[Mapbender-commits] r1969 - branches/2.5/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jan 16 05:56:54 EST 2008
Author: christoph
Date: 2008-01-16 05:56:53 -0500 (Wed, 16 Jan 2008)
New Revision: 1969
   branches/2.5/http/classes/class_gui.php
prepared statements
Modified: branches/2.5/http/classes/class_gui.php
--- branches/2.5/http/classes/class_gui.php	2008-01-15 14:12:05 UTC (rev 1968)
+++ branches/2.5/http/classes/class_gui.php	2008-01-16 10:56:53 UTC (rev 1969)
@@ -1,5 +1,4 @@
 <?php
 # $Id$
 # http://www.mapbender.org/index.php/class_gui.php
 # Copyright (C) 2002 CCGIS
@@ -19,253 +18,201 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 $con = db_connect($DBSERVER,$OWNER,$PW);
 db_select_db(DB,$con);
-class gui{
+ * GUI is a set of GUI elements and services.
+class gui {
-	function gui() {
+	public function __construct () {
- 	// CB - returns true if a gui '$gui_id' exists
- 	function guiExists($gui_id){
-		$sql = "SELECT * FROM gui ";
-		$sql .= "WHERE gui_id = $1";
+ 	 * Checks if a GUI with a given ID exists in the database
+ 	 * @param integer $gui_id the ID of the GUI that is being checked
+ 	 * @return boolean true if a gui '$gui_id' exists; else false
+ 	public function guiExists ($gui_id){
+		$sql = "SELECT * FROM gui WHERE gui_id = $1";
 		$v = array($gui_id);
 		$t = array('s');
 		$res = db_prep_query($sql,$v,$t);
 		$row = db_fetch_array($res);
-		if ($row) return true;
-		else return false;
+		if ($row) {
+			return true;
+		return false;
-	// CB - deletes a GUI $guiId and all its links to users, layers etc.
-	function deleteGui ($guiId) {
+	 * Deletes a GUI $guiId and all its links to users, layers etc.
+	 * @param Integer $guiId the GUI that is going to be deleted
+	 * @return boolean true if the deletion succeded, else false
+	public function deleteGui ($guiId) {
 		$guiList = $guiId;
-		$sql = "BEGIN";
-		$res = db_query($sql);
-		if (!$res) {
-			$report .=  "<br><br>" . $sql . "<br><br>" . db_error() . "<br>";
-			$error = true;
+		$sql = array();
+		$v = array();
+		$t = array();
-		$sql = "DELETE FROM gui WHERE gui_id = $1";
-		$v = array($guiList);
-		$t = array('s');
-		$res = db_prep_query($sql,$v,$t);
-		if (!$res) {
-			$error = true;
+		array_push("BEGIN");
+		array_push($v, array());
+		array_push($t, array());
+		array_push($sql, "DELETE FROM gui WHERE gui_id = $1");
+		array_push($v, array($guiList));
+		array_push($t, array('s'));
-		$sql = "DELETE FROM gui_element WHERE fkey_gui_id = $1";
-		$t = array('s');
-		if (!$res) {
-			$error = true;
+		array_push($sql, "DELETE FROM gui_element WHERE fkey_gui_id = $1");
-		$sql = "DELETE FROM gui_element_vars WHERE fkey_gui_id = $1";
-		$t = array('s');
-		if (!$res) {
-			$error = true;
+		array_push($sql, "DELETE FROM gui_element_vars WHERE fkey_gui_id = $1");
-		$sql = "DELETE FROM gui_layer WHERE fkey_gui_id = $1";
-		$t = array('s');
-		if (!$res) {
-			$error = true;
+		array_push($sql, "DELETE FROM gui_layer WHERE fkey_gui_id = $1");
-		$sql = "DELETE FROM gui_mb_group WHERE fkey_gui_id = $1";
-		$t = array('s');
-		if (!$res) {
-			$error = true;
+		array_push($sql, "DELETE FROM gui_mb_group WHERE fkey_gui_id = $1");
-		$sql = "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1";
-		$t = array('s');
-		if (!$res) {
-			$error = true;
+		array_push($sql, "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1");
-		$sql = "DELETE FROM gui_treegde WHERE fkey_gui_id = $1";
-		$t = array('s');
-		if (!$res) {
-			$error = true;
+		array_push($sql, "DELETE FROM gui_treegde WHERE fkey_gui_id = $1");
-		$sql = "DELETE FROM gui_wfs WHERE fkey_gui_id = $1";
-		$t = array('s');
-		if (!$res) {
-			$error = true;
+		array_push($sql, "DELETE FROM gui_wfs WHERE fkey_gui_id = $1");
-		$sql = "DELETE FROM gui_wms WHERE fkey_gui_id = $1";
-		$t = array('s');
-		if (!$res) {
-			$error = true;
+		array_push($sql, "DELETE FROM gui_wms WHERE fkey_gui_id = $1");
-		// if $error is true, the transaction is aborted -> rollback
-		if (!$error) {
-			$sql = "COMMIT";
+		array_push($sql, "COMMIT");
+		// execute all SQLs
+		for ($i = 0; $i < count($sql); $i++) {
+			$res = db_prep_query($sql[$i], $v[$i], $t[$i]);
+			// if an SQL fails, send a ROLLBACK and return false
 			if (!$res) {
-				$error = true;
+				db_query("ROLLBACK");
+				return false;
-		//if $error is false, the transaction is executed -> commit
-		else {
-			$sql = "ROLLBACK";
-			if (!$res) {
-				$error = true;
-		return !$error;
+		return true;
-	// CB - rename a GUI
-	function renameGui ($guiId, $newGuiName) {
-		$error = false;
+	/** Renames the GUI $guiID to $newGUIName
+	 * @param Integer $guiId ID of the GUI
+	 * @param String $newGuiName the new name of the GUI
+	 * @return boolean true if the renaming succeded, else false
+	public function renameGui ($guiId, $newGuiName) {
 		if ($this->copyGui($guiId, $newGuiName, true)) {
 			$this->deleteGui($guiId);
+			return true;
-		else {
-			$error = true;
-		return !$error;
+		return false;
-	// CB - copies a GUI $guiId and all its links to users, layers etc. to GUI $newGuiName
- 	function copyGui ($guiId, $newGuiName, $withUsers) {
-		$error = false;
+ 	 * Copies a GUI $guiId and all its links to users, layers etc. to GUI $newGuiName
+	 * @param boolean $withUsers true if the users, that may access the GUI $guiId, shall have access to the new GUI; else false.
+ 	public function copyGui ($guiId, $newGuiName, $withUsers) {
 		$guiList = $guiId;
 		if (!$this->guiExists($newGuiName)) {
-			$sql = "BEGIN";
-			if (!$res) {
-				$error = true;
+			$sql = array();
+			$v = array();
+			$t = array();
+			array_push($sql, "BEGIN");
-			$sql = "INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) SELECT '" . $newGuiName . "', '" . $newGuiName . "',gui_description, gui_public FROM gui WHERE gui_id = '" . $guiList . "';";
-			if (!$res) {
-				$error = true;
+			array_push($sql, "INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) SELECT $1, $2, gui_description, gui_public FROM gui WHERE gui_id = $3;");
+			array_push($v, array ($newGuiName, $newGuiName, $guiList));
+			array_push($t, array ("s", "s", "s"));;
+			array_push($sql, "INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT $1, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url FROM gui_element WHERE fkey_gui_id = $2;");
+			array_push($v, array($newGuiName, $guiList));
+			array_push($t, array("s", "s"));
-			$sql = "INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT '" . $newGuiName . "', e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url FROM gui_element WHERE fkey_gui_id = '" . $guiList . "';";
-			if (!$res) {
-				$error = true;
+			array_push($sql, "INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT $1, fkey_e_id, var_name, var_value, context, var_type FROM gui_element_vars WHERE fkey_gui_id = $2;");
-			$sql = "INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT '" . $newGuiName . "', fkey_e_id, var_name, var_value, context, var_type FROM gui_element_vars WHERE fkey_gui_id = '" . $guiList . "';";
-			if (!$res) {
-				$error = true;
+			array_push($sql, "INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) SELECT $1, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype FROM gui_layer WHERE fkey_gui_id = $2;");
-			$sql = "INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) SELECT '" . $newGuiName . "', fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype FROM gui_layer WHERE fkey_gui_id = '" . $guiList . "';";
-			if (!$res) {
-				$error = true;
 			if ($withUsers == true) {
 				/* group of original gui is copied as well */
-				$sql = "INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) SELECT '" . $newGuiName . "', fkey_mb_group_id, mb_group_type FROM gui_mb_group WHERE fkey_gui_id = '" . $guiList . "';";
-				if (!$res) {
-					$error = true;
+				array_push($sql, "INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) SELECT $1, fkey_mb_group_id, mb_group_type FROM gui_mb_group WHERE fkey_gui_id = $2;");
 				/* users of original gui are copied as well */
-				$sql = "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) SELECT '" . $newGuiName . "', fkey_mb_user_id, mb_user_type FROM gui_mb_user WHERE fkey_gui_id = '" . $guiList . "';";
-				if (!$res) {
-					$error = true;
+				array_push($sql = "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) SELECT $1, fkey_mb_user_id, mb_user_type FROM gui_mb_user WHERE fkey_gui_id = $2;");
 			else {
 				// users of original gui are not copied, the current user is set as owner
-				$sql = "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ($1, $2, 'owner')";
-				$v = array($newGuiName, $_SESSION["mb_user_id"]);
-				$t = array('s', 'i');
-				if (!$res) {
-					$error = true;
+				array_push($sql = "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ($1, $2, 'owner')");
+				array_push($v, array($newGuiName, $_SESSION["mb_user_id"]));
+				array_push($t, array('s', 'i'));
-			$sql = "INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) SELECT '" . $newGuiName . "', fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id FROM gui_treegde WHERE fkey_gui_id = '" . $guiList . "';";
-			if (!$res) {
-				$error = true;
+			array_push($sql, "INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) SELECT $1, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id FROM gui_treegde WHERE fkey_gui_id = $2;");
-			$sql = "INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) SELECT '" . $newGuiName . "', fkey_wfs_id FROM gui_wfs WHERE fkey_gui_id = '" . $guiList . "';";
-			if (!$res) {
-				$error = true;
+			array_push($sql, "INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) SELECT $1, fkey_wfs_id FROM gui_wfs WHERE fkey_gui_id = $2;");
-			$sql = "INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) SELECT '" . $newGuiName . "', fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible FROM gui_wms WHERE fkey_gui_id = '" . $guiList . "';";
-			if (!$res) {
-				$error = true;
+			array_push($sql, "INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) SELECT $1, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible FROM gui_wms WHERE fkey_gui_id = $2;");
-			// if $error is false, the transaction is executed -> commit
-			if (!$error) {
-				$sql = "COMMIT";
-			else {
+				if (!$res) {
+					return false;
-			if (!$res) {
-				$error = true;
-			return !$error;
+			return true;
 		else {
 	      echo "<script language='javascript'>";
More information about the Mapbender_commits mailing list
