[Mapbender-commits] r2290 - in branches/nimix_dev: http/classes http/frames owsproxy/http owsproxy/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Mar 25 09:48:53 EDT 2008
Author: nimix
Date: 2008-03-25 09:48:53 -0400 (Tue, 25 Mar 2008)
New Revision: 2290
   branches/nimix_dev/http/classes/class_administration.php
   branches/nimix_dev/http/frames/login.php
   branches/nimix_dev/owsproxy/http/classes/class_QueryHandler.php
   branches/nimix_dev/owsproxy/http/index.php
add external owsproxy access
Modified: branches/nimix_dev/http/classes/class_administration.php
--- branches/nimix_dev/http/classes/class_administration.php	2008-03-25 11:07:20 UTC (rev 2289)
+++ branches/nimix_dev/http/classes/class_administration.php	2008-03-25 13:48:53 UTC (rev 2290)
@@ -29,6 +29,48 @@
  * @uses phpmailer
 class administration{
+	 * authentificates a user
+	 * @param string name of the user
+	 * @param string passwort for the user
+	 * @return mixed row of the user in db if authentification was successful or false otherwise
+	function authUser($name,$pw){
+		$setEncPw = false;
+		$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = $2";
+		$v = array($name,md5($pw));
+		$t = array('s','s');
+		$res = db_prep_query($sql,$v,$t);
+		if($row = db_fetch_array($res)){
+			return $row;
+		else if(SYS_DBTYPE == 'pgsql' && $setEncPw == true){
+			// 	unencrypted pw in postgres without md5-support?
+			$v = array($name,$pw);
+			$resn = db_prep_query($sql,$v,$t);
+			if($rown = db_fetch_array($resn)){
+				$sqlu = "UPDATE mb_user SET mb_user_password = $1 WHERE mb_user_id = $2";
+				$vu = array(md5($pw),$rown["mb_user_id"]);
+				$tu = array('s','i');
+				$rowu = db_prep_query($sqlu,$vu,$tu);
+				return $rown;
+		else if(SYS_DBTYPE == 'mysql' && $setEncPw == true){
+			$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = password($2)";
+				return $rown;
      * checks whether the passed email-address is valid / following a pattern
      * @todo is this an exact representation of the RFC 2822?
Modified: branches/nimix_dev/http/frames/login.php
--- branches/nimix_dev/http/frames/login.php	2008-03-25 11:07:20 UTC (rev 2289)
+++ branches/nimix_dev/http/frames/login.php	2008-03-25 13:48:53 UTC (rev 2290)
@@ -18,45 +18,11 @@
 ob_start();
 include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__) . "/../classes/class_administration.php");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
-function auth_user($name,$pw){
-	$setEncPw = false;
-	$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = $2";
-	$v = array($name,md5($pw));
-	$t = array('s','s');
-	$res = db_prep_query($sql,$v,$t);
-	if($row = db_fetch_array($res)){
-		return $row;
-	else if(SYS_DBTYPE == 'pgsql' && $setEncPw == true){
-		// 	unencrypted pw in postgres without md5-support?
-		$v = array($name,$pw);
-		$resn = db_prep_query($sql,$v,$t);
-		if($rown = db_fetch_array($resn)){
-			$sqlu = "UPDATE mb_user SET mb_user_password = $1 WHERE mb_user_id = $2";
-			$vu = array(md5($pw),$rown["mb_user_id"]);
-			$tu = array('s','i');
-			$rowu = db_prep_query($sqlu,$vu,$tu);
-			return $rown;
-	else if(SYS_DBTYPE == 'mysql' && $setEncPw == true){
-		$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = password($2)";
-			return $rown;
 function setSession(){
 	session_start();
@@ -143,7 +109,8 @@
-	$row = auth_user($name, $password);
+	$n = new administration();
+	$row = $n->authUser($name, $password);
 	// if given user data is found in database, set session data (db_fetch_array returns false if no row is found)
 	if($row){
Modified: branches/nimix_dev/owsproxy/http/classes/class_QueryHandler.php
--- branches/nimix_dev/owsproxy/http/classes/class_QueryHandler.php	2008-03-25 11:07:20 UTC (rev 2289)
+++ branches/nimix_dev/owsproxy/http/classes/class_QueryHandler.php	2008-03-25 13:48:53 UTC (rev 2290)
@@ -73,6 +73,12 @@
 		if($key == 'sid'){
 			return false;
+		if($key == 'name'){
+			return false;
+		if($key == 'password'){
+			return false;
 		else if($key == $this->owsproxyServiceKey){
 			return false;
Modified: branches/nimix_dev/owsproxy/http/index.php
--- branches/nimix_dev/owsproxy/http/index.php	2008-03-25 11:07:20 UTC (rev 2289)
+++ branches/nimix_dev/owsproxy/http/index.php	2008-03-25 13:48:53 UTC (rev 2290)
@@ -35,20 +35,38 @@
 $owsproxyService = $_REQUEST['wms']; //ToDo: change this to 'service' in the apache url-rewriting
 $query = new QueryHandler();
+$n = new administration();
 // an array with keys and values toLoserCase -> caseinsensitiv
 $reqParams = $query->getRequestParams();
 $notice = new mb_notice("owsproxy id:".$query->getOwsproxyServiceId());
-// check session
-session_id($_REQUEST["sid"]);
-session_start();
-if(!$_SESSION['mb_user_id']){
-	$notice = new mb_notice("Permission denied");
-	throwE("Permission denied");
-	die();
+$user_id = '';
+$name = $_REQUEST["name"];
+$password = $_REQUEST["password"];
+//look if username and password is given
+if(isset($name) && $name != '' && isset($password) && $password != ''){
+	$user_row = $n->authUser($_REQUEST["name"], $_REQUEST["password"]);
+	if(!$user_row){
+		$notice = new mb_notice("Permission denied");
+		throwE("Permission denied");
+		die();
+	$user_id = $user_row["mb_user_id"];
+else{
+	// check session
+	session_id($_REQUEST["sid"]);
+	session_start();
+	if(!$_SESSION['mb_user_id']){
+		die();
+	$user_id = $_SESSION['mb_user_id'];
 //if($_SESSION['mb_user_ip'] != $_SERVER['REMOTE_ADDR']){
 //	throwE(array("No session data available.","Permission denied.","Please authenticate."));
@@ -56,7 +74,6 @@
 /*************  workflow ************/
-$n = new administration();
 switch (strtolower($reqParams['request'])) {
 	case 'getcapabilities':
 		$arrayOnlineresources = checkWmsPermission($query->getOwsproxyServiceId());
@@ -428,8 +445,8 @@
  * @return array array with detailed information about requested wms
 function checkWmsPermission($wms){
-	global $con, $n;
-	$myguis = $n->getGuisByPermission($_SESSION["mb_user_id"],true);
+	global $con, $n, $user_id;
+	$myguis = $n->getGuisByPermission($user_id,true);
 	$mywms = $n->getWmsByOwnGuis($myguis);
 	$sql = "SELECT * FROM wms WHERE wms_owsproxy = $1";
@@ -464,8 +481,8 @@
  * @return array array with detailed information on reqested wfs
 function checkWfsPermission($wfsOws, $features){
-	global $con, $n;
-	$myconfs = $n->getWfsConfByPermission($_SESSION["mb_user_id"]);
+	$myconfs = $n->getWfsConfByPermission($user_id);
 	//check if we know the features requested
 	if(count($features) == 0){
@@ -522,12 +539,12 @@
 function checkLayerPermission($wms_id,$l){
-	global $n, $owsproxyService;
+	global $n, $owsproxyService, $user_id;
 //	$notice = new mb_notice("owsproxy: checkLayerpermission: wms: ".$wms_id.", layer: ".$l);
 	$myl = split(",",$l);
 	$r = array();
 	foreach($myl as $mysl){
-		if($n->getLayerPermission($wms_id, $mysl, $_SESSION["mb_user_id"]) === true){
+		if($n->getLayerPermission($wms_id, $mysl, $user_id) === true){
 			array_push($r, $mysl);
More information about the Mapbender_commits mailing list
