[Mapbender-commits] r2446 - branches/beck_dev/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 8 07:07:47 EDT 2008
Author: beck
Date: 2008-05-08 07:07:47 -0400 (Thu, 08 May 2008)
New Revision: 2446
Removed:
   branches/beck_dev/mapbender/http/javascripts/mod_map2object.php
Deleted: branches/beck_dev/mapbender/http/javascripts/mod_map2object.php
--- branches/beck_dev/mapbender/http/javascripts/mod_map2object.php	2008-05-08 10:41:08 UTC (rev 2445)
+++ branches/beck_dev/mapbender/http/javascripts/mod_map2object.php	2008-05-08 11:07:47 UTC (rev 2446)
@@ -1,26 +0,0 @@
-<?php
-# $Id: mod_map2object.php 2413 2008-04-23 16:21:04Z christoph $
-# http://www.mapbender.org/index.php/mod_map2object.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-echo "var mod_map2object_target = '".$e_target[0]."';";
-function mod_map2object(){
-	alert(mod_map2object_target);
\ No newline at end of file
More information about the Mapbender_commits mailing list
