[Mapbender-commits] r2707 - branches/testbaudson_dev/documents
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jul 23 11:51:55 EDT 2008
Author: christoph
Date: 2008-07-23 11:51:55 -0400 (Wed, 23 Jul 2008)
New Revision: 2707
   branches/testbaudson_dev/documents/mpbn25_.dia
wfs, layer, wms, gui etc
Modified: branches/testbaudson_dev/documents/mpbn25_.dia
--- branches/testbaudson_dev/documents/mpbn25_.dia	2008-07-23 13:27:56 UTC (rev 2706)
+++ branches/testbaudson_dev/documents/mpbn25_.dia	2008-07-23 15:51:55 UTC (rev 2707)
@@ -65,13 +65,13 @@
   <dia:layer name="Background" visible="true">
     <dia:object type="UML - Class" version="0" id="O0">
       <dia:attribute name="obj_pos">
-        <dia:point val="12.25,4.2"/>
+        <dia:point val="4,-8"/>
       </dia:attribute>
       <dia:attribute name="obj_bb">
-        <dia:rectangle val="12.2,4.15;25.05,9.05"/>
+        <dia:rectangle val="3.95,-8.05;16.8,-3.15"/>
       </dia:attribute>
       <dia:attribute name="elem_corner">
       </dia:attribute>
       <dia:attribute name="elem_width">
         <dia:real val="12.75"/>
@@ -265,13 +265,13 @@
     </dia:object>
     <dia:object type="UML - Class" version="0" id="O1">
-        <dia:point val="12.5,-34.7"/>
+        <dia:point val="4,-36"/>
       </dia:attribute>
-        <dia:rectangle val="12.45,-34.75;27.75,-17.85"/>
+        <dia:rectangle val="3.95,-36.05;19.25,-19.15"/>
       </dia:attribute>
       </dia:attribute>
         <dia:real val="15.199999999999999"/>
@@ -810,13 +810,13 @@
     </dia:object>
     <dia:object type="UML - Class" version="0" id="O2">
-        <dia:point val="12.6,-9.6"/>
+        <dia:point val="4,-15"/>
       </dia:attribute>
-        <dia:rectangle val="12.55,-9.65;22.25,-6.35"/>
+        <dia:rectangle val="3.95,-15.05;13.65,-11.75"/>
       </dia:attribute>
       </dia:attribute>
         <dia:real val="9.5999999999999996"/>
@@ -964,16 +964,16 @@
     </dia:object>
     <dia:object type="UML - Association" version="1" id="O3">
-        <dia:point val="20.1,-17.8497"/>
+        <dia:point val="11.6,-19.1497"/>
       </dia:attribute>
-        <dia:rectangle val="16.65,-17.8997;30.2,-8.85"/>
+        <dia:rectangle val="8.05,-19.1997;21.6,-14.25"/>
       </dia:attribute>
       <dia:attribute name="orth_points">
-        <dia:point val="20.1,-13.7249"/>
-        <dia:point val="17.4,-13.7249"/>
-        <dia:point val="17.4,-9.6"/>
+        <dia:point val="11.6,-17.0749"/>
+        <dia:point val="8.8,-17.0749"/>
+        <dia:point val="8.8,-15"/>
       </dia:attribute>
       <dia:attribute name="orth_orient">
         <dia:enum val="1"/>
@@ -1032,16 +1032,16 @@
     </dia:object>
     <dia:object type="UML - Association" version="1" id="O4">
-        <dia:point val="18.625,4.1497"/>
+        <dia:point val="10.375,-8.0503"/>
       </dia:attribute>
-        <dia:rectangle val="16.65,-7.15;30.2,4.9497"/>
+        <dia:rectangle val="8.05,-12.55;21.6,-7.2503"/>
       </dia:attribute>
-        <dia:point val="18.625,-1.12515"/>
-        <dia:point val="17.4,-1.12515"/>
-        <dia:point val="17.4,-6.4"/>
+        <dia:point val="10.375,-9.92515"/>
+        <dia:point val="8.8,-9.92515"/>
+        <dia:point val="8.8,-11.8"/>
       </dia:attribute>
         <dia:enum val="1"/>
@@ -1100,13 +1100,13 @@
     </dia:object>
     <dia:object type="UML - SmallPackage" version="0" id="O5">
-        <dia:point val="10.8,21.8875"/>
+        <dia:point val="3.9843,10.3825"/>
       </dia:attribute>
-        <dia:rectangle val="10.75,20.9375;56.6,24.1375"/>
+        <dia:rectangle val="3.9343,9.4325;49.7843,12.6325"/>
       </dia:attribute>
       </dia:attribute>
         <dia:real val="45.75"/>
@@ -1135,7 +1135,7 @@
             <dia:real val="0.80000000000000004"/>
           </dia:attribute>
           <dia:attribute name="pos">
-            <dia:point val="11.1,23.53"/>
+            <dia:point val="4.2843,12.025"/>
           </dia:attribute>
           <dia:attribute name="color">
             <dia:color val="#000000"/>
@@ -1148,13 +1148,13 @@
     </dia:object>
     <dia:object type="UML - SmallPackage" version="0" id="O6">
-        <dia:point val="10.785,25.5025"/>
+        <dia:point val="3.9693,13.9975"/>
       </dia:attribute>
-        <dia:rectangle val="10.735,24.5525;42.235,27.7525"/>
+        <dia:rectangle val="3.9193,13.0475;35.4193,16.2475"/>
       </dia:attribute>
       </dia:attribute>
         <dia:real val="31.400000000000002"/>
@@ -1183,7 +1183,7 @@
           </dia:attribute>
-            <dia:point val="11.085,27.145"/>
+            <dia:point val="4.2693,15.64"/>
           </dia:attribute>
@@ -1196,13 +1196,13 @@
     </dia:object>
     <dia:object type="UML - SmallPackage" version="0" id="O7">
-        <dia:point val="10.8157,17.505"/>
+        <dia:point val="4,6"/>
       </dia:attribute>
-        <dia:rectangle val="10.7657,16.555;43.6657,20.555"/>
+        <dia:rectangle val="3.95,5.05;36.85,9.05"/>
       </dia:attribute>
       </dia:attribute>
         <dia:real val="32.800000000000004"/>
@@ -1232,7 +1232,7 @@
           </dia:attribute>
-            <dia:point val="11.1157,19.1475"/>
+            <dia:point val="4.3,7.6425"/>
           </dia:attribute>
@@ -1245,13 +1245,13 @@
     </dia:object>
     <dia:object type="UML - SmallPackage" version="0" id="O8">
-        <dia:point val="10.8083,38.855"/>
+        <dia:point val="3.9926,29.6"/>
       </dia:attribute>
-        <dia:rectangle val="10.7583,37.905;43.3083,41.105"/>
+        <dia:rectangle val="3.9426,28.65;36.4926,31.85"/>
       </dia:attribute>
       </dia:attribute>
         <dia:real val="32.450000000000003"/>
@@ -1280,7 +1280,7 @@
           </dia:attribute>
-            <dia:point val="11.1083,40.4975"/>
+            <dia:point val="4.2926,31.2425"/>
           </dia:attribute>
@@ -1293,13 +1293,13 @@
     </dia:object>
     <dia:object type="UML - SmallPackage" version="0" id="O9">
-        <dia:point val="10.7583,35.33"/>
+        <dia:point val="3.9426,23.825"/>
       </dia:attribute>
-        <dia:rectangle val="10.7083,34.38;57.9583,37.58"/>
+        <dia:rectangle val="3.8926,22.875;51.1426,26.075"/>
       </dia:attribute>
       </dia:attribute>
         <dia:real val="47.149999999999999"/>
@@ -1328,7 +1328,7 @@
           </dia:attribute>
-            <dia:point val="11.0583,36.9725"/>
+            <dia:point val="4.2426,25.4675"/>
           </dia:attribute>
@@ -1341,13 +1341,13 @@
     </dia:object>
     <dia:object type="UML - SmallPackage" version="0" id="O10">
-        <dia:point val="10.7083,31.03"/>
+        <dia:point val="3.8926,19.525"/>
       </dia:attribute>
-        <dia:rectangle val="10.6583,30.08;44.6083,34.08"/>
+        <dia:rectangle val="3.8426,18.575;37.7926,22.575"/>
       </dia:attribute>
       </dia:attribute>
         <dia:real val="33.850000000000001"/>
@@ -1377,7 +1377,7 @@
           </dia:attribute>
-            <dia:point val="11.0083,32.6725"/>
+            <dia:point val="4.1926,21.1675"/>
           </dia:attribute>
@@ -1388,5 +1388,4086 @@
         </dia:composite>
       </dia:attribute>
     </dia:object>
+    <dia:object type="UML - Class" version="0" id="O11">
+      <dia:attribute name="obj_pos">
+        <dia:point val="56,-35"/>
+      </dia:attribute>
+      <dia:attribute name="obj_bb">
+        <dia:rectangle val="55.95,-35.05;71.95,-30.15"/>
+      </dia:attribute>
+      <dia:attribute name="elem_corner">
+      </dia:attribute>
+      <dia:attribute name="elem_width">
+        <dia:real val="15.9"/>
+      </dia:attribute>
+      <dia:attribute name="elem_height">
+        <dia:real val="4.8000000000000007"/>
+      </dia:attribute>
+      <dia:attribute name="name">
+        <dia:string>#gui#</dia:string>
+      </dia:attribute>
+      <dia:attribute name="stereotype">
+        <dia:string>##</dia:string>
+      </dia:attribute>
+      <dia:attribute name="comment">
+      </dia:attribute>
+      <dia:attribute name="abstract">
+        <dia:boolean val="false"/>
+      </dia:attribute>
+      <dia:attribute name="suppress_attributes">
+      </dia:attribute>
+      <dia:attribute name="suppress_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_attributes">
+        <dia:boolean val="true"/>
+      </dia:attribute>
+      <dia:attribute name="visible_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_comments">
+      </dia:attribute>
+      <dia:attribute name="wrap_operations">
+      </dia:attribute>
+      <dia:attribute name="wrap_after_char">
+        <dia:int val="40"/>
+      </dia:attribute>
+      <dia:attribute name="comment_line_length">
+      </dia:attribute>
+      <dia:attribute name="comment_tagging">
+      </dia:attribute>
+      <dia:attribute name="line_color">
+        <dia:color val="#000000"/>
+      </dia:attribute>
+      <dia:attribute name="fill_color">
+        <dia:color val="#90ee90"/>
+      </dia:attribute>
+      <dia:attribute name="text_color">
+      </dia:attribute>
+      <dia:attribute name="normal_font">
+        <dia:font family="monospace" style="0" name="Courier"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_font">
+        <dia:font family="monospace" style="88" name="Courier-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font">
+        <dia:font family="monospace" style="8" name="Courier-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="classname_font">
+        <dia:font family="sans" style="80" name="Helvetica-Bold"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font">
+        <dia:font family="sans" style="88" name="Helvetica-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="comment_font">
+        <dia:font family="sans" style="8" name="Helvetica-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="normal_font_height">
+        <dia:real val="0.80000000000000004"/>
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font_height">
+      </dia:attribute>
+      <dia:attribute name="abstract_font_height">
+      </dia:attribute>
+      <dia:attribute name="classname_font_height">
+        <dia:real val="1"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font_height">
+      </dia:attribute>
+      <dia:attribute name="comment_font_height">
+      </dia:attribute>
+      <dia:attribute name="attributes">
+        <dia:composite type="umlattribute">
+            <dia:string>#gui_id#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="type">
+            <dia:string>#varchar(50)#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="value">
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="visibility">
+            <dia:enum val="2"/>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="class_scope">
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#'' not null#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:enum val="0"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_description#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(255)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_public#</dia:string>
+          </dia:attribute>
+            <dia:string>#integer#</dia:string>
+          </dia:attribute>
+            <dia:string>#1 not null#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="operations"/>
+      <dia:attribute name="template">
+      </dia:attribute>
+      <dia:attribute name="templates"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O12">
+        <dia:point val="56,-25"/>
+      </dia:attribute>
+        <dia:rectangle val="55.95,-25.05;69.85,-6.55"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="13.800000000000001"/>
+      </dia:attribute>
+        <dia:real val="18.400000000000006"/>
+      </dia:attribute>
+        <dia:string>#gui_element#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#fkey_gui_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#''#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_pos#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_public#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_comment#</dia:string>
+          </dia:attribute>
+            <dia:string>#text#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_element#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#'' NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_attributes#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_left#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_tio#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_width#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_height#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_z_index#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_more_styles#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_content#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_closetag#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_js_file#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_mb_mod#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_target#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_requires#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_url#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="operations">
+        <dia:composite type="umloperation">
+            <dia:string>#gui_element_idx#</dia:string>
+          </dia:attribute>
+            <dia:string>#btree#</dia:string>
+          </dia:attribute>
+            <dia:string>#unique index#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="inheritance_type">
+          </dia:attribute>
+          <dia:attribute name="query">
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="parameters">
+            <dia:composite type="umlparameter">
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              <dia:attribute name="kind">
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O13">
+        <dia:point val="56,-2"/>
+      </dia:attribute>
+        <dia:rectangle val="55.95,-2.05;69.15,4.45"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="13.1"/>
+      </dia:attribute>
+        <dia:real val="6.4000000000000004"/>
+      </dia:attribute>
+        <dia:string>#gui_element_vars#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_e_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#var_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#var_value#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#context#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#var_type#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+            <dia:string>#gui_element_vars_idx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#index#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O14">
+        <dia:point val="62.9,-6.54972"/>
+      </dia:attribute>
+        <dia:rectangle val="61.8,-6.59972;75.35,-1.3004"/>
+      </dia:attribute>
+      <dia:attribute name="orth_points">
+        <dia:point val="62.9,-4.30006"/>
+        <dia:point val="62.55,-4.30006"/>
+        <dia:point val="62.55,-2.0504"/>
+      </dia:attribute>
+      <dia:attribute name="orth_orient">
+        <dia:enum val="1"/>
+      </dia:attribute>
+      <dia:attribute name="autorouting">
+      </dia:attribute>
+      </dia:attribute>
+      <dia:attribute name="direction">
+      </dia:attribute>
+      <dia:attribute name="ends">
+        <dia:composite>
+          <dia:attribute name="role">
+            <dia:string>#fkey_gui_id,e_id#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="multiplicity">
+          </dia:attribute>
+          <dia:attribute name="arrow">
+          </dia:attribute>
+          <dia:attribute name="aggregate">
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+            <dia:string>#fkey_gui_id,fkey_e_id#</dia:string>
+          </dia:attribute>
+            <dia:string>#on delete cascade on update cascade#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O12" connection="50"/>
+        <dia:connection handle="1" to="O13" connection="20"/>
+      </dia:connections>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O15">
+        <dia:point val="63.95,-30.1497"/>
+      </dia:attribute>
+        <dia:rectangle val="62.15,-30.1997;75.7,-24.25"/>
+      </dia:attribute>
+        <dia:point val="63.95,-27.5749"/>
+        <dia:point val="62.9,-27.5749"/>
+        <dia:point val="62.9,-25"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="16"/>
+        <dia:connection handle="1" to="O12" connection="1"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O16">
+        <dia:point val="34,-31"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-31.05;47.85,-26.95"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="4"/>
+      </dia:attribute>
+        <dia:string>#gui_mb_user#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#00ff00"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_mb_user_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#0 NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_type#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O17">
+        <dia:point val="19.2492,-27.6"/>
+      </dia:attribute>
+        <dia:rectangle val="19.1992,-29.75;34.7013,-27.085"/>
+      </dia:attribute>
+        <dia:point val="29.8875,-27.6"/>
+        <dia:point val="29.8875,-29"/>
+        <dia:point val="33.9513,-29"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#mb_user_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O1" connection="46"/>
+        <dia:connection handle="1" to="O16" connection="14"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O18">
+        <dia:point val="56,-33.1"/>
+      </dia:attribute>
+        <dia:rectangle val="47.1004,-34.185;61.7004,-28.0825"/>
+      </dia:attribute>
+        <dia:point val="51.9252,-33.1"/>
+        <dia:point val="51.9252,-29"/>
+        <dia:point val="47.8504,-29"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="8"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O19">
+        <dia:point val="96,-33"/>
+      </dia:attribute>
+        <dia:rectangle val="95.95,-33.05;113.35,-5.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="17.300000000000001"/>
+      </dia:attribute>
+        <dia:real val="27.200000000000014"/>
+      </dia:attribute>
+        <dia:string>#wms#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffc0cb"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#wms_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_version#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getcapabilities#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getmap#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getfeatureinfo#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getlegendurl#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_filter#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_owsproxy#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_upload_url#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fees#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#accessconstraints#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactperson#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactposition#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactorganization#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#address#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#city#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#stateorprovince#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#postcode#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#country#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactvoicetelephone#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactfacsimiletelephone#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactelectronicmailaddress#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_mb_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_owner#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_timestamp#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_supportsld#</dia:string>
+          </dia:attribute>
+            <dia:string>#boolean#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_userlayer#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_userstyle#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_remotewfs#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O20">
+        <dia:point val="95.9843,1.3825"/>
+      </dia:attribute>
+        <dia:rectangle val="95.9343,0.4325;136.184,3.6325"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="40.149999999999999"/>
+      </dia:attribute>
+        <dia:real val="2.2000000000000002"/>
+      </dia:attribute>
+      <dia:attribute name="line_colour">
+      </dia:attribute>
+      <dia:attribute name="fill_colour">
+      </dia:attribute>
+        <dia:string>#postgres:post#</dia:string>
+      </dia:attribute>
+      <dia:attribute name="text">
+        <dia:composite type="text">
+          <dia:attribute name="string">
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wms','wms_id'), (SELECT max(wms_id) FROM wms), true);#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="font">
+          </dia:attribute>
+          <dia:attribute name="height">
+          </dia:attribute>
+          <dia:attribute name="pos">
+            <dia:point val="96.2843,3.025"/>
+          </dia:attribute>
+          <dia:attribute name="color">
+          </dia:attribute>
+          <dia:attribute name="alignment">
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O21">
+        <dia:point val="95.9693,4.9975"/>
+      </dia:attribute>
+        <dia:rectangle val="95.9193,4.0475;123.219,7.2475"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="27.200000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#innodb:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE wms CHANGE COLUMN wms_id wms_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="96.2693,6.64"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O22">
+        <dia:point val="96,-3"/>
+      </dia:attribute>
+        <dia:rectangle val="95.95,-3.95;124.65,0.05"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="28.600000000000001"/>
+      </dia:attribute>
+        <dia:real val="3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#postgres:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE wms_id_seq;
+ALTER TABLE wms ALTER COLUMN wms_id SET DEFAULT nextval('wms_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="96.3,-1.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O23">
+        <dia:point val="77,-19"/>
+      </dia:attribute>
+        <dia:rectangle val="76.95,-19.05;91.55,-7.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="14.5"/>
+      </dia:attribute>
+        <dia:real val="11.200000000000001"/>
+      </dia:attribute>
+        <dia:string>#layer#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#layer_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_wms_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_pos#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_parent#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_queryable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_minscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#0#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_maxscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_dataurl#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_metadataurl#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O24">
+        <dia:point val="77,-35"/>
+      </dia:attribute>
+        <dia:rectangle val="76.95,-35.05;91.2,-23.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="14.15"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#gui_layer#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_layer_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_wms_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_status#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#1#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_selectable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_visible#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_queryable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_minscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_maxscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_priotity#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_style#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_wfs_featuretype#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O25">
+        <dia:point val="77,-4"/>
+      </dia:attribute>
+        <dia:rectangle val="76.95,-4.05;94.35,18.45"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="22.400000000000009"/>
+      </dia:attribute>
+        <dia:string>#wfs#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffa500"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#wfs_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_version#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_getcapabilities#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_getfeature#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_transaction#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_owsproxy#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_upload_url#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#individualname#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#positionname#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#providername#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#deliverypoint#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#postalcode#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#voice#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#facsimile#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#electronicmailaddress#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_mb_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_owner#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_timestamp#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
   </dia:layer>
 </dia:diagram>
More information about the Mapbender_commits mailing list
