[Mapbender-commits] r2553 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 24 08:31:10 EDT 2008
Author: christoph
Date: 2008-06-24 08:31:10 -0400 (Tue, 24 Jun 2008)
New Revision: 2553
   trunk/mapbender/http/classes/class_gml2.php
set correct path to classes
Modified: trunk/mapbender/http/classes/class_gml2.php
--- trunk/mapbender/http/classes/class_gml2.php	2008-06-24 09:25:44 UTC (rev 2552)
+++ trunk/mapbender/http/classes/class_gml2.php	2008-06-24 12:31:10 UTC (rev 2553)
@@ -16,10 +16,10 @@
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once("class_mb_exception.php");
-require_once("class_connector.php");
-require_once("../classes/class_json.php");
-require_once("../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 class gml2 {
 	var $geomtype_point = 'Point';
 	var $geomtype_polygon = 'Polygon';
More information about the Mapbender_commits mailing list
