[Mapbender-commits] r2430 - in branches: . beck_dev/trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 7 06:42:30 EDT 2008
Author: beck
Date: 2008-05-07 06:42:30 -0400 (Wed, 07 May 2008)
New Revision: 2430
Added:
   branches/beck_dev/
Removed:
   branches/lb_wmc/
   branches/beck_dev/trunk/mapbender/http/classes/class.wmc2object.php
Copied: branches/beck_dev (from rev 2429, branches/lb_wmc)
Modified: branches/beck_dev/trunk/mapbender/http/classes/class.wmc2object.php
--- branches/lb_wmc/trunk/mapbender/http/classes/class.wmc2object.php	2008-05-07 10:03:47 UTC (rev 2429)
+++ branches/beck_dev/trunk/mapbender/http/classes/class.wmc2object.php	2008-05-07 10:42:30 UTC (rev 2430)
@@ -1,4 +1,5 @@
 <?php
+ini_set("display_errors","on"); // development only
  * @class
@@ -41,6 +42,13 @@
 	function developmentBootstrap() {
 		$this->mapbenderFrameName = "mapframe1";
+		$this->mapbenderElement   = "map";
+		$this->mapURL             = "http://www.domain.tld/";
+		$this->mapSRS             = "map";
+		$this->mapWidth           = "map";
+		$this->mapHeight          = "map";
+		$this->mapExtent          = "map";
+		$this->mapVisibleLayers   = "map";
More information about the Mapbender_commits mailing list
