[Mapbender-commits] r2470 - branches/2.5/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 21 14:38:55 EDT 2008
Author: astrid_emde
Date: 2008-05-21 14:38:55 -0400 (Wed, 21 May 2008)
New Revision: 2470
   branches/2.5/http/php/mod_wfs_server.php
the url to update a wfs is constructed to a valid wfs request from the content of colum wfs_capabilities. Parameter are added
Modified: branches/2.5/http/php/mod_wfs_server.php
--- branches/2.5/http/php/mod_wfs_server.php	2008-05-21 18:37:34 UTC (rev 2469)
+++ branches/2.5/http/php/mod_wfs_server.php	2008-05-21 18:38:55 UTC (rev 2470)
@@ -24,27 +24,27 @@
 	case 'getAssignedConfs':
 		$obj->assignedConfs = getAssignedConfs($obj);
 		sendOutput($obj);
-	break;
-	case 'getUpdateUrl':
-		$obj->url = getUpdateUrl($obj);
-		sendOutput($obj);
-	break;
+	break;
+	case 'getUpdateUrl':
+		$obj->url = getUpdateUrl($obj);
+		sendOutput($obj);
+	break;
 		case 'add':
 		addConfsToGui($obj);
 		sendOutput($obj);
 	break;
 	case 'remove':
 		removeConfsFromGui($obj);
-		sendOutput($obj);
-	break;
-	case 'updateWfs':
-		updateWfs($obj);
 		sendOutput($obj);
-	break;
-	case 'deleteWfs':
-		deleteWfs($obj);
-		sendOutput($obj);
 	break;
+	case 'updateWfs':
+		updateWfs($obj);
+		sendOutput($obj);
+	break;
+	case 'deleteWfs':
+		deleteWfs($obj);
+		sendOutput($obj);
+	break;
 	case 'setOwsproxy':
 		$ows = array();
 		$ows['string'] = setOwsproxy($obj);
@@ -70,7 +70,7 @@
  * Get all services (ids and titles) where the current user is owner
  * @return mixed[] services the ids and titles of the services
 function getServices(){
@@ -81,11 +81,11 @@
 	$adm = new administration();
 	$serviceList = $adm->getWfsByOwner($_SESSION['mb_user_id']);
 	if(count($serviceList) == 0){
-		return false;
+		return false;
 	$sql = "SELECT * FROM wfs WHERE wfs_id IN (";
 	$v = $serviceList;
-	$t = array();
+	$t = array();
 	for ($i = 1; $i <= count($serviceList); $i++) {
 		if ($i > 1) {
 			$sql .= ", ";
@@ -103,13 +103,13 @@
- * Get all configurations of the selcted wfs if the current user is owner
- * @return mixed[]
+ * Get all configurations of the selcted wfs if the current user is owner
+ * @return mixed[]
 function getWfsConfData($wfsID){
 	global $con;
-	// re-check permission
+	// re-check permission
 	if(in_array($wfsID, $serviceList)){
@@ -127,41 +127,41 @@
 			$cnt++;
 		if($cnt == 0){
-			return false;
+			return false;
 		else{
 			return $wfsConf;
-	else if($wfsID==="gui_confs"){
-		$wfsConf = array();
-		$wfsConf['id'] = array();
-		$wfsConf['abstract'] = array();
-		$wfsConf['id'] = $adm->getWfsConfByPermission($_SESSION['mb_user_id']);
-		$cnt = 0;
-		foreach($wfsConf['id'] as $wfscid){
-			$sql = "SELECT wfs_conf_abstract FROM wfs_conf WHERE wfs_conf_id = $1";
-			$v = array($wfscid);
-			$t = array('i');
-			$res = db_prep_query($sql,$v,$t);
-			while($row = db_fetch_array($res)){
-				array_push($wfsConf['abstract'], $row['wfs_conf_abstract']);
-			$cnt++;
-		if($cnt == 0){
-			return false;
-		else{
-			return $wfsConf;
+	else if($wfsID==="gui_confs"){
+		$wfsConf = array();
+		$wfsConf['id'] = array();
+		$wfsConf['abstract'] = array();
+		$wfsConf['id'] = $adm->getWfsConfByPermission($_SESSION['mb_user_id']);
+		$cnt = 0;
+		foreach($wfsConf['id'] as $wfscid){
+			$sql = "SELECT wfs_conf_abstract FROM wfs_conf WHERE wfs_conf_id = $1";
+			$v = array($wfscid);
+			$t = array('i');
+			$res = db_prep_query($sql,$v,$t);
+			while($row = db_fetch_array($res)){
+				array_push($wfsConf['abstract'], $row['wfs_conf_abstract']);
+			$cnt++;
+		if($cnt == 0){
+			return false;
+		else{
+			return $wfsConf;
  * Get all GUIs where the current user is owner. This are the GUIs where the user could publish his
  * wfs configurations
- * @return mixed[]
+ * @return mixed[]
 function getGuis(){
@@ -175,19 +175,20 @@
  * get all wfs_confs of the selected WFS which are assigned to the selected gui
- * @param
- * @return mixed[]
+ * @param
+ * @return mixed[]
 function getAssignedConfs($obj){
 	global $con;
 	$assignedConfs = array();
 	$confs = getWfsConfData($obj->selectedWfs);
 	if($confs === false){
-		return false;
+		return false;
 	$sql = "SELECT * FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id IN (".join(",",$confs['id']).")";
+         	$e = new mb_exception("Error: aaaa " . $sql);
 	$v = array($obj->selectedGui);
-	$t = array('s');
+	$t = array('s');
 	if(!$res){
 		$e = new mb_exception("Error: SQL: " . $sql . " -> Gui: " .$obj->selectedGui);
@@ -205,7 +206,7 @@
 		$sql = "SELECT * FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id = $2";
 		$v = array($obj->gui,$obj->confs->$i);
 		$t = array('s','i');
 		if(!$row = db_fetch_array($res)){
 			$sql1 = "INSERT INTO gui_wfs_conf (fkey_gui_id,fkey_wfs_conf_id) VALUES ($1,$2)";
 			$v1 = array($obj->gui, $obj->confs->$i);
@@ -224,82 +225,90 @@
- * updates an WFS
- * @param object the un-encoded object
- * @return boolean success
-function updateWfs($obj){
-	$obj->success = false;
-	$mywfs = new wfs();
-	$mywfs->createObjFromDB($obj->wfs);
-	if(!$mywfs->updateObjFromXML($obj->url)){
-		return false;
-	if(!$mywfs->wfs2db("")){
-		return false;
-	$obj->success = true;
-	return true;
- * deletes an WFS
-function deleteWfs($obj){
-	//$obj->success = false;
-	$sql = "DELETE FROM wfs WHERE wfs_id = $1";
-	$v = array($obj->wfs);
-	$t = array('i');
-	return true;
- * gets the specified url column from db
- * @return string requested url
-function getUpdateUrl($obj){
-	global $con;
-	$sql = "SELECT * FROM wfs WHERE wfs_id = $1;";
-	$t = array('i');
-		return $row[$obj->column];
-	return "";
+ * updates an WFS
+ * @param object the un-encoded object
+ * @return boolean success
+function updateWfs($obj){
+	$obj->success = false;
+	$mywfs = new wfs();
+	$mywfs->createObjFromDB($obj->wfs);
+	if(!$mywfs->updateObjFromXML($obj->url)){
+		return false;
+	if(!$mywfs->wfs2db("")){
+		return false;
+	$obj->success = true;
+	return true;
+ * deletes an WFS
+function deleteWfs($obj){
+	//$obj->success = false;
+	$sql = "DELETE FROM wfs WHERE wfs_id = $1";
+	$v = array($obj->wfs);
+	$t = array('i');
+	return true;
+ * gets the specified url column from db
+ * @return string requested url
+function getUpdateUrl($obj){
+	global $con;
+	$sql = "SELECT * FROM wfs WHERE wfs_id = $1;";
+	$t = array('i');
+		$ContentOfColumn = $row[$obj->column];
+		if($obj->column == 'wfs_getcapabilities'){
+										$n = new administration();
+										$updateUrl = $n->checkURL($ContentOfColumn)."Version=".$row['wfs_version']."&Request=getCapabilities&SERVICE=WFS";
+		}else{
+					$updateUrl = $ContentOfColumn;
+		return $updateUrl;
+	return "";
 function getOwsproxy($obj){
-	$n = new administration();
-	if($obj->wfs=="gui_confs")
+	if($obj->wfs=="gui_confs")
 		return false;
-	return $n->getWfsOwsproxyString($obj->wfs);
+	return $n->getWfsOwsproxyString($obj->wfs);
 function setOwsproxy($obj){
-		return false;
+		return false;
 	return $n->setWfsOwsproxyString($obj->wfs,true);
 function removeOwsproxy($obj){
-		return false;
+		return false;
 	return $n->setWfsOwsproxyString($obj->wfs,false);
  * encodes and delivers the data
 function sendOutput($out){
 	global $json;
More information about the Mapbender_commits mailing list
