[Mapbender-commits] r2674 - in branches/testbaudson_dev: http/classes http/frames http/javascripts http/php lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 18 06:26:22 EDT 2008
Author: christoph
Date: 2008-07-18 06:26:21 -0400 (Fri, 18 Jul 2008)
New Revision: 2674
Added:
   branches/testbaudson_dev/lib/application.php
   branches/testbaudson_dev/lib/element.php
   branches/testbaudson_dev/lib/mapbender.php
   branches/testbaudson_dev/http/classes/class_element.php
   branches/testbaudson_dev/http/classes/class_gui.php
   branches/testbaudson_dev/http/frames/index.php
   branches/testbaudson_dev/http/javascripts/geometry.js
   branches/testbaudson_dev/http/javascripts/mod_box1.js
   branches/testbaudson_dev/http/javascripts/mod_savewmc.php
   branches/testbaudson_dev/http/javascripts/mod_wfs_gazetteer_client.php
   branches/testbaudson_dev/http/php/mb_validateSession.php
   branches/testbaudson_dev/http/php/mod_createUser.php
   branches/testbaudson_dev/http/php/mod_renameGUI.php
refactoring
merged with trunk
Modified: branches/testbaudson_dev/http/classes/class_element.php
--- branches/testbaudson_dev/http/classes/class_element.php	2008-07-17 12:29:29 UTC (rev 2673)
+++ branches/testbaudson_dev/http/classes/class_element.php	2008-07-18 10:26:21 UTC (rev 2674)
@@ -1,240 +1,3 @@
-<?php
-# $Id: class_bbox.php 1965 2008-01-15 08:24:29Z christoph $
-# http://www.mapbender.org/index.php/
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-define("ELEMENT_PATTERN", "/sessionID/");
-class Element {
-	var $guiId;
-	var $id;
-	var $pos;
-	var $isPublic;
-	var $comment;
-	var $title;
-	var $element;
-	var $src;
-	var $attributes;
-	var $left;
-	var $top;
-	var $width;
-	var $height;
-	var $zIndex;
-	var $moreStyles;
-	var $content;
-	var $closeTag;
-	var $jsFile;
-	var $mbMod;
-	var $target;
-	var $requires;
-	var $helpUrl;
-	public function __contruct() {
-	public function select ($id, $applicationId) {
-		$sql = "SELECT fkey_gui_id, e_id, e_pos, e_public, e_comment, e_public, ".
-				"gettext($1, e_title) as e_title, e_element, e_src, e_attributes, " .
-				"e_left, e_top, e_width, e_height, e_z_index, e_more_styles, " .
-				"e_content, e_closetag, e_js_file, e_mb_mod, e_target, " .
-				"e_requires, e_url FROM gui_element WHERE e_id = $2 AND " .
-				"fkey_gui_id = $3 LIMIT 1";
-		$v = array ($_SESSION["mb_lang"], $id, $applicationId);
-		$t = array ("s", "s", "s");
-		$res = db_prep_query($sql, $v, $t);
-		$row = db_fetch_array($res);
-		if ($row) {
-			$this->guiId = $applicationId;
-			$this->id = $row["e_id"];
-			$this->pos = $row["e_pos"];
-			$this->isPublic = $row["e_public"];
-			$this->comment = $row["e_comment"];
-			$this->title = $row["e_title"];
-			$this->element = $row["e_element"];
-			$this->src = $row["e_src"];
-			$this->attributes = $row["e_attributes"];
-			$this->left = $row["e_left"];
-			$this->top = $row["e_top"];
-			$this->width = $row["e_width"];
-			$this->height = $row["e_height"];
-			$this->zIndex = $row["e_z_index"];
-			$this->moreStyles = $row["e_more_styles"];
-			$this->content = $row["e_content"];
-			$this->closeTag = $row["e_closetag"];
-			$this->jsFile = $row["e_js_file"];
-			$this->mbMod = $row["e_mb_mod"];
-			$this->target = $row["e_target"];
-			$this->requires = $row["e_requires"];
-			$this->helpUrl = $row["e_url"];
-			return true;
-		return false;
-	public function __toString () {
-		return $this->toHtml();
-	public function getJavaScriptModules () {
-		$jsArray = array();
-		if ($this->mbMod != "") {
-			$moduleArray = explode(",", $this->mbMod);
-			for ($i = 0; $i < count($moduleArray); $i++) {
-				$currentFile = dirname(__FILE__) . "/../javascripts/" . trim($moduleArray[$i]);
-				if (file_exists($currentFile)) {
-					array_push($jsArray, $currentFile);
-				else {
-					$e = new mb_exception("Javascript module not found: " . $currentFile);
-		return $jsArray;
-	public function toHtmlArray () {
-		if ($this->isPublic) {
-			return array($this->getHtmlOpenTag(), $this->getHtmlContent(), $this->getHtmlCloseTag());
-		return array("", "", "");
-	public function toHtml () {
-			return implode("", $this->toHtmlArray());
-		return "";
-	private function getHtmlOpenTag () {
-		$openTag = "";
-		if ($this->id) {
-			// tag name
-			$openTag .= "<" . $this->element . " ";
-			// id and name
-			$openTag .= "id='" . $this->id . "' name='" . $this->id . "' ";
-			// attributes
-			if ($this->attributes) {
-				$openTag .= stripslashes($this->replaceSessionStringByUrlParameters($this->attributes)) . " ";
-			// title
-			if ($this->title) {
-				$openTag .= "title='" . $this->title . "' ";
-			// src
-			if ($this->src) {
-   				$openTag .= "src = '" . $this->replaceSessionStringByUrlParameters($this->src);
-				// for iframes which are not "loadData",
-				// add additional parameters
-				if ($this->closeTag == "iframe" && $this->id != "loadData") {
-					if(mb_strpos($this->src, "?")) {
-						$openTag .= "&";
-					else {
-	      				$openTag .= "?";
-	      			$openTag .= "e_id_css=" . $this->id . "&" .
-	      					 "e_id= " . $this->id . "&" .
-	      					 "e_target=" . $this->target . "&" .
-	      					 $this->getUrlParameters();
-   				$openTag .= "' ";
-			// style
-			$openTag .= " style = '";
-			if ($this->top != "" && $this->left != "") {
-				$openTag .= "position:absolute;" .
-						 "left:" . $this->left . ";" .
-						 "top:" . $this->top . ";";
-			if ($this->width != "" && $this->height != "") {
-				$openTag .= "width:" . $this->width . ";" .
-						 "height:" . $this->height . ";";
-			if ($this->zIndex) {
-		    	$openTag .= "z-index:" . $this->zIndex . ";";
-			if ($this->moreStyles) {
-		    	$openTag .= $this->moreStyles;
-			$openTag .= "'>";
-			if ($this->element == "body" && USE_LOAD_MESSAGE) {
-				$htmlWhileLoading = "<img src='../img/indicator_wheel.gif'>&nbsp;" .
-					"<b>Ma<font color='#0000CE'>p</font><font color='#C00000'>b</font>ender " .
-					MB_VERSION_NUMBER . " " . strtolower(MB_VERSION_APPENDIX) . "</b>..." .
-					"loading application '" . $this->guiId . "'";
-				$openTag .= "<div id='loading_mapbender' " .
-								"style='position:absolute;top:100;left:100'>" .
-								$htmlWhileLoading . "</div>" .
-								"<div id='complete_mapbender' " .
-								"style='display:none'>";
-		return $openTag;
-	private function getHtmlContent () {
-		$htmlContent = "";
-		if ($this->content != "") {
-			$htmlContent .= stripslashes($this->content);
-		return $htmlContent;
-	private function getHtmlCloseTag () {
-			return "</div></body>";
-		if ($this->closeTag != "") {
-			return "</" . $this->closeTag . ">";
-		return "";
-	private function getUrlParameters () {
-		$urlParameters = SID;
-		if (isset($this->guiId)) {
-			$urlParameters .= "&guiID=" . $this->guiId;
-		if (isset($this->id)) {
-			$urlParameters .= "&elementID=" . $this->id;
-		return $urlParameters;
-	private function replaceSessionStringByUrlParameters ($string) {
-		$urlParameters = $this->getUrlParameters();
-		return preg_replace(ELEMENT_PATTERN, $urlParameters, $string);
+<?php
+include_once(dirname(__FILE__)."/../../lib/element.php");
\ No newline at end of file
Modified: branches/testbaudson_dev/http/classes/class_gui.php
--- branches/testbaudson_dev/http/classes/class_gui.php	2008-07-17 12:29:29 UTC (rev 2673)
+++ branches/testbaudson_dev/http/classes/class_gui.php	2008-07-18 10:26:21 UTC (rev 2674)
@@ -1,296 +1,3 @@
 <?php
-# $Id$
-# http://www.mapbender.org/index.php/class_gui.php
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/../classes/class_element.php");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
- * GUI is a set of GUI elements and services.
-class gui {
-	var $id;
-	var $elementArray = array();
-	public function __construct ($id) {
-		if ($id) {
-			$this->id = $id;
-			$this->elementArray = $this->selectElements();
-	public function selectElements () {
-		$sql = "SELECT e_id FROM gui_element WHERE fkey_gui_id = $1 " .
-				"ORDER BY e_pos";
-		$v = array($this->id);
-		$t = array('s');
-		$res = db_prep_query($sql,$v,$t);
-		$elementArray = array();
-		while ($row = db_fetch_array($res)) {
-			array_push($elementArray, $row[0]);
-		$this->elementArray = array();
-		for ($i = 0; $i < count($elementArray); $i++) {
-			$currentElement = new Element();
-			$currentElement->select($elementArray[$i], $this->id);
-			array_push($this->elementArray, $currentElement);
-		return $this->elementArray;
-		$htmlString = "";
-		$htmlString .= $this->elementsToHtml();
-		return $htmlString;
-		for ($i = 0; $i < count($this->elementArray); $i++) {
-			$currentElement = $this->elementArray[$i];
-			array_merge($jsArray, $currentElement->getJavaScriptModules());
-		return $jsArray;
- 	 * Checks if a GUI with a given ID exists in the database
- 	 * @param integer $gui_id the ID of the GUI that is being checked
- 	 * @return boolean true if a gui '$gui_id' exists; else false
- 	public function guiExists ($gui_id){
-		$sql = "SELECT * FROM gui WHERE gui_id = $1";
-		$v = array($gui_id);
-		$t = array('s');
-		if ($row) {
-			return true;
-		return false;
-	 * Deletes a GUI $guiId and all its links to users, layers etc.
-	 * @param Integer $guiId the GUI that is going to be deleted
-	 * @return boolean true if the deletion succeded, else false
-	public function deleteGui ($guiId) {
-		$guiList = $guiId;
-		$sql = array();
-		$v = array();
-		$t = array();
-		array_push($sql, "BEGIN");
-		array_push($v, array());
-		array_push($t, array());
-		array_push($sql, "DELETE FROM gui WHERE gui_id = $1");
-		array_push($v, array($guiList));
-		array_push($t, array('s'));
-		array_push($sql, "DELETE FROM gui_element WHERE fkey_gui_id = $1");
-		array_push($sql, "DELETE FROM gui_element_vars WHERE fkey_gui_id = $1");
-		array_push($sql, "DELETE FROM gui_layer WHERE fkey_gui_id = $1");
-		array_push($sql, "DELETE FROM gui_mb_group WHERE fkey_gui_id = $1");
-		array_push($sql, "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1");
-		array_push($sql, "DELETE FROM gui_treegde WHERE fkey_gui_id = $1");
-		array_push($sql, "DELETE FROM gui_wfs WHERE fkey_gui_id = $1");
-		array_push($sql, "DELETE FROM gui_wms WHERE fkey_gui_id = $1");
-		array_push($sql, "COMMIT");
-		// execute all SQLs
-		for ($i = 0; $i < count($sql); $i++) {
-			$res = db_prep_query($sql[$i], $v[$i], $t[$i]);
-			// if an SQL fails, send a ROLLBACK and return false
-			if (!$res) {
-				db_query("ROLLBACK");
-				return false;
-		return true;
-	/** Renames the GUI $guiID to $newGUIName
-	 * @param Integer $guiId ID of the GUI
-	 * @param String $newGuiName the new name of the GUI
-	 * @return boolean true if the renaming succeded, else false
-	public function renameGui ($guiId, $newGuiName) {
-		if ($this->copyGui($guiId, $newGuiName, true)) {
-			$this->deleteGui($guiId);
-			return true;
-		return false;
- 	 * Copies a GUI $guiId and all its links to users, layers etc. to GUI $newGuiName
-	 * @param boolean $withUsers true if the users, that may access the GUI $guiId, shall have access to the new GUI; else false.
- 	public function copyGui ($guiId, $newGuiName, $withUsers) {
-		if (!$this->guiExists($newGuiName)) {
-			$sql = array();
-			$v = array();
-			$t = array();
-			array_push($sql, "INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) SELECT $1, $2, gui_description, gui_public FROM gui WHERE gui_id = $3;");
-			array_push($v, array ($newGuiName, $newGuiName, $guiList));
-			array_push($t, array ("s", "s", "s"));;
-			array_push($sql, "INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT $1, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url FROM gui_element WHERE fkey_gui_id = $2;");
-			array_push($v, array($newGuiName, $guiList));
-			array_push($t, array("s", "s"));
-			array_push($sql, "INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT $1, fkey_e_id, var_name, var_value, context, var_type FROM gui_element_vars WHERE fkey_gui_id = $2;");
-			array_push($sql, "INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) SELECT $1, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype FROM gui_layer WHERE fkey_gui_id = $2;");
-			if ($withUsers == true) {
-				/* group of original gui is copied as well */
-				array_push($sql, "INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) SELECT $1, fkey_mb_group_id, mb_group_type FROM gui_mb_group WHERE fkey_gui_id = $2;");
-				/* users of original gui are copied as well */
-				array_push($sql, "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) SELECT $1, fkey_mb_user_id, mb_user_type FROM gui_mb_user WHERE fkey_gui_id = $2;");
-			else {
-				// users of original gui are not copied, the current user is set as owner
-				array_push($sql, "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ($1, $2, 'owner')");
-				array_push($v, array($newGuiName, $_SESSION["mb_user_id"]));
-				array_push($t, array('s', 'i'));
-			array_push($sql, "INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) SELECT $1, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id FROM gui_treegde WHERE fkey_gui_id = $2;");
-			array_push($sql, "INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) SELECT $1, fkey_wfs_id FROM gui_wfs WHERE fkey_gui_id = $2;");
-			array_push($sql, "INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) SELECT $1, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible FROM gui_wms WHERE fkey_gui_id = $2;");
-				if (!$res) {
-					return false;
-			return true;
-		else {
-	      echo "<script language='javascript'>";
-	      echo "alert('This gui name " . $newGuiName . " is taken!');";
-	      echo "</script>";
-	      return false;
-	private function elementsToHtml () {
-		$bodyStringArray = array();
-		$elementString = "";
-			if ($currentElement->id != "body") {
-				$elementString .= $currentElement->toHtml();
-			else {
-				$bodyStringArray = $currentElement->toHtmlArray();
-		$elementString .= "<form id='sendData' name='sendData' action='' " .
-						  "method='POST' target='loadData' " .
-						  "style='position:absolute;left:800px'>" .
-						  "<input type='hidden' name='data'></form>";
-		if (count($bodyStringArray) == 3) {
-			$elementString = $bodyStringArray[0] .
-				$bodyStringArray[1] .
-				$elementString .
-				$bodyStringArray[2];
-		return $elementString;
+include_once(dirname(__FILE__)."/../../lib/application.php");
Modified: branches/testbaudson_dev/http/frames/index.php
--- branches/testbaudson_dev/http/frames/index.php	2008-07-17 12:29:29 UTC (rev 2673)
+++ branches/testbaudson_dev/http/frames/index.php	2008-07-18 10:26:21 UTC (rev 2674)
@@ -18,9 +18,8 @@
-require("../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_locale.php");
-require_once(dirname(__FILE__)."/../classes/class_gui.php");
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../../lib/mapbender.php");
 $_SESSION["mb_user_gui"] = $gui_id;
@@ -29,54 +28,10 @@
 // if not, return to login screen
 if (!in_array($gui_id, $_SESSION["mb_user_guis"])) {
-	$e = new mb_exception("mb_validateSession.php: User: " . $_SESSION["mb_user_id"] . " not allowed to access GUI " . $gui_id);
+	$e = new mb_exception("index.php: User is not allowed to access application. User ID: " . $_SESSION["mb_user_id"] . ", Application: " . $gui_id);
 	header("Location: ".LOGIN);
 	die();
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-Licensing: See the GNU General Public License for more details.
-http://www.gnu.org/copyleft/gpl.html
-or:
-mapbender/licence/
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
-<title><?php echo  $gui_id;?> - presented by Mapbender</title>
-<?php
-$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = 'body' AND fkey_gui_id = $1 and var_type='file/css'";
-$v = array($gui_id);
-$t = array('s');
-$res = db_prep_query($sql,$v,$t);
-$cnt = 0;
-while($row = db_fetch_array($res)){
-	echo "<link rel=\"stylesheet\" type=\"text/css\" href=\"".$row["var_value"]."\">\n";
-<style type="text/css">
-<?php
-$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = 'body' AND fkey_gui_id = $1 and var_type='text/css'";
-$t = array('s');
-$cnt = 0;
-	echo $row["var_value"];
-</style>
-<script type='text/javascript' src='../javascripts/core.php'></script>
-</head>
-<?php
-$currentApplication = new gui($gui_id);
-echo $currentApplication->toHtml();
-echo "<script type='text/javascript' src='../javascripts/map.php?".$urlParameters."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
-</html>
+$mapbender = new Mapbender($_SESSION, $_GET, $_POST);
+echo $mapbender->toHtml();
Modified: branches/testbaudson_dev/http/javascripts/geometry.js
--- branches/testbaudson_dev/http/javascripts/geometry.js	2008-07-17 12:29:29 UTC (rev 2673)
+++ branches/testbaudson_dev/http/javascripts/geometry.js	2008-07-18 10:26:21 UTC (rev 2674)
@@ -1486,7 +1486,7 @@
 		mG = new MultiGeometry(geomType.point);
 		mG.addGeometry();
 		mG.get(-1).addPoint(center);
-		highlight.add(mG);
+		highlight.add(mG,snappingColor);
 		highlight.paint();
 	this.getTolerance = function() {
@@ -1549,6 +1549,11 @@
 	 * @private
+	var snappingColor = aColor;
+	 * @private
 	var lineWidth = 2;
Modified: branches/testbaudson_dev/http/javascripts/mod_box1.js
--- branches/testbaudson_dev/http/javascripts/mod_box1.js	2008-07-17 12:29:29 UTC (rev 2673)
+++ branches/testbaudson_dev/http/javascripts/mod_box1.js	2008-07-18 10:26:21 UTC (rev 2674)
@@ -17,13 +17,13 @@
 	mb_isActive = true;
 	mb_getMousePos(e,mb_isBF);
 	mb_start_x = clickX;
-	mb_start_y = clickY
+	mb_start_y = clickY;
 	mb_end_x = mb_start_x+1;
 	mb_end_y = mb_start_y+1;
 	mb_offset_left = mb_start_x;
 	mb_offset_top = mb_start_y;
 	mb_offset_bottom = mb_start_y;
-	mb_offset_right = mb_start_x
+	mb_offset_right = mb_start_x;
 	mb_drawBox(mb_start_x,mb_start_y,mb_end_x,mb_end_y);
 	return false;
@@ -121,7 +121,7 @@
 		var maxy = y2;
    // area or clickpoint ?
-	var ret = new Array();
+	var ret = [];
 	if((maxx - minx) > 3 && (miny - maxy) > 3){
 		var posMin = makeClickPos2RealWorldPos(mb_isBF,minx,miny);
 		var posMax = makeClickPos2RealWorldPos(mb_isBF,maxx,maxy);
@@ -139,4 +139,4 @@
 		return ret;
 		//zoom(mb_zF,true,1.0,pos[0], pos[1]);
Modified: branches/testbaudson_dev/http/javascripts/mod_savewmc.php
--- branches/testbaudson_dev/http/javascripts/mod_savewmc.php	2008-07-17 12:29:29 UTC (rev 2673)
+++ branches/testbaudson_dev/http/javascripts/mod_savewmc.php	2008-07-18 10:26:21 UTC (rev 2674)
@@ -22,9 +22,12 @@
 echo "mod_savewmc_target = '".$e_target[0]."';";
 function setOnUnload() {
 	if (ie) {
-		document.getElementsByTagName('body')[0].onunload = function() {var x = new Function ("", "mod_savewmc_session()"); x(); };
+		document.getElementsByTagName('body')[0].onunload = function() {
+			var x = new Function ("", "mod_savewmc_session()"); x();
 	else {
 		document.getElementsByTagName('body')[0].setAttribute("onUnload", "mod_savewmc_session();");
@@ -65,4 +68,4 @@
 		$.ajaxSetup({async:false}); //TODO: find out why async doesn't work onunload
 	$.post("../php/mod_savewmc_server.php", {"saveInSession":storeInSession, "generalTitle":generalTitle, "extensionData":extensionDataString, "mapObject":$.toJSON(mb_mapObj)}, callbackFunction);
Modified: branches/testbaudson_dev/http/javascripts/mod_wfs_gazetteer_client.php
--- branches/testbaudson_dev/http/javascripts/mod_wfs_gazetteer_client.php	2008-07-17 12:29:29 UTC (rev 2673)
+++ branches/testbaudson_dev/http/javascripts/mod_wfs_gazetteer_client.php	2008-07-18 10:26:21 UTC (rev 2674)
@@ -18,12 +18,18 @@
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+session_start();
+$gui_id = $_SESSION["mb_user_gui"];
-$gui_id = $_SESSION["mb_user_gui"];
 $target = $_REQUEST["e_target"];
+$e_id_css = $_REQUEST["e_id_css"];
+$e_id = $_REQUEST["e_id"];
 $isLoaded = $_REQUEST["isLoaded"];
+require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db($DB,$con);
 <html>
@@ -38,7 +44,8 @@
 <?php
 	include '../include/dyn_js.php';
 	include '../include/dyn_php.php';
+	include(dirname(__FILE__) . "/../../conf/" . $wfs_spatial_request_conf_filename);
 	echo "var targetString = '" . $target . "';";
 	echo "var wfsConfIdString = '" . $wfsConfIdString . "';";
 	echo "var e_id_css = '" . $e_id_css . "';";
@@ -58,21 +65,235 @@
 	maxHighlightedPoints = 0;
 //	var e = new parent.Mb_warning("mod_wfs_gazetteer_client.php: Element var maxHighlightedPoints is not set, see 'edit element vars'.");
+// Element var showResultInPopup
+try {if(showResultInPopup){}}catch(e) {showResultInPopup = 1;}
+//element var openLinkFromSearch for opening attribute link directly onclick of searchResult entry
+try{
+	if (openLinkFromSearch){}
+catch(e){
+	openLinkFromSearch =0;
 var targetArray = targetString.split(",");
 var global_wfsConfObj;
 var global_selectedWfsConfId;
 var point_px = 10;
 var resultGeom = null;
 var cw_fillcolor = "#cc33cc";
+var frameName = e_id_css;
+var inputNotEnough = [];
+//start button management spatialRequest ////////
+var button_point = "point";
+var button_polygon = "polygon";
+var button_rectangle = "rectangle";
+var button_extent = "extent";
+var mb_wfs_tolerance = 8;
+var activeButton = null;
+var mod_wfs_spatialRequest_geometry = null;
+var mod_wfs_spatialRequest_frameName = "";
+var mod_wfs_spatialRequest_epsg;
+var mod_wfs_spatialRequest_width;
+var mod_wfs_spatialRequest_height;
+ * This Geometry contains the geometry of the optinal spatial constraint
+var spatialRequestGeom = null;
+ * Something like box, polygon, point, extent
+var spatialRequestType = null;
+ * This Geometry contains the result from the WFS request
+var geomArray;
+var buttonWfs_id = [];
+var buttonWfs_on = [];
+var buttonWfs_src = [];
+var buttonWfs_title_off = [];
+var buttonWfs_title_on = [];
+var buttonWfs_x = [];
+var buttonWfs_y = [];
+function addButtonWfs(id, isOn, src, title, x, y) {
+	buttonWfs_id.push(id);
+	buttonWfs_on.push(isOn);
+	buttonWfs_src.push(src);
+	buttonWfs_title_off.push(title);
+	buttonWfs_title_on.push(title);
+	buttonWfs_x.push(x);
+	buttonWfs_y.push(y);
+// end of button management spatialRequest ///////////
 parent.mb_registerInitFunctions("window.frames['"+this.name+"'].initModWfsGazetteer()");
+parent.mb_registerInitFunctions("window.frames['"+this.name+"'].init_wfsSpatialRequest()");
-function openwindow(Adresse) {
-	Fenster1 = window.open(Adresse, "Informationen", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
-	Fenster1.focus();
+function init_wfsSpatialRequest() {
+	//parent.mb_ajax_json("../php/mod_wfsSpatialRequest_messages.php", function(obj, status) {
+	//	msgObj = obj;
+		buttonWfs_id = [];
+		buttonWfs_on = [];
+		buttonWfs_src = [];
+		buttonWfs_title_off = [];
+		buttonWfs_title_on = [];
+		buttonWfs_x = [];
+		buttonWfs_y = [];
+		addButtonWfs("rectangle", buttonRectangle.status, buttonRectangle.img, buttonRectangle.title, buttonRectangle.x, buttonRectangle.y);
+		addButtonWfs("polygon", buttonPolygon.status, buttonPolygon.img, buttonPolygon.title, buttonPolygon.x, buttonPolygon.y);
+		addButtonWfs("point", buttonPoint.status, buttonPoint.img, buttonPoint.title, buttonPoint.x, buttonPoint.y);
+		addButtonWfs("extent", buttonExtent.status, buttonExtent.img, buttonExtent.title, buttonExtent.x, buttonExtent.y);
+		displayButtons();
+function wfsInitFunction (j) {
+	var functionCall = "parent.mb_regButton_frame('initWfsButton', '"+frameName+"', "+j+")";
+	var x = new Function ("", functionCall);
+	x();
+function initWfsButton(ind, pos) {
+	parent.mb_button[ind] = document.getElementById(buttonWfs_id[pos]);
+	parent.mb_button[ind].img_over = buttonWfs_imgdir + buttonWfs_src[pos].replace(/_off/,"_over");
+	parent.mb_button[ind].img_on = buttonWfs_imgdir + buttonWfs_src[pos].replace(/_off/,"_on");
+	parent.mb_button[ind].img_off = buttonWfs_imgdir + buttonWfs_src[pos];
+	parent.mb_button[ind].img_out = buttonWfs_imgdir + buttonWfs_src[pos];
+	parent.mb_button[ind].status = 0;
+	parent.mb_button[ind].elName = buttonWfs_id[pos];
+	parent.mb_button[ind].frameName = frameName;
+	parent.mb_button[ind].go = new Function ("requestGeometryHighlight.clean(); wfsEnable(parent.mb_button["+ind+"], " + pos + ")");
+	parent.mb_button[ind].stop = new Function ("wfsDisable(parent.mb_button["+ind+"], " + pos + ")");
+	var ind = parent.getMapObjIndexByName("mapframe1");
+	mod_wfs_spatialRequest_width = parent.mb_mapObj[ind].width;
+	mod_wfs_spatialRequest_height = parent.mb_mapObj[ind].height;
+	mod_wfs_spatialRequest_epsg = parent.mb_mapObj[ind].epsg;
+	parent.mb_registerPanSubElement("measuring");
+function displayButtons() {
+	for (var i = 0 ; i < buttonWfs_id.length ; i ++) {
+		if (parseInt(buttonWfs_on[i])==1) {
+			var currentImg = document.createElement("img");
+			currentImg.id = buttonWfs_id[i];
+			currentImg.name = buttonWfs_id[i];
+			currentImg.title = buttonWfs_title_off[i];
+			currentImg.src = buttonWfs_imgdir+buttonWfs_src[i];
+			currentImg.style.marginRight = "5px";
+			currentImg.onmouseover = new Function("wfsInitFunction("+i+")");
+			document.getElementById("displaySpatialButtons").appendChild(currentImg);
+function disableButtons() {
+	removeChildNodes(document.getElementById("displaySpatialButtons"));
+function wfsEnable(obj) {
+   	var el = parent.window.frames["mapframe1"].document;
+   	el.onmouseover = null;
+   	el.onmousedown = null;
+   	el.onmouseup = null;
+   	el.onmousemove = null;
+	if (obj.id == button_point) {
+		if (activeButton == null) {
+			activeButton = obj;
+	if (obj.id == button_polygon) {
+	else if (obj.id == button_rectangle){
+	else if (obj.id == button_extent){
+	callRequestGeometryConstructor(obj.id,"mapframe1");
+function callRequestGeometryConstructor(selectedType,target){
+		if(document.getElementById("res")){
+			document.getElementById("res").innerHTML ="";
+			spatialRequestGeom = null;
+		if(document.getElementById("spatialResHint")){
+			document.getElementById("spatialResHint").innerHTML = "";
+		spatialRequestType = selectedType;
+		var geometryConstructor = new parent.RequestGeometryConstructor(target);
+		geometryConstructor.getGeometry(selectedType,function(target,queryGeom){
+			if(queryGeom !=''){
+				var spatialRes = document.createElement("span");
+				spatialRes.id = "spatialResHint";
+				spatialRes.name = "spatialResHint";
+				document.getElementById("displaySpatialButtons").appendChild(spatialRes);
+				document.getElementById("spatialResHint").innerHTML = spatialRequestIsSetMessage;
+				spatialRequestGeom = queryGeom;
+			parent.mb_disableThisButton(selectedType);
+			// spatialRequestGeom is a Geometry, but for the highlight
+			// a MultiGeometry is needed.
+			var multiGeom;
+			// a line represents a bbox...but highlight must be a polyon
+			// (extent or box selection)
+			if (spatialRequestGeom.geomType == parent.geomType.line) {
+				multiGeom = new parent.MultiGeometry(parent.geomType.polygon);
+				newGeom = new parent.Geometry(parent.geomType.polygon);
+				var p1 = spatialRequestGeom.get(0);
+				var p2 = spatialRequestGeom.get(1);
+				newGeom.addPoint(p1);
+				newGeom.addPointByCoordinates(p1.x, p2.y);
+				newGeom.addPoint(p2);
+				newGeom.addPointByCoordinates(p2.x, p1.y);
+				newGeom.close();
+				multiGeom.add(newGeom);
+			// standard case
+			// (polygon and point selection)
+			else {
+				multiGeom = new parent.MultiGeometry(spatialRequestGeom.geomType);
+				multiGeom.add(spatialRequestGeom);
+			// add highlight of geometry
+			requestGeometryHighlight.add(multiGeom);
+			requestGeometryHighlight.paint();
+function wfsDisable(obj) {
+	el.ondblclick = null;
+	parent.writeTag("mapframe1","measure_display","");
+	parent.writeTag("mapframe1","measure_sub","");
+	activeButton = null;
+function openwindow(url) {
+	window1 = window.open(url, "Information", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
+	window1.focus();
 function appendWfsConf(newWfsConfIdString) {
@@ -146,7 +367,9 @@
 	document.getElementById("wfsGeomType").style.visibility = "hidden";
 	document.getElementById("wfsRemove").style.visibility = "hidden";
+	geomArray = new parent.GeometryArray();
 	parent.mb_ajax_json("../php/mod_wfs_gazetteer_server.php", {command:"getWfsConf",wfsConfIdString:wfsConfIdString}, function(json, status) {
 		global_wfsConfObj = json;
 		var wfsCount = 0;
@@ -170,6 +393,12 @@
 		parent.mb_setWmcExtensionData({"wfsConfIdString":wfsConfIdString});
+	// creates a Highlight object for the request geometry
+	var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":100};
+	requestGeometryHighlight = new parent.Highlight(targetArray, "requestGeometryHighlight", styleProperties, 2);
+	parent.mb_registerSubFunctions("window.frames['" + frameName +"'].requestGeometryHighlight.paint()");
 function setWfsInfo() {
@@ -207,7 +436,7 @@
 		wfsGeomTypeNode.style.visibility = 'visible';
 	else {
-		var e = new parent.Mb_exception("WFS gazetteer: geometry type unknown.");
+		var e = new parent.Mb_exception("WFS gazetteer: geometry type unknown.");
 	// set image: remove this WFS
@@ -230,7 +459,7 @@
 			initModWfsGazetteer();
 function setWfsConfIdString() {
@@ -248,14 +477,27 @@
 	var selectNode = document.createElement("select");
 	selectNode.name = "wfs_conf_sel";
 	var wfsFormNode = document.getElementById("selectWfsConfForm");
-	selectNode.onchange = function() {
+	if (parent.ie) {
+		selectNode.onchange = function() {
 		global_selectedWfsConfId = this.value;
-		setWfsInfo();
+     	if(typeof(resultGeometryPopup)!="undefined"){
+	 		resultGeometryPopup.destroy();
+	 	if(typeof(wfsPopup)!="undefined"){
+	 		wfsPopup.destroy();
+    	setWfsInfo();
 		appendStyles();
 		appendWfsForm();
+	else{
+	   selectNode.setAttribute("onchange", "if(typeof(resultGeometryPopup)!='undefined'){resultGeometryPopup.destroy();}if(typeof(wfsPopup)!='undefined'){wfsPopup.destroy();};global_selectedWfsConfId = this.value;setWfsInfo();appendStyles();appendWfsForm();");
 	var isSelected = false;
 	for (var wfsConfId in global_wfsConfObj) {
 		var optionNode = document.createElement("option");
 		optionNode.value = wfsConfId;
@@ -294,150 +536,712 @@
 	for (var i = 0; i < wfsConfElementArray.length; i++){
 		if (parseInt(wfsConfElementArray[i].f_search)) {
 			var spanNode = document.createElement("span");
-			spanNode.setAttribute("id", "ttttt");
+			spanNode.setAttribute("id", wfsConfElementArray[i].element_name+"Span");
 			spanNode.className = wfsConfElementArray[i].f_label_id;
 			spanNode.innerHTML = wfsConfElementArray[i].f_label;
-			var inputNode = document.createElement("input");
-			inputNode.type = "text";
-			inputNode.className = wfsConfElementArray[i].f_style_id;
-			inputNode.id = wfsConfElementArray[i].element_name;
+			if(wfsConfElementArray[i].f_form_element_html.match(/\<select/)){
+				var inputNode = document.createElement("span");
+				inputNode.id = wfsConfElementArray[i].element_name+"Select";
+				inputNode.innerHTML = wfsConfElementArray[i].f_form_element_html;
+			else if(wfsConfElementArray[i].f_form_element_html.match(/checkbox/)){
+				inputNode.id = wfsConfElementArray[i].element_name+"Checkbox";
+			else{
+				var inputNode = document.createElement("input");
+				inputNode.type = "text";
+				inputNode.className = wfsConfElementArray[i].f_style_id;
+				inputNode.id = wfsConfElementArray[i].element_name;
+				if(wfsConfElementArray[i].f_form_element_html.match(/datepicker/)){
+					inputNode.readOnly=true;
+					inputNode.style.backgroundColor = "#D3D3D3";
+					inputNode.title = "Use datepicker for selection of date";
 			form.appendChild(spanNode);
 			form.appendChild(inputNode);
+			//build imgNode for datepicker image
+				var imgNode = document.createElement("span");
+				imgNode.id = wfsConfElementArray[i].element_name+"Img";
+				imgNode.title = "Click here to open datepicker";
+				imgNode.innerHTML = wfsConfElementArray[i].f_form_element_html;
+				form.appendChild(imgNode);
 			form.appendChild(document.createElement("br"));
 	var submitButton = document.createElement("input");
 	submitButton.type = "submit";
+	submitButton.id = "submitButton";
 	submitButton.className = global_wfsConfObj[global_selectedWfsConfId].g_button_id;
 	submitButton.value = global_wfsConfObj[global_selectedWfsConfId].g_button;
 	form.appendChild(submitButton);
+	var delFilterButton = document.createElement("input");
+	delFilterButton.type = "button";
+	delFilterButton.style.marginLeft = "5px";
+	delFilterButton.className = global_wfsConfObj[global_selectedWfsConfId].g_button_id;
+	delFilterButton.value = clearFilterButtonLabel;
+	// Internet explorer
+	if (parent.ie) {$_REQUEST['pdfPathString']
+		delFilterButton.onclick = function() {
+			var x = new Function ("", "clearFilter();");
+			x();
+	// Firefox
+	else {
+		delFilterButton.onclick = function () {
+			clearFilter();
+	form.appendChild(delFilterButton);
+	checkSrs();
+function checkSrs(){
+	//check SRS
+	var submit = document.getElementById("submitButton");
+	if(global_wfsConfObj[global_selectedWfsConfId].featuretype_srs.toUpperCase()!=parent.mb_mapObj[ind].getSRS().toUpperCase()){
+		var msg = "Different EPSG of map and wfs featuretype, no spatial request possible!\n";
+		msg += parent.mb_mapObj[ind].getSRS()+" und "+global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
+		alert(msg);
+		//disable Submit Button
+		if(submit)submit.disabled = true;
+	else{
+		if(submit)submit.disabled = false;
+function clearFilter(){
+	var wfsConfElementArray = global_wfsConfObj[global_selectedWfsConfId].element;
+	for (var i = 0; i < wfsConfElementArray.length; i++){
+		if (parseInt(wfsConfElementArray[i].f_search)) {
+			if(wfsConfElementArray[i].f_form_element_html.match(/checkbox/)){
+				var elementArray = document.getElementsByName(wfsConfElementArray[i].element_name);
+				for (var j = 0; j < elementArray.length; j++){
+					elementArray[j].checked = "";
+				document.getElementById('checkAll').checked = "";
+			else{
+				document.getElementById(wfsConfElementArray[i].element_name).value = "";
+	//remove geometry from spatialrequest, remove drawn rectangle or polygon and hint
+	requestGeometryHighlight.clean();
+	if(document.getElementById('spatialResHint')){
+	//remove result popup
+ 	//remove detail popup
+ 	document.getElementById("res").innerHTML = "";
+function getNumberOfFilterParameters(){
+	var cnt = 0;
+	var el = global_wfsConfObj[global_selectedWfsConfId].element;
+	inputNotEnough = [];
+	for (var i = 0; i < el.length; i++){
+		if( el[i]['f_search'] == 1){
+			if(el[i]['f_form_element_html'].match(/\<select/)){
+				var elementValue = document.getElementById(el[i]['element_name']).options[document.getElementById(el[i]['element_name']).selectedIndex].value;
+    		else if(el[i]['f_form_element_html'].match(/checkbox/)){
+				var elementArray = document.getElementsByName(el[i]['element_name']);
+				var selectedVal = [];
+					if (elementArray[j].checked == true){
+						selectedVal.push(elementArray[j].value);
+				var elementValue = selectedVal.join(",");
+			else{
+				var elementValue = document.getElementById(el[i]['element_name']).value;
+			if (elementValue != '') {
+				cnt++;
+			if(elementValue.length < el[i]['f_min_input']){
+				inputNotEnough.push(el[i]['element_name']+"("+el[i]['f_min_input']+")");
+	if(inputNotEnough.length>0){
+		alert("Mandatory fields: "+inputNotEnough.join(', '));
+		return false;
+//	if(spatialRequestGeom == null){
+//		alert("Bitte räumliche Eingrenzung vornehmen.");
+//		return false;
+	return cnt;
 function validate(){
+	if(geomArray.count()>0){
+ 		geomArray.empty();
 	global_resultHighlight = new parent.Highlight(targetArray, "wfs_gazetteer_highlight", {"position":"absolute", "top":"0px", "left":"0px", "z-index":100}, 2);
 	var filterParameterCount = getNumberOfFilterParameters();
-	if(filterParameterCount == 0){
+	if(filterParameterCount == 0 && spatialRequestGeom == null){
+	//if(filterParameterCount == 0){
+		//alert("Please specify at least one filter attribute.");
 		return false;
 	else{
-		var andConditions = "";
+		if(inputNotEnough.length==0){
+			var andConditions = "";
+			var srs = global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
-		var el = global_wfsConfObj[global_selectedWfsConfId].element;
-		for (var i = 0; i < el.length; i++) {
-			if (el[i]['f_search'] == 1 && document.getElementById(el[i]['element_name']).value != '') {
-				var a = new Array();
-				a = document.getElementById(el[i]['element_name']).value.split(",");
-				var orConditions = "";
-				for (var j=0; j < a.length; j++) {
-					orConditions += "<ogc:PropertyIsLike wildCard='*' singleChar='.' escape='!'>";
-					orConditions += "<ogc:PropertyName>" + el[i]['element_name'] + "</ogc:PropertyName>";
-					orConditions += "<ogc:Literal>*";
-					if(el[i]['f_toupper'] == 1){
-						orConditions += a[j].toUpperCase();
+			for (var i = 0; i < el.length; i++) {
+				if (el[i]['f_search'] == 1){
 					else{
-						orConditions += a[j];
-					orConditions += "*</ogc:Literal>";
-					orConditions += "</ogc:PropertyIsLike>";
-				if(a.length > 1){
-					andConditions += "<Or>" + orConditions + "</Or>";
+				if (el[i]['f_search'] == 1 && elementValue != '') {
+					var a = new Array();
+					a = elementValue.split(",");
+					var orConditions = "";
+					for (var j=0; j < a.length; j++) {
+						if(el[i]['f_operator']=='bothside'){
+							orConditions += "<ogc:PropertyIsLike wildCard='*' singleChar='.' escape='!'>";
+							orConditions += "<ogc:PropertyName>" + el[i]['element_name'] + "</ogc:PropertyName>";
+							orConditions += "<ogc:Literal>*";
+							if(el[i]['f_toupper'] == 1){
+								orConditions += a[j].toUpperCase();
+							else{
+								orConditions += a[j];
+							orConditions += "*</ogc:Literal>";
+							orConditions += "</ogc:PropertyIsLike>";
+						else if(el[i]['f_operator']=='rightside'){
+							orConditions += "<ogc:Literal>";
+							else{
+						else if(el[i]['f_operator']=='greater_than'){
+							orConditions += "<ogc:PropertyIsGreaterThan>";
+							else{
+							orConditions += "</ogc:Literal>";
+							orConditions += "</ogc:PropertyIsGreaterThan>";
+						else if(el[i]['f_operator']=='less_than'){
+							orConditions += "<ogc:PropertyIsLessThan>";
+							else{
+							orConditions += "</ogc:PropertyIsLessThan>";
+						else if(el[i]['f_operator']=='less_equal_than'){
+							orConditions += "<ogc:PropertyIsLessThanOrEqualTo>";
+							else{
+							orConditions += "</ogc:PropertyIsLessThanOrEqualTo>";
+						else if(el[i]['f_operator']=='greater_equal_than'){
+							orConditions += "<ogc:PropertyIsGreaterThanOrEqualTo>";
+							else{
+							orConditions += "</ogc:PropertyIsGreaterThanOrEqualTo>";
+						else if(el[i]['f_operator']=='equal'){
+							orConditions += "<ogc:PropertyIsEqualTo>";
+							else{
+							orConditions += "</ogc:PropertyIsEqualTo>";
+						else{
+							else{
+					if(a.length > 1){
+						andConditions += "<Or>" + orConditions + "</Or>";
+					else {
+						andConditions += orConditions;
-				else {
-					andConditions += orConditions;
-		var u = global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature + parent.mb_getConjunctionCharacter(global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature);
-		u += "REQUEST=getFeature&Typename="+global_wfsConfObj[global_selectedWfsConfId].featuretype_name+"&Version=1.0.0&service=WFS";
-		u += "&filter=";
-		if (filterParameterCount > 1) {
-			andConditions = "<And>" + andConditions + "</And>";
-		var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>"+andConditions+"</ogc:Filter>";
-		document.getElementById("res").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Searching...</td></tr></table>";
-		var parameters = {command:"getSearchResults", "wfs_conf_id":global_selectedWfsConfId, "frame":this.name, "url":u, "filter":filter, "backlink":""};
-		parent.mb_ajax_get("../php/mod_wfs_gazetteer_server.php", parameters, function (jsCode, status) {
-			document.getElementById("res").innerHTML = "<table><tr><td>Arranging search results...</td></tr></table>";
-			eval(jsCode);
-			for (var i=0; i < parent.wms.length; i++) {
-				for (var j=0; j < parent.wms[i].objLayer.length; j++) {
-					var currentLayer = parent.wms[i].objLayer[j];
-					var wms_id = parent.wms[i].wms_id;
-					if (currentLayer.gui_layer_wfs_featuretype == global_selectedWfsConfId) {
-						var layer_name = currentLayer.layer_name;
-						parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'querylayer',1);
-						parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'visible',1);
+			if(spatialRequestGeom!=null){
+				if(spatialRequestGeom.geomType == "polygon"){
+					if(buttonPolygon.filteroption=='within'){
+						andConditions += "<Within><ogc:PropertyName>";
+						for (var j=0; j < el.length; j++) {
+							if(el[j]['f_geom']==1){
+								var elementName = el[j]['element_name'];
+								andConditions += el[j]['element_name'];
+						andConditions += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\">";
+						andConditions += "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+						for(var k=0; k<spatialRequestGeom.count(); k++){
+							if(k>0)	andConditions += " ";
+							andConditions += spatialRequestGeom.get(k).x+","+spatialRequestGeom.get(k).y;
+						andConditions += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>";
+						andConditions += "</gml:Polygon></Within>";
+					else if(buttonPolygon.filteroption=='intersects'){
+						andConditions += "<Intersects><ogc:PropertyName>";
+						andConditions += "</gml:Polygon></Intersects>";
+				else if(spatialRequestGeom.geomType == "line"){
+					var rectangle = [];
+					rectangle = spatialRequestGeom.getBBox();
+					if(buttonRectangle.filteroption=='within'){
+						andConditions += rectangle[0].x+","+rectangle[0].y;
+						andConditions += " ";
+						andConditions += rectangle[0].x+","+rectangle[1].y;
+						andConditions += rectangle[1].x+","+rectangle[1].y;
+						andConditions += rectangle[1].x+","+rectangle[0].y;
+					else if(buttonRectangle.filteroption=='intersects'){
+				else if(spatialRequestGeom.geomType == "point"){
+					var tmp = spatialRequestGeom.get(0);
+					var mapPos = parent.makeRealWorld2mapPos("mapframe1",tmp.x, tmp.y);
+					var buffer = mb_wfs_tolerance/2;
+					var mapPosXAddPix = mapPos[0] + buffer;
+					var mapPosYAddPix = mapPos[1] +buffer;
+					var mapPosXRemovePix = mapPos[0] - buffer;
+					var mapPosYRemovePix = mapPos[1] - buffer;
+					var realWorld1 = parent.makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYRemovePix);
+					var realWorld2 = parent.makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
+					var realWorld3 = parent.makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
+					var realWorld4 = parent.makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYAddPix);
+					andConditions += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+					andConditions += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] +  " ";
+					andConditions += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
+					andConditions += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects>";
+				//andConditions += "<ogc:Not><ogc:PropertyIsNull>";
+	            //andConditions += "<ogc:PropertyName>" + elementName + "</ogc:PropertyName>";
+	       		//andConditions += "</ogc:PropertyIsNull></ogc:Not>";
-			var body = "";
-			if (typeof(geom) == 'object') {
-				resultGeom = geom; // set the global variable
-				for (var i=0; i < geom.count(); i++) {
-					body += "<div id='geom"+i+"'style='cursor:pointer;' ";
-					if ((i % 2) === 0) {
-						body += "class='even'";
+			var u = global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature + parent.mb_getConjunctionCharacter(global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature);
+			u += "REQUEST=getFeature&Typename="+global_wfsConfObj[global_selectedWfsConfId].featuretype_name+"&Version=1.0.0&service=WFS";
+			u += "&filter=";
+			if (filterParameterCount > 1 || spatialRequestGeom != null) {
+				andConditions = "<And>" + andConditions + "</And>";
+			var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>"+andConditions+"</ogc:Filter>";
+			document.getElementById("res").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Searching...</td></tr></table>";
+			var parameters = {command:"getSearchResults", "wfs_conf_id":global_selectedWfsConfId, "frame":this.name, "url":u, "filter":filter, "backlink":""};
+			parent.mb_ajax_get("../php/mod_wfs_gazetteer_server.php", parameters, function (jsCode, status) {
+				document.getElementById("res").innerHTML = "<table><tr><td>Arranging search results...</td></tr></table>";
+				if(status=='success'){
+					for (var i=0; i < parent.wms.length; i++) {
+						for (var j=0; j < parent.wms[i].objLayer.length; j++) {
+							var currentLayer = parent.wms[i].objLayer[j];
+							var wms_id = parent.wms[i].wms_id;
+							if (currentLayer.gui_layer_wfs_featuretype == global_selectedWfsConfId) {
+								var layer_name = currentLayer.layer_name;
+								parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'querylayer',1);
+								parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'visible',1);
-					else {
-						body += "class='uneven'";
+					var geoObj = eval('(' + jsCode + ')');
+		       		if (jsCode) {
+			        	if (typeof(geoObj) == 'object') {
+			        		geomArray.importGeoJSON(geoObj);
+			        		document.getElementById("res").innerHTML = '';
+							displayResult(geomArray);
+						else {
+							displayResult();
-					body += " onmouseover=\"setResult('over', this.id)\" ";
-					body += " onmouseout=\"setResult('out', this.id)\" ";
-					body += " onclick=\"setResult('click', this.id)\">";
-					for (var j=0; j < geom.get(i).e.count(); j++) {
-						body += geom.get(i).e.getValue(j) + " ";
+		       		else {
+						alert("No results.");
-					body += "</div>";
+		else{
+			return false;
+	//spatialRequestGeom = null;
+	return false;
+function displayResult(geom){
+	geomArray = geom;
+	if(geomArray!=null && geomArray.count()>0){
+		var contentHtml = createListOfGeometries();
+	else{
+		var contentHtml = "No results.";
+	if(showResultInPopup==1){
+		if (typeof(resultGeometryPopup) == "undefined") {
+			resultGeometryPopup = new parent.mb_popup(searchPopupTitle,contentHtml,searchPopupWidth,searchPopupHeight,searchPopupX,searchPopupY);
+		else {
+		resultGeometryPopup.show();
+	else{
+		document.getElementById("res").innerHTML = contentHtml;
+function createListOfGeometries(){
+		var domPath = "window.frames['"+frameName+"'].";
+	else{
+		var domPath = "";
+	var listOfGeom = "<form name='resultListForm'><table style='background-color:#EEEEEE;'>\n";
+	var wfsConf = global_wfsConfObj[global_selectedWfsConfId];
+	var labelArray = [];
+	if (geomArray.count() > 0) {
+			listOfGeom += "<tr>";
+			var labelObj = getListTitle();
+			for (var k = 1 ; k < labelObj.length; k ++) {
+				listOfGeom += "<td>";
+				listOfGeom += labelObj[k];
+				listOfGeom += "</td>";
-			else {
-				body = "Kein Ergebnis.";
+			listOfGeom += "</tr>";
+		for (var i = 0 ; i < geomArray.count(); i ++) {
+			if (geomArray.get(i).get(-1).isComplete()) {
+				listOfGeom += "<tr>\n";
+				var resultElObj = getListValues(geomArray.get(i));
+				for (var l = 1 ; l < resultElObj.length; l ++) {
+					if(resultElObj[l]!=''){
+						listOfGeom += "<td style='cursor:pointer;\n";
+							if ((i % 2) === 0) {
+								listOfGeom += "color:blue'";
+							else {
+								listOfGeom += "color:red'";
+						else{
+								listOfGeom += "' class='even'";
+							else {
+								listOfGeom += "' class='uneven'";
+						listOfGeom += " onmouseover=\""+domPath+"setResult('over',"+i+")\" ";
+						listOfGeom += " onmouseout=\""+domPath+"setResult('out',"+i+")\" ";
+						listOfGeom += " onclick=\""+domPath+"setResult('click',"+i+"); "+domPath+"showWfs("+i+");\" ";
+						listOfGeom += ">"+ resultElObj[l] +"</td>";
+				listOfGeom += "\t</tr>\n";
-			document.getElementById('res').innerHTML = body;
-	return false;
+	listOfGeom += "</table></form>\n";
+	return listOfGeom;
-function getNumberOfFilterParameters(){
-	var cnt = 0;
+function getListTitle(){
+	for (var j = 0 ; j < wfsConf.element.length ; j++) {
+		if(wfsConf.element[j].f_show == 1 && wfsConf.element[j].f_label!=''){
+			var labelPos = wfsConf.element[j].f_respos;
+			labelArray[labelPos] = wfsConf.element[j].f_label;
+	return labelArray;
+function getListValues(geom){
+	var resultArray = [];
+	for (var i = 0 ; i < wfsConf.element.length ; i++) {
+		if (wfsConf.element[i].f_show == 1 && geom.e.getElementValueByName(wfsConf.element[i].element_name) !=false) {
+			var pos = wfsConf.element[i].f_respos;
+			if(pos>0){
+				resultArray[pos] = geom.e.getElementValueByName(wfsConf.element[i].element_name);
+	return resultArray;
-	for (var i = 0; i < el.length; i++){
-		if( el[i]['f_search'] == 1){
-			if (document.getElementById(el[i]['element_name']).value != '') {
-				cnt++;
+function showWfs(geometryIndex) {
+	var wfsElement = geomArray.get(geometryIndex).e;
+	var showDetailsObj = [];
+	var details = 0;
+	for (var i = 0 ; i <wfsConf.element.length; i ++) {
+		if(wfsConf.element[i].f_show_detail == 1 && wfsElement.getElementValueByName(wfsConf.element[i].element_name)!=''){
+			var elPos = wfsConf.element[i].f_detailpos;
+			if(elPos>0){
+				var currentObj = {};
+//				showDetailsObj[elPos] = {};
+				currentObj.elPos = elPos;
+				currentObj.data = {};
+				//var elementVal = wfsElement.getElementValueByName(wfsConf.element[i].element_name);
+				//showDetailsObj[elPos][wfsConf.element[i].f_label] = elementVal;
+				if(wfsConf.element[i].f_form_element_html.indexOf("href")!=-1){
+					var newPath = wfsElement.getElementValueByName(wfsConf.element[i].element_name).replace(/%computername%/,"Rechnername");
+					var setUrl = wfsConf.element[i].f_form_element_html.replace(/href\s*=\s*['|"]\s*['|"]/, "href='"+newPath+"' target='_blank'");
+					if(setUrl.match(/><\/a>/)){
+						var newLink	=	setUrl.replace(/><\/a>/, ">"+wfsElement.getElementValueByName(wfsConf.element[i].element_name)+"</a>");
+					else{
+						var newLink = setUrl;
+					if(openLinkFromSearch=='1'){
+						window.open(elementVal, elementVal,"width=500, height=400,left=100,top=100,scrollbars=yes");
+//					showDetailsObj[elPos][wfsConf.element[i].f_label] =  newLink;
+					currentObj.data[wfsConf.element[i].f_label] = newLink;
+				else{
+//					showDetailsObj[elPos][wfsConf.element[i].f_label] = wfsElement.getElementValueByName(wfsConf.element[i].element_name);
+					currentObj.data[wfsConf.element[i].f_label] = wfsElement.getElementValueByName(wfsConf.element[i].element_name);
+				showDetailsObj.push(currentObj);
+			details = 1;
+		else{
+			details = 0;
-	return cnt;
+	var resultHtml = "";
+	resultHtml += "<table style='background-color:#EEEEEE;'>\n";
+//	for (var elPos in showDetailsObj) {
+	showDetailsObj.sort(showDetailObjSort);
+	for (var i=0; i < showDetailsObj.length; i++) {
+//		var currentDetail = showDetailsObj[elPos];
+		var currentDetail = showDetailsObj[i].data;
+		for(var key in currentDetail){
+			var currentDetailName = key;
+			var currentDetailValue = currentDetail[key];
+			resultHtml +="<tr><td>\n";
+			resultHtml += currentDetailName;
+			resultHtml +="</td>\n";
+			resultHtml += "<td>\n";
+			resultHtml += currentDetailValue;
+			resultHtml += "</td></tr>\n";
+	if(details != 1){
+		resultHtml +="<tr><td>No detail information</td></tr>\n";
+	resultHtml += "</table>\n";
+		if (typeof(wfsPopup) == "undefined") {
+			wfsPopup = new parent.mb_popup(detailPopupTitle,resultHtml,detailPopupWidth,detailPopupHeight,detailPopupX,detailPopupY);
+		else {
+		wfsPopup.show();
+function showDetailObjSort (a, b) {
+	return (parseInt(a.elPos) - parseInt(b.elPos));
 * event -> {over || out || click}
 * geom -> commaseparated coordinates x1,y1,x2,y2 ...
-function setResult(event, id){
-	var index = parseInt(id.slice(4));
-	var currentGeom = resultGeom.get(index);
+function setResult(event, index){
+	var currentGeom = geomArray.get(index);
 	if (maxHighlightedPoints > 0 && currentGeom.getTotalPointCount() > maxHighlightedPoints) {
 		currentGeom = currentGeom.getBBox4();
@@ -463,14 +1267,23 @@
 	return true;
+function callPick(obj){
+	dTarget = obj;
+	var dp = window.open('../tools/datepicker/datepicker.php?m=Jan_Feb_Mar_Apr_May_June_July_Aug_Sept_Oct_Nov_Dec&d=Mon_Tue_Wed_Thu_Fri_Sat_Sun&t=today','dp','left=200,top=200,width=230,height=210,toolbar=0,location=0,directories=0,status=0,menubar=0,scrollbars=0');
+	dp.focus();
+	return false;
 </script>
 </head>
 <body leftmargin='0' topmargin='10'  bgcolor='#ffffff'>
 <form name='selectWfsConfForm' id='selectWfsConfForm'></form>
+<div name='displaySpatialButtons' id='displaySpatialButtons' style='width:180px'></div>
+<a name='wfsInfo' id='wfsInfo'></a>
+<img src = "" name='wfsRemove' id='wfsRemove'>
 <img src = "" name='wfsGeomType' id='wfsGeomType'>
-<img src = "" name='wfsRemove' id='wfsRemove'>
-<a name='wfsInfo' id='wfsInfo'></a>
 <form name='wfsForm' id='wfsForm' onsubmit='return validate()'></form>
 <div name='res' id='res' style='width:180px'></div>
 </body>
-</html>
+</html>
Modified: branches/testbaudson_dev/http/php/mb_validateSession.php
--- branches/testbaudson_dev/http/php/mb_validateSession.php	2008-07-17 12:29:29 UTC (rev 2673)
+++ branches/testbaudson_dev/http/php/mb_validateSession.php	2008-07-18 10:26:21 UTC (rev 2674)
@@ -19,7 +19,6 @@
 $e = new mb_notice("mb_validateSession.php: checking file " . $_SERVER["PHP_SELF"]);
Modified: branches/testbaudson_dev/http/php/mod_createUser.php
--- branches/testbaudson_dev/http/php/mod_createUser.php	2008-07-17 12:29:29 UTC (rev 2673)
+++ branches/testbaudson_dev/http/php/mod_createUser.php	2008-07-18 10:26:21 UTC (rev 2674)
@@ -121,7 +121,7 @@
 		$res_group = db_prep_query($sql_group,$v,$t);
 		// CB (begin)
 		// adding new GUIs for new user (copies of gui and gui1 with owner rights)
-		$gui = new gui();
+		$gui = new Application();
 		$admin = new administration();
 		//create new name for gui
 		$gui_id1 = $admin->getGuiIdByGuiName("gui");
Modified: branches/testbaudson_dev/http/php/mod_renameGUI.php
--- branches/testbaudson_dev/http/php/mod_renameGUI.php	2008-07-17 12:29:29 UTC (rev 2673)
+++ branches/testbaudson_dev/http/php/mod_renameGUI.php	2008-07-18 10:26:21 UTC (rev 2674)
@@ -154,7 +154,7 @@
 ###rename
 if($rename || $copy){
-	$gui = new gui();
 	if ($copy) {
 		if ($_POST['withU'] == 'true') $gui->copyGui($guiList, $newGuiName, true);
Added: branches/testbaudson_dev/lib/application.php
--- branches/testbaudson_dev/lib/application.php	                        (rev 0)
+++ branches/testbaudson_dev/lib/application.php	2008-07-18 10:26:21 UTC (rev 2674)
@@ -0,0 +1,322 @@
+<?php
+# $Id: class_gui.php 2541 2008-06-23 15:59:25Z christoph $
+# http://www.mapbender.org/index.php/class_gui.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../lib/element.php");
+ * GUI is a set of GUI elements and services.
+class Application {
+	var $id;
+	var $elementArray = array();
+	public function __construct ($id) {
+		if ($id) {
+			$this->id = $id;
+			$this->elementArray = $this->selectElements();
+	public function getTitle () {
+		return $this->id . " - " . _mb("presented by Mapbender");
+	public function getId () {
+		return $this->id;
+	public function selectElements () {
+		$sql = "SELECT e_id FROM gui_element WHERE fkey_gui_id = $1 " .
+				"ORDER BY e_pos";
+		$v = array($this->id);
+		$t = array('s');
+		$res = db_prep_query($sql,$v,$t);
+		$elementArray = array();
+		while ($row = db_fetch_array($res)) {
+			array_push($elementArray, $row[0]);
+		$this->elementArray = array();
+		for ($i = 0; $i < count($elementArray); $i++) {
+			$currentElement = new Element();
+			$currentElement->select($elementArray[$i], $this->id);
+			array_push($this->elementArray, $currentElement);
+		return $this->elementArray;
+	public function stylesToHtml () {
+		$htmlString = "";
+		$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = 'body' AND fkey_gui_id = $1 and var_type='file/css'";
+		$t = array('s');
+		while($row = db_fetch_array($res)){
+			$url = $row["var_value"];
+			if (file_exists($url)) {
+				$htmlString .= "<link rel='stylesheet' type='text/css' href='" . $url . "'>";
+			else {
+				$e = new mb_exception("stylesToHtml: file not found: " . $url);
+		$htmlString .= "<style type='text/css'><!--";
+		$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = 'body' AND fkey_gui_id = $1 and var_type='text/css'";
+		$t = array('s');
+			$htmlString .= $row["var_value"];
+		$htmlString .= "--></style>";
+		return $htmlString;
+	public function getJavaScriptModules () {
+		$jsArray = array();
+		for ($i = 0; $i < count($this->elementArray); $i++) {
+			$currentElement = $this->elementArray[$i];
+			array_merge($jsArray, $currentElement->getJavaScriptModules());
+		return $jsArray;
+ 	 * Checks if a GUI with a given ID exists in the database
+ 	 * @param integer $gui_id the ID of the GUI that is being checked
+ 	 * @return boolean true if a gui '$gui_id' exists; else false
+ 	public function guiExists ($gui_id){
+		$sql = "SELECT * FROM gui WHERE gui_id = $1";
+		$v = array($gui_id);
+		$t = array('s');
+		$row = db_fetch_array($res);
+		if ($row) {
+			return true;
+		return false;
+	 * Deletes a GUI $guiId and all its links to users, layers etc.
+	 * @param Integer $guiId the GUI that is going to be deleted
+	 * @return boolean true if the deletion succeded, else false
+	public function deleteGui ($guiId) {
+		$guiList = $guiId;
+		$sql = array();
+		$v = array();
+		$t = array();
+		array_push($sql, "BEGIN");
+		array_push($v, array());
+		array_push($t, array());
+		array_push($sql, "DELETE FROM gui WHERE gui_id = $1");
+		array_push($v, array($guiList));
+		array_push($t, array('s'));
+		array_push($sql, "DELETE FROM gui_element WHERE fkey_gui_id = $1");
+		array_push($sql, "DELETE FROM gui_element_vars WHERE fkey_gui_id = $1");
+		array_push($sql, "DELETE FROM gui_layer WHERE fkey_gui_id = $1");
+		array_push($sql, "DELETE FROM gui_mb_group WHERE fkey_gui_id = $1");
+		array_push($sql, "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1");
+		array_push($sql, "DELETE FROM gui_treegde WHERE fkey_gui_id = $1");
+		array_push($sql, "DELETE FROM gui_wfs WHERE fkey_gui_id = $1");
+		array_push($sql, "DELETE FROM gui_wms WHERE fkey_gui_id = $1");
+		array_push($sql, "COMMIT");
+		// execute all SQLs
+		for ($i = 0; $i < count($sql); $i++) {
+			$res = db_prep_query($sql[$i], $v[$i], $t[$i]);
+			// if an SQL fails, send a ROLLBACK and return false
+			if (!$res) {
+				db_query("ROLLBACK");
+				return false;
+		return true;
+	/** Renames the GUI $guiID to $newGUIName
+	 * @param Integer $guiId ID of the GUI
+	 * @param String $newGuiName the new name of the GUI
+	 * @return boolean true if the renaming succeded, else false
+	public function renameGui ($guiId, $newGuiName) {
+		if ($this->copyGui($guiId, $newGuiName, true)) {
+			$this->deleteGui($guiId);
+			return true;
+		return false;
+ 	 * Copies a GUI $guiId and all its links to users, layers etc. to GUI $newGuiName
+	 * @param boolean $withUsers true if the users, that may access the GUI $guiId, shall have access to the new GUI; else false.
+ 	public function copyGui ($guiId, $newGuiName, $withUsers) {
+		if (!$this->guiExists($newGuiName)) {
+			$sql = array();
+			$v = array();
+			$t = array();
+			array_push($sql, "INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) SELECT $1, $2, gui_description, gui_public FROM gui WHERE gui_id = $3;");
+			array_push($v, array ($newGuiName, $newGuiName, $guiList));
+			array_push($t, array ("s", "s", "s"));;
+			array_push($sql, "INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT $1, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url FROM gui_element WHERE fkey_gui_id = $2;");
+			array_push($v, array($newGuiName, $guiList));
+			array_push($t, array("s", "s"));
+			array_push($sql, "INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT $1, fkey_e_id, var_name, var_value, context, var_type FROM gui_element_vars WHERE fkey_gui_id = $2;");
+			array_push($sql, "INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) SELECT $1, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype FROM gui_layer WHERE fkey_gui_id = $2;");
+			if ($withUsers == true) {
+				/* group of original gui is copied as well */
+				array_push($sql, "INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) SELECT $1, fkey_mb_group_id, mb_group_type FROM gui_mb_group WHERE fkey_gui_id = $2;");
+				/* users of original gui are copied as well */
+				array_push($sql, "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) SELECT $1, fkey_mb_user_id, mb_user_type FROM gui_mb_user WHERE fkey_gui_id = $2;");
+			else {
+				// users of original gui are not copied, the current user is set as owner
+				array_push($sql, "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ($1, $2, 'owner')");
+				array_push($v, array($newGuiName, $_SESSION["mb_user_id"]));
+				array_push($t, array('s', 'i'));
+			array_push($sql, "INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) SELECT $1, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id FROM gui_treegde WHERE fkey_gui_id = $2;");
+			array_push($sql, "INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) SELECT $1, fkey_wfs_id FROM gui_wfs WHERE fkey_gui_id = $2;");
+			array_push($sql, "INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) SELECT $1, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible FROM gui_wms WHERE fkey_gui_id = $2;");
+				if (!$res) {
+					return false;
+			return true;
+		else {
+	      echo "<script language='javascript'>";
+	      echo "alert('This gui name " . $newGuiName . " is taken!');";
+	      echo "</script>";
+	      return false;
+	public function elementsToHtml () {
+		$bodyStringArray = array();
+		$elementString = "";
+			if ($currentElement->id != "body") {
+				$elementString .= $currentElement->toHtml();
+			else {
+				$bodyStringArray = $currentElement->toHtmlArray();
+		$elementString .= "<form id='sendData' name='sendData' action='' " .
+						  "method='POST' target='loadData' " .
+						  "style='position:absolute;left:800px'>" .
+						  "<input type='hidden' name='data'></form>";
+		if (count($bodyStringArray) == 3) {
+			$elementString = $bodyStringArray[0] .
+				$bodyStringArray[1] .
+				$elementString .
+				$bodyStringArray[2];
+		return $elementString;
Added: branches/testbaudson_dev/lib/element.php
--- branches/testbaudson_dev/lib/element.php	                        (rev 0)
+++ branches/testbaudson_dev/lib/element.php	2008-07-18 10:26:21 UTC (rev 2674)
@@ -0,0 +1,245 @@
+<?php
+# $Id: class_bbox.php 1965 2008-01-15 08:24:29Z christoph $
+define("ELEMENT_PATTERN", "/sessionID/");
+class Element {
+	var $guiId;
+	var $id;
+	var $pos;
+	var $isPublic;
+	var $comment;
+	var $title;
+	var $element;
+	var $src;
+	var $attributes;
+	var $left;
+	var $top;
+	var $width;
+	var $height;
+	var $zIndex;
+	var $moreStyles;
+	var $content;
+	var $closeTag;
+	var $jsFile;
+	var $mbMod;
+	var $target;
+	var $requires;
+	var $helpUrl;
+	public function __contruct() {
+	public function select ($id, $applicationId) {
+		$sql = "SELECT fkey_gui_id, e_id, e_pos, e_public, e_comment, e_public, ".
+				"gettext($1, e_title) as e_title, e_element, e_src, e_attributes, " .
+				"e_left, e_top, e_width, e_height, e_z_index, e_more_styles, " .
+				"e_content, e_closetag, e_js_file, e_mb_mod, e_target, " .
+				"e_requires, e_url FROM gui_element WHERE e_id = $2 AND " .
+				"fkey_gui_id = $3 LIMIT 1";
+		$v = array ($_SESSION["mb_lang"], $id, $applicationId);
+		$t = array ("s", "s", "s");
+		$res = db_prep_query($sql, $v, $t);
+		if ($row) {
+			$this->guiId = $applicationId;
+			$this->id = $row["e_id"];
+			$this->pos = $row["e_pos"];
+			$this->isPublic = $row["e_public"];
+			$this->comment = $row["e_comment"];
+			$this->title = $row["e_title"];
+			$this->element = $row["e_element"];
+			$this->src = $row["e_src"];
+			$this->attributes = $row["e_attributes"];
+			$this->left = $row["e_left"];
+			$this->top = $row["e_top"];
+			$this->width = $row["e_width"];
+			$this->height = $row["e_height"];
+			$this->zIndex = $row["e_z_index"];
+			$this->moreStyles = $row["e_more_styles"];
+			$this->content = $row["e_content"];
+			$this->closeTag = $row["e_closetag"];
+			$this->jsFile = $row["e_js_file"];
+			$this->mbMod = $row["e_mb_mod"];
+			$this->target = $row["e_target"];
+			$this->requires = $row["e_requires"];
+			$this->helpUrl = $row["e_url"];
+			return true;
+		return false;
+	public function __toString () {
+		return $this->toHtml();
+		if ($this->mbMod != "") {
+			$moduleArray = explode(",", $this->mbMod);
+			for ($i = 0; $i < count($moduleArray); $i++) {
+				$currentFile = dirname(__FILE__) . "/../javascripts/" . trim($moduleArray[$i]);
+				if (file_exists($currentFile)) {
+					array_push($jsArray, $currentFile);
+				else {
+					$e = new mb_exception("Javascript module not found: " . $currentFile);
+		return $jsArray;
+	public function toHtmlArray () {
+		if ($this->isPublic) {
+			return array($this->getHtmlOpenTag(), $this->getHtmlContent(), $this->getHtmlCloseTag());
+		return array("", "", "");
+	public function toHtml () {
+			return implode("", $this->toHtmlArray());
+		return "";
+	private function getHtmlOpenTag () {
+		$openTag = "";
+		if ($this->id) {
+			// tag name
+			$openTag .= "<" . $this->element . " ";
+			// id and name
+			$openTag .= "id='" . $this->id . "' name='" . $this->id . "' ";
+			// attributes
+			if ($this->attributes) {
+				$openTag .= stripslashes($this->replaceSessionStringByUrlParameters($this->attributes)) . " ";
+			// title
+			if ($this->title) {
+				$openTag .= "title='" . $this->title . "' ";
+			// alt for images
+			if ($this->element == "img") {
+				$openTag .= "alt='" . $this->title . "' ";
+			// src
+			if ($this->src) {
+   				$openTag .= "src = '" . $this->replaceSessionStringByUrlParameters($this->src);
+				// for iframes which are not "loadData",
+				// add additional parameters
+				if ($this->closeTag == "iframe" && $this->id != "loadData") {
+					if(mb_strpos($this->src, "?")) {
+						$openTag .= "&";
+					else {
+	      				$openTag .= "?";
+	      			$openTag .= "e_id_css=" . $this->id . "&" .
+	      					 "e_id= " . $this->id . "&" .
+	      					 "e_target=" . $this->target . "&" .
+	      					 $this->getUrlParameters();
+   				$openTag .= "' ";
+			// style
+			$openTag .= " style = '";
+			if ($this->top != "" && $this->left != "") {
+				$openTag .= "position:absolute;" .
+						 "left:" . $this->left . ";" .
+						 "top:" . $this->top . ";";
+			if ($this->width != "" && $this->height != "") {
+				$openTag .= "width:" . $this->width . ";" .
+						 "height:" . $this->height . ";";
+			if ($this->zIndex) {
+		    	$openTag .= "z-index:" . $this->zIndex . ";";
+			if ($this->moreStyles) {
+		    	$openTag .= $this->moreStyles;
+			$openTag .= "'>";
+			if ($this->element == "body" && USE_LOAD_MESSAGE) {
+				$htmlWhileLoading = "<img src='../img/indicator_wheel.gif'>&nbsp;" .
+					"<b>Ma<font color='#0000CE'>p</font><font color='#C00000'>b</font>ender " .
+					MB_VERSION_NUMBER . " " . strtolower(MB_VERSION_APPENDIX) . "</b>..." .
+					"loading application '" . $this->guiId . "'";
+				$openTag .= "<div id='loading_mapbender' " .
+								"style='position:absolute;top:100;left:100'>" .
+								$htmlWhileLoading . "</div>" .
+								"<div id='complete_mapbender' " .
+								"style='display:none'>";
+		return $openTag;
+	private function getHtmlContent () {
+		$htmlContent = "";
+		if ($this->content != "") {
+			$htmlContent .= stripslashes($this->content);
+		return $htmlContent;
+	private function getHtmlCloseTag () {
+			return "</div></body>";
+		if ($this->closeTag != "") {
+			return "</" . $this->closeTag . ">";
+		return "";
+	private function getUrlParameters () {
+		$urlParameters = SID;
+		if (isset($this->guiId)) {
+			$urlParameters .= "&guiID=" . $this->guiId;
+		if (isset($this->id)) {
+			$urlParameters .= "&elementID=" . $this->id;
+		return $urlParameters;
+	private function replaceSessionStringByUrlParameters ($string) {
+		$urlParameters = $this->getUrlParameters();
+		return preg_replace(ELEMENT_PATTERN, $urlParameters, $string);
\ No newline at end of file
Added: branches/testbaudson_dev/lib/mapbender.php
--- branches/testbaudson_dev/lib/mapbender.php	                        (rev 0)
+++ branches/testbaudson_dev/lib/mapbender.php	2008-07-18 10:26:21 UTC (rev 2674)
@@ -0,0 +1,86 @@
+<?php
+# $Id: class_checkInput.php 1742 2007-10-26 10:16:07Z christoph $
+# http://www.mapbender.org/index.php/class_checkInput
+require_once(dirname(__FILE__) . "/../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/application.php");
+class Mapbender {
+	private $currentApplication;
+	private $session;
+	private $get;
+	private $post;
+	public function __construct($session, $get, $post) {
+		$this->session = $session;
+		$this->get = $get;
+		$this->post = $post;
+		if ($this->session["mb_user_gui"]) {
+			$this->currentApplication = new Application($this->session["mb_user_gui"]);
+		else {
+			$e = new mb_exception("Mapbender: application id undefined.");
+	 * Returns a website containing the current application
+	 * @return String the HTML code
+		$htmlString = "";
+		$htmlString .= "<!DOCTYPE HTML PUBLIC '-//W3C//DTD HTML 4.01 Transitional//EN'>
+					<html>
+						<head>
+					Licensing: See the GNU General Public License for more details.
+					http://www.gnu.org/copyleft/gpl.html
+					or:
+					mapbender/licence/
+						<meta http-equiv='cache-control' content='no-cache'>
+						<meta http-equiv='pragma' content='no-cache'>
+						<meta http-equiv='expires' content='0'>
+						<meta http-equiv='Content-Type' content='text/html; charset=UTF-8'>
+						<title>" . $this->currentApplication->getTitle() . "</title>";
+		// add CSS files of all modules and CSS of body
+		$htmlString .= $this->currentApplication->stylesToHtml();
+		// add core JS functionality
+		$htmlString .= "<script type='text/javascript' src='../javascripts/core.php'></script>
+				</head>";
+		// add elements
+		$htmlString .= $this->currentApplication->elementsToHtml();
+		// add JavaScript
+		$htmlString .= "<script type='text/javascript' src='../javascripts/map.php?" .
+						SID  . "&guiID=" . $this->currentApplication->getId();
+		if ($this->get["mb_myBBOX"]) {
+			$htmlString .= "&mb_myBBOX=" . $this->get["mb_myBBOX"];
+		$htmlString .=  "'></script>";
+		$htmlString .= "</html>";
More information about the Mapbender_commits mailing list
