[Mapbender-commits] r2574 - in branches/dev_lenkne/http: . mb_admin mb_admin/img mb_admin/inc mb_admin/mod mb_admin/mod/editFilteredUser mb_admin/mod/editGuiElement
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jul 2 07:51:46 EDT 2008
Author: lenkne
Date: 2008-07-02 07:51:45 -0400 (Wed, 02 Jul 2008)
New Revision: 2574
Added:
   branches/dev_lenkne/http/mb_admin/
   branches/dev_lenkne/http/mb_admin/img/
   branches/dev_lenkne/http/mb_admin/img/progress_indicator.gif
   branches/dev_lenkne/http/mb_admin/inc/
   branches/dev_lenkne/http/mb_admin/inc/form.js
   branches/dev_lenkne/http/mb_admin/inc/mb_admin_functions.js
   branches/dev_lenkne/http/mb_admin/mod/
   branches/dev_lenkne/http/mb_admin/mod/editFilteredUser/
   branches/dev_lenkne/http/mb_admin/mod/editFilteredUser/editFilteredUser.php
   branches/dev_lenkne/http/mb_admin/mod/editGuiElement/
   branches/dev_lenkne/http/mb_admin/mod/editGuiElement/editGuiElement.php
admin module
Added: branches/dev_lenkne/http/mb_admin/img/progress_indicator.gif
(Binary files differ)
Property changes on: branches/dev_lenkne/http/mb_admin/img/progress_indicator.gif
___________________________________________________________________
   + application/octet-stream
Added: branches/dev_lenkne/http/mb_admin/inc/form.js
--- branches/dev_lenkne/http/mb_admin/inc/form.js	                        (rev 0)
+++ branches/dev_lenkne/http/mb_admin/inc/form.js	2008-07-02 11:51:45 UTC (rev 2574)
@@ -0,0 +1,601 @@
+ * jQuery Form Plugin
+ * version: 2.12 (06/07/2008)
+ * @requires jQuery v1.2.2 or later
+ * Examples and documentation at: http://malsup.com/jquery/form/
+ * Dual licensed under the MIT and GPL licenses:
+ *   http://www.opensource.org/licenses/mit-license.php
+ *   http://www.gnu.org/licenses/gpl.html
+ * Revision: $Id$
+(function($) {
+    Usage Note:
+    Do not use both ajaxSubmit and ajaxForm on the same form.  These
+    functions are intended to be exclusive.  Use ajaxSubmit if you want
+    to bind your own submit handler to the form.  For example,
+    $(document).ready(function() {
+        $('#myForm').bind('submit', function() {
+            $(this).ajaxSubmit({
+                target: '#output'
+            return false; // <-- important!
+    Use ajaxForm when you want the plugin to manage all the event binding
+    for you.  For example,
+        $('#myForm').ajaxForm({
+            target: '#output'
+    When using ajaxForm, the ajaxSubmit function will be invoked for you
+    at the appropriate time.
+ * ajaxSubmit() provides a mechanism for immediately submitting
+ * an HTML form using AJAX.
+$.fn.ajaxSubmit = function(options) {
+    // fast fail if nothing selected (http://dev.jquery.com/ticket/2752)
+    if (!this.length) {
+        log('ajaxSubmit: skipping submit process - no element selected');
+        return this;
+    if (typeof options == 'function')
+        options = { success: options };
+    options = $.extend({
+        url:  this.attr('action') || window.location.toString(),
+        type: this.attr('method') || 'GET'
+    }, options || {});
+    // hook for manipulating the form data before it is extracted;
+    // convenient for use with rich editors like tinyMCE or FCKEditor
+    var veto = {};
+    this.trigger('form-pre-serialize', [this, options, veto]);
+    if (veto.veto) {
+        log('ajaxSubmit: submit vetoed via form-pre-serialize trigger');
+        return this;
+    var a = this.formToArray(options.semantic);
+    if (options.data) {
+        options.extraData = options.data;
+        for (var n in options.data)
+            a.push( { name: n, value: options.data[n] } );
+    // give pre-submit callback an opportunity to abort the submit
+    if (options.beforeSubmit && options.beforeSubmit(a, this, options) === false) {
+        log('ajaxSubmit: submit aborted via beforeSubmit callback');
+        return this;
+    // fire vetoable 'validate' event
+    this.trigger('form-submit-validate', [a, this, options, veto]);
+    if (veto.veto) {
+        log('ajaxSubmit: submit vetoed via form-submit-validate trigger');
+        return this;
+    var q = $.param(a);
+    if (options.type.toUpperCase() == 'GET') {
+        options.url += (options.url.indexOf('?') >= 0 ? '&' : '?') + q;
+        options.data = null;  // data is null for 'get'
+    else
+        options.data = q; // data is the query string for 'post'
+    var $form = this, callbacks = [];
+    if (options.resetForm) callbacks.push(function() { $form.resetForm(); });
+    if (options.clearForm) callbacks.push(function() { $form.clearForm(); });
+    // perform a load on the target only if dataType is not provided
+    if (!options.dataType && options.target) {
+        var oldSuccess = options.success || function(){};
+        callbacks.push(function(data) {
+            $(options.target).html(data).each(oldSuccess, arguments);
+    else if (options.success)
+        callbacks.push(options.success);
+    options.success = function(data, status) {
+        for (var i=0, max=callbacks.length; i < max; i++)
+            callbacks[i](data, status, $form);
+    // are there files to upload?
+    var files = $('input:file', this).fieldValue();
+    var found = false;
+    for (var j=0; j < files.length; j++)
+        if (files[j])
+            found = true;
+    // options.iframe allows user to force iframe mode
+   if (options.iframe || found) {
+       // hack to fix Safari hang (thanks to Tim Molendijk for this)
+       // see:  http://groups.google.com/group/jquery-dev/browse_thread/thread/36395b7ab510dd5d
+       if ($.browser.safari && options.closeKeepAlive)
+           $.get(options.closeKeepAlive, fileUpload);
+       else
+           fileUpload();
+   else
+       $.ajax(options);
+    // fire 'notify' event
+    this.trigger('form-submit-notify', [this, options]);
+    return this;
+    // private function for handling file uploads (hat tip to YAHOO!)
+    function fileUpload() {
+        var form = $form[0];
+        if ($(':input[@name=submit]', form).length) {
+            alert('Error: Form elements must not be named "submit".');
+            return;
+        var opts = $.extend({}, $.ajaxSettings, options);
+        var id = 'jqFormIO' + (new Date().getTime());
+        var $io = $('<iframe id="' + id + '" name="' + id + '" />');
+        var io = $io[0];
+        if ($.browser.msie || $.browser.opera)
+            io.src = 'javascript:false;document.write("");';
+        $io.css({ position: 'absolute', top: '-1000px', left: '-1000px' });
+        var xhr = { // mock object
+            responseText: null,
+            responseXML: null,
+            status: 0,
+            statusText: 'n/a',
+            getAllResponseHeaders: function() {},
+            getResponseHeader: function() {},
+            setRequestHeader: function() {}
+        var g = opts.global;
+        // trigger ajax global events so that activity/block indicators work like normal
+        if (g && ! $.active++) $.event.trigger("ajaxStart");
+        if (g) $.event.trigger("ajaxSend", [xhr, opts]);
+        var cbInvoked = 0;
+        var timedOut = 0;
+        // add submitting element to data if we know it
+        var sub = form.clk;
+        if (sub) {
+            var n = sub.name;
+            if (n && !sub.disabled) {
+                options.extraData = options.extraData || {};
+                options.extraData[n] = sub.value;
+                if (sub.type == "image") {
+                    options.extraData[name+'.x'] = form.clk_x;
+                    options.extraData[name+'.y'] = form.clk_y;
+        // take a breath so that pending repaints get some cpu time before the upload starts
+        setTimeout(function() {
+            // make sure form attrs are set
+            var t = $form.attr('target'), a = $form.attr('action');
+            $form.attr({
+                target:   id,
+                encoding: 'multipart/form-data',
+                enctype:  'multipart/form-data',
+                method:   'POST',
+                action:   opts.url
+            // support timout
+            if (opts.timeout)
+                setTimeout(function() { timedOut = true; cb(); }, opts.timeout);
+            // add "extra" data to form if provided in options
+            var extraInputs = [];
+            try {
+                if (options.extraData)
+                    for (var n in options.extraData)
+                        extraInputs.push(
+                            $('<input type="hidden" name="'+n+'" value="'+options.extraData[n]+'" />')
+                                .appendTo(form)[0]);
+                // add iframe to doc and submit the form
+                $io.appendTo('body');
+                io.attachEvent ? io.attachEvent('onload', cb) : io.addEventListener('load', cb, false);
+                form.submit();
+            finally {
+                // reset attrs and remove "extra" input elements
+                $form.attr('action', a);
+                t ? $form.attr('target', t) : $form.removeAttr('target');
+                $(extraInputs).remove();
+        }, 10);
+        function cb() {
+            if (cbInvoked++) return;
+            io.detachEvent ? io.detachEvent('onload', cb) : io.removeEventListener('load', cb, false);
+            var operaHack = 0;
+            var ok = true;
+            try {
+                if (timedOut) throw 'timeout';
+                // extract the server response from the iframe
+                var data, doc;
+                doc = io.contentWindow ? io.contentWindow.document : io.contentDocument ? io.contentDocument : io.document;
+                if (doc.body == null && !operaHack && $.browser.opera) {
+                    // In Opera 9.2.x the iframe DOM is not always traversable when
+                    // the onload callback fires so we give Opera 100ms to right itself
+                    operaHack = 1;
+                    cbInvoked--;
+                    setTimeout(cb, 100);
+                    return;
+                xhr.responseText = doc.body ? doc.body.innerHTML : null;
+                xhr.responseXML = doc.XMLDocument ? doc.XMLDocument : doc;
+                xhr.getResponseHeader = function(header){
+                    var headers = {'content-type': opts.dataType};
+                    return headers[header];
+                if (opts.dataType == 'json' || opts.dataType == 'script') {
+                    var ta = doc.getElementsByTagName('textarea')[0];
+                    xhr.responseText = ta ? ta.value : xhr.responseText;
+                else if (opts.dataType == 'xml' && !xhr.responseXML && xhr.responseText != null) {
+                    xhr.responseXML = toXml(xhr.responseText);
+                data = $.httpData(xhr, opts.dataType);
+            catch(e){
+                ok = false;
+                $.handleError(opts, xhr, 'error', e);
+            // ordering of these callbacks/triggers is odd, but that's how $.ajax does it
+            if (ok) {
+                opts.success(data, 'success');
+                if (g) $.event.trigger("ajaxSuccess", [xhr, opts]);
+            if (g) $.event.trigger("ajaxComplete", [xhr, opts]);
+            if (g && ! --$.active) $.event.trigger("ajaxStop");
+            if (opts.complete) opts.complete(xhr, ok ? 'success' : 'error');
+            // clean up
+                $io.remove();
+                xhr.responseXML = null;
+            }, 100);
+        function toXml(s, doc) {
+            if (window.ActiveXObject) {
+                doc = new ActiveXObject('Microsoft.XMLDOM');
+                doc.async = 'false';
+                doc.loadXML(s);
+            else
+                doc = (new DOMParser()).parseFromString(s, 'text/xml');
+            return (doc && doc.documentElement && doc.documentElement.tagName != 'parsererror') ? doc : null;
+ * ajaxForm() provides a mechanism for fully automating form submission.
+ * The advantages of using this method instead of ajaxSubmit() are:
+ * 1: This method will include coordinates for <input type="image" /> elements (if the element
+ *    is used to submit the form).
+ * 2. This method will include the submit element's name/value data (for the element that was
+ *    used to submit the form).
+ * 3. This method binds the submit() method to the form for you.
+ * The options argument for ajaxForm works exactly as it does for ajaxSubmit.  ajaxForm merely
+ * passes the options argument along after properly binding events for submit elements and
+ * the form itself.
+$.fn.ajaxForm = function(options) {
+    return this.ajaxFormUnbind().bind('submit.form-plugin',function() {
+        $(this).ajaxSubmit(options);
+        return false;
+    }).each(function() {
+        // store options in hash
+        $(":submit,input:image", this).bind('click.form-plugin',function(e) {
+            var $form = this.form;
+            $form.clk = this;
+            if (this.type == 'image') {
+                if (e.offsetX != undefined) {
+                    $form.clk_x = e.offsetX;
+                    $form.clk_y = e.offsetY;
+                } else if (typeof $.fn.offset == 'function') { // try to use dimensions plugin
+                    var offset = $(this).offset();
+                    $form.clk_x = e.pageX - offset.left;
+                    $form.clk_y = e.pageY - offset.top;
+                } else {
+                    $form.clk_x = e.pageX - this.offsetLeft;
+                    $form.clk_y = e.pageY - this.offsetTop;
+            // clear form vars
+            setTimeout(function() { $form.clk = $form.clk_x = $form.clk_y = null; }, 10);
+// ajaxFormUnbind unbinds the event handlers that were bound by ajaxForm
+$.fn.ajaxFormUnbind = function() {
+    this.unbind('submit.form-plugin');
+    return this.each(function() {
+        $(":submit,input:image", this).unbind('click.form-plugin');
+ * formToArray() gathers form element data into an array of objects that can
+ * be passed to any of the following ajax functions: $.get, $.post, or load.
+ * Each object in the array has both a 'name' and 'value' property.  An example of
+ * an array for a simple login form might be:
+ * [ { name: 'username', value: 'jresig' }, { name: 'password', value: 'secret' } ]
+ * It is this array that is passed to pre-submit callback functions provided to the
+ * ajaxSubmit() and ajaxForm() methods.
+$.fn.formToArray = function(semantic) {
+    var a = [];
+    if (this.length == 0) return a;
+    var form = this[0];
+    var els = semantic ? form.getElementsByTagName('*') : form.elements;
+    if (!els) return a;
+    for(var i=0, max=els.length; i < max; i++) {
+        var el = els[i];
+        var n = el.name;
+        if (!n) continue;
+        if (semantic && form.clk && el.type == "image") {
+            // handle image inputs on the fly when semantic == true
+            if(!el.disabled && form.clk == el)
+                a.push({name: n+'.x', value: form.clk_x}, {name: n+'.y', value: form.clk_y});
+            continue;
+        var v = $.fieldValue(el, true);
+        if (v && v.constructor == Array) {
+            for(var j=0, jmax=v.length; j < jmax; j++)
+                a.push({name: n, value: v[j]});
+        else if (v !== null && typeof v != 'undefined')
+            a.push({name: n, value: v});
+    if (!semantic && form.clk) {
+        // input type=='image' are not found in elements array! handle them here
+        var inputs = form.getElementsByTagName("input");
+        for(var i=0, max=inputs.length; i < max; i++) {
+            var input = inputs[i];
+            var n = input.name;
+            if(n && !input.disabled && input.type == "image" && form.clk == input)
+    return a;
+ * Serializes form data into a 'submittable' string. This method will return a string
+ * in the format: name1=value1&amp;name2=value2
+$.fn.formSerialize = function(semantic) {
+    //hand off to jQuery.param for proper encoding
+    return $.param(this.formToArray(semantic));
+ * Serializes all field elements in the jQuery object into a query string.
+ * This method will return a string in the format: name1=value1&amp;name2=value2
+$.fn.fieldSerialize = function(successful) {
+    var a = [];
+    this.each(function() {
+        var n = this.name;
+        if (!n) return;
+        var v = $.fieldValue(this, successful);
+            for (var i=0,max=v.length; i < max; i++)
+                a.push({name: n, value: v[i]});
+            a.push({name: this.name, value: v});
+    return $.param(a);
+ * Returns the value(s) of the element in the matched set.  For example, consider the following form:
+ *  <form><fieldset>
+ *      <input name="A" type="text" />
+ *      <input name="B" type="checkbox" value="B1" />
+ *      <input name="B" type="checkbox" value="B2"/>
+ *      <input name="C" type="radio" value="C1" />
+ *      <input name="C" type="radio" value="C2" />
+ *  </fieldset></form>
+ *  var v = $(':text').fieldValue();
+ *  // if no values are entered into the text inputs
+ *  v == ['','']
+ *  // if values entered into the text inputs are 'foo' and 'bar'
+ *  v == ['foo','bar']
+ *  var v = $(':checkbox').fieldValue();
+ *  // if neither checkbox is checked
+ *  v === undefined
+ *  // if both checkboxes are checked
+ *  v == ['B1', 'B2']
+ *  var v = $(':radio').fieldValue();
+ *  // if neither radio is checked
+ *  v === undefined
+ *  // if first radio is checked
+ *  v == ['C1']
+ * The successful argument controls whether or not the field element must be 'successful'
+ * (per http://www.w3.org/TR/html4/interact/forms.html#successful-controls).
+ * The default value of the successful argument is true.  If this value is false the value(s)
+ * for each element is returned.
+ * Note: This method *always* returns an array.  If no valid value can be determined the
+ *       array will be empty, otherwise it will contain one or more values.
+$.fn.fieldValue = function(successful) {
+    for (var val=[], i=0, max=this.length; i < max; i++) {
+        var el = this[i];
+        var v = $.fieldValue(el, successful);
+        if (v === null || typeof v == 'undefined' || (v.constructor == Array && !v.length))
+            continue;
+        v.constructor == Array ? $.merge(val, v) : val.push(v);
+    return val;
+ * Returns the value of the field element.
+$.fieldValue = function(el, successful) {
+    var n = el.name, t = el.type, tag = el.tagName.toLowerCase();
+    if (typeof successful == 'undefined') successful = true;
+    if (successful && (!n || el.disabled || t == 'reset' || t == 'button' ||
+        (t == 'checkbox' || t == 'radio') && !el.checked ||
+        (t == 'submit' || t == 'image') && el.form && el.form.clk != el ||
+        tag == 'select' && el.selectedIndex == -1))
+            return null;
+    if (tag == 'select') {
+        var index = el.selectedIndex;
+        if (index < 0) return null;
+        var a = [], ops = el.options;
+        var one = (t == 'select-one');
+        var max = (one ? index+1 : ops.length);
+        for(var i=(one ? index : 0); i < max; i++) {
+            var op = ops[i];
+            if (op.selected) {
+                // extra pain for IE...
+                var v = $.browser.msie && !(op.attributes['value'].specified) ? op.text : op.value;
+                if (one) return v;
+                a.push(v);
+        return a;
+    return el.value;
+ * Clears the form data.  Takes the following actions on the form's input fields:
+ *  - input text fields will have their 'value' property set to the empty string
+ *  - select elements will have their 'selectedIndex' property set to -1
+ *  - checkbox and radio inputs will have their 'checked' property set to false
+ *  - inputs of type submit, button, reset, and hidden will *not* be effected
+ *  - button elements will *not* be effected
+$.fn.clearForm = function() {
+        $('input,select,textarea', this).clearFields();
+ * Clears the selected form elements.
+$.fn.clearFields = $.fn.clearInputs = function() {
+        var t = this.type, tag = this.tagName.toLowerCase();
+        if (t == 'text' || t == 'password' || tag == 'textarea')
+            this.value = '';
+        else if (t == 'checkbox' || t == 'radio')
+            this.checked = false;
+        else if (tag == 'select')
+            this.selectedIndex = -1;
+ * Resets the form data.  Causes all form elements to be reset to their original value.
+$.fn.resetForm = function() {
+        // guard against an input with the name of 'reset'
+        // note that IE reports the reset function as an 'object'
+        if (typeof this.reset == 'function' || (typeof this.reset == 'object' && !this.reset.nodeType))
+            this.reset();
+ * Enables or disables any matching elements.
+$.fn.enable = function(b) {
+    if (b == undefined) b = true;
+        this.disabled = !b
+ * Checks/unchecks any matching checkboxes or radio buttons and
+ * selects/deselects and matching option elements.
+$.fn.select = function(select) {
+    if (select == undefined) select = true;
+        var t = this.type;
+        if (t == 'checkbox' || t == 'radio')
+            this.checked = select;
+        else if (this.tagName.toLowerCase() == 'option') {
+            var $sel = $(this).parent('select');
+            if (select && $sel[0] && $sel[0].type == 'select-one') {
+                // deselect all other options
+                $sel.find('option').select(false);
+            this.selected = select;
+// helper fn for console logging
+// set $.fn.ajaxSubmit.debug to true to enable debug logging
+function log() {
+    if ($.fn.ajaxSubmit.debug && window.console && window.console.log)
+        window.console.log('[jquery.form] ' + Array.prototype.join.call(arguments,''));
+})(jQuery);
Added: branches/dev_lenkne/http/mb_admin/inc/mb_admin_functions.js
--- branches/dev_lenkne/http/mb_admin/inc/mb_admin_functions.js	                        (rev 0)
+++ branches/dev_lenkne/http/mb_admin/inc/mb_admin_functions.js	2008-07-02 11:51:45 UTC (rev 2574)
@@ -0,0 +1,206 @@
+    <script type="text/javascript" src="form.js"></script>
+var fullscreenProgressIndicator;
+var wrapperContainer;
+var contentContainer;
+var headerContainer;
+var sidebarContainer;
+var mainContainer;
+var optionsContainer;
+var footerContainer;
+function bootstrapAdminstration() {
+	wrapperContainer = document.getElementById('wrapper');
+	headerContainer  = document.getElementById('header');
+	sidebarContainer = document.getElementById('sidebar');
+	contentContainer = document.getElementById('content');
+	optionsContainer = document.getElementById('options');
+	footerContainer  = document.getElementById('footer');
+	buildFullscreenProgressIndicator();
+	displayUserHint();
+function displayUserHint() {
+	var userHint       = document.createElement('p');
+	userHint.className = 'hint';
+	userHint.innerHTML = 'Select an action from the list to proceed.';
+	contentContainer.appendChild(userHint);
+function loadAction() {
+	if(!Boolean(arguments.length)) {
+		contentContainer.innerHTML = null;
+		return;
+	var module      = arguments[0];
+	var sidebarItem = arguments[1];
+	showFullscreenProgressIndicator();
+	mb_ajax_post('../mb_admin/mod/' + module + '/' + module + '.php', {module:module}, function(result, status) {
+    		if (status == "success") {
+        		contentContainer.innerHTML = result;
+			resetsidebar();
+			sidebarItem.className += ' active';
+			hideFullscreenProgressIndicator();
+		else {
+function showUser(module, mb_user_id) {
+	mb_ajax_json('../mb_admin/mod/' + module + '/' + module + '.php', {module: module, action:"showUser", mb_user_id: mb_user_id}, function(result, status) {
+			refreshUser(result)
+		else {
+function refreshUser(obj) {
+	var userArray= document.getElementsByTagName('input');
+//alert(userArray[0].id);
+	for(var i=0;i<userArray.length;i++){
+		for(var j=0;j<obj.length;j++){
+			if(userArray[i].id==obj[j].id){
+				document.getElementById(userArray[i].id).value=obj[j].value;
+function updateUser(module) {
+	var postArray= document.getElementsByTagName('input');
+	var postText = "module=" + module;
+	for(var i=0;i<postArray.length;i++){
+		postText += "&" + postArray[i].id + "=" + postArray[i].value;
+//	alert(postText);
+	mb_ajax_post('../mb_admin/mod/' + module + '/' + module + '.php', postText, function(result, status) {
+			alert("Yuk, an alert");
+		else {
+			alert("error");
+function resetsidebar() {
+	var sidebarItems = document.getElementsByTagName('li');
+	for(var i = 0; i < sidebarItems.length; i++) {
+		var sidebarItem = sidebarItems[i];
+		if(sidebarItem.className.search(/active/) !== -1) {
+			sidebarItem.className = sidebarItem.className.replace(/active/g,'');
+function buildFullscreenProgressIndicator() {
+	fullscreenProgressIndicator = document.createElement('div');
+	var fullscreenProgressIndicatorImage = new Image();
+	fullscreenProgressIndicatorImage.src = '../img/progress_indicator.gif';
+	fullscreenProgressIndicatorImage.id  = 'progress_indicator';
+	fullscreenProgressIndicatorImage.alt = 'Loading ...';
+	fullscreenProgressIndicator.appendChild(fullscreenProgressIndicatorImage);
+	document.body.appendChild(fullscreenProgressIndicator);
+	fullscreenProgressIndicator.style.visibility      = 'hidden';
+	fullscreenProgressIndicator.style.display         = 'none';
+	fullscreenProgressIndicator.style.zIndex          = 999;
+	fullscreenProgressIndicator.style.position        = 'absolute';
+	fullscreenProgressIndicator.style.top             = 0 + 'px';
+	fullscreenProgressIndicator.style.left            = 0 + 'px';
+	var browser=navigator.appName;
+	if (browser=="Microsoft Internet Explorer"){
+//		fullscreenProgressIndicator.style.width           = document.clientWidth  + 'px';
+//		fullscreenProgressIndicator.style.height          = document.clientHeight + 'px';
+	else {
+		fullscreenProgressIndicator.style.width           = window.innerWidth  + 'px';
+		fullscreenProgressIndicator.style.height          = window.innerHeight + 'px';
+	fullscreenProgressIndicator.style.lineHeight      = (window.innerHeight - fullscreenProgressIndicatorImage.height) + 'px';
+	fullscreenProgressIndicator.style.textAlign       = 'center';
+	fullscreenProgressIndicator.style.backgroundColor = '#666';
+	fullscreenProgressIndicator.style.opacity         = '.75';
+function showFullscreenProgressIndicator() {
+	fullscreenProgressIndicator.style.visibility = 'visible';
+	fullscreenProgressIndicator.style.display    = 'block';
+function hideFullscreenProgressIndicator() {
+// Localization functions below
+eventLocalize.register(function () {
+	mb_localizeDiv();
+eventInit.register(function () {
+	mb_localizeDiv();
+function updateDivTitle(obj){
+	var locArray= document.getElementsByTagName("li");
+	for(var i=0;i<locArray.length;i++){
+			if(locArray[i].id==obj[j].id){
+				document.getElementById(locArray[i].id).innerHTML=obj[j].title;
+	var locArray= document.getElementsByTagName("ul");
+	var locArray= document.getElementsByTagName("div");
+function mb_localizeDiv(){
+	mb_ajax_json("../php/mod_admin_loc_ajax.php",function(result,status){
+		updateDivTitle(result);
Added: branches/dev_lenkne/http/mb_admin/mod/editFilteredUser/editFilteredUser.php
--- branches/dev_lenkne/http/mb_admin/mod/editFilteredUser/editFilteredUser.php	                        (rev 0)
+++ branches/dev_lenkne/http/mb_admin/mod/editFilteredUser/editFilteredUser.php	2008-07-02 11:51:45 UTC (rev 2574)
@@ -0,0 +1,235 @@
+<?php
+require_once(dirname(__FILE__)."/../../../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../../../classes/class_json.php");
+require_once(dirname(__FILE__)."/../../../classes/class_mb_exception.php");
+$module = $_REQUEST["module"];
+$action = $_REQUEST["action"];
+$mb_user_id = $_REQUEST["mb_user_id"];
+$mb_user_name = $_REQUEST["mb_user_name"];
+switch ($action) {
+case "showUser":
+	$userArray = array();
+	$sql = "SELECT * FROM mb_user WHERE mb_user_id = $mb_user_id ORDER BY mb_user_name ";
+	$v = array();
+	$t = array();
+	$res = db_prep_query($sql,$v,$t);
+	while ($row = db_fetch_array($res)) {
+		foreach ($row as $key => $value){
+			if (is_int($key)==false) {
+				array_push($userArray, array("id" => $key, "value" => $value));
+	$json = new Mapbender_JSON();
+	$output = $json->encode($userArray);
+	header("Content-type:text/plain; charset=utf-8");
+	echo $output;
+break;
+case "update":
+//TODO - need to build in checking for duplicate names
+	$sql = "SELECT * FROM mb_user WHERE mb_user_id = 1";
+	$columnArray = array();
+//	$sql = "SELECT * FROM mb_user WHERE mb_user_id <> $mb_user_id and mb_user_name = $mb_user_name " ;
+	$v = array();
+	$t = array();
+//				array_push($columnArray, $key);
+				$columnArray[$key] = "";
+	if(db_fetch_row($res)){
+		echo "<script language='JavaScript'>alert('Username must be unique!');</script>";
+	else{
+		$sql = "UPDATE mb_user SET ";
+//		$sql.= "SET mb_user_name = '$mb_user_name'";
+		$columnValues = array_intersect_key($_REQUEST, $columnArray);
+		foreach ($columnValues as $key => $value) {
+			$sql.= ", " . $key . " = " . $value . " ";
+		$sql.= " WHERE mb_user_id = " . $_REQUEST["mb_user_id"];
+		$v = array();
+		$t = array();
+//		if($password != ''){
+//			$sql = "UPDATE mb_user SET mb_user_password = $1 WHERE mb_user_name = $2";
+//			$v = array(md5($password), $name);
+//			$t = array('s','s');
+//			$res = db_prep_query($sql,$v,$t);
+//			if($password && $res){
+//				echo "<script language='JavaScript'>alert('Password has been updated successfully!');</script>";
+	print_r($columnValues);
+	echo $sql;
+	$v = array();
+	$t = array();
+	echo $output;
+break;
+default:
+//include("editFilteredUserForm.php");
+header("Content-type: text/html;");
+<div id="main">
+	<h2>Create and edit user</h2>
+	<form id="form" name="form" action="" method="post">
+	<fieldset>
+		<p>
+			<input type="button" id="action" name="action" value="update" onclick="updateUser('editFilteredUser')" />
+			<input type="button" id="delete" name="save" value="Delete" />
+			<input type="button" id="cancel" name="cancel" value="Cancel" />
+		</p>
+	</fieldset>
+	<fieldset>
+		<p>
+			<label for="mb_user_id">User ID:</label>
+			<input type="text" id="mb_user_id" name="mb_user_id" value="" disabled="disabled" />
+		</p>
+		<p>
+			<label for="mb_user_name">Name:</label>
+			<input type="text" id="mb_user_name" name="mb_user_name" value=""  />
+		</p>
+		<p>
+			<label for="mb_user_password">Password:</label>
+			<input type="password" id="mb_user_password" name="mb_user_password" value="" />
+		</p>
+		<p>
+			<label for="confirm_password">Confirm password:</label>
+			<input type="password" id="confirm_password" name="confirm_password" value="" />
+		</p>
+	</fieldset>
+	<fieldset>
+		<p>
+			<label for="mb_user_description">Description:</label>
+			<input type="text" id="mb_user_description" name="mb_user_description" value="" />
+		</p>
+		<p>
+			<label for="mb_user_email">E-mail:</label>
+			<input type="text" id="mb_user_email" name="mb_user_email" value="" />
+		</p>
+		<p>
+			<label for="mb_user_phone">Phone:</label>
+			<input type="text" id="mb_user_phone" name="mb_user_phone" value="" />
+		</p>
+		<p>
+			<label for="mb_user_phone1">Phone 1:</label>
+			<input type="text" id="mb_user_phone1" name="mb_user_phone1" value="" />
+		</p>
+		<p>
+			<label for="mb_user_facsimile">Facsimile:</label>
+			<input type="text" id="mb_user_facsimile" name="mb_user_facsimile" value="" />
+		</p>
+		<p>
+			<label for="mb_user_organization">Organization:</label>
+			<input type="text" id="mb_user_organization" name="mb_user_organization" value="" />
+		</p>
+		<p>
+			<label for="mb_user_department">Department:</label>
+			<input type="text" id="mb_user_department" name="mb_user_department" value="" />
+		</p>
+		<p>
+			<label for="mb_user_position_name">Position:</label>
+			<input type="text" id="mb_user_position_name" name="mb_user_position_name" value="" />
+		</p>
+		<p>
+			<label for="mb_user_delivery_point">Delivery point:</label>
+			<input type="text" id="mb_user_delivery_point" name="mb_user_delivery_point" value="" />
+		</p>
+		<p>
+			<label for="mb_user_city">City:</label>
+			<input type="text" id="mb_user_city" name="mb_user_city" value="" />
+		</p>
+		<p>
+			<label for="mb_user_postal_code">Postal code:</label>
+			<input type="text" id="mb_user_postal_code" name="mb_user_postal_code" value="" />
+		</p>
+		<p>
+			<label for="mb_user_country">Country:</label>
+			<input type="text" id="mb_user_country" name="mb_user_country" value="" />
+		</p>
+		<p>
+			<label for="mb_user_online_resource">Web site:</label>
+			<input type="text" id="mb_user_online_resource" name="mb_user_online_resource" value="" />
+		</p>
+	</fieldset>
+	<fieldset>
+		<p>
+			<label for="mb_user_resolution">Resolution:</label>
+			<input type="text" id="mb_user_resolution" name="mb_user_resolution" value="" />
+		</p>
+		<p>
+			<label for="mb_user_login_count">Login count:</label>
+			<input type="text" id="mb_user_login_count" name="mb_user_login_count" value="" />
+		</p>
+	</fieldset>
+	</form>
+</div>
+<div id="options">
+	<h2>Current users</h2>
+<h3>Search by name</h3>
+<input type="text" id="searchText" name="searchText" value="" style="width:200" />
+<input type="button" id="search" name="search" value="Go" onclick="search();" />
+<h3>Current users</h3>
+<ul>
+<?php
+$sql = "SELECT mb_user_name,mb_user_id,mb_user_email FROM mb_user ";
+$v = array();
+$t = array();
+$sql .= " ORDER BY mb_user_name LIMIT 10";
+$res = db_prep_query($sql, $v, $t);
+$count=0;
+while($row = db_fetch_array($res)){
+	echo "<li onclick='showUser(\"".$module."\",\"".$row["mb_user_id"]."\")'>".$row["mb_user_name"];
+		if ($row["mb_user_email"]) {
+			echo " (".$row["mb_user_email"].")";
+	echo "</li>";
+$count++;
+echo "</ul></div>";
+break; //for default case
+} // end switch
\ No newline at end of file
Added: branches/dev_lenkne/http/mb_admin/mod/editGuiElement/editGuiElement.php
--- branches/dev_lenkne/http/mb_admin/mod/editGuiElement/editGuiElement.php	                        (rev 0)
+++ branches/dev_lenkne/http/mb_admin/mod/editGuiElement/editGuiElement.php	2008-07-02 11:51:45 UTC (rev 2574)
@@ -0,0 +1,195 @@
+<?php
+switch ($action) {
+case "user_edit":
+echo $action;
+break;
+default:
+<div id="main">
+	<h2>Edit GUI elements</h2>
+	<form action="" method="post">
+	<fieldset>
+		<p>
+			<input type="button" id="save" name="save" value="Save" />
+			<input type="button" id="show" name="save" value="Show" />
+			<input type="button" id="sql" name="save" value="SQL" />
+		</p>
+	</fieldset>
+	<fieldset>
+		<p>
+			<label for="gui_name">Name:</label>
+			<input type="text" id="gui_name" name="gui_name" value="<?=$dummy_data["gui_name"]?>" disabled="disabled" class="wide" />
+		</p>
+		<p>
+			<label for="gui_description">Description:</label>
+			<input type="text" id="gui_description" name="gui_description" value="<?=$dummy_data["gui_description"]?>" disabled="disabled" class="wide" />
+			<input type="button" id="edit_gui_description" name="edit_gui_description" value="Edit" onclick="editGUIDescription();" />
+		</p>
+	</fieldset>
+	<fieldset>
+		<p>
+			<label for="element_id">ID:</label>
+			<input type="text" id="element_id" name="element_id" value="" />
+		</p>
+		<p>
+			<label for="element_position">Position:</label>
+			<input type="text" id="element_position" name="element_position" value="" class="numeric" />
+		</p>
+		<p>
+			<label>On/Off:</label>
+			<label for="gui_element_on" class="inline">On</label>
+			<input type="radio" id="gui_element_on" name="gui_element_onoff" value="1" />
+			<label for="gui_element_off" class="inline">Off</label>
+			<input type="radio" id="gui_element_off" name="gui_element_onoff" value="0" />
+		</p>
+		<p>
+			<label for="element_comment">Comment:</label>
+			<textarea cols="20" rows="5" id="element_comment" name="element_comment"></textarea>
+		</p>
+		<p>
+			<label for="element_title">Title:</label>
+			<input type="text" id="element_title" name="element_title" value="" />
+		</p>
+		<p>
+			<label for="element_htmltagopen">HTML-Tag (open):</label>
+			<input type="text" id="element_htmltagopen" name="element_htmltagopen" value="" />
+		</p>
+		<p>
+			<label for="element_htmltagclose">HTML-Tag (close):</label>
+			<input type="text" id="element_htmltagclose" name="element_htmltagclose" value="" />
+		</p>
+		<p>
+			<label for="element_content">Content:</label>
+			<textarea cols="20" rows="5" id="element_content" name="element_content"></textarea>
+		</p>
+		<p>
+			<label for="element_src">Source:</label>
+			<input type="text" id="element_src" name="element_src" value="" />
+		</p>
+		<p>
+			<label for="element_attributes">Attributes:</label>
+			<textarea cols="20" rows="5" id="element_attributes" name="element_attributes"></textarea>
+		</p>
+		<p>
+			<label for="element_width">Width:</label>
+			<input type="text" id="element_width" name="element_width" value="" class="numeric" /> Pixels
+		</p>
+		<p>
+			<label for="element_height">Height:</label>
+			<input type="text" id="element_height" name="element_height" value="" class="numeric" /> Pixels
+		</p>
+		<p>
+			<label for="element_top">Top:</label>
+			<input type="text" id="element_top" name="element_top" value="" class="numeric" /> Pixels
+		</p>
+		<p>
+			<label for="element_left">Left:</label>
+			<input type="text" id="element_left" name="element_left" value="" class="numeric" /> Pixels
+		</p>
+		<p>
+			<label for="element_zindex">Z-Index:</label>
+			<input type="text" id="element_zindex" name="element_zindex" value="" class="numeric" />
+		</p>
+		<p>
+			<label for="element_inlinecss">Inline CSS:</label>
+			<input type="text" id="element_inlinecss" name="element_inlinecss" value="" />
+		</p>
+		<p>
+			<label for="element_javascript">Javascript:</label>
+			<input type="text" id="element_javascript" name="element_javascript" value="" />
+		</p>
+		<p>
+			<label for="element_module">Module:</label>
+			<input type="text" id="element_module" name="element_module" value="" />
+		</p>
+		<p>
+			<label for="element_requires">Requires:</label>
+			<input type="text" id="element_requires" name="element_requires" value="" />
+		</p>
+		<p>
+			<label for="element_url">URL:</label>
+			<input type="text" id="element_url" name="element_url" value="" />
+		</p>
+		<p>
+			<label for="element_target">Target:</label>
+			<input type="text" id="element_target" name="element_target" value="" />
+		</p>
+	</fieldset>
+	</form>
+</div>
+<div id="options">
+	<h2>Select element</h2>
+		<h3>Foreign GUI elements</h3>
+		<p>
+			<select id="foreign_gui_list" name="foreign_gui_list">
+				<option value="">Foreign GUI &hellip;</option>
+				<option value="">Another GUI One</option>
+				<option value="">Another GUI Two</option>
+				<option value="">Another GUI Three</option>
+			</select>
+			<input type="button" id="grab_element" name="grab_element" value="Grab" onclick="grabElementFromForeignGUI();" />
+		</p>
+		<h3>Current GUI elements</h3>
+		<ul>
+			<li title="add a WMS to the running application">
+				<input type="button" id="edit_element_0" name="edit_element_0" value="Edit" onclick="editGUIElement();" />
+				<input type="checkbox" id="element_status_0" name="element_status_0" checked="checked" onclick="toggleElementStatus();" />
+				<a href="#">addWFS</a>
+			</li>
+			<li title="add a WMS to the running application from a filtered list">
+				<input type="button" id="edit_element_1" name="edit_element_1" value="Edit" onclick="editGUIElement();" />
+				<input type="checkbox" id="element_status_1" name="element_status_1" onclick="toggleElementStatus();" />
+				<a href="#">addWMSfromfilteredList_ajax</a>
+			</li>
+			<li title="History.back()">
+				<input type="button" id="edit_element_2" name="edit_element_2" value="Edit" onclick="editGUIElement();" />
+				<input type="checkbox" id="element_status_2" name="element_status_2" checked="checked" onclick="toggleElementStatus();" />
+				<a href="#">back</a>
+			</li>
+			<li title="body (obligatory)">
+				<input type="button" id="edit_element_3" name="edit_element_3" value="Edit" onclick="editGUIElement();" />
+				<input type="checkbox" id="element_status_3" name="element_status_3" checked="checked" onclick="toggleElementStatus();" />
+				<a href="#">body</a>
+			</li>
+			<li title="Center button">
+				<input type="button" id="edit_element_4" name="edit_element_4" value="Edit" onclick="editGUIElement();" />
+				<input type="checkbox" id="element_status_4" name="element_status_4" checked="checked" onclick="toggleElementStatus();" />
+				<a href="#">center1</a>
+			</li>
+			<li title="button: change password of logged user">
+				<input type="button" id="edit_element_5" name="edit_element_5" value="Edit" onclick="editGUIElement();" />
+				<input type="checkbox" id="element_status_5" name="element_status_5" checked="checked" onclick="toggleElementStatus();" />
+				<a href="#">changePassword_button</a>
+			</li>
+			<li title="close Polygon">
+				<input type="button" id="edit_element_6" name="edit_element_6" value="Edit" onclick="editGUIElement();" />
+				<input type="checkbox" id="element_status_6" name="element_status_6" onclick="toggleElementStatus();" />
+				<a href="#">closePolygon</a>
+			</li>
+			<li title="a Copyright in the map">
+				<input type="button" id="edit_element_7" name="edit_element_7" value="Edit" onclick="editGUIElement();" />
+				<input type="checkbox" id="element_status_7" name="element_status_7" checked="checked" onclick="toggleElementStatus();" />
+				<a href="#">copyright</a>
+			</li>
+			<li title="displays infos in a sticky div-tag">
+				<input type="button" id="edit_element_8" name="edit_element_8" value="Edit" onclick="editGUIElement();" />
+				<input type="checkbox" id="element_status_8" name="element_status_8" checked="checked" onclick="toggleElementStatus();" />
+				<a href="#">dependentDiv</a>
+			</li>
+		</ul>
+	</form>
+</div>
+<?php
+} // end switch
More information about the Mapbender_commits mailing list
