[Mapbender-commits] r2589 - in branches/testbaudson_dev: core http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jul 7 08:58:27 EDT 2008
Author: christoph
Date: 2008-07-07 08:58:27 -0400 (Mon, 07 Jul 2008)
New Revision: 2589
Added:
   branches/testbaudson_dev/core/globalSettings.php
   branches/testbaudson_dev/http/php/mb_validateSession.php
moved stuff to file globalSettings.php
this file can be included in classes
Added: branches/testbaudson_dev/core/globalSettings.php
--- branches/testbaudson_dev/core/globalSettings.php	                        (rev 0)
+++ branches/testbaudson_dev/core/globalSettings.php	2008-07-07 12:58:27 UTC (rev 2589)
@@ -0,0 +1,38 @@
+<?php
+// start the session
+session_start();
+// All data Mapbender handles internally are UTF-8
+mb_internal_encoding("UTF-8");
+// constants
+require_once(dirname(__FILE__)."/../core/system.php");
+// configuration file
+require_once(dirname(__FILE__)."/../conf/mapbender.conf");
+// class for error handling
+require_once(dirname(__FILE__)."/../lib/exception.php");
+// I18n wrapper function
+require_once(dirname(__FILE__) . "/../core/i18n.php");
+// establish database connection
+$con = db_connect($DBSERVER, $OWNER, $PW);
+db_select_db(DB, $con);
Modified: branches/testbaudson_dev/http/php/mb_validateSession.php
--- branches/testbaudson_dev/http/php/mb_validateSession.php	2008-07-07 12:57:17 UTC (rev 2588)
+++ branches/testbaudson_dev/http/php/mb_validateSession.php	2008-07-07 12:58:27 UTC (rev 2589)
@@ -17,18 +17,9 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-session_start();
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__)."/../php/system.php");
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
-// establish database connection
-$con = db_connect($DBSERVER, $OWNER, $PW);
-db_select_db(DB, $con);
 $e = new mb_notice("mb_validateSession.php: checking file " . $_SERVER["PHP_SELF"]);
More information about the Mapbender_commits mailing list
