[Mapbender-commits] r2476 - in branches/beck_dev/mapbender: http/classes http/javascripts http/php lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 28 11:03:41 EDT 2008
Author: christoph
Date: 2008-05-28 11:03:41 -0400 (Wed, 28 May 2008)
New Revision: 2476
Added:
   branches/beck_dev/mapbender/lib/map.js
   branches/beck_dev/mapbender/lib/point.js
   branches/beck_dev/mapbender/lib/style.js
   branches/beck_dev/mapbender/lib/wfs_obj.js
Removed:
   branches/beck_dev/mapbender/http/javascripts/map.js
   branches/beck_dev/mapbender/http/javascripts/point.js
   branches/beck_dev/mapbender/http/javascripts/style.js
   branches/beck_dev/mapbender/http/javascripts/wfs_obj.js
   branches/beck_dev/mapbender/http/php/mb_listWMCs.php
   branches/beck_dev/mapbender/http/php/mod_createJSObjFromDB.php
   branches/beck_dev/mapbender/http/classes/class_map.php
   branches/beck_dev/mapbender/http/classes/class_user.php
   branches/beck_dev/mapbender/http/classes/class_wmc.php
   branches/beck_dev/mapbender/http/classes/class_wms.php
   branches/beck_dev/mapbender/http/javascripts/map.php
   branches/beck_dev/mapbender/http/javascripts/mod_loadwmc.php
create WMC from application
Modified: branches/beck_dev/mapbender/http/classes/class_map.php
--- branches/beck_dev/mapbender/http/classes/class_map.php	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/classes/class_map.php	2008-05-28 15:03:41 UTC (rev 2476)
@@ -15,12 +15,22 @@
 	private $wmsArray = array();
+	 * @destructor
+	 * @param
+	function __destruct() {
 	 * @constructor
 	 * @param
 	function __construct() {
+	// getter and setter
 	 * @param $value Integer
@@ -59,6 +69,14 @@
+	 * @return String
+	public function getFrameName () {
+		return $this->frameName;
 	 * @param $value String
 	public function setExtent ($aMapbenderBbox) {
@@ -66,22 +84,7 @@
-	 * @param $value Object
-	public function addWms ($value) {
-		array_push($this->wms, $value);
-	 * @return String EPSG code of the map.
-	public function getEpsg () {
-		return $this->extent->epsg;
 	 * @return Mapbender_bbox
 	public function getExtent () {
@@ -90,10 +93,10 @@
-	 * @return String
+	 * @return String EPSG code of the map.
-	public function getFrameName () {
-		return $this->frameName;
+	public function getEpsg () {
+		return $this->extent->epsg;
@@ -125,10 +128,34 @@
 		$this->isOverview = $bool;
+	 * @param $value Object
+	public function addWms ($value) {
+		array_push($this->wms, $value);
+	// map manipulation
+	 * Appends the WMS of another map to this map.
+	 * @param $anotherMap Map
 	public function append ($anotherMap) {
 		$this->wmsArray = array_merge($anotherMap->getWmsArray(), $this->wmsArray);
+	 * Merges this map with another map: Copies the map settings from the
+	 * other map and merges the WMS (keeping the settings of the other
+	 * map if there are duplicates)
 	public function merge ($anotherMap) {
 		$this->width = $anotherMap->width;
 		$this->height = $anotherMap->height;
@@ -138,7 +165,10 @@
 		$this->isOverview = $anotherMap->isOverview;
 		$this->wmsArray = wms::merge(array_merge($anotherMap->getWmsArray(), $this->wmsArray));
+	// Instantiation
 	 * @return
@@ -255,11 +285,31 @@
 		return true;
+	// database functions
+	public static function selectMainMapByApplication ($appId) {
+		return map::selectByApplication($appId, "mapframe1");
+	public static function selectOverviewMapByApplication ($appId) {
+		$currentMap = map::selectByApplication($appId, "overview");
+		if ($currentMap !== null) {
+			$currentMap->setIsOverview(true);
+		return $currentMap;
+	// Output
 	 * Returns an array of string, which are JS statements.
 	 * @return String[]
-	public function createJsObj ($wmsIndex) {
+	public function toJavaScript ($wmsIndex) {
 		$jsCodeArray = array();
 		// initialise map object
@@ -303,46 +353,65 @@
 		array_push($jsCodeArray, $calcExtentString);
 		return $jsCodeArray;
-	 * @destructor
-	 * @param
-	function __destruct() {
- * A JSON output class for Map
- * @class
-class Map2JSON extends Map {
-	var $json;
+	// PRIVATE FUNCTIONS
-	 * @param
-	function __toString() {
-		$this->encodeJSON();
+	private static function selectByApplication ($appId, $frameName) {
+		// find the mapframe in the application elements...
+		$sql = "SELECT * FROM gui_element WHERE fkey_gui_id = $1 AND " .
+				"e_id = $2 LIMIT 1";
+		$v = array($appId, $frameName);
+		$t = array('s', 's');
+		$res = db_prep_query($sql,$v,$t);
+		$row = db_fetch_array($res);
-		return (string)$this->json;
+		// if found...
+		if ($row) {
+			$currentMap = new Map();
+			// use settings from database
+			$currentMap->setWidth($row["e_width"]);
+			$currentMap->setHeight($row["e_height"]);
+			$currentMap->setFrameName($row["e_id"]);
+			// get the WMS
+			$wmsArray = wms::selectMyWmsByApplication($appId);
+//			$e = new mb_notice("WMS in this map: " . implode(",", $wmsArray));
+			// if this is the overview, find the WMS index and
+			// reset the WMS array
+			// BEWARE, SUPER UGLY CODE AHEAD!!
+			// (BUT THERE IS NO OTHER WAY TO DO IT)
+			if (strpos($row["e_src"], "mod_mapOV.php?wms") !== false) {
+//				$e = new mb_exception("guess this is the OV");
+				$pattern = "/[\.\/a-zA-Z_]*\?wms=([0-9]*)[^0-9]*/";
+				$ovIndex = preg_replace($pattern, "\$1", $row["e_src"]);
+				$e = new mb_exception("OV index: " . $ovIndex);
+				if (!$ovIndex) {
+					$ovIndex = 0;
+				$wmsArray = array($wmsArray[$ovIndex]);
+//				$e = new mb_notice("WMS in this map (corrected): " . implode(",", $wmsArray));
+			else {
+//				$e = new mb_exception("guess this is NOT the OV");
+			$currentMap->wmsArray = $wmsArray;
+			// TO DO: EXTENT!
+		else {
+			return null;
-	 *@param
-	function encodeJSON() {
-		$this->json = json_encode(get_object_vars($this));
-	 *@param
-	function getJSON() {
-		return $this->json;
\ No newline at end of file
Modified: branches/beck_dev/mapbender/http/classes/class_user.php
--- branches/beck_dev/mapbender/http/classes/class_user.php	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/classes/class_user.php	2008-05-28 15:03:41 UTC (rev 2476)
@@ -38,6 +38,13 @@
+	 * @return String the ID of this user
+	public function __toString () {
+		return (string) $this->id;
 	 * Returns an array of application IDs that the user is allowed to access.
 	 * @return Array an array of application IDs
Modified: branches/beck_dev/mapbender/http/classes/class_wmc.php
--- branches/beck_dev/mapbender/http/classes/class_wmc.php	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/classes/class_wmc.php	2008-05-28 15:03:41 UTC (rev 2476)
@@ -125,7 +125,7 @@
-	// CREATION OF A WMC
+	// INSTANTIATION
@@ -149,6 +149,12 @@
 		$this->createObjFromWMC_xml($doc);
+	public function createFromApplication ($appId) {
+		// get the map objects "overview" and "mapframe1"
+		$this->mainMap = map::selectMainMapByApplication($appId);
+		$this->overviewMap = map::selectOverviewMapByApplication($appId);
 	 * Creates a WMC object from a JS map object {@see map_obj.js}
@@ -360,12 +366,12 @@
-			$wmcJsArray = array_merge($wmcJsArray, $this->overviewMap->createJsObj($overviewWmsIndex));
+			$wmcJsArray = array_merge($wmcJsArray, $this->overviewMap->toJavaScript($overviewWmsIndex));
 		// .. and add main map ..
-		$wmcJsArray = array_merge($wmcJsArray, $this->mainMap->createJsObj(null));
+		$wmcJsArray = array_merge($wmcJsArray, $this->mainMap->toJavaScript(null));
 		// Finally, request the maps
 		array_push($wmcJsArray, "setMapRequest('" . $this->mainMap->getFrameName() . "');");
@@ -376,7 +382,10 @@
 		array_push($wmcJsArray, "eventAfterLoadWMS.trigger()");
 		return $wmcJsArray;
+	// manipulation
 	 * Merges this WMC with another WMC.
 	 * The settings of the other WMC overwrite the settings of this WMC.
Modified: branches/beck_dev/mapbender/http/classes/class_wms.php
--- branches/beck_dev/mapbender/http/classes/class_wms.php	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/classes/class_wms.php	2008-05-28 15:03:41 UTC (rev 2476)
@@ -19,12 +19,12 @@
 include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_user.php");
 require_once(dirname(__FILE__)."/class_mb_exception.php");
 require_once(dirname(__FILE__)."/class_administration.php");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
 class wms {
 	var $lastURL;
@@ -122,6 +122,7 @@
 	 * 					when an error occured.
 	 * @param $anotherWms wms The same WMS with possibly other settings
 	public function copyConfiguration ($anotherWms) {
 		if (!$this->equals($anotherWms)) {
 			$e = new mb_exception("class_wms.php: copyConfiguration(): parameters cannot be copied, it's a different WMS.");
@@ -138,8 +139,8 @@
 			$myCurrentLayer->gui_layer_style      = $theirCurrentLayer->gui_layer_style;
 	 * Removes duplicate WMS from an array of WMS. To find duplicates,
 	 * two WMS are compared via equals().
@@ -1926,6 +1927,40 @@
 			die();
+	 * Selects all WMS of the current user from the database.
+	 * Then it creates the corresponding WMS object and returns
+	 * these objects as an array.
+	 * @return wms[]
+	 * @param $appId String
+	public static function selectMyWmsByApplication ($appId) {
+		// check if user is permitted to access the application
+		$currentUser = new User($_SESSION["mb_user_id"]);
+		$appArray = $currentUser->getApplicationsByPermission(false);
+		if (!in_array($appId, $appArray)) {
+			$e = new mb_warning("class_wms.php: selectMyWmsByApplication(): User '" . $currentUser . "' is not allowed to acces application '" . $appId . "'.");
+			return array();
+		// get WMS of this application
+		$sql = "SELECT fkey_wms_id FROM gui_wms WHERE " .
+				"fkey_gui_id = $1 ORDER BY gui_wms_position";
+		$v = array($appId);
+		$t = array('s');
+		// instantiate PHP objects and store in array
+		$wmsArray = array();
+		while ($row = db_fetch_array($res)) {
+			$currentWms = new wms();
+			$currentWms->createObjFromDB($appId, $row["fkey_wms_id"]);
+			array_push($wmsArray, $currentWms);
+		return $wmsArray;
 class layer extends wms {
 	var $layer_id;
Deleted: branches/beck_dev/mapbender/http/javascripts/map.js
--- branches/beck_dev/mapbender/http/javascripts/map.js	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/javascripts/map.js	2008-05-28 15:03:41 UTC (rev 2476)
@@ -1,1200 +0,0 @@
-var ie = document.all?1:0;
-var n6 = document.getElementById&&!document.all?1:0;
-var n4 = document.layers?1:0;
-var mb_mapObj = [];
-var mb_fiWin = null;
-var mb_panActive = false;
-var clickX;
-var clickY;
-var mb_start_x = 0;
-var mb_start_y = 0;
-var mb_end_x = 0;
-var mb_end_y = 0;
-var mb_offset_top = 0;
-var mb_offset_right = 0;
-var mb_offset_bottom = 0;
-var mb_offset_left = 0;
-var mb_log = null;
- * @deprecated
-function mb_execloadWmsSubFunctions(){
-	eventAfterLoadWMS.trigger();
-function mb_execWfsReadSubFunctions(geom) {
-	for(var i=0; i<mb_WfsReadSubFunctions.length; i++){
-		mb_WfsReadSubFunctions[i](geom);
-function mb_execWfsWriteSubFunctions() {
-	for(var i=0; i<mb_WfsWriteSubFunctions.length; i++){
-		mb_WfsWriteSubFunctions[i]();
-function mb_setWmcExtensionData(anArray) {
-	for (var i in anArray) {
-		if (typeof(anArray[i]) != "undefined") {
-			currentWmcExtensionData[i] = anArray[i];
-function mb_getWmcExtensionData(arrayKey) {
-	for (var i in restoredWmcExtensionData) {
-		if (arrayKey == i) {
-			return restoredWmcExtensionData[i];
-	var e = new Mb_warning("mb_getWmcExtensionData: "+arrayKey+" not found. Maybe this GUI does not allow loading or saving WMC documents from/to the session");
-	return null;
-// transparent GIF
-var mb_trans = new Image();
-mb_trans.src = "../img/transparent.gif";
- * Called in index.php on body onload
-function init() {
-	// creates the map objects (mapframe1, overview...)
-	eventInitMap.trigger();
-	// initialisation
-	eventInit.trigger();
-	// performs a map request for each map frame
-	for(var i=0; i<mb_mapObj.length; i++){
-		setMapRequest(mb_mapObj[i].frameName);
-function mb_registerMapObj(frameName, elementName,wms_index,width, height){
-	mb_mapObj.push(new mb_mapObj_const(frameName, elementName, width, height, wms_index));
- * get the conjunction character of an URL
- * @param {String} onlineresource
- * @return the character & or ?
- * @type String
-function mb_getConjunctionCharacter(onlineresource){
-	var conChar;
-	if(onlineresource.indexOf("?") > -1){
-		if(onlineresource.charAt(onlineresource.length-1) == "?"){
-			conChar = "";
-		}else if(onlineresource.charAt(onlineresource.length-1) == "&"){
-			conChar = "";
-		}else{
-			conChar = "&";
-	if(onlineresource.indexOf("?") == -1){
-		conChar = "?";
-	return conChar;
-function mb_wmsMoveByIndex(mapObj_ind, fromIndex, toIndex) {
-	if (fromIndex != toIndex && fromIndex >= 0 && fromIndex < mb_mapObj[mapObj_ind].wms.length && toIndex >= 0 && toIndex < mb_mapObj[mapObj_ind].wms.length) {
-		var changed = false;
-		var i;
-		var result;
-		if (fromIndex > toIndex) {
-			for (i = fromIndex; i > toIndex ; i--) {
-				result = mb_swapWmsByIndex(mapObj_ind, i-1, i);
-				if (result === true) {
-					changed = true;
-		else {
-			for (i = fromIndex; i < toIndex ; i++) {
-				result = mb_swapWmsByIndex(mapObj_ind, i, i+1);
-					changed = true;
-		return changed;
-	else {
-		return false;
-function mb_swapWmsByIndex(mapObj_ind, indexA, indexB) {
-	if (indexA != indexB && indexA >= 0 && indexA < mb_mapObj[mapObj_ind].wms.length && indexB >= 0 && indexB < mb_mapObj[mapObj_ind].wms.length) {
-		upper = mb_mapObj[mapObj_ind].wms[indexA];
-		mb_mapObj[mapObj_ind].wms[indexA] = mb_mapObj[mapObj_ind].wms[indexB];
-		mb_mapObj[mapObj_ind].wms[indexB] = upper;
-		var upperLayers = mb_mapObj[mapObj_ind].layers[indexA];
-		var upperStyles = mb_mapObj[mapObj_ind].styles[indexA];
-		var upperQuerylayers = mb_mapObj[mapObj_ind].querylayers[indexA];
-		mb_mapObj[mapObj_ind].layers[indexA] = mb_mapObj[mapObj_ind].layers[indexB];
-		mb_mapObj[mapObj_ind].styles[indexA] = mb_mapObj[mapObj_ind].styles[indexB];
-		mb_mapObj[mapObj_ind].querylayers[indexA] = mb_mapObj[mapObj_ind].querylayers[indexB];
-		mb_mapObj[mapObj_ind].layers[indexB] = upperLayers;
-		mb_mapObj[mapObj_ind].styles[indexB] = upperStyles;
-		mb_mapObj[mapObj_ind].querylayers[indexB] = upperQuerylayers;
-		return true;
-	else {
-		return false;
-function mb_mapObjaddWMS(obj){
-	var cnt_layers = 0;
-	var cnt_querylayers = 0;
-	var styles = "";
-	var layers = "";
-	var querylayers = "";
-	var ind = getMapObjIndexByName(obj);
-	//is the id valid?
-	for( var i=0; i<(wms.length-1); i++){
-		if(parseInt(wms[i].wms_id, 10) >= parseInt(wms[wms.length-1].wms_id, 10)){
-			wms[wms.length-1].wms_id = parseInt(mb_mapObj[ind].wms[i].wms_id, 10) + 1;
-	mb_mapObj[ind].wms[mb_mapObj[ind].wms.length] = wms[wms.length-1];
-	mb_mapObj[ind].layers[mb_mapObj[ind].layers.length] = layers;
-	mb_mapObj[ind].styles[mb_mapObj[ind].styles.length] = styles;
-	mb_mapObj[ind].querylayers[mb_mapObj[ind].querylayers.length] = querylayers;
-	mb_execloadWmsSubFunctions();
-	return true;
-function mb_mapObjremoveWMS(objind,wmsind){
-	var wms_ID = null;
-	var i;
-	var new_wmsarray = [];
-	var new_layerarray = [];
-	var new_querylayerarray = [];
-	var new_stylesarray = [];
-	var new_mapURLarray = [];
-	for	(i=0;i<mb_mapObj[objind].wms.length; i++){
-		if(i != wmsind){
-			new_wmsarray[new_wmsarray.length] = mb_mapObj[objind].wms[i];
-			new_layerarray[new_layerarray.length] = mb_mapObj[objind].layers[i];
-			new_querylayerarray[new_querylayerarray.length] = mb_mapObj[objind].querylayers[i];
-			new_stylesarray[new_stylesarray.length] = mb_mapObj[objind].styles[i];
-			new_mapURLarray[new_mapURLarray.length] = mb_mapObj[objind].mapURL[i];
-		else {
-			wms_ID = mb_mapObj[objind].wms[i].wms_id;
-	mb_mapObj[objind].wms = new_wmsarray;
-	mb_mapObj[objind].layers = new_layerarray;
-	mb_mapObj[objind].querylayers = new_querylayerarray;
-	mb_mapObj[objind].styles = new_stylesarray;
-	mb_mapObj[objind].mapURL = new_mapURLarray;
-	var another_new_wmsarray = [];
-	for	(i=0;i<wms.length; i++){
-		if(wms[i].wms_id != wms_ID){
-			another_new_wmsarray[another_new_wmsarray.length] = wms[i];
-	wms = another_new_wmsarray;
-function setExtent(width,height,epsg){
-   for(var i=0; i < wms[0].gui_epsg.length; i++){
-      if(wms[0].gui_epsg[i] == epsg){
-         var bbox_minx = parseFloat(wms[0].gui_minx[i]);
-         var bbox_miny = parseFloat(wms[0].gui_miny[i]);
-         var bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
-         var bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
-         var extenty = bbox_maxy - bbox_miny;
-         var extentx = bbox_maxx - bbox_minx;
-         var relation_px_x = width / height;
-         var relation_px_y = height / width;
-         var relation_bbox_x = extentx / extenty;
-         var centerx = bbox_minx + (extentx/2);
-         var centery = bbox_miny + (extenty/2);
-         if(relation_bbox_x <= relation_px_x){
-                bbox_minx = centerx - relation_px_x * extenty / 2;
-                bbox_maxx = centerx + relation_px_x * extenty / 2;
-         if(relation_bbox_x > relation_px_x){
-                bbox_miny = centery - relation_px_y * extentx / 2;
-                bbox_maxy = centery + relation_px_y * extentx / 2;
-        return bbox_minx  +","+ bbox_miny +","+ bbox_maxx  +","+ bbox_maxy;
-function setMapRequest(frameName){
-	var functionName = 'setMapRequest';
-	var ret = eventBeforeMapRequest.trigger({frameName:frameName}, "AND");
-	if (ret === false) {
-		return true;
-	var ts = mb_timestamp();
-	var myMapIds = [];
-	for (var i=0; i < mb_mapObj.length; i++){
-		var currentMapObject = mb_mapObj[i];
-		if (currentMapObject.frameName != frameName) {
-			continue;
-		var newMapRequest = "";
-		for (var ii = 0; ii < currentMapObject.wms.length; ii++){
-			var currentWms = currentMapObject.wms[ii];
-			if (!(currentWms.gui_wms_visible > 0)) {
-				continue;
-			myMapIds.push("map_"+ii);
-			newMapRequest += getLayerHtmlCode(frameName, i, ii);
-		writeTag(mb_mapObj[i].frameName, mb_mapObj[i].elementName, newMapRequest);
-	eventAfterMapRequest.trigger({
-		"frameName": frameName,
-		"myMapIds": myMapIds.join(",")
-	for(var i=0; i<mb_MapRequestSubFunctions.length; i++){
-		eval(mb_MapRequestSubFunctions[i]);
-function getLayerHtmlCode (frameName, i, ii) {
-	var myDivId = "div_" + ii;
-	var myMapId = "map_" + ii;
-	//disable Layer which are out of scale
-	var validLayers = mb_checkScale(frameName, i, ii);
-	var layerNames = validLayers.toString();
-	var newMapURL = false;
-	var opacityString = "";
-	if (currentMapObject.layers[ii] !== "" && layerNames !== ''){
-		// get map URL
-		newMapURL = currentMapObject.getMapUrl(i, ii);
-		var currentOpacity = currentWms.gui_wms_mapopacity;
-		if (currentOpacity != 1) {
-			opacityString += "opacity:" + currentOpacity + "; ";
-			opacityString += "Filter: Alpha(Opacity=" + currentOpacity*100 + "); ";
-			opacityString += "-moz-opacity:" + currentOpacity + " ; ";
-			opacityString += "-khtml-opacity:" + currentOpacity;
-	var imageString = "<img id='"+myMapId+"' name='mapimage' ";
-	imageString += "src='" + newMapURL + "' ";
-	imageString += "width='"+currentMapObject.width+"' ";
-	imageString += "height='"+currentMapObject.height+"' ";
-	imageString += "border='0'>";
-	var newMapRequest = "<div id='"+myDivId+"' ";
-	newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
-	newMapRequest += "z-index:" + ii + ";" + opacityString + "\">";
-	newMapRequest += imageString;
-	newMapRequest += "</div>";
-	currentMapObject.mapURL[ii]= newMapURL;
-	currentWms.mapURL = newMapURL;
-	if (mb_log && currentWms.mapURL) {
-		var tmp = eval(mb_log + "('" +newMapURL + "','" + ts + "')");
-	return newMapRequest;
-function setSingleMapRequest(frameName,wms_id){
-	var functionName = 'setSingleMapRequest';
-	eventBeforeMapRequest.trigger({frameName:frameName});
-	for(i = 0; i < mb_mapObj.length; i++){
-			continue;
-		for (var ii=0; ii < currentMapObject.wms.length; ii++){
-			if (currentWms.wms_id != wms_id) {
-				continue;
-			var newMapRequest = getLayerHtmlCode(frameName, i, ii);
-			if (mb_log) {
-				var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
-			writeTag(currentMapObject.frameName, myDivId, newMapRequest);
-			eventAfterMapRequest.trigger({"frameName":frameName, "myMapId":myMapId});
-			return true;
-	return false;
-function mb_restateLayers(frameName,wms_id){
-	//alert(frameName + " / " + wms_id);
-	var ind = getMapObjIndexByName(frameName);
-	for(var i=0; i<mb_mapObj[ind].wms.length; i++){
-		if(mb_mapObj[ind].wms[i].wms_id == wms_id){
-			var layers = "";
-			var styles = "";
-			for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
-				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
-					if(cnt_layers > 0){layers += ","; styles += ","; }
-					layers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
-					//alert(mb_mapObj[ind].wms[i].objLayer[ii].layer_name);
-					styles += "";
-					cnt_layers++;
-				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
-					if(cnt_querylayers > 0){querylayers += ",";}
-					querylayers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
-					cnt_querylayers++;
-			mb_mapObj[ind].layers[i] = layers;
-			mb_mapObj[ind].querylayers[i] = querylayers;
-			mb_mapObj[ind].styles[i] = styles;
-function mb_checkScale(frameName,mObj,wmsObj){
-	var thisLayer = mb_mapObj[mObj].layers[wmsObj].split(",");
-	var thisScale = mb_getScale(frameName);
-	var str_layer = "";
-	var cnt_layer = 0;
-	for(var i=0; i<mb_mapObj[mObj].wms[wmsObj].objLayer.length; i++){
-		var myLayername = mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_name;
-		var myMinscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_minscale;
-		var myMaxscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_maxscale;
-		for(var ii=0; ii<thisLayer.length; ii++){
-			var minscaleOK = false;
-			var maxscaleOK = false;
-			if(thisLayer[ii] == myLayername){
-				if(myMinscale === 0 || thisScale >= myMinscale){minscaleOK = true;}
-				if(myMaxscale === 0 || thisScale <= myMaxscale){maxscaleOK = true;}
-				if(maxscaleOK === true && minscaleOK === true  && !mb_mapObj[mObj].wms[wmsObj].objLayer[i].has_childs){
-					if(cnt_layer > 0){str_layer += ","; }//str_styles += ","; str_titles += ",";str_parent += ","; str_legendurls += ",";}
-					str_layer += thisLayer[ii];
-					cnt_layer++;
-	var str_layerstyles = [];
-	str_layerstyles[0] = str_layer;
-	return str_layerstyles;
-function setFeatureInfoRequest(fName,x,y, path) {
-	var functionName = 'setFeatureInfoRequest';
-	eventBeforeFeatureInfo.trigger({"fName":fName});
-	for(var i=0; i<mb_FeatureInfoPreFunctions.length; i++){
-		eval(mb_FeatureInfoPreFunctions[i]);
-	var cnt_fi = 0;
-	for(i=0; i<mb_mapObj.length; i++){
-		if(mb_mapObj[i].frameName == fName){
-			for(var ii=0; ii<mb_mapObj[i].wms.length; ii++){
-				var newfeatureInfoRequest = "";
-				var requestParams = "";
-				var validation = false;
-				newfeatureInfoRequest += mb_mapObj[i].wms[ii].wms_getfeatureinfo;
-            	newfeatureInfoRequest += mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getfeatureinfo);
-				if(mb_mapObj[i].wms[ii].wms_version == "1.0.0"){requestParams += "WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=feature_info&";}
-				if(mb_mapObj[i].wms[ii].wms_version != "1.0.0"){requestParams += "VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetFeatureInfo&SERVICE=WMS&";}
-				requestParams += "SRS="+mb_mapObj[i].epsg+"&";
-				requestParams += "BBOX="+mb_mapObj[i].extent+"&";
-				requestParams += "WIDTH="+mb_mapObj[i].width+"&";
-				requestParams += "HEIGHT="+mb_mapObj[i].height+"&";
-				requestParams += "LAYERS="+mb_mapObj[i].layers[ii]+"&";
-				requestParams += "STYLES="+mb_mapObj[i].styles[ii]+"&";
-				requestParams += "FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";
-				requestParams += "INFO_FORMAT="+mb_mapObj[i].wms[ii].gui_wms_featureinfoformat+"&";
-				requestParams += "EXCEPTIONS=application/vnd.ogc.se_xml&";
-				if(mb_feature_count > 0){
-					requestParams += "FEATURE_COUNT="+mb_feature_count+"&";
-				requestParams += "QUERY_LAYERS="+mb_mapObj[i].querylayers[ii]+"&";
-				requestParams += "X=" + x  + "&";
-				requestParams += "Y=" + y;
-				if(mb_mapObj[i].querylayers[ii] !== "" && mb_mapObj[i].layers[ii] !== ""){
-					validation = true;
-				//add vendor-specific
-				for(var v=0; v < mb_vendorSpecific.length; v++){
-					var vendorSpecificString = eval(mb_vendorSpecific[v]);
-					requestParams += "&" + vendorSpecificString;
-				if(mb_log && validation){
-					var tmp = eval(mb_log + "('" + newfeatureInfoRequest + requestParams + "','" + ts + "')");
-				if(document.getElementById("FeatureInfoRedirect") && validation){
-					newfeatureInfoRequest += requestParams;
-					if(path){
-						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr;
-					else{
-						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = newfeatureInfoRequest;
-					cnt_fi++;
-				else if(path && validation){
-					try{
-						var p = new mb_popup("Feature Info","url:"+path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr,300,400);
-						p.show();
-					}catch(e){
-						window.open(path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
-					cnt_fi++;
-				else if(validation){
-					try{
-						var p = new mb_popup("Feature Info","url:"+newfeatureInfoRequest,300,400);
-						p.show();
-					catch(e){
-						window.open(newfeatureInfoRequest, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
-					cnt_fi++;
-   	if(cnt_fi === 0){
-		alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));
- * global function to zoom a mapobject
- * use: mb_mapObj.zoom() {@link mb_mapObj_const#zoom}
- * @deprecated
-function zoom(frameName,in_, factor,x,y) {
-	var obj = getMapObjByName(frameName);
-	if(x && y){
-		obj.zoom(in_, factor, x, y);
-	else{
-		obj.zoom(in_, factor, false, false);
-	setMapRequest(frameName);
-function mb_panMap(frameName,dir){
-   var arrayBBox = mb_mapObj[ind].extent.split(",");
-   var minx = parseFloat(arrayBBox[0]);
-   var miny = parseFloat(arrayBBox[1]);
-   var maxx = parseFloat(arrayBBox[2]);
-   var maxy = parseFloat(arrayBBox[3]);
-   var xtentx = parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]);
-   var xtenty =  parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]);
-   if(dir == "NW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "N"){miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "NE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "W"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2);}
-   if(dir == "E"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2);}
-   if(dir == "SW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-   if(dir == "S"){miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-   if(dir == "SE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-  mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
-function handleSelectedLayer (frameName, wms_title, layerName, type, status) {
-//	alert(frameName + " , " +wms_title + " , " +layerName + " , " +type + " , " +status);
-//	type = {visible || querylayer] status = {0 || 1}
-	for (var i=0; i < mb_mapObj.length; i++) {
-		if (mb_mapObj[i].frameName == frameName) {
-			var myMapObj = i;
-			for (var ii = 0; ii < mb_mapObj[i].wms.length; ii++) {
-				if (mb_mapObj[i].wms[ii].wms_title == wms_title) { //ii is true
-					var myWMS = ii;
-					if (type == "visible") {
-						var arrayLayer = mb_mapObj[i].layers[ii].split(",");
-					if (type == "querylayer") {
-						var arrayLayer = mb_mapObj[i].querylayers[ii].split(",");
-					for (var iii = 1; iii < mb_mapObj[i].wms[ii].objLayer.length; iii++) {
-						var layer_name = mb_mapObj[i].wms[ii].objLayer[iii].layer_name;
-							if (layer_name == layerName && status == 1 && mb_mapObj[i].wms[ii].objLayer[iii].layer_queryable == 1){
-								if (cnt_layer > 0) {
-									str_layer += ",";
-								str_layer += layer_name;
-								cnt_layer++;
-						else if (type == "visible") {
-							if (layer_name == layerName && status == 1) {
-									str_layer += ",";
-								cnt_layer++;
-						for (var iiii = 0; iiii < arrayLayer.length; iiii++) {
-							if (layer_name == arrayLayer[iiii] && layer_name != layerName) {
-									str_layer += ",";
-								cnt_layer++;
-		mb_mapObj[myMapObj].layers[myWMS] = str_layer;
-		var array_str_layer = str_layer.split(",");
-		var str_styles = "";
-		for (var cnt=0; cnt < array_str_layer.length; cnt++) {
-			if (cnt > 0) {
-				str_styles += ",";
-			str_styles += "";
-		mb_mapObj[myMapObj].styles[myWMS] = str_styles;
-		mb_mapObj[myMapObj].querylayers[myWMS] = str_layer;
-	if(type == 'visible'){
-		setSingleMapRequest(frameName,wms_title);
-function handleSelectedLayer_array(mapObj, array_wms, array_layer, type, status){
-	//alert(mapObj+" / "+array_wms[0]+" / "+ array_layer[0]+" / "+ type+" / "+ status);
-	var ind = getMapObjIndexByName(mapObj);
-	for(var j=0; j<array_wms.length; j++){
-			if(mb_mapObj[ind].wms[i].wms_id == array_wms[j]){
-				var check = false;
-					if(mb_mapObj[ind].wms[i].wms_id == array_wms[j] && mb_mapObj[ind].wms[i].objLayer[ii].layer_name == array_layer[j]){
-						if(type == "visible"){
-							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible = parseInt(status, 10);
-							check = true;
-                        if(type == "querylayer" && (mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == "1" || mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == 1)){
-							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer = parseInt(status, 10);
-                mb_restateLayers(mapObj, array_wms[j]);
-                //alert('restate');
-                * hier noch checken, welche wms sich geaendert haben und disctinct eine singleRequest aufrufen:
-                if(check === true){
-                    if(mb_mapObj[ind].wms[i].gui_wms_visible == 1){
-						setSingleMapRequest(mapObj,mb_mapObj[ind].wms[i].wms_id);
-                        //alert('sSMR');
-function makeClickPos2RealWorldPos(frameName, myClickX, myClickY) {
-	var width = parseInt(mb_mapObj[ind].width, 10);
-	var height = parseInt(mb_mapObj[ind].height, 10);
-	var minX = parseFloat(arrayBBox[0]);
-	var minY = parseFloat(arrayBBox[1]);
-	var maxX = parseFloat(arrayBBox[2]);
-	var maxY = parseFloat(arrayBBox[3]);
-	var deltaX = (maxX - minX)/width;
-	var deltaY = (maxY - minY)/height;
-	if(deltaX > 0){
-		var roundx = 1/Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
-	else{
-		var roundx =  Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
-	if(deltaY > 0){
-		var roundy = 1/Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
-	else{
-		var roundy =  Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
-	var xtentx = maxX - minX;
-	var xtenty =  maxY - minY;
-	var posX = parseFloat(minX + (myClickX / width) * xtentx);
-	var posY = parseFloat(maxY - (myClickY / height) * xtenty);
-	posX = Math.round(posX * roundx)/roundx;
-	posY = Math.round(posY * roundy)/roundy;
-	return [posX, posY];
-function makeRealWorld2mapPos(frameName,rw_posx, rw_posy){
-   var mpObj = mb_mapObj[ind];
-   var arrayBBox = mpObj.extent.split(",");
-   return [Math.round((rw_posx - minX)*mpObj.width/(maxX - minX)), Math.round((maxY - rw_posy)*mpObj.height/(maxY - minY))];
-function mb_arrangeElement(frameName, elName, left, top) {
-   if(frameName !== ""){
-      window.frames[frameName].document.getElementById(elName).style.top = top;
-      window.frames[frameName].document.getElementById(elName).style.left = left;
-   else{
-      document.getElementById(elName).style.top = top;
-      document.getElementById(elName).style.left = left;
-/***********************Drag & Drop***********************/
-function mb_getMousePos(e,fName){
-if(fName){
-     if(ie){
-        clickX = window.frames[fName].event.clientX;
-        clickY = window.frames[fName].event.clientY;
-     else{
-        clickX = e.pageX;
-        clickY = e.pageY;
-  else{
-       if(ie){
-        clickX = event.clientX;
-        clickY = event.clientY;
-     else{
-        clickX = e.pageX;
-        clickY = e.pageY;
-  var pos = [clickX,clickY];
-  return pos;
-// function for object-identification
-function getMapObjIndexByName(frameName){
-		if(mb_mapObj[i].frameName == frameName){
-			return i;
-function getMapObjByName(frameName){
-			return mb_mapObj[i];
-	return false;
-function mb_getLayerTitleByName(map_index, wms_index, myLayer_name){
-	for(var i=0; i<mb_mapObj[map_index].wms[wms_index].objLayer.length; i++){
-		if(mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_name == myLayer_name){
-			return mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_title;
-function getWMSIDByTitle(frameName,wms_title){
-   for(var i=0; i< mb_mapObj[ind].wms.length; i++){
-      if(mb_mapObj[ind].wms[i].wms_title == wms_title){
-         //return i;
-         return mb_mapObj[ind].wms[i].wms_id;
-function getWMSIndexByTitle(frameName,wms_title){
-         return i;
-function getWMSIndexById(frameName,wms_id){
-         return i;
-//scale
-function mb_getScale(frameName) {
-	var myScale = eventBeforeGetScale.trigger({"frameName":frameName});
-   for(var i=0; i<mb_GetScalePreFunctions.length; i++){
-		var myScale = eval(mb_GetScalePreFunctions[i]);
-   if(typeof(myScale) == "number"){
-      var Y_str = myScale;
-   else{
-      var scaleY = (xtenty / mb_mapObj[ind].height) *(mb_resolution * 100);
-      if (scaleY<1){
-      	var Y_str = scaleY;
-      }else{
-      	var Y_str = Math.round(scaleY);
-   return Y_str;
-function mb_repaintScale(frameName, x, y, scale){
-   if(x === null && y === null){
-      x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
-      y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
-   var minx = parseFloat(x) - (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
-   var miny = parseFloat(y) -  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
-   var maxx = parseFloat(x) + (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
-   var maxy = parseFloat(y) +  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
-   mb_repaint(frameName,minx, miny, maxx, maxy);
-function mb_repaint(frameName,minx,miny,maxx,maxy){
- * converts the extent of the mapobject so that the maximum	extent will be displayed {@link mb_mapObj_const#calculateExtent}
- * use: mb_mapObj.calculateExtent
- * @deprecated
-function mb_calculateExtent(frameName,minx,miny,maxx,maxy){
-  var map = getMapObjByName(frameName);
-  var extent = new Extent(minx,miny,maxx,maxy);
-  map.calculateExtent(extent);
- * @class extent
- * @param {float} minx
- * @param {float} miny
- * @param {float} maxx
- * @param {float} maxy
- * @return the extent as object
- * @type Object
-function Extent(minx,miny,maxx,maxy){
-	this.minx = parseFloat(minx);
-	this.miny = parseFloat(miny);
-	this.maxx = parseFloat(maxx);
-	this.maxy = parseFloat(maxy);
-	this.extentx = this.maxx - this.minx;
-	this.extenty = this.maxy - this.miny;
-	this.centerx = this.minx + this.extentx/2;
-	this.centery = this.miny + this.extenty/2;
-	return this;
-function mb_showHighlight(frameName,x,y){
-   var pos = makeRealWorld2mapPos(frameName,x, y);
-   mb_arrangeElement(frameName,"highlight",pos[0]-7, pos[1]-7);
-   window.frames[frameName].document.getElementById("highlight").style.visibility = 'visible';
-function mb_hideHighlight(frameName){
-   mb_arrangeElement(frameName,"highlight",-20, -20);
-   window.frames[frameName].document.getElementById("highlight").style.visibility = 'hidden';
-function mb_permanentHighlight(frameName,x,y){
-   mb_arrangeElement(frameName,"permanent",pos[0]-7, pos[1]-7);
-   window.frames[frameName].document.getElementById("permanent").style.visibility = 'visible';
-// framename, commaseparated coordinates, commaseparated rgb values (color)
-//new: coords is array!
-function mb_markResult(frameName,geom,col){
-	var x = "";
-	var y = "";
-	var tmp = [];
-	for(var i=0; i < geom.length; i++){
-		if(i > 0){
-			x += ":";
-			y += ":";
-		tmp = geom[i].split(",");
-		for(var ii=0; ii < tmp.length; ii+=2){
-			var pos = makeRealWorld2mapPos(frameName,tmp[ii], tmp[ii+1]);
-			if(ii>0){
-				x += ",";
-				y += ",";
-			x += pos[0];
-			y += pos[1];
-	var source = "<img src='../extensions/markResult.php?x=" + x + "&y=" + y + "&width=" + mb_mapObj[ind].width + "&height=" + mb_mapObj[ind].height + "&color="+col+"'>";
-	//prompt("",source);
-	writeTag(frameName,"markResult",source);
-function mb_disableResult(frameName){
-   writeTag(frameName,"markResult","");
-function mb_registerGML(frameName,obj){
-	mb_mapObj[ind].geom = obj;
-function mb_timestamp(){
-	var d = new Date();
-	var ts = Math.round(Date.parse(d)/1000);
-	return ts;
-function mb_getlayerposbyname(objInd,wmsInd,lname){
-	var t = mb_mapObj[objInd].wms[wmsInd];
-	for(var i=0; i < t.objLayer.length; i++){
-		if(t.objLayer[i].layer_name == lname){
-			return t.objLayer[i].layer_pos;
-function mb_getLayerObjByName(fname,wms_id,layer_name){
-	var ind = getMapObjIndexByName(fname);
-	var wmsInd = getWMSIndexById(fname,wms_id);
-	var t = mb_mapObj[ind].wms[wmsInd];
-		if(t.objLayer[i].layer_name == layer_name){
-			return t.objLayer[i];
-function mb_getchildsbyname(objInd,wmsInd,lname){
-	var pos = mb_getlayerposbyname(objInd, wmsInd,lname);
-	var l = [];
-	l.name = [];
-	l.title = [];
-	l.legendurl = [];
-		if(t.objLayer[i].layer_parent == pos){
-			l.name[l.name.length] = t.objLayer[i].layer_name;
-			l.title[l.title.length] = t.objLayer[i].layer_title;
-			if(t.objLayer[i].layer_style.length>0){
-				l.legendurl[l.legendurl.length] = t.objLayer[i].layer_style[0].legendurl;
-			}else{
-				l.legendurl[l.legendurl.length] = 0 ;
-	if(l.name.length > 0){
-		return l;
-	else{
-		return false;
- *   button handling
-var mb_button = [];
-function mb_regButton_frame(wii, frameName, param){
-	var ind = mb_button.length;
-	mb_button[ind] = new mb_conButton(wii, ind);
-	if (frameName === null) {
-		if (param === null) {
-			eval(wii+"("+ind+")");
-		else {
-			eval(wii+"("+ind+", "+param+")");
-	else if (param === null) {
-		eval("window.frames['" + frameName + "']."+wii+"("+ind+")");
-	else {
-		eval("window.frames['" + frameName + "']."+wii+"("+ind+", "+param+")");
-	mb_button[ind].prev = mb_button[ind].src;
-	mb_button[ind].src = mb_button[ind].img_off;
-	mb_button[ind].onmouseover = function () {
-		mb_button_over(ind);
-	mb_button[ind].onmouseout = function(){
-		mb_button_out(ind);
-	mb_button[ind].onclick = function(){
-		mb_button_click(ind);
-		mb_button[ind].frameName = "";
-	else {
-		mb_button[ind].frameName = frameName;
-function mb_regButton(wii){
-	mb_regButton_frame(wii, null, null);
-function mb_conButton(wii, ind){
-   this.wii = wii;
-   return true;
-function mb_button_over(ind){
-   if(mb_button[ind].status === 0){
-      mb_button[ind].src = mb_button[ind].img_over;
-function mb_button_out(ind){
-   mb_button[ind].src = mb_button[ind].prev;
-function mb_button_click(ind){
-   var mbStatus = mb_button[ind].status;
-   if(mbStatus === 0){
-      mb_disableButton(mb_button[ind].elName);
-      mb_button[ind].prev = mb_button[ind].img_on;
-      mb_button[ind].src = mb_button[ind].img_on;
-      mb_button[ind].status = 1;
-      if (mb_button[ind].frameName !== "") {
-          window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).go();
-      else {
-	      document.getElementById(mb_button[ind].elName).go();
-   else{
-      mb_button[ind].prev = mb_button[ind].img_off;
-      mb_button[ind].status = 0;
-          window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).stop();
-      else {
-	      document.getElementById(mb_button[ind].elName).stop();
-function mb_disableButton(elName){
-   for(var i=0; i<mb_button.length; i++){
-      if(mb_button[i].elName != elName && mb_button[i].status == 1){
-            mb_button[i].status = 0;
-		      if (mb_button[i].frameName !== "") {
-    	        window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).src = mb_button[i].img_off;
-	            window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).stop();
-		      else {
-    	        document.getElementById(mb_button[i].elName).src = mb_button[i].img_off;
-	            document.getElementById(mb_button[i].elName).stop();
-            return true;
-function mb_disableThisButton(elName){
-      if(mb_button[i].elName == elName && mb_button[i].status == 1){
-      		//alert(mb_button[i].elName);
-		      else {
-            return true;
-function updateButtonTooltips(obj) {
- * the buttons are only initialized on mouseover!
- * So when localizing, not all buttons may have been registered
-//		console.log("button %i", i);
-		for(var j=0; j<obj.length; j++){
-			if (mb_button[i].elName == obj[j].id) {
-//			console.log("%s %s", mb_button[i].elName, obj[j].id);
-					window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).title = obj[j].title;
-				else {
-					document.getElementById(mb_button[i].elName).title = obj[j].title;
-	// an alternative, fixes above error,
-	// but this one only changes those in the main frame
-	var imageArray = document.getElementsByTagName("img");
-	for (var i = 0; i < imageArray.length; i++) {
-			if (imageArray[i].id == obj[j].id) {
-				document.getElementById(imageArray[i].id).title = obj[j].title;
-function mb_localizeButtons(){
-	mb_ajax_json("../php/mod_button_tooltips.php", function(obj, status){
-		updateButtonTooltips(obj);
-eventLocalize.register(function () {
-	mb_localizeButtons();
-eventInit.register(function () {
- *   miscellaneous functions
-function cloneObject(obj) {
-    if (typeof obj !== 'object' || obj === null) {
-        return obj;
-    var c = obj instanceof Array ? [] : {};
-    for (var i in obj) {
-        var prop = obj[i];
-        if (typeof prop == 'object') {
-           if (prop instanceof Array) {
-               c[i] = [];
-               for (var j = 0; j < prop.length; j++) {
-                   if (typeof prop[j] != 'object') {
-                       c[i].push(prop[j]);
-                   } else {
-                       c[i].push(cloneObject(prop[j]));
-           } else {
-               c[i] = cloneObject(prop);
-        } else {
-           c[i] = prop;
-    return c;
- *   deprecated functions
-// only used in mod_perimeter.php
-// previously used in mod_initWmc.php, mod_digitize_tab.php, mod_geometryArray.js
-function mb_checkTag(frameName, tagName, elementId, appendAtTagName, attributes){
-	var oldElement;
-	var newElement;
-	var prefix;
-	if(frameName && frameName !== ""){
-		prefix = window.frames[frameName].document;
-	else if(!frameName || frameName === ""){
-		prefix = document;
-	oldElement = prefix.getElementById(elementId);
-	if (oldElement === null) {
-		newElement = prefix.createElement(tagName);
-		newElement = prefix.getElementsByTagName(appendAtTagName)[0].appendChild(newElement);
-	else {
-		if (oldElement.nodeName.toLowerCase() == tagName.toLowerCase()) {
-			for (var i=0; i<attributes.length; i++) {
-				oldElement.setAttribute(attributes[i][0], attributes[i][1]);
-			return oldElement;
-		else {
-			return false;
-	var newElementAttributeNode = document.createAttribute("id");
-	newElementAttributeNode.value = elementId;
-	newElement.setAttributeNode(newElementAttributeNode);
-		newElement.setAttribute(attributes[i][0], attributes[i][1]);
-	return newElement;
Modified: branches/beck_dev/mapbender/http/javascripts/map.php
--- branches/beck_dev/mapbender/http/javascripts/map.php	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/javascripts/map.php	2008-05-28 15:03:41 UTC (rev 2476)
@@ -72,33 +72,33 @@
 echo "var mb_security_proxy = '" . MB_SECURITY_PROXY . "';";
-// Load JavaScript libraries
+// Load external JavaScript libraries
 require_once(dirname(__FILE__) . "/../extensions/jquery.js");
+require_once(dirname(__FILE__) . "/../extensions/jqjson.js");
+// Load internal JavaScript libraries
 require_once(dirname(__FILE__) . "/../../lib/map_obj.js");
 require_once(dirname(__FILE__) . "/../../lib/exception.js");
 require_once(dirname(__FILE__) . "/../../lib/ajax.js");
 require_once(dirname(__FILE__) . "/../../lib/div.js");
 require_once(dirname(__FILE__) . "/../../lib/list.js");
-require_once(dirname(__FILE__) . "/../javascripts/map.js");
-require_once(dirname(__FILE__) . "/../javascripts/point.js");
+require_once(dirname(__FILE__) . "/../../lib/map.js");
+require_once(dirname(__FILE__) . "/../../lib/point.js");
 require_once(dirname(__FILE__) . "/../../lib/wms.js");
-require_once(dirname(__FILE__) . "/../javascripts/wfs_obj.js");
-require_once(dirname(__FILE__) . "/../extensions/jqjson.js");
-require_once(dirname(__FILE__) . "/../javascripts/style.js");
+require_once(dirname(__FILE__) . "/../../lib/wfs_obj.js");
+require_once(dirname(__FILE__) . "/../../lib/style.js");
 // Load WMS
-$sql = "SELECT fkey_wms_id FROM gui_wms WHERE fkey_gui_id = $1 ORDER BY gui_wms_position";
-$v = array($gui_id);
-$t = array('s');
-$res = db_prep_query($sql, $v, $t);
+$wmsArray = wms::selectMyWmsByApplication($gui_id);
-while($row = db_fetch_array($res)) {
-	$mywms = new wms();
-	$mywms->createObjFromDB($gui_id, $row["fkey_wms_id"]);
-	$mywms->createJsObjFromWMS();
+for ($i = 0; $i < count($wmsArray); $i++) {
+	$currentWms = $wmsArray[$i];
+	$currentWms->createJsObjFromWMS();
@@ -147,7 +147,4 @@
Modified: branches/beck_dev/mapbender/http/javascripts/mod_loadwmc.php
--- branches/beck_dev/mapbender/http/javascripts/mod_loadwmc.php	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/javascripts/mod_loadwmc.php	2008-05-28 15:03:41 UTC (rev 2476)
@@ -66,6 +66,12 @@
 			$jsArray = $wmc->toJavaScript();
 		echo implode("", $jsArray);
+		// test wmc from app
+		$newWmc = new wmc();
+		$newWmc->createFromApplication($_SESSION["mb_user_gui"]);
 	else {
 		echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: error parsing wmc');";
Deleted: branches/beck_dev/mapbender/http/javascripts/point.js
--- branches/beck_dev/mapbender/http/javascripts/point.js	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/javascripts/point.js	2008-05-28 15:03:41 UTC (rev 2476)
@@ -1,192 +0,0 @@
-* $Id$
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-//http://www.mapbender.org/index.php/point.js
- * @class A class representing a two-dimensional point.
- * @constructor
- * @param {Float} x x value of the {@link Point}
- * @param {Float} y y value of the {@link Point}
- function Point(x, y, z){
- 	 * x value of the {@link Point}
-	 * @type Float
-//	this.x = parseFloat(x);
-	this.x = x;
- 	 * y value of the {@link Point}
-	 * @type Float
-//	this.y = parseFloat(y);
-	this.y = y;
-	this.z = z;
- * computes the distance between a {@link Point} p and this {@link Point}
- * @param {Point} p the distance between this {@link Point} and the {@link Point} p is computed.
- * @return {Float} the distance between the two {@link Point} objects.
-Point.prototype.dist = function(p){
-	return Math.sqrt(Math.pow(this.y-p.y,2) + Math.pow(this.x-p.x,2)) ;
- * checks if the coordinates of this {@link Point} match the coordinates of a {@link Point} p
- * @return {Boolean} true if the two points are equal; elso false
-Point.prototype.equals = function(p){
-	if (this.x == p.x && this.y == p.y) {return true;}
-	return false;
- * subtracts a {@link Point} p from this {@link Point}
- * @return a new {@link Point} with the difference of the two points
-Point.prototype.minus = function(p){
-	return new Point(this.x-p.x, this.y-p.y);
- * adds this {@link Point} to a {@link Point} p
- * @return a new {@link Point} with the sum of the two points
-Point.prototype.plus = function(p){
-	return new Point(this.x+p.x, this.y+p.y);
- * divides this {@link Point} by a scalar c
- * @param {Float} c divisor
- * @return a new {@link Point} divided by c
-Point.prototype.dividedBy = function(c){
-	if (c !== 0) {
-		return new Point(this.x/c, this.y/c);
-	var e = new Mb_exception("Point.dividedBy: Division by zero");
-	return false;
- * multiplies this {@link Point} by a scalar c
- * @param {Float} c factor
- * @return a new {@link Point} multiplied by c
-Point.prototype.times = function(c){
-	return new Point(this.x*c, this.y*c);
- * rounds the coordinates to numOfDigits digits
- * @param numOfDigits the coordinate will be rounded to numOfDigits digits
- * @return a new {@link Point} rounded to numOfDigits digits
- * @type Point
-Point.prototype.round = function(numOfDigits){
-	return new Point(roundToDigits(this.x, numOfDigits), roundToDigits(this.y, numOfDigits));
- * @returns a {String} representation of this Point
- * @type String
-Point.prototype.toString = function(){
-	if (typeof(this.z == "undefined")) {
-		return "[" + this.x + ", " + this.y + "]";
-	else {
-		return "[" + this.x + ", " + this.y + ", " + this.z + "]";
-// possible improvement: point has flag: map OR real. additional functions: toReal, toMap
- * @ignore
-function mapToReal(frameName, aPoint){
-	var v;
-	if (typeof(mb_mapObj) == 'object') {
-		v = makeClickPos2RealWorldPos(frameName, aPoint.x, aPoint.y);
-	else {
-		if (typeof(parent.mb_mapObj) == 'object') {
-			v = parent.makeClickPos2RealWorldPos(frameName, aPoint.x, aPoint.y);
-		else {
-			alert('where am i?');
-	return new Point(v[0], v[1]);
- * @ignore
-function realToMap(frameName, aPoint) {
-	var v;
-		v = makeRealWorld2mapPos(frameName, aPoint.x, aPoint.y);
-	else if (typeof(parent.mb_mapObj) == 'object') {
-		v = parent.makeRealWorld2mapPos(frameName, aPoint.x, aPoint.y);
-	else {
-		var e = new Mb_exception('Point.realToMap:where am i?');
- * @ignore
-function mb_calcExtent(frameName, min, max) {
-	var ind;
-		ind = getMapObjIndexByName(frameName);
-		ind = parent.getMapObjIndexByName(frameName);
-	else {
-		var e = new Mb_exception('Point.mb_calcExtent: function getMapObjIndexByName not found');
-	var extent = max.minus(min);
-	var center = extent.dividedBy(2).plus(min);
-	var relation_px_x = mb_mapObj[ind].width / mb_mapObj[ind].height;
-	var relation_px_y = mb_mapObj[ind].height / mb_mapObj[ind].width;
-	var relation_bbox_x = extent.x / extent.y;
-	var new_min;
-	var new_max;
-		new_min = new Point(center.x - relation_px_x * extent.y / 2, min.y);
-		new_max = new Point(center.x + relation_px_x * extent.y / 2, max.y);
-	else if(relation_bbox_x > relation_px_x){
-		new_min = new Point(min.x, center.y - relation_px_y * extent.x / 2);
-		new_max = new Point(max.x, center.y + relation_px_y * extent.x / 2);
-	mb_mapObj[ind].extent = new_min.x +","+ new_min.y +","+ new_max.x  +","+ new_max.y;
- * @ignore
-function roundToDigits(aFloat, numberOfDigits) {
-	return Math.round(aFloat*Math.pow(10, parseInt(numberOfDigits, 10)))/Math.pow(10, parseInt(numberOfDigits, 10));
Deleted: branches/beck_dev/mapbender/http/javascripts/style.js
--- branches/beck_dev/mapbender/http/javascripts/style.js	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/javascripts/style.js	2008-05-28 15:03:41 UTC (rev 2476)
@@ -1,54 +0,0 @@
- * creates a style tag in the head of the document.
-var StyleTag = function() {
-	 * Creates the style tag in the head of the document. Something like a constructor.
-	var createStyleTag = function() {
-		// TODO: Internet Explorer routine seems a little buggy
-		if (top.ie) {
-			// create a Style Sheet object (IE only)
-			//styleSheetObj=document.createStyleSheet();
-			// get the DOM node of the style sheet object, set the type
-			//styleObj=styleSheetObj.owningElement || styleSheetObj.ownerNode;
-			//styleObj.setAttribute("type","text/css");
-			// alternative way for IE: take existing styleSheet with index 0 instead of creating a new one
-			styleSheetObj=document.styleSheets[0];
-		else {
-			// create the style node, set the style
-			styleObj=document.createElement("style");
-			styleObj.setAttribute("type","text/css");
-			// append the node to the head
-			document.getElementsByTagName("head")[0].appendChild(styleObj);
-	 * Adds a class className with the CSS in cssString
-	this.addClass = function(className,cssString) {
-		if (top.ie) {
-			//add new style declaration to chosen styleSheet
-			var cssRules = cssString.split(";");
-			for (i=0; i<cssRules.length-1; i++){
-				styleSheetObj.addRule("."+className,cssRules[i]);
-		else {
-			// insert the content via createTextNode
-			styleObj.appendChild(document.createTextNode("."+className+"{\n\t"+cssString+"\n}\n"));
-	var styleObj;
-	var styleSheetObj; //IE only...
-	createStyleTag();
Deleted: branches/beck_dev/mapbender/http/javascripts/wfs_obj.js
--- branches/beck_dev/mapbender/http/javascripts/wfs_obj.js	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/javascripts/wfs_obj.js	2008-05-28 15:03:41 UTC (rev 2476)
@@ -1,75 +0,0 @@
-//$Id$
-//$Header: /cvsroot/mapbender/mapbender/http/javascripts/wfs_obj.js,v 1.3 2005/09/13 14:38:11 bjoern_heuser Exp $
-//global variables
-var wfs = [];
-var wfs_featuretype_count = 0;
-var wfs_element_count = 0;
-//list of all wms-objects
-function add_wfs(
-			wfs_id,
-			wfs_version,
-			wfs_title,
-			wfs_abstract,
-			wfs_getcapabilities,
-			wfs_describefeaturetype){
-					wfs[wfs.length] = new wfs_const(
-					wfs_id,
-			      wfs_version,
-			      wfs_title,
-			      wfs_abstract,
-			      wfs_describefeaturetype);
-					//wfs_featuretype[wfs.length - 1] = [];
-//the wms constructor
-function wfs_const(
-			wfs_id,
-			wfs_version,
-			wfs_title,
-			wfs_abstract,
-	this.wfs_id = wfs_id;
-	this.wfs_version = wfs_version;
-	this.wfs_title = wfs_title;
-	this.wfs_abstract = wfs_abstract;
-	this.wfs_getcapabilities = wfs_getcapabilities;
-	this.wfs_describefeaturetype = wfs_describefeaturetype;
-	this.wfs_featuretype = [];
-   //alert(wfs_id + " , " +wfs_title + " , " +wfs_abstract + " , " +wfs_getcapabilities + " , " +wfs_describefeaturetype);
-//featuretype
-function wfs_add_featuretype(
-			featuretype_name,
-			featuretype_title,
-			featuretype_srs,
-			featuretype_geomtype){
-	      wfs[wfs.length-1].wfs_featuretype[wfs[wfs.length-1].wfs_featuretype.length] = new featuretype(
-											featuretype_name,
-											featuretype_srs,
-											featuretype_geomtype);
-//alert(featuretype_name + " , " +featuretype_title + " , " +featuretype_srs + " , " +featuretype_geomtype);
-function featuretype(
-			featuretype_name,
-			featuretype_srs,
-	this.featuretype_name = featuretype_name;
-	this.featuretype_title = featuretype_title;
-	this.featuretype_srs = featuretype_srs;
-	this.featuretype_geomtype = featuretype_geomtype;
-	this.element = [];
-	wfs_featuretype_count++;
-//elements
-function wfs_add_featuretype_element(element_name, element_type, element_count, featuretype_count){
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count] = [];
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].name = element_name;
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].type = element_type;
-   //alert(element_name +" , "+element_type);
Deleted: branches/beck_dev/mapbender/http/php/mb_listWMCs.php
--- branches/beck_dev/mapbender/http/php/mb_listWMCs.php	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/php/mb_listWMCs.php	2008-05-28 15:03:41 UTC (rev 2476)
@@ -1,201 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mb_listWMCs.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__) . "/../classes/class_administration.php");
-require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
-$gui_id = $_SESSION["mb_user_gui"];
-$user_id = $_SESSION["mb_user_id"];
-$action = $_GET["action"];
-$wmcId = $_GET["wmc_id"];
-$delWmcId = $_POST["del_wmc_id"];
-$clientFilename = $_FILES['local_wmc_filename']['tmp_name'];
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-	<head>
-		<meta http-equiv="cache-control" content="no-cache">
-		<meta http-equiv="pragma" content="no-cache">
-		<meta http-equiv="expires" content="0">
-		<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
-		<title>Select web map contect document from list</title>
-	</head>
-	<body>
-		<form name='delete_wmc' action='<?php echo $self; ?>' method='POST'>
-			<input type='hidden' id='delete_wmc' name='del_wmc_id' value ='' >
-		</form>
-<?php
-function mb_listWMCs($wmcIdArray, $form_target){
-	$display = "<h2 style='font-family: Arial, Helvetica, sans-serif; color: #808080;background-color: White;'><font align='left' color='#000000'>load WMC from list</font></h2>";
-	$display .= "<table width='90%' style='font-family: Arial, Helvetica, sans-serif;font-size : 12px;color: #808080;' border='1' cellpadding='3' rules='rows'><tr style='background-color:#F0F0F0;' width='80px'><td ><b>WMC name</b></td><td><b>last update</b></td><td colspan=5></td></tr>";
-	if (count($wmcIdArray) > 0) {
-		$v = array();
-		$t = array();
-		$wmcIdList = "";
-		for ($i = 0; $i < count($wmcIdArray); $i++){
-			if ($i > 0){
-				$wmcIdList .= ",";
-			$wmcIdList .= "$".($i+1);
-			array_push($v, $wmcIdArray[$i]);
-			array_push($t, 's');
-		$sql_list_wmcs = "SELECT DISTINCT wmc_id, wmc_title, wmc_timestamp FROM mb_user_wmc ";
-		$sql_list_wmcs .= "WHERE wmc_id IN (" . $wmcIdList . ") ";
-		$sql_list_wmcs .= "ORDER BY wmc_timestamp DESC";
-		$res_list_wmcs = db_prep_query($sql_list_wmcs, $v, $t);
-		while($row = db_fetch_array($res_list_wmcs)){
-			$this_id = $row["wmc_id"];
-			$this_title = $row["wmc_title"];
-			$this_timestamp = date("M d Y H:i:s", $row["wmc_timestamp"]);
-			$display .= "<tr onmouseover='this.style.backgroundColor = \"#F08080\"' onmouseout='this.style.backgroundColor = \"#ffffff\"'>";
-			$display .= "<td>".$this_title."</td>";
-			$display .= "<td>".$this_timestamp. "</td>";
-			$display .= "<td><a href=\"" . $form_target . "&action=load&wmc_id=".$this_id."\"><img src=\"../img/button_gray/wmc_load.png\" title=\"load this WMC\"  border=0></a></td>";
-			$display .= "<td><a href=\"" . $form_target . "&action=merge&wmc_id=".$this_id."\"><img src=\"../img/button_gray/wmc_merge.png\" title=\"merge WMC\"  border=0></a></td>";
-			$display .= "<td><a href=\"" . $form_target . "&action=append&wmc_id=".$this_id."\"><img src=\"../img/button_gray/wmc_append.png\" title=\"append WMC\"  border=0></a></td>";
-			$display .= "<td><a href='../javascripts/mod_displayWmc.php?wmc_id=".$this_id."' target = '_blank'><img src=\"../img/button_gray/wmc_xml.png\" title=\"display WMC XML\"  border=0></a></td>";
-			$display .= "<td><a href=\"" . $form_target . "&action=delete&wmc_id=".$this_id."\"><img src=\"../img/button_gray/del.png\" title=\"delete this WMC\"  border=0></a></td>";
-			$display .= "</tr>";
-	else{
-		$display .= "<tr><td>There are no WMCs availiable</td></tr>";
-	$display .= "</table>";
-	return $display;
-function getTarget($gui_id) {
-	$sql = "SELECT e_requires, e_target FROM gui_element WHERE e_id = 'loadwmc' AND fkey_gui_id = $1";
-	$v = array($gui_id);
-	$t = array("s");
-	$res = db_prep_query($sql, $v, $t);
-	$cnt = 0;
-	while($row = db_fetch_array($res)){
-		$e_target = $row["e_target"];
-		$e_require = $row["e_requires"];
-		$cnt++;
-	if ($cnt > 1) {
-		$e = new mb_exception("listWMCs: e_id 'loadwmc' not unique in GUI '" . $gui_id . "'!");
-	$targetArray = explode(",", $e_target);
-	if (in_array('mapframe1', $targetArray)) {
-		return 'mapframe1';
-	else {
-		return trim($targetArray[0]);
-function loadFile($filename) {
-	$handle = fopen($filename, "r");
-	$cnt = 0;
-	while (!feof($handle)) {
-    	$buffer .= fgets($handle, 4096);
-	fclose ($handle);
-	return $buffer;
-$admin = new administration();
-$wmcIdArray = $admin->getWmcByOwner($user_id);
-// wmc is being deleted
-if (!empty($delWmcId)) {
-	$result = $admin->deleteWmc($delWmcId, $user_id);
-	if (!$result) {
-		echo "<script language='javascript'>";
-		echo "alert('WMC could not be deleted!');";
-		echo "</script>";
-// wmc is being loaded from file
-elseif ($clientFilename) {
-	$serverFilename = "../tmp/wmc" . time() . ".xml";
-	copy($clientFilename, $serverFilename);
-	$wmc = new wmc();
-	$wmc->createObjFromWMC_xml(loadFile($serverFilename));
-	$mytarget = getTarget($gui_id);
-	$js = $wmc->createJsObjFromWMC("window.opener.", $mytarget, "load");
-	echo $js;
-	if ($wmc->getTitle()) {
-		$title = "'" . $wmc->getTitle() . "' ";
-	echo "alert(\"WMC " . $title . ": load successful.\");\n";
-	echo "window.close();";
-	echo "</script>";
-// load a WMC from file
-<h2 style='font-family: Arial, Helvetica, sans-serif; color: #808080;background-color: White;'><font align='left' color='#000000'>load WMC from file</font></h2>
-<form enctype="multipart/form-data" action="<?php echo $self;?>" method=POST target="_self">
-<input type='file' name='local_wmc_filename'>
-<input type='submit' value='load'>
-</form>
-<?php
-// load a WMC from list
-echo mb_listWMCs($wmcIdArray, $self);
-if ($wmcId && in_array($wmcId, $wmcIdArray)){
-	if ($action == "delete") {
-		echo "value = confirm('Do you really want to delete this document?');";
-		echo "if (value == true) {";
-		echo "document.delete_wmc.del_wmc_id.value = '" . $wmcId . "';";
-		echo "document.delete_wmc.submit();";
-		echo "}";
-		echo "</script>";
-	else if ($action == "append" || $action == "merge" || $action == "load") {
-		$wmc = new wmc();
-		$wmc->createObjFromWMC_id($wmcId);
-		$js = $wmc->createJsObjFromWMC("window.opener.", $mytarget, $action);
-		echo $js;
-		echo "alert(\"WMC " . $title . ": " . $action . " successful.\");\n";
-		echo "</script>";
-</body>
-</html>
Deleted: branches/beck_dev/mapbender/http/php/mod_createJSObjFromDB.php
--- branches/beck_dev/mapbender/http/php/mod_createJSObjFromDB.php	2008-05-28 14:31:38 UTC (rev 2475)
+++ branches/beck_dev/mapbender/http/php/mod_createJSObjFromDB.php	2008-05-28 15:03:41 UTC (rev 2476)
@@ -1,33 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_createJSObjectFromDB.php
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
-$v = array($_SESSION["mb_user_gui"]);
-$t = array('s');
-$res = db_prep_query($sql,$v,$t);
-while($row = db_fetch_array($res)){
-	$mywms->createObjFromDB($_SESSION["mb_user_gui"],$row["fkey_wms_id"]);
Copied: branches/beck_dev/mapbender/lib/map.js (from rev 2452, branches/beck_dev/mapbender/http/javascripts/map.js)
--- branches/beck_dev/mapbender/lib/map.js	                        (rev 0)
+++ branches/beck_dev/mapbender/lib/map.js	2008-05-28 15:03:41 UTC (rev 2476)
@@ -0,0 +1,1200 @@
+var ie = document.all?1:0;
+var n6 = document.getElementById&&!document.all?1:0;
+var n4 = document.layers?1:0;
+var mb_mapObj = [];
+var mb_fiWin = null;
+var mb_panActive = false;
+var clickX;
+var clickY;
+var mb_start_x = 0;
+var mb_start_y = 0;
+var mb_end_x = 0;
+var mb_end_y = 0;
+var mb_offset_top = 0;
+var mb_offset_right = 0;
+var mb_offset_bottom = 0;
+var mb_offset_left = 0;
+var mb_log = null;
+ * @deprecated
+function mb_execloadWmsSubFunctions(){
+	eventAfterLoadWMS.trigger();
+function mb_execWfsReadSubFunctions(geom) {
+	for(var i=0; i<mb_WfsReadSubFunctions.length; i++){
+		mb_WfsReadSubFunctions[i](geom);
+function mb_execWfsWriteSubFunctions() {
+	for(var i=0; i<mb_WfsWriteSubFunctions.length; i++){
+		mb_WfsWriteSubFunctions[i]();
+function mb_setWmcExtensionData(anArray) {
+	for (var i in anArray) {
+		if (typeof(anArray[i]) != "undefined") {
+			currentWmcExtensionData[i] = anArray[i];
+function mb_getWmcExtensionData(arrayKey) {
+	for (var i in restoredWmcExtensionData) {
+		if (arrayKey == i) {
+			return restoredWmcExtensionData[i];
+	var e = new Mb_warning("mb_getWmcExtensionData: "+arrayKey+" not found. Maybe this GUI does not allow loading or saving WMC documents from/to the session");
+	return null;
+// transparent GIF
+var mb_trans = new Image();
+mb_trans.src = "../img/transparent.gif";
+ * Called in index.php on body onload
+function init() {
+	// creates the map objects (mapframe1, overview...)
+	eventInitMap.trigger();
+	// initialisation
+	eventInit.trigger();
+	// performs a map request for each map frame
+	for(var i=0; i<mb_mapObj.length; i++){
+		setMapRequest(mb_mapObj[i].frameName);
+function mb_registerMapObj(frameName, elementName,wms_index,width, height){
+	mb_mapObj.push(new mb_mapObj_const(frameName, elementName, width, height, wms_index));
+ * get the conjunction character of an URL
+ * @param {String} onlineresource
+ * @return the character & or ?
+ * @type String
+function mb_getConjunctionCharacter(onlineresource){
+	var conChar;
+	if(onlineresource.indexOf("?") > -1){
+		if(onlineresource.charAt(onlineresource.length-1) == "?"){
+			conChar = "";
+		}else if(onlineresource.charAt(onlineresource.length-1) == "&"){
+			conChar = "";
+		}else{
+			conChar = "&";
+	if(onlineresource.indexOf("?") == -1){
+		conChar = "?";
+	return conChar;
+function mb_wmsMoveByIndex(mapObj_ind, fromIndex, toIndex) {
+	if (fromIndex != toIndex && fromIndex >= 0 && fromIndex < mb_mapObj[mapObj_ind].wms.length && toIndex >= 0 && toIndex < mb_mapObj[mapObj_ind].wms.length) {
+		var changed = false;
+		var i;
+		var result;
+		if (fromIndex > toIndex) {
+			for (i = fromIndex; i > toIndex ; i--) {
+				result = mb_swapWmsByIndex(mapObj_ind, i-1, i);
+				if (result === true) {
+					changed = true;
+		else {
+			for (i = fromIndex; i < toIndex ; i++) {
+				result = mb_swapWmsByIndex(mapObj_ind, i, i+1);
+					changed = true;
+		return changed;
+	else {
+		return false;
+function mb_swapWmsByIndex(mapObj_ind, indexA, indexB) {
+	if (indexA != indexB && indexA >= 0 && indexA < mb_mapObj[mapObj_ind].wms.length && indexB >= 0 && indexB < mb_mapObj[mapObj_ind].wms.length) {
+		upper = mb_mapObj[mapObj_ind].wms[indexA];
+		mb_mapObj[mapObj_ind].wms[indexA] = mb_mapObj[mapObj_ind].wms[indexB];
+		mb_mapObj[mapObj_ind].wms[indexB] = upper;
+		var upperLayers = mb_mapObj[mapObj_ind].layers[indexA];
+		var upperStyles = mb_mapObj[mapObj_ind].styles[indexA];
+		var upperQuerylayers = mb_mapObj[mapObj_ind].querylayers[indexA];
+		mb_mapObj[mapObj_ind].layers[indexA] = mb_mapObj[mapObj_ind].layers[indexB];
+		mb_mapObj[mapObj_ind].styles[indexA] = mb_mapObj[mapObj_ind].styles[indexB];
+		mb_mapObj[mapObj_ind].querylayers[indexA] = mb_mapObj[mapObj_ind].querylayers[indexB];
+		mb_mapObj[mapObj_ind].layers[indexB] = upperLayers;
+		mb_mapObj[mapObj_ind].styles[indexB] = upperStyles;
+		mb_mapObj[mapObj_ind].querylayers[indexB] = upperQuerylayers;
+		return true;
+	else {
+		return false;
+function mb_mapObjaddWMS(obj){
+	var cnt_layers = 0;
+	var cnt_querylayers = 0;
+	var styles = "";
+	var layers = "";
+	var querylayers = "";
+	var ind = getMapObjIndexByName(obj);
+	//is the id valid?
+	for( var i=0; i<(wms.length-1); i++){
+		if(parseInt(wms[i].wms_id, 10) >= parseInt(wms[wms.length-1].wms_id, 10)){
+			wms[wms.length-1].wms_id = parseInt(mb_mapObj[ind].wms[i].wms_id, 10) + 1;
+	mb_mapObj[ind].wms[mb_mapObj[ind].wms.length] = wms[wms.length-1];
+	mb_mapObj[ind].layers[mb_mapObj[ind].layers.length] = layers;
+	mb_mapObj[ind].styles[mb_mapObj[ind].styles.length] = styles;
+	mb_mapObj[ind].querylayers[mb_mapObj[ind].querylayers.length] = querylayers;
+	mb_execloadWmsSubFunctions();
+	return true;
+function mb_mapObjremoveWMS(objind,wmsind){
+	var wms_ID = null;
+	var i;
+	var new_wmsarray = [];
+	var new_layerarray = [];
+	var new_querylayerarray = [];
+	var new_stylesarray = [];
+	var new_mapURLarray = [];
+	for	(i=0;i<mb_mapObj[objind].wms.length; i++){
+		if(i != wmsind){
+			new_wmsarray[new_wmsarray.length] = mb_mapObj[objind].wms[i];
+			new_layerarray[new_layerarray.length] = mb_mapObj[objind].layers[i];
+			new_querylayerarray[new_querylayerarray.length] = mb_mapObj[objind].querylayers[i];
+			new_stylesarray[new_stylesarray.length] = mb_mapObj[objind].styles[i];
+			new_mapURLarray[new_mapURLarray.length] = mb_mapObj[objind].mapURL[i];
+		else {
+			wms_ID = mb_mapObj[objind].wms[i].wms_id;
+	mb_mapObj[objind].wms = new_wmsarray;
+	mb_mapObj[objind].layers = new_layerarray;
+	mb_mapObj[objind].querylayers = new_querylayerarray;
+	mb_mapObj[objind].styles = new_stylesarray;
+	mb_mapObj[objind].mapURL = new_mapURLarray;
+	var another_new_wmsarray = [];
+	for	(i=0;i<wms.length; i++){
+		if(wms[i].wms_id != wms_ID){
+			another_new_wmsarray[another_new_wmsarray.length] = wms[i];
+	wms = another_new_wmsarray;
+function setExtent(width,height,epsg){
+   for(var i=0; i < wms[0].gui_epsg.length; i++){
+      if(wms[0].gui_epsg[i] == epsg){
+         var bbox_minx = parseFloat(wms[0].gui_minx[i]);
+         var bbox_miny = parseFloat(wms[0].gui_miny[i]);
+         var bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
+         var bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
+         var extenty = bbox_maxy - bbox_miny;
+         var extentx = bbox_maxx - bbox_minx;
+         var relation_px_x = width / height;
+         var relation_px_y = height / width;
+         var relation_bbox_x = extentx / extenty;
+         var centerx = bbox_minx + (extentx/2);
+         var centery = bbox_miny + (extenty/2);
+         if(relation_bbox_x <= relation_px_x){
+                bbox_minx = centerx - relation_px_x * extenty / 2;
+                bbox_maxx = centerx + relation_px_x * extenty / 2;
+         if(relation_bbox_x > relation_px_x){
+                bbox_miny = centery - relation_px_y * extentx / 2;
+                bbox_maxy = centery + relation_px_y * extentx / 2;
+        return bbox_minx  +","+ bbox_miny +","+ bbox_maxx  +","+ bbox_maxy;
+function setMapRequest(frameName){
+	var functionName = 'setMapRequest';
+	var ret = eventBeforeMapRequest.trigger({frameName:frameName}, "AND");
+	if (ret === false) {
+		return true;
+	var ts = mb_timestamp();
+	var myMapIds = [];
+	for (var i=0; i < mb_mapObj.length; i++){
+		var currentMapObject = mb_mapObj[i];
+		if (currentMapObject.frameName != frameName) {
+			continue;
+		var newMapRequest = "";
+		for (var ii = 0; ii < currentMapObject.wms.length; ii++){
+			var currentWms = currentMapObject.wms[ii];
+			if (!(currentWms.gui_wms_visible > 0)) {
+				continue;
+			myMapIds.push("map_"+ii);
+			newMapRequest += getLayerHtmlCode(frameName, i, ii);
+		writeTag(mb_mapObj[i].frameName, mb_mapObj[i].elementName, newMapRequest);
+	eventAfterMapRequest.trigger({
+		"frameName": frameName,
+		"myMapIds": myMapIds.join(",")
+	for(var i=0; i<mb_MapRequestSubFunctions.length; i++){
+		eval(mb_MapRequestSubFunctions[i]);
+function getLayerHtmlCode (frameName, i, ii) {
+	var myDivId = "div_" + ii;
+	var myMapId = "map_" + ii;
+	//disable Layer which are out of scale
+	var validLayers = mb_checkScale(frameName, i, ii);
+	var layerNames = validLayers.toString();
+	var newMapURL = false;
+	var opacityString = "";
+	if (currentMapObject.layers[ii] !== "" && layerNames !== ''){
+		// get map URL
+		newMapURL = currentMapObject.getMapUrl(i, ii);
+		var currentOpacity = currentWms.gui_wms_mapopacity;
+		if (currentOpacity != 1) {
+			opacityString += "opacity:" + currentOpacity + "; ";
+			opacityString += "Filter: Alpha(Opacity=" + currentOpacity*100 + "); ";
+			opacityString += "-moz-opacity:" + currentOpacity + " ; ";
+			opacityString += "-khtml-opacity:" + currentOpacity;
+	var imageString = "<img id='"+myMapId+"' name='mapimage' ";
+	imageString += "src='" + newMapURL + "' ";
+	imageString += "width='"+currentMapObject.width+"' ";
+	imageString += "height='"+currentMapObject.height+"' ";
+	imageString += "border='0'>";
+	var newMapRequest = "<div id='"+myDivId+"' ";
+	newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
+	newMapRequest += "z-index:" + ii + ";" + opacityString + "\">";
+	newMapRequest += imageString;
+	newMapRequest += "</div>";
+	currentMapObject.mapURL[ii]= newMapURL;
+	currentWms.mapURL = newMapURL;
+	if (mb_log && currentWms.mapURL) {
+		var tmp = eval(mb_log + "('" +newMapURL + "','" + ts + "')");
+	return newMapRequest;
+function setSingleMapRequest(frameName,wms_id){
+	var functionName = 'setSingleMapRequest';
+	eventBeforeMapRequest.trigger({frameName:frameName});
+	for(i = 0; i < mb_mapObj.length; i++){
+			continue;
+		for (var ii=0; ii < currentMapObject.wms.length; ii++){
+			if (currentWms.wms_id != wms_id) {
+				continue;
+			var newMapRequest = getLayerHtmlCode(frameName, i, ii);
+			if (mb_log) {
+				var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
+			writeTag(currentMapObject.frameName, myDivId, newMapRequest);
+			eventAfterMapRequest.trigger({"frameName":frameName, "myMapId":myMapId});
+			return true;
+	return false;
+function mb_restateLayers(frameName,wms_id){
+	//alert(frameName + " / " + wms_id);
+	var ind = getMapObjIndexByName(frameName);
+	for(var i=0; i<mb_mapObj[ind].wms.length; i++){
+		if(mb_mapObj[ind].wms[i].wms_id == wms_id){
+			var layers = "";
+			var styles = "";
+			for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
+				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
+					if(cnt_layers > 0){layers += ","; styles += ","; }
+					layers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
+					//alert(mb_mapObj[ind].wms[i].objLayer[ii].layer_name);
+					styles += "";
+					cnt_layers++;
+				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
+					if(cnt_querylayers > 0){querylayers += ",";}
+					querylayers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
+					cnt_querylayers++;
+			mb_mapObj[ind].layers[i] = layers;
+			mb_mapObj[ind].querylayers[i] = querylayers;
+			mb_mapObj[ind].styles[i] = styles;
+function mb_checkScale(frameName,mObj,wmsObj){
+	var thisLayer = mb_mapObj[mObj].layers[wmsObj].split(",");
+	var thisScale = mb_getScale(frameName);
+	var str_layer = "";
+	var cnt_layer = 0;
+	for(var i=0; i<mb_mapObj[mObj].wms[wmsObj].objLayer.length; i++){
+		var myLayername = mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_name;
+		var myMinscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_minscale;
+		var myMaxscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_maxscale;
+		for(var ii=0; ii<thisLayer.length; ii++){
+			var minscaleOK = false;
+			var maxscaleOK = false;
+			if(thisLayer[ii] == myLayername){
+				if(myMinscale === 0 || thisScale >= myMinscale){minscaleOK = true;}
+				if(myMaxscale === 0 || thisScale <= myMaxscale){maxscaleOK = true;}
+				if(maxscaleOK === true && minscaleOK === true  && !mb_mapObj[mObj].wms[wmsObj].objLayer[i].has_childs){
+					if(cnt_layer > 0){str_layer += ","; }//str_styles += ","; str_titles += ",";str_parent += ","; str_legendurls += ",";}
+					str_layer += thisLayer[ii];
+					cnt_layer++;
+	var str_layerstyles = [];
+	str_layerstyles[0] = str_layer;
+	return str_layerstyles;
+function setFeatureInfoRequest(fName,x,y, path) {
+	var functionName = 'setFeatureInfoRequest';
+	eventBeforeFeatureInfo.trigger({"fName":fName});
+	for(var i=0; i<mb_FeatureInfoPreFunctions.length; i++){
+		eval(mb_FeatureInfoPreFunctions[i]);
+	var cnt_fi = 0;
+	for(i=0; i<mb_mapObj.length; i++){
+		if(mb_mapObj[i].frameName == fName){
+			for(var ii=0; ii<mb_mapObj[i].wms.length; ii++){
+				var newfeatureInfoRequest = "";
+				var requestParams = "";
+				var validation = false;
+				newfeatureInfoRequest += mb_mapObj[i].wms[ii].wms_getfeatureinfo;
+            	newfeatureInfoRequest += mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getfeatureinfo);
+				if(mb_mapObj[i].wms[ii].wms_version == "1.0.0"){requestParams += "WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=feature_info&";}
+				if(mb_mapObj[i].wms[ii].wms_version != "1.0.0"){requestParams += "VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetFeatureInfo&SERVICE=WMS&";}
+				requestParams += "SRS="+mb_mapObj[i].epsg+"&";
+				requestParams += "BBOX="+mb_mapObj[i].extent+"&";
+				requestParams += "WIDTH="+mb_mapObj[i].width+"&";
+				requestParams += "HEIGHT="+mb_mapObj[i].height+"&";
+				requestParams += "LAYERS="+mb_mapObj[i].layers[ii]+"&";
+				requestParams += "STYLES="+mb_mapObj[i].styles[ii]+"&";
+				requestParams += "FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";
+				requestParams += "INFO_FORMAT="+mb_mapObj[i].wms[ii].gui_wms_featureinfoformat+"&";
+				requestParams += "EXCEPTIONS=application/vnd.ogc.se_xml&";
+				if(mb_feature_count > 0){
+					requestParams += "FEATURE_COUNT="+mb_feature_count+"&";
+				requestParams += "QUERY_LAYERS="+mb_mapObj[i].querylayers[ii]+"&";
+				requestParams += "X=" + x  + "&";
+				requestParams += "Y=" + y;
+				if(mb_mapObj[i].querylayers[ii] !== "" && mb_mapObj[i].layers[ii] !== ""){
+					validation = true;
+				//add vendor-specific
+				for(var v=0; v < mb_vendorSpecific.length; v++){
+					var vendorSpecificString = eval(mb_vendorSpecific[v]);
+					requestParams += "&" + vendorSpecificString;
+				if(mb_log && validation){
+					var tmp = eval(mb_log + "('" + newfeatureInfoRequest + requestParams + "','" + ts + "')");
+				if(document.getElementById("FeatureInfoRedirect") && validation){
+					newfeatureInfoRequest += requestParams;
+					if(path){
+						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr;
+					else{
+						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = newfeatureInfoRequest;
+					cnt_fi++;
+				else if(path && validation){
+					try{
+						var p = new mb_popup("Feature Info","url:"+path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr,300,400);
+						p.show();
+					}catch(e){
+						window.open(path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
+					cnt_fi++;
+				else if(validation){
+					try{
+						var p = new mb_popup("Feature Info","url:"+newfeatureInfoRequest,300,400);
+						p.show();
+					catch(e){
+						window.open(newfeatureInfoRequest, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
+					cnt_fi++;
+   	if(cnt_fi === 0){
+		alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));
+ * global function to zoom a mapobject
+ * use: mb_mapObj.zoom() {@link mb_mapObj_const#zoom}
+ * @deprecated
+function zoom(frameName,in_, factor,x,y) {
+	var obj = getMapObjByName(frameName);
+	if(x && y){
+		obj.zoom(in_, factor, x, y);
+	else{
+		obj.zoom(in_, factor, false, false);
+	setMapRequest(frameName);
+function mb_panMap(frameName,dir){
+   var arrayBBox = mb_mapObj[ind].extent.split(",");
+   var minx = parseFloat(arrayBBox[0]);
+   var miny = parseFloat(arrayBBox[1]);
+   var maxx = parseFloat(arrayBBox[2]);
+   var maxy = parseFloat(arrayBBox[3]);
+   var xtentx = parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]);
+   var xtenty =  parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]);
+   if(dir == "NW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
+   if(dir == "N"){miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
+   if(dir == "NE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
+   if(dir == "W"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2);}
+   if(dir == "E"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2);}
+   if(dir == "SW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
+   if(dir == "S"){miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
+   if(dir == "SE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
+  mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
+function handleSelectedLayer (frameName, wms_title, layerName, type, status) {
+//	alert(frameName + " , " +wms_title + " , " +layerName + " , " +type + " , " +status);
+//	type = {visible || querylayer] status = {0 || 1}
+	for (var i=0; i < mb_mapObj.length; i++) {
+		if (mb_mapObj[i].frameName == frameName) {
+			var myMapObj = i;
+			for (var ii = 0; ii < mb_mapObj[i].wms.length; ii++) {
+				if (mb_mapObj[i].wms[ii].wms_title == wms_title) { //ii is true
+					var myWMS = ii;
+					if (type == "visible") {
+						var arrayLayer = mb_mapObj[i].layers[ii].split(",");
+					if (type == "querylayer") {
+						var arrayLayer = mb_mapObj[i].querylayers[ii].split(",");
+					for (var iii = 1; iii < mb_mapObj[i].wms[ii].objLayer.length; iii++) {
+						var layer_name = mb_mapObj[i].wms[ii].objLayer[iii].layer_name;
+							if (layer_name == layerName && status == 1 && mb_mapObj[i].wms[ii].objLayer[iii].layer_queryable == 1){
+								if (cnt_layer > 0) {
+									str_layer += ",";
+								str_layer += layer_name;
+								cnt_layer++;
+						else if (type == "visible") {
+							if (layer_name == layerName && status == 1) {
+									str_layer += ",";
+								cnt_layer++;
+						for (var iiii = 0; iiii < arrayLayer.length; iiii++) {
+							if (layer_name == arrayLayer[iiii] && layer_name != layerName) {
+									str_layer += ",";
+								cnt_layer++;
+		mb_mapObj[myMapObj].layers[myWMS] = str_layer;
+		var array_str_layer = str_layer.split(",");
+		var str_styles = "";
+		for (var cnt=0; cnt < array_str_layer.length; cnt++) {
+			if (cnt > 0) {
+				str_styles += ",";
+			str_styles += "";
+		mb_mapObj[myMapObj].styles[myWMS] = str_styles;
+		mb_mapObj[myMapObj].querylayers[myWMS] = str_layer;
+	if(type == 'visible'){
+		setSingleMapRequest(frameName,wms_title);
+function handleSelectedLayer_array(mapObj, array_wms, array_layer, type, status){
+	//alert(mapObj+" / "+array_wms[0]+" / "+ array_layer[0]+" / "+ type+" / "+ status);
+	var ind = getMapObjIndexByName(mapObj);
+	for(var j=0; j<array_wms.length; j++){
+			if(mb_mapObj[ind].wms[i].wms_id == array_wms[j]){
+				var check = false;
+					if(mb_mapObj[ind].wms[i].wms_id == array_wms[j] && mb_mapObj[ind].wms[i].objLayer[ii].layer_name == array_layer[j]){
+						if(type == "visible"){
+							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible = parseInt(status, 10);
+							check = true;
+                        if(type == "querylayer" && (mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == "1" || mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == 1)){
+							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer = parseInt(status, 10);
+                mb_restateLayers(mapObj, array_wms[j]);
+                //alert('restate');
+                * hier noch checken, welche wms sich geaendert haben und disctinct eine singleRequest aufrufen:
+                if(check === true){
+                    if(mb_mapObj[ind].wms[i].gui_wms_visible == 1){
+						setSingleMapRequest(mapObj,mb_mapObj[ind].wms[i].wms_id);
+                        //alert('sSMR');
+function makeClickPos2RealWorldPos(frameName, myClickX, myClickY) {
+	var width = parseInt(mb_mapObj[ind].width, 10);
+	var height = parseInt(mb_mapObj[ind].height, 10);
+	var minX = parseFloat(arrayBBox[0]);
+	var minY = parseFloat(arrayBBox[1]);
+	var maxX = parseFloat(arrayBBox[2]);
+	var maxY = parseFloat(arrayBBox[3]);
+	var deltaX = (maxX - minX)/width;
+	var deltaY = (maxY - minY)/height;
+	if(deltaX > 0){
+		var roundx = 1/Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
+	else{
+		var roundx =  Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
+	if(deltaY > 0){
+		var roundy = 1/Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
+	else{
+		var roundy =  Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
+	var xtentx = maxX - minX;
+	var xtenty =  maxY - minY;
+	var posX = parseFloat(minX + (myClickX / width) * xtentx);
+	var posY = parseFloat(maxY - (myClickY / height) * xtenty);
+	posX = Math.round(posX * roundx)/roundx;
+	posY = Math.round(posY * roundy)/roundy;
+	return [posX, posY];
+function makeRealWorld2mapPos(frameName,rw_posx, rw_posy){
+   var mpObj = mb_mapObj[ind];
+   var arrayBBox = mpObj.extent.split(",");
+   return [Math.round((rw_posx - minX)*mpObj.width/(maxX - minX)), Math.round((maxY - rw_posy)*mpObj.height/(maxY - minY))];
+function mb_arrangeElement(frameName, elName, left, top) {
+   if(frameName !== ""){
+      window.frames[frameName].document.getElementById(elName).style.top = top;
+      window.frames[frameName].document.getElementById(elName).style.left = left;
+   else{
+      document.getElementById(elName).style.top = top;
+      document.getElementById(elName).style.left = left;
+/***********************Drag & Drop***********************/
+function mb_getMousePos(e,fName){
+if(fName){
+     if(ie){
+        clickX = window.frames[fName].event.clientX;
+        clickY = window.frames[fName].event.clientY;
+     else{
+        clickX = e.pageX;
+        clickY = e.pageY;
+  else{
+       if(ie){
+        clickX = event.clientX;
+        clickY = event.clientY;
+     else{
+        clickX = e.pageX;
+        clickY = e.pageY;
+  var pos = [clickX,clickY];
+  return pos;
+// function for object-identification
+function getMapObjIndexByName(frameName){
+		if(mb_mapObj[i].frameName == frameName){
+			return i;
+function getMapObjByName(frameName){
+			return mb_mapObj[i];
+	return false;
+function mb_getLayerTitleByName(map_index, wms_index, myLayer_name){
+	for(var i=0; i<mb_mapObj[map_index].wms[wms_index].objLayer.length; i++){
+		if(mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_name == myLayer_name){
+			return mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_title;
+function getWMSIDByTitle(frameName,wms_title){
+   for(var i=0; i< mb_mapObj[ind].wms.length; i++){
+      if(mb_mapObj[ind].wms[i].wms_title == wms_title){
+         //return i;
+         return mb_mapObj[ind].wms[i].wms_id;
+function getWMSIndexByTitle(frameName,wms_title){
+         return i;
+function getWMSIndexById(frameName,wms_id){
+         return i;
+//scale
+function mb_getScale(frameName) {
+	var myScale = eventBeforeGetScale.trigger({"frameName":frameName});
+   for(var i=0; i<mb_GetScalePreFunctions.length; i++){
+		var myScale = eval(mb_GetScalePreFunctions[i]);
+   if(typeof(myScale) == "number"){
+      var Y_str = myScale;
+   else{
+      var scaleY = (xtenty / mb_mapObj[ind].height) *(mb_resolution * 100);
+      if (scaleY<1){
+      	var Y_str = scaleY;
+      }else{
+      	var Y_str = Math.round(scaleY);
+   return Y_str;
+function mb_repaintScale(frameName, x, y, scale){
+   if(x === null && y === null){
+      x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
+      y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
+   var minx = parseFloat(x) - (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
+   var miny = parseFloat(y) -  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
+   var maxx = parseFloat(x) + (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
+   var maxy = parseFloat(y) +  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
+   mb_repaint(frameName,minx, miny, maxx, maxy);
+function mb_repaint(frameName,minx,miny,maxx,maxy){
+ * converts the extent of the mapobject so that the maximum	extent will be displayed {@link mb_mapObj_const#calculateExtent}
+ * use: mb_mapObj.calculateExtent
+ * @deprecated
+function mb_calculateExtent(frameName,minx,miny,maxx,maxy){
+  var map = getMapObjByName(frameName);
+  var extent = new Extent(minx,miny,maxx,maxy);
+  map.calculateExtent(extent);
+ * @class extent
+ * @param {float} minx
+ * @param {float} miny
+ * @param {float} maxx
+ * @param {float} maxy
+ * @return the extent as object
+ * @type Object
+function Extent(minx,miny,maxx,maxy){
+	this.minx = parseFloat(minx);
+	this.miny = parseFloat(miny);
+	this.maxx = parseFloat(maxx);
+	this.maxy = parseFloat(maxy);
+	this.extentx = this.maxx - this.minx;
+	this.extenty = this.maxy - this.miny;
+	this.centerx = this.minx + this.extentx/2;
+	this.centery = this.miny + this.extenty/2;
+	return this;
+function mb_showHighlight(frameName,x,y){
+   var pos = makeRealWorld2mapPos(frameName,x, y);
+   mb_arrangeElement(frameName,"highlight",pos[0]-7, pos[1]-7);
+   window.frames[frameName].document.getElementById("highlight").style.visibility = 'visible';
+function mb_hideHighlight(frameName){
+   mb_arrangeElement(frameName,"highlight",-20, -20);
+   window.frames[frameName].document.getElementById("highlight").style.visibility = 'hidden';
+function mb_permanentHighlight(frameName,x,y){
+   mb_arrangeElement(frameName,"permanent",pos[0]-7, pos[1]-7);
+   window.frames[frameName].document.getElementById("permanent").style.visibility = 'visible';
+// framename, commaseparated coordinates, commaseparated rgb values (color)
+//new: coords is array!
+function mb_markResult(frameName,geom,col){
+	var x = "";
+	var y = "";
+	var tmp = [];
+	for(var i=0; i < geom.length; i++){
+		if(i > 0){
+			x += ":";
+			y += ":";
+		tmp = geom[i].split(",");
+		for(var ii=0; ii < tmp.length; ii+=2){
+			var pos = makeRealWorld2mapPos(frameName,tmp[ii], tmp[ii+1]);
+			if(ii>0){
+				x += ",";
+				y += ",";
+			x += pos[0];
+			y += pos[1];
+	var source = "<img src='../extensions/markResult.php?x=" + x + "&y=" + y + "&width=" + mb_mapObj[ind].width + "&height=" + mb_mapObj[ind].height + "&color="+col+"'>";
+	//prompt("",source);
+	writeTag(frameName,"markResult",source);
+function mb_disableResult(frameName){
+   writeTag(frameName,"markResult","");
+function mb_registerGML(frameName,obj){
+	mb_mapObj[ind].geom = obj;
+function mb_timestamp(){
+	var d = new Date();
+	var ts = Math.round(Date.parse(d)/1000);
+	return ts;
+function mb_getlayerposbyname(objInd,wmsInd,lname){
+	var t = mb_mapObj[objInd].wms[wmsInd];
+	for(var i=0; i < t.objLayer.length; i++){
+		if(t.objLayer[i].layer_name == lname){
+			return t.objLayer[i].layer_pos;
+function mb_getLayerObjByName(fname,wms_id,layer_name){
+	var ind = getMapObjIndexByName(fname);
+	var wmsInd = getWMSIndexById(fname,wms_id);
+	var t = mb_mapObj[ind].wms[wmsInd];
+		if(t.objLayer[i].layer_name == layer_name){
+			return t.objLayer[i];
+function mb_getchildsbyname(objInd,wmsInd,lname){
+	var pos = mb_getlayerposbyname(objInd, wmsInd,lname);
+	var l = [];
+	l.name = [];
+	l.title = [];
+	l.legendurl = [];
+		if(t.objLayer[i].layer_parent == pos){
+			l.name[l.name.length] = t.objLayer[i].layer_name;
+			l.title[l.title.length] = t.objLayer[i].layer_title;
+			if(t.objLayer[i].layer_style.length>0){
+				l.legendurl[l.legendurl.length] = t.objLayer[i].layer_style[0].legendurl;
+			}else{
+				l.legendurl[l.legendurl.length] = 0 ;
+	if(l.name.length > 0){
+		return l;
+	else{
+		return false;
+ *   button handling
+var mb_button = [];
+function mb_regButton_frame(wii, frameName, param){
+	var ind = mb_button.length;
+	mb_button[ind] = new mb_conButton(wii, ind);
+	if (frameName === null) {
+		if (param === null) {
+			eval(wii+"("+ind+")");
+		else {
+			eval(wii+"("+ind+", "+param+")");
+	else if (param === null) {
+		eval("window.frames['" + frameName + "']."+wii+"("+ind+")");
+	else {
+		eval("window.frames['" + frameName + "']."+wii+"("+ind+", "+param+")");
+	mb_button[ind].prev = mb_button[ind].src;
+	mb_button[ind].src = mb_button[ind].img_off;
+	mb_button[ind].onmouseover = function () {
+		mb_button_over(ind);
+	mb_button[ind].onmouseout = function(){
+		mb_button_out(ind);
+	mb_button[ind].onclick = function(){
+		mb_button_click(ind);
+		mb_button[ind].frameName = "";
+	else {
+		mb_button[ind].frameName = frameName;
+function mb_regButton(wii){
+	mb_regButton_frame(wii, null, null);
+function mb_conButton(wii, ind){
+   this.wii = wii;
+   return true;
+function mb_button_over(ind){
+   if(mb_button[ind].status === 0){
+      mb_button[ind].src = mb_button[ind].img_over;
+function mb_button_out(ind){
+   mb_button[ind].src = mb_button[ind].prev;
+function mb_button_click(ind){
+   var mbStatus = mb_button[ind].status;
+   if(mbStatus === 0){
+      mb_disableButton(mb_button[ind].elName);
+      mb_button[ind].prev = mb_button[ind].img_on;
+      mb_button[ind].src = mb_button[ind].img_on;
+      mb_button[ind].status = 1;
+      if (mb_button[ind].frameName !== "") {
+          window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).go();
+      else {
+	      document.getElementById(mb_button[ind].elName).go();
+   else{
+      mb_button[ind].prev = mb_button[ind].img_off;
+      mb_button[ind].status = 0;
+          window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).stop();
+      else {
+	      document.getElementById(mb_button[ind].elName).stop();
+function mb_disableButton(elName){
+   for(var i=0; i<mb_button.length; i++){
+      if(mb_button[i].elName != elName && mb_button[i].status == 1){
+            mb_button[i].status = 0;
+		      if (mb_button[i].frameName !== "") {
+    	        window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).src = mb_button[i].img_off;
+	            window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).stop();
+		      else {
+    	        document.getElementById(mb_button[i].elName).src = mb_button[i].img_off;
+	            document.getElementById(mb_button[i].elName).stop();
+            return true;
+function mb_disableThisButton(elName){
+      if(mb_button[i].elName == elName && mb_button[i].status == 1){
+      		//alert(mb_button[i].elName);
+		      else {
+            return true;
+function updateButtonTooltips(obj) {
+ * the buttons are only initialized on mouseover!
+ * So when localizing, not all buttons may have been registered
+//		console.log("button %i", i);
+		for(var j=0; j<obj.length; j++){
+			if (mb_button[i].elName == obj[j].id) {
+//			console.log("%s %s", mb_button[i].elName, obj[j].id);
+					window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).title = obj[j].title;
+				else {
+					document.getElementById(mb_button[i].elName).title = obj[j].title;
+	// an alternative, fixes above error,
+	// but this one only changes those in the main frame
+	var imageArray = document.getElementsByTagName("img");
+	for (var i = 0; i < imageArray.length; i++) {
+			if (imageArray[i].id == obj[j].id) {
+				document.getElementById(imageArray[i].id).title = obj[j].title;
+function mb_localizeButtons(){
+	mb_ajax_json("../php/mod_button_tooltips.php", function(obj, status){
+		updateButtonTooltips(obj);
+eventLocalize.register(function () {
+	mb_localizeButtons();
+eventInit.register(function () {
+ *   miscellaneous functions
+function cloneObject(obj) {
+    if (typeof obj !== 'object' || obj === null) {
+        return obj;
+    var c = obj instanceof Array ? [] : {};
+    for (var i in obj) {
+        var prop = obj[i];
+        if (typeof prop == 'object') {
+           if (prop instanceof Array) {
+               c[i] = [];
+               for (var j = 0; j < prop.length; j++) {
+                   if (typeof prop[j] != 'object') {
+                       c[i].push(prop[j]);
+                   } else {
+                       c[i].push(cloneObject(prop[j]));
+           } else {
+               c[i] = cloneObject(prop);
+        } else {
+           c[i] = prop;
+    return c;
+ *   deprecated functions
+// only used in mod_perimeter.php
+// previously used in mod_initWmc.php, mod_digitize_tab.php, mod_geometryArray.js
+function mb_checkTag(frameName, tagName, elementId, appendAtTagName, attributes){
+	var oldElement;
+	var newElement;
+	var prefix;
+	if(frameName && frameName !== ""){
+		prefix = window.frames[frameName].document;
+	else if(!frameName || frameName === ""){
+		prefix = document;
+	oldElement = prefix.getElementById(elementId);
+	if (oldElement === null) {
+		newElement = prefix.createElement(tagName);
+		newElement = prefix.getElementsByTagName(appendAtTagName)[0].appendChild(newElement);
+	else {
+		if (oldElement.nodeName.toLowerCase() == tagName.toLowerCase()) {
+			for (var i=0; i<attributes.length; i++) {
+				oldElement.setAttribute(attributes[i][0], attributes[i][1]);
+			return oldElement;
+		else {
+			return false;
+	var newElementAttributeNode = document.createAttribute("id");
+	newElementAttributeNode.value = elementId;
+	newElement.setAttributeNode(newElementAttributeNode);
+		newElement.setAttribute(attributes[i][0], attributes[i][1]);
+	return newElement;
\ No newline at end of file
Copied: branches/beck_dev/mapbender/lib/point.js (from rev 2450, branches/beck_dev/mapbender/http/javascripts/point.js)
--- branches/beck_dev/mapbender/lib/point.js	                        (rev 0)
+++ branches/beck_dev/mapbender/lib/point.js	2008-05-28 15:03:41 UTC (rev 2476)
@@ -0,0 +1,192 @@
+* $Id$
+* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
+* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
+//http://www.mapbender.org/index.php/point.js
+ * @class A class representing a two-dimensional point.
+ * @constructor
+ * @param {Float} x x value of the {@link Point}
+ * @param {Float} y y value of the {@link Point}
+ function Point(x, y, z){
+ 	 * x value of the {@link Point}
+	 * @type Float
+//	this.x = parseFloat(x);
+	this.x = x;
+ 	 * y value of the {@link Point}
+	 * @type Float
+//	this.y = parseFloat(y);
+	this.y = y;
+	this.z = z;
+ * computes the distance between a {@link Point} p and this {@link Point}
+ * @param {Point} p the distance between this {@link Point} and the {@link Point} p is computed.
+ * @return {Float} the distance between the two {@link Point} objects.
+Point.prototype.dist = function(p){
+	return Math.sqrt(Math.pow(this.y-p.y,2) + Math.pow(this.x-p.x,2)) ;
+ * checks if the coordinates of this {@link Point} match the coordinates of a {@link Point} p
+ * @return {Boolean} true if the two points are equal; elso false
+Point.prototype.equals = function(p){
+	if (this.x == p.x && this.y == p.y) {return true;}
+	return false;
+ * subtracts a {@link Point} p from this {@link Point}
+ * @return a new {@link Point} with the difference of the two points
+Point.prototype.minus = function(p){
+	return new Point(this.x-p.x, this.y-p.y);
+ * adds this {@link Point} to a {@link Point} p
+ * @return a new {@link Point} with the sum of the two points
+Point.prototype.plus = function(p){
+	return new Point(this.x+p.x, this.y+p.y);
+ * divides this {@link Point} by a scalar c
+ * @param {Float} c divisor
+ * @return a new {@link Point} divided by c
+Point.prototype.dividedBy = function(c){
+	if (c !== 0) {
+		return new Point(this.x/c, this.y/c);
+	var e = new Mb_exception("Point.dividedBy: Division by zero");
+	return false;
+ * multiplies this {@link Point} by a scalar c
+ * @param {Float} c factor
+ * @return a new {@link Point} multiplied by c
+Point.prototype.times = function(c){
+	return new Point(this.x*c, this.y*c);
+ * rounds the coordinates to numOfDigits digits
+ * @param numOfDigits the coordinate will be rounded to numOfDigits digits
+ * @return a new {@link Point} rounded to numOfDigits digits
+ * @type Point
+Point.prototype.round = function(numOfDigits){
+	return new Point(roundToDigits(this.x, numOfDigits), roundToDigits(this.y, numOfDigits));
+ * @returns a {String} representation of this Point
+ * @type String
+Point.prototype.toString = function(){
+	if (typeof(this.z == "undefined")) {
+		return "[" + this.x + ", " + this.y + "]";
+	else {
+		return "[" + this.x + ", " + this.y + ", " + this.z + "]";
+// possible improvement: point has flag: map OR real. additional functions: toReal, toMap
+ * @ignore
+function mapToReal(frameName, aPoint){
+	var v;
+	if (typeof(mb_mapObj) == 'object') {
+		v = makeClickPos2RealWorldPos(frameName, aPoint.x, aPoint.y);
+	else {
+		if (typeof(parent.mb_mapObj) == 'object') {
+			v = parent.makeClickPos2RealWorldPos(frameName, aPoint.x, aPoint.y);
+		else {
+			alert('where am i?');
+	return new Point(v[0], v[1]);
+ * @ignore
+function realToMap(frameName, aPoint) {
+	var v;
+		v = makeRealWorld2mapPos(frameName, aPoint.x, aPoint.y);
+	else if (typeof(parent.mb_mapObj) == 'object') {
+		v = parent.makeRealWorld2mapPos(frameName, aPoint.x, aPoint.y);
+	else {
+		var e = new Mb_exception('Point.realToMap:where am i?');
+ * @ignore
+function mb_calcExtent(frameName, min, max) {
+	var ind;
+		ind = getMapObjIndexByName(frameName);
+		ind = parent.getMapObjIndexByName(frameName);
+	else {
+		var e = new Mb_exception('Point.mb_calcExtent: function getMapObjIndexByName not found');
+	var extent = max.minus(min);
+	var center = extent.dividedBy(2).plus(min);
+	var relation_px_x = mb_mapObj[ind].width / mb_mapObj[ind].height;
+	var relation_px_y = mb_mapObj[ind].height / mb_mapObj[ind].width;
+	var relation_bbox_x = extent.x / extent.y;
+	var new_min;
+	var new_max;
+		new_min = new Point(center.x - relation_px_x * extent.y / 2, min.y);
+		new_max = new Point(center.x + relation_px_x * extent.y / 2, max.y);
+	else if(relation_bbox_x > relation_px_x){
+		new_min = new Point(min.x, center.y - relation_px_y * extent.x / 2);
+		new_max = new Point(max.x, center.y + relation_px_y * extent.x / 2);
+	mb_mapObj[ind].extent = new_min.x +","+ new_min.y +","+ new_max.x  +","+ new_max.y;
+ * @ignore
+function roundToDigits(aFloat, numberOfDigits) {
+	return Math.round(aFloat*Math.pow(10, parseInt(numberOfDigits, 10)))/Math.pow(10, parseInt(numberOfDigits, 10));
Copied: branches/beck_dev/mapbender/lib/style.js (from rev 2450, branches/beck_dev/mapbender/http/javascripts/style.js)
--- branches/beck_dev/mapbender/lib/style.js	                        (rev 0)
+++ branches/beck_dev/mapbender/lib/style.js	2008-05-28 15:03:41 UTC (rev 2476)
@@ -0,0 +1,54 @@
+ * creates a style tag in the head of the document.
+var StyleTag = function() {
+	 * Creates the style tag in the head of the document. Something like a constructor.
+	var createStyleTag = function() {
+		// TODO: Internet Explorer routine seems a little buggy
+		if (top.ie) {
+			// create a Style Sheet object (IE only)
+			//styleSheetObj=document.createStyleSheet();
+			// get the DOM node of the style sheet object, set the type
+			//styleObj=styleSheetObj.owningElement || styleSheetObj.ownerNode;
+			//styleObj.setAttribute("type","text/css");
+			// alternative way for IE: take existing styleSheet with index 0 instead of creating a new one
+			styleSheetObj=document.styleSheets[0];
+		else {
+			// create the style node, set the style
+			styleObj=document.createElement("style");
+			styleObj.setAttribute("type","text/css");
+			// append the node to the head
+			document.getElementsByTagName("head")[0].appendChild(styleObj);
+	 * Adds a class className with the CSS in cssString
+	this.addClass = function(className,cssString) {
+		if (top.ie) {
+			//add new style declaration to chosen styleSheet
+			var cssRules = cssString.split(";");
+			for (i=0; i<cssRules.length-1; i++){
+				styleSheetObj.addRule("."+className,cssRules[i]);
+		else {
+			// insert the content via createTextNode
+			styleObj.appendChild(document.createTextNode("."+className+"{\n\t"+cssString+"\n}\n"));
+	var styleObj;
+	var styleSheetObj; //IE only...
+	createStyleTag();
Copied: branches/beck_dev/mapbender/lib/wfs_obj.js (from rev 2450, branches/beck_dev/mapbender/http/javascripts/wfs_obj.js)
--- branches/beck_dev/mapbender/lib/wfs_obj.js	                        (rev 0)
+++ branches/beck_dev/mapbender/lib/wfs_obj.js	2008-05-28 15:03:41 UTC (rev 2476)
@@ -0,0 +1,75 @@
+//$Id$
+//$Header: /cvsroot/mapbender/mapbender/http/javascripts/wfs_obj.js,v 1.3 2005/09/13 14:38:11 bjoern_heuser Exp $
+//global variables
+var wfs = [];
+var wfs_featuretype_count = 0;
+var wfs_element_count = 0;
+//list of all wms-objects
+function add_wfs(
+			wfs_id,
+			wfs_version,
+			wfs_title,
+			wfs_abstract,
+			wfs_getcapabilities,
+			wfs_describefeaturetype){
+					wfs[wfs.length] = new wfs_const(
+					wfs_id,
+			      wfs_version,
+			      wfs_title,
+			      wfs_abstract,
+			      wfs_describefeaturetype);
+					//wfs_featuretype[wfs.length - 1] = [];
+//the wms constructor
+function wfs_const(
+			wfs_id,
+			wfs_version,
+			wfs_title,
+			wfs_abstract,
+	this.wfs_id = wfs_id;
+	this.wfs_version = wfs_version;
+	this.wfs_title = wfs_title;
+	this.wfs_abstract = wfs_abstract;
+	this.wfs_getcapabilities = wfs_getcapabilities;
+	this.wfs_describefeaturetype = wfs_describefeaturetype;
+	this.wfs_featuretype = [];
+   //alert(wfs_id + " , " +wfs_title + " , " +wfs_abstract + " , " +wfs_getcapabilities + " , " +wfs_describefeaturetype);
+//featuretype
+function wfs_add_featuretype(
+			featuretype_name,
+			featuretype_title,
+			featuretype_srs,
+			featuretype_geomtype){
+	      wfs[wfs.length-1].wfs_featuretype[wfs[wfs.length-1].wfs_featuretype.length] = new featuretype(
+											featuretype_name,
+											featuretype_srs,
+											featuretype_geomtype);
+//alert(featuretype_name + " , " +featuretype_title + " , " +featuretype_srs + " , " +featuretype_geomtype);
+function featuretype(
+			featuretype_name,
+			featuretype_srs,
+	this.featuretype_name = featuretype_name;
+	this.featuretype_title = featuretype_title;
+	this.featuretype_srs = featuretype_srs;
+	this.featuretype_geomtype = featuretype_geomtype;
+	this.element = [];
+	wfs_featuretype_count++;
+//elements
+function wfs_add_featuretype_element(element_name, element_type, element_count, featuretype_count){
+	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count] = [];
+	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].name = element_name;
+	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].type = element_type;
+   //alert(element_name +" , "+element_type);
More information about the Mapbender_commits mailing list
