[Mapbender-commits] r2523 - branches/beck_dev/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jun 20 11:37:47 EDT 2008
Author: christoph
Date: 2008-06-20 11:37:47 -0400 (Fri, 20 Jun 2008)
New Revision: 2523
   branches/beck_dev/mapbender/http/javascripts/map.php
allow to load multiple javascripts
Modified: branches/beck_dev/mapbender/http/javascripts/map.php
--- branches/beck_dev/mapbender/http/javascripts/map.php	2008-06-20 15:29:57 UTC (rev 2522)
+++ branches/beck_dev/mapbender/http/javascripts/map.php	2008-06-20 15:37:47 UTC (rev 2523)
@@ -130,17 +130,20 @@
 $mb_res = db_prep_query($mb_sql, $mb_v, $mb_t);
 while($row_js = db_fetch_array($mb_res)){
 	if($row_js["e_js_file"] != ""){
-		$e_id = $row_js["e_id"];
-		$e_src = $row_js["e_src"];
-		$e_require = $row_js["e_requires"];
-		$e_target = explode(",",$row_js["e_target"]);
-		$currentFile = $row_js["e_js_file"];
-		if (file_exists($currentFile)) {
-			require_once($currentFile);
+		$jsArray = explode(",", $row_js["e_js_file"]);
+		for ($i = 0; $i < count($jsArray); $i++) {
+			$e_id = $row_js["e_id"];
+			$e_src = $row_js["e_src"];
+			$e_require = $row_js["e_requires"];
+			$e_target = explode(",",$row_js["e_target"]);
+			$currentFile = trim($jsArray[$i]);
+			if (file_exists($currentFile)) {
+				require_once($currentFile);
+			else {
+				$e = new mb_exception("Javascript not found: " . $currentFile);
-		else {
-			$e = new mb_exception("Javascript not found: " . $currentFile);
\ No newline at end of file
More information about the Mapbender_commits mailing list
