[Mapbender-commits] r2460 - branches/2.5/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 16 06:00:51 EDT 2008
Author: christoph
Date: 2008-05-16 06:00:51 -0400 (Fri, 16 May 2008)
New Revision: 2460
   branches/2.5/http/classes/class_gml2.php
added dirname
Modified: branches/2.5/http/classes/class_gml2.php
--- branches/2.5/http/classes/class_gml2.php	2008-05-16 08:56:23 UTC (rev 2459)
+++ branches/2.5/http/classes/class_gml2.php	2008-05-16 10:00:51 UTC (rev 2460)
@@ -16,10 +16,10 @@
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once("class_mb_exception.php");
-require_once("class_connector.php");
-require_once("../classes/class_json.php");
-require_once("../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."../classes/class_mb_exception.php");
+require_once(dirname(__FILE__)."../classes/class_connector.php");
+require_once(dirname(__FILE__)."../classes/class_json.php");
+require_once(dirname(__FILE__)."../../conf/mapbender.conf");
 class gml2 {
 	var $geomtype_point = 'Point';
 	var $geomtype_polygon = 'Polygon';
More information about the Mapbender_commits mailing list
