[Mapbender-commits] r2532 - branches/beck_dev/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jun 23 10:31:46 EDT 2008
Author: christoph
Date: 2008-06-23 10:31:46 -0400 (Mon, 23 Jun 2008)
New Revision: 2532
   branches/beck_dev/mapbender/http/javascripts/map.js
reverted to 2517
Modified: branches/beck_dev/mapbender/http/javascripts/map.js
--- branches/beck_dev/mapbender/http/javascripts/map.js	2008-06-23 14:17:40 UTC (rev 2531)
+++ branches/beck_dev/mapbender/http/javascripts/map.js	2008-06-23 14:31:46 UTC (rev 2532)
@@ -120,10 +120,6 @@
-var imagesToLoad = 0;
 function setMapRequest(frameName){
 	var functionName = 'setMapRequest';
@@ -140,9 +136,6 @@
 			continue;
-		imagesToLoad += currentMapObject.wms.length;
-		currentMapObject.firstWmsLoaded = false;
 		var newMapRequest = "";
 		for (var ii = 0; ii < currentMapObject.wms.length; ii++){
 			var currentWms = currentMapObject.wms[ii];
@@ -151,61 +144,15 @@
 			myMapIds.push("map_"+ii);
-//			newMapRequest += getLayerHtmlCode(frameName, i, ii);
+			newMapRequest += getLayerHtmlCode(frameName, i, ii);
-//			console.log("frameName: %s, wms: %s", i, ii);
-			(function () {
-				var img = new Image();
-				img.src = mb_mapObj[i].getMapUrl(i, ii);
-				var frameName = mb_mapObj[i].frameName;
-				var elementName = mb_mapObj[i].elementName;
-				var currentRequest = getLayerHtmlCode(frameName, i, ii);
-				var mapIndex = i;
-				var wmsIndex = ii;
-				mb_mapObj[i].wms[ii].writeMapTimeout = setTimeout(function () {
-					writeMap(img, frameName, elementName, currentRequest, mapIndex, wmsIndex);
-				}, 100);
-//		writeTag(mb_mapObj[i].frameName, mb_mapObj[i].elementName, newMapRequest);
+		writeTag(mb_mapObj[i].frameName, mb_mapObj[i].elementName, newMapRequest);
 	eventAfterMapRequest.trigger({
 		"frameName": frameName,
 		"myMapIds": myMapIds.join(",")
-	function writeMap (image, frameName, elementName, html, i, ii) {
-//		console.log("wms URL %s (%s)", image.src, frameName);
-		if (image.complete) {
-//			console.log("success!");
-//			mb_mapObj[i].completeHtml += html;
-			imagesToLoad --;
-//			console.log("searching for %s in frame %s", "#"+elementName, "window.frames['"+frameName+"']")
-//			console.log("found #%s elements.", $("#"+elementName, window.frames[frameName].document).size());
-			if (!mb_mapObj[i].firstWmsLoaded) {
-				mb_mapObj[i].firstWmsLoaded = true;
-				$("#"+elementName, window.frames[frameName].document).children().remove();
-				$("#"+elementName, window.frames[frameName].document).append($(html));
-			else {
-			if (imagesToLoad === 0) {
-//				console.log("all images loaded (%s)", frameName);
-//				writeTag(frameName, elementName, completeHtml);
-//				completeHtml = "";
-				eventAfterMapImagesReady.trigger();
-		else {
-//			console.log("failed, will retry...");
-				writeMap(image, frameName, elementName, html, i, ii);
-			}, 100);
 	for(var i=0; i<mb_MapRequestSubFunctions.length; i++){
 		eval(mb_MapRequestSubFunctions[i]);
More information about the Mapbender_commits mailing list
