[Mapbender-commits] r2546 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jun 23 12:20:25 EDT 2008
Author: christoph
Date: 2008-06-23 12:20:25 -0400 (Mon, 23 Jun 2008)
New Revision: 2546
Removed:
   trunk/mapbender/lib/map.js
   trunk/mapbender/lib/map_obj.js
   trunk/mapbender/lib/wfs_obj.js
   trunk/mapbender/lib/wms.js
Deleted: trunk/mapbender/lib/map.js
--- trunk/mapbender/lib/map.js	2008-06-23 16:16:52 UTC (rev 2545)
+++ trunk/mapbender/lib/map.js	2008-06-23 16:20:25 UTC (rev 2546)
@@ -1,1200 +0,0 @@
-var ie = document.all?1:0;
-var n6 = document.getElementById&&!document.all?1:0;
-var n4 = document.layers?1:0;
-var mb_mapObj = [];
-var mb_fiWin = null;
-var mb_panActive = false;
-var clickX;
-var clickY;
-var mb_start_x = 0;
-var mb_start_y = 0;
-var mb_end_x = 0;
-var mb_end_y = 0;
-var mb_offset_top = 0;
-var mb_offset_right = 0;
-var mb_offset_bottom = 0;
-var mb_offset_left = 0;
-var mb_log = null;
- * @deprecated
-function mb_execloadWmsSubFunctions(){
-	eventAfterLoadWMS.trigger();
-function mb_execWfsReadSubFunctions(geom) {
-	for(var i=0; i<mb_WfsReadSubFunctions.length; i++){
-		mb_WfsReadSubFunctions[i](geom);
-function mb_execWfsWriteSubFunctions() {
-	for(var i=0; i<mb_WfsWriteSubFunctions.length; i++){
-		mb_WfsWriteSubFunctions[i]();
-function mb_setWmcExtensionData(anArray) {
-	for (var i in anArray) {
-		if (typeof(anArray[i]) != "undefined") {
-			currentWmcExtensionData[i] = anArray[i];
-function mb_getWmcExtensionData(arrayKey) {
-	for (var i in restoredWmcExtensionData) {
-		if (arrayKey == i) {
-			return restoredWmcExtensionData[i];
-	var e = new Mb_warning("mb_getWmcExtensionData: "+arrayKey+" not found. Maybe this GUI does not allow loading or saving WMC documents from/to the session");
-	return null;
-// transparent GIF
-var mb_trans = new Image();
-mb_trans.src = "../img/transparent.gif";
- * Called in index.php on body onload
-function init() {
-	// creates the map objects (mapframe1, overview...)
-	eventInitMap.trigger();
-	// initialisation
-	eventInit.trigger();
-	// performs a map request for each map frame
-	for(var i=0; i<mb_mapObj.length; i++){
-		setMapRequest(mb_mapObj[i].frameName);
-function mb_registerMapObj(frameName, elementName,wms_index,width, height){
-	mb_mapObj.push(new mb_mapObj_const(frameName, elementName, width, height, wms_index));
- * get the conjunction character of an URL
- * @param {String} onlineresource
- * @return the character & or ?
- * @type String
-function mb_getConjunctionCharacter(onlineresource){
-	var conChar;
-	if(onlineresource.indexOf("?") > -1){
-		if(onlineresource.charAt(onlineresource.length-1) == "?"){
-			conChar = "";
-		}else if(onlineresource.charAt(onlineresource.length-1) == "&"){
-			conChar = "";
-		}else{
-			conChar = "&";
-	if(onlineresource.indexOf("?") == -1){
-		conChar = "?";
-	return conChar;
-function mb_wmsMoveByIndex(mapObj_ind, fromIndex, toIndex) {
-	if (fromIndex != toIndex && fromIndex >= 0 && fromIndex < mb_mapObj[mapObj_ind].wms.length && toIndex >= 0 && toIndex < mb_mapObj[mapObj_ind].wms.length) {
-		var changed = false;
-		var i;
-		var result;
-		if (fromIndex > toIndex) {
-			for (i = fromIndex; i > toIndex ; i--) {
-				result = mb_swapWmsByIndex(mapObj_ind, i-1, i);
-				if (result === true) {
-					changed = true;
-		else {
-			for (i = fromIndex; i < toIndex ; i++) {
-				result = mb_swapWmsByIndex(mapObj_ind, i, i+1);
-					changed = true;
-		return changed;
-	else {
-		return false;
-function mb_swapWmsByIndex(mapObj_ind, indexA, indexB) {
-	if (indexA != indexB && indexA >= 0 && indexA < mb_mapObj[mapObj_ind].wms.length && indexB >= 0 && indexB < mb_mapObj[mapObj_ind].wms.length) {
-		upper = mb_mapObj[mapObj_ind].wms[indexA];
-		mb_mapObj[mapObj_ind].wms[indexA] = mb_mapObj[mapObj_ind].wms[indexB];
-		mb_mapObj[mapObj_ind].wms[indexB] = upper;
-		var upperLayers = mb_mapObj[mapObj_ind].layers[indexA];
-		var upperStyles = mb_mapObj[mapObj_ind].styles[indexA];
-		var upperQuerylayers = mb_mapObj[mapObj_ind].querylayers[indexA];
-		mb_mapObj[mapObj_ind].layers[indexA] = mb_mapObj[mapObj_ind].layers[indexB];
-		mb_mapObj[mapObj_ind].styles[indexA] = mb_mapObj[mapObj_ind].styles[indexB];
-		mb_mapObj[mapObj_ind].querylayers[indexA] = mb_mapObj[mapObj_ind].querylayers[indexB];
-		mb_mapObj[mapObj_ind].layers[indexB] = upperLayers;
-		mb_mapObj[mapObj_ind].styles[indexB] = upperStyles;
-		mb_mapObj[mapObj_ind].querylayers[indexB] = upperQuerylayers;
-		return true;
-	else {
-		return false;
-function mb_mapObjaddWMS(obj){
-	var cnt_layers = 0;
-	var cnt_querylayers = 0;
-	var styles = "";
-	var layers = "";
-	var querylayers = "";
-	var ind = getMapObjIndexByName(obj);
-	//is the id valid?
-	for( var i=0; i<(wms.length-1); i++){
-		if(parseInt(wms[i].wms_id, 10) >= parseInt(wms[wms.length-1].wms_id, 10)){
-			wms[wms.length-1].wms_id = parseInt(mb_mapObj[ind].wms[i].wms_id, 10) + 1;
-	mb_mapObj[ind].wms[mb_mapObj[ind].wms.length] = wms[wms.length-1];
-	mb_mapObj[ind].layers[mb_mapObj[ind].layers.length] = layers;
-	mb_mapObj[ind].styles[mb_mapObj[ind].styles.length] = styles;
-	mb_mapObj[ind].querylayers[mb_mapObj[ind].querylayers.length] = querylayers;
-	mb_execloadWmsSubFunctions();
-	return true;
-function mb_mapObjremoveWMS(objind,wmsind){
-	var wms_ID = null;
-	var i;
-	var new_wmsarray = [];
-	var new_layerarray = [];
-	var new_querylayerarray = [];
-	var new_stylesarray = [];
-	var new_mapURLarray = [];
-	for	(i=0;i<mb_mapObj[objind].wms.length; i++){
-		if(i != wmsind){
-			new_wmsarray[new_wmsarray.length] = mb_mapObj[objind].wms[i];
-			new_layerarray[new_layerarray.length] = mb_mapObj[objind].layers[i];
-			new_querylayerarray[new_querylayerarray.length] = mb_mapObj[objind].querylayers[i];
-			new_stylesarray[new_stylesarray.length] = mb_mapObj[objind].styles[i];
-			new_mapURLarray[new_mapURLarray.length] = mb_mapObj[objind].mapURL[i];
-		else {
-			wms_ID = mb_mapObj[objind].wms[i].wms_id;
-	mb_mapObj[objind].wms = new_wmsarray;
-	mb_mapObj[objind].layers = new_layerarray;
-	mb_mapObj[objind].querylayers = new_querylayerarray;
-	mb_mapObj[objind].styles = new_stylesarray;
-	mb_mapObj[objind].mapURL = new_mapURLarray;
-	var another_new_wmsarray = [];
-	for	(i=0;i<wms.length; i++){
-		if(wms[i].wms_id != wms_ID){
-			another_new_wmsarray[another_new_wmsarray.length] = wms[i];
-	wms = another_new_wmsarray;
-function setExtent(width,height,epsg){
-   for(var i=0; i < wms[0].gui_epsg.length; i++){
-      if(wms[0].gui_epsg[i] == epsg){
-         var bbox_minx = parseFloat(wms[0].gui_minx[i]);
-         var bbox_miny = parseFloat(wms[0].gui_miny[i]);
-         var bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
-         var bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
-         var extenty = bbox_maxy - bbox_miny;
-         var extentx = bbox_maxx - bbox_minx;
-         var relation_px_x = width / height;
-         var relation_px_y = height / width;
-         var relation_bbox_x = extentx / extenty;
-         var centerx = bbox_minx + (extentx/2);
-         var centery = bbox_miny + (extenty/2);
-         if(relation_bbox_x <= relation_px_x){
-                bbox_minx = centerx - relation_px_x * extenty / 2;
-                bbox_maxx = centerx + relation_px_x * extenty / 2;
-         if(relation_bbox_x > relation_px_x){
-                bbox_miny = centery - relation_px_y * extentx / 2;
-                bbox_maxy = centery + relation_px_y * extentx / 2;
-        return bbox_minx  +","+ bbox_miny +","+ bbox_maxx  +","+ bbox_maxy;
-function setMapRequest(frameName){
-	var functionName = 'setMapRequest';
-	var ret = eventBeforeMapRequest.trigger({frameName:frameName}, "AND");
-	if (ret === false) {
-		return true;
-	var ts = mb_timestamp();
-	var myMapIds = [];
-	for (var i=0; i < mb_mapObj.length; i++){
-		var currentMapObject = mb_mapObj[i];
-		if (currentMapObject.frameName != frameName) {
-			continue;
-		var newMapRequest = "";
-		for (var ii = 0; ii < currentMapObject.wms.length; ii++){
-			var currentWms = currentMapObject.wms[ii];
-			if (!(currentWms.gui_wms_visible > 0)) {
-				continue;
-			myMapIds.push("map_"+ii);
-			newMapRequest += getLayerHtmlCode(frameName, i, ii);
-		writeTag(mb_mapObj[i].frameName, mb_mapObj[i].elementName, newMapRequest);
-	eventAfterMapRequest.trigger({
-		"frameName": frameName,
-		"myMapIds": myMapIds.join(",")
-	for(var i=0; i<mb_MapRequestSubFunctions.length; i++){
-		eval(mb_MapRequestSubFunctions[i]);
-function getLayerHtmlCode (frameName, i, ii) {
-	var myDivId = "div_" + ii;
-	var myMapId = "map_" + ii;
-	//disable Layer which are out of scale
-	var validLayers = mb_checkScale(frameName, i, ii);
-	var layerNames = validLayers.toString();
-	var newMapURL = false;
-	var opacityString = "";
-	if (currentMapObject.layers[ii] !== "" && layerNames !== ''){
-		// get map URL
-		newMapURL = currentMapObject.getMapUrl(i, ii);
-		var currentOpacity = currentWms.gui_wms_mapopacity;
-		if (currentOpacity != 1) {
-			opacityString += "opacity:" + currentOpacity + "; ";
-			opacityString += "Filter: Alpha(Opacity=" + currentOpacity*100 + "); ";
-			opacityString += "-moz-opacity:" + currentOpacity + " ; ";
-			opacityString += "-khtml-opacity:" + currentOpacity;
-	var imageString = "<img id='"+myMapId+"' name='mapimage' ";
-	imageString += "src='" + newMapURL + "' ";
-	imageString += "width='"+currentMapObject.width+"' ";
-	imageString += "height='"+currentMapObject.height+"' ";
-	imageString += "border='0'>";
-	var newMapRequest = "<div id='"+myDivId+"' ";
-	newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
-	newMapRequest += "z-index:" + ii + ";" + opacityString + "\">";
-	newMapRequest += imageString;
-	newMapRequest += "</div>";
-	currentMapObject.mapURL[ii]= newMapURL;
-	currentWms.mapURL = newMapURL;
-	if (mb_log && currentWms.mapURL) {
-		var tmp = eval(mb_log + "('" +newMapURL + "','" + ts + "')");
-	return newMapRequest;
-function setSingleMapRequest(frameName,wms_id){
-	var functionName = 'setSingleMapRequest';
-	eventBeforeMapRequest.trigger({frameName:frameName});
-	for(i = 0; i < mb_mapObj.length; i++){
-			continue;
-		for (var ii=0; ii < currentMapObject.wms.length; ii++){
-			if (currentWms.wms_id != wms_id) {
-				continue;
-			var newMapRequest = getLayerHtmlCode(frameName, i, ii);
-			if (mb_log) {
-				var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
-			writeTag(currentMapObject.frameName, myDivId, newMapRequest);
-			eventAfterMapRequest.trigger({"frameName":frameName, "myMapId":myMapId});
-			return true;
-	return false;
-function mb_restateLayers(frameName,wms_id){
-	//alert(frameName + " / " + wms_id);
-	var ind = getMapObjIndexByName(frameName);
-	for(var i=0; i<mb_mapObj[ind].wms.length; i++){
-		if(mb_mapObj[ind].wms[i].wms_id == wms_id){
-			var layers = "";
-			var styles = "";
-			for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
-				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
-					if(cnt_layers > 0){layers += ","; styles += ","; }
-					layers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
-					//alert(mb_mapObj[ind].wms[i].objLayer[ii].layer_name);
-					styles += "";
-					cnt_layers++;
-				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
-					if(cnt_querylayers > 0){querylayers += ",";}
-					querylayers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
-					cnt_querylayers++;
-			mb_mapObj[ind].layers[i] = layers;
-			mb_mapObj[ind].querylayers[i] = querylayers;
-			mb_mapObj[ind].styles[i] = styles;
-function mb_checkScale(frameName,mObj,wmsObj){
-	var thisLayer = mb_mapObj[mObj].layers[wmsObj].split(",");
-	var thisScale = mb_getScale(frameName);
-	var str_layer = "";
-	var cnt_layer = 0;
-	for(var i=0; i<mb_mapObj[mObj].wms[wmsObj].objLayer.length; i++){
-		var myLayername = mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_name;
-		var myMinscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_minscale;
-		var myMaxscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_maxscale;
-		for(var ii=0; ii<thisLayer.length; ii++){
-			var minscaleOK = false;
-			var maxscaleOK = false;
-			if(thisLayer[ii] == myLayername){
-				if(myMinscale === 0 || thisScale >= myMinscale){minscaleOK = true;}
-				if(myMaxscale === 0 || thisScale <= myMaxscale){maxscaleOK = true;}
-				if(maxscaleOK === true && minscaleOK === true  && !mb_mapObj[mObj].wms[wmsObj].objLayer[i].has_childs){
-					if(cnt_layer > 0){str_layer += ","; }//str_styles += ","; str_titles += ",";str_parent += ","; str_legendurls += ",";}
-					str_layer += thisLayer[ii];
-					cnt_layer++;
-	var str_layerstyles = [];
-	str_layerstyles[0] = str_layer;
-	return str_layerstyles;
-function setFeatureInfoRequest(fName,x,y, path) {
-	var functionName = 'setFeatureInfoRequest';
-	eventBeforeFeatureInfo.trigger({"fName":fName});
-	for(var i=0; i<mb_FeatureInfoPreFunctions.length; i++){
-		eval(mb_FeatureInfoPreFunctions[i]);
-	var cnt_fi = 0;
-	for(i=0; i<mb_mapObj.length; i++){
-		if(mb_mapObj[i].frameName == fName){
-			for(var ii=0; ii<mb_mapObj[i].wms.length; ii++){
-				var newfeatureInfoRequest = "";
-				var requestParams = "";
-				var validation = false;
-				newfeatureInfoRequest += mb_mapObj[i].wms[ii].wms_getfeatureinfo;
-            	newfeatureInfoRequest += mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getfeatureinfo);
-				if(mb_mapObj[i].wms[ii].wms_version == "1.0.0"){requestParams += "WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=feature_info&";}
-				if(mb_mapObj[i].wms[ii].wms_version != "1.0.0"){requestParams += "VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetFeatureInfo&SERVICE=WMS&";}
-				requestParams += "SRS="+mb_mapObj[i].epsg+"&";
-				requestParams += "BBOX="+mb_mapObj[i].extent+"&";
-				requestParams += "WIDTH="+mb_mapObj[i].width+"&";
-				requestParams += "HEIGHT="+mb_mapObj[i].height+"&";
-				requestParams += "LAYERS="+mb_mapObj[i].layers[ii]+"&";
-				requestParams += "STYLES="+mb_mapObj[i].styles[ii]+"&";
-				requestParams += "FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";
-				requestParams += "INFO_FORMAT="+mb_mapObj[i].wms[ii].gui_wms_featureinfoformat+"&";
-				requestParams += "EXCEPTIONS=application/vnd.ogc.se_xml&";
-				if(mb_feature_count > 0){
-					requestParams += "FEATURE_COUNT="+mb_feature_count+"&";
-				requestParams += "QUERY_LAYERS="+mb_mapObj[i].querylayers[ii]+"&";
-				requestParams += "X=" + x  + "&";
-				requestParams += "Y=" + y;
-				if(mb_mapObj[i].querylayers[ii] !== "" && mb_mapObj[i].layers[ii] !== ""){
-					validation = true;
-				//add vendor-specific
-				for(var v=0; v < mb_vendorSpecific.length; v++){
-					var vendorSpecificString = eval(mb_vendorSpecific[v]);
-					requestParams += "&" + vendorSpecificString;
-				if(mb_log && validation){
-					var tmp = eval(mb_log + "('" + newfeatureInfoRequest + requestParams + "','" + ts + "')");
-				if(document.getElementById("FeatureInfoRedirect") && validation){
-					newfeatureInfoRequest += requestParams;
-					if(path){
-						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr;
-					else{
-						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = newfeatureInfoRequest;
-					cnt_fi++;
-				else if(path && validation){
-					try{
-						var p = new mb_popup("Feature Info","url:"+path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr,300,400);
-						p.show();
-					}catch(e){
-						window.open(path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
-					cnt_fi++;
-				else if(validation){
-					try{
-						var p = new mb_popup("Feature Info","url:"+newfeatureInfoRequest,300,400);
-						p.show();
-					catch(e){
-						window.open(newfeatureInfoRequest, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
-					cnt_fi++;
-   	if(cnt_fi === 0){
-		alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));
- * global function to zoom a mapobject
- * use: mb_mapObj.zoom() {@link mb_mapObj_const#zoom}
- * @deprecated
-function zoom(frameName,in_, factor,x,y) {
-	var obj = getMapObjByName(frameName);
-	if(x && y){
-		obj.zoom(in_, factor, x, y);
-	else{
-		obj.zoom(in_, factor, false, false);
-	setMapRequest(frameName);
-function mb_panMap(frameName,dir){
-   var arrayBBox = mb_mapObj[ind].extent.split(",");
-   var minx = parseFloat(arrayBBox[0]);
-   var miny = parseFloat(arrayBBox[1]);
-   var maxx = parseFloat(arrayBBox[2]);
-   var maxy = parseFloat(arrayBBox[3]);
-   var xtentx = parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]);
-   var xtenty =  parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]);
-   if(dir == "NW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "N"){miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "NE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "W"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2);}
-   if(dir == "E"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2);}
-   if(dir == "SW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-   if(dir == "S"){miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-   if(dir == "SE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-  mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
-function handleSelectedLayer (frameName, wms_title, layerName, type, status) {
-//	alert(frameName + " , " +wms_title + " , " +layerName + " , " +type + " , " +status);
-//	type = {visible || querylayer] status = {0 || 1}
-	for (var i=0; i < mb_mapObj.length; i++) {
-		if (mb_mapObj[i].frameName == frameName) {
-			var myMapObj = i;
-			for (var ii = 0; ii < mb_mapObj[i].wms.length; ii++) {
-				if (mb_mapObj[i].wms[ii].wms_title == wms_title) { //ii is true
-					var myWMS = ii;
-					if (type == "visible") {
-						var arrayLayer = mb_mapObj[i].layers[ii].split(",");
-					if (type == "querylayer") {
-						var arrayLayer = mb_mapObj[i].querylayers[ii].split(",");
-					for (var iii = 1; iii < mb_mapObj[i].wms[ii].objLayer.length; iii++) {
-						var layer_name = mb_mapObj[i].wms[ii].objLayer[iii].layer_name;
-							if (layer_name == layerName && status == 1 && mb_mapObj[i].wms[ii].objLayer[iii].layer_queryable == 1){
-								if (cnt_layer > 0) {
-									str_layer += ",";
-								str_layer += layer_name;
-								cnt_layer++;
-						else if (type == "visible") {
-							if (layer_name == layerName && status == 1) {
-									str_layer += ",";
-								cnt_layer++;
-						for (var iiii = 0; iiii < arrayLayer.length; iiii++) {
-							if (layer_name == arrayLayer[iiii] && layer_name != layerName) {
-									str_layer += ",";
-								cnt_layer++;
-		mb_mapObj[myMapObj].layers[myWMS] = str_layer;
-		var array_str_layer = str_layer.split(",");
-		var str_styles = "";
-		for (var cnt=0; cnt < array_str_layer.length; cnt++) {
-			if (cnt > 0) {
-				str_styles += ",";
-			str_styles += "";
-		mb_mapObj[myMapObj].styles[myWMS] = str_styles;
-		mb_mapObj[myMapObj].querylayers[myWMS] = str_layer;
-	if(type == 'visible'){
-		setSingleMapRequest(frameName,wms_title);
-function handleSelectedLayer_array(mapObj, array_wms, array_layer, type, status){
-	//alert(mapObj+" / "+array_wms[0]+" / "+ array_layer[0]+" / "+ type+" / "+ status);
-	var ind = getMapObjIndexByName(mapObj);
-	for(var j=0; j<array_wms.length; j++){
-			if(mb_mapObj[ind].wms[i].wms_id == array_wms[j]){
-				var check = false;
-					if(mb_mapObj[ind].wms[i].wms_id == array_wms[j] && mb_mapObj[ind].wms[i].objLayer[ii].layer_name == array_layer[j]){
-						if(type == "visible"){
-							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible = parseInt(status, 10);
-							check = true;
-                        if(type == "querylayer" && (mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == "1" || mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == 1)){
-							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer = parseInt(status, 10);
-                mb_restateLayers(mapObj, array_wms[j]);
-                //alert('restate');
-                * hier noch checken, welche wms sich geaendert haben und disctinct eine singleRequest aufrufen:
-                if(check === true){
-                    if(mb_mapObj[ind].wms[i].gui_wms_visible == 1){
-						setSingleMapRequest(mapObj,mb_mapObj[ind].wms[i].wms_id);
-                        //alert('sSMR');
-function makeClickPos2RealWorldPos(frameName, myClickX, myClickY) {
-	var width = parseInt(mb_mapObj[ind].width, 10);
-	var height = parseInt(mb_mapObj[ind].height, 10);
-	var minX = parseFloat(arrayBBox[0]);
-	var minY = parseFloat(arrayBBox[1]);
-	var maxX = parseFloat(arrayBBox[2]);
-	var maxY = parseFloat(arrayBBox[3]);
-	var deltaX = (maxX - minX)/width;
-	var deltaY = (maxY - minY)/height;
-	if(deltaX > 0){
-		var roundx = 1/Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
-	else{
-		var roundx =  Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
-	if(deltaY > 0){
-		var roundy = 1/Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
-	else{
-		var roundy =  Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
-	var xtentx = maxX - minX;
-	var xtenty =  maxY - minY;
-	var posX = parseFloat(minX + (myClickX / width) * xtentx);
-	var posY = parseFloat(maxY - (myClickY / height) * xtenty);
-	posX = Math.round(posX * roundx)/roundx;
-	posY = Math.round(posY * roundy)/roundy;
-	return [posX, posY];
-function makeRealWorld2mapPos(frameName,rw_posx, rw_posy){
-   var mpObj = mb_mapObj[ind];
-   var arrayBBox = mpObj.extent.split(",");
-   return [Math.round((rw_posx - minX)*mpObj.width/(maxX - minX)), Math.round((maxY - rw_posy)*mpObj.height/(maxY - minY))];
-function mb_arrangeElement(frameName, elName, left, top) {
-   if(frameName !== ""){
-      window.frames[frameName].document.getElementById(elName).style.top = top;
-      window.frames[frameName].document.getElementById(elName).style.left = left;
-   else{
-      document.getElementById(elName).style.top = top;
-      document.getElementById(elName).style.left = left;
-/***********************Drag & Drop***********************/
-function mb_getMousePos(e,fName){
-if(fName){
-     if(ie){
-        clickX = window.frames[fName].event.clientX;
-        clickY = window.frames[fName].event.clientY;
-     else{
-        clickX = e.pageX;
-        clickY = e.pageY;
-  else{
-       if(ie){
-        clickX = event.clientX;
-        clickY = event.clientY;
-     else{
-        clickX = e.pageX;
-        clickY = e.pageY;
-  var pos = [clickX,clickY];
-  return pos;
-// function for object-identification
-function getMapObjIndexByName(frameName){
-		if(mb_mapObj[i].frameName == frameName){
-			return i;
-function getMapObjByName(frameName){
-			return mb_mapObj[i];
-	return false;
-function mb_getLayerTitleByName(map_index, wms_index, myLayer_name){
-	for(var i=0; i<mb_mapObj[map_index].wms[wms_index].objLayer.length; i++){
-		if(mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_name == myLayer_name){
-			return mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_title;
-function getWMSIDByTitle(frameName,wms_title){
-   for(var i=0; i< mb_mapObj[ind].wms.length; i++){
-      if(mb_mapObj[ind].wms[i].wms_title == wms_title){
-         //return i;
-         return mb_mapObj[ind].wms[i].wms_id;
-function getWMSIndexByTitle(frameName,wms_title){
-         return i;
-function getWMSIndexById(frameName,wms_id){
-         return i;
-//scale
-function mb_getScale(frameName) {
-	var myScale = eventBeforeGetScale.trigger({"frameName":frameName});
-   for(var i=0; i<mb_GetScalePreFunctions.length; i++){
-		var myScale = eval(mb_GetScalePreFunctions[i]);
-   if(typeof(myScale) == "number"){
-      var Y_str = myScale;
-   else{
-      var scaleY = (xtenty / mb_mapObj[ind].height) *(mb_resolution * 100);
-      if (scaleY<1){
-      	var Y_str = scaleY;
-      }else{
-      	var Y_str = Math.round(scaleY);
-   return Y_str;
-function mb_repaintScale(frameName, x, y, scale){
-   if(x === null && y === null){
-      x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
-      y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
-   var minx = parseFloat(x) - (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
-   var miny = parseFloat(y) -  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
-   var maxx = parseFloat(x) + (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
-   var maxy = parseFloat(y) +  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
-   mb_repaint(frameName,minx, miny, maxx, maxy);
-function mb_repaint(frameName,minx,miny,maxx,maxy){
- * converts the extent of the mapobject so that the maximum	extent will be displayed {@link mb_mapObj_const#calculateExtent}
- * use: mb_mapObj.calculateExtent
- * @deprecated
-function mb_calculateExtent(frameName,minx,miny,maxx,maxy){
-  var map = getMapObjByName(frameName);
-  var extent = new Extent(minx,miny,maxx,maxy);
-  map.calculateExtent(extent);
- * @class extent
- * @param {float} minx
- * @param {float} miny
- * @param {float} maxx
- * @param {float} maxy
- * @return the extent as object
- * @type Object
-function Extent(minx,miny,maxx,maxy){
-	this.minx = parseFloat(minx);
-	this.miny = parseFloat(miny);
-	this.maxx = parseFloat(maxx);
-	this.maxy = parseFloat(maxy);
-	this.extentx = this.maxx - this.minx;
-	this.extenty = this.maxy - this.miny;
-	this.centerx = this.minx + this.extentx/2;
-	this.centery = this.miny + this.extenty/2;
-	return this;
-function mb_showHighlight(frameName,x,y){
-   var pos = makeRealWorld2mapPos(frameName,x, y);
-   mb_arrangeElement(frameName,"highlight",pos[0]-7, pos[1]-7);
-   window.frames[frameName].document.getElementById("highlight").style.visibility = 'visible';
-function mb_hideHighlight(frameName){
-   mb_arrangeElement(frameName,"highlight",-20, -20);
-   window.frames[frameName].document.getElementById("highlight").style.visibility = 'hidden';
-function mb_permanentHighlight(frameName,x,y){
-   mb_arrangeElement(frameName,"permanent",pos[0]-7, pos[1]-7);
-   window.frames[frameName].document.getElementById("permanent").style.visibility = 'visible';
-// framename, commaseparated coordinates, commaseparated rgb values (color)
-//new: coords is array!
-function mb_markResult(frameName,geom,col){
-	var x = "";
-	var y = "";
-	var tmp = [];
-	for(var i=0; i < geom.length; i++){
-		if(i > 0){
-			x += ":";
-			y += ":";
-		tmp = geom[i].split(",");
-		for(var ii=0; ii < tmp.length; ii+=2){
-			var pos = makeRealWorld2mapPos(frameName,tmp[ii], tmp[ii+1]);
-			if(ii>0){
-				x += ",";
-				y += ",";
-			x += pos[0];
-			y += pos[1];
-	var source = "<img src='../extensions/markResult.php?x=" + x + "&y=" + y + "&width=" + mb_mapObj[ind].width + "&height=" + mb_mapObj[ind].height + "&color="+col+"'>";
-	//prompt("",source);
-	writeTag(frameName,"markResult",source);
-function mb_disableResult(frameName){
-   writeTag(frameName,"markResult","");
-function mb_registerGML(frameName,obj){
-	mb_mapObj[ind].geom = obj;
-function mb_timestamp(){
-	var d = new Date();
-	var ts = Math.round(Date.parse(d)/1000);
-	return ts;
-function mb_getlayerposbyname(objInd,wmsInd,lname){
-	var t = mb_mapObj[objInd].wms[wmsInd];
-	for(var i=0; i < t.objLayer.length; i++){
-		if(t.objLayer[i].layer_name == lname){
-			return t.objLayer[i].layer_pos;
-function mb_getLayerObjByName(fname,wms_id,layer_name){
-	var ind = getMapObjIndexByName(fname);
-	var wmsInd = getWMSIndexById(fname,wms_id);
-	var t = mb_mapObj[ind].wms[wmsInd];
-		if(t.objLayer[i].layer_name == layer_name){
-			return t.objLayer[i];
-function mb_getchildsbyname(objInd,wmsInd,lname){
-	var pos = mb_getlayerposbyname(objInd, wmsInd,lname);
-	var l = [];
-	l.name = [];
-	l.title = [];
-	l.legendurl = [];
-		if(t.objLayer[i].layer_parent == pos){
-			l.name[l.name.length] = t.objLayer[i].layer_name;
-			l.title[l.title.length] = t.objLayer[i].layer_title;
-			if(t.objLayer[i].layer_style.length>0){
-				l.legendurl[l.legendurl.length] = t.objLayer[i].layer_style[0].legendurl;
-			}else{
-				l.legendurl[l.legendurl.length] = 0 ;
-	if(l.name.length > 0){
-		return l;
-	else{
-		return false;
- *   button handling
-var mb_button = [];
-function mb_regButton_frame(wii, frameName, param){
-	var ind = mb_button.length;
-	mb_button[ind] = new mb_conButton(wii, ind);
-	if (frameName === null) {
-		if (param === null) {
-			eval(wii+"("+ind+")");
-		else {
-			eval(wii+"("+ind+", "+param+")");
-	else if (param === null) {
-		eval("window.frames['" + frameName + "']."+wii+"("+ind+")");
-	else {
-		eval("window.frames['" + frameName + "']."+wii+"("+ind+", "+param+")");
-	mb_button[ind].prev = mb_button[ind].src;
-	mb_button[ind].src = mb_button[ind].img_off;
-	mb_button[ind].onmouseover = function () {
-		mb_button_over(ind);
-	mb_button[ind].onmouseout = function(){
-		mb_button_out(ind);
-	mb_button[ind].onclick = function(){
-		mb_button_click(ind);
-		mb_button[ind].frameName = "";
-	else {
-		mb_button[ind].frameName = frameName;
-function mb_regButton(wii){
-	mb_regButton_frame(wii, null, null);
-function mb_conButton(wii, ind){
-   this.wii = wii;
-   return true;
-function mb_button_over(ind){
-   if(mb_button[ind].status === 0){
-      mb_button[ind].src = mb_button[ind].img_over;
-function mb_button_out(ind){
-   mb_button[ind].src = mb_button[ind].prev;
-function mb_button_click(ind){
-   var mbStatus = mb_button[ind].status;
-   if(mbStatus === 0){
-      mb_disableButton(mb_button[ind].elName);
-      mb_button[ind].prev = mb_button[ind].img_on;
-      mb_button[ind].src = mb_button[ind].img_on;
-      mb_button[ind].status = 1;
-      if (mb_button[ind].frameName !== "") {
-          window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).go();
-      else {
-	      document.getElementById(mb_button[ind].elName).go();
-   else{
-      mb_button[ind].prev = mb_button[ind].img_off;
-      mb_button[ind].status = 0;
-          window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).stop();
-      else {
-	      document.getElementById(mb_button[ind].elName).stop();
-function mb_disableButton(elName){
-   for(var i=0; i<mb_button.length; i++){
-      if(mb_button[i].elName != elName && mb_button[i].status == 1){
-            mb_button[i].status = 0;
-		      if (mb_button[i].frameName !== "") {
-    	        window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).src = mb_button[i].img_off;
-	            window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).stop();
-		      else {
-    	        document.getElementById(mb_button[i].elName).src = mb_button[i].img_off;
-	            document.getElementById(mb_button[i].elName).stop();
-            return true;
-function mb_disableThisButton(elName){
-      if(mb_button[i].elName == elName && mb_button[i].status == 1){
-      		//alert(mb_button[i].elName);
-		      else {
-            return true;
-function updateButtonTooltips(obj) {
- * the buttons are only initialized on mouseover!
- * So when localizing, not all buttons may have been registered
-//		console.log("button %i", i);
-		for(var j=0; j<obj.length; j++){
-			if (mb_button[i].elName == obj[j].id) {
-//			console.log("%s %s", mb_button[i].elName, obj[j].id);
-					window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).title = obj[j].title;
-				else {
-					document.getElementById(mb_button[i].elName).title = obj[j].title;
-	// an alternative, fixes above error,
-	// but this one only changes those in the main frame
-	var imageArray = document.getElementsByTagName("img");
-	for (var i = 0; i < imageArray.length; i++) {
-			if (imageArray[i].id == obj[j].id) {
-				document.getElementById(imageArray[i].id).title = obj[j].title;
-function mb_localizeButtons(){
-	mb_ajax_json("../php/mod_button_tooltips.php", function(obj, status){
-		updateButtonTooltips(obj);
-eventLocalize.register(function () {
-	mb_localizeButtons();
-eventInit.register(function () {
- *   miscellaneous functions
-function cloneObject(obj) {
-    if (typeof obj !== 'object' || obj === null) {
-        return obj;
-    var c = obj instanceof Array ? [] : {};
-    for (var i in obj) {
-        var prop = obj[i];
-        if (typeof prop == 'object') {
-           if (prop instanceof Array) {
-               c[i] = [];
-               for (var j = 0; j < prop.length; j++) {
-                   if (typeof prop[j] != 'object') {
-                       c[i].push(prop[j]);
-                   } else {
-                       c[i].push(cloneObject(prop[j]));
-           } else {
-               c[i] = cloneObject(prop);
-        } else {
-           c[i] = prop;
-    return c;
- *   deprecated functions
-// only used in mod_perimeter.php
-// previously used in mod_initWmc.php, mod_digitize_tab.php, mod_geometryArray.js
-function mb_checkTag(frameName, tagName, elementId, appendAtTagName, attributes){
-	var oldElement;
-	var newElement;
-	var prefix;
-	if(frameName && frameName !== ""){
-		prefix = window.frames[frameName].document;
-	else if(!frameName || frameName === ""){
-		prefix = document;
-	oldElement = prefix.getElementById(elementId);
-	if (oldElement === null) {
-		newElement = prefix.createElement(tagName);
-		newElement = prefix.getElementsByTagName(appendAtTagName)[0].appendChild(newElement);
-	else {
-		if (oldElement.nodeName.toLowerCase() == tagName.toLowerCase()) {
-			for (var i=0; i<attributes.length; i++) {
-				oldElement.setAttribute(attributes[i][0], attributes[i][1]);
-			return oldElement;
-		else {
-			return false;
-	var newElementAttributeNode = document.createAttribute("id");
-	newElementAttributeNode.value = elementId;
-	newElement.setAttributeNode(newElementAttributeNode);
-		newElement.setAttribute(attributes[i][0], attributes[i][1]);
-	return newElement;
\ No newline at end of file
Deleted: trunk/mapbender/lib/map_obj.js
--- trunk/mapbender/lib/map_obj.js	2008-06-23 16:16:52 UTC (rev 2545)
+++ trunk/mapbender/lib/map_obj.js	2008-06-23 16:20:25 UTC (rev 2546)
@@ -1,402 +0,0 @@
-* $Id: map_obj.js 2452 2008-05-15 09:02:56Z christoph $
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-function mb_mapObj_const(frameName, elementName, width, height, wms_index){
-	this.width = width;
-	this.height = height;
-	this.frameName = frameName;
-	this.elementName = elementName;
-	this.layers = [];
-	this.styles = [];
-	this.querylayers = [];
-	this.geom = "";
-	this.gml = "";
-	this.wms = [];
-	// Add pointers to WMS objects which are in this map.
-	// If wms_index is set (=map is overview), only this
-	// WMS is being pointed to.
-	var index = 0;
-	for(var i=0; i < wms.length; i++){
-		var isValidWms = (wms_index === null) || (wms_index == i);
-		if (isValidWms) {
-			this.wms[index] = wms[i];
-			this.wms[index].mapURL = false;
-			index++;
-	// set list of visible layers, active querylayers
-	// and styles for each WMS in this map
-	var cnt_layers;
-	var cnt_querylayers;
-	var styles;
-	var layers;
-	for(i=0; i< this.wms.length; i++){
-		cnt_layers = 0;
-		cnt_querylayers = 0;
-		styles = "";
-		layers = "";
-		querylayers = "";
-		for(var ii=0; ii<this.wms[i].objLayer.length; ii++){
-			// layer is visible and not root layer
-			if(this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii>0){
-					layers += ","; styles += ",";
-				layers += wms[i].objLayer[ii].layer_name;
-				styles += "";
-				cnt_layers++;
-			// layer is queryable and not root layer
-			if(this.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii>0){
-					querylayers += ",";
-				querylayers += wms[i].objLayer[ii].layer_name;
-		this.layers[i] = layers;
-		this.styles[i] = styles;
-		this.querylayers[i] = querylayers;
-	this.epsg = wms[0].gui_wms_epsg;
-	this.extent = setExtent(this.width,this.height,this.epsg);
-	this.mapURL = [];
-	var styleTag = window.frames[this.frameName].document.getElementById(this.elementName).style;
-	styleTag.width = this.width;
-	styleTag.height = this.height;
-	 * get the width of the mapObj
-	 * @member mb_mapObj_const
-	 * @return width of the mapObj
-	 * @type integer
-	this.getWidth = function(){
-		return parseInt(this.width, 10);
-	 * set the width of the mapObj
-	 * @param {integer} widht the width of the mapObj
-	this.setWidth = function(width){
-		this.width = parseInt(width, 10);
-	 * get the height of the mapObj
-	 * @type integer
-	this.getHeight = function(){
-		return parseInt(this.height, 10);
-	 * set the height of the mapObj
-	 * @param {integer} height the height of the mapObj
-	this.setHeight = function(height){
-		this.height = parseInt(height, 10);
-	 * get the extent of the mapObj
-	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
-	 * @type string
-	this.getExtent = function(){
-		return this.extent;
-	 * get the extent as minx, maxx, miny, maxy
-	 * @return extent and additional informations of the mapObj
-	 * @type Object
-	this.getExtentInfos = function(){
-		var c = this.getExtent().split(",");
-		var ext = new Extent(c[0],c[1],c[2],c[3]);
-		return ext;
-	this.calculateExtent = function(ext){
-		var relation_px_x = this.getWidth() / this.getHeight();
-		var relation_px_y = this.getHeight() / this.getWidth();
-		var relation_bbox_x = ext.extentx / ext.extenty;
-			ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
-			ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
-			ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
-			ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
-		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
-	 * zoom the map with a zoomfactor and optional to x,y coords
-	 * @param {boolean} in_ in = true, out = false
-	 * @param {float} factor the zoomfactor 1 equals 100%
-	 * @param {float} x center to x-position
-	 * @param {float} y center to y-position
-	 this.zoom = function(in_, factor, x, y){
-		factor = parseFloat(factor);
-		if (!in_) {
-			factor = 1 / factor;
-		var extent = this.getExtentInfos();
-		var distx = extent.maxx - extent.minx;
-		var disty =  extent.maxy - extent.miny;
-		if(x && y){
-			var centerx = parseFloat(x);
-			var centery = parseFloat(y);
-		else{
-			var centerx = extent.minx + distx/2;
-			var centery = extent.miny + disty/2;
-		var new_distx = distx / factor;
-		var new_disty = disty / factor;
-		var minx = centerx - new_distx / 2;
-		var miny = centery - new_disty / 2;
-		var maxx = centerx + new_distx / 2;
-		var maxy = centery + new_disty / 2;
-		this.setExtent(minx,miny,maxx,maxy);
-		//Todo:
-		//setMapRequest!
-	 * set the extent of the wms
-	 this.setExtent = function(minx,miny,maxx,maxy){
-	 	this.extent = String(minx)+","+String(miny)+","+String(maxx)+","+String(maxy);
-	 * get the srs of the mapObj
-	 * @return srs as epsg:number
-	 * @type string
-	this.getSRS = function(){
-		return this.epsg;
-	 * get all mapRequests
-	 * @return array of mapRequests of this map object
-	 * @type string[]
-	this.getMapRequests = function(){
-		var allRequests = [];
-		//loop through all wms to get the mapRequests
-		for(var i=0; i<this.wms.length; i++){
-			var currentRequest = this.wms[i].getMapRequest(this);
-			if(currentRequest){
-				allRequests.push(currentRequest);
-		if(allRequests.length > 0){
-			return allRequests;
-		return false;
-	 * Return the map URL of the WMS at index i
-	 * @param {Object} currentWmsIndex
-	this.getMapUrl = function (i, ii) {
-		var currentWms = this.wms[ii];
-		var validLayers = currentWms.getLayers(this);
-		var layerNames = validLayers.join(",");
-		url = currentWms.wms_getmap;
-		url += mb_getConjunctionCharacter(currentWms.wms_getmap);
-		if (currentWms.wms_version == "1.0.0") {
-			url += "WMTVER=" + currentWms.wms_version + "&REQUEST=map&";
-		else {
-			url += "VERSION=" + currentWms.wms_version + "&REQUEST=GetMap&SERVICE=WMS&";
-		url += "LAYERS=" + layerNames + "&";
-		url += "STYLES=";
-		var layer = layerNames.split(",");
-		for (var j = 0; j < layer.length; j++){
-			if (j > 0) {
-				url  += ",";
-			if (currentWms.getCurrentStyleByLayerName(layer[j]) !== false) {
-				url += currentWms.getCurrentStyleByLayerName(layer[j]);
-		url += "&";
-		url += "SRS=" + this.epsg + "&";
-		url += "BBOX=" + this.extent + "&";
-		url += "WIDTH=" + this.width + "&";
-		url += "HEIGHT=" + this.height + "&";
-		url += "FORMAT=" + currentWms.gui_wms_mapformat + "&";
-		url += "BGCOLOR=0xffffff&";
-		if (currentWms.gui_wms_mapformat.search(/gif/i)>-1 ||
-			currentWms.gui_wms_mapformat.search(/png/i)>-1) {
-				url += "TRANSPARENT=TRUE&";
-		url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
-		// add vendor-specific
-		for (var v = 0; v < mb_vendorSpecific.length; v++) {
-			// if eval doesn't evaluate a function, the result is undefined.
-			// Sometimes it is necessary not to evaluate a function, for
-			// example if you want to change a variable from the current
-			// scope (see mod_addSLD.php)
-			if (typeof(vendorSpecificString) != "undefined") {
-				url += vendorSpecificString + "&";
-		// add Filter
-		if (currentWms.wms_filter){
-			url += "&SLD=" + currentWms.wms_filter +"?id="+ mb_styleID + "&";
-		// add sld
-		if(currentWms.gui_wms_sldurl){
-			url += "&SLD=" + escape(currentWms.gui_wms_sldurl) + "&";
-		return url;
-	 * get all featureInfoRequests
-	 * @param float x the x-value of the click position in pixel
-	 * @param float y the y-value of the click position in pixel
-	 * @return array of all featureInfoRequests of this map object
-	 * @type string[]
-	this.getFeatureInfoRequests = function(clickPoint){
-		//loop through all wms to get the FeatureInfoRequests
-			var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
-		return false;
-	 * calculation of the mapscale
-	 * @return scale
-	 * @type integer
-	this.getScale = function(){
-		var scale;
-		var bbox = this.extent.split(",");
-		var xtenty;
-		if(this.epsg=="EPSG:4326"){
-			var pxLenx = (parseFloat(bbox[2])-parseFloat(bbox[0]))/this.width;
-			var pxLeny = (parseFloat(bbox[3])-parseFloat(bbox[1]))/this.height;
-			var lat_from = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2)*Math.PI)/180;
-			var lat_to = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2+pxLeny)*Math.PI)/180;
-			var lon_from = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2)*Math.PI)/180;
-			var lon_to = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2+pxLeny)*Math.PI)/180;
-			var dist=6371229*Math.acos(Math.sin(lat_from)*Math.sin(lat_to)+Math.cos(lat_from)*Math.cos(lat_to)*Math.cos(lon_from-lon_to));
-			scale = (dist/Math.SQRT2) * (mb_resolution * 100);
-		}else{
-			xtenty =  parseFloat(bbox[3]) - parseFloat(bbox[1]);
-			scale = (xtenty / this.height) * (mb_resolution * 100);
-		return Math.round(scale);
-	 * move a wms or layer
-	 * @param int wms_id id of wms to move
-	 * @param int layer_id id of layer to move
-	 * @return true of successful
-	 * @type boolean
-	this.move = function(wms_id, layer_id, moveUp){
-		var i,j;
-		for(i=0;i<this.wms.length;i++){
-			if (wms_id == this.wms[i].wms_id) {
-				break;
-		//check if only one wms is affected?
-		if (layer_id && layer_id != this.wms[i].objLayer[0].layer_id) {
-			return this.wms[i].moveLayer(layer_id, moveUp);
-		//else swap wms
-		j = i + (moveUp?-1:1);
-		if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length)) {
-			return false;
-		upper = this.wms[i];
-		this.wms[i] = this.wms[j];
-		this.wms[j] = upper;
-		var upperLayers = this.layers[i];
-		var upperStyles = this.styles[i];
-		var upperQuerylayers = this.querylayers[i];
-		this.layers[i] = this.layers[j];
-		this.styles[i] = this.styles[j];
-		this.querylayers[i] = this.querylayers[j];
-		this.layers[j] = upperLayers;
-		this.styles[j] = upperStyles;
-		this.querylayers[j] = upperQuerylayers;
-		return true;
-	eventAfterMapObjectConstruction.trigger();
Deleted: trunk/mapbender/lib/wfs_obj.js
--- trunk/mapbender/lib/wfs_obj.js	2008-06-23 16:16:52 UTC (rev 2545)
+++ trunk/mapbender/lib/wfs_obj.js	2008-06-23 16:20:25 UTC (rev 2546)
@@ -1,75 +0,0 @@
-//$Id:wfs_obj.js 2476 2008-05-28 15:03:41Z christoph $
-//$Header: /cvsroot/mapbender/mapbender/http/javascripts/wfs_obj.js,v 1.3 2005/09/13 14:38:11 bjoern_heuser Exp $
-//global variables
-var wfs = [];
-var wfs_featuretype_count = 0;
-var wfs_element_count = 0;
-//list of all wms-objects
-function add_wfs(
-			wfs_id,
-			wfs_version,
-			wfs_title,
-			wfs_abstract,
-			wfs_getcapabilities,
-			wfs_describefeaturetype){
-					wfs[wfs.length] = new wfs_const(
-					wfs_id,
-			      wfs_version,
-			      wfs_title,
-			      wfs_abstract,
-			      wfs_describefeaturetype);
-					//wfs_featuretype[wfs.length - 1] = [];
-//the wms constructor
-function wfs_const(
-			wfs_id,
-			wfs_version,
-			wfs_title,
-			wfs_abstract,
-	this.wfs_id = wfs_id;
-	this.wfs_version = wfs_version;
-	this.wfs_title = wfs_title;
-	this.wfs_abstract = wfs_abstract;
-	this.wfs_getcapabilities = wfs_getcapabilities;
-	this.wfs_describefeaturetype = wfs_describefeaturetype;
-	this.wfs_featuretype = [];
-   //alert(wfs_id + " , " +wfs_title + " , " +wfs_abstract + " , " +wfs_getcapabilities + " , " +wfs_describefeaturetype);
-//featuretype
-function wfs_add_featuretype(
-			featuretype_name,
-			featuretype_title,
-			featuretype_srs,
-			featuretype_geomtype){
-	      wfs[wfs.length-1].wfs_featuretype[wfs[wfs.length-1].wfs_featuretype.length] = new featuretype(
-											featuretype_name,
-											featuretype_srs,
-											featuretype_geomtype);
-//alert(featuretype_name + " , " +featuretype_title + " , " +featuretype_srs + " , " +featuretype_geomtype);
-function featuretype(
-			featuretype_name,
-			featuretype_srs,
-	this.featuretype_name = featuretype_name;
-	this.featuretype_title = featuretype_title;
-	this.featuretype_srs = featuretype_srs;
-	this.featuretype_geomtype = featuretype_geomtype;
-	this.element = [];
-	wfs_featuretype_count++;
-//elements
-function wfs_add_featuretype_element(element_name, element_type, element_count, featuretype_count){
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count] = [];
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].name = element_name;
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].type = element_type;
-   //alert(element_name +" , "+element_type);
Deleted: trunk/mapbender/lib/wms.js
--- trunk/mapbender/lib/wms.js	2008-06-23 16:16:52 UTC (rev 2545)
+++ trunk/mapbender/lib/wms.js	2008-06-23 16:20:25 UTC (rev 2546)
@@ -1,777 +0,0 @@
- * $Id: map_obj.js 2413 2008-04-23 16:21:04Z christoph $
- * COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
- * License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-//global variables
-var wms = [];
-var wms_layer_count = 0;
- * global function to add wms to the wms-object
- * @param {String} wms_id the unique id of the wms
- * @param {String} wms_version the version assumed from capabilities
- * @param {String} wms_title the title of the wms
- * @param {String} wms_abstract the abstract of the wms
- * @param {String} wms_getmap the url for map requests
- * @param {String} wms_getfeatureinfo the url for featureInof requests
- * @param {String} wms_getlegendurl the url for legend requests
- * @param {String} wms_filter a filter (deprecated)
- * @param {String} gui_wms_mapformat the image-format in the actual gui
- * @param {String} gui_wms_featureinfoformat the current format for featureInfos
- * @param {String} gui_wms_exceptionformat the exceptionformat for map requests
- * @param {String} gui_wms_epsg the current srs
- * @param {Integer} gui_wms_visible the visibility of this service
- * @param {Integer} gui_wms_opacity the initial display opacity in percent
- * @param {String} gui_wms_sldurl url to an actual sld
-function add_wms(
-			wms_id,
-			wms_version,
-			wms_title,
-			wms_abstract,
-			wms_getmap,
-			wms_getfeatureinfo,
-			wms_getlegendurl,
-			wms_filter,
-			gui_wms_mapformat,
-			gui_wms_featureinfoformat,
-			gui_wms_exceptionformat,
-			gui_wms_epsg,
-			gui_wms_visible,
-			gui_wms_opacity,
-			gui_wms_sldurl){
-					wms[wms.length] = new wms_const(
-					wms_id,
-					wms_version,
-					wms_title,
-					wms_abstract,
-					wms_getmap,
-					wms_getlegendurl,
-					wms_filter,
-					gui_wms_epsg,
-					parseInt(gui_wms_visible, 10),
-					parseInt(gui_wms_opacity),
-					gui_wms_sldurl);
-					wms_layer[wms.length - 1] = [];
- * @class A class representing the wms
- * @constructor
- * @param {String} gui_wms_visible the visibility of this service
-function wms_const(
-			wms_id,
-			wms_version,
-			wms_title,
-			wms_abstract,
-			wms_getmap,
-		    wms_getlegendurl,
-			wms_filter,
-			gui_wms_epsg,
-			gui_wms_visible,
-			gui_wms_opacity,
-			gui_wms_sldurl){
-	if (!wms_id) {
-		var id_ok = false;
-		while (id_ok === false) {
-			wms_id = "a"+Math.round(10000*Math.random());
-			id_ok = true;
-			for (var i=0; i < wms.length && id_ok === true; i++) {
-				if (wms_id == wms[i].wms_id) {
-					id_ok = false;
-	this.wms_id = wms_id;
-	this.wms_version = wms_version;
-	this.wms_title = wms_title;
-	this.wms_abstract = wms_abstract;
-	this.wms_getmap = wms_getmap;
-	this.wms_getfeatureinfo = wms_getfeatureinfo;
-	this.wms_getlegendurl = wms_getlegendurl;
-	this.wms_filter = wms_filter;
-	this.data_type = [];
-	this.data_format = [];
-	this.objLayer = [];
-	this.gui_wms_mapformat = gui_wms_mapformat;
-	this.gui_wms_featureinfoformat = gui_wms_featureinfoformat;
-	this.gui_wms_exceptionformat = gui_wms_exceptionformat;
-	this.gui_wms_epsg = gui_wms_epsg;
-	this.gui_wms_visible = gui_wms_visible;
-	this.gui_epsg = [];
-	this.gui_minx = [];
-	this.gui_miny = [];
-	this.gui_maxx = [];
-	this.gui_maxy = [];
-	// opacity version
-	this.gui_wms_mapopacity = gui_wms_opacity/100;
-	// sld version
-	this.gui_wms_sldurl = gui_wms_sldurl;
- * rephrases the mapRequest
- * @param {Object} mapObj the mapbender mapObject of the wms
- * @return mapRequest, i.e. onlineresource + params
- * @type String
-wms_const.prototype.getMapRequest = function(mapObj){
-	//check visible layers first
-	var layers = this.getLayers(mapObj);
-	if(!layers){
-		return false;
-	var rq = this.wms_getmap;
-	rq += mb_getConjunctionCharacter(this.wms_getmap);
-	if(this.wms_version === "1.0.0"){
-		rq += "WMTVER=" + this.wms_version + "&REQUEST=map";
-	else{
-		rq += "VERSION=" + this.wms_version + "&REQUEST=getMap&SERVICE=WMS";
-	rq += "&LAYERS=" + layers.join(",");
-	rq += "&WIDTH=" + mapObj.getWidth();
-	rq += "&HEIGHT=" + mapObj.getHeight();
-	rq += "&SRS=" + mapObj.getSRS();
-	rq += "&BBOX=" + mapObj.getExtent();
-	rq += "&STYLES=" + this.getLayerstyles(mapObj).join(",");
-	rq += "&FORMAT=" + this.gui_wms_mapformat;
-	rq += "&EXCEPTIONS=" + this.gui_wms_exceptionformat;
-	//Todo: error occurs:
-	//var throwNotice = new Mb_notice("getMapRequest: " + rq);
-	//window.console.log("getMapRequest: " + rq);
-	return rq;
- * rephrases the featureInfoRequest
- * @param {Point} clickPoint map-click position {@link Point}
- * @return featureInfoRequest, onlineresource + params
- * @type string
-wms_const.prototype.getFeatureInfoRequest = function(mapObj, clickPoint){
-	//check layers and querylayers first
-	var querylayers = this.getQuerylayers(mapObj);
-	if(!layers || !querylayers){
-		return false;
-	var rq = this.wms_getfeatureinfo;
-	rq += mb_getConjunctionCharacter(this.wms_getfeatureinfo);
-		rq += "WMTVER=" + this.wms_version + "&REQUEST=feature_info";
-	else{
-		rq += "VERSION=" + this.wms_version + "&REQUEST=GetFeatureInfo&SERVICE=WMS";
-	rq += "&QUERY_LAYERS=" + querylayers.join(",");
-	rq += "&INFO_FORMAT=" + this.gui_wms_featureinfoformat;
-	rq += "&EXCEPTIONS=application/vnd.ogc.se_xml";
-	rq += "&X=" + clickPoint.x;
-	rq += "&Y=" + clickPoint.y;
-	//console.log(rq);
-	return rq;
- * sets Opacity of WMS
- * @param {Integer} new opacity percentage value
-wms_const.prototype.setOpacity = function(opacity){
-	//calc new opacity
-	this.gui_wms_mapopacity = parseInt(opacity)/100;
-	if(this.gui_wms_mapopacity>1||isNaN(this.gui_wms_mapopacity))
-		this.gui_wms_mapopacity=1;
-	if(this.gui_wms_mapopacity<0)
-		this.gui_wms_mapopacity=0;
-	if (this.gui_wms_visible > 0) {
-		//get div id
-		var divId = null;
-		for (var i=0; i < wms.length; i++) {
-			if (this.wms_id == wms[i].wms_id) {
-				var divId = 'div_'+i;
-				break;
-		if(!divId)
-			return;
-		//TODO: check if mapframe1 is the right mapframe
-		wmsImage = parent.mapframe1.document.getElementById(divId);
-		if (wmsImage != null) {
-			wmsImage.style.opacity = this.gui_wms_mapopacity;
-			wmsImage.style.MozOpacity = this.gui_wms_mapopacity;
-			wmsImage.style.KhtmlOpacity = this.gui_wms_mapopacity;
-			wmsImage.style.filter = "alpha(opacity=" + this.gui_wms_mapopacity*100 + ")";
- * get all visible layers
- * @return array of layernames
- * @type string[]
-wms_const.prototype.getLayers = function(mapObj){
-	try {
-		//visibility of the wms
-		var wmsIsVisible = (this.gui_wms_visible > 0);
-		if(!wmsIsVisible){
-			return false;
-		visibleLayers = [];
-		for(var i=0; i< this.objLayer.length; i++){
-			var isVisible = (this.objLayer[i].gui_layer_visible === 1);
-			var hasNoChildren = (!this.objLayer[i].has_childs);
-			if (isVisible && hasNoChildren){
-				if(this.objLayer[i].checkScale(mapObj)){
-					//console.log("checkLayer: " + this.objLayer[i].layer_name);
-					visibleLayers.push(this.objLayer[i].layer_name);
-		if(visibleLayers.length === 0){
-			return false;
-		return visibleLayers;
-	catch (e) {
-		alert(e);
- * get the actual style of all visible layers
- * @return commaseparated list of actual layerstyles
- * @type string
-wms_const.prototype.getLayerstyles = function(mapObj){
-	var layerstyles = '';
-	var styles = [];
-	if(layers){
-		for(i = 0; i < layers.length; i++){
-			var style = this.getCurrentStyleByLayerName(layers[i]);
-			if(!style){
-				style = '';
-			styles.push(style);
-		return styles;
-	return false;
- * check if layer is parentLayer
- * @param layername
- * @return the parent value of the given layer
- * @type integer
-wms_const.prototype.checkLayerParentByLayerName = function(layername){
-		if(this.objLayer[i].layer_name == layername){
-			return this.objLayer[i].layer_parent;
- * get the title of the current layer
- * @return the title of the given layer
- * @type string
-wms_const.prototype.getTitleByLayerName = function(layername){
-			return this.objLayer[i].layer_title;
- * get the current style of the layer
- * @return the stylename of the given layer
- * @type string
-wms_const.prototype.getCurrentStyleByLayerName = function(layername){
-			if(this.objLayer[i].gui_layer_style === '' || this.objLayer[i].gui_layer_style === null){
-				return false;
-			else{
-				return this.objLayer[i].gui_layer_style;
- * get the legendurl of the gui layer style
- * @param stylename
- * @return the legendurl of the given style
- * @type string
-wms_const.prototype.getLegendUrlByGuiLayerStyle = function(layername,guiLayerStyle){
-			if(this.objLayer[i].layer_style.length === 0){
-				return false;
-			for(var k=0; k< this.objLayer[i].layer_style.length; k++){
-				if(this.objLayer[i].layer_style[k].name == guiLayerStyle){
-					var legendUrl = this.objLayer[i].layer_style[k].legendurl;
-					if (this.gui_wms_sldurl !== "") {
-					 		legendUrl += "&SLD="+escape(this.gui_wms_sldurl);
-					if(legendUrl !=='' && legendUrl !== null && typeof(legendUrl) != 'undefined'){
-						return legendUrl;
-					else {
-						return false;
-	return false;
- * get all querylayers
- * @type string[]
-wms_const.prototype.getQuerylayers = function(){
-	queryLayers = [];
-		if(this.objLayer[i].gui_layer_querylayer === 1 && ! this.objLayer[i].has_childs ){
-			queryLayers.push(this.objLayer[i].layer_name);
-	if(queryLayers.length === 0){
-		return false;
-	return queryLayers;
- * get a layer Object by layer_pos
- * @param int payer_pos layer_pos of layer you want to get
- * @return object layer
-wms_const.prototype.getLayerByLayerPos = function(layer_pos){
-	for(var i=0;i<this.objLayer.length;i++){
-		if(this.objLayer[i].layer_pos == layer_pos) {
-			return this.objLayer[i];
-	return null;
- * get the state of sublayers from a specified layer
- * @param int layer_id of the parent layer
- * @param String type "visible" or "querylayer"
- * @return int -1 if state differs else the state
-wms_const.prototype.getSublayerState = function(layer_id, type){
-	var i;
-	var state=-1,value;
-	for(i = 0; i < this.objLayer.length; i++){
-		if(this.objLayer[i].layer_id==layer_id) {
-			break;
-	//go throught sublayers
-	for(var j = i+1; j < this.objLayer.length; j++){
-		if(this.objLayer[i].parent_layer == this.objLayer[j].parent_layer) {
-			break;
-		if(type == "visible") {
-			value = this.objLayer[j].gui_layer_visible;
-		else if(type == "querylayer") {
-			value = this.objLayer[j].gui_layer_querylayer;
-		if(state == -1) {
-			state = value;
-		if(state != value) {
-			return -1;
-	return state;
- * handle change of visibility / quaryability of a layer
- * @param string layer_name of layer to handle
- * @param string type of change ("visible" or "querylayer")
- * @param int value of the change
-wms_const.prototype.handleLayer = function(layer_name, type, value){
-	var i;
-		if(this.objLayer[i].layer_name==layer_name) {
-			break;
-	//Set visibility/queryability of Layer and Sublayers
-	for(var j = i; j < this.objLayer.length; j++){
-		if (i != j && this.objLayer[i].layer_parent >= this.objLayer[j].layer_parent) {
-			break;
-			this.objLayer[j].gui_layer_visible = parseInt(value, 10);
-		else if(type=="querylayer") {
-			this.objLayer[j].gui_layer_querylayer = parseInt(value, 10);
-	//Update visibility/queryability of parent layer
-	var parentLayer = this.getLayerByLayerPos(this.objLayer[i].layer_parent);
-	if(parentLayer){
-		var state = this.getSublayerState(parentLayer.layer_id, type);
-		if(state!=-1){
-				this.objLayer[j].gui_layer_visible = state;
-				this.objLayer[j].gui_layer_querylayer = state;
- * move a layer (with his sublayers) up or down
- * @param int layerId layer_id of layer to move
- * @param boolean moveUp true to move up or false to move down
- * @return boolean success
-wms_const.prototype.moveLayer = function(layerId, moveUp){
-	var iLayer=-1;
-	var i;
-	//find layer to move
-	for(i=0;i<this.objLayer.length;i++){
-		if(this.objLayer[i].layer_id==layerId){
-			iLayer=i;
-			break;
-	if(iLayer==-1) {
-		return false;
-	var upperLayer = -1;
-	var lowerLayer = -1;
-	//find layer to swap position with
-	var parentLayer = this.objLayer[iLayer].layer_parent;
-	if(moveUp){
-		lowerLayer = iLayer;
-		//find previous layer on same level
-		for(i=iLayer-1;i>0;i--){
-			if(parentLayer == this.objLayer[i].layer_parent){
-				upperLayer = i;
-				break;
-		if(upperLayer == -1){
-			//alert("The Layer you selected is already on top of parent Layer/WMS");
-			return false;
-	else{
-		upperLayer = iLayer;
-		//find next layer on same level
-		for(i=iLayer+1;i<this.objLayer.length;i++){
-				lowerLayer = i;
-				break;
-		if(lowerLayer == -1){
-			//alert("The Layer you selected is already on bottom of parent Layer/WMS");
-			return false;
-	//calc number of layers to move down
-	var layersDown = lowerLayer - upperLayer;
-	//get number of layers to move up
-	for(i=lowerLayer+1; i<this.objLayer.length; i++){
-			break;
-	var layersUp = i - lowerLayer;
-	//do moving
-	var temp = [];
-	for(i=0;i<layersDown+layersUp;i++){
-		temp[temp.length]=this.objLayer[upperLayer+i];
-	for(i=0;i<layersUp;i++){
-		this.objLayer[upperLayer+i]=temp[i+layersDown];
-	for(i=0;i<layersDown;i++){
-		this.objLayer[upperLayer+layersUp+i]=temp[i];
-	return true;
-function wms_add_data_type_format(datatype,dataformat){
-	var insertDataFormat = true;
-	for (var i = 0 ; i < wms[wms.length-1].data_type.length ; i ++) {
-		if (wms[wms.length-1].data_type[i] == datatype && wms[wms.length-1].data_format[i] == dataformat) {
-			insertDataFormat = false;
-	if (insertDataFormat === true) {
-		wms[wms.length-1].data_type[wms[wms.length-1].data_type.length] = datatype;
-		wms[wms.length-1].data_format[wms[wms.length-1].data_format.length] = dataformat;
-function wms_addSRS(epsg,minx,miny,maxx,maxy){
-	wms[wms.length-1].gui_epsg[wms[wms.length-1].gui_epsg.length] = epsg;
-	wms[wms.length-1].gui_minx[wms[wms.length-1].gui_minx.length] = minx;
-	wms[wms.length-1].gui_miny[wms[wms.length-1].gui_miny.length] = miny;
-	wms[wms.length-1].gui_maxx[wms[wms.length-1].gui_maxx.length] = maxx;
-	wms[wms.length-1].gui_maxy[wms[wms.length-1].gui_maxy.length] = maxy;
-function wms_addLayerStyle(styleName, styleTitle, count, layerCount, styleLegendUrl, styleLegendUrlFormat){
-	var currentLayer = wms[wms.length-1].objLayer[layerCount];
-	if (currentLayer) {
-		currentLayer.layer_style[count] = {};
-		currentLayer.layer_style[count].name = styleName;
-		currentLayer.layer_style[count].title = styleTitle;
-		currentLayer.layer_style[count].legendurl = styleLegendUrl;
-		currentLayer.layer_style[count].legendurlformat = styleLegendUrlFormat;
-//TODO: add layerstyle handling....
-//layer
-function wms_add_layer(
-			layer_parent,
-			layer_uid,
-			layer_name,
-			layer_title,
-			layer_dataurl_href,
-			layer_pos,
-			layer_queryable,
-			layer_minscale,
-			layer_maxscale,
-			layer_metadataurl,
-			gui_layer_wms_id,
-			gui_layer_status,
-			gui_layer_style,
-			gui_layer_selectable,
-			gui_layer_visible,
-			gui_layer_queryable,
-			gui_layer_querylayer,
-			gui_layer_minscale,
-			gui_layer_maxscale,
-			gui_layer_wfs_featuretype){
-	wms[wms.length-1].objLayer[wms[wms.length-1].objLayer.length] = new wms_layer(
-											layer_parent,
-											layer_uid,
-											layer_name,
-											layer_title,
-											layer_pos,
-											layer_queryable,
-											layer_minscale,
-											layer_maxscale,
-											gui_layer_wms_id,
-											gui_layer_status,
-											gui_layer_style,
-											parseInt(gui_layer_selectable, 10),
-											parseInt(gui_layer_visible, 10),
-											parseInt(gui_layer_queryable, 10),
-											parseInt(gui_layer_querylayer, 10),
-											parseInt(gui_layer_minscale, 10),
-											parseInt(gui_layer_maxscale, 10),
-											gui_layer_wfs_featuretype );
-	var parentLayer = wms[wms.length-1].getLayerByLayerPos(parseInt(layer_parent, 10));
-	if(parentLayer) {
-		parentLayer.has_childs = true;
-function layer_addEpsg(epsg,minx,miny,maxx,maxy){
-	var j = wms[wms.length-1].objLayer.length-1;
-	var k = wms[wms.length-1].objLayer[j].layer_epsg.length;
-	var currentLayer = wms[wms.length-1].objLayer[j];
-	currentLayer.layer_epsg[k]={};
-	currentLayer.layer_epsg[k].epsg = epsg;
-	currentLayer.layer_epsg[k].minx = minx;
-	currentLayer.layer_epsg[k].miny = miny;
-	currentLayer.layer_epsg[k].maxx = maxx;
-	currentLayer.layer_epsg[k].maxy = maxy;
-function wms_layer(
-			layer_parent,
-			wms_layer_uid,
-			layer_name,
-			layer_title,
-			layer_pos,
-			layer_queryable,
-			layer_minscale,
-			layer_maxscale,
-			gui_layer_wms_id,
-			gui_layer_status,
-			gui_layer_style,
-	this.layer_id = wms_layer_count;
-	this.layer_uid = wms_layer_uid;
-	this.layer_parent = layer_parent;
-	this.layer_name = layer_name;
-	this.layer_title = layer_title;
-	this.layer_dataurl_href = layer_dataurl_href;
-	this.layer_pos = layer_pos;
-	this.layer_queryable = layer_queryable;
-	this.layer_minscale = layer_minscale;
-	this.layer_maxscale = layer_maxscale;
-	this.layer_metadataurl = layer_metadataurl;
-	this.layer_epsg = [];
-	this.gui_layer_wms_id = gui_layer_wms_id;
-	this.gui_layer_status = gui_layer_status;
-	this.gui_layer_selectable = gui_layer_selectable;
-	this.gui_layer_visible = gui_layer_visible;
-	this.gui_layer_queryable = gui_layer_queryable;
-	this.gui_layer_querylayer = gui_layer_querylayer;
-	this.gui_layer_minscale = gui_layer_minscale;
-	this.gui_layer_maxscale = gui_layer_maxscale;
-	this.gui_layer_style = gui_layer_style;
-	this.gui_layer_wfs_featuretype = gui_layer_wfs_featuretype;
-	this.gui_layer_style = null;
-	this.has_childs = false;
-	this.layer_style = [];
-	wms_layer_count++;
- * check the scale of the layer
- * @param Object mapObj the mapbender mapObject of the layer
- * @return boolean if the layer is in scale or not
- * @type boolean
-wms_layer.prototype.checkScale = function(mapObj){
-	var minScale = parseInt(this.gui_layer_minscale, 10);
-	var maxScale = parseInt(this.gui_layer_maxscale, 10);
-	var currentScale = parseInt(mapObj.getScale(), 10);
-	if(minScale === 0 && maxScale === 0){
-		return true;
-	if(minScale > currentScale || (maxScale !== 0 && maxScale < currentScale)) {
-		return false;
-	return true;
- * set visibility of the layer
- * @param boolean visible visibility on/off
-wms_layer.prototype.setVisible = function(visible){
-	this.gui_layer_visible = parseInt(visible, 10);
-	//console.log("setVisible(%i) for Layer %s",visible, this.layer_name);
- * set queryability of the layer
- * @param boolean queryable queryability on/off
-wms_layer.prototype.setQueryable = function(queryable){
-	this.gui_layer_querylayer = parseInt(queryable, 10);
-	//console.log("setQueryable(%i) for Layer %s",queryable, this.layer_name);
More information about the Mapbender_commits mailing list
