[Mapbender-commits] r2310 - branches/2.5/http/tools
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Mar 28 07:18:21 EDT 2008
Author: astrid_emde
Date: 2008-03-28 07:18:21 -0400 (Fri, 28 Mar 2008)
New Revision: 2310
Removed:
   branches/2.5/http/tools/mapFiler.php
mapfiler has been deleted from the mapbender tools directory :)
Deleted: branches/2.5/http/tools/mapFiler.php
--- branches/2.5/http/tools/mapFiler.php	2008-03-28 11:03:47 UTC (rev 2309)
+++ branches/2.5/http/tools/mapFiler.php	2008-03-28 11:18:21 UTC (rev 2310)
@@ -1,126 +0,0 @@
-<html>
-  <head>
-    <title>MapFile</title>
-    <style></style>
-  <script type='text/javascript' >
-  function validate(){
-  	/*eventuell den Inhalt (Pfad) noch aufbereiten?
-	* Slash und Backslash -> win, linux usw.
-	document.form1.location.type = 'text';
-	document.form1.myLocation.value = document.form1.location.value;
-	document.form1.submit();
-  </script>
-  </head>
-  <body>
-  <form name='form1' action='<?php $PHP_SELF ?>' method='POST'>
-  <table>
-	<tr>
-		<td>Location:</td>
-		<td>
-			<input type='file' name='location' >
-			<input type='hidden' name='myLocation'>
-		</td>
-	</tr>
-	<tr>
-		<td>all files with the same extension:</td>
-		<td>
-		<input type='checkbox' name='dir'>
-		</td>
-	</tr>
-	<tr>
-		<td>Factor:</td>
-		<td><input type='text' name='factor' value='4'></td>
-	</tr>
-	<tr>
-		<td><input type='button' value="let's go" onclick='validate()'></td>
-		<td></td>
-	</tr>
-  </table>
-  <?php
-import_request_variables('PG');
-/*********PARAMS***************/
-$countSymbolsFiles = 0;
-$arraySymbolsFiles;
-function modify($myDir, $myFile){
-	global $factor;
-	$myContent = fopen($myDir."/".$myFile, "r") or die("Datei " . $myDir . " / ". $myFile ." konnte nicht zum Lesen geöffnet werden!");
-	$myNewContent = fopen($myDir."/".str_replace(".","_".$factor.".",$myFile), "w") or die("Datei " . $myDir . " / ". str_replace(".","_".$factor.".",$myFile) ." konnte nicht zum Schreiben geöffnet werden!");
-	fputs($myNewContent, "#Modified by MapbenderTools" . "\n");
-	fputs($myNewContent, "#Date: ". date("d.m.Y") . "\n");
-	fputs($myNewContent, "#Factor: ". $factor . "\n\n");
-	while(!feof($myContent)){
-		$myLine = fgets($myContent, 1024);
-		if(preg_match("/\bSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
-			if(count($matches) <= 2){
-				fputs($myNewContent, str_replace($matches[1], multiplicate($matches[1]), $myLine));
-		else if(preg_match("/(.*OFFSET)\s*(\d+.?\d*)(\s*)(\d+.?\d*)(\s*)/i",$myLine,$matches)){
-			$myNewOFFSET=$matches[1] . " " .multiplicate($matches[2]) . " " . multiplicate($matches[4]).$matches[5];
-			fputs($myNewContent,$myNewOFFSET);
-		else if(preg_match("/\bMAXSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
-		else if(preg_match("/\bMINSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
-		else if(preg_match("/\bSYMBOLSCALE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
-			fputs($myNewContent, "# ". $myLine);
-		else if(preg_match("/\bSYMBOLSET\s*(.*)/i",$myLine,$matches)){ //noch nicht fertig
-			$arraySymbolFiles[$countSymbolsFiles] = str_replace("\"","",$matches[1]);
-			$countSymbolsFiles++;
-			fputs($myNewContent, $myLine);
-		#catch all
-		else{
-	fclose($myContent);
-	fclose($myNewContent);
-function multiplicate($x){
-	global $factor;
-	$x = floatval($x) * $factor;
-	return $x;
- if(isset($myLocation) && $myLocation != ""){
-	# what is to do...
-	$myFile = basename($myLocation);
-	$myDir = dirname($myLocation);
-	$suffix = strstr($myFile, ".");
-	if(!isset($dir)){
-		modify($myDir, $myFile);
-		echo "modified: " . $myDir . "/" . $myFile. "<br />";
-	else{
-		if($verz = opendir($myDir)){
-			while ($myFile = readdir ($verz)) {
-				if($myFile != ".." && $myFile != "." && is_file($myDir."/".$myFile) && strstr($myFile, $suffix)){
-			closedir($verz);
-  </form>
-  </body>
-</html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
