[Mapbender-commits] r1999 - in trunk/mapbender/http: classes javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jan 21 04:07:58 EST 2008
Author: nimix
Date: 2008-01-21 04:07:57 -0500 (Mon, 21 Jan 2008)
New Revision: 1999
   trunk/mapbender/http/classes/class_log.php
   trunk/mapbender/http/javascripts/mod_log.php
   trunk/mapbender/http/php/mod_log.php
reenable access logging
Modified: trunk/mapbender/http/classes/class_log.php
--- trunk/mapbender/http/classes/class_log.php	2008-01-21 08:36:05 UTC (rev 1998)
+++ trunk/mapbender/http/classes/class_log.php	2008-01-21 09:07:57 UTC (rev 1999)
@@ -23,7 +23,7 @@
 *modul "GET /map/http/ HTTP/1.1"
-class log{
+class log {
 	var $dir = "../../log/";
 	var $log_username = true;
@@ -32,12 +32,14 @@
 	 * {'file' || 'db'}
 	var $logtype = 'db';
+	function log($module,$req,$time_client,$type = ""){
-	function log($module,$req,$time_client){
 		$this->url = $req;
+		if($type == "")
+			$type = $this->logtype;
-		if($this->logtype == "file"){
+		if($type == "file"){
 			if(is_dir($this->dir)){
 				$logfile = $this->dir . "mb_access_" . date("Y_m_d") . ".log";
 				if(!$h = @fopen($logfile,"a")){
@@ -65,42 +67,22 @@
-		else if($this->logtype == 'db'){
+		else if($type == 'db'){
 			include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 			$con = db_connect(DBSERVER,OWNER,PW);
 			db_select_db(DB,$con);
 			for($i = 0; $i < count($this->url); $i++){
-				$sql = "INSERT INTO mb_log(";
+				$sql = "INSERT INTO mb_log (";
+				$sql .= "time_client, time_server, time_readable, mb_session, ";
+				$sql .= "gui, module, ip, username, userid, request";
+				$sql .= ") VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10)";
-				$sql .= "time_client,";
-				$sql .= "time_server,";
-				$sql .= "time_readable,";
-				$sql .= "mb_session,";
-				$sql .= "gui,";
-				$sql .= "module,";
-				$sql .= "ip,";
-				$sql .= "username,";
-				$sql .= "userid,";
-				$sql .= "request";
+				$v = array($time_client, strtotime("now"), "[".date("d/M/Y:H:i:s O")."]", SID, $_SESSION["mb_user_gui"], $module, $_SESSION["mb_user_ip"], $_SESSION["mb_user_name"], $_SESSION["mb_user_id"], $this->url[$i]);
+				$t = array("s", "s", "s", "s", "s", "s", "s", "s", "s", "s");
+				$res = db_prep_query($sql, $v, $t)or die(db_error());
-				$sql .= ") VALUES (";
-				$sql .= "'".$time_client."',";
-				$sql .= "'".strtotime("now")."',";
-				$sql .= "'[".date("d/M/Y:H:i:s O")."]',";
-				$sql .= "'".SID."',";
-				$sql .= "'".$_SESSION["mb_user_gui"]."',";
-				$sql .= "'".$module."',";
-				$sql .= "'".$_SESSION["mb_user_ip"]."',";
-				$sql .= "'".$_SESSION["mb_user_name"]."',";
-				$sql .= "'".$_SESSION["mb_user_id"]."',";
-				$sql .= "'".$this->url[$i]."'";
-				$sql .= ")";
-				$res = db_query($sql)or die(db_error());
 				if(!$res){
 					include_once(dirname(__FILE__)."/class_mb_exception.php");
 					$e = new mb_exception("class_log: Writing table mb_log failed.");
Modified: trunk/mapbender/http/javascripts/mod_log.php
--- trunk/mapbender/http/javascripts/mod_log.php	2008-01-21 08:36:05 UTC (rev 1998)
+++ trunk/mapbender/http/javascripts/mod_log.php	2008-01-21 09:07:57 UTC (rev 1999)
@@ -1,18 +1,9 @@
 mb_registerInitFunctions("mb_log_init()");
 function mb_log_init(){
 	mb_log = "mb_log_set";
-	var logdisplay = document.createElement("div");
-	var tmp = document.getElementById("log").appendChild(logdisplay);
-	tmp.setAttribute("id","logdisplay");
+try{if(logtype){}}catch(e){logtype="";}
 function mb_log_set(req, time_client){
-	var my = "../php/mod_log.php" + "?<?php echo SID; ?>&req=" + escape(req);
-	my += "&time_client=" + time_client;
-	var newdiv = document.createElement("div");
-	newdiv.innerHTML = "<img src='"+my+"'>";
-	document.getElementById("log").appendChild(newdiv);
-	var cnt = parseInt(document.getElementById("log").childNodes.length) - 2;
-	writeTag("","logdisplay", cnt);
+	mb_ajax_post('../php/mod_log.php'+"?<?php echo SID; ?>&gui_id=<?php echo $gui_id;?>&elementID=<?php echo $e_id;?>&req=" + escape(req)+ "&time_client=" + time_client, {req:req, time:time_client});
 	return true;
\ No newline at end of file
Modified: trunk/mapbender/http/php/mod_log.php
--- trunk/mapbender/http/php/mod_log.php	2008-01-21 08:36:05 UTC (rev 1998)
+++ trunk/mapbender/http/php/mod_log.php	2008-01-21 09:07:57 UTC (rev 1999)
@@ -18,9 +18,13 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-db_select_db(DB,$con);
+db_select_db(DB,$con);
+$gui_id = $_REQUEST['gui_id'];
+$e_id = $_REQUEST['elementID'];
+session_start();
+include(dirname(__FILE__)."/../include/dyn_php.php");
 if($_REQUEST['req']){
-	session_start();
 	ignore_user_abort();
 	$req = array();
 	$req[0] = urldecode($_REQUEST['req']);
@@ -28,13 +32,7 @@
 	if(empty($req)){$req = "init";}
 	include(dirname(__FILE__)."/../classes/class_log.php");
-	$log = new log("default", $req, $time_client);
-header ("Content-type: image/png");
-$im = imagecreate(1,1);
-$col = ImageColorAllocate ($im, 0, 0, 0);
-imagesetpixel ( $im, 1, 1, $col);
-ImagePNG ($im);
+	$log = new log("default", $req, $time_client, $logtype);
+echo "log into $logtype successful!";
More information about the Mapbender_commits mailing list
