[Mapbender-commits] r2540 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jun 23 11:58:56 EDT 2008
Author: christoph
Date: 2008-06-23 11:58:56 -0400 (Mon, 23 Jun 2008)
New Revision: 2540
   trunk/mapbender/http/javascripts/core.php
   trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js
   trunk/mapbender/http/javascripts/mod_adminNavigation.js
   trunk/mapbender/http/javascripts/mod_box1.js
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
   trunk/mapbender/http/javascripts/mod_pan.php
   trunk/mapbender/http/javascripts/mod_perimeter.php
Modified: trunk/mapbender/http/javascripts/core.php
--- trunk/mapbender/http/javascripts/core.php	2008-06-23 15:58:18 UTC (rev 2539)
+++ trunk/mapbender/http/javascripts/core.php	2008-06-23 15:58:56 UTC (rev 2540)
@@ -19,7 +19,6 @@
 ob_start();
 header('Content-type: application/x-javascript');
-require_once(dirname(__FILE__) . "/../javascripts/event.js");
-require_once(dirname(__FILE__) . "/../javascripts/core.js");
+require_once(dirname(__FILE__) . "/../../lib/event.js");
+require_once(dirname(__FILE__) . "/../../lib/core.js");
\ No newline at end of file
Modified: trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js
--- trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js	2008-06-23 15:58:18 UTC (rev 2539)
+++ trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js	2008-06-23 15:58:56 UTC (rev 2540)
@@ -1,3 +1,24 @@
+function mb_mapObjaddWMS(obj){
+	var cnt_layers = 0;
+	var cnt_querylayers = 0;
+	var styles = "";
+	var layers = "";
+	var querylayers = "";
+	var ind = getMapObjIndexByName(obj);
+	//is the id valid?
+	for( var i=0; i<(wms.length-1); i++){
+		if(parseInt(wms[i].wms_id, 10) >= parseInt(wms[wms.length-1].wms_id, 10)){
+			wms[wms.length-1].wms_id = parseInt(mb_mapObj[ind].wms[i].wms_id, 10) + 1;
+	mb_mapObj[ind].wms[mb_mapObj[ind].wms.length] = wms[wms.length-1];
+	mb_mapObj[ind].layers[mb_mapObj[ind].layers.length] = layers;
+	mb_mapObj[ind].styles[mb_mapObj[ind].styles.length] = styles;
+	mb_mapObj[ind].querylayers[mb_mapObj[ind].querylayers.length] = querylayers;
+	mb_execloadWmsSubFunctions();
+	return true;
 function mod_addWMS_load(caps){
 	window.frames['loadData'].document.location.href = "../php/mod_createJSObjFromXML.php?caps=" + encodeURIComponent(caps);
Modified: trunk/mapbender/http/javascripts/mod_adminNavigation.js
--- trunk/mapbender/http/javascripts/mod_adminNavigation.js	2008-06-23 15:58:18 UTC (rev 2539)
+++ trunk/mapbender/http/javascripts/mod_adminNavigation.js	2008-06-23 15:58:56 UTC (rev 2540)
@@ -1,4 +1,5 @@
 function mod_adminNavigation_init(){
+	eventInit.trigger();
 	for (var i=0; i< document.getElementsByTagName("a").length; i++){
 		document.getElementsByTagName("a")[i].onclick = new Function("mod_adminNavigation(this)");
Modified: trunk/mapbender/http/javascripts/mod_box1.js
--- trunk/mapbender/http/javascripts/mod_box1.js	2008-06-23 15:58:18 UTC (rev 2539)
+++ trunk/mapbender/http/javascripts/mod_box1.js	2008-06-23 15:58:56 UTC (rev 2540)
@@ -8,6 +8,10 @@
 var mb_isBF = false;
 var mb_zF = false;
+var mb_offset_top = 0;
+var mb_offset_right = 0;
+var mb_offset_bottom = 0;
+var mb_offset_left = 0;
 function  mod_box_start(e){
 	mb_isActive = true;
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2008-06-23 15:58:18 UTC (rev 2539)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2008-06-23 15:58:56 UTC (rev 2540)
@@ -135,8 +135,13 @@
 	executeDigitizeSubFunctions();
+function mb_registerGML(frameName,obj){
+	var ind = parent.getMapObjIndexByName(frameName);
+	parent.mb_mapObj[ind].geom = obj;
 function mod_digitize_go(e){
-	parent.mb_registerGML(mod_digitize_target,d);
+	mb_registerGML(mod_digitize_target,d);
 	// ie workaround
 	if (e == undefined) {
Modified: trunk/mapbender/http/javascripts/mod_pan.php
--- trunk/mapbender/http/javascripts/mod_pan.php	2008-06-23 15:58:18 UTC (rev 2539)
+++ trunk/mapbender/http/javascripts/mod_pan.php	2008-06-23 15:58:56 UTC (rev 2540)
@@ -28,6 +28,9 @@
 var mod_pan_img_off = new Image(); mod_pan_img_off.src = "<?php  echo $e_src;  ?>";
 var mod_pan_img_over = new Image(); mod_pan_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
+var mb_panActive = false;
 function init_mod_pan(ind){
 	mb_button[ind] = document.getElementById(mod_pan_elName);
 	mb_button[ind].img_over = mod_pan_img_over.src;
Modified: trunk/mapbender/http/javascripts/mod_perimeter.php
--- trunk/mapbender/http/javascripts/mod_perimeter.php	2008-06-23 15:58:18 UTC (rev 2539)
+++ trunk/mapbender/http/javascripts/mod_perimeter.php	2008-06-23 15:58:56 UTC (rev 2540)
@@ -36,6 +36,40 @@
 var mod_perimeter_status = 0;
 var mod_perimeter_img_obj = null;
+function mb_checkTag(frameName, tagName, elementId, appendAtTagName, attributes){
+	var oldElement;
+	var newElement;
+	var prefix;
+	if(frameName && frameName !== ""){
+		prefix = window.frames[frameName].document;
+	else if(!frameName || frameName === ""){
+		prefix = document;
+	oldElement = prefix.getElementById(elementId);
+	if (oldElement === null) {
+		newElement = prefix.createElement(tagName);
+		newElement = prefix.getElementsByTagName(appendAtTagName)[0].appendChild(newElement);
+	else {
+		if (oldElement.nodeName.toLowerCase() == tagName.toLowerCase()) {
+			for (var i=0; i<attributes.length; i++) {
+				oldElement.setAttribute(attributes[i][0], attributes[i][1]);
+			return oldElement;
+		else {
+			return false;
+	var newElementAttributeNode = document.createAttribute("id");
+	newElementAttributeNode.value = elementId;
+	newElement.setAttributeNode(newElementAttributeNode);
+		newElement.setAttribute(attributes[i][0], attributes[i][1]);
+	return newElement;
 function mod_perimeter_checkDefaults(){
 	try{var t = mod_perimeter_thickness;}catch(e){mod_perimeter_thickness = 2;}
 	try{var t = mod_perimeter_color;}catch(e){mod_perimeter_color = '#000000';}
More information about the Mapbender_commits mailing list
