[Mapbender-commits] r1992 - branches/2.5/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun Jan 20 05:59:05 EST 2008
Author: christoph
Date: 2008-01-20 05:59:05 -0500 (Sun, 20 Jan 2008)
New Revision: 1992
   branches/2.5/http/php/mod_gazLayerObj_conf.php
   branches/2.5/http/php/mod_gazLayerObj_edit.php
   branches/2.5/http/php/mod_getStyles.php
   branches/2.5/http/php/mod_loadCapabilitiesList.php
   branches/2.5/http/php/mod_treefolderAdmin.php
   branches/2.5/http/php/mod_treefolderClient.php
   branches/2.5/http/php/mod_wfs_server.php
prepared statements
Modified: branches/2.5/http/php/mod_gazLayerObj_conf.php
--- branches/2.5/http/php/mod_gazLayerObj_conf.php	2008-01-20 10:33:03 UTC (rev 1991)
+++ branches/2.5/http/php/mod_gazLayerObj_conf.php	2008-01-20 10:59:05 UTC (rev 1992)
@@ -76,9 +76,11 @@
 	$con = db_connect($DBSERVER,$OWNER,$PW);
 	db_select_db(DB,$con);
-	$sql = "UPDATE gui_layer SET gui_layer_wfs_featuretype = '".$_REQUEST["myWFS"]."' ";
-	$sql .= "WHERE fkey_gui_id='".$_REQUEST["gui"]."' AND fkey_layer_id=".$_REQUEST["layer"];
-	$res = db_query($sql);
+	$sql = "UPDATE gui_layer SET gui_layer_wfs_featuretype = $1 ";
+	$sql .= "WHERE fkey_gui_id = $2 AND fkey_layer_id = $3";
+	$v = array($_REQUEST["myWFS"], $_REQUEST["gui"], $_REQUEST["layer"]);
+	$t = array("s", "s", "i");
+	$res = db_prep_query($sql, $v, $t);
 	echo "layer is connected with: ".$_REQUEST["myWFS"];
 	die();
Modified: branches/2.5/http/php/mod_gazLayerObj_edit.php
--- branches/2.5/http/php/mod_gazLayerObj_edit.php	2008-01-20 10:33:03 UTC (rev 1991)
+++ branches/2.5/http/php/mod_gazLayerObj_edit.php	2008-01-20 10:59:05 UTC (rev 1992)
@@ -54,29 +54,34 @@
 if(isset($_REQUEST["save"])){
 	$sql = "UPDATE gazetteer SET ";
-	$sql .= "gazetteer_abstract = '".$_REQUEST["gazetteer_abstract"]."',";
-	$sql .= "g_label = '".$_REQUEST["g_label"]."',";
-	$sql .= "g_label_id = '".$_REQUEST["g_label_id"]."',";
-	$sql .= "g_button = '".$_REQUEST["g_button"]."',";
-	$sql .= "g_button_id = '".$_REQUEST["g_button_id"]."',";
-	$sql .= "g_style = '".$_REQUEST["g_style"]."',";
-	$sql .= "g_buffer = '".$_REQUEST["g_buffer"]."'";
-	$sql .= " WHERE gazetteer_id = ".$_REQUEST["fkey_gazetteer_id"].";";
+	$sql .= "gazetteer_abstract = $1, ";
+	$sql .= "g_label = $2, ";
+	$sql .= "g_label_id = $3, ";
+	$sql .= "g_button = $4, ";
+	$sql .= "g_button_id = $5, ";
+	$sql .= "g_style = $6, ";
+	$sql .= "g_buffer = $7 ";
+	$sql .= "WHERE gazetteer_id = $8;";
+	$v = array($_REQUEST["gazetteer_abstract"], $_REQUEST["g_label"], $_REQUEST["g_label_id"], $_REQUEST["g_button"], $_REQUEST["g_button_id"], $_REQUEST["g_style"], $_REQUEST["g_buffer"], $_REQUEST["fkey_gazetteer_id"]);
+	$t = array("s", "s", "s", "s", "s", "s", "s", "i");
-	for($i=0; $i<count($_REQUEST["f_id"]); $i++){
+	for ($i = 0; $i < count($_REQUEST["f_id"]); $i++){
 		$sql = "UPDATE gazetteer_element SET ";
-		$sql .= "f_search = '".$_REQUEST["f_search"][$i]."',";
-		$sql .= "f_pos = '".$_REQUEST["f_pos"][$i]."',";
-		$sql .= "f_style_id = '".$_REQUEST["f_style_id"][$i]."',";
-		$sql .= "f_label = '".$_REQUEST["f_label"][$i]."',";
-		$sql .= "f_label_id = '".$_REQUEST["f_label_id"][$i]."',";
-		$sql .= "f_show = '".$_REQUEST["f_show"][$i]."',";
-		$sql .= "f_respos = '".$_REQUEST["f_respos"][$i]."'";
-		$sql .= " WHERE fkey_gazetteer_id = ".$_REQUEST["fkey_gazetteer_id"]." AND f_id = ".$_REQUEST["f_id"][$i].";";
+		$sql .= "f_search = $1, ";
+		$sql .= "f_pos = $2, ";
+		$sql .= "f_style_id = $3, ";
+		$sql .= "f_label = $4, ";
+		$sql .= "f_label_id = $5, ";
+		$sql .= "f_show = $6, ";
+		$sql .= "f_respos = $7 ";
+		$sql .= "WHERE fkey_gazetteer_id = $8 AND f_id = $9;";
+		$v = array($_REQUEST["f_search"][$i], $_REQUEST["f_pos"][$i], $_REQUEST["f_style_id"][$i], $_REQUEST["f_label"][$i], $_REQUEST["f_label_id"][$i], $_REQUEST["f_show"][$i], $_REQUEST["f_respos"][$i], $_REQUEST["fkey_gazetteer_id"], $_REQUEST["f_id"][$i]);
+		$t = array("s", "s", "s", "s", "s", "s", "s", "i", "i");
@@ -92,8 +97,10 @@
 /* configure elements */
 if(isset($_REQUEST["fkey_gazetteer_id"])){
-	$sql = "SELECT * FROM gazetteer WHERE gazetteer_id = ".$_REQUEST["fkey_gazetteer_id"];
+	$sql = "SELECT * FROM gazetteer WHERE gazetteer_id = $1";
+	$v = array($_REQUEST["fkey_gazetteer_id"]);
+	$t = array("i");
 	if($row = db_fetch_array($res)){
 		echo "<table>";
 		echo "<tr><td>ID:</td><td>".$row["gazetteer_id"]."</td></tr>" ;
@@ -110,8 +117,10 @@
 	/* set element options */
 	$sql = "SELECT * FROM gazetteer_element ";
 	$sql .= "JOIN wfs_element ON gazetteer_element.f_id = wfs_element.element_id ";
-	$sql .= "WHERE fkey_gazetteer_id = ".$_REQUEST["fkey_gazetteer_id"];
+	$sql .= "WHERE fkey_gazetteer_id = $1";
+	$t = array("i");
 	echo "<table border='1'>";
 	echo "<tr>";
Modified: branches/2.5/http/php/mod_getStyles.php
--- branches/2.5/http/php/mod_getStyles.php	2008-01-20 10:33:03 UTC (rev 1991)
+++ branches/2.5/http/php/mod_getStyles.php	2008-01-20 10:59:05 UTC (rev 1992)
@@ -127,9 +127,11 @@
 	fclose($style_file);
 	#include(dirname(__FILE__)."/../../conf/www.conf");
 	$pattern = "/" . basename($login) . "/";
-	$sql = "UPDATE wms SET wms_filter = '".preg_replace($pattern,$style_filename,$login)."' WHERE wms_id = ". $wmsList;
+	$sql = "UPDATE wms SET wms_filter = $1 WHERE wms_id = $2";
+	$v = array(preg_replace($pattern,$style_filename,$login), $wmsList);
+	$t = array("s", "i");
 	echo $sql;
-	db_query($sql) or die("unable to change filter!");
+	db_prep_query($sql, $v, $t) or die("unable to change filter!");
@@ -142,8 +144,10 @@
 	# getStyle - Request:
 	if($wmsList && $row["wms_id"] == $wmsList){
 		$getStyle = $row["wms_getmap"]."&VERSION=1.1.1&REQUEST=getStyles&SERVICE=WMS&LAYERS=";
-		$sql_style = "SELECT layer_name FROM layer WHERE fkey_wms_id = " . $wmsList;
-		$res_style = db_query($sql_style);
+		$sql_style = "SELECT layer_name FROM layer WHERE fkey_wms_id = $1";
+		$v = array($wmsList);
+		$t = array("i");
+		$res_style = db_prep_query($sql_style, $v, $t);
 		$cnt_style = 0;
 		while($row2 = db_fetch_array($res_style)){
Modified: branches/2.5/http/php/mod_loadCapabilitiesList.php
--- branches/2.5/http/php/mod_loadCapabilitiesList.php	2008-01-20 10:33:03 UTC (rev 1991)
+++ branches/2.5/http/php/mod_loadCapabilitiesList.php	2008-01-20 10:59:05 UTC (rev 1992)
@@ -154,8 +154,10 @@
 		$cnt++;
-	$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id = '".$guiID."' AND gui_layer_wms_id = ".$wmsID;
+	$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id = $1 AND gui_layer_wms_id = $2";
+	$v = array($guiID, $wmsID);
 	$cnt = 0;
 	while($row = db_fetch_array($res)){
 		$sql_ins = "INSERT INTO gui_layer (fkey_gui_id,fkey_layer_id,gui_layer_wms_id,gui_layer_status,gui_layer_selectable,";
@@ -180,12 +182,17 @@
 	echo"<br>";
 	$sql = "SELECT * FROM gui WHERE gui_id IN (";
-	for($i=0; $i<count($ownguis); $i++){
-		if($i>0){ $sql .= ",";}
-		$sql .= "'".$ownguis[$i]."'";
+	$v = $ownguis;
+	$t = array();
+	for ($i = 1; $i <= count($ownguis); $i++){
+		if ($i > 1) {
+			$sql .= ",";
+		$sql .= "$".$i;
+		array_push($t, "s");
 	$sql .= ") ORDER BY gui_name";
 	$count=0;
 	echo"<select size='8' name='guiList' style='width:200px' onClick='submit()'>";
@@ -236,12 +243,17 @@
 	echo"<div class='text1'>Load WMS</div>";
 	$sql = "SELECT DISTINCT wms.wms_id,wms.wms_title,wms.wms_abstract,wms.wms_owner FROM gui_wms JOIN wms ON ";
 	$sql .= "wms.wms_id = gui_wms.fkey_wms_id WHERE gui_wms.fkey_gui_id IN(";
-	for($i=0; $i<count($arrayGUIs); $i++){
-		if($i>0){$sql .= ",";}
-		$sql .= "'".$arrayGUIs[$i]."'";
+	$v = $arrayGUIs;
+	$t = array();
+	for ($i = 1; $i <= count($arrayGUIs); $i++){
+		if ($i > 1) {
+			$sql .= ",";
+		$sql .= "$" . $i;
 	$sql .= ") ORDER BY wms.wms_title";
 	echo "<select class='select1' name='wmsID' size='20' onchange='submit()'>";
 	$cnt = 0;
@@ -263,8 +275,10 @@
 	if(isset($wmsID)){
 		echo "<div class='text2'>FROM:</div>";
-		$sql = "SELECT * from gui_wms WHERE fkey_wms_id ='".$wmsID."' ORDER BY fkey_gui_id";
+		$sql = "SELECT * from gui_wms WHERE fkey_wms_id = $1 ORDER BY fkey_gui_id";
+		$v = array($wmsID);
+		$t = array("s");
 		echo "<select class='select2' name='guiID' size='20' onchange='load()'>";
 		$cnt = 0;
Modified: branches/2.5/http/php/mod_treefolderAdmin.php
--- branches/2.5/http/php/mod_treefolderAdmin.php	2008-01-20 10:33:03 UTC (rev 1991)
+++ branches/2.5/http/php/mod_treefolderAdmin.php	2008-01-20 10:59:05 UTC (rev 1992)
@@ -434,21 +434,28 @@
   // this is a multinary tree structure which is easy to
   // populate with database data :)
 <?php
-$sql = "SELECT id FROM gui_treegde WHERE fkey_gui_id = '".$guiList."'";
-$res = db_query($sql);
+$sql = "SELECT id FROM gui_treegde WHERE fkey_gui_id = $1";
+// $v and $t will be re-used below!
+$v = array($guiList);
+$t = array("s");
+$res = db_prep_query($sql, $v, $t);
 if(!db_fetch_row($res)){
-	$sql = "INSERT INTO gui_treegde(fkey_gui_id, my_layer_title,lft,rgt,layer) VALUES('".$guiList."', 'new','1','4','')";
-	db_query($sql);
-	$sql = "INSERT INTO gui_treegde(fkey_gui_id,my_layer_title,lft,rgt,layer) VALUES('".$guiList."','new','2','3','')";
-	db_query($sql);
+	$sql = "INSERT INTO gui_treegde(fkey_gui_id, my_layer_title,lft,rgt,layer) VALUES($1, 'new','1','4','')";
+	//using $v and $t fom above
+	db_prep_query($sql, $v, $t);
+	$sql = "INSERT INTO gui_treegde(fkey_gui_id,my_layer_title,lft,rgt,layer) VALUES($1,'new','2','3','')";
 $sql = "SELECT n.wms_id, n.id, n.my_layer_title, n.lft, n.rgt, n.layer, COUNT(*) AS level1, ((n.rgt - n.lft -1)/2) AS offspring ";
 $sql .= "FROM gui_treegde as n, gui_treegde as p WHERE n.lft BETWEEN p.lft AND p.rgt ";
-$sql .= " AND n.fkey_gui_id = '".$guiList."' AND p.fkey_gui_id = '".$guiList."' ";
+$sql .= " AND n.fkey_gui_id = $1 AND p.fkey_gui_id = $2 ";
 $sql .= " GROUP BY n.wms_id, n.lft, n.my_layer_title,  ((n.rgt - n.lft -1)/2) , n.id, n.rgt, n.layer ORDER BY n.lft;";
 #echo $sql;
+$v = array($guiList, $guiList);
+$t = array("s", "s");
 	echo "function initArray(){";
 	echo "Note(0,-1,'','');";
 	$cnt = 0;
Modified: branches/2.5/http/php/mod_treefolderClient.php
--- branches/2.5/http/php/mod_treefolderClient.php	2008-01-20 10:33:03 UTC (rev 1991)
+++ branches/2.5/http/php/mod_treefolderClient.php	2008-01-20 10:59:05 UTC (rev 1992)
@@ -78,8 +78,10 @@
     </STYLE>
 <?php
-$sql = "SELECT e_target FROM gui_element WHERE e_id = 'treeConfGDE' AND fkey_gui_id = '".$guiList."'";
+$sql = "SELECT e_target FROM gui_element WHERE e_id = 'treeConfGDE' AND fkey_gui_id = $1";
+$t = array("s");
 $cnt = 0;
 while(db_fetch_row($res)){
 	$e_target = db_result($res,0,"e_target");
@@ -548,21 +550,27 @@
 <?php
+$t = array("s");
-	db_query($sql);
-	db_query($sql);
 $sql .= " GROUP BY n.wms_id, n.lft, n.my_layer_title,  ((n.rgt - n.lft -1)/2) , n.id, n.rgt, n.layer ORDER BY n.lft";
 	$cnt = 0;
Modified: branches/2.5/http/php/mod_wfs_server.php
--- branches/2.5/http/php/mod_wfs_server.php	2008-01-20 10:33:03 UTC (rev 1991)
+++ branches/2.5/http/php/mod_wfs_server.php	2008-01-20 10:59:05 UTC (rev 1992)
@@ -89,8 +89,18 @@
 	if(count($serviceList) == 0){
 		return false;
-	$sql = "SELECT * FROM wfs WHERE wfs_id IN(".join(",",$serviceList).") ORDER BY wfs_title";
+	$sql = "SELECT * FROM wfs WHERE wfs_id IN (";
+	$v = $serviceList;
+	$t = array();
+	for ($i = 1; $i <= count($serviceList); $i++) {
+		if ($i > 1) {
+			$sql .= ", ";
+		$sql .= "$" . $i;
+		array_push($t, "i");
+	$sql .= ") ORDER BY wfs_title";
 		array_push($services['id'], $row['wfs_id']);
 		array_push($services['title'], $row['wfs_title']);
More information about the Mapbender_commits mailing list
