[Mapbender-commits] r1989 - branches/2.5/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Jan 19 05:27:56 EST 2008
Author: christoph
Date: 2008-01-19 05:27:56 -0500 (Sat, 19 Jan 2008)
New Revision: 1989
   branches/2.5/http/php/mod_edit_element_vars.php
   branches/2.5/http/php/mod_map1.php
   branches/2.5/http/php/mod_mapOV.php
   branches/2.5/http/php/mod_simpleWMSpreferences.php
prepared statements
Modified: branches/2.5/http/php/mod_edit_element_vars.php
--- branches/2.5/http/php/mod_edit_element_vars.php	2008-01-19 09:47:08 UTC (rev 1988)
+++ branches/2.5/http/php/mod_edit_element_vars.php	2008-01-19 10:27:56 UTC (rev 1989)
@@ -110,13 +110,20 @@
 <?php
 # handle database updates etc.....
 if(isset($mySave) && $mySave == '1'){
-   if($SYS_DBTYPE=='pgsql'){
-   $sql[0] = "SET AUTOCOMMIT=1;";}
-   else{
-   $sql[0] = "SET AUTOCOMMIT=0;shit happens";
-   $sql[1] = "BEGIN;";
-   $sql[2] = "DELETE FROM gui_element_vars WHERE fkey_e_id = '".$e_id."' AND fkey_gui_id = '".$guiList1."' and ....";
+	if ($SYS_DBTYPE=='pgsql') {
+		$sql[0] = "SET AUTOCOMMIT=1;";
+	else {
+		$sql[0] = "SET AUTOCOMMIT=0;shit happens";
+	$v[0] = array();
+	$t[0] = array();
+	$sql[1] = "BEGIN;";
+	$v[1] = array();
+	$t[1] = array();
+	$sql[2] = "DELETE FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2";
+	$v[2] = array($e_id, $guiList1);
+	$t[2] = array("s", "s");
    if($e_left < 1){$e_left = "NULL";}
@@ -124,25 +131,32 @@
    if($e_width < 1){$e_width = "NULL";}
    if($e_height < 1){$e_height = "NULL";}
    if($e_z_index < 1){$e_z_index = "NULL";}
-   $sql[3] = "INSERT INTO gui_element_vars(fkey_gui_id,e_id,e_pos,e_public,e_comment,e_element,e_src,e_attributes,e_left,e_top,e_width,e_height,e_z_index,e_more_styles,e_content,e_closetag,e_js_file,e_mb_mod,e_target,e_requires) ";
-   $sql[3] .= "VALUES ('".$guiList1."','".$e_id."','".$e_pos."','".$e_public."','".db_escape_string($e_comment)."','".$e_element."','".$e_src."','".db_escape_string($e_attributes)."',".$e_left.",".$e_top.",".$e_width.",".$e_height.",".$e_z_index.",'".$e_more_styles."','".$e_content."','".$e_closetag."','".$e_js_file."','".$e_mb_mod."','".$e_target."','".$e_requires."')";
+	$sql[3] = "INSERT INTO gui_element_vars ";
+	$sql[3] .= "(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, ";
+	$sql[3] .= "e_attributes, e_left, e_top, e_width, e_height, e_z_index, ";
+	$sql[3] .= "e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, ";
+	$sql[3] .= "e_requires) ";
+	$sql[3] .= "VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $18, $19, $20)";
+	$v[3] = array($guiList1, $e_id, $e_pos, $e_public, db_escape_string($e_comment), $e_element, $e_src, db_escape_string($e_attributes), $e_left, $e_top, $e_width, $e_height, $e_z_index, $e_more_styles, $e_content, $e_closetag, $e_js_file, $e_mb_mod, $e_target, $e_requires);
+	$t[3] = array("s", "s", "i", "s", "s", "s", "s", "s", "i", "i", "i", "i", "i", "s", "s", "s", "s", "s", "s", "s");
    #echo $sql[3];
-   foreach ($sql as $mysql){
-      $res = db_query($mysql);
-      if(!$res){echo $mysql; break;}
+   for ($i = 0; $i < count($sql); $i++) {
+      $res = db_prep_query($sql[$i], $v[$i], $t[$i]);
    if($res){
-		$res = db_query( "COMMIT");
+      $res = db_query( "COMMIT");
       $res = db_query( "SET AUTOCOMMIT=1");
    else{
       $res = db_query( "ROLLBACK");
 if(isset($myDelete) && $myDelete == '1'){
-   $sql = "DELETE FROM gui_element_vars WHERE fkey_e_id = '".$e_id."' AND fkey_gui_id = '".$guiList1."' AND var_name='".$var_name."'";
-   $res = db_query($sql);
+   $sql = "DELETE FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2 AND var_name= $3";
+   $v = array($e_id, $guiList1, $var_name);
+   $t = array("s", "s", "s");
+   $res = db_prep_query($sql, $v, $t);
    $e_id = ""; $e_pos = ""; $e_public = ""; $e_comment = ""; $e_element = "";
    $e_src = ""; $e_attributes = ""; $e_left = ""; $e_top = ""; $e_width = ""; $e_height = ""; $e_z_index = "";
    $e_more_styles = ""; $e_content = ""; $e_closetag = ""; $e_js_file = ""; $e_mb_mod = ""; $e_target = ""; $e_requires = "";
@@ -154,24 +168,37 @@
    echo "</script>";
 if(isset($all) && $all == '1'){
-   $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = '".$guiList2."' AND fkey_e_id = '".$e_id."' and var_name='".$var_name."' ;";
+   $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = $2 and var_name= $3;";
+   $v = array($guiList2, $e_id, $var_name);
    $cnt = 0;
    while(db_fetch_row($res)){
-      $sql_del = "DELETE FROM gui_element_vars WHERE fkey_gui_id = '".$guiList1."' AND fkey_e_id = '".db_result($res,$cnt,"fkey_e_id")."'  and var_name='".$var_name."' ";
-      $res_del = db_query($sql_del);
+      $sql_del = "DELETE FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = $2 and var_name= $3";
+      $v = array($guiList1, db_result($res,$cnt,"fkey_e_id"), $var_name);
+      $res_del = db_prep_query($sql_del, $v, $t);
       if(db_result($res,$cnt,"e_left") == ""){$myleft = 'NULL';} else{$myleft = db_result($res,$cnt,"e_left");}
       if(db_result($res,$cnt,"e_top") == ""){$mytop = 'NULL';} else{$mytop = db_result($res,$cnt,"e_top");}
       if(db_result($res,$cnt,"e_width") == ""){$mywidth = 'NULL';} else{$mywidth = db_result($res,$cnt,"e_width");}
       if(db_result($res,$cnt,"e_height") == ""){$myheight = 'NULL';} else{$myheight = db_result($res,$cnt,"e_height");}
       if(db_result($res,$cnt,"e_z_index") == ""){$my_z_index = 'NULL';} else{$my_z_index = db_result($res,$cnt,"e_z_index");}
-      $sql_ins = "INSERT INTO gui_element_vars(fkey_gui_id,e_id,e_pos,e_public,e_comment,e_element,e_src,e_attributes,e_left,e_top,e_width,e_height,e_z_index,e_more_styles,e_content,e_closetag,e_js_file,e_mb_mod,e_target,e_requires) ";
-      $sql_ins .= "VALUES ('".$guiList1."','".db_result($res,$cnt,"e_id")."','".db_result($res,$cnt,"e_pos")."','".db_result($res,$cnt,"e_public")."','".db_escape_string(db_result($res,$cnt,"e_comment"))."','".db_result($res,$cnt,"e_element")."','".db_result($res,$cnt,"e_src")."','".db_escape_string(db_result($res,$cnt,"e_attributes"))."',".$myleft.",";
-      $sql_ins .= $mytop.",".$mywidth.",".$myheight.",".$my_z_index.",'".db_result($res,$cnt,"e_more_styles")."','".db_escape_string(db_result($res,$cnt,"e_content"))."','".db_result($res,$cnt,"e_closetag")."','".db_result($res,$cnt,"e_js_file")."','".db_result($res,$cnt,"e_mb_mod")."','".db_result($res,$cnt,"e_target")."','".db_result($res,$cnt,"e_requires")."')";
+      $sql_ins = "INSERT INTO gui_element_vars ";
+      $sql_ins .= "(fkey_gui_id, e_id, e_pos,e_public, e_comment, e_element, ";
+      $sql_ins .= "e_src, e_attributes, e_left, e_top, e_width, e_height, ";
+      $sql_ins .= "e_z_index, e_more_styles, e_content, e_closetag, e_js_file, ";
+      $sql_ins .= "e_mb_mod, e_target, e_requires) ";
+      $sql_ins .= "VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, ";
+      $sql_ins .= "$10, $11, $12, $13, $14, $15, $16, $17, $18, ";
+      $sql_ins .= "$19, $20)";
+      $v = array($guiList1, db_result($res,$cnt,"e_id"), db_result($res,$cnt,"e_pos"), db_result($res,$cnt,"e_public"), db_escape_string(db_result($res,$cnt,"e_comment")), db_result($res,$cnt,"e_element"), db_result($res,$cnt,"e_src"), db_escape_string(db_result($res,$cnt,"e_attributes")), $myleft, $mytop, $mywidth, $myheight, $my_z_index, db_result($res,$cnt,"e_more_styles"), db_escape_string(db_result($res,$cnt,"e_content")), db_result($res,$cnt,"e_closetag"), db_result($res,$cnt,"e_js_file"), db_result($res,$cnt,"e_mb_mod"), db_result($res,$cnt,"e_target"), db_result($res,$cnt,"e_requires"));
+      $t = array("s", "s", "s", "s", "s", "s", "s", "s", "i", "i", "i", "i", "i", "s", "s", "s", "s", "s", "s", "s");
-      $res_ins = db_query($sql_ins);
-      if(!$res_ins){echo db_error($connect); }
+      $res_ins = db_prep_query($sql_ins, $v, $t);
+      if (!$res_ins) {
+      	echo db_error($connect);
       $cnt++;
@@ -179,8 +206,10 @@
 echo "<script language='javascript'>";
 echo "var varIDs = new Array();";
 if(isset($guiList1)){
-   $sql = "SELECT var_name FROM gui_element_vars WHERE  fkey_gui_id = '".$guiList1."' AND fkey_e_id = '".$e_id."'";
+   $sql = "SELECT var_name FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = $2";
+   $v = array($guiList1, $e_id);
+   $t = array("s", "s");
    $cnt = 0;
       echo  "varIDs[".$cnt."] = '".db_result($res,$cnt,"var_name")."'; ";
@@ -284,8 +313,10 @@
    echo "<div class='guiList2_header'>Templates</div>";
-   $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = '".$guiList1."' AND fkey_e_id='".$e_id."'";
+   $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = $2";
    $cnt = 0;
    echo "<div class='myElements'><table>";
    while($row = db_fetch_array($res)){
@@ -303,9 +334,11 @@
 #Formular:
 echo "<table class='myForm'>";
 if(isset($guiList1) && isset($var_name)){
-   $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = '".$guiList1."' AND fkey_e_id = '".$e_id."' AND var_name='".$var_name."'";
+   $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = '".$e_id."' AND var_name = $2";
+   $v = array($guiList1, $var_name);
    //echo $sql;
    if($row = db_fetch_array($res)){
       echo "<tr><td>ID: </td><td><input type='text' class='textfield' readonly name='e_id' value='".$e_id."'></td></tr>";
       echo "<tr><td>Var Type: </td><td><input type='text' class='textfield' name='type' value='".$row["type"]."'></td></tr>";
Modified: branches/2.5/http/php/mod_map1.php
--- branches/2.5/http/php/mod_map1.php	2008-01-19 09:47:08 UTC (rev 1988)
+++ branches/2.5/http/php/mod_map1.php	2008-01-19 10:27:56 UTC (rev 1989)
@@ -37,8 +37,10 @@
 <title>mod_map1</title>
 <?php
-$sql = "SELECT e_width, e_height FROM gui_element WHERE e_id = 'mapframe1' AND fkey_gui_id = '".$_SESSION["mb_user_gui"]."'";
-$res = db_query($sql);
+$sql = "SELECT e_width, e_height FROM gui_element WHERE e_id = 'mapframe1' AND fkey_gui_id = $1";
+$v = array($_SESSION["mb_user_gui"]);
+$t = array("s");
+$res = db_prep_query($sql, $v, $t);
 $cnt = 0;
    $e_width = $row["e_width"];
Modified: branches/2.5/http/php/mod_mapOV.php
--- branches/2.5/http/php/mod_mapOV.php	2008-01-19 09:47:08 UTC (rev 1988)
+++ branches/2.5/http/php/mod_mapOV.php	2008-01-19 10:27:56 UTC (rev 1989)
@@ -45,8 +45,10 @@
 <?php
 $gui_id = $_SESSION["mb_user_gui"];
-$sql = "SELECT e_width,e_height, e_target FROM gui_element WHERE e_id = 'overview' AND fkey_gui_id = '".$gui_id."'";
+$sql = "SELECT e_width,e_height, e_target FROM gui_element WHERE e_id = 'overview' AND fkey_gui_id = $1";
+$v = array($gui_id);
+$t = array("s");
 $cnt = 0;
 echo "<script type='text/javascript'>";
Modified: branches/2.5/http/php/mod_simpleWMSpreferences.php
--- branches/2.5/http/php/mod_simpleWMSpreferences.php	2008-01-19 09:47:08 UTC (rev 1988)
+++ branches/2.5/http/php/mod_simpleWMSpreferences.php	2008-01-19 10:27:56 UTC (rev 1989)
@@ -76,8 +76,10 @@
 <?php
 $con = db_connect($DBSERVER,$OWNER,$PW);
 db_select_db(DB,$con);
-$sql = "SELECT * FROM gui_element WHERE e_id = 'WMS_preferences' AND fkey_gui_id = '".$_SESSION["mb_user_gui"]."'";
+$sql = "SELECT * FROM gui_element WHERE e_id = 'WMS_preferences' AND fkey_gui_id = $1";
+$t = array("s");
 $cnt = 0;
    $e_target = $row["e_target"];
More information about the Mapbender_commits mailing list
