[Mapbender-commits] r2622 - branches/dev_lenkne/http/classes
svn_mapbender at osgeo.org
Tue Jul 8 18:10:56 EDT 2008
Author: lenkne
Date: 2008-07-08 18:10:55 -0400 (Tue, 08 Jul 2008)
New Revision: 2622
branches/dev_lenkne/http/classes/class_administration.php
Modified: branches/dev_lenkne/http/classes/class_administration.php
--- branches/dev_lenkne/http/classes/class_administration.php 2008-07-08 16:10:34 UTC (rev 2621)
+++ branches/dev_lenkne/http/classes/class_administration.php 2008-07-08 22:10:55 UTC (rev 2622)
@@ -1,1119 +1,1186 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_administration
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/class_mb_exception.php");
-require_once(dirname(__FILE__)."/class_user.php");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
-require(dirname(__FILE__) . "/phpmailer-1.72/class.phpmailer.php");
- * class to wrap administration methods
- * @uses phpmailer
-class administration {
- * checks whether the passed email-address is valid / following a pattern
- * @todo is this an exact representation of the RFC 2822?
- * @todo this should be checked: what about umlaut-domains and tld like '.museum'?
- * @see http://tools.ietf.org/html/rfc2822
- * @param <string> a all lowercase email adress to test
- * @return <boolean> answer to "is the passed over email valid?""
- function isValidEmail($email) {
- if(mb_eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
- return true;
- return false;
- * sends an email via php mailer
- * @param string an email address for the "From"-field
- * @param string the displayed name for the "From"-field
- * @param string an email address for the "To"-field
- * @param string the text to be set as "Subject"
- * @param string the text of the emails body
- * @param string a reference to an error string
- function sendEmail($fromAddr, $fromName, $toAddr, $toName, $subject, $body, &$error_msg ){
- global $mailHost, $mailUsername, $mailPassword;
- if($fromAddr == ''){
- $fromAddr = MAILADMIN;
- if($fromName == ''){
- $fromName = MAILADMINNAME;
- if ($this->isValidEmail($fromAddr) && $this->isValidEmail($toAddr)) {
- $mail = new PHPMailer();
- if ($fromName != "" ) {
- $mail->FromName = $fromName;
- $mail->IsSMTP(); // set mailer to use SMTP
- $mail->Host = $mailHost; // specify main and backup server
- $mail->SMTPAuth = true; // turn on SMTP authentication
- $mail->Username = $mailUsername; // SMTP username
- $mail->Password = $mailPassword; // SMTP password
- $mail->From = $fromAddr;
- $mail->AddAddress($toAddr, $toName);
- #$mail->AddReplyTo("info at ccgis.de", "Information");
- $mail->WordWrap = 50; // set word wrap to 50 characters
- #$mail->AddAttachment("/var/tmp/file.tar.gz"); // add attachments
- #$mail->AddAttachment("/tmp/image.jpg", "new.jpg"); // optional name
- $mail->IsHTML(false); // set email format to HTML
- $mail->Subject = "[".$fromName."] ".$subject;
- $mail->Body = $body;
- #$mail->AltBody = "This is the body in plain text for non-HTML mail clients";
- $error_msg='';
- if(!$mail->Send())
- $error_msg .= "Mailer Error: " . $mail->ErrorInfo;
- return false;
- return true;
- else {
- return false;
- * Removes the namespace from a tag name
- * @return String like "gml"
- * @param $s String like "ogc:gml"
- public static function sepNameSpace($s) {
- $c = strpos($s,":");
- if ($c > 0) {
- return substr($s,$c+1);
- return $s;
- * Parses an XML with PHP XML parser, see
- * http://de2.php.net/manual/de/book.xml.php
- * @return Array an associative array of tags, values, attributes and types
- * @param $someXml String The actual XML as string.
- public static function parseXml ($someXml) {
- $values = null;
- $tags = null;
- $parser = xml_parser_create(CHARSET);
- // set parsing options
- xml_parser_set_option($parser, XML_OPTION_CASE_FOLDING, 0);
- xml_parser_set_option($parser, XML_OPTION_SKIP_WHITE, 1);
- xml_parser_set_option($parser, XML_OPTION_TARGET_ENCODING, CHARSET);
- // this is the actual parsing process
- xml_parse_into_struct($parser, $someXml, $values, $tags);
- // check if an error occured
- $code = xml_get_error_code ($parser);
- if ($code) {
- // report error
- $line = xml_get_current_line_number($parser);
- $errorMessage = xml_error_string($code) . " in line " . $line;
- $mb_exception = new mb_exception($errorMessage);
- return false;
- xml_parser_free($parser);
- return $values;
- * returns a random password with numbers and chars both lowercase and uppercase (0-9a-zA-Z)
- * @return string the new password
- function getRandomPassword() {
- // password length
- $max = 16;
- //new password
- $newpass = "";
- for ($i=0;$i <= $max;$i++) {
- //die ASCII-Zeichen 48 - 57 sind die zahlen 0-9
- //die ASCII-Zeichen 65 - 90 sind die buchstaben A-Z (Gro�)
- //die ASCII-Zeichen 97 - 122 sind die buchstaben a-z (Klein)
- $ascii = 0;
- do {
- $ascii=rand(48,122);
- } while ( ($ascii > 57 && $ascii < 65) || ($ascii > 90 && $ascii < 97));
- $newpass .= chr($ascii);
- return $newpass;
- * returns the name of a mapbender user which owns the GUI identified by the passed over gui_id.
- * @param string the gui_id
- * @return integer the user id of the owner
- function getOwnerByGui($gui_id){
- $sql = "(SELECT mb_user.mb_user_id";
- $sql .= "FROM mb_user ";
- $sql .= "JOIN gui_mb_user ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id ";
- $sql .= "WHERE gui_mb_user.mb_user_type = 'owner' ";
- $sql .= "AND gui_mb_user.fkey_gui_id = $1 ";
- $sql .= "GROUP BY mb_user.mb_user_id ";
- $sql .= ") ";
- $sql .= "UNION ( ";
- $sql .= "SELECT mb_user.mb_user_id ";
- $sql .= "FROM gui_mb_group ";
- $sql .= "JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id ";
- $sql .= "JOIN mb_user ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
- $sql .= "WHERE gui_mb_group.mb_group_type = 'owner' ";
- $sql .= "AND gui_mb_group.fkey_gui_id = $2 ";
- $sql .= "GROUP BY mb_user.mb_user_id)";
- $owner = array();
- $v = array($gui_id,$gui_id);
- $t = array('s','s');
- $res = db_prep_query($sql,$v,$t);
- $cnt = 0;
- while($row = db_fetch_array($res)){
- $owner[$cnt] = $row["mb_user_id"];
- $cnt++;
- return $owner;
- * returns the content of the field mb_user_email for the given userid.
- * @param integer userid the id of the current user
- * @return string the email if one row is found or false if none is found
- function getEmailByUserId($userid){
- $sql = "SELECT mb_user_email FROM mb_user ";
- $sql .= "WHERE mb_user_id = $1 GROUP by mb_user_email";
- // TODO why do we group, when userid is a primary key?
- $v = array($userid);
- $t = array('i');
- // TODO shall the next two lines be removed?
- $count_g = 0;
- $array = array();
- $row = db_fetch_array($res);
- if ($row) {
- return $row["mb_user_email"];
- else {
- return false;
- * returns the name of the user for the given userid.
- * @param integer the userid
- * @return string the name if one row is found or false if none is foundd
- function getUserNameByUserId($userid){
- $sql = "SELECT mb_user_name FROM mb_user ";
- $sql .= "WHERE mb_user_id = $1 GROUP BY mb_user_name";
- $t = array("i");
- $count_g = 0;
- $array = array();
- if ($row) {
- return $row["mb_user_name"];
- else {
- return false;
- * returns one or more userids from the given email or false,
- * if there is no record in the database matching the given email
- * @param string the email
- * @return mixed an array of userids or false when no records matches
- function getUserIdByEmail($email){
- $sql = "SELECT mb_user_id FROM mb_user ";
- $sql .= "WHERE mb_user_email = $1 GROUP BY mb_user_id";
- $v = array($email);
- $t = array('s');
- $count_g = 0;
- $array = array();
- $array[$count_g] = $row["mb_user_id"];
- $count_g++;
- if ($count_g >0) {
- return $array;
- else {
- return false;
- * returns one or more owners for the given wm_id. First all guis deploying
- * this wms are selected. Afterwards for each of the guis the owners are
- * selected and stored within an array.
- * @param integer the wms_id
- * @return mixed an array of user ids which use the wms in their guis
- * (both for persona or group ownership)
- function getOwnerByWms($wms_id){
- // first get guis which deploy this wms.
- $sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1 GROUP BY fkey_gui_id";
- $v = array($wms_id);
- $t = array('i');
- $count=0;
- $gui[$count] = $row["fkey_gui_id"];
- $count++;
- if ($count > 0) {
- // this is not needed! count($gui) is always equal to $count
- if(count($gui)>0) {
- $v = array();
- $t = array();
- $c = 1;
- $sql = "(SELECT mb_user.mb_user_id FROM mb_user JOIN gui_mb_user ";
- $sql .= "ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id ";
- $sql .= " WHERE gui_mb_user.mb_user_type = 'owner'";
- $sql .= " AND gui_mb_user.fkey_gui_id IN (";
- for($i=0; $i<count($gui); $i++){
- if($i>0){ $sql .= ",";}
- $sql .= "$".$c;
- $c++;
- array_push($v, $gui[$i]);
- array_push($t, 's');
- $sql .= ") GROUP BY mb_user.mb_user_id";
- $sql .= ") UNION (";
- $sql .= "SELECT mb_user.mb_user_id FROM gui_mb_group JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id JOIN mb_user ";
- $sql .= "ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
- $sql .= " WHERE gui_mb_group.mb_group_type = 'owner'";
- $sql .= " AND gui_mb_group.fkey_gui_id IN (";
- for($j=0; $j<count($gui); $j++){
- if($j>0){ $sql .= ",";}
- $sql .= "$".$c;
- $c++;
- $sql .= ") GROUP BY mb_user.mb_user_id)";
- $user = array();
- $cnt = 0;
- $user[$cnt] = $row["mb_user_id"];
- $cnt++;
- if ($cnt>0) {
- return $user;
- } else {
- return false;
- } else {
- return false;
- * tests whether a gui with the passed gui_id exits and returns true or false.
- * @param string the gui_id to test
- * @return boolean Does a Gui with the passed over gui_id exist?
- function guiExists($id){
- $sql = "SELECT * FROM gui WHERE gui_id = $1 ";
- $v = array($id);
- $t = array('s');
- if ($row) {
- return true;
- else {
- return false;
- * deletes a {@link http://www.mapbender.org/index.php/WMC WMC} entry specified by wmc_id and user_id
- * @param integer the user_id
- * @param string the wmc_id
- * @return boolean Did the query run succesfull? This does not necessarily mean that
- * an entry was deleted.
- * @deprecated
- function deleteWmc($wmc_id, $user_id){
- $e = new mb_notice("administration->deleteWmc is deprecated, use wmc->delete instead!");
- $wmc = new wmc();
- return $wmc->delete($wmc_id, $user_id);
- * inserts a gui with the specified gui_id, after checking the uniqueness of teh gui id.
- * @uses administration::guiExists()
- * @param string $guiId the name and id of the gui to insert.
- * @return boolean could the gui be inserted?
- function insertGui($guiId) {
- if (!$this->guiExists($guiId)) {
- $sql = "INSERT INTO gui VALUES ($1, $2, '', '1')";
- $v = array($guiId,$guiId);
- if ($res) {
- return true;
- return false;
- * deletes links between user and guis in gui_mb_user for a certain gui.
- * @param string the gui name
- * @return boolean could the sql be executed without errors. This does not
- * necessarily mean, that entries were deleted
- function delAllUsersOfGui($guiId) {
- $sql = "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1 ";
- $v = array($guiId);
- $t = array('s');
- if (!$res) {
- return false;
- else {
- return true;
- * returns an array of WMS for a given user id
- * @uses getGuisByOwner
- * @param integer $user_id the user id
- * @return integer[] wms ids for the user
- function getWmsByOwner($user_id){
- $gui_list = $this->getGuisByOwner($user_id,true);
- return $this->getWmsByOwnGuis($gui_list);
- * returns an array of WMS where the owner is the user with the passed user_id
- * @param integer the user id
- * @return array wms ids for the user
- function getWmsByWmsOwner($user_id){
- $sql = "SELECT wms_id FROM wms WHERE wms_owner = $1";
- $v = array($user_id);
- $t = array('i');
- $r = array();
- array_push($r,$row["wms_id"]);
- return $r;
- * returns an array of user which are associated with a wms
- * @param integer the wms id
- * @return array user_ids for the wms
- function getUserByWms($wms_id){
- $t = array('i');
- $count=0;
- $count++;
- $c = 1;
- $v = array();
- $t = array();
- if(count($gui)>0){
- $sql .= " WHERE gui_mb_user.fkey_gui_id IN (";
- $sql .= "$".$c;
- array_push($v,$gui[$i]);
- $c++;
- $sql .= ") GROUP BY mb_user.mb_user_id) UNION";
- $sql .= "(SELECT mb_user.mb_user_id FROM gui_mb_group JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id JOIN mb_user ";
- $sql .= " WHERE gui_mb_group.fkey_gui_id IN (";
- $sql .= "$".$c;
- $c++;
- $sql .= ") GROUP BY mb_user.mb_user_id )";
- $user = array();
- $cnt = 0;
- $cnt++;
- return $user;
- * selects the WMS-title for a given wms id.
- * @return string|boolean either the title of the wms as string or false when none exists
- function getWmsTitleByWmsId($id){
- $sql = "SELECT wms_title FROM wms WHERE wms_id = $1 GROUP BY wms_title";
- $v = array($id);
- $t = array('i');
- if ($row) return $row["wms_title"]; else return false;
- * selects the Layer-title for a given layer id.
- function getLayerTitleByLayerId($id){
- $sql = "SELECT layer_title FROM layer WHERE layer_id = $1 GROUP BY layer_title";
- $v = array($id);
- $t = array('i');
- if ($row) return $row["layer_title"]; else return false;
- * selects the WMC for a given wmc_id.
- * @return string|boolean either the wmc as string or false when none exists
- * @deprecated
- function getWmcById($id){
- $e = new mb_notice("administration->getWmcById is deprecated, use wmc->getDocument instead!");
- $wmc = new wmc();
- return $wmc->getDocument($id);
- * resets the login count of a given user to 0
- * @return boolean could the login count be reseted?
- function resetLoginCount($userId) {
- // TODO: isn't mb_user_login_count a integer?
- $sql = "UPDATE mb_user SET mb_user_login_count = '0' ";
- $sql .= "WHERE mb_user_id = $1 ";
- $v = array($userId);
- $t = array('i');
- if (!$res) {
- return false;
- else {
- return true;
- function getUserIdByUserName($username){
- $sql .= "WHERE mb_user_name = $1 GROUP BY mb_user_id";
- $v = array($username);
- $t = array('s');
- if ($row) return $row["mb_user_id"]; else return false;
- function setUserAsGuiOwner($guiId, $userId) {
- $sql = "UPDATE gui_mb_user SET mb_user_type = 'owner' ";
- $sql .= "WHERE fkey_gui_id = $1 AND fkey_mb_user_id = $2 ";
- $v = array($guiId,$userId);
- $t = array('s','i');
- if (!$res) {
- return false;
- else {
- return true;
- function getGuiIdByGuiName($guiTitle){
- $sql = "SELECT gui_id FROM gui ";
- $sql .= "WHERE gui_name = $1 GROUP BY gui_id";
- $v = array($guiTitle);
- $t = array('s');
- $count_g = 0;
- $array = array();
- $array[$count_g] = $row["gui_id"];
- $count_g++;
- return $array;
- else {
- return false;
- function getGuisByOwner($user_id,$ignore_public)
- $sql_guis = "SELECT gui.gui_id FROM gui,gui_mb_user ";
- $sql_guis .= "WHERE (gui.gui_id = gui_mb_user.fkey_gui_id AND gui_mb_user.fkey_mb_user_id = $1) ";
- if (!isset($ignore_public) OR $ignore_public == false){
- $sql_guis .= " AND gui.gui_public = 1 ";
- $sql_guis .= " AND gui_mb_user.mb_user_type = 'owner' GROUP BY gui.gui_id";
- $sql_guis .= " ORDER by gui.gui_id";
- $t = array('i');
- $res_guis = db_prep_query($sql_guis,$v,$t);
- $count_g = 0;
- $arrayGuis = array();
- while($row = db_fetch_array($res_guis)){
- $arrayGuis[$count_g] = $row["gui_id"];
- $count_g++;
- return $arrayGuis;
- * @deprecated
- function getWmcByOwner($user_id){
- $e = new mb_notice("administration->getWmcByOwner is deprecated, use user->getWmcByOwner instead!");
- $user = new User($user_id);
- return $user->getWmcByOwner();
- * @deprecated
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/class_administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/class_mb_exception.php");
+require_once(dirname(__FILE__)."/class_user.php");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+require(dirname(__FILE__) . "/phpmailer-1.72/class.phpmailer.php");
+ * class to wrap administration methods
+ * @uses phpmailer
+class administration {
+ * checks whether the passed email-address is valid / following a pattern
+ * @todo is this an exact representation of the RFC 2822?
+ * @todo this should be checked: what about umlaut-domains and tld like '.museum'?
+ * @see http://tools.ietf.org/html/rfc2822
+ * @param <string> a all lowercase email adress to test
+ * @return <boolean> answer to "is the passed over email valid?""
+ function isValidEmail($email) {
+ if(mb_eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
+ return true;
+ return false;
+ * sends an email via php mailer
+ * @param string an email address for the "From"-field
+ * @param string the displayed name for the "From"-field
+ * @param string an email address for the "To"-field
+ * @param string the text to be set as "Subject"
+ * @param string the text of the emails body
+ * @param string a reference to an error string
+ function sendEmail($fromAddr, $fromName, $toAddr, $toName, $subject, $body, &$error_msg ){
+ global $mailHost, $mailUsername, $mailPassword;
+ if($fromAddr == ''){
+ $fromAddr = MAILADMIN;
+ if($fromName == ''){
+ $fromName = MAILADMINNAME;
+ if ($this->isValidEmail($fromAddr) && $this->isValidEmail($toAddr)) {
+ $mail = new PHPMailer();
+ if ($fromName != "" ) {
+ $mail->FromName = $fromName;
+ $mail->IsSMTP(); // set mailer to use SMTP
+ $mail->Host = $mailHost; // specify main and backup server
+ $mail->SMTPAuth = true; // turn on SMTP authentication
+ $mail->Username = $mailUsername; // SMTP username
+ $mail->Password = $mailPassword; // SMTP password
+ $mail->From = $fromAddr;
+ $mail->AddAddress($toAddr, $toName);
+ #$mail->AddReplyTo("info at ccgis.de", "Information");
+ $mail->WordWrap = 50; // set word wrap to 50 characters
+ #$mail->AddAttachment("/var/tmp/file.tar.gz"); // add attachments
+ #$mail->AddAttachment("/tmp/image.jpg", "new.jpg"); // optional name
+ $mail->IsHTML(false); // set email format to HTML
+ $mail->Subject = "[".$fromName."] ".$subject;
+ $mail->Body = $body;
+ #$mail->AltBody = "This is the body in plain text for non-HTML mail clients";
+ $error_msg='';
+ if(!$mail->Send())
+ $error_msg .= "Mailer Error: " . $mail->ErrorInfo;
+ return false;
+ return true;
+ else {
+ return false;
+ * Removes the namespace from a tag name
+ * @return String like "gml"
+ * @param $s String like "ogc:gml"
+ public static function sepNameSpace($s) {
+ $c = strpos($s,":");
+ if ($c > 0) {
+ return substr($s,$c+1);
+ return $s;
+ * Parses an XML with PHP XML parser, see
+ * http://de2.php.net/manual/de/book.xml.php
+ * @return Array an associative array of tags, values, attributes and types
+ * @param $someXml String The actual XML as string.
+ public static function parseXml ($someXml) {
+ $values = null;
+ $tags = null;
+ $parser = xml_parser_create(CHARSET);
+ // set parsing options
+ xml_parser_set_option($parser, XML_OPTION_CASE_FOLDING, 0);
+ xml_parser_set_option($parser, XML_OPTION_SKIP_WHITE, 1);
+ xml_parser_set_option($parser, XML_OPTION_TARGET_ENCODING, CHARSET);
+ // this is the actual parsing process
+ xml_parse_into_struct($parser, $someXml, $values, $tags);
+ // check if an error occured
+ $code = xml_get_error_code ($parser);
+ if ($code) {
+ // report error
+ $line = xml_get_current_line_number($parser);
+ $errorMessage = xml_error_string($code) . " in line " . $line;
+ $mb_exception = new mb_exception($errorMessage);
+ return false;
+ xml_parser_free($parser);
+ return $values;
+ * returns a random password with numbers and chars both lowercase and uppercase (0-9a-zA-Z)
+ * @return string the new password
+ function getRandomPassword() {
+ // password length
+ $max = 16;
+ //new password
+ $newpass = "";
+ for ($i=0;$i <= $max;$i++) {
+ //die ASCII-Zeichen 48 - 57 sind die zahlen 0-9
+ //die ASCII-Zeichen 65 - 90 sind die buchstaben A-Z (Gro�)
+ //die ASCII-Zeichen 97 - 122 sind die buchstaben a-z (Klein)
+ $ascii = 0;
+ do {
+ $ascii=rand(48,122);
+ } while ( ($ascii > 57 && $ascii < 65) || ($ascii > 90 && $ascii < 97));
+ $newpass .= chr($ascii);
+ return $newpass;
+ * returns the name of a mapbender user which owns the GUI identified by the passed over gui_id.
+ * @param string the gui_id
+ * @return integer the user id of the owner
+ function getOwnerByGui($gui_id){
+ $sql = "(SELECT mb_user.mb_user_id";
+ $sql .= "FROM mb_user ";
+ $sql .= "JOIN gui_mb_user ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id ";
+ $sql .= "WHERE gui_mb_user.mb_user_type = 'owner' ";
+ $sql .= "AND gui_mb_user.fkey_gui_id = $1 ";
+ $sql .= "GROUP BY mb_user.mb_user_id ";
+ $sql .= ") ";
+ $sql .= "UNION ( ";
+ $sql .= "SELECT mb_user.mb_user_id ";
+ $sql .= "FROM gui_mb_group ";
+ $sql .= "JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id ";
+ $sql .= "JOIN mb_user ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
+ $sql .= "WHERE gui_mb_group.mb_group_type = 'owner' ";
+ $sql .= "AND gui_mb_group.fkey_gui_id = $2 ";
+ $sql .= "GROUP BY mb_user.mb_user_id)";
+ $owner = array();
+ $v = array($gui_id,$gui_id);
+ $t = array('s','s');
+ $res = db_prep_query($sql,$v,$t);
+ $cnt = 0;
+ while($row = db_fetch_array($res)){
+ $owner[$cnt] = $row["mb_user_id"];
+ $cnt++;
+ return $owner;
+ * returns the content of the field mb_user_email for the given userid.
+ * @param integer userid the id of the current user
+ * @return string the email if one row is found or false if none is found
+ function getEmailByUserId($userid){
+ $sql = "SELECT mb_user_email FROM mb_user ";
+ $sql .= "WHERE mb_user_id = $1 GROUP by mb_user_email";
+ // TODO why do we group, when userid is a primary key?
+ $v = array($userid);
+ $t = array('i');
+ // TODO shall the next two lines be removed?
+ $count_g = 0;
+ $array = array();
+ $row = db_fetch_array($res);
+ if ($row) {
+ return $row["mb_user_email"];
+ else {
+ return "false";
+ * returns the name of the user for the given userid.
+ * @param integer the userid
+ * @return string the name if one row is found or false if none is foundd
+ function getUserNameByUserId($userid){
+ $sql = "SELECT mb_user_name FROM mb_user ";
+ $sql .= "WHERE mb_user_id = $1 GROUP BY mb_user_name";
+ $t = array("i");
+ $count_g = 0;
+ $array = array();
+ if ($row) {
+ return $row["mb_user_name"];
+ else {
+ return false;
+ * returns one or more userids from the given email or false,
+ * if there is no record in the database matching the given email
+ * @param string the email
+ * @return mixed an array of userids or false when no records matches
+ function getUserIdByEmail($email){
+ $sql = "SELECT mb_user_id FROM mb_user ";
+ $sql .= "WHERE mb_user_email = $1 GROUP BY mb_user_id";
+ $v = array($email);
+ $t = array('s');
+ $count_g = 0;
+ $array = array();
+ $array[$count_g] = $row["mb_user_id"];
+ $count_g++;
+ if ($count_g >0) {
+ return $array;
+ else {
+ return false;
+ * returns one or more owners for the given wm_id. First all guis deploying
+ * this wms are selected. Afterwards for each of the guis the owners are
+ * selected and stored within an array.
+ * @param integer the wms_id
+ * @return mixed an array of user ids which use the wms in their guis
+ * (both for persona or group ownership)
+ function getOwnerByWms($wms_id){
+ // first get guis which deploy this wms.
+ $sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1 GROUP BY fkey_gui_id";
+ $v = array($wms_id);
+ $t = array('i');
+ $count=0;
+ $gui[$count] = $row["fkey_gui_id"];
+ $count++;
+ if ($count > 0) {
+ // this is not needed! count($gui) is always equal to $count
+ if(count($gui)>0) {
+ $v = array();
+ $t = array();
+ $c = 1;
+ $sql = "(SELECT mb_user.mb_user_id FROM mb_user JOIN gui_mb_user ";
+ $sql .= "ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id ";
+ $sql .= " WHERE gui_mb_user.mb_user_type = 'owner'";
+ $sql .= " AND gui_mb_user.fkey_gui_id IN (";
+ for($i=0; $i<count($gui); $i++){
+ if($i>0){ $sql .= ",";}
+ $sql .= "$".$c;
+ $c++;
+ array_push($v, $gui[$i]);
+ array_push($t, 's');
+ $sql .= ") GROUP BY mb_user.mb_user_id";
+ $sql .= ") UNION (";
+ $sql .= "SELECT mb_user.mb_user_id FROM gui_mb_group JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id JOIN mb_user ";
+ $sql .= "ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
+ $sql .= " WHERE gui_mb_group.mb_group_type = 'owner'";
+ $sql .= " AND gui_mb_group.fkey_gui_id IN (";
+ for($j=0; $j<count($gui); $j++){
+ if($j>0){ $sql .= ",";}
+ $sql .= "$".$c;
+ $c++;
+ $sql .= ") GROUP BY mb_user.mb_user_id)";
+ $user = array();
+ $cnt = 0;
+ $user[$cnt] = $row["mb_user_id"];
+ $cnt++;
+ if ($cnt>0) {
+ return $user;
+ } else {
+ return false;
+ } else {
+ return false;
+ * tests whether a gui with the passed gui_id exits and returns true or false.
+ * @param string the gui_id to test
+ * @return boolean Does a Gui with the passed over gui_id exist?
+ function guiExists($id){
+ $sql = "SELECT * FROM gui WHERE gui_id = $1 ";
+ $v = array($id);
+ $t = array('s');
+ if ($row) {
+ return true;
+ else {
+ return false;
+ * deletes a {@link http://www.mapbender.org/index.php/WMC WMC} entry specified by wmc_id and user_id
+ * @param integer the user_id
+ * @param string the wmc_id
+ * @return boolean Did the query run succesfull? This does not necessarily mean that
+ * an entry was deleted.
+ * @deprecated
+ function deleteWmc($wmc_id, $user_id){
+ $e = new mb_notice("administration->deleteWmc is deprecated, use wmc->delete instead!");
+ $wmc = new wmc();
+ return $wmc->delete($wmc_id, $user_id);
+ * inserts a gui with the specified gui_id, after checking the uniqueness of teh gui id.
+ * @uses administration::guiExists()
+ * @param string $guiId the name and id of the gui to insert.
+ * @return boolean could the gui be inserted?
+ function insertGui($guiId) {
+ if (!$this->guiExists($guiId)) {
+ $sql = "INSERT INTO gui VALUES ($1, $2, '', '1')";
+ $v = array($guiId,$guiId);
+ if ($res) {
+ return true;
+ return false;
+ * deletes links between user and guis in gui_mb_user for a certain gui.
+ * @param string the gui name
+ * @return boolean could the sql be executed without errors. This does not
+ * necessarily mean, that entries were deleted
+ function delAllUsersOfGui($guiId) {
+ $sql = "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1 ";
+ $v = array($guiId);
+ $t = array('s');
+ if (!$res) {
+ return false;
+ else {
+ return true;
+ * returns an array of WMS for a given user id
+ * @uses getGuisByOwner
+ * @param integer $user_id the user id
+ * @return integer[] wms ids for the user
+ function getWmsByOwner($user_id){
+ $gui_list = $this->getGuisByOwner($user_id,true);
+ return $this->getWmsByOwnGuis($gui_list);
+ * returns an array of WMS where the owner is the user with the passed user_id
+ * @param integer the user id
+ * @return array wms ids for the user
+ function getWmsByWmsOwner($user_id){
+ $sql = "SELECT wms_id FROM wms WHERE wms_owner = $1";
+ $v = array($user_id);
+ $t = array('i');
+ $r = array();
+ array_push($r,$row["wms_id"]);
+ return $r;
+ * returns an array of user which are associated with a wms
+ * @param integer the wms id
+ * @return array user_ids for the wms
+ function getUserByWms($wms_id){
+ $t = array('i');
+ $count=0;
+ $count++;
+ $c = 1;
+ $v = array();
+ $t = array();
+ if(count($gui)>0){
+ $sql .= " WHERE gui_mb_user.fkey_gui_id IN (";
+ $sql .= "$".$c;
+ array_push($v,$gui[$i]);
+ $c++;
+ $sql .= ") GROUP BY mb_user.mb_user_id) UNION";
+ $sql .= "(SELECT mb_user.mb_user_id FROM gui_mb_group JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id JOIN mb_user ";
+ $sql .= " WHERE gui_mb_group.fkey_gui_id IN (";
+ $sql .= "$".$c;
+ $c++;
+ $sql .= ") GROUP BY mb_user.mb_user_id )";
+ $user = array();
+ $cnt = 0;
+ $cnt++;
+ return $user;
+ * selects the WMS-title for a given wms id.
+ * @return string|boolean either the title of the wms as string or false when none exists
+ function getWmsTitleByWmsId($id){
+ $sql = "SELECT wms_title FROM wms WHERE wms_id = $1 GROUP BY wms_title";
+ $v = array($id);
+ $t = array('i');
+ if ($row) return $row["wms_title"]; else return false;
+ * selects the Layer-title for a given layer id.
+ function getLayerTitleByLayerId($id){
+ $sql = "SELECT layer_title FROM layer WHERE layer_id = $1 GROUP BY layer_title";
+ $v = array($id);
+ $t = array('i');
+ if ($row) return $row["layer_title"]; else return false;
+ * selects the WMC for a given wmc_id.
+ * @return string|boolean either the wmc as string or false when none exists
+ * @deprecated
+ function getWmcById($id){
+ $e = new mb_notice("administration->getWmcById is deprecated, use wmc->getDocument instead!");
+ $wmc = new wmc();
+ return $wmc->getDocument($id);
+ * resets the login count of a given user to 0
+ * @return boolean could the login count be reseted?
+ function resetLoginCount($userId) {
+ // TODO: isn't mb_user_login_count a integer?
+ $sql = "UPDATE mb_user SET mb_user_login_count = '0' ";
+ $sql .= "WHERE mb_user_id = $1 ";
+ $v = array($userId);
+ $t = array('i');
+ if (!$res) {
+ return false;
+ else {
+ return true;
+ function getAllFilteredUsers($owner) {
+ $sql = "SELECT mb_user_id,mb_user_name,mb_user_email FROM mb_user ";
+ $sql .= " WHERE mb_user_owner = $1 ORDER BY mb_user_name ";
+ $v = array($owner);
+ $t = array('i');
+ $res = db_prep_query($sql, $v, $t);
+ $allUsers = $res;
+ return $allUsers;
+ function getAllUserColumns($userId) {
+ $userArray = array();
+ $sql = "SELECT * FROM mb_user WHERE mb_user_id = $1";
+ $t = array('s');
+ while ($row = db_fetch_array($res)) {
+ foreach ($row as $key => $value){
+ if (is_int($key)==false) {
+ array_push($userArray, array("id" => $key, "value" => $value));
+ $json = new Mapbender_JSON();
+ $output = $json->encode($userArray);
+ header("Content-type:text/plain; charset=utf-8");
+ return $output;
+ function getTableColumns($table,$keyField,$keyFieldValue) {
+ $sql = "SELECT * FROM $table WHERE $keyField = $1";
+ $columnArray = array();
+ $v = array($keyFieldValue);
+ $t = array('s');
+ $i = 0;
+ while ($i < db_num_fields($res)) {
+ if(db_field_type($res, $i)=="varchar") {
+ $fieldType = "s";
+ else {
+ $fieldType = "i";
+ $columnArray[db_fieldname($res, $i)] = $fieldType;
+ $i++;
+ $sqlArray = array_merge_recursive($columnArray, array_intersect_key($_REQUEST, $columnArray));
+ return $sqlArray;
+ function deleteTableRecord($table,$keyField,$keyFieldValue) {
+ $sql = "DELETE FROM $table WHERE $keyField = $1";
+ $t = array('s');
+ if (!$res) {
+ return false;
+ else {
+ return true;
+ function getUserIdByUserName($username){
+ $sql .= "WHERE mb_user_name = $1 GROUP BY mb_user_id";
+ $v = array($username);
+ $t = array('s');
+ if ($row) return $row["mb_user_id"]; else return false;
+ function setUserAsGuiOwner($guiId, $userId) {
+ $sql = "UPDATE gui_mb_user SET mb_user_type = 'owner' ";
+ $sql .= "WHERE fkey_gui_id = $1 AND fkey_mb_user_id = $2 ";
+ $v = array($guiId,$userId);
+ $t = array('s','i');
+ if (!$res) {
+ return false;
+ else {
+ return true;
+ function getGuiIdByGuiName($guiTitle){
+ $sql = "SELECT gui_id FROM gui ";
+ $sql .= "WHERE gui_name = $1 GROUP BY gui_id";
+ $v = array($guiTitle);
+ $t = array('s');
+ $count_g = 0;
+ $array = array();
+ $array[$count_g] = $row["gui_id"];
+ $count_g++;
+ return $array;
+ else {
+ return false;
+ function getGuisByOwner($user_id,$ignore_public)
+ $sql_guis = "SELECT gui.gui_id FROM gui,gui_mb_user ";
+ $sql_guis .= "WHERE (gui.gui_id = gui_mb_user.fkey_gui_id AND gui_mb_user.fkey_mb_user_id = $1) ";
+ if (!isset($ignore_public) OR $ignore_public == false){
+ $sql_guis .= " AND gui.gui_public = 1 ";
+ $sql_guis .= " AND gui_mb_user.mb_user_type = 'owner' GROUP BY gui.gui_id";
+ $sql_guis .= " ORDER by gui.gui_id";
+ $t = array('i');
+ $res_guis = db_prep_query($sql_guis,$v,$t);
+ $count_g = 0;
+ $arrayGuis = array();
+ while($row = db_fetch_array($res_guis)){
+ $arrayGuis[$count_g] = $row["gui_id"];
+ $count_g++;
+ return $arrayGuis;
+ * @deprecated
+ function getWmcByOwner($user_id){
+ $e = new mb_notice("administration->getWmcByOwner is deprecated, use user->getWmcByOwner instead!");
+ $user = new User($user_id);
+ return $user->getWmcByOwner();
+ * @deprecated
function getGuisByPermission($mb_user_id,$ignorepublic){
$e = new mb_notice("administration->getGuisByPermission is deprecated, use user->getApplicationsByPermission instead!");
- $user = new User($mb_user_id);
- return $user->getApplicationsByPermission($ignorepublic);
- function getWmsByOwnGuis($array_gui_ids){
- if(count($array_gui_ids)>0){
- $v = array();
- $t = array();
- $sql = "SELECT fkey_wms_id from gui_wms WHERE gui_wms.fkey_gui_id IN(";
- for($i=0; $i<count($array_gui_ids); $i++){
- $sql .= "$".strval($i+1);
- array_push($v, $array_gui_ids[$i]);
- array_push($t, "s");
- $sql .= ") GROUP BY fkey_wms_id ORDER BY fkey_wms_id";
- $ownguis = array();
- $i=0;
- $ownguis[$i] = $row['fkey_wms_id'];
- $i++;
- return $ownguis;
- function getLayerByWms($wms_id){
- $sql = "SELECT layer_id from layer WHERE fkey_wms_id = $1 AND layer_pos NOT IN ('0') GROUP BY layer_id, layer_title ORDER BY layer_title";
- $t = array('i');
- $layer_id_array = array();
- $layer_id_array[count($layer_id_array)] = $row['layer_id'];
- return $layer_id_array;
- function getWmsOwner($wms_id){
- $t = array('i');
- $count=0;
- $count++;
- $v = array();
- $t = array();
- $sql = "SELECT mb_user.mb_user_id FROM mb_user JOIN gui_mb_user ";
- $sql .= "ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id WHERE";
- $sql .= " gui_mb_user.fkey_gui_id IN (";
- $sql .= "$".($i+1);
- array_push($t,'s');
- $sql .= ")";
- $sql .= " AND gui_mb_user.mb_user_type = 'owner' GROUP BY mb_user.mb_user_id";
- $i=0;
- $wmsowner = array();
- $wmsowner[$i]=$row['mb_user_id'];
- $i++;
- return $wmsowner;
- function insertUserAsGuiOwner($guiId, $userId){
- $sql = "INSERT INTO gui_mb_user VALUES ($1, $2, 'owner')";
- if (!$res) {
- return false;
- else {
- return true;
- function checkModulePermission($arrayGuis, $modulePath, $column){
- $check = true;
- if($check == true){
- $perm = false;
- if(count($arrayGuis)>0){
- $v = array();
- $t = array();
- $sql = "SELECT ".$column." FROM gui_element WHERE fkey_gui_id IN(";
- for($i=0; $i<count($arrayGuis); $i++){
- if($i > 0){ $sql .= ","; }
- array_push($v,$arrayGuis[$i]);
- $sql .= ")";
- $cnt = 0;
- if(mb_strpos(stripslashes($row[$column]),$modulePath) !== false){
- $perm = true;
- $cnt++;
- return $perm;
- else{
- return true;
- * Checks if a user is allowed to access a GUI element
- * @return boolean
- * @param $arrayGuis Object
- * @param $modulePath Object
- * @param $elementTag Object
- function checkModulePermission_new($userId, $modulePath, $elementTag){
- if (CHECK) {
- $arrayGuis = $this->getGuisByPermission($userId, true);
- switch ($elementTag) {
- case "a" :
- $column = "e_attributes";
- $pattern = "/^.*href\s*=\s*(\'|\")\.\.((\/[a-zA-Z0-9_\/\.]+)+)(\?|\'|\").*$/";
- $replace = "$2";
- break;
- case "iframe" :
- $column = "e_src";
- $pattern = "/^\.\.((\/[a-zA-Z0-9_\/\.]+)+)(\?|\'|\").*$/";
- $replace = "$1";
- break;
- if ($column && count($arrayGuis) > 0) {
- $v = array();
- $t = array();
- $sql = "SELECT DISTINCT ".$column." FROM gui_element WHERE fkey_gui_id IN (";
- $sql .= ") ORDER BY " . $column;
- if ($row[$column]) {
- if (preg_match($pattern, stripslashes($row[$column]))) {
- $dbFilename = preg_replace($pattern, $replace, stripslashes($row[$column]));
- $e = new mb_notice($dbFilename . " - " . $modulePath);
- if(strpos($modulePath, $dbFilename) !== false){
- return true;
- return false;
- return true;
- function getWMSOWSstring($wms_id){
- $sql = "SELECT wms_owsproxy FROM wms WHERE wms_id = $1 ";
- $t = array("i");
- if($row = db_fetch_array($res)){
- return $row["wms_owsproxy"];
- else{
- return false;
- function setWMSOWSstring($wms_id, $status){
- $sql = "UPDATE wms SET wms_owsproxy = $1 WHERE wms_id = $2 ";
- $t = array("s","i");
- if($status == 'on'){
- $time = md5(microtime(1));
- $v = array($time,$wms_id);
- else{
- $v = array("",$wms_id);
- * get the owsproxy-string of the current wfs
- * @param integer the wfs-id of the current wfs
- * @return mixed the owsproxy-string or false
- function getWfsOwsproxyString($wfs_id){
- $sql = "SELECT wfs_owsproxy FROM wfs WHERE wfs_id = $1 ";
- $v = array($wfs_id);
- $t = array("i");
- return $row["wfs_owsproxy"];
- else{
- return false;
- * sets or removes the owsproxy string of the current wfs
- * @param boolean set (true) or remove (false) the owsproxy-string
- function setWfsOwsproxyString($wfs_id, $status){
- $sql = "UPDATE wfs SET wfs_owsproxy = $1 WHERE wfs_id = $2 ";
- if($status == true){
- $v = array($time,$wfs_id);
- else{
- $n = new mb_notice("removed owsproxy for wfs:".$wfs_id);
- $v = array("",$wfs_id);
- $newOwsString = $this->getWfsOwsproxyString($wfs_id);
- $n = new mb_notice("Class administration - setOWSString for wfs (".$wfs_id.") to: ". $this->getWfsOwsproxyString($wfs_id));
- return $newOwsString;
- function checkURL($url){
- $pos_qm = strpos($url,"?");
- if($pos_qm > 0 && $pos_qm < (mb_strlen($url)-1) && mb_substr($url,(mb_strlen($url)-1)) != "&"){
- $url = $url."&";
- return $url;
- else if($pos_qm === false){
- return $url."?";
- else{
- return $url;
- function getModulPermission($userID,$guiID,$elementID){
- $g = $this->getGuisByPermission($userID,true);
- if(in_array($guiID,$g)){
- $sql = "SELECT * FROM gui_element WHERE fkey_gui_id = $1 AND e_id = $2 ";
- $v = array($guiID,$elementID);
- return true;
- else{
- return false;
- else{
- return false;
- function getLayerPermission($wms_id, $layer_name, $user_id){
- $layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
- $array_guis = $this->getGuisByPermission($user_id,true);
- $v = array();
- $t = array();
- $sql = "SELECT * FROM gui_layer WHERE fkey_gui_id IN (";
- $c = 1;
- for($i=0; $i<count($array_guis); $i++){
- $sql .= "$".$c;
- $c++;
- array_push($v, $array_guis[$i]);
- $sql .= ") AND fkey_layer_id = $".$c." AND gui_layer_status = 1";
- array_push($v,$layer_id);
- array_push($t,'i');
- return true;
- else{
- return false;
- function getWmsPermission($wms_id, $user_id) {
- $v = array();
- $t = array();
- $sql = "SELECT * FROM gui_wms WHERE fkey_gui_id IN (";
- $c = 1;
- $sql .= "$".$c;
- $c++;
- $sql .= ") AND fkey_wms_id = $".$c;
- array_push($v,$wms_id);
- return true;
- else{
- return false;
- function getLayerIdByLayerName($wms_id, $layer_name){
- $sql = "SELECT layer_id FROM layer WHERE ";
- $sql .= "fkey_wms_id = $1 AND layer_name = $2";
- $v = array($wms_id,$layer_name);
- $t = array('i','s');
- return $row['layer_id'];
- else{
- return false;
- function getWmsIdByWmsGetmap($getmap) {
- $sql = "SELECT wms_id FROM wms WHERE ";
- $sql .= "wms_getmap LIKE $1 LIMIT 1";
- $v = array($getmap."%");
- $t = array('s');
- return $row['wms_id'];
- else{
- return false;
- function is_utf8_string($string) {
- if (is_array($string))
- $enc = implode('', $string);
- return @!((ord($enc[0]) != 239) && (ord($enc[1]) != 187) && (ord($enc[2]) != 191));
- else
- return (utf8_encode(utf8_decode($string)) == $string);
- return preg_match('%(?:
- [\xC2-\xDF][\x80-\xBF] # non-overlong 2-byte
- |\xE0[\xA0-\xBF][\x80-\xBF] # excluding overlongs
- |[\xE1-\xEC\xEE\xEF][\x80-\xBF]{2} # straight 3-byte
- |\xED[\x80-\x9F][\x80-\xBF] # excluding surrogates
- |\xF0[\x90-\xBF][\x80-\xBF]{2} # planes 1-3
- |[\xF1-\xF3][\x80-\xBF]{3} # planes 4-15
- |\xF4[\x80-\x8F][\x80-\xBF]{2} # plane 16
- )+%xs', $string);
- function is_utf8_xml($xml) {
- return preg_match('/<\?xml[^>]+encoding="utf-8"[^>]*\?>/is', $xml);
- function is_utf8 ($data) {
- return ($this->is_utf8_xml($data) || $this->is_utf8_string($data));
- function char_encode($data) {
- if (CHARSET == "UTF-8") {
- if (!$this->is_utf8($data)) {
- $e = new mb_notice("Conversion: ISO-8859-1 to UTF-8");
- return utf8_encode($data);
- else {
- if ($this->is_utf8($data)) {
- $e = new mb_notice("Conversion: UTF-8 to ISO-8859-1");
- return utf8_decode($data);
- $e = new mb_notice("No conversion: is " . CHARSET);
- return $data;
- function char_decode($data) {
- $e = new mb_notice("no conversion: is " . CHARSET);
- return $data;
- * identifies the Featureservices where the current user is owner
- * @param integer userid the user-ID of the current user
- * @return integer[] the IDs of the featureservices
- function getWfsByOwner($userid){
- $sql = "SELECT wfs_id FROM wfs WHERE wfs_owner = $1";
- $t = array('i');
- $r = array();
- array_push($r,$row["wfs_id"]);
- return $r;
- /** identifies the Conf-FeatureServices where the current user is owner
- * @deprecated
- * @return integer[] the IDs of the wfs_conf-table
+ $user = new User($mb_user_id);
+ return $user->getApplicationsByPermission($ignorepublic);
+ function getWmsByOwnGuis($array_gui_ids){
+ if(count($array_gui_ids)>0){
+ $v = array();
+ $t = array();
+ $sql = "SELECT fkey_wms_id from gui_wms WHERE gui_wms.fkey_gui_id IN(";
+ for($i=0; $i<count($array_gui_ids); $i++){
+ $sql .= "$".strval($i+1);
+ array_push($v, $array_gui_ids[$i]);
+ array_push($t, "s");
+ $sql .= ") GROUP BY fkey_wms_id ORDER BY fkey_wms_id";
+ $ownguis = array();
+ $i=0;
+ $ownguis[$i] = $row['fkey_wms_id'];
+ $i++;
+ return $ownguis;
+ function getLayerByWms($wms_id){
+ $sql = "SELECT layer_id from layer WHERE fkey_wms_id = $1 AND layer_pos NOT IN ('0') GROUP BY layer_id, layer_title ORDER BY layer_title";
+ $t = array('i');
+ $layer_id_array = array();
+ $layer_id_array[count($layer_id_array)] = $row['layer_id'];
+ return $layer_id_array;
+ function getWmsOwner($wms_id){
+ $t = array('i');
+ $count=0;
+ $count++;
+ $v = array();
+ $t = array();
+ $sql = "SELECT mb_user.mb_user_id FROM mb_user JOIN gui_mb_user ";
+ $sql .= "ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id WHERE";
+ $sql .= " gui_mb_user.fkey_gui_id IN (";
+ $sql .= "$".($i+1);
+ array_push($t,'s');
+ $sql .= ")";
+ $sql .= " AND gui_mb_user.mb_user_type = 'owner' GROUP BY mb_user.mb_user_id";
+ $i=0;
+ $wmsowner = array();
+ $wmsowner[$i]=$row['mb_user_id'];
+ $i++;
+ return $wmsowner;
+ function insertUserAsGuiOwner($guiId, $userId){
+ $sql = "INSERT INTO gui_mb_user VALUES ($1, $2, 'owner')";
+ if (!$res) {
+ return false;
+ else {
+ return true;
+ function checkModulePermission($arrayGuis, $modulePath, $column){
+ $check = true;
+ if($check == true){
+ $perm = false;
+ if(count($arrayGuis)>0){
+ $v = array();
+ $t = array();
+ $sql = "SELECT ".$column." FROM gui_element WHERE fkey_gui_id IN(";
+ for($i=0; $i<count($arrayGuis); $i++){
+ if($i > 0){ $sql .= ","; }
+ array_push($v,$arrayGuis[$i]);
+ $sql .= ")";
+ $cnt = 0;
+ if(mb_strpos(stripslashes($row[$column]),$modulePath) !== false){
+ $perm = true;
+ $cnt++;
+ return $perm;
+ else{
+ return true;
+ * Checks if a user is allowed to access a GUI element
+ * @return boolean
+ * @param $arrayGuis Object
+ * @param $modulePath Object
+ * @param $elementTag Object
+ function checkModulePermission_new($userId, $modulePath, $elementTag){
+ if (CHECK) {
+ $arrayGuis = $this->getGuisByPermission($userId, true);
+ switch ($elementTag) {
+ case "a" :
+ $column = "e_attributes";
+ $pattern = "/^.*href\s*=\s*(\'|\")\.\.((\/[a-zA-Z0-9_\/\.]+)+)(\?|\'|\").*$/";
+ $replace = "$2";
+ break;
+ case "iframe" :
+ $column = "e_src";
+ $pattern = "/^\.\.((\/[a-zA-Z0-9_\/\.]+)+)(\?|\'|\").*$/";
+ $replace = "$1";
+ break;
+ if ($column && count($arrayGuis) > 0) {
+ $v = array();
+ $t = array();
+ $sql = "SELECT DISTINCT ".$column." FROM gui_element WHERE fkey_gui_id IN (";
+ $sql .= ") ORDER BY " . $column;
+ if ($row[$column]) {
+ if (preg_match($pattern, stripslashes($row[$column]))) {
+ $dbFilename = preg_replace($pattern, $replace, stripslashes($row[$column]));
+ $e = new mb_notice($dbFilename . " - " . $modulePath);
+ if(strpos($modulePath, $dbFilename) !== false){
+ return true;
+ return false;
+ return true;
+ function getWMSOWSstring($wms_id){
+ $sql = "SELECT wms_owsproxy FROM wms WHERE wms_id = $1 ";
+ $t = array("i");
+ if($row = db_fetch_array($res)){
+ return $row["wms_owsproxy"];
+ else{
+ return false;
+ function setWMSOWSstring($wms_id, $status){
+ $sql = "UPDATE wms SET wms_owsproxy = $1 WHERE wms_id = $2 ";
+ $t = array("s","i");
+ if($status == 'on'){
+ $time = md5(microtime(1));
+ $v = array($time,$wms_id);
+ else{
+ $v = array("",$wms_id);
+ * get the owsproxy-string of the current wfs
+ * @param integer the wfs-id of the current wfs
+ * @return mixed the owsproxy-string or false
+ function getWfsOwsproxyString($wfs_id){
+ $sql = "SELECT wfs_owsproxy FROM wfs WHERE wfs_id = $1 ";
+ $v = array($wfs_id);
+ $t = array("i");
+ return $row["wfs_owsproxy"];
+ else{
+ return false;
+ * sets or removes the owsproxy string of the current wfs
+ * @param boolean set (true) or remove (false) the owsproxy-string
+ function setWfsOwsproxyString($wfs_id, $status){
+ $sql = "UPDATE wfs SET wfs_owsproxy = $1 WHERE wfs_id = $2 ";
+ if($status == true){
+ $v = array($time,$wfs_id);
+ else{
+ $n = new mb_notice("removed owsproxy for wfs:".$wfs_id);
+ $v = array("",$wfs_id);
+ $newOwsString = $this->getWfsOwsproxyString($wfs_id);
+ $n = new mb_notice("Class administration - setOWSString for wfs (".$wfs_id.") to: ". $this->getWfsOwsproxyString($wfs_id));
+ return $newOwsString;
+ function checkURL($url){
+ $pos_qm = strpos($url,"?");
+ if($pos_qm > 0 && $pos_qm < (mb_strlen($url)-1) && mb_substr($url,(mb_strlen($url)-1)) != "&"){
+ $url = $url."&";
+ return $url;
+ else if($pos_qm === false){
+ return $url."?";
+ else{
+ return $url;
+ function getModulPermission($userID,$guiID,$elementID){
+ $g = $this->getGuisByPermission($userID,true);
+ if(in_array($guiID,$g)){
+ $sql = "SELECT * FROM gui_element WHERE fkey_gui_id = $1 AND e_id = $2 ";
+ $v = array($guiID,$elementID);
+ return true;
+ else{
+ return false;
+ else{
+ return false;
+ function getLayerPermission($wms_id, $layer_name, $user_id){
+ $layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
+ $array_guis = $this->getGuisByPermission($user_id,true);
+ $v = array();
+ $t = array();
+ $sql = "SELECT * FROM gui_layer WHERE fkey_gui_id IN (";
+ $c = 1;
+ for($i=0; $i<count($array_guis); $i++){
+ $sql .= "$".$c;
+ $c++;
+ array_push($v, $array_guis[$i]);
+ $sql .= ") AND fkey_layer_id = $".$c." AND gui_layer_status = 1";
+ array_push($v,$layer_id);
+ array_push($t,'i');
+ return true;
+ else{
+ return false;
+ function getWmsPermission($wms_id, $user_id) {
+ $v = array();
+ $t = array();
+ $sql = "SELECT * FROM gui_wms WHERE fkey_gui_id IN (";
+ $c = 1;
+ $sql .= "$".$c;
+ $c++;
+ $sql .= ") AND fkey_wms_id = $".$c;
+ array_push($v,$wms_id);
+ return true;
+ else{
+ return false;
+ function getLayerIdByLayerName($wms_id, $layer_name){
+ $sql = "SELECT layer_id FROM layer WHERE ";
+ $sql .= "fkey_wms_id = $1 AND layer_name = $2";
+ $v = array($wms_id,$layer_name);
+ $t = array('i','s');
+ return $row['layer_id'];
+ else{
+ return false;
+ function getWmsIdByWmsGetmap($getmap) {
+ $sql = "SELECT wms_id FROM wms WHERE ";
+ $sql .= "wms_getmap LIKE $1 LIMIT 1";
+ $v = array($getmap."%");
+ $t = array('s');
+ return $row['wms_id'];
+ else{
+ return false;
+ function is_utf8_string($string) {
+ if (is_array($string))
+ $enc = implode('', $string);
+ return @!((ord($enc[0]) != 239) && (ord($enc[1]) != 187) && (ord($enc[2]) != 191));
+ else
+ return (utf8_encode(utf8_decode($string)) == $string);
+ return preg_match('%(?:
+ [\xC2-\xDF][\x80-\xBF] # non-overlong 2-byte
+ |\xE0[\xA0-\xBF][\x80-\xBF] # excluding overlongs
+ |[\xE1-\xEC\xEE\xEF][\x80-\xBF]{2} # straight 3-byte
+ |\xED[\x80-\x9F][\x80-\xBF] # excluding surrogates
+ |\xF0[\x90-\xBF][\x80-\xBF]{2} # planes 1-3
+ |[\xF1-\xF3][\x80-\xBF]{3} # planes 4-15
+ |\xF4[\x80-\x8F][\x80-\xBF]{2} # plane 16
+ )+%xs', $string);
+ function is_utf8_xml($xml) {
+ return preg_match('/<\?xml[^>]+encoding="utf-8"[^>]*\?>/is', $xml);
+ function is_utf8 ($data) {
+ return ($this->is_utf8_xml($data) || $this->is_utf8_string($data));
+ function char_encode($data) {
+ if (CHARSET == "UTF-8") {
+ if (!$this->is_utf8($data)) {
+ $e = new mb_notice("Conversion: ISO-8859-1 to UTF-8");
+ return utf8_encode($data);
+ else {
+ if ($this->is_utf8($data)) {
+ $e = new mb_notice("Conversion: UTF-8 to ISO-8859-1");
+ return utf8_decode($data);
+ $e = new mb_notice("No conversion: is " . CHARSET);
+ return $data;
+ function char_decode($data) {
+ $e = new mb_notice("no conversion: is " . CHARSET);
+ return $data;
+ * identifies the Featureservices where the current user is owner
+ * @param integer userid the user-ID of the current user
+ * @return integer[] the IDs of the featureservices
+ function getWfsByOwner($userid){
+ $sql = "SELECT wfs_id FROM wfs WHERE wfs_owner = $1";
+ $t = array('i');
+ $r = array();
+ array_push($r,$row["wfs_id"]);
+ return $r;
+ /** identifies the Conf-FeatureServices where the current user is owner
+ * @deprecated
+ * @return integer[] the IDs of the wfs_conf-table
function getWfsConfByPermission($userid){
- $e = new mb_notice("administration->getWfsConfByPermission is deprecated, use user->getWfsConfByPermission instead!");
- $user = new User($userid);
- return $user->getWfsConfByPermission();
+ $e = new mb_notice("administration->getWfsConfByPermission is deprecated, use user->getWfsConfByPermission instead!");
+ $user = new User($userid);
+ return $user->getWfsConfByPermission();
\ No newline at end of file
More information about the Mapbender_commits
