[Mapbender-commits] r2439 - branches/2.5/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 7 17:03:46 EDT 2008
Author: astrid_emde
Date: 2008-05-07 17:03:46 -0400 (Wed, 07 May 2008)
New Revision: 2439
   branches/2.5/http/php/mod_editGuiWms.php
reactivated table textes with toImage to horizontal,changed extension_loaded("gd") instead of gd2
changed select_short and select_auto in table for selectbox for column style and prio
Modified: branches/2.5/http/php/mod_editGuiWms.php
--- branches/2.5/http/php/mod_editGuiWms.php	2008-05-07 20:53:50 UTC (rev 2438)
+++ branches/2.5/http/php/mod_editGuiWms.php	2008-05-07 21:03:46 UTC (rev 2439)
@@ -1,725 +1,725 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_editGuiWms.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-import_request_variables("PG");
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Edit GUI WMS</title>
-<?php
-include_once '../include/dyn_css.php';
-function toImage($text) {
-	$angle = 90;
-	if (extension_loaded("gd2")) {
-		return "<img src='../php/createImageFromText.php?text=" . urlencode($text) . "&angle=" . $angle . "'>";
-	return $text;
-<script language="JavaScript">
-function edit_gaz(gui,wms,layer){
-	window.open("../php/mod_wfsLayerObj_conf.php?gui="+gui+"&wms="+wms+"&layer="+layer);
-function validate(wert){
-	if(wert == 'delete_wms'){
-		if(document.form1.wmsList.selectedIndex == -1){
-			document.form1.wmsList.style.background = '#ff0000';
-		}else{
-			var secure = confirm("Remove WMS in this GUI ?");
-			if(secure == true){
-				document.form1.del.value='true';
-				document.form1.submit();
-	if(wert == 'up_wms'){
-		}else{
-			if (document.form1.wmsList.selectedIndex>0){
-				document.form1.up.value='true';
-	if(wert == 'down_wms'){
-		}else{
-			if (document.form1.wmsList.selectedIndex<document.form1.wmsList.length-1){
-				document.form1.down.value='true';
-function checkBoxValue(){
-   for(var i=0; i<document.forms[0].elements.length; i++){
-      if(document.forms[0].elements[i].type == 'checkbox'){
-         if(document.forms[0].elements[i].checked == true){
-            document.forms[0].elements[i].value = '1';
-         else{
-            document.forms[0].elements[i].value = '0';
-            document.forms[0].elements[i].checked = true;
-      if(document.forms[0].elements[i].type == 'text' && ( document.forms[0].elements[i].name.indexOf("minscale") > -1 || document.forms[0].elements[i].name.indexOf("maxscale") > -1 )){
-         var nr = parseInt(document.forms[0].elements[i].value);
-         if(isNaN(nr) == true){document.forms[0].elements[i].value = 0;}
-         else{document.forms[0].elements[i].value = nr;}
-   document.forms[0].update_content.value=1;
-   document.forms[0].submit();
-function getAllLayer(){
-   var arrayLayer = new Array();
-   var cntLayer = 0;
-      if(document.forms[0].elements[i].name.indexOf("layer_id") > -1){
-         arrayLayer[cntLayer] = document.forms[0].elements[i].value;
-         cntLayer++;
-   return arrayLayer;
-function setSubs(){
-   var arrayLayer = getAllLayer();
-   for(var i=0; i<arrayLayer.length; i++){
-      if(parseInt(eval("document.forms[0].L_" + arrayLayer[i] + "___layer_parent.value")) > 0){
-         eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_status.checked = false");
-function setLayer(def,status){
-   if(def == 'querylayer'){
-      for(var i=1; i<arrayLayer.length; i++){
-         if(eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.disabled == false")){
-            eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.checked = " + status);
-   if(def == 'visible'){
-         eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_visible.checked = " + status);
-function showSld(origUrl){
-	var url = document.getElementById("this_gui_wms_sldurl").value;
-	if(url==""){
-		if(origUrl=="")
-			return;
-		url=origUrl;
-	window.open(url);
-</script>
-</head>
-<body>
-<?php
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
-$mb_user_id=$_SESSION["mb_user_id"];
-#delete gui_wms from gui
-if($del && $del == 'true'){
-	$sql="SELECT DISTINCT gui_wms_position from gui_wms WHERE fkey_gui_id = $1 and fkey_wms_id = $2";
-	$v = array($guiList,$wmsList);
-	$t = array('s','i');
-	$res = db_prep_query($sql,$v,$t);
-	$cnt = 0;
-	while($row = db_fetch_array($res)){
-		$wms_position = $row["gui_wms_position"];
-		$cnt++;
-	#if($cnt > 1){die("Error: WMS (ID) not unique!");}
-		$sql = "Delete from gui_wms where fkey_gui_id = $1 and fkey_wms_id = $2 ";
-		$sql = "Delete from gui_layer where fkey_gui_id = $1 and gui_layer_wms_id = $2";
-		$del='false';
-		$sql = "UPDATE gui_wms SET gui_wms_position = (gui_wms_position - 1) WHERE gui_wms_position > $1";
-		$sql .= " AND fkey_gui_id = $2 ";
-		$v = array($wms_position,$guiList);
-		$t = array('i','s');
-	unset($wmsList);
-#update gui_wms_position
-if($up && $up == 'true'){
-	if ($wmsList!=""){
-		$sql = "SELECT gui_wms_position ";
-		$sql .= "FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
-		if($row = db_fetch_array($res)){
-	if($wms_position > 0){
-		$sql = "UPDATE gui_wms SET ";
-		$sql .= "gui_wms_position = $1";
-		$sql .= " WHERE fkey_gui_id = $2 AND fkey_wms_id = $3";
-		$v = array(($wms_position - 1),$guiList,$wmsList);
-		$t = array('i','s','i');
-		$sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4 ";
-		$v = array($wms_position,($wms_position - 1),$guiList,$wmsList);
-		$t = array('i','i','s','i');
-if($down && $down == 'true'){
-	$max = 0;
-		$sql = "SELECT MAX(gui_wms_position) as max FROM gui_wms WHERE fkey_gui_id = $1 ";
-		$v = array($guiList);
-		$t = array('s');
-			$max = $row["max"];
-	if($wms_position < $max){
-		$v = array(($wms_position + 1),$guiList,$wmsList);
-		$sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4";
-		$v = array($wms_position,($wms_position + 1),$guiList,$wmsList);
-/*handle Updates*/
-if(isset($update_content) && $update_content == "1"){
-   if(isset($this_gui_wms_epsg)){
-      $sql = "UPDATE gui_wms set gui_wms_epsg = $1, gui_wms_mapformat = $2, ";
-      $sql .= "gui_wms_featureinfoformat = $3, gui_wms_exceptionformat = $4, ";
-      $sql .= "gui_wms_visible = $5, gui_wms_opacity = $6, gui_wms_sldurl = $7 ";
-      $sql .= "WHERE fkey_gui_id = $8 AND fkey_wms_id = $9";
-		$v = array($this_gui_wms_epsg,$this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
-		$t = array('s','s','s','s','i','i','s','s','i');
-   else{
-		$sql = "UPDATE gui_wms set gui_wms_mapformat = $1, ";
-		$sql .= "gui_wms_featureinfoformat = $2, gui_wms_exceptionformat = $3, ";
-		$sql .= "gui_wms_visible = $4, gui_wms_opacity = $5, gui_wms_sldurl = $6 ";
-		$sql .= "WHERE fkey_gui_id = $7 AND fkey_wms_id = $8";
-		$v = array($this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
-		$t = array('s','s','s','i','i','s','s','i');
-   $cnt = 0;
-   while(list($key,$val) = each($_REQUEST)){
-		if(preg_match("/___/", $key)){
-			$myKey = explode("___", $key);
-			if($myKey[1]!="layer_parent" && $myKey[1]!='layer_id' ){
-				$sql = "UPDATE gui_layer SET ".$myKey[1]." = $1 WHERE fkey_gui_id = $2 AND fkey_layer_id = $3";
-				$v = array($val,$this_gui,preg_replace("/L_/","",$myKey[0]));
-				if($myKey[1]=='gui_layer_style'){
-					$t = array('s','s','i');
-				else{
-				if(!$res = db_prep_query($sql,$v,$t)){
-					echo "FEHLER in ZEILE 288";
-echo "<form name='form1' action='" . $self ."' method='post'>";
-echo "<table cellpadding='3' cellspacing='3' border='0' class='table_top'>";
-echo "<tr>";
-echo "<td>";
-echo "GUI";
-echo "</td>";
-echo "<td>";
-echo "WMS-TITLE";
-echo "</td>";
-echo "<td>";
-echo "</td>";
-echo "<tr>";
-echo "<td>";
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$admin = new administration();
-$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
-$gui_id =array();
-if (count($ownguis)>0){
-	for($i=0; $i<count($ownguis); $i++){
-		$gui_id[$i]=$ownguis[$i];
-echo"<select size='8' name='guiList' onchange='document.form1.wmsList.selectedIndex = -1;submit()'>";
-$selected_gui_id="";
-for ($i=0; $i<count($ownguis);$i++){
-   echo "<option value='".$gui_id[$i]."' ";
-   if($guiList && $guiList == $gui_id[$i]){
-      echo "selected";
-      $selected_gui_id=$gui_id[$i];
-   else{
-      if ($i==0){
-         echo "selected";
-   echo ">".$gui_id[$i]."</option>";
-echo "</select>";
-echo "</td>";
-echo "<td>";
-$sql = "SELECT * from gui_wms JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON ";
-$sql .= "gui_wms.fkey_wms_id = wms.wms_id AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_id = $1 ORDER BY gui_wms_position";
-$v = array($selected_gui_id);
-$t = array('s');
-$res = db_prep_query($sql,$v,$t);
-$count_wms = 0;
-echo "<select size='8' name='wmsList' style='width:200px' onchange='submit()'>";
-while($row = db_fetch_array($res)){
-	echo "<option value='".$row["wms_id"]."' ";
-	if(isset($wmsList) && $wmsList == $row["wms_id"]){
-		echo "selected";
-	echo ">".$row["gui_wms_position"]." - ".$row["wms_title"]."</option>";
-	$count_wms++;
-echo "</select>";
-echo "</td><td>";
-echo "<input class='myButton' type='button' name='up_wms' value=' up ' onClick='validate(\"up_wms\")'>";
-echo "<input type='hidden' name='up' value=''><br><br>";
-echo "<input class='myButton' type='button' name='down_wms' value='down'  onClick='validate(\"down_wms\")'>";
-echo "<input type='hidden' name='down' value=''><br><br>";
-echo "<input class='myButton' type='button' name='delete_wms' value='remove'  onClick='validate(\"delete_wms\")'>";
-echo "<input type='hidden' name='del' value=''>";
-echo "</td>";
-echo "</tr>";
-echo "</table>";
-if(isset($wmsList)){
-#gui_wms
-$sql_gw = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
-$v = array($guiList,$wmsList);
-$t = array('s','i');
-$res_gw = db_prep_query($sql_gw,$v,$t);
-$cnt_gw = 0;
-while($row = db_fetch_array($res_gw)){
-   $gui_wms_position[$cnt_gw] = $row["gui_wms_position"];
-   $gui_wms_mapformat[$cnt_gw] = $row["gui_wms_mapformat"];
-   $gui_wms_featureinfoformat[$cnt_gw] = $row["gui_wms_featureinfoformat"];
-   $gui_wms_exceptionformat[$cnt_gw] = $row["gui_wms_exceptionformat"];
-   $gui_wms_epsg[$cnt_gw] = $row["gui_wms_epsg"];
-   $gui_wms_visible[$cnt_gw] = $row["gui_wms_visible"];
-   $gui_wms_opacity[$cnt_gw] = $row["gui_wms_opacity"];
-   $gui_wms_sldurl[$cnt_gw] = $row["gui_wms_sldurl"]; # sld url
-   $cnt_gw++;
-#wms
-$sql_w = "SELECT * FROM wms WHERE wms_id = $1";
-$v = array($wmsList);
-$t = array('i');
-$res_w = db_prep_query($sql_w,$v,$t);
-$cnt_w = 0;
-while($row = db_fetch_array($res_w)){
-   $wms_id[$cnt_w] = $row["wms_id"];
-   $wms_version[$cnt_w] = $row["wms_version"];
-   $wms_title[$cnt_w] = $row["wms_title"];
-   $wms_abstract[$cnt_w] = $row["wms_abstract"];
-   $wms_getcapabilities[$cnt_w] = $row["wms_getcapabilities"];
-   $wms_supportsld[$cnt_w] = $row["wms_supportsld"];  # Buttons zum sld support anzeigen?
-   $cnt_w++;
-#wms_format
-$sql_wf = "SELECT * FROM  wms_format WHERE  fkey_wms_id = $1";
-$t = array('i');
-$res_wf = db_prep_query($sql_wf,$v,$t);
-$cnt_wf = 0;
-while($row = db_fetch_array($res_wf)){
-   $data_type[$cnt_wf] = $row["data_type"];
-   $data_format[$cnt_wf] = $row["data_format"];
-   $cnt_wf++;
-#gui_layer
-$sql_gl = "SELECT l.*, gl.*, sld.sld_user_layer_id, sld.use_sld FROM layer AS l, gui_layer AS gl left outer join sld_user_layer AS sld on sld.fkey_layer_id = gl.fkey_layer_id WHERE l.layer_id = gl.fkey_layer_id AND gl.gui_layer_wms_id = $1 AND gl.fkey_gui_id = $2 AND (sld.fkey_gui_id = $3 or sld.fkey_gui_id is NULL) AND (sld.fkey_mb_user_id = $4 or sld.fkey_mb_user_id is NULL) ORDER BY l.layer_pos";
-$v = array($wmsList,$guiList,$guiList,$mb_user_id);
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/mod_editGuiWms.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Edit GUI WMS</title>
+<?php
+include_once '../include/dyn_css.php';
+function toImage($text) {
+	$angle = 90;
+	if (extension_loaded("gd")) {
+		return "<img src='../php/createImageFromText.php?text=" . urlencode($text) . "&angle=" . $angle . "'>";
+	return $text;
+<script language="JavaScript">
+function edit_gaz(gui,wms,layer){
+	window.open("../php/mod_wfsLayerObj_conf.php?gui="+gui+"&wms="+wms+"&layer="+layer);
+function validate(wert){
+	if(wert == 'delete_wms'){
+		if(document.form1.wmsList.selectedIndex == -1){
+			document.form1.wmsList.style.background = '#ff0000';
+		}else{
+			var secure = confirm("Remove WMS in this GUI ?");
+			if(secure == true){
+				document.form1.del.value='true';
+				document.form1.submit();
+	if(wert == 'up_wms'){
+		}else{
+			if (document.form1.wmsList.selectedIndex>0){
+				document.form1.up.value='true';
+	if(wert == 'down_wms'){
+		}else{
+			if (document.form1.wmsList.selectedIndex<document.form1.wmsList.length-1){
+				document.form1.down.value='true';
+function checkBoxValue(){
+   for(var i=0; i<document.forms[0].elements.length; i++){
+      if(document.forms[0].elements[i].type == 'checkbox'){
+         if(document.forms[0].elements[i].checked == true){
+            document.forms[0].elements[i].value = '1';
+         else{
+            document.forms[0].elements[i].value = '0';
+            document.forms[0].elements[i].checked = true;
+      if(document.forms[0].elements[i].type == 'text' && ( document.forms[0].elements[i].name.indexOf("minscale") > -1 || document.forms[0].elements[i].name.indexOf("maxscale") > -1 )){
+         var nr = parseInt(document.forms[0].elements[i].value);
+         if(isNaN(nr) == true){document.forms[0].elements[i].value = 0;}
+         else{document.forms[0].elements[i].value = nr;}
+   document.forms[0].update_content.value=1;
+   document.forms[0].submit();
+function getAllLayer(){
+   var arrayLayer = new Array();
+   var cntLayer = 0;
+      if(document.forms[0].elements[i].name.indexOf("layer_id") > -1){
+         arrayLayer[cntLayer] = document.forms[0].elements[i].value;
+         cntLayer++;
+   return arrayLayer;
+function setSubs(){
+   var arrayLayer = getAllLayer();
+   for(var i=0; i<arrayLayer.length; i++){
+      if(parseInt(eval("document.forms[0].L_" + arrayLayer[i] + "___layer_parent.value")) > 0){
+         eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_status.checked = false");
+function setLayer(def,status){
+   if(def == 'querylayer'){
+      for(var i=1; i<arrayLayer.length; i++){
+         if(eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.disabled == false")){
+            eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.checked = " + status);
+   if(def == 'visible'){
+         eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_visible.checked = " + status);
+function showSld(origUrl){
+	var url = document.getElementById("this_gui_wms_sldurl").value;
+	if(url==""){
+		if(origUrl=="")
+			return;
+		url=origUrl;
+	window.open(url);
+</script>
+</head>
+<body>
+<?php
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+$mb_user_id=$_SESSION["mb_user_id"];
+#delete gui_wms from gui
+if($del && $del == 'true'){
+	$sql="SELECT DISTINCT gui_wms_position from gui_wms WHERE fkey_gui_id = $1 and fkey_wms_id = $2";
+	$v = array($guiList,$wmsList);
+	$t = array('s','i');
+	$res = db_prep_query($sql,$v,$t);
+	$cnt = 0;
+	while($row = db_fetch_array($res)){
+		$wms_position = $row["gui_wms_position"];
+		$cnt++;
+	#if($cnt > 1){die("Error: WMS (ID) not unique!");}
+		$sql = "Delete from gui_wms where fkey_gui_id = $1 and fkey_wms_id = $2 ";
+		$sql = "Delete from gui_layer where fkey_gui_id = $1 and gui_layer_wms_id = $2";
+		$del='false';
+		$sql = "UPDATE gui_wms SET gui_wms_position = (gui_wms_position - 1) WHERE gui_wms_position > $1";
+		$sql .= " AND fkey_gui_id = $2 ";
+		$v = array($wms_position,$guiList);
+		$t = array('i','s');
+	unset($wmsList);
+#update gui_wms_position
+if($up && $up == 'true'){
+	if ($wmsList!=""){
+		$sql = "SELECT gui_wms_position ";
+		$sql .= "FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
+		if($row = db_fetch_array($res)){
+	if($wms_position > 0){
+		$sql = "UPDATE gui_wms SET ";
+		$sql .= "gui_wms_position = $1";
+		$sql .= " WHERE fkey_gui_id = $2 AND fkey_wms_id = $3";
+		$v = array(($wms_position - 1),$guiList,$wmsList);
+		$t = array('i','s','i');
+		$sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4 ";
+		$v = array($wms_position,($wms_position - 1),$guiList,$wmsList);
+		$t = array('i','i','s','i');
+if($down && $down == 'true'){
+	$max = 0;
+		$sql = "SELECT MAX(gui_wms_position) as max FROM gui_wms WHERE fkey_gui_id = $1 ";
+		$v = array($guiList);
+		$t = array('s');
+			$max = $row["max"];
+	if($wms_position < $max){
+		$v = array(($wms_position + 1),$guiList,$wmsList);
+		$sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4";
+		$v = array($wms_position,($wms_position + 1),$guiList,$wmsList);
+/*handle Updates*/
+if(isset($update_content) && $update_content == "1"){
+   if(isset($this_gui_wms_epsg)){
+      $sql = "UPDATE gui_wms set gui_wms_epsg = $1, gui_wms_mapformat = $2, ";
+      $sql .= "gui_wms_featureinfoformat = $3, gui_wms_exceptionformat = $4, ";
+      $sql .= "gui_wms_visible = $5, gui_wms_opacity = $6, gui_wms_sldurl = $7 ";
+      $sql .= "WHERE fkey_gui_id = $8 AND fkey_wms_id = $9";
+		$v = array($this_gui_wms_epsg,$this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
+		$t = array('s','s','s','s','i','i','s','s','i');
+   else{
+		$sql = "UPDATE gui_wms set gui_wms_mapformat = $1, ";
+		$sql .= "gui_wms_featureinfoformat = $2, gui_wms_exceptionformat = $3, ";
+		$sql .= "gui_wms_visible = $4, gui_wms_opacity = $5, gui_wms_sldurl = $6 ";
+		$sql .= "WHERE fkey_gui_id = $7 AND fkey_wms_id = $8";
+		$v = array($this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
+		$t = array('s','s','s','i','i','s','s','i');
+   $cnt = 0;
+   while(list($key,$val) = each($_REQUEST)){
+		if(preg_match("/___/", $key)){
+			$myKey = explode("___", $key);
+			if($myKey[1]!="layer_parent" && $myKey[1]!='layer_id' ){
+				$sql = "UPDATE gui_layer SET ".$myKey[1]." = $1 WHERE fkey_gui_id = $2 AND fkey_layer_id = $3";
+				$v = array($val,$this_gui,preg_replace("/L_/","",$myKey[0]));
+				if($myKey[1]=='gui_layer_style'){
+					$t = array('s','s','i');
+				else{
+				if(!$res = db_prep_query($sql,$v,$t)){
+					echo "FEHLER in ZEILE 288";
+echo "<form name='form1' action='" . $self ."' method='post'>";
+echo "<table cellpadding='3' cellspacing='3' border='0' class='table_top'>";
+echo "<tr>";
+echo "<td>";
+echo "GUI";
+echo "</td>";
+echo "<td>";
+echo "WMS-TITLE";
+echo "</td>";
+echo "<td>";
+echo "</td>";
+echo "<tr>";
+echo "<td>";
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$admin = new administration();
+$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
+$gui_id =array();
+if (count($ownguis)>0){
+	for($i=0; $i<count($ownguis); $i++){
+		$gui_id[$i]=$ownguis[$i];
+echo"<select size='8' name='guiList' onchange='document.form1.wmsList.selectedIndex = -1;submit()'>";
+$selected_gui_id="";
+for ($i=0; $i<count($ownguis);$i++){
+   echo "<option value='".$gui_id[$i]."' ";
+   if($guiList && $guiList == $gui_id[$i]){
+      echo "selected";
+      $selected_gui_id=$gui_id[$i];
+   else{
+      if ($i==0){
+         echo "selected";
+   echo ">".$gui_id[$i]."</option>";
+echo "</select>";
+echo "</td>";
+echo "<td>";
+$sql = "SELECT * from gui_wms JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON ";
+$sql .= "gui_wms.fkey_wms_id = wms.wms_id AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_id = $1 ORDER BY gui_wms_position";
+$v = array($selected_gui_id);
+$t = array('s');
+$res = db_prep_query($sql,$v,$t);
+$count_wms = 0;
+echo "<select size='8' name='wmsList' style='width:200px' onchange='submit()'>";
+while($row = db_fetch_array($res)){
+	echo "<option value='".$row["wms_id"]."' ";
+	if(isset($wmsList) && $wmsList == $row["wms_id"]){
+		echo "selected";
+	echo ">".$row["gui_wms_position"]." - ".$row["wms_title"]."</option>";
+	$count_wms++;
+echo "</select>";
+echo "</td><td>";
+echo "<input class='myButton' type='button' name='up_wms' value=' up ' onClick='validate(\"up_wms\")'>";
+echo "<input type='hidden' name='up' value=''><br><br>";
+echo "<input class='myButton' type='button' name='down_wms' value='down'  onClick='validate(\"down_wms\")'>";
+echo "<input type='hidden' name='down' value=''><br><br>";
+echo "<input class='myButton' type='button' name='delete_wms' value='remove'  onClick='validate(\"delete_wms\")'>";
+echo "<input type='hidden' name='del' value=''>";
+echo "</td>";
+echo "</tr>";
+echo "</table>";
+if(isset($wmsList)){
+#gui_wms
+$sql_gw = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
+$v = array($guiList,$wmsList);
+$t = array('s','i');
+$res_gw = db_prep_query($sql_gw,$v,$t);
+$cnt_gw = 0;
+while($row = db_fetch_array($res_gw)){
+   $gui_wms_position[$cnt_gw] = $row["gui_wms_position"];
+   $gui_wms_mapformat[$cnt_gw] = $row["gui_wms_mapformat"];
+   $gui_wms_featureinfoformat[$cnt_gw] = $row["gui_wms_featureinfoformat"];
+   $gui_wms_exceptionformat[$cnt_gw] = $row["gui_wms_exceptionformat"];
+   $gui_wms_epsg[$cnt_gw] = $row["gui_wms_epsg"];
+   $gui_wms_visible[$cnt_gw] = $row["gui_wms_visible"];
+   $gui_wms_opacity[$cnt_gw] = $row["gui_wms_opacity"];
+   $gui_wms_sldurl[$cnt_gw] = $row["gui_wms_sldurl"]; # sld url
+   $cnt_gw++;
+#wms
+$sql_w = "SELECT * FROM wms WHERE wms_id = $1";
+$v = array($wmsList);
+$t = array('i');
+$res_w = db_prep_query($sql_w,$v,$t);
+$cnt_w = 0;
+while($row = db_fetch_array($res_w)){
+   $wms_id[$cnt_w] = $row["wms_id"];
+   $wms_version[$cnt_w] = $row["wms_version"];
+   $wms_title[$cnt_w] = $row["wms_title"];
+   $wms_abstract[$cnt_w] = $row["wms_abstract"];
+   $wms_getcapabilities[$cnt_w] = $row["wms_getcapabilities"];
+   $wms_supportsld[$cnt_w] = $row["wms_supportsld"];  # Buttons zum sld support anzeigen?
+   $cnt_w++;
+#wms_format
+$sql_wf = "SELECT * FROM  wms_format WHERE  fkey_wms_id = $1";
+$t = array('i');
+$res_wf = db_prep_query($sql_wf,$v,$t);
+$cnt_wf = 0;
+while($row = db_fetch_array($res_wf)){
+   $data_type[$cnt_wf] = $row["data_type"];
+   $data_format[$cnt_wf] = $row["data_format"];
+   $cnt_wf++;
+#gui_layer
+$sql_gl = "SELECT l.*, gl.*, sld.sld_user_layer_id, sld.use_sld FROM layer AS l, gui_layer AS gl left outer join sld_user_layer AS sld on sld.fkey_layer_id = gl.fkey_layer_id WHERE l.layer_id = gl.fkey_layer_id AND gl.gui_layer_wms_id = $1 AND gl.fkey_gui_id = $2 AND (sld.fkey_gui_id = $3 or sld.fkey_gui_id is NULL) AND (sld.fkey_mb_user_id = $4 or sld.fkey_mb_user_id is NULL) ORDER BY l.layer_pos";
+$v = array($wmsList,$guiList,$guiList,$mb_user_id);
 $t = array('i','s','s','i');
-$res_gl = db_prep_query($sql_gl,$v,$t);
-$gui_layer_status = array();
-$gui_layer_selectable = array();
-$gui_layer_visible = array();
-$gui_layer_queryable = array();
-$gui_layer_querylayer = array();
-$gui_layer_minscale = array();
-$gui_layer_maxscale = array();
-$gui_layer_priority = array();
-$gui_layer_style = array();
-$gui_layer_wfs_featuretype = array();
-$layer_maxscale = array();
-$layer_id = array();
-$layer_parent = array();
-$layer_name = array();
-$layer_title = array();
-$layer_queryable = array();
-$layer_minscale = array();
-$sld_user_layer_id = array();
-$use_sld = array();
-while($row = db_fetch_array($res_gl)){
-	array_push($gui_layer_status, $row["gui_layer_status"]);
-	array_push($gui_layer_selectable, $row["gui_layer_selectable"]);
-	array_push($gui_layer_visible, $row["gui_layer_visible"]);
-	array_push($gui_layer_queryable, $row["gui_layer_queryable"]);
-	array_push($gui_layer_querylayer, $row["gui_layer_querylayer"]);
-	array_push($gui_layer_minscale, $row["gui_layer_minscale"]);
-	array_push($gui_layer_maxscale, $row["gui_layer_maxscale"]);
-	array_push($gui_layer_priority, $row["gui_layer_priority"]);
-	array_push($gui_layer_style, $row["gui_layer_style"]);
-	array_push($gui_layer_wfs_featuretype, $row["gui_layer_wfs_featuretype"]);
-	array_push($layer_id, $row["layer_id"]);
-	array_push($layer_parent, $row["layer_parent"]);
-	array_push($layer_name, $row["layer_name"]);
-	array_push($layer_title, $row["layer_title"]);
-	array_push($layer_queryable, $row["layer_queryable"]);
-	array_push($layer_minscale, $row["layer_minscale"]);
-	array_push($layer_maxscale, $row["layer_maxscale"]);
-	array_push($sld_user_layer_id, $row["sld_user_layer_id"]);
-	array_push($use_sld, $row["use_sld"]);
-#layer_epsg
-$sql_le = "SELECT * FROM layer_epsg WHERE  fkey_layer_id = $1";
-$v = array($layer_id[0]);
-$t = array('i');
-$res_le = db_prep_query($sql_le,$v,$t);
-$cnt_le = 0;
-while($row = db_fetch_array($res_le)){
-   $epsg[$cnt_le] = $row["epsg"];
-   $cnt_le++;
-echo "<div style='position:absolute;left:590px; top:180px;' ><input type='button' style='width:100px;height:100px;background-color:#0066cc' value='save' onclick='checkBoxValue()'></div>";
-echo "<table class='table_top'>";
-echo "<tr>";
-echo "<td colspan='2'>";
-echo "<a href='".$wms_getcapabilities[0];
-if( $wms_version[0] == "1.0.0"){ echo "&WMTVER=". $wms_version[0]."&REQUEST=capabilities";}
-else{echo "&VERSION=". $wms_version[0]."&REQUEST=GetCapabilities&SERVICE=WMS";}
-echo "' style='font-size:14px' target='_blank'>LINK: Capabilities</a>";
-echo "</td>";
-echo "<td align = right>WMS ID: " . $wms_id[0] . "</td>";
-echo "<tr>";
-#epsg
-if($gui_wms_position[0] == 0){
-  echo "<tr>";
-     echo "<td>EPSG: </td><td>";
-     echo "<select class='mySelect'  name='this_gui_wms_epsg'>";
-        for($i=0; $i<count($epsg); $i++){
-           echo "<option value='".$epsg[$i]."' ";
-           if($epsg[$i] == $gui_wms_epsg[0]){ echo "selected";}
-           echo ">".$epsg[$i]."</option>";
-     echo "</select>";
-     echo "</td>";
-  echo "</tr>";
-#format
-echo "<tr>";
-   echo "<td>Mapformat: </td><td>";
-        echo "<select class='mySelect'  name='this_gui_wms_mapformat'>";
-        for($i=0; $i<count($data_format); $i++){
-           if($data_type[$i] == 'map'){
-              echo "<option value='".$data_format[$i]."' ";
-              if($data_format[$i] == $gui_wms_mapformat[0]){ echo "selected";}
-              echo ">".$data_format[$i]."</option>";
-     echo "</select>";
-   echo "</td>";
-echo "</tr>";
-echo "<tr>";
-   echo "<td>Infoformat: </td><td>";
-        echo "<select class='mySelect'  name='this_gui_wms_featureinfoformat'>";
-        echo "<option value='text/html'>text/html</option>";
-           if($data_type[$i] == 'featureinfo'){
-              if($data_format[$i] == $gui_wms_featureinfoformat[0]){ echo "selected";}
-     echo "</select>";
-   echo "</td>";
-echo "</tr>";
-echo "<tr>";
-   echo "<td>Exceptionformat: </td><td>";
-        echo "<select class='mySelect' name='this_gui_wms_exceptionformat'>";
-           if($data_type[$i] == 'exception'){
-              if($data_format[$i] == $gui_wms_exceptionformat[0]){ echo "selected";}
-     echo "</select>";
-   echo "</td>";
-echo "</tr><br>";
-# visibility
-echo "<tr>";
-	echo "<td>Visibility: </td><td>";
-	echo "<select class='mySelect' name='this_gui_wms_visible'>";
-	for($i=0; $i<3; $i++){
-		echo "<option value='".$i."' ";
-		if($i == $gui_wms_visible[0]){ echo "selected";}
-		echo ">";
-		if($i == '0'){
-			echo "hidden";
-		if($i == '1'){
-			echo "visible";
-		echo "</option>";
-	echo "</select>";
-	echo "</td>";
-echo "</tr>";
-# opacity
-echo "<tr>";
-	echo "<td>Opacity: </td><td>";
-	echo "<select class='mySelect' name='this_gui_wms_opacity'>";
-	for($i=0; $i<=100; $i+=10){
-		if($i - $gui_wms_opacity[0]<=5&&$i - $gui_wms_opacity[0]>=-4){ echo "selected";}
-		echo ">";
-		echo $i."%";
-		echo "</option>";
-	echo "</select>";
-	echo "</td>";
-echo "</tr>";
-# sld support
-if($wms_supportsld[0]) {
-		echo "<tr>";
-		echo "<td>SLD-URL: </td><td>";
-		echo "<input type='text' class='myText' name='this_gui_wms_sldurl' id='this_gui_wms_sldurl' title='".$gui_wms_sldurl[0]."' value='".$gui_wms_sldurl[0]."'>";
-		#echo "<a href='' onclick='return window.open(\"editor-start.php\");'><img src='sld_editor.png' border=0></a>";
-		#$layer_names = implode(",", $layer_name);
-        echo " <a href='javascript:showSld(\"".$gui_wms_sldurl[0]."\");'>SLD laden/anzeigen</a>";
-		echo "</td>";
-	echo "</tr>";
-} else {
-	echo "<input type='hidden' value='' name='this_gui_wms_sldurl'>";
-echo "</table><br>";
-echo "<table border='1' cellpadding='1'>";
-		echo "<tr>";
-                echo "<td>Nr.</td>";
-                echo "<td>ID</td>";
-                echo "<td>" . toImage('Parent') . "</td>";
-                echo "<td>Name</td>";
-                echo "<td>Title</td>";
-                echo "<td>" . toImage('on/off') . "</td>";
-                echo "<td>" . toImage('sel') . "</td>";
-                echo "<td>" . toImage('sel_default') . "</td>";
-                echo "<td>" . toImage('info') . "</td>";
-                echo "<td>" . toImage('info_default') . "</td>";
-                echo "<td>" . toImage('minScale 1:') . "</td>";
-                echo "<td>" . toImage('maxScale 1:') . "</td>";
-                echo "<td>" . toImage('Style') . "</td>";
-                echo "<td>" . toImage('Prio') . "</td>";
+$res_gl = db_prep_query($sql_gl,$v,$t);
+$gui_layer_status = array();
+$gui_layer_selectable = array();
+$gui_layer_visible = array();
+$gui_layer_queryable = array();
+$gui_layer_querylayer = array();
+$gui_layer_minscale = array();
+$gui_layer_maxscale = array();
+$gui_layer_priority = array();
+$gui_layer_style = array();
+$gui_layer_wfs_featuretype = array();
+$layer_maxscale = array();
+$layer_id = array();
+$layer_parent = array();
+$layer_name = array();
+$layer_title = array();
+$layer_queryable = array();
+$layer_minscale = array();
+$sld_user_layer_id = array();
+$use_sld = array();
+while($row = db_fetch_array($res_gl)){
+	array_push($gui_layer_status, $row["gui_layer_status"]);
+	array_push($gui_layer_selectable, $row["gui_layer_selectable"]);
+	array_push($gui_layer_visible, $row["gui_layer_visible"]);
+	array_push($gui_layer_queryable, $row["gui_layer_queryable"]);
+	array_push($gui_layer_querylayer, $row["gui_layer_querylayer"]);
+	array_push($gui_layer_minscale, $row["gui_layer_minscale"]);
+	array_push($gui_layer_maxscale, $row["gui_layer_maxscale"]);
+	array_push($gui_layer_priority, $row["gui_layer_priority"]);
+	array_push($gui_layer_style, $row["gui_layer_style"]);
+	array_push($gui_layer_wfs_featuretype, $row["gui_layer_wfs_featuretype"]);
+	array_push($layer_id, $row["layer_id"]);
+	array_push($layer_parent, $row["layer_parent"]);
+	array_push($layer_name, $row["layer_name"]);
+	array_push($layer_title, $row["layer_title"]);
+	array_push($layer_queryable, $row["layer_queryable"]);
+	array_push($layer_minscale, $row["layer_minscale"]);
+	array_push($layer_maxscale, $row["layer_maxscale"]);
+	array_push($sld_user_layer_id, $row["sld_user_layer_id"]);
+	array_push($use_sld, $row["use_sld"]);
+#layer_epsg
+$sql_le = "SELECT * FROM layer_epsg WHERE  fkey_layer_id = $1";
+$v = array($layer_id[0]);
+$t = array('i');
+$res_le = db_prep_query($sql_le,$v,$t);
+$cnt_le = 0;
+while($row = db_fetch_array($res_le)){
+   $epsg[$cnt_le] = $row["epsg"];
+   $cnt_le++;
+echo "<div style='position:absolute;left:590px; top:180px;' ><input type='button' style='width:100px;height:100px;background-color:#0066cc' value='save' onclick='checkBoxValue()'></div>";
+echo "<table class='table_top'>";
+echo "<tr>";
+echo "<td colspan='2'>";
+echo "<a href='".$wms_getcapabilities[0];
+if( $wms_version[0] == "1.0.0"){ echo "&WMTVER=". $wms_version[0]."&REQUEST=capabilities";}
+else{echo "&VERSION=". $wms_version[0]."&REQUEST=GetCapabilities&SERVICE=WMS";}
+echo "' style='font-size:14px' target='_blank'>LINK: Capabilities</a>";
+echo "</td>";
+echo "<td align = right>WMS ID: " . $wms_id[0] . "</td>";
+echo "<tr>";
+#epsg
+if($gui_wms_position[0] == 0){
+  echo "<tr>";
+     echo "<td>EPSG: </td><td>";
+     echo "<select class='mySelect'  name='this_gui_wms_epsg'>";
+        for($i=0; $i<count($epsg); $i++){
+           echo "<option value='".$epsg[$i]."' ";
+           if($epsg[$i] == $gui_wms_epsg[0]){ echo "selected";}
+           echo ">".$epsg[$i]."</option>";
+     echo "</select>";
+     echo "</td>";
+  echo "</tr>";
+#format
+echo "<tr>";
+   echo "<td>Mapformat: </td><td>";
+        echo "<select class='mySelect'  name='this_gui_wms_mapformat'>";
+        for($i=0; $i<count($data_format); $i++){
+           if($data_type[$i] == 'map'){
+              echo "<option value='".$data_format[$i]."' ";
+              if($data_format[$i] == $gui_wms_mapformat[0]){ echo "selected";}
+              echo ">".$data_format[$i]."</option>";
+     echo "</select>";
+   echo "</td>";
+echo "</tr>";
+echo "<tr>";
+   echo "<td>Infoformat: </td><td>";
+        echo "<select class='mySelect'  name='this_gui_wms_featureinfoformat'>";
+        echo "<option value='text/html'>text/html</option>";
+           if($data_type[$i] == 'featureinfo'){
+              if($data_format[$i] == $gui_wms_featureinfoformat[0]){ echo "selected";}
+     echo "</select>";
+   echo "</td>";
+echo "</tr>";
+echo "<tr>";
+   echo "<td>Exceptionformat: </td><td>";
+        echo "<select class='mySelect' name='this_gui_wms_exceptionformat'>";
+           if($data_type[$i] == 'exception'){
+              if($data_format[$i] == $gui_wms_exceptionformat[0]){ echo "selected";}
+     echo "</select>";
+   echo "</td>";
+echo "</tr><br>";
+# visibility
+echo "<tr>";
+	echo "<td>Visibility: </td><td>";
+	echo "<select class='mySelect' name='this_gui_wms_visible'>";
+	for($i=0; $i<3; $i++){
+		echo "<option value='".$i."' ";
+		if($i == $gui_wms_visible[0]){ echo "selected";}
+		echo ">";
+		if($i == '0'){
+			echo "hidden";
+		if($i == '1'){
+			echo "visible";
+		echo "</option>";
+	echo "</select>";
+	echo "</td>";
+echo "</tr>";
+# opacity
+echo "<tr>";
+	echo "<td>Opacity: </td><td>";
+	echo "<select class='mySelect' name='this_gui_wms_opacity'>";
+	for($i=0; $i<=100; $i+=10){
+		if($i - $gui_wms_opacity[0]<=5&&$i - $gui_wms_opacity[0]>=-4){ echo "selected";}
+		echo ">";
+		echo $i."%";
+		echo "</option>";
+	echo "</select>";
+	echo "</td>";
+echo "</tr>";
+# sld support
+if($wms_supportsld[0]) {
+		echo "<tr>";
+		echo "<td>SLD-URL: </td><td>";
+		echo "<input type='text' class='myText' name='this_gui_wms_sldurl' id='this_gui_wms_sldurl' title='".$gui_wms_sldurl[0]."' value='".$gui_wms_sldurl[0]."'>";
+		#echo "<a href='' onclick='return window.open(\"editor-start.php\");'><img src='sld_editor.png' border=0></a>";
+		#$layer_names = implode(",", $layer_name);
+        echo " <a href='javascript:showSld(\"".$gui_wms_sldurl[0]."\");'>SLD laden/anzeigen</a>";
+		echo "</td>";
+	echo "</tr>";
+} else {
+	echo "<input type='hidden' value='' name='this_gui_wms_sldurl'>";
+echo "</table><br>";
+echo "<table border='1' cellpadding='1'>";
+		echo "<tr>";
+                echo "<td>Nr.</td>";
+                echo "<td>ID</td>";
+                echo "<td>" . toImage('Parent') . "</td>";
+                echo "<td>Name</td>";
+                echo "<td>Title</td>";
+                echo "<td>" . toImage('on/off') . "</td>";
+                echo "<td>" . toImage('sel') . "</td>";
+                echo "<td>" . toImage('sel_default') . "</td>";
+                echo "<td>" . toImage('info') . "</td>";
+                echo "<td>" . toImage('info_default') . "</td>";
+                echo "<td>" . toImage('minScale 1:') . "</td>";
+                echo "<td>" . toImage('maxScale 1:') . "</td>";
+                echo "<td>" . toImage('Style') . "</td>";
+                echo "<td>" . toImage('Prio') . "</td>";
                 echo "<td>" . toImage('setWFS') . "</td>";
-                if($wms_supportsld[0]) {echo "<td>" . toImage('SLD') . "</td>";}
-        echo "</tr>";
-#echo "<tr><td>Nr.</td><td>ID</td><td>Parent</td><td>Name</td><td>Title</td><td>on/off</td><td>sel</td><td>sel_default</td><td>info</td><td>info_default</td><td>minScale 1:</td><td>maxScale 1:</td><td>Prio</td><td>setWFS</td></tr>";
-echo "<tr><td></td><td></td><td></td><td></td><td></td><td>";
-echo "<input type='button' class='LButton' value='Sublayer\noff' onclick='setSubs()'>";
-echo "</td><td></td><td>";
-echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"visible\",false)'>&nbsp;";
-echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"visible\",true)'></nobr>";
-echo"</td><td></td><td>";
-echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"querylayer\",false)'>&nbsp;";
-echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"querylayer\",true)'></nobr>";
-echo "</td><td></td><td></td><td></td></tr>";
-for($i=0; $i<count($layer_id); $i++){
-#layer_styles
-$sql_styles = "SELECT * FROM layer_style WHERE  fkey_layer_id = $1";
-$v = array($layer_id[$i]);
-$t = array('i');
-$res_styles = db_prep_query($sql_styles,$v,$t);
-$cnt_styles= 0;
-$style = array();
-while($row = db_fetch_array($res_styles)){
-   $style[$cnt_styles] = $row["name"];
-   $cnt_styles++;
- echo "<tr align='center'>";
-  echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_nr' disabled value='".$i."'></td>";
-  echo "<td style='background:lightgrey'><input type='text' size='2' name='L_".$layer_id[$i]."___layer_id' value='".$layer_id[$i]."' readonly></td>";
-  echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_parent' value='".$layer_parent[$i]."' readonly></td>";
-  echo "<td style='background:lightgrey'><input type='text' size='7' value='".$layer_name[$i]."' readonly></td>";
-  echo "<td><input type='text' name='".$layer_title[$i]."' size='12' value='".$layer_title[$i]."' ></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_status' type='checkbox' ";
-  if($gui_layer_status[$i] == 1){ echo "checked";}
-  echo "></td>";
-  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_selectable' type='checkbox' ";
-  if($gui_layer_selectable[$i] == 1){ echo "checked";}
-  echo "></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_visible' type='checkbox' ";
-  if($gui_layer_visible[$i] == 1){ echo "checked";}
-  echo "></td>";
-  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_queryable' type='checkbox' ";
-  if($gui_layer_queryable[$i] == 1){ echo "checked";}
-  if($layer_queryable[$i] == 0){ echo "disabled";}
-  echo "></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_querylayer' type='checkbox' ";
-  if($gui_layer_querylayer[$i] == 1){ echo "checked";}
-  echo "></td>";
-  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_minscale' type='text' size='5' value='".$gui_layer_minscale[$i]."'></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_maxscale' type='text' size='5' value='".$gui_layer_maxscale[$i]."'></td>";
-  echo "<td>\n";
-  echo "<select class='mySelect' name='L_".$layer_id[$i]."___gui_layer_style'>\n";
-  	   echo "<option value=''";
-  	   if(count($style) ==0){ echo "selected";}
-  	   echo ">---</option>\n";
-  for($j=0;$j<count($style); $j++){
-       echo "<option value='".$style[$j]."'";
-       if($style[$j] == $gui_layer_style[$i]){ echo "selected";}
-       echo ">".$style[$j]."</option>\n";
-  echo "</select></td>\n";
-  echo "<td><select class='select_short' name='L_".$layer_id[$i]."___gui_layer_priority'>";
-  for($j=0; $j<count($gui_layer_priority); $j++){
-     echo "<option value='".$j."'";
-     if($j == $gui_layer_priority[$i]){echo "selected";}
-     echo ">".$j;
-     echo "</option>";
-  /* wfs configuration */
-	echo "<td>";
-	if ($i > 0) {
-		echo "<input class='button_wfs'name='gui_layer_gaz' type='button' onclick='edit_gaz(\"".$guiList."\",".$wmsList.",".$layer_id[$i].")' value='";
-		if($gui_layer_wfs_featuretype[$i] == ""){
-			echo "setWFS";
-		else{
-			echo "wfs ".$gui_layer_wfs_featuretype[$i];
-		echo "'>";
+                if($wms_supportsld[0]) {echo "<td>" . toImage('SLD') . "</td>";}
+        echo "</tr>";
+#echo "<tr><td>Nr.</td><td>ID</td><td>Parent</td><td>Name</td><td>Title</td><td>on/off</td><td>sel</td><td>sel_default</td><td>info</td><td>info_default</td><td>minScale 1:</td><td>maxScale 1:</td><td>Prio</td><td>setWFS</td></tr>";
+echo "<tr><td></td><td></td><td></td><td></td><td></td><td>";
+echo "<input type='button' class='LButton' value='Sublayer\noff' onclick='setSubs()'>";
+echo "</td><td></td><td>";
+echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"visible\",false)'>&nbsp;";
+echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"visible\",true)'></nobr>";
+echo"</td><td></td><td>";
+echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"querylayer\",false)'>&nbsp;";
+echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"querylayer\",true)'></nobr>";
+echo "</td><td></td><td></td><td></td></tr>";
+for($i=0; $i<count($layer_id); $i++){
+#layer_styles
+$sql_styles = "SELECT * FROM layer_style WHERE  fkey_layer_id = $1";
+$v = array($layer_id[$i]);
+$t = array('i');
+$res_styles = db_prep_query($sql_styles,$v,$t);
+$cnt_styles= 0;
+$style = array();
+while($row = db_fetch_array($res_styles)){
+   $style[$cnt_styles] = $row["name"];
+   $cnt_styles++;
+ echo "<tr align='center'>";
+  echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_nr' disabled value='".$i."'></td>";
+  echo "<td style='background:lightgrey'><input type='text' size='2' name='L_".$layer_id[$i]."___layer_id' value='".$layer_id[$i]."' readonly></td>";
+  echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_parent' value='".$layer_parent[$i]."' readonly></td>";
+  echo "<td style='background:lightgrey'><input type='text' size='7' value='".$layer_name[$i]."' readonly></td>";
+  echo "<td><input type='text' name='".$layer_title[$i]."' size='12' value='".$layer_title[$i]."' ></td>";
+  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_status' type='checkbox' ";
+  if($gui_layer_status[$i] == 1){ echo "checked";}
+  echo "></td>";
+  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_selectable' type='checkbox' ";
+  if($gui_layer_selectable[$i] == 1){ echo "checked";}
+  echo "></td>";
+  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_visible' type='checkbox' ";
+  if($gui_layer_visible[$i] == 1){ echo "checked";}
+  echo "></td>";
+  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_queryable' type='checkbox' ";
+  if($gui_layer_queryable[$i] == 1){ echo "checked";}
+  if($layer_queryable[$i] == 0){ echo "disabled";}
+  echo "></td>";
+  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_querylayer' type='checkbox' ";
+  if($gui_layer_querylayer[$i] == 1){ echo "checked";}
+  echo "></td>";
+  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_minscale' type='text' size='5' value='".$gui_layer_minscale[$i]."'></td>";
+  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_maxscale' type='text' size='5' value='".$gui_layer_maxscale[$i]."'></td>";
+  echo "<td>\n";
+  echo "<select class='select_short' name='L_".$layer_id[$i]."___gui_layer_style'>\n";
+  	   echo "<option value=''";
+  	   if(count($style) ==0){ echo "selected";}
+  	   echo ">---</option>\n";
+  for($j=0;$j<count($style); $j++){
+       echo "<option value='".$style[$j]."'";
+       if($style[$j] == $gui_layer_style[$i]){ echo "selected";}
+       echo ">".$style[$j]."</option>\n";
+  echo "</select></td>\n";
+  echo "<td><select class='select_auto' name='L_".$layer_id[$i]."___gui_layer_priority'>";
+  for($j=0; $j<count($gui_layer_priority); $j++){
+     echo "<option value='".$j."'";
+     if($j == $gui_layer_priority[$i]){echo "selected";}
+     echo ">".$j;
+     echo "</option>";
+  /* wfs configuration */
+	echo "<td>";
+	if ($i > 0) {
+		echo "<input class='button_wfs'name='gui_layer_gaz' type='button' onclick='edit_gaz(\"".$guiList."\",".$wmsList.",".$layer_id[$i].")' value='";
+		if($gui_layer_wfs_featuretype[$i] == ""){
+			echo "setWFS";
+		else{
+			echo "wfs ".$gui_layer_wfs_featuretype[$i];
+		echo "'>";
 	echo "</td>";
 		echo "<td>";
@@ -729,20 +729,20 @@
 				echo "sld:".$sld_user_layer_id[$i]."(".$use_sld[$i].")";
 			else
 				echo "SLD";
-			echo "'>";
+			echo "'>";
-		echo "</td>";
- echo "</tr>\n";
- if($i == 0){ echo "<tr><td colspan='14'><hr></td></tr>";}
-echo "</table>\n";
-echo "<input type='hidden' name='this_gui' value='".$guiList."'>\n";
-echo "<input type='hidden' name='this_wms' value='".$wmsList."'>\n";
-echo "<input type='hidden' name='this_layer_count' value='".$cnt_l."'>\n";
-echo "<input type='hidden' name='update_content' value=''>\n";
-echo "</form>\n";
-</body>
+		echo "</td>";
+ echo "</tr>\n";
+ if($i == 0){ echo "<tr><td colspan='16'><hr></td></tr>";}
+echo "</table>\n";
+echo "<input type='hidden' name='this_gui' value='".$guiList."'>\n";
+echo "<input type='hidden' name='this_wms' value='".$wmsList."'>\n";
+echo "<input type='hidden' name='this_layer_count' value='".$cnt_l."'>\n";
+echo "<input type='hidden' name='update_content' value=''>\n";
+echo "</form>\n";
+</body>
 </html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
