[Mapbender-commits] r2463 - branches/2.5/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon May 19 03:17:28 EDT 2008
Author: astrid_emde
Date: 2008-05-19 03:17:26 -0400 (Mon, 19 May 2008)
New Revision: 2463
   branches/2.5/http/javascripts/mod_wfs_client.html
added some user messages (please select a WFS), changed the order of the options a bit
Modified: branches/2.5/http/javascripts/mod_wfs_client.html
--- branches/2.5/http/javascripts/mod_wfs_client.html	2008-05-19 07:08:14 UTC (rev 2462)
+++ branches/2.5/http/javascripts/mod_wfs_client.html	2008-05-19 07:17:26 UTC (rev 2463)
@@ -7,7 +7,7 @@
 <script type='text/javascript'>
  * services['action']: instructs the servercomponent
  * services['services']: infos about the services (wfs)
  * services['services']['id']: a list of ids
@@ -17,7 +17,7 @@
 var services = {};
  * wfsConf['action']: instructs the servercomponent
- * wfsConf['wfs']: the ID of the selected wfs
+ * wfsConf['wfs']: the ID of the selected wfs
  * wfsConf['wfsConf']: infos about the wfs configurations
  * wfsConf['wfsConf']['id']: a list of ids
  * wfsConf['wfsConf']['abstract']: a corresponding list of descriptions
@@ -33,31 +33,31 @@
  * handleAssignment['action']: instructs the servercomponent
- * handleAssignment['selectedConf']: a list of wfs-conf Ids
+ * handleAssignment['selectedConf']: a list of wfs-conf Ids
  * handleAssignment['selectedGui']: the selected Gui
-var handleAssignment = {}
- * vupdateWfs['action']: instructs the servercomponent
- * vupdateWfs['wfs']: id of wfs to update
- * vupdateWfs['url']: capabilities url
-var vupdateWfs = {};
- * deleteWfs_['action']: instructs the servercomponent
- * deleteWfs_['wfs']: id of wfs to update
-var deleteWfs_ = {};
- * geturl['action']: instructs the servercomponent
- * geturl['wfs']: id of wfs to get the url for
- * geturl['column']: column of the url to get in table wfs
-var geturl = {}
+var handleAssignment = {}
+ * vupdateWfs['action']: instructs the servercomponent
+ * vupdateWfs['wfs']: id of wfs to update
+ * vupdateWfs['url']: capabilities url
+var vupdateWfs = {};
+ * deleteWfs_['action']: instructs the servercomponent
+ * deleteWfs_['wfs']: id of wfs to update
+var deleteWfs_ = {};
+ * geturl['action']: instructs the servercomponent
+ * geturl['wfs']: id of wfs to get the url for
+ * geturl['column']: column of the url to get in table wfs
+var geturl = {}
 var owsproxy = {}
@@ -80,41 +80,41 @@
 	var w = document.wfsForm.wfsList;
 	var ind  = w.selectedIndex;
 	if(ind == -1){
-		return false;
-	if(ind == w.options.length-1)
+		return false;
+	if(ind == w.options.length-1)
 		return "gui_confs";
-	return w.options[ind].value;
+	return w.options[ind].value;
 function getGuiConfs(){
 	guis['action'] = 'getAssignedConfs';
 	var g = document.wfsForm.guiList;
 	var ind  = g.selectedIndex;
 	if(ind == -1){
-		return false;
+		return false;
 	guis['selectedGui'] = g.options[ind].value;
-	guis['selectedWfs'] = wfsConf['wfs'];
+	guis['selectedWfs'] = wfsConf['wfs'];
 	getData(guis);
- * Sends an request to get the url to the capabilities doc of selected wfs
-function getUpdateUrl(column){
-	geturl['action'] = 'getUpdateUrl';
-	var w = document.wfsForm.wfsList;
-	var ind  = w.selectedIndex;
-	if(ind == -1){
-		alert("please select an WFS");
-		return;
-	geturl['wfs'] = w.options[ind].value;
-	geturl['column'] = column;
-	getData(geturl);
+ * Sends an request to get the url to the capabilities doc of selected wfs
+function getUpdateUrl(column){
+	geturl['action'] = 'getUpdateUrl';
+	var w = document.wfsForm.wfsList;
+	var ind  = w.selectedIndex;
+	if(ind == -1){
+		alert("please select an WFS");
+		return;
+	geturl['wfs'] = w.options[ind].value;
+	geturl['column'] = column;
+	getData(geturl);
 function addConfsToGui(){
 	handleAssignment['action'] = 'add';
 	handleAssignment['confs'] = getSelectedConfs();
@@ -126,43 +126,48 @@
 	handleAssignment['confs'] = getSelectedAssignedConfs();
 	handleAssignment['gui'] = getSelectedGui();
 	getData(handleAssignment);
- * Sends an update request to update the capabilities of selected wfs
- * @return success
- * @type boolean
-function updateWfs(){
-	vupdateWfs['action'] = 'updateWfs';
-	if(ind == -1){
-		return false;
-	vupdateWfs['wfs'] = w.options[ind].value;
-	vupdateWfs['url'] = document.getElementById("updateUrl").value;
-	getData(vupdateWfs);
-	return true;
-function deleteWfs(){
-	deleteWfs_['action'] = 'deleteWfs';
-	deleteWfs_['wfs'] = getSelectedWfs();
-	if(deleteWfs_['wfs']&&deleteWfs_['wfs']!="gui_confs"){
-		if(confirm("Do you really want to delete the Wfs with Wfs-id:"+deleteWfs_['wfs']+"?")){
-			getData(deleteWfs_);
-		return true;
-	return false;
+ * Sends an update request to update the capabilities of selected wfs
+ * @return success
+ * @type boolean
+function updateWfs(){
+	vupdateWfs['action'] = 'updateWfs';
+	if(ind == -1){
+		return false;
+	vupdateWfs['wfs'] = w.options[ind].value;
+	if(document.getElementById("updateUrl").value == ''){
+		alert("Please choose the link to the new WFS Capabilities URL.");
+		return false;
+	vupdateWfs['url'] = document.getElementById("updateUrl").value;
+	getData(vupdateWfs);
+	return true;
+function deleteWfs(){
+	deleteWfs_['action'] = 'deleteWfs';
+	deleteWfs_['wfs'] = getSelectedWfs();
+	if(deleteWfs_['wfs']&&deleteWfs_['wfs']!="gui_confs"){
+		if(confirm("Do you really want to delete the Wfs with Wfs-id:"+deleteWfs_['wfs']+"?")){
+			getData(deleteWfs_);
+		return true;
+	return false;
 function setIndicator(){
 	var str = "<img src='../img/indicator_wheel.gif'>";
-	document.getElementById("indicator").innerHTML = str;
+	document.getElementById("indicator").innerHTML = str;
 function removeIndicator(){
 	document.getElementById("indicator").innerHTML = "";
@@ -202,38 +207,38 @@
 				break;
 				case "getWfsConfData":
 					getOwsproxy();
-					appendWfsConfData(dsJson);
+					appendWfsConfData(dsJson);
 				break;
 				case "getGuis":
 					appendGuis(dsJson);
 				break;
 				case "getAssignedConfs":
-					appendGuiConfs(dsJson);
-				break;
-				case "getUpdateUrl":
+					appendGuiConfs(dsJson);
+				break;
+				case "getUpdateUrl":
 					setUpdateUrl(dsJson)
 				break;
 				case "add":
 					getGuiConfs();
 				break;
 				case "remove":
-					getGuiConfs();
-				break;
-				case "updateWfs":
-					if(dsJson['success'])
-						alert("Update performed.");
-					else
+					getGuiConfs();
+				break;
+				case "updateWfs":
+					if(dsJson['success'])
+						alert("Update performed.");
+					else
 						alert("An error occured, see log for details.");
-				break;
-				case "deleteWfs":
-					if(dsJson['success']){
-						clearList(document.forms[0].wfsList);
-						clearList(document.forms[0].guiList);
-						getWfsList();
-						getGuis();
-						alert("WFS deleted.");
 				break;
+				case "deleteWfs":
+					if(dsJson['success']){
+						clearList(document.forms[0].wfsList);
+						clearList(document.forms[0].guiList);
+						getWfsList();
+						getGuis();
+						alert("WFS deleted.");
+				break;
 				case "setOwsproxy":
 					displayOwsproxy(dsJson);
 				break;
@@ -247,23 +252,23 @@
 					alert("No action specified.....");
 				break;
 		else{
 			alert("An error occured!");
 		removeIndicator();
- * Sets the update url comming from db in the html form
-function setUpdateUrl(dsJson){
-	document.getElementById("updateUrl").value = dsJson['url'];
+ * Sets the update url comming from db in the html form
+function setUpdateUrl(dsJson){
+	document.getElementById("updateUrl").value = dsJson['url'];
@@ -274,23 +279,23 @@
 	else{
 		document.wfsForm.owsproxy.checked = true;
 function appendServices(dsJson){
 	services['services'] = dsJson.services;
-	var o = services['services'];
+	var o = services['services'];
 	for(var i=0; i<o.id.length; i++){
 		appendOption(document.forms[0].wfsList, o.title[i], o.id[i], false);
 	appendOption(document.forms[0].wfsList, "WFS Configurations", "-1", false);
 function appendWfsConfData(dsJson){
 	wfsConf['wfsConf'] = {};
 	wfsConf['wfsConf'] = dsJson.wfsConf;
-	var o = wfsConf['wfsConf'];
-	document.forms[0].wfsConfList.innerHTML = '';
-	if(typeof(o.id)=="undefined")
+	var o = wfsConf['wfsConf'];
+	document.forms[0].wfsConfList.innerHTML = '';
+	if(typeof(o.id)=="undefined")
 		return;
 		appendOption(document.forms[0].wfsConfList, o.abstract[i], o.id[i], false);
@@ -300,10 +305,10 @@
 function appendGuis(dsJson){
 	guis['id'] = {};
 	guis['id'] = dsJson.id;
-	var o = guis['id'];
+	var o = guis['id'];
 	for(var i=0; i<o.length; i++){
 		appendOption(document.forms[0].guiList, o[i], o[i], false);
 function appendGuiConfs(dsJson){
 	var list = document.forms[0].guiConfList;
@@ -311,18 +316,18 @@
 	for(var i=0; i<dsJson.assignedConfs.length; i++){
 		var confAbstract = getConfAbstract(dsJson.assignedConfs[i]);
 		appendOption(list, confAbstract, dsJson.assignedConfs[i], false);
 function appendOption(boxObject, optionText, optionValue, selected){
 	var newOption = new Option(optionText,optionValue,false,selected);
 	boxObject.options[boxObject.length] = newOption;
-function clearList(boxObject){
-	boxObject.length = 0;
+function clearList(boxObject){
+	boxObject.length = 0;
- * returns id and abstract from a wfs configuration
+ * returns id and abstract from a wfs configuration
 function getConfAbstract(confId){
 	var c = wfsConf['wfsConf'];
@@ -370,22 +375,29 @@
 			<select size='4' name='wfsList' class='wfsList' onchange='getWfsConfData();getGuiConfs();'></select>
 		</p>
 	</fieldset>
 	<fieldset class="rightContainer">
 		<legend>Options</legend>
 		<p>
-			<input type='checkbox' name='owsproxy' id='owsproxy' onclick='setOwsproxy(this)' />
-			<label for="owsproxy">OWSProxy</label>
+			<input type='checkbox' name='owsproxy' id='owsproxy' onclick='setOwsproxy(this)' />
+			<label for="owsproxy">enable OWSProxy for the selected WFS</label>
+			<br><br>
+			<input type='button' value='Delete WFS' name='delete' id='deleteButton' onclick='deleteWfs()' />
+			<br /><br />
+		</p>
+	</fieldset>
+	<fieldset class="rightContainer">
+		<legend>Update WFS</legend>
+		<p>
+				Please choose the Link to the WFS Capabilities URL:
+				<br />
+				<a href='javascript:getUpdateUrl("wfs_getcapabilities")'>wfs_getcapabilities</a> or <a href='javascript:getUpdateUrl("wfs_upload_url")'>wfs_upload_url</a>
+			</label>
+			<input id='updateUrl' type='text' value='' name='updateUrl' class='updateUrl' />
 			<br />
-			<label for="updateUrl">
-				Link to new WFS Capabilities URL:
-				<br />
-				(<a href='javascript:getUpdateUrl("wfs_getcapabilities")'>wfs_getcapabilities</a>, <a href='javascript:getUpdateUrl("wfs_upload_url")'>wfs_upload_url</a>)
-			</label>
-			<input id='updateUrl' type='text' value='' name='updateUrl' class='updateUrl' />
-			<br />
-			<input type='button' value='Update WFS' name='update' id='updateButton' onclick='updateWfs()' />
-			<input type='button' value='Delete WFS' name='delete' id='deleteButton' onclick='deleteWfs()' />
+			<input type='button' value='Update WFS' name='update' id='updateButton' onclick='updateWfs()' />
+			<br /><br />
 		</p>
 	</fieldset>
@@ -420,8 +432,8 @@
 		<p>
 			<select size='4' name='guiConfList' class='guiConfList' onchange='' multiple="multiple"></select>
 		</p>
-	</fieldset>
+	</fieldset>
 	<hr />
 </form>
More information about the Mapbender_commits mailing list
