[Mapbender-commits] r2619 - in trunk/mapbender: http/php lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jul 8 11:46:12 EDT 2008
Author: christoph
Date: 2008-07-08 11:46:11 -0400 (Tue, 08 Jul 2008)
New Revision: 2619
Added:
   trunk/mapbender/lib/database-mysql.php
   trunk/mapbender/lib/database-pgsql.php
Removed:
   trunk/mapbender/http/php/database-mysql.php
   trunk/mapbender/http/php/database-pgsql.php
moved to ../lib
Deleted: trunk/mapbender/http/php/database-mysql.php
--- trunk/mapbender/http/php/database-mysql.php	2008-07-08 15:42:12 UTC (rev 2618)
+++ trunk/mapbender/http/php/database-mysql.php	2008-07-08 15:46:11 UTC (rev 2619)
@@ -1,409 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/database-mysql.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
- * \file
- * \brief MySQL database connection/querying layer
- * MySQL database connection/querying layer
- * example:
- * \code
- * include_once(dirname(__FILE__)."/afwphp/database-mysql.php");
- * $sys_dbhost=...
- * $sys_dbuser=...
- * $sys_dbpasswd=...
- * $sys_dbname=...
- * db_connect();
- * $rs = db_query("select * from table");
- * while($row = db_fetch_array($rs));
- * \endcode
- * System-wide database type
- * @var	constant		$sys_database_type
-$sys_database_type='mysql';
- *  Connect to the database
- *  Notice the global vars that must be set up
- *  Notice the global vars $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname that must be set up
- *  in other functions in this library
-include_once(dirname(__FILE__)."/../../http/classes/class_mb_exception.php");
-include_once(dirname(__FILE__)."/../../http/classes/class_checkInput.php");
-function db_escapestring($unescaped_string){
-	return @mysql_escape_string($unescaped_string);
-function db_escape_string($unescaped_string){
-function db_connect($DBSERVER="",$OWNER="",$PW="") {
-	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,
-		$conn,$conn_update,$sys_db_use_replication,$sys_dbreadhost;
-	if ($DBSERVER)
-		$sys_dbhost = $DBSERVER;
-	if ($OWNER)
-		$sys_dbuser = $OWNER;
-	if ($PW)
-		$sys_dbpasswd = $PW;
-	if (PORT!=''){
-		$sys_dbport = ':'.PORT;
-	else{
-		$sys_dbport = '';
-	if ($sys_db_use_replication) {
-		//  if configured for replication, $conn is the read-only host
-		//  we do not connect to update server until needed
-		$conn = @mysql_pconnect($sys_dbreadhost,$sys_dbuser,$sys_dbpasswd);
-		$conn_update=@mysql_pconnect($sys_dbhost,$sys_dbuser,$sys_dbpasswd);
-	} else {
-		$conn = @mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd);
-		#echo "@mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd)";
-	if ($sys_dbname)
-		@mysql_select_db($sys_dbname);
-	return $conn;
-function db_select_db($DB,$con="") {
-	global $conn,$sys_dbname;
-	$sys_dbname = $DB;
-	$_con = $con ? $con : $conn;
-	$ret = @mysql_select_db($sys_dbname,$_con);
-	if ($ret){
-		return true;
-	else {
-		return false;
-//	echo "$ret=@mysql_select_db($sys_dbname,$_con);";
- *  Query the database
- *  @param		$qstring (string)	SQL statement
- *  @param		$limit (int)		How many rows do you want returned
- *  @param		$offset (int)		Of matching rows, return only rows starting here
-function db_query($qstring,$limit='-1',$offset=0) {
-	global $QUERY_COUNT,$sys_db_use_replication,$sys_db_is_dirty,$DB,
-		$sys_dbname,$conn,$conn_update,$sys_dbhost,$sys_dbuser,$sys_dbpasswd;
-	$QUERY_COUNT++;
-	if(!$sys_dbname && $DB)
-	db_select_db($sys_dbname,$conn);
-	if ($limit > 0) {
-		if (!$offset || $offset < 0) {
-			$offset=0;
-		$qstring=$qstring." LIMIT $offset,$limit";
-//	if ($GLOBALS['IS_DEBUG'])
-		$GLOBALS['G_DEBUGQUERY'] .= $qstring . "<P><BR>\n";
-	//are we configured to try to use replication?
-		//if we haven't yet done an insert/update,
-		//read from the read-only db
-		if (!$sys_db_is_dirty && mb_eregi("^( )*(select)",$qstring)) {
-			if ($QUERY_COUNT%3==0) {
-				// 1/3rd of read queries go to master for now
-				return @mysql_db_query($sys_dbname,$qstring,$conn_update);
-			} else {
-				return @mysql_db_query($sys_dbname,$qstring,$conn);
-		} else {
-			//must be an update/insert/delete query - go to master server
-			$sys_db_is_dirty=true;
-	} else {
-		$ret = @mysql_db_query($sys_dbname,$qstring,$conn);
-//		echo "@mysql_db_query($sys_dbname,$qstring,$conn); ret=$ret<br>";
-		if(!$ret){
-			$e = new mb_exception("db_query($qstring)=$ret db_error=".db_error());
-		return $ret;
-	//echo "SQL__".$qstring;
- *  prepare and query the database
- *  @param		$params (array string params)
- *  @param		$types (array string types)
-function db_prep_query($qstring, $params, $types){
-	$ci = new checkInput($qstring,$params,$types);
-	$params = $ci->v;
-	for ($i=0; $i<count($params); $i++){
-		$needle = "$".strval($i+1);
-		$tmp = '';
-		if($params[$i] !== NULL){
-			if($types[$i] == 's'){ $tmp .= "'"; }
-			$tmp .= $params[$i];
-		else{
-			$tmp .= "NULL";
-		$posa = mb_strpos($qstring, $needle);
-		$posb = mb_strlen($needle);
-		$qstring = mb_substr($qstring,0,$posa).$tmp.mb_substr($qstring,($posa + $posb));
-	$r = db_query($qstring);
-	return $r;
- *	Begin a transaction
- *	Begin a transaction for databases that support them
- *	may cause unexpected behavior in databases that don't
-function db_begin() {
-	return db_query("BEGIN WORK");
- * Commit a transaction
- * Commit a transaction for databases that support them
-function db_commit() {
-	return db_query("COMMIT");
- * Roll back a transaction
- * Rollback a transaction for databases that support them
-function db_rollback() {
-	$str = db_error();
-	db_query("ROLLBACK");
-	die('sql error: ' . $str . " ROLLBACK performed....");
- * Returns the number of rows in this result set
- *  @param		$qhandle (string)	Query result set handle
-function db_numrows($qhandle) {
-	// return only if qhandle exists, otherwise 0
-	if ($qhandle) {
-		return @mysql_numrows($qhandle);
-	} else {
-		return 0;
- * php 3,4,5
-function db_num_rows($qhandle) {
-	if ($qhandle) {
-		return @mysql_num_rows($qhandle);
-	} else {
-		return 0;
- *  Frees a database result properly
-function db_free_result($qhandle) {
-	return @mysql_free_result($qhandle);
- *  Reset a result set.
- *  Reset is useful for db_fetch_array sometimes you need to start over
- *  @param		$row (int)		Row number
-function db_reset_result($qhandle,$row=0) {
-	return mysql_data_seek($qhandle,$row);
- *  Returns a field from a result set
- *  @param		$field (string)	Field name
-function db_result($qhandle,$row,$field) {
-	return @mysql_result($qhandle,$row,$field);
- *  Returns the number of fields in this result set
- *  @param		$lhandle (string)	Query result set handle
-function db_numfields($lhandle) {
-	return @mysql_numfields($lhandle);
- * php 3,4,5
-function db_num_fields($lhandle) {
-	return @mysql_num_fields($lhandle);
- *  Returns the number of rows changed in the last query
- *  @param		$fnumber (int)	Column number
-function db_fieldname($lhandle,$fnumber) {
-	   return @mysql_fieldname($lhandle,$fnumber);
-function db_affected_rows($qhandle) {
-	return @mysql_affected_rows();
- *  Fetch an array
- *  Returns an associative array from
- *  the current row of this database result
- *  Use db_reset_result to seek a particular row
-function db_fetch_array($qhandle) {
-	return @mysql_fetch_array($qhandle);
- * fetch a row into an array
-function db_fetch_row($qhandle,$fnumber=0) {
-	  return @mysql_fetch_row($qhandle);
- *  Returns the last primary key from an insert
- *  @param		$table_name (string)	Is the name of the table you inserted into
- *  @param		$pkey_field_name (string)	Is the field name of the primary key
-function db_insertid($qhandle="",$table_name="",$pkey_field_name="") {
-	return @mysql_insert_id();
-function db_insert_id($qhandle="",$table_name="",$pkey_field_name="") {
- * Returns the last error from the database
-function db_error() {
-	return @mysql_error();
- * Get the flags associated with the specified field in a result
- * 					Examples: "not_null", "primary_key", "unique_key", "multiple_key",
- *                    "blob", "unsigned", "zerofill","binary", "enum",
- *                    "auto_increment", "timestamp"
-function db_field_flags($lhandle,$fnumber) {
-	   return @mysql_field_flags($lhandle,$fnumber);
- * Get the type of the specified field
-function db_field_type($lhandle,$fnumber) {
-	   return @mysql_field_type($lhandle,$fnumber);
- * Get the length of the specified field
-function db_field_len($lhandle,$fnumber) {
-	   return @mysql_field_len($lhandle,$fnumber);
\ No newline at end of file
Deleted: trunk/mapbender/http/php/database-pgsql.php
--- trunk/mapbender/http/php/database-pgsql.php	2008-07-08 15:42:12 UTC (rev 2618)
+++ trunk/mapbender/http/php/database-pgsql.php	2008-07-08 15:46:11 UTC (rev 2619)
@@ -1,436 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/database-pgsql.php
- * \file
- * example:
- * \code
- * $sys_dbhost=...
- * $sys_dbuser=...
- * $sys_dbname=...
- * db_connect();
- * \endcode
-$sys_database_type='pgsql';
-	return @pg_escape_string(stripslashes($unescaped_string));
-$DB = DB;
-	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,$db_debug;
-	global $conn,$conn_update,$DB;
-	$db_debug=0;
-	if ($DBSERVER)
-	if ($OWNER)
-	if ($PW && $PW != null)
-	$sys_dbport = PORT;
-	if($GLOBALS['DB'])
-	$connstring = "";
-	if ($sys_dbuser)
-		$connstring.=" user=$sys_dbuser";
-	if ($sys_dbname)
-		$connstring.=" dbname=$sys_dbname";
-	if ($sys_dbhost)
-		$connstring.=" host=$sys_dbhost";
-	if ($sys_dbport)
-		$connstring.=" port=$sys_dbport";
-	if ($sys_dbpasswd)
-		$connstring.=" password=$sys_dbpasswd";
-	if ($db_debug)
-		echo $connstring." ";
-	$conn = pg_connect($connstring);
-		#if(isset($sys_db_clientencoding) && $sys_db_clientencoding > "")
-		#pg_set_client_encoding ( $conn, $sys_db_clientencoding);
-	#return $conn;
-	if ($db_debug)
-		echo "conn=".$conn;
-#echo $connstring;
-#if(!$conn)
-#{echo "FEHLER in Connection";
-#pg_error($conn);}
-	return $conn;
-#	$sys_dbname = DB;
-#	$_con = $con ? $con : $conn;
-#	$ret = @mysql_select_db($sys_dbname,$_con);
-function db_query($qstring) {
-	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,$db_debug,
-		$conn,$conn_update,$QUERY_COUNT,$DBSERVER,$OWNER,$PW,$DB;
-	$QUERY_COUNT++;
-	$ret = pg_exec($qstring);
-//	$e = new mb_exception("not ps:  ".$_SERVER['SCRIPT_FILENAME']." : ".$qstring);
-	if(!$ret){
-	return $ret;
- *  @param		$params (array params as strings)
- *  @param		$types (array types as strings)
-	$params = $ci->v;
-	if(PREPAREDSTATEMENTS == false){
-			$tmp = '';
-			else{
-				$tmp .= "NULL";
-		if(!$r){
-			$e = new mb_exception("Error while executing sql statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-	else{
-		$result = pg_prepare("", $qstring);
-		if(!$result){
-			$e = new mb_exception("Error while preparing statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-		$r = pg_execute("", $params);
-		if(!$r){
-			$e = new mb_exception("Error while executing prepared statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-	return $r;
-	if ($qhandle) {
-		return @pg_numrows($qhandle);
-	} else {
-		return 0;
- *	php > 4.2
-	if ($qhandle) {
-		return @pg_num_rows($qhandle);
-	} else {
-		return 0;
-	return @pg_freeresult($qhandle);
-#dummy
-	return 0;#mysql_data_seek($qhandle,$row);
-	return @pg_result($qhandle,$row,$field);
-	return @pg_numfields($lhandle);
- *	php >4.2
-	return @pg_num_fields($lhandle);
-	   return @pg_fieldname($lhandle,$fnumber);
-	return @pg_cmdtuples($qhandle);
- *  Fetch an array
-	return @pg_fetch_array($qhandle);
-function db_fetch_all($qhandle){
-		return @pg_fetch_all($qhandle);
-	  return pg_fetch_row($qhandle);
-	$res=db_query("SELECT max($pkey_field_name) AS id FROM $table_name");
-    if ($res && db_numrows($res) > 0) {
-        return @db_result($res,0,'id');
-    } else {
-        return 0;
-	$oid =pg_last_oid($qhandle);
-	echo $oid;
-	$res=db_query("SELECT ".$pkey_field_name." FROM ".$table_name." WHERE oid =".$oid );
-        return @db_result($res,0,0);
-    } else {
-        return 0;
-        return db_result($res,0,'id');
-    } else {
-        return 0;
-function db_last_oid()
-		$conn,$conn_update,$QUERY_COUNT;
-        global $DBSERVER,$OWNER,$PW,$DB	;
-             return pg_getlastoid($conn);
-	return @pg_last_error();
-	   print "db_field_flags()	isn't implemented";
-	   return @pg_fieldtype($lhandle,$fnumber);
-	   return @pg_fieldlen($lhandle,$fnumber);
Copied: trunk/mapbender/lib/database-mysql.php (from rev 2600, trunk/mapbender/http/php/database-mysql.php)
--- trunk/mapbender/lib/database-mysql.php	                        (rev 0)
+++ trunk/mapbender/lib/database-mysql.php	2008-07-08 15:46:11 UTC (rev 2619)
@@ -0,0 +1,409 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/database-mysql.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+ * \file
+ * \brief MySQL database connection/querying layer
+ * MySQL database connection/querying layer
+ * example:
+ * \code
+ * include_once(dirname(__FILE__)."/afwphp/database-mysql.php");
+ * $sys_dbhost=...
+ * $sys_dbuser=...
+ * $sys_dbpasswd=...
+ * $sys_dbname=...
+ * db_connect();
+ * $rs = db_query("select * from table");
+ * while($row = db_fetch_array($rs));
+ * \endcode
+ * System-wide database type
+ * @var	constant		$sys_database_type
+$sys_database_type='mysql';
+ *  Connect to the database
+ *  Notice the global vars that must be set up
+ *  Notice the global vars $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname that must be set up
+ *  in other functions in this library
+include_once(dirname(__FILE__)."/../../http/classes/class_mb_exception.php");
+include_once(dirname(__FILE__)."/../../http/classes/class_checkInput.php");
+function db_escapestring($unescaped_string){
+	return @mysql_escape_string($unescaped_string);
+function db_escape_string($unescaped_string){
+function db_connect($DBSERVER="",$OWNER="",$PW="") {
+	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,
+		$conn,$conn_update,$sys_db_use_replication,$sys_dbreadhost;
+	if ($DBSERVER)
+		$sys_dbhost = $DBSERVER;
+	if ($OWNER)
+		$sys_dbuser = $OWNER;
+	if ($PW)
+		$sys_dbpasswd = $PW;
+	if (PORT!=''){
+		$sys_dbport = ':'.PORT;
+	else{
+		$sys_dbport = '';
+	if ($sys_db_use_replication) {
+		//  if configured for replication, $conn is the read-only host
+		//  we do not connect to update server until needed
+		$conn = @mysql_pconnect($sys_dbreadhost,$sys_dbuser,$sys_dbpasswd);
+		$conn_update=@mysql_pconnect($sys_dbhost,$sys_dbuser,$sys_dbpasswd);
+	} else {
+		$conn = @mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd);
+		#echo "@mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd)";
+	if ($sys_dbname)
+		@mysql_select_db($sys_dbname);
+	return $conn;
+function db_select_db($DB,$con="") {
+	global $conn,$sys_dbname;
+	$sys_dbname = $DB;
+	$_con = $con ? $con : $conn;
+	$ret = @mysql_select_db($sys_dbname,$_con);
+	if ($ret){
+		return true;
+	else {
+		return false;
+//	echo "$ret=@mysql_select_db($sys_dbname,$_con);";
+ *  Query the database
+ *  @param		$qstring (string)	SQL statement
+ *  @param		$limit (int)		How many rows do you want returned
+ *  @param		$offset (int)		Of matching rows, return only rows starting here
+function db_query($qstring,$limit='-1',$offset=0) {
+	global $QUERY_COUNT,$sys_db_use_replication,$sys_db_is_dirty,$DB,
+		$sys_dbname,$conn,$conn_update,$sys_dbhost,$sys_dbuser,$sys_dbpasswd;
+	$QUERY_COUNT++;
+	if(!$sys_dbname && $DB)
+	db_select_db($sys_dbname,$conn);
+	if ($limit > 0) {
+		if (!$offset || $offset < 0) {
+			$offset=0;
+		$qstring=$qstring." LIMIT $offset,$limit";
+//	if ($GLOBALS['IS_DEBUG'])
+		$GLOBALS['G_DEBUGQUERY'] .= $qstring . "<P><BR>\n";
+	//are we configured to try to use replication?
+		//if we haven't yet done an insert/update,
+		//read from the read-only db
+		if (!$sys_db_is_dirty && mb_eregi("^( )*(select)",$qstring)) {
+			if ($QUERY_COUNT%3==0) {
+				// 1/3rd of read queries go to master for now
+				return @mysql_db_query($sys_dbname,$qstring,$conn_update);
+			} else {
+				return @mysql_db_query($sys_dbname,$qstring,$conn);
+		} else {
+			//must be an update/insert/delete query - go to master server
+			$sys_db_is_dirty=true;
+	} else {
+		$ret = @mysql_db_query($sys_dbname,$qstring,$conn);
+//		echo "@mysql_db_query($sys_dbname,$qstring,$conn); ret=$ret<br>";
+		if(!$ret){
+			$e = new mb_exception("db_query($qstring)=$ret db_error=".db_error());
+		return $ret;
+	//echo "SQL__".$qstring;
+ *  prepare and query the database
+ *  @param		$params (array string params)
+ *  @param		$types (array string types)
+function db_prep_query($qstring, $params, $types){
+	$ci = new checkInput($qstring,$params,$types);
+	$params = $ci->v;
+	for ($i=0; $i<count($params); $i++){
+		$needle = "$".strval($i+1);
+		$tmp = '';
+		if($params[$i] !== NULL){
+			if($types[$i] == 's'){ $tmp .= "'"; }
+			$tmp .= $params[$i];
+		else{
+			$tmp .= "NULL";
+		$posa = mb_strpos($qstring, $needle);
+		$posb = mb_strlen($needle);
+		$qstring = mb_substr($qstring,0,$posa).$tmp.mb_substr($qstring,($posa + $posb));
+	$r = db_query($qstring);
+	return $r;
+ *	Begin a transaction
+ *	Begin a transaction for databases that support them
+ *	may cause unexpected behavior in databases that don't
+function db_begin() {
+	return db_query("BEGIN WORK");
+ * Commit a transaction
+ * Commit a transaction for databases that support them
+function db_commit() {
+	return db_query("COMMIT");
+ * Roll back a transaction
+ * Rollback a transaction for databases that support them
+function db_rollback() {
+	$str = db_error();
+	db_query("ROLLBACK");
+	die('sql error: ' . $str . " ROLLBACK performed....");
+ * Returns the number of rows in this result set
+ *  @param		$qhandle (string)	Query result set handle
+function db_numrows($qhandle) {
+	// return only if qhandle exists, otherwise 0
+	if ($qhandle) {
+		return @mysql_numrows($qhandle);
+	} else {
+		return 0;
+ * php 3,4,5
+function db_num_rows($qhandle) {
+	if ($qhandle) {
+		return @mysql_num_rows($qhandle);
+	} else {
+		return 0;
+ *  Frees a database result properly
+function db_free_result($qhandle) {
+	return @mysql_free_result($qhandle);
+ *  Reset a result set.
+ *  Reset is useful for db_fetch_array sometimes you need to start over
+ *  @param		$row (int)		Row number
+function db_reset_result($qhandle,$row=0) {
+	return mysql_data_seek($qhandle,$row);
+ *  Returns a field from a result set
+ *  @param		$field (string)	Field name
+function db_result($qhandle,$row,$field) {
+	return @mysql_result($qhandle,$row,$field);
+ *  Returns the number of fields in this result set
+ *  @param		$lhandle (string)	Query result set handle
+function db_numfields($lhandle) {
+	return @mysql_numfields($lhandle);
+ * php 3,4,5
+function db_num_fields($lhandle) {
+	return @mysql_num_fields($lhandle);
+ *  Returns the number of rows changed in the last query
+ *  @param		$fnumber (int)	Column number
+function db_fieldname($lhandle,$fnumber) {
+	   return @mysql_fieldname($lhandle,$fnumber);
+function db_affected_rows($qhandle) {
+	return @mysql_affected_rows();
+ *  Fetch an array
+ *  Returns an associative array from
+ *  the current row of this database result
+ *  Use db_reset_result to seek a particular row
+function db_fetch_array($qhandle) {
+	return @mysql_fetch_array($qhandle);
+ * fetch a row into an array
+function db_fetch_row($qhandle,$fnumber=0) {
+	  return @mysql_fetch_row($qhandle);
+ *  Returns the last primary key from an insert
+ *  @param		$table_name (string)	Is the name of the table you inserted into
+ *  @param		$pkey_field_name (string)	Is the field name of the primary key
+function db_insertid($qhandle="",$table_name="",$pkey_field_name="") {
+	return @mysql_insert_id();
+function db_insert_id($qhandle="",$table_name="",$pkey_field_name="") {
+ * Returns the last error from the database
+function db_error() {
+	return @mysql_error();
+ * Get the flags associated with the specified field in a result
+ * 					Examples: "not_null", "primary_key", "unique_key", "multiple_key",
+ *                    "blob", "unsigned", "zerofill","binary", "enum",
+ *                    "auto_increment", "timestamp"
+function db_field_flags($lhandle,$fnumber) {
+	   return @mysql_field_flags($lhandle,$fnumber);
+ * Get the type of the specified field
+function db_field_type($lhandle,$fnumber) {
+	   return @mysql_field_type($lhandle,$fnumber);
+ * Get the length of the specified field
+function db_field_len($lhandle,$fnumber) {
+	   return @mysql_field_len($lhandle,$fnumber);
Copied: trunk/mapbender/lib/database-pgsql.php (from rev 2600, trunk/mapbender/http/php/database-pgsql.php)
--- trunk/mapbender/lib/database-pgsql.php	                        (rev 0)
+++ trunk/mapbender/lib/database-pgsql.php	2008-07-08 15:46:11 UTC (rev 2619)
@@ -0,0 +1,436 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/database-pgsql.php
+ * \file
+ * example:
+ * \code
+ * $sys_dbhost=...
+ * $sys_dbuser=...
+ * $sys_dbname=...
+ * db_connect();
+ * \endcode
+$sys_database_type='pgsql';
+	return @pg_escape_string(stripslashes($unescaped_string));
+$DB = DB;
+	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,$db_debug;
+	global $conn,$conn_update,$DB;
+	$db_debug=0;
+	if ($DBSERVER)
+	if ($OWNER)
+	if ($PW && $PW != null)
+	$sys_dbport = PORT;
+	if($GLOBALS['DB'])
+	$connstring = "";
+	if ($sys_dbuser)
+		$connstring.=" user=$sys_dbuser";
+	if ($sys_dbname)
+		$connstring.=" dbname=$sys_dbname";
+	if ($sys_dbhost)
+		$connstring.=" host=$sys_dbhost";
+	if ($sys_dbport)
+		$connstring.=" port=$sys_dbport";
+	if ($sys_dbpasswd)
+		$connstring.=" password=$sys_dbpasswd";
+	if ($db_debug)
+		echo $connstring." ";
+	$conn = pg_connect($connstring);
+		#if(isset($sys_db_clientencoding) && $sys_db_clientencoding > "")
+		#pg_set_client_encoding ( $conn, $sys_db_clientencoding);
+	#return $conn;
+	if ($db_debug)
+		echo "conn=".$conn;
+#echo $connstring;
+#if(!$conn)
+#{echo "FEHLER in Connection";
+#pg_error($conn);}
+	return $conn;
+#	$sys_dbname = DB;
+#	$_con = $con ? $con : $conn;
+#	$ret = @mysql_select_db($sys_dbname,$_con);
+function db_query($qstring) {
+	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,$db_debug,
+		$conn,$conn_update,$QUERY_COUNT,$DBSERVER,$OWNER,$PW,$DB;
+	$QUERY_COUNT++;
+	$ret = pg_exec($qstring);
+//	$e = new mb_exception("not ps:  ".$_SERVER['SCRIPT_FILENAME']." : ".$qstring);
+	if(!$ret){
+	return $ret;
+ *  @param		$params (array params as strings)
+ *  @param		$types (array types as strings)
+	$params = $ci->v;
+	if(PREPAREDSTATEMENTS == false){
+			$tmp = '';
+			else{
+				$tmp .= "NULL";
+		if(!$r){
+			$e = new mb_exception("Error while executing sql statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
+	else{
+		$result = pg_prepare("", $qstring);
+		if(!$result){
+			$e = new mb_exception("Error while preparing statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
+		$r = pg_execute("", $params);
+		if(!$r){
+			$e = new mb_exception("Error while executing prepared statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
+	return $r;
+	if ($qhandle) {
+		return @pg_numrows($qhandle);
+	} else {
+		return 0;
+ *	php > 4.2
+	if ($qhandle) {
+		return @pg_num_rows($qhandle);
+	} else {
+		return 0;
+	return @pg_freeresult($qhandle);
+#dummy
+	return 0;#mysql_data_seek($qhandle,$row);
+	return @pg_result($qhandle,$row,$field);
+	return @pg_numfields($lhandle);
+ *	php >4.2
+	return @pg_num_fields($lhandle);
+	   return @pg_fieldname($lhandle,$fnumber);
+	return @pg_cmdtuples($qhandle);
+ *  Fetch an array
+	return @pg_fetch_array($qhandle);
+function db_fetch_all($qhandle){
+		return @pg_fetch_all($qhandle);
+	  return pg_fetch_row($qhandle);
+	$res=db_query("SELECT max($pkey_field_name) AS id FROM $table_name");
+    if ($res && db_numrows($res) > 0) {
+        return @db_result($res,0,'id');
+    } else {
+        return 0;
+	$oid =pg_last_oid($qhandle);
+	echo $oid;
+	$res=db_query("SELECT ".$pkey_field_name." FROM ".$table_name." WHERE oid =".$oid );
+        return @db_result($res,0,0);
+    } else {
+        return 0;
+        return db_result($res,0,'id');
+    } else {
+        return 0;
+function db_last_oid()
+		$conn,$conn_update,$QUERY_COUNT;
+        global $DBSERVER,$OWNER,$PW,$DB	;
+             return pg_getlastoid($conn);
+	return @pg_last_error();
+	   print "db_field_flags()	isn't implemented";
+	   return @pg_fieldtype($lhandle,$fnumber);
+	   return @pg_fieldlen($lhandle,$fnumber);
More information about the Mapbender_commits mailing list
