[Mapbender-commits] r2566 - in branches: . testbaudson_dev testbaudson_dev/conf testbaudson_dev/ext testbaudson_dev/http/classes testbaudson_dev/http/extensions testbaudson_dev/http/frames testbaudson_dev/http/javascripts testbaudson_dev/http/php testbaudson_dev/lib testbaudson_dev/mod testbaudson_dev/mod/body testbaudson_dev/mod/editApplication testbaudson_dev/mod/mapframe1 testbaudson_dev/mod/ol
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jun 30 10:13:04 EDT 2008
Author: christoph
Date: 2008-06-30 10:13:03 -0400 (Mon, 30 Jun 2008)
New Revision: 2566
Added:
   branches/testbaudson_dev/
   branches/testbaudson_dev/ext/
   branches/testbaudson_dev/ext/JSON.php
   branches/testbaudson_dev/ext/OpenLayers.js
   branches/testbaudson_dev/ext/jqjson.js
   branches/testbaudson_dev/ext/jquery-1.2.6.min.js
   branches/testbaudson_dev/ext/jquery-ui-personalized-1.5.min.js
   branches/testbaudson_dev/ext/jquery.ajaxmanager.js
   branches/testbaudson_dev/ext/jquery.mousewheel.min.js
   branches/testbaudson_dev/ext/phpmailer-1.72/
   branches/testbaudson_dev/lib/database-mysql.php
   branches/testbaudson_dev/lib/database-pgsql.php
   branches/testbaudson_dev/mod/
   branches/testbaudson_dev/mod/body/
   branches/testbaudson_dev/mod/body/body.js
   branches/testbaudson_dev/mod/editApplication/
   branches/testbaudson_dev/mod/editApplication/alignButton.js
   branches/testbaudson_dev/mod/editApplication/draggableButton.js
   branches/testbaudson_dev/mod/editApplication/resizableButton.js
   branches/testbaudson_dev/mod/editApplication/saveButton.js
   branches/testbaudson_dev/mod/editApplication/selectableButton.js
   branches/testbaudson_dev/mod/mapframe1/
   branches/testbaudson_dev/mod/mapframe1/map.js
   branches/testbaudson_dev/mod/mapframe1/map_obj.js
   branches/testbaudson_dev/mod/mapframe1/mapframe1.php
   branches/testbaudson_dev/mod/mapframe1/wfs_obj.js
   branches/testbaudson_dev/mod/mapframe1/wms.js
   branches/testbaudson_dev/mod/ol/
   branches/testbaudson_dev/mod/ol/openlayers.php
Removed:
   branches/testbaudson_dev/http/classes/phpmailer-1.72/
   branches/testbaudson_dev/http/extensions/JSON.php
   branches/testbaudson_dev/http/extensions/OpenLayers.js
   branches/testbaudson_dev/http/extensions/jqjson.js
   branches/testbaudson_dev/http/extensions/jquery-1.2.6.min.js
   branches/testbaudson_dev/http/extensions/jquery-ui-personalized-1.5.min.js
   branches/testbaudson_dev/http/extensions/jquery.ajaxmanager.js
   branches/testbaudson_dev/http/extensions/jquery.js
   branches/testbaudson_dev/http/extensions/jquery.mousewheel.min.js
   branches/testbaudson_dev/http/extensions/json.js
   branches/testbaudson_dev/http/frames/jquery.html
   branches/testbaudson_dev/http/javascripts/initOpenLayersWms.php
   branches/testbaudson_dev/http/javascripts/initWms.php
   branches/testbaudson_dev/http/javascripts/map.js
   branches/testbaudson_dev/http/javascripts/map_obj.js
   branches/testbaudson_dev/http/javascripts/mod_openlayers.php
   branches/testbaudson_dev/http/javascripts/wfs_obj.js
   branches/testbaudson_dev/http/javascripts/wms.js
   branches/testbaudson_dev/http/php/database-mysql.php
   branches/testbaudson_dev/http/php/database-pgsql.php
   branches/testbaudson_dev/lib/alignButton.js
   branches/testbaudson_dev/lib/draggableButton.js
   branches/testbaudson_dev/lib/resizableButton.js
   branches/testbaudson_dev/lib/saveButton.js
   branches/testbaudson_dev/lib/selectableButton.js
   branches/testbaudson_dev/conf/mapbender.conf-dist
   branches/testbaudson_dev/http/classes/class_administration.php
   branches/testbaudson_dev/http/classes/class_checkInput.php
   branches/testbaudson_dev/http/classes/class_connector.php
   branches/testbaudson_dev/http/classes/class_json.php
   branches/testbaudson_dev/http/classes/class_mb_exception.php
   branches/testbaudson_dev/http/classes/class_mb_log.php
   branches/testbaudson_dev/http/classes/class_mb_notice.php
   branches/testbaudson_dev/http/classes/class_mb_warning.php
   branches/testbaudson_dev/http/classes/class_user.php
   branches/testbaudson_dev/http/classes/class_wmc.php
   branches/testbaudson_dev/http/classes/class_wms.php
   branches/testbaudson_dev/http/javascripts/map.php
   branches/testbaudson_dev/http/php/mod_editApplication.php
   branches/testbaudson_dev/lib/core.js
Copied: branches/testbaudson_dev (from rev 2556, trunk/mapbender)
Modified: branches/testbaudson_dev/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/conf/mapbender.conf-dist	2008-06-30 14:13:03 UTC (rev 2566)
@@ -23,7 +23,7 @@
 	define("OWNER", "<owner>");
 	define("PW", "<password>");
-	include_once(dirname(__FILE__) . "/../http/php/database-mysql.php");
+	include_once(dirname(__FILE__) . "/../lib/database-mysql.php");
 	# database with geos functions
@@ -43,7 +43,7 @@
-	include_once(dirname(__FILE__) . "/../http/php/database-pgsql.php");
+	include_once(dirname(__FILE__) . "/../lib/database-pgsql.php");
Copied: branches/testbaudson_dev/ext/JSON.php (from rev 2556, trunk/mapbender/http/extensions/JSON.php)
--- branches/testbaudson_dev/ext/JSON.php	                        (rev 0)
+++ branches/testbaudson_dev/ext/JSON.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,806 @@
+<?php
+/* vim: set expandtab tabstop=4 shiftwidth=4 softtabstop=4: */
+ * Converts to and from JSON format.
+ * JSON (JavaScript Object Notation) is a lightweight data-interchange
+ * format. It is easy for humans to read and write. It is easy for machines
+ * to parse and generate. It is based on a subset of the JavaScript
+ * Programming Language, Standard ECMA-262 3rd Edition - December 1999.
+ * This feature can also be found in  Python. JSON is a text format that is
+ * completely language independent but uses conventions that are familiar
+ * to programmers of the C-family of languages, including C, C++, C#, Java,
+ * JavaScript, Perl, TCL, and many others. These properties make JSON an
+ * ideal data-interchange language.
+ * This package provides a simple encoder and decoder for JSON notation. It
+ * is intended for use with client-side Javascript applications that make
+ * use of HTTPRequest to perform server communication functions - data can
+ * be encoded into JSON notation for use in a client-side javascript, or
+ * decoded from incoming Javascript requests. JSON format is native to
+ * Javascript, and can be directly eval()'ed with no further parsing
+ * overhead
+ * All strings should be in ASCII or UTF-8 format!
+ * LICENSE: Redistribution and use in source and binary forms, with or
+ * without modification, are permitted provided that the following
+ * conditions are met: Redistributions of source code must retain the
+ * above copyright notice, this list of conditions and the following
+ * disclaimer. Redistributions in binary form must reproduce the above
+ * copyright notice, this list of conditions and the following disclaimer
+ * in the documentation and/or other materials provided with the
+ * distribution.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
+ * NO EVENT SHALL CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
+ * TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
+ * USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH
+ * DAMAGE.
+ * @category
+ * @package     Services_JSON
+ * @author      Michal Migurski <mike-json at teczno.com>
+ * @author      Matt Knapp <mdknapp[at]gmail[dot]com>
+ * @author      Brett Stimmerman <brettstimmerman[at]gmail[dot]com>
+ * @copyright   2005 Michal Migurski
+ * @version     CVS: $Id: JSON.php,v 1.31 2006/06/28 05:54:17 migurski Exp $
+ * @license     http://www.opensource.org/licenses/bsd-license.php
+ * @link        http://pear.php.net/pepr/pepr-proposal-show.php?id=198
+ * Marker constant for Services_JSON::decode(), used to flag stack state
+define('SERVICES_JSON_SLICE',   1);
+define('SERVICES_JSON_IN_STR',  2);
+define('SERVICES_JSON_IN_ARR',  3);
+define('SERVICES_JSON_IN_OBJ',  4);
+define('SERVICES_JSON_IN_CMT', 5);
+ * Behavior switch for Services_JSON::decode()
+define('SERVICES_JSON_LOOSE_TYPE', 16);
+define('SERVICES_JSON_SUPPRESS_ERRORS', 32);
+ * Brief example of use:
+ * <code>
+ * // create a new instance of Services_JSON
+ * $json = new Services_JSON();
+ * // convert a complexe value to JSON notation, and send it to the browser
+ * $value = array('foo', 'bar', array(1, 2, 'baz'), array(3, array(4)));
+ * $output = $json->encode($value);
+ * print($output);
+ * // prints: ["foo","bar",[1,2,"baz"],[3,[4]]]
+ * // accept incoming POST data, assumed to be in JSON notation
+ * $input = file_get_contents('php://input', 1000000);
+ * $value = $json->decode($input);
+ * </code>
+class Services_JSON
+    * constructs a new JSON instance
+    * @param    int     $use    object behavior flags; combine with boolean-OR
+    *                           possible values:
+    *                           - SERVICES_JSON_LOOSE_TYPE:  loose typing.
+    *                                   "{...}" syntax creates associative arrays
+    *                                   instead of objects in decode().
+    *                           - SERVICES_JSON_SUPPRESS_ERRORS:  error suppression.
+    *                                   Values which can't be encoded (e.g. resources)
+    *                                   appear as NULL instead of throwing errors.
+    *                                   By default, a deeply-nested resource will
+    *                                   bubble up with an error, so all return values
+    *                                   from encode() should be checked with isError()
+    function Services_JSON($use = 0)
+        $this->use = $use;
+    * convert a string from one UTF-16 char to one UTF-8 char
+    * Normally should be handled by mb_convert_encoding, but
+    * provides a slower PHP-only method for installations
+    * that lack the multibye string extension.
+    * @param    string  $utf16  UTF-16 character
+    * @return   string  UTF-8 character
+    * @access   private
+    function utf162utf8($utf16)
+        // oh please oh please oh please oh please oh please
+        if(function_exists('mb_convert_encoding')) {
+            return mb_convert_encoding($utf16, 'UTF-8', 'UTF-16');
+        $bytes = (ord($utf16{0}) << 8) | ord($utf16{1});
+        switch(true) {
+            case ((0x7F & $bytes) == $bytes):
+                // this case should never be reached, because we are in ASCII range
+                // see: http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
+                return chr(0x7F & $bytes);
+            case (0x07FF & $bytes) == $bytes:
+                // return a 2-byte UTF-8 character
+                return chr(0xC0 | (($bytes >> 6) & 0x1F))
+                     . chr(0x80 | ($bytes & 0x3F));
+            case (0xFFFF & $bytes) == $bytes:
+                // return a 3-byte UTF-8 character
+                return chr(0xE0 | (($bytes >> 12) & 0x0F))
+                     . chr(0x80 | (($bytes >> 6) & 0x3F))
+        // ignoring UTF-32 for now, sorry
+        return '';
+    * convert a string from one UTF-8 char to one UTF-16 char
+    * @param    string  $utf8   UTF-8 character
+    * @return   string  UTF-16 character
+    * @access   private
+    function utf82utf16($utf8)
+            return mb_convert_encoding($utf8, 'UTF-16', 'UTF-8');
+        switch(strlen($utf8)) {
+            case 1:
+                return $utf8;
+            case 2:
+                // return a UTF-16 character from a 2-byte UTF-8 char
+                return chr(0x07 & (ord($utf8{0}) >> 2))
+                     . chr((0xC0 & (ord($utf8{0}) << 6))
+                         | (0x3F & ord($utf8{1})));
+            case 3:
+                // return a UTF-16 character from a 3-byte UTF-8 char
+                return chr((0xF0 & (ord($utf8{0}) << 4))
+                         | (0x0F & (ord($utf8{1}) >> 2)))
+                     . chr((0xC0 & (ord($utf8{1}) << 6))
+                         | (0x7F & ord($utf8{2})));
+        return '';
+    * encodes an arbitrary variable into JSON format
+    * @param    mixed   $var    any number, boolean, string, array, or object to be encoded.
+    *                           see argument 1 to Services_JSON() above for array-parsing behavior.
+    *                           if var is a strng, note that encode() always expects it
+    *                           to be in ASCII or UTF-8 format!
+    * @return   mixed   JSON string representation of input var or an error if a problem occurs
+    * @access   public
+    function encode($var)
+        switch (gettype($var)) {
+            case 'boolean':
+                return $var ? 'true' : 'false';
+            case 'NULL':
+                return 'null';
+            case 'integer':
+                return (int) $var;
+            case 'double':
+            case 'float':
+                return (float) $var;
+            case 'string':
+                // STRINGS ARE EXPECTED TO BE IN ASCII OR UTF-8 FORMAT
+                $ascii = '';
+                $strlen_var = strlen($var);
+                * Iterate over every character in the string,
+                * escaping with a slash or encoding to UTF-8 where necessary
+                for ($c = 0; $c < $strlen_var; ++$c) {
+                    $ord_var_c = ord($var{$c});
+                    switch (true) {
+                        case $ord_var_c == 0x08:
+                            $ascii .= '\b';
+                            break;
+                        case $ord_var_c == 0x09:
+                            $ascii .= '\t';
+                            break;
+                        case $ord_var_c == 0x0A:
+                            $ascii .= '\n';
+                            break;
+                        case $ord_var_c == 0x0C:
+                            $ascii .= '\f';
+                            break;
+                        case $ord_var_c == 0x0D:
+                            $ascii .= '\r';
+                            break;
+                        case $ord_var_c == 0x22:
+                        case $ord_var_c == 0x2F:
+                        case $ord_var_c == 0x5C:
+                            // double quote, slash, slosh
+                            $ascii .= '\\'.$var{$c};
+                            break;
+                        case (($ord_var_c >= 0x20) && ($ord_var_c <= 0x7F)):
+                            // characters U-00000000 - U-0000007F (same as ASCII)
+                            $ascii .= $var{$c};
+                            break;
+                        case (($ord_var_c & 0xE0) == 0xC0):
+                            // characters U-00000080 - U-000007FF, mask 110XXXXX
+                            // see http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
+                            $char = pack('C*', $ord_var_c, ord($var{$c + 1}));
+                            $c += 1;
+                            $utf16 = $this->utf82utf16($char);
+                            $ascii .= sprintf('\u%04s', bin2hex($utf16));
+                            break;
+                        case (($ord_var_c & 0xF0) == 0xE0):
+                            // characters U-00000800 - U-0000FFFF, mask 1110XXXX
+                                         ord($var{$c + 1}),
+                                         ord($var{$c + 2}));
+                            $c += 2;
+                            break;
+                        case (($ord_var_c & 0xF8) == 0xF0):
+                            // characters U-00010000 - U-001FFFFF, mask 11110XXX
+                                         ord($var{$c + 2}),
+                                         ord($var{$c + 3}));
+                            $c += 3;
+                            break;
+                        case (($ord_var_c & 0xFC) == 0xF8):
+                            // characters U-00200000 - U-03FFFFFF, mask 111110XX
+                                         ord($var{$c + 3}),
+                                         ord($var{$c + 4}));
+                            $c += 4;
+                            break;
+                        case (($ord_var_c & 0xFE) == 0xFC):
+                            // characters U-04000000 - U-7FFFFFFF, mask 1111110X
+                                         ord($var{$c + 4}),
+                                         ord($var{$c + 5}));
+                            $c += 5;
+                            break;
+                return '"'.$ascii.'"';
+            case 'array':
+                * As per JSON spec if any array key is not an integer
+                * we must treat the the whole array as an object. We
+                * also try to catch a sparsely populated associative
+                * array with numeric keys here because some JS engines
+                * will create an array with empty indexes up to
+                * max_index which can cause memory issues and because
+                * the keys, which may be relevant, will be remapped
+                * otherwise.
+                * As per the ECMA and JSON specification an object may
+                * have any string as a property. Unfortunately due to
+                * a hole in the ECMA specification if the key is a
+                * ECMA reserved word or starts with a digit the
+                * parameter is only accessible using ECMAScript's
+                * bracket notation.
+                // treat as a JSON object
+                if (is_array($var) && count($var) && (array_keys($var) !== range(0, sizeof($var) - 1))) {
+                    $properties = array_map(array($this, 'name_value'),
+                                            array_keys($var),
+                                            array_values($var));
+                    foreach($properties as $property) {
+                        if(Services_JSON::isError($property)) {
+                            return $property;
+                    return '{' . join(',', $properties) . '}';
+                // treat it like a regular array
+                $elements = array_map(array($this, 'encode'), $var);
+                foreach($elements as $element) {
+                    if(Services_JSON::isError($element)) {
+                        return $element;
+                return '[' . join(',', $elements) . ']';
+            case 'object':
+                $vars = get_object_vars($var);
+                                        array_keys($vars),
+                                        array_values($vars));
+                        return $property;
+            default:
+                return ($this->use & SERVICES_JSON_SUPPRESS_ERRORS)
+                    ? 'null'
+                    : new Services_JSON_Error(gettype($var)." can not be encoded as JSON string");
+    * array-walking function for use in generating JSON-formatted name-value pairs
+    * @param    string  $name   name of key to use
+    * @param    mixed   $value  reference to an array element to be encoded
+    * @return   string  JSON-formatted name-value pair, like '"name":value'
+    * @access   private
+    function name_value($name, $value)
+        $encoded_value = $this->encode($value);
+        if(Services_JSON::isError($encoded_value)) {
+            return $encoded_value;
+        return $this->encode(strval($name)) . ':' . $encoded_value;
+    * reduce a string by removing leading and trailing comments and whitespace
+    * @param    $str    string      string value to strip of comments and whitespace
+    * @return   string  string value stripped of comments and whitespace
+    * @access   private
+    function reduce_string($str)
+        $str = preg_replace(array(
+                // eliminate single line comments in '// ...' form
+                '#^\s*//(.+)$#m',
+                // eliminate multi-line comments in '/* ... */' form, at start of string
+                '#^\s*/\*(.+)\*/#Us',
+                // eliminate multi-line comments in '/* ... */' form, at end of string
+                '#/\*(.+)\*/\s*$#Us'
+            ), '', $str);
+        // eliminate extraneous space
+        return trim($str);
+    * decodes a JSON string into appropriate variable
+    * @param    string  $str    JSON-formatted string
+    * @return   mixed   number, boolean, string, array, or object
+    *                   corresponding to given JSON input string.
+    *                   See argument 1 to Services_JSON() above for object-output behavior.
+    *                   Note that decode() always returns strings
+    *                   in ASCII or UTF-8 format!
+    * @access   public
+    function decode($str)
+        $str = $this->reduce_string($str);
+        switch (strtolower($str)) {
+            case 'true':
+                return true;
+            case 'false':
+                return false;
+            case 'null':
+                return null;
+            default:
+                $m = array();
+                if (is_numeric($str)) {
+                    // Lookie-loo, it's a number
+                    // This would work on its own, but I'm trying to be
+                    // good about returning integers where appropriate:
+                    // return (float)$str;
+                    // Return float or int, as appropriate
+                    return ((float)$str == (integer)$str)
+                        ? (integer)$str
+                        : (float)$str;
+                } elseif (preg_match('/^("|\').*(\1)$/s', $str, $m) && $m[1] == $m[2]) {
+                    // STRINGS RETURNED IN UTF-8 FORMAT
+                    $delim = substr($str, 0, 1);
+                    $chrs = substr($str, 1, -1);
+                    $utf8 = '';
+                    $strlen_chrs = strlen($chrs);
+                    for ($c = 0; $c < $strlen_chrs; ++$c) {
+                        $substr_chrs_c_2 = substr($chrs, $c, 2);
+                        $ord_chrs_c = ord($chrs{$c});
+                        switch (true) {
+                            case $substr_chrs_c_2 == '\b':
+                                $utf8 .= chr(0x08);
+                                ++$c;
+                                break;
+                            case $substr_chrs_c_2 == '\t':
+                                $utf8 .= chr(0x09);
+                                ++$c;
+                                break;
+                            case $substr_chrs_c_2 == '\n':
+                                $utf8 .= chr(0x0A);
+                                ++$c;
+                                break;
+                            case $substr_chrs_c_2 == '\f':
+                                $utf8 .= chr(0x0C);
+                                ++$c;
+                                break;
+                            case $substr_chrs_c_2 == '\r':
+                                $utf8 .= chr(0x0D);
+                                ++$c;
+                                break;
+                            case $substr_chrs_c_2 == '\\"':
+                            case $substr_chrs_c_2 == '\\\'':
+                            case $substr_chrs_c_2 == '\\\\':
+                            case $substr_chrs_c_2 == '\\/':
+                                if (($delim == '"' && $substr_chrs_c_2 != '\\\'') ||
+                                   ($delim == "'" && $substr_chrs_c_2 != '\\"')) {
+                                    $utf8 .= $chrs{++$c};
+                                break;
+                            case preg_match('/\\\u[0-9A-F]{4}/i', substr($chrs, $c, 6)):
+                                // single, escaped unicode character
+                                $utf16 = chr(hexdec(substr($chrs, ($c + 2), 2)))
+                                       . chr(hexdec(substr($chrs, ($c + 4), 2)));
+                                $utf8 .= $this->utf162utf8($utf16);
+                                $c += 5;
+                                break;
+                            case ($ord_chrs_c >= 0x20) && ($ord_chrs_c <= 0x7F):
+                                $utf8 .= $chrs{$c};
+                                break;
+                            case ($ord_chrs_c & 0xE0) == 0xC0:
+                                //see http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
+                                $utf8 .= substr($chrs, $c, 2);
+                                ++$c;
+                                break;
+                            case ($ord_chrs_c & 0xF0) == 0xE0:
+                                $utf8 .= substr($chrs, $c, 3);
+                                $c += 2;
+                                break;
+                            case ($ord_chrs_c & 0xF8) == 0xF0:
+                                $utf8 .= substr($chrs, $c, 4);
+                                $c += 3;
+                                break;
+                            case ($ord_chrs_c & 0xFC) == 0xF8:
+                                $utf8 .= substr($chrs, $c, 5);
+                                $c += 4;
+                                break;
+                            case ($ord_chrs_c & 0xFE) == 0xFC:
+                                $utf8 .= substr($chrs, $c, 6);
+                                $c += 5;
+                                break;
+                    return $utf8;
+                } elseif (preg_match('/^\[.*\]$/s', $str) || preg_match('/^\{.*\}$/s', $str)) {
+                    // array, or object notation
+                    if ($str{0} == '[') {
+                        $stk = array(SERVICES_JSON_IN_ARR);
+                        $arr = array();
+                    } else {
+                        if ($this->use & SERVICES_JSON_LOOSE_TYPE) {
+                            $stk = array(SERVICES_JSON_IN_OBJ);
+                            $obj = array();
+                        } else {
+                            $obj = new stdClass();
+                    array_push($stk, array('what'  => SERVICES_JSON_SLICE,
+                                           'where' => 0,
+                                           'delim' => false));
+                    $chrs = $this->reduce_string($chrs);
+                    if ($chrs == '') {
+                        if (reset($stk) == SERVICES_JSON_IN_ARR) {
+                            return $arr;
+                        } else {
+                            return $obj;
+                    //print("\nparsing {$chrs}\n");
+                    for ($c = 0; $c <= $strlen_chrs; ++$c) {
+                        $top = end($stk);
+                        if (($c == $strlen_chrs) || (($chrs{$c} == ',') && ($top['what'] == SERVICES_JSON_SLICE))) {
+                            // found a comma that is not inside a string, array, etc.,
+                            // OR we've reached the end of the character list
+                            $slice = substr($chrs, $top['where'], ($c - $top['where']));
+                            array_push($stk, array('what' => SERVICES_JSON_SLICE, 'where' => ($c + 1), 'delim' => false));
+                            //print("Found split at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
+                                // we are in an array, so just push an element onto the stack
+                                array_push($arr, $this->decode($slice));
+                            } elseif (reset($stk) == SERVICES_JSON_IN_OBJ) {
+                                // we are in an object, so figure
+                                // out the property name and set an
+                                // element in an associative array,
+                                // for now
+                                $parts = array();
+                                if (preg_match('/^\s*(["\'].*[^\\\]["\'])\s*:\s*(\S.*),?$/Uis', $slice, $parts)) {
+                                    // "name":value pair
+                                    $key = $this->decode($parts[1]);
+                                    $val = $this->decode($parts[2]);
+                                        $obj[$key] = $val;
+                                    } else {
+                                        $obj->$key = $val;
+                                } elseif (preg_match('/^\s*(\w+)\s*:\s*(\S.*),?$/Uis', $slice, $parts)) {
+                                    // name:value pair, where name is unquoted
+                                    $key = $parts[1];
+                                    } else {
+                        } elseif ((($chrs{$c} == '"') || ($chrs{$c} == "'")) && ($top['what'] != SERVICES_JSON_IN_STR)) {
+                            // found a quote, and we are not inside a string
+                            array_push($stk, array('what' => SERVICES_JSON_IN_STR, 'where' => $c, 'delim' => $chrs{$c}));
+                            //print("Found start of string at {$c}\n");
+                        } elseif (($chrs{$c} == $top['delim']) &&
+                                 ($top['what'] == SERVICES_JSON_IN_STR) &&
+                                 ((strlen(substr($chrs, 0, $c)) - strlen(rtrim(substr($chrs, 0, $c), '\\'))) % 2 != 1)) {
+                            // found a quote, we're in a string, and it's not escaped
+                            // we know that it's not escaped becase there is _not_ an
+                            // odd number of backslashes at the end of the string so far
+                            array_pop($stk);
+                            //print("Found end of string at {$c}: ".substr($chrs, $top['where'], (1 + 1 + $c - $top['where']))."\n");
+                        } elseif (($chrs{$c} == '[') &&
+                                 in_array($top['what'], array(SERVICES_JSON_SLICE, SERVICES_JSON_IN_ARR, SERVICES_JSON_IN_OBJ))) {
+                            // found a left-bracket, and we are in an array, object, or slice
+                            array_push($stk, array('what' => SERVICES_JSON_IN_ARR, 'where' => $c, 'delim' => false));
+                            //print("Found start of array at {$c}\n");
+                        } elseif (($chrs{$c} == ']') && ($top['what'] == SERVICES_JSON_IN_ARR)) {
+                            // found a right-bracket, and we're in an array
+                            array_pop($stk);
+                            //print("Found end of array at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
+                        } elseif (($chrs{$c} == '{') &&
+                            // found a left-brace, and we are in an array, object, or slice
+                            array_push($stk, array('what' => SERVICES_JSON_IN_OBJ, 'where' => $c, 'delim' => false));
+                            //print("Found start of object at {$c}\n");
+                        } elseif (($chrs{$c} == '}') && ($top['what'] == SERVICES_JSON_IN_OBJ)) {
+                            // found a right-brace, and we're in an object
+                            array_pop($stk);
+                            //print("Found end of object at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
+                        } elseif (($substr_chrs_c_2 == '/*') &&
+                            // found a comment start, and we are in an array, object, or slice
+                            array_push($stk, array('what' => SERVICES_JSON_IN_CMT, 'where' => $c, 'delim' => false));
+                            $c++;
+                            //print("Found start of comment at {$c}\n");
+                        } elseif (($substr_chrs_c_2 == '*/') && ($top['what'] == SERVICES_JSON_IN_CMT)) {
+                            // found a comment end, and we're in one now
+                            array_pop($stk);
+                            $c++;
+                            for ($i = $top['where']; $i <= $c; ++$i)
+                                $chrs = substr_replace($chrs, ' ', $i, 1);
+                            //print("Found end of comment at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
+                        return $arr;
+                        return $obj;
+     * @todo Ultimately, this should just call PEAR::isError()
+    function isError($data, $code = null)
+        if (class_exists('pear')) {
+            return PEAR::isError($data, $code);
+        } elseif (is_object($data) && (get_class($data) == 'services_json_error' ||
+                                 is_subclass_of($data, 'services_json_error'))) {
+            return true;
+        return false;
+if (class_exists('PEAR_Error')) {
+    class Services_JSON_Error extends PEAR_Error
+        function Services_JSON_Error($message = 'unknown error', $code = null,
+                                     $mode = null, $options = null, $userinfo = null)
+            parent::PEAR_Error($message, $code, $mode, $options, $userinfo);
+} else {
+     * @todo Ultimately, this class shall be descended from PEAR_Error
Copied: branches/testbaudson_dev/ext/OpenLayers.js (from rev 2556, trunk/mapbender/http/extensions/OpenLayers.js)
--- branches/testbaudson_dev/ext/OpenLayers.js	                        (rev 0)
+++ branches/testbaudson_dev/ext/OpenLayers.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,1382 @@
+  OpenLayers.js -- OpenLayers Map Viewer Library
+  Copyright 2005-2008 MetaCarta, Inc., released under the Clear BSD license.
+  Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+  for the full text of the license.
+  Includes compressed code under the following licenses:
+  (For uncompressed versions of the code used please see the
+  OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ *  (c) 2005 Sam Stephenson <sam at conio.net>
+ *  Prototype is freely distributable under the terms of an MIT-style license.
+ *  For details, see the Prototype web site: http://prototype.conio.net/
+*  Contains portions of Rico <http://openrico.org/>
+*  Copyright 2005 Sabre Airline Solutions
+*  Licensed under the Apache License, Version 2.0 (the "License"); you
+*  may not use this file except in compliance with the License. You
+*  may obtain a copy of the License at
+*         http://www.apache.org/licenses/LICENSE-2.0
+*  Unless required by applicable law or agreed to in writing, software
+*  distributed under the License is distributed on an "AS IS" BASIS,
+*  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+*  implied. See the License for the specific language governing
+*  permissions and limitations under the License.
+var OpenLayers={singleFile:true};(function(){var singleFile=(typeof OpenLayers=="object"&&OpenLayers.singleFile);window.OpenLayers={_scriptName:(!singleFile)?"lib/OpenLayers.js":"OpenLayers.js",_getScriptLocation:function(){var scriptLocation="";var scriptName=OpenLayers._scriptName;var scripts=document.getElementsByTagName('script');for(var i=0;i<scripts.length;i++){var src=scripts[i].getAttribute('src');if(src){var index=src.lastIndexOf(scriptName);var pathLength=src.lastIndexOf('?');if(pathLength<0){pathLength=src.length;}
+if((index>-1)&&(index+scriptName.length==pathLength)){scriptLocation=src.slice(0,pathLength-scriptName.length);break;}}}
+return scriptLocation;}};if(!singleFile){var jsfiles=new Array("OpenLayers/Util.js","OpenLayers/BaseTypes.js","OpenLayers/BaseTypes/Class.js","OpenLayers/BaseTypes/Bounds.js","OpenLayers/BaseTypes/Element.js","OpenLayers/BaseTypes/LonLat.js","OpenLayers/BaseTypes/Pixel.js","OpenLayers/BaseTypes/Size.js","OpenLayers/Console.js","OpenLayers/Tween.js","Rico/Corner.js","Rico/Color.js","OpenLayers/Ajax.js","OpenLayers/Events.js","OpenLayers/Projection.js","OpenLayers/Map.js","OpenLayers/Layer.js","OpenLayers/Icon.js","OpenLayers/Marker.js","OpenLayers/Marker/Box.js","OpenLayers/Popup.js","OpenLayers/Tile.js","OpenLayers/Tile/Image.js","OpenLayers/Tile/WFS.js","OpenLayers/Layer/Image.js","OpenLayers/Layer/SphericalMercator.js","OpenLayers/Layer/EventPane.js","OpenLayers/Layer/FixedZoomLevels.js","OpenLayers/Layer/Google.js","OpenLayers/Layer/VirtualEarth.js","OpenLayers/Layer/Yahoo.js","OpenLayers/Layer/HTTPRequest.js","OpenLayers/Layer/Grid.js","OpenLayers/Layer/MapGuide.js","OpenLayers/Layer/MapServer.js","OpenLayers/Layer/MapServer/Untiled.js","OpenLayers/Layer/KaMap.js","OpenLayers/Layer/MultiMap.js","OpenLayers/Layer/Markers.js","OpenLayers/Layer/Text.js","OpenLayers/Layer/WorldWind.js","OpenLayers/Layer/WMS.js","OpenLayers/Layer/WMS/Untiled.js","OpenLayers/Layer/GeoRSS.js","OpenLayers/Layer/Boxes.js","OpenLayers/Layer/TMS.js","OpenLayers/Layer/TileCache.js","OpenLayers/Popup/Anchored.js","OpenLayers/Popup/AnchoredBubble.js","OpenLayers/Popup/Framed.js","OpenLayers/Popup/FramedCloud.js","OpenLayers/Feature.js","OpenLayers/Feature/Vector.js","OpenLayers/Feature/WFS.js","OpenLayers/Handler.js","OpenLayers/Handler/Click.js","OpenLayers/Handler/Hover.js","OpenLayers/Handler/Point.js","OpenLayers/Handler/Path.js","OpenLayers/Handler/Polygon.js","OpenLayers/Handler/Feature.js","OpenLayers/Handler/Drag.js","OpenLayers/Handler/RegularPolygon.js","OpenLayers/Handler/Box.js","OpenLayers/Handler/MouseWheel.js","OpenLayers/Handler/Keyboard.js","OpenLayers/Control.js","OpenLayers/Control/Attribution.js","OpenLayers/Control/Button.js","OpenLayers/Control/ZoomBox.js","OpenLayers/Control/ZoomToMaxExtent.js","OpenLayers/Control/DragPan.js","OpenLayers/Control/Navigation.js","OpenLayers/Control/MouseDefaults.js","OpenLayers/Control/MousePosition.js","OpenLayers/Control/OverviewMap.js","OpenLayers/Control/KeyboardDefaults.js","OpenLayers/Control/PanZoom.js","OpenLayers/Control/PanZoomBar.js","OpenLayers/Control/ArgParser.js","OpenLayers/Control/Permalink.js","OpenLayers/Control/Scale.js","OpenLayers/Control/ScaleLine.js","OpenLayers/Control/LayerSwitcher.js","OpenLayers/Control/DrawFeature.js","OpenLayers/Control/DragFeature.js","OpenLayers/Control/ModifyFeature.js","OpenLayers/Control/Panel.js","OpenLayers/Control/SelectFeature.js","OpenLayers/Control/NavigationHistory.js","OpenLayers/Geometry.js","OpenLayers/Geometry/Rectangle.js","OpenLayers/Geometry/Collection.js","OpenLayers/Geometry/Point.js","OpenLayers/Geometry/MultiPoint.js","OpenLayers/Geometry/Curve.js","OpenLayers/Geometry/LineString.js","OpenLayers/Geometry/LinearRing.js","OpenLayers/Geometry/Polygon.js","OpenLayers/Geometry/MultiLineString.js","OpenLayers/Geometry/MultiPolygon.js","OpenLayers/Geometry/Surface.js","OpenLayers/Renderer.js","OpenLayers/Renderer/Elements.js","OpenLayers/Renderer/SVG.js","OpenLayers/Renderer/VML.js","OpenLayers/Layer/Vector.js","OpenLayers/Layer/PointTrack.js","OpenLayers/Layer/GML.js","OpenLayers/Style.js","OpenLayers/StyleMap.js","OpenLayers/Rule.js","OpenLayers/Filter.js","OpenLayers/Filter/FeatureId.js","OpenLayers/Filter/Logical.js","OpenLayers/Filter/Comparison.js","OpenLayers/Format.js","OpenLayers/Format/XML.js","OpenLayers/Format/GML.js","OpenLayers/Format/KML.js","OpenLayers/Format/GeoRSS.js","OpenLayers/Format/WFS.js","OpenLayers/Format/WKT.js","OpenLayers/Format/OSM.js","OpenLayers/Format/SLD.js","OpenLayers/Format/SLD/v1.js","OpenLayers/Format/SLD/v1_0_0.js","OpenLayers/Format/Text.js","OpenLayers/Format/JSON.js","OpenLayers/Format/GeoJSON.js","OpenLayers/Format/WMC.js","OpenLayers/Format/WMC/v1.js","OpenLayers/Format/WMC/v1_0_0.js","OpenLayers/Format/WMC/v1_1_0.js","OpenLayers/Layer/WFS.js","OpenLayers/Control/MouseToolbar.js","OpenLayers/Control/NavToolbar.js","OpenLayers/Control/EditingToolbar.js","OpenLayers/Lang.js","OpenLayers/Lang/en.js");var agent=navigator.userAgent;var docWrite=(agent.match("MSIE")||agent.match("Safari"));if(docWrite){var allScriptTags=new Array(jsfiles.length);}
+var host=OpenLayers._getScriptLocation()+"lib/";for(var i=0;i<jsfiles.length;i++){if(docWrite){allScriptTags[i]="<script src='"+host+jsfiles[i]+"'></script>";}else{var s=document.createElement("script");s.src=host+jsfiles[i];var h=document.getElementsByTagName("head").length?document.getElementsByTagName("head")[0]:document.body;h.appendChild(s);}}
+if(docWrite){document.write(allScriptTags.join(""));}}})();OpenLayers.VERSION_NUMBER="$Revision: 6819 $";OpenLayers.String={startsWith:function(str,sub){return(str.indexOf(sub)==0);},contains:function(str,sub){return(str.indexOf(sub)!=-1);},trim:function(str){return str.replace(/^\s*(.*?)\s*$/,"$1");},camelize:function(str){var oStringList=str.split('-');var camelizedString=oStringList[0];for(var i=1;i<oStringList.length;i++){var s=oStringList[i];camelizedString+=s.charAt(0).toUpperCase()+s.substring(1);}
+return camelizedString;},format:function(template,context,args){if(!context){context=window;}
+var tokens=template.split("${");var item,last,replacement;for(var i=1;i<tokens.length;i++){item=tokens[i];last=item.indexOf("}");if(last>0){replacement=context[item.substring(0,last)];if(typeof replacement=="function"){replacement=args?replacement.apply(null,args):replacement();}
+tokens[i]=replacement+item.substring(++last);}else{tokens[i]="${"+item;}}
+return tokens.join("");}};if(!String.prototype.startsWith){String.prototype.startsWith=function(sStart){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.startsWith'}));return OpenLayers.String.startsWith(this,sStart);};}
+if(!String.prototype.contains){String.prototype.contains=function(str){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.contains'}));return OpenLayers.String.contains(this,str);};}
+if(!String.prototype.trim){String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.trim'}));return OpenLayers.String.trim(this);};}
+if(!String.prototype.camelize){String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.camelize'}));return OpenLayers.String.camelize(this);};}
+OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(num,sig){var fig=0;if(sig>0){fig=parseFloat(num.toPrecision(sig));}
+return fig;},format:function(num,dec,tsep,dsep){dec=(typeof dec!="undefined")?dec:0;tsep=(typeof tsep!="undefined")?tsep:OpenLayers.Number.thousandsSeparator;dsep=(typeof dsep!="undefined")?dsep:OpenLayers.Number.decimalSeparator;if(dec!=null){num=parseFloat(num.toFixed(dec));}
+var parts=num.toString().split(".");if(parts.length==1&&dec==null){dec=0;}
+var integer=parts[0];if(tsep){var thousands=/(-?[0-9]+)([0-9]{3})/;while(thousands.test(integer)){integer=integer.replace(thousands,"$1"+tsep+"$2");}}
+var str;if(dec==0){str=integer;}else{var rem=parts.length>1?parts[1]:"0";if(dec!=null){rem=rem+new Array(dec-rem.length+1).join("0");}
+str=integer+dsep+rem;}
+return str;}};if(!Number.prototype.limitSigDigs){Number.prototype.limitSigDigs=function(sig){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.limitSigDigs'}));return OpenLayers.Number.limitSigDigs(this,sig);};}
+OpenLayers.Function={bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},bindAsEventListener:function(func,object){return function(event){return func.call(object,event||window.event);};}};if(!Function.prototype.bind){Function.prototype.bind=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.bind'}));Array.prototype.unshift.apply(arguments,[this]);return OpenLayers.Function.bind.apply(null,arguments);};}
+if(!Function.prototype.bindAsEventListener){Function.prototype.bindAsEventListener=function(object){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.bindAsEventListener'}));return OpenLayers.Function.bindAsEventListener(this,object);};}
+OpenLayers.Array={filter:function(array,callback,caller){var selected=[];if(Array.prototype.filter){selected=array.filter(callback,caller);}else{var len=array.length;if(typeof callback!="function"){throw new TypeError();}
+for(var i=0;i<len;i++){if(i in array){var val=array[i];if(callback.call(caller,val,i,array)){selected.push(val);}}}}
+return selected;}};OpenLayers.Class=function(){var Class=function(){if(arguments&&arguments[0]!=OpenLayers.Class.isPrototype){this.initialize.apply(this,arguments);}};var extended={};var parent;for(var i=0;i<arguments.length;++i){if(typeof arguments[i]=="function"){parent=arguments[i].prototype;}else{parent=arguments[i];}
+OpenLayers.Util.extend(extended,parent);}
+Class.prototype=extended;return Class;};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){if(arguments&&arguments[0]!=OpenLayers.Class.isPrototype){this.initialize.apply(this,arguments);}};};OpenLayers.Class.inherit=function(){var superClass=arguments[0];var proto=new superClass(OpenLayers.Class.isPrototype);for(var i=1;i<arguments.length;i++){if(typeof arguments[i]=="function"){var mixin=arguments[i];arguments[i]=new mixin(OpenLayers.Class.isPrototype);}
+OpenLayers.Util.extend(proto,arguments[i]);}
+return proto;};OpenLayers.Util={};OpenLayers.Util.getElement=function(){var elements=[];for(var i=0;i<arguments.length;i++){var element=arguments[i];if(typeof element=='string'){element=document.getElementById(element);}
+if(arguments.length==1){return element;}
+elements.push(element);}
+return elements;};if($==null){var $=OpenLayers.Util.getElement;}
+OpenLayers.Util.extend=function(destination,source){if(destination&&source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
+var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty('toString')){destination.toString=source.toString;}}
+return destination;};OpenLayers.Util.removeItem=function(array,item){for(var i=array.length-1;i>=0;i--){if(array[i]==item){array.splice(i,1);}}
+return array;};OpenLayers.Util.clearArray=function(array){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'array = []'}));array.length=0;};OpenLayers.Util.indexOf=function(array,obj){for(var i=0;i<array.length;i++){if(array[i]==obj){return i;}}
+return-1;};OpenLayers.Util.modifyDOMElement=function(element,id,px,sz,position,border,overflow,opacity){if(id){element.id=id;}
+if(px){element.style.left=px.x+"px";element.style.top=px.y+"px";}
+if(sz){element.style.width=sz.w+"px";element.style.height=sz.h+"px";}
+if(position){element.style.position=position;}
+if(border){element.style.border=border;}
+if(overflow){element.style.overflow=overflow;}
+if(parseFloat(opacity)>=0.0&&parseFloat(opacity)<1.0){element.style.filter='alpha(opacity='+(opacity*100)+')';element.style.opacity=opacity;}else if(parseFloat(opacity)==1.0){element.style.filter='';element.style.opacity='';}};OpenLayers.Util.createDiv=function(id,px,sz,imgURL,position,border,overflow,opacity){var dom=document.createElement('div');if(imgURL){dom.style.backgroundImage='url('+imgURL+')';}
+if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
+if(!position){position="absolute";}
+OpenLayers.Util.modifyDOMElement(dom,id,px,sz,position,border,overflow,opacity);return dom;};OpenLayers.Util.createImage=function(id,px,sz,imgURL,position,border,opacity,delayDisplay){var image=document.createElement("img");if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
+if(!position){position="relative";}
+OpenLayers.Util.modifyDOMElement(image,id,px,sz,position,border,null,opacity);if(delayDisplay){image.style.display="none";OpenLayers.Event.observe(image,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,image));OpenLayers.Event.observe(image,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,image));}
+image.style.alt=id;image.galleryImg="no";if(imgURL){image.src=imgURL;}
+return image;};OpenLayers.Util.setOpacity=function(element,opacity){OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);};OpenLayers.Util.onImageLoad=function(){if(!this.viewRequestID||(this.map&&this.viewRequestID==this.map.viewRequestID)){this.style.backgroundColor=null;this.style.display="";}};OpenLayers.Util.onImageLoadErrorColor="pink";OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;OpenLayers.Util.onImageLoadError=function(){this._attempts=(this._attempts)?(this._attempts+1):1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){this.src=this.src;}else{this.style.backgroundColor=OpenLayers.Util.onImageLoadErrorColor;}
+this.style.display="";};OpenLayers.Util.alphaHack=function(){var arVersion=navigator.appVersion.split("MSIE");var version=parseFloat(arVersion[1]);var filter=false;try{filter=!!(document.body.filters);}catch(e){}
+return(filter&&(version>=5.5)&&(version<7));};OpenLayers.Util.modifyAlphaImageDiv=function(div,id,px,sz,imgURL,position,border,sizing,opacity){OpenLayers.Util.modifyDOMElement(div,id,px,sz,null,null,null,opacity);var img=div.childNodes[0];if(imgURL){img.src=imgURL;}
+OpenLayers.Util.modifyDOMElement(img,div.id+"_innerImage",null,sz,"relative",border);if(OpenLayers.Util.alphaHack()){div.style.display="inline-block";if(sizing==null){sizing="scale";}
+div.style.filter="progid:DXImageTransform.Microsoft"+".AlphaImageLoader(src='"+img.src+"', "+"sizingMethod='"+sizing+"')";if(parseFloat(div.style.opacity)>=0.0&&parseFloat(div.style.opacity)<1.0){div.style.filter+=" alpha(opacity="+div.style.opacity*100+")";}
+img.style.filter="alpha(opacity=0)";}};OpenLayers.Util.createAlphaImageDiv=function(id,px,sz,imgURL,position,border,sizing,opacity,delayDisplay){var div=OpenLayers.Util.createDiv();var img=OpenLayers.Util.createImage(null,null,null,null,null,null,null,false);div.appendChild(img);if(delayDisplay){img.style.display="none";OpenLayers.Event.observe(img,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,div));OpenLayers.Event.observe(img,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,div));}
+OpenLayers.Util.modifyAlphaImageDiv(div,id,px,sz,imgURL,position,border,sizing,opacity);return div;};OpenLayers.Util.upperCaseObject=function(object){var uObject={};for(var key in object){uObject[key.toUpperCase()]=object[key];}
+return uObject;};OpenLayers.Util.applyDefaults=function(to,from){var fromIsEvt=typeof window.Event=="function"&&from instanceof window.Event;for(var key in from){if(to[key]===undefined||(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty(key)&&!to.hasOwnProperty(key))){to[key]=from[key];}}
+if(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty('toString')&&!to.hasOwnProperty('toString')){to.toString=from.toString;}
+return to;};OpenLayers.Util.getParameterString=function(params){var paramsArray=[];for(var key in params){var value=params[key];if((value!=null)&&(typeof value!='function')){var encodedValue;if(typeof value=='object'&&value.constructor==Array){var encodedItemArray=[];for(var itemIndex=0;itemIndex<value.length;itemIndex++){encodedItemArray.push(encodeURIComponent(value[itemIndex]));}
+encodedValue=encodedItemArray.join(",");}
+else{encodedValue=encodeURIComponent(value);}
+paramsArray.push(encodeURIComponent(key)+"="+encodedValue);}}
+return paramsArray.join("&");};OpenLayers.ImgPath='';OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||(OpenLayers._getScriptLocation()+"img/");};OpenLayers.Util.Try=function(){var returnValue=null;for(var i=0;i<arguments.length;i++){var lambda=arguments[i];try{returnValue=lambda();break;}catch(e){}}
+return returnValue;};OpenLayers.Util.getNodes=function(p,tagName){var nodes=OpenLayers.Util.Try(function(){return OpenLayers.Util._getNodes(p.documentElement.childNodes,tagName);},function(){return OpenLayers.Util._getNodes(p.childNodes,tagName);});return nodes;};OpenLayers.Util._getNodes=function(nodes,tagName){var retArray=[];for(var i=0;i<nodes.length;i++){if(nodes[i].nodeName==tagName){retArray.push(nodes[i]);}}
+return retArray;};OpenLayers.Util.getTagText=function(parent,item,index){var result=OpenLayers.Util.getNodes(parent,item);if(result&&(result.length>0))
+{if(!index){index=0;}
+if(result[index].childNodes.length>1){return result.childNodes[1].nodeValue;}
+else if(result[index].childNodes.length==1){return result[index].firstChild.nodeValue;}}else{return"";}};OpenLayers.Util.getXmlNodeValue=function(node){var val=null;OpenLayers.Util.Try(function(){val=node.text;if(!val){val=node.textContent;}
+if(!val){val=node.firstChild.nodeValue;}},function(){val=node.textContent;});return val;};OpenLayers.Util.mouseLeft=function(evt,div){var target=(evt.relatedTarget)?evt.relatedTarget:evt.toElement;while(target!=div&&target!=null){target=target.parentNode;}
+return(target!=div);};OpenLayers.Util.rad=function(x){return x*Math.PI/180;};OpenLayers.Util.distVincenty=function(p1,p2){var a=6378137,b=6356752.3142,f=1/298.257223563;var L=OpenLayers.Util.rad(p2.lon-p1.lon);var U1=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p1.lat)));var U2=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p2.lat)));var sinU1=Math.sin(U1),cosU1=Math.cos(U1);var sinU2=Math.sin(U2),cosU2=Math.cos(U2);var lambda=L,lambdaP=2*Math.PI;var iterLimit=20;while(Math.abs(lambda-lambdaP)>1e-12&&--iterLimit>0){var sinLambda=Math.sin(lambda),cosLambda=Math.cos(lambda);var sinSigma=Math.sqrt((cosU2*sinLambda)*(cosU2*sinLambda)+
+(cosU1*sinU2-sinU1*cosU2*cosLambda)*(cosU1*sinU2-sinU1*cosU2*cosLambda));if(sinSigma==0){return 0;}
+var cosSigma=sinU1*sinU2+cosU1*cosU2*cosLambda;var sigma=Math.atan2(sinSigma,cosSigma);var alpha=Math.asin(cosU1*cosU2*sinLambda/sinSigma);var cosSqAlpha=Math.cos(alpha)*Math.cos(alpha);var cos2SigmaM=cosSigma-2*sinU1*sinU2/cosSqAlpha;var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));lambdaP=lambda;lambda=L+(1-C)*f*Math.sin(alpha)*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));}
+if(iterLimit==0){return NaN;}
+var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)-
+B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));var s=b*A*(sigma-deltaSigma);var d=s.toFixed(3)/1000;return d;};OpenLayers.Util.getParameters=function(url){url=url||window.location.href;var paramsString="";if(OpenLayers.String.contains(url,'?')){var start=url.indexOf('?')+1;var end=OpenLayers.String.contains(url,"#")?url.indexOf('#'):url.length;paramsString=url.substring(start,end);}
+var parameters={};var pairs=paramsString.split(/[&;]/);for(var i=0;i<pairs.length;++i){var keyValue=pairs[i].split('=');if(keyValue[0]){var key=decodeURIComponent(keyValue[0]);var value=keyValue[1]||'';value=value.split(",");for(var j=0;j<value.length;j++){value[j]=decodeURIComponent(value[j]);}
+if(value.length==1){value=value[0];}
+parameters[key]=value;}}
+return parameters;};OpenLayers.Util.getArgs=function(url){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Util.getParameters'}));return OpenLayers.Util.getParameters(url);};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(prefix){if(prefix==null){prefix="id_";}
+OpenLayers.Util.lastSeqID+=1;return prefix+OpenLayers.Util.lastSeqID;};OpenLayers.INCHES_PER_UNIT={'inches':1.0,'ft':12.0,'mi':63360.0,'m':39.3701,'km':39370.1,'dd':4374754,'yd':36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;OpenLayers.INCHES_PER_UNIT["degrees"]=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT["nmi"]=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.DOTS_PER_INCH=72;OpenLayers.Util.normalizeScale=function(scale){var normScale=(scale>1.0)?(1.0/scale):scale;return normScale;};OpenLayers.Util.getResolutionFromScale=function(scale,units){if(units==null){units="degrees";}
+var normScale=OpenLayers.Util.normalizeScale(scale);var resolution=1/(normScale*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH);return resolution;};OpenLayers.Util.getScaleFromResolution=function(resolution,units){if(units==null){units="degrees";}
+var scale=resolution*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH;return scale;};OpenLayers.Util.safeStopPropagation=function(evt){OpenLayers.Event.stop(evt,true);};OpenLayers.Util.pagePosition=function(forElement){var valueT=0,valueL=0;var element=forElement;var child=forElement;while(element){if(element==document.body){if(child&&child.style&&OpenLayers.Element.getStyle(child,'position')=='absolute'){break;}}
+valueT+=element.offsetTop||0;valueL+=element.offsetLeft||0;child=element;try{element=element.offsetParent;}catch(e){OpenLayers.Console.error(OpenLayers.i18n("pagePositionFailed",{'elemId':element.id}));break;}}
+element=forElement;while(element){valueT-=element.scrollTop||0;valueL-=element.scrollLeft||0;element=element.parentNode;}
+return[valueL,valueT];};OpenLayers.Util.isEquivalentUrl=function(url1,url2,options){options=options||{};OpenLayers.Util.applyDefaults(options,{ignoreCase:true,ignorePort80:true,ignoreHash:true});var urlObj1=OpenLayers.Util.createUrlObject(url1,options);var urlObj2=OpenLayers.Util.createUrlObject(url2,options);for(var key in urlObj1){if(options.test){alert(key+"\n1:"+urlObj1[key]+"\n2:"+urlObj2[key]);}
+var val1=urlObj1[key];var val2=urlObj2[key];switch(key){case"args":break;case"host":case"port":case"protocol":if((val1=="")||(val2=="")){break;}
+default:if((key!="args")&&(urlObj1[key]!=urlObj2[key])){return false;}
+break;}}
+for(var key in urlObj1.args){if(urlObj1.args[key]!=urlObj2.args[key]){return false;}
+delete urlObj2.args[key];}
+for(var key in urlObj2.args){return false;}
+return true;};OpenLayers.Util.createUrlObject=function(url,options){options=options||{};var urlObject={};if(options.ignoreCase){url=url.toLowerCase();}
+var a=document.createElement('a');a.href=url;urlObject.host=a.host;var port=a.port;if(port.length<=0){var newHostLength=urlObject.host.length-(port.length);urlObject.host=urlObject.host.substring(0,newHostLength);}
+urlObject.protocol=a.protocol;urlObject.port=((port=="80")&&(options.ignorePort80))?"":port;urlObject.hash=(options.ignoreHash)?"":a.hash;var queryString=a.search;if(!queryString){var qMark=url.indexOf("?");queryString=(qMark!=-1)?url.substr(qMark):"";}
+urlObject.args=OpenLayers.Util.getParameters(queryString);if(((urlObject.protocol=="file:")&&(url.indexOf("file:")!=-1))||((urlObject.protocol!="file:")&&(urlObject.host!=""))){urlObject.pathname=a.pathname;var qIndex=urlObject.pathname.indexOf("?");if(qIndex!=-1){urlObject.pathname=urlObject.pathname.substring(0,qIndex);}}else{var relStr=OpenLayers.Util.removeTail(url);var backs=0;do{var index=relStr.indexOf("../");if(index==0){backs++;relStr=relStr.substr(3);}else if(index>=0){var prevChunk=relStr.substr(0,index-1);var slash=prevChunk.indexOf("/");prevChunk=(slash!=-1)?prevChunk.substr(0,slash+1):"";var postChunk=relStr.substr(index+3);relStr=prevChunk+postChunk;}}while(index!=-1)
+var windowAnchor=document.createElement("a");var windowUrl=window.location.href;if(options.ignoreCase){windowUrl=windowUrl.toLowerCase();}
+windowAnchor.href=windowUrl;urlObject.protocol=windowAnchor.protocol;var splitter=(windowAnchor.pathname.indexOf("/")!=-1)?"/":"\\";var dirs=windowAnchor.pathname.split(splitter);dirs.pop();while((backs>0)&&(dirs.length>0)){dirs.pop();backs--;}
+relStr=dirs.join("/")+"/"+relStr;urlObject.pathname=relStr;}
+if((urlObject.protocol=="file:")||(urlObject.protocol=="")){urlObject.host="localhost";}
+return urlObject;};OpenLayers.Util.removeTail=function(url){var head=null;var qMark=url.indexOf("?");var hashMark=url.indexOf("#");if(qMark==-1){head=(hashMark!=-1)?url.substr(0,hashMark):url;}else{head=(hashMark!=-1)?url.substr(0,Math.min(qMark,hashMark)):url.substr(0,qMark);}
+return head;};OpenLayers.Util.getBrowserName=function(){var browserName="";var ua=navigator.userAgent.toLowerCase();if(ua.indexOf("opera")!=-1){browserName="opera";}else if(ua.indexOf("msie")!=-1){browserName="msie";}else if(ua.indexOf("safari")!=-1){browserName="safari";}else if(ua.indexOf("mozilla")!=-1){if(ua.indexOf("firefox")!=-1){browserName="firefox";}else{browserName="mozilla";}}
+return browserName;};OpenLayers.Util.getRenderedDimensions=function(contentHTML,size){var w=h=null;var container=document.createElement("div");container.style.overflow="";container.style.position="absolute";container.style.left="-9999px";if(size){if(size.w){w=container.style.width=size.w;}else if(size.h){h=container.style.height=size.h;}}
+var content=document.createElement("div");content.innerHTML=contentHTML;container.appendChild(content);document.body.appendChild(container);if(!w){w=parseInt(content.scrollWidth);container.style.width=w+"px";}
+if(!h){h=parseInt(content.scrollHeight);}
+container.removeChild(content);document.body.removeChild(container);return new OpenLayers.Size(w,h);};OpenLayers.Util.getScrollbarWidth=function(){var scrollbarWidth=OpenLayers.Util._scrollbarWidth;if(scrollbarWidth==null){var scr=null;var inn=null;var wNoScroll=0;var wScroll=0;scr=document.createElement('div');scr.style.position='absolute';scr.style.top='-1000px';scr.style.left='-1000px';scr.style.width='100px';scr.style.height='50px';scr.style.overflow='hidden';inn=document.createElement('div');inn.style.width='100%';inn.style.height='200px';scr.appendChild(inn);document.body.appendChild(scr);wNoScroll=inn.offsetWidth;scr.style.overflow='scroll';wScroll=inn.offsetWidth;document.body.removeChild(document.body.lastChild);OpenLayers.Util._scrollbarWidth=(wNoScroll-wScroll);scrollbarWidth=OpenLayers.Util._scrollbarWidth;}
+return scrollbarWidth;};OpenLayers.Rico=new Object();OpenLayers.Rico.Corner={round:function(e,options){e=OpenLayers.Util.getElement(e);this._setOptions(options);var color=this.options.color;if(this.options.color=="fromElement"){color=this._background(e);}
+var bgColor=this.options.bgColor;if(this.options.bgColor=="fromParent"){bgColor=this._background(e.offsetParent);}
+this._roundCornersImpl(e,color,bgColor);},changeColor:function(theDiv,newColor){theDiv.style.backgroundColor=newColor;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.backgroundColor=newColor;}},changeOpacity:function(theDiv,newOpacity){var mozillaOpacity=newOpacity;var ieOpacity='alpha(opacity='+newOpacity*100+')';theDiv.style.opacity=mozillaOpacity;theDiv.style.filter=ieOpacity;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.opacity=mozillaOpacity;spanElements[currIdx].style.filter=ieOpacity;}},reRound:function(theDiv,options){var topRico=theDiv.parentNode.childNodes[0];var bottomRico=theDiv.parentNode.childNodes[2];theDiv.parentNode.removeChild(topRico);theDiv.parentNode.removeChild(bottomRico);this.round(theDiv.parentNode,options);},_roundCornersImpl:function(e,color,bgColor){if(this.options.border){this._renderBorder(e,bgColor);}
+if(this._isTopRounded()){this._roundTopCorners(e,color,bgColor);}
+if(this._isBottomRounded()){this._roundBottomCorners(e,color,bgColor);}},_renderBorder:function(el,bgColor){var borderValue="1px solid "+this._borderColor(bgColor);var borderL="border-left: "+borderValue;var borderR="border-right: "+borderValue;var style="style='"+borderL+";"+borderR+"'";el.innerHTML="<div "+style+">"+el.innerHTML+"</div>";},_roundTopCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=0;i<this.options.numSlices;i++){corner.appendChild(this._createCornerSlice(color,bgColor,i,"top"));}
+el.style.paddingTop=0;el.insertBefore(corner,el.firstChild);},_roundBottomCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=(this.options.numSlices-1);i>=0;i--){corner.appendChild(this._createCornerSlice(color,bgColor,i,"bottom"));}
+el.style.paddingBottom=0;el.appendChild(corner);},_createCorner:function(bgColor){var corner=document.createElement("div");corner.style.backgroundColor=(this._isTransparent()?"transparent":bgColor);return corner;},_createCornerSlice:function(color,bgColor,n,position){var slice=document.createElement("span");var inStyle=slice.style;inStyle.backgroundColor=color;inStyle.display="block";inStyle.height="1px";inStyle.overflow="hidden";inStyle.fontSize="1px";var borderColor=this._borderColor(color,bgColor);if(this.options.border&&n==0){inStyle.borderTopStyle="solid";inStyle.borderTopWidth="1px";inStyle.borderLeftWidth="0px";inStyle.borderRightWidth="0px";inStyle.borderBottomWidth="0px";inStyle.height="0px";inStyle.borderColor=borderColor;}
+else if(borderColor){inStyle.borderColor=borderColor;inStyle.borderStyle="solid";inStyle.borderWidth="0px 1px";}
+if(!this.options.compact&&(n==(this.options.numSlices-1))){inStyle.height="2px";}
+this._setMargin(slice,n,position);this._setBorder(slice,n,position);return slice;},_setOptions:function(options){this.options={corners:"all",color:"fromElement",bgColor:"fromParent",blend:true,border:false,compact:false};OpenLayers.Util.extend(this.options,options||{});this.options.numSlices=this.options.compact?2:4;if(this._isTransparent()){this.options.blend=false;}},_whichSideTop:function(){if(this._hasString(this.options.corners,"all","top")){return"";}
+if(this.options.corners.indexOf("tl")>=0&&this.options.corners.indexOf("tr")>=0){return"";}
+if(this.options.corners.indexOf("tl")>=0){return"left";}else if(this.options.corners.indexOf("tr")>=0){return"right";}
+return"";},_whichSideBottom:function(){if(this._hasString(this.options.corners,"all","bottom")){return"";}
+if(this.options.corners.indexOf("bl")>=0&&this.options.corners.indexOf("br")>=0){return"";}
+if(this.options.corners.indexOf("bl")>=0){return"left";}else if(this.options.corners.indexOf("br")>=0){return"right";}
+return"";},_borderColor:function(color,bgColor){if(color=="transparent"){return bgColor;}else if(this.options.border){return this.options.border;}else if(this.options.blend){return this._blend(bgColor,color);}else{return"";}},_setMargin:function(el,n,corners){var marginSize=this._marginSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.marginLeft=marginSize+"px";el.style.marginRight="0px";}
+else if(whichSide=="right"){el.style.marginRight=marginSize+"px";el.style.marginLeft="0px";}
+else{el.style.marginLeft=marginSize+"px";el.style.marginRight=marginSize+"px";}},_setBorder:function(el,n,corners){var borderSize=this._borderSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth="0px";}
+else if(whichSide=="right"){el.style.borderRightWidth=borderSize+"px";el.style.borderLeftWidth="0px";}
+else{el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}
+if(this.options.border!=false){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}},_marginSize:function(n){if(this._isTransparent()){return 0;}
+var marginSizes=[5,3,2,1];var blendedMarginSizes=[3,2,1,0];var compactMarginSizes=[2,1];var smBlendedMarginSizes=[1,0];if(this.options.compact&&this.options.blend){return smBlendedMarginSizes[n];}else if(this.options.compact){return compactMarginSizes[n];}else if(this.options.blend){return blendedMarginSizes[n];}else{return marginSizes[n];}},_borderSize:function(n){var transparentBorderSizes=[5,3,2,1];var blendedBorderSizes=[2,1,1,1];var compactBorderSizes=[1,0];var actualBorderSizes=[0,2,0,0];if(this.options.compact&&(this.options.blend||this._isTransparent())){return 1;}else if(this.options.compact){return compactBorderSizes[n];}else if(this.options.blend){return blendedBorderSizes[n];}else if(this.options.border){return actualBorderSizes[n];}else if(this._isTransparent()){return transparentBorderSizes[n];}
+return 0;},_hasString:function(str){for(var i=1;i<arguments.length;i++)if(str.indexOf(arguments[i])>=0){return true;}return false;},_blend:function(c1,c2){var cc1=OpenLayers.Rico.Color.createFromHex(c1);cc1.blend(OpenLayers.Rico.Color.createFromHex(c2));return cc1;},_background:function(el){try{return OpenLayers.Rico.Color.createColorFromBackground(el).asHex();}catch(err){return"#ffffff";}},_isTransparent:function(){return this.options.color=="transparent";},_isTopRounded:function(){return this._hasString(this.options.corners,"all","top","tl","tr");},_isBottomRounded:function(){return this._hasString(this.options.corners,"all","bottom","bl","br");},_hasSingleTextChild:function(el){return el.childNodes.length==1&&el.childNodes[0].nodeType==3;}};OpenLayers.ProxyHost="";OpenLayers.nullHandler=function(request){alert(OpenLayers.i18n("unhandledRequest",{'statusText':request.statusText}));};OpenLayers.loadURL=function(uri,params,caller,onComplete,onFailure){var success=(onComplete)?OpenLayers.Function.bind(onComplete,caller):OpenLayers.nullHandler;var failure=(onFailure)?OpenLayers.Function.bind(onFailure,caller):OpenLayers.nullHandler;var request=new OpenLayers.Ajax.Request(uri,{method:'get',parameters:params,onComplete:success,onFailure:failure});return request.transport;};OpenLayers.parseXMLString=function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
+var ajaxResponse=OpenLayers.Util.Try(function(){var xmldom=new ActiveXObject('Microsoft.XMLDOM');xmldom.loadXML(text);return xmldom;},function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
+req.send(null);return req.responseXML;});return ajaxResponse;};OpenLayers.Ajax={emptyFunction:function(){},getTransport:function(){return OpenLayers.Util.Try(function(){return new XMLHttpRequest();},function(){return new ActiveXObject('Msxml2.XMLHTTP');},function(){return new ActiveXObject('Microsoft.XMLHTTP');})||false;},activeRequestCount:0};OpenLayers.Ajax.Responders={responders:[],register:function(responderToAdd){for(var i=0;i<this.responders.length;i++){if(responderToAdd==this.responders[i]){return;}}
+this.responders.push(responderToAdd);},unregister:function(responderToRemove){OpenLayers.Util.removeItem(this.reponders,responderToRemove);},dispatch:function(callback,request,transport){var responder;for(var i=0;i<this.responders.length;i++){responder=this.responders[i];if(responder[callback]&&typeof responder[callback]=='function'){try{responder[callback].apply(responder,[request,transport]);}catch(e){}}}}};OpenLayers.Ajax.Responders.register({onCreate:function(){OpenLayers.Ajax.activeRequestCount++;},onComplete:function(){OpenLayers.Ajax.activeRequestCount--;}});OpenLayers.Ajax.Base=OpenLayers.Class({initialize:function(options){this.options={method:'post',asynchronous:true,contentType:'application/xml',parameters:''};OpenLayers.Util.extend(this.options,options||{});this.options.method=this.options.method.toLowerCase();if(typeof this.options.parameters=='string'){this.options.parameters=OpenLayers.Util.getParameters(this.options.parameters);}}});OpenLayers.Ajax.Request=OpenLayers.Class(OpenLayers.Ajax.Base,{_complete:false,initialize:function(url,options){OpenLayers.Ajax.Base.prototype.initialize.apply(this,[options]);if(OpenLayers.ProxyHost&&OpenLayers.String.startsWith(url,"http")){url=OpenLayers.ProxyHost+encodeURIComponent(url);}
+this.transport=OpenLayers.Ajax.getTransport();this.request(url);},request:function(url){this.url=url;this.method=this.options.method;var params=OpenLayers.Util.extend({},this.options.parameters);if(this.method!='get'&&this.method!='post'){params['_method']=this.method;this.method='post';}
+this.parameters=params;if(params=OpenLayers.Util.getParameterString(params)){if(this.method=='get'){this.url+=((this.url.indexOf('?')>-1)?'&':'?')+params;}else if(/Konqueror|Safari|KHTML/.test(navigator.userAgent)){params+='&_=';}}
+try{var response=new OpenLayers.Ajax.Response(this);if(this.options.onCreate){this.options.onCreate(response);}
+OpenLayers.Ajax.Responders.dispatch('onCreate',this,response);this.transport.open(this.method.toUpperCase(),this.url,this.options.asynchronous);if(this.options.asynchronous){window.setTimeout(OpenLayers.Function.bind(this.respondToReadyState,this,1),10);}
+this.transport.onreadystatechange=OpenLayers.Function.bind(this.onStateChange,this);this.setRequestHeaders();this.body=this.method=='post'?(this.options.postBody||params):null;this.transport.send(this.body);if(!this.options.asynchronous&&this.transport.overrideMimeType){this.onStateChange();}}catch(e){this.dispatchException(e);}},onStateChange:function(){var readyState=this.transport.readyState;if(readyState>1&&!((readyState==4)&&this._complete)){this.respondToReadyState(this.transport.readyState);}},setRequestHeaders:function(){var headers={'X-Requested-With':'XMLHttpRequest','Accept':'text/javascript, text/html, application/xml, text/xml, */*','OpenLayers':true};if(this.method=='post'){headers['Content-type']=this.options.contentType+
+(this.options.encoding?'; charset='+this.options.encoding:'');if(this.transport.overrideMimeType&&(navigator.userAgent.match(/Gecko\/(\d{4})/)||[0,2005])[1]<2005){headers['Connection']='close';}}
+if(typeof this.options.requestHeaders=='object'){var extras=this.options.requestHeaders;if(typeof extras.push=='function'){for(var i=0,length=extras.length;i<length;i+=2){headers[extras[i]]=extras[i+1];}}else{for(var i in extras){headers[i]=pair[i];}}}
+for(var name in headers){this.transport.setRequestHeader(name,headers[name]);}},success:function(){var status=this.getStatus();return!status||(status>=200&&status<300);},getStatus:function(){try{return this.transport.status||0;}catch(e){return 0;}},respondToReadyState:function(readyState){var state=OpenLayers.Ajax.Request.Events[readyState];var response=new OpenLayers.Ajax.Response(this);if(state=='Complete'){try{this._complete=true;(this.options['on'+response.status]||this.options['on'+(this.success()?'Success':'Failure')]||OpenLayers.Ajax.emptyFunction)(response);}catch(e){this.dispatchException(e);}
+var contentType=response.getHeader('Content-type');}
+try{(this.options['on'+state]||OpenLayers.Ajax.emptyFunction)(response);OpenLayers.Ajax.Responders.dispatch('on'+state,this,response);}catch(e){this.dispatchException(e);}
+if(state=='Complete'){this.transport.onreadystatechange=OpenLayers.Ajax.emptyFunction;}},getHeader:function(name){try{return this.transport.getResponseHeader(name);}catch(e){return null;}},dispatchException:function(exception){var handler=this.options.onException;if(handler){handler(this,exception);OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{var listener=false;var responders=OpenLayers.Ajax.Responders.responders;for(var i=0;i<responders.length;i++){if(responders[i].onException){listener=true;break;}}
+if(listener){OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{throw exception;}}}});OpenLayers.Ajax.Request.Events=['Uninitialized','Loading','Loaded','Interactive','Complete'];OpenLayers.Ajax.Response=OpenLayers.Class({status:0,statusText:'',initialize:function(request){this.request=request;var transport=this.transport=request.transport,readyState=this.readyState=transport.readyState;if((readyState>2&&!(!!(window.attachEvent&&!window.opera)))||readyState==4){this.status=this.getStatus();this.statusText=this.getStatusText();this.responseText=transport.responseText==null?'':String(transport.responseText);}
+if(readyState==4){var xml=transport.responseXML;this.responseXML=xml===undefined?null:xml;}},getStatus:OpenLayers.Ajax.Request.prototype.getStatus,getStatusText:function(){try{return this.transport.statusText||'';}catch(e){return'';}},getHeader:OpenLayers.Ajax.Request.prototype.getHeader,getResponseHeader:function(name){return this.transport.getResponseHeader(name);}});OpenLayers.Ajax.getElementsByTagNameNS=function(parentnode,nsuri,nsprefix,tagname){var elem=null;if(parentnode.getElementsByTagNameNS){elem=parentnode.getElementsByTagNameNS(nsuri,tagname);}else{elem=parentnode.getElementsByTagName(nsprefix+':'+tagname);}
+return elem;};OpenLayers.Ajax.serializeXMLToString=function(xmldom){var serializer=new XMLSerializer();var data=serializer.serializeToString(xmldom);return data;};OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=parseFloat(left);}
+if(bottom!=null){this.bottom=parseFloat(bottom);}
+if(right!=null){this.right=parseFloat(right);}
+if(top!=null){this.top=parseFloat(top);}},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top);},equals:function(bounds){var equals=false;if(bounds!=null){equals=((this.left==bounds.left)&&(this.right==bounds.right)&&(this.top==bounds.top)&&(this.bottom==bounds.bottom));}
+return equals;},toString:function(){return("left-bottom=("+this.left+","+this.bottom+")"
++" right-top=("+this.right+","+this.top+")");},toArray:function(){return[this.left,this.bottom,this.right,this.top];},toBBOX:function(decimal){if(decimal==null){decimal=6;}
+var mult=Math.pow(10,decimal);var bbox=Math.round(this.left*mult)/mult+","+
+Math.round(this.bottom*mult)/mult+","+
+Math.round(this.right*mult)/mult+","+
+Math.round(this.top*mult)/mult;return bbox;},toGeometry:function(){return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(this.left,this.bottom),new OpenLayers.Geometry.Point(this.right,this.bottom),new OpenLayers.Geometry.Point(this.right,this.top),new OpenLayers.Geometry.Point(this.left,this.top)])]);},getWidth:function(){return(this.right-this.left);},getHeight:function(){return(this.top-this.bottom);},getSize:function(){return new OpenLayers.Size(this.getWidth(),this.getHeight());},getCenterPixel:function(){return new OpenLayers.Pixel((this.left+this.right)/2,(this.bottom+this.top)/2);},getCenterLonLat:function(){return new OpenLayers.LonLat((this.left+this.right)/2,(this.bottom+this.top)/2);},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("boundsAddError");OpenLayers.Console.error(msg);return null;}
+return new OpenLayers.Bounds(this.left+x,this.bottom+y,this.right+x,this.top+y);},extend:function(object){var bounds=null;if(object){switch(object.CLASS_NAME){case"OpenLayers.LonLat":bounds=new OpenLayers.Bounds(object.lon,object.lat,object.lon,object.lat);break;case"OpenLayers.Geometry.Point":bounds=new OpenLayers.Bounds(object.x,object.y,object.x,object.y);break;case"OpenLayers.Bounds":bounds=object;break;}
+if(bounds){if((this.left==null)||(bounds.left<this.left)){this.left=bounds.left;}
+if((this.bottom==null)||(bounds.bottom<this.bottom)){this.bottom=bounds.bottom;}
+if((this.right==null)||(bounds.right>this.right)){this.right=bounds.right;}
+if((this.top==null)||(bounds.top>this.top)){this.top=bounds.top;}}}},containsLonLat:function(ll,inclusive){return this.contains(ll.lon,ll.lat,inclusive);},containsPixel:function(px,inclusive){return this.contains(px.x,px.y,inclusive);},contains:function(x,y,inclusive){if(inclusive==null){inclusive=true;}
+var contains=false;if(inclusive){contains=((x>=this.left)&&(x<=this.right)&&(y>=this.bottom)&&(y<=this.top));}else{contains=((x>this.left)&&(x<this.right)&&(y>this.bottom)&&(y<this.top));}
+return contains;},intersectsBounds:function(bounds,inclusive){if(inclusive==null){inclusive=true;}
+var inBottom=(bounds.bottom==this.bottom&&bounds.top==this.top)?true:(((bounds.bottom>this.bottom)&&(bounds.bottom<this.top))||((this.bottom>bounds.bottom)&&(this.bottom<bounds.top)));var inTop=(bounds.bottom==this.bottom&&bounds.top==this.top)?true:(((bounds.top>this.bottom)&&(bounds.top<this.top))||((this.top>bounds.bottom)&&(this.top<bounds.top)));var inRight=(bounds.right==this.right&&bounds.left==this.left)?true:(((bounds.right>this.left)&&(bounds.right<this.right))||((this.right>bounds.left)&&(this.right<bounds.right)));var inLeft=(bounds.right==this.right&&bounds.left==this.left)?true:(((bounds.left>this.left)&&(bounds.left<this.right))||((this.left>bounds.left)&&(this.left<bounds.right)));return(this.containsBounds(bounds,true,inclusive)||bounds.containsBounds(this,true,inclusive)||((inTop||inBottom)&&(inLeft||inRight)));},containsBounds:function(bounds,partial,inclusive){if(partial==null){partial=false;}
+if(inclusive==null){inclusive=true;}
+var inLeft;var inTop;var inRight;var inBottom;if(inclusive){inLeft=(bounds.left>=this.left)&&(bounds.left<=this.right);inTop=(bounds.top>=this.bottom)&&(bounds.top<=this.top);inRight=(bounds.right>=this.left)&&(bounds.right<=this.right);inBottom=(bounds.bottom>=this.bottom)&&(bounds.bottom<=this.top);}else{inLeft=(bounds.left>this.left)&&(bounds.left<this.right);inTop=(bounds.top>this.bottom)&&(bounds.top<this.top);inRight=(bounds.right>this.left)&&(bounds.right<this.right);inBottom=(bounds.bottom>this.bottom)&&(bounds.bottom<this.top);}
+return(partial)?(inTop||inBottom)&&(inLeft||inRight):(inTop&&inLeft&&inBottom&&inRight);},determineQuadrant:function(lonlat){var quadrant="";var center=this.getCenterLonLat();quadrant+=(lonlat.lat<center.lat)?"b":"t";quadrant+=(lonlat.lon<center.lon)?"l":"r";return quadrant;},transform:function(source,dest){var ll=OpenLayers.Projection.transform({'x':this.left,'y':this.bottom},source,dest);var lr=OpenLayers.Projection.transform({'x':this.right,'y':this.bottom},source,dest);var ul=OpenLayers.Projection.transform({'x':this.left,'y':this.top},source,dest);var ur=OpenLayers.Projection.transform({'x':this.right,'y':this.top},source,dest);this.left=Math.min(ll.x,ul.x);this.bottom=Math.min(ll.y,lr.y);this.right=Math.max(lr.x,ur.x);this.top=Math.max(ul.y,ur.y);return this;},wrapDateLine:function(maxExtent,options){options=options||{};var leftTolerance=options.leftTolerance||0;var rightTolerance=options.rightTolerance||0;var newBounds=this.clone();if(maxExtent){while(newBounds.left<maxExtent.left&&(newBounds.right-rightTolerance)<=maxExtent.left){newBounds=newBounds.add(maxExtent.getWidth(),0);}
+while((newBounds.left+leftTolerance)>=maxExtent.right&&newBounds.right>maxExtent.right){newBounds=newBounds.add(-maxExtent.getWidth(),0);}}
+return newBounds;},CLASS_NAME:"OpenLayers.Bounds"});OpenLayers.Bounds.fromString=function(str){var bounds=str.split(",");return OpenLayers.Bounds.fromArray(bounds);};OpenLayers.Bounds.fromArray=function(bbox){return new OpenLayers.Bounds(parseFloat(bbox[0]),parseFloat(bbox[1]),parseFloat(bbox[2]),parseFloat(bbox[3]));};OpenLayers.Bounds.fromSize=function(size){return new OpenLayers.Bounds(0,size.h,size.w,0);};OpenLayers.Bounds.oppositeQuadrant=function(quadrant){var opp="";opp+=(quadrant.charAt(0)=='t')?'b':'t';opp+=(quadrant.charAt(1)=='l')?'r':'l';return opp;};OpenLayers.Element={visible:function(element){return OpenLayers.Util.getElement(element).style.display!='none';},toggle:function(){for(var i=0;i<arguments.length;i++){var element=OpenLayers.Util.getElement(arguments[i]);var display=OpenLayers.Element.visible(element)?'hide':'show';OpenLayers.Element[display](element);}},hide:function(){for(var i=0;i<arguments.length;i++){var element=OpenLayers.Util.getElement(arguments[i]);element.style.display='none';}},show:function(){for(var i=0;i<arguments.length;i++){var element=OpenLayers.Util.getElement(arguments[i]);element.style.display='';}},remove:function(element){element=OpenLayers.Util.getElement(element);element.parentNode.removeChild(element);},getHeight:function(element){element=OpenLayers.Util.getElement(element);return element.offsetHeight;},getDimensions:function(element){element=OpenLayers.Util.getElement(element);if(OpenLayers.Element.getStyle(element,'display')!='none'){return{width:element.offsetWidth,height:element.offsetHeight};}
+var els=element.style;var originalVisibility=els.visibility;var originalPosition=els.position;els.visibility='hidden';els.position='absolute';els.display='';var originalWidth=element.clientWidth;var originalHeight=element.clientHeight;els.display='none';els.position=originalPosition;els.visibility=originalVisibility;return{width:originalWidth,height:originalHeight};},getStyle:function(element,style){element=OpenLayers.Util.getElement(element);var value=element.style[OpenLayers.String.camelize(style)];if(!value){if(document.defaultView&&document.defaultView.getComputedStyle){var css=document.defaultView.getComputedStyle(element,null);value=css?css.getPropertyValue(style):null;}else if(element.currentStyle){value=element.currentStyle[OpenLayers.String.camelize(style)];}}
+var positions=['left','top','right','bottom'];if(window.opera&&(OpenLayers.Util.indexOf(positions,style)!=-1)&&(OpenLayers.Element.getStyle(element,'position')=='static')){value='auto';}
+return value=='auto'?null:value;}};OpenLayers.LonLat=OpenLayers.Class({lon:0.0,lat:0.0,initialize:function(lon,lat){this.lon=parseFloat(lon);this.lat=parseFloat(lat);},toString:function(){return("lon="+this.lon+",lat="+this.lat);},toShortString:function(){return(this.lon+", "+this.lat);},clone:function(){return new OpenLayers.LonLat(this.lon,this.lat);},add:function(lon,lat){if((lon==null)||(lat==null)){var msg=OpenLayers.i18n("lonlatAddError");OpenLayers.Console.error(msg);return null;}
+return new OpenLayers.LonLat(this.lon+lon,this.lat+lat);},equals:function(ll){var equals=false;if(ll!=null){equals=((this.lon==ll.lon&&this.lat==ll.lat)||(isNaN(this.lon)&&isNaN(this.lat)&&isNaN(ll.lon)&&isNaN(ll.lat)));}
+return equals;},transform:function(source,dest){var point=OpenLayers.Projection.transform({'x':this.lon,'y':this.lat},source,dest);this.lon=point.x;this.lat=point.y;return this;},wrapDateLine:function(maxExtent){var newLonLat=this.clone();if(maxExtent){while(newLonLat.lon<maxExtent.left){newLonLat.lon+=maxExtent.getWidth();}
+while(newLonLat.lon>maxExtent.right){newLonLat.lon-=maxExtent.getWidth();}}
+return newLonLat;},CLASS_NAME:"OpenLayers.LonLat"});OpenLayers.LonLat.fromString=function(str){var pair=str.split(",");return new OpenLayers.LonLat(parseFloat(pair[0]),parseFloat(pair[1]));};OpenLayers.Pixel=OpenLayers.Class({x:0.0,y:0.0,initialize:function(x,y){this.x=parseFloat(x);this.y=parseFloat(y);},toString:function(){return("x="+this.x+",y="+this.y);},clone:function(){return new OpenLayers.Pixel(this.x,this.y);},equals:function(px){var equals=false;if(px!=null){equals=((this.x==px.x&&this.y==px.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(px.x)&&isNaN(px.y)));}
+return equals;},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("pixelAddError");OpenLayers.Console.error(msg);return null;}
+return new OpenLayers.Pixel(this.x+x,this.y+y);},offset:function(px){var newPx=this.clone();if(px){newPx=this.add(px.x,px.y);}
+return newPx;},CLASS_NAME:"OpenLayers.Pixel"});OpenLayers.Size=OpenLayers.Class({w:0.0,h:0.0,initialize:function(w,h){this.w=parseFloat(w);this.h=parseFloat(h);},toString:function(){return("w="+this.w+",h="+this.h);},clone:function(){return new OpenLayers.Size(this.w,this.h);},equals:function(sz){var equals=false;if(sz!=null){equals=((this.w==sz.w&&this.h==sz.h)||(isNaN(this.w)&&isNaN(this.h)&&isNaN(sz.w)&&isNaN(sz.h)));}
+return equals;},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){if(window.console){var scripts=document.getElementsByTagName("script");for(var i=0;i<scripts.length;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.events.destroy();this.events=null;}
+this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
+if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
+this.handlers=null;}
+if(this.map){this.map.removeControl(this);this.map=null;}},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=function(){return(false);};}
+if(this.title!=""){this.div.title=this.title;}}
+if(px!=null){this.position=px.clone();}
+this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
+if(this.handler){this.handler.activate();}
+this.active=true;this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
+this.active=false;this.events.triggerEvent("deactivate");return true;}
+return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Icon=OpenLayers.Class({url:null,size:null,offset:null,calculateOffset:null,imageDiv:null,px:null,initialize:function(url,size,offset,calculateOffset){this.url=url;this.size=(size)?size:new OpenLayers.Size(20,20);this.offset=offset?offset:new OpenLayers.Pixel(-(this.size.w/2),-(this.size.h/2));this.calculateOffset=calculateOffset;var id=OpenLayers.Util.createUniqueID("OL_Icon_");this.imageDiv=OpenLayers.Util.createAlphaImageDiv(id);},destroy:function(){OpenLayers.Event.stopObservingElement(this.imageDiv.firstChild);this.imageDiv.innerHTML="";this.imageDiv=null;},clone:function(){return new OpenLayers.Icon(this.url,this.size,this.offset,this.calculateOffset);},setSize:function(size){if(size!=null){this.size=size;}
+this.draw();},setUrl:function(url){if(url!=null){this.url=url;}
+this.draw();},draw:function(px){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,this.size,this.url,"absolute");this.moveTo(px);return this.imageDiv;},setOpacity:function(opacity){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,null,null,null,null,null,opacity);},moveTo:function(px){if(px!=null){this.px=px;}
+if(this.imageDiv!=null){if(this.px==null){this.display(false);}else{if(this.calculateOffset){this.offset=this.calculateOffset(this.size);}
+var offsetPx=this.px.offset(this.offset);OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,offsetPx);}}},display:function(display){this.imageDiv.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Icon"});OpenLayers.Lang={code:null,defaultCode:"en",getCode:function(){if(!OpenLayers.Lang.code){OpenLayers.Lang.setCode();}
+return OpenLayers.Lang.code;},setCode:function(code){var lang;if(!code){code=(OpenLayers.Util.getBrowserName()=="msie")?navigator.userLanguage:navigator.language;}
+var parts=code.split('-');parts[0]=parts[0].toLowerCase();if(typeof OpenLayers.Lang[parts[0]]=="object"){lang=parts[0];}
+if(parts[1]){var testLang=parts[0]+'-'+parts[1].toUpperCase();if(typeof OpenLayers.Lang[testLang]=="object"){lang=testLang;}}
+if(!lang){OpenLayers.Console.warn('Failed to find OpenLayers.Lang.'+parts.join("-")+' dictionary, falling back to default language');lang=OpenLayers.Lang.defaultCode;}
+OpenLayers.Lang.code=lang;},translate:function(key,context){var dictionary=OpenLayers.Lang[OpenLayers.Lang.getCode()];var message=dictionary[key];if(!message){message=key;}
+if(context){message=OpenLayers.String.format(message,context);}
+return message;}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.Popup=OpenLayers.Class({events:null,id:"",lonlat:null,div:null,size:null,contentHTML:"",backgroundColor:"",opacity:"",border:"",contentDiv:null,groupDiv:null,closeDiv:null,autoSize:false,minSize:null,maxSize:null,padding:0,fixPadding:function(){if(typeof this.padding=="number"){this.padding=new OpenLayers.Bounds(this.padding,this.padding,this.padding,this.padding);}},panMapIfOutOfView:false,map:null,initialize:function(id,lonlat,size,contentHTML,closeBox,closeBoxCallback){if(id==null){id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}
+this.id=id;this.lonlat=lonlat;this.size=(size!=null)?size:new OpenLayers.Size(OpenLayers.Popup.WIDTH,OpenLayers.Popup.HEIGHT);if(contentHTML!=null){this.contentHTML=contentHTML;}
+this.backgroundColor=OpenLayers.Popup.COLOR;this.opacity=OpenLayers.Popup.OPACITY;this.border=OpenLayers.Popup.BORDER;this.div=OpenLayers.Util.createDiv(this.id,null,null,null,null,null,"hidden");this.div.className='olPopup';var groupDivId=this.id+"_GroupDiv";this.groupDiv=OpenLayers.Util.createDiv(groupDivId,null,null,null,"relative",null,"hidden");var id=this.div.id+"_contentDiv";this.contentDiv=OpenLayers.Util.createDiv(id,null,this.size.clone(),null,"relative");this.contentDiv.className='olPopupContent';this.groupDiv.appendChild(this.contentDiv);this.div.appendChild(this.groupDiv);if(closeBox){this.addCloseBox(closeBoxCallback);}
+this.registerEvents();},destroy:function(){this.id=null;this.lonlat=null;this.size=null;this.contentHTML=null;this.backgroundColor=null;this.opacity=null;this.border=null;this.events.destroy();this.events=null;if(this.closeDiv){OpenLayers.Event.stopObservingElement(this.closeDiv);this.groupDiv.removeChild(this.closeDiv);}
+this.closeDiv=null;this.div.removeChild(this.groupDiv);this.groupDiv=null;if(this.map!=null){this.map.removePopup(this);}
+this.map=null;this.div=null;this.autoSize=null;this.minSize=null;this.maxSize=null;this.padding=null;this.panMapIfOutOfView=null;},draw:function(px){if(px==null){if((this.lonlat!=null)&&(this.map!=null)){px=this.map.getLayerPxFromLonLat(this.lonlat);}}
+if(OpenLayers.Util.getBrowserName()=='firefox'){this.map.events.register("movestart",this,function(){var style=document.defaultView.getComputedStyle(this.contentDiv,null);var currentOverflow=style.getPropertyValue("overflow");if(currentOverflow!="hidden"){this.contentDiv._oldOverflow=currentOverflow;this.contentDiv.style.overflow="hidden";}});this.map.events.register("moveend",this,function(){var oldOverflow=this.contentDiv._oldOverflow;if(oldOverflow){this.contentDiv.style.overflow=oldOverflow;this.contentDiv._oldOverflow=null;}});}
+this.moveTo(px);if(!this.autoSize){this.setSize(this.size);}
+this.setBackgroundColor();this.setOpacity();this.setBorder();this.setContentHTML();if(this.panMapIfOutOfView){this.panIntoView();}
+return this.div;},updatePosition:function(){if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);if(px){this.moveTo(px);}}},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},visible:function(){return OpenLayers.Element.visible(this.div);},toggle:function(){if(this.visible()){this.hide();}else{this.show();}},show:function(){OpenLayers.Element.show(this.div);if(this.panMapIfOutOfView){this.panIntoView();}},hide:function(){OpenLayers.Element.hide(this.div);},setSize:function(size){this.size=size;var contentSize=this.size.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth+contentDivPadding.right;}
+this.size.w+=wPadding;this.size.h+=hPadding;if(OpenLayers.Util.getBrowserName()=="msie"){contentSize.w+=contentDivPadding.left+contentDivPadding.right;contentSize.h+=contentDivPadding.bottom+contentDivPadding.top;}
+if(this.div!=null){this.div.style.width=this.size.w+"px";this.div.style.height=this.size.h+"px";}
+if(this.contentDiv!=null){this.contentDiv.style.width=contentSize.w+"px";this.contentDiv.style.height=contentSize.h+"px";}},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
+if(this.div!=null){this.div.style.backgroundColor=this.backgroundColor;}},setOpacity:function(opacity){if(opacity!=undefined){this.opacity=opacity;}
+if(this.div!=null){this.div.style.opacity=this.opacity;this.div.style.filter='alpha(opacity='+this.opacity*100+')';}},setBorder:function(border){if(border!=undefined){this.border=border;}
+if(this.div!=null){this.div.style.border=this.border;}},setContentHTML:function(contentHTML){if(contentHTML!=null){this.contentHTML=contentHTML;}
+if(this.autoSize){var realSize=OpenLayers.Util.getRenderedDimensions(this.contentHTML);var safeSize=this.getSafeContentSize(realSize);var newSize=null;if(safeSize.equals(realSize)){newSize=realSize;}else{var fixedSize=new OpenLayers.Size();fixedSize.w=(safeSize.w<realSize.w)?safeSize.w:null;fixedSize.h=(safeSize.h<realSize.h)?safeSize.h:null;if(fixedSize.w&&fixedSize.h){newSize=safeSize;}else{var clippedSize=OpenLayers.Util.getRenderedDimensions(this.contentHTML,fixedSize);var currentOverflow=OpenLayers.Element.getStyle(this.contentDiv,"overflow");if((currentOverflow!="hidden")&&(clippedSize.equals(safeSize))){var scrollBar=OpenLayers.Util.getScrollbarWidth();if(fixedSize.w){clippedSize.h+=scrollBar;}else{clippedSize.w+=scrollBar;}}
+newSize=this.getSafeContentSize(clippedSize);}}
+this.setSize(newSize);}
+if(this.contentDiv!=null){this.contentDiv.innerHTML=this.contentHTML;}},getSafeContentSize:function(size){var safeContentSize=size.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth+contentDivPadding.right;}
+if(this.minSize){safeContentSize.w=Math.max(safeContentSize.w,(this.minSize.w-wPadding));safeContentSize.h=Math.max(safeContentSize.h,(this.minSize.h-hPadding));}
+if(this.maxSize){safeContentSize.w=Math.min(safeContentSize.w,(this.maxSize.w-wPadding));safeContentSize.h=Math.min(safeContentSize.h,(this.maxSize.h-hPadding));}
+if(this.map&&this.map.size){var maxY=this.map.size.h-
+this.map.paddingForPopups.top-
+this.map.paddingForPopups.bottom-
+hPadding;var maxX=this.map.size.w-
+this.map.paddingForPopups.left-
+this.map.paddingForPopups.right-
+wPadding;safeContentSize.w=Math.min(safeContentSize.w,maxX);safeContentSize.h=Math.min(safeContentSize.h,maxY);}
+return safeContentSize;},getContentDivPadding:function(){var contentDivPadding=this._contentDivPadding;if(!contentDivPadding){this.div.style.display="none";document.body.appendChild(this.div);contentDivPadding=new OpenLayers.Bounds(OpenLayers.Element.getStyle(this.contentDiv,"padding-left"),OpenLayers.Element.getStyle(this.contentDiv,"padding-bottom"),OpenLayers.Element.getStyle(this.contentDiv,"padding-right"),OpenLayers.Element.getStyle(this.contentDiv,"padding-top"));this._contentDivPadding=contentDivPadding;document.body.removeChild(this.div);this.div.style.display="";}
+return contentDivPadding;},addCloseBox:function(callback){this.closeDiv=OpenLayers.Util.createDiv(this.id+"_close",null,new OpenLayers.Size(17,17));this.closeDiv.className="olPopupCloseBox";var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+"px";this.closeDiv.style.top=contentDivPadding.top+"px";this.groupDiv.appendChild(this.closeDiv);var closePopup=callback||function(e){this.hide();OpenLayers.Event.stop(e);};OpenLayers.Event.observe(this.closeDiv,"click",OpenLayers.Function.bindAsEventListener(closePopup,this));},panIntoView:function(){var mapSize=this.map.getSize();var origTL=this.map.getViewPortPxFromLayerPx(new OpenLayers.Pixel(parseInt(this.div.style.left),parseInt(this.div.style.top)));var newTL=origTL.clone();if(origTL.x<this.map.paddingForPopups.left){newTL.x=this.map.paddingForPopups.left;}else
+if((origTL.x+this.size.w)>(mapSize.w-this.map.paddingForPopups.right)){newTL.x=mapSize.w-this.map.paddingForPopups.right-this.size.w;}
+if(origTL.y<this.map.paddingForPopups.top){newTL.y=this.map.paddingForPopups.top;}else
+if((origTL.y+this.size.h)>(mapSize.h-this.map.paddingForPopups.bottom)){newTL.y=mapSize.h-this.map.paddingForPopups.bottom-this.size.h;}
+var dx=origTL.x-newTL.x;var dy=origTL.y-newTL.y;this.map.pan(dx,dy);},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,true);this.events.on({"mousedown":this.onmousedown,"mousemove":this.onmousemove,"mouseup":this.onmouseup,"click":this.onclick,"mouseout":this.onmouseout,"dblclick":this.ondblclick,scope:this});},onmousedown:function(evt){this.mousedown=true;OpenLayers.Event.stop(evt,true);},onmousemove:function(evt){if(this.mousedown){OpenLayers.Event.stop(evt,true);}},onmouseup:function(evt){if(this.mousedown){this.mousedown=false;OpenLayers.Event.stop(evt,true);}},onclick:function(evt){OpenLayers.Event.stop(evt,true);},onmouseout:function(evt){this.mousedown=false;},ondblclick:function(evt){OpenLayers.Event.stop(evt,true);},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";OpenLayers.Renderer=OpenLayers.Class({container:null,extent:null,size:null,resolution:null,map:null,initialize:function(containerID){this.container=OpenLayers.Util.getElement(containerID);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return false;},setExtent:function(extent){this.extent=extent.clone();this.resolution=null;},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
+if(feature.geometry){this.drawGeometry(feature.geometry,style,feature.id);}},drawGeometry:function(geometry,style,featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(features instanceof Array)){features=[features];}
+for(var i=0;i<features.length;++i){this.eraseGeometry(features[i].geometry);}},eraseGeometry:function(geometry){},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
+if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
+this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
+if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
+window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){OpenLayers.Console.error('invalid value for Tween');}
+var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
+this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
+if(this.time>this.duration){if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);this.playing=false;}
+window.clearInterval(this.interval);this.interval=null;}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(red,green,blue){this.rgb={r:red,g:green,b:blue};},setRed:function(r){this.rgb.r=r;},setGreen:function(g){this.rgb.g=g;},setBlue:function(b){this.rgb.b=b;},setHue:function(h){var hsb=this.asHSB();hsb.h=h;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setSaturation:function(s){var hsb=this.asHSB();hsb.s=s;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setBrightness:function(b){var hsb=this.asHSB();hsb.b=b;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},darken:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.max(hsb.b-percent,0));},brighten:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.min(hsb.b+percent,1));},blend:function(other){this.rgb.r=Math.floor((this.rgb.r+other.rgb.r)/2);this.rgb.g=Math.floor((this.rgb.g+other.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+other.rgb.b)/2);},isBright:function(){var hsb=this.asHSB();return this.asHSB().b>0.5;},isDark:function(){return!this.isBright();},asRGB:function(){return"rgb("+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")";},asHex:function(){return"#"+this.rgb.r.toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart();},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b);},toString:function(){return this.asHex();}});OpenLayers.Rico.Color.createFromHex=function(hexCode){if(hexCode.length==4){var shortHexCode=hexCode;var hexCode='#';for(var i=1;i<4;i++){hexCode+=(shortHexCode.charAt(i)+
+shortHexCode.charAt(i));}}
+if(hexCode.indexOf('#')==0){hexCode=hexCode.substring(1);}
+var red=hexCode.substring(0,2);var green=hexCode.substring(2,4);var blue=hexCode.substring(4,6);return new OpenLayers.Rico.Color(parseInt(red,16),parseInt(green,16),parseInt(blue,16));};OpenLayers.Rico.Color.createColorFromBackground=function(elem){var actualColor=RicoUtil.getElementsComputedStyle(OpenLayers.Util.getElement(elem),"backgroundColor","background-color");if(actualColor=="transparent"&&elem.parentNode){return OpenLayers.Rico.Color.createColorFromBackground(elem.parentNode);}
+if(actualColor==null){return new OpenLayers.Rico.Color(255,255,255);}
+if(actualColor.indexOf("rgb(")==0){var colors=actualColor.substring(4,actualColor.length-1);var colorArray=colors.split(",");return new OpenLayers.Rico.Color(parseInt(colorArray[0]),parseInt(colorArray[1]),parseInt(colorArray[2]));}
+else if(actualColor.indexOf("#")==0){return OpenLayers.Rico.Color.createFromHex(actualColor);}
+else{return new OpenLayers.Rico.Color(255,255,255);}};OpenLayers.Rico.Color.HSBtoRGB=function(hue,saturation,brightness){var red=0;var green=0;var blue=0;if(saturation==0){red=parseInt(brightness*255.0+0.5);green=red;blue=red;}
+else{var h=(hue-Math.floor(hue))*6.0;var f=h-Math.floor(h);var p=brightness*(1.0-saturation);var q=brightness*(1.0-saturation*f);var t=brightness*(1.0-(saturation*(1.0-f)));switch(parseInt(h)){case 0:red=(brightness*255.0+0.5);green=(t*255.0+0.5);blue=(p*255.0+0.5);break;case 1:red=(q*255.0+0.5);green=(brightness*255.0+0.5);blue=(p*255.0+0.5);break;case 2:red=(p*255.0+0.5);green=(brightness*255.0+0.5);blue=(t*255.0+0.5);break;case 3:red=(p*255.0+0.5);green=(q*255.0+0.5);blue=(brightness*255.0+0.5);break;case 4:red=(t*255.0+0.5);green=(p*255.0+0.5);blue=(brightness*255.0+0.5);break;case 5:red=(brightness*255.0+0.5);green=(p*255.0+0.5);blue=(q*255.0+0.5);break;}}
+return{r:parseInt(red),g:parseInt(green),b:parseInt(blue)};};OpenLayers.Rico.Color.RGBtoHSB=function(r,g,b){var hue;var saturation;var brightness;var cmax=(r>g)?r:g;if(b>cmax){cmax=b;}
+var cmin=(r<g)?r:g;if(b<cmin){cmin=b;}
+brightness=cmax/255.0;if(cmax!=0){saturation=(cmax-cmin)/cmax;}else{saturation=0;}
+if(saturation==0){hue=0;}else{var redc=(cmax-r)/(cmax-cmin);var greenc=(cmax-g)/(cmax-cmin);var bluec=(cmax-b)/(cmax-cmin);if(r==cmax){hue=bluec-greenc;}else if(g==cmax){hue=2.0+redc-bluec;}else{hue=4.0+greenc-redc;}
+hue=hue/6.0;if(hue<0){hue=hue+1.0;}}
+return{h:hue,s:saturation,b:brightness};};OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0;i<this.map.controls.length;i++){var control=this.map.controls[i];if((control!=this)&&(control.CLASS_NAME=="OpenLayers.Control.ArgParser")){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
+break;}}
+if(i==this.map.controls.length){var args=OpenLayers.Util.getParameters();if(args.layers){this.layers=args.layers;this.map.events.register('addlayer',this,this.configureLayers);this.configureLayers();}
+if(args.lat&&args.lon){this.center=new OpenLayers.LonLat(parseFloat(args.lon),parseFloat(args.lat));if(args.zoom){this.zoom=parseInt(args.zoom);}
+this.map.events.register('changebaselayer',this,this.setCenter);this.setCenter();}}},setCenter:function(){if(this.map.baseLayer){this.map.events.unregister('changebaselayer',this,this.setCenter);if(this.displayProjection){this.center.transform(this.displayProjection,this.map.getProjectionObject());}
+this.map.setCenter(this.center,this.zoom);}},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister('addlayer',this,this.configureLayers);for(var i=0;i<this.layers.length;i++){var layer=this.map.layers[i];var c=this.layers.charAt(i);if(c=="B"){this.map.setBaseLayer(layer);}else if((c=="T")||(c=="F")){layer.setVisibility(c=="T");}}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.map.events.un({"removelayer":this.updateAttribution,"addlayer":this.updateAttribution,"changelayer":this.updateAttribution,"changebaselayer":this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({'changebaselayer':this.updateAttribution,'changelayer':this.updateAttribution,'addlayer':this.updateAttribution,'removelayer':this.updateAttribution,scope:this});this.updateAttribution();return this.div;},updateAttribution:function(){var attributions=[];if(this.map&&this.map.layers){for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];if(layer.attribution&&layer.getVisibility()){attributions.push(layer.attribution);}}
+this.div.innerHTML=attributions.join(this.separator);}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Control.Button=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){},CLASS_NAME:"OpenLayers.Control.Button"});OpenLayers.Control.LayerSwitcher=OpenLayers.Class(OpenLayers.Control,{activeColor:"darkblue",layerStates:null,layersDiv:null,baseLayersDiv:null,baseLayers:null,dataLbl:null,dataLayersDiv:null,dataLayers:null,minimizeDiv:null,maximizeDiv:null,ascending:true,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.layerStates=[];},destroy:function(){OpenLayers.Event.stopObservingElement(this.div);OpenLayers.Event.stopObservingElement(this.minimizeDiv);OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.clearLayersArray("base");this.clearLayersArray("data");this.map.events.un({"addlayer":this.redraw,"changelayer":this.redraw,"removelayer":this.redraw,"changebaselayer":this.redraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.on({"addlayer":this.redraw,"changelayer":this.redraw,"removelayer":this.redraw,"changebaselayer":this.redraw,scope:this});},draw:function(){OpenLayers.Control.prototype.draw.apply(this);this.loadContents();if(!this.outsideViewport){this.minimizeControl();}
+this.redraw();return this.div;},clearLayersArray:function(layersType){var layers=this[layersType+"Layers"];if(layers){for(var i=0;i<layers.length;i++){var layer=layers[i];OpenLayers.Event.stopObservingElement(layer.inputElem);OpenLayers.Event.stopObservingElement(layer.labelSpan);}}
+this[layersType+"LayersDiv"].innerHTML="";this[layersType+"Layers"]=[];},checkRedraw:function(){var redraw=false;if(!this.layerStates.length||(this.map.layers.length!=this.layerStates.length)){redraw=true;}else{for(var i=0;i<this.layerStates.length;i++){var layerState=this.layerStates[i];var layer=this.map.layers[i];if((layerState.name!=layer.name)||(layerState.inRange!=layer.inRange)||(layerState.id!=layer.id)||(layerState.visibility!=layer.visibility)){redraw=true;break;}}}
+return redraw;},redraw:function(){if(!this.checkRedraw()){return this.div;}
+this.clearLayersArray("base");this.clearLayersArray("data");var containsOverlays=false;var containsBaseLayers=false;this.layerStates=new Array(this.map.layers.length);for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];this.layerStates[i]={'name':layer.name,'visibility':layer.visibility,'inRange':layer.inRange,'id':layer.id};}
+var layers=this.map.layers.slice();if(!this.ascending){layers.reverse();}
+for(var i=0;i<layers.length;i++){var layer=layers[i];var baseLayer=layer.isBaseLayer;if(layer.displayInLayerSwitcher){if(baseLayer){containsBaseLayers=true;}else{containsOverlays=true;}
+var checked=(baseLayer)?(layer==this.map.baseLayer):layer.getVisibility();var inputElem=document.createElement("input");inputElem.id="input_"+layer.name;inputElem.name=(baseLayer)?"baseLayers":layer.name;inputElem.type=(baseLayer)?"radio":"checkbox";inputElem.value=layer.name;inputElem.checked=checked;inputElem.defaultChecked=checked;if(!baseLayer&&!layer.inRange){inputElem.disabled=true;}
+var context={'inputElem':inputElem,'layer':layer,'layerSwitcher':this};OpenLayers.Event.observe(inputElem,"mouseup",OpenLayers.Function.bindAsEventListener(this.onInputClick,context));var labelSpan=document.createElement("span");if(!baseLayer&&!layer.inRange){labelSpan.style.color="gray";}
+labelSpan.innerHTML=layer.name;labelSpan.style.verticalAlign=(baseLayer)?"bottom":"baseline";OpenLayers.Event.observe(labelSpan,"click",OpenLayers.Function.bindAsEventListener(this.onInputClick,context));var br=document.createElement("br");var groupArray=(baseLayer)?this.baseLayers:this.dataLayers;groupArray.push({'layer':layer,'inputElem':inputElem,'labelSpan':labelSpan});var groupDiv=(baseLayer)?this.baseLayersDiv:this.dataLayersDiv;groupDiv.appendChild(inputElem);groupDiv.appendChild(labelSpan);groupDiv.appendChild(br);}}
+this.dataLbl.style.display=(containsOverlays)?"":"none";this.baseLbl.style.display=(containsBaseLayers)?"":"none";return this.div;},onInputClick:function(e){if(!this.inputElem.disabled){if(this.inputElem.type=="radio"){this.inputElem.checked=true;this.layer.map.setBaseLayer(this.layer);}else{this.inputElem.checked=!this.inputElem.checked;this.layerSwitcher.updateMap();}}
+OpenLayers.Event.stop(e);},onLayerClick:function(e){this.updateMap();},updateMap:function(){for(var i=0;i<this.baseLayers.length;i++){var layerEntry=this.baseLayers[i];if(layerEntry.inputElem.checked){this.map.setBaseLayer(layerEntry.layer,false);}}
+for(var i=0;i<this.dataLayers.length;i++){var layerEntry=this.dataLayers[i];layerEntry.layer.setVisibility(layerEntry.inputElem.checked);}},maximizeControl:function(e){this.div.style.width="20em";this.div.style.height="";this.showControls(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.div.style.width="0px";this.div.style.height="0px";this.showControls(true);if(e!=null){OpenLayers.Event.stop(e);}},showControls:function(minimize){this.maximizeDiv.style.display=minimize?"":"none";this.minimizeDiv.style.display=minimize?"none":"";this.layersDiv.style.display=minimize?"none":"";},loadContents:function(){this.div.style.position="absolute";this.div.style.top="25px";this.div.style.right="0px";this.div.style.left="";this.div.style.fontFamily="sans-serif";this.div.style.fontWeight="bold";this.div.style.marginTop="3px";this.div.style.marginLeft="3px";this.div.style.marginBottom="3px";this.div.style.fontSize="smaller";this.div.style.color="white";this.div.style.backgroundColor="transparent";OpenLayers.Event.observe(this.div,"mouseup",OpenLayers.Function.bindAsEventListener(this.mouseUp,this));OpenLayers.Event.observe(this.div,"click",this.ignoreEvent);OpenLayers.Event.observe(this.div,"mousedown",OpenLayers.Function.bindAsEventListener(this.mouseDown,this));OpenLayers.Event.observe(this.div,"dblclick",this.ignoreEvent);this.layersDiv=document.createElement("div");this.layersDiv.id="layersDiv";this.layersDiv.style.paddingTop="5px";this.layersDiv.style.paddingLeft="10px";this.layersDiv.style.paddingBottom="5px";this.layersDiv.style.paddingRight="75px";this.layersDiv.style.backgroundColor=this.activeColor;this.layersDiv.style.width="100%";this.layersDiv.style.height="100%";this.baseLbl=document.createElement("div");this.baseLbl.innerHTML=OpenLayers.i18n("baseLayer");this.baseLbl.style.marginTop="3px";this.baseLbl.style.marginLeft="3px";this.baseLbl.style.marginBottom="3px";this.baseLayersDiv=document.createElement("div");this.baseLayersDiv.style.paddingLeft="10px";this.dataLbl=document.createElement("div");this.dataLbl.innerHTML=OpenLayers.i18n("overlays");this.dataLbl.style.marginTop="3px";this.dataLbl.style.marginLeft="3px";this.dataLbl.style.marginBottom="3px";this.dataLayersDiv=document.createElement("div");this.dataLayersDiv.style.paddingLeft="10px";if(this.ascending){this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);}else{this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);}
+this.div.appendChild(this.layersDiv);OpenLayers.Rico.Corner.round(this.div,{corners:"tl bl",bgColor:"transparent",color:this.activeColor,blend:false});OpenLayers.Rico.Corner.changeOpacity(this.layersDiv,0.75);var imgLocation=OpenLayers.Util.getImagesLocation();var sz=new OpenLayers.Size(18,18);var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MaximizeDiv",null,sz,img,"absolute");this.maximizeDiv.style.top="5px";this.maximizeDiv.style.right="0px";this.maximizeDiv.style.left="";this.maximizeDiv.style.display="none";OpenLayers.Event.observe(this.maximizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';var sz=new OpenLayers.Size(18,18);this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MinimizeDiv",null,sz,img,"absolute");this.minimizeDiv.style.top="5px";this.minimizeDiv.style.right="0px";this.minimizeDiv.style.left="";this.minimizeDiv.style.display="none";OpenLayers.Event.observe(this.minimizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);},ignoreEvent:function(evt){OpenLayers.Event.stop(evt);},mouseDown:function(evt){this.isMouseDown=true;this.ignoreEvent(evt);},mouseUp:function(evt){if(this.isMouseDown){this.isMouseDown=false;this.ignoreEvent(evt);}},CLASS_NAME:"OpenLayers.Control.LayerSwitcher"});OpenLayers.Control.MouseDefaults=OpenLayers.Class(OpenLayers.Control,{performedDrag:false,wheelObserver:null,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
+this.handler=null;this.map.events.un({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});OpenLayers.Event.stopObserving(window,"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.stopObserving(window,"mousewheel",this.wheelObserver);OpenLayers.Event.stopObserving(document,"mousewheel",this.wheelObserver);this.wheelObserver=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.map.events.on({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});this.registerWheelEvents();},registerWheelEvents:function(){this.wheelObserver=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);OpenLayers.Event.observe(window,"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.observe(window,"mousewheel",this.wheelObserver);OpenLayers.Event.observe(document,"mousewheel",this.wheelObserver);},defaultClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+var notAfterDrag=!this.performedDrag;this.performedDrag=false;return notAfterDrag;},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+this.mouseDragStart=evt.xy.clone();this.performedDrag=false;if(evt.shiftKey){this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);}
+document.onselectstart=function(){return false;};OpenLayers.Event.stop(evt);},defaultMouseMove:function(evt){this.mousePosition=evt.xy.clone();if(this.mouseDragStart!=null){if(this.zoomBox){var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
+if(evt.xy.y<this.mouseDragStart.y){this.zoomBox.style.top=evt.xy.y+"px";}}else{var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();this.map.div.style.cursor="move";}
+this.performedDrag=true;}},defaultMouseUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+if(this.zoomBox){this.zoomBoxEnd(evt);}else{if(this.performedDrag){this.map.setCenter(this.map.center);}}
+document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.zoomBox){this.removeZoomBox();}
+this.mouseDragStart=null;}},defaultWheelUp:function(evt){if(this.map.getZoom()<=this.map.getNumZoomLevels()){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()+1);}},defaultWheelDown:function(evt){if(this.map.getZoom()>0){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()-1);}},zoomBoxEnd:function(evt){if(this.mouseDragStart!=null){if(Math.abs(this.mouseDragStart.x-evt.xy.x)>5||Math.abs(this.mouseDragStart.y-evt.xy.y)>5){var start=this.map.getLonLatFromViewPortPx(this.mouseDragStart);var end=this.map.getLonLatFromViewPortPx(evt.xy);var top=Math.max(start.lat,end.lat);var bottom=Math.min(start.lat,end.lat);var left=Math.min(start.lon,end.lon);var right=Math.max(start.lon,end.lon);var bounds=new OpenLayers.Bounds(left,bottom,right,top);this.map.zoomToExtent(bounds);}else{var end=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(new OpenLayers.LonLat((end.lon),(end.lat)),this.map.getZoom()+1);}
+this.removeZoomBox();}},removeZoomBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},onWheelEvent:function(e){var inMap=false;var elem=OpenLayers.Event.element(e);while(elem!=null){if(this.map&&elem==this.map.div){inMap=true;break;}
+elem=elem.parentNode;}
+if(inMap){var delta=0;if(!e){e=window.event;}
+if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
+if(delta){e.xy=this.mousePosition;if(delta<0){this.defaultWheelDown(e);}else{this.defaultWheelUp(e);}}
+OpenLayers.Event.stop(e);}},CLASS_NAME:"OpenLayers.Control.MouseDefaults"});OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{element:null,prefix:'',separator:', ',suffix:'',numdigits:5,granularity:10,lastXy:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.map){this.map.events.unregister('mousemove',this,this.redraw);}
+OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.div.left="";this.div.top="";this.element=this.div;}
+this.redraw();return this.div;},redraw:function(evt){var lonLat;if(evt==null){lonLat=new OpenLayers.LonLat(0,0);}else{if(this.lastXy==null||Math.abs(evt.xy.x-this.lastXy.x)>this.granularity||Math.abs(evt.xy.y-this.lastXy.y)>this.granularity)
+{this.lastXy=evt.xy;return;}
+lonLat=this.map.getLonLatFromPixel(evt.xy);if(!lonLat){return;}
+if(this.displayProjection){lonLat.transform(this.map.getProjectionObject(),this.displayProjection);}
+this.lastXy=evt.xy;}
+var newHtml=this.formatOutput(lonLat);if(newHtml!=this.element.innerHTML){this.element.innerHTML=newHtml;}},formatOutput:function(lonLat){var digits=parseInt(this.numdigits);var newHtml=this.prefix+
+lonLat.lon.toFixed(digits)+
+this.separator+
+lonLat.lat.toFixed(digits)+
+this.suffix;return newHtml;},setMap:function(){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.register('mousemove',this,this.redraw);},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Control.NavigationHistory=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOGGLE,previous:null,previousOptions:null,next:null,nextOptions:null,limit:50,activateOnDraw:true,clearOnDeactivate:false,registry:null,nextStack:null,previousStack:null,listeners:null,restoring:false,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.registry=OpenLayers.Util.extend({"moveend":function(){return{center:this.map.getCenter(),resolution:this.map.getResolution()};}},this.registry);this.clear();var previousOptions={trigger:OpenLayers.Function.bind(this.previousTrigger,this),displayClass:this.displayClass+"Previous"};OpenLayers.Util.extend(previousOptions,this.previousOptions);this.previous=new OpenLayers.Control.Button(previousOptions);var nextOptions={trigger:OpenLayers.Function.bind(this.nextTrigger,this),displayClass:this.displayClass+"Next"};OpenLayers.Util.extend(nextOptions,this.nextOptions);this.next=new OpenLayers.Control.Button(nextOptions);},onPreviousChange:function(state,length){if(state&&!this.previous.active){this.previous.activate();}else if(!state&&this.previous.active){this.previous.deactivate();}},onNextChange:function(state,length){if(state&&!this.next.active){this.next.activate();}else if(!state&&this.next.active){this.next.deactivate();}},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this);this.previous.destroy();this.next.destroy();this.deactivate();for(var prop in this){this[prop]=null;}},setMap:function(map){this.map=map;this.next.setMap(map);this.previous.setMap(map);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.next.draw();this.previous.draw();if(this.activateOnDraw){this.activate();}},previousTrigger:function(){var current=this.previousStack.shift();var state=this.previousStack.shift();if(state!=undefined){this.nextStack.unshift(current);this.previousStack.unshift(state);this.restoring=true;this.restore(state);this.restoring=false;this.onNextChange(this.nextStack[0],this.nextStack.length);this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}else{this.previousStack.unshift(current);}
+return state;},nextTrigger:function(){var state=this.nextStack.shift();if(state!=undefined){this.previousStack.unshift(state);this.restoring=true;this.restore(state);this.restoring=false;this.onNextChange(this.nextStack[0],this.nextStack.length);this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}
+return state;},clear:function(){this.previousStack=[];this.nextStack=[];},restore:function(state){var zoom=this.map.getZoomForResolution(state.resolution);this.map.setCenter(state.center,zoom);},setListeners:function(){this.listeners={};for(var type in this.registry){this.listeners[type]=OpenLayers.Function.bind(function(){if(!this.restoring){var state=this.registry[type].apply(this,arguments);this.previousStack.unshift(state);if(this.previousStack.length>1){this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}
+if(this.previousStack.length>(this.limit+1)){this.previousStack.pop();}
+if(this.nextStack.length>0){this.nextStack=[];this.onNextChange(null,0);}}
+return true;},this);}},activate:function(){var activated=false;if(this.map){if(OpenLayers.Control.prototype.activate.apply(this)){if(this.listeners==null){this.setListeners();}
+for(var type in this.listeners){this.map.events.register(type,this,this.listeners[type]);}
+activated=true;if(this.previousStack.length==0){this.initStack();}}}
+return activated;},initStack:function(){if(this.map.getCenter()){this.listeners.moveend();}},deactivate:function(){var deactivated=false;if(this.map){if(OpenLayers.Control.prototype.deactivate.apply(this)){for(var type in this.listeners){this.map.events.unregister(type,this,this.listeners[type]);}
+if(this.clearOnDeactivate){this.clear();}
+deactivated=true;}}
+return deactivated;},CLASS_NAME:"OpenLayers.Control.NavigationHistory"});OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,buttons:null,position:null,initialize:function(options){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);while(this.buttons.length){var btn=this.buttons.shift();btn.map=null;OpenLayers.Event.stopObservingElement(btn);}
+this.buttons=null;this.position=null;},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position;this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);this._addButton("panright","east-mini.png",px.add(sz.w,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);this._addButton("zoomworld","zoom-world-mini.png",centered.add(0,sz.h*4+5),sz);this._addButton("zoomout","zoom-minus-mini.png",centered.add(0,sz.h*5+5),sz);return this.div;},_addButton:function(id,img,xy,sz){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var btn=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_PanZoom_"+id,xy,sz,imgLocation,"absolute");this.div.appendChild(btn);OpenLayers.Event.observe(btn,"mousedown",OpenLayers.Function.bindAsEventListener(this.buttonDown,btn));OpenLayers.Event.observe(btn,"dblclick",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));OpenLayers.Event.observe(btn,"click",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));btn.action=id;btn.map=this.map;btn.slideFactor=this.slideFactor;this.buttons.push(btn);return btn;},doubleClick:function(evt){OpenLayers.Event.stop(evt);return false;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+switch(this.action){case"panup":this.map.pan(0,-this.slideFactor);break;case"pandown":this.map.pan(0,this.slideFactor);break;case"panleft":this.map.pan(-this.slideFactor,0);break;case"panright":this.map.pan(this.slideFactor,0);break;case"zoomin":this.map.zoomIn();break;case"zoomout":this.map.zoomOut();break;case"zoomworld":this.map.zoomToMaxExtent();break;}
+OpenLayers.Event.stop(evt);},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,defaultControl:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var i=this.controls.length-1;i>=0;i--){if(this.controls[i].events){this.controls[i].events.un({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
+OpenLayers.Event.stopObservingElement(this.controls[i].panel_div);this.controls[i].panel_div=null;}},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){for(var i=0;i<this.controls.length;i++){if(this.controls[i]==this.defaultControl){this.controls[i].activate();}}
+this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){for(var i=0;i<this.controls.length;i++){this.controls[i].deactivate();}
+return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);for(var i=0;i<this.controls.length;i++){this.map.addControl(this.controls[i]);this.controls[i].deactivate();this.controls[i].events.on({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
+this.activate();return this.div;},redraw:function(){this.div.innerHTML="";if(this.active){for(var i=0;i<this.controls.length;i++){var element=this.controls[i].panel_div;if(this.controls[i].active){element.className=this.controls[i].displayClass+"ItemActive";}else{element.className=this.controls[i].displayClass+"ItemInactive";}
+this.div.appendChild(element);}}},activateControl:function(control){if(!this.active){return false;}
+if(control.type==OpenLayers.Control.TYPE_BUTTON){control.trigger();return;}
+if(control.type==OpenLayers.Control.TYPE_TOGGLE){if(control.active){control.deactivate();}else{control.activate();}
+return;}
+for(var i=0;i<this.controls.length;i++){if(this.controls[i]!=control){if(this.controls[i].type!=OpenLayers.Control.TYPE_TOGGLE){this.controls[i].deactivate();}}}
+control.activate();},addControls:function(controls){if(!(controls instanceof Array)){controls=[controls];}
+this.controls=this.controls.concat(controls);for(var i=0;i<controls.length;i++){var element=document.createElement("div");var textNode=document.createTextNode(" ");controls[i].panel_div=element;if(controls[i].title!=""){controls[i].panel_div.title=controls[i].title;}
+OpenLayers.Event.observe(controls[i].panel_div,"click",OpenLayers.Function.bind(this.onClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"mousedown",OpenLayers.Function.bindAsEventListener(OpenLayers.Event.stop));}
+if(this.map){for(var i=0;i<controls.length;i++){this.map.addControl(controls[i]);controls[i].deactivate();controls[i].events.on({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
+this.redraw();}},onClick:function(ctrl,evt){OpenLayers.Event.stop(evt?evt:window.event);this.activateControl(ctrl);},getControlsBy:function(property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this.controls,function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getControlsByName:function(match){return this.getControlsBy("name",match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},CLASS_NAME:"OpenLayers.Control.Panel"});OpenLayers.Control.Permalink=OpenLayers.Class(OpenLayers.Control,{element:null,base:'',displayProjection:null,initialize:function(element,base,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);this.base=base||document.location.href;},destroy:function(){if(this.element.parentNode==this.div){this.div.removeChild(this.element);}
+this.element=null;this.map.events.unregister('moveend',this,this.updateLink);OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0;i<this.map.controls.length;i++){var control=this.map.controls[i];if(control.CLASS_NAME=="OpenLayers.Control.ArgParser"){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
+break;}}
+if(i==this.map.controls.length){this.map.addControl(new OpenLayers.Control.ArgParser({'displayProjection':this.displayProjection}));}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("a");this.element.innerHTML=OpenLayers.i18n("permalink");this.element.href="";this.div.appendChild(this.element);}
+this.map.events.on({'moveend':this.updateLink,'changelayer':this.updateLink,'changebaselayer':this.updateLink,scope:this});return this.div;},updateLink:function(){var center=this.map.getCenter();if(!center){return;}
+var params=OpenLayers.Util.getParameters(this.base);params.zoom=this.map.getZoom();var lat=center.lat;var lon=center.lon;if(this.displayProjection){var mapPosition=OpenLayers.Projection.transform({x:lon,y:lat},this.map.getProjectionObject(),this.displayProjection);lon=mapPosition.x;lat=mapPosition.y;}
+params.lat=Math.round(lat*100000)/100000;params.lon=Math.round(lon*100000)/100000;params.layers='';for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];if(layer.isBaseLayer){params.layers+=(layer==this.map.baseLayer)?"B":"0";}else{params.layers+=(layer.getVisibility())?"T":"F";}}
+var href=this.base;if(href.indexOf('?')!=-1){href=href.substring(0,href.indexOf('?'));}
+href+='?'+OpenLayers.Util.getParameterString(params);this.element.href=href;},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Control.Scale=OpenLayers.Class(OpenLayers.Control,{element:null,initialize:function(element,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("div");this.div.appendChild(this.element);}
+this.map.events.register('moveend',this,this.updateScale);this.updateScale();return this.div;},updateScale:function(){var scale=this.map.getScale();if(!scale){return;}
+if(scale>=9500&&scale<=950000){scale=Math.round(scale/1000)+"K";}else if(scale>=950000){scale=Math.round(scale/1000000)+"M";}else{scale=Math.round(scale);}
+this.element.innerHTML=OpenLayers.i18n("scale",{'scaleDenom':scale});},CLASS_NAME:"OpenLayers.Control.Scale"});OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop){this.div.style.display="block";this.div.style.position="absolute";this.eTop=document.createElement("div");this.eTop.className=this.displayClass+"Top";var theLen=this.topInUnits.length;this.div.appendChild(this.eTop);if((this.topOutUnits=="")||(this.topInUnits=="")){this.eTop.style.visibility="hidden";}else{this.eTop.style.visibility="visible";}
+this.eBottom=document.createElement("div");this.eBottom.className=this.displayClass+"Bottom";this.div.appendChild(this.eBottom);if((this.bottomOutUnits=="")||(this.bottomInUnits=="")){this.eBottom.style.visibility="hidden";}else{this.eBottom.style.visibility="visible";}}
+this.map.events.register('moveend',this,this.update);this.update();return this.div;},getBarLen:function(maxLen){var digits=parseInt(Math.log(maxLen)/Math.log(10));var pow10=Math.pow(10,digits);var firstChar=parseInt(maxLen/pow10);var barLen;if(firstChar>5){barLen=5;}else if(firstChar>2){barLen=2;}else{barLen=1;}
+return barLen*pow10;},update:function(){var res=this.map.getResolution();if(!res){return;}
+var curMapUnits=this.map.units;var inches=OpenLayers.INCHES_PER_UNIT;var maxSizeData=this.maxWidth*res*inches[curMapUnits];var topUnits;var bottomUnits;if(maxSizeData>100000){topUnits=this.topOutUnits;bottomUnits=this.bottomOutUnits;}else{topUnits=this.topInUnits;bottomUnits=this.bottomInUnits;}
+var topMax=maxSizeData/inches[topUnits];var bottomMax=maxSizeData/inches[bottomUnits];var topRounded=this.getBarLen(topMax);var bottomRounded=this.getBarLen(bottomMax);topMax=topRounded/inches[curMapUnits]*inches[topUnits];bottomMax=bottomRounded/inches[curMapUnits]*inches[bottomUnits];var topPx=topMax/res;var bottomPx=bottomMax/res;this.eTop.style.width=Math.round(topPx)+"px";this.eBottom.style.width=Math.round(bottomPx)+"px";this.eTop.innerHTML=topRounded+" "+topUnits;this.eBottom.innerHTML=bottomRounded+" "+bottomUnits;},CLASS_NAME:"OpenLayers.Control.ScaleLine"});OpenLayers.Control.ZoomToMaxExtent=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){if(this.map){this.map.zoomToMaxExtent();}},CLASS_NAME:"OpenLayers.Control.ZoomToMaxExtent"});OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
+if(event.stopPropagation){event.stopPropagation();}else{event.cancelBubble=true;}},findElement:function(event,tagName){var element=OpenLayers.Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase()))){element=element.parentNode;}
+return element;},observe:function(elementParam,name,observer,useCapture){var element=OpenLayers.Util.getElement(elementParam);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent)){name='keydown';}
+if(!this.observers){this.observers={};}
+if(!element._eventCacheID){var idPrefix="eventCacheID_";if(element.id){idPrefix=element.id+"_"+idPrefix;}
+element._eventCacheID=OpenLayers.Util.createUniqueID(idPrefix);}
+var cacheID=element._eventCacheID;if(!this.observers[cacheID]){this.observers[cacheID]=[];}
+this.observers[cacheID].push({'element':element,'name':name,'observer':observer,'useCapture':useCapture});if(element.addEventListener){element.addEventListener(name,observer,useCapture);}else if(element.attachEvent){element.attachEvent('on'+name,observer);}},stopObservingElement:function(elementParam){var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[cacheID]);},_removeElementObservers:function(elementObservers){if(elementObservers){for(var i=elementObservers.length-1;i>=0;i--){var entry=elementObservers[i];var args=new Array(entry.element,entry.name,entry.observer,entry.useCapture);var removed=OpenLayers.Event.stopObserving.apply(this,args);}}},stopObserving:function(elementParam,name,observer,useCapture){useCapture=useCapture||false;var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;if(name=='keypress'){if(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.detachEvent){name='keydown';}}
+var foundEntry=false;var elementObservers=OpenLayers.Event.observers[cacheID];if(elementObservers){var i=0;while(!foundEntry&&i<elementObservers.length){var cacheEntry=elementObservers[i];if((cacheEntry.name==name)&&(cacheEntry.observer==observer)&&(cacheEntry.useCapture==useCapture)){elementObservers.splice(i,1);if(elementObservers.length==0){delete OpenLayers.Event.observers[cacheID];}
+foundEntry=true;break;}
+i++;}}
+if(foundEntry){if(element.removeEventListener){element.removeEventListener(name,observer,useCapture);}else if(element&&element.detachEvent){element.detachEvent('on'+name,observer);}}
+return foundEntry;},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var cacheID in OpenLayers.Event.observers){var elementObservers=OpenLayers.Event.observers[cacheID];OpenLayers.Event._removeElementObservers.apply(this,[elementObservers]);}
+OpenLayers.Event.observers=false;}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,'unload',OpenLayers.Event.unloadCache,false);if(window.Event){OpenLayers.Util.applyDefaults(window.Event,OpenLayers.Event);}else{var Event=OpenLayers.Event;}
+OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","resize","focus","blur"],listeners:null,object:null,element:null,eventTypes:null,eventHandler:null,fallThrough:null,initialize:function(object,element,eventTypes,fallThrough){this.object=object;this.element=element;this.eventTypes=eventTypes;this.fallThrough=fallThrough;this.listeners={};this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,this);if(this.eventTypes!=null){for(var i=0;i<this.eventTypes.length;i++){this.addEventType(this.eventTypes[i]);}}
+if(this.element!=null){this.attachToElement(element);}},destroy:function(){if(this.element){OpenLayers.Event.stopObservingElement(this.element);}
+this.element=null;this.listeners=null;this.object=null;this.eventTypes=null;this.fallThrough=null;this.eventHandler=null;},addEventType:function(eventName){if(!this.listeners[eventName]){this.listeners[eventName]=[];}},attachToElement:function(element){for(var i=0;i<this.BROWSER_EVENTS.length;i++){var eventType=this.BROWSER_EVENTS[i];this.addEventType(eventType);OpenLayers.Event.observe(element,eventType,this.eventHandler);}
+OpenLayers.Event.observe(element,"dragstart",OpenLayers.Event.stop);},on:function(object){for(var type in object){if(type!="scope"){this.register(type,object.scope,object[type]);}}},register:function(type,obj,func){if(func!=null&&((this.eventTypes&&OpenLayers.Util.indexOf(this.eventTypes,type)!=-1)||OpenLayers.Util.indexOf(this.BROWSER_EVENTS,type)!=-1)){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(listeners!=null){listeners.push({obj:obj,func:func});}}},registerPriority:function(type,obj,func){if(func!=null){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(listeners!=null){listeners.unshift({obj:obj,func:func});}}},un:function(object){for(var type in object){if(type!="scope"){this.unregister(type,object.scope,object[type]);}}},unregister:function(type,obj,func){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(listeners!=null){for(var i=0;i<listeners.length;i++){if(listeners[i].obj==obj&&listeners[i].func==func){listeners.splice(i,1);break;}}}},remove:function(type){if(this.listeners[type]!=null){this.listeners[type]=[];}},triggerEvent:function(type,evt){if(evt==null){evt={};}
+evt.object=this.object;evt.element=this.element;if(!evt.type){evt.type=type;}
+var listeners=(this.listeners[type])?this.listeners[type].slice():null;if((listeners!=null)&&(listeners.length>0)){var continueChain;for(var i=0;i<listeners.length;i++){var callback=listeners[i];continueChain=callback.func.apply(callback.obj,[evt]);if((continueChain!=undefined)&&(continueChain==false)){break;}}
+if(!this.fallThrough){OpenLayers.Event.stop(evt,true);}}
+return continueChain;},handleBrowserEvent:function(evt){evt.xy=this.getMousePosition(evt);this.triggerEvent(evt.type,evt);},getMousePosition:function(evt){if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);this.element.offsets[0]+=(document.documentElement.scrollLeft||document.body.scrollLeft);this.element.offsets[1]+=(document.documentElement.scrollTop||document.body.scrollTop);}
+return new OpenLayers.Pixel((evt.clientX+(document.documentElement.scrollLeft||document.body.scrollLeft))-this.element.offsets[0]
+-(document.documentElement.clientLeft||0),(evt.clientY+(document.documentElement.scrollTop||document.body.scrollTop))-this.element.offsets[1]
+-(document.documentElement.clientTop||0));},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Format=OpenLayers.Class({externalProjection:null,internalProjection:null,initialize:function(options){OpenLayers.Util.extend(this,options);},read:function(data){alert(OpenLayers.i18n("readNotImplemented"));},write:function(object){alert(OpenLayers.i18n("writeNotImplemented"));},CLASS_NAME:"OpenLayers.Format"});OpenLayers.Lang.en={'unhandledRequest':"Unhandled request return ${statusText}",'permalink':"Permalink",'overlays':"Overlays",'baseLayer':"Base Layer",'sameProjection':"The overview map only works when it is in the same projection as the main map",'readNotImplemented':"Read not implemented.",'writeNotImplemented':"Write not implemented.",'noFID':"Can't update a feature for which there is no FID.",'errorLoadingGML':"Error in loading GML file ${url}",'browserNotSupported':"Your browser does not support vector rendering. Currently supported renderers are:\n${renderers}",'componentShouldBe':"addFeatures : component should be an ${geomType}",'getFeatureError':"getFeatureFromEvent called on layer with no renderer. This usually means you "+"destroyed a layer, but not some handler which is associated with it.",'minZoomLevelError':"The minZoomLevel property is only intended for use "+"with the FixedZoomLevels-descendent layers. That this "+"wfs layer checks for minZoomLevel is a relic of the"+"past. We cannot, however, remove it without possibly "+"breaking OL based applications that may depend on it."+" Therefore we are deprecating it -- the minZoomLevel "+"check below will be removed at 3.0. Please instead "+"use min/max resolution setting as described here: "+"http://trac.openlayers.org/wiki/SettingZoomLevels",'commitSuccess':"WFS Transaction: SUCCESS ${response}",'commitFailed':"WFS Transaction: FAILED ${response}",'googleWarning':"The Google Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the Google Maps library "+"script was either not included, or does not contain the "+"correct API key for your site.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/Google' "+"target='_blank'>click here</a>",'getLayerWarning':"The ${layerType} Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the ${layerLib} library "+"script was either not correctly included.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/${layerLib}' "+"target='_blank'>click here</a>",'scale':"Scale = 1 : ${scaleDenom}",'layerAlreadyAdded':"You tried to add the layer: ${layerName} to the map, but it has already been added",'reprojectDeprecated':"You are using the 'reproject' option "+"on the ${layerName} layer. This option is deprecated: "+"its use was designed to support displaying data over commercial "+"basemaps, but that functionality should now be achieved by using "+"Spherical Mercator support. More information is available from "+"http://trac.openlayers.org/wiki/SphericalMercator.",'methodDeprecated':"This method has been deprecated and will be removed in 3.0. "+"Please use ${newMethod} instead.",'boundsAddError':"You must pass both x and y values to the add function.",'lonlatAddError':"You must pass both lon and lat values to the add function.",'pixelAddError':"You must pass both x and y values to the add function.",'unsupportedGeometryType':"Unsupported geometry type: ${geomType}",'pagePositionFailed':"OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",'end':''};OpenLayers.Popup.Anchored=OpenLayers.Class(OpenLayers.Popup,{relativePosition:null,anchor:null,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){var newArguments=new Array(id,lonlat,size,contentHTML,closeBox,closeBoxCallback);OpenLayers.Popup.prototype.initialize.apply(this,newArguments);this.anchor=(anchor!=null)?anchor:{size:new OpenLayers.Size(0,0),offset:new OpenLayers.Pixel(0,0)};},destroy:function(){this.anchor=null;this.relativePosition=null;OpenLayers.Popup.prototype.destroy.apply(this,arguments);},show:function(){this.updatePosition();OpenLayers.Popup.prototype.show.apply(this,arguments);},moveTo:function(px){var oldRelativePosition=this.relativePosition;this.relativePosition=this.calculateRelativePosition(px);var newPx=this.calculateNewPx(px);var newArguments=new Array(newPx);OpenLayers.Popup.prototype.moveTo.apply(this,newArguments);if(this.relativePosition!=oldRelativePosition){this.updateRelativePosition();}},setSize:function(size){OpenLayers.Popup.prototype.setSize.apply(this,arguments);if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);this.moveTo(px);}},calculateRelativePosition:function(px){var lonlat=this.map.getLonLatFromLayerPx(px);var extent=this.map.getExtent();var quadrant=extent.determineQuadrant(lonlat);return OpenLayers.Bounds.oppositeQuadrant(quadrant);},updateRelativePosition:function(){},calculateNewPx:function(px){var newPx=px.offset(this.anchor.offset);var top=(this.relativePosition.charAt(0)=='t');newPx.y+=(top)?-this.size.h:this.anchor.size.h;var left=(this.relativePosition.charAt(1)=='l');newPx.x+=(left)?-this.size.w:this.anchor.size.w;return newPx;},CLASS_NAME:"OpenLayers.Popup.Anchored"});OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){if(projection&&projection.getCode){return this.getCode()==projection.getCode();}else{return false;}},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
+OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
+return point;};OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,xmlns:null,minimumSymbolizer:{strokeLinecap:"round",strokeOpacity:1,fillOpacity:1,pointRadius:0},initialize:function(containerID){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot();this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);},destroy:function(){this.clear();this.rendererRoot=null;this.root=null;this.xmlns=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments);},clear:function(){if(this.root){while(this.root.childNodes.length>0){this.root.removeChild(this.root.firstChild);}}},getNodeType:function(geometry,style){},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.drawGeometry(geometry.components[i],style,featureId);}
+return;};if(style.display!="none"){var nodeType=this.getNodeType(geometry,style);var node=this.nodeFactory(geometry.id,nodeType);node._featureId=featureId;node._geometryClass=geometry.CLASS_NAME;node._style=style;node=this.drawGeometryNode(node,geometry);if(node.parentNode!=this.root){this.root.appendChild(node);}
+this.postDraw(node);}else{node=OpenLayers.Util.getElement(geometry.id);if(node){node.parentNode.removeChild(node);}}},drawGeometryNode:function(node,geometry,style){style=style||node._style;OpenLayers.Util.applyDefaults(style,this.minimumSymbolizer);var options={'isFilled':true,'isStroked':!!style.strokeWidth};switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":this.drawPoint(node,geometry);break;case"OpenLayers.Geometry.LineString":options.isFilled=false;this.drawLineString(node,geometry);break;case"OpenLayers.Geometry.LinearRing":this.drawLinearRing(node,geometry);break;case"OpenLayers.Geometry.Polygon":this.drawPolygon(node,geometry);break;case"OpenLayers.Geometry.Surface":this.drawSurface(node,geometry);break;case"OpenLayers.Geometry.Rectangle":this.drawRectangle(node,geometry);break;default:break;}
+node._style=style;node._options=options;return this.setStyle(node,style,options,geometry);},postDraw:function(node){},drawPoint:function(node,geometry){},drawLineString:function(node,geometry){},drawLinearRing:function(node,geometry){},drawPolygon:function(node,geometry){},drawRectangle:function(node,geometry){},drawCircle:function(node,geometry){},drawSurface:function(node,geometry){},getFeatureIdFromEvent:function(evt){var node=evt.target||evt.srcElement;return node._featureId;},eraseGeometry:function(geometry){if((geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPoint")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiLineString")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.eraseGeometry(geometry.components[i]);}}else{var element=OpenLayers.Util.getElement(geometry.id);if(element&&element.parentNode){element.parentNode.removeChild(element);}}},nodeFactory:function(id,type){var node=OpenLayers.Util.getElement(id);if(node){if(!this.nodeTypeCompare(node,type)){node.parentNode.removeChild(node);node=this.nodeFactory(id,type);}}else{node=this.createNode(type,id);}
+return node;},CLASS_NAME:"OpenLayers.Renderer.Elements"});OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,isBackBuffer:false,lastRatio:1,isFirstDraw:true,backBufferTile:null,initialize:function(layer,position,bounds,url,size){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){this.layer.events.unregister("loadend",this,this.resetBackBuffer);this.events.unregister('loadend',this,this.resetBackBuffer);}else{this.events.unregister('loadend',this,this.showTile);}
+this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;if(this.backBufferTile){this.backBufferTile.destroy();this.backBufferTile=null;}},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);}
+OpenLayers.Util.applyDefaults(obj,this);return obj;},draw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));var drawTile=(withinMaxExtent||this.layer.displayOutsideMaxExtent);if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(drawTile){if(!this.backBufferTile){this.backBufferTile=this.clone();this.backBufferTile.hide();this.backBufferTile.isBackBuffer=true;this.events.register('loadend',this,this.resetBackBuffer);this.layer.events.register("loadend",this,this.resetBackBuffer);}
+this.startTransition();}else{if(this.backBufferTile){this.backBufferTile.clear();}}}else{if(drawTile&&this.isFirstDraw){this.events.register('loadend',this,this.showTile);this.isFirstDraw=false;}}
+this.shouldDraw=drawTile;this.clear();return drawTile;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
+this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
+var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},startTransition:function(){},resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=false;var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));if(withinMaxExtent){this.backBufferTile.position=this.position;this.backBufferTile.bounds=this.bounds;this.backBufferTile.size=this.size;this.backBufferTile.imageSize=this.layer.imageSize||this.size;this.backBufferTile.imageOffset=this.layer.imageOffset;this.backBufferTile.resolution=this.layer.getResolution();this.backBufferTile.renderTile();}}},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Control.MouseToolbar=OpenLayers.Class(OpenLayers.Control.MouseDefaults,{mode:null,buttons:null,direction:"vertical",buttonClicked:null,initialize:function(position,direction){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.position=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,OpenLayers.Control.MouseToolbar.Y);if(position){this.position=position;}
+if(direction){this.direction=direction;}
+this.measureDivs=[];},destroy:function(){for(var btnId in this.buttons){var btn=this.buttons[btnId];btn.map=null;btn.events.destroy();}
+OpenLayers.Control.MouseDefaults.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);OpenLayers.Control.MouseDefaults.prototype.draw.apply(this,arguments);this.buttons={};var sz=new OpenLayers.Size(28,28);var centered=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,0);this._addButton("zoombox","drag-rectangle-off.png","drag-rectangle-on.png",centered,sz,"Shift->Drag to zoom to area");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this._addButton("pan","panning-hand-off.png","panning-hand-on.png",centered,sz,"Drag the map to pan.");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this.switchModeTo("pan");return this.div;},_addButton:function(id,img,activeImg,xy,sz,title){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var activeImgLocation=OpenLayers.Util.getImagesLocation()+activeImg;var btn=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MouseToolbar_"+id,xy,sz,imgLocation,"absolute");this.div.appendChild(btn);btn.imgLocation=imgLocation;btn.activeImgLocation=activeImgLocation;btn.events=new OpenLayers.Events(this,btn,null,true);btn.events.on({"mousedown":this.buttonDown,"mouseup":this.buttonUp,"dblclick":OpenLayers.Event.stop,scope:this});btn.action=id;btn.title=title;btn.alt=title;btn.map=this.map;this.buttons[id]=btn;return btn;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+this.buttonClicked=evt.element.action;OpenLayers.Event.stop(evt);},buttonUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+if(this.buttonClicked!=null){if(this.buttonClicked==evt.element.action){this.switchModeTo(evt.element.action);}
+OpenLayers.Event.stop(evt);this.buttonClicked=null;}},defaultDblClick:function(evt){this.switchModeTo("pan");this.performedDrag=false;var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+this.mouseDragStart=evt.xy.clone();this.performedDrag=false;this.startViaKeyboard=false;if(evt.shiftKey&&this.mode!="zoombox"){this.switchModeTo("zoombox");this.startViaKeyboard=true;}else if(evt.altKey&&this.mode!="measure"){this.switchModeTo("measure");}else if(!this.mode){this.switchModeTo("pan");}
+switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.performedDrag=true;break;case"measure":var distance="";if(this.measureStart){var measureEnd=this.map.getLonLatFromViewPortPx(this.mouseDragStart);distance=OpenLayers.Util.distVincenty(this.measureStart,measureEnd);distance=Math.round(distance*100)/100;distance=distance+"km";this.measureStartBox=this.measureBox;}
+this.measureStart=this.map.getLonLatFromViewPortPx(this.mouseDragStart);;this.measureBox=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),-2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBox.style.width="4px";this.measureBox.style.height="4px";this.measureBox.style.fontSize="1px";this.measureBox.style.backgroundColor="red";this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);if(distance){this.measureBoxDistance=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBoxDistance.innerHTML=distance;this.measureBoxDistance.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBoxDistance);this.measureDivs.push(this.measureBoxDistance);}
+this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);this.measureDivs.push(this.measureBox);break;default:this.map.div.style.cursor="move";break;}
+document.onselectstart=function(){return false;};OpenLayers.Event.stop(evt);},switchModeTo:function(mode){if(mode!=this.mode){if(this.mode&&this.buttons[this.mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[this.mode],null,null,null,this.buttons[this.mode].imgLocation);}
+if(this.mode=="measure"&&mode!="measure"){for(var i=0;i<this.measureDivs.length;i++){if(this.measureDivs[i]){this.map.layerContainerDiv.removeChild(this.measureDivs[i]);}}
+this.measureDivs=[];this.measureStart=null;}
+this.mode=mode;if(this.buttons[mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[mode],null,null,null,this.buttons[mode].activeImgLocation);}
+switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";break;default:this.map.div.style.cursor="";break;}}},leaveMode:function(){this.switchModeTo("pan");},defaultMouseMove:function(evt){if(this.mouseDragStart!=null){switch(this.mode){case"zoombox":var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
+break;default:var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();}
+switch(this.mode){case"zoombox":this.zoomBoxEnd(evt);if(this.startViaKeyboard){this.leaveMode();}
+break;case"pan":if(this.performedDrag){this.map.setCenter(this.map.center);}}
+document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="default";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.zoomBox){this.removeZoomBox();if(this.startViaKeyboard){this.leaveMode();}}
+this.mouseDragStart=null;this.map.div.style.cursor="default";}},defaultClick:function(evt){if(this.performedDrag){this.performedDrag=false;return false;}},CLASS_NAME:"OpenLayers.Control.MouseToolbar"});OpenLayers.Control.MouseToolbar.X=6;OpenLayers.Control.MouseToolbar.Y=300;OpenLayers.Control.PanZoomBar=OpenLayers.Class(OpenLayers.Control.PanZoom,{zoomStopWidth:18,zoomStopHeight:11,slider:null,sliderEvents:null,zoomBarDiv:null,divEvents:null,zoomWorldIcon:false,initialize:function(){OpenLayers.Control.PanZoom.prototype.initialize.apply(this,arguments);},destroy:function(){this.div.removeChild(this.slider);this.slider=null;this.sliderEvents.destroy();this.sliderEvents=null;this.div.removeChild(this.zoombarDiv);this.zoomBarDiv=null;this.divEvents.destroy();this.divEvents=null;this.map.events.un({"zoomend":this.moveZoomBar,"changebaselayer":this.redraw,scope:this});OpenLayers.Control.PanZoom.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.PanZoom.prototype.setMap.apply(this,arguments);this.map.events.register("changebaselayer",this,this.redraw);},redraw:function(){if(this.div!=null){this.div.innerHTML="";}
+this.draw();},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position.clone();this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);var wposition=sz.w;if(this.zoomWorldIcon){centered=new OpenLayers.Pixel(px.x+sz.w,px.y);}
+this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);if(this.zoomWorldIcon){this._addButton("zoomworld","zoom-world-mini.png",px.add(sz.w,0),sz);wposition*=2;}
+this._addButton("panright","east-mini.png",px.add(wposition,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);centered=this._addZoomBar(centered.add(0,sz.h*4+5));this._addButton("zoomout","zoom-minus-mini.png",centered,sz);return this.div;},_addZoomBar:function(centered){var imgLocation=OpenLayers.Util.getImagesLocation();var id="OpenLayers_Control_PanZoomBar_Slider"+this.map.id;var zoomsToEnd=this.map.getNumZoomLevels()-1-this.map.getZoom();var slider=OpenLayers.Util.createAlphaImageDiv(id,centered.add(-1,zoomsToEnd*this.zoomStopHeight),new OpenLayers.Size(20,9),imgLocation+"slider.png","absolute");this.slider=slider;this.sliderEvents=new OpenLayers.Events(this,slider,null,true);this.sliderEvents.on({"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.zoomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});var sz=new OpenLayers.Size();sz.h=this.zoomStopHeight*this.map.getNumZoomLevels();sz.w=this.zoomStopWidth;var div=null;if(OpenLayers.Util.alphaHack()){var id="OpenLayers_Control_PanZoomBar"+this.map.id;div=OpenLayers.Util.createAlphaImageDiv(id,centered,new OpenLayers.Size(sz.w,this.zoomStopHeight),imgLocation+"zoombar.png","absolute",null,"crop");div.style.height=sz.h;}else{div=OpenLayers.Util.createDiv('OpenLayers_Control_PanZoomBar_Zoombar'+this.map.id,centered,sz,imgLocation+"zoombar.png");}
+this.zoombarDiv=div;this.divEvents=new OpenLayers.Events(this,div,null,true);this.divEvents.on({"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.div.appendChild(div);this.startTop=parseInt(div.style.top);this.div.appendChild(slider);this.map.events.register("zoomend",this,this.moveZoomBar);centered=centered.add(0,this.zoomStopHeight*this.map.getNumZoomLevels());return centered;},passEventToSlider:function(evt){this.sliderEvents.handleBrowserEvent(evt);},divClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+var y=evt.xy.y;var top=OpenLayers.Util.pagePosition(evt.object)[1];var levels=(y-top)/this.zoomStopHeight;if(!this.map.fractionalZoom){levels=Math.floor(levels);}
+var zoom=(this.map.getNumZoomLevels()-1)-levels;zoom=Math.min(Math.max(zoom,0),this.map.getNumZoomLevels()-1);this.map.zoomTo(zoom);OpenLayers.Event.stop(evt);},zoomBarDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+this.map.events.on({"mousemove":this.passEventToSlider,"mouseup":this.passEventToSlider,scope:this});this.mouseDragStart=evt.xy.clone();this.zoomStart=evt.xy.clone();this.div.style.cursor="move";this.zoombarDiv.offsets=null;OpenLayers.Event.stop(evt);},zoomBarDrag:function(evt){if(this.mouseDragStart!=null){var deltaY=this.mouseDragStart.y-evt.xy.y;var offsets=OpenLayers.Util.pagePosition(this.zoombarDiv);if((evt.clientY-offsets[1])>0&&(evt.clientY-offsets[1])<parseInt(this.zoombarDiv.style.height)-2){var newTop=parseInt(this.slider.style.top)-deltaY;this.slider.style.top=newTop+"px";}
+this.mouseDragStart=evt.xy.clone();OpenLayers.Event.stop(evt);}},zoomBarUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+if(this.zoomStart){this.div.style.cursor="";this.map.events.un({"mouseup":this.passEventToSlider,"mousemove":this.passEventToSlider,scope:this});var deltaY=this.zoomStart.y-evt.xy.y;var zoomLevel=this.map.zoom;if(this.map.fractionalZoom){zoomLevel+=deltaY/this.zoomStopHeight;zoomLevel=Math.min(Math.max(zoomLevel,0),this.map.getNumZoomLevels()-1);}else{zoomLevel+=Math.round(deltaY/this.zoomStopHeight);}
+this.map.zoomTo(zoomLevel);this.moveZoomBar();this.mouseDragStart=null;OpenLayers.Event.stop(evt);}},moveZoomBar:function(){var newTop=((this.map.getNumZoomLevels()-1)-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=newTop+"px";},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Format.JSON=OpenLayers.Class(OpenLayers.Format,{indent:"    ",space:" ",newline:"\n",level:0,pretty:false,initialize:function(options){OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(json,filter){try{if(/^[\],:{}\s]*$/.test(json.replace(/\\["\\\/bfnrtu]/g,'@').replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g,']').replace(/(?:^|:|,)(?:\s*\[)+/g,''))){var object=eval('('+json+')');if(typeof filter==='function'){function walk(k,v){if(v&&typeof v==='object'){for(var i in v){if(v.hasOwnProperty(i)){v[i]=walk(i,v[i]);}}}
+return filter(k,v);}
+object=walk('',object);}
+return object;}}catch(e){}
+return null;},write:function(value,pretty){this.pretty=!!pretty;var json=null;var type=typeof value;if(this.serialize[type]){json=this.serialize[type].apply(this,[value]);}
+return json;},writeIndent:function(){var pieces=[];if(this.pretty){for(var i=0;i<this.level;++i){pieces.push(this.indent);}}
+return pieces.join('');},writeNewline:function(){return(this.pretty)?this.newline:'';},writeSpace:function(){return(this.pretty)?this.space:'';},serialize:{'object':function(object){if(object==null){return"null";}
+if(object.constructor==Date){return this.serialize.date.apply(this,[object]);}
+if(object.constructor==Array){return this.serialize.array.apply(this,[object]);}
+var pieces=['{'];this.level+=1;var key,keyJSON,valueJSON;var addComma=false;for(key in object){if(object.hasOwnProperty(key)){keyJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[key,this.pretty]);valueJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[object[key],this.pretty]);if(keyJSON!=null&&valueJSON!=null){if(addComma){pieces.push(',');}
+pieces.push(this.writeNewline(),this.writeIndent(),keyJSON,':',this.writeSpace(),valueJSON);addComma=true;}}}
+this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),'}');return pieces.join('');},'array':function(array){var json;var pieces=['['];this.level+=1;for(var i=0;i<array.length;++i){json=OpenLayers.Format.JSON.prototype.write.apply(this,[array[i],this.pretty]);if(json!=null){if(i>0){pieces.push(',');}
+pieces.push(this.writeNewline(),this.writeIndent(),json);}}
+this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),']');return pieces.join('');},'string':function(string){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'};if(/["\\\x00-\x1f]/.test(string)){return'"'+string.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
+c=b.charCodeAt();return'\\u00'+
+Math.floor(c/16).toString(16)+
+(c%16).toString(16);})+'"';}
+return'"'+string+'"';},'number':function(number){return isFinite(number)?String(number):"null";},'boolean':function(bool){return String(bool);},'date':function(date){function format(number){return(number<10)?'0'+number:number;}
+return'"'+date.getFullYear()+'-'+
+format(date.getMonth()+1)+'-'+
+format(date.getDate())+'T'+
+format(date.getHours())+':'+
+format(date.getMinutes())+':'+
+format(date.getSeconds())+'"';}},CLASS_NAME:"OpenLayers.Format.JSON"});OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{xmldom:null,initialize:function(options){if(window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}
+OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
+var node=OpenLayers.Util.Try(OpenLayers.Function.bind((function(){var xmldom;if(window.ActiveXObject&&!this.xmldom){xmldom=new ActiveXObject("Microsoft.XMLDOM");}else{xmldom=this.xmldom;}
+xmldom.loadXML(text);return xmldom;}),this),function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
+req.send(null);return req.responseXML;});return node;},write:function(node){var data;if(this.xmldom){data=node.xml;}else{var serializer=new XMLSerializer();if(node.nodeType==1){var doc=document.implementation.createDocument("","",null);if(doc.importNode){node=doc.importNode(node,true);}
+doc.appendChild(node);data=serializer.serializeToString(doc);}else{data=serializer.serializeToString(node);}}
+return data;},createElementNS:function(uri,name){var element;if(this.xmldom){if(typeof uri=="string"){element=this.xmldom.createNode(1,name,uri);}else{element=this.xmldom.createNode(1,name,"");}}else{element=document.createElementNS(uri,name);}
+return element;},createTextNode:function(text){var node;if(this.xmldom){node=this.xmldom.createTextNode(text);}else{node=document.createTextNode(text);}
+return node;},getElementsByTagNameNS:function(node,uri,name){var elements=[];if(node.getElementsByTagNameNS){elements=node.getElementsByTagNameNS(uri,name);}else{var allNodes=node.getElementsByTagName("*");var potentialNode,fullName;for(var i=0;i<allNodes.length;++i){potentialNode=allNodes[i];fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if((name=="*")||(fullName==potentialNode.nodeName)){if((uri=="*")||(uri==potentialNode.namespaceURI)){elements.push(potentialNode);}}}}
+return elements;},getAttributeNodeNS:function(node,uri,name){var attributeNode=null;if(node.getAttributeNodeNS){attributeNode=node.getAttributeNodeNS(uri,name);}else{var attributes=node.attributes;var potentialNode,fullName;for(var i=0;i<attributes.length;++i){potentialNode=attributes[i];if(potentialNode.namespaceURI==uri){fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if(fullName==potentialNode.nodeName){attributeNode=potentialNode;break;}}}}
+return attributeNode;},getAttributeNS:function(node,uri,name){var attributeValue="";if(node.getAttributeNS){attributeValue=node.getAttributeNS(uri,name)||"";}else{var attributeNode=this.getAttributeNodeNS(node,uri,name);if(attributeNode){attributeValue=attributeNode.nodeValue;}}
+return attributeValue;},getChildValue:function(node,def){var value;try{value=node.firstChild.nodeValue;}catch(e){value=(def!=undefined)?def:"";}
+return value;},concatChildValues:function(node,def){var value="";var child=node.firstChild;var childValue;while(child){childValue=child.nodeValue;if(childValue){value+=childValue;}
+child=child.nextSibling;}
+if(value==""&&def!=undefined){value=def;}
+return value;},hasAttributeNS:function(node,uri,name){var found=false;if(node.hasAttributeNS){found=node.hasAttributeNS(uri,name);}else{found=!!this.getAttributeNodeNS(node,uri,name);}
+return found;},setAttributeNS:function(node,uri,name,value){if(node.setAttributeNS){node.setAttributeNS(uri,name,value);}else{if(this.xmldom){if(uri){var attribute=node.ownerDocument.createNode(2,name,uri);attribute.nodeValue=value;node.setAttributeNode(attribute);}else{node.setAttribute(name,value);}}else{throw"setAttributeNS not implemented";}}},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;if(control.map){this.setMap(control.map);}
+OpenLayers.Util.extend(this,options);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
+var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0;i<events.length;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
+this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0;i<events.length;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
+this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,paddingForPopups:null,initialize:function(div,options){this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';OpenLayers.Util.extend(this,options);this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);var id=this.div.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);id=this.div.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.viewPortDiv.appendChild(this.layerContainerDiv);this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES,this.fallThrough);this.updateSize();if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft")){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
+if(this.theme){var addNode=true;var nodes=document.getElementsByTagName('link');for(var i=0;i<nodes.length;++i){if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,this.theme)){addNode=false;break;}}
+if(addNode){var cssNode=document.createElement('link');cssNode.setAttribute('rel','stylesheet');cssNode.setAttribute('type','text/css');cssNode.setAttribute('href',this.theme);document.getElementsByTagName('head')[0].appendChild(cssNode);}}
+this.layers=[];if(this.controls==null){if(OpenLayers.Control!=null){this.controls=[new OpenLayers.Control.Navigation(),new OpenLayers.Control.PanZoom(),new OpenLayers.Control.ArgParser(),new OpenLayers.Control.Attribution()];}else{this.controls=[];}}
+for(var i=0;i<this.controls.length;i++){this.addControlToMap(this.controls[i]);}
+this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,'unload',this.unloadDestroy);},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy){return false;}
+OpenLayers.Event.stopObserving(window,'unload',this.unloadDestroy);this.unloadDestroy=null;if(this.updateSizeDestroy){OpenLayers.Event.stopObserving(window,'resize',this.updateSizeDestroy);}else{this.events.unregister("resize",this,this.updateSize);}
+this.paddingForPopups=null;if(this.controls!=null){for(var i=this.controls.length-1;i>=0;--i){this.controls[i].destroy();}
+this.controls=null;}
+if(this.layers!=null){for(var i=this.layers.length-1;i>=0;--i){this.layers[i].destroy(false);}
+this.layers=null;}
+if(this.viewPortDiv){this.div.removeChild(this.viewPortDiv);}
+this.viewPortDiv=null;if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null;}
+this.events.destroy();this.events=null;},setOptions:function(options){OpenLayers.Util.extend(this,options);},getTileSize:function(){return this.tileSize;},getBy:function(array,property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this[array],function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getLayersBy:function(property,match){return this.getBy("layers",property,match);},getLayersByName:function(match){return this.getLayersBy("name",match);},getLayersByClass:function(match){return this.getLayersBy("CLASS_NAME",match);},getControlsBy:function(property,match){return this.getBy("controls",property,match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},getLayer:function(id){var foundLayer=null;for(var i=0;i<this.layers.length;i++){var layer=this.layers[i];if(layer.id==id){foundLayer=layer;break;}}
+return foundLayer;},setLayerZIndex:function(layer,zIdx){layer.setZIndex(this.Z_INDEX_BASE[layer.isBaseLayer?'BaseLayer':'Overlay']
++zIdx*5);},resetLayersZIndex:function(){for(var i=0;i<this.layers.length;i++){var layer=this.layers[i];this.setLayerZIndex(layer,i);}},addLayer:function(layer){for(var i=0;i<this.layers.length;i++){if(this.layers[i]==layer){var msg=OpenLayers.i18n('layerAlreadyAdded',{'layerName':layer.name});OpenLayers.Console.warn(msg);return false;}}
+this.events.triggerEvent("preaddlayer",{layer:layer});layer.div.className="olLayerDiv";layer.div.style.overflow="";this.setLayerZIndex(layer,this.layers.length);if(layer.isFixed){this.viewPortDiv.appendChild(layer.div);}else{this.layerContainerDiv.appendChild(layer.div);}
+this.layers.push(layer);layer.setMap(this);if(layer.isBaseLayer){if(this.baseLayer==null){this.setBaseLayer(layer);}else{layer.setVisibility(false);}}else{layer.redraw();}
+this.events.triggerEvent("addlayer",{layer:layer});},addLayers:function(layers){for(var i=0;i<layers.length;i++){this.addLayer(layers[i]);}},removeLayer:function(layer,setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
+if(layer.isFixed){this.viewPortDiv.removeChild(layer.div);}else{this.layerContainerDiv.removeChild(layer.div);}
+OpenLayers.Util.removeItem(this.layers,layer);layer.removeMap(this);layer.map=null;if(this.baseLayer==layer){this.baseLayer=null;if(setNewBaseLayer){for(var i=0;i<this.layers.length;i++){var iLayer=this.layers[i];if(iLayer.isBaseLayer){this.setBaseLayer(iLayer);break;}}}}
+this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:layer});},getNumLayers:function(){return this.layers.length;},getLayerIndex:function(layer){return OpenLayers.Util.indexOf(this.layers,layer);},setLayerIndex:function(layer,idx){var base=this.getLayerIndex(layer);if(idx<0){idx=0;}else if(idx>this.layers.length){idx=this.layers.length;}
+if(base!=idx){this.layers.splice(base,1);this.layers.splice(idx,0,layer);for(var i=0;i<this.layers.length;i++){this.setLayerZIndex(this.layers[i],i);}
+this.events.triggerEvent("changelayer",{layer:layer,property:"order"});}},raiseLayer:function(layer,delta){var idx=this.getLayerIndex(layer)+delta;this.setLayerIndex(layer,idx);},setBaseLayer:function(newBaseLayer){var oldExtent=null;if(this.baseLayer){oldExtent=this.baseLayer.getExtent();}
+if(newBaseLayer!=this.baseLayer){if(OpenLayers.Util.indexOf(this.layers,newBaseLayer)!=-1){if(this.baseLayer!=null){this.baseLayer.setVisibility(false);}
+this.baseLayer=newBaseLayer;this.viewRequestID++;this.baseLayer.visibility=true;var center=this.getCenter();if(center!=null){var newCenter=(oldExtent)?oldExtent.getCenterLonLat():center;var newZoom=(oldExtent)?this.getZoomForExtent(oldExtent,true):this.getZoomForResolution(this.resolution,true);this.setCenter(newCenter,newZoom,false,true);}
+this.events.triggerEvent("changebaselayer",{layer:this.baseLayer});}}},addControl:function(control,px){this.controls.push(control);this.addControlToMap(control,px);},addControlToMap:function(control,px){control.outsideViewport=(control.div!=null);if(this.displayProjection&&!control.displayProjection){control.displayProjection=this.displayProjection;}
+control.setMap(this);var div=control.draw(px);if(div){if(!control.outsideViewport){div.style.zIndex=this.Z_INDEX_BASE['Control']+
+this.controls.length;this.viewPortDiv.appendChild(div);}}},getControl:function(id){var returnControl=null;for(var i=0;i<this.controls.length;i++){var control=this.controls[i];if(control.id==id){returnControl=control;break;}}
+return returnControl;},removeControl:function(control){if((control)&&(control==this.getControl(control.id))){if(control.div&&(control.div.parentNode==this.viewPortDiv)){this.viewPortDiv.removeChild(control.div);}
+OpenLayers.Util.removeItem(this.controls,control);}},addPopup:function(popup,exclusive){if(exclusive){for(var i=this.popups.length-1;i>=0;--i){this.removePopup(this.popups[i]);}}
+popup.map=this;this.popups.push(popup);var popupDiv=popup.draw();if(popupDiv){popupDiv.style.zIndex=this.Z_INDEX_BASE['Popup']+
+this.popups.length;this.layerContainerDiv.appendChild(popupDiv);}},removePopup:function(popup){OpenLayers.Util.removeItem(this.popups,popup);if(popup.div){try{this.layerContainerDiv.removeChild(popup.div);}
+catch(e){}}
+popup.map=null;},getSize:function(){var size=null;if(this.size!=null){size=this.size.clone();}
+return size;},updateSize:function(){this.events.element.offsets=null;var newSize=this.getCurrentSize();var oldSize=this.getSize();if(oldSize==null){this.size=oldSize=newSize;}
+if(!newSize.equals(oldSize)){this.size=newSize;for(var i=0;i<this.layers.length;i++){this.layers[i].onMapResize();}
+if(this.baseLayer!=null){var center=new OpenLayers.Pixel(newSize.w/2,newSize.h/2);var centerLL=this.getLonLatFromViewPortPx(center);var zoom=this.getZoom();this.zoom=null;this.setCenter(this.getCenter(),zoom);}}},getCurrentSize:function(){var size=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){var dim=OpenLayers.Element.getDimensions(this.div);size.w=dim.width;size.h=dim.height;}
+if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=parseInt(this.div.style.width);size.h=parseInt(this.div.style.height);}
+return size;},calculateBounds:function(center,resolution){var extent=null;if(center==null){center=this.getCenter();}
+if(resolution==null){resolution=this.getResolution();}
+if((center!=null)&&(resolution!=null)){var size=this.getSize();var w_deg=size.w*resolution;var h_deg=size.h*resolution;extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);}
+return extent;},getCenter:function(){return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){if(!options){options={};}
+OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});var centerPx=this.getViewPortPxFromLonLat(this.getCenter());var newCenterPx=centerPx.add(dx,dy);if(!options.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.setCenter(newCenterLonLat,null,options.dragging);}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
+var center=this.getCenter();var from={lon:center.lon,lat:center.lat};var to={lon:lonlat.lon,lat:lonlat.lat};this.panTween.start(from,to,50,{callbacks:{start:OpenLayers.Function.bind(function(lonlat){this.events.triggerEvent("movestart");},this),eachStep:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'dragging':true,'noEvent':true});},this),done:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'noEvent':true});this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange,'caller':'setCenter'});},moveTo:function(lonlat,zoom,options){if(!options){options={};}
+var dragging=options.dragging;var forceZoomChange=options.forceZoomChange;var noEvent=options.noEvent;if(this.panTween&&options.caller=="setCenter"){this.panTween.stop();}
+if(!this.center&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();}
+if(this.restrictedExtent!=null){if(lonlat==null){lonlat=this.getCenter();}
+if(zoom==null){zoom=this.getZoom();}
+var resolution=this.getResolutionForZoom(zoom);var extent=this.calculateBounds(lonlat,resolution);if(!this.restrictedExtent.containsBounds(extent)){var maxCenter=this.restrictedExtent.getCenterLonLat();if(extent.getWidth()>this.restrictedExtent.getWidth()){lonlat=new OpenLayers.LonLat(maxCenter.lon,lonlat.lat);}else if(extent.left<this.restrictedExtent.left){lonlat=lonlat.add(this.restrictedExtent.left-
+extent.left,0);}else if(extent.right>this.restrictedExtent.right){lonlat=lonlat.add(this.restrictedExtent.right-
+extent.right,0);}
+if(extent.getHeight()>this.restrictedExtent.getHeight()){lonlat=new OpenLayers.LonLat(lonlat.lon,maxCenter.lat);}else if(extent.bottom<this.restrictedExtent.bottom){lonlat=lonlat.add(0,this.restrictedExtent.bottom-
+extent.bottom);}
+else if(extent.top>this.restrictedExtent.top){lonlat=lonlat.add(0,this.restrictedExtent.top-
+extent.top);}}}
+var zoomChanged=forceZoomChange||((this.isValidZoomLevel(zoom))&&(zoom!=this.getZoom()));var centerChanged=(this.isValidLonLat(lonlat))&&(!lonlat.equals(this.center));if(zoomChanged||centerChanged||!dragging){if(!this.dragging&&!noEvent){this.events.triggerEvent("movestart");}
+if(centerChanged){if((!zoomChanged)&&(this.center)){this.centerLayerContainer(lonlat);}
+this.center=lonlat.clone();}
+if((zoomChanged)||(this.layerContainerOrigin==null)){this.layerContainerOrigin=this.center.clone();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";}
+if(zoomChanged){this.zoom=zoom;this.resolution=this.getResolutionForZoom(zoom);this.viewRequestID++;}
+var bounds=this.getExtent();this.baseLayer.moveTo(bounds,zoomChanged,dragging);bounds=this.baseLayer.getExtent();for(var i=0;i<this.layers.length;i++){var layer=this.layers[i];if(!layer.isBaseLayer){var inRange=layer.calculateInRange();if(layer.inRange!=inRange){layer.inRange=inRange;if(!inRange){layer.display(false);}
+this.events.triggerEvent("changelayer",{layer:layer,property:"visibility"});}
+if(inRange&&layer.visibility){layer.moveTo(bounds,zoomChanged,dragging);}}}
+if(zoomChanged){for(var i=0;i<this.popups.length;i++){this.popups[i].updatePosition();}}
+this.events.triggerEvent("move");if(zoomChanged){this.events.triggerEvent("zoomend");}}
+if(!dragging&&!noEvent){this.events.triggerEvent("moveend");}
+this.dragging=!!dragging;},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){this.layerContainerDiv.style.left=Math.round(originPx.x-newPx.x)+"px";this.layerContainerDiv.style.top=Math.round(originPx.y-newPx.y)+"px";}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=0)&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();valid=maxExtent.containsLonLat(lonlat);}
+return valid;},getProjection:function(){var projection=this.getProjectionObject();return projection?projection.getCode():null;},getProjectionObject:function(){var projection=null;if(this.baseLayer!=null){projection=this.baseLayer.projection;}
+return projection;},getMaxResolution:function(){var maxResolution=null;if(this.baseLayer!=null){maxResolution=this.baseLayer.maxResolution;}
+return maxResolution;},getMaxExtent:function(){var maxExtent=null;if(this.baseLayer!=null){maxExtent=this.baseLayer.maxExtent;}
+return maxExtent;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
+return numZoomLevels;},getExtent:function(){var extent=null;if(this.baseLayer!=null){extent=this.baseLayer.getExtent();}
+return extent;},getResolution:function(){var resolution=null;if(this.baseLayer!=null){resolution=this.baseLayer.getResolution();}
+return resolution;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
+return scale;},getZoomForExtent:function(bounds,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForExtent(bounds,closest);}
+return zoom;},getResolutionForZoom:function(zoom){var resolution=null;if(this.baseLayer){resolution=this.baseLayer.getResolutionForZoom(zoom);}
+return resolution;},getZoomForResolution:function(resolution,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForResolution(resolution,closest);}
+return zoom;},zoomTo:function(zoom){if(this.isValidZoomLevel(zoom)){this.setCenter(null,zoom);}},zoomIn:function(){this.zoomTo(this.getZoom()+1);},zoomOut:function(){this.zoomTo(this.getZoom()-1);},zoomToExtent:function(bounds){var center=bounds.getCenterLonLat();if(this.baseLayer.wrapDateLine){var maxExtent=this.getMaxExtent();bounds=bounds.clone();while(bounds.right<bounds.left){bounds.right+=maxExtent.getWidth();}
+center=bounds.getCenterLonLat().wrapDateLine(maxExtent);}
+this.setCenter(center,this.getZoomForExtent(bounds));},zoomToMaxExtent:function(){this.zoomToExtent(this.getMaxExtent());},zoomToScale:function(scale){var res=OpenLayers.Util.getResolutionFromScale(scale,this.baseLayer.units);var size=this.getSize();var w_deg=size.w*res;var h_deg=size.h*res;var center=this.getCenter();var extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);this.zoomToExtent(extent);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(this.baseLayer!=null){lonlat=this.baseLayer.getLonLatFromViewPortPx(viewPortPx);}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(this.baseLayer!=null){px=this.baseLayer.getViewPortPxFromLonLat(lonlat);}
+return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
+return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
+return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Marker=OpenLayers.Class({icon:null,lonlat:null,events:null,map:null,initialize:function(lonlat,icon){this.lonlat=lonlat;var newIcon=(icon)?icon:OpenLayers.Marker.defaultIcon();if(this.icon==null){this.icon=newIcon;}else{this.icon.url=newIcon.url;this.icon.size=newIcon.size;this.icon.offset=newIcon.offset;this.icon.calculateOffset=newIcon.calculateOffset;}
+this.events=new OpenLayers.Events(this,this.icon.imageDiv,null);},destroy:function(){this.map=null;this.events.destroy();this.events=null;if(this.icon!=null){this.icon.destroy();this.icon=null;}},draw:function(px){return this.icon.draw(px);},moveTo:function(px){if((px!=null)&&(this.icon!=null)){this.icon.moveTo(px);}
+this.lonlat=this.map.getLonLatFromLayerPx(px);},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
+return onScreen;},inflate:function(inflate){if(this.icon){var newSize=new OpenLayers.Size(this.icon.size.w*inflate,this.icon.size.h*inflate);this.icon.setSize(newSize);}},setOpacity:function(opacity){this.icon.setOpacity(opacity);},setUrl:function(url){this.icon.setUrl(url);},display:function(display){this.icon.display(display);},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var url=OpenLayers.Util.getImagesLocation()+"marker.png";var size=new OpenLayers.Size(21,25);var calculateOffset=function(size){return new OpenLayers.Pixel(-(size.w/2),-size.h);};return new OpenLayers.Icon(url,size,null,calculateOffset);};OpenLayers.Popup.AnchoredBubble=OpenLayers.Class(OpenLayers.Popup.Anchored,{rounded:false,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){this.padding=new OpenLayers.Bounds(0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE,0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE);OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);},draw:function(px){OpenLayers.Popup.Anchored.prototype.draw.apply(this,arguments);this.setContentHTML();this.setBackgroundColor();this.setOpacity();return this.div;},updateRelativePosition:function(){this.setRicoCorners();},setSize:function(size){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.setRicoCorners();},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
+if(this.div!=null){if(this.contentDiv!=null){this.div.style.background="transparent";OpenLayers.Rico.Corner.changeColor(this.groupDiv,this.backgroundColor);}}},setOpacity:function(opacity){OpenLayers.Popup.Anchored.prototype.setOpacity.call(this,opacity);if(this.div!=null){if(this.groupDiv!=null){OpenLayers.Rico.Corner.changeOpacity(this.groupDiv,this.opacity);}}},setBorder:function(border){this.border=0;},setRicoCorners:function(){var corners=this.getCornersToRound(this.relativePosition);var options={corners:corners,color:this.backgroundColor,bgColor:"transparent",blend:false};if(!this.rounded){OpenLayers.Rico.Corner.round(this.div,options);this.rounded=true;}else{OpenLayers.Rico.Corner.reRound(this.groupDiv,options);this.setBackgroundColor();this.setOpacity();}},getCornersToRound:function(){var corners=['tl','tr','bl','br'];var corner=OpenLayers.Bounds.oppositeQuadrant(this.relativePosition);OpenLayers.Util.removeItem(corners,corner);return corners.join(" ");},CLASS_NAME:"OpenLayers.Popup.AnchoredBubble"});OpenLayers.Popup.AnchoredBubble.CORNER_SIZE=5;OpenLayers.Popup.Framed=OpenLayers.Class(OpenLayers.Popup.Anchored,{imageSrc:null,imageSize:null,isAlphaImage:false,positionBlocks:null,blocks:null,fixedRelativePosition:false,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);if(this.fixedRelativePosition){this.updateRelativePosition();this.calculateRelativePosition=function(px){return this.relativePosition;};}
+this.contentDiv.style.position="absolute";this.contentDiv.style.zIndex=1;if(closeBox){this.closeDiv.style.zIndex=1;}
+this.groupDiv.style.position="absolute";this.groupDiv.style.top="0px";this.groupDiv.style.left="0px";this.groupDiv.style.height="100%";this.groupDiv.style.width="100%";},destroy:function(){this.imageSrc=null;this.imageSize=null;this.isAlphaImage=null;this.fixedRelativePosition=false;this.positionBlocks=null;for(var i=0;i<this.blocks.length;i++){var block=this.blocks[i];if(block.image){block.div.removeChild(block.image);}
+block.image=null;if(block.div){this.groupDiv.removeChild(block.div);}
+block.div=null;}
+this.blocks=null;OpenLayers.Popup.Anchored.prototype.destroy.apply(this,arguments);},setBackgroundColor:function(color){},setBorder:function(){},setOpacity:function(opacity){},setSize:function(size){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.updateBlocks();},updateRelativePosition:function(){this.padding=this.positionBlocks[this.relativePosition].padding;if(this.closeDiv){var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+
+this.padding.right+"px";this.closeDiv.style.top=contentDivPadding.top+
+this.padding.top+"px";}
+this.updateBlocks();},calculateNewPx:function(px){var newPx=OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(this,arguments);newPx=newPx.offset(this.positionBlocks[this.relativePosition].offset);return newPx;},createBlocks:function(){this.blocks=[];var firstPosition=null;for(var key in this.positionBlocks){firstPosition=key;break;}
+var position=this.positionBlocks[firstPosition];for(var i=0;i<position.blocks.length;i++){var block={};this.blocks.push(block);var divId=this.id+'_FrameDecorationDiv_'+i;block.div=OpenLayers.Util.createDiv(divId,null,null,null,"absolute",null,"hidden",null);var imgId=this.id+'_FrameDecorationImg_'+i;var imageCreator=(this.isAlphaImage)?OpenLayers.Util.createAlphaImageDiv:OpenLayers.Util.createImage;block.image=imageCreator(imgId,null,this.imageSize,this.imageSrc,"absolute",null,null,null);block.div.appendChild(block.image);this.groupDiv.appendChild(block.div);}},updateBlocks:function(){if(!this.blocks){this.createBlocks();}
+if(this.relativePosition){var position=this.positionBlocks[this.relativePosition];for(var i=0;i<position.blocks.length;i++){var positionBlock=position.blocks[i];var block=this.blocks[i];var l=positionBlock.anchor.left;var b=positionBlock.anchor.bottom;var r=positionBlock.anchor.right;var t=positionBlock.anchor.top;var w=(isNaN(positionBlock.size.w))?this.size.w-(r+l):positionBlock.size.w;var h=(isNaN(positionBlock.size.h))?this.size.h-(b+t):positionBlock.size.h;block.div.style.width=w+'px';block.div.style.height=h+'px';block.div.style.left=(l!=null)?l+'px':'';block.div.style.bottom=(b!=null)?b+'px':'';block.div.style.right=(r!=null)?r+'px':'';block.div.style.top=(t!=null)?t+'px':'';block.image.style.left=positionBlock.position.x+'px';block.image.style.top=positionBlock.position.y+'px';}
+this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px";}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",MAX_PIXEL:15000,localResolution:null,initialize:function(containerID){if(!this.supported()){return;}
+OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y){return(x>=-this.MAX_PIXEL&&x<=this.MAX_PIXEL&&y>=-this.MAX_PIXEL&&y<=this.MAX_PIXEL);},setExtent:function(extent){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();if(!this.localResolution||resolution!=this.localResolution){this.left=-extent.left/resolution;this.top=extent.top/resolution;}
+var left=0;var top=0;if(this.localResolution&&resolution==this.localResolution){left=(this.left)-(-extent.left/resolution);top=(this.top)-(extent.top/resolution);}
+this.localResolution=resolution;var extentString=left+" "+top+" "+
+extent.getWidth()/resolution+" "+extent.getHeight()/resolution;this.rendererRoot.setAttributeNS(null,"viewBox",extentString);},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);this.rendererRoot.setAttributeNS(null,"height",this.size.h);},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":nodeType=style.externalGraphic?"image":"circle";break;case"OpenLayers.Geometry.Rectangle":nodeType="rect";break;case"OpenLayers.Geometry.LineString":nodeType="polyline";break;case"OpenLayers.Geometry.LinearRing":nodeType="polygon";break;case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="path";break;default:break;}
+return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var r=parseFloat(node.getAttributeNS(null,"r"));if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){if(style.externalGraphic){var x=parseFloat(node.getAttributeNS(null,"cx"));var y=parseFloat(node.getAttributeNS(null,"cy"));if(style.graphicWidth&&style.graphicHeight){node.setAttributeNS(null,"preserveAspectRatio","none");}
+var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;node.setAttributeNS(null,"x",(x+xOffset).toFixed());node.setAttributeNS(null,"y",(y+yOffset).toFixed());node.setAttributeNS(null,"width",width);node.setAttributeNS(null,"height",height);node.setAttributeNS("http://www.w3.org/1999/xlink","href",style.externalGraphic);node.setAttributeNS(null,"style","opacity: "+opacity);}else{node.setAttributeNS(null,"r",style.pointRadius);}}
+if(options.isFilled){node.setAttributeNS(null,"fill",style.fillColor);node.setAttributeNS(null,"fill-opacity",style.fillOpacity);}else{node.setAttributeNS(null,"fill","none");}
+if(options.isStroked){node.setAttributeNS(null,"stroke",style.strokeColor);node.setAttributeNS(null,"stroke-opacity",style.strokeOpacity);node.setAttributeNS(null,"stroke-width",style.strokeWidth);node.setAttributeNS(null,"stroke-linecap",style.strokeLinecap);}else{node.setAttributeNS(null,"stroke","none");}
+if(style.pointerEvents){node.setAttributeNS(null,"pointer-events",style.pointerEvents);}
+if(style.cursor!=null){node.setAttributeNS(null,"cursor",style.cursor);}
+return node;},createNode:function(type,id){var node=document.createElementNS(this.xmlns,type);if(id){node.setAttributeNS(null,"id",id);}
+return node;},nodeTypeCompare:function(node,type){return(type==node.nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_svgRoot","svg");},createRoot:function(){return this.nodeFactory(this.container.id+"_root","g");},drawPoint:function(node,geometry){this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"cx",x);node.setAttributeNS(null,"cy",y);node.setAttributeNS(null,"r",radius);}else{node.setAttributeNS(null,"cx","");node.setAttributeNS(null,"cy","");node.setAttributeNS(null,"r",0);}},drawLineString:function(node,geometry){node.setAttributeNS(null,"points",this.getComponentsString(geometry.components));},drawLinearRing:function(node,geometry){node.setAttributeNS(null,"points",this.getComponentsString(geometry.components));},drawPolygon:function(node,geometry){var d="";var draw=true;for(var j=0;j<geometry.components.length;j++){var linearRing=geometry.components[j];d+=" M";for(var i=0;i<linearRing.components.length;i++){var component=this.getShortString(linearRing.components[i]);if(component){d+=" "+component;}else{draw=false;}}}
+d+=" z";if(draw){node.setAttributeNS(null,"d",d);node.setAttributeNS(null,"fill-rule","evenodd");}else{node.setAttributeNS(null,"d","");}},drawRectangle:function(node,geometry){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"x",x);node.setAttributeNS(null,"y",y);node.setAttributeNS(null,"width",geometry.width/resolution);node.setAttributeNS(null,"height",geometry.height/resolution);}else{node.setAttributeNS(null,"x","");node.setAttributeNS(null,"y","");node.setAttributeNS(null,"width",0);node.setAttributeNS(null,"height",0);}},drawSurface:function(node,geometry){var d=null;var draw=true;for(var i=0;i<geometry.components.length;i++){if((i%3)==0&&(i/3)==0){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
+d="M "+component;}else if((i%3)==1){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
+d+=" C "+component;}else{var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
+d+=" "+component;}}
+d+=" Z";if(draw){node.setAttributeNS(null,"d",d);}else{node.setAttributeNS(null,"d","");}},getComponentsString:function(components){var strings=[];for(var i=0;i<components.length;i++){var component=this.getShortString(components[i]);if(component){strings.push(component);}}
+return strings.join(",");},getShortString:function(point){var resolution=this.getResolution();var x=(point.x/resolution+this.left);var y=(this.top-point.y/resolution);if(this.inValidRange(x,y)){return x+","+y;}else{return false;}},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.VML=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"urn:schemas-microsoft-com:vml",initialize:function(containerID){if(!this.supported()){return;}
+if(!document.namespaces.olv){document.namespaces.add("olv",this.xmlns);var style=document.createStyleSheet();style.addRule('olv\\:*',"behavior: url(#default#VML); "+"position: absolute; display: inline-block;");}
+OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){return!!(document.namespaces);},setExtent:function(extent){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var org=extent.left/resolution+" "+
+extent.top/resolution;this.root.setAttribute("coordorigin",org);var size=extent.getWidth()/resolution+" "+
+-extent.getHeight()/resolution;this.root.setAttribute("coordsize",size);},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.style.width=this.size.w;this.rendererRoot.style.height=this.size.h;this.root.style.width=this.size.w;this.root.style.height=this.size.h;},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":nodeType=style.externalGraphic?"olv:rect":"olv:oval";break;case"OpenLayers.Geometry.Rectangle":nodeType="olv:rect";break;case"OpenLayers.Geometry.LineString":case"OpenLayers.Geometry.LinearRing":case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="olv:shape";break;default:break;}
+return nodeType;},setStyle:function(node,style,options,geometry){style=style||node._style;options=options||node._options;if(node._geometryClass=="OpenLayers.Geometry.Point"){if(style.externalGraphic){var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var resolution=this.getResolution();var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);node.style.left=((geometry.x/resolution)+xOffset).toFixed();node.style.top=((geometry.y/resolution)-(yOffset+height)).toFixed();node.style.width=width;node.style.height=height;style.fillColor="none";options.isStroked=false;}else{this.drawCircle(node,geometry,style.pointRadius);}}
+if(options.isFilled){node.setAttribute("fillcolor",style.fillColor);}else{node.setAttribute("filled","false");}
+var fills=node.getElementsByTagName("fill");var fill=(fills.length==0)?null:fills[0];if(!options.isFilled){if(fill){node.removeChild(fill);}}else{if(!fill){fill=this.createNode('olv:fill',node.id+"_fill");}
+fill.setAttribute("opacity",style.fillOpacity);if(node._geometryClass=="OpenLayers.Geometry.Point"&&style.externalGraphic){if(style.graphicOpacity){fill.setAttribute("opacity",style.graphicOpacity);}
+fill.setAttribute("src",style.externalGraphic);fill.setAttribute("type","frame");node.style.flip="y";if(!(style.graphicWidth&&style.graphicHeight)){fill.aspect="atmost";}}
+if(fill.parentNode!=node){node.appendChild(fill);}}
+if(options.isStroked){node.setAttribute("strokecolor",style.strokeColor);node.setAttribute("strokeweight",style.strokeWidth+"px");}else{node.setAttribute("stroked","false");}
+var strokes=node.getElementsByTagName("stroke");var stroke=(strokes.length==0)?null:strokes[0];if(!options.isStroked){if(stroke){node.removeChild(stroke);}}else{if(!stroke){stroke=this.createNode('olv:stroke',node.id+"_stroke");node.appendChild(stroke);}
+stroke.setAttribute("opacity",style.strokeOpacity);stroke.setAttribute("endcap",!style.strokeLinecap||style.strokeLinecap=='butt'?'flat':style.strokeLinecap);}
+if(style.cursor!=null){node.style.cursor=style.cursor;}
+return node;},postDraw:function(node){var fillColor=node._style.fillColor;var strokeColor=node._style.strokeColor;if(fillColor=="none"&&node.getAttribute("fillcolor")!=fillColor){node.setAttribute("fillcolor",fillColor);}
+if(strokeColor=="none"&&node.getAttribute("strokecolor")!=strokeColor){node.setAttribute("strokecolor",strokeColor);}},setNodeDimension:function(node,geometry){var bbox=geometry.getBounds();if(bbox){var resolution=this.getResolution();var scaledBox=new OpenLayers.Bounds((bbox.left/resolution).toFixed(),(bbox.bottom/resolution).toFixed(),(bbox.right/resolution).toFixed(),(bbox.top/resolution).toFixed());node.style.left=scaledBox.left;node.style.top=scaledBox.top;node.style.width=scaledBox.getWidth();node.style.height=scaledBox.getHeight();node.coordorigin=scaledBox.left+" "+scaledBox.top;node.coordsize=scaledBox.getWidth()+" "+scaledBox.getHeight();}},createNode:function(type,id){var node=document.createElement(type);if(id){node.setAttribute('id',id);}
+node.setAttribute('unselectable','on',0);node.onselectstart=function(){return(false);};return node;},nodeTypeCompare:function(node,type){var subType=type;var splitIndex=subType.indexOf(":");if(splitIndex!=-1){subType=subType.substr(splitIndex+1);}
+var nodeName=node.nodeName;splitIndex=nodeName.indexOf(":");if(splitIndex!=-1){nodeName=nodeName.substr(splitIndex+1);}
+return(subType==nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_vmlRoot","div");},createRoot:function(){return this.nodeFactory(this.container.id+"_root","olv:group");},drawPoint:function(node,geometry){this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){if(!isNaN(geometry.x)&&!isNaN(geometry.y)){var resolution=this.getResolution();node.style.left=(geometry.x/resolution).toFixed()-radius;node.style.top=(geometry.y/resolution).toFixed()-radius;var diameter=radius*2;node.style.width=diameter;node.style.height=diameter;}},drawLineString:function(node,geometry){this.drawLine(node,geometry,false);},drawLinearRing:function(node,geometry){this.drawLine(node,geometry,true);},drawLine:function(node,geometry,closeLine){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var numComponents=geometry.components.length;var parts=new Array(numComponents);var comp,x,y;for(var i=0;i<numComponents;i++){comp=geometry.components[i];x=(comp.x/resolution);y=(comp.y/resolution);parts[i]=" "+x.toFixed()+","+y.toFixed()+" l ";}
+var end=(closeLine)?" x e":" e";node.path="m"+parts.join("")+end;},drawPolygon:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var linearRing,i,comp,x,y;for(var j=0;j<geometry.components.length;j++){linearRing=geometry.components[j];path.push("m");for(i=0;i<linearRing.components.length;i++){comp=linearRing.components[i];x=comp.x/resolution;y=comp.y/resolution;path.push(" "+x.toFixed()+","+y.toFixed());if(i==0){path.push(" l");}}
+path.push(" x ");}
+path.push("e");node.path=path.join("");},drawRectangle:function(node,geometry){var resolution=this.getResolution();node.style.left=geometry.x/resolution;node.style.top=geometry.y/resolution;node.style.width=geometry.width/resolution;node.style.height=geometry.height/resolution;},drawSurface:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var comp,x,y;for(var i=0;i<geometry.components.length;i++){comp=geometry.components[i];x=comp.x/resolution;y=comp.y/resolution;if((i%3)==0&&(i/3)==0){path.push("m");}else if((i%3)==1){path.push(" c");}
+path.push(" "+x+","+y);}
+path.push(" x e");node.path=path.join("");},CLASS_NAME:"OpenLayers.Renderer.VML"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.frame=document.createElement('div');this.frame.style.overflow='hidden';this.frame.style.position='absolute';this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();},destroy:function(){if(this.imgDiv!=null){if(this.layerAlphaHack){OpenLayers.Event.stopObservingElement(this.imgDiv.childNodes[0].id);}else{OpenLayers.Event.stopObservingElement(this.imgDiv.id);}
+if(this.imgDiv.parentNode==this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv.map=null;}}
+this.imgDiv=null;if((this.frame!=null)&&(this.frame.parentNode==this.layer.div)){this.layer.div.removeChild(this.frame);}
+this.frame=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile.Image(this.layer,this.position,this.bounds,this.url,this.size);}
+obj=OpenLayers.Tile.prototype.clone.apply(this,[obj]);obj.imgDiv=null;return obj;},draw:function(){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject){this.bounds=this.getBoundsFromBaseLayer(this.position);}
+if(!OpenLayers.Tile.prototype.draw.apply(this,arguments)){return false;}
+if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
+return this.renderTile();},renderTile:function(){if(this.imgDiv==null){this.initImgDiv();}
+this.imgDiv.viewRequestID=this.layer.map.viewRequestID;this.url=this.layer.getURL(this.bounds);OpenLayers.Util.modifyDOMElement(this.frame,null,this.position,this.size);var imageSize=this.layer.getImageSize();if(this.layerAlphaHack){OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,null,null,imageSize,this.url);}else{OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,imageSize);this.imgDiv.src=this.url;}
+return true;},clear:function(){if(this.imgDiv){this.hide();if(OpenLayers.Tile.Image.useBlankTile){this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif";}}},initImgDiv:function(){var offset=this.layer.imageOffset;var size=this.layer.getImageSize();if(this.layerAlphaHack){this.imgDiv=OpenLayers.Util.createAlphaImageDiv(null,offset,size,null,"relative",null,null,null,true);}else{this.imgDiv=OpenLayers.Util.createImage(null,offset,size,null,"relative",null,null,true);}
+this.imgDiv.className='olTileImage';this.frame.style.zIndex=this.isBackBuffer?0:1;this.frame.appendChild(this.imgDiv);this.layer.div.appendChild(this.frame);if(this.layer.opacity!=null){OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,null,null,null,null,this.layer.opacity);}
+this.imgDiv.map=this.layer.map;var onload=function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};if(this.layerAlphaHack){OpenLayers.Event.observe(this.imgDiv.childNodes[0],'load',OpenLayers.Function.bind(onload,this));}else{OpenLayers.Event.observe(this.imgDiv,'load',OpenLayers.Function.bind(onload,this));}
+var onerror=function(){if(this.imgDiv._attempts>OpenLayers.IMAGE_RELOAD_ATTEMPTS){onload.call(this);}};OpenLayers.Event.observe(this.imgDiv,"error",OpenLayers.Function.bind(onerror,this));},checkImgURL:function(){if(this.layer){var loaded=this.layerAlphaHack?this.imgDiv.firstChild.src:this.imgDiv.src;if(!OpenLayers.Util.isEquivalentUrl(loaded,this.url)){this.hide();}}},startTransition:function(){if(!this.backBufferTile||!this.backBufferTile.imgDiv){return;}
+var ratio=1;if(this.backBufferTile.resolution){ratio=this.backBufferTile.resolution/this.layer.getResolution();}
+if(ratio!=this.lastRatio){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
+OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}
+this.lastRatio=ratio;},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(navigator.userAgent.toLowerCase().indexOf("gecko")!=-1){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.Util.getBrowserName()=="safari"||OpenLayers.Util.getBrowserName()=="opera");OpenLayers.Tile.WFS=OpenLayers.Class(OpenLayers.Tile,{features:null,url:null,request:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.features=[];},destroy:function(){OpenLayers.Tile.prototype.destroy.apply(this,arguments);this.destroyAllFeatures();this.features=null;this.url=null;if(this.request){this.request.abort();this.request=null;}},clear:function(){this.destroyAllFeatures();},draw:function(){if(OpenLayers.Tile.prototype.draw.apply(this,arguments)){if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
+this.loadFeaturesForRegion(this.requestSuccess);}},loadFeaturesForRegion:function(success,failure){if(this.request){this.request.abort();}
+this.request=OpenLayers.loadURL(this.url,null,this,success);},requestSuccess:function(request){if(this.features){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=OpenLayers.Format.XML.prototype.read(request.responseText);}
+if(this.layer.vectorMode){this.layer.addFeatures(this.layer.formatObject.read(doc));}else{var resultFeatures=OpenLayers.Ajax.getElementsByTagNameNS(doc,"http://www.opengis.net/gml","gml","featureMember");this.addResults(resultFeatures);}}
+if(this.events){this.events.triggerEvent("loadend");}
+this.request=null;},addResults:function(results){for(var i=0;i<results.length;i++){var feature=new this.layer.featureClass(this.layer,results[i]);this.features.push(feature);}},destroyAllFeatures:function(){while(this.features.length>0){var feature=this.features.shift();feature.destroy();}},CLASS_NAME:"OpenLayers.Tile.WFS"});OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,handlers:null,initialize:function(options){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){if(!this.mapDiv){return;}
+this.handlers.click.destroy();this.mapDiv.removeChild(this.extentRectangle);this.extentRectangle=null;this.rectEvents.destroy();this.rectEvents=null;this.ovmap.destroy();this.ovmap=null;this.element.removeChild(this.mapDiv);this.mapDiv=null;this.div.removeChild(this.element);this.element=null;if(this.maximizeDiv){OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.div.removeChild(this.maximizeDiv);this.maximizeDiv=null;}
+if(this.minimizeDiv){OpenLayers.Event.stopObservingElement(this.minimizeDiv);this.div.removeChild(this.minimizeDiv);this.minimizeDiv=null;}
+this.map.events.un({"moveend":this.update,"changebaselayer":this.baseLayerDraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!(this.layers.length>0)){if(this.map.baseLayer){var layer=this.map.baseLayer.clone();this.layers=[layer];}else{this.map.events.register("changebaselayer",this,this.baseLayerDraw);return this.div;}}
+this.element=document.createElement('div');this.element.className=this.displayClass+'Element';this.element.style.display='none';this.mapDiv=document.createElement('div');this.mapDiv.style.width=this.size.w+'px';this.mapDiv.style.height=this.size.h+'px';this.mapDiv.style.position='relative';this.mapDiv.style.overflow='hidden';this.mapDiv.id=OpenLayers.Util.createUniqueID('overviewMap');this.extentRectangle=document.createElement('div');this.extentRectangle.style.position='absolute';this.extentRectangle.style.zIndex=1000;this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.mapDiv.appendChild(this.extentRectangle);this.element.appendChild(this.mapDiv);this.div.appendChild(this.element);if(!this.outsideViewport){this.div.className+=" "+this.displayClass+'Container';var imgLocation=OpenLayers.Util.getImagesLocation();var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv(this.displayClass+'MaximizeButton',null,new OpenLayers.Size(18,18),img,'absolute');this.maximizeDiv.style.display='none';this.maximizeDiv.className=this.displayClass+'MaximizeButton';OpenLayers.Event.observe(this.maximizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv('OpenLayers_Control_minimizeDiv',null,new OpenLayers.Size(18,18),img,'absolute');this.minimizeDiv.style.display='none';this.minimizeDiv.className=this.displayClass+'MinimizeButton';OpenLayers.Event.observe(this.minimizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);var eventsToStop=['dblclick','mousedown'];for(var i=0;i<eventsToStop.length;i++){OpenLayers.Event.observe(this.maximizeDiv,eventsToStop[i],OpenLayers.Event.stop);OpenLayers.Event.observe(this.minimizeDiv,eventsToStop[i],OpenLayers.Event.stop);}
+this.minimizeControl();}else{this.element.style.display='';}
+if(this.map.getExtent()){this.update();}
+this.map.events.register('moveend',this,this.update);return this.div;},baseLayerDraw:function(){this.draw();this.map.events.unregister("changebaselayer",this,this.baseLayerDraw);},rectDrag:function(px){var deltaX=this.handlers.drag.last.x-px.x;var deltaY=this.handlers.drag.last.y-px.y;if(deltaX!=0||deltaY!=0){var rectTop=this.rectPxBounds.top;var rectLeft=this.rectPxBounds.left;var rectHeight=Math.abs(this.rectPxBounds.getHeight());var rectWidth=this.rectPxBounds.getWidth();var newTop=Math.max(0,(rectTop-deltaY));newTop=Math.min(newTop,this.ovmap.size.h-this.hComp-rectHeight);var newLeft=Math.max(0,(rectLeft-deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-this.wComp-rectWidth);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+rectHeight,newLeft+rectWidth,newTop));}},mapDivClick:function(evt){var pxCenter=this.rectPxBounds.getCenterPixel();var deltaX=evt.xy.x-pxCenter.x;var deltaY=evt.xy.y-pxCenter.y;var top=this.rectPxBounds.top;var left=this.rectPxBounds.left;var height=Math.abs(this.rectPxBounds.getHeight());var width=this.rectPxBounds.getWidth();var newTop=Math.max(0,(top+deltaY));newTop=Math.min(newTop,this.ovmap.size.h-height);var newLeft=Math.max(0,(left+deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-width);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+height,newLeft+width,newTop));this.updateMapToRect();},maximizeControl:function(e){this.element.style.display='';this.showToggle(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.element.style.display='none';this.showToggle(true);if(e!=null){OpenLayers.Event.stop(e);}},showToggle:function(minimize){this.maximizeDiv.style.display=minimize?'':'none';this.minimizeDiv.style.display=minimize?'none':'';},update:function(){if(this.ovmap==null){this.createMap();}
+if(!this.isSuitableOverview()){this.updateOverview();}
+this.updateRectToMap();},isSuitableOverview:function(){var mapExtent=this.map.getExtent();var maxExtent=this.map.maxExtent;var testExtent=new OpenLayers.Bounds(Math.max(mapExtent.left,maxExtent.left),Math.max(mapExtent.bottom,maxExtent.bottom),Math.min(mapExtent.right,maxExtent.right),Math.min(mapExtent.top,maxExtent.top));var resRatio=this.ovmap.getResolution()/this.map.getResolution();return((resRatio>this.minRatio)&&(resRatio<=this.maxRatio)&&(this.ovmap.getExtent().containsBounds(testExtent)));},updateOverview:function(){var mapRes=this.map.getResolution();var targetRes=this.ovmap.getResolution();var resRatio=targetRes/mapRes;if(resRatio>this.maxRatio){targetRes=this.minRatio*mapRes;}else if(resRatio<=this.minRatio){targetRes=this.maxRatio*mapRes;}
+this.ovmap.setCenter(this.map.center,this.ovmap.getZoomForResolution(targetRes));this.updateRectToMap();},createMap:function(){var options=OpenLayers.Util.extend({controls:[],maxResolution:'auto',fallThrough:false},this.mapOptions);this.ovmap=new OpenLayers.Map(this.mapDiv,options);OpenLayers.Event.stopObserving(window,'unload',this.ovmap.unloadDestroy);this.ovmap.addLayers(this.layers);this.ovmap.zoomToMaxExtent();this.wComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-left-width'))+
+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-right-width'));this.wComp=(this.wComp)?this.wComp:2;this.hComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-top-width'))+
+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-bottom-width'));this.hComp=(this.hComp)?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{"click":this.mapDivClick},{"single":true,"double":false,"stopSingle":true,"stopDouble":true,"pixelTolerance":1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,true);this.rectEvents.register("mouseover",this,function(e){if(!this.handlers.drag.active&&!this.map.dragging){this.handlers.drag.activate();}});this.rectEvents.register("mouseout",this,function(e){if(!this.handlers.drag.dragging){this.handlers.drag.deactivate();}});},updateRectToMap:function(){if(this.map.units!='degrees'){if(this.ovmap.getProjection()&&(this.map.getProjection()!=this.ovmap.getProjection())){alert(OpenLayers.i18n("sameProjection"));}}
+var pxBounds=this.getRectBoundsFromMapBounds(this.map.getExtent());if(pxBounds){this.setRectPxBounds(pxBounds);}},updateMapToRect:function(){var lonLatBounds=this.getMapBoundsFromRectBounds(this.rectPxBounds);this.map.panTo(lonLatBounds.getCenterLonLat());},setRectPxBounds:function(pxBounds){var top=Math.max(pxBounds.top,0);var left=Math.max(pxBounds.left,0);var bottom=Math.min(pxBounds.top+Math.abs(pxBounds.getHeight()),this.ovmap.size.h-this.hComp);var right=Math.min(pxBounds.left+pxBounds.getWidth(),this.ovmap.size.w-this.wComp);var width=Math.max(right-left,0);var height=Math.max(bottom-top,0);if(width<this.minRectSize||height<this.minRectSize){this.extentRectangle.className=this.displayClass+
+this.minRectDisplayClass;var rLeft=left+(width/2)-(this.minRectSize/2);var rTop=top+(height/2)-(this.minRectSize/2);this.extentRectangle.style.top=Math.round(rTop)+'px';this.extentRectangle.style.left=Math.round(rLeft)+'px';this.extentRectangle.style.height=this.minRectSize+'px';this.extentRectangle.style.width=this.minRectSize+'px';}else{this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.extentRectangle.style.top=Math.round(top)+'px';this.extentRectangle.style.left=Math.round(left)+'px';this.extentRectangle.style.height=Math.round(height)+'px';this.extentRectangle.style.width=Math.round(width)+'px';}
+this.rectPxBounds=new OpenLayers.Bounds(Math.round(left),Math.round(bottom),Math.round(right),Math.round(top));},getRectBoundsFromMapBounds:function(lonLatBounds){var leftBottomLonLat=new OpenLayers.LonLat(lonLatBounds.left,lonLatBounds.bottom);var rightTopLonLat=new OpenLayers.LonLat(lonLatBounds.right,lonLatBounds.top);var leftBottomPx=this.getOverviewPxFromLonLat(leftBottomLonLat);var rightTopPx=this.getOverviewPxFromLonLat(rightTopLonLat);var bounds=null;if(leftBottomPx&&rightTopPx){bounds=new OpenLayers.Bounds(leftBottomPx.x,leftBottomPx.y,rightTopPx.x,rightTopPx.y);}
+return bounds;},getMapBoundsFromRectBounds:function(pxBounds){var leftBottomPx=new OpenLayers.Pixel(pxBounds.left,pxBounds.bottom);var rightTopPx=new OpenLayers.Pixel(pxBounds.right,pxBounds.top);var leftBottomLonLat=this.getLonLatFromOverviewPx(leftBottomPx);var rightTopLonLat=this.getLonLatFromOverviewPx(rightTopPx);return new OpenLayers.Bounds(leftBottomLonLat.lon,leftBottomLonLat.lat,rightTopLonLat.lon,rightTopLonLat.lat);},getLonLatFromOverviewPx:function(overviewMapPx){var size=this.ovmap.size;var res=this.ovmap.getResolution();var center=this.ovmap.getExtent().getCenterLonLat();var delta_x=overviewMapPx.x-(size.w/2);var delta_y=overviewMapPx.y-(size.h/2);return new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);},getOverviewPxFromLonLat:function(lonlat){var res=this.ovmap.getResolution();var extent=this.ovmap.getExtent();var px=null;if(extent){px=new OpenLayers.Pixel(Math.round(1/res*(lonlat.lon-extent.left)),Math.round(1/res*(extent.top-lonlat.lat)));}
+return px;},CLASS_NAME:'OpenLayers.Control.OverviewMap'});OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:OpenLayers.Popup.AnchoredBubble,popup:null,initialize:function(layer,lonlat,data){this.layer=layer;this.lonlat=lonlat;this.data=(data!=null)?data:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if((this.layer!=null)&&(this.layer.map!=null)){if(this.popup!=null){this.layer.map.removePopup(this.popup);}}
+this.layer=null;this.id=null;this.lonlat=null;this.data=null;if(this.marker!=null){this.destroyMarker(this.marker);this.marker=null;}
+if(this.popup!=null){this.destroyPopup(this.popup);this.popup=null;}},onScreen:function(){var onScreen=false;if((this.layer!=null)&&(this.layer.map!=null)){var screenBounds=this.layer.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
+return onScreen;},createMarker:function(){if(this.lonlat!=null){this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);}
+return this.marker;},destroyMarker:function(){this.marker.destroy();},createPopup:function(closeBox){if(this.lonlat!=null){var id=this.id+"_popup";var anchor=(this.marker)?this.marker.icon:null;if(!this.popup){this.popup=new this.popupClass(id,this.lonlat,this.data.popupSize,this.data.popupContentHTML,anchor,closeBox);}
+if(this.data.overflow!=null){this.popup.contentDiv.style.overflow=this.data.overflow;}
+this.popup.feature=this;}
+return this.popup;},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null;}},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.Format.WMC=OpenLayers.Class({defaultVersion:"1.1.0",version:null,layerOptions:null,parser:null,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
+if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.WMC["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a WMC parser for version "+
+version;}
+this.parser=new format(this.options);}
+var context=this.parser.read(data,options);var map;if(options.map){this.context=context;if(options.map instanceof OpenLayers.Map){map=this.mergeContextToMap(context,options.map);}else{map=this.contextToMap(context,options.map);}}else{map=context;}
+return map;},contextToMap:function(context,id){var map=new OpenLayers.Map(id,{maxExtent:context.maxExtent,projection:context.projection});map.addLayers(context.layers);map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(context.layers);return map;},write:function(obj,options){if(obj.CLASS_NAME=="OpenLayers.Map"){obj=this.mapToContext(obj);}
+var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.WMC["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a WMS capabilities parser for version "+
+version;}
+var wmc=this.parser.write(obj,options);return wmc;},mapToContext:function(map){var context={bounds:map.getExtent(),maxExtent:map.maxExtent,projection:map.projection,layers:map.layers,size:map.getSize()};return context;},CLASS_NAME:"OpenLayers.Format.WMC"});OpenLayers.Format.WMC.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ol:"http://openlayers.org/context",wmc:"http://www.opengis.net/context",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"",getNamespacePrefix:function(uri){var prefix=null;if(uri==null){prefix=this.namespaces[this.defaultPrefix];}else{for(prefix in this.namespaces){if(this.namespaces[prefix]==uri){break;}}}
+return prefix;},defaultPrefix:"wmc",rootPrefix:null,defaultStyleName:"",defaultStyleTitle:"Default",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;this.rootPrefix=root.prefix;var context={version:root.getAttribute("version")};this.runChildNodes(context,root);return context;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor,prefix,local;for(var i=0;i<children.length;++i){childNode=children[i];if(childNode.nodeType==1){prefix=this.getNamespacePrefix(childNode.namespaceURI);local=childNode.nodeName.split(":").pop();processor=this["read_"+prefix+"_"+local];if(processor){processor.apply(this,[obj,childNode]);}}}},read_wmc_General:function(context,node){this.runChildNodes(context,node);},read_wmc_BoundingBox:function(context,node){context.projection=node.getAttribute("SRS");context.bounds=new OpenLayers.Bounds(parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy")));},read_wmc_LayerList:function(context,node){context.layers=[];this.runChildNodes(context,node);},read_wmc_Layer:function(context,node){var layerInfo={params:{},options:{visibility:(node.getAttribute("hidden")!="1")},queryable:(node.getAttribute("queryable")=="1"),formats:[],styles:[]};this.runChildNodes(layerInfo,node);layerInfo.params.layers=layerInfo.name;layerInfo.options.maxExtent=layerInfo.maxExtent;var layer=this.getLayerFromInfo(layerInfo);context.layers.push(layer);},getLayerFromInfo:function(layerInfo){var options=layerInfo.options;if(this.layerOptions){OpenLayers.Util.applyDefaults(options,this.layerOptions);}
+var layer=new OpenLayers.Layer.WMS(layerInfo.title,layerInfo.href,layerInfo.params,options);return layer;},read_wmc_Extension:function(obj,node){this.runChildNodes(obj,node);},read_ol_units:function(layerInfo,node){layerInfo.options.units=this.getChildValue(node);},read_ol_maxExtent:function(obj,node){var bounds=new OpenLayers.Bounds(node.getAttribute("minx"),node.getAttribute("miny"),node.getAttribute("maxx"),node.getAttribute("maxy"));obj.maxExtent=bounds;},read_ol_transparent:function(layerInfo,node){layerInfo.params.transparent=this.getChildValue(node);},read_ol_numZoomLevels:function(layerInfo,node){layerInfo.options.numZoomLevels=parseInt(this.getChildValue(node));},read_ol_opacity:function(layerInfo,node){layerInfo.options.opacity=parseFloat(this.getChildValue(node));},read_ol_singleTile:function(layerInfo,node){layerInfo.options.singleTile=(this.getChildValue(node)=="true");},read_ol_isBaseLayer:function(layerInfo,node){layerInfo.options.isBaseLayer=(this.getChildValue(node)=="true");},read_ol_displayInLayerSwitcher:function(layerInfo,node){layerInfo.options.displayInLayerSwitcher=(this.getChildValue(node)=="true");},read_wmc_Server:function(layerInfo,node){layerInfo.params.version=node.getAttribute("version");this.runChildNodes(layerInfo,node);},read_wmc_FormatList:function(layerInfo,node){this.runChildNodes(layerInfo,node);},read_wmc_Format:function(layerInfo,node){var format=this.getChildValue(node);layerInfo.formats.push(format);if(node.getAttribute("current")=="1"){layerInfo.params.format=format;}},read_wmc_StyleList:function(layerInfo,node){this.runChildNodes(layerInfo,node);},read_wmc_Style:function(layerInfo,node){var style={};this.runChildNodes(style,node);if(node.getAttribute("current")=="1"){if(style.href){layerInfo.params.sld=style.href;}else if(style.body){layerInfo.params.sld_body=style.body;}else{layerInfo.params.styles=style.name;}}
+layerInfo.styles.push(style);},read_wmc_SLD:function(style,node){this.runChildNodes(style,node);},read_sld_StyledLayerDescriptor:function(sld,node){var xml=OpenLayers.Format.XML.prototype.write.apply(this,[node]);sld.body=xml;},read_wmc_OnlineResource:function(obj,node){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},read_wmc_Name:function(obj,node){var name=this.getChildValue(node);if(name){obj.name=name;}},read_wmc_Title:function(obj,node){var title=this.getChildValue(node);if(title){obj.title=title;}},read_wmc_Abstract:function(obj,node){var abst=this.getChildValue(node);if(abst){obj["abstract"]=abst;}},read_wmc_LatLonBoundingBox:function(layer,node){layer.llbbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];},read_wmc_LegendURL:function(style,node){var legend={width:node.getAttribute('width'),height:node.getAttribute('height')};var links=node.getElementsByTagName("OnlineResource");if(links.length>0){this.read_wmc_OnlineResource(legend,links[0]);}
+style.legend=legend;},write:function(context,options){var root=this.createElementDefaultNS("ViewContext");this.setAttributes(root,{version:this.VERSION,id:(options&&typeof options.id=="string")?options.id:OpenLayers.Util.createUniqueID("OpenLayers_Context_")});this.setAttributeNS(root,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);root.appendChild(this.write_wmc_General(context));root.appendChild(this.write_wmc_LayerList(context));return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},createElementDefaultNS:function(name,childValue,attributes){var node=this.createElementNS(this.namespaces[this.defaultPrefix],name);if(childValue){node.appendChild(this.createTextNode(childValue));}
+if(attributes){this.setAttributes(node,attributes);}
+return node;},setAttributes:function(node,obj){var value;for(var name in obj){value=obj[name].toString();if(value.match(/[A-Z]/)){this.setAttributeNS(node,null,name,value);}else{node.setAttribute(name,value);}}},write_wmc_General:function(context){var node=this.createElementDefaultNS("General");if(context.size){node.appendChild(this.createElementDefaultNS("Window",null,{width:context.size.w,height:context.size.h}));}
+var bounds=context.bounds;node.appendChild(this.createElementDefaultNS("BoundingBox",null,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10),SRS:context.projection}));node.appendChild(this.createElementDefaultNS("Title",context.title));node.appendChild(this.write_ol_MapExtension(context));return node;},write_ol_MapExtension:function(context){var node=this.createElementDefaultNS("Extension");var bounds=context.maxExtent;if(bounds){var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10)});node.appendChild(maxExtent);}
+return node;},write_wmc_LayerList:function(context){var list=this.createElementDefaultNS("LayerList");var layer;for(var i=0;i<context.layers.length;++i){layer=context.layers[i];if(layer instanceof OpenLayers.Layer.WMS){list.appendChild(this.write_wmc_Layer(layer));}}
+return list;},write_wmc_Layer:function(layer){var node=this.createElementDefaultNS("Layer",null,{queryable:"1",hidden:layer.visibility?"0":"1"});node.appendChild(this.write_wmc_Server(layer));node.appendChild(this.createElementDefaultNS("Name",layer.params["LAYERS"]));node.appendChild(this.createElementDefaultNS("Title",layer.name));node.appendChild(this.write_wmc_FormatList(layer));node.appendChild(this.write_wmc_StyleList(layer));node.appendChild(this.write_wmc_LayerExtension(layer));return node;},write_wmc_LayerExtension:function(layer){var node=this.createElementDefaultNS("Extension");var bounds=layer.maxExtent;var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10)});node.appendChild(maxExtent);var param=layer.params["TRANSPARENT"];if(param){var trans=this.createElementNS(this.namespaces.ol,"ol:transparent");trans.appendChild(this.createTextNode(param));node.appendChild(trans);}
+var properties=["numZoomLevels","units","isBaseLayer","opacity","displayInLayerSwitcher","singleTile"];var child;for(var i=0;i<properties.length;++i){child=this.createOLPropertyNode(layer,properties[i]);if(child){node.appendChild(child);}}
+return node;},createOLPropertyNode:function(obj,prop){var node=null;if(obj[prop]!=null){node=this.createElementNS(this.namespaces.ol,"ol:"+prop);node.appendChild(this.createTextNode(obj[prop].toString()));}
+return node;},write_wmc_Server:function(layer){var node=this.createElementDefaultNS("Server");this.setAttributes(node,{service:"OGC:WMS",version:layer.params["VERSION"]});node.appendChild(this.write_wmc_OnlineResource(layer.url));return node;},write_wmc_FormatList:function(layer){var node=this.createElementDefaultNS("FormatList");node.appendChild(this.createElementDefaultNS("Format",layer.params["FORMAT"],{current:"1"}));return node;},write_wmc_StyleList:function(layer){var node=this.createElementDefaultNS("StyleList");var style=this.createElementDefaultNS("Style",null,{current:"1"});if(layer.params["SLD"]){var sld=this.createElementDefaultNS("SLD");var link=this.write_wmc_OnlineResource(layer.params["SLD"]);sld.appendChild(link);style.appendChild(sld);}else if(layer.params["SLD_BODY"]){var sld=this.createElementDefaultNS("SLD");var body=layer.params["SLD_BODY"];var doc=OpenLayers.Format.XML.prototype.read.apply(this,[body]);var imported=doc.documentElement;if(sld.ownerDocument&&sld.ownerDocument.importNode){imported=sld.ownerDocument.importNode(imported,true);}
+sld.appendChild(imported);style.appendChild(sld);}else{var name=layer.params["STYLES"]?layer.params["STYLES"]:this.defaultStyleName;style.appendChild(this.createElementDefaultNS("Name",name));style.appendChild(this.createElementDefaultNS("Title",this.defaultStyleTitle));}
+node.appendChild(style);return node;},write_wmc_OnlineResource:function(href){var node=this.createElementDefaultNS("OnlineResource");this.setAttributeNS(node,this.namespaces.xlink,"xlink:type","simple");this.setAttributeNS(node,this.namespaces.xlink,"xlink:href",href);return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt.xy;return true;};}},mousedown:null,dblclick:function(evt){if(this.passesTolerance(evt)){if(this["double"]){this.callback('dblclick',[evt]);}
+this.clearTimer();}
+return!this.stopDouble;},click:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){this.clearTimer();}else{var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,clickEvent),this.delay);}}
+return!this.stopSingle;},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down){var dpx=Math.sqrt(Math.pow(this.down.x-evt.xy.x,2)+
+Math.pow(this.down.y-evt.xy.y,2));if(dpx>this.pixelTolerance){passes=false;}}
+return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback('click',[evt]);}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,oldOnselectstart:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},down:function(evt){},move:function(evt){},up:function(evt){},out:function(evt){},mousedown:function(evt){var propagate=true;this.dragging=false;if(this.checkModifiers(evt)&&OpenLayers.Event.isLeftClick(evt)){this.started=true;this.start=evt.xy;this.last=evt.xy;this.map.div.style.cursor="move";this.down(evt);this.callback("down",[evt.xy]);OpenLayers.Event.stop(evt);if(!this.oldOnselectstart){this.oldOnselectstart=(document.onselectstart)?document.onselectstart:function(){return true;};document.onselectstart=function(){return false;};}
+propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
+return propagate;},mousemove:function(evt){if(this.started){if(evt.xy.x!=this.last.x||evt.xy.y!=this.last.y){this.dragging=true;this.move(evt);this.callback("move",[evt.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=function(){return false;};}
+this.last=evt.xy;}}
+return true;},mouseup:function(evt){if(this.started){var dragged=(this.start!=this.last);this.started=false;this.dragging=false;this.map.div.style.cursor="";this.up(evt);this.callback("up",[evt.xy]);if(dragged){this.callback("done",[evt.xy]);}
+document.onselectstart=this.oldOnselectstart;}
+return true;},mouseout:function(evt){if(this.started&&OpenLayers.Util.mouseLeft(evt,this.map.div)){var dragged=(this.start!=this.last);this.started=false;this.dragging=false;this.map.div.style.cursor="";this.out(evt);this.callback("out",[]);if(dragged){this.callback("done",[evt.xy]);}
+if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}
+return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemove':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null}},feature:null,lastFeature:null,down:null,up:null,clickoutTolerance:4,geometryTypes:null,stopClick:true,stopDown:true,stopUp:true,layerIndex:null,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},mousedown:function(evt){this.down=evt.xy;return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){this.handle(evt);return true;},dblclick:function(evt){return!this.handle(evt);},geometryTypeMatches:function(feature){return this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1;},handle:function(evt){var type=evt.type;var handled=false;var previouslyIn=!!(this.feature);var click=(type=="click"||type=="dblclick");this.feature=this.layer.getFeatureFromEvent(evt);if(this.feature){var inNew=(this.feature!=this.lastFeature);if(this.geometryTypeMatches(this.feature)){if(previouslyIn&&inNew){this.triggerCallback(type,'out',[this.lastFeature]);this.triggerCallback(type,'in',[this.feature]);}else if(!previouslyIn||click){this.triggerCallback(type,'in',[this.feature]);}
+this.lastFeature=this.feature;handled=true;}else{if(previouslyIn&&inNew||(click&&this.lastFeature)){this.triggerCallback(type,'out',[this.lastFeature]);}
+this.feature=null;}}else{if(previouslyIn||(click&&this.lastFeature)){this.triggerCallback(type,'out',[this.lastFeature]);}}
+return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&mode=='out'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
+Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickoutTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.layerIndex=this.layer.div.style.zIndex;this.layer.div.style.zIndex=this.map.Z_INDEX_BASE['Popup']-1;activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){if(this.layer&&this.layer.div){this.layer.div.style.zIndex=this.layerIndex;}
+this.feature=null;this.lastFeature=null;this.down=null;this.up=null;deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:false,px:null,timerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},mousemove:function(evt){if(this.passesTolerance(evt.xy)){this.clearTimer();this.callback('move',[evt]);this.px=evt.xy;evt=OpenLayers.Util.extend({},evt);this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);}
+return!this.stopMove;},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.div)){this.clearTimer();this.callback('move',[evt]);}
+return true;},passesTolerance:function(px){var passes=true;if(this.pixelTolerance&&this.px){var dpx=Math.sqrt(Math.pow(this.px.x-px.x,2)+
+Math.pow(this.px.y-px.y,2));if(dpx<this.pixelTolerance){passes=false;}}
+return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},delayedCall:function(evt){this.callback('pause',[evt]);},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Hover"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keypress","keyup"],eventListener:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){for(var i=0;i<this.KEY_EVENTS.length;i++){OpenLayers.Event.observe(window,this.KEY_EVENTS[i],this.eventListener);}
+return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0;i<this.KEY_EVENTS.length;i++){OpenLayers.Event.stopObserving(window,this.KEY_EVENTS[i],this.eventListener);}
+deactivated=true;}
+return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt.charCode||evt.keyCode]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
+var overScrollableDiv=false;var overLayerDiv=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);var overflow=style.getPropertyValue("overflow");}
+overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
+if(!overLayerDiv){for(var i=0;i<this.map.layers.length;i++){if(elem==this.map.layers[i].div||elem==this.map.layers[i].pane){overLayerDiv=true;break;}}}
+overMapDiv=(elem==this.map.div);elem=elem.parentNode;}
+if(!overScrollableDiv&&overMapDiv){if(overLayerDiv){this.wheelZoom(e);}
+OpenLayers.Event.stop(e);}},wheelZoom:function(e){var delta=0;if(!e){e=window.event;}
+if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
+if(delta){if(this.mousePosition){e.xy=this.mousePosition;}
+if(!e.xy){e.xy=this.map.getPixelFromLonLat(this.map.getCenter());}
+if(delta<0){this.callback("down",[e,delta]);}else{this.callback("up",[e,delta]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged"],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
+if(this.wrapDateLine){this.displayOutsideMaxExtent=true;}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
+if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
+this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.events.destroy();}
+this.eventListeners=null;this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer(this.name,this.options);}
+OpenLayers.Util.applyDefaults(obj,this);obj.map=null;return obj;},setName:function(newName){if(newName!=this.name){this.name=newName;if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"name"});}}},addOptions:function(newOptions){if(this.options==null){this.options={};}
+OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},onMapResize:function(){},redraw:function(){var redrawn=false;if(this.map){this.inRange=this.calculateInRange();var extent=this.getExtent();if(extent&&this.inRange&&this.visibility){this.moveTo(extent,true,false);redrawn=true;}}
+return redrawn;},moveTo:function(bounds,zoomChanged,dragging){var display=this.visibility;if(!this.isBaseLayer){display=display&&this.inRange;}
+this.display(display);},setMap:function(map){if(this.map==null){this.map=map;this.maxExtent=this.maxExtent||this.map.maxExtent;this.projection=this.projection||this.map.projection;if(this.projection&&typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
+this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer){this.inRange=this.calculateInRange();var show=((this.visibility)&&(this.inRange));this.div.style.display=show?"":"none";}
+this.setTileSize();}},removeMap:function(map){},getImageSize:function(){return(this.imageSize||this.tileSize);},setTileSize:function(size){var tileSize=(size)?size:((this.tileSize)?this.tileSize:this.map.getTileSize());this.tileSize=tileSize;if(this.gutter){this.imageOffset=new OpenLayers.Pixel(-this.gutter,-this.gutter);this.imageSize=new OpenLayers.Size(tileSize.w+(2*this.gutter),tileSize.h+(2*this.gutter));}},getVisibility:function(){return this.visibility;},setVisibility:function(visibility){if(visibility!=this.visibility){this.visibility=visibility;this.display(visibility);this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});}
+this.events.triggerEvent("visibilitychanged");}},display:function(display){var inRange=this.calculateInRange();if(display!=(this.div.style.display!="none")){this.div.style.display=(display&&inRange)?"block":"none";}},calculateInRange:function(){var inRange=false;if(this.map){var resolution=this.map.getResolution();inRange=((resolution>=this.minResolution)&&(resolution<=this.maxResolution));}
+return inRange;},setIsBaseLayer:function(isBaseLayer){if(isBaseLayer!=this.isBaseLayer){this.isBaseLayer=isBaseLayer;if(this.map!=null){this.map.events.triggerEvent("changebaselayer",{layer:this});}}},initResolutions:function(){var props=new Array('projection','units','scales','resolutions','maxScale','minScale','maxResolution','minResolution','minExtent','maxExtent','numZoomLevels','maxZoomLevel');var confProps={};for(var i=0;i<props.length;i++){var property=props[i];confProps[property]=this.options[property]||this.map[property];}
+if(this.options.minScale!=null&&this.options.maxScale!=null&&this.options.scales==null){confProps.scales=null;}
+if(this.options.minResolution!=null&&this.options.maxResolution!=null&&this.options.resolutions==null){confProps.resolutions=null;}
+if((!confProps.numZoomLevels)&&(confProps.maxZoomLevel)){confProps.numZoomLevels=confProps.maxZoomLevel+1;}
+if((confProps.scales!=null)||(confProps.resolutions!=null)){if(confProps.scales!=null){confProps.resolutions=[];for(var i=0;i<confProps.scales.length;i++){var scale=confProps.scales[i];confProps.resolutions[i]=OpenLayers.Util.getResolutionFromScale(scale,confProps.units);}}
+confProps.numZoomLevels=confProps.resolutions.length;}else{if(confProps.minScale){confProps.maxResolution=OpenLayers.Util.getResolutionFromScale(confProps.minScale,confProps.units);}else if(confProps.maxResolution=="auto"){var viewSize=this.map.getSize();var wRes=confProps.maxExtent.getWidth()/viewSize.w;var hRes=confProps.maxExtent.getHeight()/viewSize.h;confProps.maxResolution=Math.max(wRes,hRes);}
+if(confProps.maxScale!=null){confProps.minResolution=OpenLayers.Util.getResolutionFromScale(confProps.maxScale,confProps.units);}else if((confProps.minResolution=="auto")&&(confProps.minExtent!=null)){var viewSize=this.map.getSize();var wRes=confProps.minExtent.getWidth()/viewSize.w;var hRes=confProps.minExtent.getHeight()/viewSize.h;confProps.minResolution=Math.max(wRes,hRes);}
+if(confProps.minResolution!=null&&this.options.numZoomLevels==undefined){var ratio=confProps.maxResolution/confProps.minResolution;confProps.numZoomLevels=Math.floor(Math.log(ratio)/Math.log(2))+1;}
+confProps.resolutions=new Array(confProps.numZoomLevels);var base=2;if(typeof confProps.minResolution=="number"&&confProps.numZoomLevels>1){base=Math.pow((confProps.maxResolution/confProps.minResolution),(1/(confProps.numZoomLevels-1)));}
+for(var i=0;i<confProps.numZoomLevels;i++){var res=confProps.maxResolution/Math.pow(base,i);confProps.resolutions[i]=res;}}
+confProps.resolutions.sort(function(a,b){return(b-a);});this.resolutions=confProps.resolutions;this.maxResolution=confProps.resolutions[0];var lastIndex=confProps.resolutions.length-1;this.minResolution=confProps.resolutions[lastIndex];this.scales=[];for(var i=0;i<confProps.resolutions.length;i++){this.scales[i]=OpenLayers.Util.getScaleFromResolution(confProps.resolutions[i],confProps.units);}
+this.minScale=this.scales[0];this.maxScale=this.scales[this.scales.length-1];this.numZoomLevels=confProps.numZoomLevels;},getResolution:function(){var zoom=this.map.getZoom();return this.getResolutionForZoom(zoom);},getExtent:function(){return this.map.calculateBounds();},getZoomForExtent:function(extent,closest){var viewSize=this.map.getSize();var idealResolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);return this.getZoomForResolution(idealResolution,closest);},getDataExtent:function(){},getResolutionForZoom:function(zoom){zoom=Math.max(0,Math.min(zoom,this.resolutions.length-1));var resolution;if(this.map.fractionalZoom){var low=Math.floor(zoom);var high=Math.ceil(zoom);resolution=this.resolutions[high]+
+((zoom-low)*(this.resolutions[low]-this.resolutions[high]));}else{resolution=this.resolutions[Math.round(zoom)];}
+return resolution;},getZoomForResolution:function(resolution,closest){var zoom;if(this.map.fractionalZoom){var lowZoom=0;var highZoom=this.resolutions.length-1;var highRes=this.resolutions[lowZoom];var lowRes=this.resolutions[highZoom];var res;for(var i=0;i<this.resolutions.length;++i){res=this.resolutions[i];if(res>=resolution){highRes=res;lowZoom=i;}
+if(res<=resolution){lowRes=res;highZoom=i;break;}}
+var dRes=highRes-lowRes;if(dRes>0){zoom=lowZoom+((resolution-lowRes)/dRes);}else{zoom=lowZoom;}}else{var diff;var minDiff=Number.POSITIVE_INFINITY;for(var i=0;i<this.resolutions.length;i++){if(closest){diff=Math.abs(this.resolutions[i]-resolution);if(diff>minDiff){break;}
+minDiff=diff;}else{if(this.resolutions[i]<resolution){break;}}}
+zoom=Math.max(0,i-1);}
+return zoom;},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(viewPortPx!=null){var size=this.map.getSize();var center=this.map.getCenter();if(center){var res=this.map.getResolution();var delta_x=viewPortPx.x-(size.w/2);var delta_y=viewPortPx.y-(size.h/2);lonlat=new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}}}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(lonlat!=null){var resolution=this.map.getResolution();var extent=this.map.getExtent();px=new OpenLayers.Pixel((1/resolution*(lonlat.lon-extent.left)),(1/resolution*(extent.top-lonlat.lat)));}
+return px;},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0;i<this.div.childNodes.length;++i){var element=this.div.childNodes[i].firstChild;OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);}}},setZIndex:function(zIndex){this.div.style.zIndex=zIndex;},adjustBounds:function(bounds){if(this.gutter){var mapGutter=this.gutter*this.map.getResolution();bounds=new OpenLayers.Bounds(bounds.left-mapGutter,bounds.bottom-mapGutter,bounds.right+mapGutter,bounds.top+mapGutter);}
+if(this.wrapDateLine){var wrappingOptions={'rightTolerance':this.getResolution()};bounds=bounds.wrapDateLine(this.maxExtent,wrappingOptions);}
+return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(bounds,borderColor,borderWidth){this.bounds=bounds;this.div=OpenLayers.Util.createDiv();this.div.style.overflow='hidden';this.events=new OpenLayers.Events(this,this.div,null);this.setBorder(borderColor,borderWidth);},destroy:function(){this.bounds=null;this.div=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments);},setBorder:function(color,width){if(!color){color="red";}
+if(!width){width=2;}
+this.div.style.border=width+"px solid "+color;},draw:function(px,sz){OpenLayers.Util.modifyDOMElement(this.div,null,px,sz);return this.div;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsBounds(this.bounds,true,true);}
+return onScreen;},display:function(display){this.div.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{autoSize:true,panMapIfOutOfView:true,imageSize:new OpenLayers.Size(676,736),isAlphaImage:false,fixedRelativePosition:false,positionBlocks:{"tl":{'offset':new OpenLayers.Pixel(44,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,32,80,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(0,-668)}]},"tr":{'offset':new OpenLayers.Pixel(-45,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(0,0,null,null),position:new OpenLayers.Pixel(-215,-668)}]},"bl":{'offset':new OpenLayers.Pixel(45,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(null,null,0,0),position:new OpenLayers.Pixel(-101,-674)}]},"br":{'offset':new OpenLayers.Pixel(-44,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(600,660),initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){this.imageSrc=OpenLayers.Util.getImagesLocation()+'cloud-popup-relative.png';OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className="olFramedCloudPopupContent";},destroy:function(){OpenLayers.Popup.Framed.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={drag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks)),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){if(!this.handlers.drag.dragging){this.feature=feature;this.handlers.drag.activate();this.over=true;this.map.div.style.cursor="move";}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}},downFeature:function(pixel){this.lastPixel=pixel;this.onStart(this.feature,pixel);},moveFeature:function(pixel){var res=this.map.getResolution();this.feature.geometry.move(res*(pixel.x-this.lastPixel.x),res*(this.lastPixel.y-pixel.y));this.layer.drawFeature(this.feature);this.lastPixel=pixel;this.onDrag(this.feature,pixel);},upFeature:function(pixel){if(!this.over){this.handlers.drag.deactivate();this.feature=null;this.map.div.style.cursor="default";}},doneDragging:function(pixel){this.onComplete(this.feature,pixel);},outFeature:function(feature){if(!this.handlers.drag.dragging){this.over=false;this.handlers.drag.deactivate();this.map.div.style.cursor="default";this.feature=null;}else{if(this.feature.id==feature.id){this.over=false;}}},cancel:function(){this.handlers.drag.deactivate();this.over=false;},setMap:function(map){this.handlers.drag.setMap(map);this.handlers.feature.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,draw:function(){this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone});},panMap:function(xy){this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:this.handler.dragging,animate:false});},panMapDone:function(xy){if(this.panned){this.panMap(xy);this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{slideFactor:75,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
+this.handler=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{"keypress":this.defaultKeyPress});this.activate();},defaultKeyPress:function(code){switch(code){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:var size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:var size=this.map.getSize();this.map.pan(0,0.75*size.h);break;case 35:var size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:var size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:this.map.zoomIn();break;case 45:this.map.zoomOut();break;case 107:this.map.zoomIn();break;case 109:this.map.zoomOut();break;}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});OpenLayers.State={UNKNOWN:'Unknown',INSERT:'Insert',UPDATE:'Update',DELETE:'Delete'};OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,state:null,style:null,renderIntent:"default",initialize:function(geometry,attributes,style){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,attributes]);this.lonlat=null;this.geometry=geometry;this.state=null;this.attributes={};if(attributes){this.attributes=OpenLayers.Util.extend(this.attributes,attributes);}
+this.style=style?style:null;},destroy:function(){if(this.layer){this.layer.removeFeatures(this);this.layer=null;}
+this.geometry=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments);},clone:function(){return new OpenLayers.Feature.Vector(this.geometry.clone(),this.attributes,this.style);},onScreen:function(boundsOnly){var onScreen=false;if(this.layer&&this.layer.map){var screenBounds=this.layer.map.getExtent();if(boundsOnly){var featureBounds=this.geometry.getBounds();onScreen=screenBounds.intersectsBounds(featureBounds);}else{var screenPoly=screenBounds.toGeometry();onScreen=screenPoly.intersects(this.geometry);}}
+return onScreen;},createMarker:function(){return null;},destroyMarker:function(){},createPopup:function(){return null;},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;if(this.geometry){atPoint=this.geometry.atPoint(lonlat,toleranceLon,toleranceLat);}
+return atPoint;},destroyPopup:function(){},toState:function(state){if(state==OpenLayers.State.UPDATE){switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=state;break;case OpenLayers.State.UPDATE:case OpenLayers.State.INSERT:break;}}else if(state==OpenLayers.State.INSERT){switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=state;break;}}else if(state==OpenLayers.State.DELETE){switch(this.state){case OpenLayers.State.INSERT:break;case OpenLayers.State.DELETE:break;case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=state;break;}}else if(state==OpenLayers.State.UNKNOWN){this.state=state;}},CLASS_NAME:"OpenLayers.Feature.Vector"});OpenLayers.Feature.Vector.style={'default':{fillColor:"#ee9900",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:""},'select':{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer"},'temporary':{fillColor:"yellow",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"yellow",strokeOpacity:1,strokeLinecap:"round",strokeWidth:4,hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:""}};OpenLayers.Feature.WFS=OpenLayers.Class(OpenLayers.Feature,{initialize:function(layer,xmlNode){var newArguments=arguments;var data=this.processXMLNode(xmlNode);newArguments=new Array(layer,data.lonlat,data);OpenLayers.Feature.prototype.initialize.apply(this,newArguments);this.createMarker();this.layer.addMarker(this.marker);},destroy:function(){if(this.marker!=null){this.layer.removeMarker(this.marker);}
+OpenLayers.Feature.prototype.destroy.apply(this,arguments);},processXMLNode:function(xmlNode){var point=OpenLayers.Ajax.getElementsByTagNameNS(xmlNode,"http://www.opengis.net/gml","gml","Point");var text=OpenLayers.Util.getXmlNodeValue(OpenLayers.Ajax.getElementsByTagNameNS(point[0],"http://www.opengis.net/gml","gml","coordinates")[0]);var floats=text.split(",");return{lonlat:new OpenLayers.LonLat(parseFloat(floats[0]),parseFloat(floats[1])),id:null};},CLASS_NAME:"OpenLayers.Feature.WFS"});OpenLayers.Format.WMC.v1_0_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.WMC.v1_0_0"});OpenLayers.Format.WMC.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},read_sld_MinScaleDenominator:function(layerInfo,node){layerInfo.options.maxScale=this.getChildValue(node);},read_sld_MaxScaleDenominator:function(layerInfo,node){layerInfo.options.minScale=this.getChildValue(node);},write_wmc_Layer:function(layer){var node=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,[layer]);if(layer.options.resolutions||layer.options.scales||layer.options.minResolution||layer.options.maxScale){var minSD=this.createElementNS(this.namespaces.sld,"sld:MinScaleDenominator");minSD.appendChild(this.createTextNode(layer.maxScale.toPrecision(10)));node.insertBefore(minSD,node.childNodes[3]);}
+if(layer.options.resolutions||layer.options.scales||layer.options.maxResolution||layer.options.minScale){var maxSD=this.createElementNS(this.namespaces.sld,"sld:MaxScaleDenominator");maxSD.appendChild(this.createTextNode(layer.minScale.toPrecision(10)));node.insertBefore(maxSD,node.childNodes[4]);}
+return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);var callbacks={"down":this.startBox,"move":this.moveBox,"out":this.removeBox,"up":this.endBox};this.dragHandler=new OpenLayers.Handler.Drag(this,callbacks,{keyMask:this.keyMask});},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.dragHandler.start);this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.map.div.style.cursor="crosshair";},moveBox:function(xy){var deltaX=Math.abs(this.dragHandler.start.x-xy.x);var deltaY=Math.abs(this.dragHandler.start.y-xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(xy.x<this.dragHandler.start.x){this.zoomBox.style.left=xy.x+"px";}
+if(xy.y<this.dragHandler.start.y){this.zoomBox.style.top=xy.y+"px";}},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
+this.removeBox();this.map.div.style.cursor="";this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:'shiftKey',persist:false,irregular:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(control,callbacks,options){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:new Object();},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var options={displayInLayerSwitcher:false};this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)){if(this.dragging){this.cancel();}
+if(this.layer.map!=null){this.layer.destroy(false);if(this.feature){this.feature.destroy();}}
+this.layer=null;this.feature=null;deactivated=true;}
+return deactivated;},down:function(evt){this.fixedRadius=!!(this.radius);var maploc=this.map.getLonLatFromPixel(evt.xy);this.origin=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(!this.fixedRadius||this.irregular){this.radius=this.map.getResolution();}
+if(this.persist){this.clear();}
+this.feature=new OpenLayers.Feature.Vector();this.createGeometry();this.layer.addFeatures([this.feature],{silent:true});this.layer.drawFeature(this.feature,this.style);},move:function(evt){var maploc=this.map.getLonLatFromPixel(evt.xy);var point=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(this.irregular){var ry=Math.sqrt(2)*Math.abs(point.y-this.origin.y)/2;this.radius=Math.max(this.map.getResolution()/2,ry);}else if(this.fixedRadius){this.origin=point;}else{this.calculateAngle(point,evt);this.radius=Math.max(this.map.getResolution()/2,point.distanceTo(this.origin));}
+this.modifyGeometry();if(this.irregular){var dx=point.x-this.origin.x;var dy=point.y-this.origin.y;var ratio;if(dy==0){ratio=dx/(this.radius*Math.sqrt(2));}else{ratio=dx/dy;}
+this.feature.geometry.resize(1,this.origin,ratio);this.feature.geometry.move(dx/2,dy/2);}
+this.layer.drawFeature(this.feature,this.style);},up:function(evt){this.finalize();},out:function(evt){this.finalize();},createGeometry:function(){this.angle=Math.PI*((1/this.sides)-(1/2));if(this.snapAngle){this.angle+=this.snapAngle*(Math.PI/180);}
+this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,this.sides,this.snapAngle);},modifyGeometry:function(){var angle,dx,dy,point;var ring=this.feature.geometry.components[0];if(ring.components.length!=(this.sides+1)){this.createGeometry();ring=this.feature.geometry.components[0];}
+for(var i=0;i<this.sides;++i){point=ring.components[i];angle=this.angle+(i*2*Math.PI/this.sides);point.x=this.origin.x+(this.radius*Math.cos(angle));point.y=this.origin.y+(this.radius*Math.sin(angle));point.clearBounds();}},calculateAngle:function(point,evt){var alpha=Math.atan2(point.y-this.origin.y,point.x-this.origin.x);if(this.snapAngle&&(this.snapToggle&&!evt[this.snapToggle])){var snapAngleRad=(Math.PI/180)*this.snapAngle;this.angle=Math.round(alpha/snapAngleRad)*snapAngleRad;}else{this.angle=alpha;}},cancel:function(){this.callback("cancel",null);this.finalize();},finalize:function(){this.origin=null;this.radius=this.options.radius;},clear:function(){this.layer.renderer.clear();this.layer.destroyFeatures();},callback:function(name,args){if(this.callbacks[name]){this.callbacks[name].apply(this.control,[this.feature.geometry.clone()]);}
+if(!this.persist&&(name=="done"||name=="cancel")){this.clear();}},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:true,isBaseLayer:true,isFixed:true,pane:null,mapObject:null,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(this.pane==null){this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane");}},destroy:function(){this.mapObject=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";if(OpenLayers.Util.getBrowserName()=="msie"){this.pane.style.background="url("+OpenLayers.Util.getImagesLocation()+"blank.gif)";}
+if(this.isFixed){this.map.viewPortDiv.appendChild(this.pane);}else{this.map.layerContainerDiv.appendChild(this.pane);}
+this.loadMapObject();if(this.mapObject==null){this.loadWarningMessage();}},removeMap:function(map){if(this.pane&&this.pane.parentNode){this.pane.parentNode.removeChild(this.pane);this.pane=null;}
+OpenLayers.Layer.prototype.removeMap.apply(this,arguments);},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var viewSize=this.map.getSize();var msgW=Math.min(viewSize.w,300);var msgH=Math.min(viewSize.h,200);var size=new OpenLayers.Size(msgW,msgH);var centerPx=new OpenLayers.Pixel(viewSize.w/2,viewSize.h/2);var topLeft=centerPx.add(-size.w/2,-size.h/2);var div=OpenLayers.Util.createDiv(this.name+"_warning",topLeft,size,null,null,null,"auto");div.style.padding="7px";div.style.backgroundColor="yellow";div.innerHTML=this.getWarningHTML();this.div.appendChild(div);},getWarningHTML:function(){return"";},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);this.pane.style.display=this.div.style.display;},setZIndex:function(zIndex){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(this.mapObject!=null){var newCenter=this.map.getCenter();var newZoom=this.map.getZoom();if(newCenter!=null){var moOldCenter=this.getMapObjectCenter();var oldCenter=this.getOLLonLatFromMapObjectLonLat(moOldCenter);var moOldZoom=this.getMapObjectZoom();var oldZoom=this.getOLZoomFromMapObjectZoom(moOldZoom);if(!(newCenter.equals(oldCenter))||!(newZoom==oldZoom)){if(dragging&&this.dragPanMapObject&&this.smoothDragPan){var oldPx=this.map.getViewPortPxFromLonLat(oldCenter);var newPx=this.map.getViewPortPxFromLonLat(newCenter);this.dragPanMapObject(newPx.x-oldPx.x,oldPx.y-newPx.y);}else{var center=this.getMapObjectLonLatFromOLLonLat(newCenter);var zoom=this.getMapObjectZoomFromOLZoom(newZoom);this.setMapObjectCenter(center,zoom,dragging);}}}}},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moPixel=this.getMapObjectPixelFromOLPixel(viewPortPx);var moLonLat=this.getMapObjectLonLatFromMapObjectPixel(moPixel);lonlat=this.getOLLonLatFromMapObjectLonLat(moLonLat);}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var viewPortPx=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moLonLat=this.getMapObjectLonLatFromOLLonLat(lonlat);var moPixel=this.getMapObjectPixelFromMapObjectLonLat(moLonLat);viewPortPx=this.getOLPixelFromMapObjectPixel(moPixel);}
+return viewPortPx;},getOLLonLatFromMapObjectLonLat:function(moLonLat){var olLonLat=null;if(moLonLat!=null){var lon=this.getLongitudeFromMapObjectLonLat(moLonLat);var lat=this.getLatitudeFromMapObjectLonLat(moLonLat);olLonLat=new OpenLayers.LonLat(lon,lat);}
+return olLonLat;},getMapObjectLonLatFromOLLonLat:function(olLonLat){var moLatLng=null;if(olLonLat!=null){moLatLng=this.getMapObjectLonLatFromLonLat(olLonLat.lon,olLonLat.lat);}
+return moLatLng;},getOLPixelFromMapObjectPixel:function(moPixel){var olPixel=null;if(moPixel!=null){var x=this.getXFromMapObjectPixel(moPixel);var y=this.getYFromMapObjectPixel(moPixel);olPixel=new OpenLayers.Pixel(x,y);}
+return olPixel;},getMapObjectPixelFromOLPixel:function(olPixel){var moPixel=null;if(olPixel!=null){moPixel=this.getMapObjectPixelFromXY(olPixel.x,olPixel.y);}
+return moPixel;},CLASS_NAME:"OpenLayers.Layer.EventPane"});OpenLayers.Layer.FixedZoomLevels=OpenLayers.Class({initialize:function(){},initResolutions:function(){var props=new Array('minZoomLevel','maxZoomLevel','numZoomLevels');for(var i=0;i<props.length;i++){var property=props[i];this[property]=(this.options[property]!=null)?this.options[property]:this.map[property];}
+if((this.minZoomLevel==null)||(this.minZoomLevel<this.MIN_ZOOM_LEVEL)){this.minZoomLevel=this.MIN_ZOOM_LEVEL;}
+var limitZoomLevels=this.MAX_ZOOM_LEVEL-this.minZoomLevel+1;if(this.numZoomLevels!=null){this.numZoomLevels=Math.min(this.numZoomLevels,limitZoomLevels);}else{if(this.maxZoomLevel!=null){var zoomDiff=this.maxZoomLevel-this.minZoomLevel+1;this.numZoomLevels=Math.min(zoomDiff,limitZoomLevels);}else{this.numZoomLevels=limitZoomLevels;}}
+this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(this.RESOLUTIONS!=null){var resolutionsIndex=0;this.resolutions=[];for(var i=this.minZoomLevel;i<=this.maxZoomLevel;i++){this.resolutions[resolutionsIndex++]=this.RESOLUTIONS[i];}
+this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1];}},getResolution:function(){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getResolution.apply(this,arguments);}else{var resolution=null;var viewSize=this.map.getSize();var extent=this.getExtent();if((viewSize!=null)&&(extent!=null)){resolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);}
+return resolution;}},getExtent:function(){var extent=null;var size=this.map.getSize();var tlPx=new OpenLayers.Pixel(0,0);var tlLL=this.getLonLatFromViewPortPx(tlPx);var brPx=new OpenLayers.Pixel(size.w,size.h);var brLL=this.getLonLatFromViewPortPx(brPx);if((tlLL!=null)&&(brLL!=null)){extent=new OpenLayers.Bounds(tlLL.lon,brLL.lat,brLL.lon,tlLL.lat);}
+return extent;},getZoomForResolution:function(resolution){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getZoomForResolution.apply(this,arguments);}else{var extent=OpenLayers.Layer.prototype.getExtent.apply(this,[]);return this.getZoomForExtent(extent);}},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=moZoom-this.minZoomLevel;}
+return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=olZoom+this.minZoomLevel;}
+return zoom;},CLASS_NAME:"FixedZoomLevels.js"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.options);}
+obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setUrl:function(newUrl){this.url=newUrl;},mergeNewParams:function(newParams){this.params=OpenLayers.Util.extend(this.params,newParams);return this.redraw();},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0;i<paramString.length;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
+return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
+var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
+paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
+return requestString;},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Layer.Image=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:true,url:null,extent:null,size:null,tile:null,aspectRatio:null,initialize:function(name,url,extent,size,options){this.url=url;this.extent=extent;this.size=size;OpenLayers.Layer.prototype.initialize.apply(this,[name,options]);this.aspectRatio=(this.extent.getHeight()/this.size.h)/(this.extent.getWidth()/this.size.w);},destroy:function(){if(this.tile){this.tile.destroy();this.tile=null;}
+OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Image(this.name,this.url,this.extent,this.size,this.options);}
+obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setMap:function(map){if(this.options.maxResolution==null){this.options.maxResolution=this.aspectRatio*this.extent.getWidth()/this.size.w;}
+OpenLayers.Layer.prototype.setMap.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var firstRendering=(this.tile==null);if(zoomChanged||firstRendering){this.setTileSize();var ul=new OpenLayers.LonLat(this.extent.left,this.extent.top);var ulPx=this.map.getLayerPxFromLonLat(ul);if(firstRendering){this.tile=new OpenLayers.Tile.Image(this,ulPx,this.extent,null,this.tileSize);}else{this.tile.size=this.tileSize.clone();this.tile.position=ulPx.clone();}
+this.tile.draw();}},setTileSize:function(){var tileWidth=this.extent.getWidth()/this.map.getResolution();var tileHeight=this.extent.getHeight()/this.map.getResolution();this.tileSize=new OpenLayers.Size(tileWidth,tileHeight);},setUrl:function(newUrl){this.url=newUrl;this.tile.draw();},getURL:function(bounds){return this.url;},CLASS_NAME:"OpenLayers.Layer.Image"});OpenLayers.Layer.Markers=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:false,markers:null,drawn:false,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);this.markers=[];},destroy:function(){this.clearMarkers();this.markers=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0;i<this.markers.length;i++){this.markers[i].setOpacity(this.opacity);}}},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(zoomChanged||!this.drawn){for(var i=0;i<this.markers.length;i++){this.drawMarker(this.markers[i]);}
+this.drawn=true;}},addMarker:function(marker){this.markers.push(marker);if(this.opacity!=null){marker.setOpacity(this.opacity);}
+if(this.map&&this.map.getExtent()){marker.map=this.map;this.drawMarker(marker);}},removeMarker:function(marker){if(this.markers&&this.markers.length){OpenLayers.Util.removeItem(this.markers,marker);if((marker.icon!=null)&&(marker.icon.imageDiv!=null)&&(marker.icon.imageDiv.parentNode==this.div)){this.div.removeChild(marker.icon.imageDiv);marker.drawn=false;}}},clearMarkers:function(){if(this.markers!=null){while(this.markers.length>0){this.removeMarker(this.markers[0]);}}},drawMarker:function(marker){var px=this.map.getLayerPxFromLonLat(marker.lonlat);if(px==null){marker.display(false);}else{var markerImg=marker.draw(px);if(!marker.drawn){this.div.appendChild(markerImg);marker.drawn=true;}}},getDataExtent:function(){var maxExtent=null;if(this.markers&&(this.markers.length>0)){var maxExtent=new OpenLayers.Bounds();for(var i=0;i<this.markers.length;i++){var marker=this.markers[i];maxExtent.extend(marker.lonlat);}}
+return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Markers"});OpenLayers.Layer.SphericalMercator={getExtent:function(){var extent=null;if(this.sphericalMercator){extent=this.map.calculateBounds();}else{extent=OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);}
+return extent;},initMercatorParameters:function(){this.RESOLUTIONS=[];var maxResolution=156543.0339;for(var zoom=0;zoom<=this.MAX_ZOOM_LEVEL;++zoom){this.RESOLUTIONS[zoom]=maxResolution/Math.pow(2,zoom);}
+this.units="m";this.projection="EPSG:900913";},forwardMercator:function(lon,lat){var x=lon*20037508.34/180;var y=Math.log(Math.tan((90+lat)*Math.PI/360))/(Math.PI/180);y=y*20037508.34/180;return new OpenLayers.LonLat(x,y);},inverseMercator:function(x,y){var lon=(x/20037508.34)*180;var lat=(y/20037508.34)*180;lat=180/Math.PI*(2*Math.atan(Math.exp(lat*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(lon,lat);},projectForward:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.forwardMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;},projectInverse:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.inverseMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;}};OpenLayers.Projection.addTransform("EPSG:4326","EPSG:900913",OpenLayers.Layer.SphericalMercator.projectForward);OpenLayers.Projection.addTransform("EPSG:900913","EPSG:4326",OpenLayers.Layer.SphericalMercator.projectInverse);OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,featureAdded:function(){},handlerOptions:null,initialize:function(layer,handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature},this.callbacks);this.layer=layer;this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);this.layer.addFeatures([feature]);this.featureAdded(feature);},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,onSelect:function(){},onUnselect:function(){},geometryTypes:null,layer:null,callbacks:null,selectStyle:null,renderIntent:"select",handler:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.callbacks=OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.callbacks);var handlerOptions={geometryTypes:this.geometryTypes};this.handler=new OpenLayers.Handler.Feature(this,layer,this.callbacks,handlerOptions);},unselectAll:function(options){var feature;for(var i=this.layer.selectedFeatures.length-1;i>=0;--i){feature=this.layer.selectedFeatures[i];if(!options||options.except!=feature){this.unselect(feature);}}},clickFeature:function(feature){if(!this.hover){var selected=(OpenLayers.Util.indexOf(this.layer.selectedFeatures,feature)>-1);if(selected){if(this.toggleSelect()){this.unselect(feature);}else if(!this.multipleSelect()){this.unselectAll({except:feature});}}else{if(!this.multipleSelect()){this.unselectAll({except:feature});}
+this.select(feature);}}},multipleSelect:function(){return this.multiple||this.handler.evt[this.multipleKey];},toggleSelect:function(){return this.toggle||this.handler.evt[this.toggleKey];},clickoutFeature:function(feature){if(!this.hover&&this.clickout){this.unselectAll();}},overFeature:function(feature){if(this.hover&&(OpenLayers.Util.indexOf(this.layer.selectedFeatures,feature)==-1)){this.select(feature);}},outFeature:function(feature){if(this.hover){this.unselect(feature);}},select:function(feature){this.layer.selectedFeatures.push(feature);var selectStyle=this.selectStyle||this.renderIntent;this.layer.drawFeature(feature,selectStyle);this.layer.events.triggerEvent("featureselected",{feature:feature});this.onSelect(feature);},unselect:function(feature){this.layer.drawFeature(feature,"default");OpenLayers.Util.removeItem(this.layer.selectedFeatures,feature);this.layer.events.triggerEvent("featureunselected",{feature:feature});this.onUnselect(feature);},setMap:function(map){this.handler.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax=center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;var bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
+this.map.zoomToExtent(bounds);}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){this.regExes={'typeStr':/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,'spaces':/\s+/,'parenComma':/\)\s*,\s*\(/,'doubleParenComma':/\)\s*\)\s*,\s*\(\s*\(/,'trimParens':/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(wkt){var features,type,str;var matches=this.regExes.typeStr.exec(wkt);if(matches){type=matches[1].toLowerCase();str=matches[2];if(this.parse[type]){features=this.parse[type].apply(this,[str]);}
+if(this.internalProjection&&this.externalProjection){if(features&&features.CLASS_NAME=="OpenLayers.Feature.Vector"){features.geometry.transform(this.externalProjection,this.internalProjection);}else if(features&&typeof features=="object"){for(var i=0;i<features.length;i++){var component=features[i];component.geometry.transform(this.externalProjection,this.internalProjection);}}}}
+return features;},write:function(features){var collection,geometry,type,data,isCollection;if(features.constructor==Array){collection=features;isCollection=true;}else{collection=[features];isCollection=false;}
+var pieces=[];if(isCollection){pieces.push('GEOMETRYCOLLECTION(');}
+for(var i=0;i<collection.length;++i){if(isCollection&&i>0){pieces.push(',');}
+geometry=collection[i].geometry;type=geometry.CLASS_NAME.split('.')[2].toLowerCase();if(!this.extract[type]){return null;}
+if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+data=this.extract[type].apply(this,[geometry]);pieces.push(type.toUpperCase()+'('+data+')');}
+if(isCollection){pieces.push(')');}
+return pieces.join('');},extract:{'point':function(point){return point.x+' '+point.y;},'multipoint':function(multipoint){var array=[];for(var i=0;i<multipoint.components.length;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
+return array.join(',');},'linestring':function(linestring){var array=[];for(var i=0;i<linestring.components.length;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
+return array.join(',');},'multilinestring':function(multilinestring){var array=[];for(var i=0;i<multilinestring.components.length;++i){array.push('('+
+this.extract.linestring.apply(this,[multilinestring.components[i]])+')');}
+return array.join(',');},'polygon':function(polygon){var array=[];for(var i=0;i<polygon.components.length;++i){array.push('('+
+this.extract.linestring.apply(this,[polygon.components[i]])+')');}
+return array.join(',');},'multipolygon':function(multipolygon){var array=[];for(var i=0;i<multipolygon.components.length;++i){array.push('('+
+this.extract.polygon.apply(this,[multipolygon.components[i]])+')');}
+return array.join(',');}},parse:{'point':function(str){var coords=OpenLayers.String.trim(str).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(coords[0],coords[1]));},'multipoint':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0;i<points.length;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPoint(components));},'linestring':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0;i<points.length;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString(components));},'multilinestring':function(str){var line;var lines=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0;i<lines.length;++i){line=lines[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.linestring.apply(this,[line]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiLineString(components));},'polygon':function(str){var ring,linestring,linearring;var rings=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0;i<rings.length;++i){ring=rings[i].replace(this.regExes.trimParens,'$1');linestring=this.parse.linestring.apply(this,[ring]).geometry;linearring=new OpenLayers.Geometry.LinearRing(linestring.components);components.push(linearring);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon(components));},'multipolygon':function(str){var polygon;var polygons=OpenLayers.String.trim(str).split(this.regExes.doubleParenComma);var components=[];for(var i=0;i<polygons.length;++i){polygon=polygons[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.polygon.apply(this,[polygon]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPolygon(components));},'geometrycollection':function(str){str=str.replace(/,\s*([A-Za-z])/g,'|$1');var wktArray=OpenLayers.String.trim(str).split('|');var components=[];for(var i=0;i<wktArray.length;++i){components.push(OpenLayers.Format.WKT.prototype.read.apply(this,[wktArray[i]]));}
+return components;}},CLASS_NAME:"OpenLayers.Format.WKT"});OpenLayers.Layer.Boxes=OpenLayers.Class(OpenLayers.Layer.Markers,{initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);},drawMarker:function(marker){var bounds=marker.bounds;var topleft=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.left,bounds.top));var botright=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.right,bounds.bottom));if(botright==null||topleft==null){marker.display(false);}else{var sz=new OpenLayers.Size(Math.max(1,botright.x-topleft.x),Math.max(1,botright.y-topleft.y));var markerDiv=marker.draw(topleft,sz);if(!marker.drawn){this.div.appendChild(markerDiv);marker.drawn=true;}}},removeMarker:function(marker){OpenLayers.Util.removeItem(this.markers,marker);if((marker.div!=null)&&(marker.div.parentNode==this.div)){this.div.removeChild(marker.div);}},CLASS_NAME:"OpenLayers.Layer.Boxes"});OpenLayers.Layer.GeoRSS=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,icon:null,popupSize:null,useFeedTitle:true,initialize:function(name,location,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,[name,options]);this.location=location;this.features=[];},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadRSS:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.loadURL(this.location,null,this,this.parseData);this.loaded=true;}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadRSS();}},parseData:function(ajaxRequest){var doc=ajaxRequest.responseXML;if(!doc||!doc.documentElement){doc=OpenLayers.Format.XML.prototype.read(ajaxRequest.responseText);}
+if(this.useFeedTitle){var name=null;try{name=doc.getElementsByTagNameNS('*','title')[0].firstChild.nodeValue;}
+catch(e){name=doc.getElementsByTagName('title')[0].firstChild.nodeValue;}
+if(name){this.setName(name);}}
+var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
+var format=new OpenLayers.Format.GeoRSS(options);var features=format.read(doc);for(var i=0;i<features.length;i++){var data={};var feature=features[i];if(!feature.geometry){continue;}
+var title=feature.attributes.title?feature.attributes.title:"Untitled";var description=feature.attributes.description?feature.attributes.description:"No description.";var link=feature.attributes.link?feature.attributes.link:"";var location=feature.geometry.getBounds().getCenterLonLat();data.icon=this.icon==null?OpenLayers.Marker.defaultIcon():this.icon.clone();data.popupSize=this.popupSize?this.popupSize.clone():new OpenLayers.Size(250,120);if(title||description){var contentHTML='<div class="olLayerGeoRSSClose">[x]</div>';contentHTML+='<div class="olLayerGeoRSSTitle">';if(link){contentHTML+='<a class="link" href="'+link+'" target="_blank">';}
+contentHTML+=title;if(link){contentHTML+='</a>';}
+contentHTML+='</div>';contentHTML+='<div style="" class="olLayerGeoRSSDescription">';contentHTML+=description;contentHTML+='</div>';data['popupContentHTML']=contentHTML;}
+var feature=new OpenLayers.Feature(this,location,data);this.features.push(feature);var marker=feature.createMarker();marker.events.register('click',feature,this.markerClick);this.addMarker(marker);}
+this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0;i<this.layer.map.popups.length;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
+if(!sameMarkerClicked){var popup=this.createPopup();OpenLayers.Event.observe(popup.div,"click",OpenLayers.Function.bind(function(){for(var i=0;i<this.layer.map.popups.length;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}},this));this.layer.map.addPopup(popup);}
+OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.GeoRSS"});OpenLayers.Layer.Google=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:19,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515,0.00000268220901489257],type:null,sphericalMercator:false,dragObject:null,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);this.addContainerPxFunction();if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){try{this.mapObject=new GMap2(this.div);if(typeof this.mapObject.getDragObject=="function"){this.dragObject=this.mapObject.getDragObject();}else{this.dragPanMapObject=null;}
+var poweredBy=this.div.lastChild;this.div.removeChild(poweredBy);this.pane.appendChild(poweredBy);poweredBy.className="olLayerGooglePoweredBy gmnoprint";poweredBy.style.left="";poweredBy.style.bottom="";var termsOfUse=this.div.lastChild;this.div.removeChild(termsOfUse);this.pane.appendChild(termsOfUse);termsOfUse.className="olLayerGoogleCopyright";termsOfUse.style.right="";termsOfUse.style.bottom="";}catch(e){OpenLayers.Console.error(e);}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);if(this.type!=null){this.map.events.register("moveend",this,this.setMapType);}},setMapType:function(){if(this.mapObject.getCenter()!=null){if(OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),this.type)==-1){this.mapObject.addMapType(this.type);}
+this.mapObject.setMapType(this.type);this.map.events.unregister("moveend",this,this.setMapType);}},onMapResize:function(){this.mapObject.checkResize();},getOLBoundsFromMapObjectBounds:function(moBounds){var olBounds=null;if(moBounds!=null){var sw=moBounds.getSouthWest();var ne=moBounds.getNorthEast();if(this.sphericalMercator){sw=this.forwardMercator(sw.lng(),sw.lat());ne=this.forwardMercator(ne.lng(),ne.lat());}else{sw=new OpenLayers.LonLat(sw.lng(),sw.lat());ne=new OpenLayers.LonLat(ne.lng(),ne.lat());}
+olBounds=new OpenLayers.Bounds(sw.lon,sw.lat,ne.lon,ne.lat);}
+return olBounds;},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new GLatLngBounds(new GLatLng(sw.lat,sw.lon),new GLatLng(ne.lat,ne.lon));}
+return moBounds;},addContainerPxFunction:function(){if((typeof GMap2!="undefined")&&!GMap2.prototype.fromLatLngToContainerPixel){GMap2.prototype.fromLatLngToContainerPixel=function(gLatLng){var gPoint=this.fromLatLngToDivPixel(gLatLng);var div=this.getContainer().firstChild.firstChild;gPoint.x+=div.offsetLeft;gPoint.y+=div.offsetTop;return gPoint;};}},getWarningHTML:function(){return OpenLayers.i18n("googleWarning");},setMapObjectCenter:function(center,zoom){this.mapObject.setCenter(center,zoom);},dragPanMapObject:function(dX,dY){this.dragObject.moveBy(new GSize(-dX,dY));},getMapObjectCenter:function(){return this.mapObject.getCenter();},getMapObjectZoom:function(){return this.mapObject.getZoom();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.fromContainerPixelToLatLng(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.fromLatLngToContainerPixel(moLonLat);},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lon:moLonLat.lng();},getLatitudeFromMapObjectLonLat:function(moLonLat){var lat=this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lat:moLonLat.lat();return lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new GLatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new GLatLng(lat,lon);}
+return gLatLng;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new GPoint(x,y);},CLASS_NAME:"OpenLayers.Layer.Google"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,grid:null,singleTile:false,ratio:1.5,buffer:2,numLoadingTiles:0,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0;iRow<this.grid.length;iRow++){var row=this.grid[iRow];for(var iCol=0;iCol<row.length;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
+this.grid=[];}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.options);}
+obj=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
+obj.grid=[];return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){this.initSingleTile(bounds);}}else{if(forceReTile||!tilesBounds.containsBounds(bounds,true)){this.initGriddedTiles(bounds);}else{this.moveGriddedTiles(bounds);}}}},setTileSize:function(size){if(this.singleTile){size=this.map.getSize().clone();size.h=parseInt(size.h*this.ratio);size.w=parseInt(size.w*this.ratio);}
+OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[size]);},getGridBounds:function(){var msg="The getGridBounds() function is deprecated. It will be "+"removed in 3.0. Please use getTilesBounds() instead.";OpenLayers.Console.warn(msg);return this.getTilesBounds();},getTilesBounds:function(){var bounds=null;if(this.grid.length){var bottom=this.grid.length-1;var bottomLeftTile=this.grid[bottom][0];var right=this.grid[0].length-1;var topRightTile=this.grid[0][right];bounds=new OpenLayers.Bounds(bottomLeftTile.bounds.left,bottomLeftTile.bounds.bottom,topRightTile.bounds.right,topRightTile.bounds.top);}
+return bounds;},initSingleTile:function(bounds){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var px=this.map.getLayerPxFromLonLat(ul);if(!this.grid.length){this.grid[0]=[];}
+var tile=this.grid[0][0];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);tile.draw();this.grid[0][0]=tile;}else{tile.moveTo(tileBounds,px);}
+this.removeExcessTiles(1,1);},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=bounds.top-(extent.bottom+tilelat);var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-tilerowremain*this.tileSize.h;var tileoffsetlat=extent.bottom+tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},initGriddedTiles:function(bounds){var viewSize=this.map.getSize();var minRows=Math.ceil(viewSize.h/this.tileSize.h)+
+Math.max(1,2*this.buffer);var minCols=Math.ceil(viewSize.w/this.tileSize.w)+
+Math.max(1,2*this.buffer);var extent=this.map.getMaxExtent();var resolution=this.map.getResolution();var tileLayout=this.calculateGridLayout(bounds,extent,resolution);var tileoffsetx=Math.round(tileLayout.tileoffsetx);var tileoffsety=Math.round(tileLayout.tileoffsety);var tileoffsetlon=tileLayout.tileoffsetlon;var tileoffsetlat=tileLayout.tileoffsetlat;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;this.origin=new OpenLayers.Pixel(tileoffsetx,tileoffsety);var startX=tileoffsetx;var startLon=tileoffsetlon;var rowidx=0;var layerContainerDivLeft=parseInt(this.map.layerContainerDiv.style.left);var layerContainerDivTop=parseInt(this.map.layerContainerDiv.style.top);do{var row=this.grid[rowidx++];if(!row){row=[];this.grid.push(row);}
+tileoffsetlon=startLon;tileoffsetx=startX;var colidx=0;do{var tileBounds=new OpenLayers.Bounds(tileoffsetlon,tileoffsetlat,tileoffsetlon+tilelon,tileoffsetlat+tilelat);var x=tileoffsetx;x-=layerContainerDivLeft;var y=tileoffsety;y-=layerContainerDivTop;var px=new OpenLayers.Pixel(x,y);var tile=row[colidx++];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);row.push(tile);}else{tile.moveTo(tileBounds,px,false);}
+tileoffsetlon+=tilelon;tileoffsetx+=this.tileSize.w;}while((tileoffsetlon<=bounds.right+tilelon*this.buffer)||colidx<minCols)
+tileoffsetlat-=tilelat;tileoffsety+=this.tileSize.h;}while((tileoffsetlat>=bounds.bottom-tilelat*this.buffer)||rowidx<minRows)
+this.removeExcessTiles(rowidx,colidx);this.spiralTileLoad();},spiralTileLoad:function(){var tileQueue=[];var directions=["right","down","left","up"];var iRow=0;var iCell=-1;var direction=OpenLayers.Util.indexOf(directions,"right");var directionsTried=0;while(directionsTried<directions.length){var testRow=iRow;var testCell=iCell;switch(directions[direction]){case"right":testCell++;break;case"down":testRow++;break;case"left":testCell--;break;case"up":testRow--;break;}
+var tile=null;if((testRow<this.grid.length)&&(testRow>=0)&&(testCell<this.grid[0].length)&&(testCell>=0)){tile=this.grid[testRow][testCell];}
+if((tile!=null)&&(!tile.queued)){tileQueue.unshift(tile);tile.queued=true;directionsTried=0;iRow=testRow;iCell=testCell;}else{direction=(direction+1)%4;directionsTried++;}}
+for(var i=0;i<tileQueue.length;i++){var tile=tileQueue[i];tile.draw();tile.queued=false;}},addTile:function(bounds,position){},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this.numLoadingTiles==0){this.events.triggerEvent("loadstart");}
+this.numLoadingTiles++;};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded");if(this.numLoadingTiles==0){this.events.triggerEvent("loadend");}};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},moveGriddedTiles:function(bounds){var buffer=this.buffer||1;while(true){var tlLayer=this.grid[0][0].position;var tlViewPort=this.map.getViewPortPxFromLayerPx(tlLayer);if(tlViewPort.x>-this.tileSize.w*(buffer-1)){this.shiftColumn(true);}else if(tlViewPort.x<-this.tileSize.w*buffer){this.shiftColumn(false);}else if(tlViewPort.y>-this.tileSize.h*(buffer-1)){this.shiftRow(true);}else if(tlViewPort.y<-this.tileSize.h*buffer){this.shiftRow(false);}else{break;}};},shiftRow:function(prepend){var modelRowIndex=(prepend)?0:(this.grid.length-1);var grid=this.grid;var modelRow=grid[modelRowIndex];var resolution=this.map.getResolution();var deltaY=(prepend)?-this.tileSize.h:this.tileSize.h;var deltaLat=resolution*-deltaY;var row=(prepend)?grid.pop():grid.shift();for(var i=0;i<modelRow.length;i++){var modelTile=modelRow[i];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.bottom=bounds.bottom+deltaLat;bounds.top=bounds.top+deltaLat;position.y=position.y+deltaY;row[i].moveTo(bounds,position);}
+if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.map.getResolution();var deltaLon=resolution*deltaX;for(var i=0;i<this.grid.length;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){while(this.grid.length>rows){var row=this.grid.pop();for(var i=0,l=row.length;i<l;i++){var tile=row[i];this.removeTileMonitoringHooks(tile);tile.destroy();}}
+while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.map.getMaxExtent();var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
+maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
+maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Layer.MultiMap=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[9,1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();this.RESOLUTIONS.unshift(10);}},loadMapObject:function(){try{this.mapObject=new MultimapViewer(this.div);}catch(e){}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':"MM",'layerLib':"MultiMap"});},setMapObjectCenter:function(center,zoom){this.mapObject.goToPosition(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCurrentPosition();},getMapObjectZoom:function(){return this.mapObject.getZoomFactor();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){moPixel.x=moPixel.x-(this.map.getSize().w/2);moPixel.y=moPixel.y-(this.map.getSize().h/2);return this.mapObject.getMapPositionAt(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.geoPosToContainerPixels(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lon,moLonLat.lat).lon:moLonLat.lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lon,moLonLat.lat).lat:moLonLat.lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var mmLatLon;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);mmLatLon=new MMLatLon(lonlat.lat,lonlat.lon);}else{mmLatLon=new MMLatLon(lat,lon);}
+return mmLatLon;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new MMPoint(x,y);},CLASS_NAME:"OpenLayers.Layer.MultiMap"});OpenLayers.Layer.Text=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);this.features=new Array();},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadText:function(){if(!this.loaded){if(this.location!=null){var onFail=function(e){this.events.triggerEvent("loadend");};this.events.triggerEvent("loadstart");OpenLayers.loadURL(this.location,null,this,this.parseData,onFail);this.loaded=true;}}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadText();}},parseData:function(ajaxRequest){var text=ajaxRequest.responseText;var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
+var parser=new OpenLayers.Format.Text(options);features=parser.read(text);for(var i=0;i<features.length;i++){var data={};var feature=features[i];var location;var iconSize,iconOffset;location=new OpenLayers.LonLat(feature.geometry.x,feature.geometry.y);if(feature.style.graphicWidth&&feature.style.graphicHeight){iconSize=new OpenLayers.Size(feature.style.graphicWidth,feature.style.graphicHeight);}
+if(feature.style.graphicXOffset&&feature.style.graphicYOffset){iconOffset=new OpenLayers.Pixel(feature.style.graphicXOffset,feature.style.graphicYOffset);}
+if(feature.style.externalGraphic!=null){data.icon=new OpenLayers.Icon(feature.style.externalGraphic,iconSize,iconOffset);}else{data.icon=OpenLayers.Marker.defaultIcon();if(iconSize!=null){data.icon.setSize(iconSize);}}
+if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){data['popupContentHTML']='<h2>'+feature.attributes.title+'</h2>'+'<p>'+feature.attributes.description+'</p>';}
+data['overflow']=feature.attributes.overflow||"auto";var markerFeature=new OpenLayers.Feature(this,location,data);this.features.push(markerFeature);var marker=markerFeature.createMarker();if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){marker.events.register('click',markerFeature,this.markerClick);}
+this.addMarker(marker);}
+if(!sameMarkerClicked){this.layer.map.addPopup(this.createPopup());}
+OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Layer.VirtualEarth=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,sphericalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){var veDiv=OpenLayers.Util.createDiv(this.name);var sz=this.map.getSize();veDiv.style.width=sz.w;veDiv.style.height=sz.h;this.div.appendChild(veDiv);try{this.mapObject=new VEMap(this.name);}catch(e){}
+if(this.mapObject!=null){try{this.mapObject.LoadMap(null,null,this.type,true);this.mapObject.AttachEvent("onmousedown",function(){return true;});}catch(e){}
+this.mapObject.HideDashboard();}
+if(!this.mapObject||!this.mapObject.vemapcontrol||!this.mapObject.vemapcontrol.PanMap||(typeof this.mapObject.vemapcontrol.PanMap!="function")){this.dragPanMapObject=null;}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'VE','layerLib':'VirtualEarth'});},setMapObjectCenter:function(center,zoom){this.mapObject.SetCenterAndZoom(center,zoom);},getMapObjectCenter:function(){return this.mapObject.GetCenter();},dragPanMapObject:function(dX,dY){this.mapObject.vemapcontrol.PanMap(dX,-dY);},getMapObjectZoom:function(){return this.mapObject.GetZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.PixelToLatLong(moPixel.x,moPixel.y);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.LatLongToPixel(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lon:moLonLat.Longitude;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lat:moLonLat.Latitude;},getMapObjectLonLatFromLonLat:function(lon,lat){var veLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);veLatLong=new VELatLong(lonlat.lat,lonlat.lon);}else{veLatLong=new VELatLong(lat,lon);}
+return veLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new Msn.VE.Pixel(x,y);},CLASS_NAME:"OpenLayers.Layer.VirtualEarth"});OpenLayers.Layer.Yahoo=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:15,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,sphericalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject=new YMap(this.div,this.type,size);this.mapObject.disableKeyControls();this.mapObject.disableDragMap();if(!this.mapObject.moveByXY||(typeof this.mapObject.moveByXY!="function")){this.dragPanMapObject=null;}}catch(e){}},onMapResize:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject.resizeTo(size);}catch(e){}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);this.map.events.register("moveend",this,this.fixYahooEventPane);},fixYahooEventPane:function(){var yahooEventPane=OpenLayers.Util.getElement("ygddfdiv");if(yahooEventPane!=null){if(yahooEventPane.parentNode!=null){yahooEventPane.parentNode.removeChild(yahooEventPane);}
+this.map.events.unregister("moveend",this,this.fixYahooEventPane);}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'Yahoo','layerLib':'Yahoo'});},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getOLZoomFromMapObjectZoom.apply(this,[moZoom]);zoom=18-zoom;}
+return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getMapObjectZoomFromOLZoom.apply(this,[olZoom]);zoom=18-zoom;}
+return zoom;},setMapObjectCenter:function(center,zoom){this.mapObject.drawZoomAndCenter(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCenterLatLon();},dragPanMapObject:function(dX,dY){this.mapObject.moveByXY({'x':-dX,'y':dY});},getMapObjectZoom:function(){return this.mapObject.getZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.convertXYLatLon(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.convertLatLonXY(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lon:moLonLat.Lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lat:moLonLat.Lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var yLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);yLatLong=new YGeoPoint(lonlat.lat,lonlat.lon);}else{yLatLong=new YGeoPoint(lat,lon);}
+return yLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new YCoordPoint(x,y);},getMapObjectSizeFromOLSize:function(olSize){return new YSize(olSize.w,olSize.h);},CLASS_NAME:"OpenLayers.Layer.Yahoo"});OpenLayers.Style=OpenLayers.Class({name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,propertyStyles:null,initialize:function(style,options){this.rules=[];this.setDefaultStyle(style||OpenLayers.Feature.Vector.style["default"]);OpenLayers.Util.extend(this,options);},destroy:function(){for(var i=0;i<this.rules.length;i++){this.rules[i].destroy();this.rules[i]=null;}
+this.rules=null;this.defaultStyle=null;},createSymbolizer:function(feature){var style=this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),feature);var rules=this.rules;var rule,context;var elseRules=[];var appliedRules=false;for(var i=0;i<rules.length;i++){rule=rules[i];var applies=rule.evaluate(feature);if(applies){if(rule instanceof OpenLayers.Rule&&rule.elseFilter){elseRules.push(rule);}else{appliedRules=true;this.applySymbolizer(rule,style,feature);}}}
+if(appliedRules==false&&elseRules.length>0){appliedRules=true;for(var i=0;i<elseRules.length;i++){this.applySymbolizer(elseRules[i],style,feature);}}
+if(rules.length>0&&appliedRules==false){style.display="none";}else{style.display="";}
+return style;},applySymbolizer:function(rule,style,feature){var symbolizerPrefix=feature.geometry?this.getSymbolizerPrefix(feature.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];var symbolizer=rule.symbolizer[symbolizerPrefix]||rule.symbolizer;return this.createLiterals(OpenLayers.Util.extend(style,symbolizer),feature);},createLiterals:function(style,feature){var context=this.context||feature.attributes||feature.data;for(var i in this.propertyStyles){style[i]=OpenLayers.Style.createLiteral(style[i],context,feature);}
+return style;},findPropertyStyles:function(){var propertyStyles={};var style=this.defaultStyle;this.addPropertyStyles(propertyStyles,style);var rules=this.rules;var symbolizer,value;for(var i=0;i<rules.length;i++){var symbolizer=rules[i].symbolizer;for(var key in symbolizer){value=symbolizer[key];if(typeof value=="object"){this.addPropertyStyles(propertyStyles,value);}else{this.addPropertyStyles(propertyStyles,symbolizer);break;}}}
+return propertyStyles;},addPropertyStyles:function(propertyStyles,symbolizer){var property;for(var key in symbolizer){property=symbolizer[key];if(typeof property=="string"&&property.match(/\$\{\w+\}/)){propertyStyles[key]=true;}}
+return propertyStyles;},addRules:function(rules){this.rules=this.rules.concat(rules);this.propertyStyles=this.findPropertyStyles();},setDefaultStyle:function(style){this.defaultStyle=style;this.propertyStyles=this.findPropertyStyles();},getSymbolizerPrefix:function(geometry){var prefixes=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0;i<prefixes.length;i++){if(geometry.CLASS_NAME.indexOf(prefixes[i])!=-1){return prefixes[i];}}},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(value,context,feature){if(typeof value=="string"&&value.indexOf("${")!=-1){value=OpenLayers.String.format(value,context,[feature]);value=(isNaN(value)||!value)?value:parseFloat(value);}
+return value;};OpenLayers.Style.SYMBOLIZER_PREFIXES=['Point','Line','Polygon'];OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:true,toggle:true,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,mode:null,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer());this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,100];this.mode=OpenLayers.Control.ModifyFeature.RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(this.deleteCodes instanceof Array)){this.deleteCodes=[this.deleteCodes];}
+var control=this;var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle};this.selectControl=new OpenLayers.Control.SelectFeature(layer,selectOptions);this.layer.events.on({"featureselected":this.selectFeature,"featureunselected":this.unselectFeature,scope:this});var dragOptions={geometryTypes:["OpenLayers.Geometry.Point"],snappingOptions:this.snappingOptions,onStart:function(feature,pixel){control.dragStart.apply(control,[feature,pixel]);},onDrag:function(feature){control.dragVertex.apply(control,[feature]);},onComplete:function(feature){control.dragComplete.apply(control,[feature]);}};this.dragControl=new OpenLayers.Control.DragFeature(layer,dragOptions);var keyboardOptions={keypress:this.handleKeypress};this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,keyboardOptions)};},destroy:function(){this.layer.events.un({"featureselected":this.selectFeature,"featureunselected":this.unselectFeature,scope:this});this.layer=null;this.selectControl.destroy();this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.selectControl.activate()&&this.handlers.keyboard.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.vertices);this.layer.removeFeatures(this.virtualVertices);this.vertices=[];this.dragControl.deactivate();if(this.feature&&this.feature.geometry){this.selectControl.unselect.apply(this.selectControl,[this.feature]);}
+this.selectControl.deactivate();this.handlers.keyboard.deactivate();deactivated=true;}
+return deactivated;},selectFeature:function(object){this.feature=object.feature;this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);this.layer.events.triggerEvent("beforefeaturemodified",{feature:this.feature});},unselectFeature:function(object){this.layer.removeFeatures(this.vertices);this.vertices=[];this.layer.destroyFeatures(this.virtualVertices);this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle]);delete this.dragHandle;}
+if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);delete this.radiusHandle;}
+this.feature=null;this.dragControl.deactivate();this.onModificationEnd(object.feature);this.layer.events.triggerEvent("afterfeaturemodified",{feature:object.feature});},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
+if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){this.selectControl.clickFeature.apply(this.selectControl,[feature]);this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}}},dragVertex:function(vertex){if(this.feature.geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){if(this.feature!=vertex){this.feature=vertex;}}else{if(vertex._index){vertex.geometry.parent.addComponent(vertex.geometry,vertex._index);delete vertex._index;OpenLayers.Util.removeItem(this.virtualVertices,vertex);this.vertices.push(vertex);}else if(vertex==this.dragHandle){this.layer.removeFeatures(this.vertices);this.vertices=[];if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);this.radiusHandle=null;}}
+if(this.virtualVertices.length>0){this.layer.destroyFeatures(this.virtualVertices);this.virtualVertices=[];}
+this.layer.drawFeature(this.feature,this.selectControl.renderIntent);}
+this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},resetVertices:function(){if(this.dragControl.feature){this.dragControl.outFeature(this.dragControl.feature);}
+if(this.vertices.length>0){this.layer.removeFeatures(this.vertices);this.vertices=[];}
+if(this.virtualVertices.length>0){this.layer.removeFeatures(this.virtualVertices);this.virtualVertices=[];}
+if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle]);this.dragHandle=null;}
+if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);this.radiusHandle=null;}
+if(this.feature&&this.feature.geometry.CLASS_NAME!="OpenLayers.Geometry.Point"){if((this.mode&OpenLayers.Control.ModifyFeature.DRAG)){this.collectDragHandle();}
+if((this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE))){this.collectRadiusHandle();}
+if((this.mode&OpenLayers.Control.ModifyFeature.RESHAPE)){this.collectVertices();}}},handleKeypress:function(code){if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.drawFeature(this.feature,this.selectControl.renderIntent);this.resetVertices();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i,vertex,component;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
+for(i=0;i<numVert;++i){component=geometry.components[i];if(component.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(component);control.vertices.push(vertex);}else{collectComponentVertices(component);}}
+if(geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0;i<geometry.components.length-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;control.virtualVertices.push(point);}}}}}
+collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.vertices,{silent:true});this.layer.addFeatures(this.virtualVertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};this.dragHandle=origin;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.Feature.Vector(radiusGeometry);var resize=(this.mode&OpenLayers.Control.ModifyFeature.RESIZE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
+if(resize){var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));geometry.resize(l1/l0,originGeometry);}};this.radiusHandle=radius;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,zoomBox:null,zoomWheelEnabled:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
+this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
+this.handlers.click.activate();this.zoomBox.activate();return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){this.handlers.click=new OpenLayers.Handler.Click(this,{'dblclick':this.defaultDblClick},{'double':true,'stopDouble':true});this.dragPan=new OpenLayers.Control.DragPan({map:this.map});this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:OpenLayers.Handler.MOD_SHIFT});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown});this.activate();},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},wheelChange:function(evt,deltaZ){var newZoom=this.map.getZoom()+deltaZ;if(!this.map.isValidZoomLevel(newZoom)){return;}
+var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt){this.wheelChange(evt,1);},wheelDown:function(evt){this.wheelChange(evt,-1);},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
+return this.bounds;},calculateBounds:function(){},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;var bounds=this.getBounds();if((bounds!=null)&&(lonlat!=null)){var dX=(toleranceLon!=null)?toleranceLon:0;var dY=(toleranceLat!=null)?toleranceLat:0;var toleranceBounds=new OpenLayers.Bounds(this.bounds.left-dX,this.bounds.bottom-dY,this.bounds.right+dX,this.bounds.top+dY);atPoint=toleranceBounds.containsLonLat(lonlat);}
+return atPoint;},getLength:function(){return 0.0;},getArea:function(){return 0.0;},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this));},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.segmentsIntersect=function(seg1,seg2,point){var intersection=false;var x11_21=seg1.x1-seg2.x1;var y11_21=seg1.y1-seg2.y1;var x12_11=seg1.x2-seg1.x1;var y12_11=seg1.y2-seg1.y1;var y22_21=seg2.y2-seg2.y1;var x22_21=seg2.x2-seg2.x1;var d=(y22_21*x12_11)-(x22_21*y12_11);var n1=(x22_21*y11_21)-(y22_21*x11_21);var n2=(x12_11*y11_21)-(y12_11*x11_21);if(d==0){if(n1==0&&n2==0){intersection=true;}}else{var along1=n1/d;var along2=n2/d;if(along1>=0&&along1<=1&&along2>=0&&along2<=1){if(!point){intersection=true;}else{var x=seg1.x1+(along1*x12_11);var y=seg1.y1+(along1*y12_11);intersection=new OpenLayers.Geometry.Point(x,y);}}}
+return intersection;};OpenLayers.Layer.KaMap=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,units:null,resolution:OpenLayers.DOTS_PER_INCH,DEFAULT_PARAMS:{i:'jpeg',map:''},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=(params?params:{});if(params){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);return this.getFullRequestString({t:pY,l:pX,s:scale});},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=tilecol*tilelon;var offsetlat=bounds.top;var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-(tilerowremain+1)*this.tileSize.h;var tileoffsetlat=tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.KaMap(this.name,this.url,this.params,this.options);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
+obj.grid=[];return obj;},getTileBounds:function(viewPortPx){var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=tileMapWidth*Math.floor(mapPoint.lon/tileMapWidth);var tileBottom=tileMapHeight*Math.floor(mapPoint.lat/tileMapHeight);return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.KaMap"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,singleTile:false,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},defaultSize:new OpenLayers.Size(300,300),initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.transparent!=true));}
+if(this.singleTile){OpenLayers.Util.applyDefaults(this.params,this.SINGLE_TILE_PARAMS);}else{OpenLayers.Util.applyDefaults(this.params,this.TILE_PARAMS);this.setTileSize(this.defaultSize);}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapGuide(this.name,this.url,this.params,this.options);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){var url;var center=bounds.getCenterLonLat();var mapSize=this.map.getCurrentSize();if(this.singleTile){var params={};params.setdisplaydpi=OpenLayers.DOTS_PER_INCH;params.setdisplayheight=mapSize.h*this.ratio;params.setdisplaywidth=mapSize.w*this.ratio;params.setviewcenterx=center.lon;params.setviewcentery=center.lat;params.setviewscale=this.map.getScale();if(!this.isBaseLayer){this.params.operation="GETDYNAMICMAPOVERLAYIMAGE";var getVisParams={};getVisParams.operation="GETVISIBLEMAPEXTENT";getVisParams.version="1.0.0";getVisParams.session=this.params.session;getVisParams.mapName=this.params.mapName;getVisParams.format='text/xml';getVisParams=OpenLayers.Util.extend(getVisParams,params);new OpenLayers.Ajax.Request(this.url,{parameters:getVisParams,method:'get',asynchronous:false});}
+url=this.getFullRequestString(params);}else{var currentRes=this.map.getResolution();var colidx=Math.floor((bounds.left-this.maxExtent.left)/currentRes);colidx=Math.round(colidx/this.tileSize.w);var rowidx=Math.floor((this.maxExtent.top-bounds.top)/currentRes);rowidx=Math.round(rowidx/this.tileSize.h);url=this.getFullRequestString({tilecol:colidx,tilerow:rowidx,scaleindex:this.resolutions.length-this.map.zoom-1});}
+return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;if(typeof url=="object"){url=url[Math.floor(Math.random()*url.length)];}
+var requestString=url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getArgs(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
+var paramsString=OpenLayers.Util.getParameterString(allParams);paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
+return requestString;},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=extent.top-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=extent.top-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);if(arguments.length>0){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}
+if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="true")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,this.options);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var extent=[bounds.left,bounds.bottom,bounds.right,bounds.top];var imageSize=this.getImageSize();var url=this.getFullRequestString({mapext:extent,imgext:extent,map_size:[imageSize.w,imageSize.h],imgx:imageSize.w/2,imgy:imageSize.h/2,imgxy:[imageSize.w,imageSize.h]});return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
+var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
+paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
+return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",isBaseLayer:true,tileOrigin:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.options);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.map.getZoom();var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
+return url+path;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Layer.TileCache=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,tileOrigin:null,format:'image/png',initialize:function(name,url,layername,options){this.layername=layername;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,{},options]);this.extension=this.format.split('/')[1].toLowerCase();this.extension=(this.extension=='jpg')?'jpeg':this.extension;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TileCache(this.name,this.url,this.layername,this.options);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var res=this.map.getResolution();var bbox=this.maxExtent;var size=this.tileSize;var tileX=Math.round((bounds.left-bbox.left)/(res*size.w));var tileY=Math.round((bounds.bottom-bbox.bottom)/(res*size.h));var tileZ=this.map.zoom;function zeroPad(number,length){number=String(number);var zeros=[];for(var i=0;i<length;++i){zeros.push('0');}
+return zeros.join('').substring(0,length-number.length)+number;}
+var components=[this.layername,zeroPad(tileZ,2),zeroPad(parseInt(tileX/1000000),3),zeroPad((parseInt(tileX/1000)%1000),3),zeroPad((parseInt(tileX)%1000),3),zeroPad(parseInt(tileY/1000000),3),zeroPad((parseInt(tileY/1000)%1000),3),zeroPad((parseInt(tileY)%1000),3)+'.'+this.extension];var path=components.join('/');var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
+url=(url.charAt(url.length-1)=='/')?url:url+'/';return url+path;},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TileCache"});OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",exceptions:"application/vnd.ogc.se_inimage",format:"image/jpeg"},reproject:false,isBaseLayer:true,encodeBBOX:false,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
+if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.options);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={'BBOX':this.encodeBBOX?bounds.toBBOX():bounds.toArray(),'WIDTH':imageSize.w,'HEIGHT':imageSize.h};var requestString=this.getFullRequestString(newParams);return requestString;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var projectionCode=this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:true,lzd:null,zoomLevels:null,initialize:function(name,url,lzd,zoomLevels,params,options){this.lzd=lzd;this.zoomLevels=zoomLevels;var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=(params?params:{});if(params){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getZoom:function(){var zoom=this.map.getZoom();var extent=this.map.getMaxExtent();zoom=zoom-Math.log(this.maxResolution/(this.lzd/512))/Math.log(2);return zoom;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var zoom=this.getZoom();var extent=this.map.getMaxExtent();var deg=this.lzd/Math.pow(2,this.getZoom());var x=Math.floor((bounds.left-extent.left)/deg);var y=Math.floor((bounds.bottom-extent.bottom)/deg);if(this.map.getResolution()<=(this.lzd/512)&&this.getZoom()<=this.zoomLevels){return this.getFullRequestString({L:zoom,X:x,Y:y});}else{return OpenLayers.Util.getImagesLocation()+"blank.gif";}},CLASS_NAME:"OpenLayers.Layer.WorldWind"});OpenLayers.Rule=OpenLayers.Class({id:null,name:'default',title:null,description:null,context:null,filter:null,elseFilter:false,symbolizer:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(options){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.symbolizer={};OpenLayers.Util.extend(this,options);},destroy:function(){for(var i in this.symbolizer){this.symbolizer[i]=null;}
+this.symbolizer=null;},evaluate:function(feature){var context=this.getContext(feature);var applies=true;if(this.minScaleDenominator||this.maxScaleDenominator){var scale=feature.layer.map.getScale();}
+if(this.minScaleDenominator){applies=scale>=OpenLayers.Style.createLiteral(this.minScaleDenominator,context);}
+if(applies&&this.maxScaleDenominator){applies=scale<OpenLayers.Style.createLiteral(this.maxScaleDenominator,context);}
+if(applies&&this.filter){if(this.filter.CLASS_NAME=="OpenLayers.Filter.FeatureId"){applies=this.filter.evaluate(feature);}else{applies=this.filter.evaluate(context);}}
+return applies;},getContext:function(feature){var context=this.context;if(!context){context=feature.attributes||feature.data;}
+return context;},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"])};if(style instanceof OpenLayers.Style){this.styles["default"]=style;this.styles["select"]=style;this.styles["temporary"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles[key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temporary"]=new OpenLayers.Style(style);break;}}}
+OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
+this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
+if(!this.styles[intent]){intent="default";}
+feature.renderIntent=intent;var defaultSymbolizer={};if(this.extendDefault&&intent!="default"){defaultSymbolizer=this.styles["default"].createSymbolizer(feature);}
+return OpenLayers.Util.extend(defaultSymbolizer,this.styles[intent].createSymbolizer(feature));},addUniqueValueRules:function(renderIntent,property,symbolizers){var rules=[];for(var value in symbolizers){rules.push(new OpenLayers.Rule({symbolizer:symbolizers[value],filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:property,value:value})}));}
+this.styles[renderIntent].addRules(rules);},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation(),new OpenLayers.Control.ZoomBox()]);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.NavToolbar"});OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,lowerBoundary:null,upperBoundary:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(context){switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:case OpenLayers.Filter.Comparison.LESS_THAN:case OpenLayers.Filter.Comparison.GREATER_THAN:case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:return this.binaryCompare(context,this.property,this.value);case OpenLayers.Filter.Comparison.BETWEEN:var result=context[this.property]>=this.lowerBoundary;result=result&&context[this.property]<=this.upperBoundary;return result;case OpenLayers.Filter.Comparison.LIKE:var regexp=new RegExp(this.value,"gi");return regexp.test(context[this.property]);}},value2regex:function(wildCard,singleChar,escapeChar){if(wildCard=="."){var msg="'.' is an unsupported wildCard character for "+"OpenLayers.Filter.Comparison";OpenLayers.Console.error(msg);return null;}
+wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar,"g"),"\\");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},binaryCompare:function(context,property,value){switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:return context[property]==value;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:return context[property]!=value;case OpenLayers.Filter.Comparison.LESS_THAN:return context[property]<value;case OpenLayers.Filter.Comparison.GREATER_THAN:return context[property]>value;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:return context[property]<=value;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:return context[property]>=value;}},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_EQUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,initialize:function(options){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){for(var i=0;i<this.fids.length;i++){var fid=feature.fid||feature.id;if(fid==this.fids[i]){return true;}}
+return false;},CLASS_NAME:"OpenLayers.Filter.FeatureId"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(options){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this);},evaluate:function(context){switch(this.type){case OpenLayers.Filter.Logical.AND:for(var i=0;i<this.filters.length;i++){if(this.filters[i].evaluate(context)==false){return false;}}
+return true;case OpenLayers.Filter.Logical.OR:for(var i=0;i<this.filters.length;i++){if(this.filters[i].evaluate(context)==true){return true;}}
+return false;case OpenLayers.Filter.Logical.NOT:return(!this.filters[0].evaluate(context));}},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(components){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];if(components!=null){this.addComponents(components);}},destroy:function(){this.components.length=0;this.components=null;},clone:function(){var geometry=eval("new "+this.CLASS_NAME+"()");for(var i=0;i<this.components.length;i++){geometry.addComponent(this.components[i].clone());}
+OpenLayers.Util.applyDefaults(geometry,this);return geometry;},getComponentsString:function(){var strings=[];for(var i=0;i<this.components.length;i++){strings.push(this.components[i].toShortString());}
+return strings.join(",");},calculateBounds:function(){this.bounds=null;if(this.components&&this.components.length>0){this.setBounds(this.components[0].getBounds());for(var i=1;i<this.components.length;i++){this.extendBounds(this.components[i].getBounds());}}},addComponents:function(components){if(!(components instanceof Array)){components=[components];}
+for(var i=0;i<components.length;i++){this.addComponent(components[i]);}},addComponent:function(component,index){var added=false;if(component){if(this.componentTypes==null||(OpenLayers.Util.indexOf(this.componentTypes,component.CLASS_NAME)>-1)){if(index!=null&&(index<this.components.length)){var components1=this.components.slice(0,index);var components2=this.components.slice(index,this.components.length);components1.push(component);this.components=components1.concat(components2);}else{this.components.push(component);}
+component.parent=this;this.clearBounds();added=true;}}
+return added;},removeComponents:function(components){if(!(components instanceof Array)){components=[components];}
+for(var i=components.length-1;i>=0;--i){this.removeComponent(components[i]);}},removeComponent:function(component){OpenLayers.Util.removeItem(this.components,component);this.clearBounds();},getLength:function(){var length=0.0;for(var i=0;i<this.components.length;i++){length+=this.components[i].getLength();}
+return length;},getArea:function(){var area=0.0;for(var i=0;i<this.components.length;i++){area+=this.components[i].getArea();}
+return area;},move:function(x,y){for(var i=0;i<this.components.length;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0;i<this.components.length;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length;++i){this.components[i].resize(scale,origin,ratio);}},equals:function(geometry){var equivalent=true;if(!geometry||!geometry.CLASS_NAME||(this.CLASS_NAME!=geometry.CLASS_NAME)){equivalent=false;}else if(!(geometry.components instanceof Array)||(geometry.components.length!=this.components.length)){equivalent=false;}else{for(var i=0;i<this.components.length;++i){if(!this.components[i].equals(geometry.components[i])){equivalent=false;break;}}}
+return equivalent;},transform:function(source,dest){if(source&&dest){for(var i=0;i<this.components.length;i++){var component=this.components[i];component.transform(source,dest);}}
+return this;},intersects:function(geometry){var intersect=false;for(var i=0;i<this.components.length;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
+return intersect;},CLASS_NAME:"OpenLayers.Geometry.Collection"});OpenLayers.Geometry.Point=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,initialize:function(x,y){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=parseFloat(x);this.y=parseFloat(y);},clone:function(obj){if(obj==null){obj=new OpenLayers.Geometry.Point(this.x,this.y);}
+OpenLayers.Util.applyDefaults(obj,this);return obj;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x,this.y);},distanceTo:function(point){var distance=0.0;if((this.x!=null)&&(this.y!=null)&&(point!=null)&&(point.x!=null)&&(point.y!=null)){var dx2=Math.pow(this.x-point.x,2);var dy2=Math.pow(this.y-point.y,2);distance=Math.sqrt(dx2+dy2);}
+return distance;},equals:function(geom){var equals=false;if(geom!=null){equals=((this.x==geom.x&&this.y==geom.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(geom.x)&&isNaN(geom.y)));}
+return equals;},toShortString:function(){return(this.x+", "+this.y);},move:function(x,y){this.x=this.x+x;this.y=this.y+y;this.clearBounds();},rotate:function(angle,origin){angle*=Math.PI/180;var radius=this.distanceTo(origin);var theta=angle+Math.atan2(this.y-origin.y,this.x-origin.x);this.x=origin.x+(radius*Math.cos(theta));this.y=origin.y+(radius*Math.sin(theta));this.clearBounds();},resize:function(scale,origin,ratio){ratio=(ratio==undefined)?1:ratio;this.x=origin.x+(scale*ratio*(this.x-origin.x));this.y=origin.y+(scale*(this.y-origin.y));this.clearBounds();},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.equals(geometry);}else{intersect=geometry.intersects(this);}
+return intersect;},transform:function(source,dest){if((source&&dest)){OpenLayers.Projection.transform(this,source,dest);}
+return this;},CLASS_NAME:"OpenLayers.Geometry.Point"});OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(x,y,width,height){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=x;this.y=y;this.width=width;this.height=height;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height);},getLength:function(){var length=(2*this.width)+(2*this.height);return length;},getArea:function(){var area=this.width*this.height;return area;},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});OpenLayers.Geometry.Surface=OpenLayers.Class(OpenLayers.Geometry,{initialize:function(){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.Surface"});OpenLayers.Layer.MapServer.Untiled=OpenLayers.Class(OpenLayers.Layer.MapServer,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.MapServer.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.MapServer.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.MapServer class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer.Untiled(this.name,this.url,this.params,this.options);}
+obj=OpenLayers.Layer.MapServer.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.MapServer.Untiled"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{EVENT_TYPES:["beforefeatureadded","featureadded","featuresadded","featureselected","featureunselected","beforefeaturemodified","featuremodified","afterfeaturemodified"],isBaseLayer:false,isFixed:false,isVector:true,features:null,selectedFeatures:null,reportError:true,style:null,styleMap:null,renderers:['SVG','VML'],renderer:null,geometryType:null,drawn:false,initialize:function(name,options){this.EVENT_TYPES=OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(OpenLayers.Layer.prototype.EVENT_TYPES);OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
+if(!this.renderer||!this.renderer.supported()){this.renderer=null;this.displayError();}
+if(!this.styleMap){this.styleMap=new OpenLayers.StyleMap();}
+this.features=[];this.selectedFeatures=[];},destroy:function(){OpenLayers.Layer.prototype.destroy.apply(this,arguments);this.destroyFeatures();this.features=null;this.selectedFeatures=null;if(this.renderer){this.renderer.destroy();}
+this.renderer=null;this.geometryType=null;this.drawn=null;},assignRenderer:function(){for(var i=0;i<this.renderers.length;i++){var rendererClass=OpenLayers.Renderer[this.renderers[i]];if(rendererClass&&rendererClass.prototype.supported()){this.renderer=new rendererClass(this.div);break;}}},displayError:function(){if(this.reportError){alert(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(!dragging){this.renderer.root.style.visibility="hidden";if(navigator.userAgent.toLowerCase().indexOf("gecko")!=-1){this.div.scrollLeft=this.div.scrollLeft;}
+this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();this.renderer.setExtent(extent);this.renderer.root.style.visibility="visible";}
+if(!this.drawn||zoomChanged){this.drawn=true;for(var i=0;i<this.features.length;i++){var feature=this.features[i];this.drawFeature(feature);}}},addFeatures:function(features,options){if(!(features instanceof Array)){features=[features];}
+var notify=!options||!options.silent;for(var i=0;i<features.length;i++){var feature=features[i];if(this.geometryType&&!(feature.geometry instanceof this.geometryType)){var throwStr=OpenLayers.i18n('componentShouldBe',{'geomType':this.geometryType.prototype.CLASS_NAME});throw throwStr;}
+this.features.push(feature);feature.layer=this;if(!feature.style&&this.style){feature.style=OpenLayers.Util.extend({},this.style);}
+if(notify){this.events.triggerEvent("beforefeatureadded",{feature:feature});this.preFeatureInsert(feature);}
+if(this.drawn){this.drawFeature(feature);}
+if(notify){this.events.triggerEvent("featureadded",{feature:feature});this.onFeatureInsert(feature);}}
+if(notify){this.events.triggerEvent("featuresadded",{features:features});}},removeFeatures:function(features){if(!(features instanceof Array)){features=[features];}
+for(var i=features.length-1;i>=0;i--){var feature=features[i];this.features=OpenLayers.Util.removeItem(this.features,feature);if(feature.geometry){this.renderer.eraseGeometry(feature.geometry);}
+if(OpenLayers.Util.indexOf(this.selectedFeatures,feature)!=-1){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}}},destroyFeatures:function(features){var all=(features==undefined);if(all){features=this.features;this.selectedFeatures=[];}
+this.eraseFeatures(features);var feature;for(var i=features.length-1;i>=0;i--){feature=features[i];if(!all){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}
+feature.destroy();}},drawFeature:function(feature,style){if(typeof style!="object"){var renderIntent=typeof style=="string"?style:feature.renderIntent;style=feature.style||this.style;if(!style){style=this.styleMap.createSymbolizer(feature,renderIntent);}}
+this.renderer.drawFeature(feature,style);},eraseFeatures:function(features){this.renderer.eraseFeatures(features);},getFeatureFromEvent:function(evt){if(!this.renderer){OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));return null;}
+var featureId=this.renderer.getFeatureIdFromEvent(evt);return this.getFeatureById(featureId);},getFeatureById:function(featureId){var feature=null;for(var i=0;i<this.features.length;++i){if(this.features[i].id==featureId){feature=this.features[i];break;}}
+return feature;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.WMS.Untiled=OpenLayers.Class(OpenLayers.Layer.WMS,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.WMS.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.WMS.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.WMS class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS.Untiled(this.name,this.url,this.params,this.options);}
+obj=OpenLayers.Layer.WMS.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.WMS.Untiled"});OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(sld,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
+version;}
+this.parser=new format(this.options);}
+var root=this.parser.write(sld);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
+if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
+version;}
+var sld=this.parser.read(data);return sld;},CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Text=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(text){var lines=text.split('\n');var columns;var features=[];for(var lcv=0;lcv<(lines.length-1);lcv++){var currLine=lines[lcv].replace(/^\s*/,'').replace(/\s*$/,'');if(currLine.charAt(0)!='#'){if(!columns){columns=currLine.split('\t');}else{var vals=currLine.split('\t');var geometry=new OpenLayers.Geometry.Point(0,0);var attributes={};var style={};var icon,iconSize,iconOffset,overflow;var set=false;for(var valIndex=0;valIndex<vals.length;valIndex++){if(vals[valIndex]){if(columns[valIndex]=='point'){var coords=vals[valIndex].split(',');geometry.y=parseFloat(coords[0]);geometry.x=parseFloat(coords[1]);set=true;}else if(columns[valIndex]=='lat'){geometry.y=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='lon'){geometry.x=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='title')
+attributes['title']=vals[valIndex];else if(columns[valIndex]=='image'||columns[valIndex]=='icon')
+style['externalGraphic']=vals[valIndex];else if(columns[valIndex]=='iconSize'){var size=vals[valIndex].split(',');style['graphicWidth']=parseFloat(size[0]);style['graphicHeight']=parseFloat(size[1]);}else if(columns[valIndex]=='iconOffset'){var offset=vals[valIndex].split(',');style['graphicXOffset']=parseFloat(offset[0]);style['graphicYOffset']=parseFloat(offset[1]);}else if(columns[valIndex]=='description'){attributes['description']=vals[valIndex];}else if(columns[valIndex]=='overflow'){attributes['overflow']=vals[valIndex];}}}
+if(set){if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
+var feature=new OpenLayers.Feature.Vector(geometry,attributes,style);features.push(feature);}}}}
+return features;},CLASS_NAME:"OpenLayers.Format.Text"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},addPoint:function(point,index){this.addComponent(point,index);},removePoint:function(point){this.removeComponent(point);},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1;i<this.components.length;i++){area-=Math.abs(this.components[i].getArea());}}
+return area;},containsPoint:function(point){var numRings=this.components.length;var contained=false;if(numRings>0){contained=this.components[0].containsPoint(point);if(contained!==1){if(contained&&numRings>1){var hole;for(var i=1;i<numRings;++i){hole=this.components[i].containsPoint(point);if(hole){if(hole===1){contained=1;}else{contained=false;}
+break;}}}}}
+return contained;},intersects:function(geometry){var intersect=false;var i;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"||geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){for(i=0;i<this.components.length;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
+if(!intersect){for(i=0;i<geometry.components.length;++i){intersect=this.containsPoint(geometry.components[i]);if(intersect){break;}}}}else{for(i=0;i<geometry.components.length;++i){intersect=this.intersects(geometry.components[i]);if(intersect){break;}}}
+if(!intersect&&geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){var ring=this.components[0];for(i=0;i<ring.components.length;++i){intersect=geometry.containsPoint(ring.components[i]);if(intersect){break;}}}
+return intersect;},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(origin,radius,sides,rotation){var angle=Math.PI*((1/sides)-(1/2));if(rotation){angle+=(rotation/180)*Math.PI;}
+var rotatedAngle,x,y;var points=[];for(var i=0;i<sides;++i){rotatedAngle=angle+(i*2*Math.PI/sides);x=origin.x+(radius*Math.cos(rotatedAngle));y=origin.y+(radius*Math.sin(rotatedAngle));points.push(new OpenLayers.Geometry.Point(x,y));}
+var ring=new OpenLayers.Geometry.LinearRing(points);return new OpenLayers.Geometry.Polygon([ring]);};OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,drawing:false,mouseDown:false,lastDown:null,lastUp:null,initialize:function(control,callbacks,options){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
+var options={displayInLayerSwitcher:false,calculateInRange:function(){return true;}};this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(){this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
+if(this.drawing){this.cancel();}
+if(this.layer.map!=null){this.layer.destroy(false);}
+this.layer=null;return true;},destroyFeature:function(){if(this.point){this.point.destroy();}
+this.point=null;},finalize:function(){this.layer.renderer.clear();this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.callback("done",[this.geometryClone()]);this.destroyFeature();},cancel:function(){this.layer.renderer.clear();this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.callback("cancel",[this.geometryClone()]);this.destroyFeature();},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.point.geometry.clone();},mousedown:function(evt){if(!this.checkModifiers(evt)){return true;}
+if(this.lastDown&&this.lastDown.equals(evt.xy)){return true;}
+if(this.lastDown==null){this.createFeature();}
+this.lastDown=evt.xy;this.drawing=true;var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.drawFeature();return false;},mousemove:function(evt){if(this.drawing){var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.point.geometry.clearBounds();this.drawFeature();}
+return true;},mouseup:function(evt){if(this.drawing){this.finalize();return false;}else{return true;}},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Layer.GML=OpenLayers.Class(OpenLayers.Layer.Vector,{loaded:false,format:null,formatOptions:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);this.url=url;},setVisibility:function(visibility,noEvent){OpenLayers.Layer.Vector.prototype.setVisibility.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadGML();}},loadGML:function(){if(!this.loaded){var results=OpenLayers.loadURL(this.url,null,this,this.requestSuccess,this.requestFailure);this.loaded=true;}},setUrl:function(url){this.url=url;this.destroyFeatures();this.loaded=false;this.events.triggerEvent("loadstart");this.loadGML();},requestSuccess:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
+var gml=this.format?new this.format(options):new OpenLayers.Format.GML(options);this.addFeatures(gml.read(doc));this.events.triggerEvent("loadend");},requestFailure:function(request){alert(OpenLayers.i18n("errorLoadingGML",{'url':this.url}));this.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Layer.GML"});OpenLayers.Layer.PointTrack=OpenLayers.Class(OpenLayers.Layer.Vector,{dataFrom:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},addNodes:function(pointFeatures){if(pointFeatures.length<2){OpenLayers.Console.error("At least two point features have to be added to create"+"a line from");return;}
+var lines=new Array(pointFeatures.length-1);var pointFeature,startPoint,endPoint;for(var i=0;i<pointFeatures.length;i++){pointFeature=pointFeatures[i];endPoint=pointFeature.geometry;if(!endPoint){var lonlat=pointFeature.lonlat;endPoint=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else if(endPoint.CLASS_NAME!="OpenLayers.Geometry.Point"){OpenLayers.Console.error("Only features with point geometries are supported.");return;}
+if(i>0){var attributes=(this.dataFrom!=null)?(pointFeatures[i+this.dataFrom].data||pointFeatures[i+this.dataFrom].attributes):null;var line=new OpenLayers.Geometry.LineString([startPoint,endPoint]);lines[i-1]=new OpenLayers.Feature.Vector(line,attributes);}
+startPoint=endPoint;}
+this.addFeatures(lines);},CLASS_NAME:"OpenLayers.Layer.PointTrack"});OpenLayers.Layer.PointTrack.dataFrom={'SOURCE_NODE':-1,'TARGET_NODE':0};OpenLayers.Layer.WFS=OpenLayers.Class(OpenLayers.Layer.Vector,OpenLayers.Layer.Markers,{isBaseLayer:false,tile:null,ratio:2,DEFAULT_PARAMS:{service:"WFS",version:"1.0.0",request:"GetFeature"},featureClass:null,format:null,formatObject:null,formatOptions:null,vectorMode:true,encodeBBOX:false,extractAttributes:false,initialize:function(name,url,params,options){if(options==undefined){options={};}
+if(options.featureClass||!OpenLayers.Layer.Vector||!OpenLayers.Feature.Vector){this.vectorMode=false;}
+OpenLayers.Util.extend(options,{'reportError':false});var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);if(!this.renderer||!this.vectorMode){this.vectorMode=false;if(!options.featureClass){options.featureClass=OpenLayers.Feature.WFS;}
+OpenLayers.Layer.Markers.prototype.initialize.apply(this,newArguments);}
+if(this.params&&this.params.typename&&!this.options.typename){this.options.typename=this.params.typename;}
+if(!this.options.geometry_column){this.options.geometry_column="the_geom";}
+this.params=params;OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));this.url=url;},destroy:function(){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.destroy.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);}
+if(this.tile){this.tile.destroy();}
+this.tile=null;this.ratio=null;this.featureClass=null;this.format=null;if(this.formatObject&&this.formatObject.destroy){this.formatObject.destroy();}
+this.formatObject=null;this.formatOptions=null;this.vectorMode=null;this.encodeBBOX=null;this.extractAttributes=null;},setMap:function(map){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);var options={'extractAttributes':this.extractAttributes};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
+this.formatObject=this.format?new this.format(options):new OpenLayers.Format.GML(options);}else{OpenLayers.Layer.Markers.prototype.setMap.apply(this,arguments);}},moveTo:function(bounds,zoomChanged,dragging){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);}
+if(dragging){return false;}
+if(zoomChanged){if(this.vectorMode){this.renderer.clear();}}
+if(this.options.minZoomLevel){OpenLayers.Console.warn(OpenLayers.i18n('minZoomLevelError'));if(this.map.getZoom()<this.options.minZoomLevel){return null;}}
+if(bounds==null){bounds=this.map.getExtent();}
+var firstRendering=(this.tile==null);var outOfBounds=(!firstRendering&&!this.tile.bounds.containsBounds(bounds));if(zoomChanged||firstRendering||(!dragging&&outOfBounds)){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var tileSize=this.map.getSize();tileSize.w=tileSize.w*this.ratio;tileSize.h=tileSize.h*this.ratio;var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var pos=this.map.getLayerPxFromLonLat(ul);var url=this.getFullRequestString();var params={BBOX:this.encodeBBOX?tileBounds.toBBOX():tileBounds.toArray()};if(this.map&&!this.projection.equals(this.map.getProjectionObject())){var projectedBounds=tileBounds.clone();projectedBounds.transform(this.map.getProjectionObject(),this.projection);params.BBOX=this.encodeBBOX?projectedBounds.toBBOX():projectedBounds.toArray();}
+url+="&"+OpenLayers.Util.getParameterString(params);if(!this.tile){this.tile=new OpenLayers.Tile.WFS(this,pos,tileBounds,url,tileSize);this.addTileMonitoringHooks(this.tile);this.tile.draw();}else{if(this.vectorMode){this.destroyFeatures();this.renderer.clear();}else{this.clearMarkers();}
+this.removeTileMonitoringHooks(this.tile);this.tile.destroy();this.tile=null;this.tile=new OpenLayers.Tile.WFS(this,pos,tileBounds,url,tileSize);this.addTileMonitoringHooks(this.tile);this.tile.draw();}}},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this==this.layer.tile){this.layer.events.triggerEvent("loadstart");}};tile.events.register("loadstart",tile,tile.onLoadStart);tile.onLoadEnd=function(){if(this==this.layer.tile){this.layer.events.triggerEvent("tileloaded");this.layer.events.triggerEvent("loadend");}};tile.events.register("loadend",tile,tile.onLoadEnd);tile.events.register("unload",tile,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:tile});},onMapResize:function(){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.onMapResize.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.onMapResize.apply(this,arguments);}},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.HTTPRequest.prototype.mergeNewParams.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WFS(this.name,this.url,this.params,this.options);}
+if(this.vectorMode){obj=OpenLayers.Layer.Vector.prototype.clone.apply(this,[obj]);}else{obj=OpenLayers.Layer.Markers.prototype.clone.apply(this,[obj]);}
+return obj;},getFullRequestString:function(newParams,altUrl){var projectionCode=this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},commit:function(){if(!this.writer){var options={};if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
+this.writer=new OpenLayers.Format.WFS(options,this);}
+var data=this.writer.write(this.features);var url=this.url;var success=OpenLayers.Function.bind(this.commitSuccess,this);var failure=OpenLayers.Function.bind(this.commitFailure,this);new OpenLayers.Ajax.Request(url,{method:'post',postBody:data,onComplete:success,onFailure:failure});},commitSuccess:function(request){var response=request.responseText;if(response.indexOf('SUCCESS')!=-1){this.commitReport(OpenLayers.i18n("commitSuccess",{'response':response}));for(var i=0;i<this.features.length;i++){this.features[i].state=null;}}else if(response.indexOf('FAILED')!=-1||response.indexOf('Exception')!=-1){this.commitReport(OpenLayers.i18n("commitFailed",{'response':response}));}},commitFailure:function(request){},commitReport:function(string,response){alert(string);},refresh:function(){if(this.tile){if(this.vectorMode){this.renderer.clear();this.features.length=0;}else{this.clearMarkers();this.markers.length=0;}
+this.tile.draw();}},CLASS_NAME:"OpenLayers.Layer.WFS"});OpenLayers.Format.SLD.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{sld:"http://www.opengis.net/sld",ogc:"http://www.opengis.net/ogc",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"sld",schemaLocation:null,defaultSymbolizer:{fillColor:"#808080",fillOpacity:1,strokeColor:"#000000",strokeOpacity:1,strokeWidth:1,pointRadius:6},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var sld={namedLayers:{}};this.readChildNodes(data,sld);return sld;},readers:{"sld":{"StyledLayerDescriptor":function(node,sld){sld.version=node.getAttribute("version");this.readChildNodes(node,sld);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj.description=this.getChildValue(node);},"NamedLayer":function(node,sld){var layer={userStyles:[],namedStyles:[]};this.readChildNodes(node,layer);for(var i=0;i<layer.userStyles.length;++i){layer.userStyles[i].layerName=layer.name;}
+sld.namedLayers[layer.name]=layer;},"NamedStyle":function(node,layer){layer.namedStyles.push(this.getChildName(node.firstChild));},"UserStyle":function(node,layer){var style=new OpenLayers.Style(this.defaultSymbolizer);this.readChildNodes(node,style);layer.userStyles.push(style);},"IsDefault":function(node,style){if(this.getChildValue(node)=="1"){style.isDefault=true;}},"FeatureTypeStyle":function(node,style){var obj={rules:[]};this.readChildNodes(node,obj);style.rules=obj.rules;},"Rule":function(node,obj){var rule=new OpenLayers.Rule();this.readChildNodes(node,rule);obj.rules.push(rule);},"ElseFilter":function(node,rule){rule.elseFilter=true;},"MinScaleDenominator":function(node,rule){rule.minScaleDenominator=this.getChildValue(node);},"MaxScaleDenominator":function(node,rule){rule.maxScaleDenominator=this.getChildValue(node);},"LineSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Line"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Line"]=symbolizer;},"PolygonSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Polygon"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Polygon"]=symbolizer;},"PointSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Point"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Point"]=symbolizer;},"Stroke":function(node,symbolizer){this.readChildNodes(node,symbolizer);},"Fill":function(node,symbolizer){this.readChildNodes(node,symbolizer);},"CssParameter":function(node,symbolizer){var cssProperty=node.getAttribute("name");var symProperty=this.cssMap[cssProperty];if(symProperty){var value=this.readOgcExpression(node);if(value){symbolizer[symProperty]=value;}}},"Graphic":function(node,symbolizer){var graphic={};this.readChildNodes(node,graphic);var properties=["strokeColor","strokeWidth","strokeOpacity","strokeLinecap","fillColor","fillOpacity","graphicName","rotation","graphicFormat"];var prop,value;for(var i=0;i<properties.length;++i){prop=properties[i];value=graphic[prop];if(value!=undefined){symbolizer[prop]=value;}}
+if(graphic.opacity!=undefined){symbolizer.graphicOpacity=graphic.opacity;}
+if(graphic.size!=undefined){symbolizer.pointRadius=graphic.size;}
+if(graphic.href!=undefined){symbolizer.externalGraphic=graphic.href;}},"ExternalGraphic":function(node,graphic){this.readChildNodes(node,graphic);},"Mark":function(node,graphic){this.readChildNodes(node,graphic);},"WellKnownName":function(node,graphic){graphic.graphicName=this.getChildValue(node);},"Opacity":function(node,obj){var opacity=this.getChildValue(node);if(opacity){obj.opacity=opacity;}},"Size":function(node,obj){var size=this.getChildValue(node);if(size){obj.size=size;}},"Rotation":function(node,obj){var rotation=this.getChildValue(node);if(rotation){obj.rotation=rotation;}},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Format":function(node,graphic){graphic.graphicFormat=this.getChildValue(node);}},"ogc":{"Filter":function(node,rule){var obj={fids:[],filters:[]};this.readChildNodes(node,obj);if(obj.fids.length>0){rule.filter=new OpenLayers.Filter.FeatureId({fids:obj.fids});}else if(obj.filters.length>0){rule.filter=obj.filters[0];}},"FeatureId":function(node,obj){var fid=node.getAttribute("fid");if(fid){obj.fids.push(fid);}},"And":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});this.readChildNodes(node,filter);obj.filters.push(filter);},"Or":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.OR});this.readChildNodes(node,filter);obj.filters.push(filter);},"Not":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsBetween":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLike":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(node,filter);var wildCard=node.getAttribute("wildCard");var singleChar=node.getAttribute("singleChar");var esc=node.getAttribute("escape");filter.value2regex(wildCard,singleChar,esc);obj.filters.push(filter);},"Literal":function(node,obj){obj.value=this.getChildValue(node);},"PropertyName":function(node,filter){filter.property=this.getChildValue(node);},"LowerBoundary":function(node,filter){filter.lowerBoundary=this.readOgcExpression(node);},"UpperBoundary":function(node,filter){filter.upperBoundary=this.readOgcExpression(node);}}},readOgcExpression:function(node){var obj={};this.readChildNodes(node,obj);var value=obj.value;if(!value){value=this.getChildValue(node);}
+return value;},cssMap:{"stroke":"strokeColor","stroke-opacity":"strokeOpacity","stroke-width":"strokeWidth","stroke-linecap":"strokeLinecap","fill":"fillColor","fill-opacity":"fillOpacity"},getCssProperty:function(sym){var css=null;for(var prop in this.cssMap){if(this.cssMap[prop]==sym){css=prop;break;}}
+return css;},getGraphicFormat:function(href){var format,regex;for(var key in this.graphicFormats){if(this.graphicFormats[key].test(href)){format=key;break;}}
+return format||this.defautlGraphicFormat;},defaultGraphicFormat:"image/png",graphicFormats:{"image/jpeg":/\.jpe?g$/i,"image/gif":/\.gif$/i,"image/png":/\.png$/i},write:function(sld){return this.writers.sld.StyledLayerDescriptor.apply(this,[sld]);},writers:{"sld":{"StyledLayerDescriptor":function(sld){var root=this.createElementNSPlus("StyledLayerDescriptor",{attributes:{"version":this.VERSION,"xsi:schemaLocation":this.schemaLocation}});if(sld.name){this.writeNode(root,"Name",sld.name);}
+if(sld.title){this.writeNode(root,"Title",sld.title);}
+if(sld.description){this.writeNode(root,"Abstract",sld.description);}
+for(var name in sld.namedLayers){this.writeNode(root,"NamedLayer",sld.namedLayers[name]);}
+return root;},"Name":function(name){return this.createElementNSPlus("Name",{value:name});},"Title":function(title){return this.createElementNSPlus("Title",{value:title});},"Abstract":function(description){return this.createElementNSPlus("Abstract",{value:description});},"NamedLayer":function(layer){var node=this.createElementNSPlus("NamedLayer");this.writeNode(node,"Name",layer.name);if(layer.namedStyles){for(var i=0;i<layer.namedStyles.length;++i){this.writeNode(node,"NamedStyle",layer.namedStyles[i]);}}
+if(layer.userStyles){for(var i=0;i<layer.userStyles.length;++i){this.writeNode(node,"UserStyle",layer.userStyles[i]);}}
+return node;},"NamedStyle":function(name){var node=this.createElementNSPlus("NamedStyle");this.writeNode(node,"Name",name);return node;},"UserStyle":function(style){var node=this.createElementNSPlus("UserStyle");if(style.name){this.writeNode(node,"Name",style.name);}
+if(style.title){this.writeNode(node,"Title",style.title);}
+if(style.description){this.writeNode(node,"Abstract",style.description);}
+if(style.isDefault){this.writeNode(node,"IsDefault",style.isDefault);}
+this.writeNode(node,"FeatureTypeStyle",style);return node;},"IsDefault":function(bool){return this.createElementNSPlus("IsDefault",{value:(bool)?"1":"0"});},"FeatureTypeStyle":function(style){var node=this.createElementNSPlus("FeatureTypeStyle");for(var i=0;i<style.rules.length;++i){this.writeNode(node,"Rule",style.rules[i]);}
+return node;},"Rule":function(rule){var node=this.createElementNSPlus("Rule");if(rule.name){this.writeNode(node,"Name",rule.name);}
+if(rule.title){this.writeNode(node,"Title",rule.title);}
+if(rule.description){this.writeNode(node,"Abstract",rule.description);}
+if(rule.elseFilter){this.writeNode(node,"ElseFilter");}else if(rule.filter){this.writeNode(node,"ogc:Filter",rule.filter);}
+if(rule.minScaleDenominator!=undefined){this.writeNode(node,"MinScaleDenominator",rule.minScaleDenominator);}
+if(rule.maxScaleDenominator!=undefined){this.writeNode(node,"MaxScaleDenominator",rule.maxScaleDenominator);}
+var types=OpenLayers.Style.SYMBOLIZER_PREFIXES;var type,symbolizer;for(var i=0;i<types.length;++i){type=types[i];symbolizer=rule.symbolizer[type];if(symbolizer){this.writeNode(node,type+"Symbolizer",symbolizer);}}
+return node;},"ElseFilter":function(){return this.createElementNSPlus("ElseFilter");},"MinScaleDenominator":function(scale){return this.createElementNSPlus("MinScaleDenominator",{value:scale});},"MaxScaleDenominator":function(scale){return this.createElementNSPlus("MaxScaleDenominator",{value:scale});},"LineSymbolizer":function(symbolizer){var node=this.createElementNSPlus("LineSymbolizer");this.writeNode(node,"Stroke",symbolizer);return node;},"Stroke":function(symbolizer){var node=this.createElementNSPlus("Stroke");if(symbolizer.strokeColor!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeColor"});}
+if(symbolizer.strokeOpacity!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeOpacity"});}
+if(symbolizer.strokeWidth!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeWidth"});}
+return node;},"CssParameter":function(obj){return this.createElementNSPlus("CssParameter",{attributes:{name:this.getCssProperty(obj.key)},value:obj.symbolizer[obj.key]});},"PolygonSymbolizer":function(symbolizer){var node=this.createElementNSPlus("PolygonSymbolizer");this.writeNode(node,"Fill",symbolizer);this.writeNode(node,"Stroke",symbolizer);return node;},"Fill":function(symbolizer){var node=this.createElementNSPlus("Fill");if(symbolizer.fillColor){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"fillColor"});}
+if(symbolizer.fillOpacity){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"fillOpacity"});}
+return node;},"PointSymbolizer":function(symbolizer){var node=this.createElementNSPlus("PointSymbolizer");this.writeNode(node,"Graphic",symbolizer);return node;},"Graphic":function(symbolizer){var node=this.createElementNSPlus("Graphic");if(symbolizer.externalGraphic!=undefined){this.writeNode(node,"ExternalGraphic",symbolizer);}else if(symbolizer.graphicName){this.writeNode(node,"Mark",symbolizer);}
+if(symbolizer.graphicOpacity!=undefined){this.writeNode(node,"Opacity",symbolizer.graphicOpacity);}
+if(symbolizer.pointRadius!=undefined){this.writeNode(node,"Size",symbolizer.pointRadius);}
+if(symbolizer.rotation!=undefined){this.writeNode(node,"Rotation",symbolizer.rotation);}
+return node;},"ExternalGraphic":function(symbolizer){var node=this.createElementNSPlus("ExternalGraphic");this.writeNode(node,"OnlineResource",symbolizer.externalGraphic);var format=symbolizer.graphicFormat||this.getGraphicFormat(symbolizer.externalGraphic);this.writeNode(node,"Format",format);return node;},"Mark":function(symbolizer){var node=this.createElementNSPlus("Mark");this.writeNode(node,"WellKnownName",symbolizer.graphicName);this.writeNode(node,"Fill",symbolizer);this.writeNode(node,"Stroke",symbolizer);return node;},"WellKnownName":function(name){return this.createElementNSPlus("WellKnownName",{value:name});},"Opacity":function(value){return this.createElementNSPlus("Opacity",{value:value});},"Size":function(value){return this.createElementNSPlus("Size",{value:value});},"Rotation":function(value){return this.createElementNSPlus("Rotation",{value:value});},"OnlineResource":function(href){return this.createElementNSPlus("OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":href}});},"Format":function(format){return this.createElementNSPlus("Format",{value:format});}},"ogc":{"Filter":function(filter){var node=this.createElementNSPlus("ogc:Filter");var sub=filter.CLASS_NAME.split(".").pop();if(sub=="FeatureId"){for(var i=0;i<filter.fids.length;++i){this.writeNode(node,"FeatureId",filter.fids[i]);}}else{this.writeNode(node,this.getFilterType(filter),filter);}
+return node;},"FeatureId":function(fid){return this.createElementNSPlus("ogc:FeatureId",{attributes:{fid:fid}});},"And":function(filter){var node=this.createElementNSPlus("ogc:And");var childFilter;for(var i=0;i<filter.filters.length;++i){childFilter=filter.filters[i];this.writeNode(node,this.getFilterType(childFilter),childFilter);}
+return node;},"Or":function(filter){var node=this.createElementNSPlus("ogc:Or");var childFilter;for(var i=0;i<filter.filters.length;++i){childFilter=filter.filters[i];this.writeNode(node,this.getFilterType(childFilter),childFilter);}
+return node;},"Not":function(filter){var node=this.createElementNSPlus("ogc:Not");var childFilter=filter.filters[0];this.writeNode(node,this.getFilterType(childFilter),childFilter);return node;},"PropertyIsEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsNotEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsNotEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsLessThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThan");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsGreaterThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThan");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsLessThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsGreaterThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsBetween":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsBetween");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"LowerBoundary",filter);this.writeNode(node,"UpperBoundary",filter);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{wildCard:"*",singleChar:".",escape:"!"}});this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.regex2value());return node;},"PropertyName":function(filter){return this.createElementNSPlus("ogc:PropertyName",{value:filter.property});},"Literal":function(value){return this.createElementNSPlus("ogc:Literal",{value:value});},"LowerBoundary":function(filter){var node=this.createElementNSPlus("ogc:LowerBoundary");this.writeNode(node,"Literal",filter.lowerBoundary);return node;},"UpperBoundary":function(filter){var node=this.createElementNSPlus("ogc:UpperBoundary");this.writeNode(node,"Literal",filter.upperBoundary);return node;}}},getFilterType:function(filter){var filterType=this.filterMap[filter.type];if(!filterType){throw"SLD writing not supported for rule type: "+filter.type;}
+return filterType;},filterMap:{"&&":"And","||":"Or","!":"Not","==":"PropertyIsEqualTo","!=":"PropertyIsNotEqualTo","<":"PropertyIsLessThan",">":"PropertyIsGreaterThan","<=":"PropertyIsLessThanOrEqualTo",">=":"PropertyIsGreaterThanOrEqualTo","..":"PropertyIsBetween","~":"PropertyIsLike"},getNamespacePrefix:function(uri){var prefix=null;if(uri==null){prefix=this.namespaces[this.defaultPrefix];}else{var gotPrefix=false;for(prefix in this.namespaces){if(this.namespaces[prefix]==uri){gotPrefix=true;break;}}
+if(!gotPrefix){prefix=null;}}
+return prefix;},readChildNodes:function(node,obj){var children=node.childNodes;var child,group,reader,prefix,local;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){prefix=this.getNamespacePrefix(child.namespaceURI);local=child.nodeName.split(":").pop();group=this.readers[prefix];if(group){reader=group[local];if(reader){reader.apply(this,[child,obj]);}}}}},writeNode:function(parent,name,obj){var prefix,local;var split=name.indexOf(":");if(split>0){prefix=name.substring(0,split);local=name.substring(split+1);}else{prefix=this.getNamespacePrefix(parent.namespaceURI);local=name;}
+var child=this.writers[prefix][local].apply(this,[obj]);parent.appendChild(child);return child;},createElementNSPlus:function(name,options){options=options||{};var loc=name.indexOf(":");var uri=options.uri||this.namespaces[options.prefix];if(!uri){loc=name.indexOf(":");uri=this.namespaces[name.substring(0,loc)];}
+if(!uri){uri=this.namespaces[this.defaultPrefix];}
+var node=this.createElementNS(uri,name);if(options.attributes){this.setAttributes(node,options.attributes);}
+if(options.value){node.appendChild(this.createTextNode(options.value));}
+return node;},setAttributes:function(node,obj){var value,loc,alias,uri;for(var name in obj){value=obj[name].toString();uri=this.namespaces[name.substring(0,name.indexOf(":"))]||null;this.setAttributeNS(node,uri,name,value);}},CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,arguments);},getLength:function(){var length=0.0;if(this.components&&(this.components.length>1)){for(var i=1;i<this.components.length;i++){length+=this.components[i-1].distanceTo(this.components[i]);}}
+return length;},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",initialize:function(options){OpenLayers.Format.SLD.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{initialize:function(points){OpenLayers.Geometry.Curve.prototype.initialize.apply(this,arguments);},removeComponent:function(point){if(this.components&&(this.components.length>2)){OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);}},intersects:function(geometry){var intersect=false;var type=geometry.CLASS_NAME;if(type=="OpenLayers.Geometry.LineString"||type=="OpenLayers.Geometry.LinearRing"||type=="OpenLayers.Geometry.Point"){var segs1=this.getSortedSegments();var segs2;if(type=="OpenLayers.Geometry.Point"){segs2=[{x1:geometry.x,y1:geometry.y,x2:geometry.x,y2:geometry.y}];}else{segs2=geometry.getSortedSegments();}
+var seg1,seg1x1,seg1x2,seg1y1,seg1y2,seg2,seg2y1,seg2y2;outer:for(var i=0;i<segs1.length;++i){seg1=segs1[i];seg1x1=seg1.x1;seg1x2=seg1.x2;seg1y1=seg1.y1;seg1y2=seg1.y2;inner:for(var j=0;j<segs2.length;++j){seg2=segs2[j];if(seg2.x1>seg1x2){break;}
+if(seg2.x2<seg1x1){continue;}
+seg2y1=seg2.y1;seg2y2=seg2.y2;if(Math.min(seg2y1,seg2y2)>Math.max(seg1y1,seg1y2)){continue;}
+if(Math.max(seg2y1,seg2y2)<Math.min(seg1y1,seg1y2)){continue;}
+if(OpenLayers.Geometry.segmentsIntersect(seg1,seg2)){intersect=true;break outer;}}}}else{intersect=geometry.intersects(this);}
+return intersect;},getSortedSegments:function(){var numSeg=this.components.length-1;var segments=new Array(numSeg);for(var i=0;i<numSeg;++i){point1=this.components[i];point2=this.components[i+1];if(point1.x<point2.x){segments[i]={x1:point1.x,y1:point1.y,x2:point2.x,y2:point2.y};}else{segments[i]={x1:point2.x,y1:point2.y,x2:point1.x,y2:point1.y};}}
+function byX1(seg1,seg2){return seg1.x1-seg2.x1;}
+return segments.sort(byX1);},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:true,xy:true,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var featureNodes=this.getElementsByTagNameNS(data.documentElement,this.gmlns,this.featureName);var features=[];for(var i=0;i<featureNodes.length;i++){var feature=this.parseFeature(featureNodes[i]);if(feature){features.push(feature);}}
+return features;},parseFeature:function(node){var order=["MultiPolygon","Polygon","MultiLineString","LineString","MultiPoint","Point","Envelope"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];nodeList=this.getElementsByTagNameNS(node,this.gmlns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
+break;}}
+var attributes;if(this.extractAttributes){attributes=this.parseAttributes(node);}
+var feature=new OpenLayers.Feature.Vector(geometry,attributes);var childNode=node.firstChild;var fid;while(childNode){if(childNode.nodeType==1){fid=childNode.getAttribute("fid")||childNode.getAttribute("id");if(fid){break;}}
+childNode=childNode.nextSibling;}
+feature.fid=fid;return feature;},parseGeometry:{point:function(node){var nodeList,coordString;var coords=[];var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"pos");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
+if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}}
+if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coord");if(nodeList.length>0){var xList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"X");var yList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"Y");if(xList.length>0&&yList.length>0){coords=[xList[0].firstChild.nodeValue,yList[0].firstChild.nodeValue];}}}
+if(coords.length==2){coords[2]=null;}
+if(this.xy){return new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}
+else{return new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}},multipoint:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Point");var components=[];if(nodeList.length>0){var point;for(var i=0;i<nodeList.length;++i){point=this.parseGeometry.point.apply(this,[nodeList[i]]);if(point){components.push(point);}}}
+return new OpenLayers.Geometry.MultiPoint(components);},linestring:function(node,ring){var nodeList,coordString;var coords=[];var points=[];nodeList=this.getElementsByTagNameNS(node,this.gmlns,"posList");if(nodeList.length>0){coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);var dim=parseInt(nodeList[0].getAttribute("dimension"));var j,x,y,z;for(var i=0;i<coords.length/dim;++i){j=i*dim;x=coords[j];y=coords[j+1];z=(dim==2)?null:coords[j+2];if(this.xy){points.push(new OpenLayers.Geometry.Point(x,y,z));}else{points.push(new OpenLayers.Geometry.Point(y,x,z));}}}
+if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);for(var i=0;i<pointList.length;++i){coords=pointList[i].split(",");if(coords.length==2){coords[2]=null;}
+if(this.xy){points.push(new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]));}else{points.push(new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]));}}}}
+var line=null;if(points.length!=0){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}
+return line;},multilinestring:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LineString");var components=[];if(nodeList.length>0){var line;for(var i=0;i<nodeList.length;++i){line=this.parseGeometry.linestring.apply(this,[nodeList[i]]);if(line){components.push(line);}}}
+return new OpenLayers.Geometry.MultiLineString(components);},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LinearRing");var components=[];if(nodeList.length>0){var ring;for(var i=0;i<nodeList.length;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components.push(ring);}}}
+return new OpenLayers.Geometry.Polygon(components);},multipolygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Polygon");var components=[];if(nodeList.length>0){var polygon;for(var i=0;i<nodeList.length;++i){polygon=this.parseGeometry.polygon.apply(this,[nodeList[i]]);if(polygon){components.push(polygon);}}}
+return new OpenLayers.Geometry.MultiPolygon(components);},envelope:function(node){var components=[];var coordString;var envelope;var lpoint=this.getElementsByTagNameNS(node,this.gmlns,"lowerCorner");if(lpoint.length>0){var coords=[];if(lpoint.length>0){coordString=lpoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
+if(this.xy){var lowerPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var lowerPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
+var upoint=this.getElementsByTagNameNS(node,this.gmlns,"upperCorner");if(upoint.length>0){var coords=[];if(upoint.length>0){coordString=upoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
+if(this.xy){var upperPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var upperPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
+if(lowerPoint&&upperPoint){components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));var ring=new OpenLayers.Geometry.LinearRing(components);envelope=new OpenLayers.Geometry.Polygon([ring]);}
+return envelope;}},parseAttributes:function(node){var attributes={};var childNode=node.firstChild;var children,i,child,grandchildren,grandchild,name,value;while(childNode){if(childNode.nodeType==1){children=childNode.childNodes;for(i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length==1){grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}
+break;}
+return attributes;},write:function(features){if(!(features instanceof Array)){features=[features];}
+var gml=this.createElementNS("http://www.opengis.net/wfs","wfs:"+this.collectionName);for(var i=0;i<features.length;i++){gml.appendChild(this.createFeatureXML(features[i]));}
+return OpenLayers.Format.XML.prototype.write.apply(this,[gml]);},createFeatureXML:function(feature){var geometry=feature.geometry;var geometryNode=this.buildGeometryNode(geometry);var geomContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
+this.geometryName);geomContainer.appendChild(geometryNode);var featureNode=this.createElementNS(this.gmlns,"gml:"+this.featureName);var featureContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
+this.layerName);var fid=feature.fid||feature.id;featureContainer.setAttribute("fid",fid);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr.substring(attr.lastIndexOf(":")+1);var attrContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
+nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
+featureNode.appendChild(featureContainer);return featureNode;},buildGeometryNode:function(geometry){if(this.externalProjection&&this.internalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];return builder.apply(this,[geometry]);},buildGeometry:{point:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Point");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multipoint:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPoint");var points=geometry.components;var pointMember,pointGeom;for(var i=0;i<points.length;i++){pointMember=this.createElementNS(this.gmlns,"gml:pointMember");pointGeom=this.buildGeometry.point.apply(this,[points[i]]);pointMember.appendChild(pointGeom);gml.appendChild(pointMember);}
+return gml;},linestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LineString");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multilinestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiLineString");var lines=geometry.components;var lineMember,lineGeom;for(var i=0;i<lines.length;++i){lineMember=this.createElementNS(this.gmlns,"gml:lineStringMember");lineGeom=this.buildGeometry.linestring.apply(this,[lines[i]]);lineMember.appendChild(lineGeom);gml.appendChild(lineMember);}
+return gml;},linearring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LinearRing");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},polygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0;i<rings.length;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.gmlns,"gml:"+type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[i]]);ringMember.appendChild(ringGeom);gml.appendChild(ringMember);}
+return gml;},multipolygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPolygon");var polys=geometry.components;var polyMember,polyGeom;for(var i=0;i<polys.length;++i){polyMember=this.createElementNS(this.gmlns,"gml:polygonMember");polyGeom=this.buildGeometry.polygon.apply(this,[polys[i]]);polyMember.appendChild(polyGeom);gml.appendChild(polyMember);}
+return gml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.gmlns,"gml:coordinates");coordinatesNode.setAttribute("decimal",".");coordinatesNode.setAttribute("cs",",");coordinatesNode.setAttribute("ts"," ");var points=(geometry.components)?geometry.components:[geometry];var parts=[];for(var i=0;i<points.length;i++){parts.push(points[i].x+","+points[i].y);}
+var txtNode=this.createTextNode(parts.join(" "));coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.GML"});OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{initialize:function(options){OpenLayers.Format.JSON.prototype.initialize.apply(this,[options]);},read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
+if(!obj){OpenLayers.Console.error("Bad JSON: "+json);}else if(typeof(obj.type)!="string"){OpenLayers.Console.error("Bad GeoJSON - no type: "+json);}else if(this.isValidType(obj,type)){switch(type){case"Geometry":try{results=this.parseGeometry(obj);}catch(err){OpenLayers.Console.error(err);}
+break;case"Feature":try{results=this.parseFeature(obj);results.type="Feature";}catch(err){OpenLayers.Console.error(err);}
+break;case"FeatureCollection":results=[];switch(obj.type){case"Feature":try{results.push(this.parseFeature(obj));}catch(err){results=null;OpenLayers.Console.error(err);}
+break;case"FeatureCollection":for(var i=0;i<obj.features.length;++i){try{results.push(this.parseFeature(obj.features[i]));}catch(err){results=null;OpenLayers.Console.error(err);}}
+break;default:try{var geom=this.parseGeometry(obj);results.push(new OpenLayers.Feature.Vector(geom));}catch(err){results=null;OpenLayers.Console.error(err);}}
+break;}}
+return results;},isValidType:function(obj,type){var valid=false;switch(type){case"Geometry":if(OpenLayers.Util.indexOf(["Point","MultiPoint","LineString","MultiLineString","Polygon","MultiPolygon","Box","GeometryCollection"],obj.type)==-1){OpenLayers.Console.error("Unsupported geometry type: "+
+obj.type);}else{valid=true;}
+break;case"FeatureCollection":valid=true;break;default:if(obj.type==type){valid=true;}else{OpenLayers.Console.error("Cannot convert types from "+
+obj.type+" to "+type);}}
+return valid;},parseFeature:function(obj){var feature,geometry,attributes;attributes=(obj.properties)?obj.properties:{};try{geometry=this.parseGeometry(obj.geometry);}catch(err){throw err;}
+feature=new OpenLayers.Feature.Vector(geometry,attributes);if(obj.id){feature.fid=obj.id;}
+return feature;},parseGeometry:function(obj){var geometry;if(obj.type=="GeometryCollection"){if(!(obj.geometries instanceof Array)){throw"GeometryCollection must have geometries array: "+obj;}
+var numGeom=obj.geometries.length;var components=new Array(numGeom);for(var i=0;i<numGeom;++i){components[i]=this.parseGeometry.apply(this,[obj.geometries[i]]);}
+geometry=new OpenLayers.Geometry.Collection(components);}else{if(!(obj.coordinates instanceof Array)){throw"Geometry must have coordinates array: "+obj;}
+if(!this.parseCoords[obj.type.toLowerCase()]){throw"Unsupported geometry type: "+obj.type;}
+try{geometry=this.parseCoords[obj.type.toLowerCase()].apply(this,[obj.coordinates]);}catch(err){throw err;}}
+if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
+return geometry;},parseCoords:{"point":function(array){if(array.length!=2){throw"Only 2D points are supported: "+array;}
+return new OpenLayers.Geometry.Point(array[0],array[1]);},"multipoint":function(array){var points=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
+points.push(p);}
+return new OpenLayers.Geometry.MultiPoint(points);},"linestring":function(array){var points=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
+points.push(p);}
+return new OpenLayers.Geometry.LineString(points);},"multilinestring":function(array){var lines=[];var l=null;for(var i=0;i<array.length;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
+lines.push(l);}
+return new OpenLayers.Geometry.MultiLineString(lines);},"polygon":function(array){var rings=[];var r,l;for(var i=0;i<array.length;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
+r=new OpenLayers.Geometry.LinearRing(l.components);rings.push(r);}
+return new OpenLayers.Geometry.Polygon(rings);},"multipolygon":function(array){var polys=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["polygon"].apply(this,[array[i]]);}catch(err){throw err;}
+polys.push(p);}
+return new OpenLayers.Geometry.MultiPolygon(polys);},"box":function(array){if(array.length!=2){throw"GeoJSON box coordinates must have 2 elements";}
+return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(array[0][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[0][1])])]);}},write:function(obj,pretty){var geojson={"type":null};if(obj instanceof Array){geojson.type="FeatureCollection";var numFeatures=obj.length;geojson.features=new Array(numFeatures);for(var i=0;i<numFeatures;++i){var element=obj[i];if(!element instanceof OpenLayers.Feature.Vector){var msg="FeatureCollection only supports collections "+"of features: "+element;throw msg;}
+geojson.features[i]=this.extract.feature.apply(this,[element]);}}else if(obj.CLASS_NAME.indexOf("OpenLayers.Geometry")==0){geojson=this.extract.geometry.apply(this,[obj]);}else if(obj instanceof OpenLayers.Feature.Vector){geojson=this.extract.feature.apply(this,[obj]);if(obj.layer&&obj.layer.projection){geojson.crs=this.createCRSObject(obj);}}
+return OpenLayers.Format.JSON.prototype.write.apply(this,[geojson,pretty]);},createCRSObject:function(object){var proj=object.layer.projection.toString();var crs={};if(proj.match(/epsg:/i)){var code=parseInt(proj.substring(proj.indexOf(":")+1));if(code==4326){crs={"type":"OGC","properties":{"urn":"urn:ogc:def:crs:OGC:1.3:CRS84"}};}else{crs={"type":"EPSG","properties":{"code":code}};}}
+return crs;},extract:{'feature':function(feature){var geom=this.extract.geometry.apply(this,[feature.geometry]);return{"type":"Feature","id":feature.fid==null?feature.id:feature.fid,"properties":feature.attributes,"geometry":geom};},'geometry':function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var geometryType=geometry.CLASS_NAME.split('.')[2];var data=this.extract[geometryType.toLowerCase()].apply(this,[geometry]);var json;if(geometryType=="Collection"){json={"type":"GeometryCollection","geometries":data};}else{json={"type":geometryType,"coordinates":data};}
+return json;},'point':function(point){return[point.x,point.y];},'multipoint':function(multipoint){var array=[];for(var i=0;i<multipoint.components.length;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
+return array;},'linestring':function(linestring){var array=[];for(var i=0;i<linestring.components.length;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
+return array;},'multilinestring':function(multilinestring){var array=[];for(var i=0;i<multilinestring.components.length;++i){array.push(this.extract.linestring.apply(this,[multilinestring.components[i]]));}
+return array;},'polygon':function(polygon){var array=[];for(var i=0;i<polygon.components.length;++i){array.push(this.extract.linestring.apply(this,[polygon.components[i]]));}
+return array;},'multipolygon':function(multipolygon){var array=[];for(var i=0;i<multipolygon.components.length;++i){array.push(this.extract.polygon.apply(this,[multipolygon.components[i]]));}
+return array;},'collection':function(collection){var len=collection.components.length;var array=new Array(len);for(var i=0;i<len;++i){array[i]=this.extract.geometry.apply(this,[collection.components[i]]);}
+return array;}},CLASS_NAME:"OpenLayers.Format.GeoJSON"});OpenLayers.Format.GeoRSS=OpenLayers.Class(OpenLayers.Format.XML,{rssns:"http://backend.userland.com/rss2",featureNS:"http://mapserver.gis.umn.edu/mapserver",georssns:"http://www.georss.org/georss",geons:"http://www.w3.org/2003/01/geo/wgs84_pos#",featureTitle:"Untitled",featureDescription:"No Description",gmlParser:null,xy:false,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},createGeometryFromItem:function(item){var point=this.getElementsByTagNameNS(item,this.georssns,"point");var lat=this.getElementsByTagNameNS(item,this.geons,'lat');var lon=this.getElementsByTagNameNS(item,this.geons,'long');var line=this.getElementsByTagNameNS(item,this.georssns,"line");var polygon=this.getElementsByTagNameNS(item,this.georssns,"polygon");var where=this.getElementsByTagNameNS(item,this.georssns,"where");if(point.length>0||(lat.length>0&&lon.length>0)){var location;if(point.length>0){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s+/);if(location.length!=2){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s*,\s*/);}}else{location=[parseFloat(lat[0].firstChild.nodeValue),parseFloat(lon[0].firstChild.nodeValue)];}
+var geometry=new OpenLayers.Geometry.Point(parseFloat(location[1]),parseFloat(location[0]));}else if(line.length>0){var coords=OpenLayers.String.trim(line[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;for(var i=0;i<coords.length;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
+geometry=new OpenLayers.Geometry.LineString(components);}else if(polygon.length>0){var coords=OpenLayers.String.trim(polygon[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;for(var i=0;i<coords.length;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
+geometry=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(components)]);}else if(where.length>0){if(!this.gmlParser){this.gmlParser=new OpenLayers.Format.GML({'xy':this.xy});}
+var feature=this.gmlParser.parseFeature(where[0]);geometry=feature.geometry;}
+if(geometry&&this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
+return geometry;},createFeatureFromItem:function(item){var geometry=this.createGeometryFromItem(item);var title=this.getChildValue(item,"*","title",this.featureTitle);var description=this.getChildValue(item,"*","description",this.getChildValue(item,"*","content",this.featureDescription));var link=this.getChildValue(item,"*","link");if(!link){try{link=this.getElementsByTagNameNS(item,"*","link")[0].getAttribute("href");}catch(e){link=null;}}
+var id=this.getChildValue(item,"*","id",null);var data={"title":title,"description":description,"link":link};var feature=new OpenLayers.Feature.Vector(geometry,data);feature.fid=id;return feature;},getChildValue:function(node,nsuri,name,def){var value;try{value=this.getElementsByTagNameNS(node,nsuri,name)[0].firstChild.nodeValue;}catch(e){value=(def==undefined)?"":def;}
+return value;},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
+var itemlist=null;itemlist=this.getElementsByTagNameNS(doc,'*','item');if(itemlist.length==0){itemlist=this.getElementsByTagNameNS(doc,'*','entry');}
+var numItems=itemlist.length;var features=new Array(numItems);for(var i=0;i<numItems;i++){features[i]=this.createFeatureFromItem(itemlist[i]);}
+return features;},write:function(features){var georss;if(features instanceof Array){georss=this.createElementNS(this.rssns,"rss");for(var i=0;i<features.length;i++){georss.appendChild(this.createFeatureXML(features[i]));}}else{georss=this.createFeatureXML(features);}
+return OpenLayers.Format.XML.prototype.write.apply(this,[georss]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var featureNode=this.createElementNS(this.rssns,"item");var titleNode=this.createElementNS(this.rssns,"title");titleNode.appendChild(this.createTextNode(feature.attributes.title?feature.attributes.title:""));var descNode=this.createElementNS(this.rssns,"description");descNode.appendChild(this.createTextNode(feature.attributes.description?feature.attributes.description:""));featureNode.appendChild(titleNode);featureNode.appendChild(descNode);if(feature.attributes.link){var linkNode=this.createElementNS(this.rssns,"link");linkNode.appendChild(this.createTextNode(feature.attributes.link));featureNode.appendChild(linkNode);}
+for(var attr in feature.attributes){if(attr=="link"||attr=="title"||attr=="description"){continue;}
+var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
+var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureNode.appendChild(attrContainer);}
+featureNode.appendChild(geometryNode);return featureNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var node;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){node=this.createElementNS(this.georssns,'georss:polygon');node.appendChild(this.buildCoordinatesNode(geometry.components[0]));}
+else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){node=this.createElementNS(this.georssns,'georss:line');node.appendChild(this.buildCoordinatesNode(geometry));}
+else if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){node=this.createElementNS(this.georssns,'georss:point');node.appendChild(this.buildCoordinatesNode(geometry));}else{throw"Couldn't parse "+geometry.CLASS_NAME;}
+return node;},buildCoordinatesNode:function(geometry){var points=null;if(geometry.components){points=geometry.components;}
+var path;if(points){var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;i++){parts[i]=points[i].y+" "+points[i].x;}
+path=parts.join(" ");}else{path=geometry.y+" "+geometry.x;}
+return this.createTextNode(path);},CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Format.KML=OpenLayers.Class(OpenLayers.Format.XML,{kmlns:"http://earth.google.com/kml/2.0",placemarksDesc:"No description available",foldersName:"OpenLayers export",foldersDesc:"Exported on "+new Date(),extractAttributes:true,extractStyles:false,internalns:null,features:null,styles:null,styleBaseUrl:"",fetched:null,maxDepth:0,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g),kmlColor:(/(\w{2})(\w{2})(\w{2})(\w{2})/),kmlIconPalette:(/root:\/\/icons\/palette-(\d+)(\.\w+)/),straightBracket:(/\$\[(.*?)\]/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){this.features=[];this.styles={};this.fetched={};var options={depth:this.maxDepth,styleBaseUrl:this.styleBaseUrl};return this.parseData(data,options);},parseData:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var types=["Link","NetworkLink","Style","StyleMap","Placemark"];for(var i=0;i<types.length;++i){var type=types[i];var nodes=this.getElementsByTagNameNS(data,"*",type);if(nodes.length==0){continue;}
+switch(type.toLowerCase()){case"link":case"networklink":this.parseLinks(nodes,options);break;case"style":if(this.extractStyles){this.parseStyles(nodes,options);}
+break;case"stylemap":if(this.extractStyles){this.parseStyleMaps(nodes,options);}
+break;case"placemark":this.parseFeatures(nodes,options);break;}}
+return this.features;},parseLinks:function(nodes,options){if(options.depth>=this.maxDepth){return false;}
+var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;for(var i=0;i<nodes.length;i++){var href=this.parseProperty(nodes[i],"*","href");if(href&&!this.fetched[href]){this.fetched[href]=true;var data=this.fetchLink(href);if(data){this.parseData(data,newOptions);}}}},fetchLink:function(href){var request=new OpenLayers.Ajax.Request(href,{method:'get',asynchronous:false});if(request&&request.transport){return request.transport.responseText;}},parseStyles:function(nodes,options){for(var i=0;i<nodes.length;i++){var style=this.parseStyle(nodes[i]);if(style){styleName=(options.styleBaseUrl||"")+"#"+style.id;this.styles[styleName]=style;}}},parseStyle:function(node){var style={};var types=["LineStyle","PolyStyle","IconStyle","BalloonStyle"];var type,nodeList,geometry,parser;for(var i=0;i<types.length;++i){type=types[i];styleTypeNode=this.getElementsByTagNameNS(node,"*",type)[0];if(!styleTypeNode){continue;}
+switch(type.toLowerCase()){case"linestyle":var color=this.parseProperty(styleTypeNode,"*","color");if(color){var matches=(color.toString()).match(this.regExes.kmlColor);var alpha=matches[1];style["strokeOpacity"]=parseInt(alpha,16)/255;var b=matches[2];var g=matches[3];var r=matches[4];style["strokeColor"]="#"+r+g+b;}
+var width=this.parseProperty(styleTypeNode,"*","width");if(width){style["strokeWidth"]=width;}
+case"polystyle":var color=this.parseProperty(styleTypeNode,"*","color");if(color){var matches=(color.toString()).match(this.regExes.kmlColor);var alpha=matches[1];style["fillOpacity"]=parseInt(alpha,16)/255;var b=matches[2];var g=matches[3];var r=matches[4];style["fillColor"]="#"+r+g+b;}
+break;case"iconstyle":var scale=parseFloat(this.parseProperty(styleTypeNode,"*","scale")||1);var width=32*scale;var height=32*scale;var iconNode=this.getElementsByTagNameNS(styleTypeNode,"*","Icon")[0];if(iconNode){var href=this.parseProperty(iconNode,"*","href");if(href){var w=this.parseProperty(iconNode,"*","w");var h=this.parseProperty(iconNode,"*","h");var google="http://maps.google.com/mapfiles/kml";if(OpenLayers.String.startsWith(href,google)&&!w&&!h){w=64;h=64;scale=scale/2;}
+w=w||h;h=h||w;if(w){width=parseInt(w)*scale;}
+if(h){height=parseInt(h)*scale;}
+var matches=href.match(this.regExes.kmlIconPalette);if(matches){var palette=matches[1];var file_extension=matches[2];var x=this.parseProperty(iconNode,"*","x");var y=this.parseProperty(iconNode,"*","y");var posX=x?x/32:0;var posY=y?(7-y/32):7;var pos=posY*8+posX;href="http://maps.google.com/mapfiles/kml/pal"
++palette+"/icon"+pos+file_extension;}
+style["graphicOpacity"]=1;style["externalGraphic"]=href;}}
+var hotSpotNode=this.getElementsByTagNameNS(styleTypeNode,"*","hotSpot")[0];if(hotSpotNode){var x=parseFloat(hotSpotNode.getAttribute("x"));var y=parseFloat(hotSpotNode.getAttribute("y"));var xUnits=hotSpotNode.getAttribute("xunits");if(xUnits=="pixels"){style["graphicXOffset"]=-x*scale;}
+else if(xUnits=="insetPixels"){style["graphicXOffset"]=-width+(x*scale);}
+else if(xUnits=="fraction"){style["graphicXOffset"]=-width*x;}
+var yUnits=hotSpotNode.getAttribute("yunits");if(yUnits=="pixels"){style["graphicYOffset"]=-height+(y*scale)+1;}
+else if(yUnits=="insetPixels"){style["graphicYOffset"]=-(y*scale)+1;}
+else if(yUnits=="fraction"){style["graphicYOffset"]=-height*(1-y)+1;}}
+style["graphicWidth"]=width;style["graphicHeight"]=height;break;case"balloonstyle":var balloonStyle=OpenLayers.Util.getXmlNodeValue(styleTypeNode);if(balloonStyle){style["balloonStyle"]=balloonStyle.replace(this.regExes.straightBracket,"${$1}");}
+break;default:}}
+if(!style["strokeColor"]&&style["fillColor"]){style["strokeColor"]=style["fillColor"];}
+var id=node.getAttribute("id");if(id&&style){style.id=id;}
+return style;},parseStyleMaps:function(nodes,options){for(var i=0;i<nodes.length;i++){var node=nodes[i];var pairs=this.getElementsByTagNameNS(node,"*","Pair");var id=node.getAttribute("id");for(var j=0;j<pairs.length;j++){var pair=pairs[j];var key=this.parseProperty(pair,"*","key");var styleUrl=this.parseProperty(pair,"*","styleUrl");if(styleUrl&&key=="normal"){this.styles[(options.styleBaseUrl||"")+"#"+id]=this.styles[(options.styleBaseUrl||"")+styleUrl];}
+if(styleUrl&&key=="highlight"){}}}},parseFeatures:function(nodes,options){var features=new Array(nodes.length);for(var i=0;i<nodes.length;i++){var featureNode=nodes[i];var feature=this.parseFeature.apply(this,[featureNode]);if(feature){if(this.extractStyles&&feature.attributes&&feature.attributes.styleUrl){feature.style=this.getStyle(feature.attributes.styleUrl);}
+var inlineStyleNode=this.getElementsByTagNameNS(featureNode,"*","Style")[0];if(inlineStyleNode){var inlineStyle=this.parseStyle(inlineStyleNode);if(inlineStyle){feature.style=OpenLayers.Util.extend({},feature.style);OpenLayers.Util.extend(feature.style,inlineStyle);}}
+features[i]=feature;}else{throw"Bad Placemark: "+i;}}
+this.features=this.features.concat(features);},parseFeature:function(node){var order=["MultiGeometry","Polygon","LineString","Point"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];this.internalns=node.namespaceURI?node.namespaceURI:this.kmlns;nodeList=this.getElementsByTagNameNS(node,this.internalns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
+break;}}
+var feature=new OpenLayers.Feature.Vector(geometry,attributes);var fid=node.getAttribute("id")||node.getAttribute("name");if(fid!=null){feature.fid=fid;}
+return feature;},getStyle:function(styleUrl,options){var styleBaseUrl=OpenLayers.Util.removeTail(styleUrl);var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;newOptions.styleBaseUrl=styleBaseUrl;if(!this.styles[styleUrl]&&!OpenLayers.String.startsWith(styleUrl,"#")&&newOptions.depth<=this.maxDepth&&!this.fetched[styleBaseUrl]){var data=this.fetchLink(styleBaseUrl);if(data){this.parseData(data,newOptions);}}
+var style=this.styles[styleUrl];return style;},parseGeometry:{point:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var coords=[];if(nodeList.length>0){var coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}
+var point=null;if(coords.length>1){if(coords.length==2){coords[2]=null;}
+point=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad coordinate string: "+coordString;}
+return point;},linestring:function(node,ring){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var line=null;if(nodeList.length>0){var coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);var numPoints=pointList.length;var points=new Array(numPoints);var coords,numCoords;for(var i=0;i<numPoints;++i){coords=pointList[i].split(",");numCoords=coords.length;if(numCoords>1){if(coords.length==2){coords[2]=null;}
+points[i]=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad LineString point coordinates: "+
+pointList[i];}}
+if(numPoints){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}else{throw"Bad LineString coordinates: "+coordString;}}
+return line;},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"LinearRing");var numRings=nodeList.length;var components=new Array(numRings);if(numRings>0){var ring;for(var i=0;i<nodeList.length;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components[i]=ring;}else{throw"Bad LinearRing geometry: "+i;}}}
+return new OpenLayers.Geometry.Polygon(components);},multigeometry:function(node){var child,parser;var parts=[];var children=node.childNodes;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){var type=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var parser=this.parseGeometry[type.toLowerCase()];if(parser){parts.push(parser.apply(this,[child]));}}}
+return new OpenLayers.Geometry.Collection(parts);}},parseAttributes:function(node){var attributes={};var child,grandchildren,grandchild;var children=node.childNodes;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length==1||grandchildren.length==3){var grandchild;switch(grandchildren.length){case 1:grandchild=grandchildren[0];break;case 3:default:grandchild=grandchildren[1];break;}
+if(grandchild.nodeType==3||grandchild.nodeType==4){var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var value=OpenLayers.Util.getXmlNodeValue(grandchild);if(value){value=value.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
+return attributes;},parseProperty:function(xmlNode,namespace,tagName){var value;var nodeList=this.getElementsByTagNameNS(xmlNode,namespace,tagName);try{value=OpenLayers.Util.getXmlNodeValue(nodeList[0]);}catch(e){value=null;}
+return value;},write:function(features){if(!(features instanceof Array)){features=[features];}
+var kml=this.createElementNS(this.kmlns,"kml");var folder=this.createFolderXML();for(var i=0;i<features.length;++i){folder.appendChild(this.createPlacemarkXML(features[i]));}
+kml.appendChild(folder);return OpenLayers.Format.XML.prototype.write.apply(this,[kml]);},createFolderXML:function(){var folderName=this.createElementNS(this.kmlns,"name");var folderNameText=this.createTextNode(this.foldersName);folderName.appendChild(folderNameText);var folderDesc=this.createElementNS(this.kmlns,"description");var folderDescText=this.createTextNode(this.foldersDesc);folderDesc.appendChild(folderDescText);var folder=this.createElementNS(this.kmlns,"Folder");folder.appendChild(folderName);folder.appendChild(folderDesc);return folder;},createPlacemarkXML:function(feature){var placemarkName=this.createElementNS(this.kmlns,"name");var name=(feature.attributes.name)?feature.attributes.name:feature.id;placemarkName.appendChild(this.createTextNode(name));var placemarkDesc=this.createElementNS(this.kmlns,"description");var desc=(feature.attributes.description)?feature.attributes.description:this.placemarksDesc;placemarkDesc.appendChild(this.createTextNode(desc));var placemarkNode=this.createElementNS(this.kmlns,"Placemark");if(feature.fid!=null){placemarkNode.setAttribute("id",feature.fid);}
+placemarkNode.appendChild(placemarkName);placemarkNode.appendChild(placemarkDesc);var geometryNode=this.buildGeometryNode(feature.geometry);placemarkNode.appendChild(geometryNode);return placemarkNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];var node=null;if(builder){node=builder.apply(this,[geometry]);}
+return node;},buildGeometry:{point:function(geometry){var kml=this.createElementNS(this.kmlns,"Point");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multipoint:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linestring:function(geometry){var kml=this.createElementNS(this.kmlns,"LineString");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multilinestring:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linearring:function(geometry){var kml=this.createElementNS(this.kmlns,"LinearRing");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},polygon:function(geometry){var kml=this.createElementNS(this.kmlns,"Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0;i<rings.length;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.kmlns,type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[i]]);ringMember.appendChild(ringGeom);kml.appendChild(ringMember);}
+return kml;},multipolygon:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},collection:function(geometry){var kml=this.createElementNS(this.kmlns,"MultiGeometry");var child;for(var i=0;i<geometry.components.length;++i){child=this.buildGeometryNode.apply(this,[geometry.components[i]]);if(child){kml.appendChild(child);}}
+return kml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.kmlns,"coordinates");var path;var points=geometry.components;if(points){var point;var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;++i){point=points[i];parts[i]=point.x+","+point.y;}
+path=parts.join(" ");}else{path=geometry.x+","+geometry.y;}
+var txtNode=this.createTextNode(path);coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.KML"});OpenLayers.Format.OSM=OpenLayers.Class(OpenLayers.Format.XML,{checkTags:false,interestingTagsExclude:null,areaTags:null,initialize:function(options){var layer_defaults={'interestingTagsExclude':['source','source_ref','source:ref','history','attribution','created_by'],'areaTags':['area','building','leisure','tourism','ruins','historic','landuse','military','natural','sport']};layer_defaults=OpenLayers.Util.extend(layer_defaults,options);var interesting={};for(var i=0;i<layer_defaults.interestingTagsExclude.length;i++){interesting[layer_defaults.interestingTagsExclude[i]]=true;}
+layer_defaults.interestingTagsExclude=interesting;var area={};for(var i=0;i<layer_defaults.areaTags.length;i++){area[layer_defaults.areaTags[i]]=true;}
+layer_defaults.areaTags=area;OpenLayers.Format.XML.prototype.initialize.apply(this,[layer_defaults]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
+var nodes=this.getNodes(doc);var ways=this.getWays(doc);var feat_list=new Array(ways.length);for(var i=0;i<ways.length;i++){var point_list=new Array(ways[i].nodes.length);var poly=this.isWayArea(ways[i])?1:0;for(var j=0;j<ways[i].nodes.length;j++){var node=nodes[ways[i].nodes[j]];var point=new OpenLayers.Geometry.Point(node.lon,node.lat);point.osm_id=parseInt(ways[i].nodes[j]);point_list[j]=point;node.used=true;}
+var geometry=null;if(poly){geometry=new OpenLayers.Geometry.Polygon(new OpenLayers.Geometry.LinearRing(point_list));}else{geometry=new OpenLayers.Geometry.LineString(point_list);}
+var feat=new OpenLayers.Feature.Vector(geometry,ways[i].tags);feat.osm_id=parseInt(ways[i].id);feat.fid="way."+feat.osm_id;feat_list[i]=feat;}
+for(var node_id in nodes){var node=nodes[node_id];if(!node.used||this.checkTags){var tags=null;if(this.checkTags){var result=this.getTags(node.node,true);if(node.used&&!result[1]){continue;}
+tags=result[0];}else{tags=this.getTags(node.node);}
+var feat=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(node['lon'],node['lat']),tags);if(this.internalProjection&&this.externalProjection){feat.geometry.transform(this.externalProjection,this.internalProjection);}
+feat.osm_id=parseInt(node_id);feat.fid="node."+feat.osm_id;feat_list.push(feat);}
+node.node=null;}
+return feat_list;},getNodes:function(doc){var node_list=doc.getElementsByTagName("node");var nodes={};for(var i=0;i<node_list.length;i++){var node=node_list[i];var id=node.getAttribute("id");nodes[id]={'lat':node.getAttribute("lat"),'lon':node.getAttribute("lon"),'node':node};}
+return nodes;},getWays:function(doc){var way_list=doc.getElementsByTagName("way");var return_ways=[];for(var i=0;i<way_list.length;i++){var way=way_list[i];var way_object={id:way.getAttribute("id")};way_object.tags=this.getTags(way);var node_list=way.getElementsByTagName("nd");way_object.nodes=new Array(node_list.length);for(var j=0;j<node_list.length;j++){way_object.nodes[j]=node_list[j].getAttribute("ref");}
+return_ways.push(way_object);}
+return return_ways;},getTags:function(dom_node,interesting_tags){var tag_list=dom_node.getElementsByTagName("tag");var tags={};var interesting=false;for(var j=0;j<tag_list.length;j++){var key=tag_list[j].getAttribute("k");tags[key]=tag_list[j].getAttribute("v");if(interesting_tags){if(!this.interestingTagsExclude[key]){interesting=true;}}}
+return interesting_tags?[tags,interesting]:tags;},isWayArea:function(way){var poly_shaped=false;var poly_tags=false;if(way.nodes[0]==way.nodes[way.nodes.length-1]){poly_shaped=true;}
+if(this.checkTags){for(var key in way.tags){if(this.areaTags[key]){poly_tags=true;break;}}}
+return poly_shaped&&(this.checkTags?poly_tags:true);},write:function(features){if(!(features instanceof Array)){features=[features];}
+this.osm_id=1;this.created_nodes={};var root_node=this.createElementNS(null,"osm");root_node.setAttribute("version","0.5");root_node.setAttribute("generator","OpenLayers "+OpenLayers.VERSION_NUMBER);for(var i=features.length-1;i>=0;i--){var nodes=this.createFeatureNodes(features[i]);for(var j=0;j<nodes.length;j++){root_node.appendChild(nodes[j]);}}
+return OpenLayers.Format.XML.prototype.write.apply(this,[root_node]);},createFeatureNodes:function(feature){var nodes=[];var className=feature.geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);type=type.toLowerCase();var builder=this.createXML[type];if(builder){nodes=builder.apply(this,[feature]);}
+return nodes;},createXML:{'point':function(point){var id=null;var geometry=point.geometry?point.geometry:point;var already_exists=false;if(point.osm_id){id=point.osm_id;if(this.created_nodes[id]){already_exists=true;}}else{id=-this.osm_id;this.osm_id++;}
+if(already_exists){node=this.created_nodes[id];}else{var node=this.createElementNS(null,"node");}
+this.created_nodes[id]=node;node.setAttribute("id",id);node.setAttribute("lon",geometry.x);node.setAttribute("lat",geometry.y);if(point.attributes){this.serializeTags(point,node);}
+this.setState(point,node);return already_exists?[]:[node];},linestring:function(feature){var nodes=[];var geometry=feature.geometry;if(feature.osm_id){id=feature.osm_id;}else{id=-this.osm_id;this.osm_id++;}
+var way=this.createElementNS(null,"way");way.setAttribute("id",id);for(var i=0;i<geometry.components.length;i++){var node=this.createXML['point'].apply(this,[geometry.components[i]]);if(node.length){node=node[0];var node_ref=node.getAttribute("id");nodes.push(node);}else{node_ref=geometry.components[i].osm_id;node=this.created_nodes[node_ref];}
+this.setState(feature,node);var nd_dom=this.createElementNS(null,"nd");nd_dom.setAttribute("ref",node_ref);way.appendChild(nd_dom);}
+this.serializeTags(feature,way);nodes.push(way);return nodes;},polygon:function(feature){var attrs=OpenLayers.Util.extend({'area':'yes'},feature.attributes);var feat=new OpenLayers.Feature.Vector(feature.geometry.components[0],attrs);feat.osm_id=feature.osm_id;return this.createXML['linestring'].apply(this,[feat]);}},serializeTags:function(feature,node){for(var key in feature.attributes){var tag=this.createElementNS(null,"tag");tag.setAttribute("k",key);tag.setAttribute("v",feature.attributes[key]);node.appendChild(tag);}},setState:function(feature,node){if(feature.state){var state=null;switch(feature.state){case OpenLayers.State.UPDATE:state="modify";case OpenLayers.State.DELETE:state="delete";}
+if(state){node.setAttribute("action",state);}}},CLASS_NAME:"OpenLayers.Format.OSM"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.LineString.prototype.initialize.apply(this,arguments);},addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
+var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);return added;},removeComponent:function(point){if(this.components.length>4){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);}},move:function(x,y){for(var i=0;i<this.components.length-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0;i<this.components.length-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length-1;++i){this.components[i].resize(scale,origin,ratio);}},transform:function(source,dest){if(source&&dest){for(var i=0;i<this.components.length-1;i++){var component=this.components[i];component.transform(source,dest);}}
+return this;},getArea:function(){var area=0.0;if(this.components&&(this.components.length>2)){var sum=0.0;for(var i=0;i<this.components.length-1;i++){var b=this.components[i];var c=this.components[i+1];sum+=(b.x+c.x)*(c.y-b.y);}
+area=-sum/2.0;}
+return area;},containsPoint:function(point){var approx=OpenLayers.Number.limitSigDigs;var digs=14;var px=approx(point.x,digs);var py=approx(point.y,digs);function getX(y,x1,y1,x2,y2){return(((x1-x2)*y)+((x2*y1)-(x1*y2)))/(y1-y2);}
+var numSeg=this.components.length-1;var start,end,x1,y1,x2,y2,cx,cy;var crosses=0;for(var i=0;i<numSeg;++i){start=this.components[i];x1=approx(start.x,digs);y1=approx(start.y,digs);end=this.components[i+1];x2=approx(end.x,digs);y2=approx(end.y,digs);if(y1==y2){if(py==y1){if(x1<=x2&&(px>=x1&&px<=x2)||x1>=x2&&(px<=x1&&px>=x2)){crosses=-1;break;}}
+continue;}
+cx=approx(getX(py,x1,y1,x2,y2),digs);if(cx==px){if(y1<y2&&(py>=y1&&py<=y2)||y1>y2&&(py<=y1&&py>=y2)){crosses=-1;break;}}
+if(cx<=px){continue;}
+if(x1!=x2&&(cx<Math.min(x1,x2)||cx>Math.max(x1,x2))){continue;}
+if(y1<y2&&(py>=y1&&py<y2)||y1>y2&&(py<y1&&py>=y2)){++crosses;}}
+var contained=(crosses==-1)?1:!!(crosses&1);return contained;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){intersect=geometry.intersects(this);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){intersect=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[geometry]);}else{for(var i=0;i<geometry.components.length;++i){intersect=geometry.components[i].intersects(this);if(intersect){break;}}}
+return intersect;},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,freehand:false,freehandToggle:'shiftKey',initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(){this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString());this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},destroyFeature:function(){OpenLayers.Handler.Point.prototype.destroyFeature.apply(this);if(this.line){this.line.destroy();}
+this.line=null;},addPoint:function(){this.line.geometry.addComponent(this.point.geometry.clone(),this.line.geometry.components.length);this.callback("point",[this.point.geometry]);},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(){var index=this.line.geometry.components.length-1;this.line.geometry.components[index].x=this.point.geometry.x;this.line.geometry.components[index].y=this.point.geometry.y;this.line.geometry.components[index].clearBounds();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.line.geometry.clone();},mousedown:function(evt){if(this.lastDown&&this.lastDown.equals(evt.xy)){return false;}
+if(this.lastDown==null){this.createFeature();}
+this.mouseDown=true;this.lastDown=evt.xy;var lonlat=this.control.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;if((this.lastUp==null)||!this.lastUp.equals(evt.xy)){this.addPoint();}
+this.drawFeature();this.drawing=true;return false;},mousemove:function(evt){if(this.drawing){var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;if(this.mouseDown&&this.freehandMode(evt)){this.addPoint();}else{this.modifyFeature();}
+this.drawFeature();}
+return true;},mouseup:function(evt){this.mouseDown=false;if(this.drawing){if(this.freehandMode(evt)){this.finalize();}else{if(this.lastUp==null){this.addPoint();}
+this.lastUp=evt.xy;}
+return false;}
+return true;},dblclick:function(evt){if(!this.freehandMode(evt)){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.finalize();}
+return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Format.WFS=OpenLayers.Class(OpenLayers.Format.GML,{layer:null,wfsns:"http://www.opengis.net/wfs",ogcns:"http://www.opengis.net/ogc",initialize:function(options,layer){OpenLayers.Format.GML.prototype.initialize.apply(this,[options]);this.layer=layer;if(this.layer.featureNS){this.featureNS=this.layer.featureNS;}
+if(this.layer.options.geometry_column){this.geometryName=this.layer.options.geometry_column;}
+if(this.layer.options.typename){this.featureName=this.layer.options.typename;}},write:function(features){var transaction=this.createElementNS(this.wfsns,'wfs:Transaction');transaction.setAttribute("version","1.0.0");transaction.setAttribute("service","WFS");for(var i=0;i<features.length;i++){switch(features[i].state){case OpenLayers.State.INSERT:transaction.appendChild(this.insert(features[i]));break;case OpenLayers.State.UPDATE:transaction.appendChild(this.update(features[i]));break;case OpenLayers.State.DELETE:transaction.appendChild(this.remove(features[i]));break;}}
+return OpenLayers.Format.XML.prototype.write.apply(this,[transaction]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var geomContainer=this.createElementNS(this.featureNS,"feature:"+this.geometryName);geomContainer.appendChild(geometryNode);var featureContainer=this.createElementNS(this.featureNS,"feature:"+this.featureName);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
+var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
+return featureContainer;},insert:function(feature){var insertNode=this.createElementNS(this.wfsns,'wfs:Insert');insertNode.appendChild(this.createFeatureXML(feature));return insertNode;},update:function(feature){if(!feature.fid){alert(OpenLayers.i18n("noFID"));}
+var updateNode=this.createElementNS(this.wfsns,'wfs:Update');updateNode.setAttribute("typeName",this.layerName);var propertyNode=this.createElementNS(this.wfsns,'wfs:Property');var nameNode=this.createElementNS(this.wfsns,'wfs:Name');var txtNode=this.createTextNode(this.geometryName);nameNode.appendChild(txtNode);propertyNode.appendChild(nameNode);var valueNode=this.createElementNS(this.wfsns,'wfs:Value');var geometryNode=this.buildGeometryNode(feature.geometry);if(feature.layer){geometryNode.setAttribute("srsName",feature.layer.projection.getCode());}
+valueNode.appendChild(geometryNode);propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);for(var propName in feature.attributes){propertyNode=this.createElementNS(this.wfsns,'wfs:Property');nameNode=this.createElementNS(this.wfsns,'wfs:Name');nameNode.appendChild(this.createTextNode(propName));propertyNode.appendChild(nameNode);valueNode=this.createElementNS(this.wfsns,'wfs:Value');valueNode.appendChild(this.createTextNode(feature.attributes[propName]));propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);}
+var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);updateNode.appendChild(filterNode);return updateNode;},remove:function(feature){if(!feature.fid){alert(OpenLayers.i18n("noFID"));return false;}
+var deleteNode=this.createElementNS(this.wfsns,'wfs:Delete');deleteNode.setAttribute("typeName",this.layerName);var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);deleteNode.appendChild(filterNode);return deleteNode;},destroy:function(){this.layer=null;},CLASS_NAME:"OpenLayers.Format.WFS"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{polygon:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Path.prototype.initialize.apply(this,arguments);},createFeature:function(){this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon());this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing());this.polygon.geometry.addComponent(this.line.geometry);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},destroyFeature:function(){OpenLayers.Handler.Path.prototype.destroyFeature.apply(this);if(this.polygon){this.polygon.destroy();}
+this.polygon=null;},modifyFeature:function(){var index=this.line.geometry.components.length-2;this.line.geometry.components[index].x=this.point.geometry.x;this.line.geometry.components[index].y=this.point.geometry.y;this.line.geometry.components[index].clearBounds();},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.polygon.geometry.clone();},dblclick:function(evt){if(!this.freehandMode(evt)){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.finalize();}
+return false;},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{'displayClass':'olControlDrawFeaturePoint'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{'displayClass':'olControlDrawFeaturePath'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Polygon,{'displayClass':'olControlDrawFeaturePolygon'})];for(var i=0;i<controls.length;i++){controls[i].featureAdded=function(feature){feature.state=OpenLayers.State.INSERT;};}
+this.addControls(controls);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});
\ No newline at end of file
Copied: branches/testbaudson_dev/ext/jqjson.js (from rev 2556, trunk/mapbender/http/extensions/jqjson.js)
--- branches/testbaudson_dev/ext/jqjson.js	                        (rev 0)
+++ branches/testbaudson_dev/ext/jqjson.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,96 @@
+(function ($) {
+    var m = {
+            '\b': '\\b',
+            '\t': '\\t',
+            '\n': '\\n',
+            '\f': '\\f',
+            '\r': '\\r',
+        s = {
+            'array': function (x) {
+                var a = ['['], b, f, i, l = x.length, v;
+                for (i = 0; i < l; i += 1) {
+                    v = x[i];
+                    f = s[typeof v];
+                    if (f) {
+                        v = f(v);
+                        if (typeof v == 'string') {
+                            if (b) {
+                                a[a.length] = ',';
+                            a[a.length] = v;
+                            b = true;
+                a[a.length] = ']';
+                return a.join('');
+            'boolean': function (x) {
+                return String(x);
+            'null': function (x) {
+                return "null";
+            'number': function (x) {
+                return isFinite(x) ? String(x) : 'null';
+            'object': function (x) {
+                if (x) {
+                    if (x instanceof Array) {
+                        return s.array(x);
+                    var a = ['{'], b, f, i, v;
+                    for (i in x) {
+                        v = x[i];
+                        f = s[typeof v];
+                        if (f) {
+                            v = f(v);
+                                if (b) {
+                                a.push(s.string(i), ':', v);
+                                b = true;
+                    a[a.length] = '}';
+                return 'null';
+            'string': function (x) {
+                if (/["\\\x00-\x1f]/.test(x)) {
+                    x = x.replace(/([\x00-\x1f\\"])/g, function(a, b) {
+                        var c = m[b];
+                        if (c) {
+                            return c;
+                        c = b.charCodeAt();
+                        return '\\u00' +
+                            Math.floor(c / 16).toString(16) +
+                            (c % 16).toString(16);
+                return '"' + x + '"';
+	$.toJSON = function(v) {
+		var f = isNaN(v) ? s[typeof v] : s['number'];
+		if (f) return f(v);
+	$.parseJSON = function(v, safe) {
+		if (safe === undefined) safe = $.parseJSON.safe;
+		if (safe && !/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.test(v))
+			return undefined;
+		return eval('('+v+')');
+	$.parseJSON.safe = false;
+})(jQuery);
Copied: branches/testbaudson_dev/ext/jquery-1.2.6.min.js (from rev 2556, trunk/mapbender/http/extensions/jquery-1.2.6.min.js)
--- branches/testbaudson_dev/ext/jquery-1.2.6.min.js	                        (rev 0)
+++ branches/testbaudson_dev/ext/jquery-1.2.6.min.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,32 @@
+ * jQuery 1.2.6 - New Wave Javascript
+ * Copyright (c) 2008 John Resig (jquery.com)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * $Date: 2008-05-24 14:22:17 -0400 (Sat, 24 May 2008) $
+ * $Rev: 5685 $
+(function(){var _jQuery=window.jQuery,_$=window.$;var jQuery=window.jQuery=window.$=function(selector,context){return new jQuery.fn.init(selector,context);};var quickExpr=/^[^<]*(<(.|\s)+>)[^>]*$|^#(\w+)$/,isSimple=/^.[^:#\[\.]*$/,undefined;jQuery.fn=jQuery.prototype={init:function(selector,context){selector=selector||document;if(selector.nodeType){this[0]=selector;this.length=1;return this;}if(typeof selector=="string"){var match=quickExpr.exec(selector);if(match&&(match[1]||!context)){if(match[1])selector=jQuery.clean([match[1]],context);else{var elem=document.getElementById(match[3]);if(elem){if(elem.id!=match[3])return jQuery().find(selector);return jQuery(elem);}selector=[];}}else
+return jQuery(context).find(selector);}else if(jQuery.isFunction(selector))return jQuery(document)[jQuery.fn.ready?"ready":"load"](selector);return this.setArray(jQuery.makeArray(selector));},jquery:"1.2.6",size:function(){return this.length;},length:0,get:function(num){return num==undefined?jQuery.makeArray(this):this[num];},pushStack:function(elems){var ret=jQuery(elems);ret.prevObject=this;return ret;},setArray:function(elems){this.length=0;Array.prototype.push.apply(this,elems);return this;},each:function(callback,args){return jQuery.each(this,callback,args);},index:function(elem){var ret=-1;return jQuery.inArray(elem&&elem.jquery?elem[0]:elem,this);},attr:function(name,value,type){var options=name;if(name.constructor==String)if(value===undefined)return this[0]&&jQuery[type||"attr"](this[0],name);else{options={};options[name]=value;}return this.each(function(i){for(name in options)jQuery.attr(type?this.style:this,name,jQuery.prop(this,options[name],type,i,name));});},css:function(key,value){if((key=='width'||key=='height')&&parseFloat(value)<0)value=undefined;return this.attr(key,value,"curCSS");},text:function(text){if(typeof text!="object"&&text!=null)return this.empty().append((this[0]&&this[0].ownerDocument||document).createTextNode(text));var ret="";jQuery.each(text||this,function(){jQuery.each(this.childNodes,function(){if(this.nodeType!=8)ret+=this.nodeType!=1?this.nodeValue:jQuery.fn.text([this]);});});return ret;},wrapAll:function(html){if(this[0])jQuery(html,this[0].ownerDocument).clone().insertBefore(this[0]).map(function(){var elem=this;while(elem.firstChild)elem=elem.firstChild;return elem;}).append(this);return this;},wrapInner:function(html){return this.each(function(){jQuery(this).contents().wrapAll(html);});},wrap:function(html){return this.each(function(){jQuery(this).wrapAll(html);});},append:function(){return this.domManip(arguments,true,false,function(elem){if(this.nodeType==1)this.appendChild(elem);});},prepend:function(){return this.domManip(arguments,true,true,function(elem){if(this.nodeType==1)this.insertBefore(elem,this.firstChild);});},before:function(){return this.domManip(arguments,false,false,function(elem){this.parentNode.insertBefore(elem,this);});},after:function(){return this.domManip(arguments,false,true,function(elem){this.parentNode.insertBefore(elem,this.nextSibling);});},end:function(){return this.prevObject||jQuery([]);},find:function(selector){var elems=jQuery.map(this,function(elem){return jQuery.find(selector,elem);});return this.pushStack(/[^+>] [^+>]/.test(selector)||selector.indexOf("..")>-1?jQuery.unique(elems):elems);},clone:function(events){var ret=this.map(function(){if(jQuery.browser.msie&&!jQuery.isXMLDoc(this)){var clone=this.cloneNode(true),container=document.createElement("div");container.appendChild(clone);return jQuery.clean([container.innerHTML])[0];}else
+return this.cloneNode(true);});var clone=ret.find("*").andSelf().each(function(){if(this[expando]!=undefined)this[expando]=null;});if(events===true)this.find("*").andSelf().each(function(i){if(this.nodeType==3)return;var events=jQuery.data(this,"events");for(var type in events)for(var handler in events[type])jQuery.event.add(clone[i],type,events[type][handler],events[type][handler].data);});return ret;},filter:function(selector){return this.pushStack(jQuery.isFunction(selector)&&jQuery.grep(this,function(elem,i){return selector.call(elem,i);})||jQuery.multiFilter(selector,this));},not:function(selector){if(selector.constructor==String)if(isSimple.test(selector))return this.pushStack(jQuery.multiFilter(selector,this,true));else
+selector=jQuery.multiFilter(selector,this);var isArrayLike=selector.length&&selector[selector.length-1]!==undefined&&!selector.nodeType;return this.filter(function(){return isArrayLike?jQuery.inArray(this,selector)<0:this!=selector;});},add:function(selector){return this.pushStack(jQuery.unique(jQuery.merge(this.get(),typeof selector=='string'?jQuery(selector):jQuery.makeArray(selector))));},is:function(selector){return!!selector&&jQuery.multiFilter(selector,this).length>0;},hasClass:function(selector){return this.is("."+selector);},val:function(value){if(value==undefined){if(this.length){var elem=this[0];if(jQuery.nodeName(elem,"select")){var index=elem.selectedIndex,values=[],options=elem.options,one=elem.type=="select-one";if(index<0)return null;for(var i=one?index:0,max=one?index+1:options.length;i<max;i++){var option=options[i];if(option.selected){value=jQuery.browser.msie&&!option.attributes.value.specified?option.text:option.value;if(one)return value;values.push(value);}}return values;}else
+return(this[0].value||"").replace(/\r/g,"");}return undefined;}if(value.constructor==Number)value+='';return this.each(function(){if(this.nodeType!=1)return;if(value.constructor==Array&&/radio|checkbox/.test(this.type))this.checked=(jQuery.inArray(this.value,value)>=0||jQuery.inArray(this.name,value)>=0);else if(jQuery.nodeName(this,"select")){var values=jQuery.makeArray(value);jQuery("option",this).each(function(){this.selected=(jQuery.inArray(this.value,values)>=0||jQuery.inArray(this.text,values)>=0);});if(!values.length)this.selectedIndex=-1;}else
+this.value=value;});},html:function(value){return value==undefined?(this[0]?this[0].innerHTML:null):this.empty().append(value);},replaceWith:function(value){return this.after(value).remove();},eq:function(i){return this.slice(i,i+1);},slice:function(){return this.pushStack(Array.prototype.slice.apply(this,arguments));},map:function(callback){return this.pushStack(jQuery.map(this,function(elem,i){return callback.call(elem,i,elem);}));},andSelf:function(){return this.add(this.prevObject);},data:function(key,value){var parts=key.split(".");parts[1]=parts[1]?"."+parts[1]:"";if(value===undefined){var data=this.triggerHandler("getData"+parts[1]+"!",[parts[0]]);if(data===undefined&&this.length)data=jQuery.data(this[0],key);return data===undefined&&parts[1]?this.data(parts[0]):data;}else
+return this.trigger("setData"+parts[1]+"!",[parts[0],value]).each(function(){jQuery.data(this,key,value);});},removeData:function(key){return this.each(function(){jQuery.removeData(this,key);});},domManip:function(args,table,reverse,callback){var clone=this.length>1,elems;return this.each(function(){if(!elems){elems=jQuery.clean(args,this.ownerDocument);if(reverse)elems.reverse();}var obj=this;if(table&&jQuery.nodeName(this,"table")&&jQuery.nodeName(elems[0],"tr"))obj=this.getElementsByTagName("tbody")[0]||this.appendChild(this.ownerDocument.createElement("tbody"));var scripts=jQuery([]);jQuery.each(elems,function(){var elem=clone?jQuery(this).clone(true)[0]:this;if(jQuery.nodeName(elem,"script"))scripts=scripts.add(elem);else{if(elem.nodeType==1)scripts=scripts.add(jQuery("script",elem).remove());callback.call(obj,elem);}});scripts.each(evalScript);});}};jQuery.fn.init.prototype=jQuery.fn;function evalScript(i,elem){if(elem.src)jQuery.ajax({url:elem.src,async:false,dataType:"script"});else
+jQuery.globalEval(elem.text||elem.textContent||elem.innerHTML||"");if(elem.parentNode)elem.parentNode.removeChild(elem);}function now(){return+new Date;}jQuery.extend=jQuery.fn.extend=function(){var target=arguments[0]||{},i=1,length=arguments.length,deep=false,options;if(target.constructor==Boolean){deep=target;target=arguments[1]||{};i=2;}if(typeof target!="object"&&typeof target!="function")target={};if(length==i){target=this;--i;}for(;i<length;i++)if((options=arguments[i])!=null)for(var name in options){var src=target[name],copy=options[name];if(target===copy)continue;if(deep&&copy&&typeof copy=="object"&&!copy.nodeType)target[name]=jQuery.extend(deep,src||(copy.length!=null?[]:{}),copy);else if(copy!==undefined)target[name]=copy;}return target;};var expando="jQuery"+now(),uuid=0,windowData={},exclude=/z-?index|font-?weight|opacity|zoom|line-?height/i,defaultView=document.defaultView||{};jQuery.extend({noConflict:function(deep){window.$=_$;if(deep)window.jQuery=_jQuery;return jQuery;},isFunction:function(fn){return!!fn&&typeof fn!="string"&&!fn.nodeName&&fn.constructor!=Array&&/^[\s[]?function/.test(fn+"");},isXMLDoc:function(elem){return elem.documentElement&&!elem.body||elem.tagName&&elem.ownerDocument&&!elem.ownerDocument.body;},globalEval:function(data){data=jQuery.trim(data);if(data){var head=document.getElementsByTagName("head")[0]||document.documentElement,script=document.createElement("script");script.type="text/javascript";if(jQuery.browser.msie)script.text=data;else
+script.appendChild(document.createTextNode(data));head.insertBefore(script,head.firstChild);head.removeChild(script);}},nodeName:function(elem,name){return elem.nodeName&&elem.nodeName.toUpperCase()==name.toUpperCase();},cache:{},data:function(elem,name,data){elem=elem==window?windowData:elem;var id=elem[expando];if(!id)id=elem[expando]=++uuid;if(name&&!jQuery.cache[id])jQuery.cache[id]={};if(data!==undefined)jQuery.cache[id][name]=data;return name?jQuery.cache[id][name]:id;},removeData:function(elem,name){elem=elem==window?windowData:elem;var id=elem[expando];if(name){if(jQuery.cache[id]){delete jQuery.cache[id][name];name="";for(name in jQuery.cache[id])break;if(!name)jQuery.removeData(elem);}}else{try{delete elem[expando];}catch(e){if(elem.removeAttribute)elem.removeAttribute(expando);}delete jQuery.cache[id];}},each:function(object,callback,args){var name,i=0,length=object.length;if(args){if(length==undefined){for(name in object)if(callback.apply(object[name],args)===false)break;}else
+for(;i<length;)if(callback.apply(object[i++],args)===false)break;}else{if(length==undefined){for(name in object)if(callback.call(object[name],name,object[name])===false)break;}else
+for(var value=object[0];i<length&&callback.call(value,i,value)!==false;value=object[++i]){}}return object;},prop:function(elem,value,type,i,name){if(jQuery.isFunction(value))value=value.call(elem,i);return value&&value.constructor==Number&&type=="curCSS"&&!exclude.test(name)?value+"px":value;},className:{add:function(elem,classNames){jQuery.each((classNames||"").split(/\s+/),function(i,className){if(elem.nodeType==1&&!jQuery.className.has(elem.className,className))elem.className+=(elem.className?" ":"")+className;});},remove:function(elem,classNames){if(elem.nodeType==1)elem.className=classNames!=undefined?jQuery.grep(elem.className.split(/\s+/),function(className){return!jQuery.className.has(classNames,className);}).join(" "):"";},has:function(elem,className){return jQuery.inArray(className,(elem.className||elem).toString().split(/\s+/))>-1;}},swap:function(elem,options,callback){var old={};for(var name in options){old[name]=elem.style[name];elem.style[name]=options[name];}callback.call(elem);for(var name in options)elem.style[name]=old[name];},css:function(elem,name,force){if(name=="width"||name=="height"){var val,props={position:"absolute",visibility:"hidden",display:"block"},which=name=="width"?["Left","Right"]:["Top","Bottom"];function getWH(){val=name=="width"?elem.offsetWidth:elem.offsetHeight;var padding=0,border=0;jQuery.each(which,function(){padding+=parseFloat(jQuery.curCSS(elem,"padding"+this,true))||0;border+=parseFloat(jQuery.curCSS(elem,"border"+this+"Width",true))||0;});val-=Math.round(padding+border);}if(jQuery(elem).is(":visible"))getWH();else
+jQuery.swap(elem,props,getWH);return Math.max(0,val);}return jQuery.curCSS(elem,name,force);},curCSS:function(elem,name,force){var ret,style=elem.style;function color(elem){if(!jQuery.browser.safari)return false;var ret=defaultView.getComputedStyle(elem,null);return!ret||ret.getPropertyValue("color")=="";}if(name=="opacity"&&jQuery.browser.msie){ret=jQuery.attr(style,"opacity");return ret==""?"1":ret;}if(jQuery.browser.opera&&name=="display"){var save=style.outline;style.outline="0 solid black";style.outline=save;}if(name.match(/float/i))name=styleFloat;if(!force&&style&&style[name])ret=style[name];else if(defaultView.getComputedStyle){if(name.match(/float/i))name="float";name=name.replace(/([A-Z])/g,"-$1").toLowerCase();var computedStyle=defaultView.getComputedStyle(elem,null);if(computedStyle&&!color(elem))ret=computedStyle.getPropertyValue(name);else{var swap=[],stack=[],a=elem,i=0;for(;a&&color(a);a=a.parentNode)stack.unshift(a);for(;i<stack.length;i++)if(color(stack[i])){swap[i]=stack[i].style.display;stack[i].style.display="block";}ret=name=="display"&&swap[stack.length-1]!=null?"none":(computedStyle&&computedStyle.getPropertyValue(name))||"";for(i=0;i<swap.length;i++)if(swap[i]!=null)stack[i].style.display=swap[i];}if(name=="opacity"&&ret=="")ret="1";}else if(elem.currentStyle){var camelCase=name.replace(/\-(\w)/g,function(all,letter){return letter.toUpperCase();});ret=elem.currentStyle[name]||elem.currentStyle[camelCase];if(!/^\d+(px)?$/i.test(ret)&&/^\d/.test(ret)){var left=style.left,rsLeft=elem.runtimeStyle.left;elem.runtimeStyle.left=elem.currentStyle.left;style.left=ret||0;ret=style.pixelLeft+"px";style.left=left;elem.runtimeStyle.left=rsLeft;}}return ret;},clean:function(elems,context){var ret=[];context=context||document;if(typeof context.createElement=='undefined')context=context.ownerDocument||context[0]&&context[0].ownerDocument||document;jQuery.each(elems,function(i,elem){if(!elem)return;if(elem.constructor==Number)elem+='';if(typeof elem=="string"){elem=elem.replace(/(<(\w+)[^>]*?)\/>/g,function(all,front,tag){return tag.match(/^(abbr|br|col|img|input|link|meta|param|hr|area|embed)$/i)?all:front+"></"+tag+">";});var tags=jQuery.trim(elem).toLowerCase(),div=context.createElement("div");var wrap=!tags.indexOf("<opt")&&[1,"<select multiple='multiple'>","</select>"]||!tags.indexOf("<leg")&&[1,"<fieldset>","</fieldset>"]||tags.match(/^<(thead|tbody|tfoot|colg|cap)/)&&[1,"<table>","</table>"]||!tags.indexOf("<tr")&&[2,"<table><tbody>","</tbody></table>"]||(!tags.indexOf("<td")||!tags.indexOf("<th"))&&[3,"<table><tbody><tr>","</tr></tbody></table>"]||!tags.indexOf("<col")&&[2,"<table><tbody></tbody><colgroup>","</colgroup></table>"]||jQuery.browser.msie&&[1,"div<div>","</div>"]||[0,"",""];div.innerHTML=wrap[1]+elem+wrap[2];while(wrap[0]--)div=div.lastChild;if(jQuery.browser.msie){var tbody=!tags.indexOf("<table")&&tags.indexOf("<tbody")<0?div.firstChild&&div.firstChild.childNodes:wrap[1]=="<table>"&&tags.indexOf("<tbody")<0?div.childNodes:[];for(var j=tbody.length-1;j>=0;--j)if(jQuery.nodeName(tbody[j],"tbody")&&!tbody[j].childNodes.length)tbody[j].parentNode.removeChild(tbody[j]);if(/^\s/.test(elem))div.insertBefore(context.createTextNode(elem.match(/^\s*/)[0]),div.firstChild);}elem=jQuery.makeArray(div.childNodes);}if(elem.length===0&&(!jQuery.nodeName(elem,"form")&&!jQuery.nodeName(elem,"select")))return;if(elem[0]==undefined||jQuery.nodeName(elem,"form")||elem.options)ret.push(elem);else
+ret=jQuery.merge(ret,elem);});return ret;},attr:function(elem,name,value){if(!elem||elem.nodeType==3||elem.nodeType==8)return undefined;var notxml=!jQuery.isXMLDoc(elem),set=value!==undefined,msie=jQuery.browser.msie;name=notxml&&jQuery.props[name]||name;if(elem.tagName){var special=/href|src|style/.test(name);if(name=="selected"&&jQuery.browser.safari)elem.parentNode.selectedIndex;if(name in elem&&notxml&&!special){if(set){if(name=="type"&&jQuery.nodeName(elem,"input")&&elem.parentNode)throw"type property can't be changed";elem[name]=value;}if(jQuery.nodeName(elem,"form")&&elem.getAttributeNode(name))return elem.getAttributeNode(name).nodeValue;return elem[name];}if(msie&&notxml&&name=="style")return jQuery.attr(elem.style,"cssText",value);if(set)elem.setAttribute(name,""+value);var attr=msie&&notxml&&special?elem.getAttribute(name,2):elem.getAttribute(name);return attr===null?undefined:attr;}if(msie&&name=="opacity"){if(set){elem.zoom=1;elem.filter=(elem.filter||"").replace(/alpha\([^)]*\)/,"")+(parseInt(value)+''=="NaN"?"":"alpha(opacity="+value*100+")");}return elem.filter&&elem.filter.indexOf("opacity=")>=0?(parseFloat(elem.filter.match(/opacity=([^)]*)/)[1])/100)+'':"";}name=name.replace(/-([a-z])/ig,function(all,letter){return letter.toUpperCase();});if(set)elem[name]=value;return elem[name];},trim:function(text){return(text||"").replace(/^\s+|\s+$/g,"");},makeArray:function(array){var ret=[];if(array!=null){var i=array.length;if(i==null||array.split||array.setInterval||array.call)ret[0]=array;else
+while(i)ret[--i]=array[i];}return ret;},inArray:function(elem,array){for(var i=0,length=array.length;i<length;i++)if(array[i]===elem)return i;return-1;},merge:function(first,second){var i=0,elem,pos=first.length;if(jQuery.browser.msie){while(elem=second[i++])if(elem.nodeType!=8)first[pos++]=elem;}else
+while(elem=second[i++])first[pos++]=elem;return first;},unique:function(array){var ret=[],done={};try{for(var i=0,length=array.length;i<length;i++){var id=jQuery.data(array[i]);if(!done[id]){done[id]=true;ret.push(array[i]);}}}catch(e){ret=array;}return ret;},grep:function(elems,callback,inv){var ret=[];for(var i=0,length=elems.length;i<length;i++)if(!inv!=!callback(elems[i],i))ret.push(elems[i]);return ret;},map:function(elems,callback){var ret=[];for(var i=0,length=elems.length;i<length;i++){var value=callback(elems[i],i);if(value!=null)ret[ret.length]=value;}return ret.concat.apply([],ret);}});var userAgent=navigator.userAgent.toLowerCase();jQuery.browser={version:(userAgent.match(/.+(?:rv|it|ra|ie)[\/: ]([\d.]+)/)||[])[1],safari:/webkit/.test(userAgent),opera:/opera/.test(userAgent),msie:/msie/.test(userAgent)&&!/opera/.test(userAgent),mozilla:/mozilla/.test(userAgent)&&!/(compatible|webkit)/.test(userAgent)};var styleFloat=jQuery.browser.msie?"styleFloat":"cssFloat";jQuery.extend({boxModel:!jQuery.browser.msie||document.compatMode=="CSS1Compat",props:{"for":"htmlFor","class":"className","float":styleFloat,cssFloat:styleFloat,styleFloat:styleFloat,readonly:"readOnly",maxlength:"maxLength",cellspacing:"cellSpacing"}});jQuery.each({parent:function(elem){return elem.parentNode;},parents:function(elem){return jQuery.dir(elem,"parentNode");},next:function(elem){return jQuery.nth(elem,2,"nextSibling");},prev:function(elem){return jQuery.nth(elem,2,"previousSibling");},nextAll:function(elem){return jQuery.dir(elem,"nextSibling");},prevAll:function(elem){return jQuery.dir(elem,"previousSibling");},siblings:function(elem){return jQuery.sibling(elem.parentNode.firstChild,elem);},children:function(elem){return jQuery.sibling(elem.firstChild);},contents:function(elem){return jQuery.nodeName(elem,"iframe")?elem.contentDocument||elem.contentWindow.document:jQuery.makeArray(elem.childNodes);}},function(name,fn){jQuery.fn[name]=function(selector){var ret=jQuery.map(this,fn);if(selector&&typeof selector=="string")ret=jQuery.multiFilter(selector,ret);return this.pushStack(jQuery.unique(ret));};});jQuery.each({appendTo:"append",prependTo:"prepend",insertBefore:"before",insertAfter:"after",replaceAll:"replaceWith"},function(name,original){jQuery.fn[name]=function(){var args=arguments;return this.each(function(){for(var i=0,length=args.length;i<length;i++)jQuery(args[i])[original](this);});};});jQuery.each({removeAttr:function(name){jQuery.attr(this,name,"");if(this.nodeType==1)this.removeAttribute(name);},addClass:function(classNames){jQuery.className.add(this,classNames);},removeClass:function(classNames){jQuery.className.remove(this,classNames);},toggleClass:function(classNames){jQuery.className[jQuery.className.has(this,classNames)?"remove":"add"](this,classNames);},remove:function(selector){if(!selector||jQuery.filter(selector,[this]).r.length){jQuery("*",this).add(this).each(function(){jQuery.event.remove(this);jQuery.removeData(this);});if(this.parentNode)this.parentNode.removeChild(this);}},empty:function(){jQuery(">*",this).remove();while(this.firstChild)this.removeChild(this.firstChild);}},function(name,fn){jQuery.fn[name]=function(){return this.each(fn,arguments);};});jQuery.each(["Height","Width"],function(i,name){var type=name.toLowerCase();jQuery.fn[type]=function(size){return this[0]==window?jQuery.browser.opera&&document.body["client"+name]||jQuery.browser.safari&&window["inner"+name]||document.compatMode=="CSS1Compat"&&document.documentElement["client"+name]||document.body["client"+name]:this[0]==document?Math.max(Math.max(document.body["scroll"+name],document.documentElement["scroll"+name]),Math.max(document.body["offset"+name],document.documentElement["offset"+name])):size==undefined?(this.length?jQuery.css(this[0],type):null):this.css(type,size.constructor==String?size:size+"px");};});function num(elem,prop){return elem[0]&&parseInt(jQuery.curCSS(elem[0],prop,true),10)||0;}var chars=jQuery.browser.safari&&parseInt(jQuery.browser.version)<417?"(?:[\\w*_-]|\\\\.)":"(?:[\\w\u0128-\uFFFF*_-]|\\\\.)",quickChild=new RegExp("^>\\s*("+chars+"+)"),quickID=new RegExp("^("+chars+"+)(#)("+chars+"+)"),quickClass=new RegExp("^([#.]?)("+chars+"*)");jQuery.extend({expr:{"":function(a,i,m){return m[2]=="*"||jQuery.nodeName(a,m[2]);},"#":function(a,i,m){return a.getAttribute("id")==m[2];},":":{lt:function(a,i,m){return i<m[3]-0;},gt:function(a,i,m){return i>m[3]-0;},nth:function(a,i,m){return m[3]-0==i;},eq:function(a,i,m){return m[3]-0==i;},first:function(a,i){return i==0;},last:function(a,i,m,r){return i==r.length-1;},even:function(a,i){return i%2==0;},odd:function(a,i){return i%2;},"first-child":function(a){return a.parentNode.getElementsByTagName("*")[0]==a;},"last-child":function(a){return jQuery.nth(a.parentNode.lastChild,1,"previousSibling")==a;},"only-child":function(a){return!jQuery.nth(a.parentNode.lastChild,2,"previousSibling");},parent:function(a){return a.firstChild;},empty:function(a){return!a.firstChild;},contains:function(a,i,m){return(a.textContent||a.innerText||jQuery(a).text()||"").indexOf(m[3])>=0;},visible:function(a){return"hidden"!=a.type&&jQuery.css(a,"display")!="none"&&jQuery.css(a,"visibility")!="hidden";},hidden:function(a){return"hidden"==a.type||jQuery.css(a,"display")=="none"||jQuery.css(a,"visibility")=="hidden";},enabled:function(a){return!a.disabled;},disabled:function(a){return a.disabled;},checked:function(a){return a.checked;},selected:function(a){return a.selected||jQuery.attr(a,"selected");},text:function(a){return"text"==a.type;},radio:function(a){return"radio"==a.type;},checkbox:function(a){return"checkbox"==a.type;},file:function(a){return"file"==a.type;},password:function(a){return"password"==a.type;},submit:function(a){return"submit"==a.type;},image:function(a){return"image"==a.type;},reset:function(a){return"reset"==a.type;},button:function(a){return"button"==a.type||jQuery.nodeName(a,"button");},input:function(a){return/input|select|textarea|button/i.test(a.nodeName);},has:function(a,i,m){return jQuery.find(m[3],a).length;},header:function(a){return/h\d/i.test(a.nodeName);},animated:function(a){return jQuery.grep(jQuery.timers,function(fn){return a==fn.elem;}).length;}}},parse:[/^(\[) *@?([\w-]+) *([!*$^~=]*) *('?"?)(.*?)\4 *\]/,/^(:)([\w-]+)\("?'?(.*?(\(.*?\))?[^(]*?)"?'?\)/,new RegExp("^([:.#]*)("+chars+"+)")],multiFilter:function(expr,elems,not){var old,cur=[];while(expr&&expr!=old){old=expr;var f=jQuery.filter(expr,elems,not);expr=f.t.replace(/^\s*,\s*/,"");cur=not?elems=f.r:jQuery.merge(cur,f.r);}return cur;},find:function(t,context){if(typeof t!="string")return[t];if(context&&context.nodeType!=1&&context.nodeType!=9)return[];context=context||document;var ret=[context],done=[],last,nodeName;while(t&&last!=t){var r=[];last=t;t=jQuery.trim(t);var foundToken=false,re=quickChild,m=re.exec(t);if(m){nodeName=m[1].toUpperCase();for(var i=0;ret[i];i++)for(var c=ret[i].firstChild;c;c=c.nextSibling)if(c.nodeType==1&&(nodeName=="*"||c.nodeName.toUpperCase()==nodeName))r.push(c);ret=r;t=t.replace(re,"");if(t.indexOf(" ")==0)continue;foundToken=true;}else{re=/^([>+~])\s*(\w*)/i;if((m=re.exec(t))!=null){r=[];var merge={};nodeName=m[2].toUpperCase();m=m[1];for(var j=0,rl=ret.length;j<rl;j++){var n=m=="~"||m=="+"?ret[j].nextSibling:ret[j].firstChild;for(;n;n=n.nextSibling)if(n.nodeType==1){var id=jQuery.data(n);if(m=="~"&&merge[id])break;if(!nodeName||n.nodeName.toUpperCase()==nodeName){if(m=="~")merge[id]=true;r.push(n);}if(m=="+")break;}}ret=r;t=jQuery.trim(t.replace(re,""));foundToken=true;}}if(t&&!foundToken){if(!t.indexOf(",")){if(context==ret[0])ret.shift();done=jQuery.merge(done,ret);r=ret=[context];t=" "+t.substr(1,t.length);}else{var re2=quickID;var m=re2.exec(t);if(m){m=[0,m[2],m[3],m[1]];}else{re2=quickClass;m=re2.exec(t);}m[2]=m[2].replace(/\\/g,"");var elem=ret[ret.length-1];if(m[1]=="#"&&elem&&elem.getElementById&&!jQuery.isXMLDoc(elem)){var oid=elem.getElementById(m[2]);if((jQuery.browser.msie||jQuery.browser.opera)&&oid&&typeof oid.id=="string"&&oid.id!=m[2])oid=jQuery('[@id="'+m[2]+'"]',elem)[0];ret=r=oid&&(!m[3]||jQuery.nodeName(oid,m[3]))?[oid]:[];}else{for(var i=0;ret[i];i++){var tag=m[1]=="#"&&m[3]?m[3]:m[1]!=""||m[0]==""?"*":m[2];if(tag=="*"&&ret[i].nodeName.toLowerCase()=="object")tag="param";r=jQuery.merge(r,ret[i].getElementsByTagName(tag));}if(m[1]==".")r=jQuery.classFilter(r,m[2]);if(m[1]=="#"){var tmp=[];for(var i=0;r[i];i++)if(r[i].getAttribute("id")==m[2]){tmp=[r[i]];break;}r=tmp;}ret=r;}t=t.replace(re2,"");}}if(t){var val=jQuery.filter(t,r);ret=r=val.r;t=jQuery.trim(val.t);}}if(t)ret=[];if(ret&&context==ret[0])ret.shift();done=jQuery.merge(done,ret);return done;},classFilter:function(r,m,not){m=" "+m+" ";var tmp=[];for(var i=0;r[i];i++){var pass=(" "+r[i].className+" ").indexOf(m)>=0;if(!not&&pass||not&&!pass)tmp.push(r[i]);}return tmp;},filter:function(t,r,not){var last;while(t&&t!=last){last=t;var p=jQuery.parse,m;for(var i=0;p[i];i++){m=p[i].exec(t);if(m){t=t.substring(m[0].length);m[2]=m[2].replace(/\\/g,"");break;}}if(!m)break;if(m[1]==":"&&m[2]=="not")r=isSimple.test(m[3])?jQuery.filter(m[3],r,true).r:jQuery(r).not(m[3]);else if(m[1]==".")r=jQuery.classFilter(r,m[2],not);else if(m[1]=="["){var tmp=[],type=m[3];for(var i=0,rl=r.length;i<rl;i++){var a=r[i],z=a[jQuery.props[m[2]]||m[2]];if(z==null||/href|src|selected/.test(m[2]))z=jQuery.attr(a,m[2])||'';if((type==""&&!!z||type=="="&&z==m[5]||type=="!="&&z!=m[5]||type=="^="&&z&&!z.indexOf(m[5])||type=="$="&&z.substr(z.length-m[5].length)==m[5]||(type=="*="||type=="~=")&&z.indexOf(m[5])>=0)^not)tmp.push(a);}r=tmp;}else if(m[1]==":"&&m[2]=="nth-child"){var merge={},tmp=[],test=/(-?)(\d*)n((?:\+|-)?\d*)/.exec(m[3]=="even"&&"2n"||m[3]=="odd"&&"2n+1"||!/\D/.test(m[3])&&"0n+"+m[3]||m[3]),first=(test[1]+(test[2]||1))-0,last=test[3]-0;for(var i=0,rl=r.length;i<rl;i++){var node=r[i],parentNode=node.parentNode,id=jQuery.data(parentNode);if(!merge[id]){var c=1;for(var n=parentNode.firstChild;n;n=n.nextSibling)if(n.nodeType==1)n.nodeIndex=c++;merge[id]=true;}var add=false;if(first==0){if(node.nodeIndex==last)add=true;}else if((node.nodeIndex-last)%first==0&&(node.nodeIndex-last)/first>=0)add=true;if(add^not)tmp.push(node);}r=tmp;}else{var fn=jQuery.expr[m[1]];if(typeof fn=="object")fn=fn[m[2]];if(typeof fn=="string")fn=eval("false||function(a,i){return "+fn+";}");r=jQuery.grep(r,function(elem,i){return fn(elem,i,m,r);},not);}}return{r:r,t:t};},dir:function(elem,dir){var matched=[],cur=elem[dir];while(cur&&cur!=document){if(cur.nodeType==1)matched.push(cur);cur=cur[dir];}return matched;},nth:function(cur,result,dir,elem){result=result||1;var num=0;for(;cur;cur=cur[dir])if(cur.nodeType==1&&++num==result)break;return cur;},sibling:function(n,elem){var r=[];for(;n;n=n.nextSibling){if(n.nodeType==1&&n!=elem)r.push(n);}return r;}});jQuery.event={add:function(elem,types,handler,data){if(elem.nodeType==3||elem.nodeType==8)return;if(jQuery.browser.msie&&elem.setInterval)elem=window;if(!handler.guid)handler.guid=this.guid++;if(data!=undefined){var fn=handler;handler=this.proxy(fn,function(){return fn.apply(this,arguments);});handler.data=data;}var events=jQuery.data(elem,"events")||jQuery.data(elem,"events",{}),handle=jQuery.data(elem,"handle")||jQuery.data(elem,"handle",function(){if(typeof jQuery!="undefined"&&!jQuery.event.triggered)return jQuery.event.handle.apply(arguments.callee.elem,arguments);});handle.elem=elem;jQuery.each(types.split(/\s+/),function(index,type){var parts=type.split(".");type=parts[0];handler.type=parts[1];var handlers=events[type];if(!handlers){handlers=events[type]={};if(!jQuery.event.special[type]||jQuery.event.special[type].setup.call(elem)===false){if(elem.addEventListener)elem.addEventListener(type,handle,false);else if(elem.attachEvent)elem.attachEvent("on"+type,handle);}}handlers[handler.guid]=handler;jQuery.event.global[type]=true;});elem=null;},guid:1,global:{},remove:function(elem,types,handler){if(elem.nodeType==3||elem.nodeType==8)return;var events=jQuery.data(elem,"events"),ret,index;if(events){if(types==undefined||(typeof types=="string"&&types.charAt(0)=="."))for(var type in events)this.remove(elem,type+(types||""));else{if(types.type){handler=types.handler;types=types.type;}jQuery.each(types.split(/\s+/),function(index,type){var parts=type.split(".");type=parts[0];if(events[type]){if(handler)delete events[type][handler.guid];else
+for(handler in events[type])if(!parts[1]||events[type][handler].type==parts[1])delete events[type][handler];for(ret in events[type])break;if(!ret){if(!jQuery.event.special[type]||jQuery.event.special[type].teardown.call(elem)===false){if(elem.removeEventListener)elem.removeEventListener(type,jQuery.data(elem,"handle"),false);else if(elem.detachEvent)elem.detachEvent("on"+type,jQuery.data(elem,"handle"));}ret=null;delete events[type];}}});}for(ret in events)break;if(!ret){var handle=jQuery.data(elem,"handle");if(handle)handle.elem=null;jQuery.removeData(elem,"events");jQuery.removeData(elem,"handle");}}},trigger:function(type,data,elem,donative,extra){data=jQuery.makeArray(data);if(type.indexOf("!")>=0){type=type.slice(0,-1);var exclusive=true;}if(!elem){if(this.global[type])jQuery("*").add([window,document]).trigger(type,data);}else{if(elem.nodeType==3||elem.nodeType==8)return undefined;var val,ret,fn=jQuery.isFunction(elem[type]||null),event=!data[0]||!data[0].preventDefault;if(event){data.unshift({type:type,target:elem,preventDefault:function(){},stopPropagation:function(){},timeStamp:now()});data[0][expando]=true;}data[0].type=type;if(exclusive)data[0].exclusive=true;var handle=jQuery.data(elem,"handle");if(handle)val=handle.apply(elem,data);if((!fn||(jQuery.nodeName(elem,'a')&&type=="click"))&&elem["on"+type]&&elem["on"+type].apply(elem,data)===false)val=false;if(event)data.shift();if(extra&&jQuery.isFunction(extra)){ret=extra.apply(elem,val==null?data:data.concat(val));if(ret!==undefined)val=ret;}if(fn&&donative!==false&&val!==false&&!(jQuery.nodeName(elem,'a')&&type=="click")){this.triggered=true;try{elem[type]();}catch(e){}}this.triggered=false;}return val;},handle:function(event){var val,ret,namespace,all,handlers;event=arguments[0]=jQuery.event.fix(event||window.event);namespace=event.type.split(".");event.type=namespace[0];namespace=namespace[1];all=!namespace&&!event.exclusive;handlers=(jQuery.data(this,"events")||{})[event.type];for(var j in handlers){var handler=handlers[j];if(all||handler.type==namespace){event.handler=handler;event.data=handler.data;ret=handler.apply(this,arguments);if(val!==false)val=ret;if(ret===false){event.preventDefault();event.stopPropagation();}}}return val;},fix:function(event){if(event[expando]==true)return event;var originalEvent=event;event={originalEvent:originalEvent};var props="altKey attrChange attrName bubbles button cancelable charCode clientX clientY ctrlKey currentTarget data detail eventPhase fromElement handler keyCode metaKey newValue originalTarget pageX pageY prevValue relatedNode relatedTarget screenX screenY shiftKey srcElement target timeStamp toElement type view wheelDelta which".split(" ");for(var i=props.length;i;i--)event[props[i]]=originalEvent[props[i]];event[expando]=true;event.preventDefault=function(){if(originalEvent.preventDefault)originalEvent.preventDefault();originalEvent.returnValue=false;};event.stopPropagation=function(){if(originalEvent.stopPropagation)originalEvent.stopPropagation();originalEvent.cancelBubble=true;};event.timeStamp=event.timeStamp||now();if(!event.target)event.target=event.srcElement||document;if(event.target.nodeType==3)event.target=event.target.parentNode;if(!event.relatedTarget&&event.fromElement)event.relatedTarget=event.fromElement==event.target?event.toElement:event.fromElement;if(event.pageX==null&&event.clientX!=null){var doc=document.documentElement,body=document.body;event.pageX=event.clientX+(doc&&doc.scrollLeft||body&&body.scrollLeft||0)-(doc.clientLeft||0);event.pageY=event.clientY+(doc&&doc.scrollTop||body&&body.scrollTop||0)-(doc.clientTop||0);}if(!event.which&&((event.charCode||event.charCode===0)?event.charCode:event.keyCode))event.which=event.charCode||event.keyCode;if(!event.metaKey&&event.ctrlKey)event.metaKey=event.ctrlKey;if(!event.which&&event.button)event.which=(event.button&1?1:(event.button&2?3:(event.button&4?2:0)));return event;},proxy:function(fn,proxy){proxy.guid=fn.guid=fn.guid||proxy.guid||this.guid++;return proxy;},special:{ready:{setup:function(){bindReady();return;},teardown:function(){return;}},mouseenter:{setup:function(){if(jQuery.browser.msie)return false;jQuery(this).bind("mouseover",jQuery.event.special.mouseenter.handler);return true;},teardown:function(){if(jQuery.browser.msie)return false;jQuery(this).unbind("mouseover",jQuery.event.special.mouseenter.handler);return true;},handler:function(event){if(withinElement(event,this))return true;event.type="mouseenter";return jQuery.event.handle.apply(this,arguments);}},mouseleave:{setup:function(){if(jQuery.browser.msie)return false;jQuery(this).bind("mouseout",jQuery.event.special.mouseleave.handler);return true;},teardown:function(){if(jQuery.browser.msie)return false;jQuery(this).unbind("mouseout",jQuery.event.special.mouseleave.handler);return true;},handler:function(event){if(withinElement(event,this))return true;event.type="mouseleave";return jQuery.event.handle.apply(this,arguments);}}}};jQuery.fn.extend({bind:function(type,data,fn){return type=="unload"?this.one(type,data,fn):this.each(function(){jQuery.event.add(this,type,fn||data,fn&&data);});},one:function(type,data,fn){var one=jQuery.event.proxy(fn||data,function(event){jQuery(this).unbind(event,one);return(fn||data).apply(this,arguments);});return this.each(function(){jQuery.event.add(this,type,one,fn&&data);});},unbind:function(type,fn){return this.each(function(){jQuery.event.remove(this,type,fn);});},trigger:function(type,data,fn){return this.each(function(){jQuery.event.trigger(type,data,this,true,fn);});},triggerHandler:function(type,data,fn){return this[0]&&jQuery.event.trigger(type,data,this[0],false,fn);},toggle:function(fn){var args=arguments,i=1;while(i<args.length)jQuery.event.proxy(fn,args[i++]);return this.click(jQuery.event.proxy(fn,function(event){this.lastToggle=(this.lastToggle||0)%i;event.preventDefault();return args[this.lastToggle++].apply(this,arguments)||false;}));},hover:function(fnOver,fnOut){return this.bind('mouseenter',fnOver).bind('mouseleave',fnOut);},ready:function(fn){bindReady();if(jQuery.isReady)fn.call(document,jQuery);else
+jQuery.readyList.push(function(){return fn.call(this,jQuery);});return this;}});jQuery.extend({isReady:false,readyList:[],ready:function(){if(!jQuery.isReady){jQuery.isReady=true;if(jQuery.readyList){jQuery.each(jQuery.readyList,function(){this.call(document);});jQuery.readyList=null;}jQuery(document).triggerHandler("ready");}}});var readyBound=false;function bindReady(){if(readyBound)return;readyBound=true;if(document.addEventListener&&!jQuery.browser.opera)document.addEventListener("DOMContentLoaded",jQuery.ready,false);if(jQuery.browser.msie&&window==top)(function(){if(jQuery.isReady)return;try{document.documentElement.doScroll("left");}catch(error){setTimeout(arguments.callee,0);return;}jQuery.ready();})();if(jQuery.browser.opera)document.addEventListener("DOMContentLoaded",function(){if(jQuery.isReady)return;for(var i=0;i<document.styleSheets.length;i++)if(document.styleSheets[i].disabled){setTimeout(arguments.callee,0);return;}jQuery.ready();},false);if(jQuery.browser.safari){var numStyles;(function(){if(jQuery.isReady)return;if(document.readyState!="loaded"&&document.readyState!="complete"){setTimeout(arguments.callee,0);return;}if(numStyles===undefined)numStyles=jQuery("style, link[rel=stylesheet]").length;if(document.styleSheets.length!=numStyles){setTimeout(arguments.callee,0);return;}jQuery.ready();})();}jQuery.event.add(window,"load",jQuery.ready);}jQuery.each(("blur,focus,load,resize,scroll,unload,click,dblclick,"+"mousedown,mouseup,mousemove,mouseover,mouseout,change,select,"+"submit,keydown,keypress,keyup,error").split(","),function(i,name){jQuery.fn[name]=function(fn){return fn?this.bind(name,fn):this.trigger(name);};});var withinElement=function(event,elem){var parent=event.relatedTarget;while(parent&&parent!=elem)try{parent=parent.parentNode;}catch(error){parent=elem;}return parent==elem;};jQuery(window).bind("unload",function(){jQuery("*").add(document).unbind();});jQuery.fn.extend({_load:jQuery.fn.load,load:function(url,params,callback){if(typeof url!='string')return this._load(url);var off=url.indexOf(" ");if(off>=0){var selector=url.slice(off,url.length);url=url.slice(0,off);}callback=callback||function(){};var type="GET";if(params)if(jQuery.isFunction(params)){callback=params;params=null;}else{params=jQuery.param(params);type="POST";}var self=this;jQuery.ajax({url:url,type:type,dataType:"html",data:params,complete:function(res,status){if(status=="success"||status=="notmodified")self.html(selector?jQuery("<div/>").append(res.responseText.replace(/<script(.|\s)*?\/script>/g,"")).find(selector):res.responseText);self.each(callback,[res.responseText,status,res]);}});return this;},serialize:function(){return jQuery.param(this.serializeArray());},serializeArray:function(){return this.map(function(){return jQuery.nodeName(this,"form")?jQuery.makeArray(this.elements):this;}).filter(function(){return this.name&&!this.disabled&&(this.checked||/select|textarea/i.test(this.nodeName)||/text|hidden|password/i.test(this.type));}).map(function(i,elem){var val=jQuery(this).val();return val==null?null:val.constructor==Array?jQuery.map(val,function(val,i){return{name:elem.name,value:val};}):{name:elem.name,value:val};}).get();}});jQuery.each("ajaxStart,ajaxStop,ajaxComplete,ajaxError,ajaxSuccess,ajaxSend".split(","),function(i,o){jQuery.fn[o]=function(f){return this.bind(o,f);};});var jsc=now();jQuery.extend({get:function(url,data,callback,type){if(jQuery.isFunction(data)){callback=data;data=null;}return jQuery.ajax({type:"GET",url:url,data:data,success:callback,dataType:type});},getScript:function(url,callback){return jQuery.get(url,null,callback,"script");},getJSON:function(url,data,callback){return jQuery.get(url,data,callback,"json");},post:function(url,data,callback,type){if(jQuery.isFunction(data)){callback=data;data={};}return jQuery.ajax({type:"POST",url:url,data:data,success:callback,dataType:type});},ajaxSetup:function(settings){jQuery.extend(jQuery.ajaxSettings,settings);},ajaxSettings:{url:location.href,global:true,type:"GET",timeout:0,contentType:"application/x-www-form-urlencoded",processData:true,async:true,data:null,username:null,password:null,accepts:{xml:"application/xml, text/xml",html:"text/html",script:"text/javascript, application/javascript",json:"application/json, text/javascript",text:"text/plain",_default:"*/*"}},lastModified:{},ajax:function(s){s=jQuery.extend(true,s,jQuery.extend(true,{},jQuery.ajaxSettings,s));var jsonp,jsre=/=\?(&|$)/g,status,data,type=s.type.toUpperCase();if(s.data&&s.processData&&typeof s.data!="string")s.data=jQuery.param(s.data);if(s.dataType=="jsonp"){if(type=="GET"){if(!s.url.match(jsre))s.url+=(s.url.match(/\?/)?"&":"?")+(s.jsonp||"callback")+"=?";}else if(!s.data||!s.data.match(jsre))s.data=(s.data?s.data+"&":"")+(s.jsonp||"callback")+"=?";s.dataType="json";}if(s.dataType=="json"&&(s.data&&s.data.match(jsre)||s.url.match(jsre))){jsonp="jsonp"+jsc++;if(s.data)s.data=(s.data+"").replace(jsre,"="+jsonp+"$1");s.url=s.url.replace(jsre,"="+jsonp+"$1");s.dataType="script";window[jsonp]=function(tmp){data=tmp;success();complete();window[jsonp]=undefined;try{delete window[jsonp];}catch(e){}if(head)head.removeChild(script);};}if(s.dataType=="script"&&s.cache==null)s.cache=false;if(s.cache===false&&type=="GET"){var ts=now();var ret=s.url.replace(/(\?|&)_=.*?(&|$)/,"$1_="+ts+"$2");s.url=ret+((ret==s.url)?(s.url.match(/\?/)?"&":"?")+"_="+ts:"");}if(s.data&&type=="GET"){s.url+=(s.url.match(/\?/)?"&":"?")+s.data;s.data=null;}if(s.global&&!jQuery.active++)jQuery.event.trigger("ajaxStart");var remote=/^(?:\w+:)?\/\/([^\/?#]+)/;if(s.dataType=="script"&&type=="GET"&&remote.test(s.url)&&remote.exec(s.url)[1]!=location.host){var head=document.getElementsByTagName("head")[0];var script=document.createElement("script");script.src=s.url;if(s.scriptCharset)script.charset=s.scriptCharset;if(!jsonp){var done=false;script.onload=script.onreadystatechange=function(){if(!done&&(!this.readyState||this.readyState=="loaded"||this.readyState=="complete")){done=true;success();complete();head.removeChild(script);}};}head.appendChild(script);return undefined;}var requestDone=false;var xhr=window.ActiveXObject?new ActiveXObject("Microsoft.XMLHTTP"):new XMLHttpRequest();if(s.username)xhr.open(type,s.url,s.async,s.username,s.password);else
+xhr.open(type,s.url,s.async);try{if(s.data)xhr.setRequestHeader("Content-Type",s.contentType);if(s.ifModified)xhr.setRequestHeader("If-Modified-Since",jQuery.lastModified[s.url]||"Thu, 01 Jan 1970 00:00:00 GMT");xhr.setRequestHeader("X-Requested-With","XMLHttpRequest");xhr.setRequestHeader("Accept",s.dataType&&s.accepts[s.dataType]?s.accepts[s.dataType]+", */*":s.accepts._default);}catch(e){}if(s.beforeSend&&s.beforeSend(xhr,s)===false){s.global&&jQuery.active--;xhr.abort();return false;}if(s.global)jQuery.event.trigger("ajaxSend",[xhr,s]);var onreadystatechange=function(isTimeout){if(!requestDone&&xhr&&(xhr.readyState==4||isTimeout=="timeout")){requestDone=true;if(ival){clearInterval(ival);ival=null;}status=isTimeout=="timeout"&&"timeout"||!jQuery.httpSuccess(xhr)&&"error"||s.ifModified&&jQuery.httpNotModified(xhr,s.url)&&"notmodified"||"success";if(status=="success"){try{data=jQuery.httpData(xhr,s.dataType,s.dataFilter);}catch(e){status="parsererror";}}if(status=="success"){var modRes;try{modRes=xhr.getResponseHeader("Last-Modified");}catch(e){}if(s.ifModified&&modRes)jQuery.lastModified[s.url]=modRes;if(!jsonp)success();}else
+jQuery.handleError(s,xhr,status);complete();if(s.async)xhr=null;}};if(s.async){var ival=setInterval(onreadystatechange,13);if(s.timeout>0)setTimeout(function(){if(xhr){xhr.abort();if(!requestDone)onreadystatechange("timeout");}},s.timeout);}try{xhr.send(s.data);}catch(e){jQuery.handleError(s,xhr,null,e);}if(!s.async)onreadystatechange();function success(){if(s.success)s.success(data,status);if(s.global)jQuery.event.trigger("ajaxSuccess",[xhr,s]);}function complete(){if(s.complete)s.complete(xhr,status);if(s.global)jQuery.event.trigger("ajaxComplete",[xhr,s]);if(s.global&&!--jQuery.active)jQuery.event.trigger("ajaxStop");}return xhr;},handleError:function(s,xhr,status,e){if(s.error)s.error(xhr,status,e);if(s.global)jQuery.event.trigger("ajaxError",[xhr,s,e]);},active:0,httpSuccess:function(xhr){try{return!xhr.status&&location.protocol=="file:"||(xhr.status>=200&&xhr.status<300)||xhr.status==304||xhr.status==1223||jQuery.browser.safari&&xhr.status==undefined;}catch(e){}return false;},httpNotModified:function(xhr,url){try{var xhrRes=xhr.getResponseHeader("Last-Modified");return xhr.status==304||xhrRes==jQuery.lastModified[url]||jQuery.browser.safari&&xhr.status==undefined;}catch(e){}return false;},httpData:function(xhr,type,filter){var ct=xhr.getResponseHeader("content-type"),xml=type=="xml"||!type&&ct&&ct.indexOf("xml")>=0,data=xml?xhr.responseXML:xhr.responseText;if(xml&&data.documentElement.tagName=="parsererror")throw"parsererror";if(filter)data=filter(data,type);if(type=="script")jQuery.globalEval(data);if(type=="json")data=eval("("+data+")");return data;},param:function(a){var s=[];if(a.constructor==Array||a.jquery)jQuery.each(a,function(){s.push(encodeURIComponent(this.name)+"="+encodeURIComponent(this.value));});else
+for(var j in a)if(a[j]&&a[j].constructor==Array)jQuery.each(a[j],function(){s.push(encodeURIComponent(j)+"="+encodeURIComponent(this));});else
+s.push(encodeURIComponent(j)+"="+encodeURIComponent(jQuery.isFunction(a[j])?a[j]():a[j]));return s.join("&").replace(/%20/g,"+");}});jQuery.fn.extend({show:function(speed,callback){return speed?this.animate({height:"show",width:"show",opacity:"show"},speed,callback):this.filter(":hidden").each(function(){this.style.display=this.oldblock||"";if(jQuery.css(this,"display")=="none"){var elem=jQuery("<"+this.tagName+" />").appendTo("body");this.style.display=elem.css("display");if(this.style.display=="none")this.style.display="block";elem.remove();}}).end();},hide:function(speed,callback){return speed?this.animate({height:"hide",width:"hide",opacity:"hide"},speed,callback):this.filter(":visible").each(function(){this.oldblock=this.oldblock||jQuery.css(this,"display");this.style.display="none";}).end();},_toggle:jQuery.fn.toggle,toggle:function(fn,fn2){return jQuery.isFunction(fn)&&jQuery.isFunction(fn2)?this._toggle.apply(this,arguments):fn?this.animate({height:"toggle",width:"toggle",opacity:"toggle"},fn,fn2):this.each(function(){jQuery(this)[jQuery(this).is(":hidden")?"show":"hide"]();});},slideDown:function(speed,callback){return this.animate({height:"show"},speed,callback);},slideUp:function(speed,callback){return this.animate({height:"hide"},speed,callback);},slideToggle:function(speed,callback){return this.animate({height:"toggle"},speed,callback);},fadeIn:function(speed,callback){return this.animate({opacity:"show"},speed,callback);},fadeOut:function(speed,callback){return this.animate({opacity:"hide"},speed,callback);},fadeTo:function(speed,to,callback){return this.animate({opacity:to},speed,callback);},animate:function(prop,speed,easing,callback){var optall=jQuery.speed(speed,easing,callback);return this[optall.queue===false?"each":"queue"](function(){if(this.nodeType!=1)return false;var opt=jQuery.extend({},optall),p,hidden=jQuery(this).is(":hidden"),self=this;for(p in prop){if(prop[p]=="hide"&&hidden||prop[p]=="show"&&!hidden)return opt.complete.call(this);if(p=="height"||p=="width"){opt.display=jQuery.css(this,"display");opt.overflow=this.style.overflow;}}if(opt.overflow!=null)this.style.overflow="hidden";opt.curAnim=jQuery.extend({},prop);jQuery.each(prop,function(name,val){var e=new jQuery.fx(self,opt,name);if(/toggle|show|hide/.test(val))e[val=="toggle"?hidden?"show":"hide":val](prop);else{var parts=val.toString().match(/^([+-]=)?([\d+-.]+)(.*)$/),start=e.cur(true)||0;if(parts){var end=parseFloat(parts[2]),unit=parts[3]||"px";if(unit!="px"){self.style[name]=(end||1)+unit;start=((end||1)/e.cur(true))*start;self.style[name]=start+unit;}if(parts[1])end=((parts[1]=="-="?-1:1)*end)+start;e.custom(start,end,unit);}else
+e.custom(start,val,"");}});return true;});},queue:function(type,fn){if(jQuery.isFunction(type)||(type&&type.constructor==Array)){fn=type;type="fx";}if(!type||(typeof type=="string"&&!fn))return queue(this[0],type);return this.each(function(){if(fn.constructor==Array)queue(this,type,fn);else{queue(this,type).push(fn);if(queue(this,type).length==1)fn.call(this);}});},stop:function(clearQueue,gotoEnd){var timers=jQuery.timers;if(clearQueue)this.queue([]);this.each(function(){for(var i=timers.length-1;i>=0;i--)if(timers[i].elem==this){if(gotoEnd)timers[i](true);timers.splice(i,1);}});if(!gotoEnd)this.dequeue();return this;}});var queue=function(elem,type,array){if(elem){type=type||"fx";var q=jQuery.data(elem,type+"queue");if(!q||array)q=jQuery.data(elem,type+"queue",jQuery.makeArray(array));}return q;};jQuery.fn.dequeue=function(type){type=type||"fx";return this.each(function(){var q=queue(this,type);q.shift();if(q.length)q[0].call(this);});};jQuery.extend({speed:function(speed,easing,fn){var opt=speed&&speed.constructor==Object?speed:{complete:fn||!fn&&easing||jQuery.isFunction(speed)&&speed,duration:speed,easing:fn&&easing||easing&&easing.constructor!=Function&&easing};opt.duration=(opt.duration&&opt.duration.constructor==Number?opt.duration:jQuery.fx.speeds[opt.duration])||jQuery.fx.speeds.def;opt.old=opt.complete;opt.complete=function(){if(opt.queue!==false)jQuery(this).dequeue();if(jQuery.isFunction(opt.old))opt.old.call(this);};return opt;},easing:{linear:function(p,n,firstNum,diff){return firstNum+diff*p;},swing:function(p,n,firstNum,diff){return((-Math.cos(p*Math.PI)/2)+0.5)*diff+firstNum;}},timers:[],timerId:null,fx:function(elem,options,prop){this.options=options;this.elem=elem;this.prop=prop;if(!options.orig)options.orig={};}});jQuery.fx.prototype={update:function(){if(this.options.step)this.options.step.call(this.elem,this.now,this);(jQuery.fx.step[this.prop]||jQuery.fx.step._default)(this);if(this.prop=="height"||this.prop=="width")this.elem.style.display="block";},cur:function(force){if(this.elem[this.prop]!=null&&this.elem.style[this.prop]==null)return this.elem[this.prop];var r=parseFloat(jQuery.css(this.elem,this.prop,force));return r&&r>-10000?r:parseFloat(jQuery.curCSS(this.elem,this.prop))||0;},custom:function(from,to,unit){this.startTime=now();this.start=from;this.end=to;this.unit=unit||this.unit||"px";this.now=this.start;this.pos=this.state=0;this.update();var self=this;function t(gotoEnd){return self.step(gotoEnd);}t.elem=this.elem;jQuery.timers.push(t);if(jQuery.timerId==null){jQuery.timerId=setInterval(function(){var timers=jQuery.timers;for(var i=0;i<timers.length;i++)if(!timers[i]())timers.splice(i--,1);if(!timers.length){clearInterval(jQuery.timerId);jQuery.timerId=null;}},13);}},show:function(){this.options.orig[this.prop]=jQuery.attr(this.elem.style,this.prop);this.options.show=true;this.custom(0,this.cur());if(this.prop=="width"||this.prop=="height")this.elem.style[this.prop]="1px";jQuery(this.elem).show();},hide:function(){this.options.orig[this.prop]=jQuery.attr(this.elem.style,this.prop);this.options.hide=true;this.custom(this.cur(),0);},step:function(gotoEnd){var t=now();if(gotoEnd||t>this.options.duration+this.startTime){this.now=this.end;this.pos=this.state=1;this.update();this.options.curAnim[this.prop]=true;var done=true;for(var i in this.options.curAnim)if(this.options.curAnim[i]!==true)done=false;if(done){if(this.options.display!=null){this.elem.style.overflow=this.options.overflow;this.elem.style.display=this.options.display;if(jQuery.css(this.elem,"display")=="none")this.elem.style.display="block";}if(this.options.hide)this.elem.style.display="none";if(this.options.hide||this.options.show)for(var p in this.options.curAnim)jQuery.attr(this.elem.style,p,this.options.orig[p]);}if(done)this.options.complete.call(this.elem);return false;}else{var n=t-this.startTime;this.state=n/this.options.duration;this.pos=jQuery.easing[this.options.easing||(jQuery.easing.swing?"swing":"linear")](this.state,n,0,1,this.options.duration);this.now=this.start+((this.end-this.start)*this.pos);this.update();}return true;}};jQuery.extend(jQuery.fx,{speeds:{slow:600,fast:200,def:400},step:{scrollLeft:function(fx){fx.elem.scrollLeft=fx.now;},scrollTop:function(fx){fx.elem.scrollTop=fx.now;},opacity:function(fx){jQuery.attr(fx.elem.style,"opacity",fx.now);},_default:function(fx){fx.elem.style[fx.prop]=fx.now+fx.unit;}}});jQuery.fn.offset=function(){var left=0,top=0,elem=this[0],results;if(elem)with(jQuery.browser){var parent=elem.parentNode,offsetChild=elem,offsetParent=elem.offsetParent,doc=elem.ownerDocument,safari2=safari&&parseInt(version)<522&&!/adobeair/i.test(userAgent),css=jQuery.curCSS,fixed=css(elem,"position")=="fixed";if(elem.getBoundingClientRect){var box=elem.getBoundingClientRect();add(box.left+Math.max(doc.documentElement.scrollLeft,doc.body.scrollLeft),box.top+Math.max(doc.documentElement.scrollTop,doc.body.scrollTop));add(-doc.documentElement.clientLeft,-doc.documentElement.clientTop);}else{add(elem.offsetLeft,elem.offsetTop);while(offsetParent){add(offsetParent.offsetLeft,offsetParent.offsetTop);if(mozilla&&!/^t(able|d|h)$/i.test(offsetParent.tagName)||safari&&!safari2)border(offsetParent);if(!fixed&&css(offsetParent,"position")=="fixed")fixed=true;offsetChild=/^body$/i.test(offsetParent.tagName)?offsetChild:offsetParent;offsetParent=offsetParent.offsetParent;}while(parent&&parent.tagName&&!/^body|html$/i.test(parent.tagName)){if(!/^inline|table.*$/i.test(css(parent,"display")))add(-parent.scrollLeft,-parent.scrollTop);if(mozilla&&css(parent,"overflow")!="visible")border(parent);parent=parent.parentNode;}if((safari2&&(fixed||css(offsetChild,"position")=="absolute"))||(mozilla&&css(offsetChild,"position")!="absolute"))add(-doc.body.offsetLeft,-doc.body.offsetTop);if(fixed)add(Math.max(doc.documentElement.scrollLeft,doc.body.scrollLeft),Math.max(doc.documentElement.scrollTop,doc.body.scrollTop));}results={top:top,left:left};}function border(elem){add(jQuery.curCSS(elem,"borderLeftWidth",true),jQuery.curCSS(elem,"borderTopWidth",true));}function add(l,t){left+=parseInt(l,10)||0;top+=parseInt(t,10)||0;}return results;};jQuery.fn.extend({position:function(){var left=0,top=0,results;if(this[0]){var offsetParent=this.offsetParent(),offset=this.offset(),parentOffset=/^body|html$/i.test(offsetParent[0].tagName)?{top:0,left:0}:offsetParent.offset();offset.top-=num(this,'marginTop');offset.left-=num(this,'marginLeft');parentOffset.top+=num(offsetParent,'borderTopWidth');parentOffset.left+=num(offsetParent,'borderLeftWidth');results={top:offset.top-parentOffset.top,left:offset.left-parentOffset.left};}return results;},offsetParent:function(){var offsetParent=this[0].offsetParent;while(offsetParent&&(!/^body|html$/i.test(offsetParent.tagName)&&jQuery.css(offsetParent,'position')=='static'))offsetParent=offsetParent.offsetParent;return jQuery(offsetParent);}});jQuery.each(['Left','Top'],function(i,name){var method='scroll'+name;jQuery.fn[method]=function(val){if(!this[0])return;return val!=undefined?this.each(function(){this==window||this==document?window.scrollTo(!i?val:jQuery(window).scrollLeft(),i?val:jQuery(window).scrollTop()):this[method]=val;}):this[0]==window||this[0]==document?self[i?'pageYOffset':'pageXOffset']||jQuery.boxModel&&document.documentElement[method]||document.body[method]:this[0][method];};});jQuery.each(["Height","Width"],function(i,name){var tl=i?"Left":"Top",br=i?"Right":"Bottom";jQuery.fn["inner"+name]=function(){return this[name.toLowerCase()]()+num(this,"padding"+tl)+num(this,"padding"+br);};jQuery.fn["outer"+name]=function(margin){return this["inner"+name]()+num(this,"border"+tl+"Width")+num(this,"border"+br+"Width")+(margin?num(this,"margin"+tl)+num(this,"margin"+br):0);};});})();
Copied: branches/testbaudson_dev/ext/jquery-ui-personalized-1.5.min.js (from rev 2556, trunk/mapbender/http/extensions/jquery-ui-personalized-1.5.min.js)
--- branches/testbaudson_dev/ext/jquery-ui-personalized-1.5.min.js	                        (rev 0)
+++ branches/testbaudson_dev/ext/jquery-ui-personalized-1.5.min.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,146 @@
+;(function($){$.ui={plugin:{add:function(module,option,set){var proto=$.ui[module].prototype;for(var i in set){proto.plugins[i]=proto.plugins[i]||[];proto.plugins[i].push([option,set[i]]);}},call:function(instance,name,args){var set=instance.plugins[name];if(!set){return;}
+for(var i=0;i<set.length;i++){if(instance.options[set[i][0]]){set[i][1].apply(instance.element,args);}}}},cssCache:{},css:function(name){if($.ui.cssCache[name]){return $.ui.cssCache[name];}
+var tmp=$('<div class="ui-resizable-gen">').addClass(name).css({position:'absolute',top:'-5000px',left:'-5000px',display:'block'}).appendTo('body');$.ui.cssCache[name]=!!((!(/auto|default/).test(tmp.css('cursor'))||(/^[1-9]/).test(tmp.css('height'))||(/^[1-9]/).test(tmp.css('width'))||!(/none/).test(tmp.css('backgroundImage'))||!(/transparent|rgba\(0, 0, 0, 0\)/).test(tmp.css('backgroundColor'))));try{$('body').get(0).removeChild(tmp.get(0));}catch(e){}
+return $.ui.cssCache[name];},disableSelection:function(e){e.unselectable="on";e.onselectstart=function(){return false;};if(e.style){e.style.MozUserSelect="none";}},enableSelection:function(e){e.unselectable="off";e.onselectstart=function(){return true;};if(e.style){e.style.MozUserSelect="";}},hasScroll:function(e,a){var scroll=/top/.test(a||"top")?'scrollTop':'scrollLeft',has=false;if(e[scroll]>0)return true;e[scroll]=1;has=e[scroll]>0?true:false;e[scroll]=0;return has;}};var _remove=$.fn.remove;$.fn.remove=function(){$("*",this).add(this).trigger("remove");return _remove.apply(this,arguments);};function getter(namespace,plugin,method){var methods=$[namespace][plugin].getter||[];methods=(typeof methods=="string"?methods.split(/,?\s+/):methods);return($.inArray(method,methods)!=-1);}
+$.widget=function(name,prototype){var namespace=name.split(".")[0];name=name.split(".")[1];$.fn[name]=function(options){var isMethodCall=(typeof options=='string'),args=Array.prototype.slice.call(arguments,1);if(isMethodCall&&getter(namespace,name,options)){var instance=$.data(this[0],name);return(instance?instance[options].apply(instance,args):undefined);}
+return this.each(function(){var instance=$.data(this,name);if(isMethodCall&&instance&&$.isFunction(instance[options])){instance[options].apply(instance,args);}else if(!isMethodCall){$.data(this,name,new $[namespace][name](this,options));}});};$[namespace][name]=function(element,options){var self=this;this.widgetName=name;this.widgetBaseClass=namespace+'-'+name;this.options=$.extend({disabled:false},$[namespace][name].defaults,options);this.element=$(element).bind('setData.'+name,function(e,key,value){return self.setData(key,value);}).bind('getData.'+name,function(e,key){return self.getData(key);}).bind('remove',function(){return self.destroy();});this.init();};$[namespace][name].prototype=$.extend({},$.widget.prototype,prototype);};$.widget.prototype={init:function(){},destroy:function(){this.element.removeData(this.widgetName);},getData:function(key){return this.options[key];},setData:function(key,value){this.options[key]=value;if(key=='disabled'){this.element[value?'addClass':'removeClass'](this.widgetBaseClass+'-disabled');}},enable:function(){this.setData('disabled',false);},disable:function(){this.setData('disabled',true);}};$.ui.mouse={mouseInit:function(){var self=this;this.element.bind('mousedown.'+this.widgetName,function(e){return self.mouseDown(e);});if($.browser.msie){this._mouseUnselectable=this.element.attr('unselectable');this.element.attr('unselectable','on');}
+this.started=false;},mouseDestroy:function(){this.element.unbind('.'+this.widgetName);($.browser.msie&&this.element.attr('unselectable',this._mouseUnselectable));},mouseDown:function(e){(this._mouseStarted&&this.mouseUp(e));this._mouseDownEvent=e;var self=this,btnIsLeft=(e.which==1),elIsCancel=(typeof this.options.cancel=="string"?$(e.target).is(this.options.cancel):false);if(!btnIsLeft||elIsCancel||!this.mouseCapture(e)){return true;}
+this._mouseDelayMet=!this.options.delay;if(!this._mouseDelayMet){this._mouseDelayTimer=setTimeout(function(){self._mouseDelayMet=true;},this.options.delay);}
+if(this.mouseDistanceMet(e)&&this.mouseDelayMet(e)){this._mouseStarted=(this.mouseStart(e)!==false);if(!this._mouseStarted){e.preventDefault();return true;}}
+this._mouseMoveDelegate=function(e){return self.mouseMove(e);};this._mouseUpDelegate=function(e){return self.mouseUp(e);};$(document).bind('mousemove.'+this.widgetName,this._mouseMoveDelegate).bind('mouseup.'+this.widgetName,this._mouseUpDelegate);return false;},mouseMove:function(e){if($.browser.msie&&!e.button){return this.mouseUp(e);}
+if(this._mouseStarted){this.mouseDrag(e);return false;}
+if(this.mouseDistanceMet(e)&&this.mouseDelayMet(e)){this._mouseStarted=(this.mouseStart(this._mouseDownEvent,e)!==false);(this._mouseStarted?this.mouseDrag(e):this.mouseUp(e));}
+return!this._mouseStarted;},mouseUp:function(e){$(document).unbind('mousemove.'+this.widgetName,this._mouseMoveDelegate).unbind('mouseup.'+this.widgetName,this._mouseUpDelegate);if(this._mouseStarted){this._mouseStarted=false;this.mouseStop(e);}
+return false;},mouseDistanceMet:function(e){return(Math.max(Math.abs(this._mouseDownEvent.pageX-e.pageX),Math.abs(this._mouseDownEvent.pageY-e.pageY))>=this.options.distance);},mouseDelayMet:function(e){return this._mouseDelayMet;},mouseStart:function(e){},mouseDrag:function(e){},mouseStop:function(e){},mouseCapture:function(e){return true;}};$.ui.mouse.defaults={cancel:null,distance:1,delay:0};})(jQuery);(function($){$.widget("ui.draggable",$.extend($.ui.mouse,{init:function(){var o=this.options;if(o.helper=='original'&&!(/(relative|absolute|fixed)/).test(this.element.css('position')))
+this.element.css('position','relative');this.element.addClass('ui-draggable');(o.disabled&&this.element.addClass('ui-draggable-disabled'));this.mouseInit();},mouseStart:function(e){var o=this.options;if(this.helper||o.disabled||$(e.target).is('.ui-resizable-handle'))return false;var handle=!this.options.handle||!$(this.options.handle,this.element).length?true:false;$(this.options.handle,this.element).find("*").andSelf().each(function(){if(this==e.target)handle=true;});if(!handle)return false;if($.ui.ddmanager)$.ui.ddmanager.current=this;this.helper=$.isFunction(o.helper)?$(o.helper.apply(this.element[0],[e])):(o.helper=='clone'?this.element.clone():this.element);if(!this.helper.parents('body').length)this.helper.appendTo((o.appendTo=='parent'?this.element[0].parentNode:o.appendTo));if(this.helper[0]!=this.element[0]&&!(/(fixed|absolute)/).test(this.helper.css("position")))this.helper.css("position","absolute");this.margins={left:(parseInt(this.element.css("marginLeft"),10)||0),top:(parseInt(this.element.css("marginTop"),10)||0)};this.cssPosition=this.helper.css("position");this.offset=this.element.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};this.offset.click={left:e.pageX-this.offset.left,top:e.pageY-this.offset.top};this.offsetParent=this.helper.offsetParent();var po=this.offsetParent.offset();if(this.offsetParent[0]==document.body&&$.browser.mozilla)po={top:0,left:0};this.offset.parent={top:po.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:po.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)};var p=this.element.position();this.offset.relative=this.cssPosition=="relative"?{top:p.top-(parseInt(this.helper.css("top"),10)||0)+this.offsetParent[0].scrollTop,left:p.left-(parseInt(this.helper.css("left"),10)||0)+this.offsetParent[0].scrollLeft}:{top:0,left:0};this.originalPosition=this.generatePosition(e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if(o.cursorAt){if(o.cursorAt.left!=undefined)this.offset.click.left=o.cursorAt.left+this.margins.left;if(o.cursorAt.right!=undefined)this.offset.click.left=this.helperProportions.width-o.cursorAt.right+this.margins.left;if(o.cursorAt.top!=undefined)this.offset.click.top=o.cursorAt.top+this.margins.top;if(o.cursorAt.bottom!=undefined)this.offset.click.top=this.helperProportions.height-o.cursorAt.bottom+this.margins.top;}
+if(o.containment){if(o.containment=='parent')o.containment=this.helper[0].parentNode;if(o.containment=='document'||o.containment=='window')this.containment=[0-this.offset.relative.left-this.offset.parent.left,0-this.offset.relative.top-this.offset.parent.top,$(o.containment=='document'?document:window).width()-this.offset.relative.left-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.element.css("marginRight"),10)||0),($(o.containment=='document'?document:window).height()||document.body.parentNode.scrollHeight)-this.offset.relative.top-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.element.css("marginBottom"),10)||0)];if(!(/^(document|window|parent)$/).test(o.containment)){var ce=$(o.containment)[0];var co=$(o.containment).offset();this.containment=[co.left+(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.relative.left-this.offset.parent.left,co.top+(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.relative.top-this.offset.parent.top,co.left+Math.max(ce.scrollWidth,ce.offsetWidth)-(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.relative.left-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.element.css("marginRight"),10)||0),co.top+Math.max(ce.scrollHeight,ce.offsetHeight)-(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.relative.top-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.element.css("marginBottom"),10)||0)];}}
+this.propagate("start",e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if($.ui.ddmanager&&!o.dropBehaviour)$.ui.ddmanager.prepareOffsets(this,e);this.helper.addClass("ui-draggable-dragging");this.mouseDrag(e);return true;},convertPositionTo:function(d,pos){if(!pos)pos=this.position;var mod=d=="absolute"?1:-1;return{top:(pos.top
++this.offset.relative.top*mod
++this.offset.parent.top*mod
+-(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollTop)*mod
++(this.cssPosition=="fixed"?this.offsetParent[0].scrollTop:0)*mod
++this.margins.top*mod),left:(pos.left
++this.offset.relative.left*mod
++this.offset.parent.left*mod
+-(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollLeft)*mod
++(this.cssPosition=="fixed"?this.offsetParent[0].scrollLeft:0)*mod
++this.margins.left*mod)};},generatePosition:function(e){var o=this.options;var position={top:(e.pageY
+-this.offset.click.top
+-this.offset.relative.top
+-this.offset.parent.top
++(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollTop)
+-(this.cssPosition=="fixed"?this.offsetParent[0].scrollTop:0)),left:(e.pageX
+-this.offset.click.left
+-this.offset.relative.left
+-this.offset.parent.left
++(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollLeft)
+-(this.cssPosition=="fixed"?this.offsetParent[0].scrollLeft:0))};if(!this.originalPosition)return position;if(this.containment){if(position.left<this.containment[0])position.left=this.containment[0];if(position.top<this.containment[1])position.top=this.containment[1];if(position.left>this.containment[2])position.left=this.containment[2];if(position.top>this.containment[3])position.top=this.containment[3];}
+if(o.grid){var top=this.originalPosition.top+Math.round((position.top-this.originalPosition.top)/o.grid[1])*o.grid[1];position.top=this.containment?(!(top<this.containment[1]||top>this.containment[3])?top:(!(top<this.containment[1])?top-o.grid[1]:top+o.grid[1])):top;var left=this.originalPosition.left+Math.round((position.left-this.originalPosition.left)/o.grid[0])*o.grid[0];position.left=this.containment?(!(left<this.containment[0]||left>this.containment[2])?left:(!(left<this.containment[0])?left-o.grid[0]:left+o.grid[0])):left;}
+return position;},mouseDrag:function(e){this.position=this.generatePosition(e);this.positionAbs=this.convertPositionTo("absolute");this.position=this.propagate("drag",e)||this.position;if(!this.options.axis||this.options.axis!="y")this.helper[0].style.left=this.position.left+'px';if(!this.options.axis||this.options.axis!="x")this.helper[0].style.top=this.position.top+'px';if($.ui.ddmanager)$.ui.ddmanager.drag(this,e);return false;},mouseStop:function(e){if($.ui.ddmanager&&!this.options.dropBehaviour)
+$.ui.ddmanager.drop(this,e);if(this.options.revert){var self=this;$(this.helper).animate(this.originalPosition,parseInt(this.options.revert,10)||500,function(){self.propagate("stop",e);self.clear();});}else{this.propagate("stop",e);this.clear();}
+return false;},clear:function(){this.helper.removeClass("ui-draggable-dragging");if(this.options.helper!='original'&&!this.cancelHelperRemoval)this.helper.remove();this.helper=null;this.cancelHelperRemoval=false;},plugins:{},uiHash:function(e){return{helper:this.helper,position:this.position,absolutePosition:this.positionAbs,options:this.options};},propagate:function(n,e){$.ui.plugin.call(this,n,[e,this.uiHash()]);return this.element.triggerHandler(n=="drag"?n:"drag"+n,[e,this.uiHash()],this.options[n]);},destroy:function(){if(!this.element.data('draggable'))return;this.element.removeData("draggable").unbind(".draggable").removeClass('ui-draggable');this.mouseDestroy();}}));$.extend($.ui.draggable,{defaults:{appendTo:"parent",axis:false,cancel:":input,button",delay:0,distance:0,helper:"original"}});$.ui.plugin.add("draggable","cursor",{start:function(e,ui){var t=$('body');if(t.css("cursor"))ui.options._cursor=t.css("cursor");t.css("cursor",ui.options.cursor);},stop:function(e,ui){if(ui.options._cursor)$('body').css("cursor",ui.options._cursor);}});$.ui.plugin.add("draggable","zIndex",{start:function(e,ui){var t=$(ui.helper);if(t.css("zIndex"))ui.options._zIndex=t.css("zIndex");t.css('zIndex',ui.options.zIndex);},stop:function(e,ui){if(ui.options._zIndex)$(ui.helper).css('zIndex',ui.options._zIndex);}});$.ui.plugin.add("draggable","opacity",{start:function(e,ui){var t=$(ui.helper);if(t.css("opacity"))ui.options._opacity=t.css("opacity");t.css('opacity',ui.options.opacity);},stop:function(e,ui){if(ui.options._opacity)$(ui.helper).css('opacity',ui.options._opacity);}});$.ui.plugin.add("draggable","iframeFix",{start:function(e,ui){$(ui.options.iframeFix===true?"iframe":ui.options.iframeFix).each(function(){$('<div class="ui-draggable-iframeFix" style="background: #fff;"></div>').css({width:this.offsetWidth+"px",height:this.offsetHeight+"px",position:"absolute",opacity:"0.001",zIndex:1000}).css($(this).offset()).appendTo("body");});},stop:function(e,ui){$("div.DragDropIframeFix").each(function(){this.parentNode.removeChild(this);});}});$.ui.plugin.add("draggable","scroll",{start:function(e,ui){var o=ui.options;var i=$(this).data("draggable");o.scrollSensitivity=o.scrollSensitivity||20;o.scrollSpeed=o.scrollSpeed||20;i.overflowY=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-y')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(this);i.overflowX=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-x')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(this);if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML')i.overflowYOffset=i.overflowY.offset();if(i.overflowX[0]!=document&&i.overflowX[0].tagName!='HTML')i.overflowXOffset=i.overflowX.offset();},drag:function(e,ui){var o=ui.options;var i=$(this).data("draggable");if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML'){if((i.overflowYOffset.top+i.overflowY[0].offsetHeight)-e.pageY<o.scrollSensitivity)
+i.overflowY[0].scrollTop=i.overflowY[0].scrollTop+o.scrollSpeed;if(e.pageY-i.overflowYOffset.top<o.scrollSensitivity)
+i.overflowY[0].scrollTop=i.overflowY[0].scrollTop-o.scrollSpeed;}else{if(e.pageY-$(document).scrollTop()<o.scrollSensitivity)
+$(document).scrollTop($(document).scrollTop()-o.scrollSpeed);if($(window).height()-(e.pageY-$(document).scrollTop())<o.scrollSensitivity)
+$(document).scrollTop($(document).scrollTop()+o.scrollSpeed);}
+if(i.overflowX[0]!=document&&i.overflowX[0].tagName!='HTML'){if((i.overflowXOffset.left+i.overflowX[0].offsetWidth)-e.pageX<o.scrollSensitivity)
+i.overflowX[0].scrollLeft=i.overflowX[0].scrollLeft+o.scrollSpeed;if(e.pageX-i.overflowXOffset.left<o.scrollSensitivity)
+i.overflowX[0].scrollLeft=i.overflowX[0].scrollLeft-o.scrollSpeed;}else{if(e.pageX-$(document).scrollLeft()<o.scrollSensitivity)
+$(document).scrollLeft($(document).scrollLeft()-o.scrollSpeed);if($(window).width()-(e.pageX-$(document).scrollLeft())<o.scrollSensitivity)
+$(document).scrollLeft($(document).scrollLeft()+o.scrollSpeed);}}});$.ui.plugin.add("draggable","snap",{start:function(e,ui){var inst=$(this).data("draggable");inst.snapElements=[];$(ui.options.snap===true?'.ui-draggable':ui.options.snap).each(function(){var $t=$(this);var $o=$t.offset();if(this!=inst.element[0])inst.snapElements.push({item:this,width:$t.outerWidth(),height:$t.outerHeight(),top:$o.top,left:$o.left});});},drag:function(e,ui){var inst=$(this).data("draggable");var d=ui.options.snapTolerance||20;var x1=ui.absolutePosition.left,x2=x1+inst.helperProportions.width,y1=ui.absolutePosition.top,y2=y1+inst.helperProportions.height;for(var i=inst.snapElements.length-1;i>=0;i--){var l=inst.snapElements[i].left,r=l+inst.snapElements[i].width,t=inst.snapElements[i].top,b=t+inst.snapElements[i].height;if(!((l-d<x1&&x1<r+d&&t-d<y1&&y1<b+d)||(l-d<x1&&x1<r+d&&t-d<y2&&y2<b+d)||(l-d<x2&&x2<r+d&&t-d<y1&&y1<b+d)||(l-d<x2&&x2<r+d&&t-d<y2&&y2<b+d)))continue;if(ui.options.snapMode!='inner'){var ts=Math.abs(t-y2)<=20;var bs=Math.abs(b-y1)<=20;var ls=Math.abs(l-x2)<=20;var rs=Math.abs(r-x1)<=20;if(ts)ui.position.top=inst.convertPositionTo("relative",{top:t-inst.helperProportions.height,left:0}).top;if(bs)ui.position.top=inst.convertPositionTo("relative",{top:b,left:0}).top;if(ls)ui.position.left=inst.convertPositionTo("relative",{top:0,left:l-inst.helperProportions.width}).left;if(rs)ui.position.left=inst.convertPositionTo("relative",{top:0,left:r}).left;}
+if(ui.options.snapMode!='outer'){var ts=Math.abs(t-y1)<=20;var bs=Math.abs(b-y2)<=20;var ls=Math.abs(l-x1)<=20;var rs=Math.abs(r-x2)<=20;if(ts)ui.position.top=inst.convertPositionTo("relative",{top:t,left:0}).top;if(bs)ui.position.top=inst.convertPositionTo("relative",{top:b-inst.helperProportions.height,left:0}).top;if(ls)ui.position.left=inst.convertPositionTo("relative",{top:0,left:l}).left;if(rs)ui.position.left=inst.convertPositionTo("relative",{top:0,left:r-inst.helperProportions.width}).left;}};}});$.ui.plugin.add("draggable","connectToSortable",{start:function(e,ui){var inst=$(this).data("draggable");inst.sortables=[];$(ui.options.connectToSortable).each(function(){if($.data(this,'sortable')){var sortable=$.data(this,'sortable');inst.sortables.push({instance:sortable,shouldRevert:sortable.options.revert});sortable.refresh();sortable.propagate("activate",e,inst);}});},stop:function(e,ui){var inst=$(this).data("draggable");$.each(inst.sortables,function(){if(this.instance.isOver){this.instance.isOver=0;inst.cancelHelperRemoval=true;this.instance.cancelHelperRemoval=false;if(this.shouldRevert)this.instance.options.revert=true;this.instance.mouseStop(e);this.instance.element.triggerHandler("sortreceive",[e,$.extend(this.instance.ui(),{sender:inst.element})],this.instance.options["receive"]);this.instance.options.helper=this.instance.options._helper;}else{this.instance.propagate("deactivate",e,inst);}});},drag:function(e,ui){var inst=$(this).data("draggable"),self=this;var checkPos=function(o){var l=o.left,r=l+o.width,t=o.top,b=t+o.height;return(l<(this.positionAbs.left+this.offset.click.left)&&(this.positionAbs.left+this.offset.click.left)<r&&t<(this.positionAbs.top+this.offset.click.top)&&(this.positionAbs.top+this.offset.click.top)<b);};$.each(inst.sortables,function(i){if(checkPos.call(inst,this.instance.containerCache)){if(!this.instance.isOver){this.instance.isOver=1;this.instance.currentItem=$(self).clone().appendTo(this.instance.element).data("sortable-item",true);this.instance.options._helper=this.instance.options.helper;this.instance.options.helper=function(){return ui.helper[0];};e.target=this.instance.currentItem[0];this.instance.mouseCapture(e,true,true);this.instance.mouseStart(e,true,true);this.instance.offset.click.top=inst.offset.click.top;this.instance.offset.click.left=inst.offset.click.left;this.instance.offset.parent.left-=inst.offset.parent.left-this.instance.offset.parent.left;this.instance.offset.parent.top-=inst.offset.parent.top-this.instance.offset.parent.top;inst.propagate("toSortable",e);}
+if(this.instance.currentItem)this.instance.mouseDrag(e);}else{if(this.instance.isOver){this.instance.isOver=0;this.instance.cancelHelperRemoval=true;this.instance.options.revert=false;this.instance.mouseStop(e,true);this.instance.options.helper=this.instance.options._helper;this.instance.currentItem.remove();this.instance.placeholder.remove();inst.propagate("fromSortable",e);}};});}});$.ui.plugin.add("draggable","stack",{start:function(e,ui){var group=$.makeArray($(ui.options.stack.group)).sort(function(a,b){return(parseInt($(a).css("zIndex"),10)||ui.options.stack.min)-(parseInt($(b).css("zIndex"),10)||ui.options.stack.min);});$(group).each(function(i){this.style.zIndex=ui.options.stack.min+i;});this[0].style.zIndex=ui.options.stack.min+group.length;}});})(jQuery);(function($){$.widget("ui.droppable",{init:function(){this.element.addClass("ui-droppable");this.isover=0;this.isout=1;var o=this.options,accept=o.accept;o=$.extend(o,{accept:o.accept&&o.accept.constructor==Function?o.accept:function(d){return $(d).is(accept);}});this.proportions={width:this.element.outerWidth(),height:this.element.outerHeight()};$.ui.ddmanager.droppables.push(this);},plugins:{},ui:function(c){return{draggable:(c.currentItem||c.element),helper:c.helper,position:c.position,absolutePosition:c.positionAbs,options:this.options,element:this.element};},destroy:function(){var drop=$.ui.ddmanager.droppables;for(var i=0;i<drop.length;i++)
+if(drop[i]==this)
+drop.splice(i,1);this.element.removeClass("ui-droppable ui-droppable-disabled").removeData("droppable").unbind(".droppable");},over:function(e){var draggable=$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return;if(this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){$.ui.plugin.call(this,'over',[e,this.ui(draggable)]);this.element.triggerHandler("dropover",[e,this.ui(draggable)],this.options.over);}},out:function(e){var draggable=$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return;if(this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){$.ui.plugin.call(this,'out',[e,this.ui(draggable)]);this.element.triggerHandler("dropout",[e,this.ui(draggable)],this.options.out);}},drop:function(e,custom){var draggable=custom||$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return false;var childrenIntersection=false;this.element.find(".ui-droppable").not(".ui-draggable-dragging").each(function(){var inst=$.data(this,'droppable');if(inst.options.greedy&&$.ui.intersect(draggable,$.extend(inst,{offset:inst.element.offset()}),inst.options.tolerance)){childrenIntersection=true;return false;}});if(childrenIntersection)return false;if(this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){$.ui.plugin.call(this,'drop',[e,this.ui(draggable)]);this.element.triggerHandler("drop",[e,this.ui(draggable)],this.options.drop);return true;}
+return false;},activate:function(e){var draggable=$.ui.ddmanager.current;$.ui.plugin.call(this,'activate',[e,this.ui(draggable)]);if(draggable)this.element.triggerHandler("dropactivate",[e,this.ui(draggable)],this.options.activate);},deactivate:function(e){var draggable=$.ui.ddmanager.current;$.ui.plugin.call(this,'deactivate',[e,this.ui(draggable)]);if(draggable)this.element.triggerHandler("dropdeactivate",[e,this.ui(draggable)],this.options.deactivate);}});$.extend($.ui.droppable,{defaults:{disabled:false,tolerance:'intersect'}});$.ui.intersect=function(draggable,droppable,toleranceMode){if(!droppable.offset)return false;var x1=(draggable.positionAbs||draggable.position.absolute).left,x2=x1+draggable.helperProportions.width,y1=(draggable.positionAbs||draggable.position.absolute).top,y2=y1+draggable.helperProportions.height;var l=droppable.offset.left,r=l+droppable.proportions.width,t=droppable.offset.top,b=t+droppable.proportions.height;switch(toleranceMode){case'fit':return(l<x1&&x2<r&&t<y1&&y2<b);break;case'intersect':return(l<x1+(draggable.helperProportions.width/2)&&x2-(draggable.helperProportions.width/2)<r&&t<y1+(draggable.helperProportions.height/2)&&y2-(draggable.helperProportions.height/2)<b);break;case'pointer':return(l<((draggable.positionAbs||draggable.position.absolute).left+(draggable.clickOffset||draggable.offset.click).left)&&((draggable.positionAbs||draggable.position.absolute).left+(draggable.clickOffset||draggable.offset.click).left)<r&&t<((draggable.positionAbs||draggable.position.absolute).top+(draggable.clickOffset||draggable.offset.click).top)&&((draggable.positionAbs||draggable.position.absolute).top+(draggable.clickOffset||draggable.offset.click).top)<b);break;case'touch':return((y1>=t&&y1<=b)||(y2>=t&&y2<=b)||(y1<t&&y2>b))&&((x1>=l&&x1<=r)||(x2>=l&&x2<=r)||(x1<l&&x2>r));break;default:return false;break;}};$.ui.ddmanager={current:null,droppables:[],prepareOffsets:function(t,e){var m=$.ui.ddmanager.droppables;var type=e?e.type:null;for(var i=0;i<m.length;i++){if(m[i].options.disabled||(t&&!m[i].options.accept.call(m[i].element,(t.currentItem||t.element))))continue;m[i].visible=m[i].element.is(":visible");if(!m[i].visible)continue;m[i].offset=m[i].element.offset();m[i].proportions={width:m[i].element.outerWidth(),height:m[i].element.outerHeight()};if(type=="dragstart"||type=="sortactivate")m[i].activate.call(m[i],e);}},drop:function(draggable,e){var dropped=false;$.each($.ui.ddmanager.droppables,function(){if(!this.options)return;if(!this.options.disabled&&this.visible&&$.ui.intersect(draggable,this,this.options.tolerance))
+dropped=this.drop.call(this,e);if(!this.options.disabled&&this.visible&&this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){this.isout=1;this.isover=0;this.deactivate.call(this,e);}});return dropped;},drag:function(draggable,e){if(draggable.options.refreshPositions)$.ui.ddmanager.prepareOffsets(draggable,e);$.each($.ui.ddmanager.droppables,function(){if(this.disabled||this.greedyChild||!this.visible)return;var intersects=$.ui.intersect(draggable,this,this.options.tolerance);var c=!intersects&&this.isover==1?'isout':(intersects&&this.isover==0?'isover':null);if(!c)return;var parentInstance;if(this.options.greedy){var parent=this.element.parents('.ui-droppable:eq(0)');if(parent.length){parentInstance=$.data(parent[0],'droppable');parentInstance.greedyChild=(c=='isover'?1:0);}}
+if(parentInstance&&c=='isover'){parentInstance['isover']=0;parentInstance['isout']=1;parentInstance.out.call(parentInstance,e);}
+this[c]=1;this[c=='isout'?'isover':'isout']=0;this[c=="isover"?"over":"out"].call(this,e);if(parentInstance&&c=='isout'){parentInstance['isout']=0;parentInstance['isover']=1;parentInstance.over.call(parentInstance,e);}});}};$.ui.plugin.add("droppable","activeClass",{activate:function(e,ui){$(this).addClass(ui.options.activeClass);},deactivate:function(e,ui){$(this).removeClass(ui.options.activeClass);},drop:function(e,ui){$(this).removeClass(ui.options.activeClass);}});$.ui.plugin.add("droppable","hoverClass",{over:function(e,ui){$(this).addClass(ui.options.hoverClass);},out:function(e,ui){$(this).removeClass(ui.options.hoverClass);},drop:function(e,ui){$(this).removeClass(ui.options.hoverClass);}});})(jQuery);(function($){$.widget("ui.resizable",$.extend($.ui.mouse,{init:function(){var self=this,o=this.options;var elpos=this.element.css('position');this.element.addClass("ui-resizable").css({position:/static/.test(elpos)?'relative':elpos});$.extend(o,{_aspectRatio:!!(o.aspectRatio),proxy:o.proxy||o.ghost||o.animate?o.proxy||'proxy':null,knobHandles:o.knobHandles===true?'ui-resizable-knob-handle':o.knobHandles});var aBorder='1px solid #DEDEDE';o.defaultTheme={'ui-resizable':{display:'block'},'ui-resizable-handle':{position:'absolute',background:'#F2F2F2',fontSize:'0.1px'},'ui-resizable-n':{cursor:'n-resize',height:'4px',left:'0px',right:'0px',borderTop:aBorder},'ui-resizable-s':{cursor:'s-resize',height:'4px',left:'0px',right:'0px',borderBottom:aBorder},'ui-resizable-e':{cursor:'e-resize',width:'4px',top:'0px',bottom:'0px',borderRight:aBorder},'ui-resizable-w':{cursor:'w-resize',width:'4px',top:'0px',bottom:'0px',borderLeft:aBorder},'ui-resizable-se':{cursor:'se-resize',width:'4px',height:'4px',borderRight:aBorder,borderBottom:aBorder},'ui-resizable-sw':{cursor:'sw-resize',width:'4px',height:'4px',borderBottom:aBorder,borderLeft:aBorder},'ui-resizable-ne':{cursor:'ne-resize',width:'4px',height:'4px',borderRight:aBorder,borderTop:aBorder},'ui-resizable-nw':{cursor:'nw-resize',width:'4px',height:'4px',borderLeft:aBorder,borderTop:aBorder}};o.knobTheme={'ui-resizable-handle':{background:'#F2F2F2',border:'1px solid #808080',height:'8px',width:'8px'},'ui-resizable-n':{cursor:'n-resize',top:'0px',left:'45%'},'ui-resizable-s':{cursor:'s-resize',bottom:'0px',left:'45%'},'ui-resizable-e':{cursor:'e-resize',right:'0px',top:'45%'},'ui-resizable-w':{cursor:'w-resize',left:'0px',top:'45%'},'ui-resizable-se':{cursor:'se-resize',right:'0px',bottom:'0px'},'ui-resizable-sw':{cursor:'sw-resize',left:'0px',bottom:'0px'},'ui-resizable-nw':{cursor:'nw-resize',left:'0px',top:'0px'},'ui-resizable-ne':{cursor:'ne-resize',right:'0px',top:'0px'}};o._nodeName=this.element[0].nodeName;if(o._nodeName.match(/canvas|textarea|input|select|button|img/i)){var el=this.element;if(/relative/.test(el.css('position'))&&$.browser.opera)
+el.css({position:'relative',top:'auto',left:'auto'});el.wrap($('<div class="ui-wrapper" style="overflow: hidden;"></div>').css({position:el.css('position'),width:el.outerWidth(),height:el.outerHeight(),top:el.css('top'),left:el.css('left')}));var oel=this.element;this.element=this.element.parent();this.element.data('resizable',this);this.element.css({marginLeft:oel.css("marginLeft"),marginTop:oel.css("marginTop"),marginRight:oel.css("marginRight"),marginBottom:oel.css("marginBottom")});oel.css({marginLeft:0,marginTop:0,marginRight:0,marginBottom:0});if($.browser.safari&&o.preventDefault)oel.css('resize','none');o.proportionallyResize=oel.css({position:'static',zoom:1,display:'block'});this.element.css({margin:oel.css('margin')});this._proportionallyResize();}
+if(!o.handles)o.handles=!$('.ui-resizable-handle',this.element).length?"e,s,se":{n:'.ui-resizable-n',e:'.ui-resizable-e',s:'.ui-resizable-s',w:'.ui-resizable-w',se:'.ui-resizable-se',sw:'.ui-resizable-sw',ne:'.ui-resizable-ne',nw:'.ui-resizable-nw'};if(o.handles.constructor==String){o.zIndex=o.zIndex||1000;if(o.handles=='all')o.handles='n,e,s,w,se,sw,ne,nw';var n=o.handles.split(",");o.handles={};var insertionsDefault={handle:'position: absolute; display: none; overflow:hidden;',n:'top: 0pt; width:100%;',e:'right: 0pt; height:100%;',s:'bottom: 0pt; width:100%;',w:'left: 0pt; height:100%;',se:'bottom: 0pt; right: 0px;',sw:'bottom: 0pt; left: 0px;',ne:'top: 0pt; right: 0px;',nw:'top: 0pt; left: 0px;'};for(var i=0;i<n.length;i++){var handle=$.trim(n[i]),dt=o.defaultTheme,hname='ui-resizable-'+handle,loadDefault=!$.ui.css(hname)&&!o.knobHandles,userKnobClass=$.ui.css('ui-resizable-knob-handle'),allDefTheme=$.extend(dt[hname],dt['ui-resizable-handle']),allKnobTheme=$.extend(o.knobTheme[hname],!userKnobClass?o.knobTheme['ui-resizable-handle']:{});var applyZIndex=/sw|se|ne|nw/.test(handle)?{zIndex:++o.zIndex}:{};var defCss=(loadDefault?insertionsDefault[handle]:''),axis=$(['<div class="ui-resizable-handle ',hname,'" style="',defCss,insertionsDefault.handle,'"></div>'].join('')).css(applyZIndex);o.handles[handle]='.ui-resizable-'+handle;this.element.append(axis.css(loadDefault?allDefTheme:{}).css(o.knobHandles?allKnobTheme:{}).addClass(o.knobHandles?'ui-resizable-knob-handle':'').addClass(o.knobHandles));}
+if(o.knobHandles)this.element.addClass('ui-resizable-knob').css(!$.ui.css('ui-resizable-knob')?{}:{});}
+this._renderAxis=function(target){target=target||this.element;for(var i in o.handles){if(o.handles[i].constructor==String)
+o.handles[i]=$(o.handles[i],this.element).show();if(o.transparent)
+o.handles[i].css({opacity:0});if(this.element.is('.ui-wrapper')&&o._nodeName.match(/textarea|input|select|button/i)){var axis=$(o.handles[i],this.element),padWrapper=0;padWrapper=/sw|ne|nw|se|n|s/.test(i)?axis.outerHeight():axis.outerWidth();var padPos=['padding',/ne|nw|n/.test(i)?'Top':/se|sw|s/.test(i)?'Bottom':/^e$/.test(i)?'Right':'Left'].join("");if(!o.transparent)
+target.css(padPos,padWrapper);this._proportionallyResize();}
+if(!$(o.handles[i]).length)continue;}};this._renderAxis(this.element);o._handles=$('.ui-resizable-handle',self.element);if(o.disableSelection)
+o._handles.each(function(i,e){$.ui.disableSelection(e);});o._handles.mouseover(function(){if(!o.resizing){if(this.className)
+var axis=this.className.match(/ui-resizable-(se|sw|ne|nw|n|e|s|w)/i);self.axis=o.axis=axis&&axis[1]?axis[1]:'se';}});if(o.autohide){o._handles.hide();$(self.element).addClass("ui-resizable-autohide").hover(function(){$(this).removeClass("ui-resizable-autohide");o._handles.show();},function(){if(!o.resizing){$(this).addClass("ui-resizable-autohide");o._handles.hide();}});}
+this.mouseInit();},plugins:{},ui:function(){return{axis:this.options.axis,options:this.options};},propagate:function(n,e){$.ui.plugin.call(this,n,[e,this.ui()]);this.element.triggerHandler(n=="resize"?n:["resize",n].join(""),[e,this.ui()],this.options[n]);},destroy:function(){var el=this.element,wrapped=el.children(".ui-resizable").get(0);this.mouseDestroy();var _destroy=function(exp){$(exp).removeClass("ui-resizable ui-resizable-disabled").removeData("resizable").unbind(".resizable").find('.ui-resizable-handle').remove();};_destroy(el);if(el.is('.ui-wrapper')&&wrapped){el.parent().append($(wrapped).css({position:el.css('position'),width:el.outerWidth(),height:el.outerHeight(),top:el.css('top'),left:el.css('left')})).end().remove();_destroy(wrapped);}},mouseStart:function(e){if(this.options.disabled)return false;var handle=false;for(var i in this.options.handles){if($(this.options.handles[i])[0]==e.target)handle=true;}
+if(!handle)return false;var o=this.options,iniPos=this.element.position(),el=this.element,num=function(v){return parseInt(v,10)||0;},ie6=$.browser.msie&&$.browser.version<7;o.resizing=true;o.documentScroll={top:$(document).scrollTop(),left:$(document).scrollLeft()};if(el.is('.ui-draggable')||(/absolute/).test(el.css('position'))){var sOffset=$.browser.msie&&!o.containment&&(/absolute/).test(el.css('position'))&&!(/relative/).test(el.parent().css('position'));var dscrollt=sOffset?o.documentScroll.top:0,dscrolll=sOffset?o.documentScroll.left:0;el.css({position:'absolute',top:(iniPos.top+dscrollt),left:(iniPos.left+dscrolll)});}
+if($.browser.opera&&/relative/.test(el.css('position')))
+el.css({position:'relative',top:'auto',left:'auto'});this._renderProxy();var curleft=num(this.helper.css('left')),curtop=num(this.helper.css('top'));this.offset=this.helper.offset();this.position={left:curleft,top:curtop};this.size=o.proxy||ie6?{width:el.outerWidth(),height:el.outerHeight()}:{width:el.width(),height:el.height()};this.originalSize=o.proxy||ie6?{width:el.outerWidth(),height:el.outerHeight()}:{width:el.width(),height:el.height()};this.originalPosition={left:curleft,top:curtop};this.sizeDiff={width:el.outerWidth()-el.width(),height:el.outerHeight()-el.height()};this.originalMousePosition={left:e.pageX,top:e.pageY};o.aspectRatio=(typeof o.aspectRatio=='number')?o.aspectRatio:((this.originalSize.height/this.originalSize.width)||1);if(o.preserveCursor)
+$('body').css('cursor',this.axis+'-resize');this.propagate("start",e);return true;},mouseDrag:function(e){var el=this.helper,o=this.options,props={},self=this,smp=this.originalMousePosition,a=this.axis;var dx=(e.pageX-smp.left)||0,dy=(e.pageY-smp.top)||0;var trigger=this._change[a];if(!trigger)return false;var data=trigger.apply(this,[e,dx,dy]),ie6=$.browser.msie&&$.browser.version<7,csdif=this.sizeDiff;if(o._aspectRatio||e.shiftKey)
+data=this._updateRatio(data,e);data=this._respectSize(data,e);this.propagate("resize",e);el.css({top:this.position.top+"px",left:this.position.left+"px",width:this.size.width+"px",height:this.size.height+"px"});if(!o.proxy&&o.proportionallyResize)
+this._proportionallyResize();this._updateCache(data);return false;},mouseStop:function(e){this.options.resizing=false;var o=this.options,num=function(v){return parseInt(v,10)||0;},self=this;if(o.proxy){var pr=o.proportionallyResize,ista=pr&&(/textarea/i).test(pr.get(0).nodeName),soffseth=ista&&$.ui.hasScroll(pr.get(0),'left')?0:self.sizeDiff.height,soffsetw=ista?0:self.sizeDiff.width;var s={width:(self.size.width-soffsetw),height:(self.size.height-soffseth)},left=(parseInt(self.element.css('left'),10)+(self.position.left-self.originalPosition.left))||null,top=(parseInt(self.element.css('top'),10)+(self.position.top-self.originalPosition.top))||null;if(!o.animate)
+this.element.css($.extend(s,{top:top,left:left}));if(o.proxy&&!o.animate)this._proportionallyResize();}
+if(o.preserveCursor)
+$('body').css('cursor','auto');this.propagate("stop",e);if(o.proxy)this.helper.remove();return false;},_updateCache:function(data){var o=this.options;this.offset=this.helper.offset();if(data.left)this.position.left=data.left;if(data.top)this.position.top=data.top;if(data.height)this.size.height=data.height;if(data.width)this.size.width=data.width;},_updateRatio:function(data,e){var o=this.options,cpos=this.position,csize=this.size,a=this.axis;if(data.height)data.width=(csize.height/o.aspectRatio);else if(data.width)data.height=(csize.width*o.aspectRatio);if(a=='sw'){data.left=cpos.left+(csize.width-data.width);data.top=null;}
+if(a=='nw'){data.top=cpos.top+(csize.height-data.height);data.left=cpos.left+(csize.width-data.width);}
+return data;},_respectSize:function(data,e){var el=this.helper,o=this.options,pRatio=o._aspectRatio||e.shiftKey,a=this.axis,ismaxw=data.width&&o.maxWidth&&o.maxWidth<data.width,ismaxh=data.height&&o.maxHeight&&o.maxHeight<data.height,isminw=data.width&&o.minWidth&&o.minWidth>data.width,isminh=data.height&&o.minHeight&&o.minHeight>data.height;if(isminw)data.width=o.minWidth;if(isminh)data.height=o.minHeight;if(ismaxw)data.width=o.maxWidth;if(ismaxh)data.height=o.maxHeight;var dw=this.originalPosition.left+this.originalSize.width,dh=this.position.top+this.size.height;var cw=/sw|nw|w/.test(a),ch=/nw|ne|n/.test(a);if(isminw&&cw)data.left=dw-o.minWidth;if(ismaxw&&cw)data.left=dw-o.maxWidth;if(isminh&&ch)data.top=dh-o.minHeight;if(ismaxh&&ch)data.top=dh-o.maxHeight;var isNotwh=!data.width&&!data.height;if(isNotwh&&!data.left&&data.top)data.top=null;else if(isNotwh&&!data.top&&data.left)data.left=null;return data;},_proportionallyResize:function(){var o=this.options;if(!o.proportionallyResize)return;var prel=o.proportionallyResize,el=this.helper||this.element;if(!o.borderDif){var b=[prel.css('borderTopWidth'),prel.css('borderRightWidth'),prel.css('borderBottomWidth'),prel.css('borderLeftWidth')],p=[prel.css('paddingTop'),prel.css('paddingRight'),prel.css('paddingBottom'),prel.css('paddingLeft')];o.borderDif=$.map(b,function(v,i){var border=parseInt(v,10)||0,padding=parseInt(p[i],10)||0;return border+padding;});}
+prel.css({height:(el.height()-o.borderDif[0]-o.borderDif[2])+"px",width:(el.width()-o.borderDif[1]-o.borderDif[3])+"px"});},_renderProxy:function(){var el=this.element,o=this.options;this.elementOffset=el.offset();if(o.proxy){this.helper=this.helper||$('<div style="overflow:hidden;"></div>');var ie6=$.browser.msie&&$.browser.version<7,ie6offset=(ie6?1:0),pxyoffset=(ie6?2:-1);this.helper.addClass(o.proxy).css({width:el.outerWidth()+pxyoffset,height:el.outerHeight()+pxyoffset,position:'absolute',left:this.elementOffset.left-ie6offset+'px',top:this.elementOffset.top-ie6offset+'px',zIndex:++o.zIndex});this.helper.appendTo("body");if(o.disableSelection)
+$.ui.disableSelection(this.helper.get(0));}else{this.helper=el;}},_change:{e:function(e,dx,dy){return{width:this.originalSize.width+dx};},w:function(e,dx,dy){var o=this.options,cs=this.originalSize,sp=this.originalPosition;return{left:sp.left+dx,width:cs.width-dx};},n:function(e,dx,dy){var o=this.options,cs=this.originalSize,sp=this.originalPosition;return{top:sp.top+dy,height:cs.height-dy};},s:function(e,dx,dy){return{height:this.originalSize.height+dy};},se:function(e,dx,dy){return $.extend(this._change.s.apply(this,arguments),this._change.e.apply(this,[e,dx,dy]));},sw:function(e,dx,dy){return $.extend(this._change.s.apply(this,arguments),this._change.w.apply(this,[e,dx,dy]));},ne:function(e,dx,dy){return $.extend(this._change.n.apply(this,arguments),this._change.e.apply(this,[e,dx,dy]));},nw:function(e,dx,dy){return $.extend(this._change.n.apply(this,arguments),this._change.w.apply(this,[e,dx,dy]));}}}));$.extend($.ui.resizable,{defaults:{cancel:":input,button",distance:0,delay:0,preventDefault:true,transparent:false,minWidth:10,minHeight:10,aspectRatio:false,disableSelection:true,preserveCursor:true,autohide:false,knobHandles:false}});$.ui.plugin.add("resizable","containment",{start:function(e,ui){var o=ui.options,self=$(this).data("resizable"),el=self.element;var oc=o.containment,ce=(oc instanceof $)?oc.get(0):(/parent/.test(oc))?el.parent().get(0):oc;if(!ce)return;self.containerElement=$(ce);if(/document/.test(oc)||oc==document){self.containerOffset={left:0,top:0};self.containerPosition={left:0,top:0};self.parentData={element:$(document),left:0,top:0,width:$(document).width(),height:$(document).height()||document.body.parentNode.scrollHeight};}
+else{self.containerOffset=$(ce).offset();self.containerPosition=$(ce).position();self.containerSize={height:$(ce).innerHeight(),width:$(ce).innerWidth()};var co=self.containerOffset,ch=self.containerSize.height,cw=self.containerSize.width,width=($.ui.hasScroll(ce,"left")?ce.scrollWidth:cw),height=($.ui.hasScroll(ce)?ce.scrollHeight:ch);self.parentData={element:ce,left:co.left,top:co.top,width:width,height:height};}},resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),ps=self.containerSize,co=self.containerOffset,cs=self.size,cp=self.position,pRatio=o._aspectRatio||e.shiftKey,cop={top:0,left:0},ce=self.containerElement;if(/static/.test(ce.css('position')))
+cop=self.containerPosition;if(cp.left<(o.proxy?co.left:cop.left)){self.size.width=self.size.width+(o.proxy?(self.position.left-co.left):(self.position.left-cop.left));if(pRatio)self.size.height=self.size.width*o.aspectRatio;self.position.left=o.proxy?co.left:cop.left;}
+if(cp.top<(o.proxy?co.top:0)){self.size.height=self.size.height+(o.proxy?(self.position.top-co.top):self.position.top);if(pRatio)self.size.width=self.size.height/o.aspectRatio;self.position.top=o.proxy?co.top:0;}
+var woset=(o.proxy?self.offset.left-co.left:(self.position.left-cop.left))+self.sizeDiff.width,hoset=(o.proxy?self.offset.top-co.top:self.position.top)+self.sizeDiff.height;if(woset+self.size.width>=self.parentData.width){self.size.width=self.parentData.width-woset;if(pRatio)self.size.height=self.size.width*o.aspectRatio;}
+if(hoset+self.size.height>=self.parentData.height){self.size.height=self.parentData.height-hoset;if(pRatio)self.size.width=self.size.height/o.aspectRatio;}},stop:function(e,ui){var o=ui.options,self=$(this).data("resizable"),cp=self.position,co=self.containerOffset,cop=self.containerPosition,ce=self.containerElement;var helper=$(self.helper),ho=helper.offset(),w=helper.innerWidth(),h=helper.innerHeight();if(o.proxy&&!o.animate&&/relative/.test(ce.css('position')))
+$(this).css({left:(ho.left-co.left),top:(ho.top-co.top),width:w,height:h});if(o.proxy&&!o.animate&&/static/.test(ce.css('position')))
+$(this).css({left:cop.left+(ho.left-co.left),top:cop.top+(ho.top-co.top),width:w,height:h});}});$.ui.plugin.add("resizable","grid",{resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),cs=self.size,os=self.originalSize,op=self.originalPosition,a=self.axis,ratio=o._aspectRatio||e.shiftKey;o.grid=typeof o.grid=="number"?[o.grid,o.grid]:o.grid;var ox=Math.round((cs.width-os.width)/(o.grid[0]||1))*(o.grid[0]||1),oy=Math.round((cs.height-os.height)/(o.grid[1]||1))*(o.grid[1]||1);if(/^(se|s|e)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;}
+else if(/^(ne)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.top=op.top-oy;}
+else if(/^(sw)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.left=op.left-ox;}
+else{self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.top=op.top-oy;self.position.left=op.left-ox;}}});$.ui.plugin.add("resizable","animate",{stop:function(e,ui){var o=ui.options,self=$(this).data("resizable");var pr=o.proportionallyResize,ista=pr&&(/textarea/i).test(pr.get(0).nodeName),soffseth=ista&&$.ui.hasScroll(pr.get(0),'left')?0:self.sizeDiff.height,soffsetw=ista?0:self.sizeDiff.width;var style={width:(self.size.width-soffsetw),height:(self.size.height-soffseth)},left=(parseInt(self.element.css('left'),10)+(self.position.left-self.originalPosition.left))||null,top=(parseInt(self.element.css('top'),10)+(self.position.top-self.originalPosition.top))||null;self.element.animate($.extend(style,top&&left?{top:top,left:left}:{}),{duration:o.animateDuration||"slow",easing:o.animateEasing||"swing",step:function(){var data={width:parseInt(self.element.css('width'),10),height:parseInt(self.element.css('height'),10),top:parseInt(self.element.css('top'),10),left:parseInt(self.element.css('left'),10)};if(pr)pr.css({width:data.width,height:data.height});self._updateCache(data);self.propagate("animate",e);}});}});$.ui.plugin.add("resizable","ghost",{start:function(e,ui){var o=ui.options,self=$(this).data("resizable"),pr=o.proportionallyResize,cs=self.size;if(!pr)self.ghost=self.element.clone();else self.ghost=pr.clone();self.ghost.css({opacity:.25,display:'block',position:'relative',height:cs.height,width:cs.width,margin:0,left:0,top:0}).addClass('ui-resizable-ghost').addClass(typeof o.ghost=='string'?o.ghost:'');self.ghost.appendTo(self.helper);},resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),pr=o.proportionallyResize;if(self.ghost)self.ghost.css({position:'relative',height:self.size.height,width:self.size.width});},stop:function(e,ui){var o=ui.options,self=$(this).data("resizable"),pr=o.proportionallyResize;if(self.ghost&&self.helper)self.helper.get(0).removeChild(self.ghost.get(0));}});$.ui.plugin.add("resizable","alsoResize",{start:function(e,ui){var o=ui.options,self=$(this).data("resizable"),_store=function(exp){$(exp).each(function(){$(this).data("resizable-alsoresize",{width:parseInt($(this).width(),10),height:parseInt($(this).height(),10),left:parseInt($(this).css('left'),10),top:parseInt($(this).css('top'),10)});});};if(typeof(o.alsoResize)=='object'){$.each(o.alsoResize,function(exp,c){_store(exp);});}else{_store(o.alsoResize);}},resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),os=self.originalSize,op=self.originalPosition;var delta={height:(self.size.height-os.height)||0,width:(self.size.width-os.width)||0,top:(self.position.top-op.top)||0,left:(self.position.left-op.left)||0},_alsoResize=function(exp,c){$(exp).each(function(){var start=$(this).data("resizable-alsoresize"),style={},css=c&&c.length?c:['width','height','top','left'];$.each(css||['width','height','top','left'],function(i,prop){var sum=(start[prop]||0)+(delta[prop]||0);if(sum&&sum>=0)
+style[prop]=sum||null;});$(this).css(style);});};if(typeof(o.alsoResize)=='object'){$.each(o.alsoResize,function(exp,c){_alsoResize(exp,c);});}else{_alsoResize(o.alsoResize);}},stop:function(e,ui){$(this).removeData("resizable-alsoresize-start");}});})(jQuery);(function($){$.widget("ui.selectable",$.extend($.ui.mouse,{init:function(){var self=this;this.element.addClass("ui-selectable");this.dragged=false;var selectees;this.refresh=function(){selectees=$(self.options.filter,self.element[0]);selectees.each(function(){var $this=$(this);var pos=$this.offset();$.data(this,"selectable-item",{element:this,$element:$this,left:pos.left,top:pos.top,right:pos.left+$this.width(),bottom:pos.top+$this.height(),startselected:false,selected:$this.hasClass('ui-selected'),selecting:$this.hasClass('ui-selecting'),unselecting:$this.hasClass('ui-unselecting')});});};this.refresh();this.selectees=selectees.addClass("ui-selectee");this.mouseInit();this.helper=$(document.createElement('div')).css({border:'1px dotted black'});},toggle:function(){if(this.options.disabled){this.enable();}else{this.disable();}},destroy:function(){this.element.removeClass("ui-selectable ui-selectable-disabled").removeData("selectable").unbind(".selectable");this.mouseDestroy();},mouseStart:function(e){var self=this;this.opos=[e.pageX,e.pageY];if(this.options.disabled)
+return;var options=this.options;this.selectees=$(options.filter,this.element[0]);this.element.triggerHandler("selectablestart",[e,{"selectable":this.element[0],"options":options}],options.start);$('body').append(this.helper);this.helper.css({"z-index":100,"position":"absolute","left":e.clientX,"top":e.clientY,"width":0,"height":0});if(options.autoRefresh){this.refresh();}
+this.selectees.filter('.ui-selected').each(function(){var selectee=$.data(this,"selectable-item");selectee.startselected=true;if(!e.ctrlKey){selectee.$element.removeClass('ui-selected');selectee.selected=false;selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;self.element.triggerHandler("selectableunselecting",[e,{selectable:self.element[0],unselecting:selectee.element,options:options}],options.unselecting);}});var isSelectee=false;$(e.target).parents().andSelf().each(function(){if($.data(this,"selectable-item"))isSelectee=true;});return this.options.keyboard?!isSelectee:true;},mouseDrag:function(e){var self=this;this.dragged=true;if(this.options.disabled)
+return;var options=this.options;var x1=this.opos[0],y1=this.opos[1],x2=e.pageX,y2=e.pageY;if(x1>x2){var tmp=x2;x2=x1;x1=tmp;}
+if(y1>y2){var tmp=y2;y2=y1;y1=tmp;}
+this.helper.css({left:x1,top:y1,width:x2-x1,height:y2-y1});this.selectees.each(function(){var selectee=$.data(this,"selectable-item");if(!selectee||selectee.element==self.element[0])
+return;var hit=false;if(options.tolerance=='touch'){hit=(!(selectee.left>x2||selectee.right<x1||selectee.top>y2||selectee.bottom<y1));}else if(options.tolerance=='fit'){hit=(selectee.left>x1&&selectee.right<x2&&selectee.top>y1&&selectee.bottom<y2);}
+if(hit){if(selectee.selected){selectee.$element.removeClass('ui-selected');selectee.selected=false;}
+if(selectee.unselecting){selectee.$element.removeClass('ui-unselecting');selectee.unselecting=false;}
+if(!selectee.selecting){selectee.$element.addClass('ui-selecting');selectee.selecting=true;self.element.triggerHandler("selectableselecting",[e,{selectable:self.element[0],selecting:selectee.element,options:options}],options.selecting);}}else{if(selectee.selecting){if(e.ctrlKey&&selectee.startselected){selectee.$element.removeClass('ui-selecting');selectee.selecting=false;selectee.$element.addClass('ui-selected');selectee.selected=true;}else{selectee.$element.removeClass('ui-selecting');selectee.selecting=false;if(selectee.startselected){selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;}
+self.element.triggerHandler("selectableunselecting",[e,{selectable:self.element[0],unselecting:selectee.element,options:options}],options.unselecting);}}
+if(selectee.selected){if(!e.ctrlKey&&!selectee.startselected){selectee.$element.removeClass('ui-selected');selectee.selected=false;selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;self.element.triggerHandler("selectableunselecting",[e,{selectable:self.element[0],unselecting:selectee.element,options:options}],options.unselecting);}}}});return false;},mouseStop:function(e){var self=this;this.dragged=false;var options=this.options;$('.ui-unselecting',this.element[0]).each(function(){var selectee=$.data(this,"selectable-item");selectee.$element.removeClass('ui-unselecting');selectee.unselecting=false;selectee.startselected=false;self.element.triggerHandler("selectableunselected",[e,{selectable:self.element[0],unselected:selectee.element,options:options}],options.unselected);});$('.ui-selecting',this.element[0]).each(function(){var selectee=$.data(this,"selectable-item");selectee.$element.removeClass('ui-selecting').addClass('ui-selected');selectee.selecting=false;selectee.selected=true;selectee.startselected=true;self.element.triggerHandler("selectableselected",[e,{selectable:self.element[0],selected:selectee.element,options:options}],options.selected);});this.element.triggerHandler("selectablestop",[e,{selectable:self.element[0],options:this.options}],this.options.stop);this.helper.remove();return false;}}));$.extend($.ui.selectable,{defaults:{distance:0,delay:0,cancel:":input,button",appendTo:'body',autoRefresh:true,filter:'*',tolerance:'touch'}});})(jQuery);(function($){function contains(a,b){var safari2=$.browser.safari&&$.browser.version<522;if(a.contains&&!safari2){return a.contains(b);}
+if(a.compareDocumentPosition)
+return!!(a.compareDocumentPosition(b)&16);while(b=b.parentNode)
+if(b==a)return true;return false;};$.widget("ui.sortable",$.extend($.ui.mouse,{init:function(){var o=this.options;this.containerCache={};this.element.addClass("ui-sortable");this.refresh();this.floating=this.items.length?(/left|right/).test(this.items[0].item.css('float')):false;if(!(/(relative|absolute|fixed)/).test(this.element.css('position')))this.element.css('position','relative');this.offset=this.element.offset();this.mouseInit();},plugins:{},ui:function(inst){return{helper:(inst||this)["helper"],placeholder:(inst||this)["placeholder"]||$([]),position:(inst||this)["position"],absolutePosition:(inst||this)["positionAbs"],options:this.options,element:this.element,item:(inst||this)["currentItem"],sender:inst?inst.element:null};},propagate:function(n,e,inst,noPropagation){$.ui.plugin.call(this,n,[e,this.ui(inst)]);if(!noPropagation)this.element.triggerHandler(n=="sort"?n:"sort"+n,[e,this.ui(inst)],this.options[n]);},serialize:function(o){var items=($.isFunction(this.options.items)?this.options.items.call(this.element):$(this.options.items,this.element)).not('.ui-sortable-helper');var str=[];o=o||{};items.each(function(){var res=($(this).attr(o.attribute||'id')||'').match(o.expression||(/(.+)[-=_](.+)/));if(res)str.push((o.key||res[1])+'[]='+(o.key?res[1]:res[2]));});return str.join('&');},toArray:function(attr){var items=($.isFunction(this.options.items)?this.options.items.call(this.element):$(this.options.items,this.element)).not('.ui-sortable-helper');var ret=[];items.each(function(){ret.push($(this).attr(attr||'id'));});return ret;},intersectsWith:function(item){var x1=this.positionAbs.left,x2=x1+this.helperProportions.width,y1=this.positionAbs.top,y2=y1+this.helperProportions.height;var l=item.left,r=l+item.width,t=item.top,b=t+item.height;if(this.options.tolerance=="pointer"||(this.options.tolerance=="guess"&&this.helperProportions[this.floating?'width':'height']>item[this.floating?'width':'height'])){return(y1+this.offset.click.top>t&&y1+this.offset.click.top<b&&x1+this.offset.click.left>l&&x1+this.offset.click.left<r);}else{return(l<x1+(this.helperProportions.width/2)&&x2-(this.helperProportions.width/2)<r&&t<y1+(this.helperProportions.height/2)&&y2-(this.helperProportions.height/2)<b);}},intersectsWithEdge:function(item){var x1=this.positionAbs.left,x2=x1+this.helperProportions.width,y1=this.positionAbs.top,y2=y1+this.helperProportions.height;var l=item.left,r=l+item.width,t=item.top,b=t+item.height;if(this.options.tolerance=="pointer"||(this.options.tolerance=="guess"&&this.helperProportions[this.floating?'width':'height']>item[this.floating?'width':'height'])){if(!(y1+this.offset.click.top>t&&y1+this.offset.click.top<b&&x1+this.offset.click.left>l&&x1+this.offset.click.left<r))return false;if(this.floating){if(x1+this.offset.click.left>l&&x1+this.offset.click.left<l+item.width/2)return 2;if(x1+this.offset.click.left>l+item.width/2&&x1+this.offset.click.left<r)return 1;}else{if(y1+this.offset.click.top>t&&y1+this.offset.click.top<t+item.height/2)return 2;if(y1+this.offset.click.top>t+item.height/2&&y1+this.offset.click.top<b)return 1;}}else{if(!(l<x1+(this.helperProportions.width/2)&&x2-(this.helperProportions.width/2)<r&&t<y1+(this.helperProportions.height/2)&&y2-(this.helperProportions.height/2)<b))return false;if(this.floating){if(x2>l&&x1<l)return 2;if(x1<r&&x2>r)return 1;}else{if(y2>t&&y1<t)return 1;if(y1<b&&y2>b)return 2;}}
+return false;},refresh:function(){this.refreshItems();this.refreshPositions();},refreshItems:function(){this.items=[];this.containers=[this];var items=this.items;var queries=[$.isFunction(this.options.items)?this.options.items.call(this.element):$(this.options.items,this.element)];if(this.options.connectWith){for(var i=this.options.connectWith.length-1;i>=0;i--){var cur=$(this.options.connectWith[i]);for(var j=cur.length-1;j>=0;j--){var inst=$.data(cur[j],'sortable');if(inst&&!inst.options.disabled){queries.push($.isFunction(inst.options.items)?inst.options.items.call(inst.element):$(inst.options.items,inst.element));this.containers.push(inst);}};};}
+for(var i=queries.length-1;i>=0;i--){queries[i].each(function(){$.data(this,'sortable-item',true);items.push({item:$(this),width:0,height:0,left:0,top:0});});};},refreshPositions:function(fast){for(var i=this.items.length-1;i>=0;i--){var t=this.items[i].item;if(!fast)this.items[i].width=(this.options.toleranceElement?$(this.options.toleranceElement,t):t).outerWidth();if(!fast)this.items[i].height=(this.options.toleranceElement?$(this.options.toleranceElement,t):t).outerHeight();var p=(this.options.toleranceElement?$(this.options.toleranceElement,t):t).offset();this.items[i].left=p.left;this.items[i].top=p.top;};for(var i=this.containers.length-1;i>=0;i--){var p=this.containers[i].element.offset();this.containers[i].containerCache.left=p.left;this.containers[i].containerCache.top=p.top;this.containers[i].containerCache.width=this.containers[i].element.outerWidth();this.containers[i].containerCache.height=this.containers[i].element.outerHeight();};},destroy:function(){this.element.removeClass("ui-sortable ui-sortable-disabled").removeData("sortable").unbind(".sortable");this.mouseDestroy();for(var i=this.items.length-1;i>=0;i--)
+this.items[i].item.removeData("sortable-item");},createPlaceholder:function(that){var self=that||this,o=self.options;if(o.placeholder.constructor==String){var className=o.placeholder;o.placeholder={element:function(){return $('<div></div>').addClass(className)[0];},update:function(i,p){p.css(i.offset()).css({width:i.outerWidth(),height:i.outerHeight()});}};}
+self.placeholder=$(o.placeholder.element.call(self.element,self.currentItem)).appendTo('body').css({position:'absolute'});o.placeholder.update.call(self.element,self.currentItem,self.placeholder);},contactContainers:function(e){for(var i=this.containers.length-1;i>=0;i--){if(this.intersectsWith(this.containers[i].containerCache)){if(!this.containers[i].containerCache.over){if(this.currentContainer!=this.containers[i]){var dist=10000;var itemWithLeastDistance=null;var base=this.positionAbs[this.containers[i].floating?'left':'top'];for(var j=this.items.length-1;j>=0;j--){if(!contains(this.containers[i].element[0],this.items[j].item[0]))continue;var cur=this.items[j][this.containers[i].floating?'left':'top'];if(Math.abs(cur-base)<dist){dist=Math.abs(cur-base);itemWithLeastDistance=this.items[j];}}
+if(!itemWithLeastDistance&&!this.options.dropOnEmpty)
+continue;if(this.placeholder)this.placeholder.remove();if(this.containers[i].options.placeholder){this.containers[i].createPlaceholder(this);}else{this.placeholder=null;;}
+itemWithLeastDistance?this.rearrange(e,itemWithLeastDistance):this.rearrange(e,null,this.containers[i].element);this.propagate("change",e);this.containers[i].propagate("change",e,this);this.currentContainer=this.containers[i];}
+this.containers[i].propagate("over",e,this);this.containers[i].containerCache.over=1;}}else{if(this.containers[i].containerCache.over){this.containers[i].propagate("out",e,this);this.containers[i].containerCache.over=0;}}};},mouseCapture:function(e,overrideHandle){if(this.options.disabled||this.options.type=='static')return false;var currentItem=null,nodes=$(e.target).parents().each(function(){if($.data(this,'sortable-item')){currentItem=$(this);return false;}});if($.data(e.target,'sortable-item'))currentItem=$(e.target);if(!currentItem)return false;if(this.options.handle&&!overrideHandle){var validHandle=false;$(this.options.handle,currentItem).find("*").andSelf().each(function(){if(this==e.target)validHandle=true;});if(!validHandle)return false;}
+this.currentItem=currentItem;return true;},mouseStart:function(e,overrideHandle,noActivation){var o=this.options;this.currentContainer=this;this.refresh();this.helper=typeof o.helper=='function'?$(o.helper.apply(this.element[0],[e,this.currentItem])):this.currentItem.clone();if(!this.helper.parents('body').length)this.helper.appendTo((o.appendTo!='parent'?o.appendTo:this.currentItem[0].parentNode));this.helper.css({position:'absolute',clear:'both'}).addClass('ui-sortable-helper');this.margins={left:(parseInt(this.currentItem.css("marginLeft"),10)||0),top:(parseInt(this.currentItem.css("marginTop"),10)||0)};this.offset=this.currentItem.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};this.offset.click={left:e.pageX-this.offset.left,top:e.pageY-this.offset.top};this.offsetParent=this.helper.offsetParent();var po=this.offsetParent.offset();this.offset.parent={top:po.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:po.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)};this.originalPosition=this.generatePosition(e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if(o.cursorAt){if(o.cursorAt.left!=undefined)this.offset.click.left=o.cursorAt.left;if(o.cursorAt.right!=undefined)this.offset.click.left=this.helperProportions.width-o.cursorAt.right;if(o.cursorAt.top!=undefined)this.offset.click.top=o.cursorAt.top;if(o.cursorAt.bottom!=undefined)this.offset.click.top=this.helperProportions.height-o.cursorAt.bottom;}
+this.domPosition=this.currentItem.prev()[0];if(o.containment){if(o.containment=='parent')o.containment=this.helper[0].parentNode;if(o.containment=='document'||o.containment=='window')this.containment=[0-this.offset.parent.left,0-this.offset.parent.top,$(o.containment=='document'?document:window).width()-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.element.css("marginRight"),10)||0),($(o.containment=='document'?document:window).height()||document.body.parentNode.scrollHeight)-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.element.css("marginBottom"),10)||0)];if(!(/^(document|window|parent)$/).test(o.containment)){var ce=$(o.containment)[0];var co=$(o.containment).offset();this.containment=[co.left+(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.parent.left,co.top+(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.parent.top,co.left+Math.max(ce.scrollWidth,ce.offsetWidth)-(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.currentItem.css("marginRight"),10)||0),co.top+Math.max(ce.scrollHeight,ce.offsetHeight)-(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.currentItem.css("marginBottom"),10)||0)];}}
+if(o.placeholder)this.createPlaceholder();this.propagate("start",e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if(this.options.placeholder!='clone')this.currentItem.css('visibility','hidden');if(!noActivation){for(var i=this.containers.length-1;i>=0;i--){this.containers[i].propagate("activate",e,this);}}
+if($.ui.ddmanager)$.ui.ddmanager.current=this;if($.ui.ddmanager&&!o.dropBehaviour)$.ui.ddmanager.prepareOffsets(this,e);this.dragging=true;this.mouseDrag(e);return true;},convertPositionTo:function(d,pos){if(!pos)pos=this.position;var mod=d=="absolute"?1:-1;return{top:(pos.top
+-(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)*mod
+-(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft)*mod
++(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)),left:(e.pageX
++(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft))};if(!this.originalPosition)return position;if(this.containment){if(position.left<this.containment[0])position.left=this.containment[0];if(position.top<this.containment[1])position.top=this.containment[1];if(position.left>this.containment[2])position.left=this.containment[2];if(position.top>this.containment[3])position.top=this.containment[3];}
+return position;},mouseDrag:function(e){this.position=this.generatePosition(e);this.positionAbs=this.convertPositionTo("absolute");for(var i=this.items.length-1;i>=0;i--){var intersection=this.intersectsWithEdge(this.items[i]);if(!intersection)continue;if(this.items[i].item[0]!=this.currentItem[0]&&this.currentItem[intersection==1?"next":"prev"]()[0]!=this.items[i].item[0]&&!contains(this.currentItem[0],this.items[i].item[0])&&(this.options.type=='semi-dynamic'?!contains(this.element[0],this.items[i].item[0]):true)){this.direction=intersection==1?"down":"up";this.rearrange(e,this.items[i]);this.propagate("change",e);break;}}
+this.contactContainers(e);this.propagate("sort",e);if(!this.options.axis||this.options.axis=="x")this.helper[0].style.left=this.position.left+'px';if(!this.options.axis||this.options.axis=="y")this.helper[0].style.top=this.position.top+'px';if($.ui.ddmanager)$.ui.ddmanager.drag(this,e);return false;},mouseStop:function(e,noPropagation){if($.ui.ddmanager&&!this.options.dropBehaviour)
+$.ui.ddmanager.drop(this,e);if(this.options.revert){var self=this;var cur=self.currentItem.offset();if(self.placeholder)self.placeholder.animate({opacity:'hide'},(parseInt(this.options.revert,10)||500)-50);$(this.helper).animate({left:cur.left-this.offset.parent.left-self.margins.left+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft),top:cur.top-this.offset.parent.top-self.margins.top+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)},parseInt(this.options.revert,10)||500,function(){self.propagate("stop",e,null,noPropagation);self.clear(e);});}else{this.propagate("stop",e,null,noPropagation);this.clear(e,noPropagation);}
+return false;},clear:function(e,noPropagation){if(this.domPosition!=this.currentItem.prev().not(".ui-sortable-helper")[0])this.propagate("update",e,null,noPropagation);if(!contains(this.element[0],this.currentItem[0])){if(this.domPosition==this.currentItem.prev().not(".ui-sortable-helper")[0])this.propagate("update",e,null,noPropagation);this.propagate("remove",e,null,noPropagation);for(var i=this.containers.length-1;i>=0;i--){if(contains(this.containers[i].element[0],this.currentItem[0])){this.containers[i].propagate("update",e,this,noPropagation);this.containers[i].propagate("receive",e,this,noPropagation);}};};for(var i=this.containers.length-1;i>=0;i--){this.containers[i].propagate("deactivate",e,this,noPropagation);if(this.containers[i].containerCache.over){this.containers[i].propagate("out",e,this);this.containers[i].containerCache.over=0;}}
+this.dragging=false;if(this.cancelHelperRemoval)return false;$(this.currentItem).css('visibility','');if(this.placeholder)this.placeholder.remove();this.helper.remove();return true;},rearrange:function(e,i,a){a?a.append(this.currentItem):i.item[this.direction=='down'?'before':'after'](this.currentItem);this.refreshPositions(true);if(this.options.placeholder)this.options.placeholder.update.call(this.element,this.currentItem,this.placeholder);}}));$.extend($.ui.sortable,{getter:"serialize toArray",defaults:{tolerance:"guess",distance:0,delay:0,cancel:":input,button",items:'> *',zIndex:1000,dropOnEmpty:true,appendTo:"parent"}});$.ui.plugin.add("sortable","cursor",{start:function(e,ui){var t=$('body');if(t.css("cursor"))ui.options._cursor=t.css("cursor");t.css("cursor",ui.options.cursor);},stop:function(e,ui){if(ui.options._cursor)$('body').css("cursor",ui.options._cursor);}});$.ui.plugin.add("sortable","zIndex",{start:function(e,ui){var t=ui.helper;if(t.css("zIndex"))ui.options._zIndex=t.css("zIndex");t.css('zIndex',ui.options.zIndex);},stop:function(e,ui){if(ui.options._zIndex)$(ui.helper).css('zIndex',ui.options._zIndex);}});$.ui.plugin.add("sortable","opacity",{start:function(e,ui){var t=ui.helper;if(t.css("opacity"))ui.options._opacity=t.css("opacity");t.css('opacity',ui.options.opacity);},stop:function(e,ui){if(ui.options._opacity)$(ui.helper).css('opacity',ui.options._opacity);}});$.ui.plugin.add("sortable","scroll",{start:function(e,ui){var o=ui.options;var i=$(this).data("sortable");o.scrollSensitivity=o.scrollSensitivity||20;o.scrollSpeed=o.scrollSpeed||20;i.overflowY=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-y')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(i.currentItem);i.overflowX=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-x')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(i.currentItem);if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML')i.overflowYOffset=i.overflowY.offset();if(i.overflowX[0]!=document&&i.overflowX[0].tagName!='HTML')i.overflowXOffset=i.overflowX.offset();},sort:function(e,ui){var o=ui.options;var i=$(this).data("sortable");if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML'){if((i.overflowYOffset.top+i.overflowY[0].offsetHeight)-e.pageY<o.scrollSensitivity)
+$(document).scrollLeft($(document).scrollLeft()+o.scrollSpeed);}}});})(jQuery);
\ No newline at end of file
Copied: branches/testbaudson_dev/ext/jquery.ajaxmanager.js (from rev 2556, trunk/mapbender/http/extensions/jquery.ajaxmanager.js)
--- branches/testbaudson_dev/ext/jquery.ajaxmanager.js	                        (rev 0)
+++ branches/testbaudson_dev/ext/jquery.ajaxmanager.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,165 @@
+ * @author Administrator
+(function($) {
+    $.extend({
+        manageAjax: function(o){
+          o = $.extend({manageType: 'normal',maxReq: 0, blockSameRequest: false},o);
+          return new $.ajaxManager(o);
+        ajaxManager: function(o){
+            this.opt = o;
+            this.queue = [];
+    $.extend(
+        $.ajaxManager.prototype,
+            add: function(o){
+                 var quLen = this.queue.length, s = this.opt, q = this.queue, self = this,i,j;
+                 var cD = (o.data && typeof o.data != "string")?$.param(o.data):o.data;
+                 if(s.blockSameRequest){
+                    var toPrevent = false;
+                    for (var i = 0;i<quLen; i++){
+                        if(q[i] && q[i].data === cD && q[i].url === o.url && q[i].type === o.type) {
+                            toPrevent = true;
+                            break;
+                    if(toPrevent)
+                        return false;
+                 q[ quLen ] = {
+            		fnError: o.error,
+            		fnSuccess: o.success,
+            		fnComplete: o.complete,
+                    fnAbort: o.abort,
+            		error: [],
+            		success: [],
+            		complete: [],
+            		done: false,
+            		queued: false,
+                    data: cD,
+                    url: o.url,
+                    type: o.type,
+                    xhr: null
+                o.error = function(){if(q[ quLen ]) q[ quLen ].error = arguments; };
+            	o.success = function(){if(q[ quLen ]) q[ quLen ].success = arguments; };
+                o.abort = function(){if(q[ quLen ]) q[ quLen ].abort = arguments; };
+                function startCallbacks(num){
+                    if ( q[ num ].fnError ) q[ num ].fnError.apply( $, q[ num ].error );
+        			if ( q[ num ].fnSuccess ) q[ num ].fnSuccess.apply( $, q[ num ].success );
+        			if ( q[ num ].fnComplete ) q[ num ].fnComplete.apply( $, q[ num ].complete );
+        			self.abort(num,true);
+            	o.complete = function(){
+            		if(!q[ quLen ])
+                        return;
+                    q[ quLen ].complete = arguments;
+            		q[ quLen ].done = true;
+                    switch (s.manageType) {
+                      case 'sync':
+                        if (quLen === 0 || !q[ quLen-1 ]){
+                            var curQLen = q.length;
+                			for ( i = quLen; i < curQLen; i++ ) {
+                                if(q[i]){
+                                    if(q[i].done)
+                                        startCallbacks(i)
+                                    else
+                                        break;
+                        break;
+                        case 'queue':
+                			for ( i = 0, j = 0; i < curQLen; i++ ) {
+                                if(q[i] && q[i].queued){
+                                    q[i].xhr = jQuery.ajax(q[i].xhr);
+                                    q[i].queued = false;
+                                    break;
+                        startCallbacks(quLen);
+                        break;
+                      case 'abortOld':
+                        for ( i = quLen; i >= 0; i-- ) {
+                            if(q[i]){
+                                self.abort(i);
+                        break;
+                      default:
+                        break;
+                if(s.maxReq){
+                    if(s.manageType != 'queue') {
+                        for (i = quLen, j = 0; i >= 0; i--) {
+            				if(j >= s.maxReq)
+                                this.abort(i);
+                            if(q[i]){
+                                j++;
+                    } else {
+                        for (i = 0, j = 0; i <= quLen && !q[quLen].queued; i++) {
+                            if(q[i] && !q[i].queued)
+                                j++;
+                            if(j > s.maxReq)
+                                q[quLen].queued = true;
+                q[ quLen ].xhr = (q[quLen].queued)?o:jQuery.ajax(o);
+                return quLen;
+            cleanUp: function(){
+               this.queue = [];
+            abort: function(num,completed){
+               var qLen = this.queue.length, s = this.opt, q = this.queue, self = this,i;
+               function del(num){
+                   if(!q[num])
+                       return;
+                   (!completed && q[num].fnAbort) && q[num].fnAbort.apply($,[num]);
+                   if(!q[num])
+                       return;
+                   if(q[num].xhr){
+                      if (typeof q[num].xhr.abort != 'undefined')
+                          q[num].xhr.abort();
+                      if (typeof q[num].xhr.close != 'undefined')
+                          q[num].xhr.close();
+                      q[num].xhr = null;
+                    q[num] = null;
+               if(!num && num !== 0){
+                   for (i = 0; i < qLen; i++){
+                       del(i);
+                   this.cleanUp();
+               } else {
+                   del(num);
+                   var allowCleaning = true;
+                   for (i = qLen; i >= 0; i--){
+                       if(q[i]){
+                            allowCleaning = false;
+                            break;
+                   if (allowCleaning) this.cleanUp();
+})(jQuery);
Copied: branches/testbaudson_dev/ext/jquery.mousewheel.min.js (from rev 2556, trunk/mapbender/http/extensions/jquery.mousewheel.min.js)
--- branches/testbaudson_dev/ext/jquery.mousewheel.min.js	                        (rev 0)
+++ branches/testbaudson_dev/ext/jquery.mousewheel.min.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,16 @@
+/* Copyright (c) 2006 Brandon Aaron (brandon.aaron at gmail.com || http://brandonaaron.net)
+ * Dual licensed under the MIT (http://www.opensource.org/licenses/mit-license.php)
+ * and GPL (http://www.opensource.org/licenses/gpl-license.php) licenses.
+ * Thanks to: http://adomas.org/javascript-mouse-wheel/ for some pointers.
+ * Thanks to: Mathias Bank(http://www.mathias-bank.de) for a scope bug fix.
+ * $LastChangedDate: 2007-12-14 23:57:10 -0600 (Fri, 14 Dec 2007) $
+ * $Rev: 4163 $
+ * Version: 3.0
+ * Requires: $ 1.2.2+
+(function($){$.event.special.mousewheel={setup:function(){var handler=$.event.special.mousewheel.handler;if($.browser.mozilla)$(this).bind('mousemove.mousewheel',function(event){$.data(this,'mwcursorposdata',{pageX:event.pageX,pageY:event.pageY,clientX:event.clientX,clientY:event.clientY});});if(this.addEventListener)this.addEventListener(($.browser.mozilla?'DOMMouseScroll':'mousewheel'),handler,false);else
+this.onmousewheel=handler;},teardown:function(){var handler=$.event.special.mousewheel.handler;$(this).unbind('mousemove.mousewheel');if(this.removeEventListener)this.removeEventListener(($.browser.mozilla?'DOMMouseScroll':'mousewheel'),handler,false);else
+this.onmousewheel=function(){};$.removeData(this,'mwcursorposdata');},handler:function(event){var args=Array.prototype.slice.call(arguments,1);event=$.event.fix(event||window.event);$.extend(event,$.data(this,'mwcursorposdata')||{});var delta=0,returnValue=true;if(event.wheelDelta)delta=event.wheelDelta/120;if(event.detail)delta=-event.detail/3;if($.browser.opera)delta=-event.wheelDelta;event.data=event.data||{};event.type="mousewheel";args.unshift(delta);args.unshift(event);return $.event.handle.apply(this,args);}};$.fn.extend({mousewheel:function(fn){return fn?this.bind("mousewheel",fn):this.trigger("mousewheel");},unmousewheel:function(fn){return this.unbind("mousewheel",fn);}});})(jQuery);
Copied: branches/testbaudson_dev/ext/phpmailer-1.72 (from rev 2556, trunk/mapbender/http/classes/phpmailer-1.72)
Modified: branches/testbaudson_dev/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/classes/class_administration.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,1119 +1,3 @@
 <?php
-# $Id$
-# http://www.mapbender.org/index.php/class_administration
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/class_mb_exception.php");
-require_once(dirname(__FILE__)."/class_user.php");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
-require(dirname(__FILE__) . "/phpmailer-1.72/class.phpmailer.php");
- * class to wrap administration methods
- * @uses phpmailer
-class administration {
-     * checks whether the passed email-address is valid / following a pattern
-     * @todo is this an exact representation of the RFC 2822?
-     * @todo this should be checked: what about umlaut-domains and tld like '.museum'?
-     * @see http://tools.ietf.org/html/rfc2822
-     * @param <string> a all lowercase email adress to test
-     * @return <boolean> answer to "is the passed over email valid?""
-	function isValidEmail($email) {
-        if(mb_eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
-            return true;
-		return false;
-     * sends an email via php mailer
-     * @param string an email address for the "From"-field
-     * @param string the displayed name for the "From"-field
-     * @param string an email address for the "To"-field
-     * @param string the text to be set as "Subject"
-     * @param string the text of the emails body
-     * @param string a reference to an error string
-	function sendEmail($fromAddr, $fromName, $toAddr, $toName, $subject, $body, &$error_msg ){
-		global $mailHost, $mailUsername, $mailPassword;
-		if($fromAddr == ''){
-			$fromAddr = MAILADMIN;
-		if($fromName == ''){
-			$fromName = MAILADMINNAME;
-		if ($this->isValidEmail($fromAddr) && $this->isValidEmail($toAddr)) {
-			$mail = new PHPMailer();
-			if ($fromName != "" ) {
-				$mail->FromName = $fromName;
-			$mail->IsSMTP();                  // set mailer to use SMTP
-			$mail->Host = $mailHost;          // specify main and backup server
-			$mail->SMTPAuth = true;           // turn on SMTP authentication
-			$mail->Username = $mailUsername;  // SMTP username
-			$mail->Password = $mailPassword;  // SMTP password
-			$mail->From = $fromAddr;
-			$mail->AddAddress($toAddr, $toName);
-			#$mail->AddReplyTo("info at ccgis.de", "Information");
-			$mail->WordWrap = 50;                                 // set word wrap to 50 characters
-			#$mail->AddAttachment("/var/tmp/file.tar.gz");         // add attachments
-			#$mail->AddAttachment("/tmp/image.jpg", "new.jpg");    // optional name
-			$mail->IsHTML(false);                                  // set email format to HTML
-			$mail->Subject = "[".$fromName."] ".$subject;
-			$mail->Body    = $body;
-			#$mail->AltBody = "This is the body in plain text for non-HTML mail clients";
-			$error_msg='';
-			if(!$mail->Send())
-			   $error_msg .= "Mailer Error: " . $mail->ErrorInfo;
-			   return false;
-			return true;
-		else {
-			return false;
-	 * Removes the namespace from a tag name
-	 * @return String like "gml"
-	 * @param $s String like "ogc:gml"
-	public static function sepNameSpace($s) {
-		$c = strpos($s,":");
-		if ($c > 0) {
-			return substr($s,$c+1);
-		return $s;
-	 * Parses an XML with PHP XML parser, see
-	 * http://de2.php.net/manual/de/book.xml.php
-	 * @return Array an associative array of tags, values, attributes and types
-	 * @param $someXml String The actual XML as string.
-	public static function parseXml ($someXml) {
-		$values = null;
-		$tags = null;
-		$parser = xml_parser_create(CHARSET);
-		// set parsing options
-		xml_parser_set_option($parser, XML_OPTION_CASE_FOLDING, 0);
-		xml_parser_set_option($parser, XML_OPTION_SKIP_WHITE, 1);
-		xml_parser_set_option($parser, XML_OPTION_TARGET_ENCODING, CHARSET);
-		// this is the actual parsing process
-		xml_parse_into_struct($parser, $someXml, $values, $tags);
-		// check if an error occured
-		$code = xml_get_error_code ($parser);
-		if ($code) {
-			// report error
-			$line = xml_get_current_line_number($parser);
-			$errorMessage = xml_error_string($code) . " in line " . $line;
-			$mb_exception = new mb_exception($errorMessage);
-			return false;
-		xml_parser_free($parser);
-		return $values;
-     * returns a random password with numbers and chars both lowercase and uppercase (0-9a-zA-Z)
-     * @return string the new password
- 	function getRandomPassword() {
-		// password length
-		$max = 16;
-		//new password
-		$newpass = "";
-		for ($i=0;$i <= $max;$i++) {
-			//die ASCII-Zeichen 48 - 57 sind die zahlen 0-9
-			//die ASCII-Zeichen 65 - 90 sind die buchstaben A-Z (Gro�)
-			//die ASCII-Zeichen 97 - 122 sind die buchstaben a-z (Klein)
-			$ascii = 0;
-			do {
-				$ascii=rand(48,122);
-			} while ( ($ascii > 57 && $ascii < 65) || ($ascii > 90 && $ascii < 97));
-			$newpass .= chr($ascii);
-		return $newpass;
-     * returns the name of a mapbender user which owns the GUI identified by the passed over gui_id.
-     * @param string the gui_id
-     * @return integer the user id of the owner
- 	function getOwnerByGui($gui_id){
-		$sql = "(SELECT mb_user.mb_user_id";
-		$sql .= "FROM mb_user ";
-		$sql .= "JOIN gui_mb_user ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id ";
-		$sql .= "WHERE gui_mb_user.mb_user_type = 'owner' ";
-		$sql .= "AND gui_mb_user.fkey_gui_id = $1 ";
-		$sql .= "GROUP BY mb_user.mb_user_id ";
-		$sql .= ") ";
-		$sql .= "UNION ( ";
-		$sql .= "SELECT mb_user.mb_user_id ";
-		$sql .= "FROM gui_mb_group ";
-		$sql .= "JOIN mb_user_mb_group ON mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id ";
-		$sql .= "JOIN mb_user ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
-		$sql .= "WHERE gui_mb_group.mb_group_type = 'owner' ";
-		$sql .= "AND gui_mb_group.fkey_gui_id = $2 ";
-		$sql .= "GROUP BY mb_user.mb_user_id)";
-		$owner = array();
-		$v = array($gui_id,$gui_id);
-		$t = array('s','s');
-		$res = db_prep_query($sql,$v,$t);
-		$cnt = 0;
-		while($row = db_fetch_array($res)){
-			$owner[$cnt] = $row["mb_user_id"];
-			$cnt++;
-		return $owner;
-     * returns the content of the field mb_user_email for the given userid.
-     * @param integer userid the id of the current user
-     * @return string the email if one row is found or false if none is found
-	function getEmailByUserId($userid){
-		$sql = "SELECT mb_user_email FROM mb_user ";
-		$sql .= "WHERE mb_user_id = $1 GROUP by mb_user_email";
-        // TODO why do we group, when userid is a primary key?
-		$v = array($userid);
-		$t = array('i');
-		// TODO shall the next two lines be removed?
-        $count_g = 0;
-		$array = array();
-		$row = db_fetch_array($res);
-		if ($row) {
-			return $row["mb_user_email"];
-		else {
-			return false;
-     * returns the name of the user for the given userid.
-     * @param	integer		the userid
-     * @return 	string		the name if one row is found or false if none is foundd
-	function getUserNameByUserId($userid){
-		$sql = "SELECT mb_user_name FROM mb_user ";
-		$sql .= "WHERE mb_user_id = $1 GROUP BY mb_user_name";
-		$t = array("i");
-		$count_g = 0;
-		$array = array();
-		if ($row) {
-			return $row["mb_user_name"];
-		else {
-			return false;
-     * returns one or more userids from the given email or false,
-     * if there is no record in the database matching the given email
-     * @param	string	the email
-     * @return	mixed	an array of userids or false when no records matches
- 	function getUserIdByEmail($email){
-		$sql = "SELECT  mb_user_id FROM mb_user ";
-		$sql .= "WHERE mb_user_email = $1 GROUP BY mb_user_id";
-		$v = array($email);
-		$t = array('s');
-  		$count_g = 0;
-  		$array = array();
-			$array[$count_g] = $row["mb_user_id"];
-			$count_g++;
-		if ($count_g >0)	{
-			return $array;
-		else {
-			return false;
-     * returns one or more owners for the given wm_id. First all guis deploying
-     * this wms are selected. Afterwards for each of the guis the owners are
-     * selected and stored within an array.
-     * @param	integer		the wms_id
-     * @return	mixed		an array of user ids which use the wms in their guis
-     * 						(both for persona or group ownership)
-	function getOwnerByWms($wms_id){
-		// first get guis which deploy this wms.
-        $sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1 GROUP BY fkey_gui_id";
-		$v = array($wms_id);
-		$t = array('i');
-		$count=0;
-			$gui[$count] = $row["fkey_gui_id"];
-			$count++;
-		if ($count > 0) {
-			// this is not needed! count($gui) is always equal to $count
-            if(count($gui)>0) {
-				$v = array();
-				$t = array();
-				$c = 1;
-				$sql = "(SELECT mb_user.mb_user_id FROM mb_user JOIN gui_mb_user ";
-				$sql .= "ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id ";
-				$sql .= " WHERE gui_mb_user.mb_user_type = 'owner'";
-				$sql .= " AND gui_mb_user.fkey_gui_id IN (";
-				for($i=0; $i<count($gui); $i++){
-					if($i>0){ $sql .= ",";}
-					$sql .= "$".$c;
-					$c++;
-					array_push($v, $gui[$i]);
-					array_push($t, 's');
-				$sql .= ") GROUP BY mb_user.mb_user_id";
-				$sql .= ") UNION (";
-				$sql .= "SELECT mb_user.mb_user_id FROM gui_mb_group JOIN mb_user_mb_group ON  mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id  JOIN mb_user ";
-				$sql .= "ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
-				$sql .= " WHERE gui_mb_group.mb_group_type = 'owner'";
-				$sql .= " AND gui_mb_group.fkey_gui_id IN (";
-				for($j=0; $j<count($gui); $j++){
-					if($j>0){ $sql .= ",";}
-					$sql .= "$".$c;
-					$c++;
-				$sql .= ") GROUP BY mb_user.mb_user_id)";
-				$user = array();
-			$cnt = 0;
-				$user[$cnt] = $row["mb_user_id"];
-				$cnt++;
-			if ($cnt>0)	{
-                return $user;
-            } else {
-                return false;
-		} else {
-          return false;
-     * tests whether a gui with the passed gui_id exits and returns true or false.
-     * @param	string		the gui_id to test
-     * @return	boolean		Does a Gui with the passed over gui_id exist?
-	function guiExists($id){
-		$sql = "SELECT * FROM gui WHERE gui_id = $1 ";
-		$v = array($id);
-		$t = array('s');
-		if ($row) {
-			return true;
-		else {
-			return false;
-     * deletes a {@link http://www.mapbender.org/index.php/WMC WMC} entry specified by wmc_id and user_id
-     * @param	integer		the user_id
-     * @param	string		the wmc_id
-     * @return	boolean		Did the query run succesfull? This does not necessarily mean that
-     * 						an entry was deleted.
-     * @deprecated
- 	function deleteWmc($wmc_id, $user_id){
-		$e = new mb_notice("administration->deleteWmc is deprecated, use wmc->delete instead!");
-		$wmc = new wmc();
-		return $wmc->delete($wmc_id, $user_id);
-     * inserts a gui with the specified gui_id, after checking the uniqueness of teh gui id.
-     * @uses administration::guiExists()
-     * @param 	string $guiId	the name and id of the gui to insert.
-     * @return 	boolean			could the gui be inserted?
-	function insertGui($guiId) {
-		if (!$this->guiExists($guiId)) {
-			$sql = "INSERT INTO gui VALUES ($1, $2, '', '1')";
-			$v = array($guiId,$guiId);
-			if ($res) {
-				return true;
-		return false;
-     * deletes links between user and guis in gui_mb_user for a certain gui.
-     * @param string 	the gui name
-     * @return boolean 	could the sql be executed without errors. This does not
-     * 					necessarily mean, that entries were deleted
-	function delAllUsersOfGui($guiId) {
-		$sql = "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1 ";
-		$v = array($guiId);
-		$t = array('s');
-		if (!$res) {
-			return false;
-		else {
-			return true;
-     * returns an array of WMS for a given user id
-     * @uses getGuisByOwner
-     * @param integer $user_id		the user id
-     * @return integer[] 			wms ids for the user
-	function getWmsByOwner($user_id){
-		$gui_list = $this->getGuisByOwner($user_id,true);
-		return $this->getWmsByOwnGuis($gui_list);
-     * returns an array of WMS where the owner is the user with the passed user_id
-     * @param integer	the user id
-     * @return array 	wms ids for the user
-	function getWmsByWmsOwner($user_id){
-		$sql = "SELECT wms_id FROM wms WHERE wms_owner = $1";
-		$v = array($user_id);
-		$t = array('i');
-		$r = array();
-			array_push($r,$row["wms_id"]);
-		return $r;
-     * returns an array of user which are associated with a wms
-     * @param integer	the wms id
-     * @return array	user_ids for the wms
-	function getUserByWms($wms_id){
-		$t = array('i');
-		$count=0;
-			$count++;
-		$c = 1;
-		$v = array();
-		$t = array();
-		if(count($gui)>0){
-			$sql .= " WHERE gui_mb_user.fkey_gui_id IN (";
-				$sql .= "$".$c;
-				array_push($v,$gui[$i]);
-				$c++;
-			$sql .= ") GROUP BY mb_user.mb_user_id) UNION";
-			$sql .= "(SELECT mb_user.mb_user_id FROM gui_mb_group JOIN mb_user_mb_group ON   mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id     JOIN mb_user ";
-			$sql .= " WHERE gui_mb_group.fkey_gui_id IN (";
-				$sql .= "$".$c;
-				$c++;
-			$sql .= ") GROUP BY mb_user.mb_user_id )";
-			$user = array();
-			$cnt = 0;
-				$cnt++;
-		return $user;
-     * selects the WMS-title for a given wms id.
-     * @return string|boolean 	either the title of the wms as string or false when none exists
-	function getWmsTitleByWmsId($id){
-		$sql = "SELECT wms_title FROM wms WHERE wms_id = $1 GROUP BY wms_title";
-		$v = array($id);
-		$t = array('i');
-		if ($row) return $row["wms_title"]; else return false;
-     * selects the Layer-title for a given layer id.
-	function getLayerTitleByLayerId($id){
-		$sql = "SELECT layer_title FROM layer WHERE layer_id = $1 GROUP BY layer_title";
-		$v = array($id);
-		$t = array('i');
-		if ($row) return $row["layer_title"]; else return false;
-     * selects the WMC for a given wmc_id.
-     * @return string|boolean	either the wmc as string or false when none exists
-     * @deprecated
-	function getWmcById($id){
-		$e = new mb_notice("administration->getWmcById is deprecated, use wmc->getDocument instead!");
-		$wmc = new wmc();
-		return $wmc->getDocument($id);
-     * resets the login count of a given user to 0
-     * @return boolean 	could the login count be reseted?
-	function resetLoginCount($userId) {
-		// TODO: isn't mb_user_login_count a integer?
-        $sql = "UPDATE mb_user SET mb_user_login_count = '0' ";
-		$sql .= "WHERE mb_user_id = $1 ";
-		$v = array($userId);
-		$t = array('i');
-		if (!$res) {
-			return false;
-		else {
-			return true;
-	function getUserIdByUserName($username){
-		$sql .= "WHERE mb_user_name = $1 GROUP BY mb_user_id";
-		$v = array($username);
-		$t = array('s');
-		if ($row) return $row["mb_user_id"]; else return false;
-	function setUserAsGuiOwner($guiId, $userId) {
-		$sql = "UPDATE gui_mb_user SET mb_user_type = 'owner' ";
-		$sql .= "WHERE fkey_gui_id = $1 AND fkey_mb_user_id = $2 ";
-		$v = array($guiId,$userId);
-		$t = array('s','i');
-		if (!$res) {
-			return false;
-		else {
-			return true;
-	function getGuiIdByGuiName($guiTitle){
-		$sql = "SELECT gui_id FROM gui ";
-		$sql .= "WHERE gui_name = $1 GROUP BY gui_id";
-		$v = array($guiTitle);
-		$t = array('s');
-  		$count_g = 0;
-  		$array = array();
-			$array[$count_g] = $row["gui_id"];
-			$count_g++;
-			return $array;
-		else {
-			return false;
-	function getGuisByOwner($user_id,$ignore_public)
-		$sql_guis = "SELECT gui.gui_id FROM gui,gui_mb_user ";
-		$sql_guis .= "WHERE (gui.gui_id = gui_mb_user.fkey_gui_id AND gui_mb_user.fkey_mb_user_id = $1) ";
-		if (!isset($ignore_public) OR $ignore_public == false){
-			$sql_guis .= " AND gui.gui_public = 1 ";
-		$sql_guis .= " AND gui_mb_user.mb_user_type = 'owner' GROUP BY gui.gui_id";
-		$sql_guis .= " ORDER by gui.gui_id";
-		$t = array('i');
-		$res_guis = db_prep_query($sql_guis,$v,$t);
-  		$count_g = 0;
-  		$arrayGuis = array();
-		while($row = db_fetch_array($res_guis)){
-			$arrayGuis[$count_g] = $row["gui_id"];
-			$count_g++;
-		return $arrayGuis;
-	 * @deprecated
- 	function getWmcByOwner($user_id){
-		$e = new mb_notice("administration->getWmcByOwner is deprecated, use user->getWmcByOwner instead!");
-		$user = new User($user_id);
-		return $user->getWmcByOwner();
-	 * @deprecated
-	function getGuisByPermission($mb_user_id,$ignorepublic){
-		$e = new mb_notice("administration->getGuisByPermission is deprecated, use user->getApplicationsByPermission instead!");
-		$user = new User($mb_user_id);
-		return $user->getApplicationsByPermission($ignorepublic);
-	function getWmsByOwnGuis($array_gui_ids){
-		if(count($array_gui_ids)>0){
-			$v = array();
-			$t = array();
-			$sql = "SELECT fkey_wms_id from gui_wms WHERE gui_wms.fkey_gui_id IN(";
-			for($i=0; $i<count($array_gui_ids); $i++){
-				$sql .= "$".strval($i+1);
-				array_push($v, $array_gui_ids[$i]);
-				array_push($t, "s");
-			$sql .= ") GROUP BY fkey_wms_id ORDER BY fkey_wms_id";
-			$ownguis = array();
-			$i=0;
-				$ownguis[$i] = $row['fkey_wms_id'];
-				$i++;
-		return $ownguis;
-	function getLayerByWms($wms_id){
-		$sql = "SELECT layer_id from layer WHERE fkey_wms_id = $1 AND layer_pos NOT IN ('0') GROUP BY layer_id, layer_title ORDER BY layer_title";
-		$t = array('i');
-		$layer_id_array = array();
-			$layer_id_array[count($layer_id_array)] = $row['layer_id'];
-		return $layer_id_array;
-	function getWmsOwner($wms_id){
-		$t = array('i');
-		$count=0;
-			$count++;
-		$v = array();
-		$t = array();
-			$sql = "SELECT mb_user.mb_user_id FROM mb_user JOIN gui_mb_user ";
-			$sql .= "ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id WHERE";
-			$sql .= " gui_mb_user.fkey_gui_id IN (";
-				$sql .= "$".($i+1);
-				array_push($t,'s');
-			$sql .= ")";
-			$sql .= " AND gui_mb_user.mb_user_type = 'owner' GROUP BY mb_user.mb_user_id";
-			$i=0;
-			$wmsowner = array();
-				$wmsowner[$i]=$row['mb_user_id'];
-				$i++;
-		return $wmsowner;
-	function insertUserAsGuiOwner($guiId, $userId){
-		$sql = "INSERT INTO gui_mb_user VALUES ($1, $2, 'owner')";
-		if (!$res) {
-			return false;
-		else {
-			return true;
-   	function checkModulePermission($arrayGuis, $modulePath, $column){
-   		$check = true;
-   		if($check == true){
-	   		$perm = false;
-	   		if(count($arrayGuis)>0){
-	   			$v = array();
-	   			$t = array();
-		   		$sql = "SELECT ".$column." FROM gui_element WHERE fkey_gui_id IN(";
-		   		for($i=0; $i<count($arrayGuis); $i++){
-		   			if($i > 0){ $sql .= ","; }
-		   			array_push($v,$arrayGuis[$i]);
-		   		$sql .= ")";
-				$cnt = 0;
-					if(mb_strpos(stripslashes($row[$column]),$modulePath) !== false){
-						$perm = true;
-					$cnt++;
-			return $perm;
-   		else{
-   			return true;
-	 * Checks if a user is allowed to access a GUI element
-	 * @return boolean
-	 * @param $arrayGuis Object
-	 * @param $modulePath Object
-	 * @param $elementTag Object
-   	function checkModulePermission_new($userId, $modulePath, $elementTag){
-   		if (CHECK) {
-			$arrayGuis = $this->getGuisByPermission($userId, true);
-			switch ($elementTag) {
-				case "a" :
-					$column = "e_attributes";
-					$pattern = "/^.*href\s*=\s*(\'|\")\.\.((\/[a-zA-Z0-9_\/\.]+)+)(\?|\'|\").*$/";
-					$replace = "$2";
-					break;
-				case "iframe" :
-					$column = "e_src";
-					$pattern = "/^\.\.((\/[a-zA-Z0-9_\/\.]+)+)(\?|\'|\").*$/";
-					$replace = "$1";
-					break;
-	   		if ($column && count($arrayGuis) > 0) {
-	   			$v = array();
-	   			$t = array();
-		   		$sql = "SELECT DISTINCT ".$column." FROM gui_element WHERE fkey_gui_id IN (";
-		   		$sql .= ") ORDER BY " . $column;
-					if ($row[$column]) {
-						if (preg_match($pattern, stripslashes($row[$column]))) {
-							$dbFilename = preg_replace($pattern, $replace, stripslashes($row[$column]));
-							$e = new mb_notice($dbFilename . " - " . $modulePath);
-							if(strpos($modulePath, $dbFilename) !== false){
-								return true;
-			return false;
-		return true;
-	function getWMSOWSstring($wms_id){
-   		$sql = "SELECT wms_owsproxy FROM wms WHERE wms_id = $1 ";
-   		$t = array("i");
-   		if($row = db_fetch_array($res)){
-   			return $row["wms_owsproxy"];
-   		else{
-   			return false;
-   	function setWMSOWSstring($wms_id, $status){
-   		$sql = "UPDATE wms SET wms_owsproxy = $1 WHERE wms_id = $2 ";
-   		$t = array("s","i");
-   		if($status == 'on'){
-   			$time = md5(microtime(1));
-			$v = array($time,$wms_id);
-   		else{
-   			$v = array("",$wms_id);
-	 * get the owsproxy-string of the current wfs
-	 * @param integer the wfs-id of the current wfs
-	 * @return mixed the owsproxy-string or false
-   	function getWfsOwsproxyString($wfs_id){
-   		$sql = "SELECT wfs_owsproxy FROM wfs WHERE wfs_id = $1 ";
-   		$v = array($wfs_id);
-   		$t = array("i");
-   			return $row["wfs_owsproxy"];
-   		else{
-   			return false;
-	 * sets or removes the owsproxy string of the current wfs
-	 * @param boolean set (true) or remove (false) the owsproxy-string
-   	function setWfsOwsproxyString($wfs_id, $status){
-   		$sql = "UPDATE wfs SET wfs_owsproxy = $1 WHERE wfs_id = $2 ";
-   		if($status == true){
-			$v = array($time,$wfs_id);
-   		else{
-   			$n = new mb_notice("removed owsproxy for wfs:".$wfs_id);
-   			$v = array("",$wfs_id);
-   		$newOwsString = $this->getWfsOwsproxyString($wfs_id);
-   		$n = new mb_notice("Class administration - setOWSString for wfs (".$wfs_id.") to: ". $this->getWfsOwsproxyString($wfs_id));
-   		return $newOwsString;
-   	function checkURL($url){
-		$pos_qm = strpos($url,"?");
-		if($pos_qm > 0 && $pos_qm < (mb_strlen($url)-1) && mb_substr($url,(mb_strlen($url)-1)) != "&"){
-			$url = $url."&";
-			return $url;
-		else if($pos_qm === false){
-			return $url."?";
-		else{
-			return $url;
-	function getModulPermission($userID,$guiID,$elementID){
-		$g = $this->getGuisByPermission($userID,true);
-		if(in_array($guiID,$g)){
-			$sql = "SELECT * FROM gui_element WHERE fkey_gui_id = $1 AND e_id = $2 ";
-			$v = array($guiID,$elementID);
-				return true;
-			else{
-				return false;
-		else{
-			return false;
-	function getLayerPermission($wms_id, $layer_name, $user_id){
-		$layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
-		$array_guis = $this->getGuisByPermission($user_id,true);
-		$v = array();
-		$t = array();
-		$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id IN (";
-		$c = 1;
-		for($i=0; $i<count($array_guis); $i++){
-			$sql .= "$".$c;
-			$c++;
-			array_push($v, $array_guis[$i]);
-		$sql .= ") AND fkey_layer_id = $".$c." AND gui_layer_status = 1";
-		array_push($v,$layer_id);
-		array_push($t,'i');
-			return true;
-		else{
-			return false;
-	function getWmsPermission($wms_id, $user_id) {
-		$v = array();
-		$t = array();
-		$sql = "SELECT * FROM gui_wms WHERE fkey_gui_id IN (";
-		$c = 1;
-			$sql .= "$".$c;
-			$c++;
-		$sql .= ") AND fkey_wms_id = $".$c;
-		array_push($v,$wms_id);
-			return true;
-		else{
-			return false;
-	function getLayerIdByLayerName($wms_id, $layer_name){
-		$sql = "SELECT layer_id FROM layer WHERE ";
-		$sql .= "fkey_wms_id = $1 AND layer_name = $2";
-		$v = array($wms_id,$layer_name);
-		$t = array('i','s');
-			return $row['layer_id'];
-		else{
-			return false;
-	function getWmsIdByWmsGetmap($getmap) {
-		$sql = "SELECT wms_id FROM wms WHERE ";
-		$sql .= "wms_getmap LIKE $1 LIMIT 1";
-		$v = array($getmap."%");
-		$t = array('s');
-			return $row['wms_id'];
-		else{
-			return false;
-	function is_utf8_string($string) {
-	    if (is_array($string))
-	        $enc = implode('', $string);
-	        return @!((ord($enc[0]) != 239) && (ord($enc[1]) != 187) && (ord($enc[2]) != 191));
-	    else
-	        return (utf8_encode(utf8_decode($string)) == $string);
-    		return preg_match('%(?:
-		[\xC2-\xDF][\x80-\xBF]        # non-overlong 2-byte
-		|\xE0[\xA0-\xBF][\x80-\xBF]               # excluding overlongs
-		|[\xE1-\xEC\xEE\xEF][\x80-\xBF]{2}      # straight 3-byte
-		|\xED[\x80-\x9F][\x80-\xBF]               # excluding surrogates
-		|\xF0[\x90-\xBF][\x80-\xBF]{2}    # planes 1-3
-		|[\xF1-\xF3][\x80-\xBF]{3}                  # planes 4-15
-		|\xF4[\x80-\x8F][\x80-\xBF]{2}    # plane 16
-		)+%xs', $string);
-	function is_utf8_xml($xml) {
-		return preg_match('/<\?xml[^>]+encoding="utf-8"[^>]*\?>/is', $xml);
-	function is_utf8 ($data) {
-		return ($this->is_utf8_xml($data) || $this->is_utf8_string($data));
-	function char_encode($data) {
-		if (CHARSET == "UTF-8") {
-			if (!$this->is_utf8($data)) {
-				$e = new mb_notice("Conversion: ISO-8859-1 to UTF-8");
-				return utf8_encode($data);
-		else {
-			if ($this->is_utf8($data)) {
-				$e = new mb_notice("Conversion: UTF-8 to ISO-8859-1");
-				return utf8_decode($data);
-		$e = new mb_notice("No conversion: is " . CHARSET);
-		return $data;
-	function char_decode($data) {
-		$e = new mb_notice("no conversion: is " . CHARSET);
-		return $data;
-	 * identifies the Featureservices where the current user is owner
-	 * @param integer 		userid the user-ID of the current user
-	 * @return integer[] 	the IDs of the featureservices
-	 function getWfsByOwner($userid){
-	 	$sql = "SELECT wfs_id FROM wfs WHERE wfs_owner = $1";
-		$t = array('i');
-		$r = array();
-			array_push($r,$row["wfs_id"]);
-		return $r;
-	 /** identifies the Conf-FeatureServices where the current user is owner
-	 * @deprecated
-	 * @return integer[] 	the IDs of the wfs_conf-table
-	 function getWfsConfByPermission($userid){
-		$e = new mb_notice("administration->getWfsConfByPermission is deprecated, use user->getWfsConfByPermission instead!");
-		$user = new User($userid);
-		return $user->getWfsConfByPermission();
+include_once(dirname(__FILE__)."/../../lib/administration.php");
Modified: branches/testbaudson_dev/http/classes/class_checkInput.php
--- trunk/mapbender/http/classes/class_checkInput.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/classes/class_checkInput.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,54 +1,3 @@
 <?php
-# $Id$
-# http://www.mapbender.org/index.php/class_checkInput
-class checkInput{
-	var $v;
-	function checkInput($q,$v,$t){
-		if(is_array($v) == false){
-			$v = array($v);
-		if(is_array($t) == false){
-			$t = array($t);
-		if(count($v) != count($t)){
-			$e = new mb_exception("array params and array types have a different count  in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$q);
-		if(PREPAREDSTATEMENTS == true && SYS_DBTYPE == "pgsql"){
-			$this->v = $v;
-		else{
-			for($i=0; $i<count($v); $i++){
-				if($t[$i] == 's'){
-					$v[$i] = db_escape_string($v[$i]);
-				else if($t[$i] == 'i'){
-					if(preg_match("/w/",$v[$i])){
-						$e = new mb_exception($_SERVER['SCRIPT_FILENAME'].": Unable to parse integer in: ".$q." with: param ".$i.",".$v[i]);
-						die("wrong data type in sql:".$q);
-				else if($t[$i] == 'd'){
-			$this->v = $v;
+include_once(dirname(__FILE__)."/../../lib/checkInput.php");
Modified: branches/testbaudson_dev/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/classes/class_connector.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,213 +1,3 @@
 <?php
-# $Id$
-# http://www.mapbender.org/index.php/class_connector
-require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
-mb_internal_encoding("UTF-8");
- * Establishes a connection to a given URL (and loads the content).
- * Supports HTTP (GET and POST), cURL and socket connections.
- * @class
-class connector {
-	var $file;
-	private $connectionType;
-	private $httpType = "get";
-	private $httpVersion = "1.0";
-	private $httpPostData;
-	private $httpContentType;
-	 * @constructor
-	 * @param String url the URL that will be loaded (optional)
-	public function __construct($url){
-		$this->set("connectionType", CONNECTION);
-		if ($url) {
-			$this->load($url);
-	 * Loads content from the given URL.
-	public function load($url) {
-		switch ($this->connectionType) {
-			case "curl":
-				$this->file = $this->getCURL($url);
-				break;
-			case "http":
-				$this->file = $this->getHTTP($url);
-				break;
-			case "socket":
-				$this->file = $this->getSOCKET($url);
-				break;
-		if(!$this->file){
-			$e = new mb_exception("connector: unable to load: ".$url);
-			return false;
-		return $this->file;
-	 * Sets the environment variables. The following can be set:
-	 * - connectionType ("http", "curl", "socket")
-	 * - httpType ("get", "post")
-	 * - etc.
-	public function set ($key, $value) {
-		switch ($key) {
-			case "connectionType":
-				if ($this->isValidConnectionType($value)) {
-					$this->connectionType = $value;
-				break;
-			case "httpVersion":
-				if (in_array($value, array("1.0", "1.1"))) {
-					$this->httpVersion = $value;
-				else {
-					$e = new mb_exception("class_connector.php: invalid http type '" . $value . "'");
-				break;
-			case "httpType":
-				if (in_array(mb_strtoupper($value), array("POST", "GET"))) {
-					$this->httpType = $value;
-				else {
-				break;
-			case "httpPostData":
-				$this->httpPostData = $value;
-				break;
-			case "httpContentType":
-				if ($this->isValidHttpContentType($value)) {
-					$this->httpContentType = $value;
-				break;
-	private function isValidConnectionType ($value) {
-		if (in_array(mb_strtoupper($value), array("HTTP", "CURL", "SOCKET"))) {
-			return true;
-		else {
-			$e = new mb_exception("class_connector.php: invalid connection type '" . $value . "'");
-			return false;
-	private function isValidHttpContentType ($value) {
-		$validHttpContentTypeArray = array("XML");
-		if (in_array(mb_strtoupper($value), $validHttpContentTypeArray)) {
-			switch ($value) {
-				case "XML":
-					$this->httpContentType = "application/xml";
-					break;
-			return true;
-		else {
-			$e = new mb_exception("class_connector.php: invalid HTTP content type '" . $value . "'");
-			return false;
-	private function getCURL($url){
-		$ch = curl_init ($url);
-//		curl_setopt($ch, CURLOPT_BINARYTRANSFER, 1);
-		curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
-		if(CONNECTION_PROXY != ""){
-			curl_setopt($ch, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
-		if(CONNECTION_PASSWORD != ""){
-			curl_setopt ($ch, CURLOPT_PROXYUSERPWD, CONNECTION_USER.':'.CONNECTION_PASSWORD);
-		curl_setopt ($ch, CURLOPT_RETURNTRANSFER, 1);
-		$file = curl_exec ($ch);
-		curl_close ($ch);
-		return $file;
-	private function getHTTP($url){
-		if ($this->httpType == "get") {
-			return @file_get_contents($url);
-		else {
-			$urlComponentArray = parse_url($url);
-			$host = $urlComponentArray["host"];
-			$port = $urlComponentArray["port"];
-			if ($port == "") {
-				$port = 80;
-			$path = $urlComponentArray["path"];
-			$buf = '';
-		    $fp = fsockopen($host, $port);
-		    fputs($fp, "POST $path HTTP/".$this->httpVersion . "\r\n");
-		    fputs($fp, "Host: $host\r\n");
-		    if ($this->isValidHttpContentType($this->httpContentType)) {
-		    	fputs($fp,"Content-type: " . $this->httpContentType . "\r\n");
-		    fputs($fp, "Content-length: " . strlen($this->httpPostData) . "\r\n");
-		    fputs($fp, "Connection: close\r\n\r\n");
-		    fputs($fp, $this->httpPostData);
-		    $xmlstr = false;
-		    while (!feof($fp)) {
-		    	$content = fgets($fp,4096);
-		    	if( strpos($content, '<?xml') === 0){
-		    		$xmlstr = true;
-		    	if($xmlstr == true){
-		    		$buf .= $content;
-		    fclose($fp);
-		    return $buf;
-	private function getSOCKET($url){
-		$r = "";
-		$fp = fsockopen (CONNECTION_PROXY, CONNECTION_PORT, $errno, $errstr, 30);
-		if (!$fp) {
-			echo "$errstr ($errno)<br />\n";
-		else {
-			fputs ($fp, "GET ".$url." HTTP/1.0\r\n\r\n");
-				$r .= fgets($fp,4096);
-			fclose($fp);
-			return $r;
+include_once(dirname(__FILE__)."/../../lib/connector.php");
Modified: branches/testbaudson_dev/http/classes/class_json.php
--- trunk/mapbender/http/classes/class_json.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/classes/class_json.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,81 +1,3 @@
 <?php
-# $Id:class_json.php 2406 2008-04-23 15:59:31Z christoph $
-# http://www.mapbender.org/index.php/JSON
-define("JSON_PEAR", "json_pear");
-define("JSON_NATIVE", "json_native");
-if (!function_exists("json_encode")) {
-	require_once(dirname(__FILE__)."/../extensions/JSON.php");
- * A wrapper class for PHP JSON encoding/decoding.
- * Uses native PHP functions if available.
- * @class
-class Mapbender_JSON {
-	 * Either JSON_PEAR or JSON_NATIVE
-	private $library = JSON_PEAR;
-	 * Determines which JSON lib to use.
-	 * @constructor
-	public function __construct(){
-		if (function_exists("json_encode")) {
-			$this->library = JSON_NATIVE;
-	 * Encodes an object to JSON
-	public function encode($anObject) {
-		if ($this->library == JSON_PEAR) {
-			$pear = new Services_JSON();
-			$e = new mb_notice("using PEAR JSON");
-			return $pear->encode($anObject);
-		$e = new mb_notice("using native JSON");
-		return json_encode($anObject);
-	 * Decodes a JSON string
-	public function decode($aString) {
-			return $pear->decode($aString);
-		return json_decode($aString);
+include_once(dirname(__FILE__)."/../../lib/json.php");
Modified: branches/testbaudson_dev/http/classes/class_mb_exception.php
--- trunk/mapbender/http/classes/class_mb_exception.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/classes/class_mb_exception.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,42 +1,3 @@
 <?php
-# $Id$
-# http://www.mapbender.org/index.php/class_mb_exception.php
-require_once(dirname(__FILE__)."/../classes/class_mb_log.php");
- * Logs messages to a specified file, for example "../log/mb_error_log_<date>.log"
- * @package exceptionHandling
-class mb_exception extends mb_log {
-	 * @param	string $message		message that is being logged
-	public function __construct ($message) {
-		return $this->mb_log("ERROR: " . $message, $this->level);
-	 * @var string a description of the log level
-	private $level = "error";
+include_once(dirname(__FILE__)."/../../lib/exception.php");
Modified: branches/testbaudson_dev/http/classes/class_mb_log.php
--- trunk/mapbender/http/classes/class_mb_log.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/classes/class_mb_log.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,143 +1,3 @@
 <?php
-# $Id$
-require_once(dirname(__FILE__)."/../classes/class_mb_notice.php");
-require_once(dirname(__FILE__)."/../classes/class_mb_warning.php");
-abstract class mb_log {
-	 * Appends a message to a given log file.
-	 * @param	string $n		the message that is being logged.
-	 * @param	string $level	the log level of the message.
-	 * @return	bool			true if the logging succeded; else false.
-	protected function mb_log ($n, $level) {
-		if (!isset($this->mb_log_level)) {
-			$n = "class_mb_exception: please set LOG_LEVEL in mapbender.conf" . $n;
-		if ($this->isValidLevel($level)) {
-			if (is_dir($this->dir)) {
-				$logfile = $this->dir . $this->filename_prefix . date("Y_m_d") . ".log";
-				if ($h = fopen($logfile,"a")) {
-					$content = date("Y.m.d, H:i:s") . "," . $n .chr(13).chr(10);
-					if(!fwrite($h,$content)){
-						$this->result = false;
-						$this->message = "Unable to write " . $logfile;
-						return false;
-					fclose($h);
-					$this->result = true;
-					$this->message = "Successful.";
-					return true;
-				else {
-					$this->message = "Unable to open or generate " . $logfile;
-					return false;
-			else {
-				$this->message = "Directory " . $this->dir . " is not valid.";
-				return false;
-		else {
-			$this->message = "Log level '" . $level . "' is not valid or logging is disabled in mapbender.conf.";
-			return false;
-	 * Retrieves the index of the level in the array of available levels.
-	 * By this, we can find out if the message is eligable for logging.
-	 * @param	string[] $levelArray	an array of available levels
-	 * @return	mixed					false, if the level is not available; else
-	 * 									the index of the level in the log level array
-	protected function indexOf ($level, $levelArray) {
-		$index = false;
-		for ($i=0; $i < count($levelArray); $i++) {
-			if ($levelArray[$i] == $level) {
-				$index = $i;
-		return $index;
-	 * Checks if the message will be logged. Example: Log level of the message is "warning",
-	 * but the log level set in
-	 * {@link http://www.mapbender.org/index.php/Mapbender.conf#Mapbender_error_logging mapbender.conf}
-	 * is "off", then the message will not be logged.
-	 * @param	string $level	the log level of the message that is being logged.
-	 * @return	bool			true if the message will be logged; else false.
-	protected function isValidLevel ($level) {
-		$log_level_array = explode(",", $this->log_levels);
-		$isValid = in_array($level, $log_level_array);
-		$isAppropriate = ($this->indexOf($level, $log_level_array) <= $this->indexOf($this->mb_log_level, $log_level_array));
-		return $isValid && $isAppropriate;
-	 * @var	string	a comma-separated list of available log levels, see
-	 * 				{@link http://www.mapbender.org/index.php/Mapbender.conf#Mapbender_error_logging mapbender.conf}.
-	protected $log_levels = LOG_LEVEL_LIST;
-	 * @var	string	the selected log level, see
-	protected $mb_log_level = LOG_LEVEL;
-	 * @var	string	the path to the log directory
-	protected $dir = "../../log/";
-	 * @var	string	the prefix of the logs' file name
-	protected $filename_prefix = "mb_error_";
-	 * @var	bool	true if the logging succeeded; else false.
-	public $result = false;
-	 * @var	string	if the logging did not succeed, this contains an error message.
-	public $message = "";
+include_once(dirname(__FILE__)."/../../lib/log.php");
Modified: branches/testbaudson_dev/http/classes/class_mb_notice.php
--- trunk/mapbender/http/classes/class_mb_notice.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/classes/class_mb_notice.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,40 +1,3 @@
 <?php
-# $Id$
-class mb_notice extends mb_log {
-		return $this->mb_log("Notice: " . $message, $this->level);
-	private $level = "notice";
+include_once(dirname(__FILE__)."/../../lib/notice.php");
Modified: branches/testbaudson_dev/http/classes/class_mb_warning.php
--- trunk/mapbender/http/classes/class_mb_warning.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/classes/class_mb_warning.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,40 +1,3 @@
 <?php
-# $Id$
-class mb_warning extends mb_log {
-		return $this->mb_log("Warning: " . $message, $this->level);
-	private $level = "warning";
+include_once(dirname(__FILE__)."/../../lib/warning.php");
Modified: branches/testbaudson_dev/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/classes/class_user.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,159 +1,3 @@
 <?php
-# $Id: class_kml_geometry.php 1966 2008-01-15 08:25:15Z christoph $
-# http://www.mapbender.org/index.php/class_wmc.php
- * A Mapbender user as described in the table mb_user.
-class User {
-	 * @var Integer The user ID
-	var $id;
-	 * Constructor
-	 * @param $userId Integer 	the ID of the user that	is represented by
-	 * 							this object.
-	public function __construct ($userId) {
-		$this->id = $userId;
-	 * @return String the ID of this user
-	public function __toString () {
-		return (string) $this->id;
-	 * Returns an array of application IDs that the user is allowed to access.
-	 * @return Array an array of application IDs
-	 * @param $ignorepublic boolean whether or not to ignore
-	 * 								public applications (?)
-	public function getApplicationsByPermission ($ignorepublic) {
-		$mb_user_id = $this->id;
-		$mb_user_groups = array();
-		$sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
-		$v = array($mb_user_id);
-		$t = array("i");
-		$res_groups = db_prep_query($sql_groups,$v,$t);
-		$cnt_groups = 0;
-		while($row = db_fetch_array($res_groups)){
-			$mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
-			$cnt_groups++;
-		if($cnt_groups > 0){
-			$v = array();
-			$t = array();
-			$sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
-			$sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
-			for($i=0; $i<count($mb_user_groups);$i++){
-				if($i > 0){$sql_g .= ",";}
-				$sql_g .= "$".strval($i+1);
-				array_push($v,$mb_user_groups[$i]);
-				array_push($t,"i");
-			$sql_g .= ") GROUP BY gui.gui_id";
-			$res_g = db_prep_query($sql_g,$v,$t);
-			while($row = db_fetch_array($res_g)){
-				array_push($arrayGuis,$row["gui_id"]);
-		$sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
-		$sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
-		if (!isset($ignore_public) OR $ignore_public== false){
-		$sql_guis .= " GROUP BY gui.gui_id";
-		$t = array("i");
-		$guis = array();
-			if(!in_array($row['gui_id'],$arrayGuis)){
-	/** identifies the IDs of WFS confs where the user is owner
-	public function getWfsConfByPermission(){
-		$userid = $this->id;
-	 	$guisByPer = array();
-//	 	1.
-		$adm = new administration();
-	 	$guisByPer = $adm->getGuisByPermission($userid, true);
-//	 	2.
-		$ownWFSconfs = array();
-		if(count($guisByPer)>0){
-			$v = array();
-			$t = array();
-			$sql = "SELECT wfs_conf.wfs_conf_id  FROM gui_wfs_conf, wfs_conf " .
-					"where wfs_conf.wfs_conf_id = gui_wfs_conf.fkey_wfs_conf_id " .
-					"and gui_wfs_conf.fkey_gui_id IN(";
-			for($i=0; $i<count($guisByPer); $i++){
-				array_push($v, $guisByPer[$i]);
-			$sql .= ") GROUP BY wfs_conf.wfs_conf_id ORDER BY wfs_conf.wfs_conf_id";
-			$i=0;
-				$ownWFSconfs[$i] = $row['wfs_conf_id'];
-				$i++;
-		return $ownWFSconfs;
-	 * Returns all WMCs that this user owns
-	 * @return integer[] an array of WMC ids; ids from table mb_user_wmc
-	public function getWmcByOwner () {
-		$sql = "SELECT wmc_id FROM mb_user_wmc ";
-		$sql .= "WHERE fkey_user_id = $1 GROUP BY wmc_id";
-		$v = array($this->id);
-		$t = array("i");
-		$res_wmc = db_prep_query($sql, $v, $t);
-  		$wmcArray = array();
-		while($row = db_fetch_array($res_wmc)){
-			array_push($wmcArray, $row["wmc_id"]);
-		return $wmcArray;
+include_once(dirname(__FILE__)."/../../lib/user.php");
Modified: branches/testbaudson_dev/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/classes/class_wmc.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -379,7 +379,7 @@
 			array_push($wmcJsArray, "setMapRequest('" . $this->overviewMap->getFrameName() . "');");
-		array_push($wmcJsArray, "eventAfterLoadWMS.trigger()");
+		array_push($wmcJsArray, "eventAfterLoadWMS.trigger();");
 		return $wmcJsArray;
@@ -1010,4 +1010,4 @@
 	if(CHARSET=="UTF-8") return utf8_decode($str);
 	return $str;
Modified: branches/testbaudson_dev/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/classes/class_wms.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,2026 +1,3 @@
 <?php
-# $Id$
-# http://www.mapbender.org/index.php/class_wms
-include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/class_connector.php");
-require_once(dirname(__FILE__)."/class_administration.php");
-class wms {
-	var $lastURL;
-	var $wms_id;
-	var $wms_status;
-	var $wms_version;
-	var $wms_title;
-	var $wms_abstract;
-	var $wms_getcapabilities;
-	var $wms_getcapabilities_doc;
-	var $wms_getmap;
-	var $wms_getfeatureinfo;
-	var $wms_getlegendurl;
-	var $wms_upload_url;
-	var $fees;
-	var $accessconstraints;
-	var $contactperson;
-	var $contactposition;
-	var $contactorganization;
-	var $address;
-	var $city;
-	var $stateorprovince;
-	var $postcode;
-	var $country;
-	var $contactvoicetelephone;
-	var $contactfacsimiletelephone;
-	var $contactelectronicmailaddress;
-	var $wms_keyword = array();
-	var $data_type = array();
-	var $data_format = array();
-	var $objLayer = array();
-	var $wms_supportsld;
-	var $wms_userlayer;
-	var $wms_userstyle;
-	var $wms_remotewfs;
-	var $gui_wms_mapformat;
-	var $gui_wms_featureinfoformat;
-	var $gui_wms_exceptionformat;
-	var $gui_wms_epsg;
-	var $gui_wms_sldurl;
-	var $default_epsg = 0;
-	var $overwrite = true;
-	function wms() {
-	function createOlObjFromWMS($base){
-	 	if(!$this->wms_title || $this->wms_title == ""){
-			echo "alert('Error: no valid capabilities-document !!');";
-			die; exit;
-		// wms_title and abstract have previously been urlencoded
-		// this solution may not yet be the ultimate one
-		$add_wms_string = "var wms_".$this->wms_id." = new OpenLayers.Layer.WMS.Untiled(" .
-				"'" . addslashes($this->wms_title) . "'," .
-				"'" . $this->wms_getmap ."'," ."{layers:'";
-				for($i=1;$i<count($this->objLayer);$i++){
-					$add_wms_string .= addslashes($this->objLayer[$i]->layer_name);
-					if($i!=count($this->objLayer)-1)
-						$add_wms_string .= ",";
-				$add_wms_string .= "', transparent: 'true'";
-				$add_wms_string .= ",format: '".$this->gui_wms_mapformat."'});\n";
-				if($base)
-					$add_wms_string .= 	"wms_".$this->wms_id.".isBaseLayer=true;\n";
-				$add_wms_string .= 	"wms_".$this->wms_id.".setVisibility(".($this->gui_wms_visible=="1"?"true":"false").");\n";
-				$add_wms_string .= "ol_map.addLayer(wms_".$this->wms_id.");\n";
-		echo $add_wms_string;
-	 * Compares this WMS to another WMS.
-	 * @return boolean false, if
-	 * 					- the capabilities URLs don't match
-	 * 					- the layer count is different
-	 * 					- the layer names are different
-	 * @param $anotherWms wms this is just another WMS object
-	public function equals ($anotherWms) {
-		// If the getMap URLs are not equal, the WMS are not equal.
-		if ($this->wms_getmap != $anotherWms->wms_getmap) {
-//			$e = new mb_notice($this . " != " . $anotherWms . " (getMap URL)");
-			return false;
-		// If the layer count is different, the WMS are not equal.
-		if (count($this->objLayer) != count($anotherWms->objLayer)) {
-//			$e = new mb_notice($this . " != " . $anotherWms . " (layer count: " . count($this->objLayer) . ":" . count($anotherWms->objLayer). ")");
-			return false;
-		// If the layer names are different, the WMS are not equal.
-		for ($i = 0; $i < count($this->objLayer); $i++) {
-			$name1 = $this->objLayer[$i]->layer_name;
-			$name2 = $anotherWms->objLayer[$i]->layer_name;
-			if ($name1 != $name2) {
-//				$e = new mb_notice($this . " != " . $anotherWms . " (layer names, " . $name1 . " vs. " . $name2 . ")");
-				return false;
-//		$e = new mb_notice($this . " == " . $anotherWms);
-		return true;
-	 * The other WMS must be the same as this WMS, but with different
-	 * application settings. These application settings are copied,
-	 * the local settings are overwritten.
-	 * @return boolean true if the settings could be copied; false
-	 * 					when an error occured.
-	 * @param $anotherWms wms The same WMS with possibly other settings
-	public function copyConfiguration ($anotherWms) {
-		if (!$this->equals($anotherWms)) {
-			$e = new mb_exception("class_wms.php: copyConfiguration(): parameters cannot be copied, it's a different WMS.");
-			return false;
-			$myCurrentLayer = $this->objLayer[$i];
-			$theirCurrentLayer = $anotherWms->objLayer[$i];
-			$myCurrentLayer->gui_layer_selectable = $theirCurrentLayer->gui_layer_selectable;
-			$myCurrentLayer->gui_layer_visible    = $theirCurrentLayer->gui_layer_visible;
-			$myCurrentLayer->gui_layer_queryable  = $theirCurrentLayer->gui_layer_queryable;
-			$myCurrentLayer->gui_layer_querylayer = $theirCurrentLayer->gui_layer_querylayer;
-			$myCurrentLayer->gui_layer_style      = $theirCurrentLayer->gui_layer_style;
-	 * Removes duplicate WMS from an array of WMS. To find duplicates,
-	 * two WMS are compared via equals().
-	 * @return wms[]
-	 * @param $wmsArray wms[]
-	public static function merge ($wmsArray) {
-		$e = new mb_notice("before: " . implode(", ", $wmsArray));
-		if (!is_array($wmsArray)) {
-			$e = new mb_exception("class_wms.php: merge(): parameter is NOT an array.");
-			return array();
-		if (count($wmsArray) == 0) {
-			$e = new mb_exception("class_wms.php: merge(): parameter is an EMPTY array.");
-			return array();
-		$newWmsArray = array();
-		while (count($wmsArray) > 0) {
-			$currentWms = array_pop($wmsArray);
-			$isNewWms = true;
-			if (get_class($currentWms) != "wms") {
-				$e = new mb_exception("class_wms.php: merge(): current WMS is not a WMS object, but a " . get_class($currentWms));
-			else {
-				for ($i = 0; $i < count($newWmsArray) && $isNewWms; $i++) {
-					if ($currentWms->equals($newWmsArray[$i])) {
-						$isNewWms = false;
-				if ($isNewWms) {
-//					$e = new mb_notice("adding WMS " . $currentWms);
-					array_push($newWmsArray, $currentWms);
-		// reversal of the array, because the elements were popped
-		// from another array before.
-//		$e = new mb_notice("after: " . implode(", ", array_reverse($newWmsArray)));
-		return array_reverse($newWmsArray);
-		return $this->wms_title;
-	function createObjFromXML($url){
-		$x = new connector($url);
-		$data = $x->file;
-		if(!$data){
-			$this->wms_status = false;
-			return false;
-		else {
-			$this->wms_status = true;
-		$values = null;
-		$tags = null;
-		$admin = new administration();
-		$this->wms_getcapabilities_doc = $admin->char_encode($data);
-		$this->wms_upload_url = $url;
-		$this->wms_id = "";
-		$parser = xml_parser_create("");
-		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
-		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
-		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
-		xml_parse_into_struct($parser,$this->wms_getcapabilities_doc,$values,$tags);
-		$code = xml_get_error_code($parser);
-		if ($code) {
-			$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
-		$section = null;
-		$format = null;
-		$cnt_format = 0;
-		$parent = array();
-		$myParent = array();
-		$cnt_layer = -1;
-		$request = null;
-		$layer_style = array();
-		$cnt_styles = -1;
-		foreach ($values as $element) {
-			if(mb_strtoupper($element[tag]) == "WMT_MS_CAPABILITIES" && $element[type] == "open"){
-				$this->wms_version = $element[attributes][version];
-			if(mb_strtoupper($element[tag]) == "TITLE" && $element[level] == '3'){
-				$this->wms_title = $this->stripEndlineAndCarriageReturn($element[value]);
-			if(mb_strtoupper($element[tag]) == "ABSTRACT" && $element[level] == '3'){
-				$this->wms_abstract = $this->stripEndlineAndCarriageReturn($element[value]);
-			if(mb_strtolower($element[tag]) == "fees"){
-				$this->fees = $element[value];
-			if(mb_strtolower($element[tag]) == "accessconstraints"){
-				$this->accessconstraints = $element[value];
-			if(mb_strtolower($element[tag]) == "contactperson"){
-				$this->contactperson = $element[value];
-			if(mb_strtolower($element[tag]) == "contactposition"){
-				$this->contactposition = $element[value];
-			if(mb_strtolower($element[tag]) == "contactorganization"){
-				$this->contactorganization = $element[value];
-			if(mb_strtolower($element[tag]) == "address"){
-				$this->address = $element[value];
-			if(mb_strtolower($element[tag]) == "city"){
-				$this->city = $element[value];
-			if(mb_strtolower($element[tag]) == "stateorprovince"){
-				$this->stateorprovince = $element[value];
-			if(mb_strtolower($element[tag]) == "postcode"){
-				$this->postcode = $element[value];
-			if(mb_strtolower($element[tag]) == "country"){
-				$this->country = $element[value];
-			if(mb_strtolower($element[tag]) == "contactvoicetelephone"){
-				$this->contactvoicetelephone = $element[value];
-			if(mb_strtolower($element[tag]) == "contactfacsimiletelephone"){
-				$this->contactfacsimiletelephone = $element[value];
-			if(mb_strtolower($element[tag]) == "contactelectronicmailaddress"){
-				$this->contactelectronicmailaddress = $element[value];
-	  		if(mb_strtolower($element[tag]) == "keyword" && $section != 'layer'){
-				$this->wms_keyword[count($this->wms_keyword)] = $element[value];
-			/*map section*/
-			if($this->wms_version == "1.0.0"){
-		 		if(mb_strtoupper($element[tag]) == "MAP" && $element[type] == "open"){
-					$section = "map";
-				if($section == "map" && mb_strtoupper($element[tag]) == "GET"){
-					$this->wms_getmap = $element[attributes][onlineResource];
-				if($section == "map" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
-					$format = "map";
-				if(mb_strtoupper($element[tag]) != "FORMAT" && $section == "map" && $format == "map"){
-					$this->data_type[$cnt_format] = "map";
-					$this->data_format[$cnt_format] = trim($element[tag]);
-					$cnt_format++;
-				if(mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "close"){
-					$format = "";
-				if(mb_strtoupper($element[tag]) == "MAP" && $element[type] == "close"){
-					$section = "";
-			else{
-				if(mb_strtoupper($element[tag]) == "GETMAP" && $element[type] == "open"){
-					$section = "map";
-				if($section == "map" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
-					$request = "get";
-				if($section == "map" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
-					$this->wms_getmap = $element[attributes]["xlink:href"];
-				if($section == "map" && mb_strtoupper($element[tag]) == "FORMAT"){
-					$this->data_format[$cnt_format] = trim($element[value]);
-					$cnt_format++;
-				if($section == "map" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
-					$request = "";
-				if(mb_strtoupper($element[tag]) == "GETMAP" && $element[type] == "close"){
-					$section = "";
-			/*capabilities section*/
-				if(mb_strtoupper($element[tag]) == "CAPABILITIES" && $element[type] == "open"){
-					$section = "capabilities";
-				if($section == "capabilities" && mb_strtoupper($element[tag]) == "GET"){
-					$this->wms_getcapabilities = $element[attributes][onlineResource];
-				if(mb_strtoupper($element[tag]) == "CAPABILITIES" && $element[type] == "close"){
-					$section = "";
-			else{
-				if(mb_strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "open"){
-				if($section == "capabilities" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
-					$request = "get";
-				if($section == "capabilities" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
-					$this->wms_getcapabilities = $element[attributes]["xlink:href"];
-				if($section == "capabilities" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
-					$request = "";
-				if(mb_strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "close"){
-					$section = "";
-			/*featureInfo section*/
-				if(mb_strtoupper($element[tag]) == "FEATUREINFO" && $element[type] == "open"){
-					$section = "featureinfo";
-				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "GET"){
-					$this->wms_getfeatureinfo = $element[attributes][onlineResource];
-				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
-					$format = "featureinfo";
-				if(mb_strtoupper($element[tag]) != "FORMAT" && $section == "featureinfo" && $format == "featureinfo"){
-					$this->data_type[$cnt_format] = "featureinfo";
-					$cnt_format++;
-					$format = "";
-				if(mb_strtoupper($element[tag]) == "FEATUREINFO" && $element[type] == "close"){
-					$section = "";
-			else{
-				if(mb_strtoupper($element[tag]) == "GETFEATUREINFO" && $element[type] == "open"){
-				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
-					$request = "get";
-				if($section == "featureinfo" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
-					$this->wms_getfeatureinfo = $element[attributes]["xlink:href"];
-				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "FORMAT"){
-					$cnt_format++;
-				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
-					$request = "";
-				if(mb_strtoupper($element[tag]) == "GETFEATUREINFO" && $element[type] == "close"){
-					$section = "";
-			/*exception section*/
-				if(mb_strtoupper($element[tag]) == "EXCEPTION" && $element[type] == "open"){
-					$section = "exception";
-				if($section == "exception" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
-					$format = "exception";
-				if(mb_strtoupper($element[tag]) != "FORMAT" && $section == "exception" && $format == "exception"){
-					$this->data_type[$cnt_format] = "exception";
-					$cnt_format++;
-				if($section == "exception" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "close"){
-					$format = "";
-				if(mb_strtoupper($element[tag]) == "EXCEPTION" && $element[type] == "close"){
-					$section = "";
-			else{
-				if($section == "exception" && mb_strtoupper($element[tag]) == "FORMAT"){
-					$cnt_format++;
-					$section = "";
-	      /*legend section*/
-	      else{
-	        if(mb_strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "open"){
-				$section = "legend";
-	        if($section == "legend" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
-				$request = "get";
-			if($section == "legend" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
-				$this->wms_getlegendurl = $element[attributes]["xlink:href"];
-	        if($section == "legend" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
-				$request = "";
-			if(mb_strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "close"){
-				$section = "";
-			/* sld section */
-			if(mb_strtoupper($element[tag]) == "USERDEFINEDSYMBOLIZATION" && $element[type] == "complete"){
-				$this->wms_supportsld = $element[attributes]["SupportSLD"];
-				$this->wms_userlayer = $element[attributes]["UserLayer"];
-				$this->wms_userstyle = $element[attributes]["UserStyle"];
-				$this->wms_remotewfs = $element[attributes]["RemoteWFS"];
-			/*layer section*/
-			if(mb_strtoupper($element[tag]) == "LAYER"){
-				$section = "layer";
-				if ($element[type] == "open") {
-					$cnt_epsg = -1;
-					$cnt_layer++;
-					$parent[$element[level]+1] = $cnt_layer;
-					$myParent[$cnt_layer]= $parent[$element[level]];
-					$this->addLayer($cnt_layer,$myParent[$cnt_layer]);
-					$this->objLayer[$cnt_layer]->layer_queryable = $element[attributes][queryable];
-				if ($element[type] == "close") {
-			/* attribution */
-			if(mb_strtoupper($element[tag]) == "ATTRIBUTION"){
-					$section = "attribution";
-			/* styles */
-			if(mb_strtoupper($element[tag]) == "STYLE"){
-				$section = "style";
-				if($cnt_layer != $layer_style){
-					$layer_style = $cnt_layer;
-					$cnt_styles = -1;
-					$cnt_styles++;
-			if($section == "style"){
-				if(mb_strtoupper($element[tag]) == "NAME"){
-					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["name"] = $element[value];
-				if(mb_strtoupper($element[tag]) == "TITLE"){
-					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["title"] = $element[value];
-	      		if(mb_strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "open"){
-					$legendurl = true;
-				if($legendurl && mb_strtoupper($element[tag]) == "FORMAT"){
-					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["legendurlformat"] = $element[value];
-				if($legendurl && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
-					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["legendurl"] = $element[attributes]["xlink:href"];
-			    if(mb_strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "close"){
-					$legendurl = false;
-			/* end of styles */
-			if($section == "layer"){
-					$this->objLayer[$cnt_layer]->layer_name = $element[value];
-					$this->objLayer[$cnt_layer]->layer_title = $this->stripEndlineAndCarriageReturn($element[value]);
-				if(mb_strtoupper($element[tag]) == "ABSTRACT"){
-					$this->objLayer[$cnt_layer]->layer_abstract = $this->stripEndlineAndCarriageReturn($element[value]);
-				if(mb_strtoupper($element[tag]) == "KEYWORD"){
-					array_push($this->objLayer[$cnt_layer]->layer_keyword, trim($element[value]));
-	      		if(mb_strtoupper($element[tag]) == "DATAURL" && $element[type] == "open"){
-					$dataurl = true;
-				if($dataurl && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
-					$this->objLayer[$cnt_layer]->layer_dataurl_href = $element[attributes]["xlink:href"];
-			    if(mb_strtoupper($element[tag]) == "DATAURL" && $element[type] == "close"){
-					$dataurl = false;
-				if(mb_strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
-					$metadataurl = true;
-				if($metadataurl && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
-					$this->objLayer[$cnt_layer]->layer_metadataurl = $element[attributes]["xlink:href"];
-			    if(mb_strtoupper($element[tag]) == "METADATAURL" && $element[type] == "close"){
-					$metadataurl = false;
-				if(mb_strtoupper($element[tag]) == "SRS"){
-	  				$this->objLayer[$cnt_layer]->wms_srs1 = $element[value];
-					// unique srs only, see http://www.mapbender.org/index.php/Arrays_with_unique_entries
-					$this->wms_srs = array_keys(array_flip(explode(" ", $this->objLayer[0]->wms_srs1)));
-				if(mb_strtoupper($element[tag]) == "LATLONBOUNDINGBOX"){
-					$cnt_epsg++;
-					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["epsg"] = "EPSG:4326";
-					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["minx"] = $element[attributes][minx];
-					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["miny"] = $element[attributes][miny];
-					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["maxx"] = $element[attributes][maxx];
-					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["maxy"] = $element[attributes][maxy];
-				if(mb_strtoupper($element[tag]) == "BOUNDINGBOX" && $element[attributes][SRS] != "EPSG:4326"){
-					$cnt_epsg++;
-					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["epsg"] = $element[attributes][SRS];
-					// a default epsg for mapbender
-					if($cnt_layer == 0 && $this->default_epsg == 0 && mb_strlen(trim($element[attributes][SRS]))>= 10){
-						$this->default_epsg = $cnt_epsg;
-				if(mb_strtoupper($element[tag]) == "SCALEHINT"){
-					if($element[attributes][max]>1000) $max = 0; else $max = $element[attributes][max];
-					if($element[attributes][min]>1000) $min = 0; else $min = $element[attributes][min];
-					$this->objLayer[$cnt_layer]->layer_minscale = round(($min * 2004.3976484406788493955738891127));
-					$this->objLayer[$cnt_layer]->layer_maxscale = round(($max * 2004.3976484406788493955738891127));
-			else {
-				continue;
-		if(!$this->wms_title || $this->wms_title == "" || !$this->wms_getmap || $this->wms_getmap == ""){
-			$this->optimizeWMS();
-			return false;
-		else{
-			return true;
-	 * private function
-	function optimizeWMS() {
-		/*define defaults for wms-version 1.0.0*/
-		$map_default_ok = false;
-		$featureinfo_default_ok = false;
-		$exception_default_ok = false;
-			$map_default = "PNG";
-			$featureinfo_default = "MIME";
-			$exception_default = "INIMAGE";
-		/*define defaults for wms-version 1.1.0 and 1.1.1*/
-		else{
-			$map_default = "image/png";
-			$featureinfo_default = "text/html";
-			$exception_default = "application/vnd.ogc.se_inimage";
-		#some default
-		$this->gui_wms_visible = 1;
-		$this->gui_wms_opacity = 100;
-		/*if the rootlayer has no epsg...*/
-		if($this->objLayer[0]->layer_epsg[0]["epsg"] == ""){
-			$this->objLayer[0]->layer_epsg = $this->objLayer[1]->layer_epsg;
-			for($i=0;$i<count($this->objLayer[0]->layer_epsg);$i++){
-				for($j=1; $j<count($this->objLayer); $j++){
-					if($this->objLayer[0]->layer_epsg[$i]["epsg"] == $this->objLayer[$j]->layer_epsg[$i]["epsg"]){
-						if($this->objLayer[$j]->layer_epsg[$i]["minx"]<$this->objLayer[0]->layer_epsg[$i]["minx"]){
-							$this->objLayer[0]->layer_epsg[$i]["minx"] = $this->objLayer[$j]->layer_epsg[$i]["minx"];
-						if($this->objLayer[$j]->layer_epsg[$i]["miny"]<$this->objLayer[0]->layer_epsg[$i]["miny"]){
-							$this->objLayer[0]->layer_epsg[$i]["miny"] = $this->objLayer[$j]->layer_epsg[$i]["miny"];
-						if($this->objLayer[$j]->layer_epsg[$i]["maxx"]>$this->objLayer[0]->layer_epsg[$i]["maxx"]){
-							$this->objLayer[0]->layer_epsg[$i]["maxx"] = $this->objLayer[$j]->layer_epsg[$i]["maxx"];
-						if($this->objLayer[$j]->layer_epsg[$i]["maxy"]>$this->objLayer[0]->layer_epsg[$i]["maxy"]){
-							$this->objLayer[0]->layer_epsg[$i]["maxy"] = $this->objLayer[$j]->layer_epsg[$i]["maxy"];
-		for($i=0;$i<count($this->objLayer);$i++){
-			if(count($this->objLayer[$i]->layer_epsg) == 0 && count($this->objLayer[0]->layer_epsg) > 0){
-				$this->objLayer[$i]->layer_epsg = $this->objLayer[0]->layer_epsg;
-			if(!is_int($this->objLayer[$i]->layer_parent)){
-				$this->objLayer[$i]->layer_abstract = $this->wms_abstract;
-				for ($r = 0; $r < count($this->wms_keyword); $r++) {
-					array_push($this->objLayer[$i]->layer_keyword, trim($this->wms_keyword[$r]));
-			if($this->objLayer[$i]->layer_name == ""){
-				$this->objLayer[$i]->layer_name = $this->objLayer[$i]->layer_title;
-			if($this->objLayer[$i]->layer_minscale == ""){
-				$this->objLayer[$i]->layer_minscale = 0;
-			if($this->objLayer[$i]->layer_maxscale == ""){
-				$this->objLayer[$i]->layer_maxscale = 0;
-			if($this->objLayer[$i]->layer_queryable == ""){
-				$this->objLayer[$i]->layer_queryable = 0;
-			$this->objLayer[$i]->gui_layer_minscale = $this->objLayer[$i]->layer_minscale;
-			$this->objLayer[$i]->gui_layer_maxscale = $this->objLayer[$i]->layer_maxscale;
-		for($i=0;$i<count($this->data_format);$i++){
-			if(mb_strtolower($this->data_type[$i]) == 'map' && mb_strtoupper($this->data_format[$i]) == mb_strtoupper($map_default)){
-				$this->gui_wms_mapformat = mb_strtolower($map_default);
-				$map_default_ok = true;
-			if(mb_strtolower($this->data_type[$i]) == 'featureinfo' && mb_strtoupper($this->data_format[$i]) == mb_strtoupper($featureinfo_default)){
-				$this->gui_wms_featureinfoformat = mb_strtolower($featureinfo_default);
-				$featureinfo_default_ok = true;
-			if(mb_strtolower($this->data_type[$i]) == 'exception' && mb_strtolower($this->data_format[$i]) == mb_strtolower($exception_default)){
-				$this->gui_wms_exceptionformat = mb_strtolower($exception_default);
-				$exception_default_ok = true;
-		if($map_default_ok == false){
-				if(mb_strtolower($this->data_type[$i]) == "map" ){$this->gui_wms_mapformat = $this->data_format[$i]; break;}
-		if($featureinfo_default_ok == false){
-				if(mb_strtolower($this->data_type[$i]) == "featureinfo" ){$this->gui_wms_featureinfoformat = $this->data_format[$i]; break;}
-		if($exception_default_ok == false){
-				if(mb_strtolower($this->data_type[$i]) == "exception" ){$this->gui_wms_exceptionformat = $this->data_format[$i]; break;}
-		if(count($this->objLayer[0]->layer_epsg)>1){
-			$this->gui_wms_epsg = $this->objLayer[0]->layer_epsg[$this->default_epsg][epsg];
-		else{
-			$this->gui_wms_epsg = $this->objLayer[0]->layer_epsg[0][epsg];
-		/*the queryable layers*/
-		for($i=0; $i<count($this->objLayer); $i++){
-			if($this->objLayer[$i]->layer_queryable == 1){
-				$this->objLayer[$i]->gui_layer_queryable = 1;
-			else{
-				$this->objLayer[$i]->gui_layer_queryable = 0;
-				$this->objLayer[$i]->layer_pos=$i;
-		/* fill sld variables when empty */
-		if($this->wms_supportsld == ""){
-				$this->wms_supportsld = 0;
-		if($this->wms_userlayer == ""){
-				$this->wms_userlayer = 0;
-		if($this->wms_userstyle == ""){
-				$this->wms_userstyle = 0;
-		if($this->wms_remotewfs == ""){
-				$this->wms_remotewfs = 0;
-	function displayWMS(){
-		echo "<br>id: " . $this->wms_id . " <br>";
-		echo "version: " . $this->wms_version . " <br>";
-		echo "title: " . $this->wms_title . " <br>";
-		echo "abstract: " . $this->wms_abstract . " <br>";
-		echo "maprequest: " . $this->wms_getmap . " <br>";
-		echo "capabilitiesrequest: " . $this->wms_getcapabilities . " <br>";
-		echo "featureinforequest: " . $this->wms_getfeatureinfo . " <br>";
-		echo "gui_wms_mapformat: " . $this->gui_wms_mapformat . " <br>";
-		echo "gui_wms_featureinfoformat: " . $this->gui_wms_featureinfoformat . " <br>";
-		echo "gui_wms_exceptionformat: " . $this->gui_wms_exceptionformat . " <br>";
-		echo "gui_wms_epsg: " . $this->gui_wms_epsg . " <br>";
-		echo "wms_srs: " . $this->objLayer[0]->wms_srs1 . " <br>";
-		echo "gui_wms_visible: " . $this->gui_wms_visible . " <br>";
-		echo "gui_wms_opacity: " . $this->gui_wms_opacity . " <br>";
-		echo "support_sld: " . $this->wms_supportsld . " <br>";
-		for($i=0; $i<count($this->data_type);$i++){
-			echo $this->data_type[$i]. " -> ".$this->data_format[$i]. "<br>";
-			echo "<hr>";
-			echo "id: <b>".$this->objLayer[$i]->layer_id ."</b> parent: <b>".$this->objLayer[$i]->layer_parent."</b> name: <b>".$this->objLayer[$i]->layer_name;
-			echo "</b> title: <b>".$this->objLayer[$i]->layer_title. "</b> queryable: <b>".$this->objLayer[$i]->layer_queryable."</b> minScale: <b>". $this->objLayer[$i]->layer_minscale."</b> maxScale: <b>".$this->objLayer[$i]->layer_maxscale."</b>";
-			echo "<br>dataurl: <b>".$this->objLayer[$i]->layer_dataurl_href. "</b>";
-			echo "<br>metadataurl: <b>".$this->objLayer[$i]->layer_metadataurl. "</b>";
-			echo "<table border='1'>";
-			for($j=0; $j<count($this->objLayer[$i]->layer_epsg);$j++){
-				echo "<tr><td>".$this->objLayer[$i]->layer_epsg[$j][epsg]."</td><td>".$this->objLayer[$i]->layer_epsg[$j][minx]."</td>";
-				echo "<td>".$this->objLayer[$i]->layer_epsg[$j][miny]."</td><td>".$this->objLayer[$i]->layer_epsg[$j][maxx]."</td>";
-				echo "<td>".$this->objLayer[$i]->layer_epsg[$j][maxy]."</td></tr>";
-			echo "</table>";
-			echo "layerstyle:";
-			echo "<tr><td>name</td><td>title</td><td>legendurl</td><td>legendurlformat</td></tr>";
-			for($j=0; $j<count($this->objLayer[$i]->layer_style);$j++){
-				echo "<tr><td>".$this->objLayer[$i]->layer_style[$j][name]."</td><td>".$this->objLayer[$i]->layer_style[$j][title]."</td><td>".$this->objLayer[$i]->layer_style[$j][legendurl]."</td><td>".$this->objLayer[$i]->layer_style[$j][legendurlformat]."</td></tr>";
-			echo "</table>";
-	        echo "<hr>";
-	        echo "<hr>";
-	  function addLayer($id,$parent){
-		$this->objLayer[count($this->objLayer)] = new layer($id,$parent);
-	  function stripEndlineAndCarriageReturn($string) {
-	  	return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
-		function createJsObjFromWMS($parent=0){
-			echo $this->createJsObjFromWMS_();
-	function newLayer ($currentLayer, $currentExtent) {
-		$pos = $currentLayer["extension"]["LAYER_POS"];
-		$parent = $currentLayer["extension"]["LAYER_PARENT"];
-		$this->addLayer($pos, $parent);
-		// set layer data
-		$layerIndex = count($this->objLayer) - 1;
-		$newLayer = $this->objLayer[$layerIndex];
-		$newLayer->layer_uid = $currentLayer["extension"]["LAYER_ID"];
-		$newLayer->layer_name = $currentLayer["name"];
-		$newLayer->layer_title = $currentLayer["title"];
-		$newLayer->layer_dataurl_href = $currentLayer["dataurl"];
-		$newLayer->layer_pos = $currentLayer["extension"]["LAYER_POS"];
-		$newLayer->layer_queryable = $currentLayer["queryable"];
-		$newLayer->layer_minscale = $currentLayer["extension"]["MINSCALE"];
-		$newLayer->layer_maxscale = $currentLayer["extension"]["MAXSCALE"];
-		$newLayer->layer_metadataurl = $currentLayer["metadataurl"];
-		$newLayer->gui_layer_wms_id = $currentLayer["extension"]["WMS_LAYER_ID"];
-		$newLayer->gui_layer_status = $currentLayer["extension"]["GUI_STATUS"];
-		$newLayer->gui_layer_style = ""; // TODO: Add correct data
-		$newLayer->gui_layer_selectable = $currentLayer["extension"]["GUI_SELECTABLE"];
-		$newLayer->gui_layer_visible = $currentLayer["visible"];
-		$newLayer->gui_layer_queryable = $currentLayer["extension"]["GUI_QUERYABLE"];
-		$newLayer->gui_layer_querylayer = $currentLayer["extension"]["QUERYLAYER"];
-		$newLayer->gui_layer_minscale = $currentLayer["extension"]["GUI_MINSCALE"];
-		$newLayer->gui_layer_maxscale = $currentLayer["extension"]["GUI_MAXSCALE"];
-		if (isset($currentLayer["extension"]["WFSFEATURETYPE"])) {
-			$newLayer->gui_layer_wfs_featuretype = $currentLayer["extension"]["WFSFEATURETYPE"];
-		$newLayer->layer_abstract = $currentLayer["abstract"];
-		// set layer epsg
-		$newLayer->layer_epsg = array();
-		if ($currentExtent !== null) {
-			$currentLayerEpsg = array();
-			$currentLayerEpsg["epsg"] = $currentExtent->epsg;
-			$currentLayerEpsg["minx"] = $currentExtent->min->x;
-			$currentLayerEpsg["miny"] = $currentExtent->min->y;
-			$currentLayerEpsg["maxx"] = $currentExtent->max->x;
-			$currentLayerEpsg["maxy"] = $currentExtent->max->y;
-			array_push($newLayer->layer_epsg, $currentLayerEpsg);
-		// set layer style
-		for ($i = 0; $i < count($currentLayer["format"]); $i++) {
-			$layerStyleIndex = count($newLayer->gui_layer_style) - 1;
-			$newLayer->layer_style[$layerStyleIndex] = array();
-			$currentStyle = $newLayer->layer_style[$layerStyleIndex];
-			$currentStyle["name"] = $currentLayer["style"][$i]["name"];
-			$currentStyle["title"] = $currentLayer["style"][$i]["title"];
-			$currentStyle["legendurl"] = $currentLayer["style"][$i]["legendurl"];
-			$currentStyle["legendurl_format"] = $currentLayer["style"][$i]["legendurl_type"];
-	  function createJsObjFromWMS_($parent=0){
-	  	$str = "";
-			$str .= "alert('Error: no valid capabilities-document !!');";
-			die; exit;
-			if($parent){
-				$str .=  "parent.";
-			$add_wms_string = "add_wms(" .
-					"'" . $this->wms_id ."'," .
-					"'" . $this->wms_version ."'," .
-					"'" . addslashes($this->wms_abstract) ."'," .
-					"'" . $this->wms_getfeatureinfo ."'," .
-					"'" . $this->wms_getlegendurl ."'," .
-					"'" . $this->wms_filter ."'," .
-					"'" . $this->gui_wms_mapformat . "'," .
-					"'" . $this->gui_wms_featureinfoformat . "'," .
-					"'" . $this->gui_wms_exceptionformat . "'," .
-					"'" . $this->gui_wms_epsg ."'," .
-					"'" . $this->gui_wms_visible ."'," .
-					"'" . $this->gui_wms_opacity ."'," .
-					"'" . $this->gui_wms_sldurl ."" .
-			$str .=  $add_wms_string;
-			if($parent){
-			$str .= "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');\n";
-			if($parent){
-			$str .=  "wms_add_layer('".
-				$this->objLayer[$i]->layer_parent ."','".
-				$this->objLayer[$i]->layer_uid ."','".
-				addslashes($this->objLayer[$i]->layer_name) . "','".
-				addslashes($this->objLayer[$i]->layer_title) ."','".
-				$this->objLayer[$i]->layer_dataurl_href ."','".
-				$this->objLayer[$i]->layer_pos ."','".
-				$this->objLayer[$i]->layer_queryable ."','".
-				$this->objLayer[$i]->layer_minscale . "','".
-				$this->objLayer[$i]->layer_maxscale ."','".
-				$this->objLayer[$i]->layer_metadataurl ."','".
-				$this->objLayer[$i]->gui_layer_wms_id ."','".
-				$this->objLayer[$i]->gui_layer_status ."','".
-				$this->objLayer[$i]->gui_layer_style ."','".
-				$this->objLayer[$i]->gui_layer_selectable ."','".
-				$this->objLayer[$i]->gui_layer_visible ."','".
-				$this->objLayer[$i]->gui_layer_queryable ."','".
-				$this->objLayer[$i]->gui_layer_querylayer ."','".
-				$this->objLayer[$i]->gui_layer_minscale ."','".
-				$this->objLayer[$i]->gui_layer_maxscale ."','".
-				$this->objLayer[$i]->gui_layer_wfs_featuretype ."');\n";
-				if($i==0){
-					if($parent){
-					$str .= "wms_addSRS('".
-						$this->objLayer[$i]->layer_epsg[$j]["epsg"] ."','".
-						$this->objLayer[$i]->layer_epsg[$j]["minx"] ."','".
-						$this->objLayer[$i]->layer_epsg[$j]["miny"] ."','".
-						$this->objLayer[$i]->layer_epsg[$j]["maxx"] ."','".
-						$this->objLayer[$i]->layer_epsg[$j]["maxy"] ."');\n";
-				if($parent){
-				$str .= "layer_addEpsg('".
-				if($parent){
-				$str .= "wms_addLayerStyle('".$this->objLayer[$i]->layer_style[$j]["name"].
-					"', '".$this->objLayer[$i]->layer_style[$j]["title"].
-					"', ".$j.
-					",".$i.
-					",'".$this->objLayer[$i]->layer_style[$j]["legendurl"].
-					"', '".$this->objLayer[$i]->layer_style[$j]["legendformat"]."');\n";
-		return $str;
-	  function createJsLayerObjFromWMS($parent=0, $layer_name){
-			echo " alert('Error: no valid capabilities-document !!');";
-			die; exit;
-			if($parent){
-				echo "parent.";
-			print("add_wms('".
-			$this->wms_id ."','".
-			$this->wms_version ."','".
-			preg_replace("/'/", "", $this->wms_title) ."','".
-			preg_replace("/'/", "", $this->wms_abstract) ."','".
-			$this->wms_getmap ."','" .
-			$this->wms_getfeatureinfo ."','".
-			$this->wms_getlegendurl ."','".
-			$this->wms_filter ."','".
-			$this->gui_wms_mapformat ."','".
-			$this->gui_wms_featureinfoformat ."','".
-			$this->gui_wms_exceptionformat . "','".
-			$this->gui_wms_epsg ."','".
-			$this->gui_wms_visible ."','".
-			$this->gui_wms_opacity ."','".
-			$this->gui_wms_sldurl ."');\n");
-			if($parent){
-				echo "parent.";
-			echo "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');\n";
-			if($this->objLayer[$i]->layer_name == $layer_name|| $this->objLayer[$i]->layer_pos == 0){
-				if($parent){
-					echo "parent.";
-			 print ("wms_add_layer('".
-				$this->objLayer[$i]->layer_name . "','".
-				$this->objLayer[$i]->gui_layer_wfs_featuretype ."');\n");
-				if($i==0){
-					if($parent){
-					echo "parent.";
-					print("wms_addSRS('".
-						$this->objLayer[$i]->layer_epsg[$j]["maxy"] ."');\n");
-				if($parent){
-				echo "parent.";
-				print("layer_addEpsg('".
-				if($parent){
-				echo "parent.";
-				print("wms_addLayerStyle('".$this->objLayer[$i]->layer_style[$j]["name"]."', '".$this->objLayer[$i]->layer_style[$j]["title"]."', ".$j.",".$i.",'".$this->objLayer[$i]->layer_style[$j]["legendurl"]."', '".$this->objLayer[$i]->layer_style[$j]["legendformat"]."');\n");
-	* writeObjInDB
-	* this function exports the information from the xml to the mapbender database
-	function writeObjInDB($gui_id){
-		global $con;
-		$this->checkObj();
-		db_begin();
-		# TABLE wms
-		$sql = "INSERT INTO wms (wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, ";
-		$sql.= "wms_getfeatureinfo, wms_getlegendurl, wms_getcapabilities_doc, wms_upload_url, fees, ";
-		$sql .= "accessconstraints, contactperson, contactposition, contactorganization, address, city, ";
-		$sql .= "stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, ";
-		$sql .= "wms_owner,wms_timestamp, ";
-		$sql .= "wms_supportsld, wms_userlayer, wms_userstyle, wms_remotewfs) ";
-		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24,$25,$26,$27,$28)";
-		$v = array($this->wms_version,$this->wms_title,$this->wms_abstract,$this->wms_getcapabilities,
-			$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,$this->wms_getcapabilities_doc,
-			$this->wms_upload_url,$this->fees,$this->accessconstraints,$this->contactperson,$this->contactposition,
-			$this->contactorganization,$this->address,$this->city,$this->stateorprovince,$this->postcode,$this->country,
-			$this->contactvoicetelephone,$this->contactfacsimiletelephone,$this->contactelectronicmailaddress,
-			$_SESSION['mb_user_id'],strtotime("now"),
-			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs );
-		$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i','s','s','s','s');
-		$res = db_prep_query($sql,$v,$t);
-		if(!$res){
-			db_rollback();
-		$myWMS = db_insert_id($con,'wms', 'wms_id');
-		# TABLE layer and gui_layer
-			$this->insertLayer($i,$myWMS,$gui_id);
-			$this->insertGuiLayer($i,$myWMS,$gui_id);
-		#TABLE wms_srs
-		$this->insertSRS($myWMS);
-		# TABLE wms_format
-		$this->insertFormat($myWMS);
-		# TABLE gui_wms
-		$sql ="SELECT MAX(gui_wms_position) AS pos FROM gui_wms WHERE fkey_gui_id = $1";
-		$v = array($gui_id);
-		$t = array('s');
-		if(db_result($res, 0,"pos") > -1){
-			$position = db_result($res, 0,"pos") + 1;
-		} else{ $position = 0; }
-		$sql ="INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, ";
-		$sql .= "gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg)";
-		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7)";
-		$v = array($gui_id,$myWMS,$position,$this->gui_wms_mapformat,$this->gui_wms_featureinfoformat,
-				$this->gui_wms_exceptionformat,$this->gui_wms_epsg
-		$t = array('s','i','i','s','s','s','s');
-		if(!$res){
-			db_rollback();
-		db_commit();
-	    #Changes JW
-	    $this->wms_id = $myWMS;
-	function insertLayer($i,$myWMS){
-		global $con;
-		$sql = "INSERT INTO layer(fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, ";
-		$sql .= " layer_queryable, layer_minscale, layer_maxscale,layer_dataurl,layer_metadataurl,layer_abstract) ";
-		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11)";
-		if($this->objLayer[$i]->layer_id != null){
-			$tmpPos =  $this->objLayer[$i]->layer_id;
-		else {
-			$tmpPos .= 0;
-		if($this->objLayer[$i]->layer_parent == '' && $this->objLayer[$i]->layer_parent != '0'){
-			$this->objLayer[$i]->layer_parent = '';
-		$v = array($myWMS,$tmpPos,$this->objLayer[$i]->layer_parent,$this->objLayer[$i]->layer_name,
-				$this->objLayer[$i]->layer_title,
-				$this->objLayer[$i]->layer_queryable,$this->objLayer[$i]->layer_minscale,
-				$this->objLayer[$i]->layer_maxscale,$this->objLayer[$i]->layer_dataurl_href,
-				$this->objLayer[$i]->layer_metadataurl,$this->objLayer[$i]->layer_abstract);
-		$t = array('i','i','s','s','s','i','i','i','s','s','s');
-		if(!$res){
-			db_rollback();
-		else {
-			# save the id of each layer: set param2 true
-			$this->objLayer[$i]->db_id = db_insert_id($con, 'layer','layer_id');
-			$this->insertLayerEPSG($i);
-			# TABLE layer_style for each layer
-			$this->insertLayerStyle($i);
-			# insert Keywords
-			$this->insertLayerKeyword($i);
-	function updateLayer($i,$myWMS){
-		$sql = "SELECT layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_name = $2";
-		$v = array($myWMS,$this->objLayer[$i]->layer_name);
-			$l_id = $row['layer_id'];
-		else{
-			db_rollback();
-			$e = new mb_exception("Not found: ".$this->objLayer[$i]->layer_name);
-			return;
-		$sql = "UPDATE layer SET ";
-		$sql .= "layer_pos = $1, ";
-		$sql .= "layer_parent = $2, ";
-		$sql .= "layer_title = $3, ";
-		$sql .= "layer_queryable = $4, ";
-		$sql .= "layer_minscale = $5, ";
-		$sql .= "layer_maxscale = $6, ";
-		$sql .= "layer_dataurl = $7, ";
-		$sql .= "layer_metadataurl = $8, ";
-		$sql .= "layer_abstract = $9 ";
-		$sql .= "WHERE layer_id = $10";
-		else {
-			$tmpPos .= 0;
-		$v = array($tmpPos,$this->objLayer[$i]->layer_parent,
-				$this->objLayer[$i]->layer_metadataurl,$this->objLayer[$i]->layer_abstract, $l_id
-		$t = array('i','s','s','i','i','i','s','s','s','i');
-		if($this->overwrite == true){
-			$sql .= "layer_title = $1, ";
-			$sql .= "layer_abstract = $2 ";
-			$sql .= "WHERE layer_id = $3";
-			$v = array($this->objLayer[$i]->layer_title,$this->objLayer[$i]->layer_abstract, $l_id);
-			$t = array('s','s','i');
-		if(!$res){
-			db_rollback();
-		else {
-			$this->objLayer[$i]->db_id = $l_id;
-	function insertGuiLayer($i,$myWMS,$gui_id){
-		# table gui_layer
-		$sql = "INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, ";
-		$sql .= "gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, ";
-		$sql .= "gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale, gui_layer_priority, gui_layer_style) ";
-		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12)";
-		if(count($this->objLayer[$i]->layer_style)>0){
-			$layer_style_name = $this->objLayer[$i]->layer_style[0]["name"];
-		else{
-			$layer_style_name = NULL;
-		$v = array($gui_id,$this->objLayer[$i]->db_id,$myWMS,1,1,1,$this->objLayer[$i]->layer_queryable,
-			$this->objLayer[$i]->layer_queryable,$this->objLayer[$i]->layer_minscale,$this->objLayer[$i]->layer_maxscale,$i,$layer_style_name);
-		$t = array('s','i','i','i','i','i','i','i','i','i','i','s');
-		#$e = new mb_exception("name des insert styles und fkey_layer_id: ".$layer_style_name." --- ".$this->objLayer[$i]->db_id);
-		if(!$res){
-			db_rollback();
-	function appendGuiLayer($i,$myWMS,$gui_id){
-		# table gui_layer
-		else{
-		$v = array($gui_id,$this->objLayer[$i]->db_id,$myWMS,0,0,0,$this->objLayer[$i]->layer_queryable,
-		if(!$res){
-			db_rollback();
-	function insertSRS($myWMS){
-		for($i=0; $i<count($this->wms_srs);$i++){
-			$sql ="INSERT INTO wms_srs (fkey_wms_id, wms_srs) values($1,$2)";
-			$v = array($myWMS,mb_strtoupper($this->wms_srs[$i]));
-			if(!$res){
-				db_rollback();
-	function insertFormat($myWMS){
-			$sql ="INSERT INTO wms_format (fkey_wms_id, data_type, data_format) ";
-			$sql .= " VALUES($1,$2,$3)";
-			$v = array($myWMS,$this->data_type[$i],$this->data_format[$i]);
-			$t = array('i','s','s');
-			if(!$res){
-				db_rollback();
-	function insertLayerEPSG($i){
-		$sql = "DELETE FROM layer_epsg WHERE fkey_layer_id = $1";
-		$v = array($this->objLayer[$i]->db_id);
-		$t = array('i');
-			$sql = "INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) ";
-			$sql .= "VALUES($1,$2,$3,$4,$5,$6)";
-			$v = array($this->objLayer[$i]->db_id,$this->objLayer[$i]->layer_epsg[$j][epsg],
-				$this->objLayer[$i]->layer_epsg[$j][minx],$this->objLayer[$i]->layer_epsg[$j][miny],
-				$this->objLayer[$i]->layer_epsg[$j][maxx],$this->objLayer[$i]->layer_epsg[$j][maxy]
-			$t = array('i','s','d','d','d','d');
-			if(!$res){
-				db_rollback();
-	function insertLayerStyle($i){
-		$sql = "DELETE FROM layer_style WHERE fkey_layer_id = $1";
-		$t = array('i');
-			$sql = "INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) ";
-			$sql .= "VALUES($1,$2,$3,$4,$5)";
-			$v = array($this->objLayer[$i]->db_id,$this->objLayer[$i]->layer_style[$j]["name"],
-					$this->objLayer[$i]->layer_style[$j]["title"],$this->objLayer[$i]->layer_style[$j]["legendurl"],
-					$this->objLayer[$i]->layer_style[$j]["legendurlformat"]
-			$t = array('i','s','s','s','s');
-			if(!$res){
-				db_rollback();
-	function insertLayerKeyword($i){
-		global $con;
-		$sql = "DELETE FROM layer_keyword WHERE fkey_layer_id = $1";
-		$t = array('i');
-//		var_dump($this);
-		$k = $this->objLayer[$i]->layer_keyword;
-//		var_dump($k);
-		for($j=0; $j<count($k); $j++){
-			$keyword_id = "";
-			while ($keyword_id == "") {
-				$sql = "SELECT keyword_id FROM keyword WHERE UPPER(keyword) = UPPER($1)";
-				$v = array($k[$j]);
-				$t = array('s');
-				$row = db_fetch_array($res);
-			//print_r($row);
-				if ($row) {
-					$keyword_id = $row["keyword_id"];
-				else {
-					$sql_insertKeyword = "INSERT INTO keyword (keyword)";
-					$sql_insertKeyword .= "VALUES ($1)";
-					$v1 = array($k[$j]);
-					$t1 = array('s');
-					$res_insertKeyword = db_prep_query($sql_insertKeyword,$v1,$t1);
-					if(!$res_insertKeyword){
-						db_rollback();
-			// check if layer/keyword combination already exists
-			$sql_layerKeywordExists = "SELECT * FROM layer_keyword WHERE fkey_layer_id = $1 AND fkey_keyword_id = $2";
-			$v = array($this->objLayer[$i]->db_id, $keyword_id);
-			$t = array('i', 'i');
-			$res_layerKeywordExists = db_prep_query($sql_layerKeywordExists, $v, $t);
-			$row = db_fetch_array($res_layerKeywordExists);
-			//print_r($row);
-			if (!$row) {
-				$sql1 = "INSERT INTO layer_keyword (fkey_keyword_id,fkey_layer_id)";
-				$sql1 .= "VALUES ($1,$2)";
-				$v1 = array($keyword_id,$this->objLayer[$i]->db_id);
-				$t1 = array('i','i');
-				$res1 = db_prep_query($sql1,$v1,$t1);
-				if(!$res1){
-					db_rollback();
-	function updateObjInDB($myWMS){
-		db_begin();
-		$sql = "UPDATE wms SET ";
-		$sql .= "wms_version = $1 ,";
-		$sql .= "wms_getcapabilities  = $2 ,";
-		$sql .= "wms_getmap  = $3 ,";
-		$sql .= "wms_getfeatureinfo  = $4 ,";
-		$sql .= "wms_getlegendurl  = $5 ,";
-		$sql .= "wms_getcapabilities_doc = $6 ,";
-		$sql .= "wms_upload_url = $7,  ";
-		$sql .= "wms_owner = $8, ";
-		$sql .= "wms_timestamp = $9, ";
-		$sql .= "wms_supportsld = $10, ";
-		$sql .= "wms_userlayer = $11, ";
-		$sql .= "wms_userstyle = $12, ";
-		$sql .= "wms_remotewfs = $13 ";
-		$sql .= " WHERE wms_id = $14";
-		$v = array($this->wms_version,$this->wms_getcapabilities,
-			$this->wms_getcapabilities_doc,$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),
-			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs,$myWMS);
-		$t = array('s','s','s','s','s','s','s','i','i','s','s','s','s','i');
-		if(!$res){
-			db_rollback();
-			$sql .= "wms_title  = $1 ,";
-			$sql .= "wms_abstract  = $2 ,";
-			$sql .= "fees = $3, ";
-			$sql .= "accessconstraints = $4, ";
-			$sql .= "contactperson = $5, ";
-			$sql .= "contactposition = $6, ";
-			$sql .= "contactorganization = $7, ";
-			$sql .= "address = $8, ";
-			$sql .= "city = $9, ";
-			$sql .= "stateorprovince = $10, ";
-			$sql .= "postcode = $11, ";
-			$sql .= "country = $12, ";
-			$sql .= "contactvoicetelephone = $13, ";
-			$sql .= "contactfacsimiletelephone = $14, ";
-			$sql .= "contactelectronicmailaddress = $15 ";
-			$sql .= " WHERE wms_id = $16";
-			$v = array($this->wms_title,$this->wms_abstract,$this->fees,$this->accessconstraints,
-				$this->contactperson,$this->contactposition,$this->contactorganization,$this->address,
-				$this->city,$this->stateorprovince,$this->postcode,$this->country,$this->contactvoicetelephone,
-				$this->contactfacsimiletelephone,$this->contactelectronicmailaddress,$myWMS);
-			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i');
-			if(!$res){
-				db_rollback();
-		# delete and refill srs and formats
-		$sql = "DELETE FROM wms_srs WHERE fkey_wms_id = $1 ";
-		$v = array($myWMS);
-		$t = array('i');
-		if(!$res){
-			db_rollback();
-		$sql = "DELETE FROM wms_format WHERE fkey_wms_id = $1 ";
-		$t = array('i');
-		if(!$res){
-			db_rollback();
-		# update gui_wms
-		$this->update_gui_wms($myWMS);
-		# update TABLE layer
-		# delete all layer which are outdated
-		$t = array('i');
-		$c = 2;
-		$sql = "DELETE FROM layer WHERE fkey_wms_id = $1 AND NOT layer_name IN(";
-			if($i>0){$sql .= ',';}
-			$sql .= "$".$c;
-			array_push($v,$this->objLayer[$i]->layer_name);
-			array_push($t,'s');
-			$c++;
-		$sql .= ")";
-		if(!$res){
-			db_rollback();
-		# update or insert?
-		$sql = "SELECT layer_name FROM layer WHERE fkey_wms_id = $1";
-		$t = array('i');
-		$exLayer = array();
-		while($row = db_fetch_array($res)){
-			array_push($exLayer,$row["layer_name"]);
-		$sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1";
-		$t = array('i');
-		$exGui = array();
-			array_push($exGui,$row["fkey_gui_id"]);
-			if(in_array($this->objLayer[$i]->layer_name,$exLayer)){
-				//echo "<br>update: ".$this->objLayer[$i]->layer_name;
-				$this->updateLayer($i,$myWMS);
-				for($j=0; $j<count($exGui); $j++){
-					$this->updateGuiLayer($i,$myWMS,$exGui[$j]);
-			else{
-				//echo "<br>append: ".$this->objLayer[$i]->layer_name;
-				$this->insertLayer($i,$myWMS);
-					$this->appendGuiLayer($i,$myWMS,$exGui[$j]);
-		db_commit();
-		return;
-	function updateGuiLayer($i,$myWMS,$gui_id){
-		$t = array('i','s');
-		if($row = db_fetch_array($res)){
-		else{
-			db_rollback();
-			$e = new mb_exception("Not found: ".$this->objLayer[$i]->layer_name. " in gui: ".$gui_id);
-			return;
-		$sql = "SELECT * FROM gui_layer WHERE fkey_layer_id = $1 and fkey_gui_id = $2";
-		$v = array($l_id,$gui_id);
-			if($this->objLayer[$i]->layer_queryable == 0){
-				$sql1 = "UPDATE gui_layer set gui_layer_queryable = 0, gui_layer_querylayer = 0 ";
-				$sql1 .= "WHERE fkey_layer_id = $1 and fkey_gui_id = $2";
-				$res1 = db_prep_query($sql1,$v,$t);
-				if(!$res1){
-				db_rollback();
-				$sql1 = "UPDATE gui_layer set gui_layer_queryable = 1 ";
-				if(!$res1){
-					db_rollback();
-			if($row["gui_layer_minscale"] < $this->objLayer[$i]->layer_minscale){
-				$sql1 = "UPDATE gui_layer set gui_layer_minscale = $1 ";
-				$sql1 .= "WHERE fkey_layer_id = $2 and fkey_gui_id = $3";
-				$v = array($this->objLayer[$i]->layer_minscale,$l_id,$gui_id);
-				$t = array('i','i','s');
-				if(!$res1){db_rollback();
-			if($row["gui_layer_maxscale"] > $this->objLayer[$i]->layer_maxscale){
-				$sql1 = "UPDATE gui_layer set gui_layer_maxscale = $1 ";
-				$v = array($this->objLayer[$i]->layer_maxscale,$l_id,$gui_id);
-	function update_gui_wms($myWMS){
-		$mySubmit = null;
-		$sql = "SELECT * FROM gui_wms where fkey_wms_id = $1";
-		$t = array('i');
-		$cnt = 0;
-			unset($mySubmit);
-			$myGUI[$cnt] = $row["fkey_gui_id"];
-			$sql = "UPDATE gui_wms SET ";
-			$v = array();
-			$t = array();
-			$paramCount = 0;
-			for($i=0; $i<count($this->data_type); $i++){
-				# gui_wms_mapformat
-				if(mb_strtolower($this->data_type[$i]) == "map" && mb_strtolower($this->data_format[$i]) == mb_strtolower($row["gui_wms_mapformat"])){
-					$myMapFormat = true;
-				# gui_wms_featureinfoformat
-				if(mb_strtolower($this->data_type[$i]) == "featureinfo" && mb_strtolower($this->data_format[$i]) == mb_strtolower($row["gui_wms_featureinfoformat"])){
-					$myFeatureInfoFormat = true;
-				# gui_wms_exceptionformat
-				if(mb_strtolower($this->data_type[$i]) == "exception" && mb_strtolower($this->data_format[$i]) == mb_strtolower($row["gui_wms_exceptionformat"])){
-					$myExceptionFormat = true;
-			if(!$myMapFormat){
-				$paramCount++;
-				$sql .= "gui_wms_mapformat = $" . $paramCount . " ";
-				$mySubmit = true;
-				array_push($v, $this->gui_wms_mapformat);
-				array_push($t, "s");
-			if(!$myFeatureInfoFormat){
-				if($mySubmit){ $sql .= ",";}
-				$paramCount++;
-				$sql .= "gui_wms_featureinfoformat = $" . $paramCount . " ";
-				array_push($v, $this->gui_wms_featureinfoformat);
-				$mySubmit = true;
-			if(!$myExceptionFormat){
-				$paramCount++;
-				$sql .= "gui_wms_exceptionformat = $" . $paramCount ." ";
-				array_push($v, $this->gui_wms_exceptionformat);
-				$mySubmit = true;
-			# gui_wms_epsg
-			for($j=0; $j<count($this->objLayer[0]->layer_epsg);$j++){
-				if($this->objLayer[0]->layer_epsg[$j][epsg] == mb_strtoupper($row["gui_wms_epsg"])){
-					$myGUI_EPSG = true;
-			if(!$myGUI_EPSG){
-				$paramCount++;
-				$sql .= "gui_wms_epsg = $" . $paramCount . " ";
-				array_push($v, $this->gui_wms_epsg);
-				$mySubmit = true;
-			$paramCount++;
-			$sql .= " WHERE fkey_gui_id = $" . $paramCount . " ";
-			array_push($v, $row["fkey_gui_id"]);
-			$paramCount++;
-			$sql .= "AND fkey_wms_id = $" . $paramCount;
-			array_push($v, $myWMS);
-			array_push($t, "i");
-			if($mySubmit){
-				if(!$res){
-					db_rollback();
-					echo "<pre>".$sql."</pre><br> <br><p>";
-				 	echo db_error();
-				 	echo "<br /> UPDATE ERROR -> KILL PROCESS AND ROLLBACK....................no update<br><br>";
-					$e = new mb_exception("class_wms.php: transaction: Transaction aborted, rollback.");
-			$cnt++;
-	function getVersion() {
-		return $this->wms_version;
-	function getCapabilities() {
-		return $this->wms_getcapabilities;
-	function getCapabilitiesDoc() {
-		return $this->wms_getcapabilities_doc;
-	* creatObjfromDB
-	  function createObjFromDB($gui_id,$wms_id){
-		$sql = "Select * from gui_wms where fkey_wms_id = $1 AND fkey_gui_id = $2";
-		$v = array($wms_id,$gui_id);
-		$count=0;
-		#$res_count=db_num_rows($res);
-			$this->gui_wms_mapformat=$row["gui_wms_mapformat"];
-			$this->gui_wms_featureinfoformat=$row["gui_wms_featureinfoformat"];
-			$this->gui_wms_exceptionformat=$row["gui_wms_exceptionformat"];
-			$this->gui_wms_epsg=$row["gui_wms_epsg"];
-			$this->gui_wms_visible = $row["gui_wms_visible"];
-			$this->gui_wms_opacity = $row["gui_wms_opacity"];
-			$this->gui_wms_sldurl = $row["gui_wms_sldurl"];
-			$sql = "Select * from wms where wms_id = $1 ";
-			$v = array($wms_id);
-			$t = array('i');
-			$res_wms = db_prep_query($sql,$v,$t);
-			$count_wms=0;
-			while($row2 = db_fetch_array($res_wms)){
-				$this->wms_id = $row2["wms_id"];
-				$this->wms_version = $row2["wms_version"];
-				$this->wms_title = $this->stripEndlineAndCarriageReturn($row2["wms_title"]);
-				$this->wms_abstract = $this->stripEndlineAndCarriageReturn($row2["wms_abstract"]);
-				$wmsowsproxy = $row2["wms_owsproxy"];
-				#$wmsowsproxy = "test";
-				if($wmsowsproxy != ""){
-					$owsproxyurl = OWSPROXY."/".session_id()."/".$wmsowsproxy."?";
-					$this->wms_getmap = $owsproxyurl;
-					$this->wms_getcapabilities =  $owsproxyurl;
-					$this->wms_getfeatureinfo = $owsproxyurl;
-					$this->wms_getlegendurl = $owsproxyurl;
-				else{
-					$this->wms_getmap =  $row2["wms_getmap"];
-					$this->wms_getcapabilities =  $row2["wms_getcapabilities"];
-					$this->wms_getfeatureinfo = $row2["wms_getfeatureinfo"];
-					$this->wms_getlegendurl = $row2["wms_getlegendurl"];
-				$this->wms_getcapabilities_doc = $row2["wms_getcapabilities_doc"];
-				$this->wms_filter = $row2["wms_filter"];
-				$this->wms_supportsld = $row2["wms_supportsld"];
-				$this->wms_userlayer = $row2["wms_userlayer"];
-				$this->wms_userstyle = $row2["wms_userstyle"];
-				$this->wms_remotewfs = $row2["wms_remotewfs"];
-				$count_wms++;
-			### formats
-			$sql = "SELECT * FROM wms_format WHERE fkey_wms_id = $1 ";
-			$t = array('i');
-			$count_format=0;
-			while($row3 = db_fetch_array($res_wms)){
-				$this->data_type[$count_format] = $row3["data_type"];
-				$this->data_format[$count_format] = $row3["data_format"];
-				$count_format++;
-			$count++;
-		#layer
-		$sql = "Select * from gui_layer where gui_layer_wms_id = $1 AND fkey_gui_id = $2 ";
-		$sql .= " AND gui_layer_status = 1 ORDER BY gui_layer_priority;";
-		$count=0;
-			$layer_id = $row["fkey_layer_id"];
-			$sql = "Select * from layer where layer_id = $1";
-			$v = array($layer_id);
-			$t = array('i');
-			$res_layer = db_prep_query($sql,$v,$t);
-			$count_layer=0;
-			while($row2 = db_fetch_array($res_layer)){
-				$this->addLayer($row2["layer_pos"],$row2["layer_parent"]);
-				$layer_cnt=count($this->objLayer)-1;
-				$this->objLayer[$layer_cnt]->layer_uid = $layer_id;
-				$this->objLayer[$layer_cnt]->layer_name =$row2["layer_name"];
-				$this->objLayer[$layer_cnt]->layer_title =$row2["layer_title"];
-				$this->objLayer[$layer_cnt]->layer_dataurl_href =$row2["layer_dataurl"];
-				$this->objLayer[$layer_cnt]->layer_metadataurl =$row2["layer_metadataurl"];
-				$this->objLayer[$layer_cnt]->layer_pos =$row2["layer_pos"];
-				$this->objLayer[$layer_cnt]->layer_queryable =$row2["layer_pos"];
-				$this->objLayer[$layer_cnt]->layer_queryable =$row2["layer_queryable"];
-				$this->objLayer[$layer_cnt]->layer_minscale =$row2["layer_minscale"];
-				$this->objLayer[$layer_cnt]->layer_maxscale = $row2["layer_maxscale"];
-				$count_layer++;
-			$this->objLayer[$layer_cnt]->gui_layer_wms_id = $row["gui_layer_wms_id"];
-			$this->objLayer[$layer_cnt]->gui_layer_selectable = $row["gui_layer_selectable"];
-			$this->objLayer[$layer_cnt]->gui_layer_visible = $row["gui_layer_visible"];
-			$this->objLayer[$layer_cnt]->gui_layer_queryable = $row["gui_layer_queryable"];
-			$this->objLayer[$layer_cnt]->gui_layer_querylayer = $row["gui_layer_querylayer"];
-			$this->objLayer[$layer_cnt]->gui_layer_minscale = $row["gui_layer_minscale"];
-			$this->objLayer[$layer_cnt]->gui_layer_maxscale = $row["gui_layer_maxscale"];
-			$this->objLayer[$layer_cnt]->gui_layer_style = $row["gui_layer_style"];
-			$this->objLayer[$layer_cnt]->gui_layer_wfs_featuretype = $row["gui_layer_wfs_featuretype"];
-			$sql = "Select * from layer_epsg where fkey_layer_id = $1 ORDER BY fkey_layer_id";
-			$t = array('i');
-			$res_layer_epsg = db_prep_query($sql,$v,$t);
-			$count_layer_epsg=0;
-			while($row2 = db_fetch_array($res_layer_epsg)){
-				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["epsg"]=$row2["epsg"];
-				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["minx"]=$row2["minx"];
-				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["miny"]=$row2["miny"];
-				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["maxx"]=$row2["maxx"];
-				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["maxy"]=$row2["maxy"];
-				$count_layer_epsg++;
-			### handle styles
-			$sql = "SELECT * FROM layer_style WHERE fkey_layer_id = $1 ";
-			$t = array('i');
-			$res_style = db_prep_query($sql,$v,$t);
-			$count_layer_style = 0;
-			while($row2 = db_fetch_array($res_style)){
-				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["name"]=$row2["name"];
-				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["title"]=$row2["title"];
-					if($row2["legendurl"]!=''){
-						$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]=$owsproxyurl.
-						"REQUEST=getlegendgraphic&VERSION=".$this->wms_version."&LAYER=".$this->objLayer[$layer_cnt]->layer_name."&FORMAT=".$row2["legendurlformat"].
-						"&STYLE=".$row2["name"];
-				else{
-						$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]=$row2["legendurl"];
-						#$e = new mb_exception("legendurl = ".$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]);
-				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurlformat"]=$row2["legendurlformat"];
-				$count_layer_style++;
-			$count++;
-	/** end createObjfromDB **/
-	* function checkObjExistsInDB()
-	* this function checks wether the onlineresource already exists in the database.
-	function checkObjExistsInDB(){
-		$sql = "Select * from wms where wms_getcapabilities = $1";
-		$v = array($this->wms_getcapabilities);
-		$t = array('s');
-		$res_count= db_num_rows($res);
-		$wms_id=0;
-		if($res_count>0){
-			$count=0;
-				$wms_id=$row["wms_id"];
-				$count++;
-		return $wms_id;
-	function displayDBInformation(){
-		echo $this->wms_getcapabilities;
-		$sql="Select * from wms where wms_getcapabilities = $1";
-		$t = array('s');
-		$count=0;
-		echo "count: ".$count."<br>";
-			echo "version: " .$wms_id." <br>";
-			echo "title: " .$row["wms_version"]. " <br>";
-			echo "abstract: " . $row["wms_title"] . " <br>";
-			echo "maprequest: " .$row["wms_abstract"] . " <br>";
-			echo "capabilitiesrequest: " . $row["wms_getcapabilities"] . " <br>";
-			echo "featureinforequest: " . $row["wms_getmap"]. " <br>";
-			echo "gui_wms_mapformat: " . $row["wms_getfeatureinfo"] . " <br>---------<br>";
-			$count++;
-	   echo "----<br> wms_id: ".$wms_id."<br>";
-	   $sql = "Select * from gui_wms where fkey_wms_id = $1";
-	   $t = array('i');
-	   echo "sql: ".$sql." <br>---------<br>";
-	   echo "result count: ".$res_count." <br>---------<br>";
-	   $count=0;
-	    	echo "gui_wms_featureinfoformat: " . $row["gui_wms_featureinfoformat"]." <br>";
-	    	echo "gui_wms_exceptionformat: " .  $row["gui_wms_exceptionformat"]. " <br>";
-	    	echo "gui_wms_epsg: " .  $row["gui_wms_epsg"]. " <br>";
-	      $count++;
-	   #db_close($connect);
-	function checkObj(){
-		if($this->wms_getcapabilities == '' || $this->wms_getmap == '' ){
-			echo "<br>Missing parameters: <br>";
-			$this->displayWMS();
-			print_r($this);
-			echo "<br> Data not committed<br>";
-			die();
-	 * Selects all WMS of the current user from the database.
-	 * Then it creates the corresponding WMS object and returns
-	 * these objects as an array.
-	 * @return wms[]
-	 * @param $appId String
-	public static function selectMyWmsByApplication ($appId) {
-		// check if user is permitted to access the application
-		$currentUser = new User($_SESSION["mb_user_id"]);
-		$appArray = $currentUser->getApplicationsByPermission(false);
-		if (!in_array($appId, $appArray)) {
-			$e = new mb_warning("class_wms.php: selectMyWmsByApplication(): User '" . $currentUser . "' is not allowed to acces application '" . $appId . "'.");
-			return array();
-		// get WMS of this application
-		$sql = "SELECT fkey_wms_id FROM gui_wms WHERE " .
-				"fkey_gui_id = $1 ORDER BY gui_wms_position";
-		$v = array($appId);
-		$t = array('s');
-		// instantiate PHP objects and store in array
-		$wmsArray = array();
-		while ($row = db_fetch_array($res)) {
-			$currentWms = new wms();
-			$currentWms->createObjFromDB($appId, $row["fkey_wms_id"]);
-			array_push($wmsArray, $currentWms);
-		return $wmsArray;
-class layer extends wms {
-	var $layer_id;
-	var $layer_parent;
-	var $layer_name;
-	var $layer_title;
-	var $layer_abstract;
-	var $layer_pos;
-	var $layer_queryable;
-	var $layer_minscale;
-	var $layer_maxscale;
-    var $layer_dataurl_href;
-    var $layer_metadataurl;
-    var $layer_keyword = array();
-	var $layer_epsg = array();
-	var $layer_style = array();
-	var $gui_layer_wms_id;
-	var $gui_layer_status = 1;
-	var $gui_layer_selectable = 1;
-	var $gui_layer_visible = 0;
-	var $gui_layer_queryable = 0;
-	var $gui_layer_querylayer = 0;
-	var $gui_layer_style = NULL;
-	function layer($id,$parent){
-		$this->layer_id = $id;
-		$this->layer_parent = $parent;
-		//var_dump($this);
-	public function __toString () {
-		$e = new mb_exception("TITLE: " . $this->layer_title);
-		return $this->layer_title;
+include_once(dirname(__FILE__)."/../../lib/wms.php");
\ No newline at end of file
Deleted: branches/testbaudson_dev/http/extensions/JSON.php
--- trunk/mapbender/http/extensions/JSON.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/extensions/JSON.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,806 +0,0 @@
-<?php
-/* vim: set expandtab tabstop=4 shiftwidth=4 softtabstop=4: */
- * Converts to and from JSON format.
- * JSON (JavaScript Object Notation) is a lightweight data-interchange
- * format. It is easy for humans to read and write. It is easy for machines
- * to parse and generate. It is based on a subset of the JavaScript
- * Programming Language, Standard ECMA-262 3rd Edition - December 1999.
- * This feature can also be found in  Python. JSON is a text format that is
- * completely language independent but uses conventions that are familiar
- * to programmers of the C-family of languages, including C, C++, C#, Java,
- * JavaScript, Perl, TCL, and many others. These properties make JSON an
- * ideal data-interchange language.
- * This package provides a simple encoder and decoder for JSON notation. It
- * is intended for use with client-side Javascript applications that make
- * use of HTTPRequest to perform server communication functions - data can
- * be encoded into JSON notation for use in a client-side javascript, or
- * decoded from incoming Javascript requests. JSON format is native to
- * Javascript, and can be directly eval()'ed with no further parsing
- * overhead
- * All strings should be in ASCII or UTF-8 format!
- * LICENSE: Redistribution and use in source and binary forms, with or
- * without modification, are permitted provided that the following
- * conditions are met: Redistributions of source code must retain the
- * above copyright notice, this list of conditions and the following
- * disclaimer. Redistributions in binary form must reproduce the above
- * copyright notice, this list of conditions and the following disclaimer
- * in the documentation and/or other materials provided with the
- * distribution.
- * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
- * NO EVENT SHALL CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
- * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
- * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
- * TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
- * USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH
- * DAMAGE.
- * @category
- * @package     Services_JSON
- * @author      Michal Migurski <mike-json at teczno.com>
- * @author      Matt Knapp <mdknapp[at]gmail[dot]com>
- * @author      Brett Stimmerman <brettstimmerman[at]gmail[dot]com>
- * @copyright   2005 Michal Migurski
- * @version     CVS: $Id: JSON.php,v 1.31 2006/06/28 05:54:17 migurski Exp $
- * @license     http://www.opensource.org/licenses/bsd-license.php
- * @link        http://pear.php.net/pepr/pepr-proposal-show.php?id=198
- * Marker constant for Services_JSON::decode(), used to flag stack state
-define('SERVICES_JSON_SLICE',   1);
-define('SERVICES_JSON_IN_STR',  2);
-define('SERVICES_JSON_IN_ARR',  3);
-define('SERVICES_JSON_IN_OBJ',  4);
-define('SERVICES_JSON_IN_CMT', 5);
- * Behavior switch for Services_JSON::decode()
-define('SERVICES_JSON_LOOSE_TYPE', 16);
-define('SERVICES_JSON_SUPPRESS_ERRORS', 32);
- * Brief example of use:
- * <code>
- * // create a new instance of Services_JSON
- * $json = new Services_JSON();
- * // convert a complexe value to JSON notation, and send it to the browser
- * $value = array('foo', 'bar', array(1, 2, 'baz'), array(3, array(4)));
- * $output = $json->encode($value);
- * print($output);
- * // prints: ["foo","bar",[1,2,"baz"],[3,[4]]]
- * // accept incoming POST data, assumed to be in JSON notation
- * $input = file_get_contents('php://input', 1000000);
- * $value = $json->decode($input);
- * </code>
-class Services_JSON
-    * constructs a new JSON instance
-    * @param    int     $use    object behavior flags; combine with boolean-OR
-    *                           possible values:
-    *                           - SERVICES_JSON_LOOSE_TYPE:  loose typing.
-    *                                   "{...}" syntax creates associative arrays
-    *                                   instead of objects in decode().
-    *                           - SERVICES_JSON_SUPPRESS_ERRORS:  error suppression.
-    *                                   Values which can't be encoded (e.g. resources)
-    *                                   appear as NULL instead of throwing errors.
-    *                                   By default, a deeply-nested resource will
-    *                                   bubble up with an error, so all return values
-    *                                   from encode() should be checked with isError()
-    function Services_JSON($use = 0)
-        $this->use = $use;
-    * convert a string from one UTF-16 char to one UTF-8 char
-    * Normally should be handled by mb_convert_encoding, but
-    * provides a slower PHP-only method for installations
-    * that lack the multibye string extension.
-    * @param    string  $utf16  UTF-16 character
-    * @return   string  UTF-8 character
-    * @access   private
-    function utf162utf8($utf16)
-        // oh please oh please oh please oh please oh please
-        if(function_exists('mb_convert_encoding')) {
-            return mb_convert_encoding($utf16, 'UTF-8', 'UTF-16');
-        $bytes = (ord($utf16{0}) << 8) | ord($utf16{1});
-        switch(true) {
-            case ((0x7F & $bytes) == $bytes):
-                // this case should never be reached, because we are in ASCII range
-                // see: http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
-                return chr(0x7F & $bytes);
-            case (0x07FF & $bytes) == $bytes:
-                // return a 2-byte UTF-8 character
-                return chr(0xC0 | (($bytes >> 6) & 0x1F))
-                     . chr(0x80 | ($bytes & 0x3F));
-            case (0xFFFF & $bytes) == $bytes:
-                // return a 3-byte UTF-8 character
-                return chr(0xE0 | (($bytes >> 12) & 0x0F))
-                     . chr(0x80 | (($bytes >> 6) & 0x3F))
-        // ignoring UTF-32 for now, sorry
-        return '';
-    * convert a string from one UTF-8 char to one UTF-16 char
-    * @param    string  $utf8   UTF-8 character
-    * @return   string  UTF-16 character
-    * @access   private
-    function utf82utf16($utf8)
-            return mb_convert_encoding($utf8, 'UTF-16', 'UTF-8');
-        switch(strlen($utf8)) {
-            case 1:
-                return $utf8;
-            case 2:
-                // return a UTF-16 character from a 2-byte UTF-8 char
-                return chr(0x07 & (ord($utf8{0}) >> 2))
-                     . chr((0xC0 & (ord($utf8{0}) << 6))
-                         | (0x3F & ord($utf8{1})));
-            case 3:
-                // return a UTF-16 character from a 3-byte UTF-8 char
-                return chr((0xF0 & (ord($utf8{0}) << 4))
-                         | (0x0F & (ord($utf8{1}) >> 2)))
-                     . chr((0xC0 & (ord($utf8{1}) << 6))
-                         | (0x7F & ord($utf8{2})));
-        return '';
-    * encodes an arbitrary variable into JSON format
-    * @param    mixed   $var    any number, boolean, string, array, or object to be encoded.
-    *                           see argument 1 to Services_JSON() above for array-parsing behavior.
-    *                           if var is a strng, note that encode() always expects it
-    *                           to be in ASCII or UTF-8 format!
-    * @return   mixed   JSON string representation of input var or an error if a problem occurs
-    * @access   public
-    function encode($var)
-        switch (gettype($var)) {
-            case 'boolean':
-                return $var ? 'true' : 'false';
-            case 'NULL':
-                return 'null';
-            case 'integer':
-                return (int) $var;
-            case 'double':
-            case 'float':
-                return (float) $var;
-            case 'string':
-                // STRINGS ARE EXPECTED TO BE IN ASCII OR UTF-8 FORMAT
-                $ascii = '';
-                $strlen_var = strlen($var);
-                * Iterate over every character in the string,
-                * escaping with a slash or encoding to UTF-8 where necessary
-                for ($c = 0; $c < $strlen_var; ++$c) {
-                    $ord_var_c = ord($var{$c});
-                    switch (true) {
-                        case $ord_var_c == 0x08:
-                            $ascii .= '\b';
-                            break;
-                        case $ord_var_c == 0x09:
-                            $ascii .= '\t';
-                            break;
-                        case $ord_var_c == 0x0A:
-                            $ascii .= '\n';
-                            break;
-                        case $ord_var_c == 0x0C:
-                            $ascii .= '\f';
-                            break;
-                        case $ord_var_c == 0x0D:
-                            $ascii .= '\r';
-                            break;
-                        case $ord_var_c == 0x22:
-                        case $ord_var_c == 0x2F:
-                        case $ord_var_c == 0x5C:
-                            // double quote, slash, slosh
-                            $ascii .= '\\'.$var{$c};
-                            break;
-                        case (($ord_var_c >= 0x20) && ($ord_var_c <= 0x7F)):
-                            // characters U-00000000 - U-0000007F (same as ASCII)
-                            $ascii .= $var{$c};
-                            break;
-                        case (($ord_var_c & 0xE0) == 0xC0):
-                            // characters U-00000080 - U-000007FF, mask 110XXXXX
-                            // see http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
-                            $char = pack('C*', $ord_var_c, ord($var{$c + 1}));
-                            $c += 1;
-                            $utf16 = $this->utf82utf16($char);
-                            $ascii .= sprintf('\u%04s', bin2hex($utf16));
-                            break;
-                        case (($ord_var_c & 0xF0) == 0xE0):
-                            // characters U-00000800 - U-0000FFFF, mask 1110XXXX
-                                         ord($var{$c + 1}),
-                                         ord($var{$c + 2}));
-                            $c += 2;
-                            break;
-                        case (($ord_var_c & 0xF8) == 0xF0):
-                            // characters U-00010000 - U-001FFFFF, mask 11110XXX
-                                         ord($var{$c + 2}),
-                                         ord($var{$c + 3}));
-                            $c += 3;
-                            break;
-                        case (($ord_var_c & 0xFC) == 0xF8):
-                            // characters U-00200000 - U-03FFFFFF, mask 111110XX
-                                         ord($var{$c + 3}),
-                                         ord($var{$c + 4}));
-                            $c += 4;
-                            break;
-                        case (($ord_var_c & 0xFE) == 0xFC):
-                            // characters U-04000000 - U-7FFFFFFF, mask 1111110X
-                                         ord($var{$c + 4}),
-                                         ord($var{$c + 5}));
-                            $c += 5;
-                            break;
-                return '"'.$ascii.'"';
-            case 'array':
-                * As per JSON spec if any array key is not an integer
-                * we must treat the the whole array as an object. We
-                * also try to catch a sparsely populated associative
-                * array with numeric keys here because some JS engines
-                * will create an array with empty indexes up to
-                * max_index which can cause memory issues and because
-                * the keys, which may be relevant, will be remapped
-                * otherwise.
-                * As per the ECMA and JSON specification an object may
-                * have any string as a property. Unfortunately due to
-                * a hole in the ECMA specification if the key is a
-                * ECMA reserved word or starts with a digit the
-                * parameter is only accessible using ECMAScript's
-                * bracket notation.
-                // treat as a JSON object
-                if (is_array($var) && count($var) && (array_keys($var) !== range(0, sizeof($var) - 1))) {
-                    $properties = array_map(array($this, 'name_value'),
-                                            array_keys($var),
-                                            array_values($var));
-                    foreach($properties as $property) {
-                        if(Services_JSON::isError($property)) {
-                            return $property;
-                    return '{' . join(',', $properties) . '}';
-                // treat it like a regular array
-                $elements = array_map(array($this, 'encode'), $var);
-                foreach($elements as $element) {
-                    if(Services_JSON::isError($element)) {
-                        return $element;
-                return '[' . join(',', $elements) . ']';
-            case 'object':
-                $vars = get_object_vars($var);
-                                        array_keys($vars),
-                                        array_values($vars));
-                        return $property;
-            default:
-                return ($this->use & SERVICES_JSON_SUPPRESS_ERRORS)
-                    ? 'null'
-                    : new Services_JSON_Error(gettype($var)." can not be encoded as JSON string");
-    * array-walking function for use in generating JSON-formatted name-value pairs
-    * @param    string  $name   name of key to use
-    * @param    mixed   $value  reference to an array element to be encoded
-    * @return   string  JSON-formatted name-value pair, like '"name":value'
-    * @access   private
-    function name_value($name, $value)
-        $encoded_value = $this->encode($value);
-        if(Services_JSON::isError($encoded_value)) {
-            return $encoded_value;
-        return $this->encode(strval($name)) . ':' . $encoded_value;
-    * reduce a string by removing leading and trailing comments and whitespace
-    * @param    $str    string      string value to strip of comments and whitespace
-    * @return   string  string value stripped of comments and whitespace
-    * @access   private
-    function reduce_string($str)
-        $str = preg_replace(array(
-                // eliminate single line comments in '// ...' form
-                '#^\s*//(.+)$#m',
-                // eliminate multi-line comments in '/* ... */' form, at start of string
-                '#^\s*/\*(.+)\*/#Us',
-                // eliminate multi-line comments in '/* ... */' form, at end of string
-                '#/\*(.+)\*/\s*$#Us'
-            ), '', $str);
-        // eliminate extraneous space
-        return trim($str);
-    * decodes a JSON string into appropriate variable
-    * @param    string  $str    JSON-formatted string
-    * @return   mixed   number, boolean, string, array, or object
-    *                   corresponding to given JSON input string.
-    *                   See argument 1 to Services_JSON() above for object-output behavior.
-    *                   Note that decode() always returns strings
-    *                   in ASCII or UTF-8 format!
-    * @access   public
-    function decode($str)
-        $str = $this->reduce_string($str);
-        switch (strtolower($str)) {
-            case 'true':
-                return true;
-            case 'false':
-                return false;
-            case 'null':
-                return null;
-            default:
-                $m = array();
-                if (is_numeric($str)) {
-                    // Lookie-loo, it's a number
-                    // This would work on its own, but I'm trying to be
-                    // good about returning integers where appropriate:
-                    // return (float)$str;
-                    // Return float or int, as appropriate
-                    return ((float)$str == (integer)$str)
-                        ? (integer)$str
-                        : (float)$str;
-                } elseif (preg_match('/^("|\').*(\1)$/s', $str, $m) && $m[1] == $m[2]) {
-                    // STRINGS RETURNED IN UTF-8 FORMAT
-                    $delim = substr($str, 0, 1);
-                    $chrs = substr($str, 1, -1);
-                    $utf8 = '';
-                    $strlen_chrs = strlen($chrs);
-                    for ($c = 0; $c < $strlen_chrs; ++$c) {
-                        $substr_chrs_c_2 = substr($chrs, $c, 2);
-                        $ord_chrs_c = ord($chrs{$c});
-                        switch (true) {
-                            case $substr_chrs_c_2 == '\b':
-                                $utf8 .= chr(0x08);
-                                ++$c;
-                                break;
-                            case $substr_chrs_c_2 == '\t':
-                                $utf8 .= chr(0x09);
-                                ++$c;
-                                break;
-                            case $substr_chrs_c_2 == '\n':
-                                $utf8 .= chr(0x0A);
-                                ++$c;
-                                break;
-                            case $substr_chrs_c_2 == '\f':
-                                $utf8 .= chr(0x0C);
-                                ++$c;
-                                break;
-                            case $substr_chrs_c_2 == '\r':
-                                $utf8 .= chr(0x0D);
-                                ++$c;
-                                break;
-                            case $substr_chrs_c_2 == '\\"':
-                            case $substr_chrs_c_2 == '\\\'':
-                            case $substr_chrs_c_2 == '\\\\':
-                            case $substr_chrs_c_2 == '\\/':
-                                if (($delim == '"' && $substr_chrs_c_2 != '\\\'') ||
-                                   ($delim == "'" && $substr_chrs_c_2 != '\\"')) {
-                                    $utf8 .= $chrs{++$c};
-                                break;
-                            case preg_match('/\\\u[0-9A-F]{4}/i', substr($chrs, $c, 6)):
-                                // single, escaped unicode character
-                                $utf16 = chr(hexdec(substr($chrs, ($c + 2), 2)))
-                                       . chr(hexdec(substr($chrs, ($c + 4), 2)));
-                                $utf8 .= $this->utf162utf8($utf16);
-                                $c += 5;
-                                break;
-                            case ($ord_chrs_c >= 0x20) && ($ord_chrs_c <= 0x7F):
-                                $utf8 .= $chrs{$c};
-                                break;
-                            case ($ord_chrs_c & 0xE0) == 0xC0:
-                                //see http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
-                                $utf8 .= substr($chrs, $c, 2);
-                                ++$c;
-                                break;
-                            case ($ord_chrs_c & 0xF0) == 0xE0:
-                                $utf8 .= substr($chrs, $c, 3);
-                                $c += 2;
-                                break;
-                            case ($ord_chrs_c & 0xF8) == 0xF0:
-                                $utf8 .= substr($chrs, $c, 4);
-                                $c += 3;
-                                break;
-                            case ($ord_chrs_c & 0xFC) == 0xF8:
-                                $utf8 .= substr($chrs, $c, 5);
-                                $c += 4;
-                                break;
-                            case ($ord_chrs_c & 0xFE) == 0xFC:
-                                $utf8 .= substr($chrs, $c, 6);
-                                $c += 5;
-                                break;
-                    return $utf8;
-                } elseif (preg_match('/^\[.*\]$/s', $str) || preg_match('/^\{.*\}$/s', $str)) {
-                    // array, or object notation
-                    if ($str{0} == '[') {
-                        $stk = array(SERVICES_JSON_IN_ARR);
-                        $arr = array();
-                    } else {
-                        if ($this->use & SERVICES_JSON_LOOSE_TYPE) {
-                            $stk = array(SERVICES_JSON_IN_OBJ);
-                            $obj = array();
-                        } else {
-                            $obj = new stdClass();
-                    array_push($stk, array('what'  => SERVICES_JSON_SLICE,
-                                           'where' => 0,
-                                           'delim' => false));
-                    $chrs = $this->reduce_string($chrs);
-                    if ($chrs == '') {
-                        if (reset($stk) == SERVICES_JSON_IN_ARR) {
-                            return $arr;
-                        } else {
-                            return $obj;
-                    //print("\nparsing {$chrs}\n");
-                    for ($c = 0; $c <= $strlen_chrs; ++$c) {
-                        $top = end($stk);
-                        if (($c == $strlen_chrs) || (($chrs{$c} == ',') && ($top['what'] == SERVICES_JSON_SLICE))) {
-                            // found a comma that is not inside a string, array, etc.,
-                            // OR we've reached the end of the character list
-                            $slice = substr($chrs, $top['where'], ($c - $top['where']));
-                            array_push($stk, array('what' => SERVICES_JSON_SLICE, 'where' => ($c + 1), 'delim' => false));
-                            //print("Found split at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
-                                // we are in an array, so just push an element onto the stack
-                                array_push($arr, $this->decode($slice));
-                            } elseif (reset($stk) == SERVICES_JSON_IN_OBJ) {
-                                // we are in an object, so figure
-                                // out the property name and set an
-                                // element in an associative array,
-                                // for now
-                                $parts = array();
-                                if (preg_match('/^\s*(["\'].*[^\\\]["\'])\s*:\s*(\S.*),?$/Uis', $slice, $parts)) {
-                                    // "name":value pair
-                                    $key = $this->decode($parts[1]);
-                                    $val = $this->decode($parts[2]);
-                                        $obj[$key] = $val;
-                                    } else {
-                                        $obj->$key = $val;
-                                } elseif (preg_match('/^\s*(\w+)\s*:\s*(\S.*),?$/Uis', $slice, $parts)) {
-                                    // name:value pair, where name is unquoted
-                                    $key = $parts[1];
-                                    } else {
-                        } elseif ((($chrs{$c} == '"') || ($chrs{$c} == "'")) && ($top['what'] != SERVICES_JSON_IN_STR)) {
-                            // found a quote, and we are not inside a string
-                            array_push($stk, array('what' => SERVICES_JSON_IN_STR, 'where' => $c, 'delim' => $chrs{$c}));
-                            //print("Found start of string at {$c}\n");
-                        } elseif (($chrs{$c} == $top['delim']) &&
-                                 ($top['what'] == SERVICES_JSON_IN_STR) &&
-                                 ((strlen(substr($chrs, 0, $c)) - strlen(rtrim(substr($chrs, 0, $c), '\\'))) % 2 != 1)) {
-                            // found a quote, we're in a string, and it's not escaped
-                            // we know that it's not escaped becase there is _not_ an
-                            // odd number of backslashes at the end of the string so far
-                            array_pop($stk);
-                            //print("Found end of string at {$c}: ".substr($chrs, $top['where'], (1 + 1 + $c - $top['where']))."\n");
-                        } elseif (($chrs{$c} == '[') &&
-                                 in_array($top['what'], array(SERVICES_JSON_SLICE, SERVICES_JSON_IN_ARR, SERVICES_JSON_IN_OBJ))) {
-                            // found a left-bracket, and we are in an array, object, or slice
-                            array_push($stk, array('what' => SERVICES_JSON_IN_ARR, 'where' => $c, 'delim' => false));
-                            //print("Found start of array at {$c}\n");
-                        } elseif (($chrs{$c} == ']') && ($top['what'] == SERVICES_JSON_IN_ARR)) {
-                            // found a right-bracket, and we're in an array
-                            array_pop($stk);
-                            //print("Found end of array at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
-                        } elseif (($chrs{$c} == '{') &&
-                            // found a left-brace, and we are in an array, object, or slice
-                            array_push($stk, array('what' => SERVICES_JSON_IN_OBJ, 'where' => $c, 'delim' => false));
-                            //print("Found start of object at {$c}\n");
-                        } elseif (($chrs{$c} == '}') && ($top['what'] == SERVICES_JSON_IN_OBJ)) {
-                            // found a right-brace, and we're in an object
-                            array_pop($stk);
-                            //print("Found end of object at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
-                        } elseif (($substr_chrs_c_2 == '/*') &&
-                            // found a comment start, and we are in an array, object, or slice
-                            array_push($stk, array('what' => SERVICES_JSON_IN_CMT, 'where' => $c, 'delim' => false));
-                            $c++;
-                            //print("Found start of comment at {$c}\n");
-                        } elseif (($substr_chrs_c_2 == '*/') && ($top['what'] == SERVICES_JSON_IN_CMT)) {
-                            // found a comment end, and we're in one now
-                            array_pop($stk);
-                            $c++;
-                            for ($i = $top['where']; $i <= $c; ++$i)
-                                $chrs = substr_replace($chrs, ' ', $i, 1);
-                            //print("Found end of comment at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
-                        return $arr;
-                        return $obj;
-     * @todo Ultimately, this should just call PEAR::isError()
-    function isError($data, $code = null)
-        if (class_exists('pear')) {
-            return PEAR::isError($data, $code);
-        } elseif (is_object($data) && (get_class($data) == 'services_json_error' ||
-                                 is_subclass_of($data, 'services_json_error'))) {
-            return true;
-        return false;
-if (class_exists('PEAR_Error')) {
-    class Services_JSON_Error extends PEAR_Error
-        function Services_JSON_Error($message = 'unknown error', $code = null,
-                                     $mode = null, $options = null, $userinfo = null)
-            parent::PEAR_Error($message, $code, $mode, $options, $userinfo);
-} else {
-     * @todo Ultimately, this class shall be descended from PEAR_Error
Deleted: branches/testbaudson_dev/http/extensions/OpenLayers.js
--- trunk/mapbender/http/extensions/OpenLayers.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/extensions/OpenLayers.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,1382 +0,0 @@
-  OpenLayers.js -- OpenLayers Map Viewer Library
-  Copyright 2005-2008 MetaCarta, Inc., released under the Clear BSD license.
-  Please see http://svn.openlayers.org/trunk/openlayers/license.txt
-  for the full text of the license.
-  Includes compressed code under the following licenses:
-  (For uncompressed versions of the code used please see the
-  OpenLayers SVN repository: <http://openlayers.org/>)
-/* Contains portions of Prototype.js:
- * Prototype JavaScript framework, version 1.4.0
- *  (c) 2005 Sam Stephenson <sam at conio.net>
- *  Prototype is freely distributable under the terms of an MIT-style license.
- *  For details, see the Prototype web site: http://prototype.conio.net/
-*  Contains portions of Rico <http://openrico.org/>
-*  Copyright 2005 Sabre Airline Solutions
-*  Licensed under the Apache License, Version 2.0 (the "License"); you
-*  may not use this file except in compliance with the License. You
-*  may obtain a copy of the License at
-*         http://www.apache.org/licenses/LICENSE-2.0
-*  Unless required by applicable law or agreed to in writing, software
-*  distributed under the License is distributed on an "AS IS" BASIS,
-*  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
-*  implied. See the License for the specific language governing
-*  permissions and limitations under the License.
-var OpenLayers={singleFile:true};(function(){var singleFile=(typeof OpenLayers=="object"&&OpenLayers.singleFile);window.OpenLayers={_scriptName:(!singleFile)?"lib/OpenLayers.js":"OpenLayers.js",_getScriptLocation:function(){var scriptLocation="";var scriptName=OpenLayers._scriptName;var scripts=document.getElementsByTagName('script');for(var i=0;i<scripts.length;i++){var src=scripts[i].getAttribute('src');if(src){var index=src.lastIndexOf(scriptName);var pathLength=src.lastIndexOf('?');if(pathLength<0){pathLength=src.length;}
-if((index>-1)&&(index+scriptName.length==pathLength)){scriptLocation=src.slice(0,pathLength-scriptName.length);break;}}}
-return scriptLocation;}};if(!singleFile){var jsfiles=new Array("OpenLayers/Util.js","OpenLayers/BaseTypes.js","OpenLayers/BaseTypes/Class.js","OpenLayers/BaseTypes/Bounds.js","OpenLayers/BaseTypes/Element.js","OpenLayers/BaseTypes/LonLat.js","OpenLayers/BaseTypes/Pixel.js","OpenLayers/BaseTypes/Size.js","OpenLayers/Console.js","OpenLayers/Tween.js","Rico/Corner.js","Rico/Color.js","OpenLayers/Ajax.js","OpenLayers/Events.js","OpenLayers/Projection.js","OpenLayers/Map.js","OpenLayers/Layer.js","OpenLayers/Icon.js","OpenLayers/Marker.js","OpenLayers/Marker/Box.js","OpenLayers/Popup.js","OpenLayers/Tile.js","OpenLayers/Tile/Image.js","OpenLayers/Tile/WFS.js","OpenLayers/Layer/Image.js","OpenLayers/Layer/SphericalMercator.js","OpenLayers/Layer/EventPane.js","OpenLayers/Layer/FixedZoomLevels.js","OpenLayers/Layer/Google.js","OpenLayers/Layer/VirtualEarth.js","OpenLayers/Layer/Yahoo.js","OpenLayers/Layer/HTTPRequest.js","OpenLayers/Layer/Grid.js","OpenLayers/Layer/MapGuide.js","OpenLayers/Layer/MapServer.js","OpenLayers/Layer/MapServer/Untiled.js","OpenLayers/Layer/KaMap.js","OpenLayers/Layer/MultiMap.js","OpenLayers/Layer/Markers.js","OpenLayers/Layer/Text.js","OpenLayers/Layer/WorldWind.js","OpenLayers/Layer/WMS.js","OpenLayers/Layer/WMS/Untiled.js","OpenLayers/Layer/GeoRSS.js","OpenLayers/Layer/Boxes.js","OpenLayers/Layer/TMS.js","OpenLayers/Layer/TileCache.js","OpenLayers/Popup/Anchored.js","OpenLayers/Popup/AnchoredBubble.js","OpenLayers/Popup/Framed.js","OpenLayers/Popup/FramedCloud.js","OpenLayers/Feature.js","OpenLayers/Feature/Vector.js","OpenLayers/Feature/WFS.js","OpenLayers/Handler.js","OpenLayers/Handler/Click.js","OpenLayers/Handler/Hover.js","OpenLayers/Handler/Point.js","OpenLayers/Handler/Path.js","OpenLayers/Handler/Polygon.js","OpenLayers/Handler/Feature.js","OpenLayers/Handler/Drag.js","OpenLayers/Handler/RegularPolygon.js","OpenLayers/Handler/Box.js","OpenLayers/Handler/MouseWheel.js","OpenLayers/Handler/Keyboard.js","OpenLayers/Control.js","OpenLayers/Control/Attribution.js","OpenLayers/Control/Button.js","OpenLayers/Control/ZoomBox.js","OpenLayers/Control/ZoomToMaxExtent.js","OpenLayers/Control/DragPan.js","OpenLayers/Control/Navigation.js","OpenLayers/Control/MouseDefaults.js","OpenLayers/Control/MousePosition.js","OpenLayers/Control/OverviewMap.js","OpenLayers/Control/KeyboardDefaults.js","OpenLayers/Control/PanZoom.js","OpenLayers/Control/PanZoomBar.js","OpenLayers/Control/ArgParser.js","OpenLayers/Control/Permalink.js","OpenLayers/Control/Scale.js","OpenLayers/Control/ScaleLine.js","OpenLayers/Control/LayerSwitcher.js","OpenLayers/Control/DrawFeature.js","OpenLayers/Control/DragFeature.js","OpenLayers/Control/ModifyFeature.js","OpenLayers/Control/Panel.js","OpenLayers/Control/SelectFeature.js","OpenLayers/Control/NavigationHistory.js","OpenLayers/Geometry.js","OpenLayers/Geometry/Rectangle.js","OpenLayers/Geometry/Collection.js","OpenLayers/Geometry/Point.js","OpenLayers/Geometry/MultiPoint.js","OpenLayers/Geometry/Curve.js","OpenLayers/Geometry/LineString.js","OpenLayers/Geometry/LinearRing.js","OpenLayers/Geometry/Polygon.js","OpenLayers/Geometry/MultiLineString.js","OpenLayers/Geometry/MultiPolygon.js","OpenLayers/Geometry/Surface.js","OpenLayers/Renderer.js","OpenLayers/Renderer/Elements.js","OpenLayers/Renderer/SVG.js","OpenLayers/Renderer/VML.js","OpenLayers/Layer/Vector.js","OpenLayers/Layer/PointTrack.js","OpenLayers/Layer/GML.js","OpenLayers/Style.js","OpenLayers/StyleMap.js","OpenLayers/Rule.js","OpenLayers/Filter.js","OpenLayers/Filter/FeatureId.js","OpenLayers/Filter/Logical.js","OpenLayers/Filter/Comparison.js","OpenLayers/Format.js","OpenLayers/Format/XML.js","OpenLayers/Format/GML.js","OpenLayers/Format/KML.js","OpenLayers/Format/GeoRSS.js","OpenLayers/Format/WFS.js","OpenLayers/Format/WKT.js","OpenLayers/Format/OSM.js","OpenLayers/Format/SLD.js","OpenLayers/Format/SLD/v1.js","OpenLayers/Format/SLD/v1_0_0.js","OpenLayers/Format/Text.js","OpenLayers/Format/JSON.js","OpenLayers/Format/GeoJSON.js","OpenLayers/Format/WMC.js","OpenLayers/Format/WMC/v1.js","OpenLayers/Format/WMC/v1_0_0.js","OpenLayers/Format/WMC/v1_1_0.js","OpenLayers/Layer/WFS.js","OpenLayers/Control/MouseToolbar.js","OpenLayers/Control/NavToolbar.js","OpenLayers/Control/EditingToolbar.js","OpenLayers/Lang.js","OpenLayers/Lang/en.js");var agent=navigator.userAgent;var docWrite=(agent.match("MSIE")||agent.match("Safari"));if(docWrite){var allScriptTags=new Array(jsfiles.length);}
-var host=OpenLayers._getScriptLocation()+"lib/";for(var i=0;i<jsfiles.length;i++){if(docWrite){allScriptTags[i]="<script src='"+host+jsfiles[i]+"'></script>";}else{var s=document.createElement("script");s.src=host+jsfiles[i];var h=document.getElementsByTagName("head").length?document.getElementsByTagName("head")[0]:document.body;h.appendChild(s);}}
-if(docWrite){document.write(allScriptTags.join(""));}}})();OpenLayers.VERSION_NUMBER="$Revision: 6819 $";OpenLayers.String={startsWith:function(str,sub){return(str.indexOf(sub)==0);},contains:function(str,sub){return(str.indexOf(sub)!=-1);},trim:function(str){return str.replace(/^\s*(.*?)\s*$/,"$1");},camelize:function(str){var oStringList=str.split('-');var camelizedString=oStringList[0];for(var i=1;i<oStringList.length;i++){var s=oStringList[i];camelizedString+=s.charAt(0).toUpperCase()+s.substring(1);}
-return camelizedString;},format:function(template,context,args){if(!context){context=window;}
-var tokens=template.split("${");var item,last,replacement;for(var i=1;i<tokens.length;i++){item=tokens[i];last=item.indexOf("}");if(last>0){replacement=context[item.substring(0,last)];if(typeof replacement=="function"){replacement=args?replacement.apply(null,args):replacement();}
-tokens[i]=replacement+item.substring(++last);}else{tokens[i]="${"+item;}}
-return tokens.join("");}};if(!String.prototype.startsWith){String.prototype.startsWith=function(sStart){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.startsWith'}));return OpenLayers.String.startsWith(this,sStart);};}
-if(!String.prototype.contains){String.prototype.contains=function(str){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.contains'}));return OpenLayers.String.contains(this,str);};}
-if(!String.prototype.trim){String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.trim'}));return OpenLayers.String.trim(this);};}
-if(!String.prototype.camelize){String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.camelize'}));return OpenLayers.String.camelize(this);};}
-OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(num,sig){var fig=0;if(sig>0){fig=parseFloat(num.toPrecision(sig));}
-return fig;},format:function(num,dec,tsep,dsep){dec=(typeof dec!="undefined")?dec:0;tsep=(typeof tsep!="undefined")?tsep:OpenLayers.Number.thousandsSeparator;dsep=(typeof dsep!="undefined")?dsep:OpenLayers.Number.decimalSeparator;if(dec!=null){num=parseFloat(num.toFixed(dec));}
-var parts=num.toString().split(".");if(parts.length==1&&dec==null){dec=0;}
-var integer=parts[0];if(tsep){var thousands=/(-?[0-9]+)([0-9]{3})/;while(thousands.test(integer)){integer=integer.replace(thousands,"$1"+tsep+"$2");}}
-var str;if(dec==0){str=integer;}else{var rem=parts.length>1?parts[1]:"0";if(dec!=null){rem=rem+new Array(dec-rem.length+1).join("0");}
-str=integer+dsep+rem;}
-return str;}};if(!Number.prototype.limitSigDigs){Number.prototype.limitSigDigs=function(sig){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.limitSigDigs'}));return OpenLayers.Number.limitSigDigs(this,sig);};}
-OpenLayers.Function={bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},bindAsEventListener:function(func,object){return function(event){return func.call(object,event||window.event);};}};if(!Function.prototype.bind){Function.prototype.bind=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.bind'}));Array.prototype.unshift.apply(arguments,[this]);return OpenLayers.Function.bind.apply(null,arguments);};}
-if(!Function.prototype.bindAsEventListener){Function.prototype.bindAsEventListener=function(object){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.bindAsEventListener'}));return OpenLayers.Function.bindAsEventListener(this,object);};}
-OpenLayers.Array={filter:function(array,callback,caller){var selected=[];if(Array.prototype.filter){selected=array.filter(callback,caller);}else{var len=array.length;if(typeof callback!="function"){throw new TypeError();}
-for(var i=0;i<len;i++){if(i in array){var val=array[i];if(callback.call(caller,val,i,array)){selected.push(val);}}}}
-return selected;}};OpenLayers.Class=function(){var Class=function(){if(arguments&&arguments[0]!=OpenLayers.Class.isPrototype){this.initialize.apply(this,arguments);}};var extended={};var parent;for(var i=0;i<arguments.length;++i){if(typeof arguments[i]=="function"){parent=arguments[i].prototype;}else{parent=arguments[i];}
-OpenLayers.Util.extend(extended,parent);}
-Class.prototype=extended;return Class;};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){if(arguments&&arguments[0]!=OpenLayers.Class.isPrototype){this.initialize.apply(this,arguments);}};};OpenLayers.Class.inherit=function(){var superClass=arguments[0];var proto=new superClass(OpenLayers.Class.isPrototype);for(var i=1;i<arguments.length;i++){if(typeof arguments[i]=="function"){var mixin=arguments[i];arguments[i]=new mixin(OpenLayers.Class.isPrototype);}
-OpenLayers.Util.extend(proto,arguments[i]);}
-return proto;};OpenLayers.Util={};OpenLayers.Util.getElement=function(){var elements=[];for(var i=0;i<arguments.length;i++){var element=arguments[i];if(typeof element=='string'){element=document.getElementById(element);}
-if(arguments.length==1){return element;}
-elements.push(element);}
-return elements;};if($==null){var $=OpenLayers.Util.getElement;}
-OpenLayers.Util.extend=function(destination,source){if(destination&&source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
-var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty('toString')){destination.toString=source.toString;}}
-return destination;};OpenLayers.Util.removeItem=function(array,item){for(var i=array.length-1;i>=0;i--){if(array[i]==item){array.splice(i,1);}}
-return array;};OpenLayers.Util.clearArray=function(array){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'array = []'}));array.length=0;};OpenLayers.Util.indexOf=function(array,obj){for(var i=0;i<array.length;i++){if(array[i]==obj){return i;}}
-return-1;};OpenLayers.Util.modifyDOMElement=function(element,id,px,sz,position,border,overflow,opacity){if(id){element.id=id;}
-if(px){element.style.left=px.x+"px";element.style.top=px.y+"px";}
-if(sz){element.style.width=sz.w+"px";element.style.height=sz.h+"px";}
-if(position){element.style.position=position;}
-if(border){element.style.border=border;}
-if(overflow){element.style.overflow=overflow;}
-if(parseFloat(opacity)>=0.0&&parseFloat(opacity)<1.0){element.style.filter='alpha(opacity='+(opacity*100)+')';element.style.opacity=opacity;}else if(parseFloat(opacity)==1.0){element.style.filter='';element.style.opacity='';}};OpenLayers.Util.createDiv=function(id,px,sz,imgURL,position,border,overflow,opacity){var dom=document.createElement('div');if(imgURL){dom.style.backgroundImage='url('+imgURL+')';}
-if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
-if(!position){position="absolute";}
-OpenLayers.Util.modifyDOMElement(dom,id,px,sz,position,border,overflow,opacity);return dom;};OpenLayers.Util.createImage=function(id,px,sz,imgURL,position,border,opacity,delayDisplay){var image=document.createElement("img");if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
-if(!position){position="relative";}
-OpenLayers.Util.modifyDOMElement(image,id,px,sz,position,border,null,opacity);if(delayDisplay){image.style.display="none";OpenLayers.Event.observe(image,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,image));OpenLayers.Event.observe(image,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,image));}
-image.style.alt=id;image.galleryImg="no";if(imgURL){image.src=imgURL;}
-return image;};OpenLayers.Util.setOpacity=function(element,opacity){OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);};OpenLayers.Util.onImageLoad=function(){if(!this.viewRequestID||(this.map&&this.viewRequestID==this.map.viewRequestID)){this.style.backgroundColor=null;this.style.display="";}};OpenLayers.Util.onImageLoadErrorColor="pink";OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;OpenLayers.Util.onImageLoadError=function(){this._attempts=(this._attempts)?(this._attempts+1):1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){this.src=this.src;}else{this.style.backgroundColor=OpenLayers.Util.onImageLoadErrorColor;}
-this.style.display="";};OpenLayers.Util.alphaHack=function(){var arVersion=navigator.appVersion.split("MSIE");var version=parseFloat(arVersion[1]);var filter=false;try{filter=!!(document.body.filters);}catch(e){}
-return(filter&&(version>=5.5)&&(version<7));};OpenLayers.Util.modifyAlphaImageDiv=function(div,id,px,sz,imgURL,position,border,sizing,opacity){OpenLayers.Util.modifyDOMElement(div,id,px,sz,null,null,null,opacity);var img=div.childNodes[0];if(imgURL){img.src=imgURL;}
-OpenLayers.Util.modifyDOMElement(img,div.id+"_innerImage",null,sz,"relative",border);if(OpenLayers.Util.alphaHack()){div.style.display="inline-block";if(sizing==null){sizing="scale";}
-div.style.filter="progid:DXImageTransform.Microsoft"+".AlphaImageLoader(src='"+img.src+"', "+"sizingMethod='"+sizing+"')";if(parseFloat(div.style.opacity)>=0.0&&parseFloat(div.style.opacity)<1.0){div.style.filter+=" alpha(opacity="+div.style.opacity*100+")";}
-img.style.filter="alpha(opacity=0)";}};OpenLayers.Util.createAlphaImageDiv=function(id,px,sz,imgURL,position,border,sizing,opacity,delayDisplay){var div=OpenLayers.Util.createDiv();var img=OpenLayers.Util.createImage(null,null,null,null,null,null,null,false);div.appendChild(img);if(delayDisplay){img.style.display="none";OpenLayers.Event.observe(img,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,div));OpenLayers.Event.observe(img,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,div));}
-OpenLayers.Util.modifyAlphaImageDiv(div,id,px,sz,imgURL,position,border,sizing,opacity);return div;};OpenLayers.Util.upperCaseObject=function(object){var uObject={};for(var key in object){uObject[key.toUpperCase()]=object[key];}
-return uObject;};OpenLayers.Util.applyDefaults=function(to,from){var fromIsEvt=typeof window.Event=="function"&&from instanceof window.Event;for(var key in from){if(to[key]===undefined||(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty(key)&&!to.hasOwnProperty(key))){to[key]=from[key];}}
-if(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty('toString')&&!to.hasOwnProperty('toString')){to.toString=from.toString;}
-return to;};OpenLayers.Util.getParameterString=function(params){var paramsArray=[];for(var key in params){var value=params[key];if((value!=null)&&(typeof value!='function')){var encodedValue;if(typeof value=='object'&&value.constructor==Array){var encodedItemArray=[];for(var itemIndex=0;itemIndex<value.length;itemIndex++){encodedItemArray.push(encodeURIComponent(value[itemIndex]));}
-encodedValue=encodedItemArray.join(",");}
-else{encodedValue=encodeURIComponent(value);}
-paramsArray.push(encodeURIComponent(key)+"="+encodedValue);}}
-return paramsArray.join("&");};OpenLayers.ImgPath='';OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||(OpenLayers._getScriptLocation()+"img/");};OpenLayers.Util.Try=function(){var returnValue=null;for(var i=0;i<arguments.length;i++){var lambda=arguments[i];try{returnValue=lambda();break;}catch(e){}}
-return returnValue;};OpenLayers.Util.getNodes=function(p,tagName){var nodes=OpenLayers.Util.Try(function(){return OpenLayers.Util._getNodes(p.documentElement.childNodes,tagName);},function(){return OpenLayers.Util._getNodes(p.childNodes,tagName);});return nodes;};OpenLayers.Util._getNodes=function(nodes,tagName){var retArray=[];for(var i=0;i<nodes.length;i++){if(nodes[i].nodeName==tagName){retArray.push(nodes[i]);}}
-return retArray;};OpenLayers.Util.getTagText=function(parent,item,index){var result=OpenLayers.Util.getNodes(parent,item);if(result&&(result.length>0))
-{if(!index){index=0;}
-if(result[index].childNodes.length>1){return result.childNodes[1].nodeValue;}
-else if(result[index].childNodes.length==1){return result[index].firstChild.nodeValue;}}else{return"";}};OpenLayers.Util.getXmlNodeValue=function(node){var val=null;OpenLayers.Util.Try(function(){val=node.text;if(!val){val=node.textContent;}
-if(!val){val=node.firstChild.nodeValue;}},function(){val=node.textContent;});return val;};OpenLayers.Util.mouseLeft=function(evt,div){var target=(evt.relatedTarget)?evt.relatedTarget:evt.toElement;while(target!=div&&target!=null){target=target.parentNode;}
-return(target!=div);};OpenLayers.Util.rad=function(x){return x*Math.PI/180;};OpenLayers.Util.distVincenty=function(p1,p2){var a=6378137,b=6356752.3142,f=1/298.257223563;var L=OpenLayers.Util.rad(p2.lon-p1.lon);var U1=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p1.lat)));var U2=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p2.lat)));var sinU1=Math.sin(U1),cosU1=Math.cos(U1);var sinU2=Math.sin(U2),cosU2=Math.cos(U2);var lambda=L,lambdaP=2*Math.PI;var iterLimit=20;while(Math.abs(lambda-lambdaP)>1e-12&&--iterLimit>0){var sinLambda=Math.sin(lambda),cosLambda=Math.cos(lambda);var sinSigma=Math.sqrt((cosU2*sinLambda)*(cosU2*sinLambda)+
-(cosU1*sinU2-sinU1*cosU2*cosLambda)*(cosU1*sinU2-sinU1*cosU2*cosLambda));if(sinSigma==0){return 0;}
-var cosSigma=sinU1*sinU2+cosU1*cosU2*cosLambda;var sigma=Math.atan2(sinSigma,cosSigma);var alpha=Math.asin(cosU1*cosU2*sinLambda/sinSigma);var cosSqAlpha=Math.cos(alpha)*Math.cos(alpha);var cos2SigmaM=cosSigma-2*sinU1*sinU2/cosSqAlpha;var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));lambdaP=lambda;lambda=L+(1-C)*f*Math.sin(alpha)*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));}
-if(iterLimit==0){return NaN;}
-var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)-
-B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));var s=b*A*(sigma-deltaSigma);var d=s.toFixed(3)/1000;return d;};OpenLayers.Util.getParameters=function(url){url=url||window.location.href;var paramsString="";if(OpenLayers.String.contains(url,'?')){var start=url.indexOf('?')+1;var end=OpenLayers.String.contains(url,"#")?url.indexOf('#'):url.length;paramsString=url.substring(start,end);}
-var parameters={};var pairs=paramsString.split(/[&;]/);for(var i=0;i<pairs.length;++i){var keyValue=pairs[i].split('=');if(keyValue[0]){var key=decodeURIComponent(keyValue[0]);var value=keyValue[1]||'';value=value.split(",");for(var j=0;j<value.length;j++){value[j]=decodeURIComponent(value[j]);}
-if(value.length==1){value=value[0];}
-parameters[key]=value;}}
-return parameters;};OpenLayers.Util.getArgs=function(url){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Util.getParameters'}));return OpenLayers.Util.getParameters(url);};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(prefix){if(prefix==null){prefix="id_";}
-OpenLayers.Util.lastSeqID+=1;return prefix+OpenLayers.Util.lastSeqID;};OpenLayers.INCHES_PER_UNIT={'inches':1.0,'ft':12.0,'mi':63360.0,'m':39.3701,'km':39370.1,'dd':4374754,'yd':36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;OpenLayers.INCHES_PER_UNIT["degrees"]=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT["nmi"]=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.DOTS_PER_INCH=72;OpenLayers.Util.normalizeScale=function(scale){var normScale=(scale>1.0)?(1.0/scale):scale;return normScale;};OpenLayers.Util.getResolutionFromScale=function(scale,units){if(units==null){units="degrees";}
-var normScale=OpenLayers.Util.normalizeScale(scale);var resolution=1/(normScale*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH);return resolution;};OpenLayers.Util.getScaleFromResolution=function(resolution,units){if(units==null){units="degrees";}
-var scale=resolution*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH;return scale;};OpenLayers.Util.safeStopPropagation=function(evt){OpenLayers.Event.stop(evt,true);};OpenLayers.Util.pagePosition=function(forElement){var valueT=0,valueL=0;var element=forElement;var child=forElement;while(element){if(element==document.body){if(child&&child.style&&OpenLayers.Element.getStyle(child,'position')=='absolute'){break;}}
-valueT+=element.offsetTop||0;valueL+=element.offsetLeft||0;child=element;try{element=element.offsetParent;}catch(e){OpenLayers.Console.error(OpenLayers.i18n("pagePositionFailed",{'elemId':element.id}));break;}}
-element=forElement;while(element){valueT-=element.scrollTop||0;valueL-=element.scrollLeft||0;element=element.parentNode;}
-return[valueL,valueT];};OpenLayers.Util.isEquivalentUrl=function(url1,url2,options){options=options||{};OpenLayers.Util.applyDefaults(options,{ignoreCase:true,ignorePort80:true,ignoreHash:true});var urlObj1=OpenLayers.Util.createUrlObject(url1,options);var urlObj2=OpenLayers.Util.createUrlObject(url2,options);for(var key in urlObj1){if(options.test){alert(key+"\n1:"+urlObj1[key]+"\n2:"+urlObj2[key]);}
-var val1=urlObj1[key];var val2=urlObj2[key];switch(key){case"args":break;case"host":case"port":case"protocol":if((val1=="")||(val2=="")){break;}
-default:if((key!="args")&&(urlObj1[key]!=urlObj2[key])){return false;}
-break;}}
-for(var key in urlObj1.args){if(urlObj1.args[key]!=urlObj2.args[key]){return false;}
-delete urlObj2.args[key];}
-for(var key in urlObj2.args){return false;}
-return true;};OpenLayers.Util.createUrlObject=function(url,options){options=options||{};var urlObject={};if(options.ignoreCase){url=url.toLowerCase();}
-var a=document.createElement('a');a.href=url;urlObject.host=a.host;var port=a.port;if(port.length<=0){var newHostLength=urlObject.host.length-(port.length);urlObject.host=urlObject.host.substring(0,newHostLength);}
-urlObject.protocol=a.protocol;urlObject.port=((port=="80")&&(options.ignorePort80))?"":port;urlObject.hash=(options.ignoreHash)?"":a.hash;var queryString=a.search;if(!queryString){var qMark=url.indexOf("?");queryString=(qMark!=-1)?url.substr(qMark):"";}
-urlObject.args=OpenLayers.Util.getParameters(queryString);if(((urlObject.protocol=="file:")&&(url.indexOf("file:")!=-1))||((urlObject.protocol!="file:")&&(urlObject.host!=""))){urlObject.pathname=a.pathname;var qIndex=urlObject.pathname.indexOf("?");if(qIndex!=-1){urlObject.pathname=urlObject.pathname.substring(0,qIndex);}}else{var relStr=OpenLayers.Util.removeTail(url);var backs=0;do{var index=relStr.indexOf("../");if(index==0){backs++;relStr=relStr.substr(3);}else if(index>=0){var prevChunk=relStr.substr(0,index-1);var slash=prevChunk.indexOf("/");prevChunk=(slash!=-1)?prevChunk.substr(0,slash+1):"";var postChunk=relStr.substr(index+3);relStr=prevChunk+postChunk;}}while(index!=-1)
-var windowAnchor=document.createElement("a");var windowUrl=window.location.href;if(options.ignoreCase){windowUrl=windowUrl.toLowerCase();}
-windowAnchor.href=windowUrl;urlObject.protocol=windowAnchor.protocol;var splitter=(windowAnchor.pathname.indexOf("/")!=-1)?"/":"\\";var dirs=windowAnchor.pathname.split(splitter);dirs.pop();while((backs>0)&&(dirs.length>0)){dirs.pop();backs--;}
-relStr=dirs.join("/")+"/"+relStr;urlObject.pathname=relStr;}
-if((urlObject.protocol=="file:")||(urlObject.protocol=="")){urlObject.host="localhost";}
-return urlObject;};OpenLayers.Util.removeTail=function(url){var head=null;var qMark=url.indexOf("?");var hashMark=url.indexOf("#");if(qMark==-1){head=(hashMark!=-1)?url.substr(0,hashMark):url;}else{head=(hashMark!=-1)?url.substr(0,Math.min(qMark,hashMark)):url.substr(0,qMark);}
-return head;};OpenLayers.Util.getBrowserName=function(){var browserName="";var ua=navigator.userAgent.toLowerCase();if(ua.indexOf("opera")!=-1){browserName="opera";}else if(ua.indexOf("msie")!=-1){browserName="msie";}else if(ua.indexOf("safari")!=-1){browserName="safari";}else if(ua.indexOf("mozilla")!=-1){if(ua.indexOf("firefox")!=-1){browserName="firefox";}else{browserName="mozilla";}}
-return browserName;};OpenLayers.Util.getRenderedDimensions=function(contentHTML,size){var w=h=null;var container=document.createElement("div");container.style.overflow="";container.style.position="absolute";container.style.left="-9999px";if(size){if(size.w){w=container.style.width=size.w;}else if(size.h){h=container.style.height=size.h;}}
-var content=document.createElement("div");content.innerHTML=contentHTML;container.appendChild(content);document.body.appendChild(container);if(!w){w=parseInt(content.scrollWidth);container.style.width=w+"px";}
-if(!h){h=parseInt(content.scrollHeight);}
-container.removeChild(content);document.body.removeChild(container);return new OpenLayers.Size(w,h);};OpenLayers.Util.getScrollbarWidth=function(){var scrollbarWidth=OpenLayers.Util._scrollbarWidth;if(scrollbarWidth==null){var scr=null;var inn=null;var wNoScroll=0;var wScroll=0;scr=document.createElement('div');scr.style.position='absolute';scr.style.top='-1000px';scr.style.left='-1000px';scr.style.width='100px';scr.style.height='50px';scr.style.overflow='hidden';inn=document.createElement('div');inn.style.width='100%';inn.style.height='200px';scr.appendChild(inn);document.body.appendChild(scr);wNoScroll=inn.offsetWidth;scr.style.overflow='scroll';wScroll=inn.offsetWidth;document.body.removeChild(document.body.lastChild);OpenLayers.Util._scrollbarWidth=(wNoScroll-wScroll);scrollbarWidth=OpenLayers.Util._scrollbarWidth;}
-return scrollbarWidth;};OpenLayers.Rico=new Object();OpenLayers.Rico.Corner={round:function(e,options){e=OpenLayers.Util.getElement(e);this._setOptions(options);var color=this.options.color;if(this.options.color=="fromElement"){color=this._background(e);}
-var bgColor=this.options.bgColor;if(this.options.bgColor=="fromParent"){bgColor=this._background(e.offsetParent);}
-this._roundCornersImpl(e,color,bgColor);},changeColor:function(theDiv,newColor){theDiv.style.backgroundColor=newColor;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.backgroundColor=newColor;}},changeOpacity:function(theDiv,newOpacity){var mozillaOpacity=newOpacity;var ieOpacity='alpha(opacity='+newOpacity*100+')';theDiv.style.opacity=mozillaOpacity;theDiv.style.filter=ieOpacity;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.opacity=mozillaOpacity;spanElements[currIdx].style.filter=ieOpacity;}},reRound:function(theDiv,options){var topRico=theDiv.parentNode.childNodes[0];var bottomRico=theDiv.parentNode.childNodes[2];theDiv.parentNode.removeChild(topRico);theDiv.parentNode.removeChild(bottomRico);this.round(theDiv.parentNode,options);},_roundCornersImpl:function(e,color,bgColor){if(this.options.border){this._renderBorder(e,bgColor);}
-if(this._isTopRounded()){this._roundTopCorners(e,color,bgColor);}
-if(this._isBottomRounded()){this._roundBottomCorners(e,color,bgColor);}},_renderBorder:function(el,bgColor){var borderValue="1px solid "+this._borderColor(bgColor);var borderL="border-left: "+borderValue;var borderR="border-right: "+borderValue;var style="style='"+borderL+";"+borderR+"'";el.innerHTML="<div "+style+">"+el.innerHTML+"</div>";},_roundTopCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=0;i<this.options.numSlices;i++){corner.appendChild(this._createCornerSlice(color,bgColor,i,"top"));}
-el.style.paddingTop=0;el.insertBefore(corner,el.firstChild);},_roundBottomCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=(this.options.numSlices-1);i>=0;i--){corner.appendChild(this._createCornerSlice(color,bgColor,i,"bottom"));}
-el.style.paddingBottom=0;el.appendChild(corner);},_createCorner:function(bgColor){var corner=document.createElement("div");corner.style.backgroundColor=(this._isTransparent()?"transparent":bgColor);return corner;},_createCornerSlice:function(color,bgColor,n,position){var slice=document.createElement("span");var inStyle=slice.style;inStyle.backgroundColor=color;inStyle.display="block";inStyle.height="1px";inStyle.overflow="hidden";inStyle.fontSize="1px";var borderColor=this._borderColor(color,bgColor);if(this.options.border&&n==0){inStyle.borderTopStyle="solid";inStyle.borderTopWidth="1px";inStyle.borderLeftWidth="0px";inStyle.borderRightWidth="0px";inStyle.borderBottomWidth="0px";inStyle.height="0px";inStyle.borderColor=borderColor;}
-else if(borderColor){inStyle.borderColor=borderColor;inStyle.borderStyle="solid";inStyle.borderWidth="0px 1px";}
-if(!this.options.compact&&(n==(this.options.numSlices-1))){inStyle.height="2px";}
-this._setMargin(slice,n,position);this._setBorder(slice,n,position);return slice;},_setOptions:function(options){this.options={corners:"all",color:"fromElement",bgColor:"fromParent",blend:true,border:false,compact:false};OpenLayers.Util.extend(this.options,options||{});this.options.numSlices=this.options.compact?2:4;if(this._isTransparent()){this.options.blend=false;}},_whichSideTop:function(){if(this._hasString(this.options.corners,"all","top")){return"";}
-if(this.options.corners.indexOf("tl")>=0&&this.options.corners.indexOf("tr")>=0){return"";}
-if(this.options.corners.indexOf("tl")>=0){return"left";}else if(this.options.corners.indexOf("tr")>=0){return"right";}
-return"";},_whichSideBottom:function(){if(this._hasString(this.options.corners,"all","bottom")){return"";}
-if(this.options.corners.indexOf("bl")>=0&&this.options.corners.indexOf("br")>=0){return"";}
-if(this.options.corners.indexOf("bl")>=0){return"left";}else if(this.options.corners.indexOf("br")>=0){return"right";}
-return"";},_borderColor:function(color,bgColor){if(color=="transparent"){return bgColor;}else if(this.options.border){return this.options.border;}else if(this.options.blend){return this._blend(bgColor,color);}else{return"";}},_setMargin:function(el,n,corners){var marginSize=this._marginSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.marginLeft=marginSize+"px";el.style.marginRight="0px";}
-else if(whichSide=="right"){el.style.marginRight=marginSize+"px";el.style.marginLeft="0px";}
-else{el.style.marginLeft=marginSize+"px";el.style.marginRight=marginSize+"px";}},_setBorder:function(el,n,corners){var borderSize=this._borderSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth="0px";}
-else if(whichSide=="right"){el.style.borderRightWidth=borderSize+"px";el.style.borderLeftWidth="0px";}
-else{el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}
-if(this.options.border!=false){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}},_marginSize:function(n){if(this._isTransparent()){return 0;}
-var marginSizes=[5,3,2,1];var blendedMarginSizes=[3,2,1,0];var compactMarginSizes=[2,1];var smBlendedMarginSizes=[1,0];if(this.options.compact&&this.options.blend){return smBlendedMarginSizes[n];}else if(this.options.compact){return compactMarginSizes[n];}else if(this.options.blend){return blendedMarginSizes[n];}else{return marginSizes[n];}},_borderSize:function(n){var transparentBorderSizes=[5,3,2,1];var blendedBorderSizes=[2,1,1,1];var compactBorderSizes=[1,0];var actualBorderSizes=[0,2,0,0];if(this.options.compact&&(this.options.blend||this._isTransparent())){return 1;}else if(this.options.compact){return compactBorderSizes[n];}else if(this.options.blend){return blendedBorderSizes[n];}else if(this.options.border){return actualBorderSizes[n];}else if(this._isTransparent()){return transparentBorderSizes[n];}
-return 0;},_hasString:function(str){for(var i=1;i<arguments.length;i++)if(str.indexOf(arguments[i])>=0){return true;}return false;},_blend:function(c1,c2){var cc1=OpenLayers.Rico.Color.createFromHex(c1);cc1.blend(OpenLayers.Rico.Color.createFromHex(c2));return cc1;},_background:function(el){try{return OpenLayers.Rico.Color.createColorFromBackground(el).asHex();}catch(err){return"#ffffff";}},_isTransparent:function(){return this.options.color=="transparent";},_isTopRounded:function(){return this._hasString(this.options.corners,"all","top","tl","tr");},_isBottomRounded:function(){return this._hasString(this.options.corners,"all","bottom","bl","br");},_hasSingleTextChild:function(el){return el.childNodes.length==1&&el.childNodes[0].nodeType==3;}};OpenLayers.ProxyHost="";OpenLayers.nullHandler=function(request){alert(OpenLayers.i18n("unhandledRequest",{'statusText':request.statusText}));};OpenLayers.loadURL=function(uri,params,caller,onComplete,onFailure){var success=(onComplete)?OpenLayers.Function.bind(onComplete,caller):OpenLayers.nullHandler;var failure=(onFailure)?OpenLayers.Function.bind(onFailure,caller):OpenLayers.nullHandler;var request=new OpenLayers.Ajax.Request(uri,{method:'get',parameters:params,onComplete:success,onFailure:failure});return request.transport;};OpenLayers.parseXMLString=function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
-var ajaxResponse=OpenLayers.Util.Try(function(){var xmldom=new ActiveXObject('Microsoft.XMLDOM');xmldom.loadXML(text);return xmldom;},function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
-req.send(null);return req.responseXML;});return ajaxResponse;};OpenLayers.Ajax={emptyFunction:function(){},getTransport:function(){return OpenLayers.Util.Try(function(){return new XMLHttpRequest();},function(){return new ActiveXObject('Msxml2.XMLHTTP');},function(){return new ActiveXObject('Microsoft.XMLHTTP');})||false;},activeRequestCount:0};OpenLayers.Ajax.Responders={responders:[],register:function(responderToAdd){for(var i=0;i<this.responders.length;i++){if(responderToAdd==this.responders[i]){return;}}
-this.responders.push(responderToAdd);},unregister:function(responderToRemove){OpenLayers.Util.removeItem(this.reponders,responderToRemove);},dispatch:function(callback,request,transport){var responder;for(var i=0;i<this.responders.length;i++){responder=this.responders[i];if(responder[callback]&&typeof responder[callback]=='function'){try{responder[callback].apply(responder,[request,transport]);}catch(e){}}}}};OpenLayers.Ajax.Responders.register({onCreate:function(){OpenLayers.Ajax.activeRequestCount++;},onComplete:function(){OpenLayers.Ajax.activeRequestCount--;}});OpenLayers.Ajax.Base=OpenLayers.Class({initialize:function(options){this.options={method:'post',asynchronous:true,contentType:'application/xml',parameters:''};OpenLayers.Util.extend(this.options,options||{});this.options.method=this.options.method.toLowerCase();if(typeof this.options.parameters=='string'){this.options.parameters=OpenLayers.Util.getParameters(this.options.parameters);}}});OpenLayers.Ajax.Request=OpenLayers.Class(OpenLayers.Ajax.Base,{_complete:false,initialize:function(url,options){OpenLayers.Ajax.Base.prototype.initialize.apply(this,[options]);if(OpenLayers.ProxyHost&&OpenLayers.String.startsWith(url,"http")){url=OpenLayers.ProxyHost+encodeURIComponent(url);}
-this.transport=OpenLayers.Ajax.getTransport();this.request(url);},request:function(url){this.url=url;this.method=this.options.method;var params=OpenLayers.Util.extend({},this.options.parameters);if(this.method!='get'&&this.method!='post'){params['_method']=this.method;this.method='post';}
-this.parameters=params;if(params=OpenLayers.Util.getParameterString(params)){if(this.method=='get'){this.url+=((this.url.indexOf('?')>-1)?'&':'?')+params;}else if(/Konqueror|Safari|KHTML/.test(navigator.userAgent)){params+='&_=';}}
-try{var response=new OpenLayers.Ajax.Response(this);if(this.options.onCreate){this.options.onCreate(response);}
-OpenLayers.Ajax.Responders.dispatch('onCreate',this,response);this.transport.open(this.method.toUpperCase(),this.url,this.options.asynchronous);if(this.options.asynchronous){window.setTimeout(OpenLayers.Function.bind(this.respondToReadyState,this,1),10);}
-this.transport.onreadystatechange=OpenLayers.Function.bind(this.onStateChange,this);this.setRequestHeaders();this.body=this.method=='post'?(this.options.postBody||params):null;this.transport.send(this.body);if(!this.options.asynchronous&&this.transport.overrideMimeType){this.onStateChange();}}catch(e){this.dispatchException(e);}},onStateChange:function(){var readyState=this.transport.readyState;if(readyState>1&&!((readyState==4)&&this._complete)){this.respondToReadyState(this.transport.readyState);}},setRequestHeaders:function(){var headers={'X-Requested-With':'XMLHttpRequest','Accept':'text/javascript, text/html, application/xml, text/xml, */*','OpenLayers':true};if(this.method=='post'){headers['Content-type']=this.options.contentType+
-(this.options.encoding?'; charset='+this.options.encoding:'');if(this.transport.overrideMimeType&&(navigator.userAgent.match(/Gecko\/(\d{4})/)||[0,2005])[1]<2005){headers['Connection']='close';}}
-if(typeof this.options.requestHeaders=='object'){var extras=this.options.requestHeaders;if(typeof extras.push=='function'){for(var i=0,length=extras.length;i<length;i+=2){headers[extras[i]]=extras[i+1];}}else{for(var i in extras){headers[i]=pair[i];}}}
-for(var name in headers){this.transport.setRequestHeader(name,headers[name]);}},success:function(){var status=this.getStatus();return!status||(status>=200&&status<300);},getStatus:function(){try{return this.transport.status||0;}catch(e){return 0;}},respondToReadyState:function(readyState){var state=OpenLayers.Ajax.Request.Events[readyState];var response=new OpenLayers.Ajax.Response(this);if(state=='Complete'){try{this._complete=true;(this.options['on'+response.status]||this.options['on'+(this.success()?'Success':'Failure')]||OpenLayers.Ajax.emptyFunction)(response);}catch(e){this.dispatchException(e);}
-var contentType=response.getHeader('Content-type');}
-try{(this.options['on'+state]||OpenLayers.Ajax.emptyFunction)(response);OpenLayers.Ajax.Responders.dispatch('on'+state,this,response);}catch(e){this.dispatchException(e);}
-if(state=='Complete'){this.transport.onreadystatechange=OpenLayers.Ajax.emptyFunction;}},getHeader:function(name){try{return this.transport.getResponseHeader(name);}catch(e){return null;}},dispatchException:function(exception){var handler=this.options.onException;if(handler){handler(this,exception);OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{var listener=false;var responders=OpenLayers.Ajax.Responders.responders;for(var i=0;i<responders.length;i++){if(responders[i].onException){listener=true;break;}}
-if(listener){OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{throw exception;}}}});OpenLayers.Ajax.Request.Events=['Uninitialized','Loading','Loaded','Interactive','Complete'];OpenLayers.Ajax.Response=OpenLayers.Class({status:0,statusText:'',initialize:function(request){this.request=request;var transport=this.transport=request.transport,readyState=this.readyState=transport.readyState;if((readyState>2&&!(!!(window.attachEvent&&!window.opera)))||readyState==4){this.status=this.getStatus();this.statusText=this.getStatusText();this.responseText=transport.responseText==null?'':String(transport.responseText);}
-if(readyState==4){var xml=transport.responseXML;this.responseXML=xml===undefined?null:xml;}},getStatus:OpenLayers.Ajax.Request.prototype.getStatus,getStatusText:function(){try{return this.transport.statusText||'';}catch(e){return'';}},getHeader:OpenLayers.Ajax.Request.prototype.getHeader,getResponseHeader:function(name){return this.transport.getResponseHeader(name);}});OpenLayers.Ajax.getElementsByTagNameNS=function(parentnode,nsuri,nsprefix,tagname){var elem=null;if(parentnode.getElementsByTagNameNS){elem=parentnode.getElementsByTagNameNS(nsuri,tagname);}else{elem=parentnode.getElementsByTagName(nsprefix+':'+tagname);}
-return elem;};OpenLayers.Ajax.serializeXMLToString=function(xmldom){var serializer=new XMLSerializer();var data=serializer.serializeToString(xmldom);return data;};OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=parseFloat(left);}
-if(bottom!=null){this.bottom=parseFloat(bottom);}
-if(right!=null){this.right=parseFloat(right);}
-if(top!=null){this.top=parseFloat(top);}},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top);},equals:function(bounds){var equals=false;if(bounds!=null){equals=((this.left==bounds.left)&&(this.right==bounds.right)&&(this.top==bounds.top)&&(this.bottom==bounds.bottom));}
-return equals;},toString:function(){return("left-bottom=("+this.left+","+this.bottom+")"
-+" right-top=("+this.right+","+this.top+")");},toArray:function(){return[this.left,this.bottom,this.right,this.top];},toBBOX:function(decimal){if(decimal==null){decimal=6;}
-var mult=Math.pow(10,decimal);var bbox=Math.round(this.left*mult)/mult+","+
-Math.round(this.bottom*mult)/mult+","+
-Math.round(this.right*mult)/mult+","+
-Math.round(this.top*mult)/mult;return bbox;},toGeometry:function(){return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(this.left,this.bottom),new OpenLayers.Geometry.Point(this.right,this.bottom),new OpenLayers.Geometry.Point(this.right,this.top),new OpenLayers.Geometry.Point(this.left,this.top)])]);},getWidth:function(){return(this.right-this.left);},getHeight:function(){return(this.top-this.bottom);},getSize:function(){return new OpenLayers.Size(this.getWidth(),this.getHeight());},getCenterPixel:function(){return new OpenLayers.Pixel((this.left+this.right)/2,(this.bottom+this.top)/2);},getCenterLonLat:function(){return new OpenLayers.LonLat((this.left+this.right)/2,(this.bottom+this.top)/2);},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("boundsAddError");OpenLayers.Console.error(msg);return null;}
-return new OpenLayers.Bounds(this.left+x,this.bottom+y,this.right+x,this.top+y);},extend:function(object){var bounds=null;if(object){switch(object.CLASS_NAME){case"OpenLayers.LonLat":bounds=new OpenLayers.Bounds(object.lon,object.lat,object.lon,object.lat);break;case"OpenLayers.Geometry.Point":bounds=new OpenLayers.Bounds(object.x,object.y,object.x,object.y);break;case"OpenLayers.Bounds":bounds=object;break;}
-if(bounds){if((this.left==null)||(bounds.left<this.left)){this.left=bounds.left;}
-if((this.bottom==null)||(bounds.bottom<this.bottom)){this.bottom=bounds.bottom;}
-if((this.right==null)||(bounds.right>this.right)){this.right=bounds.right;}
-if((this.top==null)||(bounds.top>this.top)){this.top=bounds.top;}}}},containsLonLat:function(ll,inclusive){return this.contains(ll.lon,ll.lat,inclusive);},containsPixel:function(px,inclusive){return this.contains(px.x,px.y,inclusive);},contains:function(x,y,inclusive){if(inclusive==null){inclusive=true;}
-var contains=false;if(inclusive){contains=((x>=this.left)&&(x<=this.right)&&(y>=this.bottom)&&(y<=this.top));}else{contains=((x>this.left)&&(x<this.right)&&(y>this.bottom)&&(y<this.top));}
-return contains;},intersectsBounds:function(bounds,inclusive){if(inclusive==null){inclusive=true;}
-var inBottom=(bounds.bottom==this.bottom&&bounds.top==this.top)?true:(((bounds.bottom>this.bottom)&&(bounds.bottom<this.top))||((this.bottom>bounds.bottom)&&(this.bottom<bounds.top)));var inTop=(bounds.bottom==this.bottom&&bounds.top==this.top)?true:(((bounds.top>this.bottom)&&(bounds.top<this.top))||((this.top>bounds.bottom)&&(this.top<bounds.top)));var inRight=(bounds.right==this.right&&bounds.left==this.left)?true:(((bounds.right>this.left)&&(bounds.right<this.right))||((this.right>bounds.left)&&(this.right<bounds.right)));var inLeft=(bounds.right==this.right&&bounds.left==this.left)?true:(((bounds.left>this.left)&&(bounds.left<this.right))||((this.left>bounds.left)&&(this.left<bounds.right)));return(this.containsBounds(bounds,true,inclusive)||bounds.containsBounds(this,true,inclusive)||((inTop||inBottom)&&(inLeft||inRight)));},containsBounds:function(bounds,partial,inclusive){if(partial==null){partial=false;}
-if(inclusive==null){inclusive=true;}
-var inLeft;var inTop;var inRight;var inBottom;if(inclusive){inLeft=(bounds.left>=this.left)&&(bounds.left<=this.right);inTop=(bounds.top>=this.bottom)&&(bounds.top<=this.top);inRight=(bounds.right>=this.left)&&(bounds.right<=this.right);inBottom=(bounds.bottom>=this.bottom)&&(bounds.bottom<=this.top);}else{inLeft=(bounds.left>this.left)&&(bounds.left<this.right);inTop=(bounds.top>this.bottom)&&(bounds.top<this.top);inRight=(bounds.right>this.left)&&(bounds.right<this.right);inBottom=(bounds.bottom>this.bottom)&&(bounds.bottom<this.top);}
-return(partial)?(inTop||inBottom)&&(inLeft||inRight):(inTop&&inLeft&&inBottom&&inRight);},determineQuadrant:function(lonlat){var quadrant="";var center=this.getCenterLonLat();quadrant+=(lonlat.lat<center.lat)?"b":"t";quadrant+=(lonlat.lon<center.lon)?"l":"r";return quadrant;},transform:function(source,dest){var ll=OpenLayers.Projection.transform({'x':this.left,'y':this.bottom},source,dest);var lr=OpenLayers.Projection.transform({'x':this.right,'y':this.bottom},source,dest);var ul=OpenLayers.Projection.transform({'x':this.left,'y':this.top},source,dest);var ur=OpenLayers.Projection.transform({'x':this.right,'y':this.top},source,dest);this.left=Math.min(ll.x,ul.x);this.bottom=Math.min(ll.y,lr.y);this.right=Math.max(lr.x,ur.x);this.top=Math.max(ul.y,ur.y);return this;},wrapDateLine:function(maxExtent,options){options=options||{};var leftTolerance=options.leftTolerance||0;var rightTolerance=options.rightTolerance||0;var newBounds=this.clone();if(maxExtent){while(newBounds.left<maxExtent.left&&(newBounds.right-rightTolerance)<=maxExtent.left){newBounds=newBounds.add(maxExtent.getWidth(),0);}
-while((newBounds.left+leftTolerance)>=maxExtent.right&&newBounds.right>maxExtent.right){newBounds=newBounds.add(-maxExtent.getWidth(),0);}}
-return newBounds;},CLASS_NAME:"OpenLayers.Bounds"});OpenLayers.Bounds.fromString=function(str){var bounds=str.split(",");return OpenLayers.Bounds.fromArray(bounds);};OpenLayers.Bounds.fromArray=function(bbox){return new OpenLayers.Bounds(parseFloat(bbox[0]),parseFloat(bbox[1]),parseFloat(bbox[2]),parseFloat(bbox[3]));};OpenLayers.Bounds.fromSize=function(size){return new OpenLayers.Bounds(0,size.h,size.w,0);};OpenLayers.Bounds.oppositeQuadrant=function(quadrant){var opp="";opp+=(quadrant.charAt(0)=='t')?'b':'t';opp+=(quadrant.charAt(1)=='l')?'r':'l';return opp;};OpenLayers.Element={visible:function(element){return OpenLayers.Util.getElement(element).style.display!='none';},toggle:function(){for(var i=0;i<arguments.length;i++){var element=OpenLayers.Util.getElement(arguments[i]);var display=OpenLayers.Element.visible(element)?'hide':'show';OpenLayers.Element[display](element);}},hide:function(){for(var i=0;i<arguments.length;i++){var element=OpenLayers.Util.getElement(arguments[i]);element.style.display='none';}},show:function(){for(var i=0;i<arguments.length;i++){var element=OpenLayers.Util.getElement(arguments[i]);element.style.display='';}},remove:function(element){element=OpenLayers.Util.getElement(element);element.parentNode.removeChild(element);},getHeight:function(element){element=OpenLayers.Util.getElement(element);return element.offsetHeight;},getDimensions:function(element){element=OpenLayers.Util.getElement(element);if(OpenLayers.Element.getStyle(element,'display')!='none'){return{width:element.offsetWidth,height:element.offsetHeight};}
-var els=element.style;var originalVisibility=els.visibility;var originalPosition=els.position;els.visibility='hidden';els.position='absolute';els.display='';var originalWidth=element.clientWidth;var originalHeight=element.clientHeight;els.display='none';els.position=originalPosition;els.visibility=originalVisibility;return{width:originalWidth,height:originalHeight};},getStyle:function(element,style){element=OpenLayers.Util.getElement(element);var value=element.style[OpenLayers.String.camelize(style)];if(!value){if(document.defaultView&&document.defaultView.getComputedStyle){var css=document.defaultView.getComputedStyle(element,null);value=css?css.getPropertyValue(style):null;}else if(element.currentStyle){value=element.currentStyle[OpenLayers.String.camelize(style)];}}
-var positions=['left','top','right','bottom'];if(window.opera&&(OpenLayers.Util.indexOf(positions,style)!=-1)&&(OpenLayers.Element.getStyle(element,'position')=='static')){value='auto';}
-return value=='auto'?null:value;}};OpenLayers.LonLat=OpenLayers.Class({lon:0.0,lat:0.0,initialize:function(lon,lat){this.lon=parseFloat(lon);this.lat=parseFloat(lat);},toString:function(){return("lon="+this.lon+",lat="+this.lat);},toShortString:function(){return(this.lon+", "+this.lat);},clone:function(){return new OpenLayers.LonLat(this.lon,this.lat);},add:function(lon,lat){if((lon==null)||(lat==null)){var msg=OpenLayers.i18n("lonlatAddError");OpenLayers.Console.error(msg);return null;}
-return new OpenLayers.LonLat(this.lon+lon,this.lat+lat);},equals:function(ll){var equals=false;if(ll!=null){equals=((this.lon==ll.lon&&this.lat==ll.lat)||(isNaN(this.lon)&&isNaN(this.lat)&&isNaN(ll.lon)&&isNaN(ll.lat)));}
-return equals;},transform:function(source,dest){var point=OpenLayers.Projection.transform({'x':this.lon,'y':this.lat},source,dest);this.lon=point.x;this.lat=point.y;return this;},wrapDateLine:function(maxExtent){var newLonLat=this.clone();if(maxExtent){while(newLonLat.lon<maxExtent.left){newLonLat.lon+=maxExtent.getWidth();}
-while(newLonLat.lon>maxExtent.right){newLonLat.lon-=maxExtent.getWidth();}}
-return newLonLat;},CLASS_NAME:"OpenLayers.LonLat"});OpenLayers.LonLat.fromString=function(str){var pair=str.split(",");return new OpenLayers.LonLat(parseFloat(pair[0]),parseFloat(pair[1]));};OpenLayers.Pixel=OpenLayers.Class({x:0.0,y:0.0,initialize:function(x,y){this.x=parseFloat(x);this.y=parseFloat(y);},toString:function(){return("x="+this.x+",y="+this.y);},clone:function(){return new OpenLayers.Pixel(this.x,this.y);},equals:function(px){var equals=false;if(px!=null){equals=((this.x==px.x&&this.y==px.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(px.x)&&isNaN(px.y)));}
-return equals;},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("pixelAddError");OpenLayers.Console.error(msg);return null;}
-return new OpenLayers.Pixel(this.x+x,this.y+y);},offset:function(px){var newPx=this.clone();if(px){newPx=this.add(px.x,px.y);}
-return newPx;},CLASS_NAME:"OpenLayers.Pixel"});OpenLayers.Size=OpenLayers.Class({w:0.0,h:0.0,initialize:function(w,h){this.w=parseFloat(w);this.h=parseFloat(h);},toString:function(){return("w="+this.w+",h="+this.h);},clone:function(){return new OpenLayers.Size(this.w,this.h);},equals:function(sz){var equals=false;if(sz!=null){equals=((this.w==sz.w&&this.h==sz.h)||(isNaN(this.w)&&isNaN(this.h)&&isNaN(sz.w)&&isNaN(sz.h)));}
-return equals;},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){if(window.console){var scripts=document.getElementsByTagName("script");for(var i=0;i<scripts.length;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
-this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
-this.events.destroy();this.events=null;}
-this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
-if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
-this.handlers=null;}
-if(this.map){this.map.removeControl(this);this.map=null;}},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=function(){return(false);};}
-if(this.title!=""){this.div.title=this.title;}}
-if(px!=null){this.position=px.clone();}
-this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
-if(this.handler){this.handler.activate();}
-this.active=true;this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
-this.active=false;this.events.triggerEvent("deactivate");return true;}
-return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Icon=OpenLayers.Class({url:null,size:null,offset:null,calculateOffset:null,imageDiv:null,px:null,initialize:function(url,size,offset,calculateOffset){this.url=url;this.size=(size)?size:new OpenLayers.Size(20,20);this.offset=offset?offset:new OpenLayers.Pixel(-(this.size.w/2),-(this.size.h/2));this.calculateOffset=calculateOffset;var id=OpenLayers.Util.createUniqueID("OL_Icon_");this.imageDiv=OpenLayers.Util.createAlphaImageDiv(id);},destroy:function(){OpenLayers.Event.stopObservingElement(this.imageDiv.firstChild);this.imageDiv.innerHTML="";this.imageDiv=null;},clone:function(){return new OpenLayers.Icon(this.url,this.size,this.offset,this.calculateOffset);},setSize:function(size){if(size!=null){this.size=size;}
-this.draw();},setUrl:function(url){if(url!=null){this.url=url;}
-this.draw();},draw:function(px){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,this.size,this.url,"absolute");this.moveTo(px);return this.imageDiv;},setOpacity:function(opacity){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,null,null,null,null,null,opacity);},moveTo:function(px){if(px!=null){this.px=px;}
-if(this.imageDiv!=null){if(this.px==null){this.display(false);}else{if(this.calculateOffset){this.offset=this.calculateOffset(this.size);}
-var offsetPx=this.px.offset(this.offset);OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,offsetPx);}}},display:function(display){this.imageDiv.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Icon"});OpenLayers.Lang={code:null,defaultCode:"en",getCode:function(){if(!OpenLayers.Lang.code){OpenLayers.Lang.setCode();}
-return OpenLayers.Lang.code;},setCode:function(code){var lang;if(!code){code=(OpenLayers.Util.getBrowserName()=="msie")?navigator.userLanguage:navigator.language;}
-var parts=code.split('-');parts[0]=parts[0].toLowerCase();if(typeof OpenLayers.Lang[parts[0]]=="object"){lang=parts[0];}
-if(parts[1]){var testLang=parts[0]+'-'+parts[1].toUpperCase();if(typeof OpenLayers.Lang[testLang]=="object"){lang=testLang;}}
-if(!lang){OpenLayers.Console.warn('Failed to find OpenLayers.Lang.'+parts.join("-")+' dictionary, falling back to default language');lang=OpenLayers.Lang.defaultCode;}
-OpenLayers.Lang.code=lang;},translate:function(key,context){var dictionary=OpenLayers.Lang[OpenLayers.Lang.getCode()];var message=dictionary[key];if(!message){message=key;}
-if(context){message=OpenLayers.String.format(message,context);}
-return message;}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.Popup=OpenLayers.Class({events:null,id:"",lonlat:null,div:null,size:null,contentHTML:"",backgroundColor:"",opacity:"",border:"",contentDiv:null,groupDiv:null,closeDiv:null,autoSize:false,minSize:null,maxSize:null,padding:0,fixPadding:function(){if(typeof this.padding=="number"){this.padding=new OpenLayers.Bounds(this.padding,this.padding,this.padding,this.padding);}},panMapIfOutOfView:false,map:null,initialize:function(id,lonlat,size,contentHTML,closeBox,closeBoxCallback){if(id==null){id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}
-this.id=id;this.lonlat=lonlat;this.size=(size!=null)?size:new OpenLayers.Size(OpenLayers.Popup.WIDTH,OpenLayers.Popup.HEIGHT);if(contentHTML!=null){this.contentHTML=contentHTML;}
-this.backgroundColor=OpenLayers.Popup.COLOR;this.opacity=OpenLayers.Popup.OPACITY;this.border=OpenLayers.Popup.BORDER;this.div=OpenLayers.Util.createDiv(this.id,null,null,null,null,null,"hidden");this.div.className='olPopup';var groupDivId=this.id+"_GroupDiv";this.groupDiv=OpenLayers.Util.createDiv(groupDivId,null,null,null,"relative",null,"hidden");var id=this.div.id+"_contentDiv";this.contentDiv=OpenLayers.Util.createDiv(id,null,this.size.clone(),null,"relative");this.contentDiv.className='olPopupContent';this.groupDiv.appendChild(this.contentDiv);this.div.appendChild(this.groupDiv);if(closeBox){this.addCloseBox(closeBoxCallback);}
-this.registerEvents();},destroy:function(){this.id=null;this.lonlat=null;this.size=null;this.contentHTML=null;this.backgroundColor=null;this.opacity=null;this.border=null;this.events.destroy();this.events=null;if(this.closeDiv){OpenLayers.Event.stopObservingElement(this.closeDiv);this.groupDiv.removeChild(this.closeDiv);}
-this.closeDiv=null;this.div.removeChild(this.groupDiv);this.groupDiv=null;if(this.map!=null){this.map.removePopup(this);}
-this.map=null;this.div=null;this.autoSize=null;this.minSize=null;this.maxSize=null;this.padding=null;this.panMapIfOutOfView=null;},draw:function(px){if(px==null){if((this.lonlat!=null)&&(this.map!=null)){px=this.map.getLayerPxFromLonLat(this.lonlat);}}
-if(OpenLayers.Util.getBrowserName()=='firefox'){this.map.events.register("movestart",this,function(){var style=document.defaultView.getComputedStyle(this.contentDiv,null);var currentOverflow=style.getPropertyValue("overflow");if(currentOverflow!="hidden"){this.contentDiv._oldOverflow=currentOverflow;this.contentDiv.style.overflow="hidden";}});this.map.events.register("moveend",this,function(){var oldOverflow=this.contentDiv._oldOverflow;if(oldOverflow){this.contentDiv.style.overflow=oldOverflow;this.contentDiv._oldOverflow=null;}});}
-this.moveTo(px);if(!this.autoSize){this.setSize(this.size);}
-this.setBackgroundColor();this.setOpacity();this.setBorder();this.setContentHTML();if(this.panMapIfOutOfView){this.panIntoView();}
-return this.div;},updatePosition:function(){if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);if(px){this.moveTo(px);}}},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},visible:function(){return OpenLayers.Element.visible(this.div);},toggle:function(){if(this.visible()){this.hide();}else{this.show();}},show:function(){OpenLayers.Element.show(this.div);if(this.panMapIfOutOfView){this.panIntoView();}},hide:function(){OpenLayers.Element.hide(this.div);},setSize:function(size){this.size=size;var contentSize=this.size.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth+contentDivPadding.right;}
-this.size.w+=wPadding;this.size.h+=hPadding;if(OpenLayers.Util.getBrowserName()=="msie"){contentSize.w+=contentDivPadding.left+contentDivPadding.right;contentSize.h+=contentDivPadding.bottom+contentDivPadding.top;}
-if(this.div!=null){this.div.style.width=this.size.w+"px";this.div.style.height=this.size.h+"px";}
-if(this.contentDiv!=null){this.contentDiv.style.width=contentSize.w+"px";this.contentDiv.style.height=contentSize.h+"px";}},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
-if(this.div!=null){this.div.style.backgroundColor=this.backgroundColor;}},setOpacity:function(opacity){if(opacity!=undefined){this.opacity=opacity;}
-if(this.div!=null){this.div.style.opacity=this.opacity;this.div.style.filter='alpha(opacity='+this.opacity*100+')';}},setBorder:function(border){if(border!=undefined){this.border=border;}
-if(this.div!=null){this.div.style.border=this.border;}},setContentHTML:function(contentHTML){if(contentHTML!=null){this.contentHTML=contentHTML;}
-if(this.autoSize){var realSize=OpenLayers.Util.getRenderedDimensions(this.contentHTML);var safeSize=this.getSafeContentSize(realSize);var newSize=null;if(safeSize.equals(realSize)){newSize=realSize;}else{var fixedSize=new OpenLayers.Size();fixedSize.w=(safeSize.w<realSize.w)?safeSize.w:null;fixedSize.h=(safeSize.h<realSize.h)?safeSize.h:null;if(fixedSize.w&&fixedSize.h){newSize=safeSize;}else{var clippedSize=OpenLayers.Util.getRenderedDimensions(this.contentHTML,fixedSize);var currentOverflow=OpenLayers.Element.getStyle(this.contentDiv,"overflow");if((currentOverflow!="hidden")&&(clippedSize.equals(safeSize))){var scrollBar=OpenLayers.Util.getScrollbarWidth();if(fixedSize.w){clippedSize.h+=scrollBar;}else{clippedSize.w+=scrollBar;}}
-newSize=this.getSafeContentSize(clippedSize);}}
-this.setSize(newSize);}
-if(this.contentDiv!=null){this.contentDiv.innerHTML=this.contentHTML;}},getSafeContentSize:function(size){var safeContentSize=size.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth+contentDivPadding.right;}
-if(this.minSize){safeContentSize.w=Math.max(safeContentSize.w,(this.minSize.w-wPadding));safeContentSize.h=Math.max(safeContentSize.h,(this.minSize.h-hPadding));}
-if(this.maxSize){safeContentSize.w=Math.min(safeContentSize.w,(this.maxSize.w-wPadding));safeContentSize.h=Math.min(safeContentSize.h,(this.maxSize.h-hPadding));}
-if(this.map&&this.map.size){var maxY=this.map.size.h-
-this.map.paddingForPopups.top-
-this.map.paddingForPopups.bottom-
-hPadding;var maxX=this.map.size.w-
-this.map.paddingForPopups.left-
-this.map.paddingForPopups.right-
-wPadding;safeContentSize.w=Math.min(safeContentSize.w,maxX);safeContentSize.h=Math.min(safeContentSize.h,maxY);}
-return safeContentSize;},getContentDivPadding:function(){var contentDivPadding=this._contentDivPadding;if(!contentDivPadding){this.div.style.display="none";document.body.appendChild(this.div);contentDivPadding=new OpenLayers.Bounds(OpenLayers.Element.getStyle(this.contentDiv,"padding-left"),OpenLayers.Element.getStyle(this.contentDiv,"padding-bottom"),OpenLayers.Element.getStyle(this.contentDiv,"padding-right"),OpenLayers.Element.getStyle(this.contentDiv,"padding-top"));this._contentDivPadding=contentDivPadding;document.body.removeChild(this.div);this.div.style.display="";}
-return contentDivPadding;},addCloseBox:function(callback){this.closeDiv=OpenLayers.Util.createDiv(this.id+"_close",null,new OpenLayers.Size(17,17));this.closeDiv.className="olPopupCloseBox";var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+"px";this.closeDiv.style.top=contentDivPadding.top+"px";this.groupDiv.appendChild(this.closeDiv);var closePopup=callback||function(e){this.hide();OpenLayers.Event.stop(e);};OpenLayers.Event.observe(this.closeDiv,"click",OpenLayers.Function.bindAsEventListener(closePopup,this));},panIntoView:function(){var mapSize=this.map.getSize();var origTL=this.map.getViewPortPxFromLayerPx(new OpenLayers.Pixel(parseInt(this.div.style.left),parseInt(this.div.style.top)));var newTL=origTL.clone();if(origTL.x<this.map.paddingForPopups.left){newTL.x=this.map.paddingForPopups.left;}else
-if((origTL.x+this.size.w)>(mapSize.w-this.map.paddingForPopups.right)){newTL.x=mapSize.w-this.map.paddingForPopups.right-this.size.w;}
-if(origTL.y<this.map.paddingForPopups.top){newTL.y=this.map.paddingForPopups.top;}else
-if((origTL.y+this.size.h)>(mapSize.h-this.map.paddingForPopups.bottom)){newTL.y=mapSize.h-this.map.paddingForPopups.bottom-this.size.h;}
-var dx=origTL.x-newTL.x;var dy=origTL.y-newTL.y;this.map.pan(dx,dy);},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,true);this.events.on({"mousedown":this.onmousedown,"mousemove":this.onmousemove,"mouseup":this.onmouseup,"click":this.onclick,"mouseout":this.onmouseout,"dblclick":this.ondblclick,scope:this});},onmousedown:function(evt){this.mousedown=true;OpenLayers.Event.stop(evt,true);},onmousemove:function(evt){if(this.mousedown){OpenLayers.Event.stop(evt,true);}},onmouseup:function(evt){if(this.mousedown){this.mousedown=false;OpenLayers.Event.stop(evt,true);}},onclick:function(evt){OpenLayers.Event.stop(evt,true);},onmouseout:function(evt){this.mousedown=false;},ondblclick:function(evt){OpenLayers.Event.stop(evt,true);},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";OpenLayers.Renderer=OpenLayers.Class({container:null,extent:null,size:null,resolution:null,map:null,initialize:function(containerID){this.container=OpenLayers.Util.getElement(containerID);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return false;},setExtent:function(extent){this.extent=extent.clone();this.resolution=null;},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
-if(feature.geometry){this.drawGeometry(feature.geometry,style,feature.id);}},drawGeometry:function(geometry,style,featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(features instanceof Array)){features=[features];}
-for(var i=0;i<features.length;++i){this.eraseGeometry(features[i].geometry);}},eraseGeometry:function(geometry){},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
-if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
-this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
-if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
-window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){OpenLayers.Console.error('invalid value for Tween');}
-var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
-this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
-if(this.time>this.duration){if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);this.playing=false;}
-window.clearInterval(this.interval);this.interval=null;}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(red,green,blue){this.rgb={r:red,g:green,b:blue};},setRed:function(r){this.rgb.r=r;},setGreen:function(g){this.rgb.g=g;},setBlue:function(b){this.rgb.b=b;},setHue:function(h){var hsb=this.asHSB();hsb.h=h;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setSaturation:function(s){var hsb=this.asHSB();hsb.s=s;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setBrightness:function(b){var hsb=this.asHSB();hsb.b=b;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},darken:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.max(hsb.b-percent,0));},brighten:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.min(hsb.b+percent,1));},blend:function(other){this.rgb.r=Math.floor((this.rgb.r+other.rgb.r)/2);this.rgb.g=Math.floor((this.rgb.g+other.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+other.rgb.b)/2);},isBright:function(){var hsb=this.asHSB();return this.asHSB().b>0.5;},isDark:function(){return!this.isBright();},asRGB:function(){return"rgb("+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")";},asHex:function(){return"#"+this.rgb.r.toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart();},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b);},toString:function(){return this.asHex();}});OpenLayers.Rico.Color.createFromHex=function(hexCode){if(hexCode.length==4){var shortHexCode=hexCode;var hexCode='#';for(var i=1;i<4;i++){hexCode+=(shortHexCode.charAt(i)+
-shortHexCode.charAt(i));}}
-if(hexCode.indexOf('#')==0){hexCode=hexCode.substring(1);}
-var red=hexCode.substring(0,2);var green=hexCode.substring(2,4);var blue=hexCode.substring(4,6);return new OpenLayers.Rico.Color(parseInt(red,16),parseInt(green,16),parseInt(blue,16));};OpenLayers.Rico.Color.createColorFromBackground=function(elem){var actualColor=RicoUtil.getElementsComputedStyle(OpenLayers.Util.getElement(elem),"backgroundColor","background-color");if(actualColor=="transparent"&&elem.parentNode){return OpenLayers.Rico.Color.createColorFromBackground(elem.parentNode);}
-if(actualColor==null){return new OpenLayers.Rico.Color(255,255,255);}
-if(actualColor.indexOf("rgb(")==0){var colors=actualColor.substring(4,actualColor.length-1);var colorArray=colors.split(",");return new OpenLayers.Rico.Color(parseInt(colorArray[0]),parseInt(colorArray[1]),parseInt(colorArray[2]));}
-else if(actualColor.indexOf("#")==0){return OpenLayers.Rico.Color.createFromHex(actualColor);}
-else{return new OpenLayers.Rico.Color(255,255,255);}};OpenLayers.Rico.Color.HSBtoRGB=function(hue,saturation,brightness){var red=0;var green=0;var blue=0;if(saturation==0){red=parseInt(brightness*255.0+0.5);green=red;blue=red;}
-else{var h=(hue-Math.floor(hue))*6.0;var f=h-Math.floor(h);var p=brightness*(1.0-saturation);var q=brightness*(1.0-saturation*f);var t=brightness*(1.0-(saturation*(1.0-f)));switch(parseInt(h)){case 0:red=(brightness*255.0+0.5);green=(t*255.0+0.5);blue=(p*255.0+0.5);break;case 1:red=(q*255.0+0.5);green=(brightness*255.0+0.5);blue=(p*255.0+0.5);break;case 2:red=(p*255.0+0.5);green=(brightness*255.0+0.5);blue=(t*255.0+0.5);break;case 3:red=(p*255.0+0.5);green=(q*255.0+0.5);blue=(brightness*255.0+0.5);break;case 4:red=(t*255.0+0.5);green=(p*255.0+0.5);blue=(brightness*255.0+0.5);break;case 5:red=(brightness*255.0+0.5);green=(p*255.0+0.5);blue=(q*255.0+0.5);break;}}
-return{r:parseInt(red),g:parseInt(green),b:parseInt(blue)};};OpenLayers.Rico.Color.RGBtoHSB=function(r,g,b){var hue;var saturation;var brightness;var cmax=(r>g)?r:g;if(b>cmax){cmax=b;}
-var cmin=(r<g)?r:g;if(b<cmin){cmin=b;}
-brightness=cmax/255.0;if(cmax!=0){saturation=(cmax-cmin)/cmax;}else{saturation=0;}
-if(saturation==0){hue=0;}else{var redc=(cmax-r)/(cmax-cmin);var greenc=(cmax-g)/(cmax-cmin);var bluec=(cmax-b)/(cmax-cmin);if(r==cmax){hue=bluec-greenc;}else if(g==cmax){hue=2.0+redc-bluec;}else{hue=4.0+greenc-redc;}
-hue=hue/6.0;if(hue<0){hue=hue+1.0;}}
-return{h:hue,s:saturation,b:brightness};};OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0;i<this.map.controls.length;i++){var control=this.map.controls[i];if((control!=this)&&(control.CLASS_NAME=="OpenLayers.Control.ArgParser")){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
-break;}}
-if(i==this.map.controls.length){var args=OpenLayers.Util.getParameters();if(args.layers){this.layers=args.layers;this.map.events.register('addlayer',this,this.configureLayers);this.configureLayers();}
-if(args.lat&&args.lon){this.center=new OpenLayers.LonLat(parseFloat(args.lon),parseFloat(args.lat));if(args.zoom){this.zoom=parseInt(args.zoom);}
-this.map.events.register('changebaselayer',this,this.setCenter);this.setCenter();}}},setCenter:function(){if(this.map.baseLayer){this.map.events.unregister('changebaselayer',this,this.setCenter);if(this.displayProjection){this.center.transform(this.displayProjection,this.map.getProjectionObject());}
-this.map.setCenter(this.center,this.zoom);}},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister('addlayer',this,this.configureLayers);for(var i=0;i<this.layers.length;i++){var layer=this.map.layers[i];var c=this.layers.charAt(i);if(c=="B"){this.map.setBaseLayer(layer);}else if((c=="T")||(c=="F")){layer.setVisibility(c=="T");}}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.map.events.un({"removelayer":this.updateAttribution,"addlayer":this.updateAttribution,"changelayer":this.updateAttribution,"changebaselayer":this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({'changebaselayer':this.updateAttribution,'changelayer':this.updateAttribution,'addlayer':this.updateAttribution,'removelayer':this.updateAttribution,scope:this});this.updateAttribution();return this.div;},updateAttribution:function(){var attributions=[];if(this.map&&this.map.layers){for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];if(layer.attribution&&layer.getVisibility()){attributions.push(layer.attribution);}}
-this.div.innerHTML=attributions.join(this.separator);}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Control.Button=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){},CLASS_NAME:"OpenLayers.Control.Button"});OpenLayers.Control.LayerSwitcher=OpenLayers.Class(OpenLayers.Control,{activeColor:"darkblue",layerStates:null,layersDiv:null,baseLayersDiv:null,baseLayers:null,dataLbl:null,dataLayersDiv:null,dataLayers:null,minimizeDiv:null,maximizeDiv:null,ascending:true,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.layerStates=[];},destroy:function(){OpenLayers.Event.stopObservingElement(this.div);OpenLayers.Event.stopObservingElement(this.minimizeDiv);OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.clearLayersArray("base");this.clearLayersArray("data");this.map.events.un({"addlayer":this.redraw,"changelayer":this.redraw,"removelayer":this.redraw,"changebaselayer":this.redraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.on({"addlayer":this.redraw,"changelayer":this.redraw,"removelayer":this.redraw,"changebaselayer":this.redraw,scope:this});},draw:function(){OpenLayers.Control.prototype.draw.apply(this);this.loadContents();if(!this.outsideViewport){this.minimizeControl();}
-this.redraw();return this.div;},clearLayersArray:function(layersType){var layers=this[layersType+"Layers"];if(layers){for(var i=0;i<layers.length;i++){var layer=layers[i];OpenLayers.Event.stopObservingElement(layer.inputElem);OpenLayers.Event.stopObservingElement(layer.labelSpan);}}
-this[layersType+"LayersDiv"].innerHTML="";this[layersType+"Layers"]=[];},checkRedraw:function(){var redraw=false;if(!this.layerStates.length||(this.map.layers.length!=this.layerStates.length)){redraw=true;}else{for(var i=0;i<this.layerStates.length;i++){var layerState=this.layerStates[i];var layer=this.map.layers[i];if((layerState.name!=layer.name)||(layerState.inRange!=layer.inRange)||(layerState.id!=layer.id)||(layerState.visibility!=layer.visibility)){redraw=true;break;}}}
-return redraw;},redraw:function(){if(!this.checkRedraw()){return this.div;}
-this.clearLayersArray("base");this.clearLayersArray("data");var containsOverlays=false;var containsBaseLayers=false;this.layerStates=new Array(this.map.layers.length);for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];this.layerStates[i]={'name':layer.name,'visibility':layer.visibility,'inRange':layer.inRange,'id':layer.id};}
-var layers=this.map.layers.slice();if(!this.ascending){layers.reverse();}
-for(var i=0;i<layers.length;i++){var layer=layers[i];var baseLayer=layer.isBaseLayer;if(layer.displayInLayerSwitcher){if(baseLayer){containsBaseLayers=true;}else{containsOverlays=true;}
-var checked=(baseLayer)?(layer==this.map.baseLayer):layer.getVisibility();var inputElem=document.createElement("input");inputElem.id="input_"+layer.name;inputElem.name=(baseLayer)?"baseLayers":layer.name;inputElem.type=(baseLayer)?"radio":"checkbox";inputElem.value=layer.name;inputElem.checked=checked;inputElem.defaultChecked=checked;if(!baseLayer&&!layer.inRange){inputElem.disabled=true;}
-var context={'inputElem':inputElem,'layer':layer,'layerSwitcher':this};OpenLayers.Event.observe(inputElem,"mouseup",OpenLayers.Function.bindAsEventListener(this.onInputClick,context));var labelSpan=document.createElement("span");if(!baseLayer&&!layer.inRange){labelSpan.style.color="gray";}
-labelSpan.innerHTML=layer.name;labelSpan.style.verticalAlign=(baseLayer)?"bottom":"baseline";OpenLayers.Event.observe(labelSpan,"click",OpenLayers.Function.bindAsEventListener(this.onInputClick,context));var br=document.createElement("br");var groupArray=(baseLayer)?this.baseLayers:this.dataLayers;groupArray.push({'layer':layer,'inputElem':inputElem,'labelSpan':labelSpan});var groupDiv=(baseLayer)?this.baseLayersDiv:this.dataLayersDiv;groupDiv.appendChild(inputElem);groupDiv.appendChild(labelSpan);groupDiv.appendChild(br);}}
-this.dataLbl.style.display=(containsOverlays)?"":"none";this.baseLbl.style.display=(containsBaseLayers)?"":"none";return this.div;},onInputClick:function(e){if(!this.inputElem.disabled){if(this.inputElem.type=="radio"){this.inputElem.checked=true;this.layer.map.setBaseLayer(this.layer);}else{this.inputElem.checked=!this.inputElem.checked;this.layerSwitcher.updateMap();}}
-OpenLayers.Event.stop(e);},onLayerClick:function(e){this.updateMap();},updateMap:function(){for(var i=0;i<this.baseLayers.length;i++){var layerEntry=this.baseLayers[i];if(layerEntry.inputElem.checked){this.map.setBaseLayer(layerEntry.layer,false);}}
-for(var i=0;i<this.dataLayers.length;i++){var layerEntry=this.dataLayers[i];layerEntry.layer.setVisibility(layerEntry.inputElem.checked);}},maximizeControl:function(e){this.div.style.width="20em";this.div.style.height="";this.showControls(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.div.style.width="0px";this.div.style.height="0px";this.showControls(true);if(e!=null){OpenLayers.Event.stop(e);}},showControls:function(minimize){this.maximizeDiv.style.display=minimize?"":"none";this.minimizeDiv.style.display=minimize?"none":"";this.layersDiv.style.display=minimize?"none":"";},loadContents:function(){this.div.style.position="absolute";this.div.style.top="25px";this.div.style.right="0px";this.div.style.left="";this.div.style.fontFamily="sans-serif";this.div.style.fontWeight="bold";this.div.style.marginTop="3px";this.div.style.marginLeft="3px";this.div.style.marginBottom="3px";this.div.style.fontSize="smaller";this.div.style.color="white";this.div.style.backgroundColor="transparent";OpenLayers.Event.observe(this.div,"mouseup",OpenLayers.Function.bindAsEventListener(this.mouseUp,this));OpenLayers.Event.observe(this.div,"click",this.ignoreEvent);OpenLayers.Event.observe(this.div,"mousedown",OpenLayers.Function.bindAsEventListener(this.mouseDown,this));OpenLayers.Event.observe(this.div,"dblclick",this.ignoreEvent);this.layersDiv=document.createElement("div");this.layersDiv.id="layersDiv";this.layersDiv.style.paddingTop="5px";this.layersDiv.style.paddingLeft="10px";this.layersDiv.style.paddingBottom="5px";this.layersDiv.style.paddingRight="75px";this.layersDiv.style.backgroundColor=this.activeColor;this.layersDiv.style.width="100%";this.layersDiv.style.height="100%";this.baseLbl=document.createElement("div");this.baseLbl.innerHTML=OpenLayers.i18n("baseLayer");this.baseLbl.style.marginTop="3px";this.baseLbl.style.marginLeft="3px";this.baseLbl.style.marginBottom="3px";this.baseLayersDiv=document.createElement("div");this.baseLayersDiv.style.paddingLeft="10px";this.dataLbl=document.createElement("div");this.dataLbl.innerHTML=OpenLayers.i18n("overlays");this.dataLbl.style.marginTop="3px";this.dataLbl.style.marginLeft="3px";this.dataLbl.style.marginBottom="3px";this.dataLayersDiv=document.createElement("div");this.dataLayersDiv.style.paddingLeft="10px";if(this.ascending){this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);}else{this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);}
-this.div.appendChild(this.layersDiv);OpenLayers.Rico.Corner.round(this.div,{corners:"tl bl",bgColor:"transparent",color:this.activeColor,blend:false});OpenLayers.Rico.Corner.changeOpacity(this.layersDiv,0.75);var imgLocation=OpenLayers.Util.getImagesLocation();var sz=new OpenLayers.Size(18,18);var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MaximizeDiv",null,sz,img,"absolute");this.maximizeDiv.style.top="5px";this.maximizeDiv.style.right="0px";this.maximizeDiv.style.left="";this.maximizeDiv.style.display="none";OpenLayers.Event.observe(this.maximizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';var sz=new OpenLayers.Size(18,18);this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MinimizeDiv",null,sz,img,"absolute");this.minimizeDiv.style.top="5px";this.minimizeDiv.style.right="0px";this.minimizeDiv.style.left="";this.minimizeDiv.style.display="none";OpenLayers.Event.observe(this.minimizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);},ignoreEvent:function(evt){OpenLayers.Event.stop(evt);},mouseDown:function(evt){this.isMouseDown=true;this.ignoreEvent(evt);},mouseUp:function(evt){if(this.isMouseDown){this.isMouseDown=false;this.ignoreEvent(evt);}},CLASS_NAME:"OpenLayers.Control.LayerSwitcher"});OpenLayers.Control.MouseDefaults=OpenLayers.Class(OpenLayers.Control,{performedDrag:false,wheelObserver:null,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
-this.handler=null;this.map.events.un({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});OpenLayers.Event.stopObserving(window,"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.stopObserving(window,"mousewheel",this.wheelObserver);OpenLayers.Event.stopObserving(document,"mousewheel",this.wheelObserver);this.wheelObserver=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.map.events.on({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});this.registerWheelEvents();},registerWheelEvents:function(){this.wheelObserver=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);OpenLayers.Event.observe(window,"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.observe(window,"mousewheel",this.wheelObserver);OpenLayers.Event.observe(document,"mousewheel",this.wheelObserver);},defaultClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-var notAfterDrag=!this.performedDrag;this.performedDrag=false;return notAfterDrag;},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.mouseDragStart=evt.xy.clone();this.performedDrag=false;if(evt.shiftKey){this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);}
-document.onselectstart=function(){return false;};OpenLayers.Event.stop(evt);},defaultMouseMove:function(evt){this.mousePosition=evt.xy.clone();if(this.mouseDragStart!=null){if(this.zoomBox){var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
-if(evt.xy.y<this.mouseDragStart.y){this.zoomBox.style.top=evt.xy.y+"px";}}else{var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();this.map.div.style.cursor="move";}
-this.performedDrag=true;}},defaultMouseUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-if(this.zoomBox){this.zoomBoxEnd(evt);}else{if(this.performedDrag){this.map.setCenter(this.map.center);}}
-document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.zoomBox){this.removeZoomBox();}
-this.mouseDragStart=null;}},defaultWheelUp:function(evt){if(this.map.getZoom()<=this.map.getNumZoomLevels()){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()+1);}},defaultWheelDown:function(evt){if(this.map.getZoom()>0){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()-1);}},zoomBoxEnd:function(evt){if(this.mouseDragStart!=null){if(Math.abs(this.mouseDragStart.x-evt.xy.x)>5||Math.abs(this.mouseDragStart.y-evt.xy.y)>5){var start=this.map.getLonLatFromViewPortPx(this.mouseDragStart);var end=this.map.getLonLatFromViewPortPx(evt.xy);var top=Math.max(start.lat,end.lat);var bottom=Math.min(start.lat,end.lat);var left=Math.min(start.lon,end.lon);var right=Math.max(start.lon,end.lon);var bounds=new OpenLayers.Bounds(left,bottom,right,top);this.map.zoomToExtent(bounds);}else{var end=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(new OpenLayers.LonLat((end.lon),(end.lat)),this.map.getZoom()+1);}
-this.removeZoomBox();}},removeZoomBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},onWheelEvent:function(e){var inMap=false;var elem=OpenLayers.Event.element(e);while(elem!=null){if(this.map&&elem==this.map.div){inMap=true;break;}
-elem=elem.parentNode;}
-if(inMap){var delta=0;if(!e){e=window.event;}
-if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
-if(delta){e.xy=this.mousePosition;if(delta<0){this.defaultWheelDown(e);}else{this.defaultWheelUp(e);}}
-OpenLayers.Event.stop(e);}},CLASS_NAME:"OpenLayers.Control.MouseDefaults"});OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{element:null,prefix:'',separator:', ',suffix:'',numdigits:5,granularity:10,lastXy:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.map){this.map.events.unregister('mousemove',this,this.redraw);}
-OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.div.left="";this.div.top="";this.element=this.div;}
-this.redraw();return this.div;},redraw:function(evt){var lonLat;if(evt==null){lonLat=new OpenLayers.LonLat(0,0);}else{if(this.lastXy==null||Math.abs(evt.xy.x-this.lastXy.x)>this.granularity||Math.abs(evt.xy.y-this.lastXy.y)>this.granularity)
-{this.lastXy=evt.xy;return;}
-lonLat=this.map.getLonLatFromPixel(evt.xy);if(!lonLat){return;}
-if(this.displayProjection){lonLat.transform(this.map.getProjectionObject(),this.displayProjection);}
-this.lastXy=evt.xy;}
-var newHtml=this.formatOutput(lonLat);if(newHtml!=this.element.innerHTML){this.element.innerHTML=newHtml;}},formatOutput:function(lonLat){var digits=parseInt(this.numdigits);var newHtml=this.prefix+
-lonLat.lon.toFixed(digits)+
-this.separator+
-lonLat.lat.toFixed(digits)+
-this.suffix;return newHtml;},setMap:function(){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.register('mousemove',this,this.redraw);},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Control.NavigationHistory=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOGGLE,previous:null,previousOptions:null,next:null,nextOptions:null,limit:50,activateOnDraw:true,clearOnDeactivate:false,registry:null,nextStack:null,previousStack:null,listeners:null,restoring:false,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.registry=OpenLayers.Util.extend({"moveend":function(){return{center:this.map.getCenter(),resolution:this.map.getResolution()};}},this.registry);this.clear();var previousOptions={trigger:OpenLayers.Function.bind(this.previousTrigger,this),displayClass:this.displayClass+"Previous"};OpenLayers.Util.extend(previousOptions,this.previousOptions);this.previous=new OpenLayers.Control.Button(previousOptions);var nextOptions={trigger:OpenLayers.Function.bind(this.nextTrigger,this),displayClass:this.displayClass+"Next"};OpenLayers.Util.extend(nextOptions,this.nextOptions);this.next=new OpenLayers.Control.Button(nextOptions);},onPreviousChange:function(state,length){if(state&&!this.previous.active){this.previous.activate();}else if(!state&&this.previous.active){this.previous.deactivate();}},onNextChange:function(state,length){if(state&&!this.next.active){this.next.activate();}else if(!state&&this.next.active){this.next.deactivate();}},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this);this.previous.destroy();this.next.destroy();this.deactivate();for(var prop in this){this[prop]=null;}},setMap:function(map){this.map=map;this.next.setMap(map);this.previous.setMap(map);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.next.draw();this.previous.draw();if(this.activateOnDraw){this.activate();}},previousTrigger:function(){var current=this.previousStack.shift();var state=this.previousStack.shift();if(state!=undefined){this.nextStack.unshift(current);this.previousStack.unshift(state);this.restoring=true;this.restore(state);this.restoring=false;this.onNextChange(this.nextStack[0],this.nextStack.length);this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}else{this.previousStack.unshift(current);}
-return state;},nextTrigger:function(){var state=this.nextStack.shift();if(state!=undefined){this.previousStack.unshift(state);this.restoring=true;this.restore(state);this.restoring=false;this.onNextChange(this.nextStack[0],this.nextStack.length);this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}
-return state;},clear:function(){this.previousStack=[];this.nextStack=[];},restore:function(state){var zoom=this.map.getZoomForResolution(state.resolution);this.map.setCenter(state.center,zoom);},setListeners:function(){this.listeners={};for(var type in this.registry){this.listeners[type]=OpenLayers.Function.bind(function(){if(!this.restoring){var state=this.registry[type].apply(this,arguments);this.previousStack.unshift(state);if(this.previousStack.length>1){this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}
-if(this.previousStack.length>(this.limit+1)){this.previousStack.pop();}
-if(this.nextStack.length>0){this.nextStack=[];this.onNextChange(null,0);}}
-return true;},this);}},activate:function(){var activated=false;if(this.map){if(OpenLayers.Control.prototype.activate.apply(this)){if(this.listeners==null){this.setListeners();}
-for(var type in this.listeners){this.map.events.register(type,this,this.listeners[type]);}
-activated=true;if(this.previousStack.length==0){this.initStack();}}}
-return activated;},initStack:function(){if(this.map.getCenter()){this.listeners.moveend();}},deactivate:function(){var deactivated=false;if(this.map){if(OpenLayers.Control.prototype.deactivate.apply(this)){for(var type in this.listeners){this.map.events.unregister(type,this,this.listeners[type]);}
-if(this.clearOnDeactivate){this.clear();}
-deactivated=true;}}
-return deactivated;},CLASS_NAME:"OpenLayers.Control.NavigationHistory"});OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,buttons:null,position:null,initialize:function(options){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);while(this.buttons.length){var btn=this.buttons.shift();btn.map=null;OpenLayers.Event.stopObservingElement(btn);}
-this.buttons=null;this.position=null;},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position;this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);this._addButton("panright","east-mini.png",px.add(sz.w,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);this._addButton("zoomworld","zoom-world-mini.png",centered.add(0,sz.h*4+5),sz);this._addButton("zoomout","zoom-minus-mini.png",centered.add(0,sz.h*5+5),sz);return this.div;},_addButton:function(id,img,xy,sz){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var btn=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_PanZoom_"+id,xy,sz,imgLocation,"absolute");this.div.appendChild(btn);OpenLayers.Event.observe(btn,"mousedown",OpenLayers.Function.bindAsEventListener(this.buttonDown,btn));OpenLayers.Event.observe(btn,"dblclick",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));OpenLayers.Event.observe(btn,"click",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));btn.action=id;btn.map=this.map;btn.slideFactor=this.slideFactor;this.buttons.push(btn);return btn;},doubleClick:function(evt){OpenLayers.Event.stop(evt);return false;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-switch(this.action){case"panup":this.map.pan(0,-this.slideFactor);break;case"pandown":this.map.pan(0,this.slideFactor);break;case"panleft":this.map.pan(-this.slideFactor,0);break;case"panright":this.map.pan(this.slideFactor,0);break;case"zoomin":this.map.zoomIn();break;case"zoomout":this.map.zoomOut();break;case"zoomworld":this.map.zoomToMaxExtent();break;}
-OpenLayers.Event.stop(evt);},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,defaultControl:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var i=this.controls.length-1;i>=0;i--){if(this.controls[i].events){this.controls[i].events.un({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
-OpenLayers.Event.stopObservingElement(this.controls[i].panel_div);this.controls[i].panel_div=null;}},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){for(var i=0;i<this.controls.length;i++){if(this.controls[i]==this.defaultControl){this.controls[i].activate();}}
-this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){for(var i=0;i<this.controls.length;i++){this.controls[i].deactivate();}
-return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);for(var i=0;i<this.controls.length;i++){this.map.addControl(this.controls[i]);this.controls[i].deactivate();this.controls[i].events.on({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
-this.activate();return this.div;},redraw:function(){this.div.innerHTML="";if(this.active){for(var i=0;i<this.controls.length;i++){var element=this.controls[i].panel_div;if(this.controls[i].active){element.className=this.controls[i].displayClass+"ItemActive";}else{element.className=this.controls[i].displayClass+"ItemInactive";}
-this.div.appendChild(element);}}},activateControl:function(control){if(!this.active){return false;}
-if(control.type==OpenLayers.Control.TYPE_BUTTON){control.trigger();return;}
-if(control.type==OpenLayers.Control.TYPE_TOGGLE){if(control.active){control.deactivate();}else{control.activate();}
-return;}
-for(var i=0;i<this.controls.length;i++){if(this.controls[i]!=control){if(this.controls[i].type!=OpenLayers.Control.TYPE_TOGGLE){this.controls[i].deactivate();}}}
-control.activate();},addControls:function(controls){if(!(controls instanceof Array)){controls=[controls];}
-this.controls=this.controls.concat(controls);for(var i=0;i<controls.length;i++){var element=document.createElement("div");var textNode=document.createTextNode(" ");controls[i].panel_div=element;if(controls[i].title!=""){controls[i].panel_div.title=controls[i].title;}
-OpenLayers.Event.observe(controls[i].panel_div,"click",OpenLayers.Function.bind(this.onClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"mousedown",OpenLayers.Function.bindAsEventListener(OpenLayers.Event.stop));}
-if(this.map){for(var i=0;i<controls.length;i++){this.map.addControl(controls[i]);controls[i].deactivate();controls[i].events.on({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
-this.redraw();}},onClick:function(ctrl,evt){OpenLayers.Event.stop(evt?evt:window.event);this.activateControl(ctrl);},getControlsBy:function(property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this.controls,function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getControlsByName:function(match){return this.getControlsBy("name",match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},CLASS_NAME:"OpenLayers.Control.Panel"});OpenLayers.Control.Permalink=OpenLayers.Class(OpenLayers.Control,{element:null,base:'',displayProjection:null,initialize:function(element,base,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);this.base=base||document.location.href;},destroy:function(){if(this.element.parentNode==this.div){this.div.removeChild(this.element);}
-this.element=null;this.map.events.unregister('moveend',this,this.updateLink);OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0;i<this.map.controls.length;i++){var control=this.map.controls[i];if(control.CLASS_NAME=="OpenLayers.Control.ArgParser"){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
-break;}}
-if(i==this.map.controls.length){this.map.addControl(new OpenLayers.Control.ArgParser({'displayProjection':this.displayProjection}));}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("a");this.element.innerHTML=OpenLayers.i18n("permalink");this.element.href="";this.div.appendChild(this.element);}
-this.map.events.on({'moveend':this.updateLink,'changelayer':this.updateLink,'changebaselayer':this.updateLink,scope:this});return this.div;},updateLink:function(){var center=this.map.getCenter();if(!center){return;}
-var params=OpenLayers.Util.getParameters(this.base);params.zoom=this.map.getZoom();var lat=center.lat;var lon=center.lon;if(this.displayProjection){var mapPosition=OpenLayers.Projection.transform({x:lon,y:lat},this.map.getProjectionObject(),this.displayProjection);lon=mapPosition.x;lat=mapPosition.y;}
-params.lat=Math.round(lat*100000)/100000;params.lon=Math.round(lon*100000)/100000;params.layers='';for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];if(layer.isBaseLayer){params.layers+=(layer==this.map.baseLayer)?"B":"0";}else{params.layers+=(layer.getVisibility())?"T":"F";}}
-var href=this.base;if(href.indexOf('?')!=-1){href=href.substring(0,href.indexOf('?'));}
-href+='?'+OpenLayers.Util.getParameterString(params);this.element.href=href;},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Control.Scale=OpenLayers.Class(OpenLayers.Control,{element:null,initialize:function(element,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("div");this.div.appendChild(this.element);}
-this.map.events.register('moveend',this,this.updateScale);this.updateScale();return this.div;},updateScale:function(){var scale=this.map.getScale();if(!scale){return;}
-if(scale>=9500&&scale<=950000){scale=Math.round(scale/1000)+"K";}else if(scale>=950000){scale=Math.round(scale/1000000)+"M";}else{scale=Math.round(scale);}
-this.element.innerHTML=OpenLayers.i18n("scale",{'scaleDenom':scale});},CLASS_NAME:"OpenLayers.Control.Scale"});OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop){this.div.style.display="block";this.div.style.position="absolute";this.eTop=document.createElement("div");this.eTop.className=this.displayClass+"Top";var theLen=this.topInUnits.length;this.div.appendChild(this.eTop);if((this.topOutUnits=="")||(this.topInUnits=="")){this.eTop.style.visibility="hidden";}else{this.eTop.style.visibility="visible";}
-this.eBottom=document.createElement("div");this.eBottom.className=this.displayClass+"Bottom";this.div.appendChild(this.eBottom);if((this.bottomOutUnits=="")||(this.bottomInUnits=="")){this.eBottom.style.visibility="hidden";}else{this.eBottom.style.visibility="visible";}}
-this.map.events.register('moveend',this,this.update);this.update();return this.div;},getBarLen:function(maxLen){var digits=parseInt(Math.log(maxLen)/Math.log(10));var pow10=Math.pow(10,digits);var firstChar=parseInt(maxLen/pow10);var barLen;if(firstChar>5){barLen=5;}else if(firstChar>2){barLen=2;}else{barLen=1;}
-return barLen*pow10;},update:function(){var res=this.map.getResolution();if(!res){return;}
-var curMapUnits=this.map.units;var inches=OpenLayers.INCHES_PER_UNIT;var maxSizeData=this.maxWidth*res*inches[curMapUnits];var topUnits;var bottomUnits;if(maxSizeData>100000){topUnits=this.topOutUnits;bottomUnits=this.bottomOutUnits;}else{topUnits=this.topInUnits;bottomUnits=this.bottomInUnits;}
-var topMax=maxSizeData/inches[topUnits];var bottomMax=maxSizeData/inches[bottomUnits];var topRounded=this.getBarLen(topMax);var bottomRounded=this.getBarLen(bottomMax);topMax=topRounded/inches[curMapUnits]*inches[topUnits];bottomMax=bottomRounded/inches[curMapUnits]*inches[bottomUnits];var topPx=topMax/res;var bottomPx=bottomMax/res;this.eTop.style.width=Math.round(topPx)+"px";this.eBottom.style.width=Math.round(bottomPx)+"px";this.eTop.innerHTML=topRounded+" "+topUnits;this.eBottom.innerHTML=bottomRounded+" "+bottomUnits;},CLASS_NAME:"OpenLayers.Control.ScaleLine"});OpenLayers.Control.ZoomToMaxExtent=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){if(this.map){this.map.zoomToMaxExtent();}},CLASS_NAME:"OpenLayers.Control.ZoomToMaxExtent"});OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
-if(event.stopPropagation){event.stopPropagation();}else{event.cancelBubble=true;}},findElement:function(event,tagName){var element=OpenLayers.Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase()))){element=element.parentNode;}
-return element;},observe:function(elementParam,name,observer,useCapture){var element=OpenLayers.Util.getElement(elementParam);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent)){name='keydown';}
-if(!this.observers){this.observers={};}
-if(!element._eventCacheID){var idPrefix="eventCacheID_";if(element.id){idPrefix=element.id+"_"+idPrefix;}
-element._eventCacheID=OpenLayers.Util.createUniqueID(idPrefix);}
-var cacheID=element._eventCacheID;if(!this.observers[cacheID]){this.observers[cacheID]=[];}
-this.observers[cacheID].push({'element':element,'name':name,'observer':observer,'useCapture':useCapture});if(element.addEventListener){element.addEventListener(name,observer,useCapture);}else if(element.attachEvent){element.attachEvent('on'+name,observer);}},stopObservingElement:function(elementParam){var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[cacheID]);},_removeElementObservers:function(elementObservers){if(elementObservers){for(var i=elementObservers.length-1;i>=0;i--){var entry=elementObservers[i];var args=new Array(entry.element,entry.name,entry.observer,entry.useCapture);var removed=OpenLayers.Event.stopObserving.apply(this,args);}}},stopObserving:function(elementParam,name,observer,useCapture){useCapture=useCapture||false;var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;if(name=='keypress'){if(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.detachEvent){name='keydown';}}
-var foundEntry=false;var elementObservers=OpenLayers.Event.observers[cacheID];if(elementObservers){var i=0;while(!foundEntry&&i<elementObservers.length){var cacheEntry=elementObservers[i];if((cacheEntry.name==name)&&(cacheEntry.observer==observer)&&(cacheEntry.useCapture==useCapture)){elementObservers.splice(i,1);if(elementObservers.length==0){delete OpenLayers.Event.observers[cacheID];}
-foundEntry=true;break;}
-i++;}}
-if(foundEntry){if(element.removeEventListener){element.removeEventListener(name,observer,useCapture);}else if(element&&element.detachEvent){element.detachEvent('on'+name,observer);}}
-return foundEntry;},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var cacheID in OpenLayers.Event.observers){var elementObservers=OpenLayers.Event.observers[cacheID];OpenLayers.Event._removeElementObservers.apply(this,[elementObservers]);}
-OpenLayers.Event.observers=false;}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,'unload',OpenLayers.Event.unloadCache,false);if(window.Event){OpenLayers.Util.applyDefaults(window.Event,OpenLayers.Event);}else{var Event=OpenLayers.Event;}
-OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","resize","focus","blur"],listeners:null,object:null,element:null,eventTypes:null,eventHandler:null,fallThrough:null,initialize:function(object,element,eventTypes,fallThrough){this.object=object;this.element=element;this.eventTypes=eventTypes;this.fallThrough=fallThrough;this.listeners={};this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,this);if(this.eventTypes!=null){for(var i=0;i<this.eventTypes.length;i++){this.addEventType(this.eventTypes[i]);}}
-if(this.element!=null){this.attachToElement(element);}},destroy:function(){if(this.element){OpenLayers.Event.stopObservingElement(this.element);}
-this.element=null;this.listeners=null;this.object=null;this.eventTypes=null;this.fallThrough=null;this.eventHandler=null;},addEventType:function(eventName){if(!this.listeners[eventName]){this.listeners[eventName]=[];}},attachToElement:function(element){for(var i=0;i<this.BROWSER_EVENTS.length;i++){var eventType=this.BROWSER_EVENTS[i];this.addEventType(eventType);OpenLayers.Event.observe(element,eventType,this.eventHandler);}
-OpenLayers.Event.observe(element,"dragstart",OpenLayers.Event.stop);},on:function(object){for(var type in object){if(type!="scope"){this.register(type,object.scope,object[type]);}}},register:function(type,obj,func){if(func!=null&&((this.eventTypes&&OpenLayers.Util.indexOf(this.eventTypes,type)!=-1)||OpenLayers.Util.indexOf(this.BROWSER_EVENTS,type)!=-1)){if(obj==null){obj=this.object;}
-var listeners=this.listeners[type];if(listeners!=null){listeners.push({obj:obj,func:func});}}},registerPriority:function(type,obj,func){if(func!=null){if(obj==null){obj=this.object;}
-var listeners=this.listeners[type];if(listeners!=null){listeners.unshift({obj:obj,func:func});}}},un:function(object){for(var type in object){if(type!="scope"){this.unregister(type,object.scope,object[type]);}}},unregister:function(type,obj,func){if(obj==null){obj=this.object;}
-var listeners=this.listeners[type];if(listeners!=null){for(var i=0;i<listeners.length;i++){if(listeners[i].obj==obj&&listeners[i].func==func){listeners.splice(i,1);break;}}}},remove:function(type){if(this.listeners[type]!=null){this.listeners[type]=[];}},triggerEvent:function(type,evt){if(evt==null){evt={};}
-evt.object=this.object;evt.element=this.element;if(!evt.type){evt.type=type;}
-var listeners=(this.listeners[type])?this.listeners[type].slice():null;if((listeners!=null)&&(listeners.length>0)){var continueChain;for(var i=0;i<listeners.length;i++){var callback=listeners[i];continueChain=callback.func.apply(callback.obj,[evt]);if((continueChain!=undefined)&&(continueChain==false)){break;}}
-if(!this.fallThrough){OpenLayers.Event.stop(evt,true);}}
-return continueChain;},handleBrowserEvent:function(evt){evt.xy=this.getMousePosition(evt);this.triggerEvent(evt.type,evt);},getMousePosition:function(evt){if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);this.element.offsets[0]+=(document.documentElement.scrollLeft||document.body.scrollLeft);this.element.offsets[1]+=(document.documentElement.scrollTop||document.body.scrollTop);}
-return new OpenLayers.Pixel((evt.clientX+(document.documentElement.scrollLeft||document.body.scrollLeft))-this.element.offsets[0]
--(document.documentElement.clientLeft||0),(evt.clientY+(document.documentElement.scrollTop||document.body.scrollTop))-this.element.offsets[1]
--(document.documentElement.clientTop||0));},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Format=OpenLayers.Class({externalProjection:null,internalProjection:null,initialize:function(options){OpenLayers.Util.extend(this,options);},read:function(data){alert(OpenLayers.i18n("readNotImplemented"));},write:function(object){alert(OpenLayers.i18n("writeNotImplemented"));},CLASS_NAME:"OpenLayers.Format"});OpenLayers.Lang.en={'unhandledRequest':"Unhandled request return ${statusText}",'permalink':"Permalink",'overlays':"Overlays",'baseLayer':"Base Layer",'sameProjection':"The overview map only works when it is in the same projection as the main map",'readNotImplemented':"Read not implemented.",'writeNotImplemented':"Write not implemented.",'noFID':"Can't update a feature for which there is no FID.",'errorLoadingGML':"Error in loading GML file ${url}",'browserNotSupported':"Your browser does not support vector rendering. Currently supported renderers are:\n${renderers}",'componentShouldBe':"addFeatures : component should be an ${geomType}",'getFeatureError':"getFeatureFromEvent called on layer with no renderer. This usually means you "+"destroyed a layer, but not some handler which is associated with it.",'minZoomLevelError':"The minZoomLevel property is only intended for use "+"with the FixedZoomLevels-descendent layers. That this "+"wfs layer checks for minZoomLevel is a relic of the"+"past. We cannot, however, remove it without possibly "+"breaking OL based applications that may depend on it."+" Therefore we are deprecating it -- the minZoomLevel "+"check below will be removed at 3.0. Please instead "+"use min/max resolution setting as described here: "+"http://trac.openlayers.org/wiki/SettingZoomLevels",'commitSuccess':"WFS Transaction: SUCCESS ${response}",'commitFailed':"WFS Transaction: FAILED ${response}",'googleWarning':"The Google Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the Google Maps library "+"script was either not included, or does not contain the "+"correct API key for your site.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/Google' "+"target='_blank'>click here</a>",'getLayerWarning':"The ${layerType} Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the ${layerLib} library "+"script was either not correctly included.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/${layerLib}' "+"target='_blank'>click here</a>",'scale':"Scale = 1 : ${scaleDenom}",'layerAlreadyAdded':"You tried to add the layer: ${layerName} to the map, but it has already been added",'reprojectDeprecated':"You are using the 'reproject' option "+"on the ${layerName} layer. This option is deprecated: "+"its use was designed to support displaying data over commercial "+"basemaps, but that functionality should now be achieved by using "+"Spherical Mercator support. More information is available from "+"http://trac.openlayers.org/wiki/SphericalMercator.",'methodDeprecated':"This method has been deprecated and will be removed in 3.0. "+"Please use ${newMethod} instead.",'boundsAddError':"You must pass both x and y values to the add function.",'lonlatAddError':"You must pass both lon and lat values to the add function.",'pixelAddError':"You must pass both x and y values to the add function.",'unsupportedGeometryType':"Unsupported geometry type: ${geomType}",'pagePositionFailed':"OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",'end':''};OpenLayers.Popup.Anchored=OpenLayers.Class(OpenLayers.Popup,{relativePosition:null,anchor:null,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){var newArguments=new Array(id,lonlat,size,contentHTML,closeBox,closeBoxCallback);OpenLayers.Popup.prototype.initialize.apply(this,newArguments);this.anchor=(anchor!=null)?anchor:{size:new OpenLayers.Size(0,0),offset:new OpenLayers.Pixel(0,0)};},destroy:function(){this.anchor=null;this.relativePosition=null;OpenLayers.Popup.prototype.destroy.apply(this,arguments);},show:function(){this.updatePosition();OpenLayers.Popup.prototype.show.apply(this,arguments);},moveTo:function(px){var oldRelativePosition=this.relativePosition;this.relativePosition=this.calculateRelativePosition(px);var newPx=this.calculateNewPx(px);var newArguments=new Array(newPx);OpenLayers.Popup.prototype.moveTo.apply(this,newArguments);if(this.relativePosition!=oldRelativePosition){this.updateRelativePosition();}},setSize:function(size){OpenLayers.Popup.prototype.setSize.apply(this,arguments);if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);this.moveTo(px);}},calculateRelativePosition:function(px){var lonlat=this.map.getLonLatFromLayerPx(px);var extent=this.map.getExtent();var quadrant=extent.determineQuadrant(lonlat);return OpenLayers.Bounds.oppositeQuadrant(quadrant);},updateRelativePosition:function(){},calculateNewPx:function(px){var newPx=px.offset(this.anchor.offset);var top=(this.relativePosition.charAt(0)=='t');newPx.y+=(top)?-this.size.h:this.anchor.size.h;var left=(this.relativePosition.charAt(1)=='l');newPx.x+=(left)?-this.size.w:this.anchor.size.w;return newPx;},CLASS_NAME:"OpenLayers.Popup.Anchored"});OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){if(projection&&projection.getCode){return this.getCode()==projection.getCode();}else{return false;}},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
-OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
-return point;};OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,xmlns:null,minimumSymbolizer:{strokeLinecap:"round",strokeOpacity:1,fillOpacity:1,pointRadius:0},initialize:function(containerID){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot();this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);},destroy:function(){this.clear();this.rendererRoot=null;this.root=null;this.xmlns=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments);},clear:function(){if(this.root){while(this.root.childNodes.length>0){this.root.removeChild(this.root.firstChild);}}},getNodeType:function(geometry,style){},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.drawGeometry(geometry.components[i],style,featureId);}
-return;};if(style.display!="none"){var nodeType=this.getNodeType(geometry,style);var node=this.nodeFactory(geometry.id,nodeType);node._featureId=featureId;node._geometryClass=geometry.CLASS_NAME;node._style=style;node=this.drawGeometryNode(node,geometry);if(node.parentNode!=this.root){this.root.appendChild(node);}
-this.postDraw(node);}else{node=OpenLayers.Util.getElement(geometry.id);if(node){node.parentNode.removeChild(node);}}},drawGeometryNode:function(node,geometry,style){style=style||node._style;OpenLayers.Util.applyDefaults(style,this.minimumSymbolizer);var options={'isFilled':true,'isStroked':!!style.strokeWidth};switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":this.drawPoint(node,geometry);break;case"OpenLayers.Geometry.LineString":options.isFilled=false;this.drawLineString(node,geometry);break;case"OpenLayers.Geometry.LinearRing":this.drawLinearRing(node,geometry);break;case"OpenLayers.Geometry.Polygon":this.drawPolygon(node,geometry);break;case"OpenLayers.Geometry.Surface":this.drawSurface(node,geometry);break;case"OpenLayers.Geometry.Rectangle":this.drawRectangle(node,geometry);break;default:break;}
-node._style=style;node._options=options;return this.setStyle(node,style,options,geometry);},postDraw:function(node){},drawPoint:function(node,geometry){},drawLineString:function(node,geometry){},drawLinearRing:function(node,geometry){},drawPolygon:function(node,geometry){},drawRectangle:function(node,geometry){},drawCircle:function(node,geometry){},drawSurface:function(node,geometry){},getFeatureIdFromEvent:function(evt){var node=evt.target||evt.srcElement;return node._featureId;},eraseGeometry:function(geometry){if((geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPoint")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiLineString")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.eraseGeometry(geometry.components[i]);}}else{var element=OpenLayers.Util.getElement(geometry.id);if(element&&element.parentNode){element.parentNode.removeChild(element);}}},nodeFactory:function(id,type){var node=OpenLayers.Util.getElement(id);if(node){if(!this.nodeTypeCompare(node,type)){node.parentNode.removeChild(node);node=this.nodeFactory(id,type);}}else{node=this.createNode(type,id);}
-return node;},CLASS_NAME:"OpenLayers.Renderer.Elements"});OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,isBackBuffer:false,lastRatio:1,isFirstDraw:true,backBufferTile:null,initialize:function(layer,position,bounds,url,size){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){this.layer.events.unregister("loadend",this,this.resetBackBuffer);this.events.unregister('loadend',this,this.resetBackBuffer);}else{this.events.unregister('loadend',this,this.showTile);}
-this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;if(this.backBufferTile){this.backBufferTile.destroy();this.backBufferTile=null;}},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);}
-OpenLayers.Util.applyDefaults(obj,this);return obj;},draw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));var drawTile=(withinMaxExtent||this.layer.displayOutsideMaxExtent);if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(drawTile){if(!this.backBufferTile){this.backBufferTile=this.clone();this.backBufferTile.hide();this.backBufferTile.isBackBuffer=true;this.events.register('loadend',this,this.resetBackBuffer);this.layer.events.register("loadend",this,this.resetBackBuffer);}
-this.startTransition();}else{if(this.backBufferTile){this.backBufferTile.clear();}}}else{if(drawTile&&this.isFirstDraw){this.events.register('loadend',this,this.showTile);this.isFirstDraw=false;}}
-this.shouldDraw=drawTile;this.clear();return drawTile;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
-this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
-var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},startTransition:function(){},resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=false;var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));if(withinMaxExtent){this.backBufferTile.position=this.position;this.backBufferTile.bounds=this.bounds;this.backBufferTile.size=this.size;this.backBufferTile.imageSize=this.layer.imageSize||this.size;this.backBufferTile.imageOffset=this.layer.imageOffset;this.backBufferTile.resolution=this.layer.getResolution();this.backBufferTile.renderTile();}}},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Control.MouseToolbar=OpenLayers.Class(OpenLayers.Control.MouseDefaults,{mode:null,buttons:null,direction:"vertical",buttonClicked:null,initialize:function(position,direction){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.position=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,OpenLayers.Control.MouseToolbar.Y);if(position){this.position=position;}
-if(direction){this.direction=direction;}
-this.measureDivs=[];},destroy:function(){for(var btnId in this.buttons){var btn=this.buttons[btnId];btn.map=null;btn.events.destroy();}
-OpenLayers.Control.MouseDefaults.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);OpenLayers.Control.MouseDefaults.prototype.draw.apply(this,arguments);this.buttons={};var sz=new OpenLayers.Size(28,28);var centered=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,0);this._addButton("zoombox","drag-rectangle-off.png","drag-rectangle-on.png",centered,sz,"Shift->Drag to zoom to area");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this._addButton("pan","panning-hand-off.png","panning-hand-on.png",centered,sz,"Drag the map to pan.");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this.switchModeTo("pan");return this.div;},_addButton:function(id,img,activeImg,xy,sz,title){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var activeImgLocation=OpenLayers.Util.getImagesLocation()+activeImg;var btn=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MouseToolbar_"+id,xy,sz,imgLocation,"absolute");this.div.appendChild(btn);btn.imgLocation=imgLocation;btn.activeImgLocation=activeImgLocation;btn.events=new OpenLayers.Events(this,btn,null,true);btn.events.on({"mousedown":this.buttonDown,"mouseup":this.buttonUp,"dblclick":OpenLayers.Event.stop,scope:this});btn.action=id;btn.title=title;btn.alt=title;btn.map=this.map;this.buttons[id]=btn;return btn;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.buttonClicked=evt.element.action;OpenLayers.Event.stop(evt);},buttonUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-if(this.buttonClicked!=null){if(this.buttonClicked==evt.element.action){this.switchModeTo(evt.element.action);}
-OpenLayers.Event.stop(evt);this.buttonClicked=null;}},defaultDblClick:function(evt){this.switchModeTo("pan");this.performedDrag=false;var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.mouseDragStart=evt.xy.clone();this.performedDrag=false;this.startViaKeyboard=false;if(evt.shiftKey&&this.mode!="zoombox"){this.switchModeTo("zoombox");this.startViaKeyboard=true;}else if(evt.altKey&&this.mode!="measure"){this.switchModeTo("measure");}else if(!this.mode){this.switchModeTo("pan");}
-switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.performedDrag=true;break;case"measure":var distance="";if(this.measureStart){var measureEnd=this.map.getLonLatFromViewPortPx(this.mouseDragStart);distance=OpenLayers.Util.distVincenty(this.measureStart,measureEnd);distance=Math.round(distance*100)/100;distance=distance+"km";this.measureStartBox=this.measureBox;}
-this.measureStart=this.map.getLonLatFromViewPortPx(this.mouseDragStart);;this.measureBox=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),-2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBox.style.width="4px";this.measureBox.style.height="4px";this.measureBox.style.fontSize="1px";this.measureBox.style.backgroundColor="red";this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);if(distance){this.measureBoxDistance=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBoxDistance.innerHTML=distance;this.measureBoxDistance.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBoxDistance);this.measureDivs.push(this.measureBoxDistance);}
-this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);this.measureDivs.push(this.measureBox);break;default:this.map.div.style.cursor="move";break;}
-document.onselectstart=function(){return false;};OpenLayers.Event.stop(evt);},switchModeTo:function(mode){if(mode!=this.mode){if(this.mode&&this.buttons[this.mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[this.mode],null,null,null,this.buttons[this.mode].imgLocation);}
-if(this.mode=="measure"&&mode!="measure"){for(var i=0;i<this.measureDivs.length;i++){if(this.measureDivs[i]){this.map.layerContainerDiv.removeChild(this.measureDivs[i]);}}
-this.measureDivs=[];this.measureStart=null;}
-this.mode=mode;if(this.buttons[mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[mode],null,null,null,this.buttons[mode].activeImgLocation);}
-switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";break;default:this.map.div.style.cursor="";break;}}},leaveMode:function(){this.switchModeTo("pan");},defaultMouseMove:function(evt){if(this.mouseDragStart!=null){switch(this.mode){case"zoombox":var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
-break;default:var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();}
-switch(this.mode){case"zoombox":this.zoomBoxEnd(evt);if(this.startViaKeyboard){this.leaveMode();}
-break;case"pan":if(this.performedDrag){this.map.setCenter(this.map.center);}}
-document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="default";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.zoomBox){this.removeZoomBox();if(this.startViaKeyboard){this.leaveMode();}}
-this.mouseDragStart=null;this.map.div.style.cursor="default";}},defaultClick:function(evt){if(this.performedDrag){this.performedDrag=false;return false;}},CLASS_NAME:"OpenLayers.Control.MouseToolbar"});OpenLayers.Control.MouseToolbar.X=6;OpenLayers.Control.MouseToolbar.Y=300;OpenLayers.Control.PanZoomBar=OpenLayers.Class(OpenLayers.Control.PanZoom,{zoomStopWidth:18,zoomStopHeight:11,slider:null,sliderEvents:null,zoomBarDiv:null,divEvents:null,zoomWorldIcon:false,initialize:function(){OpenLayers.Control.PanZoom.prototype.initialize.apply(this,arguments);},destroy:function(){this.div.removeChild(this.slider);this.slider=null;this.sliderEvents.destroy();this.sliderEvents=null;this.div.removeChild(this.zoombarDiv);this.zoomBarDiv=null;this.divEvents.destroy();this.divEvents=null;this.map.events.un({"zoomend":this.moveZoomBar,"changebaselayer":this.redraw,scope:this});OpenLayers.Control.PanZoom.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.PanZoom.prototype.setMap.apply(this,arguments);this.map.events.register("changebaselayer",this,this.redraw);},redraw:function(){if(this.div!=null){this.div.innerHTML="";}
-this.draw();},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position.clone();this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);var wposition=sz.w;if(this.zoomWorldIcon){centered=new OpenLayers.Pixel(px.x+sz.w,px.y);}
-this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);if(this.zoomWorldIcon){this._addButton("zoomworld","zoom-world-mini.png",px.add(sz.w,0),sz);wposition*=2;}
-this._addButton("panright","east-mini.png",px.add(wposition,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);centered=this._addZoomBar(centered.add(0,sz.h*4+5));this._addButton("zoomout","zoom-minus-mini.png",centered,sz);return this.div;},_addZoomBar:function(centered){var imgLocation=OpenLayers.Util.getImagesLocation();var id="OpenLayers_Control_PanZoomBar_Slider"+this.map.id;var zoomsToEnd=this.map.getNumZoomLevels()-1-this.map.getZoom();var slider=OpenLayers.Util.createAlphaImageDiv(id,centered.add(-1,zoomsToEnd*this.zoomStopHeight),new OpenLayers.Size(20,9),imgLocation+"slider.png","absolute");this.slider=slider;this.sliderEvents=new OpenLayers.Events(this,slider,null,true);this.sliderEvents.on({"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.zoomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});var sz=new OpenLayers.Size();sz.h=this.zoomStopHeight*this.map.getNumZoomLevels();sz.w=this.zoomStopWidth;var div=null;if(OpenLayers.Util.alphaHack()){var id="OpenLayers_Control_PanZoomBar"+this.map.id;div=OpenLayers.Util.createAlphaImageDiv(id,centered,new OpenLayers.Size(sz.w,this.zoomStopHeight),imgLocation+"zoombar.png","absolute",null,"crop");div.style.height=sz.h;}else{div=OpenLayers.Util.createDiv('OpenLayers_Control_PanZoomBar_Zoombar'+this.map.id,centered,sz,imgLocation+"zoombar.png");}
-this.zoombarDiv=div;this.divEvents=new OpenLayers.Events(this,div,null,true);this.divEvents.on({"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.div.appendChild(div);this.startTop=parseInt(div.style.top);this.div.appendChild(slider);this.map.events.register("zoomend",this,this.moveZoomBar);centered=centered.add(0,this.zoomStopHeight*this.map.getNumZoomLevels());return centered;},passEventToSlider:function(evt){this.sliderEvents.handleBrowserEvent(evt);},divClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-var y=evt.xy.y;var top=OpenLayers.Util.pagePosition(evt.object)[1];var levels=(y-top)/this.zoomStopHeight;if(!this.map.fractionalZoom){levels=Math.floor(levels);}
-var zoom=(this.map.getNumZoomLevels()-1)-levels;zoom=Math.min(Math.max(zoom,0),this.map.getNumZoomLevels()-1);this.map.zoomTo(zoom);OpenLayers.Event.stop(evt);},zoomBarDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.map.events.on({"mousemove":this.passEventToSlider,"mouseup":this.passEventToSlider,scope:this});this.mouseDragStart=evt.xy.clone();this.zoomStart=evt.xy.clone();this.div.style.cursor="move";this.zoombarDiv.offsets=null;OpenLayers.Event.stop(evt);},zoomBarDrag:function(evt){if(this.mouseDragStart!=null){var deltaY=this.mouseDragStart.y-evt.xy.y;var offsets=OpenLayers.Util.pagePosition(this.zoombarDiv);if((evt.clientY-offsets[1])>0&&(evt.clientY-offsets[1])<parseInt(this.zoombarDiv.style.height)-2){var newTop=parseInt(this.slider.style.top)-deltaY;this.slider.style.top=newTop+"px";}
-this.mouseDragStart=evt.xy.clone();OpenLayers.Event.stop(evt);}},zoomBarUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-if(this.zoomStart){this.div.style.cursor="";this.map.events.un({"mouseup":this.passEventToSlider,"mousemove":this.passEventToSlider,scope:this});var deltaY=this.zoomStart.y-evt.xy.y;var zoomLevel=this.map.zoom;if(this.map.fractionalZoom){zoomLevel+=deltaY/this.zoomStopHeight;zoomLevel=Math.min(Math.max(zoomLevel,0),this.map.getNumZoomLevels()-1);}else{zoomLevel+=Math.round(deltaY/this.zoomStopHeight);}
-this.map.zoomTo(zoomLevel);this.moveZoomBar();this.mouseDragStart=null;OpenLayers.Event.stop(evt);}},moveZoomBar:function(){var newTop=((this.map.getNumZoomLevels()-1)-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=newTop+"px";},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Format.JSON=OpenLayers.Class(OpenLayers.Format,{indent:"    ",space:" ",newline:"\n",level:0,pretty:false,initialize:function(options){OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(json,filter){try{if(/^[\],:{}\s]*$/.test(json.replace(/\\["\\\/bfnrtu]/g,'@').replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g,']').replace(/(?:^|:|,)(?:\s*\[)+/g,''))){var object=eval('('+json+')');if(typeof filter==='function'){function walk(k,v){if(v&&typeof v==='object'){for(var i in v){if(v.hasOwnProperty(i)){v[i]=walk(i,v[i]);}}}
-return filter(k,v);}
-object=walk('',object);}
-return object;}}catch(e){}
-return null;},write:function(value,pretty){this.pretty=!!pretty;var json=null;var type=typeof value;if(this.serialize[type]){json=this.serialize[type].apply(this,[value]);}
-return json;},writeIndent:function(){var pieces=[];if(this.pretty){for(var i=0;i<this.level;++i){pieces.push(this.indent);}}
-return pieces.join('');},writeNewline:function(){return(this.pretty)?this.newline:'';},writeSpace:function(){return(this.pretty)?this.space:'';},serialize:{'object':function(object){if(object==null){return"null";}
-if(object.constructor==Date){return this.serialize.date.apply(this,[object]);}
-if(object.constructor==Array){return this.serialize.array.apply(this,[object]);}
-var pieces=['{'];this.level+=1;var key,keyJSON,valueJSON;var addComma=false;for(key in object){if(object.hasOwnProperty(key)){keyJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[key,this.pretty]);valueJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[object[key],this.pretty]);if(keyJSON!=null&&valueJSON!=null){if(addComma){pieces.push(',');}
-pieces.push(this.writeNewline(),this.writeIndent(),keyJSON,':',this.writeSpace(),valueJSON);addComma=true;}}}
-this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),'}');return pieces.join('');},'array':function(array){var json;var pieces=['['];this.level+=1;for(var i=0;i<array.length;++i){json=OpenLayers.Format.JSON.prototype.write.apply(this,[array[i],this.pretty]);if(json!=null){if(i>0){pieces.push(',');}
-pieces.push(this.writeNewline(),this.writeIndent(),json);}}
-this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),']');return pieces.join('');},'string':function(string){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'};if(/["\\\x00-\x1f]/.test(string)){return'"'+string.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
-c=b.charCodeAt();return'\\u00'+
-Math.floor(c/16).toString(16)+
-(c%16).toString(16);})+'"';}
-return'"'+string+'"';},'number':function(number){return isFinite(number)?String(number):"null";},'boolean':function(bool){return String(bool);},'date':function(date){function format(number){return(number<10)?'0'+number:number;}
-return'"'+date.getFullYear()+'-'+
-format(date.getMonth()+1)+'-'+
-format(date.getDate())+'T'+
-format(date.getHours())+':'+
-format(date.getMinutes())+':'+
-format(date.getSeconds())+'"';}},CLASS_NAME:"OpenLayers.Format.JSON"});OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{xmldom:null,initialize:function(options){if(window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}
-OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
-var node=OpenLayers.Util.Try(OpenLayers.Function.bind((function(){var xmldom;if(window.ActiveXObject&&!this.xmldom){xmldom=new ActiveXObject("Microsoft.XMLDOM");}else{xmldom=this.xmldom;}
-xmldom.loadXML(text);return xmldom;}),this),function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
-req.send(null);return req.responseXML;});return node;},write:function(node){var data;if(this.xmldom){data=node.xml;}else{var serializer=new XMLSerializer();if(node.nodeType==1){var doc=document.implementation.createDocument("","",null);if(doc.importNode){node=doc.importNode(node,true);}
-doc.appendChild(node);data=serializer.serializeToString(doc);}else{data=serializer.serializeToString(node);}}
-return data;},createElementNS:function(uri,name){var element;if(this.xmldom){if(typeof uri=="string"){element=this.xmldom.createNode(1,name,uri);}else{element=this.xmldom.createNode(1,name,"");}}else{element=document.createElementNS(uri,name);}
-return element;},createTextNode:function(text){var node;if(this.xmldom){node=this.xmldom.createTextNode(text);}else{node=document.createTextNode(text);}
-return node;},getElementsByTagNameNS:function(node,uri,name){var elements=[];if(node.getElementsByTagNameNS){elements=node.getElementsByTagNameNS(uri,name);}else{var allNodes=node.getElementsByTagName("*");var potentialNode,fullName;for(var i=0;i<allNodes.length;++i){potentialNode=allNodes[i];fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if((name=="*")||(fullName==potentialNode.nodeName)){if((uri=="*")||(uri==potentialNode.namespaceURI)){elements.push(potentialNode);}}}}
-return elements;},getAttributeNodeNS:function(node,uri,name){var attributeNode=null;if(node.getAttributeNodeNS){attributeNode=node.getAttributeNodeNS(uri,name);}else{var attributes=node.attributes;var potentialNode,fullName;for(var i=0;i<attributes.length;++i){potentialNode=attributes[i];if(potentialNode.namespaceURI==uri){fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if(fullName==potentialNode.nodeName){attributeNode=potentialNode;break;}}}}
-return attributeNode;},getAttributeNS:function(node,uri,name){var attributeValue="";if(node.getAttributeNS){attributeValue=node.getAttributeNS(uri,name)||"";}else{var attributeNode=this.getAttributeNodeNS(node,uri,name);if(attributeNode){attributeValue=attributeNode.nodeValue;}}
-return attributeValue;},getChildValue:function(node,def){var value;try{value=node.firstChild.nodeValue;}catch(e){value=(def!=undefined)?def:"";}
-return value;},concatChildValues:function(node,def){var value="";var child=node.firstChild;var childValue;while(child){childValue=child.nodeValue;if(childValue){value+=childValue;}
-child=child.nextSibling;}
-if(value==""&&def!=undefined){value=def;}
-return value;},hasAttributeNS:function(node,uri,name){var found=false;if(node.hasAttributeNS){found=node.hasAttributeNS(uri,name);}else{found=!!this.getAttributeNodeNS(node,uri,name);}
-return found;},setAttributeNS:function(node,uri,name,value){if(node.setAttributeNS){node.setAttributeNS(uri,name,value);}else{if(this.xmldom){if(uri){var attribute=node.ownerDocument.createNode(2,name,uri);attribute.nodeValue=value;node.setAttributeNode(attribute);}else{node.setAttribute(name,value);}}else{throw"setAttributeNS not implemented";}}},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;if(control.map){this.setMap(control.map);}
-OpenLayers.Util.extend(this,options);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
-var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
-var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0;i<events.length;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
-this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
-var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0;i<events.length;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
-this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,paddingForPopups:null,initialize:function(div,options){this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';OpenLayers.Util.extend(this,options);this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);var id=this.div.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);id=this.div.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.viewPortDiv.appendChild(this.layerContainerDiv);this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES,this.fallThrough);this.updateSize();if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
-this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft")){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
-if(this.theme){var addNode=true;var nodes=document.getElementsByTagName('link');for(var i=0;i<nodes.length;++i){if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,this.theme)){addNode=false;break;}}
-if(addNode){var cssNode=document.createElement('link');cssNode.setAttribute('rel','stylesheet');cssNode.setAttribute('type','text/css');cssNode.setAttribute('href',this.theme);document.getElementsByTagName('head')[0].appendChild(cssNode);}}
-this.layers=[];if(this.controls==null){if(OpenLayers.Control!=null){this.controls=[new OpenLayers.Control.Navigation(),new OpenLayers.Control.PanZoom(),new OpenLayers.Control.ArgParser(),new OpenLayers.Control.Attribution()];}else{this.controls=[];}}
-for(var i=0;i<this.controls.length;i++){this.addControlToMap(this.controls[i]);}
-this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,'unload',this.unloadDestroy);},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy){return false;}
-OpenLayers.Event.stopObserving(window,'unload',this.unloadDestroy);this.unloadDestroy=null;if(this.updateSizeDestroy){OpenLayers.Event.stopObserving(window,'resize',this.updateSizeDestroy);}else{this.events.unregister("resize",this,this.updateSize);}
-this.paddingForPopups=null;if(this.controls!=null){for(var i=this.controls.length-1;i>=0;--i){this.controls[i].destroy();}
-this.controls=null;}
-if(this.layers!=null){for(var i=this.layers.length-1;i>=0;--i){this.layers[i].destroy(false);}
-this.layers=null;}
-if(this.viewPortDiv){this.div.removeChild(this.viewPortDiv);}
-this.viewPortDiv=null;if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null;}
-this.events.destroy();this.events=null;},setOptions:function(options){OpenLayers.Util.extend(this,options);},getTileSize:function(){return this.tileSize;},getBy:function(array,property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this[array],function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getLayersBy:function(property,match){return this.getBy("layers",property,match);},getLayersByName:function(match){return this.getLayersBy("name",match);},getLayersByClass:function(match){return this.getLayersBy("CLASS_NAME",match);},getControlsBy:function(property,match){return this.getBy("controls",property,match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},getLayer:function(id){var foundLayer=null;for(var i=0;i<this.layers.length;i++){var layer=this.layers[i];if(layer.id==id){foundLayer=layer;break;}}
-return foundLayer;},setLayerZIndex:function(layer,zIdx){layer.setZIndex(this.Z_INDEX_BASE[layer.isBaseLayer?'BaseLayer':'Overlay']
-+zIdx*5);},resetLayersZIndex:function(){for(var i=0;i<this.layers.length;i++){var layer=this.layers[i];this.setLayerZIndex(layer,i);}},addLayer:function(layer){for(var i=0;i<this.layers.length;i++){if(this.layers[i]==layer){var msg=OpenLayers.i18n('layerAlreadyAdded',{'layerName':layer.name});OpenLayers.Console.warn(msg);return false;}}
-this.events.triggerEvent("preaddlayer",{layer:layer});layer.div.className="olLayerDiv";layer.div.style.overflow="";this.setLayerZIndex(layer,this.layers.length);if(layer.isFixed){this.viewPortDiv.appendChild(layer.div);}else{this.layerContainerDiv.appendChild(layer.div);}
-this.layers.push(layer);layer.setMap(this);if(layer.isBaseLayer){if(this.baseLayer==null){this.setBaseLayer(layer);}else{layer.setVisibility(false);}}else{layer.redraw();}
-this.events.triggerEvent("addlayer",{layer:layer});},addLayers:function(layers){for(var i=0;i<layers.length;i++){this.addLayer(layers[i]);}},removeLayer:function(layer,setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
-if(layer.isFixed){this.viewPortDiv.removeChild(layer.div);}else{this.layerContainerDiv.removeChild(layer.div);}
-OpenLayers.Util.removeItem(this.layers,layer);layer.removeMap(this);layer.map=null;if(this.baseLayer==layer){this.baseLayer=null;if(setNewBaseLayer){for(var i=0;i<this.layers.length;i++){var iLayer=this.layers[i];if(iLayer.isBaseLayer){this.setBaseLayer(iLayer);break;}}}}
-this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:layer});},getNumLayers:function(){return this.layers.length;},getLayerIndex:function(layer){return OpenLayers.Util.indexOf(this.layers,layer);},setLayerIndex:function(layer,idx){var base=this.getLayerIndex(layer);if(idx<0){idx=0;}else if(idx>this.layers.length){idx=this.layers.length;}
-if(base!=idx){this.layers.splice(base,1);this.layers.splice(idx,0,layer);for(var i=0;i<this.layers.length;i++){this.setLayerZIndex(this.layers[i],i);}
-this.events.triggerEvent("changelayer",{layer:layer,property:"order"});}},raiseLayer:function(layer,delta){var idx=this.getLayerIndex(layer)+delta;this.setLayerIndex(layer,idx);},setBaseLayer:function(newBaseLayer){var oldExtent=null;if(this.baseLayer){oldExtent=this.baseLayer.getExtent();}
-if(newBaseLayer!=this.baseLayer){if(OpenLayers.Util.indexOf(this.layers,newBaseLayer)!=-1){if(this.baseLayer!=null){this.baseLayer.setVisibility(false);}
-this.baseLayer=newBaseLayer;this.viewRequestID++;this.baseLayer.visibility=true;var center=this.getCenter();if(center!=null){var newCenter=(oldExtent)?oldExtent.getCenterLonLat():center;var newZoom=(oldExtent)?this.getZoomForExtent(oldExtent,true):this.getZoomForResolution(this.resolution,true);this.setCenter(newCenter,newZoom,false,true);}
-this.events.triggerEvent("changebaselayer",{layer:this.baseLayer});}}},addControl:function(control,px){this.controls.push(control);this.addControlToMap(control,px);},addControlToMap:function(control,px){control.outsideViewport=(control.div!=null);if(this.displayProjection&&!control.displayProjection){control.displayProjection=this.displayProjection;}
-control.setMap(this);var div=control.draw(px);if(div){if(!control.outsideViewport){div.style.zIndex=this.Z_INDEX_BASE['Control']+
-this.controls.length;this.viewPortDiv.appendChild(div);}}},getControl:function(id){var returnControl=null;for(var i=0;i<this.controls.length;i++){var control=this.controls[i];if(control.id==id){returnControl=control;break;}}
-return returnControl;},removeControl:function(control){if((control)&&(control==this.getControl(control.id))){if(control.div&&(control.div.parentNode==this.viewPortDiv)){this.viewPortDiv.removeChild(control.div);}
-OpenLayers.Util.removeItem(this.controls,control);}},addPopup:function(popup,exclusive){if(exclusive){for(var i=this.popups.length-1;i>=0;--i){this.removePopup(this.popups[i]);}}
-popup.map=this;this.popups.push(popup);var popupDiv=popup.draw();if(popupDiv){popupDiv.style.zIndex=this.Z_INDEX_BASE['Popup']+
-this.popups.length;this.layerContainerDiv.appendChild(popupDiv);}},removePopup:function(popup){OpenLayers.Util.removeItem(this.popups,popup);if(popup.div){try{this.layerContainerDiv.removeChild(popup.div);}
-catch(e){}}
-popup.map=null;},getSize:function(){var size=null;if(this.size!=null){size=this.size.clone();}
-return size;},updateSize:function(){this.events.element.offsets=null;var newSize=this.getCurrentSize();var oldSize=this.getSize();if(oldSize==null){this.size=oldSize=newSize;}
-if(!newSize.equals(oldSize)){this.size=newSize;for(var i=0;i<this.layers.length;i++){this.layers[i].onMapResize();}
-if(this.baseLayer!=null){var center=new OpenLayers.Pixel(newSize.w/2,newSize.h/2);var centerLL=this.getLonLatFromViewPortPx(center);var zoom=this.getZoom();this.zoom=null;this.setCenter(this.getCenter(),zoom);}}},getCurrentSize:function(){var size=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){var dim=OpenLayers.Element.getDimensions(this.div);size.w=dim.width;size.h=dim.height;}
-if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=parseInt(this.div.style.width);size.h=parseInt(this.div.style.height);}
-return size;},calculateBounds:function(center,resolution){var extent=null;if(center==null){center=this.getCenter();}
-if(resolution==null){resolution=this.getResolution();}
-if((center!=null)&&(resolution!=null)){var size=this.getSize();var w_deg=size.w*resolution;var h_deg=size.h*resolution;extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);}
-return extent;},getCenter:function(){return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){if(!options){options={};}
-OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});var centerPx=this.getViewPortPxFromLonLat(this.getCenter());var newCenterPx=centerPx.add(dx,dy);if(!options.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.setCenter(newCenterLonLat,null,options.dragging);}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
-var center=this.getCenter();var from={lon:center.lon,lat:center.lat};var to={lon:lonlat.lon,lat:lonlat.lat};this.panTween.start(from,to,50,{callbacks:{start:OpenLayers.Function.bind(function(lonlat){this.events.triggerEvent("movestart");},this),eachStep:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'dragging':true,'noEvent':true});},this),done:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'noEvent':true});this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange,'caller':'setCenter'});},moveTo:function(lonlat,zoom,options){if(!options){options={};}
-var dragging=options.dragging;var forceZoomChange=options.forceZoomChange;var noEvent=options.noEvent;if(this.panTween&&options.caller=="setCenter"){this.panTween.stop();}
-if(!this.center&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();}
-if(this.restrictedExtent!=null){if(lonlat==null){lonlat=this.getCenter();}
-if(zoom==null){zoom=this.getZoom();}
-var resolution=this.getResolutionForZoom(zoom);var extent=this.calculateBounds(lonlat,resolution);if(!this.restrictedExtent.containsBounds(extent)){var maxCenter=this.restrictedExtent.getCenterLonLat();if(extent.getWidth()>this.restrictedExtent.getWidth()){lonlat=new OpenLayers.LonLat(maxCenter.lon,lonlat.lat);}else if(extent.left<this.restrictedExtent.left){lonlat=lonlat.add(this.restrictedExtent.left-
-extent.left,0);}else if(extent.right>this.restrictedExtent.right){lonlat=lonlat.add(this.restrictedExtent.right-
-extent.right,0);}
-if(extent.getHeight()>this.restrictedExtent.getHeight()){lonlat=new OpenLayers.LonLat(lonlat.lon,maxCenter.lat);}else if(extent.bottom<this.restrictedExtent.bottom){lonlat=lonlat.add(0,this.restrictedExtent.bottom-
-extent.bottom);}
-else if(extent.top>this.restrictedExtent.top){lonlat=lonlat.add(0,this.restrictedExtent.top-
-extent.top);}}}
-var zoomChanged=forceZoomChange||((this.isValidZoomLevel(zoom))&&(zoom!=this.getZoom()));var centerChanged=(this.isValidLonLat(lonlat))&&(!lonlat.equals(this.center));if(zoomChanged||centerChanged||!dragging){if(!this.dragging&&!noEvent){this.events.triggerEvent("movestart");}
-if(centerChanged){if((!zoomChanged)&&(this.center)){this.centerLayerContainer(lonlat);}
-this.center=lonlat.clone();}
-if((zoomChanged)||(this.layerContainerOrigin==null)){this.layerContainerOrigin=this.center.clone();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";}
-if(zoomChanged){this.zoom=zoom;this.resolution=this.getResolutionForZoom(zoom);this.viewRequestID++;}
-var bounds=this.getExtent();this.baseLayer.moveTo(bounds,zoomChanged,dragging);bounds=this.baseLayer.getExtent();for(var i=0;i<this.layers.length;i++){var layer=this.layers[i];if(!layer.isBaseLayer){var inRange=layer.calculateInRange();if(layer.inRange!=inRange){layer.inRange=inRange;if(!inRange){layer.display(false);}
-this.events.triggerEvent("changelayer",{layer:layer,property:"visibility"});}
-if(inRange&&layer.visibility){layer.moveTo(bounds,zoomChanged,dragging);}}}
-if(zoomChanged){for(var i=0;i<this.popups.length;i++){this.popups[i].updatePosition();}}
-this.events.triggerEvent("move");if(zoomChanged){this.events.triggerEvent("zoomend");}}
-if(!dragging&&!noEvent){this.events.triggerEvent("moveend");}
-this.dragging=!!dragging;},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){this.layerContainerDiv.style.left=Math.round(originPx.x-newPx.x)+"px";this.layerContainerDiv.style.top=Math.round(originPx.y-newPx.y)+"px";}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=0)&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();valid=maxExtent.containsLonLat(lonlat);}
-return valid;},getProjection:function(){var projection=this.getProjectionObject();return projection?projection.getCode():null;},getProjectionObject:function(){var projection=null;if(this.baseLayer!=null){projection=this.baseLayer.projection;}
-return projection;},getMaxResolution:function(){var maxResolution=null;if(this.baseLayer!=null){maxResolution=this.baseLayer.maxResolution;}
-return maxResolution;},getMaxExtent:function(){var maxExtent=null;if(this.baseLayer!=null){maxExtent=this.baseLayer.maxExtent;}
-return maxExtent;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
-return numZoomLevels;},getExtent:function(){var extent=null;if(this.baseLayer!=null){extent=this.baseLayer.getExtent();}
-return extent;},getResolution:function(){var resolution=null;if(this.baseLayer!=null){resolution=this.baseLayer.getResolution();}
-return resolution;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
-return scale;},getZoomForExtent:function(bounds,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForExtent(bounds,closest);}
-return zoom;},getResolutionForZoom:function(zoom){var resolution=null;if(this.baseLayer){resolution=this.baseLayer.getResolutionForZoom(zoom);}
-return resolution;},getZoomForResolution:function(resolution,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForResolution(resolution,closest);}
-return zoom;},zoomTo:function(zoom){if(this.isValidZoomLevel(zoom)){this.setCenter(null,zoom);}},zoomIn:function(){this.zoomTo(this.getZoom()+1);},zoomOut:function(){this.zoomTo(this.getZoom()-1);},zoomToExtent:function(bounds){var center=bounds.getCenterLonLat();if(this.baseLayer.wrapDateLine){var maxExtent=this.getMaxExtent();bounds=bounds.clone();while(bounds.right<bounds.left){bounds.right+=maxExtent.getWidth();}
-center=bounds.getCenterLonLat().wrapDateLine(maxExtent);}
-this.setCenter(center,this.getZoomForExtent(bounds));},zoomToMaxExtent:function(){this.zoomToExtent(this.getMaxExtent());},zoomToScale:function(scale){var res=OpenLayers.Util.getResolutionFromScale(scale,this.baseLayer.units);var size=this.getSize();var w_deg=size.w*res;var h_deg=size.h*res;var center=this.getCenter();var extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);this.zoomToExtent(extent);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(this.baseLayer!=null){lonlat=this.baseLayer.getLonLatFromViewPortPx(viewPortPx);}
-return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(this.baseLayer!=null){px=this.baseLayer.getViewPortPxFromLonLat(lonlat);}
-return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
-return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
-return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Marker=OpenLayers.Class({icon:null,lonlat:null,events:null,map:null,initialize:function(lonlat,icon){this.lonlat=lonlat;var newIcon=(icon)?icon:OpenLayers.Marker.defaultIcon();if(this.icon==null){this.icon=newIcon;}else{this.icon.url=newIcon.url;this.icon.size=newIcon.size;this.icon.offset=newIcon.offset;this.icon.calculateOffset=newIcon.calculateOffset;}
-this.events=new OpenLayers.Events(this,this.icon.imageDiv,null);},destroy:function(){this.map=null;this.events.destroy();this.events=null;if(this.icon!=null){this.icon.destroy();this.icon=null;}},draw:function(px){return this.icon.draw(px);},moveTo:function(px){if((px!=null)&&(this.icon!=null)){this.icon.moveTo(px);}
-this.lonlat=this.map.getLonLatFromLayerPx(px);},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
-return onScreen;},inflate:function(inflate){if(this.icon){var newSize=new OpenLayers.Size(this.icon.size.w*inflate,this.icon.size.h*inflate);this.icon.setSize(newSize);}},setOpacity:function(opacity){this.icon.setOpacity(opacity);},setUrl:function(url){this.icon.setUrl(url);},display:function(display){this.icon.display(display);},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var url=OpenLayers.Util.getImagesLocation()+"marker.png";var size=new OpenLayers.Size(21,25);var calculateOffset=function(size){return new OpenLayers.Pixel(-(size.w/2),-size.h);};return new OpenLayers.Icon(url,size,null,calculateOffset);};OpenLayers.Popup.AnchoredBubble=OpenLayers.Class(OpenLayers.Popup.Anchored,{rounded:false,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){this.padding=new OpenLayers.Bounds(0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE,0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE);OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);},draw:function(px){OpenLayers.Popup.Anchored.prototype.draw.apply(this,arguments);this.setContentHTML();this.setBackgroundColor();this.setOpacity();return this.div;},updateRelativePosition:function(){this.setRicoCorners();},setSize:function(size){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.setRicoCorners();},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
-if(this.div!=null){if(this.contentDiv!=null){this.div.style.background="transparent";OpenLayers.Rico.Corner.changeColor(this.groupDiv,this.backgroundColor);}}},setOpacity:function(opacity){OpenLayers.Popup.Anchored.prototype.setOpacity.call(this,opacity);if(this.div!=null){if(this.groupDiv!=null){OpenLayers.Rico.Corner.changeOpacity(this.groupDiv,this.opacity);}}},setBorder:function(border){this.border=0;},setRicoCorners:function(){var corners=this.getCornersToRound(this.relativePosition);var options={corners:corners,color:this.backgroundColor,bgColor:"transparent",blend:false};if(!this.rounded){OpenLayers.Rico.Corner.round(this.div,options);this.rounded=true;}else{OpenLayers.Rico.Corner.reRound(this.groupDiv,options);this.setBackgroundColor();this.setOpacity();}},getCornersToRound:function(){var corners=['tl','tr','bl','br'];var corner=OpenLayers.Bounds.oppositeQuadrant(this.relativePosition);OpenLayers.Util.removeItem(corners,corner);return corners.join(" ");},CLASS_NAME:"OpenLayers.Popup.AnchoredBubble"});OpenLayers.Popup.AnchoredBubble.CORNER_SIZE=5;OpenLayers.Popup.Framed=OpenLayers.Class(OpenLayers.Popup.Anchored,{imageSrc:null,imageSize:null,isAlphaImage:false,positionBlocks:null,blocks:null,fixedRelativePosition:false,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);if(this.fixedRelativePosition){this.updateRelativePosition();this.calculateRelativePosition=function(px){return this.relativePosition;};}
-this.contentDiv.style.position="absolute";this.contentDiv.style.zIndex=1;if(closeBox){this.closeDiv.style.zIndex=1;}
-this.groupDiv.style.position="absolute";this.groupDiv.style.top="0px";this.groupDiv.style.left="0px";this.groupDiv.style.height="100%";this.groupDiv.style.width="100%";},destroy:function(){this.imageSrc=null;this.imageSize=null;this.isAlphaImage=null;this.fixedRelativePosition=false;this.positionBlocks=null;for(var i=0;i<this.blocks.length;i++){var block=this.blocks[i];if(block.image){block.div.removeChild(block.image);}
-block.image=null;if(block.div){this.groupDiv.removeChild(block.div);}
-block.div=null;}
-this.blocks=null;OpenLayers.Popup.Anchored.prototype.destroy.apply(this,arguments);},setBackgroundColor:function(color){},setBorder:function(){},setOpacity:function(opacity){},setSize:function(size){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.updateBlocks();},updateRelativePosition:function(){this.padding=this.positionBlocks[this.relativePosition].padding;if(this.closeDiv){var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+
-this.padding.right+"px";this.closeDiv.style.top=contentDivPadding.top+
-this.padding.top+"px";}
-this.updateBlocks();},calculateNewPx:function(px){var newPx=OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(this,arguments);newPx=newPx.offset(this.positionBlocks[this.relativePosition].offset);return newPx;},createBlocks:function(){this.blocks=[];var firstPosition=null;for(var key in this.positionBlocks){firstPosition=key;break;}
-var position=this.positionBlocks[firstPosition];for(var i=0;i<position.blocks.length;i++){var block={};this.blocks.push(block);var divId=this.id+'_FrameDecorationDiv_'+i;block.div=OpenLayers.Util.createDiv(divId,null,null,null,"absolute",null,"hidden",null);var imgId=this.id+'_FrameDecorationImg_'+i;var imageCreator=(this.isAlphaImage)?OpenLayers.Util.createAlphaImageDiv:OpenLayers.Util.createImage;block.image=imageCreator(imgId,null,this.imageSize,this.imageSrc,"absolute",null,null,null);block.div.appendChild(block.image);this.groupDiv.appendChild(block.div);}},updateBlocks:function(){if(!this.blocks){this.createBlocks();}
-if(this.relativePosition){var position=this.positionBlocks[this.relativePosition];for(var i=0;i<position.blocks.length;i++){var positionBlock=position.blocks[i];var block=this.blocks[i];var l=positionBlock.anchor.left;var b=positionBlock.anchor.bottom;var r=positionBlock.anchor.right;var t=positionBlock.anchor.top;var w=(isNaN(positionBlock.size.w))?this.size.w-(r+l):positionBlock.size.w;var h=(isNaN(positionBlock.size.h))?this.size.h-(b+t):positionBlock.size.h;block.div.style.width=w+'px';block.div.style.height=h+'px';block.div.style.left=(l!=null)?l+'px':'';block.div.style.bottom=(b!=null)?b+'px':'';block.div.style.right=(r!=null)?r+'px':'';block.div.style.top=(t!=null)?t+'px':'';block.image.style.left=positionBlock.position.x+'px';block.image.style.top=positionBlock.position.y+'px';}
-this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px";}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",MAX_PIXEL:15000,localResolution:null,initialize:function(containerID){if(!this.supported()){return;}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y){return(x>=-this.MAX_PIXEL&&x<=this.MAX_PIXEL&&y>=-this.MAX_PIXEL&&y<=this.MAX_PIXEL);},setExtent:function(extent){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();if(!this.localResolution||resolution!=this.localResolution){this.left=-extent.left/resolution;this.top=extent.top/resolution;}
-var left=0;var top=0;if(this.localResolution&&resolution==this.localResolution){left=(this.left)-(-extent.left/resolution);top=(this.top)-(extent.top/resolution);}
-this.localResolution=resolution;var extentString=left+" "+top+" "+
-extent.getWidth()/resolution+" "+extent.getHeight()/resolution;this.rendererRoot.setAttributeNS(null,"viewBox",extentString);},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);this.rendererRoot.setAttributeNS(null,"height",this.size.h);},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":nodeType=style.externalGraphic?"image":"circle";break;case"OpenLayers.Geometry.Rectangle":nodeType="rect";break;case"OpenLayers.Geometry.LineString":nodeType="polyline";break;case"OpenLayers.Geometry.LinearRing":nodeType="polygon";break;case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="path";break;default:break;}
-return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var r=parseFloat(node.getAttributeNS(null,"r"));if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){if(style.externalGraphic){var x=parseFloat(node.getAttributeNS(null,"cx"));var y=parseFloat(node.getAttributeNS(null,"cy"));if(style.graphicWidth&&style.graphicHeight){node.setAttributeNS(null,"preserveAspectRatio","none");}
-var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;node.setAttributeNS(null,"x",(x+xOffset).toFixed());node.setAttributeNS(null,"y",(y+yOffset).toFixed());node.setAttributeNS(null,"width",width);node.setAttributeNS(null,"height",height);node.setAttributeNS("http://www.w3.org/1999/xlink","href",style.externalGraphic);node.setAttributeNS(null,"style","opacity: "+opacity);}else{node.setAttributeNS(null,"r",style.pointRadius);}}
-if(options.isFilled){node.setAttributeNS(null,"fill",style.fillColor);node.setAttributeNS(null,"fill-opacity",style.fillOpacity);}else{node.setAttributeNS(null,"fill","none");}
-if(options.isStroked){node.setAttributeNS(null,"stroke",style.strokeColor);node.setAttributeNS(null,"stroke-opacity",style.strokeOpacity);node.setAttributeNS(null,"stroke-width",style.strokeWidth);node.setAttributeNS(null,"stroke-linecap",style.strokeLinecap);}else{node.setAttributeNS(null,"stroke","none");}
-if(style.pointerEvents){node.setAttributeNS(null,"pointer-events",style.pointerEvents);}
-if(style.cursor!=null){node.setAttributeNS(null,"cursor",style.cursor);}
-return node;},createNode:function(type,id){var node=document.createElementNS(this.xmlns,type);if(id){node.setAttributeNS(null,"id",id);}
-return node;},nodeTypeCompare:function(node,type){return(type==node.nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_svgRoot","svg");},createRoot:function(){return this.nodeFactory(this.container.id+"_root","g");},drawPoint:function(node,geometry){this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"cx",x);node.setAttributeNS(null,"cy",y);node.setAttributeNS(null,"r",radius);}else{node.setAttributeNS(null,"cx","");node.setAttributeNS(null,"cy","");node.setAttributeNS(null,"r",0);}},drawLineString:function(node,geometry){node.setAttributeNS(null,"points",this.getComponentsString(geometry.components));},drawLinearRing:function(node,geometry){node.setAttributeNS(null,"points",this.getComponentsString(geometry.components));},drawPolygon:function(node,geometry){var d="";var draw=true;for(var j=0;j<geometry.components.length;j++){var linearRing=geometry.components[j];d+=" M";for(var i=0;i<linearRing.components.length;i++){var component=this.getShortString(linearRing.components[i]);if(component){d+=" "+component;}else{draw=false;}}}
-d+=" z";if(draw){node.setAttributeNS(null,"d",d);node.setAttributeNS(null,"fill-rule","evenodd");}else{node.setAttributeNS(null,"d","");}},drawRectangle:function(node,geometry){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"x",x);node.setAttributeNS(null,"y",y);node.setAttributeNS(null,"width",geometry.width/resolution);node.setAttributeNS(null,"height",geometry.height/resolution);}else{node.setAttributeNS(null,"x","");node.setAttributeNS(null,"y","");node.setAttributeNS(null,"width",0);node.setAttributeNS(null,"height",0);}},drawSurface:function(node,geometry){var d=null;var draw=true;for(var i=0;i<geometry.components.length;i++){if((i%3)==0&&(i/3)==0){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d="M "+component;}else if((i%3)==1){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d+=" C "+component;}else{var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d+=" "+component;}}
-d+=" Z";if(draw){node.setAttributeNS(null,"d",d);}else{node.setAttributeNS(null,"d","");}},getComponentsString:function(components){var strings=[];for(var i=0;i<components.length;i++){var component=this.getShortString(components[i]);if(component){strings.push(component);}}
-return strings.join(",");},getShortString:function(point){var resolution=this.getResolution();var x=(point.x/resolution+this.left);var y=(this.top-point.y/resolution);if(this.inValidRange(x,y)){return x+","+y;}else{return false;}},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.VML=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"urn:schemas-microsoft-com:vml",initialize:function(containerID){if(!this.supported()){return;}
-if(!document.namespaces.olv){document.namespaces.add("olv",this.xmlns);var style=document.createStyleSheet();style.addRule('olv\\:*',"behavior: url(#default#VML); "+"position: absolute; display: inline-block;");}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){return!!(document.namespaces);},setExtent:function(extent){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var org=extent.left/resolution+" "+
-extent.top/resolution;this.root.setAttribute("coordorigin",org);var size=extent.getWidth()/resolution+" "+
--extent.getHeight()/resolution;this.root.setAttribute("coordsize",size);},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.style.width=this.size.w;this.rendererRoot.style.height=this.size.h;this.root.style.width=this.size.w;this.root.style.height=this.size.h;},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":nodeType=style.externalGraphic?"olv:rect":"olv:oval";break;case"OpenLayers.Geometry.Rectangle":nodeType="olv:rect";break;case"OpenLayers.Geometry.LineString":case"OpenLayers.Geometry.LinearRing":case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="olv:shape";break;default:break;}
-return nodeType;},setStyle:function(node,style,options,geometry){style=style||node._style;options=options||node._options;if(node._geometryClass=="OpenLayers.Geometry.Point"){if(style.externalGraphic){var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var resolution=this.getResolution();var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);node.style.left=((geometry.x/resolution)+xOffset).toFixed();node.style.top=((geometry.y/resolution)-(yOffset+height)).toFixed();node.style.width=width;node.style.height=height;style.fillColor="none";options.isStroked=false;}else{this.drawCircle(node,geometry,style.pointRadius);}}
-if(options.isFilled){node.setAttribute("fillcolor",style.fillColor);}else{node.setAttribute("filled","false");}
-var fills=node.getElementsByTagName("fill");var fill=(fills.length==0)?null:fills[0];if(!options.isFilled){if(fill){node.removeChild(fill);}}else{if(!fill){fill=this.createNode('olv:fill',node.id+"_fill");}
-fill.setAttribute("opacity",style.fillOpacity);if(node._geometryClass=="OpenLayers.Geometry.Point"&&style.externalGraphic){if(style.graphicOpacity){fill.setAttribute("opacity",style.graphicOpacity);}
-fill.setAttribute("src",style.externalGraphic);fill.setAttribute("type","frame");node.style.flip="y";if(!(style.graphicWidth&&style.graphicHeight)){fill.aspect="atmost";}}
-if(fill.parentNode!=node){node.appendChild(fill);}}
-if(options.isStroked){node.setAttribute("strokecolor",style.strokeColor);node.setAttribute("strokeweight",style.strokeWidth+"px");}else{node.setAttribute("stroked","false");}
-var strokes=node.getElementsByTagName("stroke");var stroke=(strokes.length==0)?null:strokes[0];if(!options.isStroked){if(stroke){node.removeChild(stroke);}}else{if(!stroke){stroke=this.createNode('olv:stroke',node.id+"_stroke");node.appendChild(stroke);}
-stroke.setAttribute("opacity",style.strokeOpacity);stroke.setAttribute("endcap",!style.strokeLinecap||style.strokeLinecap=='butt'?'flat':style.strokeLinecap);}
-if(style.cursor!=null){node.style.cursor=style.cursor;}
-return node;},postDraw:function(node){var fillColor=node._style.fillColor;var strokeColor=node._style.strokeColor;if(fillColor=="none"&&node.getAttribute("fillcolor")!=fillColor){node.setAttribute("fillcolor",fillColor);}
-if(strokeColor=="none"&&node.getAttribute("strokecolor")!=strokeColor){node.setAttribute("strokecolor",strokeColor);}},setNodeDimension:function(node,geometry){var bbox=geometry.getBounds();if(bbox){var resolution=this.getResolution();var scaledBox=new OpenLayers.Bounds((bbox.left/resolution).toFixed(),(bbox.bottom/resolution).toFixed(),(bbox.right/resolution).toFixed(),(bbox.top/resolution).toFixed());node.style.left=scaledBox.left;node.style.top=scaledBox.top;node.style.width=scaledBox.getWidth();node.style.height=scaledBox.getHeight();node.coordorigin=scaledBox.left+" "+scaledBox.top;node.coordsize=scaledBox.getWidth()+" "+scaledBox.getHeight();}},createNode:function(type,id){var node=document.createElement(type);if(id){node.setAttribute('id',id);}
-node.setAttribute('unselectable','on',0);node.onselectstart=function(){return(false);};return node;},nodeTypeCompare:function(node,type){var subType=type;var splitIndex=subType.indexOf(":");if(splitIndex!=-1){subType=subType.substr(splitIndex+1);}
-var nodeName=node.nodeName;splitIndex=nodeName.indexOf(":");if(splitIndex!=-1){nodeName=nodeName.substr(splitIndex+1);}
-return(subType==nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_vmlRoot","div");},createRoot:function(){return this.nodeFactory(this.container.id+"_root","olv:group");},drawPoint:function(node,geometry){this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){if(!isNaN(geometry.x)&&!isNaN(geometry.y)){var resolution=this.getResolution();node.style.left=(geometry.x/resolution).toFixed()-radius;node.style.top=(geometry.y/resolution).toFixed()-radius;var diameter=radius*2;node.style.width=diameter;node.style.height=diameter;}},drawLineString:function(node,geometry){this.drawLine(node,geometry,false);},drawLinearRing:function(node,geometry){this.drawLine(node,geometry,true);},drawLine:function(node,geometry,closeLine){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var numComponents=geometry.components.length;var parts=new Array(numComponents);var comp,x,y;for(var i=0;i<numComponents;i++){comp=geometry.components[i];x=(comp.x/resolution);y=(comp.y/resolution);parts[i]=" "+x.toFixed()+","+y.toFixed()+" l ";}
-var end=(closeLine)?" x e":" e";node.path="m"+parts.join("")+end;},drawPolygon:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var linearRing,i,comp,x,y;for(var j=0;j<geometry.components.length;j++){linearRing=geometry.components[j];path.push("m");for(i=0;i<linearRing.components.length;i++){comp=linearRing.components[i];x=comp.x/resolution;y=comp.y/resolution;path.push(" "+x.toFixed()+","+y.toFixed());if(i==0){path.push(" l");}}
-path.push(" x ");}
-path.push("e");node.path=path.join("");},drawRectangle:function(node,geometry){var resolution=this.getResolution();node.style.left=geometry.x/resolution;node.style.top=geometry.y/resolution;node.style.width=geometry.width/resolution;node.style.height=geometry.height/resolution;},drawSurface:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var comp,x,y;for(var i=0;i<geometry.components.length;i++){comp=geometry.components[i];x=comp.x/resolution;y=comp.y/resolution;if((i%3)==0&&(i/3)==0){path.push("m");}else if((i%3)==1){path.push(" c");}
-path.push(" "+x+","+y);}
-path.push(" x e");node.path=path.join("");},CLASS_NAME:"OpenLayers.Renderer.VML"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.frame=document.createElement('div');this.frame.style.overflow='hidden';this.frame.style.position='absolute';this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();},destroy:function(){if(this.imgDiv!=null){if(this.layerAlphaHack){OpenLayers.Event.stopObservingElement(this.imgDiv.childNodes[0].id);}else{OpenLayers.Event.stopObservingElement(this.imgDiv.id);}
-if(this.imgDiv.parentNode==this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv.map=null;}}
-this.imgDiv=null;if((this.frame!=null)&&(this.frame.parentNode==this.layer.div)){this.layer.div.removeChild(this.frame);}
-this.frame=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile.Image(this.layer,this.position,this.bounds,this.url,this.size);}
-obj=OpenLayers.Tile.prototype.clone.apply(this,[obj]);obj.imgDiv=null;return obj;},draw:function(){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject){this.bounds=this.getBoundsFromBaseLayer(this.position);}
-if(!OpenLayers.Tile.prototype.draw.apply(this,arguments)){return false;}
-if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
-return this.renderTile();},renderTile:function(){if(this.imgDiv==null){this.initImgDiv();}
-this.imgDiv.viewRequestID=this.layer.map.viewRequestID;this.url=this.layer.getURL(this.bounds);OpenLayers.Util.modifyDOMElement(this.frame,null,this.position,this.size);var imageSize=this.layer.getImageSize();if(this.layerAlphaHack){OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,null,null,imageSize,this.url);}else{OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,imageSize);this.imgDiv.src=this.url;}
-return true;},clear:function(){if(this.imgDiv){this.hide();if(OpenLayers.Tile.Image.useBlankTile){this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif";}}},initImgDiv:function(){var offset=this.layer.imageOffset;var size=this.layer.getImageSize();if(this.layerAlphaHack){this.imgDiv=OpenLayers.Util.createAlphaImageDiv(null,offset,size,null,"relative",null,null,null,true);}else{this.imgDiv=OpenLayers.Util.createImage(null,offset,size,null,"relative",null,null,true);}
-this.imgDiv.className='olTileImage';this.frame.style.zIndex=this.isBackBuffer?0:1;this.frame.appendChild(this.imgDiv);this.layer.div.appendChild(this.frame);if(this.layer.opacity!=null){OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,null,null,null,null,this.layer.opacity);}
-this.imgDiv.map=this.layer.map;var onload=function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};if(this.layerAlphaHack){OpenLayers.Event.observe(this.imgDiv.childNodes[0],'load',OpenLayers.Function.bind(onload,this));}else{OpenLayers.Event.observe(this.imgDiv,'load',OpenLayers.Function.bind(onload,this));}
-var onerror=function(){if(this.imgDiv._attempts>OpenLayers.IMAGE_RELOAD_ATTEMPTS){onload.call(this);}};OpenLayers.Event.observe(this.imgDiv,"error",OpenLayers.Function.bind(onerror,this));},checkImgURL:function(){if(this.layer){var loaded=this.layerAlphaHack?this.imgDiv.firstChild.src:this.imgDiv.src;if(!OpenLayers.Util.isEquivalentUrl(loaded,this.url)){this.hide();}}},startTransition:function(){if(!this.backBufferTile||!this.backBufferTile.imgDiv){return;}
-var ratio=1;if(this.backBufferTile.resolution){ratio=this.backBufferTile.resolution/this.layer.getResolution();}
-if(ratio!=this.lastRatio){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
-OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}
-this.lastRatio=ratio;},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(navigator.userAgent.toLowerCase().indexOf("gecko")!=-1){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.Util.getBrowserName()=="safari"||OpenLayers.Util.getBrowserName()=="opera");OpenLayers.Tile.WFS=OpenLayers.Class(OpenLayers.Tile,{features:null,url:null,request:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.features=[];},destroy:function(){OpenLayers.Tile.prototype.destroy.apply(this,arguments);this.destroyAllFeatures();this.features=null;this.url=null;if(this.request){this.request.abort();this.request=null;}},clear:function(){this.destroyAllFeatures();},draw:function(){if(OpenLayers.Tile.prototype.draw.apply(this,arguments)){if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
-this.loadFeaturesForRegion(this.requestSuccess);}},loadFeaturesForRegion:function(success,failure){if(this.request){this.request.abort();}
-this.request=OpenLayers.loadURL(this.url,null,this,success);},requestSuccess:function(request){if(this.features){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=OpenLayers.Format.XML.prototype.read(request.responseText);}
-if(this.layer.vectorMode){this.layer.addFeatures(this.layer.formatObject.read(doc));}else{var resultFeatures=OpenLayers.Ajax.getElementsByTagNameNS(doc,"http://www.opengis.net/gml","gml","featureMember");this.addResults(resultFeatures);}}
-if(this.events){this.events.triggerEvent("loadend");}
-this.request=null;},addResults:function(results){for(var i=0;i<results.length;i++){var feature=new this.layer.featureClass(this.layer,results[i]);this.features.push(feature);}},destroyAllFeatures:function(){while(this.features.length>0){var feature=this.features.shift();feature.destroy();}},CLASS_NAME:"OpenLayers.Tile.WFS"});OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,handlers:null,initialize:function(options){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){if(!this.mapDiv){return;}
-this.handlers.click.destroy();this.mapDiv.removeChild(this.extentRectangle);this.extentRectangle=null;this.rectEvents.destroy();this.rectEvents=null;this.ovmap.destroy();this.ovmap=null;this.element.removeChild(this.mapDiv);this.mapDiv=null;this.div.removeChild(this.element);this.element=null;if(this.maximizeDiv){OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.div.removeChild(this.maximizeDiv);this.maximizeDiv=null;}
-if(this.minimizeDiv){OpenLayers.Event.stopObservingElement(this.minimizeDiv);this.div.removeChild(this.minimizeDiv);this.minimizeDiv=null;}
-this.map.events.un({"moveend":this.update,"changebaselayer":this.baseLayerDraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!(this.layers.length>0)){if(this.map.baseLayer){var layer=this.map.baseLayer.clone();this.layers=[layer];}else{this.map.events.register("changebaselayer",this,this.baseLayerDraw);return this.div;}}
-this.element=document.createElement('div');this.element.className=this.displayClass+'Element';this.element.style.display='none';this.mapDiv=document.createElement('div');this.mapDiv.style.width=this.size.w+'px';this.mapDiv.style.height=this.size.h+'px';this.mapDiv.style.position='relative';this.mapDiv.style.overflow='hidden';this.mapDiv.id=OpenLayers.Util.createUniqueID('overviewMap');this.extentRectangle=document.createElement('div');this.extentRectangle.style.position='absolute';this.extentRectangle.style.zIndex=1000;this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.mapDiv.appendChild(this.extentRectangle);this.element.appendChild(this.mapDiv);this.div.appendChild(this.element);if(!this.outsideViewport){this.div.className+=" "+this.displayClass+'Container';var imgLocation=OpenLayers.Util.getImagesLocation();var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv(this.displayClass+'MaximizeButton',null,new OpenLayers.Size(18,18),img,'absolute');this.maximizeDiv.style.display='none';this.maximizeDiv.className=this.displayClass+'MaximizeButton';OpenLayers.Event.observe(this.maximizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv('OpenLayers_Control_minimizeDiv',null,new OpenLayers.Size(18,18),img,'absolute');this.minimizeDiv.style.display='none';this.minimizeDiv.className=this.displayClass+'MinimizeButton';OpenLayers.Event.observe(this.minimizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);var eventsToStop=['dblclick','mousedown'];for(var i=0;i<eventsToStop.length;i++){OpenLayers.Event.observe(this.maximizeDiv,eventsToStop[i],OpenLayers.Event.stop);OpenLayers.Event.observe(this.minimizeDiv,eventsToStop[i],OpenLayers.Event.stop);}
-this.minimizeControl();}else{this.element.style.display='';}
-if(this.map.getExtent()){this.update();}
-this.map.events.register('moveend',this,this.update);return this.div;},baseLayerDraw:function(){this.draw();this.map.events.unregister("changebaselayer",this,this.baseLayerDraw);},rectDrag:function(px){var deltaX=this.handlers.drag.last.x-px.x;var deltaY=this.handlers.drag.last.y-px.y;if(deltaX!=0||deltaY!=0){var rectTop=this.rectPxBounds.top;var rectLeft=this.rectPxBounds.left;var rectHeight=Math.abs(this.rectPxBounds.getHeight());var rectWidth=this.rectPxBounds.getWidth();var newTop=Math.max(0,(rectTop-deltaY));newTop=Math.min(newTop,this.ovmap.size.h-this.hComp-rectHeight);var newLeft=Math.max(0,(rectLeft-deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-this.wComp-rectWidth);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+rectHeight,newLeft+rectWidth,newTop));}},mapDivClick:function(evt){var pxCenter=this.rectPxBounds.getCenterPixel();var deltaX=evt.xy.x-pxCenter.x;var deltaY=evt.xy.y-pxCenter.y;var top=this.rectPxBounds.top;var left=this.rectPxBounds.left;var height=Math.abs(this.rectPxBounds.getHeight());var width=this.rectPxBounds.getWidth();var newTop=Math.max(0,(top+deltaY));newTop=Math.min(newTop,this.ovmap.size.h-height);var newLeft=Math.max(0,(left+deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-width);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+height,newLeft+width,newTop));this.updateMapToRect();},maximizeControl:function(e){this.element.style.display='';this.showToggle(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.element.style.display='none';this.showToggle(true);if(e!=null){OpenLayers.Event.stop(e);}},showToggle:function(minimize){this.maximizeDiv.style.display=minimize?'':'none';this.minimizeDiv.style.display=minimize?'none':'';},update:function(){if(this.ovmap==null){this.createMap();}
-if(!this.isSuitableOverview()){this.updateOverview();}
-this.updateRectToMap();},isSuitableOverview:function(){var mapExtent=this.map.getExtent();var maxExtent=this.map.maxExtent;var testExtent=new OpenLayers.Bounds(Math.max(mapExtent.left,maxExtent.left),Math.max(mapExtent.bottom,maxExtent.bottom),Math.min(mapExtent.right,maxExtent.right),Math.min(mapExtent.top,maxExtent.top));var resRatio=this.ovmap.getResolution()/this.map.getResolution();return((resRatio>this.minRatio)&&(resRatio<=this.maxRatio)&&(this.ovmap.getExtent().containsBounds(testExtent)));},updateOverview:function(){var mapRes=this.map.getResolution();var targetRes=this.ovmap.getResolution();var resRatio=targetRes/mapRes;if(resRatio>this.maxRatio){targetRes=this.minRatio*mapRes;}else if(resRatio<=this.minRatio){targetRes=this.maxRatio*mapRes;}
-this.ovmap.setCenter(this.map.center,this.ovmap.getZoomForResolution(targetRes));this.updateRectToMap();},createMap:function(){var options=OpenLayers.Util.extend({controls:[],maxResolution:'auto',fallThrough:false},this.mapOptions);this.ovmap=new OpenLayers.Map(this.mapDiv,options);OpenLayers.Event.stopObserving(window,'unload',this.ovmap.unloadDestroy);this.ovmap.addLayers(this.layers);this.ovmap.zoomToMaxExtent();this.wComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-left-width'))+
-parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-right-width'));this.wComp=(this.wComp)?this.wComp:2;this.hComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-top-width'))+
-parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-bottom-width'));this.hComp=(this.hComp)?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{"click":this.mapDivClick},{"single":true,"double":false,"stopSingle":true,"stopDouble":true,"pixelTolerance":1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,true);this.rectEvents.register("mouseover",this,function(e){if(!this.handlers.drag.active&&!this.map.dragging){this.handlers.drag.activate();}});this.rectEvents.register("mouseout",this,function(e){if(!this.handlers.drag.dragging){this.handlers.drag.deactivate();}});},updateRectToMap:function(){if(this.map.units!='degrees'){if(this.ovmap.getProjection()&&(this.map.getProjection()!=this.ovmap.getProjection())){alert(OpenLayers.i18n("sameProjection"));}}
-var pxBounds=this.getRectBoundsFromMapBounds(this.map.getExtent());if(pxBounds){this.setRectPxBounds(pxBounds);}},updateMapToRect:function(){var lonLatBounds=this.getMapBoundsFromRectBounds(this.rectPxBounds);this.map.panTo(lonLatBounds.getCenterLonLat());},setRectPxBounds:function(pxBounds){var top=Math.max(pxBounds.top,0);var left=Math.max(pxBounds.left,0);var bottom=Math.min(pxBounds.top+Math.abs(pxBounds.getHeight()),this.ovmap.size.h-this.hComp);var right=Math.min(pxBounds.left+pxBounds.getWidth(),this.ovmap.size.w-this.wComp);var width=Math.max(right-left,0);var height=Math.max(bottom-top,0);if(width<this.minRectSize||height<this.minRectSize){this.extentRectangle.className=this.displayClass+
-this.minRectDisplayClass;var rLeft=left+(width/2)-(this.minRectSize/2);var rTop=top+(height/2)-(this.minRectSize/2);this.extentRectangle.style.top=Math.round(rTop)+'px';this.extentRectangle.style.left=Math.round(rLeft)+'px';this.extentRectangle.style.height=this.minRectSize+'px';this.extentRectangle.style.width=this.minRectSize+'px';}else{this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.extentRectangle.style.top=Math.round(top)+'px';this.extentRectangle.style.left=Math.round(left)+'px';this.extentRectangle.style.height=Math.round(height)+'px';this.extentRectangle.style.width=Math.round(width)+'px';}
-this.rectPxBounds=new OpenLayers.Bounds(Math.round(left),Math.round(bottom),Math.round(right),Math.round(top));},getRectBoundsFromMapBounds:function(lonLatBounds){var leftBottomLonLat=new OpenLayers.LonLat(lonLatBounds.left,lonLatBounds.bottom);var rightTopLonLat=new OpenLayers.LonLat(lonLatBounds.right,lonLatBounds.top);var leftBottomPx=this.getOverviewPxFromLonLat(leftBottomLonLat);var rightTopPx=this.getOverviewPxFromLonLat(rightTopLonLat);var bounds=null;if(leftBottomPx&&rightTopPx){bounds=new OpenLayers.Bounds(leftBottomPx.x,leftBottomPx.y,rightTopPx.x,rightTopPx.y);}
-return bounds;},getMapBoundsFromRectBounds:function(pxBounds){var leftBottomPx=new OpenLayers.Pixel(pxBounds.left,pxBounds.bottom);var rightTopPx=new OpenLayers.Pixel(pxBounds.right,pxBounds.top);var leftBottomLonLat=this.getLonLatFromOverviewPx(leftBottomPx);var rightTopLonLat=this.getLonLatFromOverviewPx(rightTopPx);return new OpenLayers.Bounds(leftBottomLonLat.lon,leftBottomLonLat.lat,rightTopLonLat.lon,rightTopLonLat.lat);},getLonLatFromOverviewPx:function(overviewMapPx){var size=this.ovmap.size;var res=this.ovmap.getResolution();var center=this.ovmap.getExtent().getCenterLonLat();var delta_x=overviewMapPx.x-(size.w/2);var delta_y=overviewMapPx.y-(size.h/2);return new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);},getOverviewPxFromLonLat:function(lonlat){var res=this.ovmap.getResolution();var extent=this.ovmap.getExtent();var px=null;if(extent){px=new OpenLayers.Pixel(Math.round(1/res*(lonlat.lon-extent.left)),Math.round(1/res*(extent.top-lonlat.lat)));}
-return px;},CLASS_NAME:'OpenLayers.Control.OverviewMap'});OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:OpenLayers.Popup.AnchoredBubble,popup:null,initialize:function(layer,lonlat,data){this.layer=layer;this.lonlat=lonlat;this.data=(data!=null)?data:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if((this.layer!=null)&&(this.layer.map!=null)){if(this.popup!=null){this.layer.map.removePopup(this.popup);}}
-this.layer=null;this.id=null;this.lonlat=null;this.data=null;if(this.marker!=null){this.destroyMarker(this.marker);this.marker=null;}
-if(this.popup!=null){this.destroyPopup(this.popup);this.popup=null;}},onScreen:function(){var onScreen=false;if((this.layer!=null)&&(this.layer.map!=null)){var screenBounds=this.layer.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
-return onScreen;},createMarker:function(){if(this.lonlat!=null){this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);}
-return this.marker;},destroyMarker:function(){this.marker.destroy();},createPopup:function(closeBox){if(this.lonlat!=null){var id=this.id+"_popup";var anchor=(this.marker)?this.marker.icon:null;if(!this.popup){this.popup=new this.popupClass(id,this.lonlat,this.data.popupSize,this.data.popupContentHTML,anchor,closeBox);}
-if(this.data.overflow!=null){this.popup.contentDiv.style.overflow=this.data.overflow;}
-this.popup.feature=this;}
-return this.popup;},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null;}},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.Format.WMC=OpenLayers.Class({defaultVersion:"1.1.0",version:null,layerOptions:null,parser:null,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.WMC["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a WMC parser for version "+
-version;}
-this.parser=new format(this.options);}
-var context=this.parser.read(data,options);var map;if(options.map){this.context=context;if(options.map instanceof OpenLayers.Map){map=this.mergeContextToMap(context,options.map);}else{map=this.contextToMap(context,options.map);}}else{map=context;}
-return map;},contextToMap:function(context,id){var map=new OpenLayers.Map(id,{maxExtent:context.maxExtent,projection:context.projection});map.addLayers(context.layers);map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(context.layers);return map;},write:function(obj,options){if(obj.CLASS_NAME=="OpenLayers.Map"){obj=this.mapToContext(obj);}
-var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.WMC["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a WMS capabilities parser for version "+
-version;}
-var wmc=this.parser.write(obj,options);return wmc;},mapToContext:function(map){var context={bounds:map.getExtent(),maxExtent:map.maxExtent,projection:map.projection,layers:map.layers,size:map.getSize()};return context;},CLASS_NAME:"OpenLayers.Format.WMC"});OpenLayers.Format.WMC.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ol:"http://openlayers.org/context",wmc:"http://www.opengis.net/context",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"",getNamespacePrefix:function(uri){var prefix=null;if(uri==null){prefix=this.namespaces[this.defaultPrefix];}else{for(prefix in this.namespaces){if(this.namespaces[prefix]==uri){break;}}}
-return prefix;},defaultPrefix:"wmc",rootPrefix:null,defaultStyleName:"",defaultStyleTitle:"Default",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;this.rootPrefix=root.prefix;var context={version:root.getAttribute("version")};this.runChildNodes(context,root);return context;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor,prefix,local;for(var i=0;i<children.length;++i){childNode=children[i];if(childNode.nodeType==1){prefix=this.getNamespacePrefix(childNode.namespaceURI);local=childNode.nodeName.split(":").pop();processor=this["read_"+prefix+"_"+local];if(processor){processor.apply(this,[obj,childNode]);}}}},read_wmc_General:function(context,node){this.runChildNodes(context,node);},read_wmc_BoundingBox:function(context,node){context.projection=node.getAttribute("SRS");context.bounds=new OpenLayers.Bounds(parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy")));},read_wmc_LayerList:function(context,node){context.layers=[];this.runChildNodes(context,node);},read_wmc_Layer:function(context,node){var layerInfo={params:{},options:{visibility:(node.getAttribute("hidden")!="1")},queryable:(node.getAttribute("queryable")=="1"),formats:[],styles:[]};this.runChildNodes(layerInfo,node);layerInfo.params.layers=layerInfo.name;layerInfo.options.maxExtent=layerInfo.maxExtent;var layer=this.getLayerFromInfo(layerInfo);context.layers.push(layer);},getLayerFromInfo:function(layerInfo){var options=layerInfo.options;if(this.layerOptions){OpenLayers.Util.applyDefaults(options,this.layerOptions);}
-var layer=new OpenLayers.Layer.WMS(layerInfo.title,layerInfo.href,layerInfo.params,options);return layer;},read_wmc_Extension:function(obj,node){this.runChildNodes(obj,node);},read_ol_units:function(layerInfo,node){layerInfo.options.units=this.getChildValue(node);},read_ol_maxExtent:function(obj,node){var bounds=new OpenLayers.Bounds(node.getAttribute("minx"),node.getAttribute("miny"),node.getAttribute("maxx"),node.getAttribute("maxy"));obj.maxExtent=bounds;},read_ol_transparent:function(layerInfo,node){layerInfo.params.transparent=this.getChildValue(node);},read_ol_numZoomLevels:function(layerInfo,node){layerInfo.options.numZoomLevels=parseInt(this.getChildValue(node));},read_ol_opacity:function(layerInfo,node){layerInfo.options.opacity=parseFloat(this.getChildValue(node));},read_ol_singleTile:function(layerInfo,node){layerInfo.options.singleTile=(this.getChildValue(node)=="true");},read_ol_isBaseLayer:function(layerInfo,node){layerInfo.options.isBaseLayer=(this.getChildValue(node)=="true");},read_ol_displayInLayerSwitcher:function(layerInfo,node){layerInfo.options.displayInLayerSwitcher=(this.getChildValue(node)=="true");},read_wmc_Server:function(layerInfo,node){layerInfo.params.version=node.getAttribute("version");this.runChildNodes(layerInfo,node);},read_wmc_FormatList:function(layerInfo,node){this.runChildNodes(layerInfo,node);},read_wmc_Format:function(layerInfo,node){var format=this.getChildValue(node);layerInfo.formats.push(format);if(node.getAttribute("current")=="1"){layerInfo.params.format=format;}},read_wmc_StyleList:function(layerInfo,node){this.runChildNodes(layerInfo,node);},read_wmc_Style:function(layerInfo,node){var style={};this.runChildNodes(style,node);if(node.getAttribute("current")=="1"){if(style.href){layerInfo.params.sld=style.href;}else if(style.body){layerInfo.params.sld_body=style.body;}else{layerInfo.params.styles=style.name;}}
-layerInfo.styles.push(style);},read_wmc_SLD:function(style,node){this.runChildNodes(style,node);},read_sld_StyledLayerDescriptor:function(sld,node){var xml=OpenLayers.Format.XML.prototype.write.apply(this,[node]);sld.body=xml;},read_wmc_OnlineResource:function(obj,node){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},read_wmc_Name:function(obj,node){var name=this.getChildValue(node);if(name){obj.name=name;}},read_wmc_Title:function(obj,node){var title=this.getChildValue(node);if(title){obj.title=title;}},read_wmc_Abstract:function(obj,node){var abst=this.getChildValue(node);if(abst){obj["abstract"]=abst;}},read_wmc_LatLonBoundingBox:function(layer,node){layer.llbbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];},read_wmc_LegendURL:function(style,node){var legend={width:node.getAttribute('width'),height:node.getAttribute('height')};var links=node.getElementsByTagName("OnlineResource");if(links.length>0){this.read_wmc_OnlineResource(legend,links[0]);}
-style.legend=legend;},write:function(context,options){var root=this.createElementDefaultNS("ViewContext");this.setAttributes(root,{version:this.VERSION,id:(options&&typeof options.id=="string")?options.id:OpenLayers.Util.createUniqueID("OpenLayers_Context_")});this.setAttributeNS(root,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);root.appendChild(this.write_wmc_General(context));root.appendChild(this.write_wmc_LayerList(context));return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},createElementDefaultNS:function(name,childValue,attributes){var node=this.createElementNS(this.namespaces[this.defaultPrefix],name);if(childValue){node.appendChild(this.createTextNode(childValue));}
-if(attributes){this.setAttributes(node,attributes);}
-return node;},setAttributes:function(node,obj){var value;for(var name in obj){value=obj[name].toString();if(value.match(/[A-Z]/)){this.setAttributeNS(node,null,name,value);}else{node.setAttribute(name,value);}}},write_wmc_General:function(context){var node=this.createElementDefaultNS("General");if(context.size){node.appendChild(this.createElementDefaultNS("Window",null,{width:context.size.w,height:context.size.h}));}
-var bounds=context.bounds;node.appendChild(this.createElementDefaultNS("BoundingBox",null,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10),SRS:context.projection}));node.appendChild(this.createElementDefaultNS("Title",context.title));node.appendChild(this.write_ol_MapExtension(context));return node;},write_ol_MapExtension:function(context){var node=this.createElementDefaultNS("Extension");var bounds=context.maxExtent;if(bounds){var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10)});node.appendChild(maxExtent);}
-return node;},write_wmc_LayerList:function(context){var list=this.createElementDefaultNS("LayerList");var layer;for(var i=0;i<context.layers.length;++i){layer=context.layers[i];if(layer instanceof OpenLayers.Layer.WMS){list.appendChild(this.write_wmc_Layer(layer));}}
-return list;},write_wmc_Layer:function(layer){var node=this.createElementDefaultNS("Layer",null,{queryable:"1",hidden:layer.visibility?"0":"1"});node.appendChild(this.write_wmc_Server(layer));node.appendChild(this.createElementDefaultNS("Name",layer.params["LAYERS"]));node.appendChild(this.createElementDefaultNS("Title",layer.name));node.appendChild(this.write_wmc_FormatList(layer));node.appendChild(this.write_wmc_StyleList(layer));node.appendChild(this.write_wmc_LayerExtension(layer));return node;},write_wmc_LayerExtension:function(layer){var node=this.createElementDefaultNS("Extension");var bounds=layer.maxExtent;var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10)});node.appendChild(maxExtent);var param=layer.params["TRANSPARENT"];if(param){var trans=this.createElementNS(this.namespaces.ol,"ol:transparent");trans.appendChild(this.createTextNode(param));node.appendChild(trans);}
-var properties=["numZoomLevels","units","isBaseLayer","opacity","displayInLayerSwitcher","singleTile"];var child;for(var i=0;i<properties.length;++i){child=this.createOLPropertyNode(layer,properties[i]);if(child){node.appendChild(child);}}
-return node;},createOLPropertyNode:function(obj,prop){var node=null;if(obj[prop]!=null){node=this.createElementNS(this.namespaces.ol,"ol:"+prop);node.appendChild(this.createTextNode(obj[prop].toString()));}
-return node;},write_wmc_Server:function(layer){var node=this.createElementDefaultNS("Server");this.setAttributes(node,{service:"OGC:WMS",version:layer.params["VERSION"]});node.appendChild(this.write_wmc_OnlineResource(layer.url));return node;},write_wmc_FormatList:function(layer){var node=this.createElementDefaultNS("FormatList");node.appendChild(this.createElementDefaultNS("Format",layer.params["FORMAT"],{current:"1"}));return node;},write_wmc_StyleList:function(layer){var node=this.createElementDefaultNS("StyleList");var style=this.createElementDefaultNS("Style",null,{current:"1"});if(layer.params["SLD"]){var sld=this.createElementDefaultNS("SLD");var link=this.write_wmc_OnlineResource(layer.params["SLD"]);sld.appendChild(link);style.appendChild(sld);}else if(layer.params["SLD_BODY"]){var sld=this.createElementDefaultNS("SLD");var body=layer.params["SLD_BODY"];var doc=OpenLayers.Format.XML.prototype.read.apply(this,[body]);var imported=doc.documentElement;if(sld.ownerDocument&&sld.ownerDocument.importNode){imported=sld.ownerDocument.importNode(imported,true);}
-sld.appendChild(imported);style.appendChild(sld);}else{var name=layer.params["STYLES"]?layer.params["STYLES"]:this.defaultStyleName;style.appendChild(this.createElementDefaultNS("Name",name));style.appendChild(this.createElementDefaultNS("Title",this.defaultStyleTitle));}
-node.appendChild(style);return node;},write_wmc_OnlineResource:function(href){var node=this.createElementDefaultNS("OnlineResource");this.setAttributeNS(node,this.namespaces.xlink,"xlink:type","simple");this.setAttributeNS(node,this.namespaces.xlink,"xlink:href",href);return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt.xy;return true;};}},mousedown:null,dblclick:function(evt){if(this.passesTolerance(evt)){if(this["double"]){this.callback('dblclick',[evt]);}
-this.clearTimer();}
-return!this.stopDouble;},click:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){this.clearTimer();}else{var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,clickEvent),this.delay);}}
-return!this.stopSingle;},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down){var dpx=Math.sqrt(Math.pow(this.down.x-evt.xy.x,2)+
-Math.pow(this.down.y-evt.xy.y,2));if(dpx>this.pixelTolerance){passes=false;}}
-return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback('click',[evt]);}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,oldOnselectstart:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},down:function(evt){},move:function(evt){},up:function(evt){},out:function(evt){},mousedown:function(evt){var propagate=true;this.dragging=false;if(this.checkModifiers(evt)&&OpenLayers.Event.isLeftClick(evt)){this.started=true;this.start=evt.xy;this.last=evt.xy;this.map.div.style.cursor="move";this.down(evt);this.callback("down",[evt.xy]);OpenLayers.Event.stop(evt);if(!this.oldOnselectstart){this.oldOnselectstart=(document.onselectstart)?document.onselectstart:function(){return true;};document.onselectstart=function(){return false;};}
-propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
-return propagate;},mousemove:function(evt){if(this.started){if(evt.xy.x!=this.last.x||evt.xy.y!=this.last.y){this.dragging=true;this.move(evt);this.callback("move",[evt.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=function(){return false;};}
-this.last=evt.xy;}}
-return true;},mouseup:function(evt){if(this.started){var dragged=(this.start!=this.last);this.started=false;this.dragging=false;this.map.div.style.cursor="";this.up(evt);this.callback("up",[evt.xy]);if(dragged){this.callback("done",[evt.xy]);}
-document.onselectstart=this.oldOnselectstart;}
-return true;},mouseout:function(evt){if(this.started&&OpenLayers.Util.mouseLeft(evt,this.map.div)){var dragged=(this.start!=this.last);this.started=false;this.dragging=false;this.map.div.style.cursor="";this.out(evt);this.callback("out",[]);if(dragged){this.callback("done",[evt.xy]);}
-if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}
-return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemove':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null}},feature:null,lastFeature:null,down:null,up:null,clickoutTolerance:4,geometryTypes:null,stopClick:true,stopDown:true,stopUp:true,layerIndex:null,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},mousedown:function(evt){this.down=evt.xy;return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){this.handle(evt);return true;},dblclick:function(evt){return!this.handle(evt);},geometryTypeMatches:function(feature){return this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1;},handle:function(evt){var type=evt.type;var handled=false;var previouslyIn=!!(this.feature);var click=(type=="click"||type=="dblclick");this.feature=this.layer.getFeatureFromEvent(evt);if(this.feature){var inNew=(this.feature!=this.lastFeature);if(this.geometryTypeMatches(this.feature)){if(previouslyIn&&inNew){this.triggerCallback(type,'out',[this.lastFeature]);this.triggerCallback(type,'in',[this.feature]);}else if(!previouslyIn||click){this.triggerCallback(type,'in',[this.feature]);}
-this.lastFeature=this.feature;handled=true;}else{if(previouslyIn&&inNew||(click&&this.lastFeature)){this.triggerCallback(type,'out',[this.lastFeature]);}
-this.feature=null;}}else{if(previouslyIn||(click&&this.lastFeature)){this.triggerCallback(type,'out',[this.lastFeature]);}}
-return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&mode=='out'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
-Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickoutTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.layerIndex=this.layer.div.style.zIndex;this.layer.div.style.zIndex=this.map.Z_INDEX_BASE['Popup']-1;activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){if(this.layer&&this.layer.div){this.layer.div.style.zIndex=this.layerIndex;}
-this.feature=null;this.lastFeature=null;this.down=null;this.up=null;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:false,px:null,timerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},mousemove:function(evt){if(this.passesTolerance(evt.xy)){this.clearTimer();this.callback('move',[evt]);this.px=evt.xy;evt=OpenLayers.Util.extend({},evt);this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);}
-return!this.stopMove;},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.div)){this.clearTimer();this.callback('move',[evt]);}
-return true;},passesTolerance:function(px){var passes=true;if(this.pixelTolerance&&this.px){var dpx=Math.sqrt(Math.pow(this.px.x-px.x,2)+
-Math.pow(this.px.y-px.y,2));if(dpx<this.pixelTolerance){passes=false;}}
-return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},delayedCall:function(evt){this.callback('pause',[evt]);},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Hover"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keypress","keyup"],eventListener:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){for(var i=0;i<this.KEY_EVENTS.length;i++){OpenLayers.Event.observe(window,this.KEY_EVENTS[i],this.eventListener);}
-return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0;i<this.KEY_EVENTS.length;i++){OpenLayers.Event.stopObserving(window,this.KEY_EVENTS[i],this.eventListener);}
-deactivated=true;}
-return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt.charCode||evt.keyCode]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
-var overScrollableDiv=false;var overLayerDiv=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);var overflow=style.getPropertyValue("overflow");}
-overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
-if(!overLayerDiv){for(var i=0;i<this.map.layers.length;i++){if(elem==this.map.layers[i].div||elem==this.map.layers[i].pane){overLayerDiv=true;break;}}}
-overMapDiv=(elem==this.map.div);elem=elem.parentNode;}
-if(!overScrollableDiv&&overMapDiv){if(overLayerDiv){this.wheelZoom(e);}
-OpenLayers.Event.stop(e);}},wheelZoom:function(e){var delta=0;if(!e){e=window.event;}
-if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
-if(delta){if(this.mousePosition){e.xy=this.mousePosition;}
-if(!e.xy){e.xy=this.map.getPixelFromLonLat(this.map.getCenter());}
-if(delta<0){this.callback("down",[e,delta]);}else{this.callback("up",[e,delta]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged"],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
-if(this.wrapDateLine){this.displayOutsideMaxExtent=true;}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
-if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
-this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
-this.events.destroy();}
-this.eventListeners=null;this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer(this.name,this.options);}
-OpenLayers.Util.applyDefaults(obj,this);obj.map=null;return obj;},setName:function(newName){if(newName!=this.name){this.name=newName;if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"name"});}}},addOptions:function(newOptions){if(this.options==null){this.options={};}
-OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},onMapResize:function(){},redraw:function(){var redrawn=false;if(this.map){this.inRange=this.calculateInRange();var extent=this.getExtent();if(extent&&this.inRange&&this.visibility){this.moveTo(extent,true,false);redrawn=true;}}
-return redrawn;},moveTo:function(bounds,zoomChanged,dragging){var display=this.visibility;if(!this.isBaseLayer){display=display&&this.inRange;}
-this.display(display);},setMap:function(map){if(this.map==null){this.map=map;this.maxExtent=this.maxExtent||this.map.maxExtent;this.projection=this.projection||this.map.projection;if(this.projection&&typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
-this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer){this.inRange=this.calculateInRange();var show=((this.visibility)&&(this.inRange));this.div.style.display=show?"":"none";}
-this.setTileSize();}},removeMap:function(map){},getImageSize:function(){return(this.imageSize||this.tileSize);},setTileSize:function(size){var tileSize=(size)?size:((this.tileSize)?this.tileSize:this.map.getTileSize());this.tileSize=tileSize;if(this.gutter){this.imageOffset=new OpenLayers.Pixel(-this.gutter,-this.gutter);this.imageSize=new OpenLayers.Size(tileSize.w+(2*this.gutter),tileSize.h+(2*this.gutter));}},getVisibility:function(){return this.visibility;},setVisibility:function(visibility){if(visibility!=this.visibility){this.visibility=visibility;this.display(visibility);this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});}
-this.events.triggerEvent("visibilitychanged");}},display:function(display){var inRange=this.calculateInRange();if(display!=(this.div.style.display!="none")){this.div.style.display=(display&&inRange)?"block":"none";}},calculateInRange:function(){var inRange=false;if(this.map){var resolution=this.map.getResolution();inRange=((resolution>=this.minResolution)&&(resolution<=this.maxResolution));}
-return inRange;},setIsBaseLayer:function(isBaseLayer){if(isBaseLayer!=this.isBaseLayer){this.isBaseLayer=isBaseLayer;if(this.map!=null){this.map.events.triggerEvent("changebaselayer",{layer:this});}}},initResolutions:function(){var props=new Array('projection','units','scales','resolutions','maxScale','minScale','maxResolution','minResolution','minExtent','maxExtent','numZoomLevels','maxZoomLevel');var confProps={};for(var i=0;i<props.length;i++){var property=props[i];confProps[property]=this.options[property]||this.map[property];}
-if(this.options.minScale!=null&&this.options.maxScale!=null&&this.options.scales==null){confProps.scales=null;}
-if(this.options.minResolution!=null&&this.options.maxResolution!=null&&this.options.resolutions==null){confProps.resolutions=null;}
-if((!confProps.numZoomLevels)&&(confProps.maxZoomLevel)){confProps.numZoomLevels=confProps.maxZoomLevel+1;}
-if((confProps.scales!=null)||(confProps.resolutions!=null)){if(confProps.scales!=null){confProps.resolutions=[];for(var i=0;i<confProps.scales.length;i++){var scale=confProps.scales[i];confProps.resolutions[i]=OpenLayers.Util.getResolutionFromScale(scale,confProps.units);}}
-confProps.numZoomLevels=confProps.resolutions.length;}else{if(confProps.minScale){confProps.maxResolution=OpenLayers.Util.getResolutionFromScale(confProps.minScale,confProps.units);}else if(confProps.maxResolution=="auto"){var viewSize=this.map.getSize();var wRes=confProps.maxExtent.getWidth()/viewSize.w;var hRes=confProps.maxExtent.getHeight()/viewSize.h;confProps.maxResolution=Math.max(wRes,hRes);}
-if(confProps.maxScale!=null){confProps.minResolution=OpenLayers.Util.getResolutionFromScale(confProps.maxScale,confProps.units);}else if((confProps.minResolution=="auto")&&(confProps.minExtent!=null)){var viewSize=this.map.getSize();var wRes=confProps.minExtent.getWidth()/viewSize.w;var hRes=confProps.minExtent.getHeight()/viewSize.h;confProps.minResolution=Math.max(wRes,hRes);}
-if(confProps.minResolution!=null&&this.options.numZoomLevels==undefined){var ratio=confProps.maxResolution/confProps.minResolution;confProps.numZoomLevels=Math.floor(Math.log(ratio)/Math.log(2))+1;}
-confProps.resolutions=new Array(confProps.numZoomLevels);var base=2;if(typeof confProps.minResolution=="number"&&confProps.numZoomLevels>1){base=Math.pow((confProps.maxResolution/confProps.minResolution),(1/(confProps.numZoomLevels-1)));}
-for(var i=0;i<confProps.numZoomLevels;i++){var res=confProps.maxResolution/Math.pow(base,i);confProps.resolutions[i]=res;}}
-confProps.resolutions.sort(function(a,b){return(b-a);});this.resolutions=confProps.resolutions;this.maxResolution=confProps.resolutions[0];var lastIndex=confProps.resolutions.length-1;this.minResolution=confProps.resolutions[lastIndex];this.scales=[];for(var i=0;i<confProps.resolutions.length;i++){this.scales[i]=OpenLayers.Util.getScaleFromResolution(confProps.resolutions[i],confProps.units);}
-this.minScale=this.scales[0];this.maxScale=this.scales[this.scales.length-1];this.numZoomLevels=confProps.numZoomLevels;},getResolution:function(){var zoom=this.map.getZoom();return this.getResolutionForZoom(zoom);},getExtent:function(){return this.map.calculateBounds();},getZoomForExtent:function(extent,closest){var viewSize=this.map.getSize();var idealResolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);return this.getZoomForResolution(idealResolution,closest);},getDataExtent:function(){},getResolutionForZoom:function(zoom){zoom=Math.max(0,Math.min(zoom,this.resolutions.length-1));var resolution;if(this.map.fractionalZoom){var low=Math.floor(zoom);var high=Math.ceil(zoom);resolution=this.resolutions[high]+
-((zoom-low)*(this.resolutions[low]-this.resolutions[high]));}else{resolution=this.resolutions[Math.round(zoom)];}
-return resolution;},getZoomForResolution:function(resolution,closest){var zoom;if(this.map.fractionalZoom){var lowZoom=0;var highZoom=this.resolutions.length-1;var highRes=this.resolutions[lowZoom];var lowRes=this.resolutions[highZoom];var res;for(var i=0;i<this.resolutions.length;++i){res=this.resolutions[i];if(res>=resolution){highRes=res;lowZoom=i;}
-if(res<=resolution){lowRes=res;highZoom=i;break;}}
-var dRes=highRes-lowRes;if(dRes>0){zoom=lowZoom+((resolution-lowRes)/dRes);}else{zoom=lowZoom;}}else{var diff;var minDiff=Number.POSITIVE_INFINITY;for(var i=0;i<this.resolutions.length;i++){if(closest){diff=Math.abs(this.resolutions[i]-resolution);if(diff>minDiff){break;}
-minDiff=diff;}else{if(this.resolutions[i]<resolution){break;}}}
-zoom=Math.max(0,i-1);}
-return zoom;},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(viewPortPx!=null){var size=this.map.getSize();var center=this.map.getCenter();if(center){var res=this.map.getResolution();var delta_x=viewPortPx.x-(size.w/2);var delta_y=viewPortPx.y-(size.h/2);lonlat=new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}}}
-return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(lonlat!=null){var resolution=this.map.getResolution();var extent=this.map.getExtent();px=new OpenLayers.Pixel((1/resolution*(lonlat.lon-extent.left)),(1/resolution*(extent.top-lonlat.lat)));}
-return px;},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0;i<this.div.childNodes.length;++i){var element=this.div.childNodes[i].firstChild;OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);}}},setZIndex:function(zIndex){this.div.style.zIndex=zIndex;},adjustBounds:function(bounds){if(this.gutter){var mapGutter=this.gutter*this.map.getResolution();bounds=new OpenLayers.Bounds(bounds.left-mapGutter,bounds.bottom-mapGutter,bounds.right+mapGutter,bounds.top+mapGutter);}
-if(this.wrapDateLine){var wrappingOptions={'rightTolerance':this.getResolution()};bounds=bounds.wrapDateLine(this.maxExtent,wrappingOptions);}
-return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(bounds,borderColor,borderWidth){this.bounds=bounds;this.div=OpenLayers.Util.createDiv();this.div.style.overflow='hidden';this.events=new OpenLayers.Events(this,this.div,null);this.setBorder(borderColor,borderWidth);},destroy:function(){this.bounds=null;this.div=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments);},setBorder:function(color,width){if(!color){color="red";}
-if(!width){width=2;}
-this.div.style.border=width+"px solid "+color;},draw:function(px,sz){OpenLayers.Util.modifyDOMElement(this.div,null,px,sz);return this.div;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsBounds(this.bounds,true,true);}
-return onScreen;},display:function(display){this.div.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{autoSize:true,panMapIfOutOfView:true,imageSize:new OpenLayers.Size(676,736),isAlphaImage:false,fixedRelativePosition:false,positionBlocks:{"tl":{'offset':new OpenLayers.Pixel(44,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,32,80,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(0,-668)}]},"tr":{'offset':new OpenLayers.Pixel(-45,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(0,0,null,null),position:new OpenLayers.Pixel(-215,-668)}]},"bl":{'offset':new OpenLayers.Pixel(45,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(null,null,0,0),position:new OpenLayers.Pixel(-101,-674)}]},"br":{'offset':new OpenLayers.Pixel(-44,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(600,660),initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){this.imageSrc=OpenLayers.Util.getImagesLocation()+'cloud-popup-relative.png';OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className="olFramedCloudPopupContent";},destroy:function(){OpenLayers.Popup.Framed.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={drag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks)),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){if(!this.handlers.drag.dragging){this.feature=feature;this.handlers.drag.activate();this.over=true;this.map.div.style.cursor="move";}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}},downFeature:function(pixel){this.lastPixel=pixel;this.onStart(this.feature,pixel);},moveFeature:function(pixel){var res=this.map.getResolution();this.feature.geometry.move(res*(pixel.x-this.lastPixel.x),res*(this.lastPixel.y-pixel.y));this.layer.drawFeature(this.feature);this.lastPixel=pixel;this.onDrag(this.feature,pixel);},upFeature:function(pixel){if(!this.over){this.handlers.drag.deactivate();this.feature=null;this.map.div.style.cursor="default";}},doneDragging:function(pixel){this.onComplete(this.feature,pixel);},outFeature:function(feature){if(!this.handlers.drag.dragging){this.over=false;this.handlers.drag.deactivate();this.map.div.style.cursor="default";this.feature=null;}else{if(this.feature.id==feature.id){this.over=false;}}},cancel:function(){this.handlers.drag.deactivate();this.over=false;},setMap:function(map){this.handlers.drag.setMap(map);this.handlers.feature.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,draw:function(){this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone});},panMap:function(xy){this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:this.handler.dragging,animate:false});},panMapDone:function(xy){if(this.panned){this.panMap(xy);this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{slideFactor:75,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
-this.handler=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{"keypress":this.defaultKeyPress});this.activate();},defaultKeyPress:function(code){switch(code){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:var size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:var size=this.map.getSize();this.map.pan(0,0.75*size.h);break;case 35:var size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:var size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:this.map.zoomIn();break;case 45:this.map.zoomOut();break;case 107:this.map.zoomIn();break;case 109:this.map.zoomOut();break;}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});OpenLayers.State={UNKNOWN:'Unknown',INSERT:'Insert',UPDATE:'Update',DELETE:'Delete'};OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,state:null,style:null,renderIntent:"default",initialize:function(geometry,attributes,style){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,attributes]);this.lonlat=null;this.geometry=geometry;this.state=null;this.attributes={};if(attributes){this.attributes=OpenLayers.Util.extend(this.attributes,attributes);}
-this.style=style?style:null;},destroy:function(){if(this.layer){this.layer.removeFeatures(this);this.layer=null;}
-this.geometry=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments);},clone:function(){return new OpenLayers.Feature.Vector(this.geometry.clone(),this.attributes,this.style);},onScreen:function(boundsOnly){var onScreen=false;if(this.layer&&this.layer.map){var screenBounds=this.layer.map.getExtent();if(boundsOnly){var featureBounds=this.geometry.getBounds();onScreen=screenBounds.intersectsBounds(featureBounds);}else{var screenPoly=screenBounds.toGeometry();onScreen=screenPoly.intersects(this.geometry);}}
-return onScreen;},createMarker:function(){return null;},destroyMarker:function(){},createPopup:function(){return null;},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;if(this.geometry){atPoint=this.geometry.atPoint(lonlat,toleranceLon,toleranceLat);}
-return atPoint;},destroyPopup:function(){},toState:function(state){if(state==OpenLayers.State.UPDATE){switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=state;break;case OpenLayers.State.UPDATE:case OpenLayers.State.INSERT:break;}}else if(state==OpenLayers.State.INSERT){switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=state;break;}}else if(state==OpenLayers.State.DELETE){switch(this.state){case OpenLayers.State.INSERT:break;case OpenLayers.State.DELETE:break;case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=state;break;}}else if(state==OpenLayers.State.UNKNOWN){this.state=state;}},CLASS_NAME:"OpenLayers.Feature.Vector"});OpenLayers.Feature.Vector.style={'default':{fillColor:"#ee9900",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:""},'select':{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer"},'temporary':{fillColor:"yellow",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"yellow",strokeOpacity:1,strokeLinecap:"round",strokeWidth:4,hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:""}};OpenLayers.Feature.WFS=OpenLayers.Class(OpenLayers.Feature,{initialize:function(layer,xmlNode){var newArguments=arguments;var data=this.processXMLNode(xmlNode);newArguments=new Array(layer,data.lonlat,data);OpenLayers.Feature.prototype.initialize.apply(this,newArguments);this.createMarker();this.layer.addMarker(this.marker);},destroy:function(){if(this.marker!=null){this.layer.removeMarker(this.marker);}
-OpenLayers.Feature.prototype.destroy.apply(this,arguments);},processXMLNode:function(xmlNode){var point=OpenLayers.Ajax.getElementsByTagNameNS(xmlNode,"http://www.opengis.net/gml","gml","Point");var text=OpenLayers.Util.getXmlNodeValue(OpenLayers.Ajax.getElementsByTagNameNS(point[0],"http://www.opengis.net/gml","gml","coordinates")[0]);var floats=text.split(",");return{lonlat:new OpenLayers.LonLat(parseFloat(floats[0]),parseFloat(floats[1])),id:null};},CLASS_NAME:"OpenLayers.Feature.WFS"});OpenLayers.Format.WMC.v1_0_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.WMC.v1_0_0"});OpenLayers.Format.WMC.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},read_sld_MinScaleDenominator:function(layerInfo,node){layerInfo.options.maxScale=this.getChildValue(node);},read_sld_MaxScaleDenominator:function(layerInfo,node){layerInfo.options.minScale=this.getChildValue(node);},write_wmc_Layer:function(layer){var node=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,[layer]);if(layer.options.resolutions||layer.options.scales||layer.options.minResolution||layer.options.maxScale){var minSD=this.createElementNS(this.namespaces.sld,"sld:MinScaleDenominator");minSD.appendChild(this.createTextNode(layer.maxScale.toPrecision(10)));node.insertBefore(minSD,node.childNodes[3]);}
-if(layer.options.resolutions||layer.options.scales||layer.options.maxResolution||layer.options.minScale){var maxSD=this.createElementNS(this.namespaces.sld,"sld:MaxScaleDenominator");maxSD.appendChild(this.createTextNode(layer.minScale.toPrecision(10)));node.insertBefore(maxSD,node.childNodes[4]);}
-return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);var callbacks={"down":this.startBox,"move":this.moveBox,"out":this.removeBox,"up":this.endBox};this.dragHandler=new OpenLayers.Handler.Drag(this,callbacks,{keyMask:this.keyMask});},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.dragHandler.start);this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.map.div.style.cursor="crosshair";},moveBox:function(xy){var deltaX=Math.abs(this.dragHandler.start.x-xy.x);var deltaY=Math.abs(this.dragHandler.start.y-xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(xy.x<this.dragHandler.start.x){this.zoomBox.style.left=xy.x+"px";}
-if(xy.y<this.dragHandler.start.y){this.zoomBox.style.top=xy.y+"px";}},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
-this.removeBox();this.map.div.style.cursor="";this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:'shiftKey',persist:false,irregular:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(control,callbacks,options){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:new Object();},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var options={displayInLayerSwitcher:false};this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)){if(this.dragging){this.cancel();}
-if(this.layer.map!=null){this.layer.destroy(false);if(this.feature){this.feature.destroy();}}
-this.layer=null;this.feature=null;deactivated=true;}
-return deactivated;},down:function(evt){this.fixedRadius=!!(this.radius);var maploc=this.map.getLonLatFromPixel(evt.xy);this.origin=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(!this.fixedRadius||this.irregular){this.radius=this.map.getResolution();}
-if(this.persist){this.clear();}
-this.feature=new OpenLayers.Feature.Vector();this.createGeometry();this.layer.addFeatures([this.feature],{silent:true});this.layer.drawFeature(this.feature,this.style);},move:function(evt){var maploc=this.map.getLonLatFromPixel(evt.xy);var point=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(this.irregular){var ry=Math.sqrt(2)*Math.abs(point.y-this.origin.y)/2;this.radius=Math.max(this.map.getResolution()/2,ry);}else if(this.fixedRadius){this.origin=point;}else{this.calculateAngle(point,evt);this.radius=Math.max(this.map.getResolution()/2,point.distanceTo(this.origin));}
-this.modifyGeometry();if(this.irregular){var dx=point.x-this.origin.x;var dy=point.y-this.origin.y;var ratio;if(dy==0){ratio=dx/(this.radius*Math.sqrt(2));}else{ratio=dx/dy;}
-this.feature.geometry.resize(1,this.origin,ratio);this.feature.geometry.move(dx/2,dy/2);}
-this.layer.drawFeature(this.feature,this.style);},up:function(evt){this.finalize();},out:function(evt){this.finalize();},createGeometry:function(){this.angle=Math.PI*((1/this.sides)-(1/2));if(this.snapAngle){this.angle+=this.snapAngle*(Math.PI/180);}
-this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,this.sides,this.snapAngle);},modifyGeometry:function(){var angle,dx,dy,point;var ring=this.feature.geometry.components[0];if(ring.components.length!=(this.sides+1)){this.createGeometry();ring=this.feature.geometry.components[0];}
-for(var i=0;i<this.sides;++i){point=ring.components[i];angle=this.angle+(i*2*Math.PI/this.sides);point.x=this.origin.x+(this.radius*Math.cos(angle));point.y=this.origin.y+(this.radius*Math.sin(angle));point.clearBounds();}},calculateAngle:function(point,evt){var alpha=Math.atan2(point.y-this.origin.y,point.x-this.origin.x);if(this.snapAngle&&(this.snapToggle&&!evt[this.snapToggle])){var snapAngleRad=(Math.PI/180)*this.snapAngle;this.angle=Math.round(alpha/snapAngleRad)*snapAngleRad;}else{this.angle=alpha;}},cancel:function(){this.callback("cancel",null);this.finalize();},finalize:function(){this.origin=null;this.radius=this.options.radius;},clear:function(){this.layer.renderer.clear();this.layer.destroyFeatures();},callback:function(name,args){if(this.callbacks[name]){this.callbacks[name].apply(this.control,[this.feature.geometry.clone()]);}
-if(!this.persist&&(name=="done"||name=="cancel")){this.clear();}},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:true,isBaseLayer:true,isFixed:true,pane:null,mapObject:null,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(this.pane==null){this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane");}},destroy:function(){this.mapObject=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";if(OpenLayers.Util.getBrowserName()=="msie"){this.pane.style.background="url("+OpenLayers.Util.getImagesLocation()+"blank.gif)";}
-if(this.isFixed){this.map.viewPortDiv.appendChild(this.pane);}else{this.map.layerContainerDiv.appendChild(this.pane);}
-this.loadMapObject();if(this.mapObject==null){this.loadWarningMessage();}},removeMap:function(map){if(this.pane&&this.pane.parentNode){this.pane.parentNode.removeChild(this.pane);this.pane=null;}
-OpenLayers.Layer.prototype.removeMap.apply(this,arguments);},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var viewSize=this.map.getSize();var msgW=Math.min(viewSize.w,300);var msgH=Math.min(viewSize.h,200);var size=new OpenLayers.Size(msgW,msgH);var centerPx=new OpenLayers.Pixel(viewSize.w/2,viewSize.h/2);var topLeft=centerPx.add(-size.w/2,-size.h/2);var div=OpenLayers.Util.createDiv(this.name+"_warning",topLeft,size,null,null,null,"auto");div.style.padding="7px";div.style.backgroundColor="yellow";div.innerHTML=this.getWarningHTML();this.div.appendChild(div);},getWarningHTML:function(){return"";},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);this.pane.style.display=this.div.style.display;},setZIndex:function(zIndex){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(this.mapObject!=null){var newCenter=this.map.getCenter();var newZoom=this.map.getZoom();if(newCenter!=null){var moOldCenter=this.getMapObjectCenter();var oldCenter=this.getOLLonLatFromMapObjectLonLat(moOldCenter);var moOldZoom=this.getMapObjectZoom();var oldZoom=this.getOLZoomFromMapObjectZoom(moOldZoom);if(!(newCenter.equals(oldCenter))||!(newZoom==oldZoom)){if(dragging&&this.dragPanMapObject&&this.smoothDragPan){var oldPx=this.map.getViewPortPxFromLonLat(oldCenter);var newPx=this.map.getViewPortPxFromLonLat(newCenter);this.dragPanMapObject(newPx.x-oldPx.x,oldPx.y-newPx.y);}else{var center=this.getMapObjectLonLatFromOLLonLat(newCenter);var zoom=this.getMapObjectZoomFromOLZoom(newZoom);this.setMapObjectCenter(center,zoom,dragging);}}}}},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moPixel=this.getMapObjectPixelFromOLPixel(viewPortPx);var moLonLat=this.getMapObjectLonLatFromMapObjectPixel(moPixel);lonlat=this.getOLLonLatFromMapObjectLonLat(moLonLat);}
-return lonlat;},getViewPortPxFromLonLat:function(lonlat){var viewPortPx=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moLonLat=this.getMapObjectLonLatFromOLLonLat(lonlat);var moPixel=this.getMapObjectPixelFromMapObjectLonLat(moLonLat);viewPortPx=this.getOLPixelFromMapObjectPixel(moPixel);}
-return viewPortPx;},getOLLonLatFromMapObjectLonLat:function(moLonLat){var olLonLat=null;if(moLonLat!=null){var lon=this.getLongitudeFromMapObjectLonLat(moLonLat);var lat=this.getLatitudeFromMapObjectLonLat(moLonLat);olLonLat=new OpenLayers.LonLat(lon,lat);}
-return olLonLat;},getMapObjectLonLatFromOLLonLat:function(olLonLat){var moLatLng=null;if(olLonLat!=null){moLatLng=this.getMapObjectLonLatFromLonLat(olLonLat.lon,olLonLat.lat);}
-return moLatLng;},getOLPixelFromMapObjectPixel:function(moPixel){var olPixel=null;if(moPixel!=null){var x=this.getXFromMapObjectPixel(moPixel);var y=this.getYFromMapObjectPixel(moPixel);olPixel=new OpenLayers.Pixel(x,y);}
-return olPixel;},getMapObjectPixelFromOLPixel:function(olPixel){var moPixel=null;if(olPixel!=null){moPixel=this.getMapObjectPixelFromXY(olPixel.x,olPixel.y);}
-return moPixel;},CLASS_NAME:"OpenLayers.Layer.EventPane"});OpenLayers.Layer.FixedZoomLevels=OpenLayers.Class({initialize:function(){},initResolutions:function(){var props=new Array('minZoomLevel','maxZoomLevel','numZoomLevels');for(var i=0;i<props.length;i++){var property=props[i];this[property]=(this.options[property]!=null)?this.options[property]:this.map[property];}
-if((this.minZoomLevel==null)||(this.minZoomLevel<this.MIN_ZOOM_LEVEL)){this.minZoomLevel=this.MIN_ZOOM_LEVEL;}
-var limitZoomLevels=this.MAX_ZOOM_LEVEL-this.minZoomLevel+1;if(this.numZoomLevels!=null){this.numZoomLevels=Math.min(this.numZoomLevels,limitZoomLevels);}else{if(this.maxZoomLevel!=null){var zoomDiff=this.maxZoomLevel-this.minZoomLevel+1;this.numZoomLevels=Math.min(zoomDiff,limitZoomLevels);}else{this.numZoomLevels=limitZoomLevels;}}
-this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(this.RESOLUTIONS!=null){var resolutionsIndex=0;this.resolutions=[];for(var i=this.minZoomLevel;i<=this.maxZoomLevel;i++){this.resolutions[resolutionsIndex++]=this.RESOLUTIONS[i];}
-this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1];}},getResolution:function(){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getResolution.apply(this,arguments);}else{var resolution=null;var viewSize=this.map.getSize();var extent=this.getExtent();if((viewSize!=null)&&(extent!=null)){resolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);}
-return resolution;}},getExtent:function(){var extent=null;var size=this.map.getSize();var tlPx=new OpenLayers.Pixel(0,0);var tlLL=this.getLonLatFromViewPortPx(tlPx);var brPx=new OpenLayers.Pixel(size.w,size.h);var brLL=this.getLonLatFromViewPortPx(brPx);if((tlLL!=null)&&(brLL!=null)){extent=new OpenLayers.Bounds(tlLL.lon,brLL.lat,brLL.lon,tlLL.lat);}
-return extent;},getZoomForResolution:function(resolution){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getZoomForResolution.apply(this,arguments);}else{var extent=OpenLayers.Layer.prototype.getExtent.apply(this,[]);return this.getZoomForExtent(extent);}},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=moZoom-this.minZoomLevel;}
-return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=olZoom+this.minZoomLevel;}
-return zoom;},CLASS_NAME:"FixedZoomLevels.js"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setUrl:function(newUrl){this.url=newUrl;},mergeNewParams:function(newParams){this.params=OpenLayers.Util.extend(this.params,newParams);return this.redraw();},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0;i<paramString.length;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
-return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
-var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
-paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Layer.Image=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:true,url:null,extent:null,size:null,tile:null,aspectRatio:null,initialize:function(name,url,extent,size,options){this.url=url;this.extent=extent;this.size=size;OpenLayers.Layer.prototype.initialize.apply(this,[name,options]);this.aspectRatio=(this.extent.getHeight()/this.size.h)/(this.extent.getWidth()/this.size.w);},destroy:function(){if(this.tile){this.tile.destroy();this.tile=null;}
-OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Image(this.name,this.url,this.extent,this.size,this.options);}
-obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setMap:function(map){if(this.options.maxResolution==null){this.options.maxResolution=this.aspectRatio*this.extent.getWidth()/this.size.w;}
-OpenLayers.Layer.prototype.setMap.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var firstRendering=(this.tile==null);if(zoomChanged||firstRendering){this.setTileSize();var ul=new OpenLayers.LonLat(this.extent.left,this.extent.top);var ulPx=this.map.getLayerPxFromLonLat(ul);if(firstRendering){this.tile=new OpenLayers.Tile.Image(this,ulPx,this.extent,null,this.tileSize);}else{this.tile.size=this.tileSize.clone();this.tile.position=ulPx.clone();}
-this.tile.draw();}},setTileSize:function(){var tileWidth=this.extent.getWidth()/this.map.getResolution();var tileHeight=this.extent.getHeight()/this.map.getResolution();this.tileSize=new OpenLayers.Size(tileWidth,tileHeight);},setUrl:function(newUrl){this.url=newUrl;this.tile.draw();},getURL:function(bounds){return this.url;},CLASS_NAME:"OpenLayers.Layer.Image"});OpenLayers.Layer.Markers=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:false,markers:null,drawn:false,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);this.markers=[];},destroy:function(){this.clearMarkers();this.markers=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0;i<this.markers.length;i++){this.markers[i].setOpacity(this.opacity);}}},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(zoomChanged||!this.drawn){for(var i=0;i<this.markers.length;i++){this.drawMarker(this.markers[i]);}
-this.drawn=true;}},addMarker:function(marker){this.markers.push(marker);if(this.opacity!=null){marker.setOpacity(this.opacity);}
-if(this.map&&this.map.getExtent()){marker.map=this.map;this.drawMarker(marker);}},removeMarker:function(marker){if(this.markers&&this.markers.length){OpenLayers.Util.removeItem(this.markers,marker);if((marker.icon!=null)&&(marker.icon.imageDiv!=null)&&(marker.icon.imageDiv.parentNode==this.div)){this.div.removeChild(marker.icon.imageDiv);marker.drawn=false;}}},clearMarkers:function(){if(this.markers!=null){while(this.markers.length>0){this.removeMarker(this.markers[0]);}}},drawMarker:function(marker){var px=this.map.getLayerPxFromLonLat(marker.lonlat);if(px==null){marker.display(false);}else{var markerImg=marker.draw(px);if(!marker.drawn){this.div.appendChild(markerImg);marker.drawn=true;}}},getDataExtent:function(){var maxExtent=null;if(this.markers&&(this.markers.length>0)){var maxExtent=new OpenLayers.Bounds();for(var i=0;i<this.markers.length;i++){var marker=this.markers[i];maxExtent.extend(marker.lonlat);}}
-return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Markers"});OpenLayers.Layer.SphericalMercator={getExtent:function(){var extent=null;if(this.sphericalMercator){extent=this.map.calculateBounds();}else{extent=OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);}
-return extent;},initMercatorParameters:function(){this.RESOLUTIONS=[];var maxResolution=156543.0339;for(var zoom=0;zoom<=this.MAX_ZOOM_LEVEL;++zoom){this.RESOLUTIONS[zoom]=maxResolution/Math.pow(2,zoom);}
-this.units="m";this.projection="EPSG:900913";},forwardMercator:function(lon,lat){var x=lon*20037508.34/180;var y=Math.log(Math.tan((90+lat)*Math.PI/360))/(Math.PI/180);y=y*20037508.34/180;return new OpenLayers.LonLat(x,y);},inverseMercator:function(x,y){var lon=(x/20037508.34)*180;var lat=(y/20037508.34)*180;lat=180/Math.PI*(2*Math.atan(Math.exp(lat*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(lon,lat);},projectForward:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.forwardMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;},projectInverse:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.inverseMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;}};OpenLayers.Projection.addTransform("EPSG:4326","EPSG:900913",OpenLayers.Layer.SphericalMercator.projectForward);OpenLayers.Projection.addTransform("EPSG:900913","EPSG:4326",OpenLayers.Layer.SphericalMercator.projectInverse);OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,featureAdded:function(){},handlerOptions:null,initialize:function(layer,handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature},this.callbacks);this.layer=layer;this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);this.layer.addFeatures([feature]);this.featureAdded(feature);},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,onSelect:function(){},onUnselect:function(){},geometryTypes:null,layer:null,callbacks:null,selectStyle:null,renderIntent:"select",handler:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.callbacks=OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.callbacks);var handlerOptions={geometryTypes:this.geometryTypes};this.handler=new OpenLayers.Handler.Feature(this,layer,this.callbacks,handlerOptions);},unselectAll:function(options){var feature;for(var i=this.layer.selectedFeatures.length-1;i>=0;--i){feature=this.layer.selectedFeatures[i];if(!options||options.except!=feature){this.unselect(feature);}}},clickFeature:function(feature){if(!this.hover){var selected=(OpenLayers.Util.indexOf(this.layer.selectedFeatures,feature)>-1);if(selected){if(this.toggleSelect()){this.unselect(feature);}else if(!this.multipleSelect()){this.unselectAll({except:feature});}}else{if(!this.multipleSelect()){this.unselectAll({except:feature});}
-this.select(feature);}}},multipleSelect:function(){return this.multiple||this.handler.evt[this.multipleKey];},toggleSelect:function(){return this.toggle||this.handler.evt[this.toggleKey];},clickoutFeature:function(feature){if(!this.hover&&this.clickout){this.unselectAll();}},overFeature:function(feature){if(this.hover&&(OpenLayers.Util.indexOf(this.layer.selectedFeatures,feature)==-1)){this.select(feature);}},outFeature:function(feature){if(this.hover){this.unselect(feature);}},select:function(feature){this.layer.selectedFeatures.push(feature);var selectStyle=this.selectStyle||this.renderIntent;this.layer.drawFeature(feature,selectStyle);this.layer.events.triggerEvent("featureselected",{feature:feature});this.onSelect(feature);},unselect:function(feature){this.layer.drawFeature(feature,"default");OpenLayers.Util.removeItem(this.layer.selectedFeatures,feature);this.layer.events.triggerEvent("featureunselected",{feature:feature});this.onUnselect(feature);},setMap:function(map){this.handler.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax=center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;var bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
-this.map.zoomToExtent(bounds);}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){this.regExes={'typeStr':/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,'spaces':/\s+/,'parenComma':/\)\s*,\s*\(/,'doubleParenComma':/\)\s*\)\s*,\s*\(\s*\(/,'trimParens':/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(wkt){var features,type,str;var matches=this.regExes.typeStr.exec(wkt);if(matches){type=matches[1].toLowerCase();str=matches[2];if(this.parse[type]){features=this.parse[type].apply(this,[str]);}
-if(this.internalProjection&&this.externalProjection){if(features&&features.CLASS_NAME=="OpenLayers.Feature.Vector"){features.geometry.transform(this.externalProjection,this.internalProjection);}else if(features&&typeof features=="object"){for(var i=0;i<features.length;i++){var component=features[i];component.geometry.transform(this.externalProjection,this.internalProjection);}}}}
-return features;},write:function(features){var collection,geometry,type,data,isCollection;if(features.constructor==Array){collection=features;isCollection=true;}else{collection=[features];isCollection=false;}
-var pieces=[];if(isCollection){pieces.push('GEOMETRYCOLLECTION(');}
-for(var i=0;i<collection.length;++i){if(isCollection&&i>0){pieces.push(',');}
-geometry=collection[i].geometry;type=geometry.CLASS_NAME.split('.')[2].toLowerCase();if(!this.extract[type]){return null;}
-if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-data=this.extract[type].apply(this,[geometry]);pieces.push(type.toUpperCase()+'('+data+')');}
-if(isCollection){pieces.push(')');}
-return pieces.join('');},extract:{'point':function(point){return point.x+' '+point.y;},'multipoint':function(multipoint){var array=[];for(var i=0;i<multipoint.components.length;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
-return array.join(',');},'linestring':function(linestring){var array=[];for(var i=0;i<linestring.components.length;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
-return array.join(',');},'multilinestring':function(multilinestring){var array=[];for(var i=0;i<multilinestring.components.length;++i){array.push('('+
-this.extract.linestring.apply(this,[multilinestring.components[i]])+')');}
-return array.join(',');},'polygon':function(polygon){var array=[];for(var i=0;i<polygon.components.length;++i){array.push('('+
-this.extract.linestring.apply(this,[polygon.components[i]])+')');}
-return array.join(',');},'multipolygon':function(multipolygon){var array=[];for(var i=0;i<multipolygon.components.length;++i){array.push('('+
-this.extract.polygon.apply(this,[multipolygon.components[i]])+')');}
-return array.join(',');}},parse:{'point':function(str){var coords=OpenLayers.String.trim(str).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(coords[0],coords[1]));},'multipoint':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0;i<points.length;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPoint(components));},'linestring':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0;i<points.length;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString(components));},'multilinestring':function(str){var line;var lines=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0;i<lines.length;++i){line=lines[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.linestring.apply(this,[line]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiLineString(components));},'polygon':function(str){var ring,linestring,linearring;var rings=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0;i<rings.length;++i){ring=rings[i].replace(this.regExes.trimParens,'$1');linestring=this.parse.linestring.apply(this,[ring]).geometry;linearring=new OpenLayers.Geometry.LinearRing(linestring.components);components.push(linearring);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon(components));},'multipolygon':function(str){var polygon;var polygons=OpenLayers.String.trim(str).split(this.regExes.doubleParenComma);var components=[];for(var i=0;i<polygons.length;++i){polygon=polygons[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.polygon.apply(this,[polygon]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPolygon(components));},'geometrycollection':function(str){str=str.replace(/,\s*([A-Za-z])/g,'|$1');var wktArray=OpenLayers.String.trim(str).split('|');var components=[];for(var i=0;i<wktArray.length;++i){components.push(OpenLayers.Format.WKT.prototype.read.apply(this,[wktArray[i]]));}
-return components;}},CLASS_NAME:"OpenLayers.Format.WKT"});OpenLayers.Layer.Boxes=OpenLayers.Class(OpenLayers.Layer.Markers,{initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);},drawMarker:function(marker){var bounds=marker.bounds;var topleft=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.left,bounds.top));var botright=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.right,bounds.bottom));if(botright==null||topleft==null){marker.display(false);}else{var sz=new OpenLayers.Size(Math.max(1,botright.x-topleft.x),Math.max(1,botright.y-topleft.y));var markerDiv=marker.draw(topleft,sz);if(!marker.drawn){this.div.appendChild(markerDiv);marker.drawn=true;}}},removeMarker:function(marker){OpenLayers.Util.removeItem(this.markers,marker);if((marker.div!=null)&&(marker.div.parentNode==this.div)){this.div.removeChild(marker.div);}},CLASS_NAME:"OpenLayers.Layer.Boxes"});OpenLayers.Layer.GeoRSS=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,icon:null,popupSize:null,useFeedTitle:true,initialize:function(name,location,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,[name,options]);this.location=location;this.features=[];},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadRSS:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.loadURL(this.location,null,this,this.parseData);this.loaded=true;}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadRSS();}},parseData:function(ajaxRequest){var doc=ajaxRequest.responseXML;if(!doc||!doc.documentElement){doc=OpenLayers.Format.XML.prototype.read(ajaxRequest.responseText);}
-if(this.useFeedTitle){var name=null;try{name=doc.getElementsByTagNameNS('*','title')[0].firstChild.nodeValue;}
-catch(e){name=doc.getElementsByTagName('title')[0].firstChild.nodeValue;}
-if(name){this.setName(name);}}
-var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var format=new OpenLayers.Format.GeoRSS(options);var features=format.read(doc);for(var i=0;i<features.length;i++){var data={};var feature=features[i];if(!feature.geometry){continue;}
-var title=feature.attributes.title?feature.attributes.title:"Untitled";var description=feature.attributes.description?feature.attributes.description:"No description.";var link=feature.attributes.link?feature.attributes.link:"";var location=feature.geometry.getBounds().getCenterLonLat();data.icon=this.icon==null?OpenLayers.Marker.defaultIcon():this.icon.clone();data.popupSize=this.popupSize?this.popupSize.clone():new OpenLayers.Size(250,120);if(title||description){var contentHTML='<div class="olLayerGeoRSSClose">[x]</div>';contentHTML+='<div class="olLayerGeoRSSTitle">';if(link){contentHTML+='<a class="link" href="'+link+'" target="_blank">';}
-contentHTML+=title;if(link){contentHTML+='</a>';}
-contentHTML+='</div>';contentHTML+='<div style="" class="olLayerGeoRSSDescription">';contentHTML+=description;contentHTML+='</div>';data['popupContentHTML']=contentHTML;}
-var feature=new OpenLayers.Feature(this,location,data);this.features.push(feature);var marker=feature.createMarker();marker.events.register('click',feature,this.markerClick);this.addMarker(marker);}
-this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0;i<this.layer.map.popups.length;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
-if(!sameMarkerClicked){var popup=this.createPopup();OpenLayers.Event.observe(popup.div,"click",OpenLayers.Function.bind(function(){for(var i=0;i<this.layer.map.popups.length;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}},this));this.layer.map.addPopup(popup);}
-OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.GeoRSS"});OpenLayers.Layer.Google=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:19,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515,0.00000268220901489257],type:null,sphericalMercator:false,dragObject:null,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);this.addContainerPxFunction();if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){try{this.mapObject=new GMap2(this.div);if(typeof this.mapObject.getDragObject=="function"){this.dragObject=this.mapObject.getDragObject();}else{this.dragPanMapObject=null;}
-var poweredBy=this.div.lastChild;this.div.removeChild(poweredBy);this.pane.appendChild(poweredBy);poweredBy.className="olLayerGooglePoweredBy gmnoprint";poweredBy.style.left="";poweredBy.style.bottom="";var termsOfUse=this.div.lastChild;this.div.removeChild(termsOfUse);this.pane.appendChild(termsOfUse);termsOfUse.className="olLayerGoogleCopyright";termsOfUse.style.right="";termsOfUse.style.bottom="";}catch(e){OpenLayers.Console.error(e);}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);if(this.type!=null){this.map.events.register("moveend",this,this.setMapType);}},setMapType:function(){if(this.mapObject.getCenter()!=null){if(OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),this.type)==-1){this.mapObject.addMapType(this.type);}
-this.mapObject.setMapType(this.type);this.map.events.unregister("moveend",this,this.setMapType);}},onMapResize:function(){this.mapObject.checkResize();},getOLBoundsFromMapObjectBounds:function(moBounds){var olBounds=null;if(moBounds!=null){var sw=moBounds.getSouthWest();var ne=moBounds.getNorthEast();if(this.sphericalMercator){sw=this.forwardMercator(sw.lng(),sw.lat());ne=this.forwardMercator(ne.lng(),ne.lat());}else{sw=new OpenLayers.LonLat(sw.lng(),sw.lat());ne=new OpenLayers.LonLat(ne.lng(),ne.lat());}
-olBounds=new OpenLayers.Bounds(sw.lon,sw.lat,ne.lon,ne.lat);}
-return olBounds;},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new GLatLngBounds(new GLatLng(sw.lat,sw.lon),new GLatLng(ne.lat,ne.lon));}
-return moBounds;},addContainerPxFunction:function(){if((typeof GMap2!="undefined")&&!GMap2.prototype.fromLatLngToContainerPixel){GMap2.prototype.fromLatLngToContainerPixel=function(gLatLng){var gPoint=this.fromLatLngToDivPixel(gLatLng);var div=this.getContainer().firstChild.firstChild;gPoint.x+=div.offsetLeft;gPoint.y+=div.offsetTop;return gPoint;};}},getWarningHTML:function(){return OpenLayers.i18n("googleWarning");},setMapObjectCenter:function(center,zoom){this.mapObject.setCenter(center,zoom);},dragPanMapObject:function(dX,dY){this.dragObject.moveBy(new GSize(-dX,dY));},getMapObjectCenter:function(){return this.mapObject.getCenter();},getMapObjectZoom:function(){return this.mapObject.getZoom();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.fromContainerPixelToLatLng(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.fromLatLngToContainerPixel(moLonLat);},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lon:moLonLat.lng();},getLatitudeFromMapObjectLonLat:function(moLonLat){var lat=this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lat:moLonLat.lat();return lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new GLatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new GLatLng(lat,lon);}
-return gLatLng;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new GPoint(x,y);},CLASS_NAME:"OpenLayers.Layer.Google"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,grid:null,singleTile:false,ratio:1.5,buffer:2,numLoadingTiles:0,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0;iRow<this.grid.length;iRow++){var row=this.grid[iRow];for(var iCol=0;iCol<row.length;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
-this.grid=[];}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
-obj.grid=[];return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){this.initSingleTile(bounds);}}else{if(forceReTile||!tilesBounds.containsBounds(bounds,true)){this.initGriddedTiles(bounds);}else{this.moveGriddedTiles(bounds);}}}},setTileSize:function(size){if(this.singleTile){size=this.map.getSize().clone();size.h=parseInt(size.h*this.ratio);size.w=parseInt(size.w*this.ratio);}
-OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[size]);},getGridBounds:function(){var msg="The getGridBounds() function is deprecated. It will be "+"removed in 3.0. Please use getTilesBounds() instead.";OpenLayers.Console.warn(msg);return this.getTilesBounds();},getTilesBounds:function(){var bounds=null;if(this.grid.length){var bottom=this.grid.length-1;var bottomLeftTile=this.grid[bottom][0];var right=this.grid[0].length-1;var topRightTile=this.grid[0][right];bounds=new OpenLayers.Bounds(bottomLeftTile.bounds.left,bottomLeftTile.bounds.bottom,topRightTile.bounds.right,topRightTile.bounds.top);}
-return bounds;},initSingleTile:function(bounds){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var px=this.map.getLayerPxFromLonLat(ul);if(!this.grid.length){this.grid[0]=[];}
-var tile=this.grid[0][0];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);tile.draw();this.grid[0][0]=tile;}else{tile.moveTo(tileBounds,px);}
-this.removeExcessTiles(1,1);},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=bounds.top-(extent.bottom+tilelat);var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-tilerowremain*this.tileSize.h;var tileoffsetlat=extent.bottom+tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},initGriddedTiles:function(bounds){var viewSize=this.map.getSize();var minRows=Math.ceil(viewSize.h/this.tileSize.h)+
-Math.max(1,2*this.buffer);var minCols=Math.ceil(viewSize.w/this.tileSize.w)+
-Math.max(1,2*this.buffer);var extent=this.map.getMaxExtent();var resolution=this.map.getResolution();var tileLayout=this.calculateGridLayout(bounds,extent,resolution);var tileoffsetx=Math.round(tileLayout.tileoffsetx);var tileoffsety=Math.round(tileLayout.tileoffsety);var tileoffsetlon=tileLayout.tileoffsetlon;var tileoffsetlat=tileLayout.tileoffsetlat;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;this.origin=new OpenLayers.Pixel(tileoffsetx,tileoffsety);var startX=tileoffsetx;var startLon=tileoffsetlon;var rowidx=0;var layerContainerDivLeft=parseInt(this.map.layerContainerDiv.style.left);var layerContainerDivTop=parseInt(this.map.layerContainerDiv.style.top);do{var row=this.grid[rowidx++];if(!row){row=[];this.grid.push(row);}
-tileoffsetlon=startLon;tileoffsetx=startX;var colidx=0;do{var tileBounds=new OpenLayers.Bounds(tileoffsetlon,tileoffsetlat,tileoffsetlon+tilelon,tileoffsetlat+tilelat);var x=tileoffsetx;x-=layerContainerDivLeft;var y=tileoffsety;y-=layerContainerDivTop;var px=new OpenLayers.Pixel(x,y);var tile=row[colidx++];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);row.push(tile);}else{tile.moveTo(tileBounds,px,false);}
-tileoffsetlon+=tilelon;tileoffsetx+=this.tileSize.w;}while((tileoffsetlon<=bounds.right+tilelon*this.buffer)||colidx<minCols)
-tileoffsetlat-=tilelat;tileoffsety+=this.tileSize.h;}while((tileoffsetlat>=bounds.bottom-tilelat*this.buffer)||rowidx<minRows)
-this.removeExcessTiles(rowidx,colidx);this.spiralTileLoad();},spiralTileLoad:function(){var tileQueue=[];var directions=["right","down","left","up"];var iRow=0;var iCell=-1;var direction=OpenLayers.Util.indexOf(directions,"right");var directionsTried=0;while(directionsTried<directions.length){var testRow=iRow;var testCell=iCell;switch(directions[direction]){case"right":testCell++;break;case"down":testRow++;break;case"left":testCell--;break;case"up":testRow--;break;}
-var tile=null;if((testRow<this.grid.length)&&(testRow>=0)&&(testCell<this.grid[0].length)&&(testCell>=0)){tile=this.grid[testRow][testCell];}
-if((tile!=null)&&(!tile.queued)){tileQueue.unshift(tile);tile.queued=true;directionsTried=0;iRow=testRow;iCell=testCell;}else{direction=(direction+1)%4;directionsTried++;}}
-for(var i=0;i<tileQueue.length;i++){var tile=tileQueue[i];tile.draw();tile.queued=false;}},addTile:function(bounds,position){},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this.numLoadingTiles==0){this.events.triggerEvent("loadstart");}
-this.numLoadingTiles++;};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded");if(this.numLoadingTiles==0){this.events.triggerEvent("loadend");}};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},moveGriddedTiles:function(bounds){var buffer=this.buffer||1;while(true){var tlLayer=this.grid[0][0].position;var tlViewPort=this.map.getViewPortPxFromLayerPx(tlLayer);if(tlViewPort.x>-this.tileSize.w*(buffer-1)){this.shiftColumn(true);}else if(tlViewPort.x<-this.tileSize.w*buffer){this.shiftColumn(false);}else if(tlViewPort.y>-this.tileSize.h*(buffer-1)){this.shiftRow(true);}else if(tlViewPort.y<-this.tileSize.h*buffer){this.shiftRow(false);}else{break;}};},shiftRow:function(prepend){var modelRowIndex=(prepend)?0:(this.grid.length-1);var grid=this.grid;var modelRow=grid[modelRowIndex];var resolution=this.map.getResolution();var deltaY=(prepend)?-this.tileSize.h:this.tileSize.h;var deltaLat=resolution*-deltaY;var row=(prepend)?grid.pop():grid.shift();for(var i=0;i<modelRow.length;i++){var modelTile=modelRow[i];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.bottom=bounds.bottom+deltaLat;bounds.top=bounds.top+deltaLat;position.y=position.y+deltaY;row[i].moveTo(bounds,position);}
-if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.map.getResolution();var deltaLon=resolution*deltaX;for(var i=0;i<this.grid.length;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){while(this.grid.length>rows){var row=this.grid.pop();for(var i=0,l=row.length;i<l;i++){var tile=row[i];this.removeTileMonitoringHooks(tile);tile.destroy();}}
-while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.map.getMaxExtent();var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
-maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
-maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Layer.MultiMap=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[9,1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();this.RESOLUTIONS.unshift(10);}},loadMapObject:function(){try{this.mapObject=new MultimapViewer(this.div);}catch(e){}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':"MM",'layerLib':"MultiMap"});},setMapObjectCenter:function(center,zoom){this.mapObject.goToPosition(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCurrentPosition();},getMapObjectZoom:function(){return this.mapObject.getZoomFactor();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){moPixel.x=moPixel.x-(this.map.getSize().w/2);moPixel.y=moPixel.y-(this.map.getSize().h/2);return this.mapObject.getMapPositionAt(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.geoPosToContainerPixels(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lon,moLonLat.lat).lon:moLonLat.lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lon,moLonLat.lat).lat:moLonLat.lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var mmLatLon;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);mmLatLon=new MMLatLon(lonlat.lat,lonlat.lon);}else{mmLatLon=new MMLatLon(lat,lon);}
-return mmLatLon;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new MMPoint(x,y);},CLASS_NAME:"OpenLayers.Layer.MultiMap"});OpenLayers.Layer.Text=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);this.features=new Array();},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadText:function(){if(!this.loaded){if(this.location!=null){var onFail=function(e){this.events.triggerEvent("loadend");};this.events.triggerEvent("loadstart");OpenLayers.loadURL(this.location,null,this,this.parseData,onFail);this.loaded=true;}}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadText();}},parseData:function(ajaxRequest){var text=ajaxRequest.responseText;var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var parser=new OpenLayers.Format.Text(options);features=parser.read(text);for(var i=0;i<features.length;i++){var data={};var feature=features[i];var location;var iconSize,iconOffset;location=new OpenLayers.LonLat(feature.geometry.x,feature.geometry.y);if(feature.style.graphicWidth&&feature.style.graphicHeight){iconSize=new OpenLayers.Size(feature.style.graphicWidth,feature.style.graphicHeight);}
-if(feature.style.graphicXOffset&&feature.style.graphicYOffset){iconOffset=new OpenLayers.Pixel(feature.style.graphicXOffset,feature.style.graphicYOffset);}
-if(feature.style.externalGraphic!=null){data.icon=new OpenLayers.Icon(feature.style.externalGraphic,iconSize,iconOffset);}else{data.icon=OpenLayers.Marker.defaultIcon();if(iconSize!=null){data.icon.setSize(iconSize);}}
-if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){data['popupContentHTML']='<h2>'+feature.attributes.title+'</h2>'+'<p>'+feature.attributes.description+'</p>';}
-data['overflow']=feature.attributes.overflow||"auto";var markerFeature=new OpenLayers.Feature(this,location,data);this.features.push(markerFeature);var marker=markerFeature.createMarker();if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){marker.events.register('click',markerFeature,this.markerClick);}
-this.addMarker(marker);}
-if(!sameMarkerClicked){this.layer.map.addPopup(this.createPopup());}
-OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Layer.VirtualEarth=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,sphericalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){var veDiv=OpenLayers.Util.createDiv(this.name);var sz=this.map.getSize();veDiv.style.width=sz.w;veDiv.style.height=sz.h;this.div.appendChild(veDiv);try{this.mapObject=new VEMap(this.name);}catch(e){}
-if(this.mapObject!=null){try{this.mapObject.LoadMap(null,null,this.type,true);this.mapObject.AttachEvent("onmousedown",function(){return true;});}catch(e){}
-this.mapObject.HideDashboard();}
-if(!this.mapObject||!this.mapObject.vemapcontrol||!this.mapObject.vemapcontrol.PanMap||(typeof this.mapObject.vemapcontrol.PanMap!="function")){this.dragPanMapObject=null;}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'VE','layerLib':'VirtualEarth'});},setMapObjectCenter:function(center,zoom){this.mapObject.SetCenterAndZoom(center,zoom);},getMapObjectCenter:function(){return this.mapObject.GetCenter();},dragPanMapObject:function(dX,dY){this.mapObject.vemapcontrol.PanMap(dX,-dY);},getMapObjectZoom:function(){return this.mapObject.GetZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.PixelToLatLong(moPixel.x,moPixel.y);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.LatLongToPixel(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lon:moLonLat.Longitude;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lat:moLonLat.Latitude;},getMapObjectLonLatFromLonLat:function(lon,lat){var veLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);veLatLong=new VELatLong(lonlat.lat,lonlat.lon);}else{veLatLong=new VELatLong(lat,lon);}
-return veLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new Msn.VE.Pixel(x,y);},CLASS_NAME:"OpenLayers.Layer.VirtualEarth"});OpenLayers.Layer.Yahoo=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:15,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,sphericalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject=new YMap(this.div,this.type,size);this.mapObject.disableKeyControls();this.mapObject.disableDragMap();if(!this.mapObject.moveByXY||(typeof this.mapObject.moveByXY!="function")){this.dragPanMapObject=null;}}catch(e){}},onMapResize:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject.resizeTo(size);}catch(e){}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);this.map.events.register("moveend",this,this.fixYahooEventPane);},fixYahooEventPane:function(){var yahooEventPane=OpenLayers.Util.getElement("ygddfdiv");if(yahooEventPane!=null){if(yahooEventPane.parentNode!=null){yahooEventPane.parentNode.removeChild(yahooEventPane);}
-this.map.events.unregister("moveend",this,this.fixYahooEventPane);}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'Yahoo','layerLib':'Yahoo'});},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getOLZoomFromMapObjectZoom.apply(this,[moZoom]);zoom=18-zoom;}
-return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getMapObjectZoomFromOLZoom.apply(this,[olZoom]);zoom=18-zoom;}
-return zoom;},setMapObjectCenter:function(center,zoom){this.mapObject.drawZoomAndCenter(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCenterLatLon();},dragPanMapObject:function(dX,dY){this.mapObject.moveByXY({'x':-dX,'y':dY});},getMapObjectZoom:function(){return this.mapObject.getZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.convertXYLatLon(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.convertLatLonXY(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lon:moLonLat.Lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lat:moLonLat.Lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var yLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);yLatLong=new YGeoPoint(lonlat.lat,lonlat.lon);}else{yLatLong=new YGeoPoint(lat,lon);}
-return yLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new YCoordPoint(x,y);},getMapObjectSizeFromOLSize:function(olSize){return new YSize(olSize.w,olSize.h);},CLASS_NAME:"OpenLayers.Layer.Yahoo"});OpenLayers.Style=OpenLayers.Class({name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,propertyStyles:null,initialize:function(style,options){this.rules=[];this.setDefaultStyle(style||OpenLayers.Feature.Vector.style["default"]);OpenLayers.Util.extend(this,options);},destroy:function(){for(var i=0;i<this.rules.length;i++){this.rules[i].destroy();this.rules[i]=null;}
-this.rules=null;this.defaultStyle=null;},createSymbolizer:function(feature){var style=this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),feature);var rules=this.rules;var rule,context;var elseRules=[];var appliedRules=false;for(var i=0;i<rules.length;i++){rule=rules[i];var applies=rule.evaluate(feature);if(applies){if(rule instanceof OpenLayers.Rule&&rule.elseFilter){elseRules.push(rule);}else{appliedRules=true;this.applySymbolizer(rule,style,feature);}}}
-if(appliedRules==false&&elseRules.length>0){appliedRules=true;for(var i=0;i<elseRules.length;i++){this.applySymbolizer(elseRules[i],style,feature);}}
-if(rules.length>0&&appliedRules==false){style.display="none";}else{style.display="";}
-return style;},applySymbolizer:function(rule,style,feature){var symbolizerPrefix=feature.geometry?this.getSymbolizerPrefix(feature.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];var symbolizer=rule.symbolizer[symbolizerPrefix]||rule.symbolizer;return this.createLiterals(OpenLayers.Util.extend(style,symbolizer),feature);},createLiterals:function(style,feature){var context=this.context||feature.attributes||feature.data;for(var i in this.propertyStyles){style[i]=OpenLayers.Style.createLiteral(style[i],context,feature);}
-return style;},findPropertyStyles:function(){var propertyStyles={};var style=this.defaultStyle;this.addPropertyStyles(propertyStyles,style);var rules=this.rules;var symbolizer,value;for(var i=0;i<rules.length;i++){var symbolizer=rules[i].symbolizer;for(var key in symbolizer){value=symbolizer[key];if(typeof value=="object"){this.addPropertyStyles(propertyStyles,value);}else{this.addPropertyStyles(propertyStyles,symbolizer);break;}}}
-return propertyStyles;},addPropertyStyles:function(propertyStyles,symbolizer){var property;for(var key in symbolizer){property=symbolizer[key];if(typeof property=="string"&&property.match(/\$\{\w+\}/)){propertyStyles[key]=true;}}
-return propertyStyles;},addRules:function(rules){this.rules=this.rules.concat(rules);this.propertyStyles=this.findPropertyStyles();},setDefaultStyle:function(style){this.defaultStyle=style;this.propertyStyles=this.findPropertyStyles();},getSymbolizerPrefix:function(geometry){var prefixes=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0;i<prefixes.length;i++){if(geometry.CLASS_NAME.indexOf(prefixes[i])!=-1){return prefixes[i];}}},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(value,context,feature){if(typeof value=="string"&&value.indexOf("${")!=-1){value=OpenLayers.String.format(value,context,[feature]);value=(isNaN(value)||!value)?value:parseFloat(value);}
-return value;};OpenLayers.Style.SYMBOLIZER_PREFIXES=['Point','Line','Polygon'];OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:true,toggle:true,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,mode:null,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer());this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,100];this.mode=OpenLayers.Control.ModifyFeature.RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(this.deleteCodes instanceof Array)){this.deleteCodes=[this.deleteCodes];}
-var control=this;var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle};this.selectControl=new OpenLayers.Control.SelectFeature(layer,selectOptions);this.layer.events.on({"featureselected":this.selectFeature,"featureunselected":this.unselectFeature,scope:this});var dragOptions={geometryTypes:["OpenLayers.Geometry.Point"],snappingOptions:this.snappingOptions,onStart:function(feature,pixel){control.dragStart.apply(control,[feature,pixel]);},onDrag:function(feature){control.dragVertex.apply(control,[feature]);},onComplete:function(feature){control.dragComplete.apply(control,[feature]);}};this.dragControl=new OpenLayers.Control.DragFeature(layer,dragOptions);var keyboardOptions={keypress:this.handleKeypress};this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,keyboardOptions)};},destroy:function(){this.layer.events.un({"featureselected":this.selectFeature,"featureunselected":this.unselectFeature,scope:this});this.layer=null;this.selectControl.destroy();this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.selectControl.activate()&&this.handlers.keyboard.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.vertices);this.layer.removeFeatures(this.virtualVertices);this.vertices=[];this.dragControl.deactivate();if(this.feature&&this.feature.geometry){this.selectControl.unselect.apply(this.selectControl,[this.feature]);}
-this.selectControl.deactivate();this.handlers.keyboard.deactivate();deactivated=true;}
-return deactivated;},selectFeature:function(object){this.feature=object.feature;this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);this.layer.events.triggerEvent("beforefeaturemodified",{feature:this.feature});},unselectFeature:function(object){this.layer.removeFeatures(this.vertices);this.vertices=[];this.layer.destroyFeatures(this.virtualVertices);this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle]);delete this.dragHandle;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);delete this.radiusHandle;}
-this.feature=null;this.dragControl.deactivate();this.onModificationEnd(object.feature);this.layer.events.triggerEvent("afterfeaturemodified",{feature:object.feature});},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
-if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){this.selectControl.clickFeature.apply(this.selectControl,[feature]);this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}}},dragVertex:function(vertex){if(this.feature.geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){if(this.feature!=vertex){this.feature=vertex;}}else{if(vertex._index){vertex.geometry.parent.addComponent(vertex.geometry,vertex._index);delete vertex._index;OpenLayers.Util.removeItem(this.virtualVertices,vertex);this.vertices.push(vertex);}else if(vertex==this.dragHandle){this.layer.removeFeatures(this.vertices);this.vertices=[];if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);this.radiusHandle=null;}}
-if(this.virtualVertices.length>0){this.layer.destroyFeatures(this.virtualVertices);this.virtualVertices=[];}
-this.layer.drawFeature(this.feature,this.selectControl.renderIntent);}
-this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},resetVertices:function(){if(this.dragControl.feature){this.dragControl.outFeature(this.dragControl.feature);}
-if(this.vertices.length>0){this.layer.removeFeatures(this.vertices);this.vertices=[];}
-if(this.virtualVertices.length>0){this.layer.removeFeatures(this.virtualVertices);this.virtualVertices=[];}
-if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle]);this.dragHandle=null;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);this.radiusHandle=null;}
-if(this.feature&&this.feature.geometry.CLASS_NAME!="OpenLayers.Geometry.Point"){if((this.mode&OpenLayers.Control.ModifyFeature.DRAG)){this.collectDragHandle();}
-if((this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE))){this.collectRadiusHandle();}
-if((this.mode&OpenLayers.Control.ModifyFeature.RESHAPE)){this.collectVertices();}}},handleKeypress:function(code){if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.drawFeature(this.feature,this.selectControl.renderIntent);this.resetVertices();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i,vertex,component;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
-for(i=0;i<numVert;++i){component=geometry.components[i];if(component.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(component);control.vertices.push(vertex);}else{collectComponentVertices(component);}}
-if(geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0;i<geometry.components.length-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;control.virtualVertices.push(point);}}}}}
-collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.vertices,{silent:true});this.layer.addFeatures(this.virtualVertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};this.dragHandle=origin;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.Feature.Vector(radiusGeometry);var resize=(this.mode&OpenLayers.Control.ModifyFeature.RESIZE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
-if(resize){var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));geometry.resize(l1/l0,originGeometry);}};this.radiusHandle=radius;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,zoomBox:null,zoomWheelEnabled:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
-this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
-this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
-this.handlers.click.activate();this.zoomBox.activate();return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){this.handlers.click=new OpenLayers.Handler.Click(this,{'dblclick':this.defaultDblClick},{'double':true,'stopDouble':true});this.dragPan=new OpenLayers.Control.DragPan({map:this.map});this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:OpenLayers.Handler.MOD_SHIFT});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown});this.activate();},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},wheelChange:function(evt,deltaZ){var newZoom=this.map.getZoom()+deltaZ;if(!this.map.isValidZoomLevel(newZoom)){return;}
-var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt){this.wheelChange(evt,1);},wheelDown:function(evt){this.wheelChange(evt,-1);},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
-return this.bounds;},calculateBounds:function(){},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;var bounds=this.getBounds();if((bounds!=null)&&(lonlat!=null)){var dX=(toleranceLon!=null)?toleranceLon:0;var dY=(toleranceLat!=null)?toleranceLat:0;var toleranceBounds=new OpenLayers.Bounds(this.bounds.left-dX,this.bounds.bottom-dY,this.bounds.right+dX,this.bounds.top+dY);atPoint=toleranceBounds.containsLonLat(lonlat);}
-return atPoint;},getLength:function(){return 0.0;},getArea:function(){return 0.0;},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this));},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.segmentsIntersect=function(seg1,seg2,point){var intersection=false;var x11_21=seg1.x1-seg2.x1;var y11_21=seg1.y1-seg2.y1;var x12_11=seg1.x2-seg1.x1;var y12_11=seg1.y2-seg1.y1;var y22_21=seg2.y2-seg2.y1;var x22_21=seg2.x2-seg2.x1;var d=(y22_21*x12_11)-(x22_21*y12_11);var n1=(x22_21*y11_21)-(y22_21*x11_21);var n2=(x12_11*y11_21)-(y12_11*x11_21);if(d==0){if(n1==0&&n2==0){intersection=true;}}else{var along1=n1/d;var along2=n2/d;if(along1>=0&&along1<=1&&along2>=0&&along2<=1){if(!point){intersection=true;}else{var x=seg1.x1+(along1*x12_11);var y=seg1.y1+(along1*y12_11);intersection=new OpenLayers.Geometry.Point(x,y);}}}
-return intersection;};OpenLayers.Layer.KaMap=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,units:null,resolution:OpenLayers.DOTS_PER_INCH,DEFAULT_PARAMS:{i:'jpeg',map:''},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=(params?params:{});if(params){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);return this.getFullRequestString({t:pY,l:pX,s:scale});},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=tilecol*tilelon;var offsetlat=bounds.top;var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-(tilerowremain+1)*this.tileSize.h;var tileoffsetlat=tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.KaMap(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
-obj.grid=[];return obj;},getTileBounds:function(viewPortPx){var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=tileMapWidth*Math.floor(mapPoint.lon/tileMapWidth);var tileBottom=tileMapHeight*Math.floor(mapPoint.lat/tileMapHeight);return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.KaMap"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,singleTile:false,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},defaultSize:new OpenLayers.Size(300,300),initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.transparent!=true));}
-if(this.singleTile){OpenLayers.Util.applyDefaults(this.params,this.SINGLE_TILE_PARAMS);}else{OpenLayers.Util.applyDefaults(this.params,this.TILE_PARAMS);this.setTileSize(this.defaultSize);}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapGuide(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){var url;var center=bounds.getCenterLonLat();var mapSize=this.map.getCurrentSize();if(this.singleTile){var params={};params.setdisplaydpi=OpenLayers.DOTS_PER_INCH;params.setdisplayheight=mapSize.h*this.ratio;params.setdisplaywidth=mapSize.w*this.ratio;params.setviewcenterx=center.lon;params.setviewcentery=center.lat;params.setviewscale=this.map.getScale();if(!this.isBaseLayer){this.params.operation="GETDYNAMICMAPOVERLAYIMAGE";var getVisParams={};getVisParams.operation="GETVISIBLEMAPEXTENT";getVisParams.version="1.0.0";getVisParams.session=this.params.session;getVisParams.mapName=this.params.mapName;getVisParams.format='text/xml';getVisParams=OpenLayers.Util.extend(getVisParams,params);new OpenLayers.Ajax.Request(this.url,{parameters:getVisParams,method:'get',asynchronous:false});}
-url=this.getFullRequestString(params);}else{var currentRes=this.map.getResolution();var colidx=Math.floor((bounds.left-this.maxExtent.left)/currentRes);colidx=Math.round(colidx/this.tileSize.w);var rowidx=Math.floor((this.maxExtent.top-bounds.top)/currentRes);rowidx=Math.round(rowidx/this.tileSize.h);url=this.getFullRequestString({tilecol:colidx,tilerow:rowidx,scaleindex:this.resolutions.length-this.map.zoom-1});}
-return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;if(typeof url=="object"){url=url[Math.floor(Math.random()*url.length)];}
-var requestString=url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getArgs(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
-var paramsString=OpenLayers.Util.getParameterString(allParams);paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=extent.top-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=extent.top-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);if(arguments.length>0){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}
-if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="true")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var extent=[bounds.left,bounds.bottom,bounds.right,bounds.top];var imageSize=this.getImageSize();var url=this.getFullRequestString({mapext:extent,imgext:extent,map_size:[imageSize.w,imageSize.h],imgx:imageSize.w/2,imgy:imageSize.h/2,imgxy:[imageSize.w,imageSize.h]});return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
-var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
-paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",isBaseLayer:true,tileOrigin:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.map.getZoom();var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
-return url+path;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Layer.TileCache=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,tileOrigin:null,format:'image/png',initialize:function(name,url,layername,options){this.layername=layername;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,{},options]);this.extension=this.format.split('/')[1].toLowerCase();this.extension=(this.extension=='jpg')?'jpeg':this.extension;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TileCache(this.name,this.url,this.layername,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var res=this.map.getResolution();var bbox=this.maxExtent;var size=this.tileSize;var tileX=Math.round((bounds.left-bbox.left)/(res*size.w));var tileY=Math.round((bounds.bottom-bbox.bottom)/(res*size.h));var tileZ=this.map.zoom;function zeroPad(number,length){number=String(number);var zeros=[];for(var i=0;i<length;++i){zeros.push('0');}
-return zeros.join('').substring(0,length-number.length)+number;}
-var components=[this.layername,zeroPad(tileZ,2),zeroPad(parseInt(tileX/1000000),3),zeroPad((parseInt(tileX/1000)%1000),3),zeroPad((parseInt(tileX)%1000),3),zeroPad(parseInt(tileY/1000000),3),zeroPad((parseInt(tileY/1000)%1000),3),zeroPad((parseInt(tileY)%1000),3)+'.'+this.extension];var path=components.join('/');var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
-url=(url.charAt(url.length-1)=='/')?url:url+'/';return url+path;},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TileCache"});OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",exceptions:"application/vnd.ogc.se_inimage",format:"image/jpeg"},reproject:false,isBaseLayer:true,encodeBBOX:false,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
-if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={'BBOX':this.encodeBBOX?bounds.toBBOX():bounds.toArray(),'WIDTH':imageSize.w,'HEIGHT':imageSize.h};var requestString=this.getFullRequestString(newParams);return requestString;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var projectionCode=this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:true,lzd:null,zoomLevels:null,initialize:function(name,url,lzd,zoomLevels,params,options){this.lzd=lzd;this.zoomLevels=zoomLevels;var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=(params?params:{});if(params){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getZoom:function(){var zoom=this.map.getZoom();var extent=this.map.getMaxExtent();zoom=zoom-Math.log(this.maxResolution/(this.lzd/512))/Math.log(2);return zoom;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var zoom=this.getZoom();var extent=this.map.getMaxExtent();var deg=this.lzd/Math.pow(2,this.getZoom());var x=Math.floor((bounds.left-extent.left)/deg);var y=Math.floor((bounds.bottom-extent.bottom)/deg);if(this.map.getResolution()<=(this.lzd/512)&&this.getZoom()<=this.zoomLevels){return this.getFullRequestString({L:zoom,X:x,Y:y});}else{return OpenLayers.Util.getImagesLocation()+"blank.gif";}},CLASS_NAME:"OpenLayers.Layer.WorldWind"});OpenLayers.Rule=OpenLayers.Class({id:null,name:'default',title:null,description:null,context:null,filter:null,elseFilter:false,symbolizer:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(options){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.symbolizer={};OpenLayers.Util.extend(this,options);},destroy:function(){for(var i in this.symbolizer){this.symbolizer[i]=null;}
-this.symbolizer=null;},evaluate:function(feature){var context=this.getContext(feature);var applies=true;if(this.minScaleDenominator||this.maxScaleDenominator){var scale=feature.layer.map.getScale();}
-if(this.minScaleDenominator){applies=scale>=OpenLayers.Style.createLiteral(this.minScaleDenominator,context);}
-if(applies&&this.maxScaleDenominator){applies=scale<OpenLayers.Style.createLiteral(this.maxScaleDenominator,context);}
-if(applies&&this.filter){if(this.filter.CLASS_NAME=="OpenLayers.Filter.FeatureId"){applies=this.filter.evaluate(feature);}else{applies=this.filter.evaluate(context);}}
-return applies;},getContext:function(feature){var context=this.context;if(!context){context=feature.attributes||feature.data;}
-return context;},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"])};if(style instanceof OpenLayers.Style){this.styles["default"]=style;this.styles["select"]=style;this.styles["temporary"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles[key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temporary"]=new OpenLayers.Style(style);break;}}}
-OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
-this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
-if(!this.styles[intent]){intent="default";}
-feature.renderIntent=intent;var defaultSymbolizer={};if(this.extendDefault&&intent!="default"){defaultSymbolizer=this.styles["default"].createSymbolizer(feature);}
-return OpenLayers.Util.extend(defaultSymbolizer,this.styles[intent].createSymbolizer(feature));},addUniqueValueRules:function(renderIntent,property,symbolizers){var rules=[];for(var value in symbolizers){rules.push(new OpenLayers.Rule({symbolizer:symbolizers[value],filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:property,value:value})}));}
-this.styles[renderIntent].addRules(rules);},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation(),new OpenLayers.Control.ZoomBox()]);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.NavToolbar"});OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,lowerBoundary:null,upperBoundary:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(context){switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:case OpenLayers.Filter.Comparison.LESS_THAN:case OpenLayers.Filter.Comparison.GREATER_THAN:case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:return this.binaryCompare(context,this.property,this.value);case OpenLayers.Filter.Comparison.BETWEEN:var result=context[this.property]>=this.lowerBoundary;result=result&&context[this.property]<=this.upperBoundary;return result;case OpenLayers.Filter.Comparison.LIKE:var regexp=new RegExp(this.value,"gi");return regexp.test(context[this.property]);}},value2regex:function(wildCard,singleChar,escapeChar){if(wildCard=="."){var msg="'.' is an unsupported wildCard character for "+"OpenLayers.Filter.Comparison";OpenLayers.Console.error(msg);return null;}
-wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar,"g"),"\\");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},binaryCompare:function(context,property,value){switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:return context[property]==value;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:return context[property]!=value;case OpenLayers.Filter.Comparison.LESS_THAN:return context[property]<value;case OpenLayers.Filter.Comparison.GREATER_THAN:return context[property]>value;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:return context[property]<=value;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:return context[property]>=value;}},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_EQUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,initialize:function(options){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){for(var i=0;i<this.fids.length;i++){var fid=feature.fid||feature.id;if(fid==this.fids[i]){return true;}}
-return false;},CLASS_NAME:"OpenLayers.Filter.FeatureId"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(options){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this);},evaluate:function(context){switch(this.type){case OpenLayers.Filter.Logical.AND:for(var i=0;i<this.filters.length;i++){if(this.filters[i].evaluate(context)==false){return false;}}
-return true;case OpenLayers.Filter.Logical.OR:for(var i=0;i<this.filters.length;i++){if(this.filters[i].evaluate(context)==true){return true;}}
-return false;case OpenLayers.Filter.Logical.NOT:return(!this.filters[0].evaluate(context));}},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(components){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];if(components!=null){this.addComponents(components);}},destroy:function(){this.components.length=0;this.components=null;},clone:function(){var geometry=eval("new "+this.CLASS_NAME+"()");for(var i=0;i<this.components.length;i++){geometry.addComponent(this.components[i].clone());}
-OpenLayers.Util.applyDefaults(geometry,this);return geometry;},getComponentsString:function(){var strings=[];for(var i=0;i<this.components.length;i++){strings.push(this.components[i].toShortString());}
-return strings.join(",");},calculateBounds:function(){this.bounds=null;if(this.components&&this.components.length>0){this.setBounds(this.components[0].getBounds());for(var i=1;i<this.components.length;i++){this.extendBounds(this.components[i].getBounds());}}},addComponents:function(components){if(!(components instanceof Array)){components=[components];}
-for(var i=0;i<components.length;i++){this.addComponent(components[i]);}},addComponent:function(component,index){var added=false;if(component){if(this.componentTypes==null||(OpenLayers.Util.indexOf(this.componentTypes,component.CLASS_NAME)>-1)){if(index!=null&&(index<this.components.length)){var components1=this.components.slice(0,index);var components2=this.components.slice(index,this.components.length);components1.push(component);this.components=components1.concat(components2);}else{this.components.push(component);}
-component.parent=this;this.clearBounds();added=true;}}
-return added;},removeComponents:function(components){if(!(components instanceof Array)){components=[components];}
-for(var i=components.length-1;i>=0;--i){this.removeComponent(components[i]);}},removeComponent:function(component){OpenLayers.Util.removeItem(this.components,component);this.clearBounds();},getLength:function(){var length=0.0;for(var i=0;i<this.components.length;i++){length+=this.components[i].getLength();}
-return length;},getArea:function(){var area=0.0;for(var i=0;i<this.components.length;i++){area+=this.components[i].getArea();}
-return area;},move:function(x,y){for(var i=0;i<this.components.length;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0;i<this.components.length;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length;++i){this.components[i].resize(scale,origin,ratio);}},equals:function(geometry){var equivalent=true;if(!geometry||!geometry.CLASS_NAME||(this.CLASS_NAME!=geometry.CLASS_NAME)){equivalent=false;}else if(!(geometry.components instanceof Array)||(geometry.components.length!=this.components.length)){equivalent=false;}else{for(var i=0;i<this.components.length;++i){if(!this.components[i].equals(geometry.components[i])){equivalent=false;break;}}}
-return equivalent;},transform:function(source,dest){if(source&&dest){for(var i=0;i<this.components.length;i++){var component=this.components[i];component.transform(source,dest);}}
-return this;},intersects:function(geometry){var intersect=false;for(var i=0;i<this.components.length;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
-return intersect;},CLASS_NAME:"OpenLayers.Geometry.Collection"});OpenLayers.Geometry.Point=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,initialize:function(x,y){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=parseFloat(x);this.y=parseFloat(y);},clone:function(obj){if(obj==null){obj=new OpenLayers.Geometry.Point(this.x,this.y);}
-OpenLayers.Util.applyDefaults(obj,this);return obj;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x,this.y);},distanceTo:function(point){var distance=0.0;if((this.x!=null)&&(this.y!=null)&&(point!=null)&&(point.x!=null)&&(point.y!=null)){var dx2=Math.pow(this.x-point.x,2);var dy2=Math.pow(this.y-point.y,2);distance=Math.sqrt(dx2+dy2);}
-return distance;},equals:function(geom){var equals=false;if(geom!=null){equals=((this.x==geom.x&&this.y==geom.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(geom.x)&&isNaN(geom.y)));}
-return equals;},toShortString:function(){return(this.x+", "+this.y);},move:function(x,y){this.x=this.x+x;this.y=this.y+y;this.clearBounds();},rotate:function(angle,origin){angle*=Math.PI/180;var radius=this.distanceTo(origin);var theta=angle+Math.atan2(this.y-origin.y,this.x-origin.x);this.x=origin.x+(radius*Math.cos(theta));this.y=origin.y+(radius*Math.sin(theta));this.clearBounds();},resize:function(scale,origin,ratio){ratio=(ratio==undefined)?1:ratio;this.x=origin.x+(scale*ratio*(this.x-origin.x));this.y=origin.y+(scale*(this.y-origin.y));this.clearBounds();},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.equals(geometry);}else{intersect=geometry.intersects(this);}
-return intersect;},transform:function(source,dest){if((source&&dest)){OpenLayers.Projection.transform(this,source,dest);}
-return this;},CLASS_NAME:"OpenLayers.Geometry.Point"});OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(x,y,width,height){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=x;this.y=y;this.width=width;this.height=height;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height);},getLength:function(){var length=(2*this.width)+(2*this.height);return length;},getArea:function(){var area=this.width*this.height;return area;},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});OpenLayers.Geometry.Surface=OpenLayers.Class(OpenLayers.Geometry,{initialize:function(){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.Surface"});OpenLayers.Layer.MapServer.Untiled=OpenLayers.Class(OpenLayers.Layer.MapServer,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.MapServer.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.MapServer.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.MapServer class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer.Untiled(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.MapServer.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.MapServer.Untiled"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{EVENT_TYPES:["beforefeatureadded","featureadded","featuresadded","featureselected","featureunselected","beforefeaturemodified","featuremodified","afterfeaturemodified"],isBaseLayer:false,isFixed:false,isVector:true,features:null,selectedFeatures:null,reportError:true,style:null,styleMap:null,renderers:['SVG','VML'],renderer:null,geometryType:null,drawn:false,initialize:function(name,options){this.EVENT_TYPES=OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(OpenLayers.Layer.prototype.EVENT_TYPES);OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
-if(!this.renderer||!this.renderer.supported()){this.renderer=null;this.displayError();}
-if(!this.styleMap){this.styleMap=new OpenLayers.StyleMap();}
-this.features=[];this.selectedFeatures=[];},destroy:function(){OpenLayers.Layer.prototype.destroy.apply(this,arguments);this.destroyFeatures();this.features=null;this.selectedFeatures=null;if(this.renderer){this.renderer.destroy();}
-this.renderer=null;this.geometryType=null;this.drawn=null;},assignRenderer:function(){for(var i=0;i<this.renderers.length;i++){var rendererClass=OpenLayers.Renderer[this.renderers[i]];if(rendererClass&&rendererClass.prototype.supported()){this.renderer=new rendererClass(this.div);break;}}},displayError:function(){if(this.reportError){alert(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(!dragging){this.renderer.root.style.visibility="hidden";if(navigator.userAgent.toLowerCase().indexOf("gecko")!=-1){this.div.scrollLeft=this.div.scrollLeft;}
-this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();this.renderer.setExtent(extent);this.renderer.root.style.visibility="visible";}
-if(!this.drawn||zoomChanged){this.drawn=true;for(var i=0;i<this.features.length;i++){var feature=this.features[i];this.drawFeature(feature);}}},addFeatures:function(features,options){if(!(features instanceof Array)){features=[features];}
-var notify=!options||!options.silent;for(var i=0;i<features.length;i++){var feature=features[i];if(this.geometryType&&!(feature.geometry instanceof this.geometryType)){var throwStr=OpenLayers.i18n('componentShouldBe',{'geomType':this.geometryType.prototype.CLASS_NAME});throw throwStr;}
-this.features.push(feature);feature.layer=this;if(!feature.style&&this.style){feature.style=OpenLayers.Util.extend({},this.style);}
-if(notify){this.events.triggerEvent("beforefeatureadded",{feature:feature});this.preFeatureInsert(feature);}
-if(this.drawn){this.drawFeature(feature);}
-if(notify){this.events.triggerEvent("featureadded",{feature:feature});this.onFeatureInsert(feature);}}
-if(notify){this.events.triggerEvent("featuresadded",{features:features});}},removeFeatures:function(features){if(!(features instanceof Array)){features=[features];}
-for(var i=features.length-1;i>=0;i--){var feature=features[i];this.features=OpenLayers.Util.removeItem(this.features,feature);if(feature.geometry){this.renderer.eraseGeometry(feature.geometry);}
-if(OpenLayers.Util.indexOf(this.selectedFeatures,feature)!=-1){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}}},destroyFeatures:function(features){var all=(features==undefined);if(all){features=this.features;this.selectedFeatures=[];}
-this.eraseFeatures(features);var feature;for(var i=features.length-1;i>=0;i--){feature=features[i];if(!all){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}
-feature.destroy();}},drawFeature:function(feature,style){if(typeof style!="object"){var renderIntent=typeof style=="string"?style:feature.renderIntent;style=feature.style||this.style;if(!style){style=this.styleMap.createSymbolizer(feature,renderIntent);}}
-this.renderer.drawFeature(feature,style);},eraseFeatures:function(features){this.renderer.eraseFeatures(features);},getFeatureFromEvent:function(evt){if(!this.renderer){OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));return null;}
-var featureId=this.renderer.getFeatureIdFromEvent(evt);return this.getFeatureById(featureId);},getFeatureById:function(featureId){var feature=null;for(var i=0;i<this.features.length;++i){if(this.features[i].id==featureId){feature=this.features[i];break;}}
-return feature;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.WMS.Untiled=OpenLayers.Class(OpenLayers.Layer.WMS,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.WMS.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.WMS.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.WMS class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS.Untiled(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.WMS.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.WMS.Untiled"});OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(sld,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
-version;}
-this.parser=new format(this.options);}
-var root=this.parser.write(sld);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
-version;}
-var sld=this.parser.read(data);return sld;},CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Text=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(text){var lines=text.split('\n');var columns;var features=[];for(var lcv=0;lcv<(lines.length-1);lcv++){var currLine=lines[lcv].replace(/^\s*/,'').replace(/\s*$/,'');if(currLine.charAt(0)!='#'){if(!columns){columns=currLine.split('\t');}else{var vals=currLine.split('\t');var geometry=new OpenLayers.Geometry.Point(0,0);var attributes={};var style={};var icon,iconSize,iconOffset,overflow;var set=false;for(var valIndex=0;valIndex<vals.length;valIndex++){if(vals[valIndex]){if(columns[valIndex]=='point'){var coords=vals[valIndex].split(',');geometry.y=parseFloat(coords[0]);geometry.x=parseFloat(coords[1]);set=true;}else if(columns[valIndex]=='lat'){geometry.y=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='lon'){geometry.x=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='title')
-attributes['title']=vals[valIndex];else if(columns[valIndex]=='image'||columns[valIndex]=='icon')
-style['externalGraphic']=vals[valIndex];else if(columns[valIndex]=='iconSize'){var size=vals[valIndex].split(',');style['graphicWidth']=parseFloat(size[0]);style['graphicHeight']=parseFloat(size[1]);}else if(columns[valIndex]=='iconOffset'){var offset=vals[valIndex].split(',');style['graphicXOffset']=parseFloat(offset[0]);style['graphicYOffset']=parseFloat(offset[1]);}else if(columns[valIndex]=='description'){attributes['description']=vals[valIndex];}else if(columns[valIndex]=='overflow'){attributes['overflow']=vals[valIndex];}}}
-if(set){if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes,style);features.push(feature);}}}}
-return features;},CLASS_NAME:"OpenLayers.Format.Text"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},addPoint:function(point,index){this.addComponent(point,index);},removePoint:function(point){this.removeComponent(point);},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1;i<this.components.length;i++){area-=Math.abs(this.components[i].getArea());}}
-return area;},containsPoint:function(point){var numRings=this.components.length;var contained=false;if(numRings>0){contained=this.components[0].containsPoint(point);if(contained!==1){if(contained&&numRings>1){var hole;for(var i=1;i<numRings;++i){hole=this.components[i].containsPoint(point);if(hole){if(hole===1){contained=1;}else{contained=false;}
-break;}}}}}
-return contained;},intersects:function(geometry){var intersect=false;var i;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"||geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){for(i=0;i<this.components.length;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
-if(!intersect){for(i=0;i<geometry.components.length;++i){intersect=this.containsPoint(geometry.components[i]);if(intersect){break;}}}}else{for(i=0;i<geometry.components.length;++i){intersect=this.intersects(geometry.components[i]);if(intersect){break;}}}
-if(!intersect&&geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){var ring=this.components[0];for(i=0;i<ring.components.length;++i){intersect=geometry.containsPoint(ring.components[i]);if(intersect){break;}}}
-return intersect;},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(origin,radius,sides,rotation){var angle=Math.PI*((1/sides)-(1/2));if(rotation){angle+=(rotation/180)*Math.PI;}
-var rotatedAngle,x,y;var points=[];for(var i=0;i<sides;++i){rotatedAngle=angle+(i*2*Math.PI/sides);x=origin.x+(radius*Math.cos(rotatedAngle));y=origin.y+(radius*Math.sin(rotatedAngle));points.push(new OpenLayers.Geometry.Point(x,y));}
-var ring=new OpenLayers.Geometry.LinearRing(points);return new OpenLayers.Geometry.Polygon([ring]);};OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,drawing:false,mouseDown:false,lastDown:null,lastUp:null,initialize:function(control,callbacks,options){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
-var options={displayInLayerSwitcher:false,calculateInRange:function(){return true;}};this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(){this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
-if(this.drawing){this.cancel();}
-if(this.layer.map!=null){this.layer.destroy(false);}
-this.layer=null;return true;},destroyFeature:function(){if(this.point){this.point.destroy();}
-this.point=null;},finalize:function(){this.layer.renderer.clear();this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.callback("done",[this.geometryClone()]);this.destroyFeature();},cancel:function(){this.layer.renderer.clear();this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.callback("cancel",[this.geometryClone()]);this.destroyFeature();},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.point.geometry.clone();},mousedown:function(evt){if(!this.checkModifiers(evt)){return true;}
-if(this.lastDown&&this.lastDown.equals(evt.xy)){return true;}
-if(this.lastDown==null){this.createFeature();}
-this.lastDown=evt.xy;this.drawing=true;var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.drawFeature();return false;},mousemove:function(evt){if(this.drawing){var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.point.geometry.clearBounds();this.drawFeature();}
-return true;},mouseup:function(evt){if(this.drawing){this.finalize();return false;}else{return true;}},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Layer.GML=OpenLayers.Class(OpenLayers.Layer.Vector,{loaded:false,format:null,formatOptions:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);this.url=url;},setVisibility:function(visibility,noEvent){OpenLayers.Layer.Vector.prototype.setVisibility.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadGML();}},loadGML:function(){if(!this.loaded){var results=OpenLayers.loadURL(this.url,null,this,this.requestSuccess,this.requestFailure);this.loaded=true;}},setUrl:function(url){this.url=url;this.destroyFeatures();this.loaded=false;this.events.triggerEvent("loadstart");this.loadGML();},requestSuccess:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var gml=this.format?new this.format(options):new OpenLayers.Format.GML(options);this.addFeatures(gml.read(doc));this.events.triggerEvent("loadend");},requestFailure:function(request){alert(OpenLayers.i18n("errorLoadingGML",{'url':this.url}));this.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Layer.GML"});OpenLayers.Layer.PointTrack=OpenLayers.Class(OpenLayers.Layer.Vector,{dataFrom:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},addNodes:function(pointFeatures){if(pointFeatures.length<2){OpenLayers.Console.error("At least two point features have to be added to create"+"a line from");return;}
-var lines=new Array(pointFeatures.length-1);var pointFeature,startPoint,endPoint;for(var i=0;i<pointFeatures.length;i++){pointFeature=pointFeatures[i];endPoint=pointFeature.geometry;if(!endPoint){var lonlat=pointFeature.lonlat;endPoint=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else if(endPoint.CLASS_NAME!="OpenLayers.Geometry.Point"){OpenLayers.Console.error("Only features with point geometries are supported.");return;}
-if(i>0){var attributes=(this.dataFrom!=null)?(pointFeatures[i+this.dataFrom].data||pointFeatures[i+this.dataFrom].attributes):null;var line=new OpenLayers.Geometry.LineString([startPoint,endPoint]);lines[i-1]=new OpenLayers.Feature.Vector(line,attributes);}
-startPoint=endPoint;}
-this.addFeatures(lines);},CLASS_NAME:"OpenLayers.Layer.PointTrack"});OpenLayers.Layer.PointTrack.dataFrom={'SOURCE_NODE':-1,'TARGET_NODE':0};OpenLayers.Layer.WFS=OpenLayers.Class(OpenLayers.Layer.Vector,OpenLayers.Layer.Markers,{isBaseLayer:false,tile:null,ratio:2,DEFAULT_PARAMS:{service:"WFS",version:"1.0.0",request:"GetFeature"},featureClass:null,format:null,formatObject:null,formatOptions:null,vectorMode:true,encodeBBOX:false,extractAttributes:false,initialize:function(name,url,params,options){if(options==undefined){options={};}
-if(options.featureClass||!OpenLayers.Layer.Vector||!OpenLayers.Feature.Vector){this.vectorMode=false;}
-OpenLayers.Util.extend(options,{'reportError':false});var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);if(!this.renderer||!this.vectorMode){this.vectorMode=false;if(!options.featureClass){options.featureClass=OpenLayers.Feature.WFS;}
-OpenLayers.Layer.Markers.prototype.initialize.apply(this,newArguments);}
-if(this.params&&this.params.typename&&!this.options.typename){this.options.typename=this.params.typename;}
-if(!this.options.geometry_column){this.options.geometry_column="the_geom";}
-this.params=params;OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));this.url=url;},destroy:function(){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.destroy.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);}
-if(this.tile){this.tile.destroy();}
-this.tile=null;this.ratio=null;this.featureClass=null;this.format=null;if(this.formatObject&&this.formatObject.destroy){this.formatObject.destroy();}
-this.formatObject=null;this.formatOptions=null;this.vectorMode=null;this.encodeBBOX=null;this.extractAttributes=null;},setMap:function(map){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);var options={'extractAttributes':this.extractAttributes};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-this.formatObject=this.format?new this.format(options):new OpenLayers.Format.GML(options);}else{OpenLayers.Layer.Markers.prototype.setMap.apply(this,arguments);}},moveTo:function(bounds,zoomChanged,dragging){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);}
-if(dragging){return false;}
-if(zoomChanged){if(this.vectorMode){this.renderer.clear();}}
-if(this.options.minZoomLevel){OpenLayers.Console.warn(OpenLayers.i18n('minZoomLevelError'));if(this.map.getZoom()<this.options.minZoomLevel){return null;}}
-if(bounds==null){bounds=this.map.getExtent();}
-var firstRendering=(this.tile==null);var outOfBounds=(!firstRendering&&!this.tile.bounds.containsBounds(bounds));if(zoomChanged||firstRendering||(!dragging&&outOfBounds)){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var tileSize=this.map.getSize();tileSize.w=tileSize.w*this.ratio;tileSize.h=tileSize.h*this.ratio;var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var pos=this.map.getLayerPxFromLonLat(ul);var url=this.getFullRequestString();var params={BBOX:this.encodeBBOX?tileBounds.toBBOX():tileBounds.toArray()};if(this.map&&!this.projection.equals(this.map.getProjectionObject())){var projectedBounds=tileBounds.clone();projectedBounds.transform(this.map.getProjectionObject(),this.projection);params.BBOX=this.encodeBBOX?projectedBounds.toBBOX():projectedBounds.toArray();}
-url+="&"+OpenLayers.Util.getParameterString(params);if(!this.tile){this.tile=new OpenLayers.Tile.WFS(this,pos,tileBounds,url,tileSize);this.addTileMonitoringHooks(this.tile);this.tile.draw();}else{if(this.vectorMode){this.destroyFeatures();this.renderer.clear();}else{this.clearMarkers();}
-this.removeTileMonitoringHooks(this.tile);this.tile.destroy();this.tile=null;this.tile=new OpenLayers.Tile.WFS(this,pos,tileBounds,url,tileSize);this.addTileMonitoringHooks(this.tile);this.tile.draw();}}},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this==this.layer.tile){this.layer.events.triggerEvent("loadstart");}};tile.events.register("loadstart",tile,tile.onLoadStart);tile.onLoadEnd=function(){if(this==this.layer.tile){this.layer.events.triggerEvent("tileloaded");this.layer.events.triggerEvent("loadend");}};tile.events.register("loadend",tile,tile.onLoadEnd);tile.events.register("unload",tile,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:tile});},onMapResize:function(){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.onMapResize.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.onMapResize.apply(this,arguments);}},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.HTTPRequest.prototype.mergeNewParams.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WFS(this.name,this.url,this.params,this.options);}
-if(this.vectorMode){obj=OpenLayers.Layer.Vector.prototype.clone.apply(this,[obj]);}else{obj=OpenLayers.Layer.Markers.prototype.clone.apply(this,[obj]);}
-return obj;},getFullRequestString:function(newParams,altUrl){var projectionCode=this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},commit:function(){if(!this.writer){var options={};if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-this.writer=new OpenLayers.Format.WFS(options,this);}
-var data=this.writer.write(this.features);var url=this.url;var success=OpenLayers.Function.bind(this.commitSuccess,this);var failure=OpenLayers.Function.bind(this.commitFailure,this);new OpenLayers.Ajax.Request(url,{method:'post',postBody:data,onComplete:success,onFailure:failure});},commitSuccess:function(request){var response=request.responseText;if(response.indexOf('SUCCESS')!=-1){this.commitReport(OpenLayers.i18n("commitSuccess",{'response':response}));for(var i=0;i<this.features.length;i++){this.features[i].state=null;}}else if(response.indexOf('FAILED')!=-1||response.indexOf('Exception')!=-1){this.commitReport(OpenLayers.i18n("commitFailed",{'response':response}));}},commitFailure:function(request){},commitReport:function(string,response){alert(string);},refresh:function(){if(this.tile){if(this.vectorMode){this.renderer.clear();this.features.length=0;}else{this.clearMarkers();this.markers.length=0;}
-this.tile.draw();}},CLASS_NAME:"OpenLayers.Layer.WFS"});OpenLayers.Format.SLD.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{sld:"http://www.opengis.net/sld",ogc:"http://www.opengis.net/ogc",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"sld",schemaLocation:null,defaultSymbolizer:{fillColor:"#808080",fillOpacity:1,strokeColor:"#000000",strokeOpacity:1,strokeWidth:1,pointRadius:6},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var sld={namedLayers:{}};this.readChildNodes(data,sld);return sld;},readers:{"sld":{"StyledLayerDescriptor":function(node,sld){sld.version=node.getAttribute("version");this.readChildNodes(node,sld);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj.description=this.getChildValue(node);},"NamedLayer":function(node,sld){var layer={userStyles:[],namedStyles:[]};this.readChildNodes(node,layer);for(var i=0;i<layer.userStyles.length;++i){layer.userStyles[i].layerName=layer.name;}
-sld.namedLayers[layer.name]=layer;},"NamedStyle":function(node,layer){layer.namedStyles.push(this.getChildName(node.firstChild));},"UserStyle":function(node,layer){var style=new OpenLayers.Style(this.defaultSymbolizer);this.readChildNodes(node,style);layer.userStyles.push(style);},"IsDefault":function(node,style){if(this.getChildValue(node)=="1"){style.isDefault=true;}},"FeatureTypeStyle":function(node,style){var obj={rules:[]};this.readChildNodes(node,obj);style.rules=obj.rules;},"Rule":function(node,obj){var rule=new OpenLayers.Rule();this.readChildNodes(node,rule);obj.rules.push(rule);},"ElseFilter":function(node,rule){rule.elseFilter=true;},"MinScaleDenominator":function(node,rule){rule.minScaleDenominator=this.getChildValue(node);},"MaxScaleDenominator":function(node,rule){rule.maxScaleDenominator=this.getChildValue(node);},"LineSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Line"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Line"]=symbolizer;},"PolygonSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Polygon"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Polygon"]=symbolizer;},"PointSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Point"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Point"]=symbolizer;},"Stroke":function(node,symbolizer){this.readChildNodes(node,symbolizer);},"Fill":function(node,symbolizer){this.readChildNodes(node,symbolizer);},"CssParameter":function(node,symbolizer){var cssProperty=node.getAttribute("name");var symProperty=this.cssMap[cssProperty];if(symProperty){var value=this.readOgcExpression(node);if(value){symbolizer[symProperty]=value;}}},"Graphic":function(node,symbolizer){var graphic={};this.readChildNodes(node,graphic);var properties=["strokeColor","strokeWidth","strokeOpacity","strokeLinecap","fillColor","fillOpacity","graphicName","rotation","graphicFormat"];var prop,value;for(var i=0;i<properties.length;++i){prop=properties[i];value=graphic[prop];if(value!=undefined){symbolizer[prop]=value;}}
-if(graphic.opacity!=undefined){symbolizer.graphicOpacity=graphic.opacity;}
-if(graphic.size!=undefined){symbolizer.pointRadius=graphic.size;}
-if(graphic.href!=undefined){symbolizer.externalGraphic=graphic.href;}},"ExternalGraphic":function(node,graphic){this.readChildNodes(node,graphic);},"Mark":function(node,graphic){this.readChildNodes(node,graphic);},"WellKnownName":function(node,graphic){graphic.graphicName=this.getChildValue(node);},"Opacity":function(node,obj){var opacity=this.getChildValue(node);if(opacity){obj.opacity=opacity;}},"Size":function(node,obj){var size=this.getChildValue(node);if(size){obj.size=size;}},"Rotation":function(node,obj){var rotation=this.getChildValue(node);if(rotation){obj.rotation=rotation;}},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Format":function(node,graphic){graphic.graphicFormat=this.getChildValue(node);}},"ogc":{"Filter":function(node,rule){var obj={fids:[],filters:[]};this.readChildNodes(node,obj);if(obj.fids.length>0){rule.filter=new OpenLayers.Filter.FeatureId({fids:obj.fids});}else if(obj.filters.length>0){rule.filter=obj.filters[0];}},"FeatureId":function(node,obj){var fid=node.getAttribute("fid");if(fid){obj.fids.push(fid);}},"And":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});this.readChildNodes(node,filter);obj.filters.push(filter);},"Or":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.OR});this.readChildNodes(node,filter);obj.filters.push(filter);},"Not":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsBetween":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLike":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(node,filter);var wildCard=node.getAttribute("wildCard");var singleChar=node.getAttribute("singleChar");var esc=node.getAttribute("escape");filter.value2regex(wildCard,singleChar,esc);obj.filters.push(filter);},"Literal":function(node,obj){obj.value=this.getChildValue(node);},"PropertyName":function(node,filter){filter.property=this.getChildValue(node);},"LowerBoundary":function(node,filter){filter.lowerBoundary=this.readOgcExpression(node);},"UpperBoundary":function(node,filter){filter.upperBoundary=this.readOgcExpression(node);}}},readOgcExpression:function(node){var obj={};this.readChildNodes(node,obj);var value=obj.value;if(!value){value=this.getChildValue(node);}
-return value;},cssMap:{"stroke":"strokeColor","stroke-opacity":"strokeOpacity","stroke-width":"strokeWidth","stroke-linecap":"strokeLinecap","fill":"fillColor","fill-opacity":"fillOpacity"},getCssProperty:function(sym){var css=null;for(var prop in this.cssMap){if(this.cssMap[prop]==sym){css=prop;break;}}
-return css;},getGraphicFormat:function(href){var format,regex;for(var key in this.graphicFormats){if(this.graphicFormats[key].test(href)){format=key;break;}}
-return format||this.defautlGraphicFormat;},defaultGraphicFormat:"image/png",graphicFormats:{"image/jpeg":/\.jpe?g$/i,"image/gif":/\.gif$/i,"image/png":/\.png$/i},write:function(sld){return this.writers.sld.StyledLayerDescriptor.apply(this,[sld]);},writers:{"sld":{"StyledLayerDescriptor":function(sld){var root=this.createElementNSPlus("StyledLayerDescriptor",{attributes:{"version":this.VERSION,"xsi:schemaLocation":this.schemaLocation}});if(sld.name){this.writeNode(root,"Name",sld.name);}
-if(sld.title){this.writeNode(root,"Title",sld.title);}
-if(sld.description){this.writeNode(root,"Abstract",sld.description);}
-for(var name in sld.namedLayers){this.writeNode(root,"NamedLayer",sld.namedLayers[name]);}
-return root;},"Name":function(name){return this.createElementNSPlus("Name",{value:name});},"Title":function(title){return this.createElementNSPlus("Title",{value:title});},"Abstract":function(description){return this.createElementNSPlus("Abstract",{value:description});},"NamedLayer":function(layer){var node=this.createElementNSPlus("NamedLayer");this.writeNode(node,"Name",layer.name);if(layer.namedStyles){for(var i=0;i<layer.namedStyles.length;++i){this.writeNode(node,"NamedStyle",layer.namedStyles[i]);}}
-if(layer.userStyles){for(var i=0;i<layer.userStyles.length;++i){this.writeNode(node,"UserStyle",layer.userStyles[i]);}}
-return node;},"NamedStyle":function(name){var node=this.createElementNSPlus("NamedStyle");this.writeNode(node,"Name",name);return node;},"UserStyle":function(style){var node=this.createElementNSPlus("UserStyle");if(style.name){this.writeNode(node,"Name",style.name);}
-if(style.title){this.writeNode(node,"Title",style.title);}
-if(style.description){this.writeNode(node,"Abstract",style.description);}
-if(style.isDefault){this.writeNode(node,"IsDefault",style.isDefault);}
-this.writeNode(node,"FeatureTypeStyle",style);return node;},"IsDefault":function(bool){return this.createElementNSPlus("IsDefault",{value:(bool)?"1":"0"});},"FeatureTypeStyle":function(style){var node=this.createElementNSPlus("FeatureTypeStyle");for(var i=0;i<style.rules.length;++i){this.writeNode(node,"Rule",style.rules[i]);}
-return node;},"Rule":function(rule){var node=this.createElementNSPlus("Rule");if(rule.name){this.writeNode(node,"Name",rule.name);}
-if(rule.title){this.writeNode(node,"Title",rule.title);}
-if(rule.description){this.writeNode(node,"Abstract",rule.description);}
-if(rule.elseFilter){this.writeNode(node,"ElseFilter");}else if(rule.filter){this.writeNode(node,"ogc:Filter",rule.filter);}
-if(rule.minScaleDenominator!=undefined){this.writeNode(node,"MinScaleDenominator",rule.minScaleDenominator);}
-if(rule.maxScaleDenominator!=undefined){this.writeNode(node,"MaxScaleDenominator",rule.maxScaleDenominator);}
-var types=OpenLayers.Style.SYMBOLIZER_PREFIXES;var type,symbolizer;for(var i=0;i<types.length;++i){type=types[i];symbolizer=rule.symbolizer[type];if(symbolizer){this.writeNode(node,type+"Symbolizer",symbolizer);}}
-return node;},"ElseFilter":function(){return this.createElementNSPlus("ElseFilter");},"MinScaleDenominator":function(scale){return this.createElementNSPlus("MinScaleDenominator",{value:scale});},"MaxScaleDenominator":function(scale){return this.createElementNSPlus("MaxScaleDenominator",{value:scale});},"LineSymbolizer":function(symbolizer){var node=this.createElementNSPlus("LineSymbolizer");this.writeNode(node,"Stroke",symbolizer);return node;},"Stroke":function(symbolizer){var node=this.createElementNSPlus("Stroke");if(symbolizer.strokeColor!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeColor"});}
-if(symbolizer.strokeOpacity!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeOpacity"});}
-if(symbolizer.strokeWidth!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeWidth"});}
-return node;},"CssParameter":function(obj){return this.createElementNSPlus("CssParameter",{attributes:{name:this.getCssProperty(obj.key)},value:obj.symbolizer[obj.key]});},"PolygonSymbolizer":function(symbolizer){var node=this.createElementNSPlus("PolygonSymbolizer");this.writeNode(node,"Fill",symbolizer);this.writeNode(node,"Stroke",symbolizer);return node;},"Fill":function(symbolizer){var node=this.createElementNSPlus("Fill");if(symbolizer.fillColor){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"fillColor"});}
-if(symbolizer.fillOpacity){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"fillOpacity"});}
-return node;},"PointSymbolizer":function(symbolizer){var node=this.createElementNSPlus("PointSymbolizer");this.writeNode(node,"Graphic",symbolizer);return node;},"Graphic":function(symbolizer){var node=this.createElementNSPlus("Graphic");if(symbolizer.externalGraphic!=undefined){this.writeNode(node,"ExternalGraphic",symbolizer);}else if(symbolizer.graphicName){this.writeNode(node,"Mark",symbolizer);}
-if(symbolizer.graphicOpacity!=undefined){this.writeNode(node,"Opacity",symbolizer.graphicOpacity);}
-if(symbolizer.pointRadius!=undefined){this.writeNode(node,"Size",symbolizer.pointRadius);}
-if(symbolizer.rotation!=undefined){this.writeNode(node,"Rotation",symbolizer.rotation);}
-return node;},"ExternalGraphic":function(symbolizer){var node=this.createElementNSPlus("ExternalGraphic");this.writeNode(node,"OnlineResource",symbolizer.externalGraphic);var format=symbolizer.graphicFormat||this.getGraphicFormat(symbolizer.externalGraphic);this.writeNode(node,"Format",format);return node;},"Mark":function(symbolizer){var node=this.createElementNSPlus("Mark");this.writeNode(node,"WellKnownName",symbolizer.graphicName);this.writeNode(node,"Fill",symbolizer);this.writeNode(node,"Stroke",symbolizer);return node;},"WellKnownName":function(name){return this.createElementNSPlus("WellKnownName",{value:name});},"Opacity":function(value){return this.createElementNSPlus("Opacity",{value:value});},"Size":function(value){return this.createElementNSPlus("Size",{value:value});},"Rotation":function(value){return this.createElementNSPlus("Rotation",{value:value});},"OnlineResource":function(href){return this.createElementNSPlus("OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":href}});},"Format":function(format){return this.createElementNSPlus("Format",{value:format});}},"ogc":{"Filter":function(filter){var node=this.createElementNSPlus("ogc:Filter");var sub=filter.CLASS_NAME.split(".").pop();if(sub=="FeatureId"){for(var i=0;i<filter.fids.length;++i){this.writeNode(node,"FeatureId",filter.fids[i]);}}else{this.writeNode(node,this.getFilterType(filter),filter);}
-return node;},"FeatureId":function(fid){return this.createElementNSPlus("ogc:FeatureId",{attributes:{fid:fid}});},"And":function(filter){var node=this.createElementNSPlus("ogc:And");var childFilter;for(var i=0;i<filter.filters.length;++i){childFilter=filter.filters[i];this.writeNode(node,this.getFilterType(childFilter),childFilter);}
-return node;},"Or":function(filter){var node=this.createElementNSPlus("ogc:Or");var childFilter;for(var i=0;i<filter.filters.length;++i){childFilter=filter.filters[i];this.writeNode(node,this.getFilterType(childFilter),childFilter);}
-return node;},"Not":function(filter){var node=this.createElementNSPlus("ogc:Not");var childFilter=filter.filters[0];this.writeNode(node,this.getFilterType(childFilter),childFilter);return node;},"PropertyIsEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsNotEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsNotEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsLessThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThan");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsGreaterThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThan");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsLessThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsGreaterThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsBetween":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsBetween");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"LowerBoundary",filter);this.writeNode(node,"UpperBoundary",filter);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{wildCard:"*",singleChar:".",escape:"!"}});this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.regex2value());return node;},"PropertyName":function(filter){return this.createElementNSPlus("ogc:PropertyName",{value:filter.property});},"Literal":function(value){return this.createElementNSPlus("ogc:Literal",{value:value});},"LowerBoundary":function(filter){var node=this.createElementNSPlus("ogc:LowerBoundary");this.writeNode(node,"Literal",filter.lowerBoundary);return node;},"UpperBoundary":function(filter){var node=this.createElementNSPlus("ogc:UpperBoundary");this.writeNode(node,"Literal",filter.upperBoundary);return node;}}},getFilterType:function(filter){var filterType=this.filterMap[filter.type];if(!filterType){throw"SLD writing not supported for rule type: "+filter.type;}
-return filterType;},filterMap:{"&&":"And","||":"Or","!":"Not","==":"PropertyIsEqualTo","!=":"PropertyIsNotEqualTo","<":"PropertyIsLessThan",">":"PropertyIsGreaterThan","<=":"PropertyIsLessThanOrEqualTo",">=":"PropertyIsGreaterThanOrEqualTo","..":"PropertyIsBetween","~":"PropertyIsLike"},getNamespacePrefix:function(uri){var prefix=null;if(uri==null){prefix=this.namespaces[this.defaultPrefix];}else{var gotPrefix=false;for(prefix in this.namespaces){if(this.namespaces[prefix]==uri){gotPrefix=true;break;}}
-if(!gotPrefix){prefix=null;}}
-return prefix;},readChildNodes:function(node,obj){var children=node.childNodes;var child,group,reader,prefix,local;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){prefix=this.getNamespacePrefix(child.namespaceURI);local=child.nodeName.split(":").pop();group=this.readers[prefix];if(group){reader=group[local];if(reader){reader.apply(this,[child,obj]);}}}}},writeNode:function(parent,name,obj){var prefix,local;var split=name.indexOf(":");if(split>0){prefix=name.substring(0,split);local=name.substring(split+1);}else{prefix=this.getNamespacePrefix(parent.namespaceURI);local=name;}
-var child=this.writers[prefix][local].apply(this,[obj]);parent.appendChild(child);return child;},createElementNSPlus:function(name,options){options=options||{};var loc=name.indexOf(":");var uri=options.uri||this.namespaces[options.prefix];if(!uri){loc=name.indexOf(":");uri=this.namespaces[name.substring(0,loc)];}
-if(!uri){uri=this.namespaces[this.defaultPrefix];}
-var node=this.createElementNS(uri,name);if(options.attributes){this.setAttributes(node,options.attributes);}
-if(options.value){node.appendChild(this.createTextNode(options.value));}
-return node;},setAttributes:function(node,obj){var value,loc,alias,uri;for(var name in obj){value=obj[name].toString();uri=this.namespaces[name.substring(0,name.indexOf(":"))]||null;this.setAttributeNS(node,uri,name,value);}},CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,arguments);},getLength:function(){var length=0.0;if(this.components&&(this.components.length>1)){for(var i=1;i<this.components.length;i++){length+=this.components[i-1].distanceTo(this.components[i]);}}
-return length;},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",initialize:function(options){OpenLayers.Format.SLD.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{initialize:function(points){OpenLayers.Geometry.Curve.prototype.initialize.apply(this,arguments);},removeComponent:function(point){if(this.components&&(this.components.length>2)){OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);}},intersects:function(geometry){var intersect=false;var type=geometry.CLASS_NAME;if(type=="OpenLayers.Geometry.LineString"||type=="OpenLayers.Geometry.LinearRing"||type=="OpenLayers.Geometry.Point"){var segs1=this.getSortedSegments();var segs2;if(type=="OpenLayers.Geometry.Point"){segs2=[{x1:geometry.x,y1:geometry.y,x2:geometry.x,y2:geometry.y}];}else{segs2=geometry.getSortedSegments();}
-var seg1,seg1x1,seg1x2,seg1y1,seg1y2,seg2,seg2y1,seg2y2;outer:for(var i=0;i<segs1.length;++i){seg1=segs1[i];seg1x1=seg1.x1;seg1x2=seg1.x2;seg1y1=seg1.y1;seg1y2=seg1.y2;inner:for(var j=0;j<segs2.length;++j){seg2=segs2[j];if(seg2.x1>seg1x2){break;}
-if(seg2.x2<seg1x1){continue;}
-seg2y1=seg2.y1;seg2y2=seg2.y2;if(Math.min(seg2y1,seg2y2)>Math.max(seg1y1,seg1y2)){continue;}
-if(Math.max(seg2y1,seg2y2)<Math.min(seg1y1,seg1y2)){continue;}
-if(OpenLayers.Geometry.segmentsIntersect(seg1,seg2)){intersect=true;break outer;}}}}else{intersect=geometry.intersects(this);}
-return intersect;},getSortedSegments:function(){var numSeg=this.components.length-1;var segments=new Array(numSeg);for(var i=0;i<numSeg;++i){point1=this.components[i];point2=this.components[i+1];if(point1.x<point2.x){segments[i]={x1:point1.x,y1:point1.y,x2:point2.x,y2:point2.y};}else{segments[i]={x1:point2.x,y1:point2.y,x2:point1.x,y2:point1.y};}}
-function byX1(seg1,seg2){return seg1.x1-seg2.x1;}
-return segments.sort(byX1);},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:true,xy:true,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var featureNodes=this.getElementsByTagNameNS(data.documentElement,this.gmlns,this.featureName);var features=[];for(var i=0;i<featureNodes.length;i++){var feature=this.parseFeature(featureNodes[i]);if(feature){features.push(feature);}}
-return features;},parseFeature:function(node){var order=["MultiPolygon","Polygon","MultiLineString","LineString","MultiPoint","Point","Envelope"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];nodeList=this.getElementsByTagNameNS(node,this.gmlns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
-break;}}
-var attributes;if(this.extractAttributes){attributes=this.parseAttributes(node);}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes);var childNode=node.firstChild;var fid;while(childNode){if(childNode.nodeType==1){fid=childNode.getAttribute("fid")||childNode.getAttribute("id");if(fid){break;}}
-childNode=childNode.nextSibling;}
-feature.fid=fid;return feature;},parseGeometry:{point:function(node){var nodeList,coordString;var coords=[];var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"pos");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coord");if(nodeList.length>0){var xList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"X");var yList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"Y");if(xList.length>0&&yList.length>0){coords=[xList[0].firstChild.nodeValue,yList[0].firstChild.nodeValue];}}}
-if(coords.length==2){coords[2]=null;}
-if(this.xy){return new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}
-else{return new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}},multipoint:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Point");var components=[];if(nodeList.length>0){var point;for(var i=0;i<nodeList.length;++i){point=this.parseGeometry.point.apply(this,[nodeList[i]]);if(point){components.push(point);}}}
-return new OpenLayers.Geometry.MultiPoint(components);},linestring:function(node,ring){var nodeList,coordString;var coords=[];var points=[];nodeList=this.getElementsByTagNameNS(node,this.gmlns,"posList");if(nodeList.length>0){coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);var dim=parseInt(nodeList[0].getAttribute("dimension"));var j,x,y,z;for(var i=0;i<coords.length/dim;++i){j=i*dim;x=coords[j];y=coords[j+1];z=(dim==2)?null:coords[j+2];if(this.xy){points.push(new OpenLayers.Geometry.Point(x,y,z));}else{points.push(new OpenLayers.Geometry.Point(y,x,z));}}}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);for(var i=0;i<pointList.length;++i){coords=pointList[i].split(",");if(coords.length==2){coords[2]=null;}
-if(this.xy){points.push(new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]));}else{points.push(new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]));}}}}
-var line=null;if(points.length!=0){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}
-return line;},multilinestring:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LineString");var components=[];if(nodeList.length>0){var line;for(var i=0;i<nodeList.length;++i){line=this.parseGeometry.linestring.apply(this,[nodeList[i]]);if(line){components.push(line);}}}
-return new OpenLayers.Geometry.MultiLineString(components);},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LinearRing");var components=[];if(nodeList.length>0){var ring;for(var i=0;i<nodeList.length;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components.push(ring);}}}
-return new OpenLayers.Geometry.Polygon(components);},multipolygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Polygon");var components=[];if(nodeList.length>0){var polygon;for(var i=0;i<nodeList.length;++i){polygon=this.parseGeometry.polygon.apply(this,[nodeList[i]]);if(polygon){components.push(polygon);}}}
-return new OpenLayers.Geometry.MultiPolygon(components);},envelope:function(node){var components=[];var coordString;var envelope;var lpoint=this.getElementsByTagNameNS(node,this.gmlns,"lowerCorner");if(lpoint.length>0){var coords=[];if(lpoint.length>0){coordString=lpoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(this.xy){var lowerPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var lowerPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
-var upoint=this.getElementsByTagNameNS(node,this.gmlns,"upperCorner");if(upoint.length>0){var coords=[];if(upoint.length>0){coordString=upoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(this.xy){var upperPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var upperPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
-if(lowerPoint&&upperPoint){components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));var ring=new OpenLayers.Geometry.LinearRing(components);envelope=new OpenLayers.Geometry.Polygon([ring]);}
-return envelope;}},parseAttributes:function(node){var attributes={};var childNode=node.firstChild;var children,i,child,grandchildren,grandchild,name,value;while(childNode){if(childNode.nodeType==1){children=childNode.childNodes;for(i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length==1){grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}
-break;}
-return attributes;},write:function(features){if(!(features instanceof Array)){features=[features];}
-var gml=this.createElementNS("http://www.opengis.net/wfs","wfs:"+this.collectionName);for(var i=0;i<features.length;i++){gml.appendChild(this.createFeatureXML(features[i]));}
-return OpenLayers.Format.XML.prototype.write.apply(this,[gml]);},createFeatureXML:function(feature){var geometry=feature.geometry;var geometryNode=this.buildGeometryNode(geometry);var geomContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-this.geometryName);geomContainer.appendChild(geometryNode);var featureNode=this.createElementNS(this.gmlns,"gml:"+this.featureName);var featureContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-this.layerName);var fid=feature.fid||feature.id;featureContainer.setAttribute("fid",fid);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr.substring(attr.lastIndexOf(":")+1);var attrContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
-featureNode.appendChild(featureContainer);return featureNode;},buildGeometryNode:function(geometry){if(this.externalProjection&&this.internalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];return builder.apply(this,[geometry]);},buildGeometry:{point:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Point");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multipoint:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPoint");var points=geometry.components;var pointMember,pointGeom;for(var i=0;i<points.length;i++){pointMember=this.createElementNS(this.gmlns,"gml:pointMember");pointGeom=this.buildGeometry.point.apply(this,[points[i]]);pointMember.appendChild(pointGeom);gml.appendChild(pointMember);}
-return gml;},linestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LineString");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multilinestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiLineString");var lines=geometry.components;var lineMember,lineGeom;for(var i=0;i<lines.length;++i){lineMember=this.createElementNS(this.gmlns,"gml:lineStringMember");lineGeom=this.buildGeometry.linestring.apply(this,[lines[i]]);lineMember.appendChild(lineGeom);gml.appendChild(lineMember);}
-return gml;},linearring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LinearRing");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},polygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0;i<rings.length;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.gmlns,"gml:"+type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[i]]);ringMember.appendChild(ringGeom);gml.appendChild(ringMember);}
-return gml;},multipolygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPolygon");var polys=geometry.components;var polyMember,polyGeom;for(var i=0;i<polys.length;++i){polyMember=this.createElementNS(this.gmlns,"gml:polygonMember");polyGeom=this.buildGeometry.polygon.apply(this,[polys[i]]);polyMember.appendChild(polyGeom);gml.appendChild(polyMember);}
-return gml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.gmlns,"gml:coordinates");coordinatesNode.setAttribute("decimal",".");coordinatesNode.setAttribute("cs",",");coordinatesNode.setAttribute("ts"," ");var points=(geometry.components)?geometry.components:[geometry];var parts=[];for(var i=0;i<points.length;i++){parts.push(points[i].x+","+points[i].y);}
-var txtNode=this.createTextNode(parts.join(" "));coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.GML"});OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{initialize:function(options){OpenLayers.Format.JSON.prototype.initialize.apply(this,[options]);},read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
-if(!obj){OpenLayers.Console.error("Bad JSON: "+json);}else if(typeof(obj.type)!="string"){OpenLayers.Console.error("Bad GeoJSON - no type: "+json);}else if(this.isValidType(obj,type)){switch(type){case"Geometry":try{results=this.parseGeometry(obj);}catch(err){OpenLayers.Console.error(err);}
-break;case"Feature":try{results=this.parseFeature(obj);results.type="Feature";}catch(err){OpenLayers.Console.error(err);}
-break;case"FeatureCollection":results=[];switch(obj.type){case"Feature":try{results.push(this.parseFeature(obj));}catch(err){results=null;OpenLayers.Console.error(err);}
-break;case"FeatureCollection":for(var i=0;i<obj.features.length;++i){try{results.push(this.parseFeature(obj.features[i]));}catch(err){results=null;OpenLayers.Console.error(err);}}
-break;default:try{var geom=this.parseGeometry(obj);results.push(new OpenLayers.Feature.Vector(geom));}catch(err){results=null;OpenLayers.Console.error(err);}}
-break;}}
-return results;},isValidType:function(obj,type){var valid=false;switch(type){case"Geometry":if(OpenLayers.Util.indexOf(["Point","MultiPoint","LineString","MultiLineString","Polygon","MultiPolygon","Box","GeometryCollection"],obj.type)==-1){OpenLayers.Console.error("Unsupported geometry type: "+
-obj.type);}else{valid=true;}
-break;case"FeatureCollection":valid=true;break;default:if(obj.type==type){valid=true;}else{OpenLayers.Console.error("Cannot convert types from "+
-obj.type+" to "+type);}}
-return valid;},parseFeature:function(obj){var feature,geometry,attributes;attributes=(obj.properties)?obj.properties:{};try{geometry=this.parseGeometry(obj.geometry);}catch(err){throw err;}
-feature=new OpenLayers.Feature.Vector(geometry,attributes);if(obj.id){feature.fid=obj.id;}
-return feature;},parseGeometry:function(obj){var geometry;if(obj.type=="GeometryCollection"){if(!(obj.geometries instanceof Array)){throw"GeometryCollection must have geometries array: "+obj;}
-var numGeom=obj.geometries.length;var components=new Array(numGeom);for(var i=0;i<numGeom;++i){components[i]=this.parseGeometry.apply(this,[obj.geometries[i]]);}
-geometry=new OpenLayers.Geometry.Collection(components);}else{if(!(obj.coordinates instanceof Array)){throw"Geometry must have coordinates array: "+obj;}
-if(!this.parseCoords[obj.type.toLowerCase()]){throw"Unsupported geometry type: "+obj.type;}
-try{geometry=this.parseCoords[obj.type.toLowerCase()].apply(this,[obj.coordinates]);}catch(err){throw err;}}
-if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-return geometry;},parseCoords:{"point":function(array){if(array.length!=2){throw"Only 2D points are supported: "+array;}
-return new OpenLayers.Geometry.Point(array[0],array[1]);},"multipoint":function(array){var points=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
-points.push(p);}
-return new OpenLayers.Geometry.MultiPoint(points);},"linestring":function(array){var points=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
-points.push(p);}
-return new OpenLayers.Geometry.LineString(points);},"multilinestring":function(array){var lines=[];var l=null;for(var i=0;i<array.length;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
-lines.push(l);}
-return new OpenLayers.Geometry.MultiLineString(lines);},"polygon":function(array){var rings=[];var r,l;for(var i=0;i<array.length;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
-r=new OpenLayers.Geometry.LinearRing(l.components);rings.push(r);}
-return new OpenLayers.Geometry.Polygon(rings);},"multipolygon":function(array){var polys=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["polygon"].apply(this,[array[i]]);}catch(err){throw err;}
-polys.push(p);}
-return new OpenLayers.Geometry.MultiPolygon(polys);},"box":function(array){if(array.length!=2){throw"GeoJSON box coordinates must have 2 elements";}
-return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(array[0][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[0][1])])]);}},write:function(obj,pretty){var geojson={"type":null};if(obj instanceof Array){geojson.type="FeatureCollection";var numFeatures=obj.length;geojson.features=new Array(numFeatures);for(var i=0;i<numFeatures;++i){var element=obj[i];if(!element instanceof OpenLayers.Feature.Vector){var msg="FeatureCollection only supports collections "+"of features: "+element;throw msg;}
-geojson.features[i]=this.extract.feature.apply(this,[element]);}}else if(obj.CLASS_NAME.indexOf("OpenLayers.Geometry")==0){geojson=this.extract.geometry.apply(this,[obj]);}else if(obj instanceof OpenLayers.Feature.Vector){geojson=this.extract.feature.apply(this,[obj]);if(obj.layer&&obj.layer.projection){geojson.crs=this.createCRSObject(obj);}}
-return OpenLayers.Format.JSON.prototype.write.apply(this,[geojson,pretty]);},createCRSObject:function(object){var proj=object.layer.projection.toString();var crs={};if(proj.match(/epsg:/i)){var code=parseInt(proj.substring(proj.indexOf(":")+1));if(code==4326){crs={"type":"OGC","properties":{"urn":"urn:ogc:def:crs:OGC:1.3:CRS84"}};}else{crs={"type":"EPSG","properties":{"code":code}};}}
-return crs;},extract:{'feature':function(feature){var geom=this.extract.geometry.apply(this,[feature.geometry]);return{"type":"Feature","id":feature.fid==null?feature.id:feature.fid,"properties":feature.attributes,"geometry":geom};},'geometry':function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var geometryType=geometry.CLASS_NAME.split('.')[2];var data=this.extract[geometryType.toLowerCase()].apply(this,[geometry]);var json;if(geometryType=="Collection"){json={"type":"GeometryCollection","geometries":data};}else{json={"type":geometryType,"coordinates":data};}
-return json;},'point':function(point){return[point.x,point.y];},'multipoint':function(multipoint){var array=[];for(var i=0;i<multipoint.components.length;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
-return array;},'linestring':function(linestring){var array=[];for(var i=0;i<linestring.components.length;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
-return array;},'multilinestring':function(multilinestring){var array=[];for(var i=0;i<multilinestring.components.length;++i){array.push(this.extract.linestring.apply(this,[multilinestring.components[i]]));}
-return array;},'polygon':function(polygon){var array=[];for(var i=0;i<polygon.components.length;++i){array.push(this.extract.linestring.apply(this,[polygon.components[i]]));}
-return array;},'multipolygon':function(multipolygon){var array=[];for(var i=0;i<multipolygon.components.length;++i){array.push(this.extract.polygon.apply(this,[multipolygon.components[i]]));}
-return array;},'collection':function(collection){var len=collection.components.length;var array=new Array(len);for(var i=0;i<len;++i){array[i]=this.extract.geometry.apply(this,[collection.components[i]]);}
-return array;}},CLASS_NAME:"OpenLayers.Format.GeoJSON"});OpenLayers.Format.GeoRSS=OpenLayers.Class(OpenLayers.Format.XML,{rssns:"http://backend.userland.com/rss2",featureNS:"http://mapserver.gis.umn.edu/mapserver",georssns:"http://www.georss.org/georss",geons:"http://www.w3.org/2003/01/geo/wgs84_pos#",featureTitle:"Untitled",featureDescription:"No Description",gmlParser:null,xy:false,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},createGeometryFromItem:function(item){var point=this.getElementsByTagNameNS(item,this.georssns,"point");var lat=this.getElementsByTagNameNS(item,this.geons,'lat');var lon=this.getElementsByTagNameNS(item,this.geons,'long');var line=this.getElementsByTagNameNS(item,this.georssns,"line");var polygon=this.getElementsByTagNameNS(item,this.georssns,"polygon");var where=this.getElementsByTagNameNS(item,this.georssns,"where");if(point.length>0||(lat.length>0&&lon.length>0)){var location;if(point.length>0){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s+/);if(location.length!=2){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s*,\s*/);}}else{location=[parseFloat(lat[0].firstChild.nodeValue),parseFloat(lon[0].firstChild.nodeValue)];}
-var geometry=new OpenLayers.Geometry.Point(parseFloat(location[1]),parseFloat(location[0]));}else if(line.length>0){var coords=OpenLayers.String.trim(line[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;for(var i=0;i<coords.length;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
-geometry=new OpenLayers.Geometry.LineString(components);}else if(polygon.length>0){var coords=OpenLayers.String.trim(polygon[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;for(var i=0;i<coords.length;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
-geometry=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(components)]);}else if(where.length>0){if(!this.gmlParser){this.gmlParser=new OpenLayers.Format.GML({'xy':this.xy});}
-var feature=this.gmlParser.parseFeature(where[0]);geometry=feature.geometry;}
-if(geometry&&this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-return geometry;},createFeatureFromItem:function(item){var geometry=this.createGeometryFromItem(item);var title=this.getChildValue(item,"*","title",this.featureTitle);var description=this.getChildValue(item,"*","description",this.getChildValue(item,"*","content",this.featureDescription));var link=this.getChildValue(item,"*","link");if(!link){try{link=this.getElementsByTagNameNS(item,"*","link")[0].getAttribute("href");}catch(e){link=null;}}
-var id=this.getChildValue(item,"*","id",null);var data={"title":title,"description":description,"link":link};var feature=new OpenLayers.Feature.Vector(geometry,data);feature.fid=id;return feature;},getChildValue:function(node,nsuri,name,def){var value;try{value=this.getElementsByTagNameNS(node,nsuri,name)[0].firstChild.nodeValue;}catch(e){value=(def==undefined)?"":def;}
-return value;},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-var itemlist=null;itemlist=this.getElementsByTagNameNS(doc,'*','item');if(itemlist.length==0){itemlist=this.getElementsByTagNameNS(doc,'*','entry');}
-var numItems=itemlist.length;var features=new Array(numItems);for(var i=0;i<numItems;i++){features[i]=this.createFeatureFromItem(itemlist[i]);}
-return features;},write:function(features){var georss;if(features instanceof Array){georss=this.createElementNS(this.rssns,"rss");for(var i=0;i<features.length;i++){georss.appendChild(this.createFeatureXML(features[i]));}}else{georss=this.createFeatureXML(features);}
-return OpenLayers.Format.XML.prototype.write.apply(this,[georss]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var featureNode=this.createElementNS(this.rssns,"item");var titleNode=this.createElementNS(this.rssns,"title");titleNode.appendChild(this.createTextNode(feature.attributes.title?feature.attributes.title:""));var descNode=this.createElementNS(this.rssns,"description");descNode.appendChild(this.createTextNode(feature.attributes.description?feature.attributes.description:""));featureNode.appendChild(titleNode);featureNode.appendChild(descNode);if(feature.attributes.link){var linkNode=this.createElementNS(this.rssns,"link");linkNode.appendChild(this.createTextNode(feature.attributes.link));featureNode.appendChild(linkNode);}
-for(var attr in feature.attributes){if(attr=="link"||attr=="title"||attr=="description"){continue;}
-var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
-var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureNode.appendChild(attrContainer);}
-featureNode.appendChild(geometryNode);return featureNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var node;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){node=this.createElementNS(this.georssns,'georss:polygon');node.appendChild(this.buildCoordinatesNode(geometry.components[0]));}
-else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){node=this.createElementNS(this.georssns,'georss:line');node.appendChild(this.buildCoordinatesNode(geometry));}
-else if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){node=this.createElementNS(this.georssns,'georss:point');node.appendChild(this.buildCoordinatesNode(geometry));}else{throw"Couldn't parse "+geometry.CLASS_NAME;}
-return node;},buildCoordinatesNode:function(geometry){var points=null;if(geometry.components){points=geometry.components;}
-var path;if(points){var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;i++){parts[i]=points[i].y+" "+points[i].x;}
-path=parts.join(" ");}else{path=geometry.y+" "+geometry.x;}
-return this.createTextNode(path);},CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Format.KML=OpenLayers.Class(OpenLayers.Format.XML,{kmlns:"http://earth.google.com/kml/2.0",placemarksDesc:"No description available",foldersName:"OpenLayers export",foldersDesc:"Exported on "+new Date(),extractAttributes:true,extractStyles:false,internalns:null,features:null,styles:null,styleBaseUrl:"",fetched:null,maxDepth:0,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g),kmlColor:(/(\w{2})(\w{2})(\w{2})(\w{2})/),kmlIconPalette:(/root:\/\/icons\/palette-(\d+)(\.\w+)/),straightBracket:(/\$\[(.*?)\]/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){this.features=[];this.styles={};this.fetched={};var options={depth:this.maxDepth,styleBaseUrl:this.styleBaseUrl};return this.parseData(data,options);},parseData:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var types=["Link","NetworkLink","Style","StyleMap","Placemark"];for(var i=0;i<types.length;++i){var type=types[i];var nodes=this.getElementsByTagNameNS(data,"*",type);if(nodes.length==0){continue;}
-switch(type.toLowerCase()){case"link":case"networklink":this.parseLinks(nodes,options);break;case"style":if(this.extractStyles){this.parseStyles(nodes,options);}
-break;case"stylemap":if(this.extractStyles){this.parseStyleMaps(nodes,options);}
-break;case"placemark":this.parseFeatures(nodes,options);break;}}
-return this.features;},parseLinks:function(nodes,options){if(options.depth>=this.maxDepth){return false;}
-var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;for(var i=0;i<nodes.length;i++){var href=this.parseProperty(nodes[i],"*","href");if(href&&!this.fetched[href]){this.fetched[href]=true;var data=this.fetchLink(href);if(data){this.parseData(data,newOptions);}}}},fetchLink:function(href){var request=new OpenLayers.Ajax.Request(href,{method:'get',asynchronous:false});if(request&&request.transport){return request.transport.responseText;}},parseStyles:function(nodes,options){for(var i=0;i<nodes.length;i++){var style=this.parseStyle(nodes[i]);if(style){styleName=(options.styleBaseUrl||"")+"#"+style.id;this.styles[styleName]=style;}}},parseStyle:function(node){var style={};var types=["LineStyle","PolyStyle","IconStyle","BalloonStyle"];var type,nodeList,geometry,parser;for(var i=0;i<types.length;++i){type=types[i];styleTypeNode=this.getElementsByTagNameNS(node,"*",type)[0];if(!styleTypeNode){continue;}
-switch(type.toLowerCase()){case"linestyle":var color=this.parseProperty(styleTypeNode,"*","color");if(color){var matches=(color.toString()).match(this.regExes.kmlColor);var alpha=matches[1];style["strokeOpacity"]=parseInt(alpha,16)/255;var b=matches[2];var g=matches[3];var r=matches[4];style["strokeColor"]="#"+r+g+b;}
-var width=this.parseProperty(styleTypeNode,"*","width");if(width){style["strokeWidth"]=width;}
-case"polystyle":var color=this.parseProperty(styleTypeNode,"*","color");if(color){var matches=(color.toString()).match(this.regExes.kmlColor);var alpha=matches[1];style["fillOpacity"]=parseInt(alpha,16)/255;var b=matches[2];var g=matches[3];var r=matches[4];style["fillColor"]="#"+r+g+b;}
-break;case"iconstyle":var scale=parseFloat(this.parseProperty(styleTypeNode,"*","scale")||1);var width=32*scale;var height=32*scale;var iconNode=this.getElementsByTagNameNS(styleTypeNode,"*","Icon")[0];if(iconNode){var href=this.parseProperty(iconNode,"*","href");if(href){var w=this.parseProperty(iconNode,"*","w");var h=this.parseProperty(iconNode,"*","h");var google="http://maps.google.com/mapfiles/kml";if(OpenLayers.String.startsWith(href,google)&&!w&&!h){w=64;h=64;scale=scale/2;}
-w=w||h;h=h||w;if(w){width=parseInt(w)*scale;}
-if(h){height=parseInt(h)*scale;}
-var matches=href.match(this.regExes.kmlIconPalette);if(matches){var palette=matches[1];var file_extension=matches[2];var x=this.parseProperty(iconNode,"*","x");var y=this.parseProperty(iconNode,"*","y");var posX=x?x/32:0;var posY=y?(7-y/32):7;var pos=posY*8+posX;href="http://maps.google.com/mapfiles/kml/pal"
-+palette+"/icon"+pos+file_extension;}
-style["graphicOpacity"]=1;style["externalGraphic"]=href;}}
-var hotSpotNode=this.getElementsByTagNameNS(styleTypeNode,"*","hotSpot")[0];if(hotSpotNode){var x=parseFloat(hotSpotNode.getAttribute("x"));var y=parseFloat(hotSpotNode.getAttribute("y"));var xUnits=hotSpotNode.getAttribute("xunits");if(xUnits=="pixels"){style["graphicXOffset"]=-x*scale;}
-else if(xUnits=="insetPixels"){style["graphicXOffset"]=-width+(x*scale);}
-else if(xUnits=="fraction"){style["graphicXOffset"]=-width*x;}
-var yUnits=hotSpotNode.getAttribute("yunits");if(yUnits=="pixels"){style["graphicYOffset"]=-height+(y*scale)+1;}
-else if(yUnits=="insetPixels"){style["graphicYOffset"]=-(y*scale)+1;}
-else if(yUnits=="fraction"){style["graphicYOffset"]=-height*(1-y)+1;}}
-style["graphicWidth"]=width;style["graphicHeight"]=height;break;case"balloonstyle":var balloonStyle=OpenLayers.Util.getXmlNodeValue(styleTypeNode);if(balloonStyle){style["balloonStyle"]=balloonStyle.replace(this.regExes.straightBracket,"${$1}");}
-break;default:}}
-if(!style["strokeColor"]&&style["fillColor"]){style["strokeColor"]=style["fillColor"];}
-var id=node.getAttribute("id");if(id&&style){style.id=id;}
-return style;},parseStyleMaps:function(nodes,options){for(var i=0;i<nodes.length;i++){var node=nodes[i];var pairs=this.getElementsByTagNameNS(node,"*","Pair");var id=node.getAttribute("id");for(var j=0;j<pairs.length;j++){var pair=pairs[j];var key=this.parseProperty(pair,"*","key");var styleUrl=this.parseProperty(pair,"*","styleUrl");if(styleUrl&&key=="normal"){this.styles[(options.styleBaseUrl||"")+"#"+id]=this.styles[(options.styleBaseUrl||"")+styleUrl];}
-if(styleUrl&&key=="highlight"){}}}},parseFeatures:function(nodes,options){var features=new Array(nodes.length);for(var i=0;i<nodes.length;i++){var featureNode=nodes[i];var feature=this.parseFeature.apply(this,[featureNode]);if(feature){if(this.extractStyles&&feature.attributes&&feature.attributes.styleUrl){feature.style=this.getStyle(feature.attributes.styleUrl);}
-var inlineStyleNode=this.getElementsByTagNameNS(featureNode,"*","Style")[0];if(inlineStyleNode){var inlineStyle=this.parseStyle(inlineStyleNode);if(inlineStyle){feature.style=OpenLayers.Util.extend({},feature.style);OpenLayers.Util.extend(feature.style,inlineStyle);}}
-features[i]=feature;}else{throw"Bad Placemark: "+i;}}
-this.features=this.features.concat(features);},parseFeature:function(node){var order=["MultiGeometry","Polygon","LineString","Point"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];this.internalns=node.namespaceURI?node.namespaceURI:this.kmlns;nodeList=this.getElementsByTagNameNS(node,this.internalns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
-break;}}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes);var fid=node.getAttribute("id")||node.getAttribute("name");if(fid!=null){feature.fid=fid;}
-return feature;},getStyle:function(styleUrl,options){var styleBaseUrl=OpenLayers.Util.removeTail(styleUrl);var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;newOptions.styleBaseUrl=styleBaseUrl;if(!this.styles[styleUrl]&&!OpenLayers.String.startsWith(styleUrl,"#")&&newOptions.depth<=this.maxDepth&&!this.fetched[styleBaseUrl]){var data=this.fetchLink(styleBaseUrl);if(data){this.parseData(data,newOptions);}}
-var style=this.styles[styleUrl];return style;},parseGeometry:{point:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var coords=[];if(nodeList.length>0){var coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}
-var point=null;if(coords.length>1){if(coords.length==2){coords[2]=null;}
-point=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad coordinate string: "+coordString;}
-return point;},linestring:function(node,ring){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var line=null;if(nodeList.length>0){var coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);var numPoints=pointList.length;var points=new Array(numPoints);var coords,numCoords;for(var i=0;i<numPoints;++i){coords=pointList[i].split(",");numCoords=coords.length;if(numCoords>1){if(coords.length==2){coords[2]=null;}
-points[i]=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad LineString point coordinates: "+
-pointList[i];}}
-if(numPoints){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}else{throw"Bad LineString coordinates: "+coordString;}}
-return line;},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"LinearRing");var numRings=nodeList.length;var components=new Array(numRings);if(numRings>0){var ring;for(var i=0;i<nodeList.length;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components[i]=ring;}else{throw"Bad LinearRing geometry: "+i;}}}
-return new OpenLayers.Geometry.Polygon(components);},multigeometry:function(node){var child,parser;var parts=[];var children=node.childNodes;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){var type=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var parser=this.parseGeometry[type.toLowerCase()];if(parser){parts.push(parser.apply(this,[child]));}}}
-return new OpenLayers.Geometry.Collection(parts);}},parseAttributes:function(node){var attributes={};var child,grandchildren,grandchild;var children=node.childNodes;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length==1||grandchildren.length==3){var grandchild;switch(grandchildren.length){case 1:grandchild=grandchildren[0];break;case 3:default:grandchild=grandchildren[1];break;}
-if(grandchild.nodeType==3||grandchild.nodeType==4){var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var value=OpenLayers.Util.getXmlNodeValue(grandchild);if(value){value=value.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
-return attributes;},parseProperty:function(xmlNode,namespace,tagName){var value;var nodeList=this.getElementsByTagNameNS(xmlNode,namespace,tagName);try{value=OpenLayers.Util.getXmlNodeValue(nodeList[0]);}catch(e){value=null;}
-return value;},write:function(features){if(!(features instanceof Array)){features=[features];}
-var kml=this.createElementNS(this.kmlns,"kml");var folder=this.createFolderXML();for(var i=0;i<features.length;++i){folder.appendChild(this.createPlacemarkXML(features[i]));}
-kml.appendChild(folder);return OpenLayers.Format.XML.prototype.write.apply(this,[kml]);},createFolderXML:function(){var folderName=this.createElementNS(this.kmlns,"name");var folderNameText=this.createTextNode(this.foldersName);folderName.appendChild(folderNameText);var folderDesc=this.createElementNS(this.kmlns,"description");var folderDescText=this.createTextNode(this.foldersDesc);folderDesc.appendChild(folderDescText);var folder=this.createElementNS(this.kmlns,"Folder");folder.appendChild(folderName);folder.appendChild(folderDesc);return folder;},createPlacemarkXML:function(feature){var placemarkName=this.createElementNS(this.kmlns,"name");var name=(feature.attributes.name)?feature.attributes.name:feature.id;placemarkName.appendChild(this.createTextNode(name));var placemarkDesc=this.createElementNS(this.kmlns,"description");var desc=(feature.attributes.description)?feature.attributes.description:this.placemarksDesc;placemarkDesc.appendChild(this.createTextNode(desc));var placemarkNode=this.createElementNS(this.kmlns,"Placemark");if(feature.fid!=null){placemarkNode.setAttribute("id",feature.fid);}
-placemarkNode.appendChild(placemarkName);placemarkNode.appendChild(placemarkDesc);var geometryNode=this.buildGeometryNode(feature.geometry);placemarkNode.appendChild(geometryNode);return placemarkNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];var node=null;if(builder){node=builder.apply(this,[geometry]);}
-return node;},buildGeometry:{point:function(geometry){var kml=this.createElementNS(this.kmlns,"Point");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multipoint:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linestring:function(geometry){var kml=this.createElementNS(this.kmlns,"LineString");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multilinestring:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linearring:function(geometry){var kml=this.createElementNS(this.kmlns,"LinearRing");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},polygon:function(geometry){var kml=this.createElementNS(this.kmlns,"Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0;i<rings.length;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.kmlns,type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[i]]);ringMember.appendChild(ringGeom);kml.appendChild(ringMember);}
-return kml;},multipolygon:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},collection:function(geometry){var kml=this.createElementNS(this.kmlns,"MultiGeometry");var child;for(var i=0;i<geometry.components.length;++i){child=this.buildGeometryNode.apply(this,[geometry.components[i]]);if(child){kml.appendChild(child);}}
-return kml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.kmlns,"coordinates");var path;var points=geometry.components;if(points){var point;var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;++i){point=points[i];parts[i]=point.x+","+point.y;}
-path=parts.join(" ");}else{path=geometry.x+","+geometry.y;}
-var txtNode=this.createTextNode(path);coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.KML"});OpenLayers.Format.OSM=OpenLayers.Class(OpenLayers.Format.XML,{checkTags:false,interestingTagsExclude:null,areaTags:null,initialize:function(options){var layer_defaults={'interestingTagsExclude':['source','source_ref','source:ref','history','attribution','created_by'],'areaTags':['area','building','leisure','tourism','ruins','historic','landuse','military','natural','sport']};layer_defaults=OpenLayers.Util.extend(layer_defaults,options);var interesting={};for(var i=0;i<layer_defaults.interestingTagsExclude.length;i++){interesting[layer_defaults.interestingTagsExclude[i]]=true;}
-layer_defaults.interestingTagsExclude=interesting;var area={};for(var i=0;i<layer_defaults.areaTags.length;i++){area[layer_defaults.areaTags[i]]=true;}
-layer_defaults.areaTags=area;OpenLayers.Format.XML.prototype.initialize.apply(this,[layer_defaults]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-var nodes=this.getNodes(doc);var ways=this.getWays(doc);var feat_list=new Array(ways.length);for(var i=0;i<ways.length;i++){var point_list=new Array(ways[i].nodes.length);var poly=this.isWayArea(ways[i])?1:0;for(var j=0;j<ways[i].nodes.length;j++){var node=nodes[ways[i].nodes[j]];var point=new OpenLayers.Geometry.Point(node.lon,node.lat);point.osm_id=parseInt(ways[i].nodes[j]);point_list[j]=point;node.used=true;}
-var geometry=null;if(poly){geometry=new OpenLayers.Geometry.Polygon(new OpenLayers.Geometry.LinearRing(point_list));}else{geometry=new OpenLayers.Geometry.LineString(point_list);}
-var feat=new OpenLayers.Feature.Vector(geometry,ways[i].tags);feat.osm_id=parseInt(ways[i].id);feat.fid="way."+feat.osm_id;feat_list[i]=feat;}
-for(var node_id in nodes){var node=nodes[node_id];if(!node.used||this.checkTags){var tags=null;if(this.checkTags){var result=this.getTags(node.node,true);if(node.used&&!result[1]){continue;}
-tags=result[0];}else{tags=this.getTags(node.node);}
-var feat=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(node['lon'],node['lat']),tags);if(this.internalProjection&&this.externalProjection){feat.geometry.transform(this.externalProjection,this.internalProjection);}
-feat.osm_id=parseInt(node_id);feat.fid="node."+feat.osm_id;feat_list.push(feat);}
-node.node=null;}
-return feat_list;},getNodes:function(doc){var node_list=doc.getElementsByTagName("node");var nodes={};for(var i=0;i<node_list.length;i++){var node=node_list[i];var id=node.getAttribute("id");nodes[id]={'lat':node.getAttribute("lat"),'lon':node.getAttribute("lon"),'node':node};}
-return nodes;},getWays:function(doc){var way_list=doc.getElementsByTagName("way");var return_ways=[];for(var i=0;i<way_list.length;i++){var way=way_list[i];var way_object={id:way.getAttribute("id")};way_object.tags=this.getTags(way);var node_list=way.getElementsByTagName("nd");way_object.nodes=new Array(node_list.length);for(var j=0;j<node_list.length;j++){way_object.nodes[j]=node_list[j].getAttribute("ref");}
-return_ways.push(way_object);}
-return return_ways;},getTags:function(dom_node,interesting_tags){var tag_list=dom_node.getElementsByTagName("tag");var tags={};var interesting=false;for(var j=0;j<tag_list.length;j++){var key=tag_list[j].getAttribute("k");tags[key]=tag_list[j].getAttribute("v");if(interesting_tags){if(!this.interestingTagsExclude[key]){interesting=true;}}}
-return interesting_tags?[tags,interesting]:tags;},isWayArea:function(way){var poly_shaped=false;var poly_tags=false;if(way.nodes[0]==way.nodes[way.nodes.length-1]){poly_shaped=true;}
-if(this.checkTags){for(var key in way.tags){if(this.areaTags[key]){poly_tags=true;break;}}}
-return poly_shaped&&(this.checkTags?poly_tags:true);},write:function(features){if(!(features instanceof Array)){features=[features];}
-this.osm_id=1;this.created_nodes={};var root_node=this.createElementNS(null,"osm");root_node.setAttribute("version","0.5");root_node.setAttribute("generator","OpenLayers "+OpenLayers.VERSION_NUMBER);for(var i=features.length-1;i>=0;i--){var nodes=this.createFeatureNodes(features[i]);for(var j=0;j<nodes.length;j++){root_node.appendChild(nodes[j]);}}
-return OpenLayers.Format.XML.prototype.write.apply(this,[root_node]);},createFeatureNodes:function(feature){var nodes=[];var className=feature.geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);type=type.toLowerCase();var builder=this.createXML[type];if(builder){nodes=builder.apply(this,[feature]);}
-return nodes;},createXML:{'point':function(point){var id=null;var geometry=point.geometry?point.geometry:point;var already_exists=false;if(point.osm_id){id=point.osm_id;if(this.created_nodes[id]){already_exists=true;}}else{id=-this.osm_id;this.osm_id++;}
-if(already_exists){node=this.created_nodes[id];}else{var node=this.createElementNS(null,"node");}
-this.created_nodes[id]=node;node.setAttribute("id",id);node.setAttribute("lon",geometry.x);node.setAttribute("lat",geometry.y);if(point.attributes){this.serializeTags(point,node);}
-this.setState(point,node);return already_exists?[]:[node];},linestring:function(feature){var nodes=[];var geometry=feature.geometry;if(feature.osm_id){id=feature.osm_id;}else{id=-this.osm_id;this.osm_id++;}
-var way=this.createElementNS(null,"way");way.setAttribute("id",id);for(var i=0;i<geometry.components.length;i++){var node=this.createXML['point'].apply(this,[geometry.components[i]]);if(node.length){node=node[0];var node_ref=node.getAttribute("id");nodes.push(node);}else{node_ref=geometry.components[i].osm_id;node=this.created_nodes[node_ref];}
-this.setState(feature,node);var nd_dom=this.createElementNS(null,"nd");nd_dom.setAttribute("ref",node_ref);way.appendChild(nd_dom);}
-this.serializeTags(feature,way);nodes.push(way);return nodes;},polygon:function(feature){var attrs=OpenLayers.Util.extend({'area':'yes'},feature.attributes);var feat=new OpenLayers.Feature.Vector(feature.geometry.components[0],attrs);feat.osm_id=feature.osm_id;return this.createXML['linestring'].apply(this,[feat]);}},serializeTags:function(feature,node){for(var key in feature.attributes){var tag=this.createElementNS(null,"tag");tag.setAttribute("k",key);tag.setAttribute("v",feature.attributes[key]);node.appendChild(tag);}},setState:function(feature,node){if(feature.state){var state=null;switch(feature.state){case OpenLayers.State.UPDATE:state="modify";case OpenLayers.State.DELETE:state="delete";}
-if(state){node.setAttribute("action",state);}}},CLASS_NAME:"OpenLayers.Format.OSM"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.LineString.prototype.initialize.apply(this,arguments);},addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
-var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);return added;},removeComponent:function(point){if(this.components.length>4){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);}},move:function(x,y){for(var i=0;i<this.components.length-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0;i<this.components.length-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length-1;++i){this.components[i].resize(scale,origin,ratio);}},transform:function(source,dest){if(source&&dest){for(var i=0;i<this.components.length-1;i++){var component=this.components[i];component.transform(source,dest);}}
-return this;},getArea:function(){var area=0.0;if(this.components&&(this.components.length>2)){var sum=0.0;for(var i=0;i<this.components.length-1;i++){var b=this.components[i];var c=this.components[i+1];sum+=(b.x+c.x)*(c.y-b.y);}
-area=-sum/2.0;}
-return area;},containsPoint:function(point){var approx=OpenLayers.Number.limitSigDigs;var digs=14;var px=approx(point.x,digs);var py=approx(point.y,digs);function getX(y,x1,y1,x2,y2){return(((x1-x2)*y)+((x2*y1)-(x1*y2)))/(y1-y2);}
-var numSeg=this.components.length-1;var start,end,x1,y1,x2,y2,cx,cy;var crosses=0;for(var i=0;i<numSeg;++i){start=this.components[i];x1=approx(start.x,digs);y1=approx(start.y,digs);end=this.components[i+1];x2=approx(end.x,digs);y2=approx(end.y,digs);if(y1==y2){if(py==y1){if(x1<=x2&&(px>=x1&&px<=x2)||x1>=x2&&(px<=x1&&px>=x2)){crosses=-1;break;}}
-continue;}
-cx=approx(getX(py,x1,y1,x2,y2),digs);if(cx==px){if(y1<y2&&(py>=y1&&py<=y2)||y1>y2&&(py<=y1&&py>=y2)){crosses=-1;break;}}
-if(cx<=px){continue;}
-if(x1!=x2&&(cx<Math.min(x1,x2)||cx>Math.max(x1,x2))){continue;}
-if(y1<y2&&(py>=y1&&py<y2)||y1>y2&&(py<y1&&py>=y2)){++crosses;}}
-var contained=(crosses==-1)?1:!!(crosses&1);return contained;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){intersect=geometry.intersects(this);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){intersect=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[geometry]);}else{for(var i=0;i<geometry.components.length;++i){intersect=geometry.components[i].intersects(this);if(intersect){break;}}}
-return intersect;},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,freehand:false,freehandToggle:'shiftKey',initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(){this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString());this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},destroyFeature:function(){OpenLayers.Handler.Point.prototype.destroyFeature.apply(this);if(this.line){this.line.destroy();}
-this.line=null;},addPoint:function(){this.line.geometry.addComponent(this.point.geometry.clone(),this.line.geometry.components.length);this.callback("point",[this.point.geometry]);},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(){var index=this.line.geometry.components.length-1;this.line.geometry.components[index].x=this.point.geometry.x;this.line.geometry.components[index].y=this.point.geometry.y;this.line.geometry.components[index].clearBounds();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.line.geometry.clone();},mousedown:function(evt){if(this.lastDown&&this.lastDown.equals(evt.xy)){return false;}
-if(this.lastDown==null){this.createFeature();}
-this.mouseDown=true;this.lastDown=evt.xy;var lonlat=this.control.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;if((this.lastUp==null)||!this.lastUp.equals(evt.xy)){this.addPoint();}
-this.drawFeature();this.drawing=true;return false;},mousemove:function(evt){if(this.drawing){var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;if(this.mouseDown&&this.freehandMode(evt)){this.addPoint();}else{this.modifyFeature();}
-this.drawFeature();}
-return true;},mouseup:function(evt){this.mouseDown=false;if(this.drawing){if(this.freehandMode(evt)){this.finalize();}else{if(this.lastUp==null){this.addPoint();}
-this.lastUp=evt.xy;}
-return false;}
-return true;},dblclick:function(evt){if(!this.freehandMode(evt)){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.finalize();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Format.WFS=OpenLayers.Class(OpenLayers.Format.GML,{layer:null,wfsns:"http://www.opengis.net/wfs",ogcns:"http://www.opengis.net/ogc",initialize:function(options,layer){OpenLayers.Format.GML.prototype.initialize.apply(this,[options]);this.layer=layer;if(this.layer.featureNS){this.featureNS=this.layer.featureNS;}
-if(this.layer.options.geometry_column){this.geometryName=this.layer.options.geometry_column;}
-if(this.layer.options.typename){this.featureName=this.layer.options.typename;}},write:function(features){var transaction=this.createElementNS(this.wfsns,'wfs:Transaction');transaction.setAttribute("version","1.0.0");transaction.setAttribute("service","WFS");for(var i=0;i<features.length;i++){switch(features[i].state){case OpenLayers.State.INSERT:transaction.appendChild(this.insert(features[i]));break;case OpenLayers.State.UPDATE:transaction.appendChild(this.update(features[i]));break;case OpenLayers.State.DELETE:transaction.appendChild(this.remove(features[i]));break;}}
-return OpenLayers.Format.XML.prototype.write.apply(this,[transaction]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var geomContainer=this.createElementNS(this.featureNS,"feature:"+this.geometryName);geomContainer.appendChild(geometryNode);var featureContainer=this.createElementNS(this.featureNS,"feature:"+this.featureName);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
-var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
-return featureContainer;},insert:function(feature){var insertNode=this.createElementNS(this.wfsns,'wfs:Insert');insertNode.appendChild(this.createFeatureXML(feature));return insertNode;},update:function(feature){if(!feature.fid){alert(OpenLayers.i18n("noFID"));}
-var updateNode=this.createElementNS(this.wfsns,'wfs:Update');updateNode.setAttribute("typeName",this.layerName);var propertyNode=this.createElementNS(this.wfsns,'wfs:Property');var nameNode=this.createElementNS(this.wfsns,'wfs:Name');var txtNode=this.createTextNode(this.geometryName);nameNode.appendChild(txtNode);propertyNode.appendChild(nameNode);var valueNode=this.createElementNS(this.wfsns,'wfs:Value');var geometryNode=this.buildGeometryNode(feature.geometry);if(feature.layer){geometryNode.setAttribute("srsName",feature.layer.projection.getCode());}
-valueNode.appendChild(geometryNode);propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);for(var propName in feature.attributes){propertyNode=this.createElementNS(this.wfsns,'wfs:Property');nameNode=this.createElementNS(this.wfsns,'wfs:Name');nameNode.appendChild(this.createTextNode(propName));propertyNode.appendChild(nameNode);valueNode=this.createElementNS(this.wfsns,'wfs:Value');valueNode.appendChild(this.createTextNode(feature.attributes[propName]));propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);}
-var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);updateNode.appendChild(filterNode);return updateNode;},remove:function(feature){if(!feature.fid){alert(OpenLayers.i18n("noFID"));return false;}
-var deleteNode=this.createElementNS(this.wfsns,'wfs:Delete');deleteNode.setAttribute("typeName",this.layerName);var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);deleteNode.appendChild(filterNode);return deleteNode;},destroy:function(){this.layer=null;},CLASS_NAME:"OpenLayers.Format.WFS"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{polygon:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Path.prototype.initialize.apply(this,arguments);},createFeature:function(){this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon());this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing());this.polygon.geometry.addComponent(this.line.geometry);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},destroyFeature:function(){OpenLayers.Handler.Path.prototype.destroyFeature.apply(this);if(this.polygon){this.polygon.destroy();}
-this.polygon=null;},modifyFeature:function(){var index=this.line.geometry.components.length-2;this.line.geometry.components[index].x=this.point.geometry.x;this.line.geometry.components[index].y=this.point.geometry.y;this.line.geometry.components[index].clearBounds();},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.polygon.geometry.clone();},dblclick:function(evt){if(!this.freehandMode(evt)){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.finalize();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{'displayClass':'olControlDrawFeaturePoint'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{'displayClass':'olControlDrawFeaturePath'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Polygon,{'displayClass':'olControlDrawFeaturePolygon'})];for(var i=0;i<controls.length;i++){controls[i].featureAdded=function(feature){feature.state=OpenLayers.State.INSERT;};}
-this.addControls(controls);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});
\ No newline at end of file
Deleted: branches/testbaudson_dev/http/extensions/jqjson.js
--- trunk/mapbender/http/extensions/jqjson.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/extensions/jqjson.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,96 +0,0 @@
-(function ($) {
-    var m = {
-            '\b': '\\b',
-            '\t': '\\t',
-            '\n': '\\n',
-            '\f': '\\f',
-            '\r': '\\r',
-        s = {
-            'array': function (x) {
-                var a = ['['], b, f, i, l = x.length, v;
-                for (i = 0; i < l; i += 1) {
-                    v = x[i];
-                    f = s[typeof v];
-                    if (f) {
-                        v = f(v);
-                        if (typeof v == 'string') {
-                            if (b) {
-                                a[a.length] = ',';
-                            a[a.length] = v;
-                            b = true;
-                a[a.length] = ']';
-                return a.join('');
-            'boolean': function (x) {
-                return String(x);
-            'null': function (x) {
-                return "null";
-            'number': function (x) {
-                return isFinite(x) ? String(x) : 'null';
-            'object': function (x) {
-                if (x) {
-                    if (x instanceof Array) {
-                        return s.array(x);
-                    var a = ['{'], b, f, i, v;
-                    for (i in x) {
-                        v = x[i];
-                        f = s[typeof v];
-                        if (f) {
-                            v = f(v);
-                                if (b) {
-                                a.push(s.string(i), ':', v);
-                                b = true;
-                    a[a.length] = '}';
-                return 'null';
-            'string': function (x) {
-                if (/["\\\x00-\x1f]/.test(x)) {
-                    x = x.replace(/([\x00-\x1f\\"])/g, function(a, b) {
-                        var c = m[b];
-                        if (c) {
-                            return c;
-                        c = b.charCodeAt();
-                        return '\\u00' +
-                            Math.floor(c / 16).toString(16) +
-                            (c % 16).toString(16);
-                return '"' + x + '"';
-	$.toJSON = function(v) {
-		var f = isNaN(v) ? s[typeof v] : s['number'];
-		if (f) return f(v);
-	$.parseJSON = function(v, safe) {
-		if (safe === undefined) safe = $.parseJSON.safe;
-		if (safe && !/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.test(v))
-			return undefined;
-		return eval('('+v+')');
-	$.parseJSON.safe = false;
-})(jQuery);
Deleted: branches/testbaudson_dev/http/extensions/jquery-1.2.6.min.js
--- trunk/mapbender/http/extensions/jquery-1.2.6.min.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/extensions/jquery-1.2.6.min.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,32 +0,0 @@
- * jQuery 1.2.6 - New Wave Javascript
- * Copyright (c) 2008 John Resig (jquery.com)
- * Dual licensed under the MIT (MIT-LICENSE.txt)
- * and GPL (GPL-LICENSE.txt) licenses.
- * $Date: 2008-05-24 14:22:17 -0400 (Sat, 24 May 2008) $
- * $Rev: 5685 $
-(function(){var _jQuery=window.jQuery,_$=window.$;var jQuery=window.jQuery=window.$=function(selector,context){return new jQuery.fn.init(selector,context);};var quickExpr=/^[^<]*(<(.|\s)+>)[^>]*$|^#(\w+)$/,isSimple=/^.[^:#\[\.]*$/,undefined;jQuery.fn=jQuery.prototype={init:function(selector,context){selector=selector||document;if(selector.nodeType){this[0]=selector;this.length=1;return this;}if(typeof selector=="string"){var match=quickExpr.exec(selector);if(match&&(match[1]||!context)){if(match[1])selector=jQuery.clean([match[1]],context);else{var elem=document.getElementById(match[3]);if(elem){if(elem.id!=match[3])return jQuery().find(selector);return jQuery(elem);}selector=[];}}else
-return jQuery(context).find(selector);}else if(jQuery.isFunction(selector))return jQuery(document)[jQuery.fn.ready?"ready":"load"](selector);return this.setArray(jQuery.makeArray(selector));},jquery:"1.2.6",size:function(){return this.length;},length:0,get:function(num){return num==undefined?jQuery.makeArray(this):this[num];},pushStack:function(elems){var ret=jQuery(elems);ret.prevObject=this;return ret;},setArray:function(elems){this.length=0;Array.prototype.push.apply(this,elems);return this;},each:function(callback,args){return jQuery.each(this,callback,args);},index:function(elem){var ret=-1;return jQuery.inArray(elem&&elem.jquery?elem[0]:elem,this);},attr:function(name,value,type){var options=name;if(name.constructor==String)if(value===undefined)return this[0]&&jQuery[type||"attr"](this[0],name);else{options={};options[name]=value;}return this.each(function(i){for(name in options)jQuery.attr(type?this.style:this,name,jQuery.prop(this,options[name],type,i,name));});},css:function(key,value){if((key=='width'||key=='height')&&parseFloat(value)<0)value=undefined;return this.attr(key,value,"curCSS");},text:function(text){if(typeof text!="object"&&text!=null)return this.empty().append((this[0]&&this[0].ownerDocument||document).createTextNode(text));var ret="";jQuery.each(text||this,function(){jQuery.each(this.childNodes,function(){if(this.nodeType!=8)ret+=this.nodeType!=1?this.nodeValue:jQuery.fn.text([this]);});});return ret;},wrapAll:function(html){if(this[0])jQuery(html,this[0].ownerDocument).clone().insertBefore(this[0]).map(function(){var elem=this;while(elem.firstChild)elem=elem.firstChild;return elem;}).append(this);return this;},wrapInner:function(html){return this.each(function(){jQuery(this).contents().wrapAll(html);});},wrap:function(html){return this.each(function(){jQuery(this).wrapAll(html);});},append:function(){return this.domManip(arguments,true,false,function(elem){if(this.nodeType==1)this.appendChild(elem);});},prepend:function(){return this.domManip(arguments,true,true,function(elem){if(this.nodeType==1)this.insertBefore(elem,this.firstChild);});},before:function(){return this.domManip(arguments,false,false,function(elem){this.parentNode.insertBefore(elem,this);});},after:function(){return this.domManip(arguments,false,true,function(elem){this.parentNode.insertBefore(elem,this.nextSibling);});},end:function(){return this.prevObject||jQuery([]);},find:function(selector){var elems=jQuery.map(this,function(elem){return jQuery.find(selector,elem);});return this.pushStack(/[^+>] [^+>]/.test(selector)||selector.indexOf("..")>-1?jQuery.unique(elems):elems);},clone:function(events){var ret=this.map(function(){if(jQuery.browser.msie&&!jQuery.isXMLDoc(this)){var clone=this.cloneNode(true),container=document.createElement("div");container.appendChild(clone);return jQuery.clean([container.innerHTML])[0];}else
-return this.cloneNode(true);});var clone=ret.find("*").andSelf().each(function(){if(this[expando]!=undefined)this[expando]=null;});if(events===true)this.find("*").andSelf().each(function(i){if(this.nodeType==3)return;var events=jQuery.data(this,"events");for(var type in events)for(var handler in events[type])jQuery.event.add(clone[i],type,events[type][handler],events[type][handler].data);});return ret;},filter:function(selector){return this.pushStack(jQuery.isFunction(selector)&&jQuery.grep(this,function(elem,i){return selector.call(elem,i);})||jQuery.multiFilter(selector,this));},not:function(selector){if(selector.constructor==String)if(isSimple.test(selector))return this.pushStack(jQuery.multiFilter(selector,this,true));else
-selector=jQuery.multiFilter(selector,this);var isArrayLike=selector.length&&selector[selector.length-1]!==undefined&&!selector.nodeType;return this.filter(function(){return isArrayLike?jQuery.inArray(this,selector)<0:this!=selector;});},add:function(selector){return this.pushStack(jQuery.unique(jQuery.merge(this.get(),typeof selector=='string'?jQuery(selector):jQuery.makeArray(selector))));},is:function(selector){return!!selector&&jQuery.multiFilter(selector,this).length>0;},hasClass:function(selector){return this.is("."+selector);},val:function(value){if(value==undefined){if(this.length){var elem=this[0];if(jQuery.nodeName(elem,"select")){var index=elem.selectedIndex,values=[],options=elem.options,one=elem.type=="select-one";if(index<0)return null;for(var i=one?index:0,max=one?index+1:options.length;i<max;i++){var option=options[i];if(option.selected){value=jQuery.browser.msie&&!option.attributes.value.specified?option.text:option.value;if(one)return value;values.push(value);}}return values;}else
-return(this[0].value||"").replace(/\r/g,"");}return undefined;}if(value.constructor==Number)value+='';return this.each(function(){if(this.nodeType!=1)return;if(value.constructor==Array&&/radio|checkbox/.test(this.type))this.checked=(jQuery.inArray(this.value,value)>=0||jQuery.inArray(this.name,value)>=0);else if(jQuery.nodeName(this,"select")){var values=jQuery.makeArray(value);jQuery("option",this).each(function(){this.selected=(jQuery.inArray(this.value,values)>=0||jQuery.inArray(this.text,values)>=0);});if(!values.length)this.selectedIndex=-1;}else
-this.value=value;});},html:function(value){return value==undefined?(this[0]?this[0].innerHTML:null):this.empty().append(value);},replaceWith:function(value){return this.after(value).remove();},eq:function(i){return this.slice(i,i+1);},slice:function(){return this.pushStack(Array.prototype.slice.apply(this,arguments));},map:function(callback){return this.pushStack(jQuery.map(this,function(elem,i){return callback.call(elem,i,elem);}));},andSelf:function(){return this.add(this.prevObject);},data:function(key,value){var parts=key.split(".");parts[1]=parts[1]?"."+parts[1]:"";if(value===undefined){var data=this.triggerHandler("getData"+parts[1]+"!",[parts[0]]);if(data===undefined&&this.length)data=jQuery.data(this[0],key);return data===undefined&&parts[1]?this.data(parts[0]):data;}else
-return this.trigger("setData"+parts[1]+"!",[parts[0],value]).each(function(){jQuery.data(this,key,value);});},removeData:function(key){return this.each(function(){jQuery.removeData(this,key);});},domManip:function(args,table,reverse,callback){var clone=this.length>1,elems;return this.each(function(){if(!elems){elems=jQuery.clean(args,this.ownerDocument);if(reverse)elems.reverse();}var obj=this;if(table&&jQuery.nodeName(this,"table")&&jQuery.nodeName(elems[0],"tr"))obj=this.getElementsByTagName("tbody")[0]||this.appendChild(this.ownerDocument.createElement("tbody"));var scripts=jQuery([]);jQuery.each(elems,function(){var elem=clone?jQuery(this).clone(true)[0]:this;if(jQuery.nodeName(elem,"script"))scripts=scripts.add(elem);else{if(elem.nodeType==1)scripts=scripts.add(jQuery("script",elem).remove());callback.call(obj,elem);}});scripts.each(evalScript);});}};jQuery.fn.init.prototype=jQuery.fn;function evalScript(i,elem){if(elem.src)jQuery.ajax({url:elem.src,async:false,dataType:"script"});else
-jQuery.globalEval(elem.text||elem.textContent||elem.innerHTML||"");if(elem.parentNode)elem.parentNode.removeChild(elem);}function now(){return+new Date;}jQuery.extend=jQuery.fn.extend=function(){var target=arguments[0]||{},i=1,length=arguments.length,deep=false,options;if(target.constructor==Boolean){deep=target;target=arguments[1]||{};i=2;}if(typeof target!="object"&&typeof target!="function")target={};if(length==i){target=this;--i;}for(;i<length;i++)if((options=arguments[i])!=null)for(var name in options){var src=target[name],copy=options[name];if(target===copy)continue;if(deep&&copy&&typeof copy=="object"&&!copy.nodeType)target[name]=jQuery.extend(deep,src||(copy.length!=null?[]:{}),copy);else if(copy!==undefined)target[name]=copy;}return target;};var expando="jQuery"+now(),uuid=0,windowData={},exclude=/z-?index|font-?weight|opacity|zoom|line-?height/i,defaultView=document.defaultView||{};jQuery.extend({noConflict:function(deep){window.$=_$;if(deep)window.jQuery=_jQuery;return jQuery;},isFunction:function(fn){return!!fn&&typeof fn!="string"&&!fn.nodeName&&fn.constructor!=Array&&/^[\s[]?function/.test(fn+"");},isXMLDoc:function(elem){return elem.documentElement&&!elem.body||elem.tagName&&elem.ownerDocument&&!elem.ownerDocument.body;},globalEval:function(data){data=jQuery.trim(data);if(data){var head=document.getElementsByTagName("head")[0]||document.documentElement,script=document.createElement("script");script.type="text/javascript";if(jQuery.browser.msie)script.text=data;else
-script.appendChild(document.createTextNode(data));head.insertBefore(script,head.firstChild);head.removeChild(script);}},nodeName:function(elem,name){return elem.nodeName&&elem.nodeName.toUpperCase()==name.toUpperCase();},cache:{},data:function(elem,name,data){elem=elem==window?windowData:elem;var id=elem[expando];if(!id)id=elem[expando]=++uuid;if(name&&!jQuery.cache[id])jQuery.cache[id]={};if(data!==undefined)jQuery.cache[id][name]=data;return name?jQuery.cache[id][name]:id;},removeData:function(elem,name){elem=elem==window?windowData:elem;var id=elem[expando];if(name){if(jQuery.cache[id]){delete jQuery.cache[id][name];name="";for(name in jQuery.cache[id])break;if(!name)jQuery.removeData(elem);}}else{try{delete elem[expando];}catch(e){if(elem.removeAttribute)elem.removeAttribute(expando);}delete jQuery.cache[id];}},each:function(object,callback,args){var name,i=0,length=object.length;if(args){if(length==undefined){for(name in object)if(callback.apply(object[name],args)===false)break;}else
-for(;i<length;)if(callback.apply(object[i++],args)===false)break;}else{if(length==undefined){for(name in object)if(callback.call(object[name],name,object[name])===false)break;}else
-for(var value=object[0];i<length&&callback.call(value,i,value)!==false;value=object[++i]){}}return object;},prop:function(elem,value,type,i,name){if(jQuery.isFunction(value))value=value.call(elem,i);return value&&value.constructor==Number&&type=="curCSS"&&!exclude.test(name)?value+"px":value;},className:{add:function(elem,classNames){jQuery.each((classNames||"").split(/\s+/),function(i,className){if(elem.nodeType==1&&!jQuery.className.has(elem.className,className))elem.className+=(elem.className?" ":"")+className;});},remove:function(elem,classNames){if(elem.nodeType==1)elem.className=classNames!=undefined?jQuery.grep(elem.className.split(/\s+/),function(className){return!jQuery.className.has(classNames,className);}).join(" "):"";},has:function(elem,className){return jQuery.inArray(className,(elem.className||elem).toString().split(/\s+/))>-1;}},swap:function(elem,options,callback){var old={};for(var name in options){old[name]=elem.style[name];elem.style[name]=options[name];}callback.call(elem);for(var name in options)elem.style[name]=old[name];},css:function(elem,name,force){if(name=="width"||name=="height"){var val,props={position:"absolute",visibility:"hidden",display:"block"},which=name=="width"?["Left","Right"]:["Top","Bottom"];function getWH(){val=name=="width"?elem.offsetWidth:elem.offsetHeight;var padding=0,border=0;jQuery.each(which,function(){padding+=parseFloat(jQuery.curCSS(elem,"padding"+this,true))||0;border+=parseFloat(jQuery.curCSS(elem,"border"+this+"Width",true))||0;});val-=Math.round(padding+border);}if(jQuery(elem).is(":visible"))getWH();else
-jQuery.swap(elem,props,getWH);return Math.max(0,val);}return jQuery.curCSS(elem,name,force);},curCSS:function(elem,name,force){var ret,style=elem.style;function color(elem){if(!jQuery.browser.safari)return false;var ret=defaultView.getComputedStyle(elem,null);return!ret||ret.getPropertyValue("color")=="";}if(name=="opacity"&&jQuery.browser.msie){ret=jQuery.attr(style,"opacity");return ret==""?"1":ret;}if(jQuery.browser.opera&&name=="display"){var save=style.outline;style.outline="0 solid black";style.outline=save;}if(name.match(/float/i))name=styleFloat;if(!force&&style&&style[name])ret=style[name];else if(defaultView.getComputedStyle){if(name.match(/float/i))name="float";name=name.replace(/([A-Z])/g,"-$1").toLowerCase();var computedStyle=defaultView.getComputedStyle(elem,null);if(computedStyle&&!color(elem))ret=computedStyle.getPropertyValue(name);else{var swap=[],stack=[],a=elem,i=0;for(;a&&color(a);a=a.parentNode)stack.unshift(a);for(;i<stack.length;i++)if(color(stack[i])){swap[i]=stack[i].style.display;stack[i].style.display="block";}ret=name=="display"&&swap[stack.length-1]!=null?"none":(computedStyle&&computedStyle.getPropertyValue(name))||"";for(i=0;i<swap.length;i++)if(swap[i]!=null)stack[i].style.display=swap[i];}if(name=="opacity"&&ret=="")ret="1";}else if(elem.currentStyle){var camelCase=name.replace(/\-(\w)/g,function(all,letter){return letter.toUpperCase();});ret=elem.currentStyle[name]||elem.currentStyle[camelCase];if(!/^\d+(px)?$/i.test(ret)&&/^\d/.test(ret)){var left=style.left,rsLeft=elem.runtimeStyle.left;elem.runtimeStyle.left=elem.currentStyle.left;style.left=ret||0;ret=style.pixelLeft+"px";style.left=left;elem.runtimeStyle.left=rsLeft;}}return ret;},clean:function(elems,context){var ret=[];context=context||document;if(typeof context.createElement=='undefined')context=context.ownerDocument||context[0]&&context[0].ownerDocument||document;jQuery.each(elems,function(i,elem){if(!elem)return;if(elem.constructor==Number)elem+='';if(typeof elem=="string"){elem=elem.replace(/(<(\w+)[^>]*?)\/>/g,function(all,front,tag){return tag.match(/^(abbr|br|col|img|input|link|meta|param|hr|area|embed)$/i)?all:front+"></"+tag+">";});var tags=jQuery.trim(elem).toLowerCase(),div=context.createElement("div");var wrap=!tags.indexOf("<opt")&&[1,"<select multiple='multiple'>","</select>"]||!tags.indexOf("<leg")&&[1,"<fieldset>","</fieldset>"]||tags.match(/^<(thead|tbody|tfoot|colg|cap)/)&&[1,"<table>","</table>"]||!tags.indexOf("<tr")&&[2,"<table><tbody>","</tbody></table>"]||(!tags.indexOf("<td")||!tags.indexOf("<th"))&&[3,"<table><tbody><tr>","</tr></tbody></table>"]||!tags.indexOf("<col")&&[2,"<table><tbody></tbody><colgroup>","</colgroup></table>"]||jQuery.browser.msie&&[1,"div<div>","</div>"]||[0,"",""];div.innerHTML=wrap[1]+elem+wrap[2];while(wrap[0]--)div=div.lastChild;if(jQuery.browser.msie){var tbody=!tags.indexOf("<table")&&tags.indexOf("<tbody")<0?div.firstChild&&div.firstChild.childNodes:wrap[1]=="<table>"&&tags.indexOf("<tbody")<0?div.childNodes:[];for(var j=tbody.length-1;j>=0;--j)if(jQuery.nodeName(tbody[j],"tbody")&&!tbody[j].childNodes.length)tbody[j].parentNode.removeChild(tbody[j]);if(/^\s/.test(elem))div.insertBefore(context.createTextNode(elem.match(/^\s*/)[0]),div.firstChild);}elem=jQuery.makeArray(div.childNodes);}if(elem.length===0&&(!jQuery.nodeName(elem,"form")&&!jQuery.nodeName(elem,"select")))return;if(elem[0]==undefined||jQuery.nodeName(elem,"form")||elem.options)ret.push(elem);else
-ret=jQuery.merge(ret,elem);});return ret;},attr:function(elem,name,value){if(!elem||elem.nodeType==3||elem.nodeType==8)return undefined;var notxml=!jQuery.isXMLDoc(elem),set=value!==undefined,msie=jQuery.browser.msie;name=notxml&&jQuery.props[name]||name;if(elem.tagName){var special=/href|src|style/.test(name);if(name=="selected"&&jQuery.browser.safari)elem.parentNode.selectedIndex;if(name in elem&&notxml&&!special){if(set){if(name=="type"&&jQuery.nodeName(elem,"input")&&elem.parentNode)throw"type property can't be changed";elem[name]=value;}if(jQuery.nodeName(elem,"form")&&elem.getAttributeNode(name))return elem.getAttributeNode(name).nodeValue;return elem[name];}if(msie&&notxml&&name=="style")return jQuery.attr(elem.style,"cssText",value);if(set)elem.setAttribute(name,""+value);var attr=msie&&notxml&&special?elem.getAttribute(name,2):elem.getAttribute(name);return attr===null?undefined:attr;}if(msie&&name=="opacity"){if(set){elem.zoom=1;elem.filter=(elem.filter||"").replace(/alpha\([^)]*\)/,"")+(parseInt(value)+''=="NaN"?"":"alpha(opacity="+value*100+")");}return elem.filter&&elem.filter.indexOf("opacity=")>=0?(parseFloat(elem.filter.match(/opacity=([^)]*)/)[1])/100)+'':"";}name=name.replace(/-([a-z])/ig,function(all,letter){return letter.toUpperCase();});if(set)elem[name]=value;return elem[name];},trim:function(text){return(text||"").replace(/^\s+|\s+$/g,"");},makeArray:function(array){var ret=[];if(array!=null){var i=array.length;if(i==null||array.split||array.setInterval||array.call)ret[0]=array;else
-while(i)ret[--i]=array[i];}return ret;},inArray:function(elem,array){for(var i=0,length=array.length;i<length;i++)if(array[i]===elem)return i;return-1;},merge:function(first,second){var i=0,elem,pos=first.length;if(jQuery.browser.msie){while(elem=second[i++])if(elem.nodeType!=8)first[pos++]=elem;}else
-while(elem=second[i++])first[pos++]=elem;return first;},unique:function(array){var ret=[],done={};try{for(var i=0,length=array.length;i<length;i++){var id=jQuery.data(array[i]);if(!done[id]){done[id]=true;ret.push(array[i]);}}}catch(e){ret=array;}return ret;},grep:function(elems,callback,inv){var ret=[];for(var i=0,length=elems.length;i<length;i++)if(!inv!=!callback(elems[i],i))ret.push(elems[i]);return ret;},map:function(elems,callback){var ret=[];for(var i=0,length=elems.length;i<length;i++){var value=callback(elems[i],i);if(value!=null)ret[ret.length]=value;}return ret.concat.apply([],ret);}});var userAgent=navigator.userAgent.toLowerCase();jQuery.browser={version:(userAgent.match(/.+(?:rv|it|ra|ie)[\/: ]([\d.]+)/)||[])[1],safari:/webkit/.test(userAgent),opera:/opera/.test(userAgent),msie:/msie/.test(userAgent)&&!/opera/.test(userAgent),mozilla:/mozilla/.test(userAgent)&&!/(compatible|webkit)/.test(userAgent)};var styleFloat=jQuery.browser.msie?"styleFloat":"cssFloat";jQuery.extend({boxModel:!jQuery.browser.msie||document.compatMode=="CSS1Compat",props:{"for":"htmlFor","class":"className","float":styleFloat,cssFloat:styleFloat,styleFloat:styleFloat,readonly:"readOnly",maxlength:"maxLength",cellspacing:"cellSpacing"}});jQuery.each({parent:function(elem){return elem.parentNode;},parents:function(elem){return jQuery.dir(elem,"parentNode");},next:function(elem){return jQuery.nth(elem,2,"nextSibling");},prev:function(elem){return jQuery.nth(elem,2,"previousSibling");},nextAll:function(elem){return jQuery.dir(elem,"nextSibling");},prevAll:function(elem){return jQuery.dir(elem,"previousSibling");},siblings:function(elem){return jQuery.sibling(elem.parentNode.firstChild,elem);},children:function(elem){return jQuery.sibling(elem.firstChild);},contents:function(elem){return jQuery.nodeName(elem,"iframe")?elem.contentDocument||elem.contentWindow.document:jQuery.makeArray(elem.childNodes);}},function(name,fn){jQuery.fn[name]=function(selector){var ret=jQuery.map(this,fn);if(selector&&typeof selector=="string")ret=jQuery.multiFilter(selector,ret);return this.pushStack(jQuery.unique(ret));};});jQuery.each({appendTo:"append",prependTo:"prepend",insertBefore:"before",insertAfter:"after",replaceAll:"replaceWith"},function(name,original){jQuery.fn[name]=function(){var args=arguments;return this.each(function(){for(var i=0,length=args.length;i<length;i++)jQuery(args[i])[original](this);});};});jQuery.each({removeAttr:function(name){jQuery.attr(this,name,"");if(this.nodeType==1)this.removeAttribute(name);},addClass:function(classNames){jQuery.className.add(this,classNames);},removeClass:function(classNames){jQuery.className.remove(this,classNames);},toggleClass:function(classNames){jQuery.className[jQuery.className.has(this,classNames)?"remove":"add"](this,classNames);},remove:function(selector){if(!selector||jQuery.filter(selector,[this]).r.length){jQuery("*",this).add(this).each(function(){jQuery.event.remove(this);jQuery.removeData(this);});if(this.parentNode)this.parentNode.removeChild(this);}},empty:function(){jQuery(">*",this).remove();while(this.firstChild)this.removeChild(this.firstChild);}},function(name,fn){jQuery.fn[name]=function(){return this.each(fn,arguments);};});jQuery.each(["Height","Width"],function(i,name){var type=name.toLowerCase();jQuery.fn[type]=function(size){return this[0]==window?jQuery.browser.opera&&document.body["client"+name]||jQuery.browser.safari&&window["inner"+name]||document.compatMode=="CSS1Compat"&&document.documentElement["client"+name]||document.body["client"+name]:this[0]==document?Math.max(Math.max(document.body["scroll"+name],document.documentElement["scroll"+name]),Math.max(document.body["offset"+name],document.documentElement["offset"+name])):size==undefined?(this.length?jQuery.css(this[0],type):null):this.css(type,size.constructor==String?size:size+"px");};});function num(elem,prop){return elem[0]&&parseInt(jQuery.curCSS(elem[0],prop,true),10)||0;}var chars=jQuery.browser.safari&&parseInt(jQuery.browser.version)<417?"(?:[\\w*_-]|\\\\.)":"(?:[\\w\u0128-\uFFFF*_-]|\\\\.)",quickChild=new RegExp("^>\\s*("+chars+"+)"),quickID=new RegExp("^("+chars+"+)(#)("+chars+"+)"),quickClass=new RegExp("^([#.]?)("+chars+"*)");jQuery.extend({expr:{"":function(a,i,m){return m[2]=="*"||jQuery.nodeName(a,m[2]);},"#":function(a,i,m){return a.getAttribute("id")==m[2];},":":{lt:function(a,i,m){return i<m[3]-0;},gt:function(a,i,m){return i>m[3]-0;},nth:function(a,i,m){return m[3]-0==i;},eq:function(a,i,m){return m[3]-0==i;},first:function(a,i){return i==0;},last:function(a,i,m,r){return i==r.length-1;},even:function(a,i){return i%2==0;},odd:function(a,i){return i%2;},"first-child":function(a){return a.parentNode.getElementsByTagName("*")[0]==a;},"last-child":function(a){return jQuery.nth(a.parentNode.lastChild,1,"previousSibling")==a;},"only-child":function(a){return!jQuery.nth(a.parentNode.lastChild,2,"previousSibling");},parent:function(a){return a.firstChild;},empty:function(a){return!a.firstChild;},contains:function(a,i,m){return(a.textContent||a.innerText||jQuery(a).text()||"").indexOf(m[3])>=0;},visible:function(a){return"hidden"!=a.type&&jQuery.css(a,"display")!="none"&&jQuery.css(a,"visibility")!="hidden";},hidden:function(a){return"hidden"==a.type||jQuery.css(a,"display")=="none"||jQuery.css(a,"visibility")=="hidden";},enabled:function(a){return!a.disabled;},disabled:function(a){return a.disabled;},checked:function(a){return a.checked;},selected:function(a){return a.selected||jQuery.attr(a,"selected");},text:function(a){return"text"==a.type;},radio:function(a){return"radio"==a.type;},checkbox:function(a){return"checkbox"==a.type;},file:function(a){return"file"==a.type;},password:function(a){return"password"==a.type;},submit:function(a){return"submit"==a.type;},image:function(a){return"image"==a.type;},reset:function(a){return"reset"==a.type;},button:function(a){return"button"==a.type||jQuery.nodeName(a,"button");},input:function(a){return/input|select|textarea|button/i.test(a.nodeName);},has:function(a,i,m){return jQuery.find(m[3],a).length;},header:function(a){return/h\d/i.test(a.nodeName);},animated:function(a){return jQuery.grep(jQuery.timers,function(fn){return a==fn.elem;}).length;}}},parse:[/^(\[) *@?([\w-]+) *([!*$^~=]*) *('?"?)(.*?)\4 *\]/,/^(:)([\w-]+)\("?'?(.*?(\(.*?\))?[^(]*?)"?'?\)/,new RegExp("^([:.#]*)("+chars+"+)")],multiFilter:function(expr,elems,not){var old,cur=[];while(expr&&expr!=old){old=expr;var f=jQuery.filter(expr,elems,not);expr=f.t.replace(/^\s*,\s*/,"");cur=not?elems=f.r:jQuery.merge(cur,f.r);}return cur;},find:function(t,context){if(typeof t!="string")return[t];if(context&&context.nodeType!=1&&context.nodeType!=9)return[];context=context||document;var ret=[context],done=[],last,nodeName;while(t&&last!=t){var r=[];last=t;t=jQuery.trim(t);var foundToken=false,re=quickChild,m=re.exec(t);if(m){nodeName=m[1].toUpperCase();for(var i=0;ret[i];i++)for(var c=ret[i].firstChild;c;c=c.nextSibling)if(c.nodeType==1&&(nodeName=="*"||c.nodeName.toUpperCase()==nodeName))r.push(c);ret=r;t=t.replace(re,"");if(t.indexOf(" ")==0)continue;foundToken=true;}else{re=/^([>+~])\s*(\w*)/i;if((m=re.exec(t))!=null){r=[];var merge={};nodeName=m[2].toUpperCase();m=m[1];for(var j=0,rl=ret.length;j<rl;j++){var n=m=="~"||m=="+"?ret[j].nextSibling:ret[j].firstChild;for(;n;n=n.nextSibling)if(n.nodeType==1){var id=jQuery.data(n);if(m=="~"&&merge[id])break;if(!nodeName||n.nodeName.toUpperCase()==nodeName){if(m=="~")merge[id]=true;r.push(n);}if(m=="+")break;}}ret=r;t=jQuery.trim(t.replace(re,""));foundToken=true;}}if(t&&!foundToken){if(!t.indexOf(",")){if(context==ret[0])ret.shift();done=jQuery.merge(done,ret);r=ret=[context];t=" "+t.substr(1,t.length);}else{var re2=quickID;var m=re2.exec(t);if(m){m=[0,m[2],m[3],m[1]];}else{re2=quickClass;m=re2.exec(t);}m[2]=m[2].replace(/\\/g,"");var elem=ret[ret.length-1];if(m[1]=="#"&&elem&&elem.getElementById&&!jQuery.isXMLDoc(elem)){var oid=elem.getElementById(m[2]);if((jQuery.browser.msie||jQuery.browser.opera)&&oid&&typeof oid.id=="string"&&oid.id!=m[2])oid=jQuery('[@id="'+m[2]+'"]',elem)[0];ret=r=oid&&(!m[3]||jQuery.nodeName(oid,m[3]))?[oid]:[];}else{for(var i=0;ret[i];i++){var tag=m[1]=="#"&&m[3]?m[3]:m[1]!=""||m[0]==""?"*":m[2];if(tag=="*"&&ret[i].nodeName.toLowerCase()=="object")tag="param";r=jQuery.merge(r,ret[i].getElementsByTagName(tag));}if(m[1]==".")r=jQuery.classFilter(r,m[2]);if(m[1]=="#"){var tmp=[];for(var i=0;r[i];i++)if(r[i].getAttribute("id")==m[2]){tmp=[r[i]];break;}r=tmp;}ret=r;}t=t.replace(re2,"");}}if(t){var val=jQuery.filter(t,r);ret=r=val.r;t=jQuery.trim(val.t);}}if(t)ret=[];if(ret&&context==ret[0])ret.shift();done=jQuery.merge(done,ret);return done;},classFilter:function(r,m,not){m=" "+m+" ";var tmp=[];for(var i=0;r[i];i++){var pass=(" "+r[i].className+" ").indexOf(m)>=0;if(!not&&pass||not&&!pass)tmp.push(r[i]);}return tmp;},filter:function(t,r,not){var last;while(t&&t!=last){last=t;var p=jQuery.parse,m;for(var i=0;p[i];i++){m=p[i].exec(t);if(m){t=t.substring(m[0].length);m[2]=m[2].replace(/\\/g,"");break;}}if(!m)break;if(m[1]==":"&&m[2]=="not")r=isSimple.test(m[3])?jQuery.filter(m[3],r,true).r:jQuery(r).not(m[3]);else if(m[1]==".")r=jQuery.classFilter(r,m[2],not);else if(m[1]=="["){var tmp=[],type=m[3];for(var i=0,rl=r.length;i<rl;i++){var a=r[i],z=a[jQuery.props[m[2]]||m[2]];if(z==null||/href|src|selected/.test(m[2]))z=jQuery.attr(a,m[2])||'';if((type==""&&!!z||type=="="&&z==m[5]||type=="!="&&z!=m[5]||type=="^="&&z&&!z.indexOf(m[5])||type=="$="&&z.substr(z.length-m[5].length)==m[5]||(type=="*="||type=="~=")&&z.indexOf(m[5])>=0)^not)tmp.push(a);}r=tmp;}else if(m[1]==":"&&m[2]=="nth-child"){var merge={},tmp=[],test=/(-?)(\d*)n((?:\+|-)?\d*)/.exec(m[3]=="even"&&"2n"||m[3]=="odd"&&"2n+1"||!/\D/.test(m[3])&&"0n+"+m[3]||m[3]),first=(test[1]+(test[2]||1))-0,last=test[3]-0;for(var i=0,rl=r.length;i<rl;i++){var node=r[i],parentNode=node.parentNode,id=jQuery.data(parentNode);if(!merge[id]){var c=1;for(var n=parentNode.firstChild;n;n=n.nextSibling)if(n.nodeType==1)n.nodeIndex=c++;merge[id]=true;}var add=false;if(first==0){if(node.nodeIndex==last)add=true;}else if((node.nodeIndex-last)%first==0&&(node.nodeIndex-last)/first>=0)add=true;if(add^not)tmp.push(node);}r=tmp;}else{var fn=jQuery.expr[m[1]];if(typeof fn=="object")fn=fn[m[2]];if(typeof fn=="string")fn=eval("false||function(a,i){return "+fn+";}");r=jQuery.grep(r,function(elem,i){return fn(elem,i,m,r);},not);}}return{r:r,t:t};},dir:function(elem,dir){var matched=[],cur=elem[dir];while(cur&&cur!=document){if(cur.nodeType==1)matched.push(cur);cur=cur[dir];}return matched;},nth:function(cur,result,dir,elem){result=result||1;var num=0;for(;cur;cur=cur[dir])if(cur.nodeType==1&&++num==result)break;return cur;},sibling:function(n,elem){var r=[];for(;n;n=n.nextSibling){if(n.nodeType==1&&n!=elem)r.push(n);}return r;}});jQuery.event={add:function(elem,types,handler,data){if(elem.nodeType==3||elem.nodeType==8)return;if(jQuery.browser.msie&&elem.setInterval)elem=window;if(!handler.guid)handler.guid=this.guid++;if(data!=undefined){var fn=handler;handler=this.proxy(fn,function(){return fn.apply(this,arguments);});handler.data=data;}var events=jQuery.data(elem,"events")||jQuery.data(elem,"events",{}),handle=jQuery.data(elem,"handle")||jQuery.data(elem,"handle",function(){if(typeof jQuery!="undefined"&&!jQuery.event.triggered)return jQuery.event.handle.apply(arguments.callee.elem,arguments);});handle.elem=elem;jQuery.each(types.split(/\s+/),function(index,type){var parts=type.split(".");type=parts[0];handler.type=parts[1];var handlers=events[type];if(!handlers){handlers=events[type]={};if(!jQuery.event.special[type]||jQuery.event.special[type].setup.call(elem)===false){if(elem.addEventListener)elem.addEventListener(type,handle,false);else if(elem.attachEvent)elem.attachEvent("on"+type,handle);}}handlers[handler.guid]=handler;jQuery.event.global[type]=true;});elem=null;},guid:1,global:{},remove:function(elem,types,handler){if(elem.nodeType==3||elem.nodeType==8)return;var events=jQuery.data(elem,"events"),ret,index;if(events){if(types==undefined||(typeof types=="string"&&types.charAt(0)=="."))for(var type in events)this.remove(elem,type+(types||""));else{if(types.type){handler=types.handler;types=types.type;}jQuery.each(types.split(/\s+/),function(index,type){var parts=type.split(".");type=parts[0];if(events[type]){if(handler)delete events[type][handler.guid];else
-for(handler in events[type])if(!parts[1]||events[type][handler].type==parts[1])delete events[type][handler];for(ret in events[type])break;if(!ret){if(!jQuery.event.special[type]||jQuery.event.special[type].teardown.call(elem)===false){if(elem.removeEventListener)elem.removeEventListener(type,jQuery.data(elem,"handle"),false);else if(elem.detachEvent)elem.detachEvent("on"+type,jQuery.data(elem,"handle"));}ret=null;delete events[type];}}});}for(ret in events)break;if(!ret){var handle=jQuery.data(elem,"handle");if(handle)handle.elem=null;jQuery.removeData(elem,"events");jQuery.removeData(elem,"handle");}}},trigger:function(type,data,elem,donative,extra){data=jQuery.makeArray(data);if(type.indexOf("!")>=0){type=type.slice(0,-1);var exclusive=true;}if(!elem){if(this.global[type])jQuery("*").add([window,document]).trigger(type,data);}else{if(elem.nodeType==3||elem.nodeType==8)return undefined;var val,ret,fn=jQuery.isFunction(elem[type]||null),event=!data[0]||!data[0].preventDefault;if(event){data.unshift({type:type,target:elem,preventDefault:function(){},stopPropagation:function(){},timeStamp:now()});data[0][expando]=true;}data[0].type=type;if(exclusive)data[0].exclusive=true;var handle=jQuery.data(elem,"handle");if(handle)val=handle.apply(elem,data);if((!fn||(jQuery.nodeName(elem,'a')&&type=="click"))&&elem["on"+type]&&elem["on"+type].apply(elem,data)===false)val=false;if(event)data.shift();if(extra&&jQuery.isFunction(extra)){ret=extra.apply(elem,val==null?data:data.concat(val));if(ret!==undefined)val=ret;}if(fn&&donative!==false&&val!==false&&!(jQuery.nodeName(elem,'a')&&type=="click")){this.triggered=true;try{elem[type]();}catch(e){}}this.triggered=false;}return val;},handle:function(event){var val,ret,namespace,all,handlers;event=arguments[0]=jQuery.event.fix(event||window.event);namespace=event.type.split(".");event.type=namespace[0];namespace=namespace[1];all=!namespace&&!event.exclusive;handlers=(jQuery.data(this,"events")||{})[event.type];for(var j in handlers){var handler=handlers[j];if(all||handler.type==namespace){event.handler=handler;event.data=handler.data;ret=handler.apply(this,arguments);if(val!==false)val=ret;if(ret===false){event.preventDefault();event.stopPropagation();}}}return val;},fix:function(event){if(event[expando]==true)return event;var originalEvent=event;event={originalEvent:originalEvent};var props="altKey attrChange attrName bubbles button cancelable charCode clientX clientY ctrlKey currentTarget data detail eventPhase fromElement handler keyCode metaKey newValue originalTarget pageX pageY prevValue relatedNode relatedTarget screenX screenY shiftKey srcElement target timeStamp toElement type view wheelDelta which".split(" ");for(var i=props.length;i;i--)event[props[i]]=originalEvent[props[i]];event[expando]=true;event.preventDefault=function(){if(originalEvent.preventDefault)originalEvent.preventDefault();originalEvent.returnValue=false;};event.stopPropagation=function(){if(originalEvent.stopPropagation)originalEvent.stopPropagation();originalEvent.cancelBubble=true;};event.timeStamp=event.timeStamp||now();if(!event.target)event.target=event.srcElement||document;if(event.target.nodeType==3)event.target=event.target.parentNode;if(!event.relatedTarget&&event.fromElement)event.relatedTarget=event.fromElement==event.target?event.toElement:event.fromElement;if(event.pageX==null&&event.clientX!=null){var doc=document.documentElement,body=document.body;event.pageX=event.clientX+(doc&&doc.scrollLeft||body&&body.scrollLeft||0)-(doc.clientLeft||0);event.pageY=event.clientY+(doc&&doc.scrollTop||body&&body.scrollTop||0)-(doc.clientTop||0);}if(!event.which&&((event.charCode||event.charCode===0)?event.charCode:event.keyCode))event.which=event.charCode||event.keyCode;if(!event.metaKey&&event.ctrlKey)event.metaKey=event.ctrlKey;if(!event.which&&event.button)event.which=(event.button&1?1:(event.button&2?3:(event.button&4?2:0)));return event;},proxy:function(fn,proxy){proxy.guid=fn.guid=fn.guid||proxy.guid||this.guid++;return proxy;},special:{ready:{setup:function(){bindReady();return;},teardown:function(){return;}},mouseenter:{setup:function(){if(jQuery.browser.msie)return false;jQuery(this).bind("mouseover",jQuery.event.special.mouseenter.handler);return true;},teardown:function(){if(jQuery.browser.msie)return false;jQuery(this).unbind("mouseover",jQuery.event.special.mouseenter.handler);return true;},handler:function(event){if(withinElement(event,this))return true;event.type="mouseenter";return jQuery.event.handle.apply(this,arguments);}},mouseleave:{setup:function(){if(jQuery.browser.msie)return false;jQuery(this).bind("mouseout",jQuery.event.special.mouseleave.handler);return true;},teardown:function(){if(jQuery.browser.msie)return false;jQuery(this).unbind("mouseout",jQuery.event.special.mouseleave.handler);return true;},handler:function(event){if(withinElement(event,this))return true;event.type="mouseleave";return jQuery.event.handle.apply(this,arguments);}}}};jQuery.fn.extend({bind:function(type,data,fn){return type=="unload"?this.one(type,data,fn):this.each(function(){jQuery.event.add(this,type,fn||data,fn&&data);});},one:function(type,data,fn){var one=jQuery.event.proxy(fn||data,function(event){jQuery(this).unbind(event,one);return(fn||data).apply(this,arguments);});return this.each(function(){jQuery.event.add(this,type,one,fn&&data);});},unbind:function(type,fn){return this.each(function(){jQuery.event.remove(this,type,fn);});},trigger:function(type,data,fn){return this.each(function(){jQuery.event.trigger(type,data,this,true,fn);});},triggerHandler:function(type,data,fn){return this[0]&&jQuery.event.trigger(type,data,this[0],false,fn);},toggle:function(fn){var args=arguments,i=1;while(i<args.length)jQuery.event.proxy(fn,args[i++]);return this.click(jQuery.event.proxy(fn,function(event){this.lastToggle=(this.lastToggle||0)%i;event.preventDefault();return args[this.lastToggle++].apply(this,arguments)||false;}));},hover:function(fnOver,fnOut){return this.bind('mouseenter',fnOver).bind('mouseleave',fnOut);},ready:function(fn){bindReady();if(jQuery.isReady)fn.call(document,jQuery);else
-jQuery.readyList.push(function(){return fn.call(this,jQuery);});return this;}});jQuery.extend({isReady:false,readyList:[],ready:function(){if(!jQuery.isReady){jQuery.isReady=true;if(jQuery.readyList){jQuery.each(jQuery.readyList,function(){this.call(document);});jQuery.readyList=null;}jQuery(document).triggerHandler("ready");}}});var readyBound=false;function bindReady(){if(readyBound)return;readyBound=true;if(document.addEventListener&&!jQuery.browser.opera)document.addEventListener("DOMContentLoaded",jQuery.ready,false);if(jQuery.browser.msie&&window==top)(function(){if(jQuery.isReady)return;try{document.documentElement.doScroll("left");}catch(error){setTimeout(arguments.callee,0);return;}jQuery.ready();})();if(jQuery.browser.opera)document.addEventListener("DOMContentLoaded",function(){if(jQuery.isReady)return;for(var i=0;i<document.styleSheets.length;i++)if(document.styleSheets[i].disabled){setTimeout(arguments.callee,0);return;}jQuery.ready();},false);if(jQuery.browser.safari){var numStyles;(function(){if(jQuery.isReady)return;if(document.readyState!="loaded"&&document.readyState!="complete"){setTimeout(arguments.callee,0);return;}if(numStyles===undefined)numStyles=jQuery("style, link[rel=stylesheet]").length;if(document.styleSheets.length!=numStyles){setTimeout(arguments.callee,0);return;}jQuery.ready();})();}jQuery.event.add(window,"load",jQuery.ready);}jQuery.each(("blur,focus,load,resize,scroll,unload,click,dblclick,"+"mousedown,mouseup,mousemove,mouseover,mouseout,change,select,"+"submit,keydown,keypress,keyup,error").split(","),function(i,name){jQuery.fn[name]=function(fn){return fn?this.bind(name,fn):this.trigger(name);};});var withinElement=function(event,elem){var parent=event.relatedTarget;while(parent&&parent!=elem)try{parent=parent.parentNode;}catch(error){parent=elem;}return parent==elem;};jQuery(window).bind("unload",function(){jQuery("*").add(document).unbind();});jQuery.fn.extend({_load:jQuery.fn.load,load:function(url,params,callback){if(typeof url!='string')return this._load(url);var off=url.indexOf(" ");if(off>=0){var selector=url.slice(off,url.length);url=url.slice(0,off);}callback=callback||function(){};var type="GET";if(params)if(jQuery.isFunction(params)){callback=params;params=null;}else{params=jQuery.param(params);type="POST";}var self=this;jQuery.ajax({url:url,type:type,dataType:"html",data:params,complete:function(res,status){if(status=="success"||status=="notmodified")self.html(selector?jQuery("<div/>").append(res.responseText.replace(/<script(.|\s)*?\/script>/g,"")).find(selector):res.responseText);self.each(callback,[res.responseText,status,res]);}});return this;},serialize:function(){return jQuery.param(this.serializeArray());},serializeArray:function(){return this.map(function(){return jQuery.nodeName(this,"form")?jQuery.makeArray(this.elements):this;}).filter(function(){return this.name&&!this.disabled&&(this.checked||/select|textarea/i.test(this.nodeName)||/text|hidden|password/i.test(this.type));}).map(function(i,elem){var val=jQuery(this).val();return val==null?null:val.constructor==Array?jQuery.map(val,function(val,i){return{name:elem.name,value:val};}):{name:elem.name,value:val};}).get();}});jQuery.each("ajaxStart,ajaxStop,ajaxComplete,ajaxError,ajaxSuccess,ajaxSend".split(","),function(i,o){jQuery.fn[o]=function(f){return this.bind(o,f);};});var jsc=now();jQuery.extend({get:function(url,data,callback,type){if(jQuery.isFunction(data)){callback=data;data=null;}return jQuery.ajax({type:"GET",url:url,data:data,success:callback,dataType:type});},getScript:function(url,callback){return jQuery.get(url,null,callback,"script");},getJSON:function(url,data,callback){return jQuery.get(url,data,callback,"json");},post:function(url,data,callback,type){if(jQuery.isFunction(data)){callback=data;data={};}return jQuery.ajax({type:"POST",url:url,data:data,success:callback,dataType:type});},ajaxSetup:function(settings){jQuery.extend(jQuery.ajaxSettings,settings);},ajaxSettings:{url:location.href,global:true,type:"GET",timeout:0,contentType:"application/x-www-form-urlencoded",processData:true,async:true,data:null,username:null,password:null,accepts:{xml:"application/xml, text/xml",html:"text/html",script:"text/javascript, application/javascript",json:"application/json, text/javascript",text:"text/plain",_default:"*/*"}},lastModified:{},ajax:function(s){s=jQuery.extend(true,s,jQuery.extend(true,{},jQuery.ajaxSettings,s));var jsonp,jsre=/=\?(&|$)/g,status,data,type=s.type.toUpperCase();if(s.data&&s.processData&&typeof s.data!="string")s.data=jQuery.param(s.data);if(s.dataType=="jsonp"){if(type=="GET"){if(!s.url.match(jsre))s.url+=(s.url.match(/\?/)?"&":"?")+(s.jsonp||"callback")+"=?";}else if(!s.data||!s.data.match(jsre))s.data=(s.data?s.data+"&":"")+(s.jsonp||"callback")+"=?";s.dataType="json";}if(s.dataType=="json"&&(s.data&&s.data.match(jsre)||s.url.match(jsre))){jsonp="jsonp"+jsc++;if(s.data)s.data=(s.data+"").replace(jsre,"="+jsonp+"$1");s.url=s.url.replace(jsre,"="+jsonp+"$1");s.dataType="script";window[jsonp]=function(tmp){data=tmp;success();complete();window[jsonp]=undefined;try{delete window[jsonp];}catch(e){}if(head)head.removeChild(script);};}if(s.dataType=="script"&&s.cache==null)s.cache=false;if(s.cache===false&&type=="GET"){var ts=now();var ret=s.url.replace(/(\?|&)_=.*?(&|$)/,"$1_="+ts+"$2");s.url=ret+((ret==s.url)?(s.url.match(/\?/)?"&":"?")+"_="+ts:"");}if(s.data&&type=="GET"){s.url+=(s.url.match(/\?/)?"&":"?")+s.data;s.data=null;}if(s.global&&!jQuery.active++)jQuery.event.trigger("ajaxStart");var remote=/^(?:\w+:)?\/\/([^\/?#]+)/;if(s.dataType=="script"&&type=="GET"&&remote.test(s.url)&&remote.exec(s.url)[1]!=location.host){var head=document.getElementsByTagName("head")[0];var script=document.createElement("script");script.src=s.url;if(s.scriptCharset)script.charset=s.scriptCharset;if(!jsonp){var done=false;script.onload=script.onreadystatechange=function(){if(!done&&(!this.readyState||this.readyState=="loaded"||this.readyState=="complete")){done=true;success();complete();head.removeChild(script);}};}head.appendChild(script);return undefined;}var requestDone=false;var xhr=window.ActiveXObject?new ActiveXObject("Microsoft.XMLHTTP"):new XMLHttpRequest();if(s.username)xhr.open(type,s.url,s.async,s.username,s.password);else
-xhr.open(type,s.url,s.async);try{if(s.data)xhr.setRequestHeader("Content-Type",s.contentType);if(s.ifModified)xhr.setRequestHeader("If-Modified-Since",jQuery.lastModified[s.url]||"Thu, 01 Jan 1970 00:00:00 GMT");xhr.setRequestHeader("X-Requested-With","XMLHttpRequest");xhr.setRequestHeader("Accept",s.dataType&&s.accepts[s.dataType]?s.accepts[s.dataType]+", */*":s.accepts._default);}catch(e){}if(s.beforeSend&&s.beforeSend(xhr,s)===false){s.global&&jQuery.active--;xhr.abort();return false;}if(s.global)jQuery.event.trigger("ajaxSend",[xhr,s]);var onreadystatechange=function(isTimeout){if(!requestDone&&xhr&&(xhr.readyState==4||isTimeout=="timeout")){requestDone=true;if(ival){clearInterval(ival);ival=null;}status=isTimeout=="timeout"&&"timeout"||!jQuery.httpSuccess(xhr)&&"error"||s.ifModified&&jQuery.httpNotModified(xhr,s.url)&&"notmodified"||"success";if(status=="success"){try{data=jQuery.httpData(xhr,s.dataType,s.dataFilter);}catch(e){status="parsererror";}}if(status=="success"){var modRes;try{modRes=xhr.getResponseHeader("Last-Modified");}catch(e){}if(s.ifModified&&modRes)jQuery.lastModified[s.url]=modRes;if(!jsonp)success();}else
-jQuery.handleError(s,xhr,status);complete();if(s.async)xhr=null;}};if(s.async){var ival=setInterval(onreadystatechange,13);if(s.timeout>0)setTimeout(function(){if(xhr){xhr.abort();if(!requestDone)onreadystatechange("timeout");}},s.timeout);}try{xhr.send(s.data);}catch(e){jQuery.handleError(s,xhr,null,e);}if(!s.async)onreadystatechange();function success(){if(s.success)s.success(data,status);if(s.global)jQuery.event.trigger("ajaxSuccess",[xhr,s]);}function complete(){if(s.complete)s.complete(xhr,status);if(s.global)jQuery.event.trigger("ajaxComplete",[xhr,s]);if(s.global&&!--jQuery.active)jQuery.event.trigger("ajaxStop");}return xhr;},handleError:function(s,xhr,status,e){if(s.error)s.error(xhr,status,e);if(s.global)jQuery.event.trigger("ajaxError",[xhr,s,e]);},active:0,httpSuccess:function(xhr){try{return!xhr.status&&location.protocol=="file:"||(xhr.status>=200&&xhr.status<300)||xhr.status==304||xhr.status==1223||jQuery.browser.safari&&xhr.status==undefined;}catch(e){}return false;},httpNotModified:function(xhr,url){try{var xhrRes=xhr.getResponseHeader("Last-Modified");return xhr.status==304||xhrRes==jQuery.lastModified[url]||jQuery.browser.safari&&xhr.status==undefined;}catch(e){}return false;},httpData:function(xhr,type,filter){var ct=xhr.getResponseHeader("content-type"),xml=type=="xml"||!type&&ct&&ct.indexOf("xml")>=0,data=xml?xhr.responseXML:xhr.responseText;if(xml&&data.documentElement.tagName=="parsererror")throw"parsererror";if(filter)data=filter(data,type);if(type=="script")jQuery.globalEval(data);if(type=="json")data=eval("("+data+")");return data;},param:function(a){var s=[];if(a.constructor==Array||a.jquery)jQuery.each(a,function(){s.push(encodeURIComponent(this.name)+"="+encodeURIComponent(this.value));});else
-for(var j in a)if(a[j]&&a[j].constructor==Array)jQuery.each(a[j],function(){s.push(encodeURIComponent(j)+"="+encodeURIComponent(this));});else
-s.push(encodeURIComponent(j)+"="+encodeURIComponent(jQuery.isFunction(a[j])?a[j]():a[j]));return s.join("&").replace(/%20/g,"+");}});jQuery.fn.extend({show:function(speed,callback){return speed?this.animate({height:"show",width:"show",opacity:"show"},speed,callback):this.filter(":hidden").each(function(){this.style.display=this.oldblock||"";if(jQuery.css(this,"display")=="none"){var elem=jQuery("<"+this.tagName+" />").appendTo("body");this.style.display=elem.css("display");if(this.style.display=="none")this.style.display="block";elem.remove();}}).end();},hide:function(speed,callback){return speed?this.animate({height:"hide",width:"hide",opacity:"hide"},speed,callback):this.filter(":visible").each(function(){this.oldblock=this.oldblock||jQuery.css(this,"display");this.style.display="none";}).end();},_toggle:jQuery.fn.toggle,toggle:function(fn,fn2){return jQuery.isFunction(fn)&&jQuery.isFunction(fn2)?this._toggle.apply(this,arguments):fn?this.animate({height:"toggle",width:"toggle",opacity:"toggle"},fn,fn2):this.each(function(){jQuery(this)[jQuery(this).is(":hidden")?"show":"hide"]();});},slideDown:function(speed,callback){return this.animate({height:"show"},speed,callback);},slideUp:function(speed,callback){return this.animate({height:"hide"},speed,callback);},slideToggle:function(speed,callback){return this.animate({height:"toggle"},speed,callback);},fadeIn:function(speed,callback){return this.animate({opacity:"show"},speed,callback);},fadeOut:function(speed,callback){return this.animate({opacity:"hide"},speed,callback);},fadeTo:function(speed,to,callback){return this.animate({opacity:to},speed,callback);},animate:function(prop,speed,easing,callback){var optall=jQuery.speed(speed,easing,callback);return this[optall.queue===false?"each":"queue"](function(){if(this.nodeType!=1)return false;var opt=jQuery.extend({},optall),p,hidden=jQuery(this).is(":hidden"),self=this;for(p in prop){if(prop[p]=="hide"&&hidden||prop[p]=="show"&&!hidden)return opt.complete.call(this);if(p=="height"||p=="width"){opt.display=jQuery.css(this,"display");opt.overflow=this.style.overflow;}}if(opt.overflow!=null)this.style.overflow="hidden";opt.curAnim=jQuery.extend({},prop);jQuery.each(prop,function(name,val){var e=new jQuery.fx(self,opt,name);if(/toggle|show|hide/.test(val))e[val=="toggle"?hidden?"show":"hide":val](prop);else{var parts=val.toString().match(/^([+-]=)?([\d+-.]+)(.*)$/),start=e.cur(true)||0;if(parts){var end=parseFloat(parts[2]),unit=parts[3]||"px";if(unit!="px"){self.style[name]=(end||1)+unit;start=((end||1)/e.cur(true))*start;self.style[name]=start+unit;}if(parts[1])end=((parts[1]=="-="?-1:1)*end)+start;e.custom(start,end,unit);}else
-e.custom(start,val,"");}});return true;});},queue:function(type,fn){if(jQuery.isFunction(type)||(type&&type.constructor==Array)){fn=type;type="fx";}if(!type||(typeof type=="string"&&!fn))return queue(this[0],type);return this.each(function(){if(fn.constructor==Array)queue(this,type,fn);else{queue(this,type).push(fn);if(queue(this,type).length==1)fn.call(this);}});},stop:function(clearQueue,gotoEnd){var timers=jQuery.timers;if(clearQueue)this.queue([]);this.each(function(){for(var i=timers.length-1;i>=0;i--)if(timers[i].elem==this){if(gotoEnd)timers[i](true);timers.splice(i,1);}});if(!gotoEnd)this.dequeue();return this;}});var queue=function(elem,type,array){if(elem){type=type||"fx";var q=jQuery.data(elem,type+"queue");if(!q||array)q=jQuery.data(elem,type+"queue",jQuery.makeArray(array));}return q;};jQuery.fn.dequeue=function(type){type=type||"fx";return this.each(function(){var q=queue(this,type);q.shift();if(q.length)q[0].call(this);});};jQuery.extend({speed:function(speed,easing,fn){var opt=speed&&speed.constructor==Object?speed:{complete:fn||!fn&&easing||jQuery.isFunction(speed)&&speed,duration:speed,easing:fn&&easing||easing&&easing.constructor!=Function&&easing};opt.duration=(opt.duration&&opt.duration.constructor==Number?opt.duration:jQuery.fx.speeds[opt.duration])||jQuery.fx.speeds.def;opt.old=opt.complete;opt.complete=function(){if(opt.queue!==false)jQuery(this).dequeue();if(jQuery.isFunction(opt.old))opt.old.call(this);};return opt;},easing:{linear:function(p,n,firstNum,diff){return firstNum+diff*p;},swing:function(p,n,firstNum,diff){return((-Math.cos(p*Math.PI)/2)+0.5)*diff+firstNum;}},timers:[],timerId:null,fx:function(elem,options,prop){this.options=options;this.elem=elem;this.prop=prop;if(!options.orig)options.orig={};}});jQuery.fx.prototype={update:function(){if(this.options.step)this.options.step.call(this.elem,this.now,this);(jQuery.fx.step[this.prop]||jQuery.fx.step._default)(this);if(this.prop=="height"||this.prop=="width")this.elem.style.display="block";},cur:function(force){if(this.elem[this.prop]!=null&&this.elem.style[this.prop]==null)return this.elem[this.prop];var r=parseFloat(jQuery.css(this.elem,this.prop,force));return r&&r>-10000?r:parseFloat(jQuery.curCSS(this.elem,this.prop))||0;},custom:function(from,to,unit){this.startTime=now();this.start=from;this.end=to;this.unit=unit||this.unit||"px";this.now=this.start;this.pos=this.state=0;this.update();var self=this;function t(gotoEnd){return self.step(gotoEnd);}t.elem=this.elem;jQuery.timers.push(t);if(jQuery.timerId==null){jQuery.timerId=setInterval(function(){var timers=jQuery.timers;for(var i=0;i<timers.length;i++)if(!timers[i]())timers.splice(i--,1);if(!timers.length){clearInterval(jQuery.timerId);jQuery.timerId=null;}},13);}},show:function(){this.options.orig[this.prop]=jQuery.attr(this.elem.style,this.prop);this.options.show=true;this.custom(0,this.cur());if(this.prop=="width"||this.prop=="height")this.elem.style[this.prop]="1px";jQuery(this.elem).show();},hide:function(){this.options.orig[this.prop]=jQuery.attr(this.elem.style,this.prop);this.options.hide=true;this.custom(this.cur(),0);},step:function(gotoEnd){var t=now();if(gotoEnd||t>this.options.duration+this.startTime){this.now=this.end;this.pos=this.state=1;this.update();this.options.curAnim[this.prop]=true;var done=true;for(var i in this.options.curAnim)if(this.options.curAnim[i]!==true)done=false;if(done){if(this.options.display!=null){this.elem.style.overflow=this.options.overflow;this.elem.style.display=this.options.display;if(jQuery.css(this.elem,"display")=="none")this.elem.style.display="block";}if(this.options.hide)this.elem.style.display="none";if(this.options.hide||this.options.show)for(var p in this.options.curAnim)jQuery.attr(this.elem.style,p,this.options.orig[p]);}if(done)this.options.complete.call(this.elem);return false;}else{var n=t-this.startTime;this.state=n/this.options.duration;this.pos=jQuery.easing[this.options.easing||(jQuery.easing.swing?"swing":"linear")](this.state,n,0,1,this.options.duration);this.now=this.start+((this.end-this.start)*this.pos);this.update();}return true;}};jQuery.extend(jQuery.fx,{speeds:{slow:600,fast:200,def:400},step:{scrollLeft:function(fx){fx.elem.scrollLeft=fx.now;},scrollTop:function(fx){fx.elem.scrollTop=fx.now;},opacity:function(fx){jQuery.attr(fx.elem.style,"opacity",fx.now);},_default:function(fx){fx.elem.style[fx.prop]=fx.now+fx.unit;}}});jQuery.fn.offset=function(){var left=0,top=0,elem=this[0],results;if(elem)with(jQuery.browser){var parent=elem.parentNode,offsetChild=elem,offsetParent=elem.offsetParent,doc=elem.ownerDocument,safari2=safari&&parseInt(version)<522&&!/adobeair/i.test(userAgent),css=jQuery.curCSS,fixed=css(elem,"position")=="fixed";if(elem.getBoundingClientRect){var box=elem.getBoundingClientRect();add(box.left+Math.max(doc.documentElement.scrollLeft,doc.body.scrollLeft),box.top+Math.max(doc.documentElement.scrollTop,doc.body.scrollTop));add(-doc.documentElement.clientLeft,-doc.documentElement.clientTop);}else{add(elem.offsetLeft,elem.offsetTop);while(offsetParent){add(offsetParent.offsetLeft,offsetParent.offsetTop);if(mozilla&&!/^t(able|d|h)$/i.test(offsetParent.tagName)||safari&&!safari2)border(offsetParent);if(!fixed&&css(offsetParent,"position")=="fixed")fixed=true;offsetChild=/^body$/i.test(offsetParent.tagName)?offsetChild:offsetParent;offsetParent=offsetParent.offsetParent;}while(parent&&parent.tagName&&!/^body|html$/i.test(parent.tagName)){if(!/^inline|table.*$/i.test(css(parent,"display")))add(-parent.scrollLeft,-parent.scrollTop);if(mozilla&&css(parent,"overflow")!="visible")border(parent);parent=parent.parentNode;}if((safari2&&(fixed||css(offsetChild,"position")=="absolute"))||(mozilla&&css(offsetChild,"position")!="absolute"))add(-doc.body.offsetLeft,-doc.body.offsetTop);if(fixed)add(Math.max(doc.documentElement.scrollLeft,doc.body.scrollLeft),Math.max(doc.documentElement.scrollTop,doc.body.scrollTop));}results={top:top,left:left};}function border(elem){add(jQuery.curCSS(elem,"borderLeftWidth",true),jQuery.curCSS(elem,"borderTopWidth",true));}function add(l,t){left+=parseInt(l,10)||0;top+=parseInt(t,10)||0;}return results;};jQuery.fn.extend({position:function(){var left=0,top=0,results;if(this[0]){var offsetParent=this.offsetParent(),offset=this.offset(),parentOffset=/^body|html$/i.test(offsetParent[0].tagName)?{top:0,left:0}:offsetParent.offset();offset.top-=num(this,'marginTop');offset.left-=num(this,'marginLeft');parentOffset.top+=num(offsetParent,'borderTopWidth');parentOffset.left+=num(offsetParent,'borderLeftWidth');results={top:offset.top-parentOffset.top,left:offset.left-parentOffset.left};}return results;},offsetParent:function(){var offsetParent=this[0].offsetParent;while(offsetParent&&(!/^body|html$/i.test(offsetParent.tagName)&&jQuery.css(offsetParent,'position')=='static'))offsetParent=offsetParent.offsetParent;return jQuery(offsetParent);}});jQuery.each(['Left','Top'],function(i,name){var method='scroll'+name;jQuery.fn[method]=function(val){if(!this[0])return;return val!=undefined?this.each(function(){this==window||this==document?window.scrollTo(!i?val:jQuery(window).scrollLeft(),i?val:jQuery(window).scrollTop()):this[method]=val;}):this[0]==window||this[0]==document?self[i?'pageYOffset':'pageXOffset']||jQuery.boxModel&&document.documentElement[method]||document.body[method]:this[0][method];};});jQuery.each(["Height","Width"],function(i,name){var tl=i?"Left":"Top",br=i?"Right":"Bottom";jQuery.fn["inner"+name]=function(){return this[name.toLowerCase()]()+num(this,"padding"+tl)+num(this,"padding"+br);};jQuery.fn["outer"+name]=function(margin){return this["inner"+name]()+num(this,"border"+tl+"Width")+num(this,"border"+br+"Width")+(margin?num(this,"margin"+tl)+num(this,"margin"+br):0);};});})();
Deleted: branches/testbaudson_dev/http/extensions/jquery-ui-personalized-1.5.min.js
--- trunk/mapbender/http/extensions/jquery-ui-personalized-1.5.min.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/extensions/jquery-ui-personalized-1.5.min.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,146 +0,0 @@
-;(function($){$.ui={plugin:{add:function(module,option,set){var proto=$.ui[module].prototype;for(var i in set){proto.plugins[i]=proto.plugins[i]||[];proto.plugins[i].push([option,set[i]]);}},call:function(instance,name,args){var set=instance.plugins[name];if(!set){return;}
-for(var i=0;i<set.length;i++){if(instance.options[set[i][0]]){set[i][1].apply(instance.element,args);}}}},cssCache:{},css:function(name){if($.ui.cssCache[name]){return $.ui.cssCache[name];}
-var tmp=$('<div class="ui-resizable-gen">').addClass(name).css({position:'absolute',top:'-5000px',left:'-5000px',display:'block'}).appendTo('body');$.ui.cssCache[name]=!!((!(/auto|default/).test(tmp.css('cursor'))||(/^[1-9]/).test(tmp.css('height'))||(/^[1-9]/).test(tmp.css('width'))||!(/none/).test(tmp.css('backgroundImage'))||!(/transparent|rgba\(0, 0, 0, 0\)/).test(tmp.css('backgroundColor'))));try{$('body').get(0).removeChild(tmp.get(0));}catch(e){}
-return $.ui.cssCache[name];},disableSelection:function(e){e.unselectable="on";e.onselectstart=function(){return false;};if(e.style){e.style.MozUserSelect="none";}},enableSelection:function(e){e.unselectable="off";e.onselectstart=function(){return true;};if(e.style){e.style.MozUserSelect="";}},hasScroll:function(e,a){var scroll=/top/.test(a||"top")?'scrollTop':'scrollLeft',has=false;if(e[scroll]>0)return true;e[scroll]=1;has=e[scroll]>0?true:false;e[scroll]=0;return has;}};var _remove=$.fn.remove;$.fn.remove=function(){$("*",this).add(this).trigger("remove");return _remove.apply(this,arguments);};function getter(namespace,plugin,method){var methods=$[namespace][plugin].getter||[];methods=(typeof methods=="string"?methods.split(/,?\s+/):methods);return($.inArray(method,methods)!=-1);}
-$.widget=function(name,prototype){var namespace=name.split(".")[0];name=name.split(".")[1];$.fn[name]=function(options){var isMethodCall=(typeof options=='string'),args=Array.prototype.slice.call(arguments,1);if(isMethodCall&&getter(namespace,name,options)){var instance=$.data(this[0],name);return(instance?instance[options].apply(instance,args):undefined);}
-return this.each(function(){var instance=$.data(this,name);if(isMethodCall&&instance&&$.isFunction(instance[options])){instance[options].apply(instance,args);}else if(!isMethodCall){$.data(this,name,new $[namespace][name](this,options));}});};$[namespace][name]=function(element,options){var self=this;this.widgetName=name;this.widgetBaseClass=namespace+'-'+name;this.options=$.extend({disabled:false},$[namespace][name].defaults,options);this.element=$(element).bind('setData.'+name,function(e,key,value){return self.setData(key,value);}).bind('getData.'+name,function(e,key){return self.getData(key);}).bind('remove',function(){return self.destroy();});this.init();};$[namespace][name].prototype=$.extend({},$.widget.prototype,prototype);};$.widget.prototype={init:function(){},destroy:function(){this.element.removeData(this.widgetName);},getData:function(key){return this.options[key];},setData:function(key,value){this.options[key]=value;if(key=='disabled'){this.element[value?'addClass':'removeClass'](this.widgetBaseClass+'-disabled');}},enable:function(){this.setData('disabled',false);},disable:function(){this.setData('disabled',true);}};$.ui.mouse={mouseInit:function(){var self=this;this.element.bind('mousedown.'+this.widgetName,function(e){return self.mouseDown(e);});if($.browser.msie){this._mouseUnselectable=this.element.attr('unselectable');this.element.attr('unselectable','on');}
-this.started=false;},mouseDestroy:function(){this.element.unbind('.'+this.widgetName);($.browser.msie&&this.element.attr('unselectable',this._mouseUnselectable));},mouseDown:function(e){(this._mouseStarted&&this.mouseUp(e));this._mouseDownEvent=e;var self=this,btnIsLeft=(e.which==1),elIsCancel=(typeof this.options.cancel=="string"?$(e.target).is(this.options.cancel):false);if(!btnIsLeft||elIsCancel||!this.mouseCapture(e)){return true;}
-this._mouseDelayMet=!this.options.delay;if(!this._mouseDelayMet){this._mouseDelayTimer=setTimeout(function(){self._mouseDelayMet=true;},this.options.delay);}
-if(this.mouseDistanceMet(e)&&this.mouseDelayMet(e)){this._mouseStarted=(this.mouseStart(e)!==false);if(!this._mouseStarted){e.preventDefault();return true;}}
-this._mouseMoveDelegate=function(e){return self.mouseMove(e);};this._mouseUpDelegate=function(e){return self.mouseUp(e);};$(document).bind('mousemove.'+this.widgetName,this._mouseMoveDelegate).bind('mouseup.'+this.widgetName,this._mouseUpDelegate);return false;},mouseMove:function(e){if($.browser.msie&&!e.button){return this.mouseUp(e);}
-if(this._mouseStarted){this.mouseDrag(e);return false;}
-if(this.mouseDistanceMet(e)&&this.mouseDelayMet(e)){this._mouseStarted=(this.mouseStart(this._mouseDownEvent,e)!==false);(this._mouseStarted?this.mouseDrag(e):this.mouseUp(e));}
-return!this._mouseStarted;},mouseUp:function(e){$(document).unbind('mousemove.'+this.widgetName,this._mouseMoveDelegate).unbind('mouseup.'+this.widgetName,this._mouseUpDelegate);if(this._mouseStarted){this._mouseStarted=false;this.mouseStop(e);}
-return false;},mouseDistanceMet:function(e){return(Math.max(Math.abs(this._mouseDownEvent.pageX-e.pageX),Math.abs(this._mouseDownEvent.pageY-e.pageY))>=this.options.distance);},mouseDelayMet:function(e){return this._mouseDelayMet;},mouseStart:function(e){},mouseDrag:function(e){},mouseStop:function(e){},mouseCapture:function(e){return true;}};$.ui.mouse.defaults={cancel:null,distance:1,delay:0};})(jQuery);(function($){$.widget("ui.draggable",$.extend($.ui.mouse,{init:function(){var o=this.options;if(o.helper=='original'&&!(/(relative|absolute|fixed)/).test(this.element.css('position')))
-this.element.css('position','relative');this.element.addClass('ui-draggable');(o.disabled&&this.element.addClass('ui-draggable-disabled'));this.mouseInit();},mouseStart:function(e){var o=this.options;if(this.helper||o.disabled||$(e.target).is('.ui-resizable-handle'))return false;var handle=!this.options.handle||!$(this.options.handle,this.element).length?true:false;$(this.options.handle,this.element).find("*").andSelf().each(function(){if(this==e.target)handle=true;});if(!handle)return false;if($.ui.ddmanager)$.ui.ddmanager.current=this;this.helper=$.isFunction(o.helper)?$(o.helper.apply(this.element[0],[e])):(o.helper=='clone'?this.element.clone():this.element);if(!this.helper.parents('body').length)this.helper.appendTo((o.appendTo=='parent'?this.element[0].parentNode:o.appendTo));if(this.helper[0]!=this.element[0]&&!(/(fixed|absolute)/).test(this.helper.css("position")))this.helper.css("position","absolute");this.margins={left:(parseInt(this.element.css("marginLeft"),10)||0),top:(parseInt(this.element.css("marginTop"),10)||0)};this.cssPosition=this.helper.css("position");this.offset=this.element.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};this.offset.click={left:e.pageX-this.offset.left,top:e.pageY-this.offset.top};this.offsetParent=this.helper.offsetParent();var po=this.offsetParent.offset();if(this.offsetParent[0]==document.body&&$.browser.mozilla)po={top:0,left:0};this.offset.parent={top:po.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:po.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)};var p=this.element.position();this.offset.relative=this.cssPosition=="relative"?{top:p.top-(parseInt(this.helper.css("top"),10)||0)+this.offsetParent[0].scrollTop,left:p.left-(parseInt(this.helper.css("left"),10)||0)+this.offsetParent[0].scrollLeft}:{top:0,left:0};this.originalPosition=this.generatePosition(e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if(o.cursorAt){if(o.cursorAt.left!=undefined)this.offset.click.left=o.cursorAt.left+this.margins.left;if(o.cursorAt.right!=undefined)this.offset.click.left=this.helperProportions.width-o.cursorAt.right+this.margins.left;if(o.cursorAt.top!=undefined)this.offset.click.top=o.cursorAt.top+this.margins.top;if(o.cursorAt.bottom!=undefined)this.offset.click.top=this.helperProportions.height-o.cursorAt.bottom+this.margins.top;}
-if(o.containment){if(o.containment=='parent')o.containment=this.helper[0].parentNode;if(o.containment=='document'||o.containment=='window')this.containment=[0-this.offset.relative.left-this.offset.parent.left,0-this.offset.relative.top-this.offset.parent.top,$(o.containment=='document'?document:window).width()-this.offset.relative.left-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.element.css("marginRight"),10)||0),($(o.containment=='document'?document:window).height()||document.body.parentNode.scrollHeight)-this.offset.relative.top-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.element.css("marginBottom"),10)||0)];if(!(/^(document|window|parent)$/).test(o.containment)){var ce=$(o.containment)[0];var co=$(o.containment).offset();this.containment=[co.left+(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.relative.left-this.offset.parent.left,co.top+(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.relative.top-this.offset.parent.top,co.left+Math.max(ce.scrollWidth,ce.offsetWidth)-(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.relative.left-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.element.css("marginRight"),10)||0),co.top+Math.max(ce.scrollHeight,ce.offsetHeight)-(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.relative.top-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.element.css("marginBottom"),10)||0)];}}
-this.propagate("start",e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if($.ui.ddmanager&&!o.dropBehaviour)$.ui.ddmanager.prepareOffsets(this,e);this.helper.addClass("ui-draggable-dragging");this.mouseDrag(e);return true;},convertPositionTo:function(d,pos){if(!pos)pos=this.position;var mod=d=="absolute"?1:-1;return{top:(pos.top
-+this.offset.relative.top*mod
-+this.offset.parent.top*mod
--(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollTop)*mod
-+(this.cssPosition=="fixed"?this.offsetParent[0].scrollTop:0)*mod
-+this.margins.top*mod),left:(pos.left
-+this.offset.relative.left*mod
-+this.offset.parent.left*mod
--(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollLeft)*mod
-+(this.cssPosition=="fixed"?this.offsetParent[0].scrollLeft:0)*mod
-+this.margins.left*mod)};},generatePosition:function(e){var o=this.options;var position={top:(e.pageY
--this.offset.click.top
--this.offset.relative.top
--this.offset.parent.top
-+(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollTop)
--(this.cssPosition=="fixed"?this.offsetParent[0].scrollTop:0)),left:(e.pageX
--this.offset.click.left
--this.offset.relative.left
--this.offset.parent.left
-+(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollLeft)
--(this.cssPosition=="fixed"?this.offsetParent[0].scrollLeft:0))};if(!this.originalPosition)return position;if(this.containment){if(position.left<this.containment[0])position.left=this.containment[0];if(position.top<this.containment[1])position.top=this.containment[1];if(position.left>this.containment[2])position.left=this.containment[2];if(position.top>this.containment[3])position.top=this.containment[3];}
-if(o.grid){var top=this.originalPosition.top+Math.round((position.top-this.originalPosition.top)/o.grid[1])*o.grid[1];position.top=this.containment?(!(top<this.containment[1]||top>this.containment[3])?top:(!(top<this.containment[1])?top-o.grid[1]:top+o.grid[1])):top;var left=this.originalPosition.left+Math.round((position.left-this.originalPosition.left)/o.grid[0])*o.grid[0];position.left=this.containment?(!(left<this.containment[0]||left>this.containment[2])?left:(!(left<this.containment[0])?left-o.grid[0]:left+o.grid[0])):left;}
-return position;},mouseDrag:function(e){this.position=this.generatePosition(e);this.positionAbs=this.convertPositionTo("absolute");this.position=this.propagate("drag",e)||this.position;if(!this.options.axis||this.options.axis!="y")this.helper[0].style.left=this.position.left+'px';if(!this.options.axis||this.options.axis!="x")this.helper[0].style.top=this.position.top+'px';if($.ui.ddmanager)$.ui.ddmanager.drag(this,e);return false;},mouseStop:function(e){if($.ui.ddmanager&&!this.options.dropBehaviour)
-$.ui.ddmanager.drop(this,e);if(this.options.revert){var self=this;$(this.helper).animate(this.originalPosition,parseInt(this.options.revert,10)||500,function(){self.propagate("stop",e);self.clear();});}else{this.propagate("stop",e);this.clear();}
-return false;},clear:function(){this.helper.removeClass("ui-draggable-dragging");if(this.options.helper!='original'&&!this.cancelHelperRemoval)this.helper.remove();this.helper=null;this.cancelHelperRemoval=false;},plugins:{},uiHash:function(e){return{helper:this.helper,position:this.position,absolutePosition:this.positionAbs,options:this.options};},propagate:function(n,e){$.ui.plugin.call(this,n,[e,this.uiHash()]);return this.element.triggerHandler(n=="drag"?n:"drag"+n,[e,this.uiHash()],this.options[n]);},destroy:function(){if(!this.element.data('draggable'))return;this.element.removeData("draggable").unbind(".draggable").removeClass('ui-draggable');this.mouseDestroy();}}));$.extend($.ui.draggable,{defaults:{appendTo:"parent",axis:false,cancel:":input,button",delay:0,distance:0,helper:"original"}});$.ui.plugin.add("draggable","cursor",{start:function(e,ui){var t=$('body');if(t.css("cursor"))ui.options._cursor=t.css("cursor");t.css("cursor",ui.options.cursor);},stop:function(e,ui){if(ui.options._cursor)$('body').css("cursor",ui.options._cursor);}});$.ui.plugin.add("draggable","zIndex",{start:function(e,ui){var t=$(ui.helper);if(t.css("zIndex"))ui.options._zIndex=t.css("zIndex");t.css('zIndex',ui.options.zIndex);},stop:function(e,ui){if(ui.options._zIndex)$(ui.helper).css('zIndex',ui.options._zIndex);}});$.ui.plugin.add("draggable","opacity",{start:function(e,ui){var t=$(ui.helper);if(t.css("opacity"))ui.options._opacity=t.css("opacity");t.css('opacity',ui.options.opacity);},stop:function(e,ui){if(ui.options._opacity)$(ui.helper).css('opacity',ui.options._opacity);}});$.ui.plugin.add("draggable","iframeFix",{start:function(e,ui){$(ui.options.iframeFix===true?"iframe":ui.options.iframeFix).each(function(){$('<div class="ui-draggable-iframeFix" style="background: #fff;"></div>').css({width:this.offsetWidth+"px",height:this.offsetHeight+"px",position:"absolute",opacity:"0.001",zIndex:1000}).css($(this).offset()).appendTo("body");});},stop:function(e,ui){$("div.DragDropIframeFix").each(function(){this.parentNode.removeChild(this);});}});$.ui.plugin.add("draggable","scroll",{start:function(e,ui){var o=ui.options;var i=$(this).data("draggable");o.scrollSensitivity=o.scrollSensitivity||20;o.scrollSpeed=o.scrollSpeed||20;i.overflowY=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-y')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(this);i.overflowX=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-x')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(this);if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML')i.overflowYOffset=i.overflowY.offset();if(i.overflowX[0]!=document&&i.overflowX[0].tagName!='HTML')i.overflowXOffset=i.overflowX.offset();},drag:function(e,ui){var o=ui.options;var i=$(this).data("draggable");if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML'){if((i.overflowYOffset.top+i.overflowY[0].offsetHeight)-e.pageY<o.scrollSensitivity)
-i.overflowY[0].scrollTop=i.overflowY[0].scrollTop+o.scrollSpeed;if(e.pageY-i.overflowYOffset.top<o.scrollSensitivity)
-i.overflowY[0].scrollTop=i.overflowY[0].scrollTop-o.scrollSpeed;}else{if(e.pageY-$(document).scrollTop()<o.scrollSensitivity)
-$(document).scrollTop($(document).scrollTop()-o.scrollSpeed);if($(window).height()-(e.pageY-$(document).scrollTop())<o.scrollSensitivity)
-$(document).scrollTop($(document).scrollTop()+o.scrollSpeed);}
-if(i.overflowX[0]!=document&&i.overflowX[0].tagName!='HTML'){if((i.overflowXOffset.left+i.overflowX[0].offsetWidth)-e.pageX<o.scrollSensitivity)
-i.overflowX[0].scrollLeft=i.overflowX[0].scrollLeft+o.scrollSpeed;if(e.pageX-i.overflowXOffset.left<o.scrollSensitivity)
-i.overflowX[0].scrollLeft=i.overflowX[0].scrollLeft-o.scrollSpeed;}else{if(e.pageX-$(document).scrollLeft()<o.scrollSensitivity)
-$(document).scrollLeft($(document).scrollLeft()-o.scrollSpeed);if($(window).width()-(e.pageX-$(document).scrollLeft())<o.scrollSensitivity)
-$(document).scrollLeft($(document).scrollLeft()+o.scrollSpeed);}}});$.ui.plugin.add("draggable","snap",{start:function(e,ui){var inst=$(this).data("draggable");inst.snapElements=[];$(ui.options.snap===true?'.ui-draggable':ui.options.snap).each(function(){var $t=$(this);var $o=$t.offset();if(this!=inst.element[0])inst.snapElements.push({item:this,width:$t.outerWidth(),height:$t.outerHeight(),top:$o.top,left:$o.left});});},drag:function(e,ui){var inst=$(this).data("draggable");var d=ui.options.snapTolerance||20;var x1=ui.absolutePosition.left,x2=x1+inst.helperProportions.width,y1=ui.absolutePosition.top,y2=y1+inst.helperProportions.height;for(var i=inst.snapElements.length-1;i>=0;i--){var l=inst.snapElements[i].left,r=l+inst.snapElements[i].width,t=inst.snapElements[i].top,b=t+inst.snapElements[i].height;if(!((l-d<x1&&x1<r+d&&t-d<y1&&y1<b+d)||(l-d<x1&&x1<r+d&&t-d<y2&&y2<b+d)||(l-d<x2&&x2<r+d&&t-d<y1&&y1<b+d)||(l-d<x2&&x2<r+d&&t-d<y2&&y2<b+d)))continue;if(ui.options.snapMode!='inner'){var ts=Math.abs(t-y2)<=20;var bs=Math.abs(b-y1)<=20;var ls=Math.abs(l-x2)<=20;var rs=Math.abs(r-x1)<=20;if(ts)ui.position.top=inst.convertPositionTo("relative",{top:t-inst.helperProportions.height,left:0}).top;if(bs)ui.position.top=inst.convertPositionTo("relative",{top:b,left:0}).top;if(ls)ui.position.left=inst.convertPositionTo("relative",{top:0,left:l-inst.helperProportions.width}).left;if(rs)ui.position.left=inst.convertPositionTo("relative",{top:0,left:r}).left;}
-if(ui.options.snapMode!='outer'){var ts=Math.abs(t-y1)<=20;var bs=Math.abs(b-y2)<=20;var ls=Math.abs(l-x1)<=20;var rs=Math.abs(r-x2)<=20;if(ts)ui.position.top=inst.convertPositionTo("relative",{top:t,left:0}).top;if(bs)ui.position.top=inst.convertPositionTo("relative",{top:b-inst.helperProportions.height,left:0}).top;if(ls)ui.position.left=inst.convertPositionTo("relative",{top:0,left:l}).left;if(rs)ui.position.left=inst.convertPositionTo("relative",{top:0,left:r-inst.helperProportions.width}).left;}};}});$.ui.plugin.add("draggable","connectToSortable",{start:function(e,ui){var inst=$(this).data("draggable");inst.sortables=[];$(ui.options.connectToSortable).each(function(){if($.data(this,'sortable')){var sortable=$.data(this,'sortable');inst.sortables.push({instance:sortable,shouldRevert:sortable.options.revert});sortable.refresh();sortable.propagate("activate",e,inst);}});},stop:function(e,ui){var inst=$(this).data("draggable");$.each(inst.sortables,function(){if(this.instance.isOver){this.instance.isOver=0;inst.cancelHelperRemoval=true;this.instance.cancelHelperRemoval=false;if(this.shouldRevert)this.instance.options.revert=true;this.instance.mouseStop(e);this.instance.element.triggerHandler("sortreceive",[e,$.extend(this.instance.ui(),{sender:inst.element})],this.instance.options["receive"]);this.instance.options.helper=this.instance.options._helper;}else{this.instance.propagate("deactivate",e,inst);}});},drag:function(e,ui){var inst=$(this).data("draggable"),self=this;var checkPos=function(o){var l=o.left,r=l+o.width,t=o.top,b=t+o.height;return(l<(this.positionAbs.left+this.offset.click.left)&&(this.positionAbs.left+this.offset.click.left)<r&&t<(this.positionAbs.top+this.offset.click.top)&&(this.positionAbs.top+this.offset.click.top)<b);};$.each(inst.sortables,function(i){if(checkPos.call(inst,this.instance.containerCache)){if(!this.instance.isOver){this.instance.isOver=1;this.instance.currentItem=$(self).clone().appendTo(this.instance.element).data("sortable-item",true);this.instance.options._helper=this.instance.options.helper;this.instance.options.helper=function(){return ui.helper[0];};e.target=this.instance.currentItem[0];this.instance.mouseCapture(e,true,true);this.instance.mouseStart(e,true,true);this.instance.offset.click.top=inst.offset.click.top;this.instance.offset.click.left=inst.offset.click.left;this.instance.offset.parent.left-=inst.offset.parent.left-this.instance.offset.parent.left;this.instance.offset.parent.top-=inst.offset.parent.top-this.instance.offset.parent.top;inst.propagate("toSortable",e);}
-if(this.instance.currentItem)this.instance.mouseDrag(e);}else{if(this.instance.isOver){this.instance.isOver=0;this.instance.cancelHelperRemoval=true;this.instance.options.revert=false;this.instance.mouseStop(e,true);this.instance.options.helper=this.instance.options._helper;this.instance.currentItem.remove();this.instance.placeholder.remove();inst.propagate("fromSortable",e);}};});}});$.ui.plugin.add("draggable","stack",{start:function(e,ui){var group=$.makeArray($(ui.options.stack.group)).sort(function(a,b){return(parseInt($(a).css("zIndex"),10)||ui.options.stack.min)-(parseInt($(b).css("zIndex"),10)||ui.options.stack.min);});$(group).each(function(i){this.style.zIndex=ui.options.stack.min+i;});this[0].style.zIndex=ui.options.stack.min+group.length;}});})(jQuery);(function($){$.widget("ui.droppable",{init:function(){this.element.addClass("ui-droppable");this.isover=0;this.isout=1;var o=this.options,accept=o.accept;o=$.extend(o,{accept:o.accept&&o.accept.constructor==Function?o.accept:function(d){return $(d).is(accept);}});this.proportions={width:this.element.outerWidth(),height:this.element.outerHeight()};$.ui.ddmanager.droppables.push(this);},plugins:{},ui:function(c){return{draggable:(c.currentItem||c.element),helper:c.helper,position:c.position,absolutePosition:c.positionAbs,options:this.options,element:this.element};},destroy:function(){var drop=$.ui.ddmanager.droppables;for(var i=0;i<drop.length;i++)
-if(drop[i]==this)
-drop.splice(i,1);this.element.removeClass("ui-droppable ui-droppable-disabled").removeData("droppable").unbind(".droppable");},over:function(e){var draggable=$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return;if(this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){$.ui.plugin.call(this,'over',[e,this.ui(draggable)]);this.element.triggerHandler("dropover",[e,this.ui(draggable)],this.options.over);}},out:function(e){var draggable=$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return;if(this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){$.ui.plugin.call(this,'out',[e,this.ui(draggable)]);this.element.triggerHandler("dropout",[e,this.ui(draggable)],this.options.out);}},drop:function(e,custom){var draggable=custom||$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return false;var childrenIntersection=false;this.element.find(".ui-droppable").not(".ui-draggable-dragging").each(function(){var inst=$.data(this,'droppable');if(inst.options.greedy&&$.ui.intersect(draggable,$.extend(inst,{offset:inst.element.offset()}),inst.options.tolerance)){childrenIntersection=true;return false;}});if(childrenIntersection)return false;if(this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){$.ui.plugin.call(this,'drop',[e,this.ui(draggable)]);this.element.triggerHandler("drop",[e,this.ui(draggable)],this.options.drop);return true;}
-return false;},activate:function(e){var draggable=$.ui.ddmanager.current;$.ui.plugin.call(this,'activate',[e,this.ui(draggable)]);if(draggable)this.element.triggerHandler("dropactivate",[e,this.ui(draggable)],this.options.activate);},deactivate:function(e){var draggable=$.ui.ddmanager.current;$.ui.plugin.call(this,'deactivate',[e,this.ui(draggable)]);if(draggable)this.element.triggerHandler("dropdeactivate",[e,this.ui(draggable)],this.options.deactivate);}});$.extend($.ui.droppable,{defaults:{disabled:false,tolerance:'intersect'}});$.ui.intersect=function(draggable,droppable,toleranceMode){if(!droppable.offset)return false;var x1=(draggable.positionAbs||draggable.position.absolute).left,x2=x1+draggable.helperProportions.width,y1=(draggable.positionAbs||draggable.position.absolute).top,y2=y1+draggable.helperProportions.height;var l=droppable.offset.left,r=l+droppable.proportions.width,t=droppable.offset.top,b=t+droppable.proportions.height;switch(toleranceMode){case'fit':return(l<x1&&x2<r&&t<y1&&y2<b);break;case'intersect':return(l<x1+(draggable.helperProportions.width/2)&&x2-(draggable.helperProportions.width/2)<r&&t<y1+(draggable.helperProportions.height/2)&&y2-(draggable.helperProportions.height/2)<b);break;case'pointer':return(l<((draggable.positionAbs||draggable.position.absolute).left+(draggable.clickOffset||draggable.offset.click).left)&&((draggable.positionAbs||draggable.position.absolute).left+(draggable.clickOffset||draggable.offset.click).left)<r&&t<((draggable.positionAbs||draggable.position.absolute).top+(draggable.clickOffset||draggable.offset.click).top)&&((draggable.positionAbs||draggable.position.absolute).top+(draggable.clickOffset||draggable.offset.click).top)<b);break;case'touch':return((y1>=t&&y1<=b)||(y2>=t&&y2<=b)||(y1<t&&y2>b))&&((x1>=l&&x1<=r)||(x2>=l&&x2<=r)||(x1<l&&x2>r));break;default:return false;break;}};$.ui.ddmanager={current:null,droppables:[],prepareOffsets:function(t,e){var m=$.ui.ddmanager.droppables;var type=e?e.type:null;for(var i=0;i<m.length;i++){if(m[i].options.disabled||(t&&!m[i].options.accept.call(m[i].element,(t.currentItem||t.element))))continue;m[i].visible=m[i].element.is(":visible");if(!m[i].visible)continue;m[i].offset=m[i].element.offset();m[i].proportions={width:m[i].element.outerWidth(),height:m[i].element.outerHeight()};if(type=="dragstart"||type=="sortactivate")m[i].activate.call(m[i],e);}},drop:function(draggable,e){var dropped=false;$.each($.ui.ddmanager.droppables,function(){if(!this.options)return;if(!this.options.disabled&&this.visible&&$.ui.intersect(draggable,this,this.options.tolerance))
-dropped=this.drop.call(this,e);if(!this.options.disabled&&this.visible&&this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){this.isout=1;this.isover=0;this.deactivate.call(this,e);}});return dropped;},drag:function(draggable,e){if(draggable.options.refreshPositions)$.ui.ddmanager.prepareOffsets(draggable,e);$.each($.ui.ddmanager.droppables,function(){if(this.disabled||this.greedyChild||!this.visible)return;var intersects=$.ui.intersect(draggable,this,this.options.tolerance);var c=!intersects&&this.isover==1?'isout':(intersects&&this.isover==0?'isover':null);if(!c)return;var parentInstance;if(this.options.greedy){var parent=this.element.parents('.ui-droppable:eq(0)');if(parent.length){parentInstance=$.data(parent[0],'droppable');parentInstance.greedyChild=(c=='isover'?1:0);}}
-if(parentInstance&&c=='isover'){parentInstance['isover']=0;parentInstance['isout']=1;parentInstance.out.call(parentInstance,e);}
-this[c]=1;this[c=='isout'?'isover':'isout']=0;this[c=="isover"?"over":"out"].call(this,e);if(parentInstance&&c=='isout'){parentInstance['isout']=0;parentInstance['isover']=1;parentInstance.over.call(parentInstance,e);}});}};$.ui.plugin.add("droppable","activeClass",{activate:function(e,ui){$(this).addClass(ui.options.activeClass);},deactivate:function(e,ui){$(this).removeClass(ui.options.activeClass);},drop:function(e,ui){$(this).removeClass(ui.options.activeClass);}});$.ui.plugin.add("droppable","hoverClass",{over:function(e,ui){$(this).addClass(ui.options.hoverClass);},out:function(e,ui){$(this).removeClass(ui.options.hoverClass);},drop:function(e,ui){$(this).removeClass(ui.options.hoverClass);}});})(jQuery);(function($){$.widget("ui.resizable",$.extend($.ui.mouse,{init:function(){var self=this,o=this.options;var elpos=this.element.css('position');this.element.addClass("ui-resizable").css({position:/static/.test(elpos)?'relative':elpos});$.extend(o,{_aspectRatio:!!(o.aspectRatio),proxy:o.proxy||o.ghost||o.animate?o.proxy||'proxy':null,knobHandles:o.knobHandles===true?'ui-resizable-knob-handle':o.knobHandles});var aBorder='1px solid #DEDEDE';o.defaultTheme={'ui-resizable':{display:'block'},'ui-resizable-handle':{position:'absolute',background:'#F2F2F2',fontSize:'0.1px'},'ui-resizable-n':{cursor:'n-resize',height:'4px',left:'0px',right:'0px',borderTop:aBorder},'ui-resizable-s':{cursor:'s-resize',height:'4px',left:'0px',right:'0px',borderBottom:aBorder},'ui-resizable-e':{cursor:'e-resize',width:'4px',top:'0px',bottom:'0px',borderRight:aBorder},'ui-resizable-w':{cursor:'w-resize',width:'4px',top:'0px',bottom:'0px',borderLeft:aBorder},'ui-resizable-se':{cursor:'se-resize',width:'4px',height:'4px',borderRight:aBorder,borderBottom:aBorder},'ui-resizable-sw':{cursor:'sw-resize',width:'4px',height:'4px',borderBottom:aBorder,borderLeft:aBorder},'ui-resizable-ne':{cursor:'ne-resize',width:'4px',height:'4px',borderRight:aBorder,borderTop:aBorder},'ui-resizable-nw':{cursor:'nw-resize',width:'4px',height:'4px',borderLeft:aBorder,borderTop:aBorder}};o.knobTheme={'ui-resizable-handle':{background:'#F2F2F2',border:'1px solid #808080',height:'8px',width:'8px'},'ui-resizable-n':{cursor:'n-resize',top:'0px',left:'45%'},'ui-resizable-s':{cursor:'s-resize',bottom:'0px',left:'45%'},'ui-resizable-e':{cursor:'e-resize',right:'0px',top:'45%'},'ui-resizable-w':{cursor:'w-resize',left:'0px',top:'45%'},'ui-resizable-se':{cursor:'se-resize',right:'0px',bottom:'0px'},'ui-resizable-sw':{cursor:'sw-resize',left:'0px',bottom:'0px'},'ui-resizable-nw':{cursor:'nw-resize',left:'0px',top:'0px'},'ui-resizable-ne':{cursor:'ne-resize',right:'0px',top:'0px'}};o._nodeName=this.element[0].nodeName;if(o._nodeName.match(/canvas|textarea|input|select|button|img/i)){var el=this.element;if(/relative/.test(el.css('position'))&&$.browser.opera)
-el.css({position:'relative',top:'auto',left:'auto'});el.wrap($('<div class="ui-wrapper" style="overflow: hidden;"></div>').css({position:el.css('position'),width:el.outerWidth(),height:el.outerHeight(),top:el.css('top'),left:el.css('left')}));var oel=this.element;this.element=this.element.parent();this.element.data('resizable',this);this.element.css({marginLeft:oel.css("marginLeft"),marginTop:oel.css("marginTop"),marginRight:oel.css("marginRight"),marginBottom:oel.css("marginBottom")});oel.css({marginLeft:0,marginTop:0,marginRight:0,marginBottom:0});if($.browser.safari&&o.preventDefault)oel.css('resize','none');o.proportionallyResize=oel.css({position:'static',zoom:1,display:'block'});this.element.css({margin:oel.css('margin')});this._proportionallyResize();}
-if(!o.handles)o.handles=!$('.ui-resizable-handle',this.element).length?"e,s,se":{n:'.ui-resizable-n',e:'.ui-resizable-e',s:'.ui-resizable-s',w:'.ui-resizable-w',se:'.ui-resizable-se',sw:'.ui-resizable-sw',ne:'.ui-resizable-ne',nw:'.ui-resizable-nw'};if(o.handles.constructor==String){o.zIndex=o.zIndex||1000;if(o.handles=='all')o.handles='n,e,s,w,se,sw,ne,nw';var n=o.handles.split(",");o.handles={};var insertionsDefault={handle:'position: absolute; display: none; overflow:hidden;',n:'top: 0pt; width:100%;',e:'right: 0pt; height:100%;',s:'bottom: 0pt; width:100%;',w:'left: 0pt; height:100%;',se:'bottom: 0pt; right: 0px;',sw:'bottom: 0pt; left: 0px;',ne:'top: 0pt; right: 0px;',nw:'top: 0pt; left: 0px;'};for(var i=0;i<n.length;i++){var handle=$.trim(n[i]),dt=o.defaultTheme,hname='ui-resizable-'+handle,loadDefault=!$.ui.css(hname)&&!o.knobHandles,userKnobClass=$.ui.css('ui-resizable-knob-handle'),allDefTheme=$.extend(dt[hname],dt['ui-resizable-handle']),allKnobTheme=$.extend(o.knobTheme[hname],!userKnobClass?o.knobTheme['ui-resizable-handle']:{});var applyZIndex=/sw|se|ne|nw/.test(handle)?{zIndex:++o.zIndex}:{};var defCss=(loadDefault?insertionsDefault[handle]:''),axis=$(['<div class="ui-resizable-handle ',hname,'" style="',defCss,insertionsDefault.handle,'"></div>'].join('')).css(applyZIndex);o.handles[handle]='.ui-resizable-'+handle;this.element.append(axis.css(loadDefault?allDefTheme:{}).css(o.knobHandles?allKnobTheme:{}).addClass(o.knobHandles?'ui-resizable-knob-handle':'').addClass(o.knobHandles));}
-if(o.knobHandles)this.element.addClass('ui-resizable-knob').css(!$.ui.css('ui-resizable-knob')?{}:{});}
-this._renderAxis=function(target){target=target||this.element;for(var i in o.handles){if(o.handles[i].constructor==String)
-o.handles[i]=$(o.handles[i],this.element).show();if(o.transparent)
-o.handles[i].css({opacity:0});if(this.element.is('.ui-wrapper')&&o._nodeName.match(/textarea|input|select|button/i)){var axis=$(o.handles[i],this.element),padWrapper=0;padWrapper=/sw|ne|nw|se|n|s/.test(i)?axis.outerHeight():axis.outerWidth();var padPos=['padding',/ne|nw|n/.test(i)?'Top':/se|sw|s/.test(i)?'Bottom':/^e$/.test(i)?'Right':'Left'].join("");if(!o.transparent)
-target.css(padPos,padWrapper);this._proportionallyResize();}
-if(!$(o.handles[i]).length)continue;}};this._renderAxis(this.element);o._handles=$('.ui-resizable-handle',self.element);if(o.disableSelection)
-o._handles.each(function(i,e){$.ui.disableSelection(e);});o._handles.mouseover(function(){if(!o.resizing){if(this.className)
-var axis=this.className.match(/ui-resizable-(se|sw|ne|nw|n|e|s|w)/i);self.axis=o.axis=axis&&axis[1]?axis[1]:'se';}});if(o.autohide){o._handles.hide();$(self.element).addClass("ui-resizable-autohide").hover(function(){$(this).removeClass("ui-resizable-autohide");o._handles.show();},function(){if(!o.resizing){$(this).addClass("ui-resizable-autohide");o._handles.hide();}});}
-this.mouseInit();},plugins:{},ui:function(){return{axis:this.options.axis,options:this.options};},propagate:function(n,e){$.ui.plugin.call(this,n,[e,this.ui()]);this.element.triggerHandler(n=="resize"?n:["resize",n].join(""),[e,this.ui()],this.options[n]);},destroy:function(){var el=this.element,wrapped=el.children(".ui-resizable").get(0);this.mouseDestroy();var _destroy=function(exp){$(exp).removeClass("ui-resizable ui-resizable-disabled").removeData("resizable").unbind(".resizable").find('.ui-resizable-handle').remove();};_destroy(el);if(el.is('.ui-wrapper')&&wrapped){el.parent().append($(wrapped).css({position:el.css('position'),width:el.outerWidth(),height:el.outerHeight(),top:el.css('top'),left:el.css('left')})).end().remove();_destroy(wrapped);}},mouseStart:function(e){if(this.options.disabled)return false;var handle=false;for(var i in this.options.handles){if($(this.options.handles[i])[0]==e.target)handle=true;}
-if(!handle)return false;var o=this.options,iniPos=this.element.position(),el=this.element,num=function(v){return parseInt(v,10)||0;},ie6=$.browser.msie&&$.browser.version<7;o.resizing=true;o.documentScroll={top:$(document).scrollTop(),left:$(document).scrollLeft()};if(el.is('.ui-draggable')||(/absolute/).test(el.css('position'))){var sOffset=$.browser.msie&&!o.containment&&(/absolute/).test(el.css('position'))&&!(/relative/).test(el.parent().css('position'));var dscrollt=sOffset?o.documentScroll.top:0,dscrolll=sOffset?o.documentScroll.left:0;el.css({position:'absolute',top:(iniPos.top+dscrollt),left:(iniPos.left+dscrolll)});}
-if($.browser.opera&&/relative/.test(el.css('position')))
-el.css({position:'relative',top:'auto',left:'auto'});this._renderProxy();var curleft=num(this.helper.css('left')),curtop=num(this.helper.css('top'));this.offset=this.helper.offset();this.position={left:curleft,top:curtop};this.size=o.proxy||ie6?{width:el.outerWidth(),height:el.outerHeight()}:{width:el.width(),height:el.height()};this.originalSize=o.proxy||ie6?{width:el.outerWidth(),height:el.outerHeight()}:{width:el.width(),height:el.height()};this.originalPosition={left:curleft,top:curtop};this.sizeDiff={width:el.outerWidth()-el.width(),height:el.outerHeight()-el.height()};this.originalMousePosition={left:e.pageX,top:e.pageY};o.aspectRatio=(typeof o.aspectRatio=='number')?o.aspectRatio:((this.originalSize.height/this.originalSize.width)||1);if(o.preserveCursor)
-$('body').css('cursor',this.axis+'-resize');this.propagate("start",e);return true;},mouseDrag:function(e){var el=this.helper,o=this.options,props={},self=this,smp=this.originalMousePosition,a=this.axis;var dx=(e.pageX-smp.left)||0,dy=(e.pageY-smp.top)||0;var trigger=this._change[a];if(!trigger)return false;var data=trigger.apply(this,[e,dx,dy]),ie6=$.browser.msie&&$.browser.version<7,csdif=this.sizeDiff;if(o._aspectRatio||e.shiftKey)
-data=this._updateRatio(data,e);data=this._respectSize(data,e);this.propagate("resize",e);el.css({top:this.position.top+"px",left:this.position.left+"px",width:this.size.width+"px",height:this.size.height+"px"});if(!o.proxy&&o.proportionallyResize)
-this._proportionallyResize();this._updateCache(data);return false;},mouseStop:function(e){this.options.resizing=false;var o=this.options,num=function(v){return parseInt(v,10)||0;},self=this;if(o.proxy){var pr=o.proportionallyResize,ista=pr&&(/textarea/i).test(pr.get(0).nodeName),soffseth=ista&&$.ui.hasScroll(pr.get(0),'left')?0:self.sizeDiff.height,soffsetw=ista?0:self.sizeDiff.width;var s={width:(self.size.width-soffsetw),height:(self.size.height-soffseth)},left=(parseInt(self.element.css('left'),10)+(self.position.left-self.originalPosition.left))||null,top=(parseInt(self.element.css('top'),10)+(self.position.top-self.originalPosition.top))||null;if(!o.animate)
-this.element.css($.extend(s,{top:top,left:left}));if(o.proxy&&!o.animate)this._proportionallyResize();}
-if(o.preserveCursor)
-$('body').css('cursor','auto');this.propagate("stop",e);if(o.proxy)this.helper.remove();return false;},_updateCache:function(data){var o=this.options;this.offset=this.helper.offset();if(data.left)this.position.left=data.left;if(data.top)this.position.top=data.top;if(data.height)this.size.height=data.height;if(data.width)this.size.width=data.width;},_updateRatio:function(data,e){var o=this.options,cpos=this.position,csize=this.size,a=this.axis;if(data.height)data.width=(csize.height/o.aspectRatio);else if(data.width)data.height=(csize.width*o.aspectRatio);if(a=='sw'){data.left=cpos.left+(csize.width-data.width);data.top=null;}
-if(a=='nw'){data.top=cpos.top+(csize.height-data.height);data.left=cpos.left+(csize.width-data.width);}
-return data;},_respectSize:function(data,e){var el=this.helper,o=this.options,pRatio=o._aspectRatio||e.shiftKey,a=this.axis,ismaxw=data.width&&o.maxWidth&&o.maxWidth<data.width,ismaxh=data.height&&o.maxHeight&&o.maxHeight<data.height,isminw=data.width&&o.minWidth&&o.minWidth>data.width,isminh=data.height&&o.minHeight&&o.minHeight>data.height;if(isminw)data.width=o.minWidth;if(isminh)data.height=o.minHeight;if(ismaxw)data.width=o.maxWidth;if(ismaxh)data.height=o.maxHeight;var dw=this.originalPosition.left+this.originalSize.width,dh=this.position.top+this.size.height;var cw=/sw|nw|w/.test(a),ch=/nw|ne|n/.test(a);if(isminw&&cw)data.left=dw-o.minWidth;if(ismaxw&&cw)data.left=dw-o.maxWidth;if(isminh&&ch)data.top=dh-o.minHeight;if(ismaxh&&ch)data.top=dh-o.maxHeight;var isNotwh=!data.width&&!data.height;if(isNotwh&&!data.left&&data.top)data.top=null;else if(isNotwh&&!data.top&&data.left)data.left=null;return data;},_proportionallyResize:function(){var o=this.options;if(!o.proportionallyResize)return;var prel=o.proportionallyResize,el=this.helper||this.element;if(!o.borderDif){var b=[prel.css('borderTopWidth'),prel.css('borderRightWidth'),prel.css('borderBottomWidth'),prel.css('borderLeftWidth')],p=[prel.css('paddingTop'),prel.css('paddingRight'),prel.css('paddingBottom'),prel.css('paddingLeft')];o.borderDif=$.map(b,function(v,i){var border=parseInt(v,10)||0,padding=parseInt(p[i],10)||0;return border+padding;});}
-prel.css({height:(el.height()-o.borderDif[0]-o.borderDif[2])+"px",width:(el.width()-o.borderDif[1]-o.borderDif[3])+"px"});},_renderProxy:function(){var el=this.element,o=this.options;this.elementOffset=el.offset();if(o.proxy){this.helper=this.helper||$('<div style="overflow:hidden;"></div>');var ie6=$.browser.msie&&$.browser.version<7,ie6offset=(ie6?1:0),pxyoffset=(ie6?2:-1);this.helper.addClass(o.proxy).css({width:el.outerWidth()+pxyoffset,height:el.outerHeight()+pxyoffset,position:'absolute',left:this.elementOffset.left-ie6offset+'px',top:this.elementOffset.top-ie6offset+'px',zIndex:++o.zIndex});this.helper.appendTo("body");if(o.disableSelection)
-$.ui.disableSelection(this.helper.get(0));}else{this.helper=el;}},_change:{e:function(e,dx,dy){return{width:this.originalSize.width+dx};},w:function(e,dx,dy){var o=this.options,cs=this.originalSize,sp=this.originalPosition;return{left:sp.left+dx,width:cs.width-dx};},n:function(e,dx,dy){var o=this.options,cs=this.originalSize,sp=this.originalPosition;return{top:sp.top+dy,height:cs.height-dy};},s:function(e,dx,dy){return{height:this.originalSize.height+dy};},se:function(e,dx,dy){return $.extend(this._change.s.apply(this,arguments),this._change.e.apply(this,[e,dx,dy]));},sw:function(e,dx,dy){return $.extend(this._change.s.apply(this,arguments),this._change.w.apply(this,[e,dx,dy]));},ne:function(e,dx,dy){return $.extend(this._change.n.apply(this,arguments),this._change.e.apply(this,[e,dx,dy]));},nw:function(e,dx,dy){return $.extend(this._change.n.apply(this,arguments),this._change.w.apply(this,[e,dx,dy]));}}}));$.extend($.ui.resizable,{defaults:{cancel:":input,button",distance:0,delay:0,preventDefault:true,transparent:false,minWidth:10,minHeight:10,aspectRatio:false,disableSelection:true,preserveCursor:true,autohide:false,knobHandles:false}});$.ui.plugin.add("resizable","containment",{start:function(e,ui){var o=ui.options,self=$(this).data("resizable"),el=self.element;var oc=o.containment,ce=(oc instanceof $)?oc.get(0):(/parent/.test(oc))?el.parent().get(0):oc;if(!ce)return;self.containerElement=$(ce);if(/document/.test(oc)||oc==document){self.containerOffset={left:0,top:0};self.containerPosition={left:0,top:0};self.parentData={element:$(document),left:0,top:0,width:$(document).width(),height:$(document).height()||document.body.parentNode.scrollHeight};}
-else{self.containerOffset=$(ce).offset();self.containerPosition=$(ce).position();self.containerSize={height:$(ce).innerHeight(),width:$(ce).innerWidth()};var co=self.containerOffset,ch=self.containerSize.height,cw=self.containerSize.width,width=($.ui.hasScroll(ce,"left")?ce.scrollWidth:cw),height=($.ui.hasScroll(ce)?ce.scrollHeight:ch);self.parentData={element:ce,left:co.left,top:co.top,width:width,height:height};}},resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),ps=self.containerSize,co=self.containerOffset,cs=self.size,cp=self.position,pRatio=o._aspectRatio||e.shiftKey,cop={top:0,left:0},ce=self.containerElement;if(/static/.test(ce.css('position')))
-cop=self.containerPosition;if(cp.left<(o.proxy?co.left:cop.left)){self.size.width=self.size.width+(o.proxy?(self.position.left-co.left):(self.position.left-cop.left));if(pRatio)self.size.height=self.size.width*o.aspectRatio;self.position.left=o.proxy?co.left:cop.left;}
-if(cp.top<(o.proxy?co.top:0)){self.size.height=self.size.height+(o.proxy?(self.position.top-co.top):self.position.top);if(pRatio)self.size.width=self.size.height/o.aspectRatio;self.position.top=o.proxy?co.top:0;}
-var woset=(o.proxy?self.offset.left-co.left:(self.position.left-cop.left))+self.sizeDiff.width,hoset=(o.proxy?self.offset.top-co.top:self.position.top)+self.sizeDiff.height;if(woset+self.size.width>=self.parentData.width){self.size.width=self.parentData.width-woset;if(pRatio)self.size.height=self.size.width*o.aspectRatio;}
-if(hoset+self.size.height>=self.parentData.height){self.size.height=self.parentData.height-hoset;if(pRatio)self.size.width=self.size.height/o.aspectRatio;}},stop:function(e,ui){var o=ui.options,self=$(this).data("resizable"),cp=self.position,co=self.containerOffset,cop=self.containerPosition,ce=self.containerElement;var helper=$(self.helper),ho=helper.offset(),w=helper.innerWidth(),h=helper.innerHeight();if(o.proxy&&!o.animate&&/relative/.test(ce.css('position')))
-$(this).css({left:(ho.left-co.left),top:(ho.top-co.top),width:w,height:h});if(o.proxy&&!o.animate&&/static/.test(ce.css('position')))
-$(this).css({left:cop.left+(ho.left-co.left),top:cop.top+(ho.top-co.top),width:w,height:h});}});$.ui.plugin.add("resizable","grid",{resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),cs=self.size,os=self.originalSize,op=self.originalPosition,a=self.axis,ratio=o._aspectRatio||e.shiftKey;o.grid=typeof o.grid=="number"?[o.grid,o.grid]:o.grid;var ox=Math.round((cs.width-os.width)/(o.grid[0]||1))*(o.grid[0]||1),oy=Math.round((cs.height-os.height)/(o.grid[1]||1))*(o.grid[1]||1);if(/^(se|s|e)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;}
-else if(/^(ne)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.top=op.top-oy;}
-else if(/^(sw)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.left=op.left-ox;}
-else{self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.top=op.top-oy;self.position.left=op.left-ox;}}});$.ui.plugin.add("resizable","animate",{stop:function(e,ui){var o=ui.options,self=$(this).data("resizable");var pr=o.proportionallyResize,ista=pr&&(/textarea/i).test(pr.get(0).nodeName),soffseth=ista&&$.ui.hasScroll(pr.get(0),'left')?0:self.sizeDiff.height,soffsetw=ista?0:self.sizeDiff.width;var style={width:(self.size.width-soffsetw),height:(self.size.height-soffseth)},left=(parseInt(self.element.css('left'),10)+(self.position.left-self.originalPosition.left))||null,top=(parseInt(self.element.css('top'),10)+(self.position.top-self.originalPosition.top))||null;self.element.animate($.extend(style,top&&left?{top:top,left:left}:{}),{duration:o.animateDuration||"slow",easing:o.animateEasing||"swing",step:function(){var data={width:parseInt(self.element.css('width'),10),height:parseInt(self.element.css('height'),10),top:parseInt(self.element.css('top'),10),left:parseInt(self.element.css('left'),10)};if(pr)pr.css({width:data.width,height:data.height});self._updateCache(data);self.propagate("animate",e);}});}});$.ui.plugin.add("resizable","ghost",{start:function(e,ui){var o=ui.options,self=$(this).data("resizable"),pr=o.proportionallyResize,cs=self.size;if(!pr)self.ghost=self.element.clone();else self.ghost=pr.clone();self.ghost.css({opacity:.25,display:'block',position:'relative',height:cs.height,width:cs.width,margin:0,left:0,top:0}).addClass('ui-resizable-ghost').addClass(typeof o.ghost=='string'?o.ghost:'');self.ghost.appendTo(self.helper);},resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),pr=o.proportionallyResize;if(self.ghost)self.ghost.css({position:'relative',height:self.size.height,width:self.size.width});},stop:function(e,ui){var o=ui.options,self=$(this).data("resizable"),pr=o.proportionallyResize;if(self.ghost&&self.helper)self.helper.get(0).removeChild(self.ghost.get(0));}});$.ui.plugin.add("resizable","alsoResize",{start:function(e,ui){var o=ui.options,self=$(this).data("resizable"),_store=function(exp){$(exp).each(function(){$(this).data("resizable-alsoresize",{width:parseInt($(this).width(),10),height:parseInt($(this).height(),10),left:parseInt($(this).css('left'),10),top:parseInt($(this).css('top'),10)});});};if(typeof(o.alsoResize)=='object'){$.each(o.alsoResize,function(exp,c){_store(exp);});}else{_store(o.alsoResize);}},resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),os=self.originalSize,op=self.originalPosition;var delta={height:(self.size.height-os.height)||0,width:(self.size.width-os.width)||0,top:(self.position.top-op.top)||0,left:(self.position.left-op.left)||0},_alsoResize=function(exp,c){$(exp).each(function(){var start=$(this).data("resizable-alsoresize"),style={},css=c&&c.length?c:['width','height','top','left'];$.each(css||['width','height','top','left'],function(i,prop){var sum=(start[prop]||0)+(delta[prop]||0);if(sum&&sum>=0)
-style[prop]=sum||null;});$(this).css(style);});};if(typeof(o.alsoResize)=='object'){$.each(o.alsoResize,function(exp,c){_alsoResize(exp,c);});}else{_alsoResize(o.alsoResize);}},stop:function(e,ui){$(this).removeData("resizable-alsoresize-start");}});})(jQuery);(function($){$.widget("ui.selectable",$.extend($.ui.mouse,{init:function(){var self=this;this.element.addClass("ui-selectable");this.dragged=false;var selectees;this.refresh=function(){selectees=$(self.options.filter,self.element[0]);selectees.each(function(){var $this=$(this);var pos=$this.offset();$.data(this,"selectable-item",{element:this,$element:$this,left:pos.left,top:pos.top,right:pos.left+$this.width(),bottom:pos.top+$this.height(),startselected:false,selected:$this.hasClass('ui-selected'),selecting:$this.hasClass('ui-selecting'),unselecting:$this.hasClass('ui-unselecting')});});};this.refresh();this.selectees=selectees.addClass("ui-selectee");this.mouseInit();this.helper=$(document.createElement('div')).css({border:'1px dotted black'});},toggle:function(){if(this.options.disabled){this.enable();}else{this.disable();}},destroy:function(){this.element.removeClass("ui-selectable ui-selectable-disabled").removeData("selectable").unbind(".selectable");this.mouseDestroy();},mouseStart:function(e){var self=this;this.opos=[e.pageX,e.pageY];if(this.options.disabled)
-return;var options=this.options;this.selectees=$(options.filter,this.element[0]);this.element.triggerHandler("selectablestart",[e,{"selectable":this.element[0],"options":options}],options.start);$('body').append(this.helper);this.helper.css({"z-index":100,"position":"absolute","left":e.clientX,"top":e.clientY,"width":0,"height":0});if(options.autoRefresh){this.refresh();}
-this.selectees.filter('.ui-selected').each(function(){var selectee=$.data(this,"selectable-item");selectee.startselected=true;if(!e.ctrlKey){selectee.$element.removeClass('ui-selected');selectee.selected=false;selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;self.element.triggerHandler("selectableunselecting",[e,{selectable:self.element[0],unselecting:selectee.element,options:options}],options.unselecting);}});var isSelectee=false;$(e.target).parents().andSelf().each(function(){if($.data(this,"selectable-item"))isSelectee=true;});return this.options.keyboard?!isSelectee:true;},mouseDrag:function(e){var self=this;this.dragged=true;if(this.options.disabled)
-return;var options=this.options;var x1=this.opos[0],y1=this.opos[1],x2=e.pageX,y2=e.pageY;if(x1>x2){var tmp=x2;x2=x1;x1=tmp;}
-if(y1>y2){var tmp=y2;y2=y1;y1=tmp;}
-this.helper.css({left:x1,top:y1,width:x2-x1,height:y2-y1});this.selectees.each(function(){var selectee=$.data(this,"selectable-item");if(!selectee||selectee.element==self.element[0])
-return;var hit=false;if(options.tolerance=='touch'){hit=(!(selectee.left>x2||selectee.right<x1||selectee.top>y2||selectee.bottom<y1));}else if(options.tolerance=='fit'){hit=(selectee.left>x1&&selectee.right<x2&&selectee.top>y1&&selectee.bottom<y2);}
-if(hit){if(selectee.selected){selectee.$element.removeClass('ui-selected');selectee.selected=false;}
-if(selectee.unselecting){selectee.$element.removeClass('ui-unselecting');selectee.unselecting=false;}
-if(!selectee.selecting){selectee.$element.addClass('ui-selecting');selectee.selecting=true;self.element.triggerHandler("selectableselecting",[e,{selectable:self.element[0],selecting:selectee.element,options:options}],options.selecting);}}else{if(selectee.selecting){if(e.ctrlKey&&selectee.startselected){selectee.$element.removeClass('ui-selecting');selectee.selecting=false;selectee.$element.addClass('ui-selected');selectee.selected=true;}else{selectee.$element.removeClass('ui-selecting');selectee.selecting=false;if(selectee.startselected){selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;}
-self.element.triggerHandler("selectableunselecting",[e,{selectable:self.element[0],unselecting:selectee.element,options:options}],options.unselecting);}}
-if(selectee.selected){if(!e.ctrlKey&&!selectee.startselected){selectee.$element.removeClass('ui-selected');selectee.selected=false;selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;self.element.triggerHandler("selectableunselecting",[e,{selectable:self.element[0],unselecting:selectee.element,options:options}],options.unselecting);}}}});return false;},mouseStop:function(e){var self=this;this.dragged=false;var options=this.options;$('.ui-unselecting',this.element[0]).each(function(){var selectee=$.data(this,"selectable-item");selectee.$element.removeClass('ui-unselecting');selectee.unselecting=false;selectee.startselected=false;self.element.triggerHandler("selectableunselected",[e,{selectable:self.element[0],unselected:selectee.element,options:options}],options.unselected);});$('.ui-selecting',this.element[0]).each(function(){var selectee=$.data(this,"selectable-item");selectee.$element.removeClass('ui-selecting').addClass('ui-selected');selectee.selecting=false;selectee.selected=true;selectee.startselected=true;self.element.triggerHandler("selectableselected",[e,{selectable:self.element[0],selected:selectee.element,options:options}],options.selected);});this.element.triggerHandler("selectablestop",[e,{selectable:self.element[0],options:this.options}],this.options.stop);this.helper.remove();return false;}}));$.extend($.ui.selectable,{defaults:{distance:0,delay:0,cancel:":input,button",appendTo:'body',autoRefresh:true,filter:'*',tolerance:'touch'}});})(jQuery);(function($){function contains(a,b){var safari2=$.browser.safari&&$.browser.version<522;if(a.contains&&!safari2){return a.contains(b);}
-if(a.compareDocumentPosition)
-return!!(a.compareDocumentPosition(b)&16);while(b=b.parentNode)
-if(b==a)return true;return false;};$.widget("ui.sortable",$.extend($.ui.mouse,{init:function(){var o=this.options;this.containerCache={};this.element.addClass("ui-sortable");this.refresh();this.floating=this.items.length?(/left|right/).test(this.items[0].item.css('float')):false;if(!(/(relative|absolute|fixed)/).test(this.element.css('position')))this.element.css('position','relative');this.offset=this.element.offset();this.mouseInit();},plugins:{},ui:function(inst){return{helper:(inst||this)["helper"],placeholder:(inst||this)["placeholder"]||$([]),position:(inst||this)["position"],absolutePosition:(inst||this)["positionAbs"],options:this.options,element:this.element,item:(inst||this)["currentItem"],sender:inst?inst.element:null};},propagate:function(n,e,inst,noPropagation){$.ui.plugin.call(this,n,[e,this.ui(inst)]);if(!noPropagation)this.element.triggerHandler(n=="sort"?n:"sort"+n,[e,this.ui(inst)],this.options[n]);},serialize:function(o){var items=($.isFunction(this.options.items)?this.options.items.call(this.element):$(this.options.items,this.element)).not('.ui-sortable-helper');var str=[];o=o||{};items.each(function(){var res=($(this).attr(o.attribute||'id')||'').match(o.expression||(/(.+)[-=_](.+)/));if(res)str.push((o.key||res[1])+'[]='+(o.key?res[1]:res[2]));});return str.join('&');},toArray:function(attr){var items=($.isFunction(this.options.items)?this.options.items.call(this.element):$(this.options.items,this.element)).not('.ui-sortable-helper');var ret=[];items.each(function(){ret.push($(this).attr(attr||'id'));});return ret;},intersectsWith:function(item){var x1=this.positionAbs.left,x2=x1+this.helperProportions.width,y1=this.positionAbs.top,y2=y1+this.helperProportions.height;var l=item.left,r=l+item.width,t=item.top,b=t+item.height;if(this.options.tolerance=="pointer"||(this.options.tolerance=="guess"&&this.helperProportions[this.floating?'width':'height']>item[this.floating?'width':'height'])){return(y1+this.offset.click.top>t&&y1+this.offset.click.top<b&&x1+this.offset.click.left>l&&x1+this.offset.click.left<r);}else{return(l<x1+(this.helperProportions.width/2)&&x2-(this.helperProportions.width/2)<r&&t<y1+(this.helperProportions.height/2)&&y2-(this.helperProportions.height/2)<b);}},intersectsWithEdge:function(item){var x1=this.positionAbs.left,x2=x1+this.helperProportions.width,y1=this.positionAbs.top,y2=y1+this.helperProportions.height;var l=item.left,r=l+item.width,t=item.top,b=t+item.height;if(this.options.tolerance=="pointer"||(this.options.tolerance=="guess"&&this.helperProportions[this.floating?'width':'height']>item[this.floating?'width':'height'])){if(!(y1+this.offset.click.top>t&&y1+this.offset.click.top<b&&x1+this.offset.click.left>l&&x1+this.offset.click.left<r))return false;if(this.floating){if(x1+this.offset.click.left>l&&x1+this.offset.click.left<l+item.width/2)return 2;if(x1+this.offset.click.left>l+item.width/2&&x1+this.offset.click.left<r)return 1;}else{if(y1+this.offset.click.top>t&&y1+this.offset.click.top<t+item.height/2)return 2;if(y1+this.offset.click.top>t+item.height/2&&y1+this.offset.click.top<b)return 1;}}else{if(!(l<x1+(this.helperProportions.width/2)&&x2-(this.helperProportions.width/2)<r&&t<y1+(this.helperProportions.height/2)&&y2-(this.helperProportions.height/2)<b))return false;if(this.floating){if(x2>l&&x1<l)return 2;if(x1<r&&x2>r)return 1;}else{if(y2>t&&y1<t)return 1;if(y1<b&&y2>b)return 2;}}
-return false;},refresh:function(){this.refreshItems();this.refreshPositions();},refreshItems:function(){this.items=[];this.containers=[this];var items=this.items;var queries=[$.isFunction(this.options.items)?this.options.items.call(this.element):$(this.options.items,this.element)];if(this.options.connectWith){for(var i=this.options.connectWith.length-1;i>=0;i--){var cur=$(this.options.connectWith[i]);for(var j=cur.length-1;j>=0;j--){var inst=$.data(cur[j],'sortable');if(inst&&!inst.options.disabled){queries.push($.isFunction(inst.options.items)?inst.options.items.call(inst.element):$(inst.options.items,inst.element));this.containers.push(inst);}};};}
-for(var i=queries.length-1;i>=0;i--){queries[i].each(function(){$.data(this,'sortable-item',true);items.push({item:$(this),width:0,height:0,left:0,top:0});});};},refreshPositions:function(fast){for(var i=this.items.length-1;i>=0;i--){var t=this.items[i].item;if(!fast)this.items[i].width=(this.options.toleranceElement?$(this.options.toleranceElement,t):t).outerWidth();if(!fast)this.items[i].height=(this.options.toleranceElement?$(this.options.toleranceElement,t):t).outerHeight();var p=(this.options.toleranceElement?$(this.options.toleranceElement,t):t).offset();this.items[i].left=p.left;this.items[i].top=p.top;};for(var i=this.containers.length-1;i>=0;i--){var p=this.containers[i].element.offset();this.containers[i].containerCache.left=p.left;this.containers[i].containerCache.top=p.top;this.containers[i].containerCache.width=this.containers[i].element.outerWidth();this.containers[i].containerCache.height=this.containers[i].element.outerHeight();};},destroy:function(){this.element.removeClass("ui-sortable ui-sortable-disabled").removeData("sortable").unbind(".sortable");this.mouseDestroy();for(var i=this.items.length-1;i>=0;i--)
-this.items[i].item.removeData("sortable-item");},createPlaceholder:function(that){var self=that||this,o=self.options;if(o.placeholder.constructor==String){var className=o.placeholder;o.placeholder={element:function(){return $('<div></div>').addClass(className)[0];},update:function(i,p){p.css(i.offset()).css({width:i.outerWidth(),height:i.outerHeight()});}};}
-self.placeholder=$(o.placeholder.element.call(self.element,self.currentItem)).appendTo('body').css({position:'absolute'});o.placeholder.update.call(self.element,self.currentItem,self.placeholder);},contactContainers:function(e){for(var i=this.containers.length-1;i>=0;i--){if(this.intersectsWith(this.containers[i].containerCache)){if(!this.containers[i].containerCache.over){if(this.currentContainer!=this.containers[i]){var dist=10000;var itemWithLeastDistance=null;var base=this.positionAbs[this.containers[i].floating?'left':'top'];for(var j=this.items.length-1;j>=0;j--){if(!contains(this.containers[i].element[0],this.items[j].item[0]))continue;var cur=this.items[j][this.containers[i].floating?'left':'top'];if(Math.abs(cur-base)<dist){dist=Math.abs(cur-base);itemWithLeastDistance=this.items[j];}}
-if(!itemWithLeastDistance&&!this.options.dropOnEmpty)
-continue;if(this.placeholder)this.placeholder.remove();if(this.containers[i].options.placeholder){this.containers[i].createPlaceholder(this);}else{this.placeholder=null;;}
-itemWithLeastDistance?this.rearrange(e,itemWithLeastDistance):this.rearrange(e,null,this.containers[i].element);this.propagate("change",e);this.containers[i].propagate("change",e,this);this.currentContainer=this.containers[i];}
-this.containers[i].propagate("over",e,this);this.containers[i].containerCache.over=1;}}else{if(this.containers[i].containerCache.over){this.containers[i].propagate("out",e,this);this.containers[i].containerCache.over=0;}}};},mouseCapture:function(e,overrideHandle){if(this.options.disabled||this.options.type=='static')return false;var currentItem=null,nodes=$(e.target).parents().each(function(){if($.data(this,'sortable-item')){currentItem=$(this);return false;}});if($.data(e.target,'sortable-item'))currentItem=$(e.target);if(!currentItem)return false;if(this.options.handle&&!overrideHandle){var validHandle=false;$(this.options.handle,currentItem).find("*").andSelf().each(function(){if(this==e.target)validHandle=true;});if(!validHandle)return false;}
-this.currentItem=currentItem;return true;},mouseStart:function(e,overrideHandle,noActivation){var o=this.options;this.currentContainer=this;this.refresh();this.helper=typeof o.helper=='function'?$(o.helper.apply(this.element[0],[e,this.currentItem])):this.currentItem.clone();if(!this.helper.parents('body').length)this.helper.appendTo((o.appendTo!='parent'?o.appendTo:this.currentItem[0].parentNode));this.helper.css({position:'absolute',clear:'both'}).addClass('ui-sortable-helper');this.margins={left:(parseInt(this.currentItem.css("marginLeft"),10)||0),top:(parseInt(this.currentItem.css("marginTop"),10)||0)};this.offset=this.currentItem.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};this.offset.click={left:e.pageX-this.offset.left,top:e.pageY-this.offset.top};this.offsetParent=this.helper.offsetParent();var po=this.offsetParent.offset();this.offset.parent={top:po.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:po.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)};this.originalPosition=this.generatePosition(e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if(o.cursorAt){if(o.cursorAt.left!=undefined)this.offset.click.left=o.cursorAt.left;if(o.cursorAt.right!=undefined)this.offset.click.left=this.helperProportions.width-o.cursorAt.right;if(o.cursorAt.top!=undefined)this.offset.click.top=o.cursorAt.top;if(o.cursorAt.bottom!=undefined)this.offset.click.top=this.helperProportions.height-o.cursorAt.bottom;}
-this.domPosition=this.currentItem.prev()[0];if(o.containment){if(o.containment=='parent')o.containment=this.helper[0].parentNode;if(o.containment=='document'||o.containment=='window')this.containment=[0-this.offset.parent.left,0-this.offset.parent.top,$(o.containment=='document'?document:window).width()-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.element.css("marginRight"),10)||0),($(o.containment=='document'?document:window).height()||document.body.parentNode.scrollHeight)-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.element.css("marginBottom"),10)||0)];if(!(/^(document|window|parent)$/).test(o.containment)){var ce=$(o.containment)[0];var co=$(o.containment).offset();this.containment=[co.left+(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.parent.left,co.top+(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.parent.top,co.left+Math.max(ce.scrollWidth,ce.offsetWidth)-(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.currentItem.css("marginRight"),10)||0),co.top+Math.max(ce.scrollHeight,ce.offsetHeight)-(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.currentItem.css("marginBottom"),10)||0)];}}
-if(o.placeholder)this.createPlaceholder();this.propagate("start",e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if(this.options.placeholder!='clone')this.currentItem.css('visibility','hidden');if(!noActivation){for(var i=this.containers.length-1;i>=0;i--){this.containers[i].propagate("activate",e,this);}}
-if($.ui.ddmanager)$.ui.ddmanager.current=this;if($.ui.ddmanager&&!o.dropBehaviour)$.ui.ddmanager.prepareOffsets(this,e);this.dragging=true;this.mouseDrag(e);return true;},convertPositionTo:function(d,pos){if(!pos)pos=this.position;var mod=d=="absolute"?1:-1;return{top:(pos.top
--(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)*mod
--(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft)*mod
-+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)),left:(e.pageX
-+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft))};if(!this.originalPosition)return position;if(this.containment){if(position.left<this.containment[0])position.left=this.containment[0];if(position.top<this.containment[1])position.top=this.containment[1];if(position.left>this.containment[2])position.left=this.containment[2];if(position.top>this.containment[3])position.top=this.containment[3];}
-return position;},mouseDrag:function(e){this.position=this.generatePosition(e);this.positionAbs=this.convertPositionTo("absolute");for(var i=this.items.length-1;i>=0;i--){var intersection=this.intersectsWithEdge(this.items[i]);if(!intersection)continue;if(this.items[i].item[0]!=this.currentItem[0]&&this.currentItem[intersection==1?"next":"prev"]()[0]!=this.items[i].item[0]&&!contains(this.currentItem[0],this.items[i].item[0])&&(this.options.type=='semi-dynamic'?!contains(this.element[0],this.items[i].item[0]):true)){this.direction=intersection==1?"down":"up";this.rearrange(e,this.items[i]);this.propagate("change",e);break;}}
-this.contactContainers(e);this.propagate("sort",e);if(!this.options.axis||this.options.axis=="x")this.helper[0].style.left=this.position.left+'px';if(!this.options.axis||this.options.axis=="y")this.helper[0].style.top=this.position.top+'px';if($.ui.ddmanager)$.ui.ddmanager.drag(this,e);return false;},mouseStop:function(e,noPropagation){if($.ui.ddmanager&&!this.options.dropBehaviour)
-$.ui.ddmanager.drop(this,e);if(this.options.revert){var self=this;var cur=self.currentItem.offset();if(self.placeholder)self.placeholder.animate({opacity:'hide'},(parseInt(this.options.revert,10)||500)-50);$(this.helper).animate({left:cur.left-this.offset.parent.left-self.margins.left+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft),top:cur.top-this.offset.parent.top-self.margins.top+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)},parseInt(this.options.revert,10)||500,function(){self.propagate("stop",e,null,noPropagation);self.clear(e);});}else{this.propagate("stop",e,null,noPropagation);this.clear(e,noPropagation);}
-return false;},clear:function(e,noPropagation){if(this.domPosition!=this.currentItem.prev().not(".ui-sortable-helper")[0])this.propagate("update",e,null,noPropagation);if(!contains(this.element[0],this.currentItem[0])){if(this.domPosition==this.currentItem.prev().not(".ui-sortable-helper")[0])this.propagate("update",e,null,noPropagation);this.propagate("remove",e,null,noPropagation);for(var i=this.containers.length-1;i>=0;i--){if(contains(this.containers[i].element[0],this.currentItem[0])){this.containers[i].propagate("update",e,this,noPropagation);this.containers[i].propagate("receive",e,this,noPropagation);}};};for(var i=this.containers.length-1;i>=0;i--){this.containers[i].propagate("deactivate",e,this,noPropagation);if(this.containers[i].containerCache.over){this.containers[i].propagate("out",e,this);this.containers[i].containerCache.over=0;}}
-this.dragging=false;if(this.cancelHelperRemoval)return false;$(this.currentItem).css('visibility','');if(this.placeholder)this.placeholder.remove();this.helper.remove();return true;},rearrange:function(e,i,a){a?a.append(this.currentItem):i.item[this.direction=='down'?'before':'after'](this.currentItem);this.refreshPositions(true);if(this.options.placeholder)this.options.placeholder.update.call(this.element,this.currentItem,this.placeholder);}}));$.extend($.ui.sortable,{getter:"serialize toArray",defaults:{tolerance:"guess",distance:0,delay:0,cancel:":input,button",items:'> *',zIndex:1000,dropOnEmpty:true,appendTo:"parent"}});$.ui.plugin.add("sortable","cursor",{start:function(e,ui){var t=$('body');if(t.css("cursor"))ui.options._cursor=t.css("cursor");t.css("cursor",ui.options.cursor);},stop:function(e,ui){if(ui.options._cursor)$('body').css("cursor",ui.options._cursor);}});$.ui.plugin.add("sortable","zIndex",{start:function(e,ui){var t=ui.helper;if(t.css("zIndex"))ui.options._zIndex=t.css("zIndex");t.css('zIndex',ui.options.zIndex);},stop:function(e,ui){if(ui.options._zIndex)$(ui.helper).css('zIndex',ui.options._zIndex);}});$.ui.plugin.add("sortable","opacity",{start:function(e,ui){var t=ui.helper;if(t.css("opacity"))ui.options._opacity=t.css("opacity");t.css('opacity',ui.options.opacity);},stop:function(e,ui){if(ui.options._opacity)$(ui.helper).css('opacity',ui.options._opacity);}});$.ui.plugin.add("sortable","scroll",{start:function(e,ui){var o=ui.options;var i=$(this).data("sortable");o.scrollSensitivity=o.scrollSensitivity||20;o.scrollSpeed=o.scrollSpeed||20;i.overflowY=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-y')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(i.currentItem);i.overflowX=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-x')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(i.currentItem);if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML')i.overflowYOffset=i.overflowY.offset();if(i.overflowX[0]!=document&&i.overflowX[0].tagName!='HTML')i.overflowXOffset=i.overflowX.offset();},sort:function(e,ui){var o=ui.options;var i=$(this).data("sortable");if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML'){if((i.overflowYOffset.top+i.overflowY[0].offsetHeight)-e.pageY<o.scrollSensitivity)
-$(document).scrollLeft($(document).scrollLeft()+o.scrollSpeed);}}});})(jQuery);
\ No newline at end of file
Deleted: branches/testbaudson_dev/http/extensions/jquery.ajaxmanager.js
--- trunk/mapbender/http/extensions/jquery.ajaxmanager.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/extensions/jquery.ajaxmanager.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,165 +0,0 @@
- * @author Administrator
-(function($) {
-    $.extend({
-        manageAjax: function(o){
-          o = $.extend({manageType: 'normal',maxReq: 0, blockSameRequest: false},o);
-          return new $.ajaxManager(o);
-        ajaxManager: function(o){
-            this.opt = o;
-            this.queue = [];
-    $.extend(
-        $.ajaxManager.prototype,
-            add: function(o){
-                 var quLen = this.queue.length, s = this.opt, q = this.queue, self = this,i,j;
-                 var cD = (o.data && typeof o.data != "string")?$.param(o.data):o.data;
-                 if(s.blockSameRequest){
-                    var toPrevent = false;
-                    for (var i = 0;i<quLen; i++){
-                        if(q[i] && q[i].data === cD && q[i].url === o.url && q[i].type === o.type) {
-                            toPrevent = true;
-                            break;
-                    if(toPrevent)
-                        return false;
-                 q[ quLen ] = {
-            		fnError: o.error,
-            		fnSuccess: o.success,
-            		fnComplete: o.complete,
-                    fnAbort: o.abort,
-            		error: [],
-            		success: [],
-            		complete: [],
-            		done: false,
-            		queued: false,
-                    data: cD,
-                    url: o.url,
-                    type: o.type,
-                    xhr: null
-                o.error = function(){if(q[ quLen ]) q[ quLen ].error = arguments; };
-            	o.success = function(){if(q[ quLen ]) q[ quLen ].success = arguments; };
-                o.abort = function(){if(q[ quLen ]) q[ quLen ].abort = arguments; };
-                function startCallbacks(num){
-                    if ( q[ num ].fnError ) q[ num ].fnError.apply( $, q[ num ].error );
-        			if ( q[ num ].fnSuccess ) q[ num ].fnSuccess.apply( $, q[ num ].success );
-        			if ( q[ num ].fnComplete ) q[ num ].fnComplete.apply( $, q[ num ].complete );
-        			self.abort(num,true);
-            	o.complete = function(){
-            		if(!q[ quLen ])
-                        return;
-                    q[ quLen ].complete = arguments;
-            		q[ quLen ].done = true;
-                    switch (s.manageType) {
-                      case 'sync':
-                        if (quLen === 0 || !q[ quLen-1 ]){
-                            var curQLen = q.length;
-                			for ( i = quLen; i < curQLen; i++ ) {
-                                if(q[i]){
-                                    if(q[i].done)
-                                        startCallbacks(i)
-                                    else
-                                        break;
-                        break;
-                        case 'queue':
-                			for ( i = 0, j = 0; i < curQLen; i++ ) {
-                                if(q[i] && q[i].queued){
-                                    q[i].xhr = jQuery.ajax(q[i].xhr);
-                                    q[i].queued = false;
-                                    break;
-                        startCallbacks(quLen);
-                        break;
-                      case 'abortOld':
-                        for ( i = quLen; i >= 0; i-- ) {
-                            if(q[i]){
-                                self.abort(i);
-                        break;
-                      default:
-                        break;
-                if(s.maxReq){
-                    if(s.manageType != 'queue') {
-                        for (i = quLen, j = 0; i >= 0; i--) {
-            				if(j >= s.maxReq)
-                                this.abort(i);
-                            if(q[i]){
-                                j++;
-                    } else {
-                        for (i = 0, j = 0; i <= quLen && !q[quLen].queued; i++) {
-                            if(q[i] && !q[i].queued)
-                                j++;
-                            if(j > s.maxReq)
-                                q[quLen].queued = true;
-                q[ quLen ].xhr = (q[quLen].queued)?o:jQuery.ajax(o);
-                return quLen;
-            cleanUp: function(){
-               this.queue = [];
-            abort: function(num,completed){
-               var qLen = this.queue.length, s = this.opt, q = this.queue, self = this,i;
-               function del(num){
-                   if(!q[num])
-                       return;
-                   (!completed && q[num].fnAbort) && q[num].fnAbort.apply($,[num]);
-                   if(!q[num])
-                       return;
-                   if(q[num].xhr){
-                      if (typeof q[num].xhr.abort != 'undefined')
-                          q[num].xhr.abort();
-                      if (typeof q[num].xhr.close != 'undefined')
-                          q[num].xhr.close();
-                      q[num].xhr = null;
-                    q[num] = null;
-               if(!num && num !== 0){
-                   for (i = 0; i < qLen; i++){
-                       del(i);
-                   this.cleanUp();
-               } else {
-                   del(num);
-                   var allowCleaning = true;
-                   for (i = qLen; i >= 0; i--){
-                       if(q[i]){
-                            allowCleaning = false;
-                            break;
-                   if (allowCleaning) this.cleanUp();
-})(jQuery);
Deleted: branches/testbaudson_dev/http/extensions/jquery.js
--- trunk/mapbender/http/extensions/jquery.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/extensions/jquery.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,11 +0,0 @@
- * jQuery 1.2.2 - New Wave Javascript
- * Copyright (c) 2007 John Resig (jquery.com)
- * Dual licensed under the MIT (MIT-LICENSE.txt)
- * and GPL (GPL-LICENSE.txt) licenses.
- * $Date: 2008-01-14 17:56:07 -0500 (Mon, 14 Jan 2008) $
- * $Rev: 4454 $
-eval(function(p,a,c,k,e,r){e=function(c){return(c<a?'':e(parseInt(c/a)))+((c=c%a)>35?String.fromCharCode(c+29):c.toString(36))};if(!''.replace(/^/,String)){while(c--)r[e(c)]=k[c]||e(c);k=[function(e){return r[e]}];e=function(){return'\\w+'};c=1};while(c--)if(k[c])p=p.replace(new RegExp('\\b'+e(c)+'\\b','g'),k[c]);return p}('(J(){7(1e.19)L w=1e.19;L E=1e.19=J(a,b){K 1D E.2m.4Y(a,b)};7(1e.$)L D=1e.$;1e.$=E;L u=/^[^<]*(<(.|\\s)+>)[^>]*$|^#(\\w+)$/;L G=/^.[^:#\\[\\.]*$/;E.1i=E.2m={4Y:J(d,b){d=d||T;7(d.15){6[0]=d;6.M=1;K 6}N 7(1v d=="25"){L c=u.39(d);7(c&&(c[1]||!b)){7(c[1])d=E.5c([c[1]],b);N{L a=T.5N(c[3]);7(a)7(a.2s!=c[3])K E().2r(d);N{6[0]=a;6.M=1;K 6}N d=[]}}N K 1D E(b).2r(d)}N 7(E.1q(d))K 1D E(T)[E.1i.21?"21":"43"](d);K 6.6G(d.1n==1N&&d||(d.5j||d.M&&d!=1e&&!d.15&&d[0]!=10&&d[0].15)&&E.2H(d)||[d])},5j:"1.2.2",82:J(){K 6.M},M:0,22:J(a){K a==10?E.2H(6):6[a]},2E:J(b){L a=E(b);a.56=6;K a},6G:J(a){6.M=0;1N.2m.1h.1j(6,a);K 6},V:J(a,b){K E.V(6,a,b)},5E:J(b){L a=-1;6.V(J(i){7(6==b)a=i});K a},1K:J(c,a,b){L d=c;7(c.1n==4d)7(a==10)K 6.M&&E[b||"1K"](6[0],c)||10;N{d={};d[c]=a}K 6.V(J(i){P(c 1r d)E.1K(b?6.Y:6,c,E.1l(6,d[c],b,i,c))})},1m:J(b,a){7((b==\'29\'||b==\'1P\')&&2M(a)<0)a=10;K 6.1K(b,a,"2q")},1t:J(b){7(1v b!="4D"&&b!=W)K 6.4B().3t((6[0]&&6[0].2u||T).5v(b));L a="";E.V(b||6,J(){E.V(6.3p,J(){7(6.15!=8)a+=6.15!=1?6.6M:E.1i.1t([6])})});K a},5r:J(b){7(6[0])E(b,6[0].2u).5J().3n(6[0]).2a(J(){L a=6;2e(a.1B)a=a.1B;K a}).3t(6);K 6},8t:J(a){K 6.V(J(){E(6).6C().5r(a)})},8m:J(a){K 6.V(J(){E(6).5r(a)})},3t:J(){K 6.3P(1a,R,S,J(a){7(6.15==1)6.3k(a)})},6s:J(){K 6.3P(1a,R,R,J(a){7(6.15==1)6.3n(a,6.1B)})},6o:J(){K 6.3P(1a,S,S,J(a){6.1b.3n(a,6)})},5a:J(){K 6.3P(1a,S,R,J(a){6.1b.3n(a,6.2J)})},3h:J(){K 6.56||E([])},2r:J(b){L c=E.2a(6,J(a){K E.2r(b,a)});K 6.2E(/[^+>] [^+>]/.17(b)||b.1g("..")>-1?E.57(c):c)},5J:J(e){L f=6.2a(J(){7(E.14.1d&&!E.3W(6)){L a=6.6c(R),5u=T.2R("1u"),4T=T.2R("1u");5u.3k(a);4T.38=5u.38;K 4T.1B}N K 6.6c(R)});L d=f.2r("*").4R().V(J(){7(6[F]!=10)6[F]=W});7(e===R)6.2r("*").4R().V(J(i){7(6.15==3)K;L c=E.Q(6,"2N");P(L a 1r c)P(L b 1r c[a])E.16.1c(d[i],a,c[a][b],c[a][b].Q)});K f},1F:J(b){K 6.2E(E.1q(b)&&E.3x(6,J(a,i){K b.1O(a,i)})||E.3d(b,6))},4I:J(b){7(b.1n==4d)7(G.17(b))K 6.2E(E.3d(b,6,R));N b=E.3d(b,6);L a=b.M&&b[b.M-1]!==10&&!b.15;K 6.1F(J(){K a?E.35(6,b)<0:6!=b})},1c:J(a){K!a?6:6.2E(E.34(6.22(),a.1n==4d?E(a).22():a.M!=10&&(!a.12||E.12(a,"3i"))?a:[a]))},3K:J(a){K a?E.3d(a,6).M>0:S},7g:J(a){K 6.3K("."+a)},5P:J(b){7(b==10){7(6.M){L c=6[0];7(E.12(c,"2y")){L e=c.44,5L=[],11=c.11,30=c.U=="2y-30";7(e<0)K W;P(L i=30?e:0,2b=30?e+1:11.M;i<2b;i++){L d=11[i];7(d.2p){b=E.14.1d&&!d.9s.1C.9o?d.1t:d.1C;7(30)K b;5L.1h(b)}}K 5L}N K(6[0].1C||"").1p(/\\r/g,"")}K 10}K 6.V(J(){7(6.15!=1)K;7(b.1n==1N&&/5w|5y/.17(6.U))6.3o=(E.35(6.1C,b)>=0||E.35(6.37,b)>=0);N 7(E.12(6,"2y")){L a=b.1n==1N?b:[b];E("90",6).V(J(){6.2p=(E.35(6.1C,a)>=0||E.35(6.1t,a)>=0)});7(!a.M)6.44=-1}N 6.1C=b})},3q:J(a){K a==10?(6.M?6[0].38:W):6.4B().3t(a)},6P:J(a){K 6.5a(a).1Y()},6N:J(i){K 6.2V(i,i+1)},2V:J(){K 6.2E(1N.2m.2V.1j(6,1a))},2a:J(b){K 6.2E(E.2a(6,J(a,i){K b.1O(a,i,a)}))},4R:J(){K 6.1c(6.56)},3P:J(g,f,h,d){L e=6.M>1,3m;K 6.V(J(){7(!3m){3m=E.5c(g,6.2u);7(h)3m.8I()}L b=6;7(f&&E.12(6,"1V")&&E.12(3m[0],"4x"))b=6.3V("1S")[0]||6.3k(6.2u.2R("1S"));L c=E([]);E.V(3m,J(){L a=e?E(6).5J(R)[0]:6;7(E.12(a,"1o")){c=c.1c(a)}N{7(a.15==1)c=c.1c(E("1o",a).1Y());d.1O(b,a)}});c.V(6D)})}};E.2m.4Y.2m=E.2m;J 6D(i,a){7(a.3R)E.3Q({1f:a.3R,3l:S,1G:"1o"});N E.5l(a.1t||a.6A||a.38||"");7(a.1b)a.1b.2X(a)}E.1s=E.1i.1s=J(){L b=1a[0]||{},i=1,M=1a.M,5i=S,11;7(b.1n==8f){5i=b;b=1a[1]||{};i=2}7(1v b!="4D"&&1v b!="J")b={};7(M==1){b=6;i=0}P(;i<M;i++)7((11=1a[i])!=W)P(L a 1r 11){7(b===11[a])6z;7(5i&&11[a]&&1v 11[a]=="4D"&&b[a]&&!11[a].15)b[a]=E.1s(b[a],11[a]);N 7(11[a]!=10)b[a]=11[a]}K b};L F="19"+(1D 3O()).3N(),6y=0,5e={};L H=/z-?5E|89-?87|1y|6q|85-?1P/i;E.1s({81:J(a){1e.$=D;7(a)1e.19=w;K E},1q:J(a){K!!a&&1v a!="25"&&!a.12&&a.1n!=1N&&/J/i.17(a+"")},3W:J(a){K a.1I&&!a.1k||a.28&&a.2u&&!a.2u.1k},5l:J(a){a=E.3f(a);7(a){L b=T.3V("6k")[0]||T.1I,1o=T.2R("1o");1o.U="1t/4l";7(E.14.1d)1o.1t=a;N 1o.3k(T.5v(a));b.3k(1o);b.2X(1o)}},12:J(b,a){K b.12&&b.12.2F()==a.2F()},1Q:{},Q:J(c,d,b){c=c==1e?5e:c;L a=c[F];7(!a)a=c[F]=++6y;7(d&&!E.1Q[a])E.1Q[a]={};7(b!=10)E.1Q[a][d]=b;K d?E.1Q[a][d]:a},3H:J(c,b){c=c==1e?5e:c;L a=c[F];7(b){7(E.1Q[a]){2T E.1Q[a][b];b="";P(b 1r E.1Q[a])1T;7(!b)E.3H(c)}}N{1R{2T c[F]}1W(e){7(c.55)c.55(F)}2T E.1Q[a]}},V:J(c,a,b){7(b){7(c.M==10){P(L d 1r c)7(a.1j(c[d],b)===S)1T}N P(L i=0,M=c.M;i<M;i++)7(a.1j(c[i],b)===S)1T}N{7(c.M==10){P(L d 1r c)7(a.1O(c[d],d,c[d])===S)1T}N P(L i=0,M=c.M,1C=c[0];i<M&&a.1O(1C,i,1C)!==S;1C=c[++i]){}}K c},1l:J(b,a,c,i,d){7(E.1q(a))a=a.1O(b,i);K a&&a.1n==53&&c=="2q"&&!H.17(d)?a+"2P":a},1w:{1c:J(c,b){E.V((b||"").2d(/\\s+/),J(i,a){7(c.15==1&&!E.1w.3E(c.1w,a))c.1w+=(c.1w?" ":"")+a})},1Y:J(c,b){7(c.15==1)c.1w=b!=10?E.3x(c.1w.2d(/\\s+/),J(a){K!E.1w.3E(b,a)}).6g(" "):""},3E:J(b,a){K E.35(a,(b.1w||b).3D().2d(/\\s+/))>-1}},6e:J(b,c,a){L e={};P(L d 1r c){e[d]=b.Y[d];b.Y[d]=c[d]}a.1O(b);P(L d 1r c)b.Y[d]=e[d]},1m:J(d,e,c){7(e=="29"||e=="1P"){L b,3S={3C:"4Z",4X:"23",18:"3u"},3r=e=="29"?["7P","7M"]:["7L","7K"];J 4S(){b=e=="29"?d.7J:d.7I;L a=0,3a=0;E.V(3r,J(){a+=2M(E.2q(d,"7H"+6,R))||0;3a+=2M(E.2q(d,"3a"+6+"62",R))||0});b-=1Z.7E(a+3a)}7(E(d).3K(":4b"))4S();N E.6e(d,3S,4S);K 1Z.2b(0,b)}K E.2q(d,e,c)},2q:J(e,k,j){L d;J 3y(b){7(!E.14.26)K S;L a=T.4a.4L(b,W);K!a||a.4K("3y")==""}7(k=="1y"&&E.14.1d){d=E.1K(e.Y,"1y");K d==""?"1":d}7(E.14.2B&&k=="18"){L c=e.Y.18;e.Y.18="3u";e.Y.18=c}7(k.1E(/4c/i))k=y;7(!j&&e.Y&&e.Y[k])d=e.Y[k];N 7(T.4a&&T.4a.4L){7(k.1E(/4c/i))k="4c";k=k.1p(/([A-Z])/g,"-$1").2w();L h=T.4a.4L(e,W);7(h&&!3y(e))d=h.4K(k);N{L f=[],2L=[];P(L a=e;a&&3y(a);a=a.1b)2L.4U(a);P(L i=0;i<2L.M;i++)7(3y(2L[i])){f[i]=2L[i].Y.18;2L[i].Y.18="3u"}d=k=="18"&&f[2L.M-1]!=W?"2D":(h&&h.4K(k))||"";P(L i=0;i<f.M;i++)7(f[i]!=W)2L[i].Y.18=f[i]}7(k=="1y"&&d=="")d="1"}N 7(e.4j){L g=k.1p(/\\-(\\w)/g,J(a,b){K b.2F()});d=e.4j[k]||e.4j[g];7(!/^\\d+(2P)?$/i.17(d)&&/^\\d/.17(d)){L l=e.Y.2c,3A=e.3A.2c;e.3A.2c=e.4j.2c;e.Y.2c=d||0;d=e.Y.7l+"2P";e.Y.2c=l;e.3A.2c=3A}}K d},5c:J(l,h){L k=[];h=h||T;7(1v h.2R==\'10\')h=h.2u||h[0]&&h[0].2u||T;E.V(l,J(i,d){7(!d)K;7(d.1n==53)d=d.3D();7(1v d=="25"){d=d.1p(/(<(\\w+)[^>]*?)\\/>/g,J(b,a,c){K c.1E(/^(7k|7h|5Q|7f|48|5O|a3|3v|9Y|9W|9T)$/i)?b:a+"></"+c+">"});L f=E.3f(d).2w(),1u=h.2R("1u");L e=!f.1g("<9R")&&[1,"<2y 78=\'78\'>","</2y>"]||!f.1g("<9O")&&[1,"<77>","</77>"]||f.1E(/^<(9K|1S|9I|9F|9A)/)&&[1,"<1V>","</1V>"]||!f.1g("<4x")&&[2,"<1V><1S>","</1S></1V>"]||(!f.1g("<9y")||!f.1g("<9v"))&&[3,"<1V><1S><4x>","</4x></1S></1V>"]||!f.1g("<5Q")&&[2,"<1V><1S></1S><76>","</76></1V>"]||E.14.1d&&[1,"1u<1u>","</1u>"]||[0,"",""];1u.38=e[1]+d+e[2];2e(e[0]--)1u=1u.5D;7(E.14.1d){L g=!f.1g("<1V")&&f.1g("<1S")<0?1u.1B&&1u.1B.3p:e[1]=="<1V>"&&f.1g("<1S")<0?1u.3p:[];P(L j=g.M-1;j>=0;--j)7(E.12(g[j],"1S")&&!g[j].3p.M)g[j].1b.2X(g[j]);7(/^\\s/.17(d))1u.3n(h.5v(d.1E(/^\\s*/)[0]),1u.1B)}d=E.2H(1u.3p)}7(d.M===0&&(!E.12(d,"3i")&&!E.12(d,"2y")))K;7(d[0]==10||E.12(d,"3i")||d.11)k.1h(d);N k=E.34(k,d)});K k},1K:J(d,e,c){7(!d||d.15==3||d.15==8)K 10;L f=E.3W(d)?{}:E.3S;7(e=="2p"&&E.14.26)d.1b.44;7(f[e]){7(c!=10)d[f[e]]=c;K d[f[e]]}N 7(E.14.1d&&e=="Y")K E.1K(d.Y,"9r",c);N 7(c==10&&E.14.1d&&E.12(d,"3i")&&(e=="9q"||e=="9p"))K d.9n(e).6M;N 7(d.28){7(c!=10){7(e=="U"&&E.12(d,"48")&&d.1b)6Z"U 9i 9g\'t 9b 9a";d.99(e,""+c)}7(E.14.1d&&/6T|3R/.17(e)&&!E.3W(d))K d.4z(e,2);K d.4z(e)}N{7(e=="1y"&&E.14.1d){7(c!=10){d.6q=1;d.1F=(d.1F||"").1p(/6W\\([^)]*\\)/,"")+(2M(c).3D()=="93"?"":"6W(1y="+c*6S+")")}K d.1F&&d.1F.1g("1y=")>=0?(2M(d.1F.1E(/1y=([^)]*)/)[1])/6S).3D():""}e=e.1p(/-([a-z])/92,J(a,b){K b.2F()});7(c!=10)d[e]=c;K d[e]}},3f:J(a){K(a||"").1p(/^\\s+|\\s+$/g,"")},2H:J(b){L a=[];7(1v b!="91")P(L i=0,M=b.M;i<M;i++)a.1h(b[i]);N a=b.2V(0);K a},35:J(b,a){P(L i=0,M=a.M;i<M;i++)7(a[i]==b)K i;K-1},34:J(a,b){7(E.14.1d){P(L i=0;b[i];i++)7(b[i].15!=8)a.1h(b[i])}N P(L i=0;b[i];i++)a.1h(b[i]);K a},57:J(a){L c=[],2j={};1R{P(L i=0,M=a.M;i<M;i++){L b=E.Q(a[i]);7(!2j[b]){2j[b]=R;c.1h(a[i])}}}1W(e){c=a}K c},3x:J(c,a,d){7(1v a=="25")a=4A("S||J(a,i){K "+a+"}");L b=[];P(L i=0,M=c.M;i<M;i++)7(!d&&a(c[i],i)||d&&!a(c[i],i))b.1h(c[i]);K b},2a:J(d,a){L c=[];P(L i=0,M=d.M;i<M;i++){L b=a(d[i],i);7(b!==W&&b!=10){7(b.1n!=1N)b=[b];c=c.6Q(b)}}K c}});L v=8X.8V.2w();E.14={5n:(v.1E(/.+(?:8R|8Q|8P|8O)[\\/: ]([\\d.]+)/)||[])[1],26:/6L/.17(v),2B:/2B/.17(v),1d:/1d/.17(v)&&!/2B/.17(v),3X:/3X/.17(v)&&!/(8M|6L)/.17(v)};L y=E.14.1d?"6K":"6J";E.1s({8J:!E.14.1d||T.6I=="6H",3S:{"P":"8G","8E":"1w","4c":y,6J:y,6K:y,38:"38",1w:"1w",1C:"1C",2W:"2W",3o:"3o",8C:"8B",2p:"2p",8A:"8z",44:"44",6F:"6F",28:"28",12:"12"}});E.V({6E:"O.1b",8y:"19.4w(O,\'1b\')",8x:"19.31(O,2,\'2J\')",8w:"19.31(O,2,\'4v\')",8v:"19.4w(O,\'2J\')",8u:"19.4w(O,\'4v\')",8s:"19.5m(O.1b.1B,O)",8r:"19.5m(O.1B)",6C:"19.12(O,\'8q\')?O.8p||O.8o.T:19.2H(O.3p)"},J(c,d){d=4A("S||J(O){K "+d+"}");E.1i[c]=J(b){L a=E.2a(6,d);7(b&&1v b=="25")a=E.3d(b,a);K 6.2E(E.57(a))}});E.V({6B:"3t",8n:"6s",3n:"6o",8l:"5a",8k:"6P"},J(c,b){E.1i[c]=J(){L a=1a;K 6.V(J(){P(L i=0,M=a.M;i<M;i++)E(a[i])[b](6)})}});E.V({8j:J(a){E.1K(6,a,"");7(6.15==1)6.55(a)},8i:J(a){E.1w.1c(6,a)},8h:J(a){E.1w.1Y(6,a)},8g:J(a){E.1w[E.1w.3E(6,a)?"1Y":"1c"](6,a)},1Y:J(a){7(!a||E.1F(a,[6]).r.M){E("*",6).1c(6).V(J(){E.16.1Y(6);E.3H(6)});7(6.1b)6.1b.2X(6)}},4B:J(){E(">*",6).1Y();2e(6.1B)6.2X(6.1B)}},J(a,b){E.1i[a]=J(){K 6.V(b,1a)}});E.V(["8e","62"],J(i,c){L b=c.2w();E.1i[b]=J(a){K 6[0]==1e?E.14.2B&&T.1k["5h"+c]||E.14.26&&1e["8d"+c]||T.6I=="6H"&&T.1I["5h"+c]||T.1k["5h"+c]:6[0]==T?1Z.2b(1Z.2b(T.1k["5g"+c],T.1I["5g"+c]),1Z.2b(T.1k["5f"+c],T.1I["5f"+c])):a==10?(6.M?E.1m(6[0],b):W):6.1m(b,a.1n==4d?a:a+"2P")}});L C=E.14.26&&4t(E.14.5n)<8c?"(?:[\\\\w*4s-]|\\\\\\\\.)":"(?:[\\\\w\\8b-\\8a*4s-]|\\\\\\\\.)",6w=1D 4r("^>\\\\s*("+C+"+)"),6v=1D 4r("^("+C+"+)(#)("+C+"+)"),6u=1D 4r("^([#.]?)("+C+"*)");E.1s({5d:{"":"m[2]==\'*\'||19.12(a,m[2])","#":"a.4z(\'2s\')==m[2]",":":{88:"i<m[3]-0",86:"i>m[3]-0",31:"m[3]-0==i",6N:"m[3]-0==i",3j:"i==0",3M:"i==r.M-1",6r:"i%2==0",6p:"i%2","3j-4m":"a.1b.3V(\'*\')[0]==a","3M-4m":"19.31(a.1b.5D,1,\'4v\')==a","84-4m":"!19.31(a.1b.5D,2,\'4v\')",6E:"a.1B",4B:"!a.1B",83:"(a.6A||a.80||19(a).1t()||\'\').1g(m[3])>=0",4b:\'"23"!=a.U&&19.1m(a,"18")!="2D"&&19.1m(a,"4X")!="23"\',23:\'"23"==a.U||19.1m(a,"18")=="2D"||19.1m(a,"4X")=="23"\',7Y:"!a.2W",2W:"a.2W",3o:"a.3o",2p:"a.2p||19.1K(a,\'2p\')",1t:"\'1t\'==a.U",5w:"\'5w\'==a.U",5y:"\'5y\'==a.U",5b:"\'5b\'==a.U",3J:"\'3J\'==a.U",59:"\'59\'==a.U",6n:"\'6n\'==a.U",6m:"\'6m\'==a.U",2G:\'"2G"==a.U||19.12(a,"2G")\',48:"/48|2y|6l|2G/i.17(a.12)",3E:"19.2r(m[3],a).M",7X:"/h\\\\d/i.17(a.12)",7W:"19.3x(19.3I,J(1i){K a==1i.O;}).M"}},6j:[/^(\\[) *@?([\\w-]+) *([!*$^~=]*) *(\'?"?)(.*?)\\4 *\\]/,/^(:)([\\w-]+)\\("?\'?(.*?(\\(.*?\\))?[^(]*?)"?\'?\\)/,1D 4r("^([:.#]*)("+C+"+)")],3d:J(a,c,b){L d,2o=[];2e(a&&a!=d){d=a;L f=E.1F(a,c,b);a=f.t.1p(/^\\s*,\\s*/,"");2o=b?c=f.r:E.34(2o,f.r)}K 2o},2r:J(t,p){7(1v t!="25")K[t];7(p&&p.15!=1&&p.15!=9)K[];p=p||T;L d=[p],2j=[],3M,12;2e(t&&3M!=t){L r=[];3M=t;t=E.3f(t);L o=S;L g=6w;L m=g.39(t);7(m){12=m[1].2F();P(L i=0;d[i];i++)P(L c=d[i].1B;c;c=c.2J)7(c.15==1&&(12=="*"||c.12.2F()==12))r.1h(c);d=r;t=t.1p(g,"");7(t.1g(" ")==0)6z;o=R}N{g=/^([>+~])\\s*(\\w*)/i;7((m=g.39(t))!=W){r=[];L l={};12=m[2].2F();m=m[1];P(L j=0,3g=d.M;j<3g;j++){L n=m=="~"||m=="+"?d[j].2J:d[j].1B;P(;n;n=n.2J)7(n.15==1){L h=E.Q(n);7(m=="~"&&l[h])1T;7(!12||n.12.2F()==12){7(m=="~")l[h]=R;r.1h(n)}7(m=="+")1T}}d=r;t=E.3f(t.1p(g,""));o=R}}7(t&&!o){7(!t.1g(",")){7(p==d[0])d.4k();2j=E.34(2j,d);r=d=[p];t=" "+t.6i(1,t.M)}N{L k=6v;L m=k.39(t);7(m){m=[0,m[2],m[3],m[1]]}N{k=6u;m=k.39(t)}m[2]=m[2].1p(/\\\\/g,"");L f=d[d.M-1];7(m[1]=="#"&&f&&f.5N&&!E.3W(f)){L q=f.5N(m[2]);7((E.14.1d||E.14.2B)&&q&&1v q.2s=="25"&&q.2s!=m[2])q=E(\'[@2s="\'+m[2]+\'"]\',f)[0];d=r=q&&(!m[3]||E.12(q,m[3]))?[q]:[]}N{P(L i=0;d[i];i++){L a=m[1]=="#"&&m[3]?m[3]:m[1]!=""||m[0]==""?"*":m[2];7(a=="*"&&d[i].12.2w()=="4D")a="3v";r=E.34(r,d[i].3V(a))}7(m[1]==".")r=E.58(r,m[2]);7(m[1]=="#"){L e=[];P(L i=0;r[i];i++)7(r[i].4z("2s")==m[2]){e=[r[i]];1T}r=e}d=r}t=t.1p(k,"")}}7(t){L b=E.1F(t,r);d=r=b.r;t=E.3f(b.t)}}7(t)d=[];7(d&&p==d[0])d.4k();2j=E.34(2j,d);K 2j},58:J(r,m,a){m=" "+m+" ";L c=[];P(L i=0;r[i];i++){L b=(" "+r[i].1w+" ").1g(m)>=0;7(!a&&b||a&&!b)c.1h(r[i])}K c},1F:J(t,r,h){L d;2e(t&&t!=d){d=t;L p=E.6j,m;P(L i=0;p[i];i++){m=p[i].39(t);7(m){t=t.7V(m[0].M);m[2]=m[2].1p(/\\\\/g,"");1T}}7(!m)1T;7(m[1]==":"&&m[2]=="4I")r=G.17(m[3])?E.1F(m[3],r,R).r:E(r).4I(m[3]);N 7(m[1]==".")r=E.58(r,m[2],h);N 7(m[1]=="["){L g=[],U=m[3];P(L i=0,3g=r.M;i<3g;i++){L a=r[i],z=a[E.3S[m[2]]||m[2]];7(z==W||/6T|3R|2p/.17(m[2]))z=E.1K(a,m[2])||\'\';7((U==""&&!!z||U=="="&&z==m[5]||U=="!="&&z!=m[5]||U=="^="&&z&&!z.1g(m[5])||U=="$="&&z.6i(z.M-m[5].M)==m[5]||(U=="*="||U=="~=")&&z.1g(m[5])>=0)^h)g.1h(a)}r=g}N 7(m[1]==":"&&m[2]=="31-4m"){L e={},g=[],17=/(-?)(\\d*)n((?:\\+|-)?\\d*)/.39(m[3]=="6r"&&"2n"||m[3]=="6p"&&"2n+1"||!/\\D/.17(m[3])&&"7U+"+m[3]||m[3]),3j=(17[1]+(17[2]||1))-0,d=17[3]-0;P(L i=0,3g=r.M;i<3g;i++){L j=r[i],1b=j.1b,2s=E.Q(1b);7(!e[2s]){L c=1;P(L n=1b.1B;n;n=n.2J)7(n.15==1)n.4p=c++;e[2s]=R}L b=S;7(3j==0){7(j.4p==d)b=R}N 7((j.4p-d)%3j==0&&(j.4p-d)/3j>=0)b=R;7(b^h)g.1h(j)}r=g}N{L f=E.5d[m[1]];7(1v f!="25")f=E.5d[m[1]][m[2]];f=4A("S||J(a,i){K "+f+"}");r=E.3x(r,f,h)}}K{r:r,t:t}},4w:J(b,c){L d=[];L a=b[c];2e(a&&a!=T){7(a.15==1)d.1h(a);a=a[c]}K d},31:J(a,e,c,b){e=e||1;L d=0;P(;a;a=a[c])7(a.15==1&&++d==e)1T;K a},5m:J(n,a){L r=[];P(;n;n=n.2J){7(n.15==1&&(!a||n!=a))r.1h(n)}K r}});E.16={1c:J(f,i,g,e){7(f.15==3||f.15==8)K;7(E.14.1d&&f.54!=10)f=1e;7(!g.2A)g.2A=6.2A++;7(e!=10){L h=g;g=J(){K h.1j(6,1a)};g.Q=e;g.2A=h.2A}L j=E.Q(f,"2N")||E.Q(f,"2N",{}),1x=E.Q(f,"1x")||E.Q(f,"1x",J(){L a;7(1v E=="10"||E.16.52)K a;a=E.16.1x.1j(1a.3G.O,1a);K a});1x.O=f;E.V(i.2d(/\\s+/),J(c,b){L a=b.2d(".");b=a[0];g.U=a[1];L d=j[b];7(!d){d=j[b]={};7(!E.16.2l[b]||E.16.2l[b].4i.1O(f)===S){7(f.3F)f.3F(b,1x,S);N 7(f.6h)f.6h("4h"+b,1x)}}d[g.2A]=g;E.16.2g[b]=R});f=W},2A:1,2g:{},1Y:J(e,h,f){7(e.15==3||e.15==8)K;L i=E.Q(e,"2N"),2f,5E;7(i){7(h==10)P(L g 1r i)6.1Y(e,g);N{7(h.U){f=h.2k;h=h.U}E.V(h.2d(/\\s+/),J(b,a){L c=a.2d(".");a=c[0];7(i[a]){7(f)2T i[a][f.2A];N P(f 1r i[a])7(!c[1]||i[a][f].U==c[1])2T i[a][f];P(2f 1r i[a])1T;7(!2f){7(!E.16.2l[a]||E.16.2l[a].4g.1O(e)===S){7(e.6f)e.6f(a,E.Q(e,"1x"),S);N 7(e.6d)e.6d("4h"+a,E.Q(e,"1x"))}2f=W;2T i[a]}}})}P(2f 1r i)1T;7(!2f){L d=E.Q(e,"1x");7(d)d.O=W;E.3H(e,"2N");E.3H(e,"1x")}}},1U:J(f,b,c,d,g){b=E.2H(b||[]);7(!c){7(6.2g[f])E("*").1c([1e,T]).1U(f,b)}N{7(c.15==3||c.15==8)K 10;L a,2f,1i=E.1q(c[f]||W),16=!b[0]||!b[0].32;7(16)b.4U(6.51({U:f,2K:c}));b[0].U=f;7(E.1q(E.Q(c,"1x")))a=E.Q(c,"1x").1j(c,b);7(!1i&&c["4h"+f]&&c["4h"+f].1j(c,b)===S)a=S;7(16)b.4k();7(g&&E.1q(g)){2f=g.1j(c,a==W?b:b.6Q(a));7(2f!==10)a=2f}7(1i&&d!==S&&a!==S&&!(E.12(c,\'a\')&&f=="50")){6.52=R;1R{c[f]()}1W(e){}}6.52=S}K a},1x:J(c){L a;c=E.16.51(c||1e.16||{});L b=c.U.2d(".");c.U=b[0];L f=E.Q(6,"2N")&&E.Q(6,"2N")[c.U],3B=1N.2m.2V.1O(1a,1);3B.4U(c);P(L j 1r f){L d=f[j];3B[0].2k=d;3B[0].Q=d.Q;7(!b[1]||d.U==b[1]){L e=d.1j(6,3B);7(a!==S)a=e;7(e===S){c.32();c.41()}}}7(E.14.1d)c.2K=c.32=c.41=c.2k=c.Q=W;K a},51:J(c){L a=c;c=E.1s({},a);c.32=J(){7(a.32)a.32();a.7T=S};c.41=J(){7(a.41)a.41();a.7S=R};7(!c.2K)c.2K=c.7R||T;7(c.2K.15==3)c.2K=a.2K.1b;7(!c.4W&&c.4V)c.4W=c.4V==c.2K?c.7Q:c.4V;7(c.6b==W&&c.6a!=W){L b=T.1I,1k=T.1k;c.6b=c.6a+(b&&b.2i||1k&&1k.2i||0)-(b.68||0);c.7O=c.7N+(b&&b.2x||1k&&1k.2x||0)-(b.67||0)}7(!c.3r&&((c.4f||c.4f===0)?c.4f:c.66))c.3r=c.4f||c.66;7(!c.65&&c.64)c.65=c.64;7(!c.3r&&c.2G)c.3r=(c.2G&1?1:(c.2G&2?3:(c.2G&4?2:0)));K c},2l:{21:{4i:J(){5A();K},4g:J(){K}},47:{4i:J(){7(E.14.1d)K S;E(6).2z("4Q",E.16.2l.47.2k);K R},4g:J(){7(E.14.1d)K S;E(6).42("4Q",E.16.2l.47.2k);K R},2k:J(a){7(I(a,6))K R;1a[0].U="47";K E.16.1x.1j(6,1a)}},46:{4i:J(){7(E.14.1d)K S;E(6).2z("4P",E.16.2l.46.2k);K R},4g:J(){7(E.14.1d)K S;E(6).42("4P",E.16.2l.46.2k);K R},2k:J(a){7(I(a,6))K R;1a[0].U="46";K E.16.1x.1j(6,1a)}}}};E.1i.1s({2z:J(c,a,b){K c=="4O"?6.30(c,a,b):6.V(J(){E.16.1c(6,c,b||a,b&&a)})},30:J(d,b,c){K 6.V(J(){E.16.1c(6,d,J(a){E(6).42(a);K(c||b).1j(6,1a)},c&&b)})},42:J(a,b){K 6.V(J(){E.16.1Y(6,a,b)})},1U:J(c,a,b){K 6.V(J(){E.16.1U(c,a,6,R,b)})},63:J(c,a,b){7(6[0])K E.16.1U(c,a,6[0],S,b);K 10},2h:J(){L b=1a;K 6.50(J(a){6.4N=0==6.4N?1:0;a.32();K b[6.4N].1j(6,1a)||S})},7F:J(a,b){K 6.2z(\'47\',a).2z(\'46\',b)},21:J(a){5A();7(E.2Q)a.1O(T,E);N E.3w.1h(J(){K a.1O(6,E)});K 6}});E.1s({2Q:S,3w:[],21:J(){7(!E.2Q){E.2Q=R;7(E.3w){E.V(E.3w,J(){6.1j(T)});E.3w=W}E(T).63("21")}}});L x=S;J 5A(){7(x)K;x=R;7(T.3F&&!E.14.2B)T.3F("61",E.21,S);7(E.14.1d&&1e==3b)(J(){7(E.2Q)K;1R{T.1I.7D("2c")}1W(3e){3z(1a.3G,0);K}E.21()})();7(E.14.2B)T.3F("61",J(){7(E.2Q)K;P(L i=0;i<T.4M.M;i++)7(T.4M[i].2W){3z(1a.3G,0);K}E.21()},S);7(E.14.26){L a;(J(){7(E.2Q)K;7(T.3c!="60"&&T.3c!="1z"){3z(1a.3G,0);K}7(a===10)a=E("Y, 5O[7B=7A]").M;7(T.4M.M!=a){3z(1a.3G,0);K}E.21()})()}E.16.1c(1e,"43",E.21)}E.V(("7z,7y,43,7x,5g,4O,50,7w,"+"7v,7u,7C,4Q,4P,7t,2y,"+"59,7s,7r,7G,3e").2d(","),J(i,b){E.1i[b]=J(a){K a?6.2z(b,a):6.1U(b)}});L I=J(a,c){L b=a.4W;2e(b&&b!=c)1R{b=b.1b}1W(3e){b=c}K b==c};E(1e).2z("4O",J(){E("*").1c(T).42()});E.1i.1s({43:J(g,d,c){7(E.1q(g))K 6.2z("43",g);L e=g.1g(" ");7(e>=0){L i=g.2V(e,g.M);g=g.2V(0,e)}c=c||J(){};L f="4J";7(d)7(E.1q(d)){c=d;d=W}N{d=E.3v(d);f="5Z"}L h=6;E.3Q({1f:g,U:f,1G:"3q",Q:d,1z:J(a,b){7(b=="1X"||b=="5Y")h.3q(i?E("<1u/>").3t(a.4e.1p(/<1o(.|\\s)*?\\/1o>/g,"")).2r(i):a.4e);h.V(c,[a.4e,b,a])}});K 6},7q:J(){K E.3v(6.5X())},5X:J(){K 6.2a(J(){K E.12(6,"3i")?E.2H(6.7p):6}).1F(J(){K 6.37&&!6.2W&&(6.3o||/2y|6l/i.17(6.12)||/1t|23|3J/i.17(6.U))}).2a(J(i,c){L b=E(6).5P();K b==W?W:b.1n==1N?E.2a(b,J(a,i){K{37:c.37,1C:a}}):{37:c.37,1C:b}}).22()}});E.V("5W,5V,5U,69,5T,5S".2d(","),J(i,o){E.1i[o]=J(f){K 6.2z(o,f)}});L B=(1D 3O).3N();E.1s({22:J(d,b,a,c){7(E.1q(b)){a=b;b=W}K E.3Q({U:"4J",1f:d,Q:b,1X:a,1G:c})},7o:J(b,a){K E.22(b,W,a,"1o")},7n:J(c,b,a){K E.22(c,b,a,"2O")},7m:J(d,b,a,c){7(E.1q(b)){a=b;b={}}K E.3Q({U:"5Z",1f:d,Q:b,1X:a,1G:c})},7Z:J(a){E.1s(E.4H,a)},4H:{2g:R,U:"4J",2U:0,5R:"49/x-7j-3i-7i",6x:R,3l:R,Q:W,6t:W,3J:W,4n:{3L:"49/3L, 1t/3L",3q:"1t/3q",1o:"1t/4l, 49/4l",2O:"49/2O, 1t/4l",1t:"1t/7e",4o:"*/*"}},4q:{},3Q:J(s){L f,2Y=/=\\?(&|$)/g,1A,Q;s=E.1s(R,s,E.1s(R,{},E.4H,s));7(s.Q&&s.6x&&1v s.Q!="25")s.Q=E.3v(s.Q);7(s.1G=="4u"){7(s.U.2w()=="22"){7(!s.1f.1E(2Y))s.1f+=(s.1f.1E(/\\?/)?"&":"?")+(s.4u||"7d")+"=?"}N 7(!s.Q||!s.Q.1E(2Y))s.Q=(s.Q?s.Q+"&":"")+(s.4u||"7d")+"=?";s.1G="2O"}7(s.1G=="2O"&&(s.Q&&s.Q.1E(2Y)||s.1f.1E(2Y))){f="4u"+B++;7(s.Q)s.Q=(s.Q+"").1p(2Y,"="+f+"$1");s.1f=s.1f.1p(2Y,"="+f+"$1");s.1G="1o";1e[f]=J(a){Q=a;1X();1z();1e[f]=10;1R{2T 1e[f]}1W(e){}7(h)h.2X(g)}}7(s.1G=="1o"&&s.1Q==W)s.1Q=S;7(s.1Q===S&&s.U.2w()=="22"){L i=(1D 3O()).3N();L j=s.1f.1p(/(\\?|&)4s=.*?(&|$)/,"$a2="+i+"$2");s.1f=j+((j==s.1f)?(s.1f.1E(/\\?/)?"&":"?")+"4s="+i:"")}7(s.Q&&s.U.2w()=="22"){s.1f+=(s.1f.1E(/\\?/)?"&":"?")+s.Q;s.Q=W}7(s.2g&&!E.5M++)E.16.1U("5W");7((!s.1f.1g("9Z")||!s.1f.1g("//"))&&(s.1G=="1o"||s.1G=="2O")&&s.U.2w()=="22"){L h=T.3V("6k")[0];L g=T.2R("1o");g.3R=s.1f;7(s.7c)g.9X=s.7c;7(!f){L l=S;g.9V=g.9U=J(){7(!l&&(!6.3c||6.3c=="60"||6.3c=="1z")){l=R;1X();1z();h.2X(g)}}}h.3k(g);K 10}L m=S;L k=1e.7a?1D 7a("9S.9Q"):1D 79();k.9P(s.U,s.1f,s.3l,s.6t,s.3J);1R{7(s.Q)k.4G("9N-9M",s.5R);7(s.5I)k.4G("9L-5H-9J",E.4q[s.1f]||"9H, 9G 9E 9B 5G:5G:5G 9z");k.4G("X-9x-9u","79");k.4G("9t",s.1G&&s.4n[s.1G]?s.4n[s.1G]+", */*":s.4n.4o)}1W(e){}7(s.75)s.75(k);7(s.2g)E.16.1U("5S",[k,s]);L c=J(a){7(!m&&k&&(k.3c==4||a=="2U")){m=R;7(d){74(d);d=W}1A=a=="2U"&&"2U"||!E.73(k)&&"3e"||s.5I&&E.72(k,s.1f)&&"5Y"||"1X";7(1A=="1X"){1R{Q=E.71(k,s.1G)}1W(e){1A="5C"}}7(1A=="1X"){L b;1R{b=k.5B("70-5H")}1W(e){}7(s.5I&&b)E.4q[s.1f]=b;7(!f)1X()}N E.5t(s,k,1A);1z();7(s.3l)k=W}};7(s.3l){L d=54(c,13);7(s.2U>0)3z(J(){7(k){k.9m();7(!m)c("2U")}},s.2U)}1R{k.9l(s.Q)}1W(e){E.5t(s,k,W,e)}7(!s.3l)c();J 1X(){7(s.1X)s.1X(Q,1A);7(s.2g)E.16.1U("5T",[k,s])}J 1z(){7(s.1z)s.1z(k,1A);7(s.2g)E.16.1U("5U",[k,s]);7(s.2g&&!--E.5M)E.16.1U("5V")}K k},5t:J(s,a,b,e){7(s.3e)s.3e(a,b,e);7(s.2g)E.16.1U("69",[a,s,e])},5M:0,73:J(r){1R{K!r.1A&&9k.9j=="5b:"||(r.1A>=6Y&&r.1A<9h)||r.1A==6X||r.1A==9e||E.14.26&&r.1A==10}1W(e){}K S},72:J(a,c){1R{L b=a.5B("70-5H");K a.1A==6X||b==E.4q[c]||E.14.26&&a.1A==10}1W(e){}K S},71:J(r,b){L c=r.5B("9d-U");L d=b=="3L"||!b&&c&&c.1g("3L")>=0;L a=d?r.9c:r.4e;7(d&&a.1I.28=="5C")6Z"5C";7(b=="1o")E.5l(a);7(b=="2O")a=4A("("+a+")");K a},3v:J(a){L s=[];7(a.1n==1N||a.5j)E.V(a,J(){s.1h(3s(6.37)+"="+3s(6.1C))});N P(L j 1r a)7(a[j]&&a[j].1n==1N)E.V(a[j],J(){s.1h(3s(j)+"="+3s(6))});N s.1h(3s(j)+"="+3s(a[j]));K s.6g("&").1p(/%20/g,"+")}});E.1i.1s({1J:J(c,b){K c?6.27({1P:"1J",29:"1J",1y:"1J"},c,b):6.1F(":23").V(J(){6.Y.18=6.5x||"";7(E.1m(6,"18")=="2D"){L a=E("<"+6.28+" />").6B("1k");6.Y.18=a.1m("18");7(6.Y.18=="2D")6.Y.18="3u";a.1Y()}}).3h()},1H:J(b,a){K b?6.27({1P:"1H",29:"1H",1y:"1H"},b,a):6.1F(":4b").V(J(){6.5x=6.5x||E.1m(6,"18");6.Y.18="2D"}).3h()},6U:E.1i.2h,2h:J(a,b){K E.1q(a)&&E.1q(b)?6.6U(a,b):a?6.27({1P:"2h",29:"2h",1y:"2h"},a,b):6.V(J(){E(6)[E(6).3K(":23")?"1J":"1H"]()})},98:J(b,a){K 6.27({1P:"1J"},b,a)},97:J(b,a){K 6.27({1P:"1H"},b,a)},96:J(b,a){K 6.27({1P:"2h"},b,a)},95:J(b,a){K 6.27({1y:"1J"},b,a)},94:J(b,a){K 6.27({1y:"1H"},b,a)},9f:J(c,a,b){K 6.27({1y:a},c,b)},27:J(l,k,j,h){L i=E.6V(k,j,h);K 6[i.2S===S?"V":"2S"](J(){7(6.15!=1)K S;L g=E.1s({},i);L f=E(6).3K(":23"),4y=6;P(L p 1r l){7(l[p]=="1H"&&f||l[p]=="1J"&&!f)K E.1q(g.1z)&&g.1z.1j(6);7(p=="1P"||p=="29"){g.18=E.1m(6,"18");g.36=6.Y.36}}7(g.36!=W)6.Y.36="23";g.40=E.1s({},l);E.V(l,J(c,a){L e=1D E.2v(4y,g,c);7(/2h|1J|1H/.17(a))e[a=="2h"?f?"1J":"1H":a](l);N{L b=a.3D().1E(/^([+-]=)?([\\d+-.]+)(.*)$/),24=e.2o(R)||0;7(b){L d=2M(b[2]),2C=b[3]||"2P";7(2C!="2P"){4y.Y[c]=(d||1)+2C;24=((d||1)/e.2o(R))*24;4y.Y[c]=24+2C}7(b[1])d=((b[1]=="-="?-1:1)*d)+24;e.3Z(24,d,2C)}N e.3Z(24,a,"")}});K R})},2S:J(a,b){7(E.1q(a)||(a&&a.1n==1N)){b=a;a="2v"}7(!a||(1v a=="25"&&!b))K A(6[0],a);K 6.V(J(){7(b.1n==1N)A(6,a,b);N{A(6,a).1h(b);7(A(6,a).M==1)b.1j(6)}})},8Z:J(b,c){L a=E.3I;7(b)6.2S([]);6.V(J(){P(L i=a.M-1;i>=0;i--)7(a[i].O==6){7(c)a[i](R);a.6R(i,1)}});7(!c)6.5z();K 6}});L A=J(b,c,a){7(!b)K 10;c=c||"2v";L q=E.Q(b,c+"2S");7(!q||a)q=E.Q(b,c+"2S",a?E.2H(a):[]);K q};E.1i.5z=J(a){a=a||"2v";K 6.V(J(){L q=A(6,a);q.4k();7(q.M)q[0].1j(6)})};E.1s({6V:J(b,a,c){L d=b&&b.1n==8Y?b:{1z:c||!c&&a||E.1q(b)&&b,2t:b,3Y:c&&a||a&&a.1n!=8W&&a};d.2t=(d.2t&&d.2t.1n==53?d.2t:{9w:8U,8T:6Y}[d.2t])||8S;d.5o=d.1z;d.1z=J(){7(d.2S!==S)E(6).5z();7(E.1q(d.5o))d.5o.1j(6)};K d},3Y:{6O:J(p,n,b,a){K b+a*p},5F:J(p,n,b,a){K((-1Z.9C(p*1Z.9D)/2)+0.5)*a+b}},3I:[],3T:W,2v:J(b,c,a){6.11=c;6.O=b;6.1l=a;7(!c.3U)c.3U={}}});E.2v.2m={4C:J(){7(6.11.33)6.11.33.1j(6.O,[6.2I,6]);(E.2v.33[6.1l]||E.2v.33.4o)(6);7(6.1l=="1P"||6.1l=="29")6.O.Y.18="3u"},2o:J(a){7(6.O[6.1l]!=W&&6.O.Y[6.1l]==W)K 6.O[6.1l];L r=2M(E.1m(6.O,6.1l,a));K r&&r>-8N?r:2M(E.2q(6.O,6.1l))||0},3Z:J(c,b,d){6.5s=(1D 3O()).3N();6.24=c;6.3h=b;6.2C=d||6.2C||"2P";6.2I=6.24;6.4E=6.4F=0;6.4C();L e=6;J t(a){K e.33(a)}t.O=6.O;E.3I.1h(t);7(E.3T==W){E.3T=54(J(){L a=E.3I;P(L i=0;i<a.M;i++)7(!a[i]())a.6R(i--,1);7(!a.M){74(E.3T);E.3T=W}},13)}},1J:J(){6.11.3U[6.1l]=E.1K(6.O.Y,6.1l);6.11.1J=R;6.3Z(0,6.2o());7(6.1l=="29"||6.1l=="1P")6.O.Y[6.1l]="8L";E(6.O).1J()},1H:J(){6.11.3U[6.1l]=E.1K(6.O.Y,6.1l);6.11.1H=R;6.3Z(6.2o(),0)},33:J(a){L t=(1D 3O()).3N();7(a||t>6.11.2t+6.5s){6.2I=6.3h;6.4E=6.4F=1;6.4C();6.11.40[6.1l]=R;L b=R;P(L i 1r 6.11.40)7(6.11.40[i]!==R)b=S;7(b){7(6.11.18!=W){6.O.Y.36=6.11.36;6.O.Y.18=6.11.18;7(E.1m(6.O,"18")=="2D")6.O.Y.18="3u"}7(6.11.1H)6.O.Y.18="2D";7(6.11.1H||6.11.1J)P(L p 1r 6.11.40)E.1K(6.O.Y,p,6.11.3U[p])}7(b&&E.1q(6.11.1z))6.11.1z.1j(6.O);K S}N{L n=t-6.5s;6.4F=n/6.11.2t;6.4E=E.3Y[6.11.3Y||(E.3Y.5F?"5F":"6O")](6.4F,n,0,1,6.11.2t);6.2I=6.24+((6.3h-6.24)*6.4E);6.4C()}K R}};E.2v.33={2i:J(a){a.O.2i=a.2I},2x:J(a){a.O.2x=a.2I},1y:J(a){E.1K(a.O.Y,"1y",a.2I)},4o:J(a){a.O.Y[a.1l]=a.2I+a.2C}};E.1i.5f=J(){L b=0,3b=0,O=6[0],5q;7(O)8K(E.14){L d=O.1b,45=O,1M=O.1M,1L=O.2u,5p=26&&4t(5n)<8H,2Z=E.1m(O,"3C")=="2Z";7(O.7b){L c=O.7b();1c(c.2c+1Z.2b(1L.1I.2i,1L.1k.2i),c.3b+1Z.2b(1L.1I.2x,1L.1k.2x));1c(-1L.1I.68,-1L.1I.67)}N{1c(O.5k,O.5K);2e(1M){1c(1M.5k,1M.5K);7(3X&&!/^t(8F|d|h)$/i.17(1M.28)||26&&!5p)3a(1M);7(!2Z&&E.1m(1M,"3C")=="2Z")2Z=R;45=/^1k$/i.17(1M.28)?45:1M;1M=1M.1M}2e(d&&d.28&&!/^1k|3q$/i.17(d.28)){7(!/^a0|1V.*$/i.17(E.1m(d,"18")))1c(-d.2i,-d.2x);7(3X&&E.1m(d,"36")!="4b")3a(d);d=d.1b}7((5p&&(2Z||E.1m(45,"3C")=="4Z"))||(3X&&E.1m(45,"3C")!="4Z"))1c(-1L.1k.5k,-1L.1k.5K);7(2Z)1c(1Z.2b(1L.1I.2i,1L.1k.2i),1Z.2b(1L.1I.2x,1L.1k.2x))}5q={3b:3b,2c:b}}J 3a(a){1c(E.2q(a,"a1",R),E.2q(a,"8D",R))}J 1c(l,t){b+=4t(l)||0;3b+=4t(t)||0}K 5q}})();',62,624,'||||||this|if||||||||||||||||||||||||||||||||||||||function|return|var|length|else|elem|for|data|true|false|document|type|each|null||style||undefined|options|nodeName||browser|nodeType|event|test|display|jQuery|arguments|parentNode|add|msie|window|url|indexOf|push|fn|apply|body|prop|css|constructor|script|replace|isFunction|in|extend|text|div|typeof|className|handle|opacity|complete|status|firstChild|value|new|match|filter|dataType|hide|documentElement|show|attr|doc|offsetParent|Array|call|height|cache|try|tbody|break|trigger|table|catch|success|remove|Math||ready|get|hidden|start|string|safari|animate|tagName|width|map|max|left|split|while|ret|global|toggle|scrollLeft|done|handler|special|prototype||cur|selected|curCSS|find|id|duration|ownerDocument|fx|toLowerCase|scrollTop|select|bind|guid|opera|unit|none|pushStack|toUpperCase|button|makeArray|now|nextSibling|target|stack|parseFloat|events|json|px|isReady|createElement|queue|delete|timeout|slice|disabled|removeChild|jsre|fixed|one|nth|preventDefault|step|merge|inArray|overflow|name|innerHTML|exec|border|top|readyState|multiFilter|error|trim|rl|end|form|first|appendChild|async|elems|insertBefore|checked|childNodes|html|which|encodeURIComponent|append|block|param|readyList|grep|color|setTimeout|runtimeStyle|args|position|toString|has|addEventListener|callee|removeData|timers|password|is|xml|last|getTime|Date|domManip|ajax|src|props|timerId|orig|getElementsByTagName|isXMLDoc|mozilla|easing|custom|curAnim|stopPropagation|unbind|load|selectedIndex|offsetChild|mouseleave|mouseenter|input|application|defaultView|visible|float|String|responseText|charCode|teardown|on|setup|currentStyle|shift|javascript|child|accepts|_default|nodeIndex|lastModified|RegExp|_|parseInt|jsonp|previousSibling|dir|tr|self|getAttribute|eval|empty|update|object|pos|state|setRequestHeader|ajaxSettings|not|GET|getPropertyValue|getComputedStyle|styleSheets|lastToggle|unload|mouseout|mouseover|andSelf|getWH|container2|unshift|fromElement|relatedTarget|visibility|init|absolute|click|fix|triggered|Number|setInterval|removeAttribute|prevObject|unique|classFilter|submit|after|file|clean|expr|windowData|offset|scroll|client|deep|jquery|offsetLeft|globalEval|sibling|version|old|safari2|results|wrapAll|startTime|handleError|container|createTextNode|radio|oldblock|checkbox|dequeue|bindReady|getResponseHeader|parsererror|lastChild|index|swing|00|Modified|ifModified|clone|offsetTop|values|active|getElementById|link|val|col|contentType|ajaxSend|ajaxSuccess|ajaxComplete|ajaxStop|ajaxStart|serializeArray|notmodified|POST|loaded|DOMContentLoaded|Width|triggerHandler|ctrlKey|metaKey|keyCode|clientTop|clientLeft|ajaxError|clientX|pageX|cloneNode|detachEvent|swap|removeEventListener|join|attachEvent|substr|parse|head|textarea|reset|image|before|odd|zoom|even|prepend|username|quickClass|quickID|quickChild|processData|uuid|continue|textContent|appendTo|contents|evalScript|parent|defaultValue|setArray|CSS1Compat|compatMode|cssFloat|styleFloat|webkit|nodeValue|eq|linear|replaceWith|concat|splice|100|href|_toggle|speed|alpha|304|200|throw|Last|httpData|httpNotModified|httpSuccess|clearInterval|beforeSend|colgroup|fieldset|multiple|XMLHttpRequest|ActiveXObject|getBoundingClientRect|scriptCharset|callback|plain|img|hasClass|br|urlencoded|www|abbr|pixelLeft|post|getJSON|getScript|elements|serialize|keypress|keydown|change|mouseup|mousedown|dblclick|resize|focus|blur|stylesheet|rel|mousemove|doScroll|round|hover|keyup|padding|offsetHeight|offsetWidth|Bottom|Top|Right|clientY|pageY|Left|toElement|srcElement|cancelBubble|returnValue|0n|substring|animated|header|enabled|ajaxSetup|innerText|noConflict|size|contains|only|line|gt|weight|lt|font|uFFFF|u0128|417|inner|Height|Boolean|toggleClass|removeClass|addClass|removeAttr|replaceAll|insertAfter|wrap|prependTo|contentWindow|contentDocument|iframe|children|siblings|wrapInner|prevAll|nextAll|prev|next|parents|maxLength|maxlength|readOnly|readonly|borderTopWidth|class|able|htmlFor|522|reverse|boxModel|with|1px|compatible|10000|ie|ra|it|rv|400|fast|600|userAgent|Function|navigator|Object|stop|option|array|ig|NaN|fadeOut|fadeIn|slideToggle|slideUp|slideDown|setAttribute|changed|be|responseXML|content|1223|fadeTo|can|300|property|protocol|location|send|abort|getAttributeNode|specified|method|action|cssText|attributes|Accept|With|th|slow|Requested|td|GMT|cap|1970|cos|PI|Jan|colg|01|Thu|tfoot|Since|thead|If|Type|Content|leg|open|XMLHTTP|opt|Microsoft|embed|onreadystatechange|onload|area|charset|hr|http|inline|borderLeftWidth|1_|meta'.split('|'),0,{}));
Deleted: branches/testbaudson_dev/http/extensions/jquery.mousewheel.min.js
--- trunk/mapbender/http/extensions/jquery.mousewheel.min.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/extensions/jquery.mousewheel.min.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,16 +0,0 @@
-/* Copyright (c) 2006 Brandon Aaron (brandon.aaron at gmail.com || http://brandonaaron.net)
- * Dual licensed under the MIT (http://www.opensource.org/licenses/mit-license.php)
- * and GPL (http://www.opensource.org/licenses/gpl-license.php) licenses.
- * Thanks to: http://adomas.org/javascript-mouse-wheel/ for some pointers.
- * Thanks to: Mathias Bank(http://www.mathias-bank.de) for a scope bug fix.
- * $LastChangedDate: 2007-12-14 23:57:10 -0600 (Fri, 14 Dec 2007) $
- * $Rev: 4163 $
- * Version: 3.0
- * Requires: $ 1.2.2+
-(function($){$.event.special.mousewheel={setup:function(){var handler=$.event.special.mousewheel.handler;if($.browser.mozilla)$(this).bind('mousemove.mousewheel',function(event){$.data(this,'mwcursorposdata',{pageX:event.pageX,pageY:event.pageY,clientX:event.clientX,clientY:event.clientY});});if(this.addEventListener)this.addEventListener(($.browser.mozilla?'DOMMouseScroll':'mousewheel'),handler,false);else
-this.onmousewheel=handler;},teardown:function(){var handler=$.event.special.mousewheel.handler;$(this).unbind('mousemove.mousewheel');if(this.removeEventListener)this.removeEventListener(($.browser.mozilla?'DOMMouseScroll':'mousewheel'),handler,false);else
-this.onmousewheel=function(){};$.removeData(this,'mwcursorposdata');},handler:function(event){var args=Array.prototype.slice.call(arguments,1);event=$.event.fix(event||window.event);$.extend(event,$.data(this,'mwcursorposdata')||{});var delta=0,returnValue=true;if(event.wheelDelta)delta=event.wheelDelta/120;if(event.detail)delta=-event.detail/3;if($.browser.opera)delta=-event.wheelDelta;event.data=event.data||{};event.type="mousewheel";args.unshift(delta);args.unshift(event);return $.event.handle.apply(this,args);}};$.fn.extend({mousewheel:function(fn){return fn?this.bind("mousewheel",fn):this.trigger("mousewheel");},unmousewheel:function(fn){return this.unbind("mousewheel",fn);}});})(jQuery);
Deleted: branches/testbaudson_dev/http/extensions/json.js
--- trunk/mapbender/http/extensions/json.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/extensions/json.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,214 +0,0 @@
-    json.js
-    2007-01-10
-    This file adds these methods to JavaScript:
-		toJSONString(obj)
-        arrayToJSONString(obj)
-        booleanToJSONString(obj)
-        dateToJSONString(obj)
-        numberToJSONString(obj)
-        objectToJSONString(obj)
-        stringToJSONString(obj)
-            These methods produce a JSON text from a JavaScript value.
-            It must not contain any cyclical references. Illegal values
-            will be excluded.
-            The default conversion for dates is to an ISO string. You can
-            add a toJSONString method to any date object to get a different
-            representation.
-        parseJSON(string, filter)
-            This method parses a JSON text to produce an object or
-            array. It can throw a SyntaxError exception.
-            The optional filter parameter is a function which can filter and
-            transform the results. It receives each of the keys and values, and
-            its return value is used instead of the original value. If it
-            returns what it received, then structure is not modified. If it
-            returns undefined then the member is deleted.
-            Example:
-            // Parse the text. If a key contains the string 'date' then
-            // convert the value to a date.
-            myData = text.parseJSON(function (key, value) {
-                return key.indexOf('date') >= 0 ? new Date(value) : value;
-    It is expected that these methods will formally become part of the
-    JavaScript Programming Language in the Fourth Edition of the
-    ECMAScript standard in 2007.
-function arrayToJSONString(ao){
-	var a = ['['], b, i, l = ao.length, v;
-	function p(s) {
-		if (b) {
-			a.push(',');
-		a.push(s);
-		b = true;
-	for (i = 0; i < l; i += 1) {
-		v = ao[i];
-		switch (typeof v) {
-		case 'undefined':
-		case 'function':
-		case 'unknown':
-			break;
-		case 'object':
-			if (v) {
-				p(toJSONString(v));
-			} else {
-				p("null");
-			break;
-		default:
-	a.push(']');
-	return a.join('');
-function boolToJSONString(bo) {
-	return String(bo);
-function dateToJSONString(dao) {
-	function f(n) {
-		return n < 10 ? '0' + n : n;
-	return '"' + dao.getFullYear() + '-' +
-		f(dao.getMonth() + 1) + '-' +
-		f(dao.getDate()) + 'T' +
-		f(dao.getHours()) + ':' +
-		f(dao.getMinutes()) + ':' +
-		f(dao.getSeconds()) + '"';
-function numberToJSONString(no) {
-	return isFinite(no) ? String(no) : "null";
-function objectToJSONString(ob) {
-	var a = ['{'], b, i, v;
-	function p(s) {
-		if (b) {
-			a.push(',');
-		a.push(toJSONString(i), ':', s);
-		b = true;
-	for (i in ob) {
-		if (ob.hasOwnProperty(i)) {
-			v = ob[i];
-			case 'undefined':
-			case 'function':
-			case 'unknown':
-				break;
-			case 'object':
-				if (v) {
-				} else {
-					p("null");
-				break;
-			default:
-	a.push('}');
-function stringToJSONString(so){
-	var m = {
-		'\b': '\\b',
-		'\t': '\\t',
-		'\n': '\\n',
-		'\f': '\\f',
-		'\r': '\\r',
-	if (/["\\\x00-\x1f]/.test(so)) {
-		return '"' + so.replace(/([\x00-\x1f\\"])/g, function(a, b) {
-			var c = m[b];
-			if (c) {
-				return c;
-			c = b.charCodeAt();
-			return '\\u00' +
-				Math.floor(c / 16).toString(16) +
-				(c % 16).toString(16);
-	return '"' + so + '"';
-function toJSONString(o){
-	switch(typeof o){
-	case 'undefined':
-	case 'function':
-	case 'unknown':
-		break;
-	case 'object':
-		if (o.constructor == Array){
-			return arrayToJSONString(o);
-		}else if(o.constructor == Date){
-			return dateToJSONString(o);
-		}else{
-			return objectToJSONString(o);
-	case 'number':
-		return numberToJSONString(o);
-	case 'string':
-		return stringToJSONString(o);
-	case 'boolean':
-		return boolToJSONString(o);
-function parseJSON(so, filter){
-	var m = {
-		'\b': '\\b',
-		'\t': '\\t',
-		'\n': '\\n',
-		'\f': '\\f',
-		'\r': '\\r',
-	try {
-		if (/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.
-				test(so)) {
-			var j = eval('(' + so + ')');
-			if (typeof filter === 'function') {
-				function walk(k, v) {
-					if (v && typeof v === 'object') {
-						for (var i in v) {
-							if (v.hasOwnProperty(i)) {
-								v[i] = walk(i, v[i]);
-					return filter(k, v);
-				return walk('', j);
-			return j;
-	} catch (e) {
-	throw new SyntaxError("parseJSON");
Deleted: branches/testbaudson_dev/http/frames/jquery.html
--- trunk/mapbender/http/frames/jquery.html	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/frames/jquery.html	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,10 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>Untitled</title>
-<script type='text/javascript' src="../extensions/jquery.js"></script>
-</head>
-<body>
-</body>
-</html>
Deleted: branches/testbaudson_dev/http/javascripts/initOpenLayersWms.php
--- trunk/mapbender/http/javascripts/initOpenLayersWms.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/javascripts/initOpenLayersWms.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,34 +0,0 @@
-<?php
-# $Id: mod_createJSObjFromDB.php 2144 2008-02-26 23:16:14Z christoph $
-# http://www.mapbender.org/index.php/mod_createJSObjectFromDB.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
-$sql = "SELECT fkey_wms_id FROM gui_wms WHERE fkey_gui_id = $1 ORDER BY gui_wms_position";
-$v = array($_SESSION["mb_user_gui"]);
-$t = array('s');
-$res = db_prep_query($sql,$v,$t);
-$cnt=0;
-while($row = db_fetch_array($res)){
-	$mywms = new wms();
-	$mywms->createObjFromDB($_SESSION["mb_user_gui"],$row["fkey_wms_id"]);
-	$mywms->createOlObjFromWMS($cnt==0);
-	$cnt++;
Deleted: branches/testbaudson_dev/http/javascripts/initWms.php
--- trunk/mapbender/http/javascripts/initWms.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/javascripts/initWms.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,14 +0,0 @@
-<?php
-// Load WMS
-$wmsArray = wms::selectMyWmsByApplication($gui_id);
-for ($i = 0; $i < count($wmsArray); $i++) {
-	$currentWms = $wmsArray[$i];
-	$currentWms->createJsObjFromWMS();
Deleted: branches/testbaudson_dev/http/javascripts/map.js
--- trunk/mapbender/http/javascripts/map.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/javascripts/map.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,690 +0,0 @@
- * used in mod_box1, mod_dragMapSize, mod_pan
-var mb_start_x = 0;
-var mb_start_y = 0;
-var mb_end_x = 0;
-var mb_end_y = 0;
- * @deprecated
-function mb_execloadWmsSubFunctions(){
-	eventAfterLoadWMS.trigger();
-function mb_execWfsReadSubFunctions(geom) {
-	for(var i=0; i<mb_WfsReadSubFunctions.length; i++){
-		mb_WfsReadSubFunctions[i](geom);
-function mb_execWfsWriteSubFunctions() {
-	for(var i=0; i<mb_WfsWriteSubFunctions.length; i++){
-		mb_WfsWriteSubFunctions[i]();
-function mb_setWmcExtensionData(anArray) {
-	for (var i in anArray) {
-		if (typeof(anArray[i]) != "undefined") {
-			currentWmcExtensionData[i] = anArray[i];
-function mb_getWmcExtensionData(arrayKey) {
-	for (var i in restoredWmcExtensionData) {
-		if (arrayKey == i) {
-			return restoredWmcExtensionData[i];
-	var e = new Mb_warning("mb_getWmcExtensionData: "+arrayKey+" not found. Maybe this GUI does not allow loading or saving WMC documents from/to the session");
-	return null;
-eventAfterInit.register(function () {
-	// performs a map request for each map frame
-	for (var i = 0; i < mb_mapObj.length; i++){
-		setMapRequest(mb_mapObj[i].frameName);
-function mb_registerMapObj(frameName, elementName,wms_index,width, height){
-	mb_mapObj.push(new mb_mapObj_const(frameName, elementName, width, height, wms_index));
-function mb_mapObjremoveWMS(objind,wmsind){
-	var wms_ID = null;
-	var i;
-	var new_wmsarray = [];
-	var new_layerarray = [];
-	var new_querylayerarray = [];
-	var new_stylesarray = [];
-	var new_mapURLarray = [];
-	for	(i=0;i<mb_mapObj[objind].wms.length; i++){
-		if(i != wmsind){
-			new_wmsarray[new_wmsarray.length] = mb_mapObj[objind].wms[i];
-			new_layerarray[new_layerarray.length] = mb_mapObj[objind].layers[i];
-			new_querylayerarray[new_querylayerarray.length] = mb_mapObj[objind].querylayers[i];
-			new_stylesarray[new_stylesarray.length] = mb_mapObj[objind].styles[i];
-			new_mapURLarray[new_mapURLarray.length] = mb_mapObj[objind].mapURL[i];
-		else {
-			wms_ID = mb_mapObj[objind].wms[i].wms_id;
-	mb_mapObj[objind].wms = new_wmsarray;
-	mb_mapObj[objind].layers = new_layerarray;
-	mb_mapObj[objind].querylayers = new_querylayerarray;
-	mb_mapObj[objind].styles = new_stylesarray;
-	mb_mapObj[objind].mapURL = new_mapURLarray;
-	var another_new_wmsarray = [];
-	for	(i=0;i<wms.length; i++){
-		if(wms[i].wms_id != wms_ID){
-			another_new_wmsarray[another_new_wmsarray.length] = wms[i];
-	wms = another_new_wmsarray;
-function setExtent(width,height,epsg){
-   for(var i=0; i < wms[0].gui_epsg.length; i++){
-      if(wms[0].gui_epsg[i] == epsg){
-         var bbox_minx = parseFloat(wms[0].gui_minx[i]);
-         var bbox_miny = parseFloat(wms[0].gui_miny[i]);
-         var bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
-         var bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
-         var extenty = bbox_maxy - bbox_miny;
-         var extentx = bbox_maxx - bbox_minx;
-         var relation_px_x = width / height;
-         var relation_px_y = height / width;
-         var relation_bbox_x = extentx / extenty;
-         var centerx = bbox_minx + (extentx/2);
-         var centery = bbox_miny + (extenty/2);
-         if(relation_bbox_x <= relation_px_x){
-                bbox_minx = centerx - relation_px_x * extenty / 2;
-                bbox_maxx = centerx + relation_px_x * extenty / 2;
-         if(relation_bbox_x > relation_px_x){
-                bbox_miny = centery - relation_px_y * extentx / 2;
-                bbox_maxy = centery + relation_px_y * extentx / 2;
-        return bbox_minx  +","+ bbox_miny +","+ bbox_maxx  +","+ bbox_maxy;
-function setMapRequest(frameName){
-	var functionName = 'setMapRequest';
-	var ret = eventBeforeMapRequest.trigger({frameName:frameName}, "AND");
-	if (ret === false) {
-		return true;
-	var ts = mb_timestamp();
-	var myMapIds = [];
-	for (var i=0; i < mb_mapObj.length; i++){
-		var currentMapObject = mb_mapObj[i];
-		if (currentMapObject.frameName != frameName) {
-			continue;
-		var newMapRequest = "";
-		for (var ii = 0; ii < currentMapObject.wms.length; ii++){
-			var currentWms = currentMapObject.wms[ii];
-			if (!(currentWms.gui_wms_visible > 0)) {
-				continue;
-			myMapIds.push("map_"+ii);
-			newMapRequest += getLayerHtmlCode(frameName, i, ii);
-		writeTag(mb_mapObj[i].frameName, mb_mapObj[i].elementName, newMapRequest);
-	eventAfterMapRequest.trigger({
-		"frameName": frameName,
-		"myMapIds": myMapIds.join(",")
-	for(var i=0; i<mb_MapRequestSubFunctions.length; i++){
-		eval(mb_MapRequestSubFunctions[i]);
-function getLayerHtmlCode (frameName, i, ii) {
-	var myDivId = "div_" + ii;
-	var myMapId = "map_" + ii;
-	//disable Layer which are out of scale
-	var validLayers = mb_checkScale(frameName, i, ii);
-	var layerNames = validLayers.toString();
-	var newMapURL = false;
-	var opacityString = "";
-	if (currentMapObject.layers[ii] !== "" && layerNames !== ''){
-		// get map URL
-		newMapURL = currentMapObject.getMapUrl(i, ii);
-		var currentOpacity = currentWms.gui_wms_mapopacity;
-		if (currentOpacity != 1) {
-			opacityString += "opacity:" + currentOpacity + "; ";
-			opacityString += "Filter: Alpha(Opacity=" + currentOpacity*100 + "); ";
-			opacityString += "-moz-opacity:" + currentOpacity + " ; ";
-			opacityString += "-khtml-opacity:" + currentOpacity;
-	var imageString = "<img id='"+myMapId+"' name='mapimage' ";
-	imageString += "src='" + newMapURL + "' ";
-	imageString += "width='"+currentMapObject.width+"' ";
-	imageString += "height='"+currentMapObject.height+"' ";
-	imageString += "border='0'>";
-	var newMapRequest = "<div id='"+myDivId+"' ";
-	newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
-	newMapRequest += "z-index:" + ii + ";" + opacityString + "\">";
-	newMapRequest += imageString;
-	newMapRequest += "</div>";
-	currentMapObject.mapURL[ii]= newMapURL;
-	currentWms.mapURL = newMapURL;
-	if (mb_log && currentWms.mapURL) {
-		var tmp = eval(mb_log + "('" +newMapURL + "','" + ts + "')");
-	return newMapRequest;
-function setSingleMapRequest(frameName,wms_id){
-	var functionName = 'setSingleMapRequest';
-	eventBeforeMapRequest.trigger({frameName:frameName});
-	for(i = 0; i < mb_mapObj.length; i++){
-			continue;
-		for (var ii=0; ii < currentMapObject.wms.length; ii++){
-			if (currentWms.wms_id != wms_id) {
-				continue;
-			var newMapRequest = getLayerHtmlCode(frameName, i, ii);
-			if (mb_log) {
-				var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
-			writeTag(currentMapObject.frameName, myDivId, newMapRequest);
-			eventAfterMapRequest.trigger({"frameName":frameName, "myMapId":myMapId});
-			return true;
-	return false;
-function mb_restateLayers(frameName,wms_id){
-	//alert(frameName + " / " + wms_id);
-	var ind = getMapObjIndexByName(frameName);
-	for(var i=0; i<mb_mapObj[ind].wms.length; i++){
-		if(mb_mapObj[ind].wms[i].wms_id == wms_id){
-			var cnt_layers = 0;
-			var cnt_querylayers = 0;
-			var layers = "";
-			var styles = "";
-			var querylayers = "";
-			for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
-				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
-					if(cnt_layers > 0){layers += ","; styles += ","; }
-					layers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
-					//alert(mb_mapObj[ind].wms[i].objLayer[ii].layer_name);
-					styles += "";
-					cnt_layers++;
-				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
-					if(cnt_querylayers > 0){querylayers += ",";}
-					querylayers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
-					cnt_querylayers++;
-			mb_mapObj[ind].layers[i] = layers;
-			mb_mapObj[ind].querylayers[i] = querylayers;
-			mb_mapObj[ind].styles[i] = styles;
-function mb_checkScale(frameName,mObj,wmsObj){
-	var thisLayer = mb_mapObj[mObj].layers[wmsObj].split(",");
-	var thisScale = mb_getScale(frameName);
-	var str_layer = "";
-	var cnt_layer = 0;
-	for(var i=0; i<mb_mapObj[mObj].wms[wmsObj].objLayer.length; i++){
-		var myLayername = mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_name;
-		var myMinscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_minscale;
-		var myMaxscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_maxscale;
-		for(var ii=0; ii<thisLayer.length; ii++){
-			var minscaleOK = false;
-			var maxscaleOK = false;
-			if(thisLayer[ii] == myLayername){
-				if(myMinscale === 0 || thisScale >= myMinscale){minscaleOK = true;}
-				if(myMaxscale === 0 || thisScale <= myMaxscale){maxscaleOK = true;}
-				if(maxscaleOK === true && minscaleOK === true  && !mb_mapObj[mObj].wms[wmsObj].objLayer[i].has_childs){
-					if(cnt_layer > 0){str_layer += ","; }//str_styles += ","; str_titles += ",";str_parent += ","; str_legendurls += ",";}
-					str_layer += thisLayer[ii];
-					cnt_layer++;
-	var str_layerstyles = [];
-	str_layerstyles[0] = str_layer;
-	return str_layerstyles;
-function setFeatureInfoRequest(fName,x,y, path) {
-	var functionName = 'setFeatureInfoRequest';
-	eventBeforeFeatureInfo.trigger({"fName":fName});
-	for(var i=0; i<mb_FeatureInfoPreFunctions.length; i++){
-		eval(mb_FeatureInfoPreFunctions[i]);
-	var cnt_fi = 0;
-	for(i=0; i<mb_mapObj.length; i++){
-		if(mb_mapObj[i].frameName == fName){
-			for(var ii=0; ii<mb_mapObj[i].wms.length; ii++){
-				var newfeatureInfoRequest = "";
-				var requestParams = "";
-				var validation = false;
-				newfeatureInfoRequest += mb_mapObj[i].wms[ii].wms_getfeatureinfo;
-            	newfeatureInfoRequest += mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getfeatureinfo);
-				if(mb_mapObj[i].wms[ii].wms_version == "1.0.0"){requestParams += "WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=feature_info&";}
-				if(mb_mapObj[i].wms[ii].wms_version != "1.0.0"){requestParams += "VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetFeatureInfo&SERVICE=WMS&";}
-				requestParams += "SRS="+mb_mapObj[i].epsg+"&";
-				requestParams += "BBOX="+mb_mapObj[i].extent+"&";
-				requestParams += "WIDTH="+mb_mapObj[i].width+"&";
-				requestParams += "HEIGHT="+mb_mapObj[i].height+"&";
-				requestParams += "LAYERS="+mb_mapObj[i].layers[ii]+"&";
-				requestParams += "STYLES="+mb_mapObj[i].styles[ii]+"&";
-				requestParams += "FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";
-				requestParams += "INFO_FORMAT="+mb_mapObj[i].wms[ii].gui_wms_featureinfoformat+"&";
-				requestParams += "EXCEPTIONS=application/vnd.ogc.se_xml&";
-				if(mb_feature_count > 0){
-					requestParams += "FEATURE_COUNT="+mb_feature_count+"&";
-				requestParams += "QUERY_LAYERS="+mb_mapObj[i].querylayers[ii]+"&";
-				requestParams += "X=" + x  + "&";
-				requestParams += "Y=" + y;
-				if(mb_mapObj[i].querylayers[ii] !== "" && mb_mapObj[i].layers[ii] !== ""){
-					validation = true;
-				//add vendor-specific
-				for(var v=0; v < mb_vendorSpecific.length; v++){
-					var vendorSpecificString = eval(mb_vendorSpecific[v]);
-					requestParams += "&" + vendorSpecificString;
-				if(mb_log && validation){
-					var tmp = eval(mb_log + "('" + newfeatureInfoRequest + requestParams + "','" + ts + "')");
-				if(document.getElementById("FeatureInfoRedirect") && validation){
-					newfeatureInfoRequest += requestParams;
-					if(path){
-						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr;
-					else{
-						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = newfeatureInfoRequest;
-					cnt_fi++;
-				else if(path && validation){
-					try{
-						var p = new mb_popup("Feature Info","url:"+path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr,300,400);
-						p.show();
-					}catch(e){
-						window.open(path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
-					cnt_fi++;
-				else if(validation){
-					try{
-						var p = new mb_popup("Feature Info","url:"+newfeatureInfoRequest,300,400);
-						p.show();
-					catch(e){
-						window.open(newfeatureInfoRequest, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
-					cnt_fi++;
-   	if(cnt_fi === 0){
-		alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));
- * global function to zoom a mapobject
- * use: mb_mapObj.zoom() {@link mb_mapObj_const#zoom}
- * @deprecated
-function zoom(frameName,in_, factor,x,y) {
-	var obj = getMapObjByName(frameName);
-	if(x && y){
-		obj.zoom(in_, factor, x, y);
-	else{
-		obj.zoom(in_, factor, false, false);
-	setMapRequest(frameName);
-function mb_panMap(frameName,dir){
-   var arrayBBox = mb_mapObj[ind].extent.split(",");
-   var minx = parseFloat(arrayBBox[0]);
-   var miny = parseFloat(arrayBBox[1]);
-   var maxx = parseFloat(arrayBBox[2]);
-   var maxy = parseFloat(arrayBBox[3]);
-   var xtentx = parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]);
-   var xtenty =  parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]);
-   if(dir == "NW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "N"){miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "NE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "W"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2);}
-   if(dir == "E"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2);}
-   if(dir == "SW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-   if(dir == "S"){miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-   if(dir == "SE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-  mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
-function handleSelectedLayer (frameName, wms_title, layerName, type, status) {
-//	alert(frameName + " , " +wms_title + " , " +layerName + " , " +type + " , " +status);
-//	type = {visible || querylayer] status = {0 || 1}
-	for (var i=0; i < mb_mapObj.length; i++) {
-		if (mb_mapObj[i].frameName == frameName) {
-			var myMapObj = i;
-			for (var ii = 0; ii < mb_mapObj[i].wms.length; ii++) {
-				if (mb_mapObj[i].wms[ii].wms_title == wms_title) { //ii is true
-					var myWMS = ii;
-					if (type == "visible") {
-						var arrayLayer = mb_mapObj[i].layers[ii].split(",");
-					if (type == "querylayer") {
-						var arrayLayer = mb_mapObj[i].querylayers[ii].split(",");
-					for (var iii = 1; iii < mb_mapObj[i].wms[ii].objLayer.length; iii++) {
-						var layer_name = mb_mapObj[i].wms[ii].objLayer[iii].layer_name;
-							if (layer_name == layerName && status == 1 && mb_mapObj[i].wms[ii].objLayer[iii].layer_queryable == 1){
-								if (cnt_layer > 0) {
-									str_layer += ",";
-								str_layer += layer_name;
-								cnt_layer++;
-						else if (type == "visible") {
-							if (layer_name == layerName && status == 1) {
-									str_layer += ",";
-								cnt_layer++;
-						for (var iiii = 0; iiii < arrayLayer.length; iiii++) {
-							if (layer_name == arrayLayer[iiii] && layer_name != layerName) {
-									str_layer += ",";
-								cnt_layer++;
-		mb_mapObj[myMapObj].layers[myWMS] = str_layer;
-		var array_str_layer = str_layer.split(",");
-		var str_styles = "";
-		for (var cnt=0; cnt < array_str_layer.length; cnt++) {
-			if (cnt > 0) {
-				str_styles += ",";
-			str_styles += "";
-		mb_mapObj[myMapObj].styles[myWMS] = str_styles;
-		mb_mapObj[myMapObj].querylayers[myWMS] = str_layer;
-	if(type == 'visible'){
-		setSingleMapRequest(frameName,wms_title);
-function handleSelectedLayer_array(mapObj, array_wms, array_layer, type, status){
-	//alert(mapObj+" / "+array_wms[0]+" / "+ array_layer[0]+" / "+ type+" / "+ status);
-	var ind = getMapObjIndexByName(mapObj);
-	for(var j=0; j<array_wms.length; j++){
-			if(mb_mapObj[ind].wms[i].wms_id == array_wms[j]){
-				var check = false;
-					if(mb_mapObj[ind].wms[i].wms_id == array_wms[j] && mb_mapObj[ind].wms[i].objLayer[ii].layer_name == array_layer[j]){
-						if(type == "visible"){
-							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible = parseInt(status, 10);
-							check = true;
-                        if(type == "querylayer" && (mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == "1" || mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == 1)){
-							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer = parseInt(status, 10);
-                mb_restateLayers(mapObj, array_wms[j]);
-                //alert('restate');
-                * hier noch checken, welche wms sich geaendert haben und disctinct eine singleRequest aufrufen:
-                if(check === true){
-                    if(mb_mapObj[ind].wms[i].gui_wms_visible == 1){
-						setSingleMapRequest(mapObj,mb_mapObj[ind].wms[i].wms_id);
-                        //alert('sSMR');
-function makeClickPos2RealWorldPos(frameName, myClickX, myClickY) {
-	var width = parseInt(mb_mapObj[ind].width, 10);
-	var height = parseInt(mb_mapObj[ind].height, 10);
-	var minX = parseFloat(arrayBBox[0]);
-	var minY = parseFloat(arrayBBox[1]);
-	var maxX = parseFloat(arrayBBox[2]);
-	var maxY = parseFloat(arrayBBox[3]);
-	var deltaX = (maxX - minX)/width;
-	var deltaY = (maxY - minY)/height;
-	if(deltaX > 0){
-		var roundx = 1/Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
-	else{
-		var roundx =  Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
-	if(deltaY > 0){
-		var roundy = 1/Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
-	else{
-		var roundy =  Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
-	var xtentx = maxX - minX;
-	var xtenty =  maxY - minY;
-	var posX = parseFloat(minX + (myClickX / width) * xtentx);
-	var posY = parseFloat(maxY - (myClickY / height) * xtenty);
-	posX = Math.round(posX * roundx)/roundx;
-	posY = Math.round(posY * roundy)/roundy;
-	return [posX, posY];
-function makeRealWorld2mapPos(frameName,rw_posx, rw_posy){
-   var mpObj = mb_mapObj[ind];
-   var arrayBBox = mpObj.extent.split(",");
-   return [Math.round((rw_posx - minX)*mpObj.width/(maxX - minX)), Math.round((maxY - rw_posy)*mpObj.height/(maxY - minY))];
-// function for object-identification
-function getMapObjIndexByName(frameName){
-	for(var i=0; i<mb_mapObj.length; i++){
-		if(mb_mapObj[i].frameName == frameName){
-			return i;
-function getMapObjByName(frameName){
-			return mb_mapObj[i];
-	return false;
-function getWMSIDByTitle(frameName,wms_title){
-   for(var i=0; i< mb_mapObj[ind].wms.length; i++){
-      if(mb_mapObj[ind].wms[i].wms_title == wms_title){
-         //return i;
-         return mb_mapObj[ind].wms[i].wms_id;
-function getWMSIndexById(frameName,wms_id){
-         return i;
-//scale
-function mb_getScale(frameName) {
-	var myScale = eventBeforeGetScale.trigger({"frameName":frameName});
-   for(var i=0; i<mb_GetScalePreFunctions.length; i++){
-		var myScale = eval(mb_GetScalePreFunctions[i]);
-   if(typeof(myScale) == "number"){
-      var Y_str = myScale;
-   else{
-      var scaleY = (xtenty / mb_mapObj[ind].height) *(mb_resolution * 100);
-      if (scaleY<1){
-      	var Y_str = scaleY;
-      }else{
-      	var Y_str = Math.round(scaleY);
-   return Y_str;
-function mb_repaintScale(frameName, x, y, scale){
-   if(x === null && y === null){
-      x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
-      y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
-   var minx = parseFloat(x) - (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
-   var miny = parseFloat(y) -  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
-   var maxx = parseFloat(x) + (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
-   var maxy = parseFloat(y) +  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
-   mb_repaint(frameName,minx, miny, maxx, maxy);
-function mb_repaint(frameName,minx,miny,maxx,maxy){
- * converts the extent of the mapobject so that the maximum	extent will be displayed {@link mb_mapObj_const#calculateExtent}
- * use: mb_mapObj.calculateExtent
- * @deprecated
-function mb_calculateExtent(frameName,minx,miny,maxx,maxy){
-  var map = getMapObjByName(frameName);
-  var extent = new Extent(minx,miny,maxx,maxy);
-  map.calculateExtent(extent);
- * @class extent
- * @param {float} minx
- * @param {float} miny
- * @param {float} maxx
- * @param {float} maxy
- * @return the extent as object
- * @type Object
-function Extent(minx,miny,maxx,maxy){
-	this.minx = parseFloat(minx);
-	this.miny = parseFloat(miny);
-	this.maxx = parseFloat(maxx);
-	this.maxy = parseFloat(maxy);
-	this.extentx = this.maxx - this.minx;
-	this.extenty = this.maxy - this.miny;
-	this.centerx = this.minx + this.extentx/2;
-	this.centery = this.miny + this.extenty/2;
-	return this;
Modified: branches/testbaudson_dev/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/javascripts/map.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -74,9 +74,9 @@
 // Load external JavaScript libraries
-require_once(dirname(__FILE__) . "/../extensions/jquery-1.2.6.min.js");
-require_once(dirname(__FILE__) . "/../extensions/jqjson.js");
-require_once(dirname(__FILE__) . "/../extensions/jquery.mousewheel.min.js");
+require_once(dirname(__FILE__) . "/../../ext/jquery-1.2.6.min.js");
+require_once(dirname(__FILE__) . "/../../ext/jqjson.js");
+require_once(dirname(__FILE__) . "/../../ext/jquery.mousewheel.min.js");
 // Load internal JavaScript libraries
@@ -90,14 +90,6 @@
 require_once(dirname(__FILE__) . "/../../lib/button.js");
-// map obj
-#require_once(dirname(__FILE__) . "/../../lib/map_obj.js");
-#require_once(dirname(__FILE__) . "/../../lib/map.js");
-#require_once(dirname(__FILE__) . "/../../lib/wms.js");
-#require_once(dirname(__FILE__) . "/../../lib/wfs_obj.js");
 // Load JavaScript modules of GUI elements
 $sql = "SELECT DISTINCT e_mb_mod FROM gui_element WHERE e_public = 1 AND fkey_gui_id = $1";
Deleted: branches/testbaudson_dev/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/javascripts/map_obj.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,404 +0,0 @@
-* $Id: map_obj.js 2517 2008-06-19 16:40:00Z christoph $
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-var mb_mapObj = [];
-function mb_mapObj_const(frameName, elementName, width, height, wms_index){
-	this.width = width;
-	this.height = height;
-	this.frameName = frameName;
-	this.elementName = elementName;
-	this.layers = [];
-	this.styles = [];
-	this.querylayers = [];
-	this.geom = "";
-	this.gml = "";
-	this.wms = [];
-	// Add pointers to WMS objects which are in this map.
-	// If wms_index is set (=map is overview), only this
-	// WMS is being pointed to.
-	var index = 0;
-	for(var i=0; i < wms.length; i++){
-		var isValidWms = (wms_index === null) || (wms_index == i);
-		if (isValidWms) {
-			this.wms[index] = wms[i];
-			this.wms[index].mapURL = false;
-			index++;
-	// set list of visible layers, active querylayers
-	// and styles for each WMS in this map
-	var cnt_layers;
-	var cnt_querylayers;
-	var styles;
-	var layers;
-	for(i=0; i< this.wms.length; i++){
-		cnt_layers = 0;
-		cnt_querylayers = 0;
-		styles = "";
-		layers = "";
-		querylayers = "";
-		for(var ii=0; ii<this.wms[i].objLayer.length; ii++){
-			// layer is visible and not root layer
-			if(this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii>0){
-					layers += ","; styles += ",";
-				layers += wms[i].objLayer[ii].layer_name;
-				styles += "";
-				cnt_layers++;
-			// layer is queryable and not root layer
-			if(this.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii>0){
-					querylayers += ",";
-				querylayers += wms[i].objLayer[ii].layer_name;
-		this.layers[i] = layers;
-		this.styles[i] = styles;
-		this.querylayers[i] = querylayers;
-	this.epsg = wms[0].gui_wms_epsg;
-	this.extent = setExtent(this.width,this.height,this.epsg);
-	this.mapURL = [];
-	var styleTag = window.frames[this.frameName].document.getElementById(this.elementName).style;
-	styleTag.width = this.width;
-	styleTag.height = this.height;
-	 * get the width of the mapObj
-	 * @member mb_mapObj_const
-	 * @return width of the mapObj
-	 * @type integer
-	this.getWidth = function(){
-		return parseInt(this.width, 10);
-	 * set the width of the mapObj
-	 * @param {integer} widht the width of the mapObj
-	this.setWidth = function(width){
-		this.width = parseInt(width, 10);
-	 * get the height of the mapObj
-	 * @type integer
-	this.getHeight = function(){
-		return parseInt(this.height, 10);
-	 * set the height of the mapObj
-	 * @param {integer} height the height of the mapObj
-	this.setHeight = function(height){
-		this.height = parseInt(height, 10);
-	 * get the extent of the mapObj
-	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
-	 * @type string
-	this.getExtent = function(){
-		return this.extent;
-	 * get the extent as minx, maxx, miny, maxy
-	 * @return extent and additional informations of the mapObj
-	 * @type Object
-	this.getExtentInfos = function(){
-		var c = this.getExtent().split(",");
-		var ext = new Extent(c[0],c[1],c[2],c[3]);
-		return ext;
-	this.calculateExtent = function(ext){
-		var relation_px_x = this.getWidth() / this.getHeight();
-		var relation_px_y = this.getHeight() / this.getWidth();
-		var relation_bbox_x = ext.extentx / ext.extenty;
-			ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
-			ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
-			ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
-			ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
-		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
-	 * zoom the map with a zoomfactor and optional to x,y coords
-	 * @param {boolean} in_ in = true, out = false
-	 * @param {float} factor the zoomfactor 1 equals 100%
-	 * @param {float} x center to x-position
-	 * @param {float} y center to y-position
-	 this.zoom = function(in_, factor, x, y){
-		factor = parseFloat(factor);
-		if (!in_) {
-			factor = 1 / factor;
-		var extent = this.getExtentInfos();
-		var distx = extent.maxx - extent.minx;
-		var disty =  extent.maxy - extent.miny;
-		if(x && y){
-			var centerx = parseFloat(x);
-			var centery = parseFloat(y);
-		else{
-			var centerx = extent.minx + distx/2;
-			var centery = extent.miny + disty/2;
-		var new_distx = distx / factor;
-		var new_disty = disty / factor;
-		var minx = centerx - new_distx / 2;
-		var miny = centery - new_disty / 2;
-		var maxx = centerx + new_distx / 2;
-		var maxy = centery + new_disty / 2;
-		this.setExtent(minx,miny,maxx,maxy);
-		//Todo:
-		//setMapRequest!
-	 * set the extent of the wms
-	 this.setExtent = function(minx,miny,maxx,maxy){
-	 	this.extent = String(minx)+","+String(miny)+","+String(maxx)+","+String(maxy);
-	 * get the srs of the mapObj
-	 * @return srs as epsg:number
-	 * @type string
-	this.getSRS = function(){
-		return this.epsg;
-	 * get all mapRequests
-	 * @return array of mapRequests of this map object
-	 * @type string[]
-	this.getMapRequests = function(){
-		var allRequests = [];
-		//loop through all wms to get the mapRequests
-		for(var i=0; i<this.wms.length; i++){
-			var currentRequest = this.wms[i].getMapRequest(this);
-			if(currentRequest){
-				allRequests.push(currentRequest);
-		if(allRequests.length > 0){
-			return allRequests;
-		return false;
-	 * Return the map URL of the WMS at index i
-	 * @param {Object} currentWmsIndex
-	this.getMapUrl = function (i, ii) {
-		var currentWms = this.wms[ii];
-		var validLayers = currentWms.getLayers(this);
-		var layerNames = validLayers.join(",");
-		url = currentWms.wms_getmap;
-		url += mb_getConjunctionCharacter(currentWms.wms_getmap);
-		if (currentWms.wms_version == "1.0.0") {
-			url += "WMTVER=" + currentWms.wms_version + "&REQUEST=map&";
-		else {
-			url += "VERSION=" + currentWms.wms_version + "&REQUEST=GetMap&SERVICE=WMS&";
-		url += "LAYERS=" + layerNames + "&";
-		url += "STYLES=";
-		var layer = layerNames.split(",");
-		for (var j = 0; j < layer.length; j++){
-			if (j > 0) {
-				url  += ",";
-			if (currentWms.getCurrentStyleByLayerName(layer[j]) !== false) {
-				url += currentWms.getCurrentStyleByLayerName(layer[j]);
-		url += "&";
-		url += "SRS=" + this.epsg + "&";
-		url += "BBOX=" + this.extent + "&";
-		url += "WIDTH=" + this.width + "&";
-		url += "HEIGHT=" + this.height + "&";
-		url += "FORMAT=" + currentWms.gui_wms_mapformat + "&";
-		url += "BGCOLOR=0xffffff&";
-		if (currentWms.gui_wms_mapformat.search(/gif/i)>-1 ||
-			currentWms.gui_wms_mapformat.search(/png/i)>-1) {
-				url += "TRANSPARENT=TRUE&";
-		url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
-		// add vendor-specific
-		for (var v = 0; v < mb_vendorSpecific.length; v++) {
-			// if eval doesn't evaluate a function, the result is undefined.
-			// Sometimes it is necessary not to evaluate a function, for
-			// example if you want to change a variable from the current
-			// scope (see mod_addSLD.php)
-			if (typeof(vendorSpecificString) != "undefined") {
-				url += vendorSpecificString + "&";
-		// add Filter
-		if (currentWms.wms_filter !== ""){
-			url += "&SLD=" + currentWms.wms_filter +"?id="+ mb_styleID + "&";
-		// add sld
-		if(currentWms.gui_wms_sldurl !== ""){
-			url += "&SLD=" + escape(currentWms.gui_wms_sldurl) + "&";
-		return url;
-	 * get all featureInfoRequests
-	 * @param float x the x-value of the click position in pixel
-	 * @param float y the y-value of the click position in pixel
-	 * @return array of all featureInfoRequests of this map object
-	 * @type string[]
-	this.getFeatureInfoRequests = function(clickPoint){
-		//loop through all wms to get the FeatureInfoRequests
-			var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
-		return false;
-	 * calculation of the mapscale
-	 * @return scale
-	 * @type integer
-	this.getScale = function(){
-		var scale;
-		var bbox = this.extent.split(",");
-		var xtenty;
-		if(this.epsg=="EPSG:4326"){
-			var pxLenx = (parseFloat(bbox[2])-parseFloat(bbox[0]))/this.width;
-			var pxLeny = (parseFloat(bbox[3])-parseFloat(bbox[1]))/this.height;
-			var lat_from = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2)*Math.PI)/180;
-			var lat_to = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2+pxLeny)*Math.PI)/180;
-			var lon_from = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2)*Math.PI)/180;
-			var lon_to = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2+pxLeny)*Math.PI)/180;
-			var dist=6371229*Math.acos(Math.sin(lat_from)*Math.sin(lat_to)+Math.cos(lat_from)*Math.cos(lat_to)*Math.cos(lon_from-lon_to));
-			scale = (dist/Math.SQRT2) * (mb_resolution * 100);
-		}else{
-			xtenty =  parseFloat(bbox[3]) - parseFloat(bbox[1]);
-			scale = (xtenty / this.height) * (mb_resolution * 100);
-		return Math.round(scale);
-	 * move a wms or layer
-	 * @param int wms_id id of wms to move
-	 * @param int layer_id id of layer to move
-	 * @return true of successful
-	 * @type boolean
-	this.move = function(wms_id, layer_id, moveUp){
-		var i,j;
-		for(i=0;i<this.wms.length;i++){
-			if (wms_id == this.wms[i].wms_id) {
-				break;
-		//check if only one wms is affected?
-		if (layer_id && layer_id != this.wms[i].objLayer[0].layer_id) {
-			return this.wms[i].moveLayer(layer_id, moveUp);
-		//else swap wms
-		j = i + (moveUp?-1:1);
-		if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length)) {
-			return false;
-		upper = this.wms[i];
-		this.wms[i] = this.wms[j];
-		this.wms[j] = upper;
-		var upperLayers = this.layers[i];
-		var upperStyles = this.styles[i];
-		var upperQuerylayers = this.querylayers[i];
-		this.layers[i] = this.layers[j];
-		this.styles[i] = this.styles[j];
-		this.querylayers[i] = this.querylayers[j];
-		this.layers[j] = upperLayers;
-		this.styles[j] = upperStyles;
-		this.querylayers[j] = upperQuerylayers;
-		return true;
-	eventAfterMapObjectConstruction.trigger();
\ No newline at end of file
Deleted: branches/testbaudson_dev/http/javascripts/mod_openlayers.php
--- trunk/mapbender/http/javascripts/mod_openlayers.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/javascripts/mod_openlayers.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,42 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Openlayers
-    var ol_options = { scales: [50000000, 30000000, 10000000, 5000000],
-                    resolutions: [1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125],
-                    minScale: 50000000,
-                    maxResolution: "auto",
-                    maxExtent: new OpenLayers.Bounds(-180, -90, 90, 180),
-                    maxResolution: 0.17578125,
-                    maxScale: 10000000,
-                    minResolution: "auto",
-                    minExtent: new OpenLayers.Bounds(-1, -1, 1, 1),
-                    minResolution: 0.0439453125,
-                    numZoomLevels: 5,
-                    units: "degrees"
-var ol_map;
-OpenLayers.ImgPath = "../img/openlayers/";
-ol_map = new OpenLayers.Map('<?php echo $e_id;?>', {'maxResolution': 1.40625/2});
-	ol_map.zoomToMaxExtent();
Deleted: branches/testbaudson_dev/http/javascripts/wfs_obj.js
--- trunk/mapbender/http/javascripts/wfs_obj.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/javascripts/wfs_obj.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,75 +0,0 @@
-//$Id$
-//$Header: /cvsroot/mapbender/mapbender/http/javascripts/wfs_obj.js,v 1.3 2005/09/13 14:38:11 bjoern_heuser Exp $
-//global variables
-var wfs = [];
-var wfs_featuretype_count = 0;
-var wfs_element_count = 0;
-//list of all wms-objects
-function add_wfs(
-			wfs_id,
-			wfs_version,
-			wfs_title,
-			wfs_abstract,
-			wfs_getcapabilities,
-			wfs_describefeaturetype){
-					wfs[wfs.length] = new wfs_const(
-					wfs_id,
-			      wfs_version,
-			      wfs_title,
-			      wfs_abstract,
-			      wfs_describefeaturetype);
-					//wfs_featuretype[wfs.length - 1] = [];
-//the wms constructor
-function wfs_const(
-			wfs_id,
-			wfs_version,
-			wfs_title,
-			wfs_abstract,
-	this.wfs_id = wfs_id;
-	this.wfs_version = wfs_version;
-	this.wfs_title = wfs_title;
-	this.wfs_abstract = wfs_abstract;
-	this.wfs_getcapabilities = wfs_getcapabilities;
-	this.wfs_describefeaturetype = wfs_describefeaturetype;
-	this.wfs_featuretype = [];
-   //alert(wfs_id + " , " +wfs_title + " , " +wfs_abstract + " , " +wfs_getcapabilities + " , " +wfs_describefeaturetype);
-//featuretype
-function wfs_add_featuretype(
-			featuretype_name,
-			featuretype_title,
-			featuretype_srs,
-			featuretype_geomtype){
-	      wfs[wfs.length-1].wfs_featuretype[wfs[wfs.length-1].wfs_featuretype.length] = new featuretype(
-											featuretype_name,
-											featuretype_srs,
-											featuretype_geomtype);
-//alert(featuretype_name + " , " +featuretype_title + " , " +featuretype_srs + " , " +featuretype_geomtype);
-function featuretype(
-			featuretype_name,
-			featuretype_srs,
-	this.featuretype_name = featuretype_name;
-	this.featuretype_title = featuretype_title;
-	this.featuretype_srs = featuretype_srs;
-	this.featuretype_geomtype = featuretype_geomtype;
-	this.element = [];
-	wfs_featuretype_count++;
-//elements
-function wfs_add_featuretype_element(element_name, element_type, element_count, featuretype_count){
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count] = [];
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].name = element_name;
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].type = element_type;
-   //alert(element_name +" , "+element_type);
Deleted: branches/testbaudson_dev/http/javascripts/wms.js
--- trunk/mapbender/http/javascripts/wms.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/javascripts/wms.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,777 +0,0 @@
- * $Id: map_obj.js 2413 2008-04-23 16:21:04Z christoph $
- * COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
- * License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-//global variables
-var wms = [];
-var wms_layer_count = 0;
- * global function to add wms to the wms-object
- * @param {String} wms_id the unique id of the wms
- * @param {String} wms_version the version assumed from capabilities
- * @param {String} wms_title the title of the wms
- * @param {String} wms_abstract the abstract of the wms
- * @param {String} wms_getmap the url for map requests
- * @param {String} wms_getfeatureinfo the url for featureInof requests
- * @param {String} wms_getlegendurl the url for legend requests
- * @param {String} wms_filter a filter (deprecated)
- * @param {String} gui_wms_mapformat the image-format in the actual gui
- * @param {String} gui_wms_featureinfoformat the current format for featureInfos
- * @param {String} gui_wms_exceptionformat the exceptionformat for map requests
- * @param {String} gui_wms_epsg the current srs
- * @param {Integer} gui_wms_visible the visibility of this service
- * @param {Integer} gui_wms_opacity the initial display opacity in percent
- * @param {String} gui_wms_sldurl url to an actual sld
-function add_wms(
-			wms_id,
-			wms_version,
-			wms_title,
-			wms_abstract,
-			wms_getmap,
-			wms_getfeatureinfo,
-			wms_getlegendurl,
-			wms_filter,
-			gui_wms_mapformat,
-			gui_wms_featureinfoformat,
-			gui_wms_exceptionformat,
-			gui_wms_epsg,
-			gui_wms_visible,
-			gui_wms_opacity,
-			gui_wms_sldurl){
-					wms[wms.length] = new wms_const(
-					wms_id,
-					wms_version,
-					wms_title,
-					wms_abstract,
-					wms_getmap,
-					wms_getlegendurl,
-					wms_filter,
-					gui_wms_epsg,
-					parseInt(gui_wms_visible, 10),
-					parseInt(gui_wms_opacity),
-					gui_wms_sldurl);
-					wms_layer[wms.length - 1] = [];
- * @class A class representing the wms
- * @constructor
- * @param {String} gui_wms_visible the visibility of this service
-function wms_const(
-			wms_id,
-			wms_version,
-			wms_title,
-			wms_abstract,
-			wms_getmap,
-		    wms_getlegendurl,
-			wms_filter,
-			gui_wms_epsg,
-			gui_wms_visible,
-			gui_wms_opacity,
-			gui_wms_sldurl){
-	if (!wms_id) {
-		var id_ok = false;
-		while (id_ok === false) {
-			wms_id = "a"+Math.round(10000*Math.random());
-			id_ok = true;
-			for (var i=0; i < wms.length && id_ok === true; i++) {
-				if (wms_id == wms[i].wms_id) {
-					id_ok = false;
-	this.wms_id = wms_id;
-	this.wms_version = wms_version;
-	this.wms_title = wms_title;
-	this.wms_abstract = wms_abstract;
-	this.wms_getmap = wms_getmap;
-	this.wms_getfeatureinfo = wms_getfeatureinfo;
-	this.wms_getlegendurl = wms_getlegendurl;
-	this.wms_filter = wms_filter;
-	this.data_type = [];
-	this.data_format = [];
-	this.objLayer = [];
-	this.gui_wms_mapformat = gui_wms_mapformat;
-	this.gui_wms_featureinfoformat = gui_wms_featureinfoformat;
-	this.gui_wms_exceptionformat = gui_wms_exceptionformat;
-	this.gui_wms_epsg = gui_wms_epsg;
-	this.gui_wms_visible = gui_wms_visible;
-	this.gui_epsg = [];
-	this.gui_minx = [];
-	this.gui_miny = [];
-	this.gui_maxx = [];
-	this.gui_maxy = [];
-	// opacity version
-	this.gui_wms_mapopacity = gui_wms_opacity/100;
-	// sld version
-	this.gui_wms_sldurl = gui_wms_sldurl;
- * rephrases the mapRequest
- * @param {Object} mapObj the mapbender mapObject of the wms
- * @return mapRequest, i.e. onlineresource + params
- * @type String
-wms_const.prototype.getMapRequest = function(mapObj){
-	//check visible layers first
-	var layers = this.getLayers(mapObj);
-	if(!layers){
-		return false;
-	var rq = this.wms_getmap;
-	rq += mb_getConjunctionCharacter(this.wms_getmap);
-	if(this.wms_version === "1.0.0"){
-		rq += "WMTVER=" + this.wms_version + "&REQUEST=map";
-	else{
-		rq += "VERSION=" + this.wms_version + "&REQUEST=getMap&SERVICE=WMS";
-	rq += "&LAYERS=" + layers.join(",");
-	rq += "&WIDTH=" + mapObj.getWidth();
-	rq += "&HEIGHT=" + mapObj.getHeight();
-	rq += "&SRS=" + mapObj.getSRS();
-	rq += "&BBOX=" + mapObj.getExtent();
-	rq += "&STYLES=" + this.getLayerstyles(mapObj).join(",");
-	rq += "&FORMAT=" + this.gui_wms_mapformat;
-	rq += "&EXCEPTIONS=" + this.gui_wms_exceptionformat;
-	//Todo: error occurs:
-	//var throwNotice = new Mb_notice("getMapRequest: " + rq);
-	//window.console.log("getMapRequest: " + rq);
-	return rq;
- * rephrases the featureInfoRequest
- * @param {Point} clickPoint map-click position {@link Point}
- * @return featureInfoRequest, onlineresource + params
- * @type string
-wms_const.prototype.getFeatureInfoRequest = function(mapObj, clickPoint){
-	//check layers and querylayers first
-	var querylayers = this.getQuerylayers(mapObj);
-	if(!layers || !querylayers){
-		return false;
-	var rq = this.wms_getfeatureinfo;
-	rq += mb_getConjunctionCharacter(this.wms_getfeatureinfo);
-		rq += "WMTVER=" + this.wms_version + "&REQUEST=feature_info";
-	else{
-		rq += "VERSION=" + this.wms_version + "&REQUEST=GetFeatureInfo&SERVICE=WMS";
-	rq += "&QUERY_LAYERS=" + querylayers.join(",");
-	rq += "&INFO_FORMAT=" + this.gui_wms_featureinfoformat;
-	rq += "&EXCEPTIONS=application/vnd.ogc.se_xml";
-	rq += "&X=" + clickPoint.x;
-	rq += "&Y=" + clickPoint.y;
-	//console.log(rq);
-	return rq;
- * sets Opacity of WMS
- * @param {Integer} new opacity percentage value
-wms_const.prototype.setOpacity = function(opacity){
-	//calc new opacity
-	this.gui_wms_mapopacity = parseInt(opacity)/100;
-	if(this.gui_wms_mapopacity>1||isNaN(this.gui_wms_mapopacity))
-		this.gui_wms_mapopacity=1;
-	if(this.gui_wms_mapopacity<0)
-		this.gui_wms_mapopacity=0;
-	if (this.gui_wms_visible > 0) {
-		//get div id
-		var divId = null;
-		for (var i=0; i < wms.length; i++) {
-			if (this.wms_id == wms[i].wms_id) {
-				var divId = 'div_'+i;
-				break;
-		if(!divId)
-			return;
-		//TODO: check if mapframe1 is the right mapframe
-		wmsImage = parent.mapframe1.document.getElementById(divId);
-		if (wmsImage != null) {
-			wmsImage.style.opacity = this.gui_wms_mapopacity;
-			wmsImage.style.MozOpacity = this.gui_wms_mapopacity;
-			wmsImage.style.KhtmlOpacity = this.gui_wms_mapopacity;
-			wmsImage.style.filter = "alpha(opacity=" + this.gui_wms_mapopacity*100 + ")";
- * get all visible layers
- * @return array of layernames
- * @type string[]
-wms_const.prototype.getLayers = function(mapObj){
-	try {
-		//visibility of the wms
-		var wmsIsVisible = (this.gui_wms_visible > 0);
-		if(!wmsIsVisible){
-			return false;
-		visibleLayers = [];
-		for(var i=0; i< this.objLayer.length; i++){
-			var isVisible = (this.objLayer[i].gui_layer_visible === 1);
-			var hasNoChildren = (!this.objLayer[i].has_childs);
-			if (isVisible && hasNoChildren){
-				if(this.objLayer[i].checkScale(mapObj)){
-					//console.log("checkLayer: " + this.objLayer[i].layer_name);
-					visibleLayers.push(this.objLayer[i].layer_name);
-		if(visibleLayers.length === 0){
-			return false;
-		return visibleLayers;
-	catch (e) {
-		alert(e);
- * get the actual style of all visible layers
- * @return commaseparated list of actual layerstyles
- * @type string
-wms_const.prototype.getLayerstyles = function(mapObj){
-	var layerstyles = '';
-	var styles = [];
-	if(layers){
-		for(i = 0; i < layers.length; i++){
-			var style = this.getCurrentStyleByLayerName(layers[i]);
-			if(!style){
-				style = '';
-			styles.push(style);
-		return styles;
-	return false;
- * check if layer is parentLayer
- * @param layername
- * @return the parent value of the given layer
- * @type integer
-wms_const.prototype.checkLayerParentByLayerName = function(layername){
-		if(this.objLayer[i].layer_name == layername){
-			return this.objLayer[i].layer_parent;
- * get the title of the current layer
- * @return the title of the given layer
- * @type string
-wms_const.prototype.getTitleByLayerName = function(layername){
-			return this.objLayer[i].layer_title;
- * get the current style of the layer
- * @return the stylename of the given layer
- * @type string
-wms_const.prototype.getCurrentStyleByLayerName = function(layername){
-			if(this.objLayer[i].gui_layer_style === '' || this.objLayer[i].gui_layer_style === null){
-				return false;
-			else{
-				return this.objLayer[i].gui_layer_style;
- * get the legendurl of the gui layer style
- * @param stylename
- * @return the legendurl of the given style
- * @type string
-wms_const.prototype.getLegendUrlByGuiLayerStyle = function(layername,guiLayerStyle){
-			if(this.objLayer[i].layer_style.length === 0){
-				return false;
-			for(var k=0; k< this.objLayer[i].layer_style.length; k++){
-				if(this.objLayer[i].layer_style[k].name == guiLayerStyle){
-					var legendUrl = this.objLayer[i].layer_style[k].legendurl;
-					if (this.gui_wms_sldurl !== "") {
-					 		legendUrl += "&SLD="+escape(this.gui_wms_sldurl);
-					if(legendUrl !=='' && legendUrl !== null && typeof(legendUrl) != 'undefined'){
-						return legendUrl;
-					else {
-						return false;
-	return false;
- * get all querylayers
- * @type string[]
-wms_const.prototype.getQuerylayers = function(){
-	queryLayers = [];
-		if(this.objLayer[i].gui_layer_querylayer === 1 && ! this.objLayer[i].has_childs ){
-			queryLayers.push(this.objLayer[i].layer_name);
-	if(queryLayers.length === 0){
-		return false;
-	return queryLayers;
- * get a layer Object by layer_pos
- * @param int payer_pos layer_pos of layer you want to get
- * @return object layer
-wms_const.prototype.getLayerByLayerPos = function(layer_pos){
-	for(var i=0;i<this.objLayer.length;i++){
-		if(this.objLayer[i].layer_pos == layer_pos) {
-			return this.objLayer[i];
-	return null;
- * get the state of sublayers from a specified layer
- * @param int layer_id of the parent layer
- * @param String type "visible" or "querylayer"
- * @return int -1 if state differs else the state
-wms_const.prototype.getSublayerState = function(layer_id, type){
-	var i;
-	var state=-1,value;
-	for(i = 0; i < this.objLayer.length; i++){
-		if(this.objLayer[i].layer_id==layer_id) {
-			break;
-	//go throught sublayers
-	for(var j = i+1; j < this.objLayer.length; j++){
-		if(this.objLayer[i].parent_layer == this.objLayer[j].parent_layer) {
-			break;
-		if(type == "visible") {
-			value = this.objLayer[j].gui_layer_visible;
-		else if(type == "querylayer") {
-			value = this.objLayer[j].gui_layer_querylayer;
-		if(state == -1) {
-			state = value;
-		if(state != value) {
-			return -1;
-	return state;
- * handle change of visibility / quaryability of a layer
- * @param string layer_name of layer to handle
- * @param string type of change ("visible" or "querylayer")
- * @param int value of the change
-wms_const.prototype.handleLayer = function(layer_name, type, value){
-	var i;
-		if(this.objLayer[i].layer_name==layer_name) {
-			break;
-	//Set visibility/queryability of Layer and Sublayers
-	for(var j = i; j < this.objLayer.length; j++){
-		if (i != j && this.objLayer[i].layer_parent >= this.objLayer[j].layer_parent) {
-			break;
-			this.objLayer[j].gui_layer_visible = parseInt(value, 10);
-		else if(type=="querylayer") {
-			this.objLayer[j].gui_layer_querylayer = parseInt(value, 10);
-	//Update visibility/queryability of parent layer
-	var parentLayer = this.getLayerByLayerPos(this.objLayer[i].layer_parent);
-	if(parentLayer){
-		var state = this.getSublayerState(parentLayer.layer_id, type);
-		if(state!=-1){
-				this.objLayer[j].gui_layer_visible = state;
-				this.objLayer[j].gui_layer_querylayer = state;
- * move a layer (with his sublayers) up or down
- * @param int layerId layer_id of layer to move
- * @param boolean moveUp true to move up or false to move down
- * @return boolean success
-wms_const.prototype.moveLayer = function(layerId, moveUp){
-	var iLayer=-1;
-	var i;
-	//find layer to move
-	for(i=0;i<this.objLayer.length;i++){
-		if(this.objLayer[i].layer_id==layerId){
-			iLayer=i;
-			break;
-	if(iLayer==-1) {
-		return false;
-	var upperLayer = -1;
-	var lowerLayer = -1;
-	//find layer to swap position with
-	var parentLayer = this.objLayer[iLayer].layer_parent;
-	if(moveUp){
-		lowerLayer = iLayer;
-		//find previous layer on same level
-		for(i=iLayer-1;i>0;i--){
-			if(parentLayer == this.objLayer[i].layer_parent){
-				upperLayer = i;
-				break;
-		if(upperLayer == -1){
-			//alert("The Layer you selected is already on top of parent Layer/WMS");
-			return false;
-	else{
-		upperLayer = iLayer;
-		//find next layer on same level
-		for(i=iLayer+1;i<this.objLayer.length;i++){
-				lowerLayer = i;
-				break;
-		if(lowerLayer == -1){
-			//alert("The Layer you selected is already on bottom of parent Layer/WMS");
-			return false;
-	//calc number of layers to move down
-	var layersDown = lowerLayer - upperLayer;
-	//get number of layers to move up
-	for(i=lowerLayer+1; i<this.objLayer.length; i++){
-			break;
-	var layersUp = i - lowerLayer;
-	//do moving
-	var temp = [];
-	for(i=0;i<layersDown+layersUp;i++){
-		temp[temp.length]=this.objLayer[upperLayer+i];
-	for(i=0;i<layersUp;i++){
-		this.objLayer[upperLayer+i]=temp[i+layersDown];
-	for(i=0;i<layersDown;i++){
-		this.objLayer[upperLayer+layersUp+i]=temp[i];
-	return true;
-function wms_add_data_type_format(datatype,dataformat){
-	var insertDataFormat = true;
-	for (var i = 0 ; i < wms[wms.length-1].data_type.length ; i ++) {
-		if (wms[wms.length-1].data_type[i] == datatype && wms[wms.length-1].data_format[i] == dataformat) {
-			insertDataFormat = false;
-	if (insertDataFormat === true) {
-		wms[wms.length-1].data_type[wms[wms.length-1].data_type.length] = datatype;
-		wms[wms.length-1].data_format[wms[wms.length-1].data_format.length] = dataformat;
-function wms_addSRS(epsg,minx,miny,maxx,maxy){
-	wms[wms.length-1].gui_epsg[wms[wms.length-1].gui_epsg.length] = epsg;
-	wms[wms.length-1].gui_minx[wms[wms.length-1].gui_minx.length] = minx;
-	wms[wms.length-1].gui_miny[wms[wms.length-1].gui_miny.length] = miny;
-	wms[wms.length-1].gui_maxx[wms[wms.length-1].gui_maxx.length] = maxx;
-	wms[wms.length-1].gui_maxy[wms[wms.length-1].gui_maxy.length] = maxy;
-function wms_addLayerStyle(styleName, styleTitle, count, layerCount, styleLegendUrl, styleLegendUrlFormat){
-	var currentLayer = wms[wms.length-1].objLayer[layerCount];
-	if (currentLayer) {
-		currentLayer.layer_style[count] = {};
-		currentLayer.layer_style[count].name = styleName;
-		currentLayer.layer_style[count].title = styleTitle;
-		currentLayer.layer_style[count].legendurl = styleLegendUrl;
-		currentLayer.layer_style[count].legendurlformat = styleLegendUrlFormat;
-//TODO: add layerstyle handling....
-//layer
-function wms_add_layer(
-			layer_parent,
-			layer_uid,
-			layer_name,
-			layer_title,
-			layer_dataurl_href,
-			layer_pos,
-			layer_queryable,
-			layer_minscale,
-			layer_maxscale,
-			layer_metadataurl,
-			gui_layer_wms_id,
-			gui_layer_status,
-			gui_layer_style,
-			gui_layer_selectable,
-			gui_layer_visible,
-			gui_layer_queryable,
-			gui_layer_querylayer,
-			gui_layer_minscale,
-			gui_layer_maxscale,
-			gui_layer_wfs_featuretype){
-	wms[wms.length-1].objLayer[wms[wms.length-1].objLayer.length] = new wms_layer(
-											layer_parent,
-											layer_uid,
-											layer_name,
-											layer_title,
-											layer_pos,
-											layer_queryable,
-											layer_minscale,
-											layer_maxscale,
-											gui_layer_wms_id,
-											gui_layer_status,
-											gui_layer_style,
-											parseInt(gui_layer_selectable, 10),
-											parseInt(gui_layer_visible, 10),
-											parseInt(gui_layer_queryable, 10),
-											parseInt(gui_layer_querylayer, 10),
-											parseInt(gui_layer_minscale, 10),
-											parseInt(gui_layer_maxscale, 10),
-											gui_layer_wfs_featuretype );
-	var parentLayer = wms[wms.length-1].getLayerByLayerPos(parseInt(layer_parent, 10));
-	if(parentLayer) {
-		parentLayer.has_childs = true;
-function layer_addEpsg(epsg,minx,miny,maxx,maxy){
-	var j = wms[wms.length-1].objLayer.length-1;
-	var k = wms[wms.length-1].objLayer[j].layer_epsg.length;
-	var currentLayer = wms[wms.length-1].objLayer[j];
-	currentLayer.layer_epsg[k]={};
-	currentLayer.layer_epsg[k].epsg = epsg;
-	currentLayer.layer_epsg[k].minx = minx;
-	currentLayer.layer_epsg[k].miny = miny;
-	currentLayer.layer_epsg[k].maxx = maxx;
-	currentLayer.layer_epsg[k].maxy = maxy;
-function wms_layer(
-			layer_parent,
-			wms_layer_uid,
-			layer_name,
-			layer_title,
-			layer_pos,
-			layer_queryable,
-			layer_minscale,
-			layer_maxscale,
-			gui_layer_wms_id,
-			gui_layer_status,
-			gui_layer_style,
-	this.layer_id = wms_layer_count;
-	this.layer_uid = wms_layer_uid;
-	this.layer_parent = layer_parent;
-	this.layer_name = layer_name;
-	this.layer_title = layer_title;
-	this.layer_dataurl_href = layer_dataurl_href;
-	this.layer_pos = layer_pos;
-	this.layer_queryable = layer_queryable;
-	this.layer_minscale = layer_minscale;
-	this.layer_maxscale = layer_maxscale;
-	this.layer_metadataurl = layer_metadataurl;
-	this.layer_epsg = [];
-	this.gui_layer_wms_id = gui_layer_wms_id;
-	this.gui_layer_status = gui_layer_status;
-	this.gui_layer_selectable = gui_layer_selectable;
-	this.gui_layer_visible = gui_layer_visible;
-	this.gui_layer_queryable = gui_layer_queryable;
-	this.gui_layer_querylayer = gui_layer_querylayer;
-	this.gui_layer_minscale = gui_layer_minscale;
-	this.gui_layer_maxscale = gui_layer_maxscale;
-	this.gui_layer_style = gui_layer_style;
-	this.gui_layer_wfs_featuretype = gui_layer_wfs_featuretype;
-	this.gui_layer_style = null;
-	this.has_childs = false;
-	this.layer_style = [];
-	wms_layer_count++;
- * check the scale of the layer
- * @param Object mapObj the mapbender mapObject of the layer
- * @return boolean if the layer is in scale or not
- * @type boolean
-wms_layer.prototype.checkScale = function(mapObj){
-	var minScale = parseInt(this.gui_layer_minscale, 10);
-	var maxScale = parseInt(this.gui_layer_maxscale, 10);
-	var currentScale = parseInt(mapObj.getScale(), 10);
-	if(minScale === 0 && maxScale === 0){
-		return true;
-	if(minScale > currentScale || (maxScale !== 0 && maxScale < currentScale)) {
-		return false;
-	return true;
- * set visibility of the layer
- * @param boolean visible visibility on/off
-wms_layer.prototype.setVisible = function(visible){
-	this.gui_layer_visible = parseInt(visible, 10);
-	//console.log("setVisible(%i) for Layer %s",visible, this.layer_name);
- * set queryability of the layer
- * @param boolean queryable queryability on/off
-wms_layer.prototype.setQueryable = function(queryable){
-	this.gui_layer_querylayer = parseInt(queryable, 10);
-	//console.log("setQueryable(%i) for Layer %s",queryable, this.layer_name);
Deleted: branches/testbaudson_dev/http/php/database-mysql.php
--- trunk/mapbender/http/php/database-mysql.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/php/database-mysql.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,409 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/database-mysql.php
- * \file
- * \brief MySQL database connection/querying layer
- * MySQL database connection/querying layer
- * example:
- * \code
- * include_once(dirname(__FILE__)."/afwphp/database-mysql.php");
- * $sys_dbhost=...
- * $sys_dbuser=...
- * $sys_dbpasswd=...
- * $sys_dbname=...
- * db_connect();
- * $rs = db_query("select * from table");
- * while($row = db_fetch_array($rs));
- * \endcode
- * System-wide database type
- * @var	constant		$sys_database_type
-$sys_database_type='mysql';
- *  Connect to the database
- *  Notice the global vars that must be set up
- *  Notice the global vars $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname that must be set up
- *  in other functions in this library
-include_once(dirname(__FILE__)."/../../http/classes/class_mb_exception.php");
-include_once(dirname(__FILE__)."/../../http/classes/class_checkInput.php");
-function db_escapestring($unescaped_string){
-	return @mysql_escape_string($unescaped_string);
-function db_escape_string($unescaped_string){
-function db_connect($DBSERVER="",$OWNER="",$PW="") {
-	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,
-		$conn,$conn_update,$sys_db_use_replication,$sys_dbreadhost;
-	if ($DBSERVER)
-		$sys_dbhost = $DBSERVER;
-	if ($OWNER)
-		$sys_dbuser = $OWNER;
-	if ($PW)
-		$sys_dbpasswd = $PW;
-	if (PORT!=''){
-		$sys_dbport = ':'.PORT;
-	else{
-		$sys_dbport = '';
-	if ($sys_db_use_replication) {
-		//  if configured for replication, $conn is the read-only host
-		//  we do not connect to update server until needed
-		$conn = @mysql_pconnect($sys_dbreadhost,$sys_dbuser,$sys_dbpasswd);
-		$conn_update=@mysql_pconnect($sys_dbhost,$sys_dbuser,$sys_dbpasswd);
-	} else {
-		$conn = @mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd);
-		#echo "@mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd)";
-	if ($sys_dbname)
-		@mysql_select_db($sys_dbname);
-	return $conn;
-function db_select_db($DB,$con="") {
-	global $conn,$sys_dbname;
-	$sys_dbname = $DB;
-	$_con = $con ? $con : $conn;
-	$ret = @mysql_select_db($sys_dbname,$_con);
-	if ($ret){
-		return true;
-	else {
-		return false;
-//	echo "$ret=@mysql_select_db($sys_dbname,$_con);";
- *  Query the database
- *  @param		$qstring (string)	SQL statement
- *  @param		$limit (int)		How many rows do you want returned
- *  @param		$offset (int)		Of matching rows, return only rows starting here
-function db_query($qstring,$limit='-1',$offset=0) {
-	global $QUERY_COUNT,$sys_db_use_replication,$sys_db_is_dirty,$DB,
-		$sys_dbname,$conn,$conn_update,$sys_dbhost,$sys_dbuser,$sys_dbpasswd;
-	$QUERY_COUNT++;
-	if(!$sys_dbname && $DB)
-	db_select_db($sys_dbname,$conn);
-	if ($limit > 0) {
-		if (!$offset || $offset < 0) {
-			$offset=0;
-		$qstring=$qstring." LIMIT $offset,$limit";
-//	if ($GLOBALS['IS_DEBUG'])
-		$GLOBALS['G_DEBUGQUERY'] .= $qstring . "<P><BR>\n";
-	//are we configured to try to use replication?
-		//if we haven't yet done an insert/update,
-		//read from the read-only db
-		if (!$sys_db_is_dirty && mb_eregi("^( )*(select)",$qstring)) {
-			if ($QUERY_COUNT%3==0) {
-				// 1/3rd of read queries go to master for now
-				return @mysql_db_query($sys_dbname,$qstring,$conn_update);
-			} else {
-				return @mysql_db_query($sys_dbname,$qstring,$conn);
-		} else {
-			//must be an update/insert/delete query - go to master server
-			$sys_db_is_dirty=true;
-	} else {
-		$ret = @mysql_db_query($sys_dbname,$qstring,$conn);
-//		echo "@mysql_db_query($sys_dbname,$qstring,$conn); ret=$ret<br>";
-		if(!$ret){
-			$e = new mb_exception("db_query($qstring)=$ret db_error=".db_error());
-		return $ret;
-	//echo "SQL__".$qstring;
- *  prepare and query the database
- *  @param		$params (array string params)
- *  @param		$types (array string types)
-function db_prep_query($qstring, $params, $types){
-	$ci = new checkInput($qstring,$params,$types);
-	$params = $ci->v;
-	for ($i=0; $i<count($params); $i++){
-		$needle = "$".strval($i+1);
-		$tmp = '';
-		if($params[$i] !== NULL){
-			if($types[$i] == 's'){ $tmp .= "'"; }
-			$tmp .= $params[$i];
-		else{
-			$tmp .= "NULL";
-		$posa = mb_strpos($qstring, $needle);
-		$posb = mb_strlen($needle);
-		$qstring = mb_substr($qstring,0,$posa).$tmp.mb_substr($qstring,($posa + $posb));
-	$r = db_query($qstring);
-	return $r;
- *	Begin a transaction
- *	Begin a transaction for databases that support them
- *	may cause unexpected behavior in databases that don't
-function db_begin() {
-	return db_query("BEGIN WORK");
- * Commit a transaction
- * Commit a transaction for databases that support them
-function db_commit() {
-	return db_query("COMMIT");
- * Roll back a transaction
- * Rollback a transaction for databases that support them
-function db_rollback() {
-	$str = db_error();
-	db_query("ROLLBACK");
-	die('sql error: ' . $str . " ROLLBACK performed....");
- * Returns the number of rows in this result set
- *  @param		$qhandle (string)	Query result set handle
-function db_numrows($qhandle) {
-	// return only if qhandle exists, otherwise 0
-	if ($qhandle) {
-		return @mysql_numrows($qhandle);
-	} else {
-		return 0;
- * php 3,4,5
-function db_num_rows($qhandle) {
-	if ($qhandle) {
-		return @mysql_num_rows($qhandle);
-	} else {
-		return 0;
- *  Frees a database result properly
-function db_free_result($qhandle) {
-	return @mysql_free_result($qhandle);
- *  Reset a result set.
- *  Reset is useful for db_fetch_array sometimes you need to start over
- *  @param		$row (int)		Row number
-function db_reset_result($qhandle,$row=0) {
-	return mysql_data_seek($qhandle,$row);
- *  Returns a field from a result set
- *  @param		$field (string)	Field name
-function db_result($qhandle,$row,$field) {
-	return @mysql_result($qhandle,$row,$field);
- *  Returns the number of fields in this result set
- *  @param		$lhandle (string)	Query result set handle
-function db_numfields($lhandle) {
-	return @mysql_numfields($lhandle);
- * php 3,4,5
-function db_num_fields($lhandle) {
-	return @mysql_num_fields($lhandle);
- *  Returns the number of rows changed in the last query
- *  @param		$fnumber (int)	Column number
-function db_fieldname($lhandle,$fnumber) {
-	   return @mysql_fieldname($lhandle,$fnumber);
-function db_affected_rows($qhandle) {
-	return @mysql_affected_rows();
- *  Fetch an array
- *  Returns an associative array from
- *  the current row of this database result
- *  Use db_reset_result to seek a particular row
-function db_fetch_array($qhandle) {
-	return @mysql_fetch_array($qhandle);
- * fetch a row into an array
-function db_fetch_row($qhandle,$fnumber=0) {
-	  return @mysql_fetch_row($qhandle);
- *  Returns the last primary key from an insert
- *  @param		$table_name (string)	Is the name of the table you inserted into
- *  @param		$pkey_field_name (string)	Is the field name of the primary key
-function db_insertid($qhandle="",$table_name="",$pkey_field_name="") {
-	return @mysql_insert_id();
-function db_insert_id($qhandle="",$table_name="",$pkey_field_name="") {
- * Returns the last error from the database
-function db_error() {
-	return @mysql_error();
- * Get the flags associated with the specified field in a result
- * 					Examples: "not_null", "primary_key", "unique_key", "multiple_key",
- *                    "blob", "unsigned", "zerofill","binary", "enum",
- *                    "auto_increment", "timestamp"
-function db_field_flags($lhandle,$fnumber) {
-	   return @mysql_field_flags($lhandle,$fnumber);
- * Get the type of the specified field
-function db_field_type($lhandle,$fnumber) {
-	   return @mysql_field_type($lhandle,$fnumber);
- * Get the length of the specified field
-function db_field_len($lhandle,$fnumber) {
-	   return @mysql_field_len($lhandle,$fnumber);
Deleted: branches/testbaudson_dev/http/php/database-pgsql.php
--- trunk/mapbender/http/php/database-pgsql.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/php/database-pgsql.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,436 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/database-pgsql.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
- * \file
- * example:
- * \code
- * $sys_dbhost=...
- * $sys_dbuser=...
- * $sys_dbname=...
- * db_connect();
- * \endcode
-$sys_database_type='pgsql';
-	return @pg_escape_string(stripslashes($unescaped_string));
-$DB = DB;
-	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,$db_debug;
-	global $conn,$conn_update,$DB;
-	$db_debug=0;
-	if ($DBSERVER)
-	if ($OWNER)
-	if ($PW && $PW != null)
-	$sys_dbport = PORT;
-	if($GLOBALS['DB'])
-	$connstring = "";
-	if ($sys_dbuser)
-		$connstring.=" user=$sys_dbuser";
-	if ($sys_dbname)
-		$connstring.=" dbname=$sys_dbname";
-	if ($sys_dbhost)
-		$connstring.=" host=$sys_dbhost";
-	if ($sys_dbport)
-		$connstring.=" port=$sys_dbport";
-	if ($sys_dbpasswd)
-		$connstring.=" password=$sys_dbpasswd";
-	if ($db_debug)
-		echo $connstring." ";
-	$conn = pg_connect($connstring);
-		#if(isset($sys_db_clientencoding) && $sys_db_clientencoding > "")
-		#pg_set_client_encoding ( $conn, $sys_db_clientencoding);
-	#return $conn;
-	if ($db_debug)
-		echo "conn=".$conn;
-#echo $connstring;
-#if(!$conn)
-#{echo "FEHLER in Connection";
-#pg_error($conn);}
-	return $conn;
-#	$sys_dbname = DB;
-#	$_con = $con ? $con : $conn;
-#	$ret = @mysql_select_db($sys_dbname,$_con);
-function db_query($qstring) {
-	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,$db_debug,
-		$conn,$conn_update,$QUERY_COUNT,$DBSERVER,$OWNER,$PW,$DB;
-	$QUERY_COUNT++;
-	$ret = pg_exec($qstring);
-//	$e = new mb_exception("not ps:  ".$_SERVER['SCRIPT_FILENAME']." : ".$qstring);
-	if(!$ret){
-	return $ret;
- *  @param		$params (array params as strings)
- *  @param		$types (array types as strings)
-	$params = $ci->v;
-	if(PREPAREDSTATEMENTS == false){
-			$tmp = '';
-			else{
-				$tmp .= "NULL";
-		if(!$r){
-			$e = new mb_exception("Error while executing sql statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-	else{
-		$result = pg_prepare("", $qstring);
-		if(!$result){
-			$e = new mb_exception("Error while preparing statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-		$r = pg_execute("", $params);
-		if(!$r){
-			$e = new mb_exception("Error while executing prepared statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-	return $r;
-	if ($qhandle) {
-		return @pg_numrows($qhandle);
-	} else {
-		return 0;
- *	php > 4.2
-	if ($qhandle) {
-		return @pg_num_rows($qhandle);
-	} else {
-		return 0;
-	return @pg_freeresult($qhandle);
-#dummy
-	return 0;#mysql_data_seek($qhandle,$row);
-	return @pg_result($qhandle,$row,$field);
-	return @pg_numfields($lhandle);
- *	php >4.2
-	return @pg_num_fields($lhandle);
-	   return @pg_fieldname($lhandle,$fnumber);
-	return @pg_cmdtuples($qhandle);
- *  Fetch an array
-	return @pg_fetch_array($qhandle);
-function db_fetch_all($qhandle){
-		return @pg_fetch_all($qhandle);
-	  return pg_fetch_row($qhandle);
-	$res=db_query("SELECT max($pkey_field_name) AS id FROM $table_name");
-    if ($res && db_numrows($res) > 0) {
-        return @db_result($res,0,'id');
-    } else {
-        return 0;
-	$oid =pg_last_oid($qhandle);
-	echo $oid;
-	$res=db_query("SELECT ".$pkey_field_name." FROM ".$table_name." WHERE oid =".$oid );
-        return @db_result($res,0,0);
-    } else {
-        return 0;
-        return db_result($res,0,'id');
-    } else {
-        return 0;
-function db_last_oid()
-		$conn,$conn_update,$QUERY_COUNT;
-        global $DBSERVER,$OWNER,$PW,$DB	;
-             return pg_getlastoid($conn);
-	return @pg_last_error();
-	   print "db_field_flags()	isn't implemented";
-	   return @pg_fieldtype($lhandle,$fnumber);
-	   return @pg_fieldlen($lhandle,$fnumber);
Modified: branches/testbaudson_dev/http/php/mod_editApplication.php
--- trunk/mapbender/http/php/mod_editApplication.php	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/http/php/mod_editApplication.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -18,8 +18,8 @@
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-require_once(dirname(__FILE__)."/../classes/class_user.php");
+require_once(dirname(__FILE__)."/../../lib/administration.php");
+require_once(dirname(__FILE__)."/../../lib/user.php");
 $editApplicationId = $_REQUEST["editApplicationId"];
@@ -57,19 +57,19 @@
 </style>
 <link rel='stylesheet' type='text/css' href='../css/popup.css'>
-<script type='text/javascript' src='../extensions/jquery-1.2.6.min.js'></script>
-<script type='text/javascript' src='../extensions/jquery-ui-personalized-1.5.min.js'></script>
-<script type='text/javascript' src='../extensions/jqjson.js'></script>
-<script type='text/javascript' src='../javascripts/popup.js'></script>
 <script language="JavaScript" type="text/javascript">
 <?php
-	include("../../lib/event.js");
-	include("../../lib/buttonNew.js");
-	include("../../lib/draggableButton.js");
-	include("../../lib/selectableButton.js");
-	include("../../lib/resizableButton.js");
-	include("../../lib/alignButton.js");
-	include("../../lib/saveButton.js");
+require_once(dirname(__FILE__)."/../../ext/jquery-1.2.6.min.js");
+require_once(dirname(__FILE__)."/../../ext/jquery-ui-personalized-1.5.min.js");
+require_once(dirname(__FILE__)."/../../ext/jqjson.js");
+require_once(dirname(__FILE__)."/../javascripts/popup.js");
+require_once(dirname(__FILE__)."/../../lib/event.js");
+require_once(dirname(__FILE__)."/../../lib/buttonNew.js");
+require_once(dirname(__FILE__)."/../../mod/editApplication/draggableButton.js");
+require_once(dirname(__FILE__)."/../../mod/editApplication/selectableButton.js");
+require_once(dirname(__FILE__)."/../../mod/editApplication/resizableButton.js");
+require_once(dirname(__FILE__)."/../../mod/editApplication/alignButton.js");
+require_once(dirname(__FILE__)."/../../mod/editApplication/saveButton.js");
 	echo "var editApplicationId = '" . $editApplicationId . "';";
Deleted: branches/testbaudson_dev/lib/alignButton.js
--- trunk/mapbender/lib/alignButton.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/lib/alignButton.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,99 +0,0 @@
-var Align = {
-	top : {
-		buttonParameters : {
-			on:"../img/button_blink_red/up_on.png",
-			over:"../img/button_blink_red/up_on.png",
-			off:"../img/button_blink_red/up_off.png",
-			type:"singular"
-		align : function () {
-			if ($(".ui-selected").size() < 2) {
-				return false;
-			var minY;
-			$(".ui-selected").each(function() {
-				var currentMinY = parseInt(this.style.top);
-				if ((!minY && minY !== 0 ) || currentMinY < minY) {
-					minY = currentMinY;
-				this.style.top = minY + "px";
-	left : {
-			on:"../img/button_blink_red/back_on.png",
-			over:"../img/button_blink_red/back_on.png",
-			off:"../img/button_blink_red/back_off.png",
-			type:"singular"
-				return false;
-			var minX;
-				var currentMinX = parseInt(this.style.left);
-				if ((!minX && minX !== 0 ) || currentMinX < minX) {
-					minX = currentMinX;
-				this.style.left = minX + "px";
-	bottom : {
-			on:"../img/button_blink_red/down_on.png",
-			over:"../img/button_blink_red/down_on.png",
-			off:"../img/button_blink_red/down_off.png",
-			type:"singular"
-				return false;
-			var maxY;
-				var currentMaxY = parseInt(this.style.top) + parseInt(this.style.height);
-				if ((!maxY && maxY !== 0) || currentMaxY > maxY) {
-					maxY = currentMaxY;
-				var newY = maxY - parseInt(this.style.height);
-				this.style.top = newY + "px";
-	right : {
-			on:"../img/button_blink_red/forward_on.png",
-			over:"../img/button_blink_red/forward_on.png",
-			off:"../img/button_blink_red/forward_off.png",
-			type:"singular"
-				return false;
-			var maxX;
-				var currentMaxX = parseInt(this.style.left) + parseInt(this.style.width);
-				if ((!maxX && maxX !== 0) || currentMaxX > maxX) {
-					maxX = currentMaxX;
-				var newX = maxX - parseInt(this.style.width);
-				this.style.left = newX + "px";
Modified: branches/testbaudson_dev/lib/core.js
--- trunk/mapbender/lib/core.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/lib/core.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -36,54 +36,6 @@
  * Triggered before a feature info is requested.
 var eventBeforeFeatureInfo = new MapbenderEvent();
-eventBeforeFeatureInfo.register(function() {
-	for (var j=0; j<mb_mapObj.length; j++) {
-		var mapObj = mb_mapObj[j];
-		var cnt_layers;
-		var styles;
-		var layers;
-		var querylayers = "";
-		for(i=0; i< mapObj.wms.length; i++){
-			cnt_layers = 0;
-			styles = "";
-			layers = "";
-			querylayers = "";
-			for(var ii=0; ii<mapObj.wms[i].objLayer.length; ii++){
-				if(mapObj.wms[i].objLayer[ii].gui_layer_visible == 1 && ii>0){
-					if(cnt_layers > 0){
-					styles += "";
-					cnt_layers++;
-				if(mapObj.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii>0){
-					if(cnt_querylayers > 0){
-					cnt_querylayers++;
-			mapObj.layers[i] = layers;
-			mapObj.styles[i] = styles;
-			mapObj.querylayers[i] = querylayers;
  * Triggered after a WMS has been loaded.
@@ -105,13 +57,6 @@
 var eventInitMap = new MapbenderEvent();
-eventInit.register(function() {
-	$lm = $("#loading_mapbender");
-	$cm = $("#complete_mapbender");
-	$lm.empty();
-	$cm.show();
  * Switches the locale. Triggered by module switch_locale or onload(?)
@@ -234,6 +179,14 @@
 	eventAfterInit.trigger();
+eventInit.register(function() {
+	$lm = $("#loading_mapbender");
+	$cm = $("#complete_mapbender");
+	$lm.empty();
+	$cm.show();
  * deprecated function for writing content within a tag via innerHTML
  * @deprecated
@@ -245,4 +198,4 @@
   else if(!frameName || frameName === ""){
        document.getElementById(elName).innerHTML = tagSource;
Copied: branches/testbaudson_dev/lib/database-mysql.php (from rev 2556, trunk/mapbender/http/php/database-mysql.php)
--- branches/testbaudson_dev/lib/database-mysql.php	                        (rev 0)
+++ branches/testbaudson_dev/lib/database-mysql.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,410 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/database-mysql.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+ * \file
+ * \brief MySQL database connection/querying layer
+ * MySQL database connection/querying layer
+ * example:
+ * \code
+ * include_once(dirname(__FILE__)."/afwphp/database-mysql.php");
+ * $sys_dbhost=...
+ * $sys_dbuser=...
+ * $sys_dbpasswd=...
+ * $sys_dbname=...
+ * db_connect();
+ * $rs = db_query("select * from table");
+ * while($row = db_fetch_array($rs));
+ * \endcode
+ * System-wide database type
+ * @var	constant		$sys_database_type
+$sys_database_type='mysql';
+ *  Connect to the database
+ *  Notice the global vars that must be set up
+ *  Notice the global vars $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname that must be set up
+ *  in other functions in this library
+include_once(dirname(__FILE__)."/exception.php");
+include_once(dirname(__FILE__)."/checkInput.php");
+function db_escapestring($unescaped_string){
+	return @mysql_escape_string($unescaped_string);
+function db_escape_string($unescaped_string){
+function db_connect($DBSERVER="",$OWNER="",$PW="") {
+	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,
+		$conn,$conn_update,$sys_db_use_replication,$sys_dbreadhost;
+	if ($DBSERVER)
+		$sys_dbhost = $DBSERVER;
+	if ($OWNER)
+		$sys_dbuser = $OWNER;
+	if ($PW)
+		$sys_dbpasswd = $PW;
+	if (PORT!=''){
+		$sys_dbport = ':'.PORT;
+	else{
+		$sys_dbport = '';
+	if ($sys_db_use_replication) {
+		//  if configured for replication, $conn is the read-only host
+		//  we do not connect to update server until needed
+		$conn = @mysql_pconnect($sys_dbreadhost,$sys_dbuser,$sys_dbpasswd);
+		$conn_update=@mysql_pconnect($sys_dbhost,$sys_dbuser,$sys_dbpasswd);
+	} else {
+		$conn = @mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd);
+		#echo "@mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd)";
+	if ($sys_dbname)
+		@mysql_select_db($sys_dbname);
+	return $conn;
+function db_select_db($DB,$con="") {
+	global $conn,$sys_dbname;
+	$sys_dbname = $DB;
+	$_con = $con ? $con : $conn;
+	$ret = @mysql_select_db($sys_dbname,$_con);
+	if ($ret){
+		return true;
+	else {
+		return false;
+//	echo "$ret=@mysql_select_db($sys_dbname,$_con);";
+ *  Query the database
+ *  @param		$qstring (string)	SQL statement
+ *  @param		$limit (int)		How many rows do you want returned
+ *  @param		$offset (int)		Of matching rows, return only rows starting here
+function db_query($qstring,$limit='-1',$offset=0) {
+	global $QUERY_COUNT,$sys_db_use_replication,$sys_db_is_dirty,$DB,
+		$sys_dbname,$conn,$conn_update,$sys_dbhost,$sys_dbuser,$sys_dbpasswd;
+	$QUERY_COUNT++;
+	if(!$sys_dbname && $DB)
+	db_select_db($sys_dbname,$conn);
+	if ($limit > 0) {
+		if (!$offset || $offset < 0) {
+			$offset=0;
+		$qstring=$qstring." LIMIT $offset,$limit";
+//	if ($GLOBALS['IS_DEBUG'])
+		$GLOBALS['G_DEBUGQUERY'] .= $qstring . "<P><BR>\n";
+	//are we configured to try to use replication?
+		//if we haven't yet done an insert/update,
+		//read from the read-only db
+		if (!$sys_db_is_dirty && mb_eregi("^( )*(select)",$qstring)) {
+			if ($QUERY_COUNT%3==0) {
+				// 1/3rd of read queries go to master for now
+				return @mysql_db_query($sys_dbname,$qstring,$conn_update);
+			} else {
+				return @mysql_db_query($sys_dbname,$qstring,$conn);
+		} else {
+			//must be an update/insert/delete query - go to master server
+			$sys_db_is_dirty=true;
+	} else {
+		$ret = @mysql_db_query($sys_dbname,$qstring,$conn);
+//		echo "@mysql_db_query($sys_dbname,$qstring,$conn); ret=$ret<br>";
+		if(!$ret){
+			$e = new mb_exception("db_query($qstring)=$ret db_error=".db_error());
+		return $ret;
+	//echo "SQL__".$qstring;
+ *  prepare and query the database
+ *  @param		$params (array string params)
+ *  @param		$types (array string types)
+function db_prep_query($qstring, $params, $types){
+	$ci = new checkInput($qstring,$params,$types);
+	$params = $ci->v;
+	for ($i=0; $i<count($params); $i++){
+		$needle = "$".strval($i+1);
+		$tmp = '';
+		if($params[$i] !== NULL){
+			if($types[$i] == 's'){ $tmp .= "'"; }
+			$tmp .= $params[$i];
+		else{
+			$tmp .= "NULL";
+		$posa = mb_strpos($qstring, $needle);
+		$posb = mb_strlen($needle);
+		$qstring = mb_substr($qstring,0,$posa).$tmp.mb_substr($qstring,($posa + $posb));
+	$r = db_query($qstring);
+	return $r;
+ *	Begin a transaction
+ *	Begin a transaction for databases that support them
+ *	may cause unexpected behavior in databases that don't
+function db_begin() {
+	return db_query("BEGIN WORK");
+ * Commit a transaction
+ * Commit a transaction for databases that support them
+function db_commit() {
+	return db_query("COMMIT");
+ * Roll back a transaction
+ * Rollback a transaction for databases that support them
+function db_rollback() {
+	$str = db_error();
+	db_query("ROLLBACK");
+	die('sql error: ' . $str . " ROLLBACK performed....");
+ * Returns the number of rows in this result set
+ *  @param		$qhandle (string)	Query result set handle
+function db_numrows($qhandle) {
+	// return only if qhandle exists, otherwise 0
+	if ($qhandle) {
+		return @mysql_numrows($qhandle);
+	} else {
+		return 0;
+ * php 3,4,5
+function db_num_rows($qhandle) {
+	if ($qhandle) {
+		return @mysql_num_rows($qhandle);
+	} else {
+		return 0;
+ *  Frees a database result properly
+function db_free_result($qhandle) {
+	return @mysql_free_result($qhandle);
+ *  Reset a result set.
+ *  Reset is useful for db_fetch_array sometimes you need to start over
+ *  @param		$row (int)		Row number
+function db_reset_result($qhandle,$row=0) {
+	return mysql_data_seek($qhandle,$row);
+ *  Returns a field from a result set
+ *  @param		$field (string)	Field name
+function db_result($qhandle,$row,$field) {
+	return @mysql_result($qhandle,$row,$field);
+ *  Returns the number of fields in this result set
+ *  @param		$lhandle (string)	Query result set handle
+function db_numfields($lhandle) {
+	return @mysql_numfields($lhandle);
+ * php 3,4,5
+function db_num_fields($lhandle) {
+	return @mysql_num_fields($lhandle);
+ *  Returns the number of rows changed in the last query
+ *  @param		$fnumber (int)	Column number
+function db_fieldname($lhandle,$fnumber) {
+	   return @mysql_fieldname($lhandle,$fnumber);
+function db_affected_rows($qhandle) {
+	return @mysql_affected_rows();
+ *  Fetch an array
+ *  Returns an associative array from
+ *  the current row of this database result
+ *  Use db_reset_result to seek a particular row
+function db_fetch_array($qhandle) {
+	return @mysql_fetch_array($qhandle);
+ * fetch a row into an array
+function db_fetch_row($qhandle,$fnumber=0) {
+	  return @mysql_fetch_row($qhandle);
+ *  Returns the last primary key from an insert
+ *  @param		$table_name (string)	Is the name of the table you inserted into
+ *  @param		$pkey_field_name (string)	Is the field name of the primary key
+function db_insertid($qhandle="",$table_name="",$pkey_field_name="") {
+	return @mysql_insert_id();
+function db_insert_id($qhandle="",$table_name="",$pkey_field_name="") {
+ * Returns the last error from the database
+function db_error() {
+	return @mysql_error();
+ * Get the flags associated with the specified field in a result
+ * 					Examples: "not_null", "primary_key", "unique_key", "multiple_key",
+ *                    "blob", "unsigned", "zerofill","binary", "enum",
+ *                    "auto_increment", "timestamp"
+function db_field_flags($lhandle,$fnumber) {
+	   return @mysql_field_flags($lhandle,$fnumber);
+ * Get the type of the specified field
+function db_field_type($lhandle,$fnumber) {
+	   return @mysql_field_type($lhandle,$fnumber);
+ * Get the length of the specified field
+function db_field_len($lhandle,$fnumber) {
+	   return @mysql_field_len($lhandle,$fnumber);
Copied: branches/testbaudson_dev/lib/database-pgsql.php (from rev 2556, trunk/mapbender/http/php/database-pgsql.php)
--- branches/testbaudson_dev/lib/database-pgsql.php	                        (rev 0)
+++ branches/testbaudson_dev/lib/database-pgsql.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,436 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/database-pgsql.php
+ * \file
+ * example:
+ * \code
+ * $sys_dbhost=...
+ * $sys_dbuser=...
+ * $sys_dbname=...
+ * db_connect();
+ * \endcode
+$sys_database_type='pgsql';
+	return @pg_escape_string(stripslashes($unescaped_string));
+$DB = DB;
+	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,$db_debug;
+	global $conn,$conn_update,$DB;
+	$db_debug=0;
+	if ($DBSERVER)
+	if ($OWNER)
+	if ($PW && $PW != null)
+	$sys_dbport = PORT;
+	if($GLOBALS['DB'])
+	$connstring = "";
+	if ($sys_dbuser)
+		$connstring.=" user=$sys_dbuser";
+	if ($sys_dbname)
+		$connstring.=" dbname=$sys_dbname";
+	if ($sys_dbhost)
+		$connstring.=" host=$sys_dbhost";
+	if ($sys_dbport)
+		$connstring.=" port=$sys_dbport";
+	if ($sys_dbpasswd)
+		$connstring.=" password=$sys_dbpasswd";
+	if ($db_debug)
+		echo $connstring." ";
+	$conn = pg_connect($connstring);
+		#if(isset($sys_db_clientencoding) && $sys_db_clientencoding > "")
+		#pg_set_client_encoding ( $conn, $sys_db_clientencoding);
+	#return $conn;
+	if ($db_debug)
+		echo "conn=".$conn;
+#echo $connstring;
+#if(!$conn)
+#{echo "FEHLER in Connection";
+#pg_error($conn);}
+	return $conn;
+#	$sys_dbname = DB;
+#	$_con = $con ? $con : $conn;
+#	$ret = @mysql_select_db($sys_dbname,$_con);
+function db_query($qstring) {
+	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,$db_debug,
+		$conn,$conn_update,$QUERY_COUNT,$DBSERVER,$OWNER,$PW,$DB;
+	$QUERY_COUNT++;
+	$ret = pg_exec($qstring);
+//	$e = new mb_exception("not ps:  ".$_SERVER['SCRIPT_FILENAME']." : ".$qstring);
+	if(!$ret){
+	return $ret;
+ *  @param		$params (array params as strings)
+ *  @param		$types (array types as strings)
+	$params = $ci->v;
+	if(PREPAREDSTATEMENTS == false){
+			$tmp = '';
+			else{
+				$tmp .= "NULL";
+		if(!$r){
+			$e = new mb_exception("Error while executing sql statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
+	else{
+		$result = pg_prepare("", $qstring);
+		if(!$result){
+			$e = new mb_exception("Error while preparing statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
+		$r = pg_execute("", $params);
+		if(!$r){
+			$e = new mb_exception("Error while executing prepared statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
+	return $r;
+	if ($qhandle) {
+		return @pg_numrows($qhandle);
+	} else {
+		return 0;
+ *	php > 4.2
+	if ($qhandle) {
+		return @pg_num_rows($qhandle);
+	} else {
+		return 0;
+	return @pg_freeresult($qhandle);
+#dummy
+	return 0;#mysql_data_seek($qhandle,$row);
+	return @pg_result($qhandle,$row,$field);
+	return @pg_numfields($lhandle);
+ *	php >4.2
+	return @pg_num_fields($lhandle);
+	   return @pg_fieldname($lhandle,$fnumber);
+	return @pg_cmdtuples($qhandle);
+ *  Fetch an array
+	return @pg_fetch_array($qhandle);
+function db_fetch_all($qhandle){
+		return @pg_fetch_all($qhandle);
+	  return pg_fetch_row($qhandle);
+	$res=db_query("SELECT max($pkey_field_name) AS id FROM $table_name");
+    if ($res && db_numrows($res) > 0) {
+        return @db_result($res,0,'id');
+    } else {
+        return 0;
+	$oid =pg_last_oid($qhandle);
+	echo $oid;
+	$res=db_query("SELECT ".$pkey_field_name." FROM ".$table_name." WHERE oid =".$oid );
+        return @db_result($res,0,0);
+    } else {
+        return 0;
+        return db_result($res,0,'id');
+    } else {
+        return 0;
+function db_last_oid()
+		$conn,$conn_update,$QUERY_COUNT;
+        global $DBSERVER,$OWNER,$PW,$DB	;
+             return pg_getlastoid($conn);
+	return @pg_last_error();
+	   print "db_field_flags()	isn't implemented";
+	   return @pg_fieldtype($lhandle,$fnumber);
+	   return @pg_fieldlen($lhandle,$fnumber);
Deleted: branches/testbaudson_dev/lib/draggableButton.js
--- trunk/mapbender/lib/draggableButton.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/lib/draggableButton.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,98 +0,0 @@
-var Draggable = {
-		on:"../img/button_blink_red/pan_on.png",
-		over:"../img/button_blink_red/pan_over.png",
-		off:"../img/button_blink_red/pan_off.png",
-		type:"toggle"
-	grid : [7,7],
-	makeDraggable : function() {
-		var $selection = $(".ui-selected");
-		if ($selection.size() > 0) {
-			// if elements have been selected, we want to drag
-			// them together, not individually. So we move these
-			// elements into a new div tag, and make that tag
-			// draggable
-			Draggable.moveSelectionToDiv();
-			$(".div-draggable").draggable({
-				grid:Draggable.grid
-		else {
-			$(".collection").children().draggable({
-	removeDraggable : function () {
-		if ($(".ui-selected").size() > 0) {
-			Draggable.moveSelectionFromDiv();
-		$(".collection").children().draggable("destroy");
-	moveSelectionFromDiv : function () {
-		var divX, divY;
-		var $draggableDiv = $(".div-draggable");
-		$draggableDiv.each(function() {
-			divX = parseInt(this.style.left);
-			divY = parseInt(this.style.top);
-		$draggableDiv.children().each(function() {
-			var newX = parseInt(this.style.left) + divX;
-			var newY = parseInt(this.style.top) + divY;
-			$(this).removeClass("ui-selectee");
-			$(this).removeClass("ui-selected");
-			$(this).addClass("div-border");
-			$clone = $(this).clone();
-			$(".collection").append($clone);
-		$draggableDiv.remove();
-	moveSelectionToDiv : function () {
-		// first, put all selected elements inside a
-		// single div tag; then, make that div tag
-		// draggable
-		// the coordinates of the new div tag need
-		// to be computed first
-		var minX, minY;
-			var currentLeft = parseInt(this.style.left);
-			if ((!minX && minX !== 0) || currentLeft < minX) {
-				minX = currentLeft;
-			var currentTop = parseInt(this.style.top);
-			if ((!minY && minY !== 0) || currentTop < minY) {
-				minY = currentTop;
-		var $div = $("<div class='div-draggable'></div>");
-		$div.css("position", "absolute");
-		$div.css("top", minY);
-		$div.css("left", minX);
-		// to move the selected nodes, we clone them and attach
-		// them to the new div. the old tags are removed
-			var newX = parseInt(this.style.left) - minX;
-			var newY = parseInt(this.style.top) - minY;
-			$clone.css("position", "absolute");
-			$clone.css("top", newY + "px");
-			$clone.css("left", newX + "px");
-			$div.append($clone);
-			$(this).remove();
-		$div.appendTo($(".collection"));
Deleted: branches/testbaudson_dev/lib/resizableButton.js
--- trunk/mapbender/lib/resizableButton.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/lib/resizableButton.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,18 +0,0 @@
-var Resizable = {
-		on:"../img/button_blink_red/select_rectangle_on.png",
-		over:"../img/button_blink_red/select_rectangle_over.png",
-		off:"../img/button_blink_red/select_rectangle_off.png",
-		type:"toggle"
-	makeResizable : function () {
-		var selector = ".collection > div";
-		$all = $(selector);
-		$all.resizable();
-	removeResizable : function () {
-		$all.resizable("destroy");
Deleted: branches/testbaudson_dev/lib/saveButton.js
--- trunk/mapbender/lib/saveButton.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/lib/saveButton.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,34 +0,0 @@
-var Save = {
-		on:"../img/button_blink_red/wmc_save_on.png",
-		over:"../img/button_blink_red/wmc_save_over.png",
-		off:"../img/button_blink_red/wmc_save_off.png",
-		type:"toggle"
-	updateDatabase : function (callback) {
-		var data = [];
-		$(".collection").children().each(function() {
-			data.push({
-				id:this.id,
-				top:parseInt(this.style.top),
-				left:parseInt(this.style.left),
-				width:parseInt(this.style.width),
-				height:parseInt(this.style.height)
-		var queryObj = {
-			command:"update",
-			parameters:{
-				applicationId:editApplicationId,
-				data:data
-		$.post("mod_editApplication_server.php", {
-			queryObj:$.toJSON(queryObj)
-		}, function (json, status) {
-			var replyObj = eval('(' + json + ')');
-			alert(replyObj.success);
-			callback();
Deleted: branches/testbaudson_dev/lib/selectableButton.js
--- trunk/mapbender/lib/selectableButton.js	2008-06-24 12:33:05 UTC (rev 2556)
+++ branches/testbaudson_dev/lib/selectableButton.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -1,32 +0,0 @@
-var Selectable = {
-		on:"../img/button_blink_red/selArea_on.png",
-		over:"../img/button_blink_red/selArea_over.png",
-		off:"../img/button_blink_red/selArea_off.png",
-		type:"toggle"
-	makeSelectable : function () {
-		// if a selection has been made, remove it
-			Selectable.removeSelection();
-		$all = $(".collection");
-		$all.selectable({
-			selecting:function() {
-				$(".ui-selecting").removeClass("div-border");
-			unselecting:function() {
-				$(".ui-selectee").addClass("div-border");
-	removeSelection : function () {
-		$(".ui-selected").addClass("div-border");
-		$(".collection").selectable("destroy");
-		$(".ui-selected").removeClass("ui-selected");
-		$(".ui-selectee").removeClass("ui-selectee");
-		$(".ui-selectable").removeClass("ui-selectable");
Added: branches/testbaudson_dev/mod/body/body.js
--- branches/testbaudson_dev/mod/body/body.js	                        (rev 0)
+++ branches/testbaudson_dev/mod/body/body.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,6 @@
+	$lm.empty();
+	$cm.show();
Copied: branches/testbaudson_dev/mod/editApplication/alignButton.js (from rev 2556, trunk/mapbender/lib/alignButton.js)
--- branches/testbaudson_dev/mod/editApplication/alignButton.js	                        (rev 0)
+++ branches/testbaudson_dev/mod/editApplication/alignButton.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,99 @@
+var Align = {
+	top : {
+		buttonParameters : {
+			on:"../img/button_blink_red/up_on.png",
+			over:"../img/button_blink_red/up_on.png",
+			off:"../img/button_blink_red/up_off.png",
+			type:"singular"
+		align : function () {
+			if ($(".ui-selected").size() < 2) {
+				return false;
+			var minY;
+			$(".ui-selected").each(function() {
+				var currentMinY = parseInt(this.style.top);
+				if ((!minY && minY !== 0 ) || currentMinY < minY) {
+					minY = currentMinY;
+				this.style.top = minY + "px";
+	left : {
+			on:"../img/button_blink_red/back_on.png",
+			over:"../img/button_blink_red/back_on.png",
+			off:"../img/button_blink_red/back_off.png",
+			type:"singular"
+				return false;
+			var minX;
+				var currentMinX = parseInt(this.style.left);
+				if ((!minX && minX !== 0 ) || currentMinX < minX) {
+					minX = currentMinX;
+				this.style.left = minX + "px";
+	bottom : {
+			on:"../img/button_blink_red/down_on.png",
+			over:"../img/button_blink_red/down_on.png",
+			off:"../img/button_blink_red/down_off.png",
+			type:"singular"
+				return false;
+			var maxY;
+				var currentMaxY = parseInt(this.style.top) + parseInt(this.style.height);
+				if ((!maxY && maxY !== 0) || currentMaxY > maxY) {
+					maxY = currentMaxY;
+				var newY = maxY - parseInt(this.style.height);
+				this.style.top = newY + "px";
+	right : {
+			on:"../img/button_blink_red/forward_on.png",
+			over:"../img/button_blink_red/forward_on.png",
+			off:"../img/button_blink_red/forward_off.png",
+			type:"singular"
+				return false;
+			var maxX;
+				var currentMaxX = parseInt(this.style.left) + parseInt(this.style.width);
+				if ((!maxX && maxX !== 0) || currentMaxX > maxX) {
+					maxX = currentMaxX;
+				var newX = maxX - parseInt(this.style.width);
+				this.style.left = newX + "px";
Copied: branches/testbaudson_dev/mod/editApplication/draggableButton.js (from rev 2556, trunk/mapbender/lib/draggableButton.js)
--- branches/testbaudson_dev/mod/editApplication/draggableButton.js	                        (rev 0)
+++ branches/testbaudson_dev/mod/editApplication/draggableButton.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,98 @@
+var Draggable = {
+		on:"../img/button_blink_red/pan_on.png",
+		over:"../img/button_blink_red/pan_over.png",
+		off:"../img/button_blink_red/pan_off.png",
+		type:"toggle"
+	grid : [7,7],
+	makeDraggable : function() {
+		var $selection = $(".ui-selected");
+		if ($selection.size() > 0) {
+			// if elements have been selected, we want to drag
+			// them together, not individually. So we move these
+			// elements into a new div tag, and make that tag
+			// draggable
+			Draggable.moveSelectionToDiv();
+			$(".div-draggable").draggable({
+				grid:Draggable.grid
+		else {
+			$(".collection").children().draggable({
+	removeDraggable : function () {
+		if ($(".ui-selected").size() > 0) {
+			Draggable.moveSelectionFromDiv();
+		$(".collection").children().draggable("destroy");
+	moveSelectionFromDiv : function () {
+		var divX, divY;
+		var $draggableDiv = $(".div-draggable");
+		$draggableDiv.each(function() {
+			divX = parseInt(this.style.left);
+			divY = parseInt(this.style.top);
+		$draggableDiv.children().each(function() {
+			var newX = parseInt(this.style.left) + divX;
+			var newY = parseInt(this.style.top) + divY;
+			$(this).removeClass("ui-selectee");
+			$(this).removeClass("ui-selected");
+			$(this).addClass("div-border");
+			$clone = $(this).clone();
+			$(".collection").append($clone);
+		$draggableDiv.remove();
+	moveSelectionToDiv : function () {
+		// first, put all selected elements inside a
+		// single div tag; then, make that div tag
+		// draggable
+		// the coordinates of the new div tag need
+		// to be computed first
+		var minX, minY;
+			var currentLeft = parseInt(this.style.left);
+			if ((!minX && minX !== 0) || currentLeft < minX) {
+				minX = currentLeft;
+			var currentTop = parseInt(this.style.top);
+			if ((!minY && minY !== 0) || currentTop < minY) {
+				minY = currentTop;
+		var $div = $("<div class='div-draggable'></div>");
+		$div.css("position", "absolute");
+		$div.css("top", minY);
+		$div.css("left", minX);
+		// to move the selected nodes, we clone them and attach
+		// them to the new div. the old tags are removed
+			var newX = parseInt(this.style.left) - minX;
+			var newY = parseInt(this.style.top) - minY;
+			$clone.css("position", "absolute");
+			$clone.css("top", newY + "px");
+			$clone.css("left", newX + "px");
+			$div.append($clone);
+			$(this).remove();
+		$div.appendTo($(".collection"));
Copied: branches/testbaudson_dev/mod/editApplication/resizableButton.js (from rev 2556, trunk/mapbender/lib/resizableButton.js)
--- branches/testbaudson_dev/mod/editApplication/resizableButton.js	                        (rev 0)
+++ branches/testbaudson_dev/mod/editApplication/resizableButton.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,18 @@
+var Resizable = {
+		on:"../img/button_blink_red/select_rectangle_on.png",
+		over:"../img/button_blink_red/select_rectangle_over.png",
+		off:"../img/button_blink_red/select_rectangle_off.png",
+		type:"toggle"
+	makeResizable : function () {
+		var selector = ".collection > div";
+		$all = $(selector);
+		$all.resizable();
+	removeResizable : function () {
+		$all.resizable("destroy");
Copied: branches/testbaudson_dev/mod/editApplication/saveButton.js (from rev 2556, trunk/mapbender/lib/saveButton.js)
--- branches/testbaudson_dev/mod/editApplication/saveButton.js	                        (rev 0)
+++ branches/testbaudson_dev/mod/editApplication/saveButton.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,34 @@
+var Save = {
+		on:"../img/button_blink_red/wmc_save_on.png",
+		over:"../img/button_blink_red/wmc_save_over.png",
+		off:"../img/button_blink_red/wmc_save_off.png",
+		type:"toggle"
+	updateDatabase : function (callback) {
+		var data = [];
+		$(".collection").children().each(function() {
+			data.push({
+				id:this.id,
+				top:parseInt(this.style.top),
+				left:parseInt(this.style.left),
+				width:parseInt(this.style.width),
+				height:parseInt(this.style.height)
+		var queryObj = {
+			command:"update",
+			parameters:{
+				applicationId:editApplicationId,
+				data:data
+		$.post("mod_editApplication_server.php", {
+			queryObj:$.toJSON(queryObj)
+		}, function (json, status) {
+			var replyObj = eval('(' + json + ')');
+			alert(replyObj.success);
+			callback();
Copied: branches/testbaudson_dev/mod/editApplication/selectableButton.js (from rev 2556, trunk/mapbender/lib/selectableButton.js)
--- branches/testbaudson_dev/mod/editApplication/selectableButton.js	                        (rev 0)
+++ branches/testbaudson_dev/mod/editApplication/selectableButton.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,32 @@
+var Selectable = {
+		on:"../img/button_blink_red/selArea_on.png",
+		over:"../img/button_blink_red/selArea_over.png",
+		off:"../img/button_blink_red/selArea_off.png",
+		type:"toggle"
+	makeSelectable : function () {
+		// if a selection has been made, remove it
+			Selectable.removeSelection();
+		$all = $(".collection");
+		$all.selectable({
+			selecting:function() {
+				$(".ui-selecting").removeClass("div-border");
+			unselecting:function() {
+				$(".ui-selectee").addClass("div-border");
+	removeSelection : function () {
+		$(".ui-selected").addClass("div-border");
+		$(".collection").selectable("destroy");
+		$(".ui-selected").removeClass("ui-selected");
+		$(".ui-selectee").removeClass("ui-selectee");
+		$(".ui-selectable").removeClass("ui-selectable");
\ No newline at end of file
Copied: branches/testbaudson_dev/mod/mapframe1/map.js (from rev 2562, trunk/mapbender/http/javascripts/map.js)
--- branches/testbaudson_dev/mod/mapframe1/map.js	                        (rev 0)
+++ branches/testbaudson_dev/mod/mapframe1/map.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,737 @@
+ * used in mod_box1, mod_dragMapSize, mod_pan
+var mb_start_x = 0;
+var mb_start_y = 0;
+var mb_end_x = 0;
+var mb_end_y = 0;
+ * @deprecated
+function mb_execloadWmsSubFunctions(){
+	eventAfterLoadWMS.trigger();
+function mb_execWfsReadSubFunctions(geom) {
+	for(var i=0; i<mb_WfsReadSubFunctions.length; i++){
+		mb_WfsReadSubFunctions[i](geom);
+function mb_execWfsWriteSubFunctions() {
+	for(var i=0; i<mb_WfsWriteSubFunctions.length; i++){
+		mb_WfsWriteSubFunctions[i]();
+function mb_setWmcExtensionData(anArray) {
+	for (var i in anArray) {
+		if (typeof(anArray[i]) != "undefined") {
+			currentWmcExtensionData[i] = anArray[i];
+function mb_getWmcExtensionData(arrayKey) {
+	for (var i in restoredWmcExtensionData) {
+		if (arrayKey == i) {
+			return restoredWmcExtensionData[i];
+	var e = new Mb_warning("mb_getWmcExtensionData: "+arrayKey+" not found. Maybe this GUI does not allow loading or saving WMC documents from/to the session");
+	return null;
+eventAfterInit.register(function () {
+	// performs a map request for each map frame
+	for (var i = 0; i < mb_mapObj.length; i++){
+		setMapRequest(mb_mapObj[i].frameName);
+eventBeforeFeatureInfo.register(function() {
+	for (var j=0; j<mb_mapObj.length; j++) {
+		var mapObj = mb_mapObj[j];
+		// set list of visible layers, active querylayers
+		// and styles for each WMS in this map
+		var cnt_layers;
+		var cnt_querylayers;
+		var styles;
+		var layers;
+		var querylayers = "";
+		for(i=0; i< mapObj.wms.length; i++){
+			cnt_layers = 0;
+			cnt_querylayers = 0;
+			styles = "";
+			layers = "";
+			querylayers = "";
+			for(var ii=0; ii<mapObj.wms[i].objLayer.length; ii++){
+				// layer is visible and not root layer
+				if(mapObj.wms[i].objLayer[ii].gui_layer_visible == 1 && ii>0){
+					if(cnt_layers > 0){
+						layers += ","; styles += ",";
+					layers += wms[i].objLayer[ii].layer_name;
+					styles += "";
+					cnt_layers++;
+				// layer is queryable and not root layer
+				if(mapObj.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii>0){
+					if(cnt_querylayers > 0){
+						querylayers += ",";
+					querylayers += wms[i].objLayer[ii].layer_name;
+					cnt_querylayers++;
+			mapObj.layers[i] = layers;
+			mapObj.styles[i] = styles;
+			mapObj.querylayers[i] = querylayers;
+function mb_registerMapObj(frameName, elementName,wms_index,width, height){
+	mb_mapObj.push(new mb_mapObj_const(frameName, elementName, width, height, wms_index));
+function mb_mapObjremoveWMS(objind,wmsind){
+	var wms_ID = null;
+	var i;
+	var new_wmsarray = [];
+	var new_layerarray = [];
+	var new_querylayerarray = [];
+	var new_stylesarray = [];
+	var new_mapURLarray = [];
+	for	(i=0;i<mb_mapObj[objind].wms.length; i++){
+		if(i != wmsind){
+			new_wmsarray[new_wmsarray.length] = mb_mapObj[objind].wms[i];
+			new_layerarray[new_layerarray.length] = mb_mapObj[objind].layers[i];
+			new_querylayerarray[new_querylayerarray.length] = mb_mapObj[objind].querylayers[i];
+			new_stylesarray[new_stylesarray.length] = mb_mapObj[objind].styles[i];
+			new_mapURLarray[new_mapURLarray.length] = mb_mapObj[objind].mapURL[i];
+		else {
+			wms_ID = mb_mapObj[objind].wms[i].wms_id;
+	mb_mapObj[objind].wms = new_wmsarray;
+	mb_mapObj[objind].layers = new_layerarray;
+	mb_mapObj[objind].querylayers = new_querylayerarray;
+	mb_mapObj[objind].styles = new_stylesarray;
+	mb_mapObj[objind].mapURL = new_mapURLarray;
+	var another_new_wmsarray = [];
+	for	(i=0;i<wms.length; i++){
+		if(wms[i].wms_id != wms_ID){
+			another_new_wmsarray[another_new_wmsarray.length] = wms[i];
+	wms = another_new_wmsarray;
+function setExtent(width,height,epsg){
+   for(var i=0; i < wms[0].gui_epsg.length; i++){
+      if(wms[0].gui_epsg[i] == epsg){
+         var bbox_minx = parseFloat(wms[0].gui_minx[i]);
+         var bbox_miny = parseFloat(wms[0].gui_miny[i]);
+         var bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
+         var bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
+         var extenty = bbox_maxy - bbox_miny;
+         var extentx = bbox_maxx - bbox_minx;
+         var relation_px_x = width / height;
+         var relation_px_y = height / width;
+         var relation_bbox_x = extentx / extenty;
+         var centerx = bbox_minx + (extentx/2);
+         var centery = bbox_miny + (extenty/2);
+         if(relation_bbox_x <= relation_px_x){
+                bbox_minx = centerx - relation_px_x * extenty / 2;
+                bbox_maxx = centerx + relation_px_x * extenty / 2;
+         if(relation_bbox_x > relation_px_x){
+                bbox_miny = centery - relation_px_y * extentx / 2;
+                bbox_maxy = centery + relation_px_y * extentx / 2;
+        return bbox_minx  +","+ bbox_miny +","+ bbox_maxx  +","+ bbox_maxy;
+function setMapRequest(frameName){
+	var functionName = 'setMapRequest';
+	var ret = eventBeforeMapRequest.trigger({frameName:frameName}, "AND");
+	if (ret === false) {
+		return true;
+	var ts = mb_timestamp();
+	var myMapIds = [];
+	for (var i=0; i < mb_mapObj.length; i++){
+		var currentMapObject = mb_mapObj[i];
+		if (currentMapObject.frameName != frameName) {
+			continue;
+		var newMapRequest = "";
+		for (var ii = 0; ii < currentMapObject.wms.length; ii++){
+			var currentWms = currentMapObject.wms[ii];
+			if (!(currentWms.gui_wms_visible > 0)) {
+				continue;
+			myMapIds.push("map_"+ii);
+			newMapRequest += getLayerHtmlCode(frameName, i, ii);
+		writeTag(mb_mapObj[i].frameName, mb_mapObj[i].elementName, newMapRequest);
+	eventAfterMapRequest.trigger({
+		"frameName": frameName,
+		"myMapIds": myMapIds.join(",")
+	for(var i=0; i<mb_MapRequestSubFunctions.length; i++){
+		eval(mb_MapRequestSubFunctions[i]);
+function getLayerHtmlCode (frameName, i, ii) {
+	var myDivId = "div_" + ii;
+	var myMapId = "map_" + ii;
+	//disable Layer which are out of scale
+	var validLayers = mb_checkScale(frameName, i, ii);
+	var layerNames = validLayers.toString();
+	var newMapURL = false;
+	var opacityString = "";
+	if (currentMapObject.layers[ii] !== "" && layerNames !== ''){
+		// get map URL
+		newMapURL = currentMapObject.getMapUrl(i, ii);
+		var currentOpacity = currentWms.gui_wms_mapopacity;
+		if (currentOpacity != 1) {
+			opacityString += "opacity:" + currentOpacity + "; ";
+			opacityString += "Filter: Alpha(Opacity=" + currentOpacity*100 + "); ";
+			opacityString += "-moz-opacity:" + currentOpacity + " ; ";
+			opacityString += "-khtml-opacity:" + currentOpacity;
+	var imageString = "<img id='"+myMapId+"' name='mapimage' ";
+	imageString += "src='" + newMapURL + "' ";
+	imageString += "width='"+currentMapObject.width+"' ";
+	imageString += "height='"+currentMapObject.height+"' ";
+	imageString += "border='0'>";
+	var newMapRequest = "<div id='"+myDivId+"' ";
+	newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
+	newMapRequest += "z-index:" + ii + ";" + opacityString + "\">";
+	newMapRequest += imageString;
+	newMapRequest += "</div>";
+	currentMapObject.mapURL[ii]= newMapURL;
+	currentWms.mapURL = newMapURL;
+	if (mb_log && currentWms.mapURL) {
+		var tmp = eval(mb_log + "('" +newMapURL + "','" + ts + "')");
+	return newMapRequest;
+function setSingleMapRequest(frameName,wms_id){
+	var functionName = 'setSingleMapRequest';
+	eventBeforeMapRequest.trigger({frameName:frameName});
+	for(i = 0; i < mb_mapObj.length; i++){
+			continue;
+		for (var ii=0; ii < currentMapObject.wms.length; ii++){
+			if (currentWms.wms_id != wms_id) {
+				continue;
+			var newMapRequest = getLayerHtmlCode(frameName, i, ii);
+			if (mb_log) {
+				var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
+			writeTag(currentMapObject.frameName, myDivId, newMapRequest);
+			eventAfterMapRequest.trigger({"frameName":frameName, "myMapId":myMapId});
+			return true;
+	return false;
+function mb_restateLayers(frameName,wms_id){
+	//alert(frameName + " / " + wms_id);
+	var ind = getMapObjIndexByName(frameName);
+	for(var i=0; i<mb_mapObj[ind].wms.length; i++){
+		if(mb_mapObj[ind].wms[i].wms_id == wms_id){
+			var cnt_layers = 0;
+			var cnt_querylayers = 0;
+			var layers = "";
+			var styles = "";
+			for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
+				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
+					if(cnt_layers > 0){layers += ","; styles += ","; }
+					layers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
+					//alert(mb_mapObj[ind].wms[i].objLayer[ii].layer_name);
+					styles += "";
+					cnt_layers++;
+				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
+					if(cnt_querylayers > 0){querylayers += ",";}
+					querylayers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
+			mb_mapObj[ind].layers[i] = layers;
+			mb_mapObj[ind].querylayers[i] = querylayers;
+			mb_mapObj[ind].styles[i] = styles;
+function mb_checkScale(frameName,mObj,wmsObj){
+	var thisLayer = mb_mapObj[mObj].layers[wmsObj].split(",");
+	var thisScale = mb_getScale(frameName);
+	var str_layer = "";
+	var cnt_layer = 0;
+	for(var i=0; i<mb_mapObj[mObj].wms[wmsObj].objLayer.length; i++){
+		var myLayername = mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_name;
+		var myMinscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_minscale;
+		var myMaxscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_maxscale;
+		for(var ii=0; ii<thisLayer.length; ii++){
+			var minscaleOK = false;
+			var maxscaleOK = false;
+			if(thisLayer[ii] == myLayername){
+				if(myMinscale === 0 || thisScale >= myMinscale){minscaleOK = true;}
+				if(myMaxscale === 0 || thisScale <= myMaxscale){maxscaleOK = true;}
+				if(maxscaleOK === true && minscaleOK === true  && !mb_mapObj[mObj].wms[wmsObj].objLayer[i].has_childs){
+					if(cnt_layer > 0){str_layer += ","; }//str_styles += ","; str_titles += ",";str_parent += ","; str_legendurls += ",";}
+					str_layer += thisLayer[ii];
+					cnt_layer++;
+	var str_layerstyles = [];
+	str_layerstyles[0] = str_layer;
+	return str_layerstyles;
+function setFeatureInfoRequest(fName,x,y, path) {
+	var functionName = 'setFeatureInfoRequest';
+	eventBeforeFeatureInfo.trigger({"fName":fName});
+	for(var i=0; i<mb_FeatureInfoPreFunctions.length; i++){
+		eval(mb_FeatureInfoPreFunctions[i]);
+	var cnt_fi = 0;
+	for(i=0; i<mb_mapObj.length; i++){
+		if(mb_mapObj[i].frameName == fName){
+			for(var ii=0; ii<mb_mapObj[i].wms.length; ii++){
+				var newfeatureInfoRequest = "";
+				var requestParams = "";
+				var validation = false;
+				newfeatureInfoRequest += mb_mapObj[i].wms[ii].wms_getfeatureinfo;
+            	newfeatureInfoRequest += mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getfeatureinfo);
+				if(mb_mapObj[i].wms[ii].wms_version == "1.0.0"){requestParams += "WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=feature_info&";}
+				if(mb_mapObj[i].wms[ii].wms_version != "1.0.0"){requestParams += "VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetFeatureInfo&SERVICE=WMS&";}
+				requestParams += "SRS="+mb_mapObj[i].epsg+"&";
+				requestParams += "BBOX="+mb_mapObj[i].extent+"&";
+				requestParams += "WIDTH="+mb_mapObj[i].width+"&";
+				requestParams += "HEIGHT="+mb_mapObj[i].height+"&";
+				requestParams += "LAYERS="+mb_mapObj[i].layers[ii]+"&";
+				requestParams += "STYLES="+mb_mapObj[i].styles[ii]+"&";
+				requestParams += "FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";
+				requestParams += "INFO_FORMAT="+mb_mapObj[i].wms[ii].gui_wms_featureinfoformat+"&";
+				requestParams += "EXCEPTIONS=application/vnd.ogc.se_xml&";
+				if(mb_feature_count > 0){
+					requestParams += "FEATURE_COUNT="+mb_feature_count+"&";
+				requestParams += "QUERY_LAYERS="+mb_mapObj[i].querylayers[ii]+"&";
+				requestParams += "X=" + x  + "&";
+				requestParams += "Y=" + y;
+				if(mb_mapObj[i].querylayers[ii] !== "" && mb_mapObj[i].layers[ii] !== ""){
+					validation = true;
+				//add vendor-specific
+				for(var v=0; v < mb_vendorSpecific.length; v++){
+					var vendorSpecificString = eval(mb_vendorSpecific[v]);
+					requestParams += "&" + vendorSpecificString;
+				if(mb_log && validation){
+					var tmp = eval(mb_log + "('" + newfeatureInfoRequest + requestParams + "','" + ts + "')");
+				if(document.getElementById("FeatureInfoRedirect") && validation){
+					newfeatureInfoRequest += requestParams;
+					if(path){
+						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr;
+					else{
+						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = newfeatureInfoRequest;
+					cnt_fi++;
+				else if(path && validation){
+					try{
+						var p = new mb_popup("Feature Info","url:"+path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr,300,400);
+						p.show();
+					}catch(e){
+						window.open(path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
+					cnt_fi++;
+				else if(validation){
+					try{
+						var p = new mb_popup("Feature Info","url:"+newfeatureInfoRequest,300,400);
+						p.show();
+					catch(e){
+						window.open(newfeatureInfoRequest, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
+					cnt_fi++;
+   	if(cnt_fi === 0){
+		alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));
+ * global function to zoom a mapobject
+ * use: mb_mapObj.zoom() {@link mb_mapObj_const#zoom}
+ * @deprecated
+function zoom(frameName,in_, factor,x,y) {
+	var obj = getMapObjByName(frameName);
+	if(x && y){
+		obj.zoom(in_, factor, x, y);
+	else{
+		obj.zoom(in_, factor, false, false);
+	setMapRequest(frameName);
+function mb_panMap(frameName,dir){
+   var arrayBBox = mb_mapObj[ind].extent.split(",");
+   var minx = parseFloat(arrayBBox[0]);
+   var miny = parseFloat(arrayBBox[1]);
+   var maxx = parseFloat(arrayBBox[2]);
+   var maxy = parseFloat(arrayBBox[3]);
+   var xtentx = parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]);
+   var xtenty =  parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]);
+   if(dir == "NW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
+   if(dir == "N"){miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
+   if(dir == "NE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
+   if(dir == "W"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2);}
+   if(dir == "E"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2);}
+   if(dir == "SW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
+   if(dir == "S"){miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
+   if(dir == "SE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
+  mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
+function handleSelectedLayer (frameName, wms_title, layerName, type, status) {
+//	alert(frameName + " , " +wms_title + " , " +layerName + " , " +type + " , " +status);
+//	type = {visible || querylayer] status = {0 || 1}
+	for (var i=0; i < mb_mapObj.length; i++) {
+		if (mb_mapObj[i].frameName == frameName) {
+			var myMapObj = i;
+			for (var ii = 0; ii < mb_mapObj[i].wms.length; ii++) {
+				if (mb_mapObj[i].wms[ii].wms_title == wms_title) { //ii is true
+					var myWMS = ii;
+					if (type == "visible") {
+						var arrayLayer = mb_mapObj[i].layers[ii].split(",");
+					if (type == "querylayer") {
+						var arrayLayer = mb_mapObj[i].querylayers[ii].split(",");
+					for (var iii = 1; iii < mb_mapObj[i].wms[ii].objLayer.length; iii++) {
+						var layer_name = mb_mapObj[i].wms[ii].objLayer[iii].layer_name;
+							if (layer_name == layerName && status == 1 && mb_mapObj[i].wms[ii].objLayer[iii].layer_queryable == 1){
+								if (cnt_layer > 0) {
+									str_layer += ",";
+								str_layer += layer_name;
+								cnt_layer++;
+						else if (type == "visible") {
+							if (layer_name == layerName && status == 1) {
+									str_layer += ",";
+								cnt_layer++;
+						for (var iiii = 0; iiii < arrayLayer.length; iiii++) {
+							if (layer_name == arrayLayer[iiii] && layer_name != layerName) {
+									str_layer += ",";
+								cnt_layer++;
+		mb_mapObj[myMapObj].layers[myWMS] = str_layer;
+		var array_str_layer = str_layer.split(",");
+		var str_styles = "";
+		for (var cnt=0; cnt < array_str_layer.length; cnt++) {
+			if (cnt > 0) {
+				str_styles += ",";
+			str_styles += "";
+		mb_mapObj[myMapObj].styles[myWMS] = str_styles;
+		mb_mapObj[myMapObj].querylayers[myWMS] = str_layer;
+	if(type == 'visible'){
+		setSingleMapRequest(frameName,wms_title);
+function handleSelectedLayer_array(mapObj, array_wms, array_layer, type, status){
+	//alert(mapObj+" / "+array_wms[0]+" / "+ array_layer[0]+" / "+ type+" / "+ status);
+	var ind = getMapObjIndexByName(mapObj);
+	for(var j=0; j<array_wms.length; j++){
+			if(mb_mapObj[ind].wms[i].wms_id == array_wms[j]){
+				var check = false;
+					if(mb_mapObj[ind].wms[i].wms_id == array_wms[j] && mb_mapObj[ind].wms[i].objLayer[ii].layer_name == array_layer[j]){
+						if(type == "visible"){
+							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible = parseInt(status, 10);
+							check = true;
+                        if(type == "querylayer" && (mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == "1" || mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == 1)){
+							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer = parseInt(status, 10);
+                mb_restateLayers(mapObj, array_wms[j]);
+                //alert('restate');
+                * hier noch checken, welche wms sich geaendert haben und disctinct eine singleRequest aufrufen:
+                if(check === true){
+                    if(mb_mapObj[ind].wms[i].gui_wms_visible == 1){
+						setSingleMapRequest(mapObj,mb_mapObj[ind].wms[i].wms_id);
+                        //alert('sSMR');
+function makeClickPos2RealWorldPos(frameName, myClickX, myClickY) {
+	var width = parseInt(mb_mapObj[ind].width, 10);
+	var height = parseInt(mb_mapObj[ind].height, 10);
+	var minX = parseFloat(arrayBBox[0]);
+	var minY = parseFloat(arrayBBox[1]);
+	var maxX = parseFloat(arrayBBox[2]);
+	var maxY = parseFloat(arrayBBox[3]);
+	var deltaX = (maxX - minX)/width;
+	var deltaY = (maxY - minY)/height;
+	if(deltaX > 0){
+		var roundx = 1/Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
+	else{
+		var roundx =  Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
+	if(deltaY > 0){
+		var roundy = 1/Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
+	else{
+		var roundy =  Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
+	var xtentx = maxX - minX;
+	var xtenty =  maxY - minY;
+	var posX = parseFloat(minX + (myClickX / width) * xtentx);
+	var posY = parseFloat(maxY - (myClickY / height) * xtenty);
+	posX = Math.round(posX * roundx)/roundx;
+	posY = Math.round(posY * roundy)/roundy;
+	return [posX, posY];
+function makeRealWorld2mapPos(frameName,rw_posx, rw_posy){
+   var mpObj = mb_mapObj[ind];
+   var arrayBBox = mpObj.extent.split(",");
+   return [Math.round((rw_posx - minX)*mpObj.width/(maxX - minX)), Math.round((maxY - rw_posy)*mpObj.height/(maxY - minY))];
+// function for object-identification
+function getMapObjIndexByName(frameName){
+	for(var i=0; i<mb_mapObj.length; i++){
+		if(mb_mapObj[i].frameName == frameName){
+			return i;
+function getMapObjByName(frameName){
+			return mb_mapObj[i];
+	return false;
+function getWMSIDByTitle(frameName,wms_title){
+   for(var i=0; i< mb_mapObj[ind].wms.length; i++){
+      if(mb_mapObj[ind].wms[i].wms_title == wms_title){
+         //return i;
+         return mb_mapObj[ind].wms[i].wms_id;
+function getWMSIndexById(frameName,wms_id){
+         return i;
+//scale
+function mb_getScale(frameName) {
+	var myScale = eventBeforeGetScale.trigger({"frameName":frameName});
+   for(var i=0; i<mb_GetScalePreFunctions.length; i++){
+		var myScale = eval(mb_GetScalePreFunctions[i]);
+   if(typeof(myScale) == "number"){
+      var Y_str = myScale;
+   else{
+      var scaleY = (xtenty / mb_mapObj[ind].height) *(mb_resolution * 100);
+      if (scaleY<1){
+      	var Y_str = scaleY;
+      }else{
+      	var Y_str = Math.round(scaleY);
+   return Y_str;
+function mb_repaintScale(frameName, x, y, scale){
+   if(x === null && y === null){
+      x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
+      y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
+   var minx = parseFloat(x) - (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
+   var miny = parseFloat(y) -  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
+   var maxx = parseFloat(x) + (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
+   var maxy = parseFloat(y) +  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
+   mb_repaint(frameName,minx, miny, maxx, maxy);
+function mb_repaint(frameName,minx,miny,maxx,maxy){
+ * converts the extent of the mapobject so that the maximum	extent will be displayed {@link mb_mapObj_const#calculateExtent}
+ * use: mb_mapObj.calculateExtent
+ * @deprecated
+function mb_calculateExtent(frameName,minx,miny,maxx,maxy){
+  var map = getMapObjByName(frameName);
+  var extent = new Extent(minx,miny,maxx,maxy);
+  map.calculateExtent(extent);
+ * @class extent
+ * @param {float} minx
+ * @param {float} miny
+ * @param {float} maxx
+ * @param {float} maxy
+ * @return the extent as object
+ * @type Object
+function Extent(minx,miny,maxx,maxy){
+	this.minx = parseFloat(minx);
+	this.miny = parseFloat(miny);
+	this.maxx = parseFloat(maxx);
+	this.maxy = parseFloat(maxy);
+	this.extentx = this.maxx - this.minx;
+	this.extenty = this.maxy - this.miny;
+	this.centerx = this.minx + this.extentx/2;
+	this.centery = this.miny + this.extenty/2;
+	return this;
Copied: branches/testbaudson_dev/mod/mapframe1/map_obj.js (from rev 2556, trunk/mapbender/http/javascripts/map_obj.js)
--- branches/testbaudson_dev/mod/mapframe1/map_obj.js	                        (rev 0)
+++ branches/testbaudson_dev/mod/mapframe1/map_obj.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,404 @@
+* $Id: map_obj.js 2517 2008-06-19 16:40:00Z christoph $
+* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
+* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
+var mb_mapObj = [];
+function mb_mapObj_const(frameName, elementName, width, height, wms_index){
+	this.width = width;
+	this.height = height;
+	this.frameName = frameName;
+	this.elementName = elementName;
+	this.layers = [];
+	this.styles = [];
+	this.querylayers = [];
+	this.geom = "";
+	this.gml = "";
+	this.wms = [];
+	// Add pointers to WMS objects which are in this map.
+	// If wms_index is set (=map is overview), only this
+	// WMS is being pointed to.
+	var index = 0;
+	for(var i=0; i < wms.length; i++){
+		var isValidWms = (wms_index === null) || (wms_index == i);
+		if (isValidWms) {
+			this.wms[index] = wms[i];
+			this.wms[index].mapURL = false;
+			index++;
+	var cnt_layers;
+	var styles;
+	var layers;
+	for(i=0; i< this.wms.length; i++){
+		cnt_layers = 0;
+		styles = "";
+		layers = "";
+		querylayers = "";
+		for(var ii=0; ii<this.wms[i].objLayer.length; ii++){
+			if(this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii>0){
+				styles += "";
+				cnt_layers++;
+			if(this.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii>0){
+		this.layers[i] = layers;
+		this.styles[i] = styles;
+		this.querylayers[i] = querylayers;
+	this.epsg = wms[0].gui_wms_epsg;
+	this.extent = setExtent(this.width,this.height,this.epsg);
+	this.mapURL = [];
+	var styleTag = window.frames[this.frameName].document.getElementById(this.elementName).style;
+	styleTag.width = this.width;
+	styleTag.height = this.height;
+	 * get the width of the mapObj
+	 * @member mb_mapObj_const
+	 * @return width of the mapObj
+	 * @type integer
+	this.getWidth = function(){
+		return parseInt(this.width, 10);
+	 * set the width of the mapObj
+	 * @param {integer} widht the width of the mapObj
+	this.setWidth = function(width){
+		this.width = parseInt(width, 10);
+	 * get the height of the mapObj
+	 * @type integer
+	this.getHeight = function(){
+		return parseInt(this.height, 10);
+	 * set the height of the mapObj
+	 * @param {integer} height the height of the mapObj
+	this.setHeight = function(height){
+		this.height = parseInt(height, 10);
+	 * get the extent of the mapObj
+	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
+	 * @type string
+	this.getExtent = function(){
+		return this.extent;
+	 * get the extent as minx, maxx, miny, maxy
+	 * @return extent and additional informations of the mapObj
+	 * @type Object
+	this.getExtentInfos = function(){
+		var c = this.getExtent().split(",");
+		var ext = new Extent(c[0],c[1],c[2],c[3]);
+		return ext;
+	this.calculateExtent = function(ext){
+		var relation_px_x = this.getWidth() / this.getHeight();
+		var relation_px_y = this.getHeight() / this.getWidth();
+		var relation_bbox_x = ext.extentx / ext.extenty;
+			ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
+			ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
+			ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
+			ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
+		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
+	 * zoom the map with a zoomfactor and optional to x,y coords
+	 * @param {boolean} in_ in = true, out = false
+	 * @param {float} factor the zoomfactor 1 equals 100%
+	 * @param {float} x center to x-position
+	 * @param {float} y center to y-position
+	 this.zoom = function(in_, factor, x, y){
+		factor = parseFloat(factor);
+		if (!in_) {
+			factor = 1 / factor;
+		var extent = this.getExtentInfos();
+		var distx = extent.maxx - extent.minx;
+		var disty =  extent.maxy - extent.miny;
+		if(x && y){
+			var centerx = parseFloat(x);
+			var centery = parseFloat(y);
+		else{
+			var centerx = extent.minx + distx/2;
+			var centery = extent.miny + disty/2;
+		var new_distx = distx / factor;
+		var new_disty = disty / factor;
+		var minx = centerx - new_distx / 2;
+		var miny = centery - new_disty / 2;
+		var maxx = centerx + new_distx / 2;
+		var maxy = centery + new_disty / 2;
+		this.setExtent(minx,miny,maxx,maxy);
+		//Todo:
+		//setMapRequest!
+	 * set the extent of the wms
+	 this.setExtent = function(minx,miny,maxx,maxy){
+	 	this.extent = String(minx)+","+String(miny)+","+String(maxx)+","+String(maxy);
+	 * get the srs of the mapObj
+	 * @return srs as epsg:number
+	 * @type string
+	this.getSRS = function(){
+		return this.epsg;
+	 * get all mapRequests
+	 * @return array of mapRequests of this map object
+	 * @type string[]
+	this.getMapRequests = function(){
+		var allRequests = [];
+		//loop through all wms to get the mapRequests
+		for(var i=0; i<this.wms.length; i++){
+			var currentRequest = this.wms[i].getMapRequest(this);
+			if(currentRequest){
+				allRequests.push(currentRequest);
+		if(allRequests.length > 0){
+			return allRequests;
+		return false;
+	 * Return the map URL of the WMS at index i
+	 * @param {Object} currentWmsIndex
+	this.getMapUrl = function (i, ii) {
+		var currentWms = this.wms[ii];
+		var validLayers = currentWms.getLayers(this);
+		var layerNames = validLayers.join(",");
+		url = currentWms.wms_getmap;
+		url += mb_getConjunctionCharacter(currentWms.wms_getmap);
+		if (currentWms.wms_version == "1.0.0") {
+			url += "WMTVER=" + currentWms.wms_version + "&REQUEST=map&";
+		else {
+			url += "VERSION=" + currentWms.wms_version + "&REQUEST=GetMap&SERVICE=WMS&";
+		url += "LAYERS=" + layerNames + "&";
+		url += "STYLES=";
+		var layer = layerNames.split(",");
+		for (var j = 0; j < layer.length; j++){
+			if (j > 0) {
+				url  += ",";
+			if (currentWms.getCurrentStyleByLayerName(layer[j]) !== false) {
+				url += currentWms.getCurrentStyleByLayerName(layer[j]);
+		url += "&";
+		url += "SRS=" + this.epsg + "&";
+		url += "BBOX=" + this.extent + "&";
+		url += "WIDTH=" + this.width + "&";
+		url += "HEIGHT=" + this.height + "&";
+		url += "FORMAT=" + currentWms.gui_wms_mapformat + "&";
+		url += "BGCOLOR=0xffffff&";
+		if (currentWms.gui_wms_mapformat.search(/gif/i)>-1 ||
+			currentWms.gui_wms_mapformat.search(/png/i)>-1) {
+				url += "TRANSPARENT=TRUE&";
+		url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
+		// add vendor-specific
+		for (var v = 0; v < mb_vendorSpecific.length; v++) {
+			// if eval doesn't evaluate a function, the result is undefined.
+			// Sometimes it is necessary not to evaluate a function, for
+			// example if you want to change a variable from the current
+			// scope (see mod_addSLD.php)
+			if (typeof(vendorSpecificString) != "undefined") {
+				url += vendorSpecificString + "&";
+		// add Filter
+		if (currentWms.wms_filter !== ""){
+			url += "&SLD=" + currentWms.wms_filter +"?id="+ mb_styleID + "&";
+		// add sld
+		if(currentWms.gui_wms_sldurl !== ""){
+			url += "&SLD=" + escape(currentWms.gui_wms_sldurl) + "&";
+		return url;
+	 * get all featureInfoRequests
+	 * @param float x the x-value of the click position in pixel
+	 * @param float y the y-value of the click position in pixel
+	 * @return array of all featureInfoRequests of this map object
+	 * @type string[]
+	this.getFeatureInfoRequests = function(clickPoint){
+		//loop through all wms to get the FeatureInfoRequests
+			var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
+		return false;
+	 * calculation of the mapscale
+	 * @return scale
+	 * @type integer
+	this.getScale = function(){
+		var scale;
+		var bbox = this.extent.split(",");
+		var xtenty;
+		if(this.epsg=="EPSG:4326"){
+			var pxLenx = (parseFloat(bbox[2])-parseFloat(bbox[0]))/this.width;
+			var pxLeny = (parseFloat(bbox[3])-parseFloat(bbox[1]))/this.height;
+			var lat_from = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2)*Math.PI)/180;
+			var lat_to = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2+pxLeny)*Math.PI)/180;
+			var lon_from = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2)*Math.PI)/180;
+			var lon_to = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2+pxLeny)*Math.PI)/180;
+			var dist=6371229*Math.acos(Math.sin(lat_from)*Math.sin(lat_to)+Math.cos(lat_from)*Math.cos(lat_to)*Math.cos(lon_from-lon_to));
+			scale = (dist/Math.SQRT2) * (mb_resolution * 100);
+		}else{
+			xtenty =  parseFloat(bbox[3]) - parseFloat(bbox[1]);
+			scale = (xtenty / this.height) * (mb_resolution * 100);
+		return Math.round(scale);
+	 * move a wms or layer
+	 * @param int wms_id id of wms to move
+	 * @param int layer_id id of layer to move
+	 * @return true of successful
+	 * @type boolean
+	this.move = function(wms_id, layer_id, moveUp){
+		var i,j;
+		for(i=0;i<this.wms.length;i++){
+			if (wms_id == this.wms[i].wms_id) {
+				break;
+		//check if only one wms is affected?
+		if (layer_id && layer_id != this.wms[i].objLayer[0].layer_id) {
+			return this.wms[i].moveLayer(layer_id, moveUp);
+		//else swap wms
+		j = i + (moveUp?-1:1);
+		if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length)) {
+			return false;
+		upper = this.wms[i];
+		this.wms[i] = this.wms[j];
+		this.wms[j] = upper;
+		var upperLayers = this.layers[i];
+		var upperStyles = this.styles[i];
+		var upperQuerylayers = this.querylayers[i];
+		this.layers[i] = this.layers[j];
+		this.styles[i] = this.styles[j];
+		this.querylayers[i] = this.querylayers[j];
+		this.layers[j] = upperLayers;
+		this.styles[j] = upperStyles;
+		this.querylayers[j] = upperQuerylayers;
+		return true;
+	eventAfterMapObjectConstruction.trigger();
Added: branches/testbaudson_dev/mod/mapframe1/mapframe1.php
--- branches/testbaudson_dev/mod/mapframe1/mapframe1.php	                        (rev 0)
+++ branches/testbaudson_dev/mod/mapframe1/mapframe1.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,15 @@
+<?php
+require_once(dirname(__FILE__)."/map_obj.js");
+require_once(dirname(__FILE__)."/map.js");
+require_once(dirname(__FILE__)."/wms.js");
+require_once(dirname(__FILE__)."/wfs_obj.js");
+require_once(dirname(__FILE__)."/../../lib/wms.php");
+$wmsArray = wms::selectMyWmsByApplication($gui_id);
+for ($i = 0; $i < count($wmsArray); $i++) {
+	$currentWms = $wmsArray[$i];
+	$currentWms->createJsObjFromWMS();
Copied: branches/testbaudson_dev/mod/mapframe1/wfs_obj.js (from rev 2556, trunk/mapbender/http/javascripts/wfs_obj.js)
--- branches/testbaudson_dev/mod/mapframe1/wfs_obj.js	                        (rev 0)
+++ branches/testbaudson_dev/mod/mapframe1/wfs_obj.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,75 @@
+//$Id$
+//$Header: /cvsroot/mapbender/mapbender/http/javascripts/wfs_obj.js,v 1.3 2005/09/13 14:38:11 bjoern_heuser Exp $
+//global variables
+var wfs = [];
+var wfs_featuretype_count = 0;
+var wfs_element_count = 0;
+//list of all wms-objects
+function add_wfs(
+			wfs_id,
+			wfs_version,
+			wfs_title,
+			wfs_abstract,
+			wfs_getcapabilities,
+			wfs_describefeaturetype){
+					wfs[wfs.length] = new wfs_const(
+					wfs_id,
+			      wfs_version,
+			      wfs_title,
+			      wfs_abstract,
+			      wfs_describefeaturetype);
+					//wfs_featuretype[wfs.length - 1] = [];
+//the wms constructor
+function wfs_const(
+			wfs_id,
+			wfs_version,
+			wfs_title,
+			wfs_abstract,
+	this.wfs_id = wfs_id;
+	this.wfs_version = wfs_version;
+	this.wfs_title = wfs_title;
+	this.wfs_abstract = wfs_abstract;
+	this.wfs_getcapabilities = wfs_getcapabilities;
+	this.wfs_describefeaturetype = wfs_describefeaturetype;
+	this.wfs_featuretype = [];
+   //alert(wfs_id + " , " +wfs_title + " , " +wfs_abstract + " , " +wfs_getcapabilities + " , " +wfs_describefeaturetype);
+//featuretype
+function wfs_add_featuretype(
+			featuretype_name,
+			featuretype_title,
+			featuretype_srs,
+			featuretype_geomtype){
+	      wfs[wfs.length-1].wfs_featuretype[wfs[wfs.length-1].wfs_featuretype.length] = new featuretype(
+											featuretype_name,
+											featuretype_srs,
+											featuretype_geomtype);
+//alert(featuretype_name + " , " +featuretype_title + " , " +featuretype_srs + " , " +featuretype_geomtype);
+function featuretype(
+			featuretype_name,
+			featuretype_srs,
+	this.featuretype_name = featuretype_name;
+	this.featuretype_title = featuretype_title;
+	this.featuretype_srs = featuretype_srs;
+	this.featuretype_geomtype = featuretype_geomtype;
+	this.element = [];
+	wfs_featuretype_count++;
+//elements
+function wfs_add_featuretype_element(element_name, element_type, element_count, featuretype_count){
+	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count] = [];
+	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].name = element_name;
+	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].type = element_type;
+   //alert(element_name +" , "+element_type);
Copied: branches/testbaudson_dev/mod/mapframe1/wms.js (from rev 2556, trunk/mapbender/http/javascripts/wms.js)
--- branches/testbaudson_dev/mod/mapframe1/wms.js	                        (rev 0)
+++ branches/testbaudson_dev/mod/mapframe1/wms.js	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,777 @@
+ * $Id: map_obj.js 2413 2008-04-23 16:21:04Z christoph $
+ * COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
+ * License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
+//global variables
+var wms = [];
+var wms_layer_count = 0;
+ * global function to add wms to the wms-object
+ * @param {String} wms_id the unique id of the wms
+ * @param {String} wms_version the version assumed from capabilities
+ * @param {String} wms_title the title of the wms
+ * @param {String} wms_abstract the abstract of the wms
+ * @param {String} wms_getmap the url for map requests
+ * @param {String} wms_getfeatureinfo the url for featureInof requests
+ * @param {String} wms_getlegendurl the url for legend requests
+ * @param {String} wms_filter a filter (deprecated)
+ * @param {String} gui_wms_mapformat the image-format in the actual gui
+ * @param {String} gui_wms_featureinfoformat the current format for featureInfos
+ * @param {String} gui_wms_exceptionformat the exceptionformat for map requests
+ * @param {String} gui_wms_epsg the current srs
+ * @param {Integer} gui_wms_visible the visibility of this service
+ * @param {Integer} gui_wms_opacity the initial display opacity in percent
+ * @param {String} gui_wms_sldurl url to an actual sld
+function add_wms(
+			wms_id,
+			wms_version,
+			wms_title,
+			wms_abstract,
+			wms_getmap,
+			wms_getfeatureinfo,
+			wms_getlegendurl,
+			wms_filter,
+			gui_wms_mapformat,
+			gui_wms_featureinfoformat,
+			gui_wms_exceptionformat,
+			gui_wms_epsg,
+			gui_wms_visible,
+			gui_wms_opacity,
+			gui_wms_sldurl){
+					wms[wms.length] = new wms_const(
+					wms_id,
+					wms_version,
+					wms_title,
+					wms_abstract,
+					wms_getmap,
+					wms_getlegendurl,
+					wms_filter,
+					gui_wms_epsg,
+					parseInt(gui_wms_visible, 10),
+					parseInt(gui_wms_opacity),
+					gui_wms_sldurl);
+					wms_layer[wms.length - 1] = [];
+ * @class A class representing the wms
+ * @constructor
+ * @param {String} gui_wms_visible the visibility of this service
+function wms_const(
+			wms_id,
+			wms_version,
+			wms_title,
+			wms_abstract,
+			wms_getmap,
+		    wms_getlegendurl,
+			wms_filter,
+			gui_wms_epsg,
+			gui_wms_visible,
+			gui_wms_opacity,
+			gui_wms_sldurl){
+	if (!wms_id) {
+		var id_ok = false;
+		while (id_ok === false) {
+			wms_id = "a"+Math.round(10000*Math.random());
+			id_ok = true;
+			for (var i=0; i < wms.length && id_ok === true; i++) {
+				if (wms_id == wms[i].wms_id) {
+					id_ok = false;
+	this.wms_id = wms_id;
+	this.wms_version = wms_version;
+	this.wms_title = wms_title;
+	this.wms_abstract = wms_abstract;
+	this.wms_getmap = wms_getmap;
+	this.wms_getfeatureinfo = wms_getfeatureinfo;
+	this.wms_getlegendurl = wms_getlegendurl;
+	this.wms_filter = wms_filter;
+	this.data_type = [];
+	this.data_format = [];
+	this.objLayer = [];
+	this.gui_wms_mapformat = gui_wms_mapformat;
+	this.gui_wms_featureinfoformat = gui_wms_featureinfoformat;
+	this.gui_wms_exceptionformat = gui_wms_exceptionformat;
+	this.gui_wms_epsg = gui_wms_epsg;
+	this.gui_wms_visible = gui_wms_visible;
+	this.gui_epsg = [];
+	this.gui_minx = [];
+	this.gui_miny = [];
+	this.gui_maxx = [];
+	this.gui_maxy = [];
+	// opacity version
+	this.gui_wms_mapopacity = gui_wms_opacity/100;
+	// sld version
+	this.gui_wms_sldurl = gui_wms_sldurl;
+ * rephrases the mapRequest
+ * @param {Object} mapObj the mapbender mapObject of the wms
+ * @return mapRequest, i.e. onlineresource + params
+ * @type String
+wms_const.prototype.getMapRequest = function(mapObj){
+	//check visible layers first
+	var layers = this.getLayers(mapObj);
+	if(!layers){
+		return false;
+	var rq = this.wms_getmap;
+	rq += mb_getConjunctionCharacter(this.wms_getmap);
+	if(this.wms_version === "1.0.0"){
+		rq += "WMTVER=" + this.wms_version + "&REQUEST=map";
+	else{
+		rq += "VERSION=" + this.wms_version + "&REQUEST=getMap&SERVICE=WMS";
+	rq += "&LAYERS=" + layers.join(",");
+	rq += "&WIDTH=" + mapObj.getWidth();
+	rq += "&HEIGHT=" + mapObj.getHeight();
+	rq += "&SRS=" + mapObj.getSRS();
+	rq += "&BBOX=" + mapObj.getExtent();
+	rq += "&STYLES=" + this.getLayerstyles(mapObj).join(",");
+	rq += "&FORMAT=" + this.gui_wms_mapformat;
+	rq += "&EXCEPTIONS=" + this.gui_wms_exceptionformat;
+	//Todo: error occurs:
+	//var throwNotice = new Mb_notice("getMapRequest: " + rq);
+	//window.console.log("getMapRequest: " + rq);
+	return rq;
+ * rephrases the featureInfoRequest
+ * @param {Point} clickPoint map-click position {@link Point}
+ * @return featureInfoRequest, onlineresource + params
+ * @type string
+wms_const.prototype.getFeatureInfoRequest = function(mapObj, clickPoint){
+	//check layers and querylayers first
+	var querylayers = this.getQuerylayers(mapObj);
+	if(!layers || !querylayers){
+		return false;
+	var rq = this.wms_getfeatureinfo;
+	rq += mb_getConjunctionCharacter(this.wms_getfeatureinfo);
+		rq += "WMTVER=" + this.wms_version + "&REQUEST=feature_info";
+	else{
+		rq += "VERSION=" + this.wms_version + "&REQUEST=GetFeatureInfo&SERVICE=WMS";
+	rq += "&QUERY_LAYERS=" + querylayers.join(",");
+	rq += "&INFO_FORMAT=" + this.gui_wms_featureinfoformat;
+	rq += "&EXCEPTIONS=application/vnd.ogc.se_xml";
+	rq += "&X=" + clickPoint.x;
+	rq += "&Y=" + clickPoint.y;
+	//console.log(rq);
+	return rq;
+ * sets Opacity of WMS
+ * @param {Integer} new opacity percentage value
+wms_const.prototype.setOpacity = function(opacity){
+	//calc new opacity
+	this.gui_wms_mapopacity = parseInt(opacity)/100;
+	if(this.gui_wms_mapopacity>1||isNaN(this.gui_wms_mapopacity))
+		this.gui_wms_mapopacity=1;
+	if(this.gui_wms_mapopacity<0)
+		this.gui_wms_mapopacity=0;
+	if (this.gui_wms_visible > 0) {
+		//get div id
+		var divId = null;
+		for (var i=0; i < wms.length; i++) {
+			if (this.wms_id == wms[i].wms_id) {
+				var divId = 'div_'+i;
+				break;
+		if(!divId)
+			return;
+		//TODO: check if mapframe1 is the right mapframe
+		wmsImage = parent.mapframe1.document.getElementById(divId);
+		if (wmsImage != null) {
+			wmsImage.style.opacity = this.gui_wms_mapopacity;
+			wmsImage.style.MozOpacity = this.gui_wms_mapopacity;
+			wmsImage.style.KhtmlOpacity = this.gui_wms_mapopacity;
+			wmsImage.style.filter = "alpha(opacity=" + this.gui_wms_mapopacity*100 + ")";
+ * get all visible layers
+ * @return array of layernames
+ * @type string[]
+wms_const.prototype.getLayers = function(mapObj){
+	try {
+		//visibility of the wms
+		var wmsIsVisible = (this.gui_wms_visible > 0);
+		if(!wmsIsVisible){
+			return false;
+		visibleLayers = [];
+		for(var i=0; i< this.objLayer.length; i++){
+			var isVisible = (this.objLayer[i].gui_layer_visible === 1);
+			var hasNoChildren = (!this.objLayer[i].has_childs);
+			if (isVisible && hasNoChildren){
+				if(this.objLayer[i].checkScale(mapObj)){
+					//console.log("checkLayer: " + this.objLayer[i].layer_name);
+					visibleLayers.push(this.objLayer[i].layer_name);
+		if(visibleLayers.length === 0){
+			return false;
+		return visibleLayers;
+	catch (e) {
+		alert(e);
+ * get the actual style of all visible layers
+ * @return commaseparated list of actual layerstyles
+ * @type string
+wms_const.prototype.getLayerstyles = function(mapObj){
+	var layerstyles = '';
+	var styles = [];
+	if(layers){
+		for(i = 0; i < layers.length; i++){
+			var style = this.getCurrentStyleByLayerName(layers[i]);
+			if(!style){
+				style = '';
+			styles.push(style);
+		return styles;
+	return false;
+ * check if layer is parentLayer
+ * @param layername
+ * @return the parent value of the given layer
+ * @type integer
+wms_const.prototype.checkLayerParentByLayerName = function(layername){
+		if(this.objLayer[i].layer_name == layername){
+			return this.objLayer[i].layer_parent;
+ * get the title of the current layer
+ * @return the title of the given layer
+ * @type string
+wms_const.prototype.getTitleByLayerName = function(layername){
+			return this.objLayer[i].layer_title;
+ * get the current style of the layer
+ * @return the stylename of the given layer
+ * @type string
+wms_const.prototype.getCurrentStyleByLayerName = function(layername){
+			if(this.objLayer[i].gui_layer_style === '' || this.objLayer[i].gui_layer_style === null){
+				return false;
+			else{
+				return this.objLayer[i].gui_layer_style;
+ * get the legendurl of the gui layer style
+ * @param stylename
+ * @return the legendurl of the given style
+ * @type string
+wms_const.prototype.getLegendUrlByGuiLayerStyle = function(layername,guiLayerStyle){
+			if(this.objLayer[i].layer_style.length === 0){
+				return false;
+			for(var k=0; k< this.objLayer[i].layer_style.length; k++){
+				if(this.objLayer[i].layer_style[k].name == guiLayerStyle){
+					var legendUrl = this.objLayer[i].layer_style[k].legendurl;
+					if (this.gui_wms_sldurl !== "") {
+					 		legendUrl += "&SLD="+escape(this.gui_wms_sldurl);
+					if(legendUrl !=='' && legendUrl !== null && typeof(legendUrl) != 'undefined'){
+						return legendUrl;
+					else {
+						return false;
+	return false;
+ * get all querylayers
+ * @type string[]
+wms_const.prototype.getQuerylayers = function(){
+	queryLayers = [];
+		if(this.objLayer[i].gui_layer_querylayer === 1 && ! this.objLayer[i].has_childs ){
+			queryLayers.push(this.objLayer[i].layer_name);
+	if(queryLayers.length === 0){
+		return false;
+	return queryLayers;
+ * get a layer Object by layer_pos
+ * @param int payer_pos layer_pos of layer you want to get
+ * @return object layer
+wms_const.prototype.getLayerByLayerPos = function(layer_pos){
+	for(var i=0;i<this.objLayer.length;i++){
+		if(this.objLayer[i].layer_pos == layer_pos) {
+			return this.objLayer[i];
+	return null;
+ * get the state of sublayers from a specified layer
+ * @param int layer_id of the parent layer
+ * @param String type "visible" or "querylayer"
+ * @return int -1 if state differs else the state
+wms_const.prototype.getSublayerState = function(layer_id, type){
+	var i;
+	var state=-1,value;
+	for(i = 0; i < this.objLayer.length; i++){
+		if(this.objLayer[i].layer_id==layer_id) {
+			break;
+	//go throught sublayers
+	for(var j = i+1; j < this.objLayer.length; j++){
+		if(this.objLayer[i].parent_layer == this.objLayer[j].parent_layer) {
+			break;
+		if(type == "visible") {
+			value = this.objLayer[j].gui_layer_visible;
+		else if(type == "querylayer") {
+			value = this.objLayer[j].gui_layer_querylayer;
+		if(state == -1) {
+			state = value;
+		if(state != value) {
+			return -1;
+	return state;
+ * handle change of visibility / quaryability of a layer
+ * @param string layer_name of layer to handle
+ * @param string type of change ("visible" or "querylayer")
+ * @param int value of the change
+wms_const.prototype.handleLayer = function(layer_name, type, value){
+	var i;
+		if(this.objLayer[i].layer_name==layer_name) {
+			break;
+	//Set visibility/queryability of Layer and Sublayers
+	for(var j = i; j < this.objLayer.length; j++){
+		if (i != j && this.objLayer[i].layer_parent >= this.objLayer[j].layer_parent) {
+			break;
+			this.objLayer[j].gui_layer_visible = parseInt(value, 10);
+		else if(type=="querylayer") {
+			this.objLayer[j].gui_layer_querylayer = parseInt(value, 10);
+	//Update visibility/queryability of parent layer
+	var parentLayer = this.getLayerByLayerPos(this.objLayer[i].layer_parent);
+	if(parentLayer){
+		var state = this.getSublayerState(parentLayer.layer_id, type);
+		if(state!=-1){
+				this.objLayer[j].gui_layer_visible = state;
+				this.objLayer[j].gui_layer_querylayer = state;
+ * move a layer (with his sublayers) up or down
+ * @param int layerId layer_id of layer to move
+ * @param boolean moveUp true to move up or false to move down
+ * @return boolean success
+wms_const.prototype.moveLayer = function(layerId, moveUp){
+	var iLayer=-1;
+	var i;
+	//find layer to move
+	for(i=0;i<this.objLayer.length;i++){
+		if(this.objLayer[i].layer_id==layerId){
+			iLayer=i;
+			break;
+	if(iLayer==-1) {
+		return false;
+	var upperLayer = -1;
+	var lowerLayer = -1;
+	//find layer to swap position with
+	var parentLayer = this.objLayer[iLayer].layer_parent;
+	if(moveUp){
+		lowerLayer = iLayer;
+		//find previous layer on same level
+		for(i=iLayer-1;i>0;i--){
+			if(parentLayer == this.objLayer[i].layer_parent){
+				upperLayer = i;
+				break;
+		if(upperLayer == -1){
+			//alert("The Layer you selected is already on top of parent Layer/WMS");
+			return false;
+	else{
+		upperLayer = iLayer;
+		//find next layer on same level
+		for(i=iLayer+1;i<this.objLayer.length;i++){
+				lowerLayer = i;
+				break;
+		if(lowerLayer == -1){
+			//alert("The Layer you selected is already on bottom of parent Layer/WMS");
+			return false;
+	//calc number of layers to move down
+	var layersDown = lowerLayer - upperLayer;
+	//get number of layers to move up
+	for(i=lowerLayer+1; i<this.objLayer.length; i++){
+			break;
+	var layersUp = i - lowerLayer;
+	//do moving
+	var temp = [];
+	for(i=0;i<layersDown+layersUp;i++){
+		temp[temp.length]=this.objLayer[upperLayer+i];
+	for(i=0;i<layersUp;i++){
+		this.objLayer[upperLayer+i]=temp[i+layersDown];
+	for(i=0;i<layersDown;i++){
+		this.objLayer[upperLayer+layersUp+i]=temp[i];
+	return true;
+function wms_add_data_type_format(datatype,dataformat){
+	var insertDataFormat = true;
+	for (var i = 0 ; i < wms[wms.length-1].data_type.length ; i ++) {
+		if (wms[wms.length-1].data_type[i] == datatype && wms[wms.length-1].data_format[i] == dataformat) {
+			insertDataFormat = false;
+	if (insertDataFormat === true) {
+		wms[wms.length-1].data_type[wms[wms.length-1].data_type.length] = datatype;
+		wms[wms.length-1].data_format[wms[wms.length-1].data_format.length] = dataformat;
+function wms_addSRS(epsg,minx,miny,maxx,maxy){
+	wms[wms.length-1].gui_epsg[wms[wms.length-1].gui_epsg.length] = epsg;
+	wms[wms.length-1].gui_minx[wms[wms.length-1].gui_minx.length] = minx;
+	wms[wms.length-1].gui_miny[wms[wms.length-1].gui_miny.length] = miny;
+	wms[wms.length-1].gui_maxx[wms[wms.length-1].gui_maxx.length] = maxx;
+	wms[wms.length-1].gui_maxy[wms[wms.length-1].gui_maxy.length] = maxy;
+function wms_addLayerStyle(styleName, styleTitle, count, layerCount, styleLegendUrl, styleLegendUrlFormat){
+	var currentLayer = wms[wms.length-1].objLayer[layerCount];
+	if (currentLayer) {
+		currentLayer.layer_style[count] = {};
+		currentLayer.layer_style[count].name = styleName;
+		currentLayer.layer_style[count].title = styleTitle;
+		currentLayer.layer_style[count].legendurl = styleLegendUrl;
+		currentLayer.layer_style[count].legendurlformat = styleLegendUrlFormat;
+//TODO: add layerstyle handling....
+//layer
+function wms_add_layer(
+			layer_parent,
+			layer_uid,
+			layer_name,
+			layer_title,
+			layer_dataurl_href,
+			layer_pos,
+			layer_queryable,
+			layer_minscale,
+			layer_maxscale,
+			layer_metadataurl,
+			gui_layer_wms_id,
+			gui_layer_status,
+			gui_layer_style,
+			gui_layer_selectable,
+			gui_layer_visible,
+			gui_layer_queryable,
+			gui_layer_querylayer,
+			gui_layer_minscale,
+			gui_layer_maxscale,
+			gui_layer_wfs_featuretype){
+	wms[wms.length-1].objLayer[wms[wms.length-1].objLayer.length] = new wms_layer(
+											layer_parent,
+											layer_uid,
+											layer_name,
+											layer_title,
+											layer_pos,
+											layer_queryable,
+											layer_minscale,
+											layer_maxscale,
+											gui_layer_wms_id,
+											gui_layer_status,
+											gui_layer_style,
+											parseInt(gui_layer_selectable, 10),
+											parseInt(gui_layer_visible, 10),
+											parseInt(gui_layer_queryable, 10),
+											parseInt(gui_layer_querylayer, 10),
+											parseInt(gui_layer_minscale, 10),
+											parseInt(gui_layer_maxscale, 10),
+											gui_layer_wfs_featuretype );
+	var parentLayer = wms[wms.length-1].getLayerByLayerPos(parseInt(layer_parent, 10));
+	if(parentLayer) {
+		parentLayer.has_childs = true;
+function layer_addEpsg(epsg,minx,miny,maxx,maxy){
+	var j = wms[wms.length-1].objLayer.length-1;
+	var k = wms[wms.length-1].objLayer[j].layer_epsg.length;
+	var currentLayer = wms[wms.length-1].objLayer[j];
+	currentLayer.layer_epsg[k]={};
+	currentLayer.layer_epsg[k].epsg = epsg;
+	currentLayer.layer_epsg[k].minx = minx;
+	currentLayer.layer_epsg[k].miny = miny;
+	currentLayer.layer_epsg[k].maxx = maxx;
+	currentLayer.layer_epsg[k].maxy = maxy;
+function wms_layer(
+			layer_parent,
+			wms_layer_uid,
+			layer_name,
+			layer_title,
+			layer_pos,
+			layer_queryable,
+			layer_minscale,
+			layer_maxscale,
+			gui_layer_wms_id,
+			gui_layer_status,
+			gui_layer_style,
+	this.layer_id = wms_layer_count;
+	this.layer_uid = wms_layer_uid;
+	this.layer_parent = layer_parent;
+	this.layer_name = layer_name;
+	this.layer_title = layer_title;
+	this.layer_dataurl_href = layer_dataurl_href;
+	this.layer_pos = layer_pos;
+	this.layer_queryable = layer_queryable;
+	this.layer_minscale = layer_minscale;
+	this.layer_maxscale = layer_maxscale;
+	this.layer_metadataurl = layer_metadataurl;
+	this.layer_epsg = [];
+	this.gui_layer_wms_id = gui_layer_wms_id;
+	this.gui_layer_status = gui_layer_status;
+	this.gui_layer_selectable = gui_layer_selectable;
+	this.gui_layer_visible = gui_layer_visible;
+	this.gui_layer_queryable = gui_layer_queryable;
+	this.gui_layer_querylayer = gui_layer_querylayer;
+	this.gui_layer_minscale = gui_layer_minscale;
+	this.gui_layer_maxscale = gui_layer_maxscale;
+	this.gui_layer_style = gui_layer_style;
+	this.gui_layer_wfs_featuretype = gui_layer_wfs_featuretype;
+	this.gui_layer_style = null;
+	this.has_childs = false;
+	this.layer_style = [];
+	wms_layer_count++;
+ * check the scale of the layer
+ * @param Object mapObj the mapbender mapObject of the layer
+ * @return boolean if the layer is in scale or not
+ * @type boolean
+wms_layer.prototype.checkScale = function(mapObj){
+	var minScale = parseInt(this.gui_layer_minscale, 10);
+	var maxScale = parseInt(this.gui_layer_maxscale, 10);
+	var currentScale = parseInt(mapObj.getScale(), 10);
+	if(minScale === 0 && maxScale === 0){
+		return true;
+	if(minScale > currentScale || (maxScale !== 0 && maxScale < currentScale)) {
+		return false;
+	return true;
+ * set visibility of the layer
+ * @param boolean visible visibility on/off
+wms_layer.prototype.setVisible = function(visible){
+	this.gui_layer_visible = parseInt(visible, 10);
+	//console.log("setVisible(%i) for Layer %s",visible, this.layer_name);
+ * set queryability of the layer
+ * @param boolean queryable queryability on/off
+wms_layer.prototype.setQueryable = function(queryable){
+	this.gui_layer_querylayer = parseInt(queryable, 10);
+	//console.log("setQueryable(%i) for Layer %s",queryable, this.layer_name);
Added: branches/testbaudson_dev/mod/ol/openlayers.php
--- branches/testbaudson_dev/mod/ol/openlayers.php	                        (rev 0)
+++ branches/testbaudson_dev/mod/ol/openlayers.php	2008-06-30 14:13:03 UTC (rev 2566)
@@ -0,0 +1,58 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/Openlayers
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+var ol_options = { scales: [50000000, 30000000, 10000000, 5000000],
+                resolutions: [1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125],
+                minScale: 50000000,
+                maxResolution: "auto",
+                maxExtent: new OpenLayers.Bounds(-180, -90, 90, 180),
+                maxResolution: 0.17578125,
+                maxScale: 10000000,
+                minResolution: "auto",
+                minExtent: new OpenLayers.Bounds(-1, -1, 1, 1),
+                minResolution: 0.0439453125,
+                numZoomLevels: 5,
+                units: "degrees"
+OpenLayers.ImgPath = "../img/openlayers/";
+var ol_map = new OpenLayers.Map('<?php echo $e_id;?>', {'maxResolution': 1.40625/2});
+	ol_map.zoomToMaxExtent();
+<?php
+$sql = "SELECT fkey_wms_id FROM gui_wms WHERE fkey_gui_id = $1 ORDER BY gui_wms_position";
+$v = array($_SESSION["mb_user_gui"]);
+$t = array('s');
+$res = db_prep_query($sql,$v,$t);
+$cnt=0;
+while($row = db_fetch_array($res)){
+	$mywms = new wms();
+	$mywms->createObjFromDB($_SESSION["mb_user_gui"],$row["fkey_wms_id"]);
+	$mywms->createOlObjFromWMS($cnt==0);
+	$cnt++;
More information about the Mapbender_commits mailing list
