[Mapbender-commits] r2528 - branches/beck_dev/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jun 20 13:18:58 EDT 2008
Author: greq
Date: 2008-06-20 13:18:58 -0400 (Fri, 20 Jun 2008)
New Revision: 2528
   branches/beck_dev/mapbender/http/javascripts/map.js
map dragging / zooming doesn't works fine !!!
ToDo: testing, analysing, ...
Modified: branches/beck_dev/mapbender/http/javascripts/map.js
--- branches/beck_dev/mapbender/http/javascripts/map.js	2008-06-20 15:43:25 UTC (rev 2527)
+++ branches/beck_dev/mapbender/http/javascripts/map.js	2008-06-20 17:18:58 UTC (rev 2528)
@@ -121,9 +121,9 @@
-var writeMapTimeout;
 var imagesToLoad = 0;
 function setMapRequest(frameName){
 	var functionName = 'setMapRequest';
@@ -141,6 +141,7 @@
 		imagesToLoad += currentMapObject.wms.length;
+		currentMapObject.firstWmsLoaded = false;
 		var newMapRequest = "";
 		for (var ii = 0; ii < currentMapObject.wms.length; ii++){
@@ -151,17 +152,21 @@
 			myMapIds.push("map_"+ii);
 //			newMapRequest += getLayerHtmlCode(frameName, i, ii);
-			var currentRequest = getLayerHtmlCode(frameName, i, ii);
-			img = new Image();
-			img.src = mb_mapObj[i].getMapUrl(i, ii);
-			var frameName = mb_mapObj[i].frameName;
-			var elementName = mb_mapObj[i].elementName;
-			writeMapTimeout = setTimeout(function () {
-				writeMap(img, frameName, elementName, currentRequest);
-			}, 100);
+//			console.log("frameName: %s, wms: %s", i, ii);
+			(function () {
+				var img = new Image();
+				img.src = mb_mapObj[i].getMapUrl(i, ii);
+				var frameName = mb_mapObj[i].frameName;
+				var elementName = mb_mapObj[i].elementName;
+				var currentRequest = getLayerHtmlCode(frameName, i, ii);
+				var mapIndex = i;
+				var wmsIndex = ii;
+				mb_mapObj[i].wms[ii].writeMapTimeout = setTimeout(function () {
+					writeMap(img, frameName, elementName, currentRequest, mapIndex, wmsIndex);
+				}, 100);
 //		writeTag(mb_mapObj[i].frameName, mb_mapObj[i].elementName, newMapRequest);
@@ -171,18 +176,33 @@
-	function writeMap (image, frameName, elementName, html) {
+	function writeMap (image, frameName, elementName, html, i, ii) {
+//		console.log("wms URL %s (%s)", image.src, frameName);
 		if (image.complete) {
-			writeTag(frameName, elementName, html);
+//			console.log("success!");
+//			mb_mapObj[i].completeHtml += html;
 			imagesToLoad --;
+//			console.log("searching for %s in frame %s", "#"+elementName, "window.frames['"+frameName+"']")
+//			console.log("found #%s elements.", $("#"+elementName, window.frames[frameName].document).size());
+			if (!mb_mapObj[i].firstWmsLoaded) {
+				mb_mapObj[i].firstWmsLoaded = true;
+				$("#"+elementName, window.frames[frameName].document).children().remove();
+				$("#"+elementName, window.frames[frameName].document).append($(html));
+			else {
 			if (imagesToLoad === 0) {
+//				console.log("all images loaded (%s)", frameName);
+//				writeTag(frameName, elementName, completeHtml);
+//				completeHtml = "";
 				eventAfterMapImagesReady.trigger();
 		else {
-				writeMap(image, frameName, elementName, html);
+//			console.log("failed, will retry...");
+				writeMap(image, frameName, elementName, html, i, ii);
 			}, 100);
More information about the Mapbender_commits mailing list
