[Mapbender-commits] r3235 - in trunk/mapbender/http: classes javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Nov 12 09:24:30 EST 2008
Author: christoph
Date: 2008-11-12 09:24:29 -0500 (Wed, 12 Nov 2008)
New Revision: 3235
   trunk/mapbender/http/classes/class_gml2.php
   trunk/mapbender/http/javascripts/geometry.js
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
   trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php
   trunk/mapbender/http/javascripts/wfs.js
   trunk/mapbender/http/php/mod_wfs_result.php
http://trac.osgeo.org/mapbender/ticket/305
Modified: trunk/mapbender/http/classes/class_gml2.php
--- trunk/mapbender/http/classes/class_gml2.php	2008-11-12 14:14:56 UTC (rev 3234)
+++ trunk/mapbender/http/classes/class_gml2.php	2008-11-12 14:24:29 UTC (rev 3235)
@@ -16,8 +16,8 @@
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 require_once(dirname(__FILE__)."/../classes/class_connector.php");
 require_once(dirname(__FILE__)."/../classes/class_json.php");
@@ -56,7 +56,7 @@
 	function parseXML($data) {
-		$this->doc = $data;
+		$this->doc = $this->removeWhiteSpace($data);
 		return $this->toGeoJSON();
@@ -78,6 +78,7 @@
 		$gmlDoc = new SimpleXMLElement($this->doc);
 		$gmlDoc->registerXPathNamespace('xls', 'http://www.opengis.net/xls');
+		$gmlDoc->registerXPathNamespace('wfs', 'http://www.opengis.net/wfs');
 		$gmlDoc->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
 		// build feature collection
@@ -102,7 +103,7 @@
 			return $featureCollection->toGeoJSON();
 		else{
-			return "{'errorMessage':'Kein Ergebnis'}";
+			return "{}";
@@ -646,6 +647,7 @@
 class GMLPolygon {
 	var $pointArray = array();
+	var $innerRingArray = array();
 	public function __construct() {
@@ -675,13 +677,38 @@
 			$cnt++;
+		$innerRingNodeArray = $simpleXMLNode->xpath("gml:innerBoundaryIs/gml:LinearRing");
+		if ($innerRingNodeArray) {
+			$ringCount = 0;
+			foreach ($innerRingNodeArray as $ringNode) {
+				$coordinates = $ringNode->xpath("gml:coordinates");
+				foreach ($coordinates as $coordinate) {
+					$coordsDom = dom_import_simplexml($coordinate);
+					foreach(explode(' ',$coordsDom->nodeValue) as $pointCoords){
+						list($x,$y,$z) = explode(',',$pointCoords);
+						$this->addPointToRing($ringCount, $x, $y);
+				$ringCount++;
 	protected function addPoint ($x, $y) {
 		array_push($this->pointArray, array("x" => $x, "y" => $y));
+	protected function addPointToRing ($i, $x, $y) {
+		if (count($this->innerRingArray) <= $i) {
+			array_push($this->innerRingArray, array());
+		$index = count($this->innerRingIndex);
+		$currentIndex = ($i < $index ? $i : $index);
+		array_push($this->innerRingArray[$currentIndex], array("x" => $x, "y" => $y));
 	public function toGeoJSON () {
 		$numberOfPoints = count($this->pointArray);
 		$str = "";
@@ -693,7 +720,19 @@
 				$str .= "[".$this->pointArray[$i]["x"].",".$this->pointArray[$i]["y"]."]";
-			$str .= "]]}";
+			$str .= "]";
+			for ($i=0; $i < count($this->innerRingArray); $i++) {
+				$str .= ",[";
+				for ($j=0; $j < count($this->innerRingArray[$i]); $j++) {
+					if ($j > 0) {
+						$str .= ",";
+					$str .= "[".$this->innerRingArray[$i][$j]["x"].",".$this->innerRingArray[$i][$j]["y"]."]";
+				$str .= "]";
+			$str .= "]}";
 		else {
 			$e = new mb_exception("GMLPolygon: toGeoJSON: this point is null.");
@@ -762,7 +801,6 @@
 	protected function addPoint ($x, $y, $i) {
 		array_push($this->lineArray[$i], array("x" => $x, "y" => $y));
@@ -799,38 +837,68 @@
 class GMLMultiPolygon {
 	var $polygonArray = array();
+	protected function addPointToRing ($i, $j, $x, $y) {
+		if (count($this->innerRingArray[$i]) <= $j) {
+			array_push($this->innerRingArray[$i], array());
+		array_push($this->innerRingArray[$i][$j], array("x" => $x, "y" => $y));
 	public function parseMultiPolygon ($domNode) {
 //		echo $domNode->nodeName."<br>";
 		$simpleXMLNode = simplexml_import_dom($domNode);
 		$simpleXMLNode->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
-		$allCoords = $simpleXMLNode->xpath("gml:polygonMember/gml:Polygon/gml:outerBoundaryIs/gml:LinearRing/gml:coordinates");
+		$allPolygons = $simpleXMLNode->xpath("gml:polygonMember/gml:Polygon");
 		$cnt=0;
-		foreach ($allCoords as $Coords) {
+		foreach ($allPolygons as $polygon) {
+			$allCoords = $polygon->xpath("gml:outerBoundaryIs/gml:LinearRing/gml:coordinates");
 			$this->polygonArray[$cnt] = array();
+			foreach ($allCoords as $Coords) {
+				$coordsDom = dom_import_simplexml($Coords);
+				foreach (explode(' ',$coordsDom->nodeValue) as $pointCoords) {
+					$this->addPoint($x, $y, $cnt);
-			$coordsDom = dom_import_simplexml($Coords);
+			$this->innerRingArray[$cnt] = array();
+			$innerRingNodeArray = $polygon->xpath("gml:innerBoundaryIs");
+				$ringCount = 0;
+					$currentRingNode = $ringNode->xpath("gml:LinearRing");
+					foreach ($currentRingNode as $node) {
+						$coordinates = $node->xpath("gml:coordinates");
-//			$name = $coordsDom->nodeName;
-//			$value = $coordsDom->nodeValue;
-//			echo "===> name: ".$name. ", Value: ".$value."<br>";
-			foreach(explode(' ',$coordsDom->nodeValue) as $pointCoords){
-				list($x,$y,$z) = explode(',',$pointCoords);
-				$this->addPoint($x, $y, $cnt);
+								$this->addPointToRing($cnt, $ringCount, $x, $y);
+						$ringCount++;
 			$cnt++;
+			new mb_exception("create multipolygon " . serialize($this->innerRingArray));
@@ -846,17 +914,30 @@
 			for ($cnt =0; $cnt < $numberPolygonArray; $cnt++){
 				if ($cnt > 0) {
-						$str .= ",";
-					$str .="[";
+					$str .= ",";
+				$str .= "[";
+				$str .= "[";
 				for ($i=0; $i < count($this->polygonArray[$cnt]); $i++) {
 					if ($i > 0) {
 						$str .= ",";
 					$str .= "[".$this->polygonArray[$cnt][$i]["x"].",".$this->polygonArray[$cnt][$i]["y"]."]";
-				$str .="]";
+				$str .= "]";
+				for ($i=0; $i < count($this->innerRingArray[$cnt]); $i++) {
+					$str .= ",[";
+					for ($j=0; $j < count($this->innerRingArray[$cnt][$i]); $j++) {
+						if ($j > 0) {
+							$str .= ",";
+						$str .= "[".$this->innerRingArray[$cnt][$i][$j]["x"].",".$this->innerRingArray[$cnt][$i][$j]["y"]."]";
+					$str .= "]";
+				$str .= "]";
 			$str .= "]}";
Modified: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js	2008-11-12 14:14:56 UTC (rev 3234)
+++ trunk/mapbender/http/javascripts/geometry.js	2008-11-12 14:24:29 UTC (rev 3235)
@@ -310,171 +310,153 @@
 GeometryArray.prototype.importGeoJSON = function (geoJSON) {
-	var isFeatureCollection = false;
-	var featureCollectionEpsg = 4326;
-	var featureEpsg = 4326;
+	// you can pass either geoJSON or the evaluated geoJSON string
+	// for backwards compatibility
+	if (typeof(geoJSON) == 'string') {
+		var geoJSON = eval('(' + geoJSON + ')');
+	var featureCollectionEpsg = (geoJSON.crs && geoJSON.crs.type == "EPSG") ? geoJSON.crs.properties.code : 4326;
+	var featureEpsg = (geoJSON.crs && geoJSON.crs.type == "EPSG") ? geoJSON.crs.properties.code : 4326;
 	// FEATURE COLLECTION
-	for (var i in geoJSON) {
-		if (typeof(geoJSON[i]) != "function") {
-			switch (i) {
-				case "type":
-					isFeatureCollection = (geoJSON[i] == "FeatureCollection") ? true : false;
-					break;
-				case "crs":
-					if (geoJSON[i].type == "EPSG") {
-						featureCollectionEpsg = geoJSON[i].properties.code;
-						featureEpsg = geoJSON[i].properties.code;
-					break;
-				case "features":
-					if (isFeatureCollection) {
+	var isFeatureCollection = (geoJSON.type == "FeatureCollection") ? true : false;
+	if (isFeatureCollection) {
+		// FEATURE
+		var featureArray = geoJSON.features;
+		for (var j = 0; j < featureArray.length; j++) {
+			featureEpsg = featureCollectionEpsg;
+			var currentFeature = featureArray[j];
+			var isFeature = (currentFeature.type == "Feature") ? true : false;
+			// add geometry ...
+			if (currentFeature.geometry && isFeature) {
+				// GEOMETRY
+				var currentGeometry = currentFeature.geometry;
+				var geometrytype = currentGeometry.type;
+				var coordinates = currentGeometry.coordinates;
+				switch (geometrytype) {
+					case "Point":
-						// FEATURE
+						// POINT
-						var featureArray = geoJSON[i];
-						for (var j = 0; j < featureArray.length; j++) {
-							featureEpsg = featureCollectionEpsg;
-							var currentFeature = featureArray[j];
-							var isFeature = false;
-							for (var k in currentFeature) {
-								if (typeof(currentFeature[k]) != "function") {
-									var geometrytype;
-									switch(k) {
-										case "type":
-											isFeature = (currentFeature[k] == "Feature") ? true : false;
-											break;
-										case "properties":
-											var properties = currentFeature[k];
-											// GeometryCollections are NOT YET IMPLEMENTED
-											if (geometrytype != "GeometryCollection") {
-												for (var l in properties) {
-													if (typeof(properties[l]) != "function") {
-														this.get(-1).e.setElement(l, properties[l]);
-											break;
-										case "crs":
-											if (currentFeature[k].type == "EPSG") {
-												featureEpsg = currentFeature[k].properties.code;
-											break;
-										case "geometry":
-											if (isFeature) {
-												// GEOMETRY
-												var currentGeometry = currentFeature[k];
-												for (var l in currentGeometry) {
-													if (typeof(currentGeometry[l]) != "function") {
-														switch (l) {
-															case "type":
-																geometrytype = currentGeometry[l];
-																break;
-															case "coordinates":
-																var coordinates = currentGeometry[l];
-																switch (geometrytype) {
-																	case "Point":
-																		// POINT
-																		this.addMember(geomType.point);
-																		this.get(-1).addGeometry();
-																		this.getGeometry(-1,-1).addPointByCoordinates(coordinates[0], coordinates[1], coordinates[2]);
-																		this.getGeometry(-1,-1).setEpsg(featureEpsg);
-																		this.close();
-																		break;
-																	case "LineString":
-																		// LINESTRING
-																		this.addMember(geomType.line);
-																		for (var m = 0; m < coordinates.length; m++) {
-																			var currentPoint = coordinates[m];
-																			this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0], currentPoint[1], currentPoint[2]);
-																		this.close();
-																		break;
-																	case "MultiLineString":
-																		// MULTILINESTRING
-																			var currentLine = coordinates[m];
-																			for (var n = 0; n < currentLine.length; n++) {
-																				var currentPoint = currentLine[n];
-																		this.close();
-																		break;
-																	case "Polygon":
-																		// POLYGON
-																		this.addMember(geomType.polygon);
-																			var currentPolygon = coordinates[m];
-																			for (var n = 0; n < currentPolygon.length; n++) {
-																				var currentPoint = currentPolygon[n];
-																		this.close();
-																		break;
-																	case "MultiPolygon":
-																		// MULTIPOLYGON
-																		this.close();
-																		break;
-																	case "GeometryCollection":
-																		var exc = new Mb_exception("Geometry: GeometryCollections are not yet supported");
-																		break;
+						this.addMember(geomType.point);
+						this.get(-1).addGeometry();
+						this.getGeometry(-1,-1).addPointByCoordinates(coordinates[0], coordinates[1], coordinates[2]);
+						this.getGeometry(-1,-1).setEpsg(featureEpsg);
+						this.close();
+						break;
+					case "LineString":
+						// LINESTRING
+						this.addMember(geomType.line);
+						for (var m = 0; m < coordinates.length; m++) {
+							var currentPoint = coordinates[m];
+							this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0], currentPoint[1], currentPoint[2]);
+						this.close();
+						break;
+					case "MultiLineString":
+						// MULTILINESTRING
+							var currentLine = coordinates[m];
+							for (var n = 0; n < currentLine.length; n++) {
+								var currentPoint = currentLine[n];
+						this.close();
+						break;
+					case "Polygon":
+						// POLYGON
+						this.addMember(geomType.polygon);
+							var currentPolygon = coordinates[m];
+							for (var n = 0; n < currentPolygon.length; n++) {
+								var currentPoint = currentPolygon[n];
+						this.close();
+						break;
+					case "MultiPolygon":
+						// MULTIPOLYGON
+								var currentRing = currentPolygon[n];
+								if (n == 0) {
+									for (var p = 0; p < currentRing.length; p++) {
+										var currentPoint = currentRing[p];
+										this.getGeometry(-1, -1).addPointByCoordinates(currentPoint[0], currentPoint[1], currentPoint[2]);
+								else {
+									var ring = new Geometry(geomType.polygon);
+										ring.addPointByCoordinates(currentPoint[0], currentPoint[1], currentPoint[2]);
+									ring.close();
+									this.getGeometry(-1,-1).addInnerRing(ring);
+						this.close();
+						break;
+					case "GeometryCollection":
+						var exc = new Mb_exception("Geometry: GeometryCollections are not yet supported");
+						break;
+			if (currentFeature.properties) {
+				var properties = currentFeature.properties;
+				// GeometryCollections are NOT YET IMPLEMENTED
+				if (geometrytype != "GeometryCollection") {
+					for (var l in properties) {
+						if (typeof(properties[l]) != "function") {
+							this.get(-1).e.setElement(l, properties[l]);
+					this.get(-1).e.setElement("fid", currentFeature.id);
+			if (currentFeature.crs) {
+				if (currentFeature.crs.type == "EPSG") {
+					featureEpsg = currentFeature.crs.properties.code;
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2008-11-12 14:14:56 UTC (rev 3234)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2008-11-12 14:24:29 UTC (rev 3235)
@@ -802,8 +802,10 @@
 			parent.mb_ajax_post("../php/mod_digitize_splitPolygon.php", {polygon: polygonText, line: lineText}, function(json, status) {
 				var response = eval('(' + json + ')');
 				var polygonArray = response.polygons;
+				var wfsConfId = d.get(0).wfs_conf;
 				for (var i in polygonArray) {
 					d.importGeometryFromText(polygonArray[i]);
+					d.get(-1).wfs_conf = wfsConfId;
 				parent.mb_disableThisButton(button_split);
@@ -824,8 +826,12 @@
 			parent.mb_ajax_post("../php/mod_digitize_differencePolygon.php", {polygon1: polygon1Text, polygon2: polygon2Text}, function(json, status) {
+				var wfsProperties = d.get(0).e;
+					d.get(-1).e = wfsProperties;
 				parent.mb_disableThisButton(button_difference);
Modified: trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php
--- trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php	2008-11-12 14:14:56 UTC (rev 3234)
+++ trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php	2008-11-12 14:24:29 UTC (rev 3235)
@@ -603,15 +603,14 @@
 function mb_get_geom(url, filter, index, typename, js_wfs_conf_id, db_wfs_conf_id) {
-	mb_ajax_post("../" + wfsResultModulePath + wfsResultModuleFilename,{'url':url,'filter':filter,'typename':typename,'js_wfs_conf_id':js_wfs_conf_id, 'db_wfs_conf_id':db_wfs_conf_id},function(js_code,status){
-		if (js_code) {
-			eval(js_code);
+	mb_ajax_post("../" + wfsResultModulePath + wfsResultModuleFilename,{'url':url,'filter':filter,'typename':typename,'js_wfs_conf_id':js_wfs_conf_id, 'db_wfs_conf_id':db_wfs_conf_id},function(json,status){
+		var geom = new GeometryArray();
+		geom.importGeoJSON(json);
+		for (var i = 0; i < geom.count(); i++) {
+			geom.get(i).wfs_conf = js_wfs_conf_id;
-		if (typeof(geom) == "undefined") {
-			var geom = new GeometryArray();
 		checkIfAllAjaxCallsFinished(geom);
-//		prompt('', js_code);
@@ -623,7 +622,6 @@
 	if (numberOfFinishedAjaxCalls == numberOfAjaxCalls) {
 		numberOfFinishedAjaxCalls = 0;
 		mb_execWfsReadSubFunctions(_geomArray);
Modified: trunk/mapbender/http/javascripts/wfs.js
--- trunk/mapbender/http/javascripts/wfs.js	2008-11-12 14:14:56 UTC (rev 3234)
+++ trunk/mapbender/http/javascripts/wfs.js	2008-11-12 14:24:29 UTC (rev 3235)
@@ -341,7 +341,6 @@
 function get_wfs_str(myconf, d, m, type, fid) {
-	<!-- Getting the Namspace for the FeautureType -->
 	var featureTypeArray = myconf['featuretype_name'].split(':')
 	var featureNS = featureTypeArray[0];
@@ -420,13 +419,34 @@
 		if(d.get(m).geomType == geomType.polygon){
 			str += '<gml:MultiPolygon srsName="' + myconf['featuretype_srs'] + '">';
-			str += '<gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>';
+			for (var k = 0; k < d.get(m).count(); k++) {
+				str += '<gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>';
+				for(var l = 0; l < d.getGeometry(m, k).count(); l++){
+					if (l > 0) {
+						str += " ";
+					str += d.getPoint(m,k,l).x + "," + d.getPoint(m,k,l).y;
-			for(var k=0; k<d.getGeometry(m,0).count(); k++){
-				if(k>0)	str += " ";
-				str += d.getPoint(m,0,k).x + "," + d.getPoint(m,0,k).y;
+				str += '</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>';
+				if (d.getGeometry(m, k).innerRings) {
+					for(var ii = 0; ii < d.getGeometry(m, k).innerRings.count(); ii++){
+						str += '<gml:innerBoundaryIs><gml:LinearRing><gml:coordinates>';
+						for(var l = 0; l < d.getGeometry(m, k).innerRings.get(ii).count(); l++){
+							if (l > 0) {
+								str += " ";
+							str += d.getPoint(m,k,ii,l).x + "," + d.getPoint(m,k,ii,l).y;
+						str += '</gml:coordinates></gml:LinearRing></gml:innerBoundaryIs>';
+				str += '</gml:Polygon></gml:polygonMember>';
-			str += '</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon>';
+			str += '</gml:MultiPolygon>';
 		str += '</' + el_geom + '></'+ myconf['featuretype_name']+'></wfs:Insert>';
@@ -466,13 +486,29 @@
+			for (var l = 0; l < d.get(m).count(); l++) {
+				for(var k=0; k<d.getGeometry(m,l).count(); k++){
+					if(k>0)	str += " ";
+					str += d.getPoint(m,l,k).x + "," + d.getPoint(m,l,k).y;
+				if (d.getGeometry(m, l).innerRings) {
+					for(var ii = 0; ii < d.getGeometry(m, l).innerRings.count(); ii++){
+						for(var p = 0; p < d.getGeometry(m, l).innerRings.get(ii).count(); p++){
+							if (p > 0) {
+								str += " ";
+							str += d.getPoint(m,l,ii,p).x + "," + d.getPoint(m,l,ii,p).y;
 		str += '</wfs:Value></wfs:Property>';
 		str += '<ogc:Filter><ogc:FeatureId fid="'+fid+'"/></ogc:Filter>';
 		str += '</wfs:Update>';
@@ -493,4 +529,4 @@
 	str += '</wfs:Transaction>';
 	return str;
\ No newline at end of file
Modified: trunk/mapbender/http/php/mod_wfs_result.php
--- trunk/mapbender/http/php/mod_wfs_result.php	2008-11-12 14:14:56 UTC (rev 3234)
+++ trunk/mapbender/http/php/mod_wfs_result.php	2008-11-12 14:24:29 UTC (rev 3235)
@@ -20,10 +20,10 @@
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
 require_once(dirname(__FILE__) . "/../classes/class_stripRequest.php");
 require_once(dirname(__FILE__) . "/../classes/class_connector.php");
+require_once(dirname(__FILE__) . "/../classes/class_gml2.php");
 $filter = stripslashes($_REQUEST["filter"]);
 $url = stripslashes($_REQUEST["url"]);
-$js_wfs_conf_id = $_REQUEST["js_wfs_conf_id"];
 $db_wfs_conf_id = $_REQUEST["db_wfs_conf_id"];
 $typename = $_REQUEST["typename"];
@@ -86,105 +86,11 @@
 $wfsRequest = $url . urlencode($filter);
 $connection = new connector($wfsRequest);
 $data = $connection->file;
-if (!$data) die('wfs not available');
+if (!$data) die('{}');
-$geometries = array('Point', 'Polygon', 'LineString', 'MultiPolygon', 'MultiLineString');
+$wfsResult = new gml2 ();
+$geoJson = $wfsResult->parseXML($data);
-//TODO:
-// parsing via class_gml
-// add method toJSON to classGML
-$parser = xml_parser_create();
-xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
-xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
-xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
-xml_parse_into_struct($parser,$data,$values,$tags);
-xml_parser_free($parser);
-$member = -1;
-$section = false;
-$geom = false;
-$memberHasBeenCreated = false;
-$str = array();
-$geomtype = array();
-$el = -1;
-$fid = -1;
-$element_str = "";
-$geom_str = "";
-foreach ($values as $element) {
-	if(mb_strtoupper($element[tag]) == mb_strtoupper("gml:featureMember") && $element[type] == "open"){
-		$member++;
-		$section = true;
-		$cnt_geom = 0;
-	else if(mb_strtoupper($element[tag]) == mb_strtoupper($typename) && $element[type] == "open") {
-		$fid = $element[attributes][fid];
-	else if(in_array(sepNameSpace($element[tag]),$geometries) && $element[type] == "open" && $section == true){
-		$geom = true;
-		if (sepNameSpace($element[tag]) == "MultiLineString") {
-			$geom_str .= "geom.addMember(geomType.line);\n";
-			$memberHasBeenCreated = true;
-		else if (sepNameSpace($element[tag]) == "MultiPolygon" ) {
-			$geom_str .= "geom.addMember(geomType.polygon);\n";
-		elseif (sepNameSpace($element[tag]) == "Point") {
-			$geom_str .= "geom.addMember(geomType.point);\n";
-			$geom_str .= "geom.get(-1).addGeometry();\n";
-		elseif (sepNameSpace($element[tag]) == "LineString") {
-			if (!$memberHasBeenCreated) {
-		else if (sepNameSpace($element[tag]) == "Polygon" ) {
-		else {
-			$geom_str .= "alert('unknown geomtype ".sepNameSpace($element[tag])."');";
-		// TO DO: the following is added twice! Once suffices.
-		$element_str .= "geom.get(" . $member . ").e.setElement('fid', '".$fid."');\n";
-		$element_str .= "geom.get(" . $member . ").wfs_conf = ".$js_wfs_conf_id.";\n";
-	else if(mb_strtoupper($element[tag]) == mb_strtoupper("gml:coordinates") && $geom == true){
-		$tmp =  preg_replace("/,,/","",preg_replace("/ /",",",trim($element[value])));
-		$geom_str .= "var tmp1 = '".$tmp."';\n";
-		$geom_str .= "var tmp = tmp1.split(',');\n";
-		$geom_str .= "for (var i = 0 ; i < tmp.length ; i+=2) {\n";
-		$geom_str .= "\tgeom.getGeometry(-1,-1).addPointByCoordinates(parseFloat(tmp[i]), parseFloat(tmp[i+1]));\n";
-		$geom_str .= "}\n";
-		$geom_str .= "geom.close();\n";
-        $cnt_geom++;
-	else if(in_array(sepNameSpace($element[tag]),$geometries) && $element[type] == "close"){
-		$geom = false;
-		$memberHasBeenCreated = false;
-	else if($section == true && $geom == false && $element[value]){
-		$el++;
-		$str = $element[value];
-		$element_str .= "geom.get(" . $member . ").e.setElement('".sepNameSpace($element[tag])."', '".addslashes($str)."');\n";
-	else if(mb_strtoupper($element[tag]) == mb_strtoupper("gml:featureMember") && $element[type] == "close"){
-		$section = false;
-		$el = -1;
-if ($geom_str != "") {
-	$geom_str = "var geom = new GeometryArray();\n" . $geom_str;
 header('Content-type: text/html');
-echo $geom_str;
-echo $element_str;
+echo $geoJson;
More information about the Mapbender_commits mailing list
