[Mapbender-commits] r2637 - branches/spsneo_dev/mapbender/update
svn_mapbender at osgeo.org
Thu Jul 10 03:37:10 EDT 2008
Author: spsneo
Date: 2008-07-10 03:37:10 -0400 (Thu, 10 Jul 2008)
New Revision: 2637
Added:
branches/spsneo_dev/mapbender/update/updaters.inc
Database Update Routine ready
Added: branches/spsneo_dev/mapbender/update/updaters.inc
--- branches/spsneo_dev/mapbender/update/updaters.inc (rev 0)
+++ branches/spsneo_dev/mapbender/update/updaters.inc 2008-07-10 07:37:10 UTC (rev 2637)
@@ -0,0 +1,65 @@
+<?php
+#@author: Siddharth Prakash Singh (spsneo)
+#Google SoC 2008 project
+#This is the core file of Database Updater
+#locates the correct directory containing the sql files to be executed.
+#parse the sql files and execute the queries
+#SQL files are to be placed in /update/db/SYS_DBTYPE/CHARSET directory.
+#where SYS_DBTYPE is the constant defining the database type and CHARSET defines the encoding
+# these constants are defined in /conf/mapbender.conf file
+#SQL files should have .sql extension
+#This function executes the required sql files.
+function do_db_updates() {
+ #Connect the database server
+ $con = db_connect(DBSERVER,OWNER,PW);
+ #select the database
+ db_select_db(DB,$con);
+ #locate the correct directory according to SYS_DBTYPE and CHARSET
+ $db_dir = dir('./db/'.SYS_DBTYPE.'/'.CHARSET);
+ #Get the path of directory containing the sql files for later use in this function
+ $db_dir_path = $db_dir->path;
+ #this loops iterates for every file in the directory located
+ while (false !== ($db_file = $db_dir->read())) {
+ #check for sql files by checking the extension
+ if(preg_match("/\.sql$/", $db_file)){
+ #get the content of the entire sql file in an array
+ #where every element of the array contains one line
+ $file_content = file($db_dir_path.'/'.$db_file);
+ #check whether file opened correctly
+ if($file_content === false) {
+ echo "Unable to read SQL files. Please try again..\n";
+ #Query initiated
+ $query = "";
+ #Parse the SQL file content
+ #this loops for every line in the sql file
+ foreach($file_content as $sql_line) {
+ if(trim($sql_line) != "" && strpos($sql_line, "--") !== 0) {
+ $query .= $sql_line;
+ #Finding Valid SQL statements.
+ if(preg_match("/(.*);/", $sql_line)) {
+ #Preparing the query
+ $query = substr($query, 0, strlen($query)-1);
+ #Execute the prepared sql query
+ $result = db_query($query);
+ #Reset the query for next one
+ $query = "";
+ } //End of preg_match 2
+ } //End of trim
+ } //End of foreach
+ }//End of preg_match 1
+ }//End of while
More information about the Mapbender_commits
