[Mapbender-commits] r2258 - in branches/nimix_dev/http: javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Mar 14 12:49:41 EDT 2008
Author: nimix
Date: 2008-03-14 12:49:40 -0400 (Fri, 14 Mar 2008)
New Revision: 2258
   branches/nimix_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php
   branches/nimix_dev/http/php/mod_addWMSfromfilteredList_server.php
add element var to select gui to display, 3 db buttons (gui, group, all)
Modified: branches/nimix_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php
--- branches/nimix_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php	2008-03-14 13:42:49 UTC (rev 2257)
+++ branches/nimix_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php	2008-03-14 16:49:40 UTC (rev 2258)
@@ -56,9 +56,14 @@
 try{if(option_gui){}}catch(e){option_all='1';};
 try{if(option_db){}}catch(e){option_all='1';};
 try{if(capabilitiesInput){}}catch(e){capabilitiesInput='0';};
+try{if(gui_list){}}catch(e){gui_list='gui,gui1'};
+var guis = gui_list.split(",");
+if(gui_list==='')
+	guis = [];
 var global_source = "capabilities";  // "capabilities" || "db"
-var phpUrl = "../php/mod_addWMSfromfilteredList_server.php<?php echo $urlParameters;?>";
+var phpUrl = "../php/mod_addWMSfromfilteredList_server.php?<?php echo $urlParameters;?>";
 // ----------------- Load service --------------------
@@ -110,10 +115,12 @@
 function getWMSByGUI(guiId) {
+	if(guiId=="")
+		return getAllWMS();
 	imageOn();
 	window.opener.mb_ajax_json(phpUrl, {"command":"getWMSByGUI", "guiId":guiId}, function (json, status) {
 		imageOff();
-		displayWMS(json.wms, guiId);
+		displayWMS(json.wms);
@@ -253,7 +260,16 @@
 		for (var i = 0; i < guiArray.length; i++) {
 			var onClick = "getWMSByGUI('" + guiArray[i].id + "')";
-			addRow("resultTableBody", guiArray[i].name, guiArray[i].description, onClick);
+			if(guis.length>0){
+				for(var j=0; j < guis.length; j++){
+					if(guiArray[i].id==guis[j]){
+						addRow("resultTableBody", guiArray[i].name, guiArray[i].description, onClick);
+						break;
+			else
 	else {
@@ -261,14 +277,14 @@
-function displayWMS (wmsArray, guiId) {
+function displayWMS (wmsArray) {
 	if (wmsArray.length > 0) {
 		setTableHeader(selectWmsText, wmsNameText, wmsAbstractText);
 		for (var i = 0; i < wmsArray.length; i++) {
-			if (global_source == "db" && typeof(guiId) !== "undefined" ) {
-				var onClick = "mod_addWMSfromDB('" + guiId + "', '" + wmsArray[i].id + "')";
+			if (global_source == "db" && typeof(wmsArray[i].guiId) !== "undefined" ) {
+				var onClick = "mod_addWMSfromDB('" + wmsArray[i].guiId + "', '" + wmsArray[i].id + "')";
 			else {
 				var onClick = "mod_addWMSfromfilteredList('" + wmsArray[i].getCapabilitiesUrl + "', '" + wmsArray[i].version + "')";
@@ -291,7 +307,7 @@
 		<tr>
 			<td>Capabilities - URL:</td>
 			<td><input type="text" id="CapURL" name="CapURL"/></td>
-			<td><input type="button" value="Hinzuf&uuml;gen" onclick="mod_addWmsfromURL();"></td>
+			<td><input type="button" value="add" onclick="mod_addWmsfromURL();"></td>
 		</tr>
 	</table>
 </form>
@@ -299,10 +315,12 @@
 <form name='addWMSForm'>
 	<table border='0' cellpadding='3'  rules='rows'>
 		<tr>
-			<td><input type='button' class='wms_button' name='button_all' id='button_all' value='all wms' onclick='setSource("capabilities");getAllWMS()'></td>
+			<td><input type='button' class='wms_button' name='button_all' id='button_all' value='all wms' onclick='setSource("capabilities");getWMSByGUI(gui_list)'></td>
 			<td><input type='button' class='wms_button' name='button_group' id='button_group' value='group' onclick = 'setSource("capabilities");getGroups()'></td>
 			<td><input type='button' class='wms_button' name='button_gui' id='button_gui' value='gui' onclick = 'setSource("capabilities");getGUIs()'></td>
-			<td><input type='button' class='wms_button' name='button_db' id='button_db' value='db' onclick = 'setSource("db");getGUIs()'></td>
+			<td><input type='button' class='wms_button' name='button_dbGui' id='button_dbGui' value='gui db' onclick = 'setSource("db");getGUIs()'></td>
+			<td><input type='button' class='wms_button' name='button_dbGroup' id='button_dbGroup' value='group db' onclick = 'setSource("db");getGroups()'></td>
+			<td><input type='button' class='wms_button' name='button_dbAll' id='button_dbAll' value='all wms db' onclick = 'setSource("db");getWMSByGUI(gui_list)'></td>
 		</tr>
 	</table>
 </form>
Modified: branches/nimix_dev/http/php/mod_addWMSfromfilteredList_server.php
--- branches/nimix_dev/http/php/mod_addWMSfromfilteredList_server.php	2008-03-14 13:42:49 UTC (rev 2257)
+++ branches/nimix_dev/http/php/mod_addWMSfromfilteredList_server.php	2008-03-14 16:49:40 UTC (rev 2258)
@@ -76,7 +76,7 @@
 else if ($command == "getAllWMS") {
 	$resultObj["wms"] = array();
-	$sql = "SELECT DISTINCT wms.wms_id, wms.wms_title, gettext($1, wms.wms_abstract) as wms_abstract, wms.wms_getcapabilities, wms.wms_version ";
+	$sql = "SELECT wms.wms_id, wms.wms_title, gettext($1, wms.wms_abstract) as wms_abstract, wms.wms_getcapabilities, wms.wms_version, MIN(gui_wms.fkey_gui_id) ";
 	$sql .= "FROM wms, gui_wms ";
 	$sql .= "WHERE wms.wms_id = gui_wms.fkey_wms_id AND gui_wms.fkey_gui_id IN (";
 	$v = array($_SESSION["mb_lang"]);
@@ -90,41 +90,52 @@
 		array_push($v, $guiIdArray[$i]);
 		array_push($t, "s");
-	$sql .= ") ORDER BY wms_title";
+	$sql .= ") GROUP BY wms.wms_id, wms.wms_title, wms_abstract, wms.wms_getcapabilities, wms.wms_version ";
+	$sql .= "ORDER BY wms_title ";
 	$res = db_prep_query($sql,$v,$t);
 	while ($row = db_fetch_array($res)) {
-		$resultArray = array("id" => $row["wms_id"], "title" => $row["wms_title"], "abstract" => $row["wms_abstract"], "getCapabilitiesUrl" => $row["wms_getcapabilities"], "version" => $row["wms_version"]);
+		$resultArray = array("id" => $row["wms_id"], "title" => $row["wms_title"], "abstract" => $row["wms_abstract"], "getCapabilitiesUrl" => $row["wms_getcapabilities"], "version" => $row["wms_version"], "guiId" => $row["fkey_gui_id"]);
 		array_push($resultObj["wms"], $resultArray);
 else if ($command == "getWMSByGroup") {
-	$sql = "SELECT DISTINCT wms_id, wms_title, gettext($1, wms_abstract) as wms_abstract, wms_getcapabilities, wms_version ";
+	$sql = "SELECT wms_id, wms_title, gettext($1, wms_abstract) as wms_abstract, wms_getcapabilities, wms_version, MIN(gui_wms.fkey_gui_id) ";
 	$sql .= "FROM wms, gui_wms, gui_mb_group ";
-	$sql .= "WHERE wms.wms_id = gui_wms.fkey_wms_id AND gui_wms.fkey_gui_id = gui_mb_group.fkey_gui_id AND gui_mb_group.fkey_mb_group_id = $2";
+	$sql .= "WHERE wms.wms_id = gui_wms.fkey_wms_id AND gui_wms.fkey_gui_id = gui_mb_group.fkey_gui_id AND gui_mb_group.fkey_mb_group_id = $2 ";
+	$sql .= "GROUP BY wms_id, wms_title, wms_abstract, wms_getcapabilities, wms_version ";
 	$v = array($_SESSION["mb_lang"], $groupId);
 	$t = array("s", "i");
 	$res = db_prep_query($sql, $v, $t);
 else if ($command == "getWMSByGUI") {
-	$sql .= "FROM wms, gui_wms WHERE wms.wms_id = gui_wms.fkey_wms_id AND fkey_gui_id = $2";
-	$v = array($_SESSION["mb_lang"], $guiId);
-	$t = array("s", "s");
+	$sql = "SELECT wms_id, wms_title, gettext($1, wms_abstract) as wms_abstract, wms_getcapabilities, wms_version, MIN(fkey_gui_id) ";
+	$sql .= "FROM wms, gui_wms WHERE wms.wms_id = gui_wms.fkey_wms_id AND fkey_gui_id IN (";
+	$v = array($_SESSION["mb_lang"]);
+	$t = array("s");
+	$s = array();
+	$guiIds = split(",",$guiId);
+	for($i=0;$i<count($guiIds);$i++){
+		array_push($v, $guiIds[$i]);
+		array_push($t, 's');
+		array_push($s, "$".strval($i+2));
+	$sql .= implode(",",$s).") ";
+	$sql .= "GROUP BY wms_id, wms_title, wms_abstract, wms_getcapabilities, wms_version";
More information about the Mapbender_commits mailing list
