[Mapbender-commits] r1965 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jan 15 03:24:31 EST 2008
Author: christoph
Date: 2008-01-15 03:24:29 -0500 (Tue, 15 Jan 2008)
New Revision: 1965
Added:
   trunk/mapbender/http/classes/class_point.php
   trunk/mapbender/http/classes/class.ezpdf.php
   trunk/mapbender/http/classes/class.pdf.php
   trunk/mapbender/http/classes/class_administration.php
   trunk/mapbender/http/classes/class_bbox.php
   trunk/mapbender/http/classes/class_keyword.php
   trunk/mapbender/http/classes/class_kml.php
   trunk/mapbender/http/classes/class_layer_monitor.php
   trunk/mapbender/http/classes/class_locale.php
   trunk/mapbender/http/classes/class_metadata.php
   trunk/mapbender/http/classes/class_monitor.php
   trunk/mapbender/http/classes/class_wfs_conf.php
   trunk/mapbender/http/classes/class_wmc.php
   trunk/mapbender/http/classes/class_wms.php
added svn keywords
Property changes on: trunk/mapbender/http/classes/class.ezpdf.php
___________________________________________________________________
   + HeadURL Id LastChangedBy LastChangedDate LastChangedRevision
Property changes on: trunk/mapbender/http/classes/class.pdf.php
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php	2008-01-15 08:11:29 UTC (rev 1964)
+++ trunk/mapbender/http/classes/class_administration.php	2008-01-15 08:24:29 UTC (rev 1965)
@@ -977,7 +977,17 @@
 	function is_utf8_string($string) {
-		return preg_match('%(?:
+	    if (is_array($string))
+	        $enc = implode('', $string);
+	        return @!((ord($enc[0]) != 239) && (ord($enc[1]) != 187) && (ord($enc[2]) != 191));
+	    else
+	        return (utf8_encode(utf8_decode($string)) == $string);
+    		return preg_match('%(?:
 		[\xC2-\xDF][\x80-\xBF]        # non-overlong 2-byte
 		|\xE0[\xA0-\xBF][\x80-\xBF]               # excluding overlongs
 		|[\xE1-\xEC\xEE\xEF][\x80-\xBF]{2}      # straight 3-byte
@@ -986,6 +996,7 @@
 		|[\xF1-\xF3][\x80-\xBF]{3}                  # planes 4-15
 		|\xF4[\x80-\x8F][\x80-\xBF]{2}    # plane 16
 		)+%xs', $string);
 	function is_utf8_xml($xml) {
Modified: trunk/mapbender/http/classes/class_bbox.php
--- trunk/mapbender/http/classes/class_bbox.php	2008-01-15 08:11:29 UTC (rev 1964)
+++ trunk/mapbender/http/classes/class_bbox.php	2008-01-15 08:24:29 UTC (rev 1965)
@@ -23,138 +23,6 @@
 db_select_db(DB,$con);
- * A Mapbender_point is a 2-dimensional point with an EPSG.
-class Mapbender_point {
-	var $x;
-	var $y;
-	var $epsg;
-	 * @constructor
-	function __construct($x, $y, $epsg) {
-		if (!$x || !$y || !$epsg) {
-			$e = new mb_exception("Mapbender_point: constructor: some parameters are not set (set (x: ".$x.", y: ".$y.", epsg:".$epsg.")!");
-		$this->x = $x;
-		$this->y = $y;
-		$this->epsg = $epsg;
-	 * computes a new point with the minimal coordinates of this point and $point
-	static function min ($point1, $point2) {
-		if ($point1->epsg == $point2->epsg) {
-			if ($point1->isWestOf($point2)) {
-				$minx = $point1->x;
-			else {
-				$minx = $point2->x;
-			if ($point1->isSouthOf($point2)) {
-				$miny = $point1->y;
-			else {
-				$miny = $point2->y;
-			return new Mapbender_point($minx, $miny, $point1->epsg);
-		else {
-			$e = new mb_exception("Mapbender_point: cannot process min with different EPSG codes");
-	 * computes a new point with the maximal coordinates of this point and $point
-	static function max ($point1, $point2) {
-				$maxx = $point2->x;
-			else {
-				$maxx = $point1->x;
-				$maxy = $point2->y;
-			else {
-				$maxy = $point1->y;
-			return new Mapbender_point($maxx, $maxy, $point1->epsg);
-		else {
-	function isWestOf($point) {
-		if ($this->x < $point->x) {
-			return true;
-	function isSouthOf($point) {
-		if ($this->y < $point->y) {
-			return true;
-	 * Addition
-	 * @param anotherPoint another Mapbender_point
-	function plus ($anotherPoint) {
-		return new Mapbender_point($this->x + $anotherPoint->x, $this->y + $anotherPoint->y, $this->epsg);
-	 * Subtraction
-	function minus ($anotherPoint) {
-		return $this->plus($anotherPoint->times(-1));
-	 * Scalar multiplication
-	 * @param aFloat a floating point number
-	function times ($aFloat) {
-		return new Mapbender_point($this->x * $aFloat, $this->y * $aFloat, $this->epsg);
-	 * transforms this point to another EPSG
-	function transform($toEpsg) {
-		if(SYS_DBTYPE=='pgsql'){
-			$currentEpsg = preg_replace("/EPSG:/", "", $this->epsg);
-			$targetEpsg = preg_replace("/EPSG:/", "", $toEpsg);
-			$sql = "SELECT X(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as x, ";
-			$sql .= "Y(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as y";
-			$res = db_query($sql);
-			$point = new Mapbender_point(db_result($res,0,"x"), db_result($res,0,"y"), $toEpsg);
-			$this->x = $point->x;
-			$this->y = $point->y;
-			$this->epsg = $point->epsg;
-		else {
-			$e = new mb_exception("transformCoordinates needs PostgreSQL");
-	function __toString() {
-		return (string) "(" . $this->x . "," . $this->y . "," . $this->epsg . ")";
  * A bounding box consisting of an lower left and an upper right point, and an EPSG.
 class Mapbender_bbox {
Property changes on: trunk/mapbender/http/classes/class_bbox.php
   - Id
Property changes on: trunk/mapbender/http/classes/class_keyword.php
Modified: trunk/mapbender/http/classes/class_kml.php
--- trunk/mapbender/http/classes/class_kml.php	2008-01-15 08:11:29 UTC (rev 1964)
+++ trunk/mapbender/http/classes/class_kml.php	2008-01-15 08:24:29 UTC (rev 1965)
@@ -1,5 +1,5 @@
 <?php
-# $Id: class_wmc.php,v 1.31 2006/03/16 14:49:30 c_baudson Exp $
+# $Id$
 # http://www.mapbender.org/index.php/class_wmc.php
 # Copyright (C) 2002 CCGIS
Property changes on: trunk/mapbender/http/classes/class_kml.php
Modified: trunk/mapbender/http/classes/class_layer_monitor.php
--- trunk/mapbender/http/classes/class_layer_monitor.php	2008-01-15 08:11:29 UTC (rev 1964)
+++ trunk/mapbender/http/classes/class_layer_monitor.php	2008-01-15 08:24:29 UTC (rev 1965)
@@ -1,5 +1,5 @@
 <?php
-# $Id: class_layer_monitor.php 791 2007-08-10 10:36:04Z baudson $
+# $Id$
Property changes on: trunk/mapbender/http/classes/class_layer_monitor.php
Property changes on: trunk/mapbender/http/classes/class_locale.php
Property changes on: trunk/mapbender/http/classes/class_metadata.php
Modified: trunk/mapbender/http/classes/class_monitor.php
--- trunk/mapbender/http/classes/class_monitor.php	2008-01-15 08:11:29 UTC (rev 1964)
+++ trunk/mapbender/http/classes/class_monitor.php	2008-01-15 08:24:29 UTC (rev 1965)
@@ -1,5 +1,5 @@
 <?php
+# $Id$
Property changes on: trunk/mapbender/http/classes/class_monitor.php
Added: trunk/mapbender/http/classes/class_point.php
--- trunk/mapbender/http/classes/class_point.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_point.php	2008-01-15 08:24:29 UTC (rev 1965)
@@ -0,0 +1,158 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+ * A Mapbender_point is a 2-dimensional point with an EPSG.
+class Mapbender_point {
+	var $x;
+	var $y;
+	var $epsg;
+	 * @constructor
+	function __construct($x, $y, $epsg) {
+		if (!$x || !$y || !$epsg) {
+			$e = new mb_exception("Mapbender_point: constructor: some parameters are not set (set (x: ".$x.", y: ".$y.", epsg:".$epsg.")!");
+		$this->x = $x;
+		$this->y = $y;
+		$this->epsg = $epsg;
+	 * computes a new point with the minimal coordinates of this point and $point
+	static function min ($point1, $point2) {
+		if ($point1->epsg == $point2->epsg) {
+			if ($point1->isWestOf($point2)) {
+				$minx = $point1->x;
+			else {
+				$minx = $point2->x;
+			if ($point1->isSouthOf($point2)) {
+				$miny = $point1->y;
+			else {
+				$miny = $point2->y;
+			return new Mapbender_point($minx, $miny, $point1->epsg);
+		else {
+			$e = new mb_exception("Mapbender_point: cannot process min with different EPSG codes");
+	 * computes a new point with the maximal coordinates of this point and $point
+	static function max ($point1, $point2) {
+				$maxx = $point2->x;
+			else {
+				$maxx = $point1->x;
+				$maxy = $point2->y;
+			else {
+				$maxy = $point1->y;
+			return new Mapbender_point($maxx, $maxy, $point1->epsg);
+		else {
+	function isWestOf($point) {
+		if ($this->x < $point->x) {
+			return true;
+	function isSouthOf($point) {
+		if ($this->y < $point->y) {
+			return true;
+	 * Addition
+	 * @param anotherPoint another Mapbender_point
+	function plus ($anotherPoint) {
+		return new Mapbender_point($this->x + $anotherPoint->x, $this->y + $anotherPoint->y, $this->epsg);
+	 * Subtraction
+	function minus ($anotherPoint) {
+		return $this->plus($anotherPoint->times(-1));
+	 * Scalar multiplication
+	 * @param aFloat a floating point number
+	function times ($aFloat) {
+		return new Mapbender_point($this->x * $aFloat, $this->y * $aFloat, $this->epsg);
+	 * transforms this point to another EPSG
+	 * @param {Integer} toEpsg the coordinates are transformed to this EPSG code.
+	function transform($toEpsg) {
+		if(SYS_DBTYPE=='pgsql'){
+			$currentEpsg = preg_replace("/EPSG:/", "", $this->epsg);
+			$targetEpsg = preg_replace("/EPSG:/", "", $toEpsg);
+			$sql = "SELECT X(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as x, ";
+			$sql .= "Y(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as y";
+			$res = db_query($sql);
+			$point = new Mapbender_point(db_result($res,0,"x"), db_result($res,0,"y"), $toEpsg);
+			$this->x = $point->x;
+			$this->y = $point->y;
+			$this->epsg = $point->epsg;
+		else {
+			$e = new mb_exception("transformCoordinates needs PostgreSQL");
+	function __toString() {
+		return (string) "(" . $this->x . "," . $this->y . "," . $this->epsg . ")";
\ No newline at end of file
Property changes on: trunk/mapbender/http/classes/class_point.php
Modified: trunk/mapbender/http/classes/class_wfs_conf.php
--- trunk/mapbender/http/classes/class_wfs_conf.php	2008-01-15 08:11:29 UTC (rev 1964)
+++ trunk/mapbender/http/classes/class_wfs_conf.php	2008-01-15 08:24:29 UTC (rev 1965)
@@ -1,5 +1,5 @@
 <?php
-# $Id: class_wfs_conf.php 1032 2007-10-09 10:37:42Z baudson $
+# $Id$
 # http://www.mapbender.org/index.php/class_wfs_conf.php
Property changes on: trunk/mapbender/http/classes/class_wfs_conf.php
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2008-01-15 08:11:29 UTC (rev 1964)
+++ trunk/mapbender/http/classes/class_wmc.php	2008-01-15 08:24:29 UTC (rev 1965)
@@ -1,5 +1,5 @@
 <?php
-# $Id: class_wmc.php 1233 2007-10-19 14:28:21Z baudson $
+# $Id$
Property changes on: trunk/mapbender/http/classes/class_wmc.php
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php	2008-01-15 08:11:29 UTC (rev 1964)
+++ trunk/mapbender/http/classes/class_wms.php	2008-01-15 08:24:29 UTC (rev 1965)
@@ -94,7 +94,8 @@
 		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
 		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
 		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
-		xml_parse_into_struct($parser,$this->wms_getcapabilities_doc,$values,$tags);
+//		xml_parse_into_struct($parser,$this->wms_getcapabilities_doc,$values,$tags);
+		xml_parse_into_struct($parser,$data,$values,$tags);
 		$code = xml_get_error_code($parser);
 		if ($code) {
More information about the Mapbender_commits mailing list
