[Mapbender-commits] r2684 - in trunk/mapbender: core http/classes http/javascripts http/print http/tools
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jul 22 03:26:20 EDT 2008
Author: christoph
Date: 2008-07-22 03:26:19 -0400 (Tue, 22 Jul 2008)
New Revision: 2684
   trunk/mapbender/core/globalSettings.php
   trunk/mapbender/core/system.php
   trunk/mapbender/http/classes/class_SaveLegend.php
   trunk/mapbender/http/classes/class_administration.php
   trunk/mapbender/http/classes/class_bbox.php
   trunk/mapbender/http/classes/class_checkInput.php
   trunk/mapbender/http/classes/class_connector.php
   trunk/mapbender/http/classes/class_gml2.php
   trunk/mapbender/http/classes/class_gui.php
   trunk/mapbender/http/classes/class_json.php
   trunk/mapbender/http/classes/class_keyword.php
   trunk/mapbender/http/classes/class_kml.php
   trunk/mapbender/http/classes/class_kml_geometry.php
   trunk/mapbender/http/classes/class_kml_line.php
   trunk/mapbender/http/classes/class_kml_linearring.php
   trunk/mapbender/http/classes/class_kml_multigeometry.php
   trunk/mapbender/http/classes/class_kml_ows.php
   trunk/mapbender/http/classes/class_kml_parser_ows.php
   trunk/mapbender/http/classes/class_kml_placemark.php
   trunk/mapbender/http/classes/class_kml_point.php
   trunk/mapbender/http/classes/class_kml_polygon.php
   trunk/mapbender/http/classes/class_layer_monitor.php
   trunk/mapbender/http/classes/class_locale.php
   trunk/mapbender/http/classes/class_log.php
   trunk/mapbender/http/classes/class_metadata.php
   trunk/mapbender/http/classes/class_monitor.php
   trunk/mapbender/http/classes/class_point.php
   trunk/mapbender/http/classes/class_user.php
   trunk/mapbender/http/classes/class_weldMaps2Image.php
   trunk/mapbender/http/classes/class_weldMaps2PNG.php
   trunk/mapbender/http/classes/class_wfs.php
   trunk/mapbender/http/classes/class_wfs_conf.php
   trunk/mapbender/http/javascripts/mod_log.php
   trunk/mapbender/http/javascripts/wfs.js
   trunk/mapbender/http/print/printPDF.conf
   trunk/mapbender/http/print/printPDF_b.conf
   trunk/mapbender/http/tools/mapbender_setup.php
merged w/ 2.5 branch
Modified: trunk/mapbender/core/globalSettings.php
--- trunk/mapbender/core/globalSettings.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/core/globalSettings.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -5,8 +5,8 @@
 session_start();
 // All data Mapbender handles internally are UTF-8
 mb_internal_encoding("UTF-8");
@@ -29,7 +29,6 @@
 	require_once(dirname(__FILE__) . "/../lib/database-pgsql.php");
 // class for error handling
@@ -42,7 +41,6 @@
 require_once(dirname(__FILE__) . "/../http/classes/class_locale.php");
 $localeObj = new Mb_locale($_SESSION["mb_lang"]);
 // establish database connection
Modified: trunk/mapbender/core/system.php
--- trunk/mapbender/core/system.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/core/system.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -20,8 +20,8 @@
 # mapbender version
 define("MB_VERSION_NUMBER", "2.5.0");
-define("MB_VERSION_APPENDIX", "RC2");
-define("MB_RELEASE_DATE", mktime(0,0,0,4,21,2008));//h, min,sec,month,day,year
+define("MB_VERSION_APPENDIX", "RC5");
+define("MB_RELEASE_DATE", mktime(0,0,0,7,11,2008));//h, min,sec,month,day,year
 # constants from map.js
@@ -34,4 +34,4 @@
 define("LOG_LEVEL_LIST", "off,error,warning,notice,all");
-define("ZOOM_MOUSEWHEEL", "1.1");
\ No newline at end of file
+define("ZOOM_MOUSEWHEEL", "1.1");
Modified: trunk/mapbender/http/classes/class_SaveLegend.php
--- trunk/mapbender/http/classes/class_SaveLegend.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_SaveLegend.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -22,8 +22,9 @@
 * getlegendurl
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 require_once(dirname(__FILE__)."/class_stripRequest.php");
-require_once(dirname(__FILE__)."/class_mb_exception.php");
 require_once(dirname(__FILE__)."/class_connector.php");
 class SaveLegend{
@@ -63,4 +64,4 @@
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_administration.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -16,13 +16,9 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 require_once(dirname(__FILE__)."/class_user.php");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
 require(dirname(__FILE__) . "/phpmailer-1.72/class.phpmailer.php");
@@ -668,8 +664,8 @@
 	 * @deprecated
-	function getGuisByPermission($mb_user_id,$ignorepublic){
-		$e = new mb_notice("administration->getGuisByPermission is deprecated, use user->getApplicationsByPermission instead!");
+	function getGuisByPermission($mb_user_id,$ignorepublic){
+		$e = new mb_notice("administration->getGuisByPermission is deprecated, use user->getApplicationsByPermission instead!");
 		$user = new User($mb_user_id);
 		return $user->getApplicationsByPermission($ignorepublic);
@@ -1110,10 +1106,10 @@
 	 * @param integer 		userid the user-ID of the current user
 	 * @return integer[] 	the IDs of the wfs_conf-table
-	 function getWfsConfByPermission($userid){
+	 function getWfsConfByPermission($userid){
 		$e = new mb_notice("administration->getWfsConfByPermission is deprecated, use user->getWfsConfByPermission instead!");
 		$user = new User($userid);
 		return $user->getWfsConfByPermission();
Modified: trunk/mapbender/http/classes/class_bbox.php
--- trunk/mapbender/http/classes/class_bbox.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_bbox.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,11 +17,7 @@
-require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
-require_once(dirname(__FILE__)."/../classes/class_point.php");
  * A bounding box consisting of an lower left and an upper right point, and an EPSG.
@@ -155,4 +151,4 @@
 		return (string) "[" . $this->min . $this->max . " " . $this->epsg . "]";
Modified: trunk/mapbender/http/classes/class_checkInput.php
--- trunk/mapbender/http/classes/class_checkInput.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_checkInput.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,6 +17,8 @@
 class checkInput{
 	var $v;
 	function checkInput($q,$v,$t){
@@ -51,4 +53,4 @@
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_connector.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,11 +17,8 @@
-mb_internal_encoding("UTF-8");
  * Establishes a connection to a given URL (and loads the content).
  * Supports HTTP (GET and POST), cURL and socket connections.
@@ -210,4 +207,4 @@
Modified: trunk/mapbender/http/classes/class_gml2.php
--- trunk/mapbender/http/classes/class_gml2.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_gml2.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -16,10 +16,11 @@
 # You should have received a copy of the GNU General Public License
 require_once(dirname(__FILE__)."/../classes/class_connector.php");
 require_once(dirname(__FILE__)."/../classes/class_json.php");
 class gml2 {
 	var $geomtype_point = 'Point';
 	var $geomtype_polygon = 'Polygon';
@@ -837,4 +838,4 @@
 		return $str;
Modified: trunk/mapbender/http/classes/class_gui.php
--- trunk/mapbender/http/classes/class_gui.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_gui.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,12 +17,8 @@
-require_once(dirname(__FILE__)."/../classes/class_element.php");
-$con = db_connect($DBSERVER,$OWNER,$PW);
  * GUI is a set of GUI elements and services.
@@ -293,4 +289,4 @@
Modified: trunk/mapbender/http/classes/class_json.php
--- trunk/mapbender/http/classes/class_json.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_json.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,11 +17,8 @@
 define("JSON_PEAR", "json_pear");
 define("JSON_NATIVE", "json_native");
@@ -78,4 +75,4 @@
 		return json_decode($aString);
Modified: trunk/mapbender/http/classes/class_keyword.php
--- trunk/mapbender/http/classes/class_keyword.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_keyword.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -16,9 +16,7 @@
-include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
  * class to handle keywords for services
Modified: trunk/mapbender/http/classes/class_kml.php
--- trunk/mapbender/http/classes/class_kml.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_kml.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -16,7 +16,7 @@
 class kml {
@@ -172,4 +172,4 @@
 // end class
Modified: trunk/mapbender/http/classes/class_kml_geometry.php
--- trunk/mapbender/http/classes/class_kml_geometry.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_kml_geometry.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,7 +17,7 @@
 require_once(dirname(__FILE__)."/../classes/class_kml_polygon.php");
 require_once(dirname(__FILE__)."/../classes/class_kml_linearring.php");
@@ -57,4 +57,4 @@
 		return get_class($this);
Modified: trunk/mapbender/http/classes/class_kml_line.php
--- trunk/mapbender/http/classes/class_kml_line.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_kml_line.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,7 +17,8 @@
 require_once(dirname(__FILE__)."/../classes/class_kml_geometry.php");
@@ -117,4 +118,4 @@
 	protected $pointArray = array();
Modified: trunk/mapbender/http/classes/class_kml_linearring.php
--- trunk/mapbender/http/classes/class_kml_linearring.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_kml_linearring.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,7 +17,8 @@
 require_once(dirname(__FILE__)."/../classes/class_kml_line.php");
@@ -50,4 +51,4 @@
 		return "";
Modified: trunk/mapbender/http/classes/class_kml_multigeometry.php
--- trunk/mapbender/http/classes/class_kml_multigeometry.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_kml_multigeometry.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,7 +17,8 @@
@@ -79,4 +80,4 @@
 	private $geometryArray = array();
Modified: trunk/mapbender/http/classes/class_kml_ows.php
--- trunk/mapbender/http/classes/class_kml_ows.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_kml_ows.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,12 +17,9 @@
-session_start();
@@ -490,4 +487,4 @@
 	private $placemarkArray = array();
Modified: trunk/mapbender/http/classes/class_kml_parser_ows.php
--- trunk/mapbender/http/classes/class_kml_parser_ows.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_kml_parser_ows.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,8 +17,8 @@
@@ -305,4 +305,4 @@
Modified: trunk/mapbender/http/classes/class_kml_placemark.php
--- trunk/mapbender/http/classes/class_kml_placemark.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_kml_placemark.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,7 +17,7 @@
  * A Placemark consists of a geometry of type {@link KMLPoint}, {@link KMLPolygon},
@@ -116,4 +116,4 @@
 	private $geometry;
 	private $properties = array();
Modified: trunk/mapbender/http/classes/class_kml_point.php
--- trunk/mapbender/http/classes/class_kml_point.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_kml_point.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -19,7 +19,7 @@
  * 				along with this program; if not, write to the Free Software
  * 				Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
@@ -88,4 +88,4 @@
 	private $point;
Modified: trunk/mapbender/http/classes/class_kml_polygon.php
--- trunk/mapbender/http/classes/class_kml_polygon.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_kml_polygon.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -19,7 +19,7 @@
@@ -100,4 +100,4 @@
 	private $innerBoundaryArray = array();
Modified: trunk/mapbender/http/classes/class_layer_monitor.php
--- trunk/mapbender/http/classes/class_layer_monitor.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_layer_monitor.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,6 +17,8 @@
 class Layer_load_count {
 	function __construct () {
@@ -52,4 +54,4 @@
Modified: trunk/mapbender/http/classes/class_locale.php
--- trunk/mapbender/http/classes/class_locale.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_locale.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,8 +17,7 @@
  * sets the locale, depending on various settings:
@@ -212,4 +211,4 @@
Modified: trunk/mapbender/http/classes/class_log.php
--- trunk/mapbender/http/classes/class_log.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_log.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -22,6 +22,7 @@
 *	 [15/Jul/2004:	 10:00:08 +0200] 192.168.2.102 urldecode(username) userid
 *modul "GET /map/http/ HTTP/1.1"
 class log {
 	var $dir = "../../log/";
@@ -91,4 +92,4 @@
Modified: trunk/mapbender/http/classes/class_metadata.php
--- trunk/mapbender/http/classes/class_metadata.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_metadata.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -16,14 +16,9 @@
-#require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 require_once(dirname(__FILE__)."/class_administration.php");
Modified: trunk/mapbender/http/classes/class_monitor.php
--- trunk/mapbender/http/classes/class_monitor.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_monitor.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,9 +17,10 @@
 require_once(dirname(__FILE__)."/../classes/class_wms.php");
 require_once(dirname(__FILE__)."/../classes/class_bbox.php");
 define("MONITOR_DEFAULT_SCALE", 500000);
 define("MONITOR_IMG_WIDTH", 20);
@@ -475,4 +476,4 @@
Modified: trunk/mapbender/http/classes/class_point.php
--- trunk/mapbender/http/classes/class_point.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_point.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,10 +17,7 @@
  * A Mapbender_point is a 2-dimensional point with an EPSG.
@@ -175,4 +172,4 @@
 		return (string) "(" . $this->x . "," . $this->y . "," . $this->epsg . ")";
Modified: trunk/mapbender/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_user.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,7 +17,7 @@
  * A Mapbender user as described in the table mb_user.
@@ -156,4 +156,4 @@
 		return $wmcArray;
Modified: trunk/mapbender/http/classes/class_weldMaps2Image.php
--- trunk/mapbender/http/classes/class_weldMaps2Image.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_weldMaps2Image.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,10 +17,9 @@
   * Class generats Images (jpegs/pngs/geotiff)
@@ -201,4 +200,4 @@
Modified: trunk/mapbender/http/classes/class_weldMaps2PNG.php
--- trunk/mapbender/http/classes/class_weldMaps2PNG.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_weldMaps2PNG.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -23,10 +23,9 @@
 * get/post '___' separated maprequests
 class weldMaps2PNG{
@@ -80,4 +79,4 @@
Modified: trunk/mapbender/http/classes/class_wfs.php
--- trunk/mapbender/http/classes/class_wfs.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_wfs.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -21,9 +21,8 @@
 * class for wfs-objects
 class wfs {
Modified: trunk/mapbender/http/classes/class_wfs_conf.php
--- trunk/mapbender/http/classes/class_wfs_conf.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/classes/class_wfs_conf.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -17,9 +17,9 @@
-require_once(dirname(__FILE__)."/class_user.php");
-require_once(dirname(__FILE__)."/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_user.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
 class WfsConf {
@@ -378,4 +378,4 @@
Modified: trunk/mapbender/http/javascripts/mod_log.php
--- trunk/mapbender/http/javascripts/mod_log.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/javascripts/mod_log.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -1,5 +1,5 @@
 <?php
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require(dirname(__FILE__)."/../php/mb_validatePermission.php");
 mb_registerInitFunctions("mb_log_init()");
 function mb_log_init(){
@@ -7,7 +7,7 @@
 try{if(logtype){}}catch(e){logtype="";}
 function mb_log_set(req, time_client){
-	var url = '<?php echo $self; ?>&req=" + escape(req) + "&time_client=" + time_client;
+	var url = "../php/mod_log.php?<?php echo $urlParameters;?>&req=" + escape(req) + "&time_client=" + time_client;
 	mb_ajax_post(url, {req:req, time:time_client});
 	return true;
Modified: trunk/mapbender/http/javascripts/wfs.js
--- trunk/mapbender/http/javascripts/wfs.js	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/javascripts/wfs.js	2008-07-22 07:26:19 UTC (rev 2684)
@@ -43,7 +43,7 @@
 var usemap = "";
 var mod_usemap_radius = 10;
 var mod_usemap_line_tolerance = 5;
-var useCheckboxForHighlighting = true;
+var useCheckboxForHighlighting = false;
 var mb_wfs_fetch = new GeometryArray();
@@ -70,8 +70,10 @@
 	mb_registerSubFunctions('mod_usemap("")');
-if (useCheckboxForHighlighting) {
-	mb_registerSubFunctions('highlight.paint()');
+if (useCheckboxForHighlighting) {
+	eventInit.register(function() {
+		mb_registerSubFunctions('highlight.paint()');
@@ -227,8 +229,9 @@
 			str += 'xmlns:' + myconf['namespaces'][q]['name'] + '="' + myconf['namespaces'][q]['location'] + '" ';
 		} else if (myconf['namespaces'][q]['name'] == featureNS) {
 			ns_featureNS = true;
-			str += 'xmlns:' + myconf['namespaces'][q]['name'] + '="' + myconf['namespaces'][q]['location'] + '" ';
+			str += 'xmlns:' + myconf['namespaces'][q]['name'] + '="' + myconf['namespaces'][q]['location'] + '" '
+			strForSchemaLocation = myconf['namespaces'][q]['location'];
 	if (ns_gml == false) str += 'xmlns:gml="http://www.opengis.net/gml" ';
@@ -236,10 +239,15 @@
 	if (ns_xsi == false) str += 'xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" ';
 	if (ns_featureNS == false) str += 'xmlns:"+featureNS+"="http://www.someserver.com/"+featureNS+"" ';
 	if (ns_wfs == false) str += 'xmlns:wfs="http://www.opengis.net/wfs" ';
-	str += 'xsi:schemaLocation="http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd">';
+	str += 'xsi:schemaLocation="http://www.opengis.net/wfs';
+	str += ' http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd';
+	str += ' ' + strForSchemaLocation;
+	str += ' '+ myconf['wfs_describefeaturetype'];
+	//str += mb_getConjunctionCharacter(myconf['wfs_describefeaturetype']);
+	//str += 'typename=' + myconf['featuretype_name'];
+	str += '">';
 	// ---------------------------------------- SAVE -------------------------------------------------
Modified: trunk/mapbender/http/print/printPDF.conf
--- trunk/mapbender/http/print/printPDF.conf	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/print/printPDF.conf	2008-07-22 07:26:19 UTC (rev 2684)
@@ -1,6 +1,6 @@
 <?php
+include_once(dirname(__FILE__)."/../../core/globalSettings.php");
 # filename for temporary imagefiles
 $filename = TMPDIR."/map_".substr(md5(uniqid(rand())),0,7).".png";
@@ -9,7 +9,7 @@
 $download = true;
 $downloadFile = TMPDIR."/map_".substr(md5(uniqid(rand())),0,7).".pdf";
-$downloadText = _("Download: Map as PDF...");
 *run print as iframe or window
@@ -22,11 +22,11 @@
 * Legend
 $legend=true;
-$label_legend = _('print legend');
+$label_legend = _mb('print legend');
 $legendFilename = TMPDIR."/legend_".substr(md5(uniqid(rand())),0,7).".png";
 $legendFilenameUserPolygon = TMPDIR."/legend_".substr(md5(uniqid(rand())),0,7).".png";
-$legendText = _("Legend");
-$legendFooter = _("powered by Mapbender");
+$legendText = _mb("Legend");
+$legendFooter = _mb("powered by Mapbender");
 $legendImage = "./img/mapbender_logo.png";
 $legendImage_width = 90;
 $legendImage_height = 13;
@@ -48,50 +48,50 @@
 	$new_comment2 = $_REQUEST["comment2"];
-$text1 = _("Print preview");
 $text2 = "- Mapbender -";
 $text3 = "";
-$text4 = _("Scale 1:"). " ".$_REQUEST["map_scale"];
-$text5 = _("Date:") . " ".date("d.m.Y",strtotime("now"));
+$text4 = _mb("Scale 1:"). " ".$_REQUEST["map_scale"];
+$text5 = _mb("Date:") . " ".date("d.m.Y",strtotime("now"));
-$text6 = _("Notes:");
+$text6 = _mb("Notes:");
 $text7 = "";
 $text8 = $new_comment1;
 $text9 = $new_comment2;
 $text10 = "";
-$text11 = _("This copy has been automatically generated and is thus not valid without signature.");
-$text12 = _("This copy is protected by law (Par. 3 Abs. 1 VermKatG NW). It can be duplicaedted, modified, published or be passed to third parties only in agreement with");
-$text13 = _("the publisher, except duplicates and modifications aimed at internal use of government agencies or private use.");
+$text11 = _mb("This copy has been automatically generated and is thus not valid without signature.");
+$text12 = _mb("This copy is protected by law (Par. 3 Abs. 1 VermKatG NW). It can be duplicaedted, modified, published or be passed to third parties only in agreement with");
+$text13 = _mb("the publisher, except duplicates and modifications aimed at internal use of government agencies or private use.");
-$text14 = _("This copy is protected,");
-$text15 = _("ask me!!!!");
-$text16 = _("or the publisher");
-$text17 = _("or use is internally.");
+$text14 = _mb("This copy is protected,");
+$text15 = _mb("ask me!!!!");
+$text16 = _mb("or the publisher");
+$text17 = _mb("or use is internally.");
 * Labeling for buttons, textfields ...
-$label_format = _("Format:");
+$label_format = _mb("Format:");
 $label_format_a4 = "A4";
 $label_format_a3 = "A3";
 $label_format_a2 = "A2";
 $label_format_a1 = "A1";
 $label_format_a0 = "A0";
-$label_orientation = _("Orientation:");
-$label_portrait = _("portrait");
-$label_landscape = _("landscape");
+$label_orientation = _mb("Orientation:");
+$label_portrait = _mb("portrait");
+$label_landscape = _mb("landscape");
-$label_72dpi = sprintf(_("Quality: %d dpi"), 72);
-$label_288dpi = sprintf(_("Quality: %d dpi"), 288);
+$label_72dpi = sprintf(_mb("Quality: %d dpi"), 72);
+$label_288dpi = sprintf(_mb("Quality: %d dpi"), 288);
-$label_comment = _("Comment (max. 30)");
+$label_comment = _mb("Comment (max. 30)");
 $comment_length = 30;
-$label_button = _('print');
+$label_button = _mb('print');
 * default
Modified: trunk/mapbender/http/print/printPDF_b.conf
--- trunk/mapbender/http/print/printPDF_b.conf	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/print/printPDF_b.conf	2008-07-22 07:26:19 UTC (rev 2684)
@@ -1,6 +1,6 @@
 <?php
@@ -9,7 +9,7 @@
 $download = true;
-$downloadText = "Download: Karte als PDF...";
@@ -22,11 +22,11 @@
 * Legend
 $legend=true;
-$label_legend = 'print legend';
-$legendText = "Legende";
-$legendFooter = "powered by Mapbender";
@@ -48,50 +48,50 @@
-$text1 = "Druckansicht";
 $text3 = "";
-$text4 = "Maßstab 1 : " . $_REQUEST["map_scale"];
-$text5 = "Datum: " . date("d.m.Y",strtotime("now"));;
-$text6 = "Notizen:";
 $text7 = "";
 $text10 = "";
-$text11 = "Der Auszug ist maschinell erzeugt, er ist ohne Unterschrift gültig.";
-$text12 = "Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). Vervielfältigungen, Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit Zustimmung des";
-$text13 = "Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur innerdienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch.";
-$text14 = "Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). Vervielfältigungen,";
-$text15 = "Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit Zustimmung";
-$text16 = "des Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur inner-";
-$text17 = "dienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch.";
-$label_format = "Format:";
-$label_orientation = "Orientation: ";
-$label_portrait = "portrait";
-$label_landscape = "landscape";
-$label_72dpi = "Quality: 72 dpi";
-$label_288dpi = "Quality: 288 dpi";
-$label_comment = "Comment (max. 30)";
-$label_button = 'print';
 * default
@@ -122,8 +122,8 @@
 $a4 = true;
 $a3 = true;
 $a2 = true;
-$a1 = true;
-$a0 = true;
+$a1 = false;
+$a0 = false;
 # dimensions of the map:
Modified: trunk/mapbender/http/tools/mapbender_setup.php
--- trunk/mapbender/http/tools/mapbender_setup.php	2008-07-22 05:48:25 UTC (rev 2683)
+++ trunk/mapbender/http/tools/mapbender_setup.php	2008-07-22 07:26:19 UTC (rev 2684)
@@ -21,9 +21,7 @@
-include_once(dirname(__FILE__)."/../php/system.php");
-include_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
  <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
@@ -290,4 +288,4 @@
 	</td></tr>
 </table>
 </body>
-</html>
+</html>
More information about the Mapbender_commits mailing list
