[Mapbender-commits] r2038 - branches/2.5/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jan 29 07:49:26 EST 2008
Author: christoph
Date: 2008-01-29 07:49:26 -0500 (Tue, 29 Jan 2008)
New Revision: 2038
   branches/2.5/http/php/mod_changeEPSG.php
   branches/2.5/http/php/mod_editWMS_Metadata.php
   branches/2.5/http/php/nestedSets.php
prepared statements / parameter check
Modified: branches/2.5/http/php/mod_changeEPSG.php
--- branches/2.5/http/php/mod_changeEPSG.php	2008-01-29 12:46:00 UTC (rev 2037)
+++ branches/2.5/http/php/mod_changeEPSG.php	2008-01-29 12:49:26 UTC (rev 2038)
@@ -59,60 +59,73 @@
 	echo "var newExtent = new Array();";
 	for($i=0; $i < count($arraymapObj); $i++){
 		$temp = mb_split(",",$arraymapObj[$i]);
-		if(SYS_DBTYPE=='pgsql'){
-			$con = db_connect($DBSERVER,$OWNER,$PW);
-			$sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".preg_replace("/EPSG:/","",$temp[1])."),".preg_replace("/EPSG:/","",$_REQUEST["newSRS"]).")) as minx";
-			$resMinx = db_query($sqlMinx);
-			$minx = db_result($resMinx,0,"minx");
-			$sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".preg_replace("/EPSG:/","",$temp[1])."),".preg_replace("/EPSG:/","",$_REQUEST["newSRS"]).")) as miny";
-			$resMiny = db_query($sqlMiny);
-			$miny = db_result($resMiny,0,"miny");
-			$sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$temp[4]." ".$temp[5].")',".preg_replace("/EPSG:/","",$temp[1])."),".preg_replace("/EPSG:/","",$_REQUEST["newSRS"]).")) as maxx";
-			$resMaxx =db_query($sqlMaxx);
-			$maxx = db_result($resMaxx,0,"maxx");
-			$sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$temp[4]." ".$temp[5].")',".preg_replace("/EPSG:/","",$temp[1])."),".preg_replace("/EPSG:/","",$_REQUEST["newSRS"]).")) as maxy";
-			$resMaxy = db_query($sqlMaxy);
-			$maxy = db_result($resMaxy,0,"maxy");
-		}else{
-			$con_string = "host=$GEOS_DBSERVER port=$GEOS_PORT dbname=$GEOS_DB user=$GEOS_OWNER password=$GEOS_PW";
-			$con = pg_connect($con_string) or die ("Error while connecting database");
-			$resMinx = pg_query($con,$sqlMinx);
-			$minx = pg_fetch_result($resMinx,0,"minx");
-			$resMiny = pg_query($con,$sqlMiny);
-			$miny = pg_fetch_result($resMiny,0,"miny");
-			$resMaxx = pg_query($con,$sqlMaxx);
-			$maxx = pg_fetch_result($resMaxx,0,"maxx");
-			$resMaxy = pg_query($con,$sqlMaxy);
-			$maxy = pg_fetch_result($resMaxy,0,"maxy");
-		$extenty = $maxy - $miny;
-		$extentx = $maxx - $minx;
-		$relation_px_x = $temp[6] / $temp[7];
-		$relation_px_y = $temp[7] / $temp[6];
-		$relation_bbox_x = $extentx / $extenty;
-		if($relation_bbox_x <= $relation_px_x){
-			$centerx = $minx + ($extentx/2);
-			$minx = $centerx - $relation_px_x * $extenty / 2;
-			$maxx = $centerx + $relation_px_x * $extenty / 2;
+		// check if parameters are valid geometries to
+		// avoid SQL injections
+		$oldEPSG = preg_replace("/EPSG:/","",$temp[1]);
+		$newEPSG = preg_replace("/EPSG:/","",$_REQUEST["newSRS"]);
+		if (is_numeric($temp[2]) && is_numeric($temp[3]) && is_numeric($temp[4]) && is_numeric($temp[5]) && is_numeric($oldEPSG) && is_numeric($newEPSG)) {
+			if(SYS_DBTYPE=='pgsql'){
+				$con = db_connect($DBSERVER,$OWNER,$PW);
+				$sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".$oldEPSG."),".$newEPSG.")) as minx";
+				$resMinx = db_query($sqlMinx);
+				$minx = db_result($resMinx,0,"minx");
+				$sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".$oldEPSG."),".$newEPSG.")) as miny";
+				$resMiny = db_query($sqlMiny);
+				$miny = db_result($resMiny,0,"miny");
+				$sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$temp[4]." ".$temp[5].")',".$oldEPSG."),".$newEPSG.")) as maxx";
+				$resMaxx = db_query($sqlMaxx);
+				$maxx = db_result($resMaxx,0,"maxx");
+				$sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$temp[4]." ".$temp[5].")',".$oldEPSG."),".$newEPSG.")) as maxy";
+				$resMaxy = db_query($sqlMaxy);
+				$maxy = db_result($resMaxy,0,"maxy");
+			}else{
+				$con_string = "host=$GEOS_DBSERVER port=$GEOS_PORT dbname=$GEOS_DB user=$GEOS_OWNER password=$GEOS_PW";
+				$con = pg_connect($con_string) or die ("Error while connecting database");
+				$resMinx = pg_query($con,$sqlMinx);
+				$minx = pg_fetch_result($resMinx,0,"minx");
+				$resMiny = pg_query($con,$sqlMiny);
+				$miny = pg_fetch_result($resMiny,0,"miny");
+				$resMaxx = pg_query($con,$sqlMaxx);
+				$maxx = pg_fetch_result($resMaxx,0,"maxx");
+				$resMaxy = pg_query($con,$sqlMaxy);
+				$maxy = pg_fetch_result($resMaxy,0,"maxy");
+			$extenty = $maxy - $miny;
+			$extentx = $maxx - $minx;
+			$relation_px_x = $temp[6] / $temp[7];
+			$relation_px_y = $temp[7] / $temp[6];
+			$relation_bbox_x = $extentx / $extenty;
+			if($relation_bbox_x <= $relation_px_x){
+				$centerx = $minx + ($extentx/2);
+				$minx = $centerx - $relation_px_x * $extenty / 2;
+				$maxx = $centerx + $relation_px_x * $extenty / 2;
+			if($relation_bbox_x > $relation_px_x){
+				$centery = $miny + ($extenty/2);
+				$miny = $centery - $relation_px_y * $extentx / 2;
+				$maxy = $centery + $relation_px_y * $extentx / 2;
+			echo "newExtent[".$i."] = '".$temp[0].",".$_REQUEST["newSRS"].",".$minx.",".$miny.",".$maxx.",".$maxy."';";
-		if($relation_bbox_x > $relation_px_x){
-			$centery = $miny + ($extenty/2);
-			$miny = $centery - $relation_px_y * $extentx / 2;
-			$maxy = $centery + $relation_px_y * $extentx / 2;
-		echo "newExtent[".$i."] = '".$temp[0].",".$_REQUEST["newSRS"].",".$minx.",".$miny.",".$maxx.",".$maxy."';";
+		else {
+			echo "var e = new parent.Mb_exception('mod_changeEPSG.php: invalid input parameter (p1 = (" . $temp[2] . "," . $temp[3] . "), p2 = (" . $temp[4] . "," . $temp[5] . "), old EPSG: " . $oldEPSG . ", new EPSG: " . $newEPSG . ", ).');";
 	echo "</script>";
Modified: branches/2.5/http/php/mod_editWMS_Metadata.php
--- branches/2.5/http/php/mod_editWMS_Metadata.php	2008-01-29 12:46:00 UTC (rev 2037)
+++ branches/2.5/http/php/mod_editWMS_Metadata.php	2008-01-29 12:49:26 UTC (rev 2038)
@@ -101,51 +101,69 @@
 #Update handling
-if(isset($_REQUEST['update_content']) && $_REQUEST['update_content'] == true)
+if (isset($_REQUEST['update_content']) && $_REQUEST['update_content'] == true) {
-            $update_wms_sql = "UPDATE wms SET " .
-                      "wms_title = '".$_REQUEST['wms_title_box']."', " .
-                      "wms_abstract = '".$_REQUEST['wms_abstract_box']."', " .
-                      "fees = '".$_REQUEST['fees_box']."', " .
-                      "accessconstraints = '".$_REQUEST['accessconstraints_box']."', " .
-                      "contactperson = '".$_REQUEST['contactperson_box']."', " .
-                      "contactposition = '".$_REQUEST['contactposition_box']."', " .
-                      "contactorganization = '".$_REQUEST['contactorganization_box']."', " .
-                      "address = '".$_REQUEST['address_box']."', " .
-                      "city = '".$_REQUEST['city_box']."', " .
-                      "stateorprovince = '".$_REQUEST['stateorprovince_box']."', " .
-                      "postcode = '".$_REQUEST['postcode_box']."', " .
-                      "country = '".$_REQUEST['country_box']."', " .
-                      "contactvoicetelephone = '".$_REQUEST['contactvoicetelephone_box']."', " .
-                      "contactfacsimiletelephone = '".$_REQUEST['contactfacsimiletelephone_box']."', " .
-                      "contactelectronicmailaddress = '".$_REQUEST['contactelectronicmailaddress_box']."'";
-                      if (isset($_REQUEST['wms_timestamp_box']) && $_REQUEST['wms_timestamp_box'] <> "")
-                            $update_wms_sql .= ", " . "wms_timestamp = " .
-                            "'".guessTimestamp($_REQUEST['wms_timestamp_box'])."' ";
-   $update_wms_sql .= "WHERE wms_id = '".$_REQUEST['wms_id']."'";
-    $res_update_wms_sql = db_query($update_wms_sql);
-     while(list($key,$val) = each($_REQUEST))
+	$update_wms_sql = "UPDATE wms SET ";
+	$update_wms_sql .= "wms_title = $1, wms_abstract = $2, fees = $3, ";
+	$update_wms_sql .= "accessconstraints = $4, contactperson = $5, ";
+	$update_wms_sql .= "contactposition = $6, contactorganization = $7, ";
+	$update_wms_sql .= "address = $8, city = $9, stateorprovince = $10, ";
+	$update_wms_sql .= "postcode = $11, country = $12, ";
+	$update_wms_sql .= "contactvoicetelephone = $13, ";
+	$update_wms_sql .= "contactfacsimiletelephone = $14, ";
+	$update_wms_sql .= "contactelectronicmailaddress = $15 ";
+	$v = array();
+	array_push($v, $_REQUEST['wms_title_box']);
+	array_push($v, $_REQUEST['wms_abstract_box']);
+	array_push($v, $_REQUEST['fees_box']);
+	array_push($v, $_REQUEST['accessconstraints_box']);
+	array_push($v, $_REQUEST['contactperson_box']);
+	array_push($v, $_REQUEST['contactposition_box']);
+	array_push($v, $_REQUEST['contactorganization_box']);
+	array_push($v, $_REQUEST['address_box']);
+	array_push($v, $_REQUEST['city_box']);
+	array_push($v, $_REQUEST['stateorprovince_box']);
+	array_push($v, $_REQUEST['postcode_box']);
+	array_push($v, $_REQUEST['country_box']);
+	array_push($v, $_REQUEST['contactvoicetelephone_box']);
+	array_push($v, $_REQUEST['contactfacsimiletelephone_box']);
+	array_push($v, $_REQUEST['contactelectronicmailaddress_box']);
+	$t = array("s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s");
+	if (isset($_REQUEST['wms_timestamp_box']) && $_REQUEST['wms_timestamp_box'] <> "") {
+        $update_wms_sql .= ", wms_timestamp = $16 ";
+		array_push($v, guessTimestamp($_REQUEST['wms_timestamp_box']));
+		array_push($t, "s");
+		$update_wms_sql .= "WHERE wms_id = $17";
+	else {
+		$update_wms_sql .= "WHERE wms_id = $16";
+	array_push($v, 	$_REQUEST['wms_id']);
+    $res_update_wms_sql = db_prep_query($update_wms_sql, $v, $t);
+    while(list($key,$val) = each($_REQUEST))
         if(preg_match("/___/", $key))
             $myKey = explode("___", $key);
             $layer_id = preg_replace("/L_/","",$myKey[0]);
-            if($myKey[1]=="layer_abstract")
-                $layer_sql = "UPDATE layer SET layer_abstract = '$val' " .
-                             "WHERE layer_id = $layer_id AND fkey_wms_id = '".$_REQUEST['wms_id']."'";
-                $res_keyword_sql = db_query($layer_sql);
+            if($myKey[1]=="layer_abstract") {
+				$layer_sql = "UPDATE layer SET layer_abstract = $1 ";
+				$layer_sql .= "WHERE layer_id = $2 AND fkey_wms_id = $3";
+                $v = array($val, $layer_id, $_REQUEST['wms_id']);
+                $t = array("s", "i", "s");
+                $res_keyword_sql = db_prep_query($layer_sql, $v, $t);
-            if($myKey[1]=="layer_keywords")
+            if($myKey[1]=="layer_keywords") {
                 #Get all keywords depending on the given layer after user modification
                 $keywords  = explode(",",$val);
                 #delete all blanks from the keywords list
-                for($j = 0; $j < count($keywords); $j++)
+                for ($j = 0; $j < count($keywords); $j++) {
                     $word = $keywords[$j];
                     $word = trim($word);
                     $keywords[$j] = $word;
@@ -155,9 +173,12 @@
                 $keyword_sql = "SELECT keyword_id, keyword FROM keyword, layer_keyword, layer " .
                                "WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id " .
                                "AND layer_keyword.fkey_layer_id = layer.layer_id " .
-                               "AND layer.fkey_wms_id = '".$_REQUEST['wms_id']."'" .
-                               "AND layer.layer_id = $layer_id";
-                $res_keyword_sql = db_query($keyword_sql);
+                               "AND layer.fkey_wms_id = $1 " .
+                               "AND layer.layer_id = $2";
+                $v = array($_REQUEST['wms_id'], $layer_id);
+                $t = array("s", "i");
+                $res_keyword_sql = db_prep_query($keyword_sql, $v, $t);
                 while($keyword_row = db_fetch_array($res_keyword_sql))
                     $keyword = $keyword_row['keyword'];
@@ -171,19 +192,25 @@
                         #echo "1c: Keyword nicht in User Liste: Keyword: ", $keyword, ";<br>";
                         #Deleting reference to the keyword from the layer_keyword table.
                         $keyword_sql = "DELETE FROM layer_keyword " .
-                                       "WHERE fkey_layer_id = $layer_id " .
-                                       "AND fkey_keyword_id = $keyword_id";
-                        db_query($keyword_sql);
+                                       "WHERE fkey_layer_id = $1 " .
+                                       "AND fkey_keyword_id = $2";
+                        $v = array($layer_id, $keyword_id);
+                        $t = array("i", "i");
+                        db_prep_query($keyword_sql, $v, $t);
                         #Checking, if the keyword is in use by any layer
                         $layer_sql = "SELECT * FROM layer_keyword " .
-                                       "WHERE fkey_keyword_id = $keyword_id";
-                        $res_layer_sql = db_query($layer_sql);
+                                       "WHERE fkey_keyword_id = $1";
+                        $v = array($keyword_id);
+                        $t = array("i");
+                        $res_layer_sql = db_prep_query($layer_sql, $v, $t);
                         if(!($row = db_fetch_array($res_layer_sql)))
                             #If keyword will not longer be in use, delete it from keyword table
                             $keyword_sql = "DELETE FROM keyword " .
-                                           "WHERE keyword_id = $keyword_id";
+                                           "WHERE keyword_id = $1";
+                            $t = array("i");
                     #Keyword exists in the database and in the user data
@@ -211,8 +238,10 @@
                         $keyword = trim($keywords[$i]);
                         #Check, if the keyword is exsiting in the database
                         $keyword_sql = "SELECT keyword_id FROM keyword " .
-                                       "WHERE UPPER(keyword) = UPPER('$keyword')";
+                                       "WHERE UPPER(keyword) = UPPER($1)";
+                        $v = array($keyword);
+                        $t = array("s");
                         $keyword_row = db_fetch_array($res_keyword_sql);
                         if($keyword_row != null)
@@ -223,10 +252,15 @@
                         #Keyword does not exist in the database
                         else
-                            $keyword_sql = "INSERT INTO keyword (keyword) VALUES ('$keyword')";
-                            $keyword_sql = "SELECT keyword_id FROM keyword WHERE keyword = '$keyword'";
+                            $keyword_sql = "INSERT INTO keyword (keyword) VALUES ($1)";
+                            $t = array("s");
+                            $keyword_sql = "SELECT keyword_id FROM keyword WHERE keyword = $1";
+                            $t = array("s");
@@ -236,8 +270,10 @@
                         #Inserting the reference between layer and keyword in the layer_keyword table
                         $keyword_sql = "INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) " .
-                                       "VALUES ('$layer_id', '$keyword_id')";
+                                       "VALUES ($1, $2)";
+                        $t = array("s", "s");
                 #Delete all elements from array
@@ -253,8 +289,10 @@
 if(isset($_REQUEST['delete_preview']) && $_REQUEST['delete_preview']=='1'
 	&& isset($_REQUEST['layer_id']))
-    $preview_sql = "DELETE FROM layer_preview WHERE fkey_layer_id = ".$_REQUEST['layer_id']."";
-    $res_preview_sql = db_query($preview_sql);
+    $preview_sql = "DELETE FROM layer_preview WHERE fkey_layer_id = $1";
+    $v = array($_REQUEST['layer_id']);
+    $t = array("s");
+    $res_preview_sql = db_prep_query($preview_sql, $v, $t);
     die("Preview has been deleted!</body></html>");
@@ -277,8 +315,10 @@
     #Querying information from wms data table
-    $wms_sql = "SELECT wms_id, wms_title FROM wms WHERE wms_owner = ".$_SESSION["mb_user_id"]. " ORDER BY wms_title";
-    $res_wms_sql = db_query($wms_sql);
+    $wms_sql = "SELECT wms_id, wms_title FROM wms WHERE wms_owner = $1 ORDER BY wms_title";
+    $v = array($_SESSION["mb_user_id"]);
+    $t = array("i");
+    $res_wms_sql = db_prep_query($wms_sql, $v, $t);
     #wms-selection
     $selectBox = "";
@@ -321,8 +361,10 @@
 if(isset($wms_id) == true && $wms_id <>0)
-	$selected_wms_sql = "SELECT * FROM wms WHERE wms_id = '".$wms_id."'";
-    $res_selected_wms_sql = db_query($selected_wms_sql);
+	$selected_wms_sql = "SELECT * FROM wms WHERE wms_id = $1";
+	$v = array($wms_id);
+	$t = array("s");
+    $res_selected_wms_sql = db_prep_query($selected_wms_sql, $v, $t);
     $selected_row = db_fetch_array($res_selected_wms_sql);
@@ -400,9 +442,11 @@
 <?php
-    $layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = '".$wms_id."'" .
+    $layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = $1" .
                  " ORDER BY layer_pos";
+    $t = array("s");
     while($layer_row = db_fetch_array($res_layer_sql))
@@ -419,9 +463,11 @@
         $keyword_sql = "SELECT keyword FROM keyword, layer_keyword, layer " .
-                       "AND layer.fkey_wms_id = '".$wms_id."' " .
-                       "AND layer.layer_id = ".$layer_row['layer_id']."";
+        $v = array($wms_id, $layer_row['layer_id']);
         $keywordList = "";
         $seperator = "";
Modified: branches/2.5/http/php/nestedSets.php
--- branches/2.5/http/php/nestedSets.php	2008-01-29 12:46:00 UTC (rev 2037)
+++ branches/2.5/http/php/nestedSets.php	2008-01-29 12:49:26 UTC (rev 2038)
@@ -58,16 +58,16 @@
 	if(value == 'insert'){
 		if(document.forms[0].title.value == ''){alert("Bitte geben Sie einen Titel an."); permission = false; return;}
-		if(document.forms[0].left.value == ''){alert("Wählen Sie eine Position."); permission = false; return;}
+		if(document.forms[0].left.value == ''){alert("W�hlen Sie eine Position."); permission = false; return;}
       	if(document.forms[0].title.value == ''){alert("Please insert a title."); permission = false; return;}
 		if(document.forms[0].left.value == ''){alert("Please choose a position."); permission = false; return;}
-      if(document.forms[0].wmsList.selectedIndex > 0 && document.forms[0].layer.selectedIndex == 0){alert("Wählen Sie einen Layer."); permission = false; return;}
+      if(document.forms[0].wmsList.selectedIndex > 0 && document.forms[0].layer.selectedIndex == 0){alert("W�hlen Sie einen Layer."); permission = false; return;}
 		if(permission == true){document.forms[0].action.value = "insert"; document.forms[0].submit();}
 	if(value == 'delete'){
-		//permission = confirm("Soll das Objekt mit Inhalten gelöscht werden?");
+		//permission = confirm("Soll das Objekt mit Inhalten gel�scht werden?");
 		permission = confirm("Do you want to delete the object and the content of the object?");
 		document.forms[0].action.value = "delete";
@@ -77,7 +77,7 @@
 	if(value == 'update'){
-		if(document.forms[0].left.value == ''){alert("Bitte wählen Sie eine Position."); permission = false; return;}
+		if(document.forms[0].left.value == ''){alert("Bitte w�hlen Sie eine Position."); permission = false; return;}
 		if(document.forms[0].title.value == ''){alert("Please fill in a labeling."); permission = false; return;}
@@ -87,10 +87,10 @@
 	if(value == 'add'){
-		if(document.forms[0].guiList.selectedIndex == 0){alert("Bitte wählen Sie eine GUI."); permission = false; return;}
-		if(document.forms[0].wmsList.selectedIndex == 0){alert("Bitte wählen Sie einen WMS."); permission = false; return;}
-		if(document.forms[0].layer.selectedIndex == 0){alert("Bitte wählen Sie eine Ebene."); permission = false; return;}
+		if(document.forms[0].guiList.selectedIndex == 0){alert("Bitte w�hlen Sie eine GUI."); permission = false; return;}
+		if(document.forms[0].wmsList.selectedIndex == 0){alert("Bitte w�hlen Sie einen WMS."); permission = false; return;}
+		if(document.forms[0].layer.selectedIndex == 0){alert("Bitte w�hlen Sie eine Ebene."); permission = false; return;}
 		if(document.forms[0].left.value == ''){alert("Please fill in a position."); permission = false; return;}
@@ -116,26 +116,31 @@
 if(isset($action) && $action == "insert"){
 	$temp = explode("###", $layer);
-	$sql = "SELECT rgt FROM gui_treegde WHERE lft = ".$left." AND fkey_gui_id = '".$guiList."'";
-	$res = db_query($sql);
+	$sql = "SELECT rgt FROM gui_treegde WHERE lft = $1 AND fkey_gui_id = $1";
+	$v = array($left, $guiList);
+	$t = array("i", "s");
+	$res = db_prep_query($sql, $v, $t);
 	if($pos == 'in'){$left = $left + 1;}
 	else if($pos == 'hinter'){$left = db_result($res,0,"rgt") + 1;}
 	else{ $left = $left + 2;}
-	$sql = "UPDATE gui_treegde SET rgt=rgt+2 WHERE rgt >=". $left." AND fkey_gui_id = '".$guiList."'";
-	db_query($sql);
-	$sql = "UPDATE gui_treegde SET lft=lft+2 WHERE lft >=".$left." AND fkey_gui_id = '".$guiList."'";
-	db_query($sql);
-	$sql = "INSERT INTO gui_treegde(fkey_gui_id, fkey_layer_id, lft,rgt, my_layer_title, layer, wms_id) VALUES(";
-		$sql .= "'".$guiList."', ";
-		$sql .= "'".$temp[0]."', ";
-		$sql .= $left.", ";
-		$sql .= ($left+1).", ";
-		$sql .= "'".$name."', ";
-		$sql .= "'".$temp[1]."', ";
-		$sql .= "'".$wmsList."'";
-		$sql .= ")";
-		#echo $sql . "<br>";
-	db_query($sql);
+	$sql = "UPDATE gui_treegde SET rgt=rgt+2 WHERE rgt >= $1 AND fkey_gui_id = $2";
+	db_prep_query($sql, $v, $t);
+	$sql = "UPDATE gui_treegde SET lft=lft+2 WHERE lft >= $1 AND fkey_gui_id = $2";
+	$sql = "INSERT INTO gui_treegde(fkey_gui_id, fkey_layer_id, lft,rgt, ";
+	$sql .= "my_layer_title, layer, wms_id) VALUES($1, $2, $3, $4, $5, $6, $7)";
+		#echo $sql . "<br>";
+	$v = array($guiList, $temp[0], $left, ($left+1), $name, $temp[1], $wmsList);
+	$t = array("s", "s", "i", "i", "s", "s", "s");
 	if($layer == ""){
 		$left = $left + 1;
@@ -152,53 +157,79 @@
 if(isset($action) && $action == "delete"){
 	if($left){
-		$sql = "SELECT rgt FROM gui_treegde WHERE lft =". $left." AND fkey_gui_id = '".$guiList."'";
+		$sql = "SELECT rgt FROM gui_treegde WHERE lft = $1 AND fkey_gui_id = $2";
 		$right = db_result($res,0,"rgt");
-		$sql = "DELETE FROM gui_treegde WHERE lft BETWEEN ".$left." and ".$right." AND fkey_gui_id = '".$guiList."'";
-		db_query($sql);
-		$sql = "UPDATE gui_treegde SET lft=lft-((".$right."-".$left."+1)) WHERE lft>".$right." AND fkey_gui_id = '".$guiList."'";
-		db_query($sql);
-		$sql = "UPDATE gui_treegde SET rgt=rgt-((".$right."-".$left."+1)) WHERE rgt>".$right." AND fkey_gui_id = '".$guiList."'";
-		db_query($sql);
+		$sql = "DELETE FROM gui_treegde WHERE lft BETWEEN $1 and $2 AND fkey_gui_id = $3";
+		$v = array($left, $right, $guiList);
+		$t = array("i", "i", "s");
+		$sql = "UPDATE gui_treegde SET lft=lft-(($1 - $2 + 1)) WHERE lft > $3 AND fkey_gui_id = $4";
+		$v = array($right, $left, $right, $guiList);
+		$t = array("i", "i", "i", "s");
+		$sql = "UPDATE gui_treegde SET rgt=rgt-(($1 - $2 + 1)) WHERE rgt > $3 AND fkey_gui_id = $4";
 if(isset($action) && $action == "update"){
 	$sql = "UPDATE gui_treegde SET ";
-	$sql .= "my_layer_title = '".$name."', ";
-	$sql .= "fkey_layer_id = '".$temp[0]."', ";
-	$sql .= "layer = '".$temp[1]."', ";
-	$sql .= "wms_id = '" . $wmsList."'";
-	$sql .= " WHERE lft = ".$left." AND fkey_gui_id = '".$guiList."'";
-	db_query($sql);
+	$sql .= "my_layer_title = $1, ";
+	$sql .= "fkey_layer_id = $2, ";
+	$sql .= "layer = $3, ";
+	$sql .= "wms_id = $4";
+	$sql .= " WHERE lft = $5 AND fkey_gui_id = $6";
+	$v = array($name, $temp[0], $temp[1], $wmsList, $left, $guiList);
+	$t = array("s", "s", "s", "s", "i", "s");
 if(isset($action) && $action == "add"){
-	$sql_val = "SELECT * FROM gui_treegde WHERE lft =". $left." AND fkey_gui_id = '".$guiList."'";
-	$res_val = db_query($sql_val);
+	$sql_val = "SELECT * FROM gui_treegde WHERE lft = $1 AND fkey_gui_id = $2";
+	$res = db_prep_query($sql_val, $v, $t);
+	$sql .= "fkey_layer_id = $1, layer = $2, wms_id =  $3 ";
+	$sql .= "WHERE lft = $4 AND fkey_gui_id = $5";
-	$sql .= "fkey_layer_id = ";
-	$sql .= "'";
-	if(db_result($res_val, 0, "fkey_layer_id") != ''){ $sql .= db_result($res_val, 0, "fkey_layer_id") . ","; }
-	$sql .=  $temp[0] . "', ";
+	$v = array();
+	$t = array("s", "s", "s", "i", "s");
+	if (db_result($res_val, 0, "fkey_layer_id") != '') {
+		array_push($v, db_result($res_val, 0, "fkey_layer_id") . "," . $temp[0]);
+	else {
+		array_push($v, $temp[0]);
-	$sql .= "layer = ";
-	$sql .= "'";
-	if(db_result($res_val, 0, "layer") != ''){ $sql .= db_result($res_val, 0, "layer") . ","; }
-	$sql .= $temp[1] . "', ";
+	if (db_result($res_val, 0, "layer") != '') {
+		array_push($v, db_result($res_val, 0, "layer") . "," . $temp[1]);
+	else {
+		array_push($v, $temp[1]);
-	$sql .= "wms_id = ";
-	$sql .= "'";
-	if(db_result($res_val, 0, "wms_id") != ''){ $sql .= db_result($res_val, 0, "wms_id") . ","; }
-	$sql .= $wmsList . "' ";
-	db_query($sql);
+	if (db_result($res_val, 0, "wms_id") != '') {
+		array_push($v, db_result($res_val, 0, "wms_id") . "," . $wmsList);
+	else {
+		array_push($v, $wmsList);
+	array_push($v, $left);
+	array_push($v, $guiList);
 <br />
@@ -228,14 +259,19 @@
 $admin = new administration();
 $ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
-$sql = "SELECT * FROM gui WHERE gui_id IN ("; for($i=0;
-$i<count($ownguis); $i++){
-				if($i>0){ $sql .= ",";}
-				$sql .= "'".$ownguis[$i]."'";
+$sql = "SELECT * FROM gui WHERE gui_id IN (";
+$v = $ownguis;
+$t = array();
+for ($i = 1; $i <= count($ownguis); $i++){
+	if ($i > 1) {
+		$sql .= ",";
+	$sql .= "$" . $i;
 $sql .= ") ORDER BY gui_name";
-$res = db_query($sql);
+$res = db_prep_query($sql, $v, $t);
 $cnt = 0;
 echo "<select class='guiList' size='10' name='guiList' class='guiList'  onchange='document.forms[0].submit()'>";
 echo "<option value=''>GUI ...</option>";
@@ -265,9 +301,11 @@
 	if(isset($guiList) && $guiList != ""){
 		$sql = "SELECT gui_wms.fkey_wms_id, wms.wms_title FROM gui_wms ";
 		$sql .= "INNER JOIN wms ON gui_wms.fkey_wms_id = wms.wms_id  ";
-		$sql .= "WHERE gui_wms.fkey_gui_id = '" . $guiList . "' ";
+		$sql .= "WHERE gui_wms.fkey_gui_id = $1 ";
 		$sql .= "ORDER BY wms.wms_title";
+		$v = array($guiList);
+		$t = array("s");
 		$cnt = 0;
 		while($row = db_fetch_array($res)){
 			echo "<option value='".$row["fkey_wms_id"]."' ";
@@ -293,9 +331,11 @@
 	if(isset($wmsList) && $wmsList != ""){
 		$sql_l = "SELECT gui_layer.fkey_layer_id, layer.layer_name, layer.layer_title FROM gui_layer ";
 		$sql_l .= "LEFT JOIN layer ON gui_layer.fkey_layer_id = layer.layer_id ";
-		$sql_l .= "WHERE gui_layer.gui_layer_wms_id = " . $wmsList . " AND layer.layer_parent = '0' AND gui_layer.fkey_gui_id = '".$guiList."'";
+		$sql_l .= "WHERE gui_layer.gui_layer_wms_id = $1 AND layer.layer_parent = '0' AND gui_layer.fkey_gui_id = $2";
 		$sql_l .= " ORDER BY layer.layer_title";
-		$res_l = db_query($sql_l);
+		$v = array($wmsList, $guiList);
+		$res_l = db_prep_query($sql_l, $v, $t);
 		$cnt = 0;
 		while($row = db_fetch_array($res_l)){
 			echo "<option value='".$row["fkey_layer_id"]."###".$row["layer_name"]."'>";
More information about the Mapbender_commits mailing list
