[Mapbender-commits] r2305 - in branches/nimix_dev: http/classes http/css http/frames http/javascripts http/php resources/db/mysql resources/db/postgresql resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Mar 27 08:22:20 EDT 2008
Author: nimix
Date: 2008-03-27 08:22:20 -0400 (Thu, 27 Mar 2008)
New Revision: 2305
Added:
   branches/nimix_dev/http/php/mod_tab_messages.php
   branches/nimix_dev/resources/db/update/mod_switchLocale_noreload.sql
Removed:
   branches/nimix_dev/http/php/mod_wfs_save.php
   branches/nimix_dev/http/classes/class_locale.php
   branches/nimix_dev/http/css/metadata.css
   branches/nimix_dev/http/frames/index.php
   branches/nimix_dev/http/javascripts/core.js
   branches/nimix_dev/http/javascripts/map.js
   branches/nimix_dev/http/javascripts/map.php
   branches/nimix_dev/http/javascripts/mod_tab.js
   branches/nimix_dev/http/javascripts/mod_wfs_gazetteer_client.php
   branches/nimix_dev/http/javascripts/popup.js
   branches/nimix_dev/http/php/mb_listKMLs.php
   branches/nimix_dev/http/php/mb_listWMCs.php
   branches/nimix_dev/http/php/mod_button_tooltips.php
   branches/nimix_dev/http/php/mod_changeEPSG.php
   branches/nimix_dev/http/php/mod_changeEPSG_dynamic.php
   branches/nimix_dev/http/php/mod_changePassword.php
   branches/nimix_dev/http/php/mod_deleteGUI.php
   branches/nimix_dev/http/php/mod_deleteWFS.php
   branches/nimix_dev/http/php/mod_editElementVars.php
   branches/nimix_dev/http/php/mod_editSelf.php
   branches/nimix_dev/http/php/mod_editWMS_Metadata.php
   branches/nimix_dev/http/php/mod_edit_element_vars.php
   branches/nimix_dev/http/php/mod_edit_metadata.php
   branches/nimix_dev/http/php/mod_getStyles.php
   branches/nimix_dev/http/php/mod_newGui.php
   branches/nimix_dev/http/php/mod_owsproxy_conf.php
   branches/nimix_dev/http/php/mod_saveWKT.php
   branches/nimix_dev/http/php/mod_switchLocale_noreload.php
   branches/nimix_dev/http/php/mod_updateWMS.php
   branches/nimix_dev/http/php/mod_wfs_edit.php
   branches/nimix_dev/http/php/mod_wfs_server.php
   branches/nimix_dev/http/php/mod_zoomCoords.php
   branches/nimix_dev/http/php/mod_zoomCoords_en.php
   branches/nimix_dev/http/php/nestedSets.php
   branches/nimix_dev/resources/db/mysql/mysql_schema.sql
   branches/nimix_dev/resources/db/postgresql/pgsql_schema.sql
   branches/nimix_dev/resources/db/update/update_postgresql_db.sql
merge 2.5 changes
Modified: branches/nimix_dev/http/classes/class_locale.php
--- branches/nimix_dev/http/classes/class_locale.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/classes/class_locale.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -33,10 +33,11 @@
 	var $browserLanguages = null;
 	var $os = null;
 	var $name = null;
-	var $defaultLanguage = "de";
+	var $defaultLanguage = "en";
 	var $status = "No locale set.";
 	function Mb_locale($languageId) {
+  		$e = new Mb_notice("class_locale: setting locale to " . $languageId);
 		if (!$this->setCurrentLocale($languageId)) {
 			$e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
@@ -176,6 +177,14 @@
                       'en' => 'en_US',
                       'de_DE' => 'de_DE',
                       'de' => 'de_DE',
+                      'bg_BG' => 'bg_BG',
+                      'bg' => 'bg_BG',
+                      'es_ES' => 'es_ES',
+                      'es' => 'es_ES',
+                      'nl_NL' => 'nl_NL',
+                      'nl' => 'nl_NL',
+                      'gr_GR' => 'gr_GR',
+                      'gr' => 'gr_GR',
                       'it_IT' => 'it_IT',
                       'it' => 'it_IT');
Modified: branches/nimix_dev/http/css/metadata.css
--- branches/nimix_dev/http/css/metadata.css	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/css/metadata.css	2008-03-27 12:22:20 UTC (rev 2305)
@@ -21,8 +21,7 @@
 	border: 1px;
 	margin-right: 4px;
 	margin-left: 6px;
-	text-align: right;
+	text-align: left;
Modified: branches/nimix_dev/http/frames/index.php
--- branches/nimix_dev/http/frames/index.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/frames/index.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -125,7 +125,9 @@
 				else {
 	      			echo "?";
-      			echo "e_id_css=".db_result($res,$i,"e_id")."&e_id=".db_result($res,$i,"e_id")."&e_target=".db_result($res,$i,"e_target")."'";
+      			echo "e_id_css=".db_result($res,$i,"e_id")."&e_id=".db_result($res,$i,"e_id") .
+					"&e_target=".db_result($res,$i,"e_target").
+					"&" . $urlParameters . "'";
 		else{
 			echo " src = '".preg_replace($pattern,$replacement,db_result($res,$i,"e_src"))."'";
Modified: branches/nimix_dev/http/javascripts/core.js
--- branches/nimix_dev/http/javascripts/core.js	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/javascripts/core.js	2008-03-27 12:22:20 UTC (rev 2305)
@@ -58,6 +58,11 @@
 var eventMouseMove = new MapbenderEvent();
+ * Switches the locale. Triggered by module switch_locale or onload(?)
+var eventLocalize = new MapbenderEvent();
  * Triggered after the map object has been created.
 var eventAfterMapObjectConstruction = new MapbenderEvent(); // possibly obsolete!
@@ -146,7 +151,8 @@
  * @deprecated
 function mb_registerL10nFunctions(stringFunction) {
-	mb_l10nFunctions[mb_l10nFunctions.length] = stringFunction;
+	eventLocalize.register(stringFunction)
+//	mb_l10nFunctions[mb_l10nFunctions.length] = stringFunction;
 var mb_PanSubElements = [];
Modified: branches/nimix_dev/http/javascripts/map.js
--- branches/nimix_dev/http/javascripts/map.js	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/javascripts/map.js	2008-03-27 12:22:20 UTC (rev 2305)
@@ -31,9 +31,12 @@
 function localize() {
+	eventLocalize.trigger();
 	for(var i=0; i<mb_l10nFunctions.length; i++){
 		eval(mb_l10nFunctions[i]);
 function mb_execloadWmsSubFunctions(){
 	eventAfterLoadWMS.trigger();
@@ -1909,30 +1912,53 @@
 function updateButtonTooltips(obj) {
-//	console.log("begin tooltip update");
+ * the buttons are only initialized on mouseover!
+ * So when localizing, not all buttons may have been registered
 	for(var i=0; i<mb_button.length; i++){
 //		console.log("button %i", i);
 		for(var j=0; j<obj.length; j++){
+			if (mb_button[i].elName == obj[j].id) {
 //			console.log("%s %s", mb_button[i].elName, obj[j].id);
-			if (mb_button[i].elName == obj[j].id) {
 				if (mb_button[i].frameName !== "") {
 					window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).title = obj[j].title;
 				else {
+	// an alternative, fixes above error,
+	// but this one only changes those in the main frame
+	var imageArray = document.getElementsByTagName("img");
+	for (var i = 0; i < imageArray.length; i++) {
+		for(var j=0; j<obj.length; j++){
+			if (imageArray[i].id == obj[j].id) {
+				document.getElementById(imageArray[i].id).title = obj[j].title;
-function mb_localizeButtons() {
+function mb_localizeButtons(){
 	mb_ajax_json("../php/mod_button_tooltips.php", function(obj, status){
 		updateButtonTooltips(obj);
-mb_registerInitFunctions("mb_registerL10nFunctions('mb_localizeButtons()');");
+eventLocalize.register(function () {
+	mb_localizeButtons();
+eventInit.register(function () {
  *   miscellaneous functions
Modified: branches/nimix_dev/http/javascripts/map.php
--- branches/nimix_dev/http/javascripts/map.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/javascripts/map.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -73,11 +73,11 @@
 // Load JavaScript libraries
+require_once(dirname(__FILE__) . "/../extensions/jquery.js");
 require_once(dirname(__FILE__) . "/../javascripts/map.js");
 require_once(dirname(__FILE__) . "/../javascripts/point.js");
 require_once(dirname(__FILE__) . "/../javascripts/map_obj.js");
 require_once(dirname(__FILE__) . "/../javascripts/wfs_obj.js");
-require_once(dirname(__FILE__) . "/../extensions/jquery.js");
 require_once(dirname(__FILE__) . "/../extensions/jqjson.js");
 require_once(dirname(__FILE__) . "/../javascripts/style.js");
@@ -141,4 +141,7 @@
\ No newline at end of file
Modified: branches/nimix_dev/http/javascripts/mod_tab.js
--- branches/nimix_dev/http/javascripts/mod_tab.js	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/javascripts/mod_tab.js	2008-03-27 12:22:20 UTC (rev 2305)
@@ -17,6 +17,21 @@
 mb_registerInitFunctions('tab_init()');
+	localizeTabs();
+	localizeTabs();
+function localizeTabs() {
+	mb_ajax_json("../php/mod_tab_messages.php", function(obj, status){
+		tabs.setTitles(obj);
 function tab_init(){
 	var obj = document.getElementById("tabs").style;
@@ -210,6 +225,20 @@
+	 * Sets the titles of each single tab after l10n
+	 * @param {Object} obj an array containing objects with id and title
+	this.setTitles = function (obj) {
+		for (var i = 0; i < this.count(); i++) {
+				if (this.get(i).module == obj[j].id) {
+					this.get(i).getNode().innerHTML = obj[j].title;
 	 * Returns the absolute coordinates of tab by the module ID
 	 * @param {String} id the ID of the GUI element within the tab.
Modified: branches/nimix_dev/http/javascripts/mod_wfs_gazetteer_client.php
--- branches/nimix_dev/http/javascripts/mod_wfs_gazetteer_client.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/javascripts/mod_wfs_gazetteer_client.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -179,7 +179,8 @@
 	removeChildNodes(bulbNode);
 	var imgNode = document.createElement("img");
 	imgNode.id = "wfsInfoImg";
-	imgNode.src = "../img/button_digitize/geomInfo.png";
+	//imgNode.src = "../img/button_digitize/geomInfo.png";
+	imgNode.src = "../img/tree_new/info.png";
 	imgNode.border = 0;
 	bulbNode.appendChild(imgNode);
 	bulbNode.href = "javascript:openwindow('../php/mod_featuretypeMetadata.php?wfs_conf_id=" + global_selectedWfsConfId.toString() + "');";
@@ -194,15 +195,15 @@
 	if (wfsGeomType.match(/Point/)) {
-		wfsGeomTypeNode.src = "../img/button_digitize/point_off.png";
+		wfsGeomTypeNode.src = "../img/button_digitize/point.png";
 		wfsGeomTypeNode.style.visibility = 'visible';
 	else if (wfsGeomType.match(/Line/)) {
-		wfsGeomTypeNode.src = "../img/button_digitize/line_off.png";
+		wfsGeomTypeNode.src = "../img/button_digitize/line.png";
 	else if (wfsGeomType.match(/Polygon/)) {
-		wfsGeomTypeNode.src = "../img/button_digitize/polygon_off.png";
+		wfsGeomTypeNode.src = "../img/button_digitize/polygon.png";
 	else {
@@ -211,7 +212,8 @@
 	// set image: remove this WFS
 	var wfsRemoveNode = document.getElementById("wfsRemove");
-	wfsRemoveNode.src = "../img/button_digitize/geomRemove.png";
+	//wfsRemoveNode.src = "../img/button_digitize/geomRemove.png";
+	wfsRemoveNode.src = "../img/tree_new/delete_wms.png";
 	wfsRemoveNode.style.visibility = 'visible';
 	// Internet explorer
 	if (parent.ie) {
@@ -441,9 +443,11 @@
 	if (event == "over") {
 		global_resultHighlight.add(currentGeom, cw_fillcolor);
+		global_resultHighlight.paint();
 	else if (event == "out"){
 		global_resultHighlight.del(currentGeom, cw_fillcolor);
 	else if (event == "click"){
@@ -455,6 +459,7 @@
 		parent.mb_calculateExtent(targetArray[0], bbox[0].x, bbox[0].y, bbox[1].x, bbox[1].y);
 		parent.zoom(targetArray[0], 'true', 1.0);
 	return true;
Modified: branches/nimix_dev/http/javascripts/popup.js
--- branches/nimix_dev/http/javascripts/popup.js	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/javascripts/popup.js	2008-03-27 12:22:20 UTC (rev 2305)
@@ -71,7 +71,7 @@
 		//Set vars
 		if(posx)this.options.left=posx;
-		if(posy)this.options.top=posx;
+		if(posy)this.options.top=posy;
 		if(width)this.options.width=width;
 		if(height)this.options.height=height;
 		if(title)this.options.title=title;
Modified: branches/nimix_dev/http/php/mb_listKMLs.php
--- branches/nimix_dev/http/php/mb_listKMLs.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mb_listKMLs.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -31,7 +31,7 @@
 $clientFilename = $_FILES["local_kml_filename"]["tmp_name"];
 $kmlUrl = $_POST["local_kml_url"];
-$form_target = $_SERVER["PHP_SELF"] . "?" . SID;
+$form_target = $self;
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 <html>
Modified: branches/nimix_dev/http/php/mb_listWMCs.php
--- branches/nimix_dev/http/php/mb_listWMCs.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mb_listWMCs.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -29,7 +29,6 @@
 $delWmcId = $_POST["del_wmc_id"];
 $clientFilename = $_FILES['local_wmc_filename']['tmp_name'];
 <html>
@@ -41,7 +40,7 @@
 		<title>Select web map contect document from list</title>
 	</head>
 	<body>
-		<form name='delete_wmc' action='<?php echo $form_target; ?>' method='POST'>
+		<form name='delete_wmc' action='<?php echo $self; ?>' method='POST'>
 			<input type='hidden' id='delete_wmc' name='del_wmc_id' value ='' >
 		</form>
@@ -161,14 +160,14 @@
 // load a WMC from file
 <h2 style='font-family: Arial, Helvetica, sans-serif; color: #808080;background-color: White;'><font align='left' color='#000000'>load WMC from file</font></h2>
-<form enctype="multipart/form-data" action="<?php echo $form_target;?>" method=POST target="_self">
+<form enctype="multipart/form-data" action="<?php echo $self;?>" method=POST target="_self">
 <input type='file' name='local_wmc_filename'>
 <input type='submit' value='load'>
 </form>
 <?php
 // load a WMC from list
-echo mb_listWMCs($wmcIdArray, $form_target);
+echo mb_listWMCs($wmcIdArray, $self);
 if ($wmcId && in_array($wmcId, $wmcIdArray)){
 	if ($action == "delete") {
Modified: branches/nimix_dev/http/php/mod_button_tooltips.php
--- branches/nimix_dev/http/php/mod_button_tooltips.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_button_tooltips.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -34,6 +34,6 @@
 $json = new Services_JSON();
 $output = $json->encode($buttonObj);
-header("Content-type:text/plain; Charset='UTF-8'");
+header("Content-type:text/plain; charset=utf-8");
 echo $output;
Modified: branches/nimix_dev/http/php/mod_changeEPSG.php
--- branches/nimix_dev/http/php/mod_changeEPSG.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_changeEPSG.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -195,7 +195,7 @@
 </script>
 </head>
 <body leftmargin="1" topmargin="1" onload="mod_changeEPSG_init()" bgcolor="red">
-<form action="<?php echo $PHP_SELF .'?'.SID  ?>" method='POST'>
+<form action="<?php echo $self;  ?>" method='POST'>
 <select class='epsg' name='epsg' onchange='mod_changeEPSG()'>
 <option value="">undefined</option>
 <option value="EPSG:4326">EPSG:4326</option>
Modified: branches/nimix_dev/http/php/mod_changeEPSG_dynamic.php
--- branches/nimix_dev/http/php/mod_changeEPSG_dynamic.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_changeEPSG_dynamic.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -229,7 +229,7 @@
 <?php
 /*insert EPSG into selectbox************************************************************************************/
-echo "<form action='" . $PHP_SELF . "?".SID."' method='post'>";
+echo "<form action='" . $self ."' method='post'>";
 echo "<select  class='epsg' name='epsg' onChange='mod_changeEPSG()'>";
 for($i=0; $i<$cnt_epsg_wms; $i++){
 	echo "<option value='" . $epsg_code[$i] . "' ";
Modified: branches/nimix_dev/http/php/mod_changePassword.php
--- branches/nimix_dev/http/php/mod_changePassword.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_changePassword.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -143,7 +143,7 @@
 /* HTML */
 echo "<fieldset><legend>Change password:</legend>";
-echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
+echo "<form name='form1' action='" . $self ."' method='post'>";
 echo "<table cellpadding='5' cellspacing='0' border='0'>";
 echo "<td>";
 echo "new password:";
Modified: branches/nimix_dev/http/php/mod_deleteGUI.php
--- branches/nimix_dev/http/php/mod_deleteGUI.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_deleteGUI.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -68,7 +68,7 @@
 $res_gui = db_query($sql_gui);
 $cnt_gui = 0;
 echo "<select class='guiList' size='20' name='guiList' class='guiList'>";
 while($row = db_fetch_array($res_gui)){
Modified: branches/nimix_dev/http/php/mod_deleteWFS.php
--- branches/nimix_dev/http/php/mod_deleteWFS.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_deleteWFS.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -79,7 +79,7 @@
 $res_wfs = db_query($sql_wfs);
 $cnt_wfs = 0;
 echo "<br><b>WFS List: <b><br><br>";
 echo "<select class='wfsList' size='20' name='wfsList' >";
Modified: branches/nimix_dev/http/php/mod_editElementVars.php
--- branches/nimix_dev/http/php/mod_editElementVars.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_editElementVars.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -167,7 +167,7 @@
 <body>
 <?php
-   echo "<form name='form1' action='" . $PHP_SELF . "?".$sParams."' method='POST'>\n";
+   echo "<form name='form1' action='" . $self ."' method='POST'>\n";
    $fkey_gui_id = $_REQUEST["fkey_gui_id"];
    $fkey_e_id   = $_REQUEST["fkey_e_id"];
@@ -183,7 +183,7 @@
    echo "<input type='button' class='' name='' value='save'   onclick='thisSave()'> \n";
    echo "<input type='button' class='' name='' value='delete' onclick='thisDelete()'> \n";
-   $href = "self.location.href='mod_editElements.php?".$sParams."&guiList1=".$fkey_gui_id."&guiList2=".$fkey_gui_id."'";
+   $href = "self.location.href='mod_editElements.php?".$urlParameters."&guiList1=".$fkey_gui_id."&guiList2=".$fkey_gui_id."'";
    echo "<input type='button' class='' name='' value='return' onclick=\"".$href."\"> \n";
    echo "</div>\n";
Modified: branches/nimix_dev/http/php/mod_editSelf.php
--- branches/nimix_dev/http/php/mod_editSelf.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_editSelf.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -210,7 +210,7 @@
 /*HTML*****************************************************************************************************/
 echo "<input type='hidden' name='selected_user' value='" . $_SESSION["mb_user_id"] . "'>";
 echo "<table border='0'>";
Modified: branches/nimix_dev/http/php/mod_editWMS_Metadata.php
--- branches/nimix_dev/http/php/mod_editWMS_Metadata.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_editWMS_Metadata.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -290,7 +290,7 @@
     die("Preview has been deleted!</body></html>");
-<form name='form1' action='<?php  $self ?>' method='post'>
+<form name='form1' action='<?php echo $self; ?>' method='post'>
 <table border='0'>
 <tr>
Modified: branches/nimix_dev/http/php/mod_edit_element_vars.php
--- branches/nimix_dev/http/php/mod_edit_element_vars.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_edit_element_vars.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -277,7 +277,7 @@
 <body>
 <?php
-echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='get'>";
+echo "<form name='form1' action='" . $self ."' method='get'>";
 #Gui to edit
 if(!isset($guiList1)){
Modified: branches/nimix_dev/http/php/mod_edit_metadata.php
--- branches/nimix_dev/http/php/mod_edit_metadata.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_edit_metadata.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -355,7 +355,7 @@
 $admin = new administration();
 $ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
 $permguis = $admin->getGuisByPermission($_SESSION["mb_user_id"],true);
-echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>\n";
+echo "<form name='form1' action='" . $self ."' method='post'>\n";
 $sql = "SELECT * from gui WHERE gui.gui_id IN (";
 $v = $ownguis;
Modified: branches/nimix_dev/http/php/mod_getStyles.php
--- branches/nimix_dev/http/php/mod_getStyles.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_getStyles.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -134,7 +134,7 @@
 $sql = "SELECT * FROM wms ORDER BY wms_title";
 $res = db_query($sql);
 $cnt = 0;
 echo "<select class='wmsList' size='20' name='wmsList' class='wmsList' onchange='submit()'>";
 while($row = db_fetch_array($res)){
 	# getStyle - Request:
Modified: branches/nimix_dev/http/php/mod_newGui.php
--- branches/nimix_dev/http/php/mod_newGui.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_newGui.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -85,7 +85,7 @@
 </script>
 </head>
 <body onload='setFocus()'>
-<form name='form1' action="<?php echo $self ?>" method="POST">
+<form name='form1' action="<?php echo $self; ?>" method="POST">
 <table>
 <tr><td>Name: </td><td><input type='text' name='newGui'></td></tr>
 <tr><td>Description: </td><td><input type='text' name='newDesc'></td></tr>
Modified: branches/nimix_dev/http/php/mod_owsproxy_conf.php
--- branches/nimix_dev/http/php/mod_owsproxy_conf.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_owsproxy_conf.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -39,7 +39,7 @@
 </style>
 <script language="JavaScript" type="text/javascript">
 function set(wms_id, status){
-	document.location.href = "mod_owsproxy_conf.php?<?php echo $urlParameters;?>&wms_id="+wms_id+"&status="+status+"&<?php echo SID; ?>";
+	document.location.href = "<?php echo $self; ?>&wms_id="+wms_id+"&status="+status;
 </script>
Modified: branches/nimix_dev/http/php/mod_saveWKT.php
--- branches/nimix_dev/http/php/mod_saveWKT.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_saveWKT.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -92,7 +92,7 @@
 //$sql = "SELECT f_table_name, f_geometry_column,type,srid FROM geometry_columns";
 $res = pg_query($con,$sql);
 $cnt = 0;
-echo "<form action='".$PHP_SELF."' method='POST'>";
+echo "<form action='".$self."' method='POST'>";
 #echo "Selektieren: <input name='actionType' type='radio' value='select'>";
 #echo "Speichern: <input name='actionType' type='radio' value='create'><br>";
 echo "<select name='tablenames' onchange='submit()'>";
Modified: branches/nimix_dev/http/php/mod_switchLocale_noreload.php
--- branches/nimix_dev/http/php/mod_switchLocale_noreload.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_switchLocale_noreload.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -24,15 +24,9 @@
 <html>
 <head>
-<meta name="author" content="V. Diewald">
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<meta name="DC.Rights" content="WhereGroup GmbH & Co.KG, Bonn">
 <title>Metadata search</title>
-include_once(dirname(__FILE__) . "/../include/dyn_css.php");
+<?php
+include(dirname(__FILE__) . "/../include/dyn_css.php");
 <script type="text/javascript">
@@ -51,7 +45,6 @@
 </head>
 <body leftmargin="2" topmargin="0" bgcolor="#ffffff">
 <form name='form1' target='parent'>
-<p>
 <select id='language' name='language' onchange='validate()'>
 <?php
 $languageArray = explode(",", $languages);
@@ -64,7 +57,6 @@
 </select>
-</p>
 </form>
 </body>
 </html>
Copied: branches/nimix_dev/http/php/mod_tab_messages.php (from rev 2304, branches/2.5/http/php/mod_tab_messages.php)
--- branches/nimix_dev/http/php/mod_tab_messages.php	                        (rev 0)
+++ branches/nimix_dev/http/php/mod_tab_messages.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -0,0 +1,46 @@
+<?php
+#$Id$
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../extensions/JSON.php");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+$buttonObj = array();
+$sql = "SELECT e_id, gettext($1, e_title) AS e_title FROM gui_element, " .
+		"(SELECT v.var_value AS current_e_id FROM gui_element AS e, " .
+		"gui_element_vars AS v WHERE e.e_id = v.fkey_e_id AND ".
+		"e.fkey_gui_id = v.fkey_gui_id AND e.e_id = 'tabs' AND ".
+		"v.var_name LIKE 'tab_ids%' AND e.fkey_gui_id = $2) ".
+		"AS gui_element_temp WHERE gui_element_temp.current_e_id = e_id ".
+		"AND fkey_gui_id = $3";
+$v = array($_SESSION["mb_lang"], $_SESSION["mb_user_gui"], $_SESSION["mb_user_gui"]);
+$t = array("s", "s", "s");
+$res = db_prep_query($sql, $v, $t);
+while ($row = db_fetch_array($res)) {
+	array_push($buttonObj, array("id" => $row["e_id"], "title" => $row["e_title"]));
+$json = new Services_JSON();
+$output = $json->encode($buttonObj);
+echo $output;
Property changes on: branches/nimix_dev/http/php/mod_tab_messages.php
___________________________________________________________________
   + HeadURL Id LastChangedBy LastChangedDate LastChangedRevision
Modified: branches/nimix_dev/http/php/mod_updateWMS.php
--- branches/nimix_dev/http/php/mod_updateWMS.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_updateWMS.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -50,7 +50,7 @@
 </script>
 </head>
 <body>
-<form name='form1' action='<?php  $self ?>' method='POST'>
+<form name='form1' action='<?php echo $self; ?>' method='POST'>
 <?php
Modified: branches/nimix_dev/http/php/mod_wfs_edit.php
--- branches/nimix_dev/http/php/mod_wfs_edit.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_wfs_edit.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -134,7 +134,7 @@
                 	$sql .= '1';
                 }else{$sql .= '0';}
 				$sql .= "',";
-                $sql .= "f_form_element_html = '".addslashes($_REQUEST["f_form_element_html".$i]);
+                $sql .= "f_form_element_html = '".$_REQUEST["f_form_element_html".$i];
 				$sql .= "',";
                 $sql .= "f_mandatory = '";
                 if(!empty($_REQUEST["f_mandatory".$i])){
@@ -273,7 +273,7 @@
                 echo "<td><input name='f_edit".$cnt."' type='checkbox'";
                 if($row["f_edit"] == 1){ echo " checked"; }
                 echo "></td>";
-                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".stripslashes($row["f_form_element_html"])."</textarea></td>";
+                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".$row["f_form_element_html"]."</textarea></td>";
                 echo "<td><input name='f_auth_varname".$cnt."' type='text' size='8' value='".$row["f_auth_varname"]."'></td>";
                 echo "</tr>";
                 $cnt++;
Deleted: branches/nimix_dev/http/php/mod_wfs_save.php
--- branches/nimix_dev/http/php/mod_wfs_save.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_wfs_save.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -1,155 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Administration
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-<html>
-<head>
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>WFS Save</title>
-<script language='JavaScript' type='text/javascript'>
-var my = window.opener.parent.frames.wfs_conf.wfs_conf;
-var dig = window.opener.parent.frames.digitize;
-var w;
-function sepNameSpace(n){
-	var c = n.indexOf(":");
-	if(c>0){
-		var temp = n.split(":");
-		return temp[1];
-	else{
-		return n;
-function init(){
-	for(var i=0; i<my.length; i++){
-		N = new Option(my[i]['wfs_conf_abstract'],i,false,false);
-		document.forms[0].thema.options[document.forms[0].thema.length] = N;
-function validate(obj){
-	var ind = obj.selectedIndex;
-	if(ind == 0){return;}
-	w = obj[ind].value;
-	var str = "<table>";
-	for(var i=0; i< my[w]['element'].length; i++){
-		if(my[w]['element'][i]['f_geom'] != '1'){
-			str += "<tr>";
-			str += "<td>" + my[w]['element'][i]['element_name'] + "</td>";
-			str += "<td><input name='"+my[w]['element'][i]['element_name']+"' type='text'></td>";
-			str += "<tr>";
-	str += "</table>";
-	str += "<input type='submit' value='save'>"
-	document.getElementById("a").innerHTML = str;
-function set(){
-	document.forms[1].url.value = my[w]['wfs_transaction'];
-	var str = '<wfs:Transaction version="1.0.0" service="WFS" xmlns="http://www.someserver.com/myns" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:wfs="http://www.opengis.net/wfs" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd">';
-	str += '<wfs:Insert>';
-	str += '<'+ sepNameSpace(my[w]['featuretype_name'])+'>';
-	for(var i=0; i<document.forms[0].elements.length; i++){
-		if(document.forms[0].elements[i].type == 'text' && document.forms[0].elements[i].value != ''){
-			var tmp = sepNameSpace(document.forms[0].elements[i].name);
-			str += '<' + tmp  + '>';
-			str += document.forms[0].elements[i].value;
-			str += '</' + tmp  + '>';
-	for(var j=0; j<my[w]['element'].length; j++){
-		if(my[w]['element'][j]['f_geom'] == 1){
-			var el_geom = my[w]['element'][j]['element_name'];
-	str += '<' + el_geom + '>';
-	if(dig.D[0].type == 'text'){
-		str += '<gml:Point srsName="epsg:4326">';
-		str += '<gml:coordinates>';
-		str += dig.D[0].x[0] + "," + dig.D[0].y[0];
-		str += '</gml:coordinates>';
-		str += '</gml:Point>';
-	if(dig.D[0].type == 'line'){
-		str += '<gml:MultiLineString srsName="epsg:4326">';
-		str += '<gml:lineStringMember>';
-		str += '<gml:LineString>';
-		for(var k=0; k<dig.D[0].x.length; k++){
-			if(k>0){
-				str += " ";
-			str += dig.D[0].x[k] + "," + dig.D[0].y[k];
-		str += '</gml:LineString>';
-		str += '</gml:lineStringMember>';
-		str += '</gml:MultiLineString>';
-	if(dig.D[0].type == 'polygon'){
-		str += '<gml:MultiPolygon srsName="epsg:4326">';
-		str += '<gml:polygonMember>';
-		str += '<gml:Polygon>';
-		str += '<gml:outerBoundaryIs>';
-		str += '<gml:LinearRing>';
-			if(k>0){
-				str += " ";
-		str += '</gml:LinearRing>';
-		str += '</gml:outerBoundaryIs>';
-		str += '</gml:Polygon>';
-		str += '</gml:polygonMember>';
-		str += '</gml:MultiPolygon>';
-	str += '</' + el_geom + '>';
-	str += '</'+ sepNameSpace(my[w]['featuretype_name'])+'>';
-	str += '</wfs:Insert>';
-	str += '</wfs:Transaction>';
-	document.forms[1].filter.value = str;
-	document.forms[1].submit();
-	return false;
-</script>
-</head>
-<body onload='init()'>
-<form onsubmit='return set()'>
-<select name='thema' onchange='validate(this)'>
-<option value=''>WFS...</option>
-</select><br>
-<div id='a' name='a'></div>
-</form>
-<form action='../extensions/geom2wfst.php' method='POST'>
-<input type='text' name='url'>
-<input type='text' name='filter'>
-</form>
-</body>
-</html>
Modified: branches/nimix_dev/http/php/mod_wfs_server.php
--- branches/nimix_dev/http/php/mod_wfs_server.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_wfs_server.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -279,15 +279,21 @@
 function getOwsproxy($obj){
-	$n = new administration();
+	$n = new administration();
+	if($obj->wfs=="gui_confs")
+		return false;
 	return $n->getWfsOwsproxyString($obj->wfs);
 function setOwsproxy($obj){
+		return false;
 	return $n->setWfsOwsproxyString($obj->wfs,true);
 function removeOwsproxy($obj){
+		return false;
 	return $n->setWfsOwsproxyString($obj->wfs,false);
Modified: branches/nimix_dev/http/php/mod_zoomCoords.php
--- branches/nimix_dev/http/php/mod_zoomCoords.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_zoomCoords.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -143,7 +143,7 @@
 <?php
 # needs intl'!
-	echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
+	echo "<form name='form1' action='" . $self ."' method='post'>";
 	echo "<span class='labelx'>L&auml;nge:</span>";
 	echo "<span class='labely'>Breite:</span>";
 	echo "<input class='textx' type='text' name='X'>";
Modified: branches/nimix_dev/http/php/mod_zoomCoords_en.php
--- branches/nimix_dev/http/php/mod_zoomCoords_en.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/mod_zoomCoords_en.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -163,7 +163,7 @@
 <body bgcolor='#ffffff' onload=''>
 <?php
 #coordinates
    #deutsche Version
Modified: branches/nimix_dev/http/php/nestedSets.php
--- branches/nimix_dev/http/php/nestedSets.php	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/http/php/nestedSets.php	2008-03-27 12:22:20 UTC (rev 2305)
@@ -246,7 +246,7 @@
 <div style='position:absolute;top:50px;left:350px'>
-<form action='<?php $PHP_SELF ?>' method='POST'>
+<form action='<?php $self; ?>' method='POST'>
 <br><br>
 <table >
 <tr><td></td><td></td></tr>
Modified: branches/nimix_dev/resources/db/mysql/mysql_schema.sql
--- branches/nimix_dev/resources/db/mysql/mysql_schema.sql	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/resources/db/mysql/mysql_schema.sql	2008-03-27 12:22:20 UTC (rev 2305)
@@ -168,6 +168,7 @@
   gui_wms_epsg varchar(50) NOT NULL default '',
   gui_wms_visible smallint(6) NOT NULL default '1',
   gui_wms_sldurl varchar(255) NOT NULL default '',
+      gui_wms_opacity int(11) DEFAULT 100
   KEY gui_index (fkey_gui_id),
   KEY wms_index (fkey_wms_id)
 ) TYPE=InnoDB;
Modified: branches/nimix_dev/resources/db/postgresql/pgsql_schema.sql
--- branches/nimix_dev/resources/db/postgresql/pgsql_schema.sql	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/resources/db/postgresql/pgsql_schema.sql	2008-03-27 12:22:20 UTC (rev 2305)
@@ -208,7 +208,8 @@
     gui_wms_exceptionformat character varying(50) DEFAULT ''::character varying NOT NULL,
     gui_wms_epsg character varying(50) DEFAULT ''::character varying NOT NULL,
     gui_wms_visible integer DEFAULT 1 NOT NULL,
-    gui_wms_sldurl character varying(255) DEFAULT ''::character varying NOT NULL
+    gui_wms_sldurl character varying(255) DEFAULT ''::character varying NOT NULL,
+    gui_wms_opacity integer DEFAULT 100
Copied: branches/nimix_dev/resources/db/update/mod_switchLocale_noreload.sql (from rev 2304, branches/2.5/resources/db/update/mod_switchLocale_noreload.sql)
--- branches/nimix_dev/resources/db/update/mod_switchLocale_noreload.sql	                        (rev 0)
+++ branches/nimix_dev/resources/db/update/mod_switchLocale_noreload.sql	2008-03-27 12:22:20 UTC (rev 2305)
@@ -0,0 +1,2 @@
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','iframe','../php/mod_switchLocale_noreload.php','frameborder=''0''',720,14,50,30,5,'','','iframe','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'php_var');
Modified: branches/nimix_dev/resources/db/update/update_postgresql_db.sql
--- branches/nimix_dev/resources/db/update/update_postgresql_db.sql	2008-03-27 11:05:46 UTC (rev 2304)
+++ branches/nimix_dev/resources/db/update/update_postgresql_db.sql	2008-03-27 12:22:20 UTC (rev 2305)
@@ -220,56 +220,251 @@
 INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
 INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Pan', 'Премести областта');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Display complete map', 'Покажи цялата карта');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Zoom in', 'Покажи картата в по-едър мащаб');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Zoom out', 'Покажи картата в по-дребен мащаб');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Back', 'Назад');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Forward', 'Напред');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Coordinates', 'Координати');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Zoom by rectangle', 'Увеличи картата в избраната област');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Redraw', 'Пречертай или от клавиатурата: празен интервал');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Query', 'Зявка към данните');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Logout', 'Изход на потребител');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'WMS preferences', 'WMS настройки');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Adding WMS from filtered list', 'Добави WMS от избран списък');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Set map center', 'Постави център на карта');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Help', 'Помощ');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Show WMS infos', 'Покажи WMS информация');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Save workspace as web map context document', 'Запази работния документ като Web Map Context документ');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Resize Mapsize', 'Напасни големината на картата');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Rubber', 'Изтрий');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Get Area', 'Изчисли площ');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Close Polygon', 'Затвори полигон');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Move back to your GUI list', 'Назад към списъка с интерфейси (GUI)');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Legend', 'Легенда');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Print', 'Печат');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Imprint', 'Авторско каре');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Maps', 'Карти');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Search', 'Търсене');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Meetingpoint', 'Място на среща');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Metadatasearch', 'Търсене по метаданни');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Adding WMS', 'Добави WMS');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Adding WMS from List', 'Добави WMS от списък');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Info', 'Информация');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Change Projection', 'Промени проекция');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Copyright', 'Авторско право');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Digitize', 'Дигитализиране');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Overview','Обзорна карта');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Drag Mapsize', 'Промени размера на картата');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Mapframe', 'Рамка на картата');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Navigation Frame', 'Навигационна рамка');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Scale Select', 'Избор на мащаб');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Scale Text', 'Въведи мащаб');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Scalebar', 'Мащабна скала');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Set Background', 'Избери фоново изображение');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Zoom to Coordinates', 'Покажи картата около посочените координати');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Change Password', 'Промени парола');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Load a web map context document', 'Зареди Web Map Context документ');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Logo', 'Фирмен знак');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Measure distance', 'Измери разстояние');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Pan', 'Премести областта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Display complete map', 'Покажи цялата карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom in', 'Покажи картата в по-едър мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom out', 'Покажи картата в по-дребен мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Back', 'Назад');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Forward', 'Напред');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Coordinates', 'Координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom by rectangle', 'Увеличи картата в избраната област');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Redraw', 'Пречертай или от клавиатурата: празен интервал');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Query', 'Зявка към данните');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logout', 'Изход на потребител');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'WMS preferences', 'WMS настройки');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from filtered list', 'Добави WMS от избран списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set map center', 'Постави център на карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Help', 'Помощ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Show WMS infos', 'Покажи WMS информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Save workspace as web map context document', 'Запази работния документ като Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Resize Mapsize', 'Напасни големината на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Rubber', 'Изтрий');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Get Area', 'Изчисли площ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Close Polygon', 'Затвори полигон');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Move back to your GUI list', 'Назад към списъка с интерфейси (GUI)');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Legend', 'Легенда');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Print', 'Печат');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Imprint', 'Авторско каре');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Maps', 'Карти');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Search', 'Търсене');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Meetingpoint', 'Място на среща');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Metadatasearch', 'Търсене по метаданни');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS', 'Добави WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from List', 'Добави WMS от списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Info', 'Информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Projection', 'Промени проекция');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Copyright', 'Авторско право');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Digitize', 'Дигитализиране');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Overview','Обзорна карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Drag Mapsize', 'Промени размера на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Mapframe', 'Рамка на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Navigation Frame', 'Навигационна рамка');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Select', 'Избор на мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Text', 'Въведи мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scalebar', 'Мащабна скала');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set Background', 'Избери фоново изображение');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom to Coordinates', 'Покажи картата около посочените координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Password', 'Промени парола');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Load a web map context document', 'Зареди Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logo', 'Фирмен знак');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Measure distance', 'Измери разстояние');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Pan', 'Μετακίνηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Display complete map', 'Επίδειξη Πλήρους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom in', 'Zoom In');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom out', 'Zoom Out');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Back', 'Πίσω');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Forward', 'Πρόσθια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Coordinates', 'Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom by rectangle', 'Ζουμ από ορθογώνιο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Redraw', 'Απόσυρση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Query', 'Μέτρηση Εμβαδού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Logout', 'Αποσύνδεση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'WMS preferences', 'Αλλάξτε τη διάταξη των WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from filtered list', 'Πρόσθεση WMS από το φιλτραρισμένο κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set map center', 'Το καθορισμένο Κέντρο Χαρτών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES  ('gr', 'Help', 'Βοήθεια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Rubber', 'Το λάστιχο- Τρίφτης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Close Polygon', 'Το Κλειστό Πολύγωνο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ( 'gr', 'Move back to your GUI list', 'Παρουσίαση του GUI Καταλόγου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Print', 'Εκτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Maps', ' Χάρτες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS', 'Πρόσθεση WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from List', 'Πρόσθεση WMS από τον κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Measure distance', 'Μέτρηση Απόστασης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Meetingpoint', 'Σημείο Συνάντησης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Info', 'Πληροφορίες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Digitize', 'Ψηφιοποίηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Projection', 'Αλλαγή Προβολής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set Background', 'Επιλογή Φόντου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Overview', 'Προεπισκόπιση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Password', 'Αλλαγή Συνθηματικού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scalebar', 'Κανόνας Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr ', 'Logo', 'Λογότυπο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom to Coordinates', 'Εστίαση σε Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Text', 'Κείμενο Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Show WMS infos', 'Προβολή WMS πληροφοριών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Legend', 'Λεζάντα');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Search', 'Αναζήτηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Resize Mapsize', 'Αλλαγή Μεγέθους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Drag Mapsize', 'Αλλαγή Μεγέθους Χάρτη με Ολίσθηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Mapframe', 'Πλαίσιο Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Get Area', 'Προβολή Περιοχής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Imprint', 'Αποτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Select', 'Επιλογή Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Metadatasearch', 'Αναζήτηση στα Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Pan', 'Selectie verschuiven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Display complete map', 'Hele kaart tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom in', 'Inzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom out', 'Uitzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Back', 'Terug');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Forward', 'Voorwaarts');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Coordinates', 'Koordinaten tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom by rectangle', 'Zoom rechthoek-selectie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Redraw', 'Opfrissen of toetsenbord : spatiebalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Query', 'Data opvragen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logout', 'Afmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'WMS preferences', 'WMS instellingen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from filtered list', 'WMS van gefilterte lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set map center', 'Kaartmiddelpunt aangeven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Help', 'Help');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Show WMS infos', 'Tonen van WMS Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Save workspace as web map context document', 'zicht als Web map context dokument bewaren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Resize Mapsize', 'beeldschermgrote aanpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Rubber', 'schets verwerpen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Get Area', 'oppervlakte berekenen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Close Polygon', 'Polygoon sluiten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Move back to your GUI list', 'Terug naar GUI lijst');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Print', 'Drukken');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Maps', 'Kaarten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Search', 'Zoek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Meetingpoint', 'Trefpunt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Metadatasearch', 'Zoeken naar Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS', 'WMS toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from List', 'WMS uit lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Info', 'Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Projection', 'Projektie veranderen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Digitize', 'Digitaliseren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Overview', 'overzichtskaart');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Drag Mapsize', 'Kaart vergroten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Mapframe', 'Kaartvenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Navigation Frame', 'Navigeervenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Select', 'Schaal selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Text', 'Schaal via tekstingave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scalebar', 'Schaalbalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set Background', 'Achtergrond selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom to Coordinates', 'Naar koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Password', 'Paswoord wijzigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Load a web map context document', 'Laad een Web Map Context Dokument');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Measure distance', 'Meet afstand');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Pan', 'Sposta dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Display complete map', 'Mostra tutta la mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom in', 'Ingrandisci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom out', 'Riduci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Back', 'Indietro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Forward', 'Avanti');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Coordinates', 'Mostra coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom by rectangle', 'Seleziona dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Redraw', 'Ridisegna oppure, da tastiera: spazio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Query', 'Interroga');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logout', 'Logout');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'WMS preferences', 'Impostazioni WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from filtered list', 'Aggiungi un WMS da una lista filtrata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set map center', 'Fissa il centro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Help', 'Aiuto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Show WMS infos', 'Mostra informazioni sul WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Save workspace as web map context document', 'Salva vista come documento di Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Resize Mapsize', 'Adatta la dimensione della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Rubber', 'Cancella bozza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Get Area', 'Calcola area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Close Polygon', 'Chiudi poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Move back to your GUI list', 'Torna alla lista delle GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Print', 'Stampa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Imprint', 'Colophon');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Maps', 'Mappe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Search', 'Cerca');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Meetingpoint', 'Punti di incontro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Metadatasearch', 'Ricerca metadati');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS', 'Aggiungi WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from List', 'Aggiungi WMS da lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Projection', 'Cambia proiezione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Digitize', 'Digitalizza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Overview', 'Mappa di insieme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Drag Mapsize', 'Cambia dimensione mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Mapframe', 'Quadro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Navigation Frame', 'Quadro di navigazione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Select', 'Scelta della scala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Text', 'Scala dei testi');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scalebar', 'Scala di riferimento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set Background', 'Seleziona mappa di sfondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom to Coordinates', 'Ingrandisci alle coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Password', 'Cambia password');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Load a web map context document', 'Carica un documento Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Measure distance', 'Misura distanza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Pan', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Display complete map', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom in', 'Zoom +');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Coordinates', 'Mostrar coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom by rectangle', 'Zoom rectángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Query', 'Busqueda de datos');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logout', 'Terminar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from filtered list', 'Anadir WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Help', 'Ayuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Show WMS infos', 'Mostrar información sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Save workspace as web map context document', 'Guardar vista como fichero Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Resize Mapsize', 'Modificar el tamano de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Rubber', 'Borrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Close Polygon', 'Cerrar polígono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Move back to your GUI list', 'Volver a la lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Legend', 'Leyenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Imprint', 'Aviso legal');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Search', 'Busqueda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Meetingpoint', 'Lugar de reunión');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Metadatasearch', 'Búsqueda de datos meta');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS', 'Añadir WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from List', 'Añadir WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Info', 'Informacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Projection', 'Cambiar projecto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Digitize', 'Digitalización');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Overview', 'Mapa de visión general');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Drag Mapsize', 'Ampilar vista de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Mapframe', 'Ventana de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Navigation Frame', 'Ventana de navigacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Select', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Text', 'Teclar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scalebar', 'Fraja de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set Background', 'Poner el fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom to Coordinates', 'Zoom en coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Password', 'Cambiar clave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Load a web map context document', 'Cargar un documento de Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
 -- new table gui_kml
More information about the Mapbender_commits mailing list
