[Mapbender-commits] r2582 - in branches/testbaudson_dev: http/javascripts lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 4 04:08:06 EDT 2008
Author: christoph
Date: 2008-07-04 04:08:05 -0400 (Fri, 04 Jul 2008)
New Revision: 2582
Added:
   branches/testbaudson_dev/lib/geometry1.1.js
Removed:
   branches/testbaudson_dev/http/javascripts/geometry1.1.js
moved to lib
Deleted: branches/testbaudson_dev/http/javascripts/geometry1.1.js
--- branches/testbaudson_dev/http/javascripts/geometry1.1.js	2008-07-02 15:34:21 UTC (rev 2581)
+++ branches/testbaudson_dev/http/javascripts/geometry1.1.js	2008-07-04 08:08:05 UTC (rev 2582)
@@ -1,1125 +0,0 @@
-* $Id$
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-var Geometry = {
-	 * A static class representing geometry types.
-	Type : {
-		 * excludes Linear ring as it is no valid geometry itself
-		isValid : function (aGeometry) {
-			try {
-				if (aGeometry.getType() == this.point ||
-					aGeometry.getType() == this.line ||
-					aGeometry.getType() == this.polygon	||
-					aGeometry.getType() == this.multigeometry)
-					return true;
-			catch (e) {
-				var exc = new Mb_exception ("Geometry.Type.isValid: invalid geometry type for geometry: " + aGeometry + "; " + e);
-			return false;
-		isPoint : function (aGeometry) {
-			try {
-				if (aGeometry.getType() == this.point) {
-					return true;
-			catch (e) {
-				var exc = new Mb_exception ("Geometry.Type.isPoint: not a point: geometry: " + aGeometry + "; " + e);
-			return false;
-		isLine : function (aGeometry) {
-			try {
-				if (aGeometry.getType() == this.line) {
-					return true;
-			catch (e) {
-				var exc = new Mb_exception ("Geometry.Type.isLine: not a line: geometry: " + aGeometry + "; " + e);
-			return false;
-		isPolygon : function (aGeometry) {
-			try {
-				if (aGeometry.getType() == this.polygon) {
-					return true;
-			catch (e) {
-				var exc = new Mb_exception ("Geometry.Type.isPolygon: not a polygon: geometry: " + aGeometry + "; " + e);
-			return false;
-		isLinearRing : function (aGeometry) {
-			try {
-				if (aGeometry.getType() == this.linearring) {
-					return true;
-			catch (e) {
-				var exc = new Mb_exception ("Geometry.Type.isLinearRing: not a linear ring: geometry: " + aGeometry + "; " + e);
-			return false;
-		point : "point",
-		line : "line",
-		linearring : "linearring",
-		polygon : "polygon",
-		multigeometry : "multigeometry"
-	 * A class representing MultiGeometries. A MultiGeometry is a List containing
-	 * Point objects, Line objects, Polygon objects and MultiGeometry objects.
-	MultiGeometry : function () {
-		this.getType = function () {
-			return Geometry.Type.multipolygon;
-		this.push = function (aGeometry) {
-			if (Geometry.Type.isValid(aGeometry)) {
-				this.add(aGeometry);
-				this.get(-1).onEmpty.register(function () {
-					that.isEmpty();
-				return true;
-			return false;
-		this.pop = function () {
-			return this.remove(-1);
-		this.remove = function (index) {
-			// TODO: parameter might be a geometry
-			if (this.del(index)) {
-				this.isEmpty();
-				return true;
-			return false;
-		 * Checks if the multi geometry is empty. If yes, the event onEmpty is triggered.
-		this.isEmpty = function () {
-			if (this.count() === 0) {
-				this.onEmpty.trigger();
-				return true;
-			return false;
-		this.onEmpty = new MapbenderEvent();
-		// this class extends List
-		this.list = [];
-	 * A class representing lines. A line is a List of Point objects
-	Line : function () {
-			return Geometry.Type.line;
-		this.push = function (aPoint) {
-			if (Geometry.Type.isPoint(aPoint)) {
-				this.add(aPoint);
-					that.rearrangeList();
-				return true;
-			return false;
-			// TODO: parameter might be a point
-				return this.isEmpty();
-			return false;
-		 * remove all invalid points
-		this.rearrangeList = function () {
-			var listLength = this.count();
-			for (var i = 0; i < listLength; i++) {
-				if (!this.get(i).isSet()) {
-					this.remove(i);
-					i -= 1;
-					listLength -= 1;
-			if (this.count === 0) {
-				return true;
-			return false;
-		this.list = [];
-	 * A class representing a Polygon. A Polygon consists of an outer boundary (LinearRing)
-	 * and 0..n inner boundaries (InnerBoundaryArray).
-	Polygon : function () {
-			return Geometry.Type.polygon;
-		this.setOuterBoundary = function (aLinearRing) {
-			if (Geometry.Type.isLinearRing(aLinearRing)) {
-				outerBoundary = aLinearRing;
-				outerBoundary.onEmpty.register(function () {
-					that.isEmpty();
-				return true;
-			return false;
-		this.removeOuterBoundary = function () {
-			outerBoundary = null;
-			innerBoundaryArray = null;
-			return this.onEmpty.trigger();
-		this.appendInnerBoundary = function (aLinearRing) {
-			innerBoundaryArray.push(aLinearRing);
-		this.removeInnerBoundary = function (index) {
-			return innerBoundaryArray.remove(index);
-			if (!Geometry.Type.isLinearRing(outerBoundary)) {
-			return false;
-		var outerBoundary;
-		var innerBoundaryArray = new Geometry.InnerBoundaryArray();
-	 * An InnerBoundaryArray is a List of LinearRing objects.
-	InnerBoundaryArray : function () {
-		this.push = function (aLinearRing) {
-				return this.add(aLinearRing);
-			return false;
-			return this.del(index);
-		this.list = [];
-	 * A Linear Ring is a List of Point objects. The last Point and the first Point must be identical.
-	LinearRing : function () {
-			return Geometry.Type.linearring;
-				if (!this.isClosed()) {
-					this.add(aPoint);
-					// linear ring with at least 4 points (triangle!)
-					// AND
-					// last point equals first point
-					if (this.count() > 3 && this.get(0).equals(this.get(-1))) {
-						this.close();
-					return true;
-				else {
-					var e = new Mb_warning("Geometry.LinearRing: push: Cannot add point; linear ring is already closed!");
-			return false;
-			var i = this.getIndex(index);
-			if (i !== false) {
-				// if the first or last point is being deleted,
-				// re-set the first or last point so that the
-				// ring remains closed
-				if (i === 0 || i === this.getIndex(-1)) {
-					// remove the first point (list is automatically shifted)
-					this.del(0);
-					// check if there are still points remaining
-					if (!this.isEmpty()) {
-						// add the new first point as the last point
-						this.list[this.count()-1] = this.list[0];
-					return true;
-				// if it is a point in the middle, just delete it (list is automatically shifted)
-				else {
-					return this.del(i);
-			return false;
-		 * Checks if the outer boundary is empty. If yes, the event onEmpty is triggered.
-				return true;
-			return false;
-					this.remove(i);
-					i -= 1;
-					listLength -= 1;
-		this.close = function () {
-			// AND
-				closed = true;
-				return closed;
-			// linear with at least 3 points (triangle!)
-			// AND
-			// last point DOESNT equal first point
-			else if (this.count() > 2 && !this.get(0).equals(this.get(-1))) {
-				var newPoint = new Geometry.Point(this.get(0).x, this.get(0).y);
-				// push will return to close to set closed to true
-				this.push(newPoint);
-			else {
-				var e = new Mb_warning("Geometry.LinearRing: close: cannot close linear ring, must have at least 3 points (triangle)");
-			return false;
-		this.isClosed = function () {
-			return closed;
-		 * if the first point and the last point match, and the ring has at least 4 points (triangle!)
-		 * closed is set to true via close
-		var closed = false;
-		this.list = [];
-	 * A Point consists of an x- and a y-coordinate.
-	Point : function () {
-			return Geometry.Type.point;
-		this.remove = function () {
-			onEmpty.trigger();
-			this.x = null;
-			this.y = null;
-			this.onEmpty = null;
-	 	 * x value of the {@link Point}
-		 * @type Float
-		this.x = parseFloat(x);
-	 	 * y value of the {@link Point}
-		 * @type Float
-		this.y = parseFloat(y);
-		this.isSet = function () {
-			return (this.x !== null && this.y !== null);
-Geometry.GeometryArray.prototype = new List();
-Geometry.MultiGeometry.prototype = new List();
-Geometry.InnerBoundary.prototype = new List();
-Geometry.LinearRing.prototype = new List();
-Geometry.Line.prototype = new List();
- * computes the distance between a {@link Point} p and this {@link Point}
- * @param {Point} p the distance between this {@link Point} and the {@link Point} p is computed.
- * @return {Float} the distance between the two {@link Point} objects.
-Geometry.Point.prototype.dist = function(p){
-	return Math.sqrt(Math.pow(this.y-p.y,2) + Math.pow(this.x-p.x,2)) ;
- * checks if the coordinates of this {@link Point} match the coordinates of a {@link Point} p
- * @return {Boolean} true if the two points are equal; elso false
-Geometry.Point.prototype.equals = function(p){
-	if (this.x == p.x && this.y == p.y) {return true;}
-	return false;
- * subtracts a {@link Point} p from this {@link Point}
- * @return a new {@link Point} with the difference of the two points
-Geometry.Point.prototype.minus = function(p){
-	return new Point(this.x-p.x, this.y-p.y);
- * adds this {@link Point} to a {@link Point} p
- * @return a new {@link Point} with the sum of the two points
-Geometry.Point.prototype.plus = function(p){
-	return new Point(this.x+p.x, this.y+p.y);
- * divides this {@link Point} by a scalar c
- * @param {Float} c divisor
- * @return a new {@link Point} divided by c
-Geometry.Point.prototype.dividedBy = function(c){
-	if (c !== 0) {
-		return new Point(this.x/c, this.y/c);
-	var e = new Mb_exception("Point.dividedBy: Division by zero");
-	return false;
- * multiplies this {@link Point} by a scalar c
- * @param {Float} c factor
- * @return a new {@link Point} multiplied by c
-Geometry.Point.prototype.times = function(c){
-	return new Point(this.x*c, this.y*c);
- * rounds the coordinates to numOfDigits digits
- * @param numOfDigits the coordinate will be rounded to numOfDigits digits
- * @return a new {@link Point} rounded to numOfDigits digits
- * @type Point
-Geometry.Point.prototype.round = function(numOfDigits){
-	return new Point(roundToDigits(this.x, numOfDigits), roundToDigits(this.y, numOfDigits));
- * @returns a {String} representation of this Point
- * @type String
-Geometry.Point.prototype.toString = function(){
-	return "(" + this.x + ", " + this.y + ")";
- * @class an array of elements, each consisting of a name/value pair
- * @ constructor
-function Wfs_element(){
-	 * returns the number of elements of this {@link Wfs_element} object.
-	 * @return the number of elements
-	 * @type Integer
-	this.count = function(){
-		return name.length;
-	 * returns the name of the element at index i.
-	 * @param {Integer} i index
-	 * @return the name
-	 * @type String
-	this.getName = function(i){
-		if (isValidElementIndex(i)) {return name[i];}
-		return false;
-	 * returns the value of the element at index i.
-	 * @return the value
-	this.getValue = function(i){
-		if (isValidElementIndex(i)) {return value[i];}
-		return false;
-	 * appends a new element with a given name. If an element with this name exists, it is overwritten.
-	 * @param {String} aName the name of the new element
-	 * @param {String} aValue the value of the new element
-	this.setElement = function(aName, aValue){
-		var i = this.getElementIndexByName(aName);
-		if (i === false) {i = this.count();}
-		name[i] = aName;
-		value[i] = aValue;
-	 * checks if an index is valid
-	 * @private
-	 * @param {Integer} i an index
-	 * @return true if the index is valid; otherwise false
-	 * @type Boolean
-	var isValidElementIndex = function(i){
-		if (i>=0 && i<name.length) {return true;}
-		var e = new Mb_exception("class Wfs_element: function isValidElementIndex: illegal element index");
-		return false;
-	var name  = [];
-	var value = [];
- * gets the index of the element with a given name.
- * @param {String} elementName a name
- * @return the index of the element; if no element with this name exists, false
- * @type Integer, Boolean
-Wfs_element.prototype.getElementIndexByName = function(elementName){
-	for (var j = 0 ; j < this.count() ; j++){
-		if (this.getName(j) == elementName) {return j;}
-	return false;
- * gets the value of the element with a given name.
- * @return the value of the element; if no element with this name exists, false
- * @type String, Boolean
-Wfs_element.prototype.getElementValueByName = function(elementName){
-	var i = this.getElementIndexByName(elementName);
-	if (i === false) {return false;}
-	return this.getValue(i);
- * @class a {@link Canvas} contains a {@link DivTag} that holds graphics rendered by {@link jsGraphics}
- * @constructor
- * @requires DivTag
- * @requires jsGraphics
- * @requires GeometryArray
- * @requires MultiGeometry
- * @param {String} aMapFrame name of the target mapframe
- * @param {String} aTagName name of the target div tag
- * @param {String} aStyle style of the div tag
- * @param {Integer} aLineWidth the line width of the jsGraphics output
-function Canvas(aMapframe, aTagName, aStyle, aLineWidth) {
-	 * draws the geometry of the canvas
-	 * @param {String} t geometry type (@see GeomType)
-	 * @param {MultiGeometry} g a MultiGeometry object
-	 * @param {String} col a color
-	 * @private
- 	this.drawGeometry = function(t,g,col){
-		var mapObjInd = getMapObjIndexByName(mapframe);
-		width = mb_mapObj[mapObjInd].width;
-		height = mb_mapObj[mapObjInd].height;
-		for(var i=0; i < g.count(); i++){
-			if(t==geomType.point) {
-				var p = realToMap(mapframe,g.get(i).get(0));
-				if (p.x + diameter < mb_mapObj[mapObjInd].width && p.x - diameter > 0 &&
-					p.y + diameter < mb_mapObj[mapObjInd].height && p.y - diameter > 0) {
-					drawCircle(p.x-1, p.y-1, diameter,col);
-			else if(t==geomType.line || t==geomType.polygon) {
-				for (var j=0; j<g.get(i).count()-1; j++) {
-					var pq = calculateVisibleDash(realToMap(mapframe,g.get(i).get(j)), realToMap(mapframe,g.get(i).get(j+1)), width, height);
-					if (pq) {
-						drawLine([pq[0].x-1, pq[1].x-1], [pq[0].y-1, pq[1].y-1], col);
-			else {
-				var e = new Mb_exception("class Canvas: function drawGeometry: unknown geomType " + t);
-	 * checks if the MultiGeometry's bounding box width and height is smaller than minWidth
-	 * @private
-	this.isTooSmall = function(g){
-		var tmp = g.getBBox();
-		var min = realToMap(mapframe,tmp[0]);
-		var max = realToMap(mapframe,tmp[1]);
-		if((Math.abs(max.x - min.x) < minWidth) && (Math.abs(max.y - min.y) < minWidth)) {
-			return true;
-		return false;
-	 * gets the jsGraphics.
-	 * @private
-	 * @return the jsGraphics
-	 * @type jsGraphics
-	this.getCanvas = function(){
-		return canvas;
-	 * draws a circle with {@link jsGraphics}.
-	 * @private
-	 * @param {Float} x x value of the center
-	 * @param {Float} y y value of the center
-	 * @param {Float} diameter diameter of the circle
-	 * @param {String} color the color of the circle in hex format
-	var drawCircle = function(x, y, diameter, color) {
-		canvas.setColor(color);
-		canvas.drawEllipse(x-diameter/2,y-diameter/2,diameter,diameter);
-	 * draws a polyline with {@link jsGraphics}.
-	 * @private
-	 * @param {Array} x_array array of x values
-	 * @param {Array} y_array array of y values
-	 * @param {String} color the color of the polyline in hex format
-	var drawLine = function(x_array, y_array, color) {
-		canvas.drawPolyline(x_array, y_array);
-	 * This is the {@link DivTag} that contains the output by {@link jsGraphics}.
-	 * @type DivTag
-	this.canvasDivTag = new DivTag(aTagName, aMapframe, aStyle);
-	var that = this;
-	var diameter = 8;
-	var minWidth = 8;
-	var lineWidth = aLineWidth;
-	var mapframe = aMapframe;
-	var style = aStyle;
-	var canvas = new jsGraphics(aTagName, window.frames[mapframe]);
-	canvas.setStroke(lineWidth);
-	mb_registerPanSubElement(aTagName);
- * cleans the canvas by emptying the canvas {@link DivTag}.
-Canvas.prototype.clean = function () {
-	this.canvasDivTag.clean();
- * paints all geometries.
- * @param {GeometryArray} gA the geometries that will be drawn
-Canvas.prototype.paint = function(gA) {
-	for (var q = 0; q < gA.count(); q++) {
-		var m = gA.get(q);
-		var t = m.geomType;
-		var col = m.color;
-		if (t == geomType.point) {
-			this.drawGeometry(t,m,col);
-		else {
-			if (this.isTooSmall(m)){
-				var newMember = new MultiGeometry(geomType.point);
-				newMember.addGeometry();
-				newMember.get(-1).addPoint(m.getCenter());
-				this.drawGeometry(geomType.point,newMember,col);
-			else{
-				if(t == geomType.line) {this.drawGeometry(t,m, col);}
-				else if(t == geomType.polygon) {this.drawGeometry(t,m,col);}
-				else {
-					var e = new Mb_exception("class Canvas: function paint: unknown geomType" + t);
-	this.getCanvas().paint();
- * @class a {@link Highlight} object is {@link jsGraphics} rendering of a {@link GeometryArray} in various mapframes.
- * @constructor
- * @requires Canvas
- * @param {Array} aTargetArray an array of Strings referring to mapframes
- * @param {String} aTagName the name of the div tags
- * @param {Object} aStyle the style of the div tags
- * @param {Integer} the line width of the jsGraphics lines
-function Highlight(aTargetArray, aTagName, aStyle, aLineWidth) {
-	 * removes a {@link MultiGeometry} object from the geometry Array
-	 * @param {MultiGeometry} m a MultiGeometry
-	 * @param {String} color a color
-	this.del = function(m, color) {
-		var a = gA.findMultiGeometry(m);
-		var del = false;
-		for (var i=0; i<a.length && del === false; i++) {
-			if (gA.get(a[i]).color == color) {
-				gA.del(a[i]);
-				del = true;
-		this.paint();
-	 * adds a {@link MultiGeometry} object to the geometry Array
-	 * @param {String} color the color of the highlight
-	this.add = function(m, color) {
-		gA.addCopy(m);
-		if (typeof(color) != 'undefined') {gA.get(-1).color = color;}
-		else {gA.get(-1).color = lineColor;}
-		this.paint();
-	 * removes all MultiGeometries.
-	this.clean = function() {
-		if (gA.count() > 0) {
-			gA = new GeometryArray();
-			this.paint();
-	 * displays the highlight
-	this.paint = function() {
-		for (var i=0; i < canvas.length; i++) {
-			if (typeof(canvas[i]) == "object") {canvas[i].clean();}
-		for (var i=0; i<targets.length; i++){
-			if (typeof(canvas[i]) == 'undefined') {
-				canvas[i] = new Canvas(targets[i], tagname, style, lineWidth);
-			canvas[i].paint(gA);
-	var tagname = 'mod_gaz_draw'+aTagName;
-	var targets = aTargetArray;
-	var canvas = [];
-	var gA = new GeometryArray();
-	var lineColor = "#ff0000";
-	this.paint();
-// Snapping
- * @class a {@link Snapping} object stores is {@link jsGraphics} rendering of a {@link GeometryArray} in various mapframes.
- * @constructor
- * @requires Highlight
- * @param {String} aTarget name of the mapframe where snapping occurs
- * @param {String} aTolerance Snapping is activated if the mouse is
- *                 within aTolerance pixel distance to the reference point.
- * @param {String} aColor apparently deprecated?
- * @param {Integer} aZIndex the z-Index of the {@link jsGraphics} generated by {@link Highlight}.
-function Snapping(aTarget, aTolerance, aColor, aZIndex){
-	 * draws a circle to highlight the snapped point.
-	 * @param {Point} center the snapped point.
-	 * @param {Integer} radius radius of the circular highlight.
-	this.draw = function(center,radius){
-		mG = new MultiGeometry(geomType.point);
-		mG.addGeometry();
-		mG.get(-1).addPoint(center);
-		highlight.add(mG);
-	this.getTolerance = function() {
-		return tolerance;
-	this.getTarget = function() {
-		return target;
-	this.cleanHighlight = function() {
-		return highlight.clean();
-	this.addPoint = function(aPoint) {
-		coord.push(aPoint);
-	this.getPointCount = function() {
-		return coord.length;
-	this.getPoint = function(i) {
-		return coord[i];
-	this.resetPoints = function() {
-		coord = [];
-	this.getNearestNeighbour = function(){
-		if (min_i != -1) {return this.getPoint(min_i);}
-		return false;
-	this.setIndexOfNearestNeighbour = function(i){
-		min_i = i;
-	this.resetIndexOfNearestNeighbour = function(){
-		min_i = -1;
-	 * @private
-	var tolerance = (typeof(aTolerance) == 'undefined') ? 10 : aTolerance;
-	 * @private
-	var zIndex = (typeof(aZIndex) == 'undefined') ? 50 : aZIndex;
-	 * @private
-	var coord = [];
-	 * @private
-	var min_i = -1;
-	 * @private
-	var target = aTarget;
-	 * @private
-	var lineWidth = 2;
-	 * @private
-	var style = {"position":"absolute", "top":"0px", "left":"0px", "z-index":zIndex};
-	 * @private
-	var highlight = new Highlight([target], "snapping"+Math.round(Math.random()*Math.pow(10,10)), style, lineWidth);
-Snapping.prototype.check = function(currPoint){
-	var minDist = false;
-	for (var i = 0 ; i < this.getPointCount() ; i++) {
-		var currDist = currPoint.dist(realToMap(this.getTarget(), this.getPoint(i)));
-		if (minDist === false || currDist < minDist) {
-			minDist = currDist;
-			if (minDist < this.getTolerance()) {this.setIndexOfNearestNeighbour(i);}
-	if (this.getPointCount() > 0 && minDist > this.getTolerance()) {
-		this.resetIndexOfNearestNeighbour();
-	this.cleanHighlight();
-	if (this.isSnapped()) {
-		this.draw(this.getNearestNeighbour(), this.getTolerance());
- * Stores the points which will have the snapping property.
- * @param {GeometryArray} geom all points of geom will be stored. May also be a
- *                             {@link MultiGeometry} or {@link Geometry}.
- * @param {Point} point this point is excluded. Useful when moving a point of a
- *                      geometry; you don't want to snap against the point you
- *                      move. Optional.
-Snapping.prototype.store = function(geom, point){
-	this.resetPoints();
-	for (var i = 0 ; i < geom.count(); i++){
-		if (geom.name == nameGeometryArray || geom.name == nameMultiGeometry){
-			for (var j = 0 ; j < geom.get(i).count() ; j++){
-				if (geom.get(i).name == nameMultiGeometry){
-					for (var k = 0 ; k < geom.get(i).get(j).count() ; k++){
-						if ((geom.get(i).get(j).isComplete() === true && typeof(point) == 'undefined') || (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point))){
-							this.add(geom.getPoint(i, j, k));
-				else {
-					if ((geom.get(i).isComplete() === true && typeof(point) == 'undefined') || (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point))){
-						this.add(geom.getPoint(i, j));
-		else {
-			if (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point)){
-				this.add(geom.get(i));
- * Determines whether a point is within snapping distance to the mouse cursor
- * @return true if a point is within snapping distance; else false
- * @type Boolean
-Snapping.prototype.isSnapped = function(){
-	if (this.getNearestNeighbour() !== false) {return true;}
-	return false;
- * Returns the point that is within snapping distance and closest to the mouse cursor.
- * @return the point (if there is any); else false
- * @type Point
-Snapping.prototype.getSnappedPoint = function(){
-	return this.getNearestNeighbour();
- * Adds the point to the stored points with snapping property.
- * @param {Point} point which receives snapping property.
-Snapping.prototype.add = function(aPoint){
-	this.addPoint(aPoint);
- * Removes the highlight.
-Snapping.prototype.clean = function(){
-// misc. functions
- * @ignore
-function calculateVisibleDash (p0, p1, width, height) {
-	if (p0.x > p1.x) {var p_temp = p0; p0 = p1; p1 = p_temp; p_temp = null;}
-	var p = p0; var q = p1; var m; var ix; var iy;
-	if (p1.x != p0.x) {
-		m = -(p1.y-p0.y)/(p1.x-p0.x);
-		if (p0.x < width && p1.x > 0 && !(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height) ) {
-			if (p0.x < 0) {
-				iy = p0.y - m*(0-p0.x);
-				if (iy > 0 && iy < height) {p = new Point(0, iy);}
-				else if (iy > height) {
-				    ix = p0.x+((p0.y - height)/m);
-				    if (ix > 0 && ix < width) {p = new Point(ix, height);} else {return false;}
-				else if (iy < 0) {
-				    ix = p0.x+(p0.y/m);
-				    if (ix > 0 && ix < width) {p = new Point(ix, 0);} else {return false;}
-				else {return false;}
-			else if (p0.y >= 0 && p0.y <= height) {p = p0;}
-			else if (p0.y < 0) {
-			else if (p0.y > height && m > 0) {
-			if (p1.x > width) {
-				iy = p1.y - m*(width-p1.x);
-				if (iy > 0 && iy < height) {q = new Point(width, iy);}
-				    if (ix > 0 && ix < width) {q = new Point(ix, 0);} else {return false;}
-				    if (ix > 0 && ix < width) {q = new Point(ix, height);} else {return false;}
-			else if (p1.y >= 0 && p1.y <= height) {q = p1;}
-			else if (p1.y < 0) {
-			    ix = p1.x+(p1.y/m);
-			else if (p1.y > height) {
-			    ix = p1.x+((p1.y- height)/m);
-	else {
-		if (!(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height)) {
-			if (p0.y < 0) {p = new Point(p0.x, 0);}
-			else if (p0.y > height) {p = new Point(p0.x, height);}
-			else {p = p0;}
-			if (p1.y < 0) {q = new Point(p0.x, 0);}
-			else if (p1.y > height) {q = new Point(p0.x, height);}
-			else {q = p1;}
-	return [new Point(Math.round(q.x), Math.round(q.y)), new Point(Math.round(p.x), Math.round(p.y))];
- * @ignore
-function objString (a){
-	var z = "";
-	for (attr in a) {
-		var b = a[attr];
-		if (typeof(b) == "object") {z += objString(b);}
-		else {z += attr + " " + b + "\n";alert(attr + " " + b);}
-	return z;
Copied: branches/testbaudson_dev/lib/geometry1.1.js (from rev 2575, branches/testbaudson_dev/http/javascripts/geometry1.1.js)
--- branches/testbaudson_dev/lib/geometry1.1.js	                        (rev 0)
+++ branches/testbaudson_dev/lib/geometry1.1.js	2008-07-04 08:08:05 UTC (rev 2582)
@@ -0,0 +1,1125 @@
+* $Id$
+* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
+* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
+var Geometry = {
+	 * A static class representing geometry types.
+	Type : {
+		 * excludes Linear ring as it is no valid geometry itself
+		isValid : function (aGeometry) {
+			try {
+				if (aGeometry.getType() == this.point ||
+					aGeometry.getType() == this.line ||
+					aGeometry.getType() == this.polygon	||
+					aGeometry.getType() == this.multigeometry)
+					return true;
+			catch (e) {
+				var exc = new Mb_exception ("Geometry.Type.isValid: invalid geometry type for geometry: " + aGeometry + "; " + e);
+			return false;
+		isPoint : function (aGeometry) {
+			try {
+				if (aGeometry.getType() == this.point) {
+					return true;
+			catch (e) {
+				var exc = new Mb_exception ("Geometry.Type.isPoint: not a point: geometry: " + aGeometry + "; " + e);
+			return false;
+		isLine : function (aGeometry) {
+			try {
+				if (aGeometry.getType() == this.line) {
+					return true;
+			catch (e) {
+				var exc = new Mb_exception ("Geometry.Type.isLine: not a line: geometry: " + aGeometry + "; " + e);
+			return false;
+		isPolygon : function (aGeometry) {
+			try {
+				if (aGeometry.getType() == this.polygon) {
+					return true;
+			catch (e) {
+				var exc = new Mb_exception ("Geometry.Type.isPolygon: not a polygon: geometry: " + aGeometry + "; " + e);
+			return false;
+		isLinearRing : function (aGeometry) {
+			try {
+				if (aGeometry.getType() == this.linearring) {
+					return true;
+			catch (e) {
+				var exc = new Mb_exception ("Geometry.Type.isLinearRing: not a linear ring: geometry: " + aGeometry + "; " + e);
+			return false;
+		point : "point",
+		line : "line",
+		linearring : "linearring",
+		polygon : "polygon",
+		multigeometry : "multigeometry"
+	 * A class representing MultiGeometries. A MultiGeometry is a List containing
+	 * Point objects, Line objects, Polygon objects and MultiGeometry objects.
+	MultiGeometry : function () {
+		this.getType = function () {
+			return Geometry.Type.multipolygon;
+		this.push = function (aGeometry) {
+			if (Geometry.Type.isValid(aGeometry)) {
+				this.add(aGeometry);
+				this.get(-1).onEmpty.register(function () {
+					that.isEmpty();
+				return true;
+			return false;
+		this.pop = function () {
+			return this.remove(-1);
+		this.remove = function (index) {
+			// TODO: parameter might be a geometry
+			if (this.del(index)) {
+				this.isEmpty();
+				return true;
+			return false;
+		 * Checks if the multi geometry is empty. If yes, the event onEmpty is triggered.
+		this.isEmpty = function () {
+			if (this.count() === 0) {
+				this.onEmpty.trigger();
+				return true;
+			return false;
+		this.onEmpty = new MapbenderEvent();
+		// this class extends List
+		this.list = [];
+	 * A class representing lines. A line is a List of Point objects
+	Line : function () {
+			return Geometry.Type.line;
+		this.push = function (aPoint) {
+			if (Geometry.Type.isPoint(aPoint)) {
+				this.add(aPoint);
+					that.rearrangeList();
+				return true;
+			return false;
+			// TODO: parameter might be a point
+				return this.isEmpty();
+			return false;
+		 * remove all invalid points
+		this.rearrangeList = function () {
+			var listLength = this.count();
+			for (var i = 0; i < listLength; i++) {
+				if (!this.get(i).isSet()) {
+					this.remove(i);
+					i -= 1;
+					listLength -= 1;
+			if (this.count === 0) {
+				return true;
+			return false;
+		this.list = [];
+	 * A class representing a Polygon. A Polygon consists of an outer boundary (LinearRing)
+	 * and 0..n inner boundaries (InnerBoundaryArray).
+	Polygon : function () {
+			return Geometry.Type.polygon;
+		this.setOuterBoundary = function (aLinearRing) {
+			if (Geometry.Type.isLinearRing(aLinearRing)) {
+				outerBoundary = aLinearRing;
+				outerBoundary.onEmpty.register(function () {
+					that.isEmpty();
+				return true;
+			return false;
+		this.removeOuterBoundary = function () {
+			outerBoundary = null;
+			innerBoundaryArray = null;
+			return this.onEmpty.trigger();
+		this.appendInnerBoundary = function (aLinearRing) {
+			innerBoundaryArray.push(aLinearRing);
+		this.removeInnerBoundary = function (index) {
+			return innerBoundaryArray.remove(index);
+			if (!Geometry.Type.isLinearRing(outerBoundary)) {
+			return false;
+		var outerBoundary;
+		var innerBoundaryArray = new Geometry.InnerBoundaryArray();
+	 * An InnerBoundaryArray is a List of LinearRing objects.
+	InnerBoundaryArray : function () {
+		this.push = function (aLinearRing) {
+				return this.add(aLinearRing);
+			return false;
+			return this.del(index);
+		this.list = [];
+	 * A Linear Ring is a List of Point objects. The last Point and the first Point must be identical.
+	LinearRing : function () {
+			return Geometry.Type.linearring;
+				if (!this.isClosed()) {
+					this.add(aPoint);
+					// linear ring with at least 4 points (triangle!)
+					// AND
+					// last point equals first point
+					if (this.count() > 3 && this.get(0).equals(this.get(-1))) {
+						this.close();
+					return true;
+				else {
+					var e = new Mb_warning("Geometry.LinearRing: push: Cannot add point; linear ring is already closed!");
+			return false;
+			var i = this.getIndex(index);
+			if (i !== false) {
+				// if the first or last point is being deleted,
+				// re-set the first or last point so that the
+				// ring remains closed
+				if (i === 0 || i === this.getIndex(-1)) {
+					// remove the first point (list is automatically shifted)
+					this.del(0);
+					// check if there are still points remaining
+					if (!this.isEmpty()) {
+						// add the new first point as the last point
+						this.list[this.count()-1] = this.list[0];
+					return true;
+				// if it is a point in the middle, just delete it (list is automatically shifted)
+				else {
+					return this.del(i);
+			return false;
+		 * Checks if the outer boundary is empty. If yes, the event onEmpty is triggered.
+				return true;
+			return false;
+					this.remove(i);
+					i -= 1;
+					listLength -= 1;
+		this.close = function () {
+			// AND
+				closed = true;
+				return closed;
+			// linear with at least 3 points (triangle!)
+			// AND
+			// last point DOESNT equal first point
+			else if (this.count() > 2 && !this.get(0).equals(this.get(-1))) {
+				var newPoint = new Geometry.Point(this.get(0).x, this.get(0).y);
+				// push will return to close to set closed to true
+				this.push(newPoint);
+			else {
+				var e = new Mb_warning("Geometry.LinearRing: close: cannot close linear ring, must have at least 3 points (triangle)");
+			return false;
+		this.isClosed = function () {
+			return closed;
+		 * if the first point and the last point match, and the ring has at least 4 points (triangle!)
+		 * closed is set to true via close
+		var closed = false;
+		this.list = [];
+	 * A Point consists of an x- and a y-coordinate.
+	Point : function () {
+			return Geometry.Type.point;
+		this.remove = function () {
+			onEmpty.trigger();
+			this.x = null;
+			this.y = null;
+			this.onEmpty = null;
+	 	 * x value of the {@link Point}
+		 * @type Float
+		this.x = parseFloat(x);
+	 	 * y value of the {@link Point}
+		 * @type Float
+		this.y = parseFloat(y);
+		this.isSet = function () {
+			return (this.x !== null && this.y !== null);
+Geometry.GeometryArray.prototype = new List();
+Geometry.MultiGeometry.prototype = new List();
+Geometry.InnerBoundary.prototype = new List();
+Geometry.LinearRing.prototype = new List();
+Geometry.Line.prototype = new List();
+ * computes the distance between a {@link Point} p and this {@link Point}
+ * @param {Point} p the distance between this {@link Point} and the {@link Point} p is computed.
+ * @return {Float} the distance between the two {@link Point} objects.
+Geometry.Point.prototype.dist = function(p){
+	return Math.sqrt(Math.pow(this.y-p.y,2) + Math.pow(this.x-p.x,2)) ;
+ * checks if the coordinates of this {@link Point} match the coordinates of a {@link Point} p
+ * @return {Boolean} true if the two points are equal; elso false
+Geometry.Point.prototype.equals = function(p){
+	if (this.x == p.x && this.y == p.y) {return true;}
+	return false;
+ * subtracts a {@link Point} p from this {@link Point}
+ * @return a new {@link Point} with the difference of the two points
+Geometry.Point.prototype.minus = function(p){
+	return new Point(this.x-p.x, this.y-p.y);
+ * adds this {@link Point} to a {@link Point} p
+ * @return a new {@link Point} with the sum of the two points
+Geometry.Point.prototype.plus = function(p){
+	return new Point(this.x+p.x, this.y+p.y);
+ * divides this {@link Point} by a scalar c
+ * @param {Float} c divisor
+ * @return a new {@link Point} divided by c
+Geometry.Point.prototype.dividedBy = function(c){
+	if (c !== 0) {
+		return new Point(this.x/c, this.y/c);
+	var e = new Mb_exception("Point.dividedBy: Division by zero");
+	return false;
+ * multiplies this {@link Point} by a scalar c
+ * @param {Float} c factor
+ * @return a new {@link Point} multiplied by c
+Geometry.Point.prototype.times = function(c){
+	return new Point(this.x*c, this.y*c);
+ * rounds the coordinates to numOfDigits digits
+ * @param numOfDigits the coordinate will be rounded to numOfDigits digits
+ * @return a new {@link Point} rounded to numOfDigits digits
+ * @type Point
+Geometry.Point.prototype.round = function(numOfDigits){
+	return new Point(roundToDigits(this.x, numOfDigits), roundToDigits(this.y, numOfDigits));
+ * @returns a {String} representation of this Point
+ * @type String
+Geometry.Point.prototype.toString = function(){
+	return "(" + this.x + ", " + this.y + ")";
+ * @class an array of elements, each consisting of a name/value pair
+ * @ constructor
+function Wfs_element(){
+	 * returns the number of elements of this {@link Wfs_element} object.
+	 * @return the number of elements
+	 * @type Integer
+	this.count = function(){
+		return name.length;
+	 * returns the name of the element at index i.
+	 * @param {Integer} i index
+	 * @return the name
+	 * @type String
+	this.getName = function(i){
+		if (isValidElementIndex(i)) {return name[i];}
+		return false;
+	 * returns the value of the element at index i.
+	 * @return the value
+	this.getValue = function(i){
+		if (isValidElementIndex(i)) {return value[i];}
+		return false;
+	 * appends a new element with a given name. If an element with this name exists, it is overwritten.
+	 * @param {String} aName the name of the new element
+	 * @param {String} aValue the value of the new element
+	this.setElement = function(aName, aValue){
+		var i = this.getElementIndexByName(aName);
+		if (i === false) {i = this.count();}
+		name[i] = aName;
+		value[i] = aValue;
+	 * checks if an index is valid
+	 * @private
+	 * @param {Integer} i an index
+	 * @return true if the index is valid; otherwise false
+	 * @type Boolean
+	var isValidElementIndex = function(i){
+		if (i>=0 && i<name.length) {return true;}
+		var e = new Mb_exception("class Wfs_element: function isValidElementIndex: illegal element index");
+		return false;
+	var name  = [];
+	var value = [];
+ * gets the index of the element with a given name.
+ * @param {String} elementName a name
+ * @return the index of the element; if no element with this name exists, false
+ * @type Integer, Boolean
+Wfs_element.prototype.getElementIndexByName = function(elementName){
+	for (var j = 0 ; j < this.count() ; j++){
+		if (this.getName(j) == elementName) {return j;}
+	return false;
+ * gets the value of the element with a given name.
+ * @return the value of the element; if no element with this name exists, false
+ * @type String, Boolean
+Wfs_element.prototype.getElementValueByName = function(elementName){
+	var i = this.getElementIndexByName(elementName);
+	if (i === false) {return false;}
+	return this.getValue(i);
+ * @class a {@link Canvas} contains a {@link DivTag} that holds graphics rendered by {@link jsGraphics}
+ * @constructor
+ * @requires DivTag
+ * @requires jsGraphics
+ * @requires GeometryArray
+ * @requires MultiGeometry
+ * @param {String} aMapFrame name of the target mapframe
+ * @param {String} aTagName name of the target div tag
+ * @param {String} aStyle style of the div tag
+ * @param {Integer} aLineWidth the line width of the jsGraphics output
+function Canvas(aMapframe, aTagName, aStyle, aLineWidth) {
+	 * draws the geometry of the canvas
+	 * @param {String} t geometry type (@see GeomType)
+	 * @param {MultiGeometry} g a MultiGeometry object
+	 * @param {String} col a color
+	 * @private
+ 	this.drawGeometry = function(t,g,col){
+		var mapObjInd = getMapObjIndexByName(mapframe);
+		width = mb_mapObj[mapObjInd].width;
+		height = mb_mapObj[mapObjInd].height;
+		for(var i=0; i < g.count(); i++){
+			if(t==geomType.point) {
+				var p = realToMap(mapframe,g.get(i).get(0));
+				if (p.x + diameter < mb_mapObj[mapObjInd].width && p.x - diameter > 0 &&
+					p.y + diameter < mb_mapObj[mapObjInd].height && p.y - diameter > 0) {
+					drawCircle(p.x-1, p.y-1, diameter,col);
+			else if(t==geomType.line || t==geomType.polygon) {
+				for (var j=0; j<g.get(i).count()-1; j++) {
+					var pq = calculateVisibleDash(realToMap(mapframe,g.get(i).get(j)), realToMap(mapframe,g.get(i).get(j+1)), width, height);
+					if (pq) {
+						drawLine([pq[0].x-1, pq[1].x-1], [pq[0].y-1, pq[1].y-1], col);
+			else {
+				var e = new Mb_exception("class Canvas: function drawGeometry: unknown geomType " + t);
+	 * checks if the MultiGeometry's bounding box width and height is smaller than minWidth
+	 * @private
+	this.isTooSmall = function(g){
+		var tmp = g.getBBox();
+		var min = realToMap(mapframe,tmp[0]);
+		var max = realToMap(mapframe,tmp[1]);
+		if((Math.abs(max.x - min.x) < minWidth) && (Math.abs(max.y - min.y) < minWidth)) {
+			return true;
+		return false;
+	 * gets the jsGraphics.
+	 * @private
+	 * @return the jsGraphics
+	 * @type jsGraphics
+	this.getCanvas = function(){
+		return canvas;
+	 * draws a circle with {@link jsGraphics}.
+	 * @private
+	 * @param {Float} x x value of the center
+	 * @param {Float} y y value of the center
+	 * @param {Float} diameter diameter of the circle
+	 * @param {String} color the color of the circle in hex format
+	var drawCircle = function(x, y, diameter, color) {
+		canvas.setColor(color);
+		canvas.drawEllipse(x-diameter/2,y-diameter/2,diameter,diameter);
+	 * draws a polyline with {@link jsGraphics}.
+	 * @private
+	 * @param {Array} x_array array of x values
+	 * @param {Array} y_array array of y values
+	 * @param {String} color the color of the polyline in hex format
+	var drawLine = function(x_array, y_array, color) {
+		canvas.drawPolyline(x_array, y_array);
+	 * This is the {@link DivTag} that contains the output by {@link jsGraphics}.
+	 * @type DivTag
+	this.canvasDivTag = new DivTag(aTagName, aMapframe, aStyle);
+	var that = this;
+	var diameter = 8;
+	var minWidth = 8;
+	var lineWidth = aLineWidth;
+	var mapframe = aMapframe;
+	var style = aStyle;
+	var canvas = new jsGraphics(aTagName, window.frames[mapframe]);
+	canvas.setStroke(lineWidth);
+	mb_registerPanSubElement(aTagName);
+ * cleans the canvas by emptying the canvas {@link DivTag}.
+Canvas.prototype.clean = function () {
+	this.canvasDivTag.clean();
+ * paints all geometries.
+ * @param {GeometryArray} gA the geometries that will be drawn
+Canvas.prototype.paint = function(gA) {
+	for (var q = 0; q < gA.count(); q++) {
+		var m = gA.get(q);
+		var t = m.geomType;
+		var col = m.color;
+		if (t == geomType.point) {
+			this.drawGeometry(t,m,col);
+		else {
+			if (this.isTooSmall(m)){
+				var newMember = new MultiGeometry(geomType.point);
+				newMember.addGeometry();
+				newMember.get(-1).addPoint(m.getCenter());
+				this.drawGeometry(geomType.point,newMember,col);
+			else{
+				if(t == geomType.line) {this.drawGeometry(t,m, col);}
+				else if(t == geomType.polygon) {this.drawGeometry(t,m,col);}
+				else {
+					var e = new Mb_exception("class Canvas: function paint: unknown geomType" + t);
+	this.getCanvas().paint();
+ * @class a {@link Highlight} object is {@link jsGraphics} rendering of a {@link GeometryArray} in various mapframes.
+ * @constructor
+ * @requires Canvas
+ * @param {Array} aTargetArray an array of Strings referring to mapframes
+ * @param {String} aTagName the name of the div tags
+ * @param {Object} aStyle the style of the div tags
+ * @param {Integer} the line width of the jsGraphics lines
+function Highlight(aTargetArray, aTagName, aStyle, aLineWidth) {
+	 * removes a {@link MultiGeometry} object from the geometry Array
+	 * @param {MultiGeometry} m a MultiGeometry
+	 * @param {String} color a color
+	this.del = function(m, color) {
+		var a = gA.findMultiGeometry(m);
+		var del = false;
+		for (var i=0; i<a.length && del === false; i++) {
+			if (gA.get(a[i]).color == color) {
+				gA.del(a[i]);
+				del = true;
+		this.paint();
+	 * adds a {@link MultiGeometry} object to the geometry Array
+	 * @param {String} color the color of the highlight
+	this.add = function(m, color) {
+		gA.addCopy(m);
+		if (typeof(color) != 'undefined') {gA.get(-1).color = color;}
+		else {gA.get(-1).color = lineColor;}
+		this.paint();
+	 * removes all MultiGeometries.
+	this.clean = function() {
+		if (gA.count() > 0) {
+			gA = new GeometryArray();
+			this.paint();
+	 * displays the highlight
+	this.paint = function() {
+		for (var i=0; i < canvas.length; i++) {
+			if (typeof(canvas[i]) == "object") {canvas[i].clean();}
+		for (var i=0; i<targets.length; i++){
+			if (typeof(canvas[i]) == 'undefined') {
+				canvas[i] = new Canvas(targets[i], tagname, style, lineWidth);
+			canvas[i].paint(gA);
+	var tagname = 'mod_gaz_draw'+aTagName;
+	var targets = aTargetArray;
+	var canvas = [];
+	var gA = new GeometryArray();
+	var lineColor = "#ff0000";
+	this.paint();
+// Snapping
+ * @class a {@link Snapping} object stores is {@link jsGraphics} rendering of a {@link GeometryArray} in various mapframes.
+ * @constructor
+ * @requires Highlight
+ * @param {String} aTarget name of the mapframe where snapping occurs
+ * @param {String} aTolerance Snapping is activated if the mouse is
+ *                 within aTolerance pixel distance to the reference point.
+ * @param {String} aColor apparently deprecated?
+ * @param {Integer} aZIndex the z-Index of the {@link jsGraphics} generated by {@link Highlight}.
+function Snapping(aTarget, aTolerance, aColor, aZIndex){
+	 * draws a circle to highlight the snapped point.
+	 * @param {Point} center the snapped point.
+	 * @param {Integer} radius radius of the circular highlight.
+	this.draw = function(center,radius){
+		mG = new MultiGeometry(geomType.point);
+		mG.addGeometry();
+		mG.get(-1).addPoint(center);
+		highlight.add(mG);
+	this.getTolerance = function() {
+		return tolerance;
+	this.getTarget = function() {
+		return target;
+	this.cleanHighlight = function() {
+		return highlight.clean();
+	this.addPoint = function(aPoint) {
+		coord.push(aPoint);
+	this.getPointCount = function() {
+		return coord.length;
+	this.getPoint = function(i) {
+		return coord[i];
+	this.resetPoints = function() {
+		coord = [];
+	this.getNearestNeighbour = function(){
+		if (min_i != -1) {return this.getPoint(min_i);}
+		return false;
+	this.setIndexOfNearestNeighbour = function(i){
+		min_i = i;
+	this.resetIndexOfNearestNeighbour = function(){
+		min_i = -1;
+	 * @private
+	var tolerance = (typeof(aTolerance) == 'undefined') ? 10 : aTolerance;
+	 * @private
+	var zIndex = (typeof(aZIndex) == 'undefined') ? 50 : aZIndex;
+	 * @private
+	var coord = [];
+	 * @private
+	var min_i = -1;
+	 * @private
+	var target = aTarget;
+	 * @private
+	var lineWidth = 2;
+	 * @private
+	var style = {"position":"absolute", "top":"0px", "left":"0px", "z-index":zIndex};
+	 * @private
+	var highlight = new Highlight([target], "snapping"+Math.round(Math.random()*Math.pow(10,10)), style, lineWidth);
+Snapping.prototype.check = function(currPoint){
+	var minDist = false;
+	for (var i = 0 ; i < this.getPointCount() ; i++) {
+		var currDist = currPoint.dist(realToMap(this.getTarget(), this.getPoint(i)));
+		if (minDist === false || currDist < minDist) {
+			minDist = currDist;
+			if (minDist < this.getTolerance()) {this.setIndexOfNearestNeighbour(i);}
+	if (this.getPointCount() > 0 && minDist > this.getTolerance()) {
+		this.resetIndexOfNearestNeighbour();
+	this.cleanHighlight();
+	if (this.isSnapped()) {
+		this.draw(this.getNearestNeighbour(), this.getTolerance());
+ * Stores the points which will have the snapping property.
+ * @param {GeometryArray} geom all points of geom will be stored. May also be a
+ *                             {@link MultiGeometry} or {@link Geometry}.
+ * @param {Point} point this point is excluded. Useful when moving a point of a
+ *                      geometry; you don't want to snap against the point you
+ *                      move. Optional.
+Snapping.prototype.store = function(geom, point){
+	this.resetPoints();
+	for (var i = 0 ; i < geom.count(); i++){
+		if (geom.name == nameGeometryArray || geom.name == nameMultiGeometry){
+			for (var j = 0 ; j < geom.get(i).count() ; j++){
+				if (geom.get(i).name == nameMultiGeometry){
+					for (var k = 0 ; k < geom.get(i).get(j).count() ; k++){
+						if ((geom.get(i).get(j).isComplete() === true && typeof(point) == 'undefined') || (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point))){
+							this.add(geom.getPoint(i, j, k));
+				else {
+					if ((geom.get(i).isComplete() === true && typeof(point) == 'undefined') || (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point))){
+						this.add(geom.getPoint(i, j));
+		else {
+			if (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point)){
+				this.add(geom.get(i));
+ * Determines whether a point is within snapping distance to the mouse cursor
+ * @return true if a point is within snapping distance; else false
+ * @type Boolean
+Snapping.prototype.isSnapped = function(){
+	if (this.getNearestNeighbour() !== false) {return true;}
+	return false;
+ * Returns the point that is within snapping distance and closest to the mouse cursor.
+ * @return the point (if there is any); else false
+ * @type Point
+Snapping.prototype.getSnappedPoint = function(){
+	return this.getNearestNeighbour();
+ * Adds the point to the stored points with snapping property.
+ * @param {Point} point which receives snapping property.
+Snapping.prototype.add = function(aPoint){
+	this.addPoint(aPoint);
+ * Removes the highlight.
+Snapping.prototype.clean = function(){
+// misc. functions
+ * @ignore
+function calculateVisibleDash (p0, p1, width, height) {
+	if (p0.x > p1.x) {var p_temp = p0; p0 = p1; p1 = p_temp; p_temp = null;}
+	var p = p0; var q = p1; var m; var ix; var iy;
+	if (p1.x != p0.x) {
+		m = -(p1.y-p0.y)/(p1.x-p0.x);
+		if (p0.x < width && p1.x > 0 && !(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height) ) {
+			if (p0.x < 0) {
+				iy = p0.y - m*(0-p0.x);
+				if (iy > 0 && iy < height) {p = new Point(0, iy);}
+				else if (iy > height) {
+				    ix = p0.x+((p0.y - height)/m);
+				    if (ix > 0 && ix < width) {p = new Point(ix, height);} else {return false;}
+				else if (iy < 0) {
+				    ix = p0.x+(p0.y/m);
+				    if (ix > 0 && ix < width) {p = new Point(ix, 0);} else {return false;}
+				else {return false;}
+			else if (p0.y >= 0 && p0.y <= height) {p = p0;}
+			else if (p0.y < 0) {
+			else if (p0.y > height && m > 0) {
+			if (p1.x > width) {
+				iy = p1.y - m*(width-p1.x);
+				if (iy > 0 && iy < height) {q = new Point(width, iy);}
+				    if (ix > 0 && ix < width) {q = new Point(ix, 0);} else {return false;}
+				    if (ix > 0 && ix < width) {q = new Point(ix, height);} else {return false;}
+			else if (p1.y >= 0 && p1.y <= height) {q = p1;}
+			else if (p1.y < 0) {
+			    ix = p1.x+(p1.y/m);
+			else if (p1.y > height) {
+			    ix = p1.x+((p1.y- height)/m);
+	else {
+		if (!(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height)) {
+			if (p0.y < 0) {p = new Point(p0.x, 0);}
+			else if (p0.y > height) {p = new Point(p0.x, height);}
+			else {p = p0;}
+			if (p1.y < 0) {q = new Point(p0.x, 0);}
+			else if (p1.y > height) {q = new Point(p0.x, height);}
+			else {q = p1;}
+	return [new Point(Math.round(q.x), Math.round(q.y)), new Point(Math.round(p.x), Math.round(p.y))];
+ * @ignore
+function objString (a){
+	var z = "";
+	for (attr in a) {
+		var b = a[attr];
+		if (typeof(b) == "object") {z += objString(b);}
+		else {z += attr + " " + b + "\n";alert(attr + " " + b);}
+	return z;
More information about the Mapbender_commits mailing list
