[Mapbender-commits] r2453 - in branches/beck_dev/mapbender/http: classes javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 15 05:06:07 EDT 2008
Author: christoph
Date: 2008-05-15 05:06:04 -0400 (Thu, 15 May 2008)
New Revision: 2453
   branches/beck_dev/mapbender/http/classes/class_administration.php
   branches/beck_dev/mapbender/http/classes/class_map.php
   branches/beck_dev/mapbender/http/classes/class_wmc.php
   branches/beck_dev/mapbender/http/classes/class_wms.php
   branches/beck_dev/mapbender/http/javascripts/mod_loadwmc.js
   branches/beck_dev/mapbender/http/php/mod_insertWmcIntoDb.php
WMC updates for PortalU
Modified: branches/beck_dev/mapbender/http/classes/class_administration.php
--- branches/beck_dev/mapbender/http/classes/class_administration.php	2008-05-15 09:02:56 UTC (rev 2452)
+++ branches/beck_dev/mapbender/http/classes/class_administration.php	2008-05-15 09:06:04 UTC (rev 2453)
@@ -19,6 +19,7 @@
 require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 require_once(dirname(__FILE__)."/class_mb_exception.php");
 require_once(dirname(__FILE__)."/class_user.php");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
@@ -28,8 +29,8 @@
  * class to wrap administration methods
  * @uses phpmailer
-class administration{
+class administration {
      * checks whether the passed email-address is valid / following a pattern
      * @todo is this an exact representation of the RFC 2822?
@@ -109,6 +110,54 @@
+	 * Removes the namespace from a tag name
+	 * @return String like "gml"
+	 * @param $s String like "ogc:gml"
+	public static function sepNameSpace($s) {
+		$c = strpos($s,":");
+		if ($c > 0) {
+			return substr($s,$c+1);
+		return $s;
+	 * Parses an XML with PHP XML parser, see
+	 * http://de2.php.net/manual/de/book.xml.php
+	 * @return Array an associative array of tags, values, attributes and types
+	 * @param $someXml String The actual XML as string.
+	public static function parseXml ($someXml) {
+		$values = null;
+		$tags = null;
+		$parser = xml_parser_create(CHARSET);
+		// set parsing options
+		xml_parser_set_option($parser, XML_OPTION_CASE_FOLDING, 0);
+		xml_parser_set_option($parser, XML_OPTION_SKIP_WHITE, 1);
+		xml_parser_set_option($parser, XML_OPTION_TARGET_ENCODING, CHARSET);
+		// this is the actual parsing process
+		xml_parse_into_struct($parser, $someXml, $values, $tags);
+		// check if an error occured
+		$code = xml_get_error_code ($parser);
+		if ($code) {
+			// report error
+			$line = xml_get_current_line_number($parser);
+			$errorMessage = xml_error_string($code) . " in line " . $line;
+			$mb_exception = new mb_exception($errorMessage);
+			return false;
+		xml_parser_free($parser);
+		return $values;
      * returns a random password with numbers and chars both lowercase and uppercase (0-9a-zA-Z)
Modified: branches/beck_dev/mapbender/http/classes/class_map.php
--- branches/beck_dev/mapbender/http/classes/class_map.php	2008-05-15 09:02:56 UTC (rev 2452)
+++ branches/beck_dev/mapbender/http/classes/class_map.php	2008-05-15 09:06:04 UTC (rev 2453)
@@ -1,6 +1,5 @@
 <?php
-ini_set("display_errors","on");
+require_once(dirname(__FILE__)."/../classes/class_bbox.php");
  * Representing a map object, identical to the JS object in javascripts/map.js
  * @class
@@ -11,15 +10,8 @@
 	var $height;
 	var $frameName;
 	var $elementName = "maps";
-	var $layers = array();
-	var $querylayers = array();
-	var $styles = array();
-	var $geom = "";
-	var $gml = "";
-	var $wms = array();
-	var $epsg;
 	var $extent;
-	var $mapURL = array();
+	var $overviewLayerIndex;
 	 * @constructor
@@ -28,7 +20,6 @@
 	function __construct() {
 	 * @param $value Integer
@@ -53,59 +44,66 @@
 	 * @param $value String
-	public function setEpsg ($value) {
-		$this->epsg = $value;
+	public function setExtent ($aMapbenderBbox) {
+		$this->extent = $aMapbenderBbox;
-	 * @param $value String
-	public function setExtent ($value) {
-		$this->extent = $value;
 	 * @param $value Object
-	public function pushWms ($value) {
+	public function addWms ($value) {
 		array_push($this->wms, $value);
-	 * @param $value Object
+	 * @return String EPSG code of the map.
-	public function pushMapUrl ($value) {
-		array_push($this->mapURL, $value);
+	public function getEpsg () {
+		return $this->extent->epsg;
+	 * @return Mapbender_bbox
-		array_push($this->wms, $value);
+	public function getExtent () {
+		return $this->extent;
+	 * @return String
-	public function pushLayer ($value) {
-		array_push($this->layers, $value);
+	public function getFrameName () {
+		return $this->frameName;
+	 * Returns an array of string, which are JS statements.
+	 * @return String[]
-	public function pushQueryLayer ($value) {
-		array_push($this->querylayers, $value);
+	public function createJsObj () {
+		$jsCodeArray = array();
+		$registerMapString = "mb_registerMapObj('" .
+			$this->frameName . "', " .
+			"'maps', " .
+			(isset($this->overviewLayerIndex)?$this->overviewLayerIndex:"null") . ", " .
+			$this->width . ", " .
+			$this->height . ");";
+		array_push($jsCodeArray, $registerMapString);
+		$calcExtentString = "mb_calculateExtent('" .
+			$this->extent->min->x . ", " .
+			$this->extent->min->y . ", " .
+			$this->extent->max->x . ", " .
+			$this->extent->max->y . ");";
+		array_push($jsCodeArray, $calcExtentString);
+		return $jsCodeArray;
-	public function pushStyle ($value) {
-		array_push($this->styles, $value);
 	 * @destructor
 	 * @param
Modified: branches/beck_dev/mapbender/http/classes/class_wmc.php
--- branches/beck_dev/mapbender/http/classes/class_wmc.php	2008-05-15 09:02:56 UTC (rev 2452)
+++ branches/beck_dev/mapbender/http/classes/class_wmc.php	2008-05-15 09:06:04 UTC (rev 2453)
@@ -16,31 +16,15 @@
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__) . "/../../conf/mapbender.conf");
 require_once(dirname(__FILE__) . "/../classes/class_wms.php");
-require_once(dirname(__FILE__) . "/../classes/class_mb_exception.php");
 require_once(dirname(__FILE__) . "/../classes/class_layer_monitor.php");
 require_once(dirname(__FILE__) . "/../classes/class_point.php");
 require_once(dirname(__FILE__) . "/../classes/class_bbox.php");
 require_once(dirname(__FILE__) . "/../classes/class_json.php");
+require_once(dirname(__FILE__) . "/../classes/class_map.php");
+require_once(dirname(__FILE__) . "/../classes/class_administration.php");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
-function mb_utf8_encode ($str) {
-	if(CHARSET=="UTF-8") return utf8_encode($str);
-	return $str;
-function mb_utf8_decode ($str) {
-	if(CHARSET=="UTF-8") return utf8_decode($str);
-	return $str;
-function sepNameSpace($s){
-	$c = strpos($s,":");
-	if($c>0)return substr($s,$c+1);
-	return $s;
  * Implementation of a Web Map Context Document, WMC 1.1.0
@@ -48,27 +32,19 @@
 	var $xml;
+	var $mainMap;
+	var $overviewMap;
+	var $wmsArray = array();
+	var $generalExtensionArray = array();
+	var $monitoringIsOn = false;
+	var $saveWmcAsFile = false;
 	var $wmc_id;
 	var $wmc_version;
-	var $wmc_windowWidth;
-	var $wmc_windowHeight;
-	var $wmc_bBox_SRS;
-	var $wmc_bBox_minx;
-	var $wmc_bBox_maxx;
-	var $wmc_bBox_miny;
-	var $wmc_bBox_maxy;
 	var $wmc_name;
 	var $wmc_title;
 	var $wmc_abstract;
-	var $wmc_general_extension = array();
-	var $wmc_logourl;
-	var $wmc_logourl_format;
-	var $wmc_logourl_type;
-	var $wmc_logourl_width;
-	var $wmc_logourl_height;
-	var $wmc_descriptionurl;
-	var $wmc_descriptionurl_format;
-	var $wmc_descriptionurl_type;
 	var $wmc_keyword = array();
 	var $wmc_contactposition;
 	var $wmc_contactvoicetelephone;
@@ -82,63 +58,16 @@
 	var $wmc_contactstateorprovince;
 	var $wmc_contactpostcode;
 	var $wmc_contactcountry;
-	var $wmc_wms_title = array();
-	var $wmc_layer_queryable = array();
-	var $wmc_layer_hidden = array();
-	var $wmc_wms_id = array();
-	var $wmc_wms_service = array();
-	var $wmc_wms_version = array();
-	var $wmc_wms_layer_id = array();
-	var $wmc_layer_wfs_featuretype = array();
-	var $wmc_layer_id = array();
-	var $wmc_layer_pos = array();
-	var $wmc_layer_parent = array();
-	var $wmc_layer_querylayer = array();
-	var $wmc_layer_title = array();
-	var $wmc_layer_name = array();
-	var $wmc_layer_abstract = array();
-	var $wmc_layer_srs = array();
-	var $wmc_wms_serviceURL = array();
-	var $wmc_layer_format_current = array();
-	var $wmc_layer_dataurl = array();
-	var $wmc_layer_metadataurl = array();
-	var $wmc_layer_minscale = array();
-	var $wmc_layer_maxscale = array();
-	var $wmc_gui_layer_minscale = array();
-	var $wmc_gui_layer_maxscale = array();
-	var $wmc_layer_format = array();
-	var $wmc_layer_style_current = array();
-	var $wmc_layer_style_name = array();
-	var $wmc_layer_style_title = array();
-	var $wmc_layer_style_legendurl = array();
-	var $wmc_layer_style_legendurl_width = array();
-	var $wmc_layer_style_legendurl_height = array();
-	var $wmc_layer_style_legendurl_format = array();
-	var $wmc_layer_style_legendurl_type = array();
-	var $wmc_layer_style_sld_url = array();
-	var $wmc_layer_style_sld_type = array();
-	var $wmc_layer_style_sld_title = array();
-	var $wmc_wms_count = 0;
-	 	var $data_type = array();
-		var $data_format = array();
-		var $objLayer = array();
-		var $gui_wms_mapformat;
-		var $gui_wms_featureinfoformat;
-		var $gui_wms_exceptionformat;
-		var $gui_wms_epsg;
-		var $default_epsg = 0;
-	var $monitoringIsOn = false;
-	function wmc() {
+	var $wmc_logourl;
+	var $wmc_logourl_format;
+	var $wmc_logourl_type;
+	var $wmc_logourl_width;
+	var $wmc_logourl_height;
+	var $wmc_descriptionurl;
+	var $wmc_descriptionurl_format;
+	var $wmc_descriptionurl_type;
+	public function __construct () {
@@ -149,8 +78,8 @@
 	 * @param	string		the wmc_id
 	 * @return	boolean		Did the query run successful?
-	function delete ($wmcId, $userId) {
-		if ($userId == null) {
+	public function delete ($wmcId, $userId) {
+		if (!isset($userId) || $userId == null) {
 			$userId = $_SESSION["mb_user_id"];
@@ -172,7 +101,7 @@
 	 * @return String|boolean The document if it exists; else false
 	 * @param $id String the WMC id
-	function getDocument ($id) {
+	public function getDocument ($id) {
 		$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 ";
 		$v = array($id);
 		$t = array('s');
@@ -187,41 +116,14 @@
-	 * Saves the current WMC in the log folder.
-	 * @return string the filename of the WMC document.
-	function saveAsFile() {
-		$filename = "wmc_" . date("Y_m_d_H_i_s") . ".log";
-		$logfile = "../../log/" . $filename;
-		if($h = fopen($logfile,"a")){
-			$content = $this->xml;
-			if(!fwrite($h,$content)){
-				$e = new mb_exception("class_wmc.php: failed to write wmc.");
-				return false;
-			fclose($h);
-		return $filename;
 	 * @return string the title of the WMC.
-	function getTitle() {
+	public function getTitle() {
 		return $this->wmc_title;
-	 * @return Integer the number of (unique?) WMS contained in this WMC.
-	function getNumberOfWms () {
-		return $this->wmc_wms_count;
-	 * Creates a WMC object from a JS map object {@see map.js}
+	 * Creates a WMC object from a JS map object {@see map_obj.js}
 	 * @param object $mapObject a map object
 	 * @param integer $user_id the ID of the current user
@@ -229,7 +131,7 @@
 	 * @param object $extensionData data exclusive to Mapbender, which will be
 	 * 								mapped into the extension part of the WMC
-	function createWMCFromObj($mapObject, $user_id, $generalTitle, $extensionData) {
+	public function createWmcFromJs($mapObject, $user_id, $generalTitle, $extensionData) {
 		$extension_namespace = "mapbender";
@@ -288,6 +190,8 @@
 				$extensionData->ov_miny = floatval($arrayBBox[1]);
 				$extensionData->ov_maxx = floatval($arrayBBox[2]);
 				$extensionData->ov_maxy = floatval($arrayBBox[3]);
+				$extensionData->ov_srs = $mapObject[$i]->epsg;
+				$extensionData->ov_framename = $mapObject[$i]->frameName;
@@ -444,9 +348,7 @@
 					$e_general->appendChild($e_contact);
 				if (count($extensionData) > 0) {
-					//$e = new mb_exception("writing wmc...");
 					$e_extensionGeneral = $doc->createElement("Extension");
 					foreach ($extensionData as $keyExtensionData => $valueExtensionData) {
@@ -589,16 +491,18 @@
 							$e_extension = $doc->createElement("Extension");
-							$e_scalehint = $doc->createElement($extension_namespace.":ScaleHint");
-							$e_scalehint->setAttribute("min", $layerMinscale);
-							$e_scalehint->setAttribute("max", $layerMaxscale);
-							$e_extension->appendChild($e_scalehint);
+							$e_minscalehint = $doc->createElement($extension_namespace.":minscale", $layerMinscale);
+							$e_extension->appendChild($e_minscalehint);
-							$e_gui_scalehint = $doc->createElement($extension_namespace.":guiScaleHint");
-							$e_gui_scalehint->setAttribute("min", $guiLayerMinscale);
-							$e_gui_scalehint->setAttribute("max", $guiLayerMaxscale);
-							$e_extension->appendChild($e_gui_scalehint);
+							$e_maxscalehint = $doc->createElement($extension_namespace.":maxscale", $layerMaxscale);
+							$e_extension->appendChild($e_maxscalehint);
+							$e_gui_minscalehint = $doc->createElement($extension_namespace.":gui_minscale", $guiLayerMinscale);
+							$e_extension->appendChild($e_gui_minscalehint);
+							$e_gui_maxscalehint = $doc->createElement($extension_namespace.":gui_maxscale", $guiLayerMaxscale);
+							$e_extension->appendChild($e_gui_maxscalehint);
 							$e_layer_id = $doc->createElement($extension_namespace.":layer_id", $layerId);
 							$e_extension->appendChild($e_layer_id);
@@ -725,12 +629,7 @@
 		$doc->appendChild($e_view_context);
 		$this->xml = $doc->saveXML();
-		// for debugging: saving WMC as file
-		// (comment when no longer needed)
-	#	$filename = $this->saveAsFile();
-	#	if ($filename) {
-	#		$e = new mb_notice("class_wmc: saving WMC as file " . $filename);
+		$filename = $this->saveAsFile();
@@ -747,389 +646,368 @@
 	 * Loads a WMC from an actual WMC XML document.
+	 * Uses WMS class.
 	 * @param string $data the data from the XML file
 	function createObjFromWMC_xml($data){
-	#	$data = str_replace("&#38;", "&amp;", $data);
 		// store xml
 		$this->xml = $data;
-		$filename = $this->saveAsFile();
-		if ($filename) {
-			$e = new mb_notice("class_wmc: saving WMC as file " . $filename);
+#		$filename = $this->saveAsFile();
+#		if ($filename) {
+#			$e = new mb_notice("class_wmc: saving WMC as file " . $filename);
-		$values = NULL;
-		$tags = NULL;
-		$parser = xml_parser_create(CHARSET);
-		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
-		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
-		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
-		xml_parse_into_struct($parser,$data,$values,$tags);
-		$code = xml_get_error_code ($parser);
-		if ($code) {
-			$line = xml_get_current_line_number($parser);
-			$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
-			return false;
-		xml_parser_free($parser);
-		$section = NULL;
-		$format = NULL;
-		$cnt_format = 0;
-		$parent = array();
-		$myParent = array();
-		$cnt_layer = -1;
-		$request = NULL;
-		$layer_style = array();
-		$extension = false;
-		$general = false;
-		$layerlist = false;
-		$layer = false;
-		$formatlist = false;
-		$dataurl = false;
-		$metadataurl = false;
-		$stylelist = false;
-		$cnt_style = -1;
+		$values = administration::parseXml($data);
+		// Local variables that indicate which section of the WMC
+		// is currently parsed.
+		$extension = false;		$general = false;		$layerlist = false;
+		$layer = false;  		$formatlist = false;	$dataurl = false;
+		$metadataurl = false; 	$stylelist = false;
+		// reset WMC data
+		$this->mainMap = new Map();
+		$this->overviewMap = null;
+		$this->wmsArray = array();
+		$this->generalExtensionArray = array();
 		foreach ($values as $element) {
-						$verbose .= ".";
-			if(strtoupper($element[tag]) == "VIEWCONTEXT" && $element[type] == "open"){
-					$this->wmc_id = $element[attributes]["id"];
-					$this->wmc_version = $element[attributes]["version"];
+			$tag = strtoupper(administration::sepNameSpace($element[tag]));
+			$tagLowerCase = administration::sepNameSpace($element[tag]);
+			$type = $element[type];
+			$attributes = $element[attributes];
+			$value = mb_utf8_decode(html_entity_decode($element[value])); // TODO: not sure if utf decoding is necessary
+			if ($tag == "VIEWCONTEXT" && $type == "open") {
+				$this->wmc_id = $attributes["id"];
+				$this->wmc_version = $attributes["version"];
-			if(strtoupper($element[tag]) == "GENERAL" && $element[type] == "open"){
-			   $general = true;
+			if ($tag == "GENERAL" && $type == "open") {
+				$general = true;
-			if(strtoupper($element[tag]) == "LAYERLIST" && $element[type] == "open"){
-			   $layerlist = true;
+			if ($tag == "LAYERLIST" && $type == "open") {
+				$layerlist = true;
 			if ($general) {
-				if(strtoupper($element[tag]) == "WINDOW"){
-						$this->wmc_windowWidth = $element[attributes]["width"];
-						$this->wmc_windowHeight = $element[attributes]["height"];
+				if ($tag == "WINDOW") {
+					$this->mainMap->setWidth($attributes["width"]);
+					$this->mainMap->setHeight($attributes["height"]);
-				if(strtoupper($element[tag]) == "BOUNDINGBOX"){
-						$this->wmc_bBox_SRS = $element[attributes]["SRS"];
-						$this->wmc_bBox_minx = $element[attributes]["minx"];
-						$this->wmc_bBox_miny = $element[attributes]["miny"];
-						$this->wmc_bBox_maxx = $element[attributes]["maxx"];
-						$this->wmc_bBox_maxy = $element[attributes]["maxy"];
+				if ($tag == "BOUNDINGBOX") {
+					$bbox = new Mapbender_bbox($attributes["minx"], $attributes["miny"], $attributes["maxx"], $attributes["maxy"], $attributes["SRS"]);
+					$this->mainMap->setExtent($bbox);
-				if(strtoupper($element[tag]) == "NAME"){
-						$this->wmc_name = mb_utf8_decode(html_entity_decode($element[value]));
+				if ($tag == "NAME") {
+					$this->wmc_name = $value;
-				if(strtoupper($element[tag]) == "TITLE"){
-						$this->wmc_title = mb_utf8_decode(html_entity_decode($element[value]));
+				if ($tag == "TITLE") {
+					$this->wmc_title = $value;
-				if(strtoupper($element[tag]) == "ABSTRACT"){
-						$this->wmc_abstract = mb_utf8_decode(html_entity_decode($element[value]));
+				if ($tag == "ABSTRACT") {
+					$this->wmc_abstract = $value;
-				if(strtoupper($element[tag]) == "CONTACTINFORMATION" && $element['type'] == "open"){
-						$contactinformation = true;
+				if ($tag == "CONTACTINFORMATION" && $type == "open") {
+					$contactinformation = true;
 				if ($contactinformation) {
-					if(strtoupper($element[tag]) == "CONTACTPOSITION"){
-							$this->wmc_contactposition = mb_utf8_decode(html_entity_decode($element[value]));
+					if ($tag == "CONTACTPOSITION") {
+						$this->wmc_contactposition = $value;
-					if(strtoupper($element[tag]) == "CONTACTVOICETELEPHONE"){
-							$this->wmc_contactvoicetelephone = $element[value];
+					if ($tag == "CONTACTVOICETELEPHONE") {
+						$this->wmc_contactvoicetelephone = $value;
-					if(strtoupper($element[tag]) == "CONTACTFACSIMILETELEPHONE"){
-							$this->wmc_contactfacsimiletelephone = $element[value];
+					if ($tag == "CONTACTFACSIMILETELEPHONE") {
+						$this->wmc_contactfacsimiletelephone = $value;
-					if(strtoupper($element[tag]) == "CONTACTELECTRONICMAILADDRESS"){
-							$this->wmc_contactemail = mb_utf8_decode(html_entity_decode($element[value]));
+					if ($tag == "CONTACTELECTRONICMAILADDRESS") {
+						$this->wmc_contactemail = $value;
-					if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "open"){
-							$contactpersonprimary = true;
+					if ($tag == "CONTACTPERSONPRIMARY" && $type == "open") {
+						$contactpersonprimary = true;
 					if ($contactpersonprimary) {
-						if(strtoupper($element[tag]) == "CONTACTPERSON"){
-								$this->wmc_contactperson = mb_utf8_decode(html_entity_decode($element[value]));
+						if ($tag == "CONTACTPERSON") {
+							$this->wmc_contactperson = $value;
-						if(strtoupper($element[tag]) == "CONTACTORGANIZATION"){
-								$this->wmc_contactorganization = mb_utf8_decode(html_entity_decode($element[value]));
+						if ($tag == "CONTACTORGANIZATION") {
+							$this->wmc_contactorganization = $value;;
-						if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "close"){
-								$contactpersonprimary = false;
+						if ($tag == "CONTACTPERSONPRIMARY" && $type == "close") {
+							$contactpersonprimary = false;
-					if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "open"){
-							$contactaddress = true;
+					if ($tag == "CONTACTADDRESS" && $type == "open") {
+						$contactaddress = true;
 					if ($contactaddress) {
-						if(strtoupper($element[tag]) == "ADDRESSTYPE"){
-								$this->wmc_contactaddresstype = mb_utf8_decode(html_entity_decode($element[value]));
+						if ($tag == "ADDRESSTYPE") {
+							$this->wmc_contactaddresstype = $value;
-						if(strtoupper($element[tag]) == "ADDRESS"){
-								$this->wmc_contactaddress = mb_utf8_decode(html_entity_decode($element[value]));
+						if ($tag == "ADDRESS") {
+							$this->wmc_contactaddress = $value;
-						if(strtoupper($element[tag]) == "CITY"){
-								$this->wmc_contactcity = mb_utf8_decode(html_entity_decode($element[value]));
+						if ($tag == "CITY") {
+							$this->wmc_contactcity = $value;
-						if(strtoupper($element[tag]) == "STATEORPROVINCE"){
-								$this->wmc_contactstateorprovince = mb_utf8_decode(html_entity_decode($element[value]));
+						if ($tag == "STATEORPROVINCE") {
+							$this->wmc_contactstateorprovince = $value;
-						if(strtoupper($element[tag]) == "POSTCODE"){
-								$this->wmc_contactpostcode = $element[value];
+						if ($tag == "POSTCODE"){
+							$this->wmc_contactpostcode = $value;
-						if(strtoupper($element[tag]) == "COUNTRY"){
-								$this->wmc_contactcountry = mb_utf8_decode(html_entity_decode($element[value]));
+						if ($tag == "COUNTRY") {
+							$this->wmc_contactcountry = $value;
-						if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "close"){
-								$contactaddress = false;
+						if ($tag == "CONTACTADDRESS" && $type == "close") {
+							$contactaddress = false;
-				if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "open"){
+				if ($tag == "LOGOURL" && $type == "open") {
 						$logourl = true;
-						$this->wmc_logourl_width = $element[attributes]["width"];
-						$this->wmc_logourl_height = $element[attributes]["height"];
-						$this->wmc_logourl_format = $element[attributes]["format"];
+						$this->wmc_logourl_width = $attributes["width"];
+						$this->wmc_logourl_height = $attributes["height"];
+						$this->wmc_logourl_format = $attributes["format"];
 				if ($logourl) {
-					if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "close"){
-							$logourl = false;
+					if ($tag == "LOGOURL" && $type == "close") {
+						$logourl = false;
-					if(strtoupper($element[tag]) == "ONLINERESOURCE"){
-						$this->wmc_logourl_type = $element[attributes]["xlink:type"];
-						$this->wmc_logourl = $element[attributes]["xlink:href"];
+					if ($tag == "ONLINERESOURCE") {
+						$this->wmc_logourl_type = $attributes["xlink:type"];
+						$this->wmc_logourl = $attributes["xlink:href"];
-				if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "open"){
+				if ($tag == "DESCRIPTIONURL" && $type == "open") {
 						$descriptionurl = true;
-						$this->wmc_descriptionurl_format = $element[attributes]["format"];
+						$this->wmc_descriptionurl_format = $attributes["format"];
 				if ($descriptionurl) {
-					if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "close"){
-							$descriptionurl = false;
+					if ($tag == "DESCRIPTIONURL" && $type == "close"){
+						$descriptionurl = false;
-						$this->wmc_descriptionurl_type = $element[attributes]["xlink:type"];
-						$this->wmc_descriptionurl = $element[attributes]["xlink:href"];
+						$this->wmc_descriptionurl_type = $attributes["xlink:type"];
+						$this->wmc_descriptionurl = $attributes["xlink:href"];
-				if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "open"){
-						$keywordlist = true;
+				if ($tag == "KEYWORDLIST" && $type == "open") {
+					$keywordlist = true;
 				if ($keywordlist) {
-					if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "close"){
-							$keywordlist = false;
-							$cnt_keyword = -1;
+					if ($tag == "KEYWORDLIST" && $type == "close") {
+						$keywordlist = false;
+						$cnt_keyword = -1;
-					if(strtoupper($element[tag]) == "KEYWORD"){
+					if ($tag == "KEYWORD") {
 						$cnt_keyword++;
-						$this->wmc_keyword[$cnt_keyword] = mb_utf8_decode(html_entity_decode($element[value]));
+						$this->wmc_keyword[$cnt_keyword] = $value;
-				if(strtoupper($element[tag]) == "EXTENSION" && $element['type'] == "close"){
+				if ($tag == "EXTENSION" && $type == "close") {
 					$generalExtension = false;
+					// After the general extension tag is closed,
+					// we have all necessary information to CREATE
+					// the map objects that are contained in this
+					// WMC.
+					$this->setMapData();
 				if ($generalExtension) {
-					$this->wmc_general_extension[sepNameSpace($element[tag])] = $element[value];
-//					$e = new mb_exception("WMC: " . $element[tag] . ": " . $element[value]);
+					$this->generalExtensionArray[$tag] = $value;
-				if(strtoupper($element[tag]) == "EXTENSION" && $element['type'] == "open"){
+				if ($tag == "EXTENSION" && $type == "open") {
 					$generalExtension = true;
-				if(strtoupper($element[tag]) == "GENERAL" && $element['type'] == "close"){
+				if ($tag == "GENERAL" && $type == "close") {
 		   			$general = false;
-		if ($layerlist) {
-				if(strtoupper($element[tag]) == "LAYERLIST" && $element['type'] == "close"){
+			if ($layerlist) {
+				if ($tag == "LAYERLIST" && $type == "close") {
 				   $layerlist = false;
-				if(strtoupper($element[tag]) == "LAYER" && $element[type] == "open"){
-					 $cnt_layer++;
-					 $this->wmc_layer_queryable[$cnt_layer] = $element[attributes]["queryable"];
-					 $this->wmc_layer_hidden[$cnt_layer] = $element[attributes]["hidden"];
-					 $layer = true;
-      		 		 $cnt_epsg = 0;
+				if ($tag == "LAYER" && $type == "open") {
+					// The associative array currentLayer holds all
+					// data of the currently processed layer.
+					// The data will be set in the classes' WMS
+					// object when the layer tag is closed.
+					$currentLayer = array();
+					$currentLayer["queryable"] = $attributes["queryable"];
+					if ($attributes["hidden"] == "1") {
+						$currentLayer["visible"] = 0;
+					else {
+						$currentLayer["visible"] = 1;
+					$currentLayer["format"] = array();
+					$currentLayer["style"] = array();
+					$layer = true;
 				if ($layer) {
-					 if(strtoupper($element[tag]) == "LAYER" && $element[type] == "close"){
-					 		$layer = false;
-					 if ($formatlist) {
-						 if(strtoupper($element[tag]) == "FORMAT"){
-						 	$cnt_format++;
-						 	$this->wmc_layer_format_current[$cnt_layer][$cnt_format] = $element[attributes]["current"];
-						 	$this->wmc_layer_format[$cnt_layer][$cnt_format] = $element[value];
+					if ($tag == "LAYER" && $type == "close") {
+						// After a layer tag is closed,
+						// a layer object and append it to the WMS object
+						$this->setLayerData($currentLayer);
+				 		$layer = false;
+					if ($formatlist) {
+						if ($tag == "FORMAT") {
+						 	array_push($currentLayer["format"], array("current" => $attributes["current"], "name" => $value));
+							if ($attributes["current"] == "1") {
+								$currentLayer["formatIndex"] = count($currentLayer["format"]) - 1;
-						 if(strtoupper($element[tag]) == "FORMATLIST" && $element[type] == "close"){
+						 if ($tag == "FORMATLIST" && $type == "close") {
 					 elseif ($metadataurl) {
-						 	$this->wmc_layer_metadataurl[$cnt_layer] = $element[attributes]["xlink:href"];
-						 if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "close"){
+							$currentLayer["metadataurl"] = $attributes["xlink:href"];
+						if ($tag == "METADATAURL" && $type == "close") {
 					 elseif ($dataurl) {
-						 	$this->wmc_layer_dataurl[$cnt_layer] = $element[attributes]["xlink:href"];
+						 	$currentLayer["dataurl"] = $attributes["xlink:href"];
+						 if ($tag == "DATAURL" && $type == "close") {
+							$dataurl = false;
-						 if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "close"){
-							 $dataurl = false;
 					 elseif ($stylelist) {
-						 if(strtoupper($element[tag]) == "STYLE" && $element[type] == "open"){
-						 	$cnt_style++;
+						 if ($tag == "STYLE" && $type == "open") {
 						 	$style = true;
-						 	$this->wmc_layer_style_current[$cnt_layer][$cnt_style] = $element[attributes]["current"];
+						 	array_push($currentLayer["style"], array("current" => $attributes["current"]));
+								$currentLayer["styleIndex"] = count($currentLayer) - 1;
 						 if ($style) {
-							 if(strtoupper($element[tag]) == "STYLE" && $element[type] == "close"){
-							 	$style = false;
-							 if(strtoupper($element[tag]) == "SLD" && $element[type] == "open"){
-							 	$sld = true;
-							 if ($sld) {
-								 if(strtoupper($element[tag]) == "SLD" && $element[type] == "close"){
-								 	$sld = false;
-								 	$this->wmc_layer_style_sld_type[$cnt_layer][$cnt_style] = $element[attributes]["xlink:type"];
-								 	$this->wmc_layer_style_sld_url[$cnt_layer][$cnt_style] = $element[attributes]["xlink:href"];
-								 	$this->wmc_layer_style_sld_title[$cnt_layer][$cnt_style] = mb_utf8_decode(html_entity_decode($element[value]));
-							 else {
-								 	$this->wmc_layer_style_name[$cnt_layer][$cnt_style] = mb_utf8_decode(html_entity_decode($element[value]));
-								 	$this->wmc_layer_style_title[$cnt_layer][$cnt_style] = $element[value];
-								 if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "open"){
+							$index = count($currentLayer["style"]) - 1;
+							if ($tag == "STYLE" && $type == "close") {
+								$style = false;
+							if ($tag == "SLD" && $type == "open") {
+								$sld = true;
+							if ($sld) {
+								if ($tag == "SLD" && $type == "close") {
+									$sld = false;
+									$currentLayer["style"][$index]["sld_type"] = $attributes["xlink:type"];
+									$currentLayer["style"][$index]["sld_url"] = $attributes["xlink:href"];
+									$currentLayer["style"][$index]["sld_title"] = $value;
+							else {
+								if ($tag == "NAME"){
+									$currentLayer["style"][$index]["name"] = $value;
+									$currentLayer["style"][$index]["title"] = $value;
+								if ($tag == "LEGENDURL" && $type == "open") {
 								 	$legendurl = true;
-								 	$this->wmc_layer_style_legendurl_width[$cnt_layer][$cnt_style] = $element[attributes]["width"];
-								 	$this->wmc_layer_style_legendurl_height[$cnt_layer][$cnt_style] = $element[attributes]["height"];
-								 	$this->wmc_layer_style_legendurl_format[$cnt_layer][$cnt_style] = $element[attributes]["format"];
-								 if ($legendurl) {
-									 if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "close"){
-									 	$legendurl = false;
-									 	$this->wmc_layer_style_legendurl_type[$cnt_layer][$cnt_style] = $element[attributes]["xlink:type"];
-									 	$this->wmc_layer_style_legendurl[$cnt_layer][$cnt_style] = $element[attributes]["xlink:href"];
-						 if(strtoupper($element[tag]) == "STYLELIST" && $element[type] == "close"){
-					 else {
-						 if(strtoupper($element[tag]) == "SERVER" && $element[type] == "open"){
-						 	 $server = true;
-						 	 $this->wmc_wms_service[$cnt_layer] = $element[attributes]["service"];
-						 	 $this->wmc_wms_version[$cnt_layer] = $element[attributes]["version"];
-						 	 $this->wmc_wms_title[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[attributes]["title"]));
-						 if ($server) {
-							 if(strtoupper($element[tag]) == "SERVER" && $element[type] == "close"){
-							 	 $server = false;
-						 		 $this->wmc_wms_serviceURL[$cnt_layer] = $element[attributes]["xlink:href"];
-					 		 $this->wmc_layer_name[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[value]));
-					 		 $this->wmc_layer_title[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[value]));
-					 		 $this->wmc_layer_abstract[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[value]));
-						 if(strtoupper($element[tag]) == "SRS"){
-							 $epsgArray = explode(" ", $element[value]);
-					 		 for ($c = 0 ; $c < count($epsgArray) ; $c ++) {
-						 		 $this->wmc_layer_srs[$cnt_layer][$cnt_epsg] = $epsgArray[$c];
-								 $cnt_epsg++;
-						 if (strtoupper($element[tag]) == "EXTENSION" && $element[type] == "open") {
-						 	$extension = true;
-						 if (strtoupper($element[tag]) == "EXTENSION" && $element[type] == "close") {
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "SCALEHINT"){
-					 		 $this->wmc_layer_minscale[$cnt_layer] = $element[attributes]["min"];
-					 		 $this->wmc_layer_maxscale[$cnt_layer] = $element[attributes]["max"];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "GUISCALEHINT"){
-					 		 $this->wmc_gui_layer_minscale[$cnt_layer] = $element[attributes]["min"];
-					 		 $this->wmc_gui_layer_maxscale[$cnt_layer] = $element[attributes]["max"];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_ID"){
-					 		 $this->wmc_layer_id[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WMS_LAYER_ID"){
-					 		 $this->wmc_wms_layer_id[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_POS"){
-					 		 $this->wmc_layer_pos[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_PARENT"){
-					 		 $this->wmc_layer_parent[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "QUERYLAYER"){
-					 		 $this->wmc_layer_querylayer[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WMS_ID"){
-					 		 $this->wmc_wms_id[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WFSFEATURETYPE"){
-					 		 $this->wmc_layer_wfs_featuretype[$cnt_layer] = $element[value];
-						 if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
-							 $metadataurl = true;
-						 if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "open"){
-							 $dataurl = true;
-						 if(strtoupper($element[tag]) == "FORMATLIST" && $element[type] == "open"){
-							 $formatlist = true;
-							 $cnt_format = -1;
-						 if(strtoupper($element[tag]) == "STYLELIST" && $element[type] == "open"){
-							 $stylelist = true;
-							 $cnt_style = -1;
+								 	$currentLayer["style"][$index]["legendurl_width"] = $attributes["width"];
+								 	$currentLayer["style"][$index]["legendurl_height"] = $attributes["height"];
+								 	$currentLayer["style"][$index]["legendurl_format"] = $attributes["format"];
+								if ($legendurl) {
+									if ($tag == "LEGENDURL" && $type == "close") {
+										$legendurl = false;
+									 	$currentLayer["style"][$index]["legendurl_type"] = $attributes["xlink:type"];
+									 	$currentLayer["style"][$index]["legendurl"] = $attributes["xlink:href"];
+						if ($tag == "STYLELIST" && $type == "close") {
+							$stylelist = false;
+					else {
+						if ($tag == "SERVER" && $type == "open") {
+							 $server = true;
+							 $currentLayer["service"] = $attributes["service"];
+							 $currentLayer["version"] = $attributes["version"];
+							 $currentLayer["wms_title"] = $attributes["title"];
+						if ($server) {
+							if ($tag == "SERVER" && $type == "close") {
+						 		$server = false;
+						 		$currentLayer["url"] = $attributes["xlink:href"];
+					 		$currentLayer["name"] = $value;
+					 		$currentLayer["title"] = $value;
+					 		$currentLayer["abstract"] = $value;
+						if ($tag == "SRS") {
+							$currentLayer["epsg"] = explode(" ", $value);
+						if ($extension == true){
+							$currentLayer["extension"][$tag] = $value;
+							$currentLayer["extension"] = array();
+							$extension = true;
+						if ($tag == "METADATAURL" && $type == "open") {
+							$metadataurl = true;
+						if ($tag == "DATAURL" && $type == "open") {
+							$dataurl = true;
+						if ($tag == "FORMATLIST" && $type == "open") {
+							$formatlist = true;
+						if ($tag == "STYLELIST" && $type == "open") {
+							$stylelist = true;
 		return true;
-	  //return $verbose;
-	function load ($wmcId) {
+	public function load ($wmcId) {
 		$this->createObjFromWMC_id($wmcId);
 		// counts how often a layer has been loaded
@@ -1142,70 +1020,26 @@
 		// will contain the JS code to create the maps
 		// representing the state stored in this WMC
-		$wmc_string = "";
+		$wmcJsArray = array();
+		array_push($wmcJsArray, "wms = [];");
 		// general extension
 		if (count($this->wmc_general_extension) > 0) {
 			$json = new Mapbender_JSON();
-			$wmc_string .= "restoredWmcExtensionData = " . $json->encode($this->wmc_general_extension) . ";";
+			array_push($wmcJsArray, "restoredWmcExtensionData = " . $json->encode($this->generalExtensionArray) . ";");
-		$foundWmsArray = array();
-		// for all layers in wmc, find individual wms...
-		for ($i = 0; $i < count($this->wmc_layer_title); $i++) {
-			$currentWms = $this->wmc_wms_serviceURL[$i];
-			// skip this WMS if it has been found before
-			if (in_array($currentWms , $foundWmsArray)) {
-				continue;
-			// mark this WMS as found
-			array_push($foundWmsArray, $currentWms);
+		// for all wms...
+		for ($i = 0; $i < count($this->wmsArray); $i++) {
 			// add wms
-			$wmc_string .= $this->getJsCodeAddWms($i);
-			// add epsg
-			$wmc_string .= $this->createJsCodeAddWmsSrs();
-			$layerlist = "";
-			$querylayerlist = "";
-			$numberOfLayers = 0;
-			// find other layers belonging to this layer
-			for ($ii = $i; $ii < count($this->wmc_layer_title); $ii++) {
-				if ($currentWms != $this->wmc_wms_serviceURL[$ii]) {
-					continue;
-				// add root layer
-				if ($numberOfLayers == 0) {
-					$wmc_string .= $this->getJsCodeAddRootLayer($i);
-				$numberOfLayers++;
-				// add other layers
-				$wmc_string .= $this->getJsCodeAddLayer ($numberOfLayers, $i, $ii);
-				// add layer style
-				$wmc_string .= $this->getJsCodeAddLayerStyle ($numberOfLayers, $ii);
-				// add layer format (FIXME: is this working?)
-				$wmc_string .= $this->getJsCodeAddLayerDataFormat($ii);
+			array_push($wmcJsArray, $this->this->wmsArray[$i]->createJsObjFromWMS_());
-		$wmc_string = "mb_mapObj = null;";
-		$wmc_string = "wms = null;";
-		$wmc_string .= "mb_registerMapObj('mapframe1', 'maps', null, " . $this->wmc_windowWidth . ", " . $this->wmc_windowHeight . ");";
-		$wmc_string .= "mb_calculateExtent('mapframe1', " .
-							$this->wmc_bBox_minx .",".$this->wmc_bBox_miny ."," .
-							$this->wmc_bBox_maxx .",".$this->wmc_bBox_maxy.");";
-		$wmc_string .= "setMapRequest('mapframe1');";
+		array_push($wmcJsArray, "mb_mapObj = [];");
+		$wmcJsArray = array_merge($wmcJsArray, $this->mainMap->createJsObj());
+		$wmcJsArray = array_merge($wmcJsArray, $this->overviewMap->createJsObj());
 		$ov_bbox = array();
 		// box for mapframe
@@ -1232,17 +1066,12 @@
 		array_push($ov_bbox, $unionBox->min->y);
 		array_push($ov_bbox, $unionBox->max->x);
 		array_push($ov_bbox, $unionBox->max->y);
-		$wmc_string .= "mb_registerMapObj('overview', 'maps', 0, " . $this->wmc_windowWidth . ", " . $this->wmc_windowHeight . ");";
-		$wmc_string .= "mb_calculateExtent('overview', " .
-						$ov_bbox[0] .",".$ov_bbox[1] ."," .
-						$ov_bbox[2] .",".$ov_bbox[3] .");";
-		$wmc_string .= "setMapRequest('overview');\n";
-//		$wmc_string .= $target . "mb_execloadWmsSubFunctions();";
-		return $wmc_string;
+		// Finally, request maps
+		array_push($wmcJsArray, "setMapRequest('" . $this->mainMap->getFrameName() . "');");
+		array_push($wmcJsArray, "setMapRequest('" . $this->overviewMap->getFrameName() . "');");
+		return $wmcJsArray;
 	function append ($wmcId) {
@@ -1255,115 +1084,6 @@
 		$this->createJsObjFromWMC("", "", "merge");
-	private function getJsCodeAddWms ($i) {
-		// get the last data format of this WMS
-		for($j=0; $j < count($this->wmc_layer_format[$i]); $j++){
-			if ($this->wmc_layer_format_current[$i][$j] == 1) {
-				$wms_data_format = $this->wmc_layer_format[$i][$j];
-		// add wms
-		$wmc_addWMS_string = "add_wms(" .
-			"'" . $this->wmc_wms_id[$i] . "'," .
-			"'" . $this->wmc_wms_version[$i] ."'," .
-			"'" . $this->wmc_wms_title[$i] ."'," .
-			"'" . $this->wmc_layer_abstract[$i] ."'," .
-			"'" . $this->wmc_wms_serviceURL[$i] ."'," .
-			"'" . $this->wmc_layer_style_legendurl[$i][0] ."'," .
-			$wms_data_format ."'," .
-			"'text/html'," .
-			"'application/vnd.ogc.se_xml'," .
-			"'" . $this->wmc_bBox_SRS . "'," .
-			"'1'," .
-			"'100'," .
-		return $wmc_addWMS_string;
-	private function createJsCodeAddWmsSrs () {
-		return "wms_addSRS(" .
-			"'" . $this->wmc_bBox_minx . "'," .
-			"'" . $this->wmc_bBox_miny . "'," .
-			"'" . $this->wmc_bBox_maxx . "'," .
-			"'" . $this->wmc_bBox_maxy . "');";
-	private function getJsCodeAddLayerDataFormat($ii) {
-		$z = count($this->wmc_layer_format[$ii]);
-		for($j=0; $j < $z; $j++){
-			$wmc_string .= "wms_add_data_type_format(" .
-						"'map'," .
-						"'" . $this->wmc_layer_format[$ii][$j] ."');";
-	private function getJsCodeAddRootLayer ($i) {
-		return "wms_add_layer(" .
-				"'" . $this->wmc_wms_layer_id[$i] . "'," .
-				"'" . $this->wmc_wms_title[$i] . "'," .
-				"'0'," .
-				"'0'," .
-				"'0'," .
-				"'0'," .
-				"'1'," .
-				"'1'," .
-				"'1'," .
-				"'0'," .
-				"'0'," .
-				"'0'," .
-				"'0'," .
-	private function getJsCodeAddLayerStyle ($cnt_layers, $ii) {
-		$str = "";
-		for ($j = 0; $j < count($this->wmc_layer_style_name[$ii]); $j++){
-			$str .= "wms_addLayerStyle(" .
-					"'" . $this->wmc_layer_style_name[$ii][$j] . "'," .
-					"'" . $this->wmc_layer_style_title[$ii][$j] ."'," .
-					"'" . $j."'," .
-					"'" . $cnt_layers."'," .
-					"'" . $this->wmc_layer_style_legendurl[$ii][$j] . "'," .
-					"'" . $this->wmc_layer_style_legendurl_format[$ii][$j] . "');";
-		return $str;
-	private function getJsCodeAddLayer ($cnt_layers, $i, $ii) {
-		return "\twms_add_layer(" .
-			"'" . ($this->wmc_layer_parent[$ii]!=""?$this->wmc_layer_parent[$ii]:"0") . "'," .
-			"'" . $this->wmc_layer_id[$ii] . "'," .
-			"'" . $this->wmc_layer_name[$ii] . "'," .
-			"'" . $this->wmc_layer_title[$ii] ."'," .
-			"'" . $this->wmc_layer_dataurl[$ii] . "'," .
-			"'" . ($this->wmc_layer_pos[$ii]!=""?$this->wmc_layer_pos[$ii]:intval($cnt_layers)) ."'," .
-			"'" . $this->wmc_layer_queryable[$ii] . "'," .
-			"'" . $this->wmc_layer_minscale[$ii] . "'," .
-			"'" . $this->wmc_layer_maxscale[$ii] . "'," .
-			"'" . $this->wmc_layer_metadataurl[$ii] . "'," .
-			"'" . $this->wmc_wms_id[$i] ."'," .
-			"'1'," .
-			"'1'," .
-			"'" . intval(!$this->wmc_layer_hidden[$ii]) ."'," .
-			"'" . ($this->wmc_layer_querylayer[$ii]!=""?$this->wmc_layer_querylayer[$ii]:$this->wmc_layer_queryable[$ii]) ."'," .
-			"'" . ($this->wmc_gui_layer_minscale[$ii]!=""?$this->wmc_gui_layer_minscale[$ii]:$this->wmc_layer_minscale[$ii]) ."'," .
-			"'" . ($this->wmc_gui_layer_maxscale[$ii]!=""?$this->wmc_gui_layer_maxscale[$ii]:$this->wmc_layer_maxscale[$ii]) ."'," .
-			"'" . $this->wmc_layer_wfs_featuretype[$ii] . "'" .
 	 * Creates JS code manipulating the map and wms objects,
 	 * by this displaying the WMC
@@ -1650,6 +1370,213 @@
 		$wmc_string .= $target . "mb_execloadWmsSubFunctions();\n";
 		return $wmc_string;
+// private functions
+	 * Saves the current WMC in the log folder.
+	 * @return string the filename of the WMC document.
+	private function saveAsFile() {
+		if ($this->saveWmcAsFile) {
+			$filename = "wmc_" . date("Y_m_d_H_i_s") . ".log";
+			$logfile = "../../log/" . $filename;
+			if($h = fopen($logfile,"a")){
+				$content = $this->xml;
+				if(!fwrite($h,$content)){
+					$e = new mb_exception("class_wmc.php: failed to write wmc.");
+					return false;
+				fclose($h);
+			$e = new mb_notice("class_wmc: saving WMC as file " . $filename . "; You can turn this behaviour off in class_wmc.php");
+			return $filename;
+		return null;
+	 * Called during WMC parsing; sets the data of a single layer.
+	 * @return
+	 * @param $currentLayer Array an associative array with layer data
+	private function setLayerData ($currentLayer) {
+		// check if current layer belongs to an existing WMS...
+		$wmsIndex = null;
+			if (isset($currentLayer["url"]) &&
+				$currentLayer["url"] == $this->wmsArray[$i]->wms_getmap) {
+				$wmsIndex = $i;
+		// if yes, create a new WMS ...
+		if ($wmsIndex === null) {
+			$wmsIndex = 0;
+			$wms = new wms();
+			// set WMS data
+			$wms->wms_id = $currentLayer["extension"]["WMS_ID"]; // TO DO: how about WMS without ID?
+			$wms->wms_version = $currentLayer["version"];
+			$wms->wms_title = $currentLayer["wms_title"];
+			$wms->wms_abstract = $currentLayer["abstract"];
+			$wms->wms_getmap = $currentLayer["url"];
+			$wms->wms_getfeatureinfo = $currentLayer["url"]; // TODO : Add correct data
+			$styleIndex = $currentLayer["styleIndex"];
+			$wms->wms_getlegendurl = $currentLayer["style"][$styleIndex]["legendurl"];
+			$wms->wms_filter = ""; // TODO : Add correct data
+			$formatIndex = $currentLayer["formatIndex"];
+			$wms->gui_wms_mapformat = $currentLayer["format"][$formatIndex]["name"];
+			$wms->gui_wms_featureinfoformat = "text/html"; // TODO : Add correct data
+			$wms->gui_wms_exceptionformat = "application/vnd.ogc.se_xml"; // TODO : Add correct data
+			$wms->gui_wms_epsg = $this->mainMap->getEpsg();
+			$wms->gui_wms_visible = 1; // TODO : Add correct data
+			$wms->gui_wms_opacity = 100; // TODO : Add correct data
+			$wms->gui_wms_sldurl = $currentLayer["style"][$styleIndex]["sld_url"];
+			// set data formats
+			for ($i = 0; $i < count($currentLayer["format"]); $i++) {
+				array_push($wms->data_type, "map");
+				array_push($wms->data_format, $currentLayer["format"][$i]["name"]);
+			// set wms epsg
+			$layerEpsgIndex = count($newLayer->objLayer[$i]->layer_epsg) - 1;
+			$currentLayerEpsg = $newLayer->objLayer[$i]->layer_epsg[$layerEpsgIndex];
+			$currentLayerEpsg["epsg"] = $this->mainMap->getEpsg();
+			$mainMapExtent = $this->mainMap->getExtent();
+			$currentLayerEpsg["minx"] = $mainMapExtent->min->x;
+			$currentLayerEpsg["miny"] = $mainMapExtent->min->y;
+			$currentLayerEpsg["maxx"] = $mainMapExtent->max->x;
+			$currentLayerEpsg["maxy"] = $mainMapExtent->max->y;
+			array_push($this->wmsArray, $wms);
+			if ($currentLayer["extension"]["ISOVERVIEWLAYER"] == "1") {
+				$this->overviewMap->overviewLayerIndex = count($this->wmsArray) - 1;
+		// add layer to existing WMS ...
+		$currentWms = $this->wmsArray[$wmsIndex];
+		$pos = $currentLayer["extension"]["LAYER_POS"];
+		$parent = $currentLayer["extension"]["LAYER_PARENT"];
+		$currentWms->addLayer($pos, $parent); // TO DO: how about WMC from other sources
+		// set layer data
+		$layerIndex = count($currentWms->objLayer) - 1;
+		$newLayer = $currentWms->objLayer[$layerIndex];
+		$newLayer->layer_uid = $currentLayer["extension"]["LAYER_ID"];
+		$newLayer->layer_name = $currentLayer["name"];
+		$newLayer->layer_title = $currentLayer["title"];
+		$newLayer->layer_dataurl_href = $currentLayer["dataurl"];
+		$newLayer->layer_pos = $currentLayer["extension"]["LAYER_POS"];
+		$newLayer->layer_queryable = $currentLayer["queryable"];
+		$newLayer->layer_minscale = $currentLayer["extension"]["MINSCALE"];
+		$newLayer->layer_maxscale = $currentLayer["extension"]["MAXSCALE"];
+		$newLayer->layer_metadataurl = $currentLayer["metadataurl"];
+		$newLayer->gui_layer_wms_id = $currentLayer["extension"]["WMS_LAYER_ID"];
+		$newLayer->gui_layer_status = 1; // TODO: Add correct data
+		$newLayer->gui_layer_style = ""; // TODO: Add correct data
+		$newLayer->gui_layer_selectable = ""; // TODO: Add correct data
+		$newLayer->gui_layer_visible = $currentLayer["visible"];
+		$newLayer->gui_layer_queryable = ""; // TODO: Add correct data
+		$newLayer->gui_layer_querylayer = ""; // TODO: Add correct data
+		$newLayer->gui_layer_minscale = $currentLayer["extension"]["GUI_MINSCALE"];
+		$newLayer->gui_layer_maxscale = $currentLayer["extension"]["GUI_MAXSCALE"];
+		$newLayer->gui_layer_wfs_featuretype = ""; // TODO: Add correct data
+		$newLayer->layer_abstract = $currentLayer["abstract"];
+		// set layer epsg
+		// set layer style
+			$layerStyleIndex = count($newLayer->gui_layer_style) - 1;
+			$newLayer->layer_style[$layerStyleIndex] = array();
+			$currentStyle = $newLayer->layer_style[$layerStyleIndex];
+			$currentStyle["name"] = $currentLayer["style"][$i]["name"];
+			$currentStyle["title"] = $currentLayer["style"][$i]["title"];
+			$currentStyle["legendurl"] = $currentLayer["style"][$i]["legendurl"];
+			$currentStyle["legendurl_format"] = $currentLayer["style"][$i]["legendurl_type"];
+		return true;
+	 * Called during WMC parsing; sets the maps within a WMC.
+	 * @return
+	private function setMapData () {
+		if ($this->generalExtensionArray["OV_WIDTH"] &&
+			$this->generalExtensionArray["OV_HEIGHT"] &&
+			$this->generalExtensionArray["OV_FRAMENAME"] &&
+			$this->generalExtensionArray["OV_MINX"] &&
+			$this->generalExtensionArray["OV_MINY"] &&
+			$this->generalExtensionArray["OV_MAXX"] &&
+			$this->generalExtensionArray["OV_MAXY"] &&
+			$this->generalExtensionArray["OV_SRS"]) {
+			$this->overviewMap = new Map();
+			$this->overviewMap->setWidth($this->generalExtensionArray["OV_WIDTH"]);
+			$this->overviewMap->setHeight($this->generalExtensionArray["OV_HEIGHT"]);
+			$this->overviewMap->setFrameName($this->generalExtensionArray["OV_FRAMENAME"]);
+			$bbox = new Mapbender_bbox($this->generalExtensionArray["OV_MINX"], $this->generalExtensionArray["OV_MINY"], $this->generalExtensionArray["OV_MAXX"], $this->generalExtensionArray["OV_MAXY"], $this->generalExtensionArray["OV_SRS"]);
+			$this->overviewMap->setExtent($bbox);
+		if ($this->generalExtensionArray["MAIN_FRAMENAME"]) {
+			$this->mainMap->setFrameName($this->generalExtensionArray["MAIN_FRAMENAME"]);
+		else {
+			$this->mainMap->setFrameName("mapframe1");
+		return true;
-// end class
+ * @deprecated
+function mb_utf8_encode ($str) {
+	if(CHARSET=="UTF-8") return utf8_encode($str);
+	return $str;
+ * @deprecated
+function mb_utf8_decode ($str) {
+	if(CHARSET=="UTF-8") return utf8_decode($str);
+	return $str;
\ No newline at end of file
Modified: branches/beck_dev/mapbender/http/classes/class_wms.php
--- branches/beck_dev/mapbender/http/classes/class_wms.php	2008-05-15 09:02:56 UTC (rev 2452)
+++ branches/beck_dev/mapbender/http/classes/class_wms.php	2008-05-15 09:06:04 UTC (rev 2453)
@@ -681,13 +681,17 @@
 	  function stripEndlineAndCarriageReturn($string) {
 	  	return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
-	  function createJsObjFromWMS($parent=0){
+		function createJsObjFromWMS($parent=0){
+			echo $this->createJsObjFromWMS_();
+	  function createJsObjFromWMS_($parent=0){
+	  	$str = "";
 	  	if(!$this->wms_title || $this->wms_title == ""){
-			echo "alert('Error: no valid capabilities-document !!');";
+			$str .= "alert('Error: no valid capabilities-document !!');";
 			die; exit;
 			if($parent){
-				echo "parent.";
+				$str .=  "parent.";
 			// wms_title and abstract have previously been urlencoded
 			// this solution may not yet be the ultimate one
@@ -709,19 +713,19 @@
 					"'" . $this->gui_wms_opacity ."'," .
 					"'" . $this->gui_wms_sldurl ."" .
-			echo $add_wms_string;
+			$str .=  $add_wms_string;
 		for($i=0;$i<count($this->data_format);$i++){
 			if($parent){
-				echo "parent.";
-			echo "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');\n";
+			$str .= "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');\n";
 		for($i=0; $i<count($this->objLayer); $i++){
 			if($parent){
-				echo "parent.";
-			print ("wms_add_layer('".
+			$str .=  "wms_add_layer('".
 				$this->objLayer[$i]->layer_parent ."','".
 				$this->objLayer[$i]->layer_uid ."','".
 				addslashes($this->objLayer[$i]->layer_name) . "','".
@@ -741,37 +745,43 @@
 				$this->objLayer[$i]->gui_layer_querylayer ."','".
 				$this->objLayer[$i]->gui_layer_minscale ."','".
 				$this->objLayer[$i]->gui_layer_maxscale ."','".
-				$this->objLayer[$i]->gui_layer_wfs_featuretype ."');\n");
+				$this->objLayer[$i]->gui_layer_wfs_featuretype ."');\n";
 			for($j=0; $j<count($this->objLayer[$i]->layer_epsg);$j++){
 				if($i==0){
 					if($parent){
-					echo "parent.";
-					print("wms_addSRS('".
+					$str .= "wms_addSRS('".
 						$this->objLayer[$i]->layer_epsg[$j]["epsg"] ."','".
 						$this->objLayer[$i]->layer_epsg[$j]["minx"] ."','".
 						$this->objLayer[$i]->layer_epsg[$j]["miny"] ."','".
 						$this->objLayer[$i]->layer_epsg[$j]["maxx"] ."','".
-						$this->objLayer[$i]->layer_epsg[$j]["maxy"] ."');\n");
+						$this->objLayer[$i]->layer_epsg[$j]["maxy"] ."');\n";
 				if($parent){
-				echo "parent.";
-				print("layer_addEpsg('".
+				$str .= "layer_addEpsg('".
 			for($j=0; $j<count($this->objLayer[$i]->layer_style);$j++){
 				if($parent){
-				echo "parent.";
-				print("wms_addLayerStyle('".$this->objLayer[$i]->layer_style[$j]["name"]."', '".$this->objLayer[$i]->layer_style[$j]["title"]."', ".$j.",".$i.",'".$this->objLayer[$i]->layer_style[$j]["legendurl"]."', '".$this->objLayer[$i]->layer_style[$j]["legendformat"]."');\n");
+				$str .= "wms_addLayerStyle('".$this->objLayer[$i]->layer_style[$j]["name"].
+					"', '".$this->objLayer[$i]->layer_style[$j]["title"].
+					"', ".$j.
+					",".$i.
+					",'".$this->objLayer[$i]->layer_style[$j]["legendurl"].
+					"', '".$this->objLayer[$i]->layer_style[$j]["legendformat"]."');\n";
+		return $str;
 	  function createJsLayerObjFromWMS($parent=0, $layer_name){
Modified: branches/beck_dev/mapbender/http/javascripts/mod_loadwmc.js
--- branches/beck_dev/mapbender/http/javascripts/mod_loadwmc.js	2008-05-15 09:02:56 UTC (rev 2452)
+++ branches/beck_dev/mapbender/http/javascripts/mod_loadwmc.js	2008-05-15 09:06:04 UTC (rev 2453)
@@ -92,8 +92,11 @@
 					if (json && status == "success") {
 						var resultObj = eval("(" + json + ")");
 						try {
-							if (resultObj.javascript) {
-								eval(resultObj.javascript);
+							if (resultObj.javascript && typeof(resultObj.javascript) == "object") {
+								for (var j=0; j < resultObj.javascript.length; j++) {
+									console.log("%s", resultObj.javascript[j]);
+									eval(resultObj.javascript[j]);
 						catch (e) {
@@ -102,7 +105,7 @@
 					if (loadWmcError) {
-						alert("An error has occured while deleting this WMC.");
+						alert("An error has occured while loading this WMC.");
Modified: branches/beck_dev/mapbender/http/php/mod_insertWmcIntoDb.php
--- branches/beck_dev/mapbender/http/php/mod_insertWmcIntoDb.php	2008-05-15 09:02:56 UTC (rev 2452)
+++ branches/beck_dev/mapbender/http/php/mod_insertWmcIntoDb.php	2008-05-15 09:06:04 UTC (rev 2453)
@@ -31,7 +31,7 @@
 $extensionData = $json->decode(stripslashes($_POST["extensionData"]));
 $wmc = new wmc();
-$wmc->createWMCFromObj($mapObject, $user_id, $generalTitle, $extensionData);
+$wmc->createWmcFromJs($mapObject, $user_id, $generalTitle, $extensionData);
 if ($save_in_session) {
 	$_SESSION["mb_wmc"] = $wmc->xml;
More information about the Mapbender_commits mailing list
