[Mapbender-commits] r2666 - branches/testbaudson_dev/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jul 17 08:05:08 EDT 2008
Author: christoph
Date: 2008-07-17 08:05:08 -0400 (Thu, 17 Jul 2008)
New Revision: 2666
   branches/testbaudson_dev/http/javascripts/mod_addWMSfromList.php
   branches/testbaudson_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php
   branches/testbaudson_dev/http/javascripts/mod_measure.php
   branches/testbaudson_dev/http/javascripts/mod_pan.php
Modified: branches/testbaudson_dev/http/javascripts/mod_addWMSfromList.php
--- branches/testbaudson_dev/http/javascripts/mod_addWMSfromList.php	2008-07-17 12:03:59 UTC (rev 2665)
+++ branches/testbaudson_dev/http/javascripts/mod_addWMSfromList.php	2008-07-17 12:05:08 UTC (rev 2666)
@@ -53,6 +53,10 @@
+function mod_addWMSfromDB(gui_id, wms_id) {
+	window.opener.mod_addWMSById_load(gui_id, wms_id);
 </script>
@@ -145,7 +149,7 @@
 /*get allocated wms from allocated gui  ********************************************************************************************/
 /*get allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
-$sql_wms = "SELECT DISTINCT wms_title, wms_abstract, wms_getcapabilities,wms_version FROM wms WHERE wms_id IN (";
+$sql_wms = "SELECT DISTINCT wms_id, wms_title, wms_abstract, wms_getcapabilities,wms_version FROM wms WHERE wms_id IN (";
 $v = $fkey_wms_id;
 $t = array();
 for ($i = 1; $i <= count($fkey_wms_id); $i++){
@@ -160,6 +164,7 @@
 $res_wms = db_prep_query($sql_wms, $v, $t);
 while($row = db_fetch_array($res_wms)){
+	$wms_id[$cnt_wms] = $row["wms_id"];
 	$wms_title[$cnt_wms] = $row["wms_title"];
 	$wms_abstract[$cnt_wms] = $row["wms_abstract"];
 	$wms_getcapabilities[$cnt_wms] = $row["wms_getcapabilities"];
@@ -179,8 +184,8 @@
 echo " <tbody >";
 for($i=0; $i<$cnt_wms; $i++){
 	echo "<tr class='Farbe' onmouseover='this.style.backgroundColor = \"#F08080\"' onmouseout='this.style.backgroundColor = \"#ffffff\"'>";
-	echo "<td><div id ='id_".$wms_title[$i]."' class='even' name ='name_".$wms_title[$i]."'  style='cursor:pointer' onclick = 'mod_addWMS(\"".$wms_getcapabilities[$i]."\",\"".$wms_version[$i]."\")'>".$wms_title[$i]."</div></td>";
-	echo "<td><div  id ='id_".$wms_abstract[$i]."' class='even' name ='name_".$wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMS(\"".$wms_getcapabilities[$i]."\",\"".$wms_version[$i]."\")'>".$wms_abstract[$i]."</div></td>";
+	echo "<td><div id ='id_".$wms_title[$i]."' class='even' name ='name_".$wms_title[$i]."'  style='cursor:pointer' onclick = 'mod_addWMSfromDB(\"\",\"".$wms_id[$i]."\")'>".$wms_title[$i]."</div></td>";
+	echo "<td><div  id ='id_".$wms_abstract[$i]."' class='even' name ='name_".$wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMSfromDB(\"\",\"".$wms_id[$i]."\")'>".$wms_abstract[$i]."</div></td>";
 	echo "</tr>";
 echo "  </tbody>";
Modified: branches/testbaudson_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php
--- branches/testbaudson_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php	2008-07-17 12:03:59 UTC (rev 2665)
+++ branches/testbaudson_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php	2008-07-17 12:05:08 UTC (rev 2666)
@@ -239,7 +239,8 @@
 				var onClick = "mod_addWMSfromDB('" + guiId + "', '" + wmsArray[i].id + "')";
 			else {
-				var onClick = "mod_addWMSfromfilteredList('" + wmsArray[i].getCapabilitiesUrl + "', '" + wmsArray[i].version + "')";
+				var onClick = "mod_addWMSfromDB('" + guiId + "', '" + wmsArray[i].id + "')";
+//				var onClick = "mod_addWMSfromfilteredList('" + wmsArray[i].getCapabilitiesUrl + "', '" + wmsArray[i].version + "')";
 			addRow("resultTableBody", wmsArray[i].title, wmsArray[i].abstract, onClick);
Modified: branches/testbaudson_dev/http/javascripts/mod_measure.php
--- branches/testbaudson_dev/http/javascripts/mod_measure.php	2008-07-17 12:03:59 UTC (rev 2665)
+++ branches/testbaudson_dev/http/javascripts/mod_measure.php	2008-07-17 12:05:08 UTC (rev 2666)
@@ -143,10 +143,10 @@
 function drawDashedLine(){
 	//check if epsg has changed
 	var ind = getMapObjIndexByName(mod_measure_target);
+	mod_measure_width = mb_mapObj[ind].width;
+	mod_measure_height = mb_mapObj[ind].height;
 	if(mod_measure_epsg != mb_mapObj[ind].epsg){
 		mod_measure_delete();
-		mod_measure_width = mb_mapObj[ind].width;
-		mod_measure_height = mb_mapObj[ind].height;
 		mod_measure_epsg = mb_mapObj[ind].epsg;
 	var str_mPoints = "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='"+mod_measure_width+"' height='0'></div>";
Modified: branches/testbaudson_dev/http/javascripts/mod_pan.php
--- branches/testbaudson_dev/http/javascripts/mod_pan.php	2008-07-17 12:03:59 UTC (rev 2665)
+++ branches/testbaudson_dev/http/javascripts/mod_pan.php	2008-07-17 12:05:08 UTC (rev 2666)
@@ -43,12 +43,18 @@
 	mb_button[ind].stop = new Function ("mod_pan_disable()");
 function mod_pan_click(){
+	var p = window.frames[mod_pan_target].document.getElementById("maps");
+	p.style.cursor = "pointer";
 	var el = window.frames[mod_pan_target].document;
 	el.onmousedown = mod_pan_start;
 	el.onmouseup = mod_pan_stop;
 	el.onmousemove = mod_pan_run;
 function mod_pan_disable(){
+	p.style.cursor = "";
 	el.onmousedown = null;
 	el.onmouseup = null;
More information about the Mapbender_commits mailing list
