[Mapbender-commits] r3109 - in branches/noframes: http/javascripts
lib
svn_mapbender at osgeo.org
Fri Oct 3 09:22:45 EDT 2008
Author: christoph
Date: 2008-10-03 09:22:45 -0400 (Fri, 03 Oct 2008)
New Revision: 3109
branches/noframes/http/javascripts/mod_zoomFull.php
branches/noframes/lib/core.js
removed obsolete code
Modified: branches/noframes/http/javascripts/mod_zoomFull.php
--- branches/noframes/http/javascripts/mod_zoomFull.php 2008-10-03 13:17:48 UTC (rev 3108)
+++ branches/noframes/http/javascripts/mod_zoomFull.php 2008-10-03 13:22:45 UTC (rev 3109)
@@ -9,22 +9,10 @@
mod_zoomFull_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
function mod_zoomFull(){
- var ind = this.getMapObjIndexByName("<?php echo $e_target[0]; ?>");
- var arrayThemen = new Array();
- var arrayThemen = mb_mapObj[ind].wms[0].objLayer[0].layer_name;
- this.Layer0 = arrayThemen;
- //alert(mb_mapObj[ind].width + " - " + mb_mapObj[ind].height);
- this.width = mb_mapObj[ind].width;
- this.height = mb_mapObj[ind].height;
- this.epsg = wms[0].gui_wms_epsg;
- //mb_mapObj[ind].epsg = "EPSG:31493";
- //alert(Layer0);
- var arrayExt = new Array();
- var frameName = "<?php echo $e_target[0]; ?>"
- var exts = setExtent(width,height,epsg);
- arrayExt = exts.split(",");
- mb_repaint(frameName,arrayExt[0],arrayExt[1],arrayExt[2],arrayExt[3]);
+ var frameName = "<?php echo $e_target[0]; ?>"
+ var ind = this.getMapObjIndexByName(frameName);
+ mb_mapObj[ind].zoomFull();
function mod_zoomFull_init(obj){
Modified: branches/noframes/lib/core.js
--- branches/noframes/lib/core.js 2008-10-03 13:17:48 UTC (rev 3108)
+++ branches/noframes/lib/core.js 2008-10-03 13:22:45 UTC (rev 3109)
@@ -28,11 +28,6 @@
var eventBeforeMapRequest = new MapbenderEvent();
- * Triggered before the scale is calculated.
-var eventBeforeGetScale = new MapbenderEvent();
* Triggered before a feature info is requested.
var eventBeforeFeatureInfo = new MapbenderEvent();
@@ -128,15 +123,6 @@
* deprecated wrapped function
* @deprecated
-function mb_registerGetScalePreFunctions(stringFunction){
-// mb_GetScalePreFunctions[mb_GetScalePreFunctions.length] = stringFunction;
- eventBeforeGetScale.register(stringFunction);
- * deprecated wrapped function
- * @deprecated
function mb_registerloadWmsSubFunctions(stringFunction){
// mb_loadWmsSubFunctions[mb_loadWmsSubFunctions.length] = stringFunction;
eventAfterLoadWMS.register(stringFunction);
More information about the Mapbender_commits
