ return (true ? "t" : "f");}';
+    "Non-void with non-trivial return statement is not marked as void");
+# Try huge constructor input
+my @testsrc = (q#
+ * @class This is class information
+ * @constructor
+for (1..30){
+    push @testsrc, "
+    /** This is a private method */
+    function f$_(){ return null; }
+     * THis is function number $_
+     * \@return Nothing
+    this.func$_ = function(){if(true){if(false){return null;}}} ;\n";
+push @testsrc, "\n}\n";
+my $testsrc = join("\n", @testsrc);
+# This could crash everything
+preprocess_source($testsrc);
+pass("Process huge constructor with preprocess_source");
+# Huge constructor with unbalanced input
+ at testsrc = (q#
+ * @constructor
+for (1..100){
+    push @testsrc, "
+    this.func$_ = function(){if(true){if(false){return null;}};\n";
+$testsrc = join("\n", @testsrc);
+pass("Process huge unbalanced constructor with preprocess_source");
+# deconstruct_mozilla_getset
+$before = 'MyClass.prototype.__defineGetter__("myProp", function(){return null;});';
+$after_re = qr{
+   ^\s*MyClass\.prototype\.myProp\s*=\s*null\s*;\s*$}x;
+   #\s*function\s*\(\s*\)\s*\{\s*return\s+null\s*;\s*\}\s*;\s*$}x;
+like(deconstruct_getset($before), $after_re,
+   "Testing behaviour of __defineGetter__");
+   "Testing behaviour of __defineGetter__ in preprocess_source");
+$before = 'MyClass.prototype.__defineSetter__("myProp", function(){return null;});';
+$after_re = qr{
+   "Testing behaviour of __defineSetter__");
+   "Testing behaviour of __defineSetter__ in preprocess_source");
+reset_parser();
+$src = "
+    function MyFunc(theclass){
+        var x = 2;
+        theclass.prototype.f = function(){};
+        return x;
+    MyClass.prototype.f = function(){};
+ok(not(defined($classes->{theclass})),
+    "Ensure that dynamic prototyping doesn't add classes");
+ok(defined($classes->{MyClass}),
+    "Ensure that normal classes are added with static prototyping");
+# Test @singleton handling
+reset_parser();
+$src = q#
+    /** @singleton */
+    var SingletonClass = {
+        funcA: function(){},
+        funcB: function(){} };
+ok(defined($classes->{SingletonClass}));
+my @fnames = sort map { $_->{mapped_name}}
+    @{$classes->{SingletonClass}->{instance_methods}};
+is(scalar(@fnames), 2);
+ok(eq_array(\@fnames, ["funcA", "funcB"]));
+# miscellaneous tests
+diag("Miscellaneous tests");
+reset_parser();
+$src = "
+    /** \@constructor */
+    function A(){}
+    function C(){}
+    /** \@constructor
+    \@extends A
+    function B(){}
+    B.prototype = new C();";
+is($classes->{B}->{extends}, 'A',
+    "Test that the first extends marking is the good one, others are ignored");
+reset_parser();
+$src = "function A(){ this.n = function(){return 2};}
+        var a = new A(); ";
+ok(defined($classes->{A}),
+    "Functions are later used with 'new' must be treated as a constructor");
+ok(!defined($classes->{this}), "'this' cannot be added as a class");
+# Ensure using the @base tag automatically qualifies a function as a class,
+# even if the base class isn't defined
+reset_parser();
+$src = '/** @base SomeOtherClass */
+function MyClass(){}';
+    'A function must be upgraded to a class if the @base tag is used');
+# Allow an anonymous function to be assigned to a global variable,
+# resulting in a new class
+reset_parser();
+$src = '
+ * Some function
+ * @constructor
+var SomeClass = function(){ this.x = 2; }
+ok(defined($classes->{SomeClass}),
+    "Allow anonymous function to be assigned to a global variable");
+# Make sure that dynamically binding methods to a object at a later time
+# do not affect the documentation
+reset_parser();
+$src = '
+function AddCallback(obj){
+    obj.callback = function(){ return null; };
+ok(!defined($classes->{obj}),
+    "Don't add passed-in objects as classes when doing dynamic binding");
+reset_parser();
+$src = '
+function A(){}
+A.prototype.setup = A_Setup;
+A.prototype.tearDown = A_TearDown;
+function A_Setup(){
+    this.callback = function(){ return null; };
+function A_TearDown(){
+    this.tornDown = true;
+    "Don't add 'this' as a class when dynamically adding methods in a method");
+# Test block prototype assignment
+diag("Test block prototype assignment");
+reset_parser();
+$src = '
+SomeClass.prototype = {
+    funcA: function(){ return null; },
+    valA: 3,
+    funcB: function(){ return null; },
+    valB: "just testing",
+    funcC: function(){}
+ok(eq_set(
+            @{$classes->{SomeClass}->{instance_methods}}],
+        ['funcA', 'funcB', 'funcC']),
+    "Ensure instance methods are assigned in prototype definition block");
+ok(eq_set(
+        [ map { $_->{field_name} }
+            @{$classes->{SomeClass}->{instance_fields}}],
+        ['valA', 'valB']),
+    "Ensure instance fields are assigned in prototype definition block");
+# Test prototype assignment
+diag("Test prototype assignment");
+reset_parser();
+$src = '
+function Base(){}
+function Sub(){}
+Sub.prototype = new Base();
+ok($classes->{Sub}->{extends} eq 'Base',
+    "Prototype assignment results in inheritance");
+reset_parser();
+$src = '
+function Base(){}
+function Sub(){}
+Sub.prototype = new Base;
+    "Prototype assignment results in inheritance (2)");
+# Test the handling of methods defined more than once
+reset_parser();
+$src = '
+function f(){}
+/** doc */
+function f(){}
+ok($classes->{GLOBALS}->{class_methods}->[0]->{description} eq 'doc',
+    "In case of double function definition, the one with most info wins");
+reset_parser();
+$src = '
+/** doc */
+function f(){}
+function f(){}
+    "In case of double function definition, the one with most info wins (2)");
+# Make sure that extra JSDoc-style comment blocks are not viewed as source
+reset_parser();
+$src = '
+function x(){}
+/** more doc
+function y(){}
+function z(){}
+ok(!defined($classes->{GLOBALS}->{class_methods}->[0]),
+    "Ignore JSDoc in extra JSDoc-comment blocks");
+# Test the behaviour of the @ignore tag
+reset_parser();
+$src = '
+/** This method is normal */
+function Normal(){}
+/** @ignore */
+function Hidden(){}
+my %fnames = map { $_->{mapped_name} => 1 }
+    @{$classes->{GLOBALS}->{class_methods}};
+ok(defined $fnames{Normal}, "A normal method is picked up and documented");
+ok(!defined $fnames{Hidden}, 'An @ignored method is not picked up');
+# Test the behaviour of the @addon tag
+reset_parser();
+$src = '
+ * Should be ignored
+ClassOne.funcOne = function(){};
+ * Should not be ignored
+ * @addon
+ClassTwo.funcOne = function(){};
+ClassThree.prototype = new Object();
+ClassThree.funcThree = function(){}';
+ok(!defined($classes->{ClassOne}),
+    'Extensions to undefined classes/objects without @addon are ignored');
+ok(defined($classes->{ClassTwo}),
+    'Extensions to undefined classes/objects with @addon are not ignored');
+ok($classes->{ClassThree}->{class_methods}->[0]->{mapped_name} eq 'funcThree',
+    'Class methods without @addon work on pre-defined classes');
+# Ensure enclosing package-classes are still recognized without using @addon
+reset_parser();
+$src = '
+ * @constructor
+package.MyClass = function MyClass(){}
+package.MyClass.prototype.foo = function foo(){}
+ok(defined($classes->{package}),
+    'Super-package-classes must be recognized without the @addon tag');
+ok(defined($classes->{'package.MyClass'}),
+    'Sub-package-classes must be recognized without the @addon tag');
Added: trunk/build/JSDoc/allclasses-frame.tmpl
--- trunk/build/JSDoc/allclasses-frame.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/allclasses-frame.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,37 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN""http://www.w3.org/TR/REC-html40/loose.dtd">
+<!--NewPage-->
+<HTML>
+<HEAD>
+<TITLE>
+<TMPL_VAR NAME="project_name"> <TMPL_VAR NAME="filename">
+</TITLE>
+<LINK REL ="stylesheet" TYPE="text/css" HREF="stylesheet.css" TITLE="Style">
+</HEAD>
+<SCRIPT>
+function asd()
+parent.document.title="<TMPL_VAR NAME="project_name"> <TMPL_VAR NAME="filename">";
+</SCRIPT>
+<BODY BGCOLOR="white" onload="asd();">
+<TMPL_IF NAME="logo">
+   <IMG SRC="<TMPL_VAR NAME="logo">"/>
+</TMPL_IF>
+<H3 class="FrameHeadingFont"><B><TMPL_VAR NAME="project_name"></B></H3>
+<FONT size="+1" CLASS="FrameHeadingFont">
+<B><TMPL_VAR NAME="fname_link"></B></FONT>
+<BR>
+<TABLE BORDER="0" WIDTH="100%">
+<TMPL_LOOP name="classnames">
+<TR>
+<TD NOWRAP><FONT CLASS="FrameItemFont"><A HREF="<TMPL_VAR name="classlink">" TARGET="classFrame"><TMPL_VAR name="classname"></A>
+<BR>
+</FONT></TD>
+</TR>
+</TMPL_LOOP>
+</TABLE>
+</BODY>
+</HTML>
Added: trunk/build/JSDoc/allclasses-noframe.tmpl
--- trunk/build/JSDoc/allclasses-noframe.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/allclasses-noframe.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,36 @@
+<HTML>
+<HEAD>
+<TITLE>
+<TMPL_VAR NAME="project_name"> All Classes
+</TITLE>
+</HEAD>
+<SCRIPT>
+function asd()
+parent.document.title="<TMPL_VAR NAME="project_name"> All Classes";
+</SCRIPT>
+</TMPL_IF>
+<H3 CLASS="FrameHeadingFont"><TMPL_VAR NAME="project_name"></H3>
+<B><a href="overview-summary.html">All Classes</a></B></FONT>
+<BR>
+<TR>
+<TD NOWRAP><FONT CLASS="FrameItemFont"><A HREF="<TMPL_VAR name="classlink">" ><TMPL_VAR name="classname"></A>
+<BR>
+</FONT></TD>
+</TR>
+</TMPL_LOOP>
+</TABLE>
+</BODY>
+</HTML>
Added: trunk/build/JSDoc/constant-values.tmpl
--- trunk/build/JSDoc/constant-values.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/constant-values.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,151 @@
+<HTML>
+<HEAD>
+<TITLE>
+<TMPL_VAR NAME="project_name"> Constant Values
+</TITLE>
+</HEAD>
+<SCRIPT>
+function asd()
+parent.document.title="<TMPL_VAR NAME="project_help"> Constant Values";
+</SCRIPT>
+<!-- ========== START OF NAVBAR ========== -->
+<A NAME="navbar_top"><!-- --></A>
+<TABLE BORDER="0" WIDTH="100%" CELLPADDING="1" CELLSPACING="0">
+<TR>
+<TD COLSPAN=3 BGCOLOR="#EEEEFF" CLASS="NavBarCell1">
+<A NAME="navbar_top_firstrow"><!-- --></A>
+<TABLE BORDER="0" CELLPADDING="0" CELLSPACING="3">
+  <TR ALIGN="center" VALIGN="top">
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="overview-summary.html"><FONT CLASS="NavBarFont1"><B>Overview</B></FONT></A>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <FONT CLASS="NavBarFont1">File</FONT>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <FONT CLASS="NavBarFont1">Class</FONT>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="overview-tree.html"><FONT CLASS="NavBarFont1"><B>Tree</B></FONT></A>&nbsp;</TD>
+  <!--TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="deprecated-list.html"><FONT CLASS="NavBarFont1"><B>Deprecated</B></FONT></A>&nbsp;</TD-->
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="index-all.html"><FONT CLASS="NavBarFont1"><B>Index</B></FONT></A>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="help-doc.html"><FONT CLASS="NavBarFont1"><B>Help</B></FONT></A>&nbsp;</TD>
+  </TR>
+</TABLE>
+</TD>
+<TD ALIGN="right" VALIGN="top" ROWSPAN=3><EM>
+<B><TMPL_VAR NAME="project_name"></B>
+</EM>
+</TD>
+</TR>
+<TR>
+<TD BGCOLOR="white" CLASS="NavBarCell2"><FONT SIZE="-2">
+&nbsp;PREV&nbsp;
+&nbsp;NEXT</FONT></TD>
+  <A HREF="index.html" TARGET="_top"><B>FRAMES</B></A>  &nbsp;
+&nbsp;<A HREF="help-doc.html" TARGET="_top"><B>NO FRAMES</B></A>  &nbsp;
+&nbsp;
+<SCRIPT>
+  if(window==top) {
+    document.writeln('<A HREF="allclasses-noframe.html" TARGET=""><B>All Classes</B></A>');
+</SCRIPT>
+<NOSCRIPT>
+<A HREF="allclasses-noframe.html" TARGET=""><B>All Classes</B></A>
+</NOSCRIPT>
+</FONT></TD>
+</TR>
+</TABLE>
+<!-- =========== END OF NAVBAR =========== -->
+<HR>
+<CENTER> <H1>Constant Field Values</H1> </CENTER>
+<HR>
+<UL>
+<TMPL_LOOP NAME="classnames">
+    <LI><A HREF="#<TMPL_VAR NAME="name">"><TMPL_VAR NAME="name"></A></LI>
+</TMPL_LOOP>
+</UL>
+<HR>
+<TMPL_LOOP NAME="static_finals">
+    <A NAME="<TMPL_VAR NAME="classname">"></A>
+    <TABLE BORDER="1" CELLPADDING="3" CELLSPACING="0">
+        <TR BGCOLOR="#EEEEFF" CLASS="TableSubHeadingColor">
+            <TD colspan="2">
+                <B><A HREF="<TMPL_VAR NAME="classname">.html"><TMPL_VAR NAME="classname"></A></B>
+            </TD>
+        </TR>
+        <TMPL_LOOP NAME="static_values">
+        <TR>
+            <A NAME="<TMPL_VAR NAME="classname">.!s!<TMPL_VAR NAME="name">"></A><TD><CODE><A HREF="<TMPL_VAR NAME="classname">.html#<TMPL_VAR NAME="name">"><TMPL_VAR NAME="name"></A></CODE></TD>
+            <TD ALIGN="right"><CODE><TMPL_VAR NAME="value"></CODE></TD>
+        </TR>
+        </TMPL_LOOP>
+    </TABLE>
+    <P>
+    <P>
+</TMPL_LOOP>
+<HR>
+<A NAME="navbar_bottom"><!-- --></A>
+<TR>
+<A NAME="navbar_bottom_firstrow"><!-- --></A>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="overview-tree.html"><FONT CLASS="NavBarFont1"><b>Tree</b></FONT></A>&nbsp;</TD>
+  </TR>
+</TABLE>
+</TD>
+</EM>
+</TD>
+</TR>
+<TR>
+&nbsp;PREV&nbsp;
+&nbsp;
+<SCRIPT>
+  if(window==top) {
+</SCRIPT>
+<NOSCRIPT>
+</NOSCRIPT>
+</FONT></TD>
+</TR>
+</TABLE>
+<HR>
+<FONT SIZE="-1">
+<TMPL_VAR NAME="page_footer">
+</FONT>
+<div class="jsdoc_ctime">Documentation generated by <a href="http://jsdoc.sourceforge.net/" target="_parent">JSDoc</a> on <TMPL_VAR NAME="ctime"></div>
+</BODY>
+</HTML>
Added: trunk/build/JSDoc/help-doc.tmpl
--- trunk/build/JSDoc/help-doc.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/help-doc.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,160 @@
+<HTML>
+<HEAD>
+<TITLE>
+<TMPL_VAR NAME="project_name"> API Help
+</TITLE>
+</HEAD>
+<SCRIPT>
+function asd()
+parent.document.title="<TMPL_VAR NAME="project_help"> API Help";
+</SCRIPT>
+<TR>
+  <TD BGCOLOR="#FFFFFF" CLASS="NavBarCell1Rev"> &nbsp;<FONT CLASS="NavBarFont1Rev"><B>Help</B></FONT>&nbsp;</TD>
+  </TR>
+</TABLE>
+</TD>
+</EM>
+</TD>
+</TR>
+<TR>
+&nbsp;PREV&nbsp;
+&nbsp;
+<SCRIPT>
+  if(window==top) {
+</SCRIPT>
+<NOSCRIPT>
+</NOSCRIPT>
+</FONT></TD>
+</TR>
+</TABLE>
+<HR>
+<CENTER>
+<H1>
+How This API Document Is Organized</H1>
+</CENTER>
+This API (Application Programming Interface) document has pages corresponding to the items in the navigation bar, described as follows.<H3>
+Class</H3>
+<BLOCKQUOTE>
+<P>
+Each class has its own separate page. Each of these pages has three sections consisting of a class description, summary tables, and detailed member descriptions:<UL>
+<LI>Class inheritance diagram<LI>Direct Subclasses<LI>Class declaration<LI>Class description
+<P>
+<LI>Field Summary<LI>Constructor Summary<LI>Method Summary
+<P>
+<LI>Field Detail<LI>Constructor Detail<LI>Method Detail</UL>
+Each summary entry contains the first sentence from the detailed description for that item. </BLOCKQUOTE>
+<!--H3>
+Tree (Class Hierarchy)</H3>
+<BLOCKQUOTE>
+There is a <A HREF="overview-tree.html">Class Hierarchy</A> page for all classes. The hierarchy page contains a list of classes. The classes are organized by inheritance structure starting with <code>Object</code>.<UL>
+</BLOCKQUOTE-->
+<!-- H3>
+Deprecated API</H3>
+<BLOCKQUOTE>
+The <A HREF="deprecated-list.html">Deprecated API</A> page lists all of the API that have been deprecated. A deprecated API is not recommended for use, generally due to improvements, and a replacement API is usually given. Deprecated APIs may be removed in future implementations.</BLOCKQUOTE-->
+<H3>
+Index</H3>
+<BLOCKQUOTE>
+The <A HREF="index-all.html">Index</A> contains an alphabetic list of all classes, constructors, methods, and fields.</BLOCKQUOTE>
+<H3>
+Prev/Next</H3>
+These links take you to the next or previous class, interface, package, or related page.<H3>
+Frames/No Frames</H3>
+These links show and hide the HTML frames.  All pages are available with or without frames.
+<P>
+<FONT SIZE="-1">
+<EM>
+This help file applies to API documentation generated using the standard doclet.</EM>
+</FONT>
+<BR>
+<HR>
+<TR>
+  </TR>
+</TABLE>
+</TD>
+</EM>
+</TD>
+</TR>
+<TR>
+&nbsp;PREV&nbsp;
+&nbsp;
+<SCRIPT>
+  if(window==top) {
+</SCRIPT>
+<NOSCRIPT>
+</NOSCRIPT>
+</FONT></TD>
+</TR>
+</TABLE>
+<HR>
+<FONT SIZE="-1">
+</FONT>
+</BODY>
+</HTML>
Added: trunk/build/JSDoc/index-all.tmpl
--- trunk/build/JSDoc/index-all.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/index-all.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,142 @@
+<!--NewPage-->
+<HTML>
+<HEAD>
+<TITLE>
+Index ()
+</TITLE>
+</HEAD>
+<SCRIPT>
+function asd()
+parent.document.title="Index ()";
+</SCRIPT>
+<TR>
+  <TD BGCOLOR="#FFFFFF" CLASS="NavBarCell1Rev"> &nbsp;<FONT CLASS="NavBarFont1Rev"><B>Index</B></FONT>&nbsp;</TD>
+  </TR>
+</TABLE>
+</TD>
+</EM>
+</TD>
+</TR>
+<TR>
+&nbsp;PREV&nbsp;
+&nbsp;<A HREF="index-all.html" TARGET="_top"><B>NO FRAMES</B></A>  &nbsp;
+&nbsp;
+<SCRIPT>
+  if(window==top) {
+</SCRIPT>
+<NOSCRIPT>
+</NOSCRIPT>
+</FONT></TD>
+</TR>
+</TABLE>
+<TMPL_IF NAME="letters">
+ Listing of letters
+<TMPL_LOOP NAME="letters">&nbsp;<A HREF="index-all.html#__<TMPL_VAR NAME="letter_name">__"><TMPL_VAR NAME="letter_name"></A></TMPL_LOOP>
+<HR>
+<!-- End letter listing -->
+<TMPL_LOOP NAME="index_list">
+<A NAME="__<TMPL_VAR NAME="letter">__"><!-- --></A><H2>
+<B><TMPL_VAR NAME="letter"></B></H2>
+<TMPL_LOOP NAME="value">
+<DL>
+<DT><A HREF="<TMPL_VAR NAME="classlink">#<TMPL_VAR NAME="linkname">"><B><TMPL_VAR NAME="name"></B></A> -
+<TMPL_VAR NAME="type"> class <A HREF="<TMPL_VAR NAME="classlink">"><TMPL_VAR NAME="class"></A>
+<DD>&nbsp;
+</DL>
+</TMPL_LOOP>
+<HR>
+</TMPL_LOOP>
+</TMPL_IF>
+<TR>
+  </TR>
+</TABLE>
+</TD>
+</EM>
+</TD>
+</TR>
+<TR>
+&nbsp;PREV&nbsp;
+&nbsp;
+<SCRIPT>
+  if(window==top) {
+</SCRIPT>
+<NOSCRIPT>
+</NOSCRIPT>
+</FONT></TD>
+</TR>
+</TABLE>
+<HR>
+<FONT SIZE="-1">
+</FONT>
+<div class="jsdoc_ctime">Documentation generated by <a href="http://jsdoc.sourceforge.net/">JSDoc</a> on <TMPL_VAR NAME="ctime"></div>
+</BODY>
+</HTML>
Added: trunk/build/JSDoc/index.tmpl
--- trunk/build/JSDoc/index.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/index.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,27 @@
+<HTML>
+<HEAD>
+<TITLE>
+Generated Javascript Documentation
+</TITLE>
+</HEAD>
+<FRAMESET cols="20%,80%">
+<TMPL_IF NAME="multifile">
+<FRAMESET rows="40%,50%">
+<FRAME src="overview-frame.html" name="overviewFrame">
+</TMPL_IF>
+<FRAME src="allclasses-frame.html" name="packageFrame">
+</FRAMESET>
+</TMPL_IF>
+<FRAME src="<TMPL_VAR name="default_classname">" name="classFrame">
+</FRAMESET>
+<NOFRAMES>
+<H2>
+Frame Alert</H2>
+<P>
+This document is designed to be viewed using the frames feature. If you see this message, you are using a non-frame-capable web client.
+<BR>
+Link to <A HREF="allclasses-frame.html">Non-frame version.</A></NOFRAMES>
+</HTML>
Added: trunk/build/JSDoc/jsdoc.pl
--- trunk/build/JSDoc/jsdoc.pl	                        (rev 0)
+++ trunk/build/JSDoc/jsdoc.pl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,1569 @@
+#!/usr/bin/perl -w
+# This program makes use of the JSDoc module to make a JavaDoc equivalent
+# for JavaScript. The template that is used is based on the JavaDoc
+# doclet. This program only needs to be invoked with one or more
+# JS OO sourcefiles as command-line args.
+use strict;
+use HTML::Template;
+use File::Copy;
+use File::Basename;
+use File::Path;
+use Getopt::Long;
+use File::Find;
+use lib dirname($0);
+use JSDoc;
+use JSDoc::XML;
+use JSDoc::XMI;
+use JavaScript::Syntax::HTML qw(to_html);
+use constant LOCATION           => dirname($0) . '/';
+use constant MAIN_TMPL          => "main.tmpl";
+use constant ALLCLASSES_TMPL    => 'allclasses-frame.tmpl';
+use constant ALLCLASSES_NOFRAME_TMPL    => 'allclasses-noframe.tmpl';
+use constant OVERVIEW_FRAME_TMPL        => 'overview-frame.tmpl';
+use constant TREE_TMPL          => 'overview-tree.tmpl';
+use constant OVERVIEW_TMPL      => 'overview-summary.tmpl';
+use constant INDEX_TMPL         => 'index.tmpl';
+use constant DEFAULT_DEST_DIR   => 'js_docs_out/';
+use constant STYLESHEET         => 'stylesheet.css';
+use constant HELP_TMPL          => 'help-doc.tmpl';
+use constant INDEX_ALL_TMPL     => 'index-all.tmpl';
+use constant CONSTANTS_TMPL     => 'constant-values.tmpl';
+use vars qw/ $CLASSES $DEFAULT_CLASSNAME @CLASSNAMES @INDEX %TMPL_CACHE
+            %CLASS_ATTRS_MAP %METHOD_ATTRS_MAP %FILE_ATTRS_MAP %OPTIONS
+            @FILENAMES %FILE_OVERVIEWS $TIME $CURRENT_CLASS /;
+# Begin main execution
+&parse_cmdline;
+&initialize_param_maps;
+$TIME = localtime();
+do '.jsdoc_config';
+warn "Error parsing config file: $@\n" if $@;
+my @sources;
+mkdir($OPTIONS{OUTPUT})
+    or die "Can't create output directory $OPTIONS{OUTPUT}: $!\n"
+    unless (-e $OPTIONS{OUTPUT} && -d $OPTIONS{OUTPUT});
+if (@ARGV < 1 || $OPTIONS{HELP} || !(@sources = &load_sources())){
+    warn "No sourcefiles supplied\n" if !$OPTIONS{HELP};
+    &show_usage();
+    exit(1);
+# Parse the code tree
+&configure_parser(
+    GLOBALS_NAME        => $OPTIONS{GLOBALS_NAME},
+    NO_LEXICAL_PRIVATES => $OPTIONS{NO_LEXICAL_PRIVATES});
+$CLASSES = &parse_code_tree(@sources);
+%FILE_OVERVIEWS = %{delete $CLASSES->{__FILES__}};
+&map_implementation_classes();
+die "Nothing to document, exiting\n" unless keys %{$CLASSES};
+if ($OPTIONS{FORMAT} eq 'html'){
+    &output_html;
+} elsif ($OPTIONS{FORMAT} eq 'xml') {
+    &output_xml;
+} elsif ($OPTIONS{FORMAT} eq 'xmi'){
+    &output_xmi;
+} else {
+    die "Unknown data format '$OPTIONS{FORMAT}'\n";
+&_log('Completed generating documentation');
+# End main execution
+sub map_implementation_classes {
+    my (%implementations, %implementors);
+    for my $class (keys %$CLASSES){
+        my $implements = $CLASSES->{$class}->{constructor_vars}->{implements};
+        if ($implements){
+            for my $iname (map {strip($_)} @$implements){
+                push @{$implementations{$class}}, $iname;
+                push @{$implementors{$iname}}, $class;
+    sub add_method_to_subclasses {
+        my ($cname, $method, $subclasses_of) = @_;
+        $subclasses_of ||= $cname;
+        for my $subclass (keys %$CLASSES){
+            if (($CLASSES->{$subclass}->{extends} || '') eq $subclasses_of){
+                if (not has_method($subclass, $method)){
+                    my $inherits_hash = $CLASSES->{$subclass}->{inherits};
+                    push @{$inherits_hash->{$cname}->{instance_methods}},
+                        $method;
+                    add_method_to_subclasses($cname, $method, $subclass);
+    sub get_instance_method {
+        my ($classname, $methodname) = @_;
+        my $class = $CLASSES->{$classname} or return undef;
+            if ($method->{mapped_name} eq $methodname){
+                return $method;
+        return undef;
+    # Copy the methods to the implementor
+    for my $class (keys %implementations){
+        for my $interface (map {$CLASSES->{$_}} @{$implementations{$class}}){
+            my @interface_methods = @{$interface->{instance_methods} || []};
+            for my $superclass (keys %{$interface->{inherits} || {}}){
+                push @interface_methods,
+                    map { get_instance_method($superclass, $_) }
+                        @{$interface->{inherits}->{$superclass}->
+                            {instance_methods}};
+            for my $interface_method (@interface_methods){
+                if (not has_method($class, $interface_method->{mapped_name})){
+                    push @{$CLASSES->{$class}->{instance_methods}},
+                        $interface_method;
+                    add_method_to_subclasses($class,
+                        $interface_method->{mapped_name});
+    # Put a flag on interfaces to say who they're implemented by
+    for my $interface (keys %implementors){
+        my $interface_class = $CLASSES->{$interface};
+        push @{$interface_class->{constructor_vars}->{implemented_by}}, $_
+            for @{$implementors{$interface}};
+# Output a single template
+sub output_template {
+    my ($tmplname, $outname, $params, $relaxed) = (@_);
+    $OPTIONS{TEMPLATEDIR} =~ s/(\S+)\/$/$1/;
+    $tmplname = $OPTIONS{TEMPLATEDIR} . "/$tmplname";
+    die "Template file '$tmplname' not found"  unless -e $tmplname;
+    # Caching templates seems to improve performance quite a lot
+    if (!$TMPL_CACHE{$tmplname}){
+        $TMPL_CACHE{$tmplname} = new HTML::Template(
+            die_on_bad_params    => !$relaxed,
+            filename             => $tmplname);
+    my $tmpl = $TMPL_CACHE{$tmplname};
+    $tmpl->param($params);
+    $outname = sprintf('%s%s', $OPTIONS{OUTPUT}, $outname);
+    &print_file($outname, $tmpl->output);
+# Output data to a file
+sub print_file {
+    my ($fname, $data) = @_;
+    open FILE, ">$fname"
+        or die "Couldn't open '$fname' to write: $!\n";
+    print FILE $data;
+    close FILE;
+# Output HTML documentation in the output directory
+sub output_html {
+    &set_file_paths();
+    &output_class_templates();
+    &output_index_template();
+    &output_aux_templates();
+    &output_tree_template();
+# Output XMI in the output directory
+sub output_xmi {
+    my $xmi = JSDoc::XMI->new(LOCATION);
+    &print_file("$OPTIONS{OUTPUT}/jsdoc.xmi", $xmi->output($CLASSES));
+# Output XML in the output directory
+sub output_xml {
+    my $xml = JSDoc::XML->new(LOCATION);
+    &print_file("$OPTIONS{OUTPUT}/jsdoc.xml", $xml->output($CLASSES));
+sub set_file_paths {
+    for my $classname (keys %$CLASSES){
+        my $class = $CLASSES->{$classname};
+        my $filepath = $classname;
+        $filepath =~ s/\./\//g;
+        $filepath = "$filepath.html";
+        my $dirpath = dirname($filepath);
+        $class->{filepath} = $filepath;
+        $class->{dirpath} = $dirpath;
+        my $fullpath = "$OPTIONS{OUTPUT}$dirpath";
+        mkpath($fullpath) unless -e $fullpath;
+        $class->{ispackage} = @{$class->{inner_classes}}
+            && not (@{$class->{instance_methods} || []}
+                        or @{$class->{instance_fields} || []});
+# Gather information for each class and output its template
+sub output_class_templates {
+    # Note the class name for later, including classes that aren't defined
+    # but are used for inheritance
+    my %seen;
+    @CLASSNAMES =  sort { lc $a->{classname} cmp lc $b->{classname}}
+    grep { !$seen{$_->{classname}}++ }
+        (map {classname => $_,
+                classlink => link_to_class($_) } ,
+        grep { not defined $CLASSES->{$_}->{constructor_vars}->{private}
+                or $OPTIONS{PRIVATE} }
+        keys %$CLASSES),
+        (map { classname => $_ }, grep { !defined($$CLASSES{$_}) }
+            map { $_->{extends} } grep { defined($_->{extends}) }
+                values %$CLASSES);
+    die "Nothing to document, exiting\n" unless @CLASSNAMES;
+    @FILENAMES = map {filename => $_, mangledfilename => mangle($_)},
+        sort {lc($a) cmp lc($b)} grep {length $_} keys %FILE_OVERVIEWS;
+    for (my $i = 0; $i < @CLASSNAMES; $i++){
+        my $classname = $CLASSNAMES[$i]->{classname};
+        $CURRENT_CLASS = $classname;
+        next unless $$CLASSES{$classname};
+        # Template Parameters
+        my ($class, $subclasses, $class_summary, $constructor_params,
+            $next_class, $prev_class, $constructor_attrs,
+            $constructor_detail, $constructor_args);
+        $class= $$CLASSES{$classname};
+        next unless is_class_linkable($classname);
+        &add_to_index($class, $classname);
+        # Set up the constructor and class information
+        &resolve_synonyms($class->{constructor_vars});
+        &format_vars($class->{constructor_vars});
+        ($constructor_params, $constructor_args) =
+            &fetch_args($class->{constructor_vars},
+                        $class->{constructor_args});
+        $constructor_attrs =
+            &format_method_attributes($class->{constructor_vars});
+        $constructor_detail =
+            &resolve_inner_links($class->{constructor_detail});
+        $class_summary = &format_class_attributes($class->{constructor_vars});
+        $class_summary = &resolve_inner_links($class_summary);
+        # Navbar information
+        $next_class = $i + 1 < @CLASSNAMES
+            ? link_to_class($CLASSNAMES[$i + 1]->{classname}, $classname)
+            : undef;
+        $prev_class = $i > 0
+            ?  link_to_class($CLASSNAMES[$i - 1]->{classname}, $classname)
+            : undef;
+        my $superclass = $class->{extends} || '';
+        if ($superclass && $$CLASSES{$superclass}){
+            $superclass = make_link($superclass, $classname)
+                unless (!$OPTIONS{PRIVATE}
+                    && $$CLASSES{$superclass}->{constructor_vars}->{private});
+        my $file_overview = $class->{constructor_vars}->{filename} ?
+                sprintf('overview-summary-%s.html',
+                    mangle($class->{constructor_vars}->{filename}))
+        my @inner_classes = map {
+            classname => $_->{class_name},
+            classlink => link_to_class($_->{class_name}, $classname)
+                }, @{$class->{inner_classes} || []};
+        &output_template(MAIN_TMPL, $class->{filepath}, {
+            path_to_base        => path_to_base($classname),
+            next_class          => $next_class,
+            prev_class          => $prev_class,
+            file_overview       => $file_overview,
+            superclass          => $superclass,
+            constructor_args    => $constructor_args,
+            constructor_params  => $constructor_params,
+            constructor_attrs   => $constructor_attrs,
+            constructor_returns => $class->{constructor_vars}->{returns}[0],
+            class_summary       => $class_summary,
+            class_attribs       => $class->{constructor_vars}->{private} ?
+                                    '&lt;private&gt;' : '',
+            constructor_detail  => $constructor_detail,
+            constructor_summary => &get_summary($constructor_detail),
+            classname           => $classname,
+            hierarchy_meta      => get_class_hierarchy_metadata($classname),
+            class_tree          => &build_class_tree($classname, $CLASSES),
+            fields              => &map_fields($class),
+            methods             => &map_methods($class),
+            method_inheritance  => &map_method_inheritance($class),
+            field_inheritance   => &map_field_inheritance($class),
+            inner_classes       => \@inner_classes,
+            project_name        => $OPTIONS{PROJECT_NAME},
+            page_footer         => $OPTIONS{PAGE_FOOTER},
+            ctime               => $TIME
+        }, 1);
+# Handle cleaning up / resolving inner links in FILE_OVERVIEWS
+sub process_file_overviews {
+    for my $filename (map{$_->{filename}} @FILENAMES){
+        my $overview = $FILE_OVERVIEWS{$filename};
+        my $src = $overview->{src};
+        $overview->{src} = '';
+        format_vars($overview);
+        $overview =
+            resolve_inner_links($FILE_OVERVIEWS{$filename});
+        $overview->{src} = $src;
+        $FILE_OVERVIEWS{$filename} = $overview;
+# Output all the non-class template files
+sub output_aux_templates(){
+    unless ($OPTIONS{LOGO} and -f $OPTIONS{LOGO} and -r $OPTIONS{LOGO}){
+        $OPTIONS{LOGO} and warn "Can't read $OPTIONS{LOGO}";
+        $OPTIONS{LOGO} = '';
+    $OPTIONS{LOGO} and copy $OPTIONS{LOGO}, $OPTIONS{OUTPUT};
+    &process_file_overviews;
+    $DEFAULT_CLASSNAME =
+        (grep {
+            is_class_linkable($_->{classname}) } @CLASSNAMES)[0]->{classname};
+    my $summary = &get_overall_summary;
+    &output_classes_frames_templates;
+    &output_multiple_files_templates
+        if (@FILENAMES > 1 || $OPTIONS{PACKAGENAMING});
+    &output_index_and_help_templates($summary);
+    &output_overview_summaries($summary);
+    &output_const_summary();
+    my $stylesheet = LOCATION . STYLESHEET;
+    if ($OPTIONS{TEMPLATEDIR} ne LOCATION){
+        $stylesheet = $OPTIONS{TEMPLATEDIR} . '/' . STYLESHEET;
+        die "Stylesheet '$stylesheet' not found" unless -e $stylesheet;
+    copy ($stylesheet, $OPTIONS{OUTPUT} . STYLESHEET);
+sub get_overall_summary {
+    my $summary;
+    if ($OPTIONS{PROJECT_SUMMARY}){
+        if (-f $OPTIONS{PROJECT_SUMMARY} and
+                open SUMMARY, $OPTIONS{PROJECT_SUMMARY}){
+            local $/ = undef;
+            $summary = <SUMMARY>;
+            close SUMMARY;
+        } else {
+            warn "Can't open $OPTIONS{PROJECT_SUMMARY}";
+    } elsif (@FILENAMES == 1) {
+        # If we only have one file and it has an overview, use that overview
+        my $filename = $FILENAMES[0]->{filename};
+        if ($FILE_OVERVIEWS{$filename}->{fileoverview}){
+            $summary = $FILE_OVERVIEWS{$filename}->{fileoverview}[0];
+            $summary .= "<BR/><BR/>";
+            while (my ($name, $val) = each %{$FILE_OVERVIEWS{$filename}}){
+                $summary .= &{$FILE_ATTRS_MAP{$name}}($val)
+                    if $FILE_ATTRS_MAP{$name};
+    $summary;
+# Output the main (default) page and the help template
+sub output_index_and_help_templates {
+    my ($summary) = @_;
+    my $numpackages = scalar(grep {$_->{ispackage}} values %$CLASSES);
+    # Output the main index template
+    &output_template(INDEX_TMPL, 'index.html', {
+        DEFAULT_CLASSNAME   =>  @FILENAMES > 1
+                                ? 'overview-summary.html'
+                                : link_to_class($DEFAULT_CLASSNAME),
+        multifile           => (@FILENAMES > 1
+                                || ($numpackages && $OPTIONS{PACKAGENAMING}))});
+    # Output the help document template
+    &output_template(HELP_TMPL, 'help-doc.html',  {
+        ctime           => $TIME,
+        project_name    => $OPTIONS{PROJECT_NAME} });
+# Output the frames listing all the classes
+sub output_classes_frames_templates {
+    my @classnames = grep { is_class_linkable($_->{classname}) } @CLASSNAMES;
+    if ($OPTIONS{PACKAGENAMING}){
+        @classnames = grep { !($CLASSES->{$_->{classname}}->{ispackage}) }
+            @classnames;
+    my $params = {
+        filename    => 'All Classes',
+        fname_link  => '<a href="overview-summary.html" ' .
+                        'target="classFrame">All Classes</a>',
+        CLASSNAMES  => \@classnames };
+    if (@FILENAMES < 2 && !$OPTIONS{PACKAGENAMING}){
+        $params->{project_name} = $OPTIONS{PROJECT_NAME};
+        $params->{logo} = basename($OPTIONS{LOGO});
+    &output_template(ALLCLASSES_TMPL, 'allclasses-frame.html', $params);
+    &output_template(ALLCLASSES_NOFRAME_TMPL, 'allclasses-noframe.html', {
+        CLASSNAMES      => \@classnames,
+        logo            => basename($OPTIONS{LOGO}) });
+# Output the overview summary templates
+sub output_overview_summaries {
+    my @overviews = map {
+        name        =>  $_,
+        link        =>  &mangle("overview-summary-$_.html"),
+        overview    =>
+            get_summary(
+                $FILE_OVERVIEWS{$_}{fileoverview}[0] || '&nbsp;')
+        }, sort {lc($a) cmp lc($b)}  keys(%FILE_OVERVIEWS);
+    &output_template(OVERVIEW_TMPL, 'overview-summary.html', {
+        generic             => 1,
+        project_title       => $OPTIONS{PROJECT_NAME},
+        ctime               => $TIME,
+        project_summary     => $summary,
+        is_file_summary     => 0,
+        overviews           => \@overviews });
+    for my $filename (keys %FILE_OVERVIEWS){
+        my @classes = grep {
+            ($$CLASSES{$_}->{constructor_vars}->{filename} || '') eq $filename
+        } keys %$CLASSES;
+        my @class_overviews = sort { lc($a->{name}) cmp lc($b->{name}) }
+            map {
+                name        => $_,
+                link        => link_to_class($_),
+                overview    => get_summary(
+                    $CLASSES->{$_}->{constructor_vars}->{class}[0] || '&nbsp;')
+            },  grep { !$CLASSES->{$_}->{constructor_vars}->{private}
+                || $OPTIONS{PRIVATE} } @classes;
+        my %overview = %{$FILE_OVERVIEWS{$filename}};
+        my $src = delete $overview{src};
+        my $summary =   $overview{fileoverview}[0] ||
+            "No overview generated for '$filename'";
+        while (my ($name, $val) = each %overview){
+        my @methods =
+            map {
+                is_private      => $_->{is_private},
+                method_summary  => $_->{method_summary},
+                is_class_method => $_->{is_class_method},
+                method_anchor   =>
+                    sprintf('%s%s', $_->{is_class_method} ? '!s!' : '',
+                        $_->{method_name}),
+                method_arguments=> $_->{method_arguments},
+                method_name     => $_->{method_name},
+                type            => $_->{type},
+                file_link       => $OPTIONS{GLOBALS_NAME} . ".html"
+            }, @{&map_methods($$CLASSES{$OPTIONS{GLOBALS_NAME}}, $filename)};
+        &output_template(OVERVIEW_TMPL, "overview-summary-$filename.html", {
+            generic             => 0,
+            sourcecode          => $OPTIONS{NO_SRC} ? '' : &to_html($src),
+            project_title       => $filename,
+            ctime               => $TIME,
+            is_file_summary     => 1,
+            methods             => \@methods,
+            overviews           => \@class_overviews });
+# Output a summary page about the 'static constant' field values for all
+# classes
+sub output_const_summary {
+    my @static_params;
+    for my $classname (sort { uc($a) cmp uc($b) } keys %$CLASSES){
+        my @statics = grep { $_->{field_value} =~ /^(?:\d+)|(?:(['"]).*\1)$/}
+            grep { $_->{field_vars}->{final}} @{$class->{class_fields}};
+        if (@statics){
+            push @static_params, {
+                static_values   => [map {
+                    name        => $_->{field_name},
+                    value       => $_->{field_value},
+                    classname   => $classname}, @statics] };
+    &output_template(CONSTANTS_TMPL, 'constant-values.html', {
+        ctime               => $TIME,
+        classnames          => [map {name => $_->{classname}}, @static_params],
+        static_finals       => \@static_params
+    ) if @static_params;
+# Method to handle outputting file overview template if
+# more than one sourcefile is being processed
+sub output_multiple_files_templates {
+    my %params = (
+        logo            => basename($OPTIONS{LOGO}),
+        project_name    => $OPTIONS{PROJECT_NAME});
+        my @packagenames = sort { $a->{filename} cmp $b->{filename} }
+            map {
+                filelink    => "overview-$_->{classname}.html",
+                filename    => $_->{classname} }, grep { $_->{ispackage} }
+            values %$CLASSES;
+        $params{filenames} = \@packagenames;
+        $params{heading} = "Packages";
+    } else {
+        my @filenames = map {
+            filelink    => "overview-$_->{mangledfilename}.html",
+            filename    => $_->{filename} }, @FILENAMES;
+        $params{filenames} = \@filenames;
+        $params{heading} = "Files";
+    &output_template(OVERVIEW_FRAME_TMPL, 'overview-frame.html', \%params);
+    if (!$OPTIONS{PACKAGENAMING}){
+        for my $fname (map { $_->{filename}} @FILENAMES){
+                    eq $fname
+            } keys %$CLASSES;
+            #methods under GLOBAL (detached) class
+            my @methods;
+                if($CLASSNAMES[$i]->{classname} eq $OPTIONS{GLOBALS_NAME}){
+                    my $class = $$CLASSES{$CLASSNAMES[$i]->{classname}};
+                    for my $method (
+                            sort {lc $a->{mapped_name}
+                                    cmp lc $b->{mapped_name} }
+                                @{$class->{class_methods}}){
+                        if(defined($fname)
+                                && $fname eq $method->{vars}->{filename}){
+                            $method->{filename} = $fname;
+                            push(@methods, $method);
+                    last;
+                sprintf('overview-%s.html', $fname), {
+                    filename    => $fname,
+                    fname_link  => $FILE_OVERVIEWS{$fname}
+                                    ?  sprintf(
+                                        '<a href="overview-summary-%s.html"
+                                            target="classFrame">%s</a>',
+                                            mangle($fname), $fname)
+                                    : $fname,
+                    CLASSNAMES  => [map {
+                            classname => $_,
+                        grep { !$$CLASSES{$_}->{constructor_vars}->{private}
+                            || $OPTIONS{PRIVATE} } sort @classes] });
+        my @packages = grep { $_->{ispackage} } values %$CLASSES;
+        for my $package (@packages){
+            my $name = $package->{classname};
+            my %params = (
+                filename    =>  $name,
+                fname_link  =>  sprintf(
+                                    '<a href="%s" target="classFrame">%s</a>',
+                                    link_to_class($name), $name));
+            my @inner_classes = sort {
+                $a->{classname} cmp $b->{classname}} map {
+                classname   => $_,
+                classlink   => link_to_class($_) },
+                    map { $_->{class_name} } @{$package->{inner_classes}};
+            $params{CLASSNAMES} = \@inner_classes;
+            output_template(ALLCLASSES_TMPL, "overview-$name.html", \%params);
+# Mangle a file path so that it can be used as a filename
+sub mangle {
+    my $input = shift;
+    local $_ = $input;
+    tr{/\\}{_};
+    die if $input ne $_;
+    $_;
+# Build the tree representation of the inheritance
+# PARAM: Name of the class
+sub build_class_tree {
+    my $classname  = shift;
+    my $class = $$CLASSES{$classname};
+    my $tree = "";
+    my @family;
+    push @family, $classname;
+    while ($class->{extends} and $class->{extends} ne ""){
+        my $base = $class->{extends};
+        if ($$CLASSES{$base} and is_class_linkable($base)){
+            $base = sprintf("<a href='%s'>$base</a>",
+                        link_to_class($base, $classname))
+                    && $$CLASSES{$base}->{constructor_vars}->{private});
+        } elsif ($class->{constructor_vars}->{base}){
+            if (my ($bcname, $url) =
+                    $class->{constructor_vars}->{base}->[0]
+                        =~ /^(\S+)\s(\S.*)$/){
+                $base = "<a href='$url'>$base</a>";
+        push @family, $base;
+        $class = $$CLASSES{$class->{extends}};
+    push @family, "Object";
+    my $indent = 3;
+    $tree = (pop @family) . "\n";
+    my $name = $_;
+    while ($name = pop (@family)){
+        my $instr = " " x $indent;
+        $tree .= sprintf "%s|\n%s+--%s%s%s\n", $instr, $instr,
+            $name eq $classname ? "<b>" : "", $name,
+            $name eq $classname ? "</b>" : "";
+        $indent += 6;
+    $tree;
+# Shown if no commandline args are given
+sub show_usage(){
+    print qq{Usage: jsdoc [OPTIONS] <js sourcefiles and/or directories>+
+    -h | --help         Show this message and exit
+    -r | --recursive    Recurse through given directories
+    -p | --private      Show private methods and fields
+    -d | --directory    Specify output directory (defaults to js_docs_out)
+    -q | --quiet        Suppress normal output
+    --page-footer       Specify (html) footer string that will be added to
+                        all docs
+    --project-name      Specify project name for that will be added to docs
+    --logo              Specify a path to a logo to be used in the docs
+    --project-summary   Specify a path to a text file that contains an
+                        overview summary of the project
+    --no-sources        Don't include the source code view
+    --extensions        Provide a comma-separated list of file extensions
+                        to be considered as JavaScript source files
+    --nested-file-naming    Use package-style naming (i.e. keep directory
+                            names in the file path). This is useful if you
+                            have multiple files with the same name, but in
+                            different directories. This option is only useful
+                            if --recursive is also used.
+    --globals-name      Specify a 'class name' under which all unattached
+                        methods will be classified. The defaults to GLOBALS
+    --format            Set the output format. The options are html, xml
+                        and xmi, defaulting to html. The others are currently
+                        alpha software.
+    --template-dir      Provide another directory containing HTML templates
+    --no-lexical-privates   Ignore "private" variables and functions that are
+                            lexically defined within constructors
+    --package-naming    Use packages, with a package being defined as a class
+                        that only contains nested classes and possibly
+                        static members.
+    \n};
+# Take all the command line args as filenames and add them to @SOURCESFILES
+sub load_sources(){
+    my (@filenames, @sources);
+    my $ext_re = sprintf('%s',
+        join '|', split /\s*,\s*/, $OPTIONS{EXTENSIONS});
+    for my $arg (@ARGV){
+        if (-d $arg) {
+            $arg =~ s/(.*[^\/])$/$1\//;
+            find( {
+                wanted => sub {
+                    push @filenames, {
+                        name => $_,
+                        relname => $OPTIONS{NESTEDFILENAMING}
+                                ? substr($_, length($arg))
+                                : (fileparse($_))[0]
+                    } if ((-f and -r and /.+\.$ext_re$/oi) &&
+                                (/^\Q$arg\E[^\/]+$/ || $OPTIONS{RECURSIVE}))
+                no_chdir => 1 }, $arg);
+        } elsif (-f $arg){
+            my $relname = (fileparse($arg))[0];
+            push @filenames, { name => $arg, relname => $relname };
+    for (@filenames){
+        &_log(sprintf 'Loading sources from %s', $_->{name});
+        open SRC, '<', $_->{name}
+            or (warn sprintf("Can't open %s, skipping: $!\n", $_->{name})
+                and next);
+        local $/ = undef;
+        push @sources, $_->{relname};
+        push @sources, \<SRC>;
+        close SRC;
+    @sources;
+# Once all sources have been parsed, finds all subclasses
+# of $classname
+sub find_subclasses {
+    my ($classname) = @_;
+    my @subclasses;
+        my $subclassname = $$CLASSES{$class}->{extends};
+        if ($$CLASSES{$class}->{extends} and
+	    $$CLASSES{$class}->{extends} eq $classname){
+	        push @subclasses,  $class;
+    \@subclasses;
+# Make a summary of a description, cutting it off either at the first
+# double newline or the first period followed by whitespace.
+# PARAM: $description
+sub get_summary {
+    my ($description) = @_;
+    my $summary;
+    if ($description){
+        ($summary) = $description =~ /^(.*?(?:[?!.](?=\s)|\n\n)).*$/gs
+	    or $summary = $description;
+    } else {
+        $summary = "";
+    $summary;
+# Set up all the instance and class methods for one template
+# PARAM: A reference to a class
+# PARAM: Optional filename, only maps methods for that file (used for GLOBAL)
+sub map_methods{
+    my ($class, $fname) = @_;
+    my @methods;
+    for my $mtype (qw(instance_methods class_methods)){
+        next unless $class->{$mtype};
+        for my $method (
+            sort {lc $a->{mapped_name} cmp lc $b->{mapped_name} }
+                    @{$class->{$mtype}}){
+                next if $fname && $fname ne $method->{vars}->{filename};
+                &resolve_synonyms($method->{vars});
+                next if (!$OPTIONS{PRIVATE} && $method->{vars}->{private});
+                $method->{vars}->{returns}[0] =
+                    $method->{vars}->{returns}[0] || $method->{vars}->{return};
+                my ($args, $arglist) =
+                    &fetch_args($method->{vars}, $method->{argument_list});
+                $args = [map { &format_vars($_); $_ } @{$args}];
+                &format_vars($method->{vars});
+                my $desc = &resolve_inner_links($method->{description});
+                my $type = &map_return_type($method);
+                my $ret = $method->{vars}->{returns}[0];
+                my $attrs = &format_method_attributes($method->{vars});
+                push @methods, {
+                    method_description  => $desc,
+                    method_summary      => &get_summary($desc),
+                    method_name         => $method->{mapped_name},
+                    method_arguments    => $arglist,
+                    method_params       => $args,
+                    method_returns      => $ret,
+                    is_class_method     => $mtype eq 'class_methods',
+                    is_private          => defined($method->{vars}->{private}),
+                    attributes          => $attrs,
+                    type                => $type };
+    return \@methods;
+# Map a function return type
+sub map_return_type {
+    my ($method) = @_;
+    #return 'Object' unless $method->{vars}->{type}[0];
+    my $name = 'Object';
+    my $link = '';
+    if (defined($method->{vars}->{type})){
+        $name = $method->{vars}->{type}[0];
+    } elsif (defined($method->{vars}->{returns}[0])){
+        if ($method->{vars}->{returns}[0] =~ s/\s*\{(\S+)(?:\s+([^}]+))?\}//){
+            $name = $1;
+            $link = $2;
+        $method->{vars}->{type} = [$name];
+    $name =~ s/^\s*(\S.*?)\s*$/$1/;
+    if ($$CLASSES{$name} || $link){
+        $link ||= link_to_class($name, $CURRENT_CLASS);
+        return qq|<a href="$link">$name</a>|;
+    $name;
+sub map_fields {
+    my $class = shift;
+    my @fields;
+    # Set up the instance fields
+    for my $type (qw(instance_fields class_fields)){
+        next unless $class->{$type};
+        for (sort {lc $a->{field_name} cmp lc $b->{field_name} }
+                @{$class->{$type}}){
+            &resolve_synonyms($_->{field_vars});
+            next if (!$OPTIONS{PRIVATE} && $_->{field_vars}->{private});
+            my $description = &resolve_inner_links($_->{field_description});
+            my $const_link = ($_->{field_vars}->{final} &&
+                    ($_->{field_value} =~ /^\-?\d+(\.\d+)?$/
+                    || $_->{field_value} =~ /^(["']).*\1$/))
+                ? $class->{classname} : '';
+            push @fields, {
+                field_name          => $_->{field_name},
+                field_description   => $description,
+                field_summary       => &get_summary($description),
+                is_final            => defined($_->{field_vars}->{final}),
+                is_private          => defined($_->{field_vars}->{private}),
+                is_class_field      => $type eq 'class_fields',
+                type                => &map_field_type($_),
+                const_link          => $const_link};
+   \@fields;
+# Map a field type
+sub map_field_type {
+    my ($field) = @_;
+    return 'Object' unless $field->{field_vars}->{type}[0];
+    my $name = $field->{field_vars}->{type}[0];
+    return sprintf('<a href="%s">%s</a>',
+            link_to_class($name, $CURRENT_CLASS), $name)
+        if $$CLASSES{$name};
+    $name;
+# Map all the inherited methods to a template parameter
+sub map_method_inheritance {
+    my @method_inheritance;
+    # Set up the inherited methods
+    if ($class->{inherits}){
+        my $superclassname = $class->{extends};
+        my $superclass = $$CLASSES{$superclassname};
+        while ($superclass){
+            if (!$superclass->{constructor_vars}->{private}
+                    || $OPTIONS{PRIVATE}){
+                my $methods =
+                    $class->{inherits}->{$superclassname}->{instance_methods};
+                push @method_inheritance, {
+                    superclass_name     => $superclassname,
+                    superclass_link     => link_to_class(
+                                                $superclassname,
+                                                $class->{classname}),
+                    inherited_methods   => join(', ',
+                        map(sprintf("<a href='%s#%s'>%s</a>",
+                                link_to_class(
+                                    $superclassname, $class->{classname}),
+                                $_, $_),
+                            &filter_private_methods(
+                                $methods, $superclassname)))}
+                                    if ($methods and @$methods);
+            $superclassname = $superclass->{extends};
+            $superclass = $superclassname ? $$CLASSES{$superclassname} : undef;
+    \@method_inheritance;
+# Map all the inherited fields to a template parameter
+sub map_field_inheritance {
+    my @field_inheritance;
+    # Set up the inherited fields
+                my $fields =
+                    $class->{inherits}->{$superclassname}->{instance_fields};
+                push @field_inheritance, {
+                                                $superclassname,
+                    inherited_fields    => join(', ',
+                                link_to_class(
+                                $_, $_),
+                            &filter_private_fields($fields, $superclassname)))}
+                                if ($fields and @$fields);
+    \@field_inheritance;
+# Filter out private inherited methods
+sub filter_private_methods {
+    my ($methods, $superclassname) = @_;
+    my @visible_methods;
+    for my $method(@$methods){
+        for my $super_method
+                (@{$$CLASSES{$superclassname}->{instance_methods}}){
+            push @visible_methods, $method
+                if $method eq $super_method->{mapped_name} and
+                    (!$super_method->{vars}->{private} || $OPTIONS{PRIVATE});
+    @visible_methods;
+# Filter out private inherited fields
+sub filter_private_fields {
+    my ($fields, $superclassname) = @_;
+    my @visible_fields;
+    for my $field (@$fields){
+        for my $super_field(@{$$CLASSES{$superclassname}->{instance_fields}}){
+            push @visible_fields, $field
+                if $field eq $super_field->{field_name} and
+                    (!$super_field->{field_vars}->{private}
+                        || $OPTIONS{PRIVATE});
+    @visible_fields;
+# Builds up the listing of subclasses, implemented interfaces, and
+# who implements this interface
+sub get_class_hierarchy_metadata {
+    my @meta;
+    # Find all the direct subclasses
+    my $subclasses = join(', ',
+        map { make_link($_, $classname) } @{&find_subclasses($classname)});
+    if ($subclasses){
+        push @meta, { title => 'Direct Known Subclasses',
+                        data => $subclasses };
+    my $implemented_interfaces = join(', ',
+            @{$class->{constructor_vars}->{implements} || []});
+    if ($implemented_interfaces){
+        push @meta, { title => 'All Implemented Interfaces',
+                        data => $implemented_interfaces };
+    my $implemented_by = join(', ',
+            @{$class->{constructor_vars}->{implemented_by} || []});
+    if ($implemented_by){
+        push @meta, { title => 'All Known Implementing Classes',
+                        data => $implemented_by };
+    return \@meta;
+# Adds a class's information to the global INDEX list
+sub add_to_index {
+    my ($class, $classname) = @_;
+    push @INDEX, {
+        name        => $classname,
+        class       => $classname,
+        classlink   => link_to_class($classname),
+        type        => '', linkname => ''
+    if (!$class->{constructor_args}){
+        $class->{constructor_args} = '';
+    } else {
+        push @INDEX, {
+            name        => "$classname$class->{constructor_args}",
+            type        => 'Constructor in ',
+            linkname    => 'constructor_detail' };
+    for my $mtype (qw(class_methods instance_methods)){
+        my $type = sprintf('%s method in ',
+            $mtype eq 'class_methods' ? 'Class' : 'Instance');
+        push @INDEX, {
+            name        => "$_->{mapped_name}$_->{argument_list}",
+            type        => $type,
+            linkname    => $_->{mapped_name}}
+                for grep {
+                    not($_->{vars}->{private} and not $OPTIONS{PRIVATE})
+                } @{$class->{$mtype}};
+    for my $ftype (qw(class_fields instance_fields)){
+        my $type = sprintf('%s field in ',
+            $ftype eq 'class_fields' ? 'Class' : 'Instance');
+        push @INDEX, {
+            type        => $type,
+            linkname    => $_->{field_name}}
+                for grep {
+                    not($_->{field_vars}->{private} and not $OPTIONS{PRIVATE})
+                } @{$class->{$ftype}};
+# Outputs the index page
+sub output_index_template {
+    @INDEX = sort {lc $a->{name} cmp lc $b->{name}} @INDEX;
+    my %letters;
+    for my $item (@INDEX){
+        my $letter = uc(substr($item->{name}, 0, 1));
+        $letter = uc(substr($item->{class}, 0, 1)) if $letter eq '';
+        push @{$letters{$letter}}, $item;
+    my $letter_list = [map {letter_name => $_},
+        sort {lc $a cmp lc $b} keys %letters];
+    &output_template(INDEX_ALL_TMPL, 'index-all.html', {
+        letters         => $letter_list,
+        ctime           => $TIME,
+        index_list      => [map {
+                                letter => $_->{letter_name},
+                                value => $letters{$_->{letter_name}}
+                           }, @{$letter_list}] });
+sub is_class_linkable {
+    my ($cname) = @_;
+    my $ret_val = defined($$CLASSES{$cname}) && $$CLASSES{$cname}->{filepath};
+    $ret_val ||= 0;
+    return $ret_val;
+# Recursively builds up the overview tree
+sub build_tree {
+    my $parentclassname = shift || '';
+    my $ret = "";
+    for my $cname (map {$_->{classname}} @CLASSNAMES) {
+        next if $cname eq $OPTIONS{GLOBALS_NAME};
+        my $class = $$CLASSES{$cname};
+        my $parent = $class->{extends} || '-';
+        if ((!$parentclassname && $parent eq '-')
+                or ($parent eq $parentclassname)) {
+            $ret .= is_class_linkable($cname) ? sprintf(qq{
+                <LI TYPE="circle"><B>%s</B></LI> },
+                    make_link($cname))
+                : qq{
+                $cname</LI>
+            my $childrentree .= &build_tree($cname);
+            $ret = "$ret$childrentree" if $childrentree;
+    $ret = "<UL>$ret</UL>" unless not $ret;
+    if ($parentclassname eq ''){
+        $ret = qq{<UL><LI TYPE="circle">Object</LI>$ret</UL>};
+    $ret;
+# Outputs the overview tree
+sub output_tree_template {
+    my $tree = &build_tree();
+    &output_template(TREE_TMPL, 'overview-tree.html', {
+        classtrees      => $tree,
+        ctime           => $TIME }, 1);
+# Formats additional non-standard attributes for methods according to user
+# configuration
+sub format_method_attributes {
+    my ($attrs) = shift;
+    my $attributes = '';
+    while (my ($name, $val) = each %{$attrs}) {
+        $attributes .= &{$METHOD_ATTRS_MAP{$name}}($val)
+            if $METHOD_ATTRS_MAP{$name};
+    $attributes;
+# Formats additional non-standard attributes for classes according to user
+# configuration
+sub format_class_attributes {
+    my $attributes;
+    if ($attrs->{class} && @{ $attrs->{class} }){
+        $attributes = sprintf('<BR/>%s<BR/>', $attrs->{class}[0] || '')
+        $attributes .= &{$CLASS_ATTRS_MAP{$name}}($val)
+            if $CLASS_ATTRS_MAP{$name};
+    $attributes;
+# Parses the command line options
+sub parse_cmdline {
+    $OPTIONS{OUTPUT} = DEFAULT_DEST_DIR;
+    $OPTIONS{PROJECT_NAME} = '';
+    $OPTIONS{COPYRIGHT} = '';
+    $OPTIONS{PROJECT_SUMMARY} = '';
+    $OPTIONS{GLOBALS_NAME} = 'GLOBALS';
+    $OPTIONS{FORMAT} = 'html';
+    $OPTIONS{EXTENSIONS} = 'js';
+    $OPTIONS{TEMPLATEDIR} = LOCATION;
+    GetOptions(
+        'private|p'             => \$OPTIONS{PRIVATE},
+        'directory|d=s'         => \$OPTIONS{OUTPUT},
+        'help|h'                => \$OPTIONS{HELP},
+        'recursive|r'           => \$OPTIONS{RECURSIVE},
+        'page-footer=s'         => \$OPTIONS{PAGE_FOOTER},
+        'project-name=s'        => \$OPTIONS{PROJECT_NAME},
+        'project-summary=s'     => \$OPTIONS{PROJECT_SUMMARY},
+        'logo=s'                => \$OPTIONS{LOGO},
+        'globals-name=s'        => \$OPTIONS{GLOBALS_NAME},
+        'quiet|q'               => \$OPTIONS{QUIET},
+        'no-sources'            => \$OPTIONS{NO_SRC},
+        'nested-file-naming'    => \$OPTIONS{NESTEDFILENAMING},
+        'format=s'              => \$OPTIONS{FORMAT},
+        'extensions=s'          => \$OPTIONS{EXTENSIONS},
+        'no-lexical-privates'   => \$OPTIONS{NO_LEXICAL_PRIVATES},
+        'template-dir=s'        => \$OPTIONS{TEMPLATEDIR},
+        'package-naming'        => \$OPTIONS{PACKAGENAMING});
+    $OPTIONS{OUTPUT} =~ s/([^\/])$/$1\//;
+# Resolves links for {@link } items
+sub resolve_inner_links {
+    my $doc = shift;
+    $doc =~ s{\{\@link\s+([^\}]+)\}}{&format_link($1)}eg if $doc;
+    return $doc;
+sub link_to_class {
+    my ($toclass, $fromclass) = @_;
+    $fromclass ||= '';
+    $toclass = strip($toclass);
+    $fromclass = strip($fromclass);
+    $toclass = $CLASSES->{$toclass}->{filepath};
+    $fromclass = $CLASSES->{$fromclass}->{filepath} if $fromclass;
+    my $fromslashes = ($fromclass =~ tr/\///);
+    my $link = ('../' x $fromslashes);
+    $link .= $toclass if $toclass;
+    return $link;
+sub make_link {
+    if (is_class_linkable($toclass)){
+        my $link = link_to_class($toclass, $fromclass);
+        return "<a href='$link'>$toclass</a>";
+    return $toclass;
+sub path_to_base {
+    my ($fromclass) = @_;
+    $fromclass = $CLASSES->{$fromclass}->{filepath};
+    my $path = '../' x $fromslashes;
+    return $path;
+# Formats a {@link } item
+sub format_link {
+    my ($link) = shift;
+    die unless $CURRENT_CLASS;
+    $link = strip($link);
+    $link =~ s/<[^>]*>//g;
+    my ($class, $method, $label, $url);
+    my $class_re = qr/\w+(?:\.\w+)*/;
+    unless ((($class, $method, $label) =
+        $link =~ /^($class_re)?#($class_re)\s*(.*)$/)
+                or (($class, $label) = $link =~ /^($class_re)(?:\s+(.*))?$/)){
+            if (($url, $label) = $link =~ /^(https?:\/\/\S+)\s+(.*?)\s*$/){
+                return "<a href='$url'>$label</a>";
+            } else {
+                return $link;
+    if ($class){
+        unless ($$CLASSES{$class}){
+            warn "\@link can't find reference $class\n";
+            return $link;
+    my $classlink = ($class && defined($$CLASSES{$class}))
+            ? link_to_class($class, $CURRENT_CLASS) : '';
+    if (!$method){
+        $label = $class unless $label;
+        qq{<a href="$classlink#">$label</a>};
+    } else {
+        my $clss = $CLASSES->{$class || $CURRENT_CLASS};
+        my @methods = (@{$clss->{instance_methods}},
+                        @{$clss->{class_methods}});
+        my @fields = (@{$clss->{instance_fields}}, @{$clss->{class_fields}});
+        my @statics = (@{$clss->{class_methods}}, @{$clss->{class_fields}});
+        my $ismethod = grep { $_->{mapped_name} eq $method } @methods;
+        my $isfield = grep { $_->{field_name} eq $method } @fields
+            unless $ismethod;
+        my $isstatic = grep {
+            ($_->{field_name} || $_->{mapped_name}) eq $method } @statics;
+        if ($class){
+            $label = "$class.$method" . ($ismethod ? '()' : '') unless $label;
+            if ($ismethod or $isfield){
+                $method = ($isstatic ? "!s!" : "") . $method;
+                return qq{<a href="$classlink#$method">$label</a>};
+            } else {
+                warn "\@link can't find reference $method in $class\n";
+                return $link;
+        } else {
+            $label =  $method . ($ismethod ? "()" : "") unless $label;
+            return qq{<a href="#$method">$label</a>};
+# Initializes the customizable maps for @attributes
+sub initialize_param_maps {
+    %CLASS_ATTRS_MAP  = (
+        author =>
+            sub {
+                '<B>Author:</B> ' .
+                    join(', ', @{$_[0]}) . "<BR/>"
+        deprecated =>
+            sub {
+                '<B>Deprecated</B> <I>' . ($_[0] ? $_[0]->[0] : '') .
+                "</I><BR/><BR/>";
+        see =>
+            sub {
+                '<B>See:</B><UL>- ' .
+                join('<BR/>- ', map {&format_link($_)} @{$_[0]}) . "</UL>"
+        version =>
+            sub {
+                '<B>Version: </B>' .
+                    join(', ', @{$_[0]}) . '<BR/><BR/>'
+        requires =>
+            sub {
+                '<B>Requires:</B><UL>- ' .
+        filename =>
+            sub {
+                sprintf '<I>Defined in %s</I><BR/><BR/>',
+                    sprintf("<a href='%soverview-summary-%s.html'>%s</a>",
+                        path_to_base($CURRENT_CLASS),mangle($_[0]), $_[0]);
+        overviewfile =>
+            sub {
+                my ($content, $fh) = "";
+                my $fname = $_[0][0] or return '';
+                unless(open $fh, "$fname"){
+                    warn "Can't open overview file '$fname' : $!\n";
+                    return '';
+                { local $/ = undef; $content .= <$fh> }
+                close $fh or warn "Couldn't close overview file '$fname'\n";
+                # Crude manner to strip out extra HTML
+                $content =~ s/<body>(.*)<\/body>/$1/si;
+                "$content<br/>";
+    %METHOD_ATTRS_MAP = (
+        throws =>
+            sub {
+            "<B>Throws:</B><UL>- " .
+            join("<BR>- ", @{$_[0]}) . "</UL>"
+    $METHOD_ATTRS_MAP{exception} = $METHOD_ATTRS_MAP{throws};
+    $METHOD_ATTRS_MAP{$_} = $CLASS_ATTRS_MAP{$_} for qw(author version
+                                                      deprecated see requires);
+    $FILE_ATTRS_MAP{$_} = $CLASS_ATTRS_MAP{$_} for qw(author version
+                                                      see requires);
+# Parse the @param or @argument values into name/value pairs and
+# return the list of them
+sub fetch_args {
+    my ($vars, $arg_list) = @_;
+    return ([], $arg_list) unless $vars and $arg_list;
+    my (@args, %used);
+    for my $arg (split /\W+(?<!\$)/, ($arg_list =~ /\(([^)]*)/)[0]){
+        for (@{$vars->{param}}){
+            my ($type, $link, $name, $value) =
+                    \{\s*
+                        (\S+)                   # type name
+                        (?:\s+(\S+)\s*)?        # optional link
+                    \s*
+                    (\$?\w+)                    # parameter name
+                    (.*)                        # description
+                /x;
+            next unless $name eq $arg;
+            $used{$name} = 1;
+            $type ||= '';
+            if ($$CLASSES{$type} || $link){
+                $link ||= $type;
+                if ($CLASSES->{$link}){
+                    $type =  sprintf('<a href="%s">%s</a>',
+                        link_to_class($link, $CURRENT_CLASS), $type);
+                } else {
+                        "$link.html", $type);
+            my $type_regex = qr{\Q$arg\E\b};
+            $arg_list =~ s/(?<!gt; )($type_regex)/&lt;$type&gt; $1/
+                if $type;
+            push @args, { varname => $name, vardescrip => $value};
+            = /(?:\{\s*(\S+)(?:\s+(\S+)\s*)?\})?\s*(\$?\w+)(.*)/;
+        next if $used{$name};
+        push @args, { varname => $name, vardescrip => $value };
+    return (\@args, $arg_list);
+sub resolve_synonyms {
+    my ($item) = @_;
+    $item->{param} = $item->{param} || $item->{argument};
+    $item->{returns} = $item->{return} || $item->{returns};
+    $item->{final} = $item->{final} || $item->{const};
+# Log a message to STDOUT if the --quiet switch is not used
+sub _log {
+    print $_[0], "\n" unless $OPTIONS{QUIET};
+# Takes a vars hash and resolves {@link}s within it
+sub format_vars {
+    my ($vars) = @_;
+    for my $key (keys %$vars){
+        if (ref($vars->{$key}) eq 'ARRAY'){
+            for (0..$#{$vars->{$key}}){
+                $vars->{$key}->[$_] = &resolve_inner_links($vars->{$key}->[$_]);
+        } else {
+            $vars->{$key} = &resolve_inner_links($vars->{$key});
+# Util methods
+sub strip {
+    my ($value) = @_;
+    return $value unless $value;
+    $value =~ s/^\s*(.*?)\s*$/$1/;
+    return $value;
+sub has_method {
+    my ($classname, $mname) = @_;
+    for my $method (@{$class->{instance_methods}}){
+        if ($method->{mapped_name} eq $mname){
+            return 1;
+    return 0;
Property changes on: trunk/build/JSDoc/jsdoc.pl
___________________________________________________________________
Added: trunk/build/JSDoc/main.tmpl
--- trunk/build/JSDoc/main.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/main.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,448 @@
+<!--NewPage-->
+<HTML>
+<HEAD>
+<TITLE>
+<TMPL_VAR name="classname">
+</TITLE>
+<LINK REL ="stylesheet" TYPE="text/css" HREF="<TMPL_VAR NAME="path_to_base">stylesheet.css" TITLE="Style">
+</HEAD>
+<SCRIPT>
+function asd()
+parent.document.title="<TMPL_VAR name="classname">";
+</SCRIPT>
+<TR>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="<TMPL_VAR NAME="path_to_base">overview-summary.html"><FONT CLASS="NavBarFont1"><B>Overview</B></FONT></A>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1"> <TMPL_IF NAME="file_overview"> <A HREF="<TMPL_VAR NAME="path_to_base"><TMPL_VAR NAME="file_overview">"></TMPL_IF><FONT CLASS="NavBarFont1"><TMPL_IF NAME="file_overview"><B></TMPL_IF>File<TMPL_IF NAME="file_overview"></B></TMPL_IF></FONT><TMPL_IF NAME="file_overview"></A></TMPL_IF>&nbsp;</TD>
+  <TD BGCOLOR="#FFFFFF" CLASS="NavBarCell1Rev">&nbsp;<FONT CLASS="NavBarFont1Rev"><B>Class</B></FONT>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="<TMPL_VAR NAME="path_to_base">overview-tree.html"><FONT CLASS="NavBarFont1"><B>Tree</B></FONT></A>&nbsp;</TD>
+  <!--TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1"-->    <!--A HREF="deprecated-list.html"--><!--FONT CLASS="NavBarFont1">Deprecated</FONT--><!--/A--><!--&nbsp;</TD-->
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="<TMPL_VAR NAME="path_to_base">index-all.html"--><FONT CLASS="NavBarFont1"><B>Index</B></FONT></A>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="<TMPL_VAR NAME="path_to_base">help-doc.html"><FONT CLASS="NavBarFont1"><B>Help</B></FONT></A>&nbsp;</TD>
+  </TR>
+</TABLE>
+</TD>
+</EM>
+</TD
+</TR>
+<TR>
+&nbsp;<TMPL_IF NAME="prev_class"><A HREF="<TMPL_VAR NAME="prev_class">"></TMPL_IF><B>PREV CLASS</B><TMPL_IF NAME="prev_class"></A></TMPL_IF><!--
+   NEXT CLASS
+&nbsp;<TMPL_IF NAME="next_class"><A HREF="<TMPL_VAR NAME="next_class">"></TMPL_IF><B>NEXT CLASS</B><TMPL_IF NAME="next_class"></A></TMPL_IF></FONT></TD>
+  <A HREF="<TMPL_VAR NAME="path_to_base">index.html" TARGET="_top"><B>FRAMES</B></A>  &nbsp;
+&nbsp;<A HREF="" TARGET="_top"><B>NO FRAMES</B></A>  &nbsp;
+&nbsp;
+<SCRIPT>
+  if(window==top) {
+    document.writeln('<A HREF="<TMPL_VAR NAME="path_to_base">allclasses-noframe.html" TARGET=""><B>All Classes</B></A>');
+</SCRIPT>
+<NOSCRIPT>
+<A HREF="<TMPL_VAR NAME="path_to_base">allclasses-noframe.html" TARGET=""><B>All Classes</B></A>
+</NOSCRIPT>
+</FONT></TD>
+</TR>
+<TR>
+<TD VALIGN="top" CLASS="NavBarCell3"><FONT SIZE="-2">
+  SUMMARY:&nbsp;<A HREF="#field_summary">FIELD</A>&nbsp;|&nbsp;<A HREF="#constructor_summary">CONSTR</A>&nbsp;|&nbsp;<A HREF="#method_summary">METHOD</A></FONT></TD>
+DETAIL:&nbsp;<A HREF="#field_detail">FIELD</A>&nbsp;|&nbsp;<A HREF="#constructor_detail">CONSTR</A>&nbsp;|&nbsp;<A HREF="#method_detail">METHOD</A></FONT></TD>
+</TR>
+</TABLE>
+<HR>
+<!-- ======== START OF CLASS DATA ======== -->
+<H2>Class <TMPL_VAR NAME="classname"></H2>
+<PRE><TMPL_VAR name="class_tree"></PRE>
+<TMPL_IF NAME="hierarchy_meta">
+   <TMPL_LOOP NAME="hierarchy_meta">
+      <DL>
+      <DT>
+         <B><TMPL_VAR NAME="title">:</B>
+         <DD>
+                  <TMPL_VAR NAME="data">
+         </DD>
+      </DL>
+   </TMPL_LOOP>
+</TMPL_IF>
+<HR>
+<DL>
+   <!-- Class definition -->
+   <DT><TMPL_IF NAME="class_attribs"><TMPL_VAR NAME="class_attribs">&nbsp;</TMPL_IF>class
+   <B><TMPL_VAR NAME="classname"></B>
+   <TMPL_IF NAME="superclass">
+      <DT>extends <TMPL_VAR NAME="superclass">
+   </TMPL_IF>
+</DL>
+   <TMPL_IF NAME="class_summary">
+   <P>
+   <TMPL_VAR name="class_summary">
+   </P>
+   </TMPL_IF>
+   <HR>
+<!-- ======== NESTED CLASS SUMMARY ======== -->
+<TMPL_IF NAME="inner_classes">
+<A NAME="inner_classes"><!-- --></A>
+<TABLE BORDER="1" CELLPADDING="3" CELLSPACING="0" WIDTH="100%">
+<TR BGCOLOR="#CCCCFF" CLASS="TableHeadingColor">
+<TD COLSPAN=2><FONT SIZE="+2">
+<B>Nested Class Summary</B></FONT></TD>
+</TR>
+<TMPL_LOOP name="inner_classes">
+   <TR BGCOLOR="white" CLASS="TableRowColor">
+   <TD ALIGN="right" VALIGN="top" WIDTH="1%"><FONT SIZE="-1">
+   <CODE>&lt;static&nbsp;class&gt;</CODE></FONT></TD>
+   <TD><CODE><B><A HREF="<TMPL_VAR name="classlink">"><TMPL_VAR name="classname"></A></B></CODE></TD>
+   </TR>
+</TMPL_LOOP>
+</TABLE>
+&nbsp;
+</TMPL_IF>
+<!-- ======== END NESTED CLASS SUMMARY ======== -->
+<!-- =========== FIELD SUMMARY =========== -->
+<TMPL_IF NAME="fields">
+   <A NAME="field_summary"><!-- --></A>
+      <TABLE BORDER="1" CELLPADDING="3" CELLSPACING="0" WIDTH="100%">
+         <TR BGCOLOR="#CCCCFF" CLASS="TableHeadingColor">
+            <TD COLSPAN=2><FONT SIZE="+2">
+               <B>Field Summary</B></FONT></TD>
+         </TR>
+   <!-- This is one instance field summary -->
+   <TMPL_LOOP name="fields">
+   <CODE><TMPL_IF NAME="is_private">&lt;private&gt;&nbsp;</TMPL_IF><TMPL_IF NAME="is_class_field">&lt;static&gt; </TMPL_IF><TMPL_IF NAME="is_final">&nbsp;&lt;final&gt;</TMPL_IF>&nbsp;<TMPL_VAR NAME="type"></CODE></FONT></TD>
+   <TD><CODE><B><A HREF="#<TMPL_IF NAME="is_class_field">!s!</TMPL_IF><TMPL_VAR name="field_name">"><TMPL_VAR name="field_name"></A></B></CODE>
+   <BR>
+   &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<TMPL_VAR name="field_summary"></TD>
+   </TR>
+   </TMPL_LOOP>
+   </TABLE>
+   &nbsp;
+   </TMPL_IF>
+   <TMPL_LOOP name="field_inheritance">
+   <TMPL_IF NAME="inherited_fields">
+   &nbsp;<A NAME=""><!-- --></A>
+   <TD><B>Fields inherited from class <A HREF="<TMPL_VAR name="superclass_link">"><TMPL_VAR name="superclass_name"></A></B></TD>
+   </TR>
+   <TD><CODE>
+   <TMPL_VAR NAME="inherited_fields">
+   </CODE></TD>
+   </TR>
+</TABLE>
+&nbsp;
+</TMPL_IF>
+</TMPL_LOOP>
+<!-- =========== END FIELD SUMMARY =========== -->
+<!-- ======== CONSTRUCTOR SUMMARY ======== -->
+<TMPL_IF NAME="constructor_args">
+<A NAME="constructor_summary"><!-- --></A>
+<B>Constructor Summary</B></FONT></TD>
+</TR>
+<TR BGCOLOR="white" CLASS="TableRowColor">
+   <TD>
+      <CODE>
+	 <B>
+	    <A HREF="#<TMPL_VAR name="classname">()"><TMPL_VAR name="classname"></A></B><TMPL_VAR name="constructor_args">
+      </CODE>
+      <BR>
+      &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
+      <TMPL_VAR name="constructor_summary">
+      </TD>
+</TR>
+</TABLE>
+</TMPL_IF>
+<!-- ======== END CONSTRUCTOR SUMMARY ======== -->
+&nbsp;
+<!-- ========== METHOD SUMMARY =========== -->
+<TMPL_IF NAME="methods">
+<A NAME="method_summary"><!-- --></A>
+<B>Method Summary</B></FONT></TD>
+</TR>
+<TMPL_LOOP name="methods">
+	 <FONT SIZE="-1">
+	    <CODE><TMPL_IF NAME="is_class_method">&lt;static&gt;</TMPL_IF><TMPL_IF NAME="is_private">&nbsp;&lt;private&gt; </TMPL_IF>&nbsp;<TMPL_VAR NAME="type"></CODE>
+	 </FONT>
+      </TD>
+      <TD>
+	 <CODE>
+	    <B>
+	       <A HREF="#<TMPL_IF NAME="is_class_method">!s!</TMPL_IF><TMPL_VAR name="method_name">"><TMPL_VAR name="method_name"></A></B><TMPL_VAR name="method_arguments">
+	 </CODE>
+	 <BR>
+	 <TMPL_VAR name="method_summary">
+      </TD>
+   </TR>
+</TMPL_LOOP>
+</TABLE>
+</TMPL_IF>
+<TMPL_LOOP name="method_inheritance">
+&nbsp;<A NAME="methods_inherited_from_class_java.lang.Object"><!-- --></A>
+<TR BGCOLOR="#EEEEFF" CLASS="TableSubHeadingColor">
+<TD><B>Methods inherited from class <a href="<TMPL_VAR name="superclass_link">"><TMPL_VAR name="superclass_name"></a></B></TD>
+</TR>
+<TD><CODE>
+<!-- Inherited methods -->
+<TMPL_VAR NAME="inherited_methods">
+</CODE></TD>
+</TR>
+</TABLE>
+&nbsp;
+</TMPL_LOOP>
+<P>
+<!-- ========== END METHOD SUMMARY =========== -->
+<!-- ============ FIELD DETAIL START =========== -->
+   <A NAME="field_detail"><!-- --></A>
+         <TD COLSPAN=1><FONT SIZE="+2"><B>Field Detail</B></FONT></TD>
+      </TR>
+   </TABLE>
+   <TMPL_LOOP NAME="fields">
+   <A NAME="<TMPL_IF NAME="is_class_field">!s!</TMPL_IF><TMPL_VAR NAME="field_name">"><!-- --></A>
+   <H3><TMPL_VAR NAME="field_name"></H3>
+   <PRE><TMPL_IF NAME="is_private">&lt;private&gt;&nbsp;</TMPL_IF><TMPL_IF NAME="is_class_field">&lt;static&gt;&nbsp;</TMPL_IF><TMPL_IF NAME="is_final">&lt;final&gt;&nbsp;</TMPL_IF><TMPL_VAR NAME="type">&nbsp;<B><TMPL_VAR NAME="field_name"></B></PRE>
+   <UL>
+   <TMPL_VAR NAME="field_description">
+   <TMPL_IF NAME="const_link">
+    <P>
+    <DL>
+    <DT><B>See Also:</B><DD><A HREF="constant-values.html#<TMPL_VAR NAME="const_link">.<TMPL_IF NAME="is_class_field">!s!</TMPL_IF><TMPL_VAR NAME="field_name">">Constant Field Values</A></DL>
+    </DL>
+   </TMPL_IF>
+   </UL>
+   <HR>
+   </TMPL_LOOP>
+</TMPL_IF>
+<!-- ============ FIELD DETAIL END =========== -->
+    <!-- ========= CONSTRUCTOR DETAIL START ======== -->
+<A NAME="constructor_detail"><!-- --></A>
+      <TD COLSPAN=1>
+      <FONT SIZE="+2"><B>Constructor Detail</B></FONT>
+      </TD>
+   </TR>
+</TABLE>
+<A NAME="<TMPL_VAR name="classname">()"><!-- --></A><H3>
+<TMPL_VAR name="classname"></H3>
+<PRE><B><TMPL_VAR name="classname"></B><TMPL_VAR name="constructor_args"></PRE>
+<TMPL_IF NAME="constructor_detail">
+<UL>
+   <TMPL_VAR name="constructor_detail">
+</UL>
+</TMPL_IF>
+<TMPL_IF name="constructor_params">
+   <UL>
+   <B>Parameters:</B>
+   <TMPL_LOOP name="constructor_params">
+     <UL><CODE><TMPL_VAR name="varname"></CODE> - <TMPL_VAR name="vardescrip">
+     </UL>
+   </TMPL_LOOP>
+   </TMPL_IF>
+   </UL>
+</TMPL_IF>
+<!-- Constructor return value(s) -->
+<TMPL_IF name="constructor_returns">
+   <UL>
+   <B>Returns:</B>
+     <UL>
+     <TMPL_VAR name="constructor_returns">
+     </UL>
+   </UL>
+</TMPL_IF>
+<!-- End constructor return value(s) -->
+<!-- ADDITIONAL ATTRIBUTES -->
+<TMPL_IF name="constructor_attrs">
+<UL>
+<TMPL_VAR name="constructor_attrs">
+</UL>
+</TMPL_IF>
+<HR/>
+<!-- END ADDITIONAL ATTRIBUTES  -->
+<!-- ========= CONSTRUCTOR DETAIL END ======== -->
+<!-- ============ METHOD DETAIL START ========== -->
+<A NAME="method_detail"><!-- --></A>
+         <B>Method Detail</B></FONT>
+      </TD>
+   </TR>
+</TABLE>
+<!-- One single method detail entry -->
+   <A NAME="<TMPL_IF NAME="is_class_method">!s!</TMPL_IF><TMPL_VAR name="method_name">"><!-- --></A>
+   <H3><TMPL_VAR name="method_name"></H3>
+   <PRE><TMPL_IF NAME="is_class_method">&lt;static&gt; </TMPL_IF><TMPL_IF NAME="is_private">&nbsp;&lt;private&gt; </TMPL_IF><TMPL_VAR NAME="type"> <B><TMPL_VAR name="method_name"></B><TMPL_VAR name="method_arguments"></PRE>
+   <TMPL_IF name="method_description">
+      <UL><TMPL_VAR name="method_description"></UL>
+   </TMPL_IF>
+   <!-- METHOD PARAMETERS START -->
+   <TMPL_IF name="method_params">
+   <UL>
+   <TMPL_LOOP name="method_params">
+      </UL>
+   </TMPL_LOOP>
+   </UL>
+   </TMPL_IF>
+   <!-- METHOD PARAMETERS END -->
+   <TMPL_IF name="method_returns">
+   <UL>
+   <B>Returns:</B>
+        <UL>
+        <TMPL_VAR name="method_returns">
+        </UL>
+   </UL>
+   </TMPL_IF>
+   <!-- ADDITIONAL ATTRIBUTES START -->
+   <TMPL_IF name="attributes">
+   <UL>
+   <TMPL_VAR name="attributes">
+   </UL>
+   </TMPL_IF>
+   <!-- ADDITIONAL ATTRIBUTES  END -->
+<HR>
+</TMPL_LOOP>
+</TMPL_IF>
+<!-- ============ METHOD DETAIL END ========== -->
+<!-- ========= END OF CLASS DATA ========= -->
+<TR>
+  <TD BGCOLOR="#FFFFFF" CLASS="NavBarCell1Rev"> &nbsp;<FONT CLASS="NavBarFont1Rev"><B>Class</B></FONT>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="<TMPL_VAR NAME="path_to_base">overview-tree.html"><FONT CLASS="NavBarFont1"><b>Tree</b></FONT></A>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="<TMPL_VAR NAME="path_to_base">index-all.html"><FONT CLASS="NavBarFont1"><B>Index</B></FONT></A>&nbsp;</TD>
+  </TR>
+</TABLE>
+</TD>
+</EM>
+</TD
+</TR>
+<TR>
+   NEXT CLASS
+&nbsp;
+<SCRIPT>
+  if(window==top) {
+</SCRIPT>
+<NOSCRIPT>
+</NOSCRIPT>
+</FONT></TD>
+</TR>
+<TR>
+</TR>
+</TABLE>
+<HR>
+<FONT SIZE="-1">
+</FONT>
+</BODY>
+</HTML>
Added: trunk/build/JSDoc/overview-frame.tmpl
--- trunk/build/JSDoc/overview-frame.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/overview-frame.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,43 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN""http://www.w3.org/TR/REC-html40/loose.dtd">
+<HTML>
+<HEAD>
+<TITLE>
+Overview ()
+</TITLE>
+<LINK REL ="stylesheet" TYPE="text/css" HREF="stylesheet.css" TITLE="Style">
+</HEAD>
+<SCRIPT>
+function asd()
+parent.document.title="Overview ()";
+</SCRIPT>
+<BODY BGCOLOR="white" onload="asd();">
+<TMPL_IF NAME="logo">
+   <IMG SRC="<TMPL_VAR NAME="logo">"/>
+</TMPL_IF>
+<H3 class="FrameHeadingFont"><B><TMPL_VAR NAME="project_name"></B></H3>
+<TABLE BORDER="0" WIDTH="100%">
+<TR>
+<B></B></FONT></TD>
+</TR>
+</TABLE>
+<TR>
+<TD NOWRAP><FONT CLASS="FrameItemFont"><A HREF="allclasses-frame.html" TARGET="packageFrame">All Classes</A></FONT>
+<P>
+<FONT size="+1" CLASS="FrameHeadingFont">
+<TMPL_VAR NAME="heading"></FONT>
+<BR>
+<TMPL_LOOP name="filenames">
+<FONT CLASS="FrameItemFont"><A HREF="<TMPL_VAR NAME="filelink">" TARGET="packageFrame"><TMPL_VAR NAME="filename"></A></FONT><BR>
+</TMPL_LOOP>
+</TD>
+</TR>
+</TABLE>
+<P>
+&nbsp;
+</BODY>
+</HTML>
Added: trunk/build/JSDoc/overview-summary.tmpl
--- trunk/build/JSDoc/overview-summary.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/overview-summary.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,222 @@
+<!doctype html public "-//W3C//DTD HTML 4.0 Frameset//EN""http://www.w3.org/TR/REC-html40/frameset.dtd">
+<html>
+<head>
+<title>
+<tmpl_var name="project_name"> Overview
+</title>
+<link rel ="stylesheet" type="text/css" href="stylesheet.css" title="Style">
+<script>
+function asd() {
+	<tmpl_if name="is_file_summary">
+		parent.document.title="<tmpl_var name="project_title"> Overview";
+	<tmpl_else>
+		parent.document.title="<tmpl_var name="project_name"> Overview";
+	</tmpl_if>
+</script>
+</head>
+<body bgcolor="white" onload="asd();">
+<!-- ========== START OF NAVBAR ========== -->
+<a name="navbar_top"><!-- --></a>
+<table border="0" width="100%" cellpadding="1" cellspacing="0">
+<tr>
+<td colspan=2 bgcolor="#EEEEFF" class="NavBarCell1">
+<a name="navbar_top_firstrow"><!-- --></a>
+<table border="0" cellpadding="0" cellspacing="3">
+  <tr align="center" valign="top">
+  <tmpl_unless name="is_file_summary">
+  <td bgcolor="#FFFFFF" class="NavBarCell1Rev">	&nbsp;<font class="NavBarFont1Rev"><b>Overview</b></font>&nbsp;</td>
+  <td bgcolor="#EEEEFF" class="NavBarCell1"> <font class="NavBarFont1">File</font>&nbsp;</td>
+  <tmpl_else>
+  <td bgcolor="#EEEEFF" class="NavBarCell1">    <a href="overview-summary.html"><font class="NavBarFont1"><b>Overview</b></font></a>&nbsp;</td>
+  <td bgcolor="#FFFFFF" class="NavBarCell1Rev">	&nbsp;<font class="NavBarFont1Rev"><b>File</b></font>&nbsp;</td>
+  </tmpl_unless>
+  <td bgcolor="#FFFFFF" class="NavBarCell1"> 	<font class="NavBarFont1">Class</font>&nbsp;</td>
+  <td bgcolor="#EEEEFF" class="NavBarCell1">    <a href="overview-tree.html"><font class="NavBarFont1"><b>Tree</b></font></a>&nbsp;</td>
+  <td bgcolor="#EEEEFF" class="NavBarCell1">    <a href="index-all.html"--><font class="NavBarFont1"><b>Index</b></font></a>&nbsp;</td>
+  <td bgcolor="#EEEEFF" class="NavBarCell1">    <a href="help-doc.html"><font class="NavBarFont1"><b>Help</b></font></a>&nbsp;</td>
+  </tr>
+</table>
+</td>
+<td bgcolor="#EEEEFF" align="right" valign="top">
+<em>
+<b><tmpl_var name="project_name"></b></em>
+</td>
+</tr>
+<tr>
+<td bgcolor="white" class="NavBarCell2"><font size="-2">
+&nbsp;PREV&nbsp;
+&nbsp;NEXT</font></td>
+  <a href="index.html" target="_top"><b>FRAMES</b></a>  &nbsp;
+&nbsp;<a href="overview-summary.html" target="_top"><b>NO FRAMES</b></a>
+&nbsp;&nbsp;
+<script>
+  if(window==top) {
+    document.writeln('<A HREF="allclasses-noframe.html" TARGET=""><B>All Classes</B></A>');
+</script>
+<noscript>
+<a href="allclasses-noframe.html" target=""><b>All Classes</b></a>
+</noscript>
+</font></td>
+</tr>
+</table>
+<!-- =========== END OF NAVBAR =========== -->
+<hr>
+<center>
+	<tmpl_if name="project_title">
+	   <h2><tmpl_var name="project_title"></h2>
+	<tmpl_else>
+	   <h2>JSDoc Documentation</h2>
+	</tmpl_if>
+</center>
+<tmpl_if name="project_title">
+	<tmpl_if name="generic">
+		<p>
+			This document is the API Specification for
+			<tmpl_var name="project_title">.
+		</p>
+	</tmpl_if>
+</tmpl_if>
+<h4>Summary</h4>
+<p>
+	<tmpl_if name="project_summary">
+		<tmpl_var name="project_summary">
+	<tmpl_else>
+    	No summary generated for these documents.
+	</tmpl_if>
+</p>
+<hr>
+<tmpl_if name="overviews">
+    <table border="1" cellpadding="3" cellspacing="0" width="100%">
+    <tr bgcolor="#CCCCFF" class="TableHeadingColor">
+    <td colspan=2><font size="+2">
+        <b>Class Summary</b>
+    <tmpl_else>
+        <b>File Summary</b>
+    </tmpl_if>
+    </font></td>
+    </tr>
+    <tmpl_loop name="overviews">
+    <tr bgcolor="white" class="TableRowColor">
+    <td width="15%"><b><a href="<TMPL_VAR NAME="link">"><tmpl_var name="name"></a></b></td>
+    <td><tmpl_var name="overview"></td>
+    </tr>
+    </tmpl_loop>
+    </table>
+    <hr/>
+</tmpl_if>
+<tmpl_if name="methods">
+	<a name="method_summary"><!-- --></a>
+			<td colspan=2>
+				<font size="+2">
+					<b>Method Summary</b>
+				</font>
+			</td>
+		</tr>
+		<tmpl_loop name="methods">
+		      <td align="right" valign="top" width="1%">
+			 <font size="-1">
+			    <code><tmpl_if name="is_class_method">static</tmpl_if><tmpl_if name="is_private">&nbsp;private </tmpl_if>&nbsp;<tmpl_var name="type"></code>
+			 </font>
+		      </td>
+		      <td>
+			 <code>
+			    <b>
+			       <a href="<TMPL_VAR NAME="file_link">#<TMPL_VAR name="method_anchor">"><tmpl_var name="method_name"></a></b><tmpl_var name="method_arguments">
+			 </code>
+			 <br>
+			 <tmpl_var name="method_summary">
+		      </td>
+		   </tr>
+		</tmpl_loop>
+	</table>
+    <p>
+</tmpl_if>
+<tmpl_if name="sourcecode">
+        <pre class="sourceview"><tmpl_var name="sourcecode"></pre>
+	<hr>
+</tmpl_if>
+<tr>
+  <tmpl_else>
+  </tmpl_unless>
+  </tr>
+</table>
+</td>
+<td bgcolor="#EEEEFF" align="right" valign="top"><em>
+</td>
+</tr>
+<tr>
+&nbsp;PREV&nbsp;
+&nbsp;&nbsp;
+<script>
+  if(window==top) {
+</script>
+<noscript>
+</noscript>
+</font></td>
+</tr>
+</table>
+<hr>
+<font size="-1">
+<tmpl_var name="page_footer">
+</font>
+<div class="jsdoc_ctime">Documentation generated by <a href="http://jsdoc.sourceforge.net/" target="_parent">JSDoc</a> on <tmpl_var name="ctime"></div>
+</body>
+</html>
Added: trunk/build/JSDoc/overview-tree.tmpl
--- trunk/build/JSDoc/overview-tree.tmpl	                        (rev 0)
+++ trunk/build/JSDoc/overview-tree.tmpl	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,121 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Frameset//EN""http://www.w3.org/TR/REC-html40/frameset.dtd">
+<!--NewPage-->
+<HTML>
+<HEAD>
+<TITLE>
+<TMPL_VAR name="project_name"> Class Hierarchy
+</TITLE>
+<LINK REL="stylesheet" TYPE="text/css" HREF="stylesheet.css" TITLE="Style">
+<SCRIPT>
+function asd()
+parent.document.title="<TMPL_VAR NAME="project_name"> Class Hierarchy";
+</SCRIPT>
+</HEAD>
+<A NAME="navbar_top"><!-- --></A>
+<TABLE BORDER="0" WIDTH="100%" CELLPADDING="1" CELLSPACING="0">
+<TR>
+<TD COLSPAN=3 BGCOLOR="#EEEEFF" CLASS="NavBarCell1">
+<A NAME="navbar_top_firstrow"><!-- --></A>
+<TABLE BORDER="0" CELLPADDING="0" CELLSPACING="3">
+  <TR ALIGN="center" VALIGN="top">
+  <TD BGCOLOR="#FFFFFF" CLASS="NavBarCell1"><A HREF="overview-summary.html"><FONT CLASS="NavBarFont1"><b>Overview</b></A></FONT>&nbsp;</TD>
+  <TD BGCOLOR="#FFFFFF" CLASS="NavBarCell1"> <FONT CLASS="NavBarFont1">File</FONT>&nbsp;</TD>
+  <TD BGCOLOR="#FFFFFF" CLASS="NavBarCell1"> <FONT CLASS="NavBarFont1">Class</FONT>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1Rev">  &nbsp;<FONT CLASS="NavBarFont1Rev"><b>Tree</b></FONT>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="index-all.html"--><FONT CLASS="NavBarFont1"><b>Index</b></FONT></A>&nbsp;</TD>
+  <TD BGCOLOR="#EEEEFF" CLASS="NavBarCell1">    <A HREF="help-doc.html"><FONT CLASS="NavBarFont1"><b>Help</b></FONT></A>&nbsp;</TD>
+  </TR>
+</TABLE>
+</TD>
+<TD BGCOLOR="#FFFFFF" ALIGN="right" VALIGN="top"><EM>
+<B><TMPL_VAR NAME="project_name"></B></EM>
+</TD>
+</TR>
+<TR>
+<TD BGCOLOR="white" CLASS="NavBarCell2"><FONT SIZE="-2">
+&nbsp;PREV&nbsp;
+&nbsp;NEXT</FONT></TD>
+  <A HREF="index.html" TARGET="_top"><B>FRAMES</B></A>  &nbsp;
+&nbsp;<A HREF="overview-summary.html" TARGET="_top"><B>NO FRAMES</B></A>
+&nbsp;&nbsp;
+<SCRIPT>
+  if(window==top) {
+</SCRIPT>
+<NOSCRIPT>
+<A HREF="allclasses-noframe.html" TARGET=""><B>All Classes</B></A>
+</NOSCRIPT>
+</FONT></TD>
+</TR>
+</TABLE>
+<HR>
+<H2>Class Hierarchy</H2>
+<TMPL_VAR name="classtrees">
+<HR>
+<TR>
+<TD COLSPAN=2 BGCOLOR="#EEEEFF" CLASS="NavBarCell1">
+  </TR>
+</TABLE>
+</TD>
+</TD>
+</TR>
+<TR>
+&nbsp;PREV&nbsp;
+&nbsp;&nbsp;
+<SCRIPT>
+  if(window==top) {
+</SCRIPT>
+<NOSCRIPT>
+</NOSCRIPT>
+</FONT></TD>
+</TR>
+</TABLE>
+<hr>
+<FONT SIZE="-1">
+<TMPL_VAR NAME="page_footer">
+</FONT>
+<div class="jsdoc_ctime">Documentation generated by <a href="http://jsdoc.sourceforge.net/" parent="_parent">JSDoc</a> on <TMPL_VAR NAME="ctime"></div>
+</BODY>
+</HTML>
Added: trunk/build/JSDoc/stylesheet.css
--- trunk/build/JSDoc/stylesheet.css	                        (rev 0)
+++ trunk/build/JSDoc/stylesheet.css	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,39 @@
+/* JSDoc style sheet */
+/* Define colors, fonts and other style attributes here to override the defaults */
+/* Page background color */
+body { background-color: #FFFFFF }
+/* Table colors */
+.TableHeadingColor     { background: #CCCCFF } /* Dark mauve */
+.TableSubHeadingColor  { background: #EEEEFF } /* Light mauve */
+.TableRowColor         { background: #FFFFFF } /* White */
+/* Font used in left-hand frame lists */
+.FrameTitleFont   { font-size: 10pt; font-family: Helvetica, Arial, san-serif }
+.FrameHeadingFont { font-size: 10pt; font-family: Helvetica, Arial, san-serif }
+.FrameItemFont    { font-size: 10pt; font-family: Helvetica, Arial, san-serif }
+/* Example of smaller, sans-serif font in frames */
+/* .FrameItemFont  { font-size: 10pt; font-family: Helvetica, Arial, sans-serif } */
+/* Navigation bar fonts and colors */
+.NavBarCell1    { background-color:#EEEEFF;}/* Light mauve */
+.NavBarCell1Rev { background-color:#00008B;}/* Dark Blue */
+.NavBarFont1    { font-family: Arial, Helvetica, sans-serif; color:#000000;}
+.NavBarFont1Rev { font-family: Arial, Helvetica, sans-serif; color:#FFFFFF;}
+.NavBarCell2    { font-family: Arial, Helvetica, sans-serif; background-color:#FFFFFF;}
+.NavBarCell3    { font-family: Arial, Helvetica, sans-serif; background-color:#FFFFFF;}
+.jsdoc_ctime    { font-family: Arial, Helvetica, sans-serif; font-size: 9pt;
+                    text-align: right }
+/* Sourcecode view */
+.sourceview { background: #FFFFFF }
+.attrib { color: #DD7777 }
+.comment { color: #55AA55 }
+.reserved { color: #FF5555 }
+.literal { color: #5555FF }
Added: trunk/build/JSDoc/test.js
--- trunk/build/JSDoc/test.js	                        (rev 0)
+++ trunk/build/JSDoc/test.js	2008-02-20 11:31:02 UTC (rev 2119)
@@ -0,0 +1,505 @@
+ * @fileoverview This file is to be used for testing the JSDoc parser
+ * It is not intended to be an example of good JavaScript OO-programming,
+ * nor is it intended to fulfill any specific purpose apart from
+ * demonstrating the functionality of the
+ * {@link http://sourceforge.net/projects/jsdoc JSDoc} parser
+ * @author Gabriel Reid gab_reid at users.sourceforge.net
+ * @version 0.1
+ * Construct a new Shape object.
+ * @class This is the basic Shape class.
+ * It can be considered an abstract class, even though no such thing
+ * really existing in JavaScript
+ * @constructor
+ * @throws MemoryException if there is no more memory
+ * @throws GeneralShapeException rarely (if ever)
+ * @return A new shape
+function Shape(){
+    * This is an example of a function that is not given as a property
+    * of a prototype, but instead it is assigned within a constructor.
+    * For inner functions like this to be picked up by the parser, the
+    * function that acts as a constructor <b>must</b> be denoted with
+    * the <b>&#64;constructor</b> tag in its comment.
+    * @type String
+   this.getClassName = function(){
+      return "Shape";
+    * This is a private method, just used here as an example
+   function addReference(){
+       // Do nothing...
+ * Create a new Hexagon instance.
+ * @extends Shape
+ * @class Hexagon is a class that is a <i>logical</i> sublcass of
+ * {@link Shape} (thanks to the <code>&#64;extends</code> tag), but in
+ * reality it is completely unrelated to Shape.
+ * @param {int} sideLength The length of one side for the new Hexagon
+function Hexagon(sideLength) {
+ * This is an unattached (static) function that adds two integers together.
+ * @param {int} One The first number to add
+ * @param {int http://jsdoc.sourceforge.net/} Two The second number to add
+ * @deprecated So you shouldn't use it anymore!
+function Add(One, Two){
+    return One + Two;
+ * The color of this shape
+ * @type Color
+Shape.prototype.color = null;
+ * The border of this shape.
+ * @type int
+Shape.prototype.border = null;
+ * The assignment of function implementations for Shape, documentation will
+ * be taken over from the method declaration.
+Shape.prototype.getCoords = Shape_GetCoords;
+Shape.prototype.getColor = Shape_GetColor;
+Shape.prototype.setCoords = Shape_SetCoords;
+Shape.prototype.setColor = Shape_SetColor;
+ * These are all the instance method implementations for Shape
+ * Get the coordinates of this shape. It is assumed that we're always talking
+ * about shapes in a 2D location here.
+ * @requires Shape The shape class
+ * @returns A Coordinate object representing the location of this Shape
+ * @type Coordinate
+function Shape_GetCoords(){
+   return this.coords;
+ * Get the color of this shape.
+ * @see #setColor
+ * @type Color
+function Shape_GetColor(){
+   return this.color;
+ * Set the coordinates for this Shape
+ * @param {Coordinate} coordinates The coordinates to set for this Shape
+function Shape_SetCoords(coordinates){
+   this.coords = coordinates;
+ * Set the color for this Shape
+ * @param {Color} color The color to set for this Shape
+ * @param other There is no other param, but it can still be documented if
+ *              optional parameters are used
+ * @throws NonExistantColorException (no, not really!)
+ * @see #getColor
+function Shape_SetColor(color){
+   this.color = color;
+ * Clone this shape
+ * @returns A copy of this shape
+ * @type Shape
+Shape.prototype.clone = function(){
+   return new Shape();
+ * Create a new Rectangle instance.
+ * @class A basic rectangle class, inherits from Shape.
+ * This class could be considered a concrete implementation class
+ * @constructor
+ * @param {int} width The optional width for this Rectangle
+ * @param {int} height Thie optional height for this Rectangle
+ * @see Shape Shape is the base class for this
+function Rectangle(width, // This is the width
+                  height // This is the height
+   if (width){
+      this.width = width;
+      if (height){
+	 this.height = height;
+/* Inherit from Shape */
+Rectangle.prototype = new Shape();
+ * Value to represent the width of the Rectangle.
+ * <br>Text in <b>bold</b> and <i>italic</i> and a
+ * link to <a href="http://sf.net">SourceForge</a>
+ * @private
+ * @type int
+Rectangle.prototype.width = 0;
+ * Value to represent the height of the Rectangle
+ * @private
+ * @type int
+Rectangle.prototype.height = 0;
+ * Get the type of this object.
+ * @type String
+Rectangle.prototype.getClassName= function(){
+    return "Rectangle";
+ * These are all the instance method implementations for Rectangle
+Rectangle.prototype.getWidth = Rectangle_GetWidth;
+Rectangle.prototype.getHeight = Rectangle_GetHeight;
+Rectangle.prototype.setWidth = Rectangle_SetWidth;
+Rectangle.prototype.setHeight = Rectangle_SetHeight;
+Rectangle.prototype.getArea = Rectangle_GetArea;
+ * Get the value of the width for the Rectangle
+ * @type int
+ * @see #setWidth
+function Rectangle_GetWidth(){
+   return this.width;
+ * Get the value of the height for the Rectangle.
+ * Another getter is the {@link Shape#getColor} method in the
+ * {@link Shape base Shape class}.
+ * @return The height of this Rectangle
+ * @type int
+ * @see #setHeight
+function Rectangle_GetHeight(){
+    return this.height;
+ * Set the width value for this Rectangle.
+ * @param {int} width The width value to be set
+ * @see #getWidth
+function Rectangle_SetWidth(width){
+ * Set the height value for this Rectangle.
+ * @param {int} height The height value to be set
+ * @see #getHeight
+function Rectangle_SetHeight(height){
+ * Get the value for the total area of this Rectangle
+ * @return total area of this Rectangle
+ * @type int
+function Rectangle_GetArea(){
+   return width * height;
+ * Create a new Square instance.
+ * @class A Square is a subclass of {@link Rectangle}
+ * @param {int} height The optional height for this Rectangle
+function Square(width, height){
+   if (width){
+      if (height){
+/* Square is a subclass of Rectangle */
+Square.prototype = new Rectangle();
+ * The assignment of function implementation for Shape.
+Square.prototype.setWidth = Square_SetWidth;
+Square.prototype.setHeight = Square_SetHeight;
+ * Set the width value for this Square.
+ * @see #getWidth
+function Square_SetWidth(width){
+   this.width = this.height = width;
+ * Set the height value for this Square
+ * Sets the {@link Rectangle#height height} attribute in the Rectangle.
+function Square_SetHeight(height){
+   this.height = this.width = height;
+ * Create a new Circle instance based on a radius.
+ * @class Circle class is another subclass of Shape
+ * @param {int} radius The optional radius of this Circle
+function Circle(radius){
+   if (radius){
+      this.radius = radius;
+/* Circle inherits from Shape */
+Circle.prototype = new Shape();
+ * The radius value for this Circle
+ * @private
+ * @type int
+Circle.prototype.radius = 0;
+ * A very simple class (static) field that is also a constant
+ * @final
+ * @type float
+Circle.PI = 3.14;
+Circle.createCircle = Circle_CreateCircle;
+Circle.prototype.getRadius = Circle_GetRadius;
+Circle.prototype.setRadius = Circle_SetRadius;
+ * Get the radius value for this Circle
+ * @type int
+ * @see #setRadius
+function Circle_GetRadius(){
+   return this.radius;
+ * Set the radius value for this Circle
+ * @param {int} radius The radius value to set
+ * @see #getRadius
+function Circle_SetRadius(radius){
+ * An example of a  class (static) method that acts as a factory for Circle
+ * objects. Given a radius value, this method creates a new Circle.
+ * @param {int} radius The radius value to use for the new Circle.
+ * @type Circle
+function Circle_CreateCircle(radius){
+    return new Circle(radius);
+ * Create a new Coordinate instance based on x and y grid data.
+ * @class Coordinate is a class that can encapsulate location information.
+ * @param {int} x The optional x portion of the Coordinate
+ * @param {int} y The optinal y portion of the Coordinate
+function Coordinate(x, y){
+   if (x){
+      this.x = x;
+      if (y){
+	 this.y = y;
+ * The x portion of the Coordinate
+ * @type int
+ * @see #getX
+ * @see #setX
+Coordinate.prototype.x = 0;
+ * The y portion of the Coordinate
+ * @type int
+ * @see #getY
+ * @see #setY
+Coordinate.prototype.y = 0;
+Coordinate.prototype.getX = Coordinate_GetX;
+Coordinate.prototype.getY = Coordinate_GetY;
+Coordinate.prototype.setX = Coordinate_SetX;
+Coordinate.prototype.setY = Coordinate_SetY;
+ * Gets the x portion of the Coordinate.
+ * @type int
+ * @see #setX
+function Coordinate_GetX(){
+   return this.x;
+ * Get the y portion of the Coordinate.
+ * @type int
+ * @see #setY
+function Coordinate_GetY(){
+   return this.y;
+ * Sets the x portion of the Coordinate.
+ * @param {int} x The x value to set
+ * @see #getX
+function Coordinate_SetX(x){
+   this.x = x;
+ * Sets the y portion of the Coordinate.
+ * @param {int} y The y value to set
+ * @see #getY
+function Coordinate_SetY(y){
+   this.y = y;
+ * @class This class exists to demonstrate the assignment of a class prototype
+ * as an anonymous block.
+function ShapeFactory(){
+ShapeFactory.prototype = {
+    * Creates a new {@link Shape} instance.
+    * @return A new {@link Shape}
+    * @type Shape
+   createShape: function(){
+ * An example of a singleton class
+MySingletonShapeFactory = new function(){
+    * Get the next {@link Shape}
+    * @type Shape
+   this.getShape = function(){
+      return null;
+ * Create a new Foo instance.
+ * @class This is the Foo class. It exists to demonstrate 'nested' classes.
+ * @constructor
+ * @see Foo.Bar
+function Foo(){}
+ * Creates a new instance of Bar.
+ * @class This class exists to demonstrate 'nested' classes.
+ * @constructor
+ * @see Foo.Bar
+function Bar(){}
+ * Nested class
+ * @constructor
+Foo.Bar = function(){this.x = 2;}
+Foo.Bar.prototype = new Bar();
+Foo.Bar.prototype.y = '3';
More information about the Mapbender_commits mailing list
